[OpenDroneMap-users] Issues processing the copr data image set
Stephen Mather stephen at smathermather.com
Fri Mar 13 23:09:08 PDT 2015
Try this branch from martinjuju. I haven't tested yet, but it looks
promising.
https://github.com/OpenDroneMap/OpenDroneMap/pull/78
Worse case scenario, rerun with the main branch work the following flag:
--start-with pmvs
And you will save a lot of time.
Cheers,
Best,
Steve
On Mar 13, 2015 10:11 PM, "Frederic Muller" <fred at cm17.com> wrote:
> Since we're on the topic, is there a way to resume the processing from
> the point it failed? Or do we necessarily need to start from scratch?
> Thank you.
> Fred
> On 03/14/2015 01:24 AM, Ivan Lizarazo wrote:
> > Hi Fred
> > Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
> > I've just checked it at https://github.com/OpenDroneMap/odm_data_copr
> > and found it. Please, review it.
> > Ivan
> > On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com
> > <mailto:fred at cm17.com>> wrote:
> >     Hi!
> >     Sorry for missing that out. Here is what it says:
> >     Error in Georef:
> >     Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> >     for reading.
> >     And checking into that folder the file doesn't seem to be there. Not
> >     sure what else to add.
> >     Fred
> >     On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
> >     > Hi Fred
> >     > To get a clue, please review  the last few lines of  your
> >     >  odm_georeferencing_log.txt and let us know what it says.
> >     > Regards,
> >     > Ivan
> >     > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com
> >     > <mailto:fred at cm17.com <mailto:fred at cm17.com>>> wrote:
> >     >     Hi again,
> >     >     So I renamed all the images and put them in small letters. And
> >     now while
> >     >     I went further away in the process I still have another issue:
> >     >     quitting cause:
> "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
> >     >     -bundleFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> >     >     -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> >     >     -imagesPath /home/fred/Documents/images/odm_data/copr/
> >     >     -imagesListPath
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> >     >     -bundleResizedTo 2400 -inputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> >     >     -outputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> >     >     -logFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> >     >     returned with code 256
> >     >     Any idea what this could be?
> >     >     Thank you.
> >     >     Fred
> >     >     On 03/12/2015 10:58 PM, Alex Mandel wrote:
> >     >     > It's not the data set. Most of us have been hitting this bug
> >     with the
> >     >     > case of JPG not working and needing them to be jpg.
> >     >     > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> >     >     > I'll check that data set and update the names if they are
> >     still in
> >     >     caps
> >     >     > in git.
> >     >     > Thanks,
> >     >     > Alex
> >     >     > On 03/11/2015 12:11 AM, Frederic Muller wrote:
> >     >     >> Hi!
> >     >     >> Just installed ODM and trying to have it run first. I'm
> >     using the
> >     >     images
> >     >     >> GitHub of the project and specifically ran on COPR images.
> >     >     >> Unfortunately it has failed twice with the same error
> message
> >     >     which is
> >     >     >> "Error in OdmTexturing:
> >     >     >> Failed to read image:
> >     >     >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
> >     >     >> I looked at the image and it opens fine, but maybe the
> >     problem comes
> >     >     >> because of the double /?
> >     >     >> Or is copr data set not ready?
> >     >     >> Thank you.
> >     >     >> Fred
> >     >     _______________________________________________
> >     >     OpenDroneMap-users mailing list
> >     >     OpenDroneMap-users at lists.osgeo.org
> >     <mailto:OpenDroneMap-users at lists.osgeo.org>
> >     <mailto:OpenDroneMap-users at lists.osgeo.org>>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150314/8164a3c5/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
