[OpenLayers-Commits] r10886 - sandbox/elemoine/kinetic/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Nov 10 16:08:47 EST 2010
Author: erilem
Date: 2010-11-10 13:08:47 -0800 (Wed, 10 Nov 2010)
New Revision: 10886
   sandbox/elemoine/kinetic/examples/kinetic.html
better comments, title etc. for the kinetic.html example
Modified: sandbox/elemoine/kinetic/examples/kinetic.html
--- sandbox/elemoine/kinetic/examples/kinetic.html	2010-11-10 20:55:05 UTC (rev 10885)
+++ sandbox/elemoine/kinetic/examples/kinetic.html	2010-11-10 21:08:47 UTC (rev 10886)
@@ -1,6 +1,6 @@
 <html xmlns="http://www.w3.org/1999/xhtml">
   <head>
-    <title>OpenLayers Kinetic Scrolling Example</title>
+    <title>OpenLayers Kinetic Dragging Example</title>
     <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
     <link rel="stylesheet" href="style.css" type="text/css" />
     <style type="text/css">
@@ -45,24 +45,31 @@
     </script>
   </head>
   <body onload="init()">
-      <h1 id="title">TileCache Example</h1>
+      <h1 id="title">Kinetic Dragging Example</h1>
       <div id="tags">
-          tile, cache, tilecache, wmsc, wms-c
+          kinetic, dragging
       </div>
       <p id="shortdesc">
-        Demonstrates a TileCache layer that loads tiles from from a web
-        accessible disk-based cache only.
+        Demonstrates Kinetic Dragging.
       </p>
     <div id="map" class="smallmap"></div>
     <div id="docs">
-        This layer should be used for web accessible disk-based caches only.
-        It is not used to request new tiles from TileCache.  Note that you
-        should specify resolutions explicitly on this layer so that they match
-        your TileCache configuration.
+        <p>
+        OpenLayers Kinetic Dragging inspired from <a href="http://www.tile5.org">Tile5</a>, and
+        <a href="http://code.google.com/p/kineticscrolling/">kineticscrolling</a> for Google Maps API V3.
+        </p>
+        <p>
+        The value of the <code>panDuration</code> Map option defaults to 50 (in milliseconds). For
+        Kinetic Dragging you'd probably want to increase that value. It is set to 100 in this
+        example.
+        </p>
     </div>
   </body>
 </html>
More information about the Commits mailing list
