[OpenLayers-Commits] r10976 - in trunk/openlayers: examples lib/OpenLayers/Renderer tests/Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Dec 29 07:06:47 EST 2010
Author: ahocevar
Date: 2010-12-29 04:06:46 -0800 (Wed, 29 Dec 2010)
New Revision: 10976
   trunk/openlayers/examples/graphic-name.html
   trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
   trunk/openlayers/tests/Renderer/SVG.html
Always copy graphicName symbols, because there were too many issues with use/defs. Ctrl-Click and Shift-Click now works as expected on graphicName symbols. p=marcjansen, r=me (closes #2985)
Modified: trunk/openlayers/examples/graphic-name.html
--- trunk/openlayers/examples/graphic-name.html	2010-12-17 23:46:22 UTC (rev 10975)
+++ trunk/openlayers/examples/graphic-name.html	2010-12-29 12:06:46 UTC (rev 10976)
@@ -1,91 +1,39 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
-  <head>
-    <title>OpenLayers Graphic Names</title>
-    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-    <link rel="stylesheet" href="style.css" type="text/css" />
-    <script src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        // user custom graphicname
-        OpenLayers.Renderer.symbol.lightning = [0,0, 4,2, 6,0, 10,5, 6,3, 4,5, 0,0];
-        OpenLayers.Renderer.symbol.rectangle = [0,0, 4,0, 4,10, 0,10, 0,0];
-        var map;
-        function init() {
-            map = new OpenLayers.Map('map');
-            // list of well-known graphic names
-            var graphics = ["star", "cross", "x", "square", "triangle", "circle", "lightning", "rectangle"];
-            // Create one feature for each well known graphic.
-            // Give features a type attribute with the graphic name.
-            var num = graphics.length;
-            var slot = map.maxExtent.getWidth() / num;
-            var features = Array(num);
-            for(var i=0; i<graphics.length; ++i) {
-                lon = map.maxExtent.left + (i * slot) + (slot / 2);
-                features[i] = new OpenLayers.Feature.Vector(
-                    new OpenLayers.Geometry.Point(
-                        map.maxExtent.left + (i * slot) + (slot / 2), 0
-                        type: graphics[i]
-            // Create a style map for painting the features.
-            // The graphicName property of the symbolizer is evaluated using
-            // the type attribute on each feature (set above).
-            var styles = new OpenLayers.StyleMap({
-                "default": {
-                    graphicName: "${type}",
-                    pointRadius: 10,
-                    strokeColor: "fuchsia",
-                    strokeWidth: 2,
-                    fillColor: "lime",
-                    fillOpacity: 0.6
-                "select": {
-                    pointRadius: 20,
-                    fillOpacity: 1,
-                    rotation: 45
-            // Create a vector layer and give it your style map.
-            var layer = new OpenLayers.Layer.Vector(
-                "Graphics", {styleMap: styles, isBaseLayer: true}
-            layer.addFeatures(features);
-            map.addLayer(layer);
-            // Create a select feature control and add it to the map.
-            var select = new OpenLayers.Control.SelectFeature(layer, {hover: true});
-            map.addControl(select);
-            select.activate();
-            map.setCenter(new OpenLayers.LonLat(0, 0), 0);
-    </script>
-  </head>
-  <body onload="init()">
-    <h1 id="title">Named Graphics Example</h1>
-    <div id="tags">
-        vector, named graphic, star, cross, x, square, triangle, circle, style
-    </div>
-    <p id="shortdesc">
-        Shows how to use well-known graphic names.
-    </p>
-    <div id="map" class="smallmap"></div>
-    <div id="docs">
-        OpenLayers supports well-known names for a few graphics.  You can use
-        the names "star", "cross", "x", "square", "triangle", and "circle" as
-        the value for the graphicName property of a symbolizer.
-    </div>
-  </body>
-</html>
\ No newline at end of file
+<!DOCTYPE html>
+<html>
+    <head>
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+        <title>OpenLayers Graphic Names</title>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
+        <link rel="stylesheet" href="style.css" type="text/css" />
+        <script src="../lib/OpenLayers.js" type="text/javascript"></script>
+        <script src="./graphic-name.js" type="text/javascript"></script>
+    </head>
+    <body onload="init();">
+        <h1 id="title">Named Graphics Example</h1>
+        <div id="tags">
+            vector, named graphic, star, cross, x, square, triangle, circle, style
+        </div>
+        <p id="shortdesc">
+            Shows how to use well-known graphic names.
+        </p>
+        <div id="map" class="smallmap">
+        </div>
+        <div id="docs">
+            <p>
+                OpenLayers supports well-known names for a few graphics.  You
+                can use the names &quot;star&quot;, &quot;cross&quot;,
+                &quot;x&quot;, &quot;square&quot;, &quot;triangle&quot;, and
+                &quot;circle&quot; as value for the graphicName property of a
+                symbolizer.
+            </p>
+            <p>
+                The named symbols &quot;lightning&quot;, &quot;rectangle&quot;
+                and &quot;church&quot; are user defined.
