[OpenLayers-Commits] r10935 - in sandbox/bartvde/openls/openlayers: . examples lib/OpenLayers/Control tests/Control tests/Popup
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Nov 30 10:33:21 EST 2010
Author: bartvde
Date: 2010-11-30 07:33:21 -0800 (Tue, 30 Nov 2010)
New Revision: 10935
   sandbox/bartvde/openls/openlayers/
   sandbox/bartvde/openls/openlayers/examples/measure.html
   sandbox/bartvde/openls/openlayers/lib/OpenLayers/Control/Measure.js
   sandbox/bartvde/openls/openlayers/tests/Control/Measure.html
   sandbox/bartvde/openls/openlayers/tests/Popup/Anchored.html
merge sandbox with trunk
Property changes on: sandbox/bartvde/openls/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10912-10934
Modified: sandbox/bartvde/openls/openlayers/examples/measure.html
--- sandbox/bartvde/openls/openlayers/examples/measure.html	2010-11-30 15:28:55 UTC (rev 10934)
+++ sandbox/bartvde/openls/openlayers/examples/measure.html	2010-11-30 15:33:21 UTC (rev 10935)
@@ -132,6 +132,13 @@
                 control.geodesic = element.checked;
+        function toggleImmediate(element) {
+            for(key in measureControls) {
+                var control = measureControls[key];
+                control.setImmediate(element.checked);
     </script>
   </head>
   <body onload="init()">
@@ -164,13 +171,19 @@
                 <input type="checkbox" name="geodesic" id="geodesicToggle" onclick="toggleGeodesic(this);" />
                 <label for="geodesicToggle">use geodesic measures</label>
             </li>
+            <li>
+                <input type="checkbox" name="immediate" id="immediateToggle" onclick="toggleImmediate(this);" />
+                <label for="immediateToggle">use immediate measures</label>
+            </li>
         </ul>
         <p>Note that the geometries drawn are planar geometries and the
         metrics returned by the measure control are planar measures by
         default.  If your map is in a geographic projection or you have the
         appropriate projection definitions to transform your geometries into
         geographic coordinates, you can set the "geodesic" property of the control
-        to true to calculate geodesic measures instead of planar measures.</p>
+        to true to calculate geodesic measures instead of planar measures.
+        Also you have the possibility to set the "immediate" property to true
+        to get a new calculated value once the mouse has been mooved.</p>
     </div>
   </body>
 </html>
Modified: sandbox/bartvde/openls/openlayers/lib/OpenLayers/Control/Measure.js
--- sandbox/bartvde/openls/openlayers/lib/OpenLayers/Control/Measure.js	2010-11-30 15:28:55 UTC (rev 10934)
+++ sandbox/bartvde/openls/openlayers/lib/OpenLayers/Control/Measure.js	2010-11-30 15:33:21 UTC (rev 10935)
@@ -33,7 +33,8 @@
      *      will receive an event with measure, units, order, and geometry
      *      properties.
      * measurepartial - Triggered when a new point is added to the
-     *      measurement sketch.  Listeners receive an event with measure,
+     *      measurement sketch or if the <immediate> property is true and the
+     *      measurement sketch is modified.  Listeners receive an event with measure,
      *      units, order, and geometry.
     EVENT_TYPES: ['measure', 'measurepartial'],
@@ -104,6 +105,14 @@
     persist: false,
+     * APIProperty: immediate
+     * {Boolean} Activates the immediate measurement so that the "measurepartial"
+     *     event is also fired once the measurement sketch is modified.
+     *     Default is false.
+    immediate : false,
      * Constructor: OpenLayers.Control.Measure
      * Parameters:
@@ -117,10 +126,12 @@
             OpenLayers.Control.prototype.EVENT_TYPES
         OpenLayers.Control.prototype.initialize.apply(this, [options]);
-        this.callbacks = OpenLayers.Util.extend(
-            {done: this.measureComplete, point: this.measurePartial},
-            this.callbacks
+        var callbacks = {done: this.measureComplete,
+            point: this.measurePartial};
+        if (this.immediate){
+            callbacks.modify = this.measureImmediate;
+        this.callbacks = OpenLayers.Util.extend(callbacks, this.callbacks);
         // let the handler options override, so old code that passes 'persist'
         // directly to the handler does not need an update
@@ -147,6 +158,20 @@
         this.cancelDelay();
         this.handler.cancel();
+     * APIMethod: setImmediate
+     * Sets the <immediate> property. Changes the activity of immediate
+     * measurement.
+    setImmediate: function(immediate) {
+        this.immediate = immediate;
+            this.callbacks.modify = this.measureImmediate;
+        } else {
+            delete this.callbacks.modify;
      * Method: updateHandler
@@ -206,6 +231,20 @@
+     * Method: measureImmediate
+     * Called each time the measurement sketch is modified.
+     * Parameters: point - {<OpenLayers.Geometry.Point>} The point at the
+     * mouseposition. feature - {<OpenLayers.Feature.Vector>} The sketch feature.
+    measureImmediate : function(point, feature) {
+        if (this.delayedTrigger === null &&
+                                !this.handler.freehandMode(this.handler.evt)) {
+            this.measure(feature.geometry, "measurepartial");
      * Method: cancelDelay
      * Cancels the delay measurement that measurePartial began.
