[OpenDroneMap-users] Issues processing the copr data image set
Ivan Lizarazo ivan.lizarazo at gmail.com
Fri Mar 13 11:24:41 PDT 2015
Hi Fred
Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
I've just checked it at https://github.com/OpenDroneMap/odm_data_copr and
found it. Please, review it.
Ivan
On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com> wrote:
> Hi!
> Sorry for missing that out. Here is what it says:
> Error in Georef:
> Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> for reading.
> And checking into that folder the file doesn't seem to be there. Not
> sure what else to add.
> Fred
> On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
> > Hi Fred
> > To get a clue, please review  the last few lines of  your
> >  odm_georeferencing_log.txt and let us know what it says.
> > Regards,
> > Ivan
> > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com
> > <mailto:fred at cm17.com>> wrote:
> >     Hi again,
> >     So I renamed all the images and put them in small letters. And now
> while
> >     I went further away in the process I still have another issue:
> >     quitting cause:
>  "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
> >     -bundleFile
>  /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> >     -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> >     -imagesPath /home/fred/Documents/images/odm_data/copr/
> >     -imagesListPath
>  /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> >     -bundleResizedTo 2400 -inputFile
>  /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> >     -outputFile
>  /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> >     -logFile
>  /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> >     returned with code 256
> >     Any idea what this could be?
> >     Thank you.
> >     Fred
> >     On 03/12/2015 10:58 PM, Alex Mandel wrote:
> >     > It's not the data set. Most of us have been hitting this bug with
> the
> >     > case of JPG not working and needing them to be jpg.
> >     > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> >     > I'll check that data set and update the names if they are still in
> >     caps
> >     > in git.
> >     > Thanks,
> >     > Alex
> >     > On 03/11/2015 12:11 AM, Frederic Muller wrote:
> >     >> Hi!
> >     >> Just installed ODM and trying to have it run first. I'm using the
> >     images
> >     >> GitHub of the project and specifically ran on COPR images.
> >     >> Unfortunately it has failed twice with the same error message
> >     which is
> >     >> "Error in OdmTexturing:
> >     >> Failed to read image:
> >     >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
> >     >> I looked at the image and it opens fine, but maybe the problem
> comes
> >     >> because of the double /?
> >     >> Or is copr data set not ready?
> >     >> Thank you.
> >     >> Fred
> >     _______________________________________________
> >     OpenDroneMap-users mailing list
> >     OpenDroneMap-users at lists.osgeo.org
> >     <mailto:OpenDroneMap-users at lists.osgeo.org>
> >     http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150313/6a30062a/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
