[OpenDroneMap-users] New Error After Install
Todd Pals tpalshadow at gmail.com
Fri Mar 20 17:10:47 PDT 2015
Install finished now.  When I run on the odm_data_copr I get the following:
 - finding keypoints - Fri Mar 20 18:55:33 CDT 2015
When using programs that use GNU Parallel to process data for publication
please cite:
  O. Tange (2011): GNU Parallel - The Command-Line Power Tool,
  ;login: The USENIX Magazine, February 2011:42-47.
This helps funding further development; and it won't cost you a cent.
Or you can get GNU Parallel without this requirement by paying 10000 EUR.
To silence this citation notice run 'parallel --bibtex' once or use
'--no-notice'.
1/41 - Killed
parallel: Starting no more jobs. Waiting for 1 jobs to finish. This job
failed:
echo -n "1/41 - " && convert -format pgm
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.jpg"
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.pgm"
&& "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/vlsift"
-o
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.key.sift"
> /dev/null && perl
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/../
convert_vlsift_to_lowesift.pl"
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022"
&& gzip -f
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.key"
&& rm -f
&& rm -f
quitting cause:
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/parallel"
--halt-on-error 1 -j+0 <
"/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/_vlsift.templist.txt"
returned with code 35072
root at todd-VirtualBox:/home/todd/Documents/OpenDroneMap/test/odm_data_copr#
Thanks everyone!
Todd Pals
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150321/bb5c0505/attachment.html>
More information about the OpenDroneMap-users mailing list