Modified: sandbox/bartvde/openls/openlayers/tests/Control/Measure.html
--- sandbox/bartvde/openls/openlayers/tests/Control/Measure.html	2010-11-30 15:28:55 UTC (rev 10934)
+++ sandbox/bartvde/openls/openlayers/tests/Control/Measure.html	2010-11-30 15:33:21 UTC (rev 10935)
@@ -222,6 +222,142 @@
+    function test_immediate(t) {
+        t.plan(29);
+        var map = new OpenLayers.Map({
+            div: "map",
+            units: "m",
+            resolutions: [1],
+            layers: [
+                new OpenLayers.Layer(null, {
+                    isBaseLayer: true
+            center: new OpenLayers.LonLat(0, 0)
+        var log = [];
+        var control = new OpenLayers.Control.Measure(
+            OpenLayers.Handler.Path, {
+                persist: true,
+                immediate: true,
+                eventListeners: {
+                    measurepartial: function(evt) {
+                        log.push(evt);
+                    measure: function(evt){
+                        log.push(evt);
+        map.addControl(control);
+        control.activate();
+        // convenience function to trigger mouse events
+        function trigger(type, x, y) {
+            map.events.triggerEvent(type, {
+                xy: new OpenLayers.Pixel(x, y)
+        // delay in seconds
+        var delay = control.partialDelay / 1000;
+        // a) establish first point
+        trigger("mousedown", 0, 0);
+        trigger("mouseup", 0, 0);
+        // move 10 pixels
+        trigger("mousemove", 0, 10);
+        t.eq(log.length, 0, "a) no event fired yet");
+        t.delay_call(
+            delay, function() {
+                // confirm measurepartial is fired
+                t.eq(log.length, 1, "a) event logged");
+                t.eq(log[0].type, "measurepartial", "a) correct type");
+                // mousemove within the partialDelay fires no event, so the
+                // measure below is the one of the initial point
+                t.eq(log[0].measure, 0, "a) correct measure");
+                // b) move 10 pixels
+                trigger("mousemove", 0, 20);
+                // c) move 10 pixels again
+                trigger("mousemove", 0, 30);
+                // confirm measurepartial is fired 2 times
+                t.eq(log.length, 3, "b) event logged");
+                t.eq(log[1].type, "measurepartial", "b) correct type");
+                t.eq(log[1].measure, 20, "b) correct measure");
+                t.eq(log[2].type, "measurepartial", "c) correct type");
+                t.eq(log[2].measure, 30, "c) correct measure");
+                // d) switch immediate measurement off
+                control.setImmediate(false);
+                t.eq(control.immediate, false, "d) immediate is false");
+                // e) move 10 pixels and click
+                trigger("mousemove", 0, 40);
+                trigger("mousedown", 0, 40);
+                trigger("mouseup", 0, 40);
+                // confirm measurepartial is not fired before delay
+                t.eq(log.length, 3, "e) no event fired yet")
+            // wait for delay then confirm event was logged
+                t.eq(log.length, 4, "e) event logged")
+                t.eq(log[3].type, "measurepartial", "e) correct type");
+                t.eq(log[3].measure, 40, "e) correct measure");
+                // f) switch immediate measurement on
+                control.setImmediate(true);
+                t.eq(control.immediate, true, "f) immediate is true");
+                // g) move 10 pixels
+                trigger("mousemove", 0, 50);
+                t.eq(log.length, 5, "g) event logged");
+                t.eq(log[4].type, "measurepartial", "g) correct type");
+                t.eq(log[4].measure, 50, "g) correct measure");
+                // h) move 10 pixels
+                trigger("mousemove", 0, 60);
+                t.eq(log.length, 6, "h) event logged");
+                t.eq(log[5].type, "measurepartial", "h) correct type");
+                t.eq(log[5].measure, 60, "h) correct measure");
+                // i) double click to finish
+                trigger("mousedown", 0, 60);
+                trigger("mouseup", 0, 60);
+                t.eq(log.length, 6, "i) no event fired yet");
+                t.eq(log.length, 7, "i) event logged");
+                t.eq(log[6].type, "measurepartial", "i) correct type");
+                t.eq(log[6].measure, 60, "i) correct measure");
+                trigger("dblclick", 0, 60);
+                t.eq(log.length, 8, "i) event logged");
+                t.eq(log[7].type, "measure", "i) correct type");
+                t.eq(log[7].measure, 60, "i) correct measure");
+                // clear log
+                log = [];
+                // j) clean up
+                map.destroy();
+                // wait for delay and confirm event not logged
+                t.eq(log.length, 0, "j) no event fired after destroy");
   </script>
 </head>
Modified: sandbox/bartvde/openls/openlayers/tests/Popup/Anchored.html
--- sandbox/bartvde/openls/openlayers/tests/Popup/Anchored.html	2010-11-30 15:28:55 UTC (rev 10934)
+++ sandbox/bartvde/openls/openlayers/tests/Popup/Anchored.html	2010-11-30 15:33:21 UTC (rev 10935)
@@ -11,7 +11,7 @@
         popup = new OpenLayers.Popup.Anchored();
         t.ok( popup instanceof OpenLayers.Popup.Anchored, "new OpenLayers.Popup.Anchored returns Popup.Anchored object" );
-        t.ok(popup.id.startsWith("OpenLayers.Popup.Anchored"), "valid default popupid");
+        t.ok(OpenLayers.String.startsWith(popup.id, "OpenLayers.Popup.Anchored"), "valid default popupid");
         var firstID = popup.id;
         t.eq(popup.contentHTML, null, "good default popup.contentHTML");
More information about the Commits mailing list
