[OpenLayers-Commits] r10865 - in sandbox/camptocamp/geobretagne: . examples lib/OpenLayers/Control lib/OpenLayers/Strategy tests/Control tests/Strategy
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Nov 2 13:13:19 EDT 2010
Author: fvanderbiest
Date: 2010-11-02 10:13:19 -0700 (Tue, 02 Nov 2010)
New Revision: 10865
   sandbox/camptocamp/geobretagne/
   sandbox/camptocamp/geobretagne/examples/mm.html
   sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Measure.js
   sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Panel.js
   sandbox/camptocamp/geobretagne/lib/OpenLayers/Strategy/Fixed.js
   sandbox/camptocamp/geobretagne/tests/Control/Measure.html
   sandbox/camptocamp/geobretagne/tests/Strategy/Fixed.html
camptocamp/geobretagne sandbox: merge with r10801
Property changes on: sandbox/camptocamp/geobretagne
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk:9457-9468
/trunk/openlayers:9457-9468,9470-9476,9478-9558,9560-9580,9582-9591,9593-9607,9609-9618
   + /trunk:9457-9468
/trunk/openlayers:9457-9468,9470-9476,9478-9558,9560-9580,9582-9591,9593-9607,9609-9618,10794-10801
Modified: sandbox/camptocamp/geobretagne/examples/mm.html
--- sandbox/camptocamp/geobretagne/examples/mm.html	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/examples/mm.html	2010-11-02 17:13:19 UTC (rev 10865)
@@ -12,7 +12,8 @@
     </style>
-    <script type="text/javascript" src="http://clients.multimap.com/API/maps/1.1/metacarta_04"></script>
+    <!-- multimap api key for http://(www.)openlayers.org -->
+    <script type="text/javascript" src="http://developer.multimap.com/API/maps/1.2/OA10072915821139765"></script>
     <script src="../lib/OpenLayers.js"></script>
Modified: sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Measure.js
--- sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Measure.js	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Measure.js	2010-11-02 17:13:19 UTC (rev 10865)
@@ -92,7 +92,7 @@
      * {Number} Timeout id of trigger for measurepartial.
     delayedTrigger: null,
      * APIProperty: persist
      * {Boolean} Keep the temporary measurement sketch drawn after the
@@ -130,11 +130,20 @@
+     * APIMethod: deactivate
+    deactivate: function() {
+        this.cancelDelay();
+        return OpenLayers.Control.prototype.deactivate.apply(this, arguments);
      * APIMethod: cancel
      * Stop the control from measuring.  If <persist> is true, the temporary
      *     sketch will be erased.
     cancel: function() {
         this.handler.cancel();
@@ -164,9 +173,7 @@
      * geometry - {<OpenLayers.Geometry>}
     measureComplete: function(geometry) {
-        if(this.delayedTrigger) {
-            window.clearTimeout(this.delayedTrigger);
         this.measure(geometry, "measure");
@@ -179,10 +186,17 @@
      * geometry - {<OpenLayers.Geometry>} The sketch geometry.
     measurePartial: function(point, geometry) {
-        if (geometry.getLength() > 0) {
-            geometry = geometry.clone();
+        geometry = geometry.clone();
+        // when we're wating for a dblclick, we have to trigger measurepartial
+        // after some delay to deal with reflow issues in IE
+        if (this.handler.freehandMode(this.handler.evt)) {
+            // no dblclick in freehand mode
+            this.measure(geometry, "measurepartial");
+        } else {
             this.delayedTrigger = window.setTimeout(
                 OpenLayers.Function.bind(function() {
+                    this.delayedTrigger = null;
                 }, this),
                 this.partialDelay
@@ -191,6 +205,17 @@
+     * Method: cancelDelay
+     * Cancels the delay measurement that measurePartial began.
+    cancelDelay: function() {
+        if (this.delayedTrigger !== null) {
+            window.clearTimeout(this.delayedTrigger);
      * Method: measure
      * Parameters:
Modified: sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Panel.js
--- sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Panel.js	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/lib/OpenLayers/Control/Panel.js	2010-11-02 17:13:19 UTC (rev 10865)
@@ -121,6 +121,9 @@
      * Method: redraw
     redraw: function() {
+        for (var l=this.div.childNodes.length, i=l-1; i>=0; i--) {
+            this.div.removeChild(this.div.childNodes[i]);
         this.div.innerHTML = "";
         if (this.active) {
             for (var i=0, len=this.controls.length; i<len; i++) {
Modified: sandbox/camptocamp/geobretagne/lib/OpenLayers/Strategy/Fixed.js
--- sandbox/camptocamp/geobretagne/lib/OpenLayers/Strategy/Fixed.js	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/lib/OpenLayers/Strategy/Fixed.js	2010-11-02 17:13:19 UTC (rev 10865)
@@ -97,14 +97,13 @@
      * options - {Object} options to pass to protocol read.
