[OpenDroneMap-users] Issues processing the copr data image set
Frederic Muller fred at cm17.com
Fri Mar 13 10:28:10 PDT 2015
Hi again,
So I renamed all the images and put them in small letters. And now while
I went further away in the process I still have another issue:
quitting cause:
	"/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef" -bundleFile /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt -imagesPath /home/fred/Documents/images/odm_data/copr/ -imagesListPath /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt -bundleResizedTo 2400 -inputFile /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj -outputFile /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj -logFile /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
returned with code 256
Any idea what this could be?
Thank you.
Fred
On 03/12/2015 10:58 PM, Alex Mandel wrote:
> It's not the data set. Most of us have been hitting this bug with the
> case of JPG not working and needing them to be jpg.
> https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> I'll check that data set and update the names if they are still in caps
> in git.
> Thanks,
> Alex
> On 03/11/2015 12:11 AM, Frederic Muller wrote:
>> Hi!
>> Just installed ODM and trying to have it run first. I'm using the images
>> GitHub of the project and specifically ran on COPR images.
>> Unfortunately it has failed twice with the same error message which is
>> "Error in OdmTexturing:
>> Failed to read image:
>> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
>> I looked at the image and it opens fine, but maybe the problem comes
>> because of the double /?
>> Or is copr data set not ready?
>> Thank you.
>> Fred
More information about the OpenDroneMap-users mailing list
