[OpenDroneMap-dev] Announcement regarding Precise (12.04) support
Dakota Benjamin dmb2 at clevelandmetroparks.com
Tue Dec 15 13:07:08 PST 2015
Hello fellow devs,
Recent additions and improvements to the OpenDroneMap toolchain have caused some problems in the 12.04 build. We added Ceres Solver to bundler when we added OpenSfM as an alternative to the matching/bundling part of the toolchain, which required some libraries that were unavailable in the precise apt repositories. In the next few days, we will push blending to the texturing module, which requires OpenCV 2.4, also not available as a package in 12.04. OpenDroneMap is built on cutting-edge technology, so continuing to work in an environment that is not supported by those technologies will only hinder effective development. In light of this, we will be ceasing support for 12.04 from here on out. I believe the most recent commit that is completely 12.04 compatible is https://github.com/OpenDroneMap/OpenDroneMap/tree/57b3bfe3e34f77e546be0fd88c38d278a50ad277, which uses the perl control script.
If you would like to discuss these changes, please join in on our new gitter page: https://gitter.im/OpenDroneMap/OpenDroneMap
Thank you,
Dakota Benjamin
[http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
Geospatial Developer
clevelandmetroparks.com<http://www.clemetparks.com/>
<http://www.clemetparks.com/>"It is not down in any map; true places never are."
      Herman Melville
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20151215/37d13455/attachment.html>
More information about the OpenDroneMap-dev mailing list