+            </p>
+            <p>
+                See <a href="./graphic-name.js">graphic-name.js</a>
+                for the source code of this example.
+            </p>
+        </div>
+    </body>
+</html>
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG.js	2010-12-17 23:46:22 UTC (rev 10975)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG.js	2010-12-29 12:06:46 UTC (rev 10976)
@@ -50,14 +50,6 @@
     symbolMetrics: null,
-     * Property: supportUse
-     * {Boolean} true if defs/use is supported - known to not work as expected
-     * at least in some applewebkit/5* builds.
-     * See https://bugs.webkit.org/show_bug.cgi?id=33322
-    supportUse: null,
      * Constructor: OpenLayers.Renderer.SVG
      * Parameters:
@@ -70,7 +62,6 @@
         OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
        arguments);
         this.translationParameters = {x: 0, y: 0};
-        this.supportUse = (navigator.userAgent.toLowerCase().indexOf("applewebkit/5") == -1);
         this.symbolMetrics = {};
@@ -215,7 +206,7 @@
                 if (style.externalGraphic) {
                     nodeType = "image";
                 } else if (this.isComplexSymbol(style.graphicName)) {
-                    nodeType = this.supportUse === false ? "svg" : "use";
+                    nodeType = "svg";
                 } else {
                     nodeType = "circle";
@@ -306,17 +297,17 @@
                     parent.removeChild(node);
-                if(this.supportUse === false) {
-                    // workaround for webkit versions that cannot do defs/use
-                    // (see https://bugs.webkit.org/show_bug.cgi?id=33322):
-                    // copy the symbol instead of referencing it
-                    var src = document.getElementById(id);
-                    node.firstChild && node.removeChild(node.firstChild);
-                    node.appendChild(src.firstChild.cloneNode(true));
-                    node.setAttributeNS(null, "viewBox", src.getAttributeNS(null, "viewBox"));
-                } else {
-                    node.setAttributeNS(this.xlinkns, "href", "#" + id);
+                // The more appropriate way to implement this would be use/defs,
+                // but due to various issues in several browsers, it is safer to
+                // copy the symbols instead of referencing them.
+                // See e.g. ticket http://trac.osgeo.org/openlayers/ticket/2985
+                // and this email thread
+                // http://osgeo-org.1803224.n2.nabble.com/Select-Control-Ctrl-click-on-Feature-with-a-graphicName-opens-new-browser-window-tc5846039.html
+                var src = document.getElementById(id);
+                node.firstChild && node.removeChild(node.firstChild);
+                node.appendChild(src.firstChild.cloneNode(true));
+                node.setAttributeNS(null, "viewBox", src.getAttributeNS(null, "viewBox"));
                 node.setAttributeNS(null, "width", size);
                 node.setAttributeNS(null, "height", size);
                 node.setAttributeNS(null, "x", pos.x - offset);
@@ -334,19 +325,15 @@
             var rotation = style.rotation;
             if ((rotation !== undefined || node._rotation !== undefined) && pos) {
                 node._rotation = rotation;
                 rotation |= 0;
-                if(node.nodeName !== "svg") {
-                    node.setAttributeNS(null, "transform",
-                        "rotate(" + rotation + " " + pos.x + " " +
-                        pos.y + ")");
-                } else {
-                     var metrics = this.symbolMetrics[id];
-                     node.firstChild.setAttributeNS(null, "transform",
-                     "rotate(" + style.rotation + " " + metrics[1] +
-                         " " +  metrics[2] + ")");
+                var metrics = this.symbolMetrics[id];
+                node.firstChild.setAttributeNS(null, "transform", "rotate("
+                    + rotation + " "
+                    + metrics[1] + " "
+                    + metrics[2] + ")");
@@ -951,7 +938,7 @@
     getFeatureIdFromEvent: function(evt) {
         var featureId = OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this, arguments);
-        if(this.supportUse === false && !featureId) {
+        if(!featureId) {
             var target = evt.target;
             featureId = target.parentNode && target != this.rendererRoot &&
                 target.parentNode._featureId;
Modified: trunk/openlayers/tests/Renderer/SVG.html
--- trunk/openlayers/tests/Renderer/SVG.html	2010-12-17 23:46:22 UTC (rev 10975)
+++ trunk/openlayers/tests/Renderer/SVG.html	2010-12-29 12:06:46 UTC (rev 10976)
@@ -378,23 +378,7 @@
         var string = r.getShortString(point);
         t.eq(string, "2,-4", "returned string is correct");
-    function test_svg_getnodetype(t) {
-        if (!OpenLayers.Renderer.SVG.prototype.supported()) {
-            t.plan(0);
-            return;
-        t.plan(1);
-        var r = new OpenLayers.Renderer.SVG(document.body);
-        var g = {CLASS_NAME: "OpenLayers.Geometry.Point"}
-        var s = {graphicName: "square"};
-        t.eq(r.getNodeType(g, s), r.supportUse ? "use" : "svg", "Correct node type for well known symbols");
     function test_svg_importsymbol(t) {
             t.plan(0);
More information about the Commits mailing list