     load: function(options) {
-        var layer = this.layer;
-        layer.events.triggerEvent("loadstart");
-        layer.protocol.read(OpenLayers.Util.applyDefaults({
-            callback: OpenLayers.Function.bind(this.merge, this,
-                layer.map.getProjectionObject()),
-            filter: layer.filter
+        this.layer.events.triggerEvent("loadstart");
+        this.layer.protocol.read(OpenLayers.Util.applyDefaults({
+            callback: this.merge,
+            filter: this.layer.filter,
+            scope: this
         }, options));
-        layer.events.un({
+        this.layer.events.un({
             "visibilitychanged": this.load,
             scope: this
@@ -113,28 +112,25 @@
      * Method: merge
      * Add all features to the layer.
-     * Parameters:
-     * mapProjection - {OpenLayers.Projection} the map projection
-     * resp - {Object} options to pass to protocol read.
-    merge: function(mapProjection, resp) {
-        layer.destroyFeatures();
+    merge: function(resp) {
+        this.layer.destroyFeatures();
         var features = resp.features;
         if (features && features.length > 0) {
-            if(!mapProjection.equals(layer.projection)) {
+            var remote = this.layer.projection;
+            var local = this.layer.map.getProjectionObject();
+            if(!local.equals(remote)) {
                 var geom;
                 for(var i=0, len=features.length; i<len; ++i) {
                     geom = features[i].geometry;
                     if(geom) {
-                        geom.transform(layer.projection, mapProjection);
+                        geom.transform(remote, local);
-            layer.addFeatures(features);
+            this.layer.addFeatures(features);
-        layer.events.triggerEvent("loadend");
+        this.layer.events.triggerEvent("loadend");
     CLASS_NAME: "OpenLayers.Strategy.Fixed"
Modified: sandbox/camptocamp/geobretagne/tests/Control/Measure.html
--- sandbox/camptocamp/geobretagne/tests/Control/Measure.html	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/tests/Control/Measure.html	2010-11-02 17:13:19 UTC (rev 10865)
@@ -68,52 +68,161 @@
-    function test_partial(t) {
-        t.plan(1);
+    function test_partial(t) {
-        // set up
-        var map, layer, control, geometry, log;
-        map = new OpenLayers.Map("map", {units: "m"});
-        layer = new OpenLayers.Layer(null, {isBaseLayer: true});
-        map.addLayer(layer);
-        map.zoomToMaxExtent();
-        control = new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {
-            partialDelay: null
+        t.plan(28);
+        var map = new OpenLayers.Map({
+            div: "map",
+            units: "m",
+            resolutions: [1],
+            layers: [
+                new OpenLayers.Layer(null, {
+                    isBaseLayer: true
+            center: new OpenLayers.LonLat(0, 0)
+        var log = [];
+        var control = new OpenLayers.Control.Measure(
+            OpenLayers.Handler.Path, {persist: true,
+                eventListeners: {
+                    measurepartial: function(evt) {
+                        log.push(evt);
+                    measure: function(evt){
+                        log.push(evt);
         map.addControl(control);
         control.activate();
+        // convenience function to trigger mouse events
+        function trigger(type, x, y) {
+            map.events.triggerEvent(type, {
+                xy: new OpenLayers.Pixel(x, y)
+        // delay in seconds
+        var delay = control.partialDelay / 1000;
+        // establish first point
+        trigger("mousedown", 0, 0);
+        trigger("mouseup", 0, 0);
-        control.events.on({
-            "measurepartial": function(e) {
-                log.measure = e.measure;
+        // a) move 10 pixels and click
+        trigger("mousemove", 0, 10);
+        trigger("mousedown", 0, 10);
+        trigger("mouseup", 0, 10);
+        // confirm measurepartial is not fired before delay
+        t.eq(log.length, 0, "a) no event fired yet")
-        // test
+        t.delay_call(
+            // wait for delay then confirm event was logged
+            delay, function() {
+                t.eq(log.length, 1, "a) event logged")
+                t.eq(log[0].type, "measurepartial", "a) event logged");
+                t.eq(log[0].measure, 10, "a) correct measure");
+                // b) move 10 pixels and click
+                trigger("mousemove", 0, 20);
+                trigger("mousedown", 0, 20);
+                trigger("mouseup", 0, 20);
+                t.eq(log.length, 1, "b) no event fired yet")
+                t.eq(log.length, 2, "b) event logged");
+                t.eq(log[1].type, "measurepartial", "b) correct type");
+                t.eq(log[1].measure, 20, "b) correct measure");
-        geometry = new OpenLayers.Geometry.LineString([
-            new OpenLayers.Geometry.Point(1, 1),
-            new OpenLayers.Geometry.Point(2, 1)
+                // c) move 10 pixels and click
+                trigger("mousemove", 0, 30);
