[OpenLayers-Commits] r10929 - sandbox/camptocamp/ifremer/openlayers/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Nov 29 09:10:31 EST 2010
Author: fvanderbiest
Date: 2010-11-29 06:10:31 -0800 (Mon, 29 Nov 2010)
New Revision: 10929
   sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
   sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg
camptocamp/ifremer sandbox: added Format/CSWGetDomain/v2_0_2.js
Modified: sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
--- sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js	2010-11-29 11:26:50 UTC (rev 10928)
+++ sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js	2010-11-29 14:10:31 UTC (rev 10929)
@@ -206,7 +206,8 @@
 OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(a,b,c,d,e,f){this.layer=a;this.position=b.clone();this.bounds=c.clone();this.url=d;this.size=e.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,f)},unload:function(){if(this.isLoading){this.isLoading=false;
 this.events.triggerEvent("unload")}},destroy:function(){this.position=this.size=this.bounds=this.layer=null;this.events.destroy();this.events=null},clone:function(a){if(a==null)a=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);OpenLayers.Util.applyDefaults(a,this);return a},draw:function(){var a=this.layer.maxExtent;this.shouldDraw=a&&this.bounds.intersectsBounds(a,false)||this.layer.displayOutsideMaxExtent;this.clear();return this.shouldDraw},moveTo:function(a,b,c){if(c==
 null)c=true;this.bounds=a.clone();this.position=b.clone();c&&this.draw()},clear:function(){},getBoundsFromBaseLayer:function(a){var b=OpenLayers.i18n("reprojectDeprecated",{layerName:this.layer.name});OpenLayers.Console.warn(b);b=this.layer.map.getLonLatFromLayerPx(a);a=a.clone();a.x+=this.size.w;a.y+=this.size.h;a=this.layer.map.getLonLatFromLayerPx(a);if(b.lon>a.lon)if(b.lon<0)b.lon=-180-(b.lon+180);else a.lon=180+a.lon+180;return new OpenLayers.Bounds(b.lon,a.lat,a.lon,b.lat)},showTile:function(){this.shouldDraw&&
-this.show()},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Format.CSWGetRecords=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetRecords.DEFAULTS);var b=OpenLayers.Format.CSWGetRecords["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetRecords version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetRecords.DEFAULTS={version:"2.0.2"};
+this.show()},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Format.CSWGetDomain=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetDomain.DEFAULTS);var b=OpenLayers.Format.CSWGetDomain["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetDomain version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetDomain.DEFAULTS={version:"2.0.2"};
+OpenLayers.Format.CSWGetRecords=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetRecords.DEFAULTS);var b=OpenLayers.Format.CSWGetRecords["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetRecords version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetRecords.DEFAULTS={version:"2.0.2"};
 OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(a){if(window.ActiveXObject)this.xmldom=new ActiveXObject("Microsoft.XMLDOM");OpenLayers.Format.prototype.initialize.apply(this,[a]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var b in this.namespaces)this.namespaceAlias[this.namespaces[b]]=b},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,
 arguments)},setNamespace:function(a,b){this.namespaces[a]=b;this.namespaceAlias[b]=a},read:function(a){var b=a.indexOf("<");if(b>0)a=a.substring(b);b=OpenLayers.Util.Try(OpenLayers.Function.bind(function(){var c;c=window.ActiveXObject&&!this.xmldom?new ActiveXObject("Microsoft.XMLDOM"):this.xmldom;c.loadXML(a);return c},this),function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var c=new XMLHttpRequest;c.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),false);
 c.overrideMimeType&&c.overrideMimeType("text/xml");c.send(null);return c.responseXML});if(this.keepData)this.data=b;return b},write:function(a){if(this.xmldom)a=a.xml;else{var b=new XMLSerializer;if(a.nodeType==1){var c=document.implementation.createDocument("","",null);if(c.importNode)a=c.importNode(a,true);c.appendChild(a);a=b.serializeToString(c)}else a=b.serializeToString(a)}return a},createElementNS:function(a,b){return this.xmldom?typeof a=="string"?this.xmldom.createNode(1,b,a):this.xmldom.createNode(1,
@@ -280,7 +281,13 @@
 "none"},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera";
 OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(a,b,c){this.layer=a;this.lonlat=b;this.data=c!=null?c:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.layer!=null&&this.layer.map!=null&&this.popup!=null&&this.layer.map.removePopup(this.popup);this.layer!=null&&this.marker!=null&&this.layer.removeMarker(this.marker);this.data=this.lonlat=this.id=
