[OpenLayers-Commits] r10879 - in trunk/openlayers:
	lib/OpenLayers/Strategy tests/Strategy
    commits-20090109 at openlayers.org
    Tue Nov  9 07:57:06 EST 2010
Author: bartvde
Date: 2010-11-09 04:57:06 -0800 (Tue, 09 Nov 2010)
New Revision: 10879
   trunk/openlayers/lib/OpenLayers/Strategy/Filter.js
   trunk/openlayers/tests/Strategy/Filter.html
Filter strategy constructor should not need filter, r=tschaub,fredj (closes #2841)
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Filter.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Filter.js	2010-11-08 12:26:40 UTC (rev 10878)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Filter.js	2010-11-09 12:57:06 UTC (rev 10879)
@@ -45,14 +45,10 @@
      * Parameters:
      * options - {Object} Optional object whose properties will be set on the
-     *     instance.  Strategy must be constructed with at least a <filter>
-     *     property.
+     *     instance.
     initialize: function(options) {
         OpenLayers.Strategy.prototype.initialize.apply(this, [options]);
-        if (!this.filter || !(this.filter instanceof OpenLayers.Filter)) {
-            throw new Error("Filter strategy must be constructed with a filter");
@@ -102,7 +98,7 @@
      * Method: handleAdd
     handleAdd: function(event) {
-        if (!this.caching) {
+        if (!this.caching && this.filter) {
             var features = event.features;
             event.features = [];
             var feature;
Modified: trunk/openlayers/tests/Strategy/Filter.html
--- trunk/openlayers/tests/Strategy/Filter.html	2010-11-08 12:26:40 UTC (rev 10878)
+++ trunk/openlayers/tests/Strategy/Filter.html	2010-11-09 12:57:06 UTC (rev 10879)
@@ -21,7 +21,7 @@
 function test_initialize(t) {
-    t.plan(3);
+    t.plan(4);
     var strategy = new OpenLayers.Strategy.Filter({filter: filter});
@@ -31,6 +31,14 @@
     t.ok(strategy.filter === filter, "has filter");
     strategy.destroy();
+    try {
+        strategy = new OpenLayers.Strategy.Filter();
+        t.ok(true, "strategy without filter works");
+    } catch (err) {
+        t.fail("strategy without filter should not throw");
More information about the Commits
