[Mobilitydb-users] Query regarding intersection of a temporal point with Z dimension and polygon
Esteban Zimanyi estebanzimanyi at gmail.com
Mon Mar 22 03:08:22 PDT 2021
As a follow up of my previous answer, as you know MobilityDB delegates
spatial processing to PostGIS.
I sketched in the examples below an original MobilityDB query, the
corresponding query sent to PostGIS, and the answer received from PostGIS.
As you can see, real 3D operations without SFCGAL are not possible.
-- Intersection with vertical plane at x = 2
SELECT asText(atGeometry(tgeompoint '[Point(0 0 0)@2000-01-01, Point(3 3
3)@2000-01-04]',
  geometry 'Polygon Z((2 0 0,2 3 0,2 3 3, 2 0 3,2 0 0))'));
=> Corresponding PostGIS query
SELECT ST_asText(ST_Intersection(geometry 'Linestring Z(0 0 0,3 3 3)',
-- LINESTRING EMPTY
-- Intersection with horizontal plane at z = 2
3)@2000-01-04]',
  geometry 'Polygon Z((0 0 2,3 0 2,3 3 2,0 3 2,0 0 2))'));
 LINESTRING Z (0 0 0,3 3 3)
On Sun, Mar 21, 2021 at 7:50 PM Esteban Zimanyi <estebanzimanyi at gmail.com>
wrote:
> Alas, enabling real 3D intersection requires calling the PostGIS function
> ST_3DIntersects which in turn requires the SFCGAL backend.
> This has not yet been tested with MobilityDB but indeed it is a nice
> extension that will be envisioned in the future.
> On Sat, Mar 20, 2021 at 7:24 PM Sharath S Bhargav <
> shrthsbhargav96 at gmail.com> wrote:
>> Hello Esteban,
>> Apologies for late reply.
>> Would this work if the polygon also defined in 3 dimensions? As in if it
>> was a pure 3 dimensional operation.
>> On Tue, Mar 16, 2021 at 4:52 PM Esteban Zimanyi <estebanzimanyi at gmail.com>
>> wrote:
>>> Dear Sharath
>>> I created a small example to see whether it fits your requirements. In
>>> my local working copy of MobilityDB I enabled the operations on mixed 2D
>>> and 3D geometries (currently disallowed in MobilityDB). The example looks
>>> as follows.
>>> select astext(atGeometry(tgeompoint '[Point(0 0 0)@2000-01-01, Point(4 4
>>> 4)@2000-01-05]', geometry 'Polygon((1 1,1 2,2 2,2 1,1 1))'));
>>>                                        astext
>>>  {[POINT Z (1 1 1)@2000-01-02 00:00:00+01, POINT Z (2 2 2)@2000-01-03
>>> 00:00:00+01]}
>>> (1 row)
>>> Does this correspond to your requirements ?
>>> Esteban
>>> On Sat, Mar 13, 2021 at 4:56 AM Sharath S Bhargav <
>>>> Hello Esteban,
>>>> The method st_3DIntersection is required for true 3D intersection.
>>>> While st_intersection does return results with points having 3 dimensions
>>>> by averaging the Z dimension value. But the results returned from
>>>> MobilityDB seem to indicate that is also not supported since I get a tbool
>>>> with only false values. Can I assume that MobilityDB does not support 3
>>>> dimensions in any of the intersection functions even in a 2.5D fashion?
>>>> If the tintersect function could return true by just considering the 2
>>>> dimensions of the trajectory and average out the Z dimension that would
>>>> also work for me. I expected this behaviour since MobilityDB delegates the
>>>> spatial calculations to PostGIS and PostGIS does actually do the same and
>>>> return the intersecting line string as shown in the query example. So
>>>> considering PostGIS response, I was hoping MobilityDB could return a true
>>>> period set. It would be great if you could kindly clarify the behaviour in
>>>> this scenario. Apologies if I seem to be asking trivial questions, I am new
>>>> to the Spatio-Temporal Databases.
>>>> On Sat, Mar 13, 2021 at 3:14 AM Esteban Zimanyi <
>>>> estebanzimanyi at gmail.com> wrote:
>>>>> Dear Sharath
>>>>> As I mentioned before, MobilityDB delegates to PostGIS the calculation
>>>>> of the spatial operations. According to what you described, to implement
>>>>> your scenario you require to use the PostGIS method ST_3DIntersection
>>>>> https://postgis.net/docs/ST_3DIntersection.html
>>>>> It is stated in the above link that this method needs SFCGAL backend.
>>>>> We have never used MobilityDB together with SFCGAL. We could envision
>>>>> starting this exploration in the future, but currently we have many other
>>>>> things in the development pipeline of MobilityDB.
>>>>> If you want to start this exploration, we could provide you guidance
>>>>> in this regard and depending on our availability, we can also extend
>>>>> MobilityDB to make this happen.
>>>>> Esteban
>>>> Regards,
>>>> Sharath
>> Regards,
>> Sharath
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20210322/81c962f8/attachment.html>
More information about the Mobilitydb-users mailing list