 this.layer=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null}if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null}},onScreen:function(){var a=false;if(this.layer!=null&&this.layer.map!=null)a=this.layer.map.getExtent().containsLonLat(this.lonlat);return a},createMarker:function(){if(this.lonlat!=null)this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);return this.marker},destroyMarker:function(){this.marker.destroy()},createPopup:function(a){if(this.lonlat!=
-null){var b=this.id+"_popup",c=this.marker?this.marker.icon:null;if(!this.popup)this.popup=new this.popupClass(b,this.lonlat,this.data.popupSize,this.data.popupContentHTML,c,a);if(this.data.overflow!=null)this.popup.contentDiv.style.overflow=this.data.overflow;this.popup.feature=this}return this.popup},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null}},CLASS_NAME:"OpenLayers.Feature"});if(!OpenLayers.Format.OWSCommon)OpenLayers.Format.OWSCommon={};
+null){var b=this.id+"_popup",c=this.marker?this.marker.icon:null;if(!this.popup)this.popup=new this.popupClass(b,this.lonlat,this.data.popupSize,this.data.popupContentHTML,c,a);if(this.data.overflow!=null)this.popup.contentDiv.style.overflow=this.data.overflow;this.popup.feature=this}return this.popup},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null}},CLASS_NAME:"OpenLayers.Feature"});
+OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a==
+"string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{csw:{GetDomainResponse:function(a,b){this.readChildNodes(a,b)},DomainValues:function(a,b){if(!(b.DomainValues instanceof Array))b.DomainValues=[];for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;this.readChildNodes(a,d);b.DomainValues.push(d)},PropertyName:function(a,b){b.PropertyName=this.getChildValue(a)},ParameterName:function(a,
+b){b.ParameterName=this.getChildValue(a)},ListOfValues:function(a,b){if(!(b.ListOfValues instanceof Array))b.ListOfValues=[];this.readChildNodes(a,b.ListOfValues)},Value:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.push({Value:d})},ConceptualScheme:function(a,b){b.ConceptualScheme={};this.readChildNodes(a,b.ConceptualScheme)},Name:function(a,b){b.Name=this.getChildValue(a)},Document:function(a,b){b.Document=this.getChildValue(a)},
+Authority:function(a,b){b.Authority=this.getChildValue(a)},RangeOfValues:function(a,b){b.RangeOfValues={};this.readChildNodes(a,b.RangeOfValues)},MinValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MinValue=d},MaxValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MaxValue=d}}},write:function(a){a=this.writeNode("csw:GetDomain",a);return OpenLayers.Format.XML.prototype.write.apply(this,
+[a])},writers:{csw:{GetDomain:function(a){var b=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(a.PropertyName||this.PropertyName)this.writeNode("csw:PropertyName",a.PropertyName||this.PropertyName,b);else if(a.ParameterName||this.ParameterName)this.writeNode("csw:ParameterName",a.ParameterName||this.ParameterName,b);this.readChildNodes(b,a);return b},PropertyName:function(a){return this.createElementNSPlus("csw:PropertyName",{value:a})},ParameterName:function(a){return this.createElementNSPlus("csw:ParameterName",
+{value:a})}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});if(!OpenLayers.Format.OWSCommon)OpenLayers.Format.OWSCommon={};
 OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},readers:{ows:{ServiceIdentification:function(a,b){b.serviceIdentification={};this.readChildNodes(a,b.serviceIdentification)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},Keywords:function(a,b){b.keywords={};this.readChildNodes(a,b.keywords)},Keyword:function(a,b){b[this.getChildValue(a)]=
 true},ServiceType:function(a,b){b.serviceType={codeSpace:a.getAttribute("codeSpace"),value:this.getChildValue(a)}},ServiceTypeVersion:function(a,b){b.serviceTypeVersion=this.getChildValue(a)},Fees:function(a,b){b.fees=this.getChildValue(a)},AccessConstraints:function(a,b){b.accessConstraints=this.getChildValue(a)},ServiceProvider:function(a,b){b.serviceProvider={};this.readChildNodes(a,b.serviceProvider)},ProviderName:function(a,b){b.providerName=this.getChildValue(a)},ProviderSite:function(a,b){b.providerSite=
 this.getAttributeNS(a,this.namespaces.xlink,"href")},ServiceContact:function(a,b){b.serviceContact={};this.readChildNodes(a,b.serviceContact)},IndividualName:function(a,b){b.individualName=this.getChildValue(a)},PositionName:function(a,b){b.positionName=this.getChildValue(a)},ContactInfo:function(a,b){b.contactInfo={};this.readChildNodes(a,b.contactInfo)},Phone:function(a,b){b.phone={};this.readChildNodes(a,b.phone)},Voice:function(a,b){b.voice=this.getChildValue(a)},Address:function(a,b){b.address=
Modified: sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg
--- sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg	2010-11-29 11:26:50 UTC (rev 10928)
+++ sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg	2010-11-29 14:10:31 UTC (rev 10929)
@@ -24,6 +24,7 @@
 OpenLayers/Handler/RegularPolygon.js
 OpenLayers/Filter/Logical.js
 OpenLayers/Format/CSWGetRecords/v2_0_2.js
+OpenLayers/Format/CSWGetDomain/v2_0_2.js
 OpenLayers/Request.js
 OpenLayers/Ajax.js
More information about the Commits mailing list
