[OpenDroneMap-users] odm_data_pacifica No valid GPS position found
Alex Mandel tech_dev at wildintellect.com
Fri Mar 27 21:41:42 PDT 2015
Pacifica doesn't have georef information. Run with the georef flag set
to false to avoid the error. However note that the georef step is
actually last. So you already have the obj results you can open in
meshlab, and there is no need to rerun.
Thanks,
Alex
On 03/27/2015 03:49 PM, Ivan Ma wrote:
> I cloned the odm_data_pacifica image set and tried to run a simple test on
> the dataset. Unfortunately, it exited with this error while running
> georeferencing:
>   - running georeferencing - Fri Mar 27 12:30:53 EDT 2015
> Error in OdmExtractUtm:
> For more detailed information, see log file.
> quitting cause:
> "/home/ivanma/Documents/mdp/odm_data_pacifica/../OpenDroneMap/bin/odm_georef"
> -bundleFile
> /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> -coordFile
> /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/coordFile.txt
> -inputFile
> /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> -outputFile
> /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> -logFile
> /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> returned with code 256
> I have attached the error log as well.
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
