[MapServer-users] MS_MAP_PATTERN cannot accept network share
Benedek Petrovicz benedek.petrovicz at gmail.com
Thu Mar 23 13:47:42 PDT 2023
Hi!
I'm running into an issue where I cannot reference the mapfiles from a
network share.
I'm getting the following error: *msCGILoadMap(): Web application error.
CGI variable "map" fails to validate.*
The path to my mapfile is the following: *//MY-NAS/MapFiles/test.map*
It's under a network share.
I know that it should work, because when I set a MAP alias to the same path
in the global config, it just works.
I tried multiple MS_MAP_PATTERN settings, but couldn't get it to accept the
path.
   - *MS_MAP_PATTERN "."*
   - *MS_MAP_PATTERN "^.+$"*
Is there any way to get MapServer accept a network share path?
Unfortunately I cannot use the MAP aliases, because I have to make it work
for multiple dynamic environments.
I'm trying to make it work under MapServer 8.
Thank you!
Benedek
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230323/03853187/attachment.htm>
More information about the MapServer-users mailing list
