[OpenDroneMap-users] uninstall open drone map
Alex Mandel tech_dev at wildintellect.com
Fri Jul 31 08:52:25 PDT 2015
On 07/30/2015 10:49 AM, Chris wrote:
> Thanks Dakota!
> I got this error...
> .../OpenDroneMap-gh-pages$ git pull origin gh-pages
> From https://github.com/OpenDroneMap/OpenDroneMap
>  * branch            gh-pages   -> FETCH_HEAD
> error: Untracked working tree file '.gitignore' would be overwritten by
> merge.
That just means you made a file called .gitignore locally that will be
overwritten by the repo version.
> I ran the install.sh anyhow that went a bit quickly i thought
> I tried sample data but it errors out finding keypoints...
> - finding keypoints - Thu Jul 30 13:41:37 EDT 2015
> sh: 1: .../OpenDroneMap-gh-pages/bin/parallel: not found
Exactly what it sounds like, you need install the program called
Parallel. Install.sh should have done that, go back and check that it
actually did, and there weren't any warnings or errors. Sometimes you
might need to download the right tar manually before running install
Line 169 parallel.tar.bz2
http://ftp.gnu.org/gnu/parallel/parallel-20141022.tar.bz2
-Alex
> quitting cause:
>     ".../OpenDroneMap-gh-pages/bin/parallel" --halt-on-error 1 -j+0 <
> ".../odm_data_benchmark-master/reconstruction-with-image-size-2400/_vlsift.templist.txt"
> returned with code 32512
> any ideas?
> Thanks
> --Chris
> On 07/30/2015 09:17 AM, Dakota Benjamin wrote:
>> In the base directory (i.e. where run.pl is), run "git pull origin
>> gh-pages" in the command line then run install.sh again.
>> git pull will pull all the latest changes that have been made to the
>> gh-pages branch (the main branch) of the repo to your local machine.
>> Dakota Benjamin
>> GIS Intern
>> http://www.clevelandmetroparks.com/
>> ________________________________________
>> From: opendronemap-users-bounces at lists.osgeo.org
>> <opendronemap-users-bounces at lists.osgeo.org> on behalf of Chris
>> <housec01 at gmail.com>
>> Sent: Wednesday, July 29, 2015 10:04 PM
>> To: opendronemap-users at lists.osgeo.org
>> Subject: [OpenDroneMap-users] uninstall open drone map
>> Hi All,
>> I am new to github but i manage to fumble my way through.  I am not
>> familiar with how to update ODM however.  I did not see any uninstall.sh
>> or read it in the readme or the log.  So with that in mind is there a
>> proper way to uninstall and update or to update ODM?  Thanks for any help
>> Chris
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
