[OpenDroneMap-users] [OpenDroneMap-dev] library error in OdmTexturing
Dakota Benjamin dmb2 at clevelandmetroparks.com
Fri Oct 2 05:34:54 PDT 2015
Some things that have worked for me in the short run has been to use --resize-to 1200. I'm not sure why right now, but this tends to lead to more successful runs.
Could you attach your point cloud and the odm_meshing_log found in /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt ?
Dakota Benjamin
Cleveland Metroparks
Planning and Design
http://www.clevelandmetroparks.com/<http://www.clemetparks.com/>
From: Giuseppe Amatulli <giuseppe.amatulli at gmail.com>
Sent: Thursday, October 1, 2015 4:51 PM
To: Dakota Benjamin
Cc: opendronemap-users at lists.osgeo.org; Stefano Casalegno
Subject: Re: [OpenDroneMap-dev] library error in OdmTexturing
Hi Benjamin,
I rerun the computation with the last  python-port<https://github.com/OpenDroneMap/OpenDroneMap/tree/python-port> version, using run.py --use-opensfm True .
I got the following error.
  - running meshing - Wed Sep 30 12:19:59  2015
running "/home/ubuntu/drone/OpenDroneMap/bin/odm_meshing" -inputFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/option-0000.ply -outputFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -logFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt -maxVertexCount 100000 -octreeDepth 9 -samplesPerNode 1 -solverDivide 9
b
quitting cause:
returned with code 256.
Probably is something with my pictures  (268 JPG) due that with odm_data_seneca works fine.
Do you think that is possible to track/solve the error?
Thanks
Best Giuseppe
On 16 September 2015 at 08:17, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
I'm not sure what the problem is as I have been unable to reproduce it. I just merged a big update that uses OpenSFM in place of bundler. Try running run.py with the following: '--use-opensfm True'.
Dakota Benjamin
Planning, Design, and Natural Resources
From: Giuseppe Amatulli <giuseppe.amatulli at gmail.com<mailto:giuseppe.amatulli at gmail.com>>
Sent: Tuesday, September 15, 2015 10:00 PM
To: Dakota Benjamin
Cc: opendronemap-users at lists.osgeo.org<mailto:opendronemap-users at lists.osgeo.org>; Stefano Casalegno
Thanks Benjamin,
yes i was able to install python-port but when i run run.py i got the below error.
Is the error related to a dataset or to an installation issues?
Please consider that, I have a dataset of 268 photos got with a "SONY ILCE-QX1": 23.2 ( I got value from the following page http://www.dpreview.com/products/sony/slrs/sony_ilceqx1 ).
Thanks
Best
Giuseppe
--constrain_focal_weight 0.0
--estimate_distortion
--run_bundle" > "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt"
b
running "/home/ubuntu/drone/OpenDroneMap/bin/bundler" "/home/ubuntu/drone/dati/103MSDCSegmentation fault (core dumped)
F/reconstruction-with-image-size-2400/list.txt" --options_file "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt" > bundle/out
b
quitting cause:
    "/home/ubuntu/drone/OpenDroneMap/bin/bundler" "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/list.txt" --options_file "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt" > bundle/out
returned with code 35584.
On 15 September 2015 at 09:25, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
Try switching to the python-port branch. We are beginning to shift over to using run.py instead of run.pl<http://run.pl>, which now has more functionality and is seeing rapid improvements.
Dakota Benjamin
From: opendronemap-dev-bounces at lists.osgeo.org<mailto:opendronemap-dev-bounces at lists.osgeo.org> <opendronemap-dev-bounces at lists.osgeo.org<mailto:opendronemap-dev-bounces at lists.osgeo.org>> on behalf of Giuseppe Amatulli <giuseppe.amatulli at gmail.com<mailto:giuseppe.amatulli at gmail.com>>
Sent: Tuesday, September 15, 2015 9:14 AM
To: opendronemap-dev at lists.osgeo.org<mailto:opendronemap-dev at lists.osgeo.org>; opendronemap-users at lists.osgeo.org<mailto:opendronemap-users at lists.osgeo.org>
Cc: Stefano Casalegno
Subject: [OpenDroneMap-dev] library error in OdmTexturing
Hi
I'm preparing some material for a Drone-Course at Yale and I'm encountering sum problems in using OpenDroneMap.
In particular:
I run run.pl<http://run.pl> but I get the below error due to libdc1394 dependency (see log file below).
I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
I try to manually install
sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg libdc1394-22-dev libdc1394-22-doc libdc1394-utils
and re-install the sw but the error persist.
Any solution?
Thanks
Best
Giuseppe
############### error #######
  - running texturing - Tue Sep 15 12:37:55 UTC 2015
libdc1394 error: Failed to initialize libdc1394
Error in OdmTexturing:
Failed to read image:
'/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
For more detailed information, see log file.
quitting cause:
    "/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing" -bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
age-size-2400/pmvs/bundle.rd.out -imagesPath /home/ubuntu/drone/dati/103MSDCF/ -imagesListPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-
2400/pmvs/list.rd.txt -inputModelPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -outputFolder /home/ubuntu
/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/ -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600 -logFile /h
ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net<http://spatial-ecology.net>
Work:  http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
P.O. Box 208106
165 PROSPECT ST
P.O. Box 208106
165 PROSPECT ST
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20151002/349f677b/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
