[OpenLayers-Commits] r10901 - in sandbox/bjornharrtell/posttransition: examples lib/OpenLayers/Tile
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Nov 16 19:39:20 EST 2010
Author: bjornharrtell
Date: 2010-11-16 16:39:20 -0800 (Tue, 16 Nov 2010)
New Revision: 10901
   sandbox/bjornharrtell/posttransition/examples/posttransition.html
   sandbox/bjornharrtell/posttransition/lib/OpenLayers/Tile/Image.js
Fix excess post transitions by triggering on loadend instead of on show
No tile buffer in example
Modified: sandbox/bjornharrtell/posttransition/examples/posttransition.html
--- sandbox/bjornharrtell/posttransition/examples/posttransition.html	2010-11-16 18:49:27 UTC (rev 10900)
+++ sandbox/bjornharrtell/posttransition/examples/posttransition.html	2010-11-17 00:39:20 UTC (rev 10901)
@@ -29,7 +29,7 @@
                 "WMS tiled resize",
                 "http://vmap0.tiles.osgeo.org/wms/vmap0?",
                 {layers: 'basic'},
-                {transitionEffect: 'resize'}
+                {transitionEffect: 'resize', buffer: 0}
             map.addLayers([tiled_resize_effect]);
Modified: sandbox/bjornharrtell/posttransition/lib/OpenLayers/Tile/Image.js
--- sandbox/bjornharrtell/posttransition/lib/OpenLayers/Tile/Image.js	2010-11-16 18:49:27 UTC (rev 10900)
+++ sandbox/bjornharrtell/posttransition/lib/OpenLayers/Tile/Image.js	2010-11-17 00:39:20 UTC (rev 10901)
@@ -208,6 +208,7 @@
                     // potentially end any transition effects when the tile loads
                     this.events.register('loadend', this, this.resetBackBuffer);
+                    this.events.register('loadend', this, this.fadeInTile);
                     // clear transition back buffer tile only after all tiles in
                     // this layer have loaded to avoid visual glitches
@@ -225,6 +226,7 @@
         } else {
             if (drawTile && this.isFirstDraw) {
                 this.events.register('loadend', this, this.showTile);
                 this.isFirstDraw = false;
@@ -579,6 +581,22 @@
+    fadeInTile: function() {
+        if (!this.isBackBuffer) {
+            this.opacity = 0.0;
+            this.frame.style.opacity = this.opacity;
+            var that = this;
+            var callback = function() {
+                that.opacity += 0.05;
+                that.frame.style.opacity = that.opacity;
+                if (that.opacity<1) {
+                    setTimeout(callback, 10);
      * Method: show
      * Show the tile by showing its frame.
@@ -593,20 +611,6 @@
                 this.frame.scrollLeft = this.frame.scrollLeft;
-        if (!this.isBackBuffer) {
-            this.opacity = 0.0;
-            this.frame.style.opacity = this.opacity;
-            var that = this;
-            var callback = function() {
-                that.opacity += 0.05;
-                that.frame.style.opacity = that.opacity;
-                if (that.opacity<1) {
-                    setTimeout(callback, 10);
More information about the Commits mailing list
