[OpenLayers-Commits] r10883 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Nov 10 13:23:58 EST 2010
Author: tschaub
Date: 2010-11-10 10:23:58 -0800 (Wed, 10 Nov 2010)
New Revision: 10883
Added:
   trunk/openlayers/examples/single-tile.html
   trunk/openlayers/examples/single-tile.js
Removed:
   trunk/openlayers/examples/notile.html
Updated single tile example.
Deleted: trunk/openlayers/examples/notile.html
--- trunk/openlayers/examples/notile.html	2010-11-10 09:17:32 UTC (rev 10882)
+++ trunk/openlayers/examples/notile.html	2010-11-10 18:23:58 UTC (rev 10883)
@@ -1,42 +0,0 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
-  <head>
-    <title>OpenLayers: Single Tile</title>
-    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-    <link rel="stylesheet" href="style.css" type="text/css" />
-    <script src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        var map;
-        function init(){
-            map = new OpenLayers.Map('mapDiv', {maxResolution: 'auto'});
-            var old_ol_wms = new OpenLayers.Layer.WMS.Untiled( "WMS.Untiled",
-                "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'} );
-            old_ol_wms.addOptions({isBaseLayer: true});
-            var new_ol_wms = new OpenLayers.Layer.WMS( "WMS w/singleTile",
-                "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'},
-                { singleTile: true, ratio: 1 } );
-            new_ol_wms.addOptions({isBaseLayer: true});
-            map.addLayers([old_ol_wms, new_ol_wms]);
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
-            map.setCenter(new OpenLayers.LonLat(6.5, 40.5), 4);
-    </script>
-  </head>
-  <body onload="init()">
-    <h1 id="title">Untiled Example</h1>
-    <div id="tags">
-        tile, ratio, singleTile, performance
-    </div>
-    <p id="shortdesc">
-      Create an untiled WMS layer using the singleTile: true, option or the deprecated
-      WMS.Untiled layer.
-    </p>
-    <div id="mapDiv" class="smallmap"></div>
-    <p> The first layer is an old OpenLayers.Layer.WMS.Untiled layer, using
-        a default ratio value of 1.5.
-    <p> The second layer is an OpenLayers.Layer.WMS layer with singleTile set
-        to true, and with a ratio of 1.
-  </body>
-</html>
Copied: trunk/openlayers/examples/single-tile.html (from rev 10882, trunk/openlayers/examples/notile.html)
--- trunk/openlayers/examples/single-tile.html	                        (rev 0)
+++ trunk/openlayers/examples/single-tile.html	2010-11-10 18:23:58 UTC (rev 10883)
@@ -0,0 +1,30 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers: Single Tile</title>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+    </head>
+    <body>
+        <h1 id="title">Single Tile Example</h1>
+        <div id="tags">tile, ratio, singleTile, performance</div>
+        <p id="shortdesc">
+            Use the singleTile option on gridded layers to request a single tile.
+        </p>
+        <div id="mapDiv" class="smallmap"></div>
+        <div id="docs">
+            <p>
+                This map demonstrates the use of the singleTile property as an
+                alternative to the default tiled behavior of layers.  The first
+                layer in the map is a WMS layer with the singleTile option set
+                true.  The second layer is a WMS layer with the default options.
+            </p>
+            <p>
+                View the <a href="single-tile.js" target="_blank">single-tile.js</a>
+                source to see how this is done.
+            </p>
+        </div>
+        <script src="../lib/OpenLayers.js"></script>
+        <script src="single-tile.js"></script>
+    </body>
+</html>
Added: trunk/openlayers/examples/single-tile.js
--- trunk/openlayers/examples/single-tile.js	                        (rev 0)
+++ trunk/openlayers/examples/single-tile.js	2010-11-10 18:23:58 UTC (rev 10883)
@@ -0,0 +1,20 @@
+var map = new OpenLayers.Map({
+    div: "mapDiv",
+    layers: [
+        new OpenLayers.Layer.WMS(
+            "Single Tile",
+            "http://vmap0.tiles.osgeo.org/wms/vmap0",
+            {layers: "basic"},
+            {singleTile: true, ratio: 1}
+            "Multiple Tiles",
+            {layers: "basic"}
+    center: new OpenLayers.LonLat(6.5, 40.5),
+    zoom: 4
+map.addControl(new OpenLayers.Control.LayerSwitcher());
More information about the Commits mailing list
