[OpenDroneMap-dev] Image Correction
Stephen Mather stephen at smathermather.com
Sat May 9 18:18:57 PDT 2015
Awesome to have you back. Hope you get some good rest in too.
Cheers,
Steve
On May 9, 2015 11:52 AM, "Cole" <colek42 at gmail.com> wrote:
> I just finished a major project at work as well as finals, I will
> definitly have time to work on ODM over the next few weeks.
> v/r
> NJK
> On Sat, May 9, 2015 at 8:44 AM, Stephen Mather <stephen at smathermather.com>
> wrote:
>> Alternatively, integrating a generalized version of Alex' work here:
>> https://github.com/wildintellect/lenscorrection would be welcome.
>> Cheers,
>> Best,
>> Steve
>> On Sat, May 9, 2015 at 8:42 AM, Stephen Mather <stephen at smathermather.com
>> > wrote:
>>> Hi Cole,
>>> Have you had time to do more with this? With Daryl, Alex, and others
>>> proposing a python port, perhaps we could integrate it, and do distortion
>>> correction at the front end of the processing chain for images that require
>>> it by using this class + a user-built calibration library.
>>> Thoughts?
>>> Best,
>>> Steve
>>> On Thu, Mar 19, 2015 at 12:58 PM, Stephen Mather <
>>> stephen at smathermather.com> wrote:
>>>> It seems that the portion of the CMOS used, or effective chips size,
>>>> would be different between video and stills, so calibration would be
>>>> different for video and stills.
>>>> On Thu, Mar 19, 2015 at 11:51 AM, Alex Mandel <
>>>> tech_dev at wildintellect.com> wrote:
>>>>> You don't want a video, you want still images. I can upload some later.
>>>>> The problem with the video is that it's much lower resolution than time
>>>>> lapse shots from the same camera and you end up grabbing frames from it
>>>>> anyways.
>>>>> Measuring the checkerboard loss from really close up shots is exactly
>>>>> how I guessed the new sensor size.
>>>>> Thanks,
>>>>> Alex
>>>>> On 03/19/2015 05:41 AM, Cole wrote:
>>>>> > I was just going to email the list about that.  I would like to make
>>>>> a test
>>>>> > use case for this.  Since the ARDrone is probably not within our
>>>>> normal use
>>>>> > case, and I do not own a GoPro, would somebody be able to take a
>>>>> video of a
>>>>> > checkerboard pattern (
>>>>> http://wiki.ros.org/camera_calibration/Tutorials/StereoCalibration?action=AttachFile&do=get&target=check-108.pdf
>>>>> >  and share it.  Make sure you pan the camera so every part of the
>>>>> sensor is
>>>>> > covered by the pattern in at least one frame.  Orientation, skew,
>>>>> etc does
>>>>> > not matter.  Make sure you get it as some different distances as
>>>>> well.  I
>>>>> > think we can also calculate the CCD width of the cropped image based
>>>>> on the
>>>>> > width of the checkerboard cells.
>>>>> > The next logical progression in this work would be to take video and
>>>>> find
>>>>> > the minimum number of overlapping frames to create a desirable
>>>>> result --
>>>>> > using RANSAC.  So if y'all have some aerial gopro video footage with
>>>>> the
>>>>> > exact same camera, I would appreciate that as well.
>>>>> > As the I have a use case for my application with video inside and
>>>>> outside
>>>>> > of ROS, I will be posting a test case using the ARDrone, which uses a
>>>>> > wide-angle camera.
>>>>> > v/r
>>>>> > NJK
>>>>> > On Wed, Mar 18, 2015 at 11:33 PM, Stephen Mather <
>>>>> > wrote:
>>>>> >> Very interesting, I'll check it out. I'm thinking through the
>>>>> implications
>>>>> >> of no cropping, and while this won't affect matching, it likely
>>>>> will cause
>>>>> >> issues at the texturing stage, so a default cropping with optional
>>>>> no-crop
>>>>> >> would be useful. I assume a crop will affect the effective CCD
>>>>> width, so
>>>>> >> that will need calculated.
>>>>> >> Is there any sharable wide-angle data for testing this?
>>>>> >> Thanks,
>>>>> >> Best,
>>>>> >> Steve
>>>>> >> On Tue, Mar 17, 2015 at 4:09 AM, Cole <colek42 at gmail.com> wrote:
>>>>> >>> I have a image calibration class up at
>>>>> https://github.com/colek42/TrackIt/blob/master/catkin/src/stabilize/src/calibrate.py
>>>>> >>> It is working great.  I'll add a main function and comments in the
>>>>> next
>>>>> >>> day or so and do a pull request.  I am using an ARDrone camera,
>>>>> but this is
>>>>> >>> agnostic to the type of camera.  There is no cropping done, so the
>>>>> edges
>>>>> >>> are curved with a black background.  If it needs to be cropped let
>>>>> me know
>>>>> >>> and I'll add an arg for that.  The interface also needs a bit of
>>>>> work.
>>>>> >>> I was expecting the result to be symmetric, they are not.
>>>>> >>> v/r
>>>>> >>> NJK
>>>>> >>> _______________________________________________
>>>>> >>> OpenDroneMap-dev mailing list
>>>>> >>> OpenDroneMap-dev at lists.osgeo.org
>>>>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20150509/ea3b3b70/attachment.html>
More information about the OpenDroneMap-dev mailing list
