[OpenLayers-Commits] r10904 - trunk/openlayers/tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Nov 18 08:39:08 EST 2010
Author: erilem
Date: 2010-11-18 05:39:08 -0800 (Thu, 18 Nov 2010)
New Revision: 10904
   trunk/openlayers/tests/Request.html
make Request.html pass again, it passes in Chrome7, IE7 and FF3, no functional change
Modified: trunk/openlayers/tests/Request.html
--- trunk/openlayers/tests/Request.html	2010-11-17 12:51:22 UTC (rev 10903)
+++ trunk/openlayers/tests/Request.html	2010-11-18 13:39:08 UTC (rev 10904)
@@ -372,19 +372,41 @@
     function test_abort(t) {
         t.plan(0);
-        var fail = false;
-        OpenLayers.Request.XMLHttpRequest.onsend = function(args) {
-            fail = true;
+        var sendCalled;
+        // set up
+        var _open = OpenLayers.Request.XMLHttpRequest.prototype.open;
+        OpenLayers.Request.XMLHttpRequest.prototype.open = function() {
+            this.readyState = OpenLayers.Request.XMLHttpRequest.OPENED;
+        var _setRequestHeader = OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader;
+        OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = function() {};
+        var _send = OpenLayers.Request.XMLHttpRequest.prototype.send;
+        OpenLayers.Request.XMLHttpRequest.prototype.send = function() {
+            sendCalled = true;
+        // test
+        sendCalled = false;
+        OpenLayers.Request.issue().abort();
         t.delay_call(0.5, function() {
-            if (fail === true) {
+            if (sendCalled) {
                 t.fail("Send should not be called because request is aborted");
-            OpenLayers.Request.XMLHttpRequest.onsend = null;
+            // tear down
+            OpenLayers.Request.XMLHttpRequest.prototype.open = _open;
+            OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = _setRequestHeader;
+            OpenLayers.Request.XMLHttpRequest.prototype.send = _send;
-        var protocol = new OpenLayers.Protocol.HTTP();
-        protocol.abort(protocol.read());
     </script>
More information about the Commits mailing list
