[OpenDroneMap-users] Error using OpenDroneMap
Stephen Mather stephen at smathermather.com
Thu May 14 18:45:20 PDT 2015
Hi Willem,
It seems you aren't getting a point cloud from the PMVS step, so when it
goes to mesh, it has nothing to mesh. What is in your
reconstruction-with-image-size-2400 folder? Also, what kind of camera are
the images from?
Thanks,
Best,
Steve
On Tue, May 12, 2015 at 3:49 PM, Willem Buitendyk <willem at pcfish.ca> wrote:
> I should note that this was originally on ubuntu running on parallels.
> This time I tried it on a dedicated server running ubuntu 14.04 and
> received the same error.  There appears to be something wrong with the
> toolchain.
> My process was:
> git clone https://github.com/OpenDroneMap/OpenDroneMap.git
> install.sh
> ~/OpenDroneMap/./run.pl from within my folder located at ~/house_survey
> Willem Buitendyk
> On May 12, 2015, at 11:05 AM, Willem Buitendyk <willem at pcfish.ca> wrote:
> Hi there,
> Ubuntu 14.04.   I’ve installed the latest opendronemap.  When I use the
> run.pl command everything seems to work up until I receive the following
> error:
>  - running meshing - Tue May 12 10:53:27 PDT 2015
> [pcl::KdTreeFLANN::setInputCloud] Cannot create a KDTree with an empty
> input cloud!
> [WARNING] Initial residual too low: 0 < 0.000001
> [pcl::io::savePLYFile] Input point cloud has no data!
> Error in OdmMeshing:
> Error when saving mesh to file:
> /home/willem/house_survey/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
> For more detailed information, see log file.
> quitting cause:
> "/home/willem/OpenDroneMap/bin/odm_meshing" -inputFile
> /home/willem/house_survey/reconstruction-with-image-size-2400-results/option-0000.ply
> -outputFile
> -logFile
> /home/willem/house_survey/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt
> -maxVertexCount 100000 -octreeDepth 9 -samplesPerNode 1
> returned with code 256
> willem at ubuntu:~/house_survey$
> Willem Buitendyk
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150514/e9e19ccc/attachment.html>
More information about the OpenDroneMap-users mailing list
