[OpenDroneMap-users] ODM quits with keyerror
Ted Fines ted at apecity.com
Tue Apr 5 05:26:32 PDT 2016
Ha!  I had just opened ccd_defs.json to see if the 550 was defined, saw
that it wasn't, and was about to Google it when your message came in.  I
added the line
"DJI FC550": 17.3,
to ccd_defs.json, and now it is processing away.
Thank you!
Ted
On Tue, Apr 5, 2016 at 7:18 AM, Dakota Benjamin <
dmb2 at clevelandmetroparks.com> wrote:
> Try adding "--force-ccd 17.3"
> I got that number from the sensor width here:
> http://www.dji.com/products/compare-xcamera
> <http://www.dji.com/products/compare-xcamera>
> Zenmuse X Series Cameras Comparison | DJI
> www.dji.com
> Compare the Zenmuse X series cameras and learn about the differences
> between DJI's Zenmuse X3, Zenmuse X5, and Zenmuse X5R.
> [image: http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
> Geospatial Developer
> clevelandmetroparks.com <http://www.clemetparks.com/>
> *From:* OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org>
> on behalf of Ted Fines <ted at apecity.com>
> *Sent:* Monday, April 4, 2016 7:07 PM
> *To:* opendronemap-users at lists.osgeo.org
> *Subject:* [OpenDroneMap-users] ODM quits with keyerror
> Environment: ODM installed today (3/4/2016) on Ubuntu 14.04 w/ 4 GB of
> RAM.  I've successfully had it process the caliterra sample image set.
> I am getting an error when directing it to my own image set.  The output
> when I try to run run.py is below (there are no log files produced).  Any
> help?
> Thanks in advance,
> Ted
> ubuntu at odm:~/Test_images$ ~/OpenDroneMap/run.py
>   - configuration:
>      start_with : resize
>      end_with : odm_orthophoto
>      force_focal : None
>      odm_texturing_textureWithSize : 3600
>      matcher_neighbors : 8
>      matcher_threshold : 2.0
>      cmvs_maxImages : 500
>      odm_orthophoto_resolution : 20.0
>      pmvs_threshold : 0.7
>      zip_results : False
>      resize_to : 2400
>      use_opensfm : True
>      min_num_features : 6000
>      odm_meshing_octreeDepth : 9
>      odm_meshing_solverDivide : 9
>      pmvs_wsize : 7
>      odm_texturing_textureResolution : 4096
>      matcher_ratio : 0.6
>      odm_meshing_samplesPerNode : 1.0
>      odm_meshing_maxVertexCount : 100000
>      matcher_distance : 0
>      pmvs_level : 1
>      run_only : None
>      job_dir_name : None
>      odm_georeferencing_useGcp : False
>      odm_georeferencing_gcpFile : gcp_list.txt
>      pmvs_csize : 2
>      pmvs_minImageNum : 3
>      force_ccd : None
>   - source files - Mon Apr 04 17:56:05  2016
> Traceback (most recent call last):
>   File "/home/ubuntu/OpenDroneMap/run.py", line 986, in <module>
>     prepare_objects()
>   File "/home/ubuntu/OpenDroneMap/run.py", line 415, in prepare_objects
>     fileObject["ccd"] = float(ccdWidths[fileObject["id"]])
> KeyError: u'DJI FC550'
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160405/e028475b/attachment.html>
More information about the OpenDroneMap-users mailing list
