[OpenDroneMap-users] step by step using sensefly swinglet
Dennis Baldwin db at unmannedairlines.com
Thu Mar 26 07:17:48 PDT 2015
Chris,
Check out the runtime parameters here:
https://github.com/OpenDroneMap/OpenDroneMap/wiki/Run-Time--Parameters
If you scroll down you'll see a reference to --odm_georeferencing-useGcp
which defaults to "true". You can see it here in the run script as well:
https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L107
Looking at this line of code you'll see that when you set the value to
"false" this line gets executed:
https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L781
That should extract the GPS info from your images and place them
in odm_georeferencing/coordFile.txt. So my suggestion would be to run your
project again like this:
../OpenDroneMap/run.pl --odm_georeferencing-useGcp "false"
That will start everything from the beginning. A better way may be to do
this which should start you from the georeferencing step:
../OpenDroneMap/run.pl --start-with "odm_georeferencing"
Good luck and let us know how you get along.
Dennis
On Wed, Mar 25, 2015 at 3:00 PM, Chris <housec01 at gmail.com> wrote:
> Hi All,
> On Smathermather's Weblog there is an example shown of a mesh output and
> orthophoto using the sensefly swinglet cam to collect the imagery.  Does
> anyone have the step by step to get the orthophoto? I was able to return a
> textured mesh but it eventually errored out with "error 256"  That is
> related to the gcp file but i was under the impression if xy data was in
> the header file it would use that. Any help/direction would be
> appreciated!  My imagery was collected using swinglet cam as well.
> Thanks and awesome product!!
> Chris
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150326/8af7212b/attachment.html>
More information about the OpenDroneMap-users mailing list
