[OpenDroneMap-users] installation problem
Stephen Mather stephen at smathermather.com
Tue Mar 24 18:11:39 PDT 2015
Hi Justin,
So happy you got through the install process.
Regarding the output, there should be an un-referenced but orthorectified
PNG in the output directory if you had ground control inputs or GPS
ephemeris in the input image set.
Cheers,
Best,
Steve
On Mon, Mar 23, 2015 at 11:59 PM, Aquila Imaging <aquilaimaging at gmail.com>
wrote:
> Stephen,
> Everything is working quite well now., thank you for the clarification.
> Where is the orthophoto stored after the target data has been processed? In
> the results folder that is generated after the script finishes I see the
> point cloud files (loaded in meshlab fine) and 10 or so JPG files with odd
> mismatched pictures showing sections of the total map, but I do not see any
> files with a complete map. It feels like I am missing something simple. Can
> you point me in the right direction?
> Regards
> Justin
> On Mon, Mar 23, 2015 at 11:20 AM, Stephen Mather <
> stephen at smathermather.com> wrote:
>> No worries. I think that's a common mistake, so it may be time to make
>> that explicit in the docs.
>> On Mar 23, 2015 1:49 PM, "Aquila Imaging" <aquilaimaging at gmail.com>
>> wrote:
>>> Stephen,
>>> That was it. Install looks to be functioning correctly now. Sorry for
>>> the newb mistake! Linux is new to me. This is such an exciting project.
>>> Please let me know if there is anything I can do to support its
>>> progression.
>>> Regards,
>>> justin
>>> On Monday, March 23, 2015, Stephen Mather <stephen at smathermather.com>
>>> wrote:
>>> > Hi Justin,
>>> > Are you running install as root?
>>> > Thanks,
>>> > Best,
>>> > Steve
>>> > On Sun, Mar 22, 2015 at 11:07 AM, Aquila Imaging <
>>> aquilaimaging at gmail.com> wrote:
>>> >> Hello all!
>>> >> I am having the same problem as Todd here (details below). I am
>>> hoping someone can point me in the right direction. I sent an email with my
>>> logs to Daniel. They are also included in this email. Thank you for your
>>> help!
>>> >> When I run the update I get this:
>>> >> ________________________________
>>> >> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo ./install.sh
>>> >> created by Daniel Schwarz/daniel.schwarz at topoi.org
>>> >> released under Creative Commons/CC-BY
>>> >> Attribution
>>> >> if the script doesn't finish properly
>>> >> (i.e. it doesn't print "script finished" at the end)
>>> >> please email me the content of the logs folder
>>> >> script started - Wed Mar 18 16:18:44 CDT 2015
>>> >> installing required packages
>>> >> - updating
>>> >> And nothing seems to happen. If I try and run a set of the sample
>>> images or the set that Dennis Baldwin has in his videos I get this:
>>> >> sh: 1: jhead: not found
>>> >> no CCD width or focal length found for img_4851.jpg - camera: " "sh:
>>> 1: jhead: not found
>>> >> Regards,
>>> >> Justin
>>> >> _______________________________________________
>>> >> OpenDroneMap-users mailing list
>>> >> OpenDroneMap-users at lists.osgeo.org
>>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150324/e4805239/attachment.html>
More information about the OpenDroneMap-users mailing list
