[OpenDroneMap-dev] Problems regarding processing UAV data in OpenDroneMap
Stephen Mather stephen at smathermather.com
Tue Aug 18 17:25:47 PDT 2015
Hi Mayank,
Everything is in local coordinates at this point. Expect an update
sometime this month that will allow for proj4-based coordinates for
output of point cloud and orthophoto.
Cheers!
Best,
Steve
On Wed, Jul 29, 2015 at 8:39 AM, Mayank Sharma <mayanksharma at iirs.gov.in> wrote:
> Hello,
>         I am using OpenDroneMap to process UAV data. The images used are
> geotagged. I want to generate the DEM, ortho images and mosaics using these
> images. I have generated the textured surface after point cloud generation.
> However, I am uable to generate the ortho images and mosaics. Also the
> generated point cloud is also in local coordinate system. I will be highly
> pleased if you provide me the solutions to these problems. Can I also get a
> detailed documentation to process the data in OpenDroneMap.
> Thanking You
> Regards,
> Mayank Sharma
> Junior Research Fellow
> Indian Institute Remote Sensing
> Dehradun
> Contact No. +919760492326
> Email-id: mayanksharma at iirs.gov.in, mayanksharma.iirs at gmail.com
> OpenDroneMap-dev mailing list
> OpenDroneMap-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
More information about the OpenDroneMap-dev mailing list
