[OpenDroneMap-users] New Error After Install
Todd Pals tpalshadow at gmail.com
Fri Mar 20 18:38:56 PDT 2015
So it ran longer this time but still failed out:
  - finding keypoints - Fri Mar 20 19:16:34 CDT 2015
When using programs that use GNU Parallel to process data for publication
please cite:
  O. Tange (2011): GNU Parallel - The Command-Line Power Tool,
  ;login: The USENIX Magazine, February 2011:42-47.
This helps funding further development; and it won't cost you a cent.
Or you can get GNU Parallel without this requirement by paying 10000 EUR.
To silence this citation notice run 'parallel --bibtex' once or use
'--no-notice'.
1/41 - 950982/41 - 1112943/41 - 1114754/41 - 1037485/41 - 1077416/41 -
1002237/41 - 938488/41 - 1250809/41 - 11591110/41 - 12721611/41 -
12583112/41 - 12503613/41 - Killed
parallel: Starting no more jobs. Waiting for 1 jobs to finish. This job
failed:
echo -n "13/41 - " && convert -format pgm
"/home/todd/Documents/test/reconstruction-with-image-size-2400/IMG_0061.jpg"
"/home/todd/Documents/test/reconstruction-with-image-size-2400/IMG_0061.pgm"
&& "/home/todd/Documents/test/../OpenDroneMap/bin/vlsift"
-o
"/home/todd/Documents/test/reconstruction-with-image-size-2400/IMG_0061.key.sift"
> /dev/null && perl "/home/todd/Documents/test/../OpenDroneMap/bin/../
convert_vlsift_to_lowesift.pl"
"/home/todd/Documents/test/reconstruction-with-image-size-2400/IMG_0061" &&
gzip -f
"/home/todd/Documents/test/reconstruction-with-image-size-2400/IMG_0061.key"
&& rm -f
&& rm -f
quitting cause:
"/home/todd/Documents/test/../OpenDroneMap/bin/parallel" --halt-on-error 1
-j+0 <
"/home/todd/Documents/test/reconstruction-with-image-size-2400/_vlsift.templist.txt"
returned with code 35072
root at todd-VirtualBox:/home/todd/Documents/test#
On Fri, 20 Mar 2015 at 19:21 Todd Pals <tpalshadow at gmail.com> wrote:
> I'm sorry to waste everyone's time, I rebooted the machine, moved the
> directory around and it appears to be running now.
> On Fri, 20 Mar 2015 at 19:10 Todd Pals <tpalshadow at gmail.com> wrote:
>> Install finished now.  When I run on the odm_data_copr I get the
>> following:
>>  - finding keypoints - Fri Mar 20 18:55:33 CDT 2015
>> please cite:
>> '--no-notice'.
>> 1/41 - Killed
>> failed:
>> echo -n "1/41 - " && convert -format pgm "/home/todd/Documents/OpenDron
>> eMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.jpg"
>> "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/
>> reconstruction-with-image-size-2400/IMG_0022.pgm" &&
>> "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/vlsift"
>> reconstruction-with-image-size-2400/IMG_0022.pgm" -o
>> reconstruction-with-image-size-2400/IMG_0022.key.sift" > /dev/null &&
>> perl "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/../
>> convert_vlsift_to_lowesift.pl" "/home/todd/Documents/OpenDron
>> eMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022" &&
>> gzip -f "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/
>> reconstruction-with-image-size-2400/IMG_0022.key" && rm -f
>> reconstruction-with-image-size-2400/IMG_0022.pgm" && rm -f
>> quitting cause:
>> "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/parallel"
>> --halt-on-error 1 -j+0 < "/home/todd/Documents/OpenDron
>> eMap/test/odm_data_copr/reconstruction-with-image-size-2400/_vlsift.
>> templist.txt"
>> root at todd-VirtualBox:/home/todd/Documents/OpenDroneMap/test/
>> odm_data_copr#
>> Thanks everyone!
>> Todd Pals
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150321/47ab277c/attachment.html>
More information about the OpenDroneMap-users mailing list