+                trigger("mousedown", 0, 30);
+                trigger("mouseup", 0, 30);
+            // wait for half delay and confirm event not logged
+            delay / 2, function() {
+                t.eq(log.length, 2, "c) no event fired yet")
+            // wait for rest of delay and confirm event logged
+                t.eq(log.length, 3, "c) event logged");
+                t.eq(log[2].type, "measurepartial", "c) correct type");
+                t.eq(log[2].measure, 30, "c) correct measure");
+                // d) move 10 pixels and click
+                trigger("mousemove", 0, 40);
+                trigger("mousedown", 0, 40);
+                trigger("mouseup", 0, 40);
-        log = {};
-        control.measurePartial(null, geometry);
-        geometry.components[1].x = 3;
-        t.delay_call(0.2, function() {
+                t.eq(log.length, 3, "d) no event fired yet")
+                // e) double click to finish
+                trigger("dblclick", 0, 40);
-            t.eq(log.measure, 1, "partial measure is correct");
+                t.eq(log.length, 4, "e) event logged");
+                t.eq(log[3].type, "measure", "e) correct type");
+                t.eq(log[3].measure, 40, "e) correct measure");
+            // wait for rest of delay and confirm no measurepartial logged
+                // confirm measurepartial is not fired after dblclick
+                t.eq(log.length, 4, "e) no additional event fired");
+                // change to freehand mode and confirm synchronous event dispatch
+                control.handler.freehand = true;
+                // clear log
+                log = [];
+                // f) establish first freehand point
+                t.eq(log.length, 0, "f) no event fired yet")
+                // g) move 10 pixels
+                trigger("mousemove", 10, 0);
-            // tear down
-            map.destroy
+                t.eq(log.length, 1, "g) event logged");
+                t.eq(log[0].type, "measurepartial", "g) correct type");
+                t.eq(log[0].measure, 10, "g) correct measure");
+                // h) move 10 pixels
+                trigger("mousemove", 20, 0);
+                t.eq(log.length, 2, "h) event logged");
+                t.eq(log[1].type, "measurepartial", "h) correct type");
+                t.eq(log[1].measure, 20, "h) correct measure");
+                // i) mouse up to finish
+                trigger("mouseup", 20, 0);
+                t.eq(log.length, 3, "i) event logged");
+                t.eq(log[2].type, "measure", "i) correct type");
+                t.eq(log[2].measure, 20, "i) correct measure");
+                // j) clean up
+                log = [];
+                map.destroy();
+            // wait for delay and confirm event not logged
+                t.eq(log.length, 0, "j) no event fired after destroy");
   </script>
 </head>
 <body>
Modified: sandbox/camptocamp/geobretagne/tests/Strategy/Fixed.html
--- sandbox/camptocamp/geobretagne/tests/Strategy/Fixed.html	2010-10-28 06:50:31 UTC (rev 10864)
+++ sandbox/camptocamp/geobretagne/tests/Strategy/Fixed.html	2010-11-02 17:13:19 UTC (rev 10865)
@@ -153,7 +153,7 @@
         // call merge with a mocked up response
-        strategy.merge(new OpenLayers.Projection("EPSG:900913"), {features: features});
+        strategy.merge({features: features});
         // confirm that the original features were destroyed
         t.eq(layer.features.length, 2, "old features destroyed");
@@ -177,7 +177,7 @@
         // call merge again with mocked up response
         // test that feature geometries have not been transformed
         t.geom_eq(layer.features[0].geometry, features[0].geometry, "[same proj] feature 0 geometry not transformed");
@@ -185,56 +185,6 @@
-    function test_load(t) {
-        t.plan(4);
-        // set up
-        var log;
-        var map = new OpenLayers.Map({
-            div: "map",
-            projection: new OpenLayers.Projection("EPSG:900913"),
-            layers: [new OpenLayers.Layer("", {isBaseLayer: true})]
-        var response = new OpenLayers.Protocol.Response();
-        var strategy = new OpenLayers.Strategy.Fixed({
-            merge: function(p, r) {
-                log = {scope: this, projection: p, response: r};
-        var layer = new OpenLayers.Layer.Vector("vector", {
-            strategies: [strategy],
-            protocol: {
-                read: function(o) {
-                    o.callback.call(o.scope, response);
-        // test
-        strategy.load();
-        // verify that the callback is correctly bound
-        t.ok(log !== undefined,
-             "merge was called");
-        t.ok(log.scope == strategy,
-             "merge called with expected scope");
-        t.eq(log.projection.getCode(), map.getProjectionObject().getCode(),
-             "merge called the map projection as the first arg");
-        t.ok(log.response == response,
-             "merge called with response as the first arg");
-        // tear down
-        map.destroy();
   </script>
 </head>
 <body>
More information about the Commits mailing list
