[OpenLayers-Commits] r10876 - sandbox/camptocamp/geobretagne
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Nov 8 04:12:19 EST 2010
Author: fvanderbiest
Date: 2010-11-08 01:12:18 -0800 (Mon, 08 Nov 2010)
New Revision: 10876
Removed:
   sandbox/camptocamp/geobretagne/apidoc_config/
   sandbox/camptocamp/geobretagne/art/
   sandbox/camptocamp/geobretagne/build/
   sandbox/camptocamp/geobretagne/doc/
   sandbox/camptocamp/geobretagne/doc_config/
   sandbox/camptocamp/geobretagne/examples/
   sandbox/camptocamp/geobretagne/img/
   sandbox/camptocamp/geobretagne/lib/
   sandbox/camptocamp/geobretagne/license.txt
   sandbox/camptocamp/geobretagne/news.txt
   sandbox/camptocamp/geobretagne/readme.txt
   sandbox/camptocamp/geobretagne/release-license.txt
   sandbox/camptocamp/geobretagne/repository-license.txt
   sandbox/camptocamp/geobretagne/tests/
   sandbox/camptocamp/geobretagne/theme/
   sandbox/camptocamp/geobretagne/tools/
geobretagne sandbox reinitialized
Deleted: sandbox/camptocamp/geobretagne/license.txt
--- sandbox/camptocamp/geobretagne/license.txt	2010-11-05 21:56:24 UTC (rev 10875)
+++ sandbox/camptocamp/geobretagne/license.txt	2010-11-08 09:12:18 UTC (rev 10876)
@@ -1,37 +0,0 @@
-This license applies to all code and content in the 'branches', 'trunk', and
-'project' directories of the Openlayers code repository at svn.openlayers.org,
-and applies to all release of OpenLayers later than 2.5.
-Copyright (c) 2005-2008 MetaCarta, Inc.
-All rights reserved.
-Redistribution and use in source and binary forms, with or without
-modification, are permitted (subject to the limitations in the
-disclaimer below) provided that the following conditions are met:
- * Redistributions of source code must retain the above copyright
-   notice, this list of conditions and the following disclaimer.
- * Redistributions in binary form must reproduce the above copyright
-   notice, this list of conditions and the following disclaimer in the
-   documentation and/or other materials provided with the
-   distribution.
- * Neither the name of MetaCarta, Inc. nor the names of its
-   contributors may be used to endorse or promote products derived
-   from this software without specific prior written permission.
-NO EXPRESS OR IMPLIED LICENSES TO ANY PARTY'S PATENT RIGHTS ARE
-GRANTED BY THIS LICENSE.  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT
-HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED
-WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
-MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
-DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
-LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
-BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
-WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
-OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
-IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Deleted: sandbox/camptocamp/geobretagne/news.txt
--- sandbox/camptocamp/geobretagne/news.txt	2010-11-05 21:56:24 UTC (rev 10875)
+++ sandbox/camptocamp/geobretagne/news.txt	2010-11-08 09:12:18 UTC (rev 10876)
@@ -1,54 +0,0 @@
-OpenLayers 2.9:
- r10251
- Released 04/22/10
- http://trac.openlayers.org/wiki/Release/2.9/Notes
-OpenLayers 2.8:
- r9492
- Released 06/22/09
- http://trac.openlayers.org/wiki/Release/2.8/Notes
-OpenLayers 2.7:
- r8063
- Released 09/29/08
- http://trac.openlayers.org/wiki/Release/2.7/Notes
-OpenLayers 2.6:
- r6945
- Released 04/15/08
- http://trac.openlayers.org/wiki/Release/2.6/Notes
-OpenLayers 2.5:
- r4899
- Released 10/09/07
- http://trac.openlayers.org/wiki/Release/2.5/Notes
-OpenLayers 2.4:
- r3198
- Released 05/29/07
- http://trac.openlayers.org/wiki/Release/2.4/Notes
-OpenLayers 2.3:
- r2255
- Released 02/21/07
- http://trac.openlayers.org/wiki/Release/2.3/Notes
-OpenLayers 2.2:
- r1866
- Released 11/15/06
- http://trac.openlayers.org/wiki/Release/2.2/Notes
-OpenLayers 2.1:
- r1521
- Released 10/02/06
- http://trac.openlayers.org/wiki/Release/2.1/Notes
-OpenLayers 2.0:
- r1368
- Released 08/25/06
- http://trac.openlayers.org/wiki/Release/2.0/Notes
-OpenLayers 1.0
- r787
- Released 06/27/06
- Initial release.
Deleted: sandbox/camptocamp/geobretagne/readme.txt
--- sandbox/camptocamp/geobretagne/readme.txt	2010-11-05 21:56:24 UTC (rev 10875)
+++ sandbox/camptocamp/geobretagne/readme.txt	2010-11-08 09:12:18 UTC (rev 10876)
@@ -1,71 +0,0 @@
-OpenLayers
-OpenLayers is a JavaScript library for building map applications
-on the web. OpenLayers is made available under a BSD-license.
-Please see license.txt in this distribution for more details.
-Getting OpenLayers
-OpenLayers lives at http://www.openlayers.org/.
-You can get OpenLayers from
-    http://trac.openlayers.org/wiki/HowToDownload.
-Installing OpenLayers
-You can use OpenLayers as-is by copying build/OpenLayers.js and the
-entire theme/ and img/ directories up to your webserver, putting them
-in the same directory. The files can be in subdirectories on your website,
-or right in the root of the site, as in these examples.
-To include the OpenLayers library in your web page from the root of the site, use:
-  <script type="text/javascript" src="/OpenLayers.js" />
-As an example, using bash (with the release files in ~/openlayers ):
-$ cd /var/www/html
-$ cp ~/openlayers/build/OpenLayers.js ./
-$ cp -R ~/openlayers/theme ./
-$ cp -R ~/openlayers/img ./
-If you want to use the multiple-file version of OpenLayers (for, say,
-debugging or development purposes), copy the lib/ directory up to your
-webserver in the same directory you put the img/ folder. Then add
-the following to your web page instead:
-  <script type="text/javascript" src="/lib/OpenLayers.js" />
-$ cd /var/www/html
-$ cp -R ~/openlayers/lib ./
-Using OpenLayers in Your Own Website
-The examples/ directory is full of useful examples.
-Documentation is available at http://trac.openlayers.org/wiki/Documentation.
-You can generate the API documentation with http://www.naturaldocs.org/:
-$ cd ~/openlayers/
-$ /path/to/NaturalDocs -i lib/ -o HTML doc/ -p doc_config/ -s Default OL
-Information on changes in the API is available in news.txt.
-Contributing to OpenLayers
-Please join the email lists at http://openlayers.org/mailman/listinfo
-Patches are welcome!
-= 30 =
Deleted: sandbox/camptocamp/geobretagne/release-license.txt
--- sandbox/camptocamp/geobretagne/release-license.txt	2010-11-05 21:56:24 UTC (rev 10875)
+++ sandbox/camptocamp/geobretagne/release-license.txt	2010-11-08 09:12:18 UTC (rev 10876)
@@ -1,3 +0,0 @@
-This license information is now available at:
-http://svn.openlayers.org/trunk/openlayers/license.txt
Deleted: sandbox/camptocamp/geobretagne/repository-license.txt
--- sandbox/camptocamp/geobretagne/repository-license.txt	2010-11-05 21:56:24 UTC (rev 10875)
+++ sandbox/camptocamp/geobretagne/repository-license.txt	2010-11-08 09:12:18 UTC (rev 10876)
@@ -1,3 +0,0 @@
More information about the Commits mailing list
