[OpenLayers-Commits] r10841 - in sandbox/bjornharrtell/swipe:
examples lib lib/OpenLayers/Control
commits-20090109 at openlayers.org
Sat Oct 16 09:10:31 EDT 2010
Author: bjornharrtell
Date: 2010-10-16 06:10:31 -0700 (Sat, 16 Oct 2010)
New Revision: 10841
Added:
sandbox/bjornharrtell/swipe/examples/swipe.html
sandbox/bjornharrtell/swipe/examples/swipe.js
sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
sandbox/bjornharrtell/swipe/lib/OpenLayers.js
Swipe control and example
Added: sandbox/bjornharrtell/swipe/examples/swipe.html
--- sandbox/bjornharrtell/swipe/examples/swipe.html (rev 0)
+++ sandbox/bjornharrtell/swipe/examples/swipe.html 2010-10-16 13:10:31 UTC (rev 10841)
@@ -0,0 +1,39 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>OpenLayers Swipe Control</title>
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
+ <link rel="stylesheet" href="style.css" type="text/css">
+ <script src="http://maps.google.com/maps/api/js?sensor=false"></script>
+ <script src="../lib/OpenLayers.js"></script>
+ <script src="swipe.js"></script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">Swipe Control with Google and OSM </h1>
+ <div id="tags">
+ overlay, baselayer, swipe
+ </div>
+ <p id="shortdesc">
+ Demonstrating the Swipe Control.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <ul id="controlToggle">
+ <li>
+ <input type="checkbox" name="swipe" value="none" id="swipe"
+ onclick="toggleControl(this);""/>
+ <label for="swipe">Activate Swipe Control</label>
+ </li>
+ </ul>
+ <div id="docs">
+ <p>
+ The Swipe Control will reveal/hide a target layer right/left side of mouse mouse position on the map.
+ </p><p>
+ See the <a href="swipe.js" target="_blank">
+ swipe.js source</a> how the Swipe Control is used.
+ </p>
+ </div>
+ </body>
+</html>
Property changes on: sandbox/bjornharrtell/swipe/examples/swipe.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Id URL
Added: svn:eol-style
+ native
Added: sandbox/bjornharrtell/swipe/examples/swipe.js
--- sandbox/bjornharrtell/swipe/examples/swipe.js (rev 0)
+++ sandbox/bjornharrtell/swipe/examples/swipe.js 2010-10-16 13:10:31 UTC (rev 10841)
@@ -0,0 +1,29 @@
+var map;
+var swipe;
+function init() {
+ map = new OpenLayers.Map({
+ div : "map",
+ allOverlays : true
+ var osm = new OpenLayers.Layer.OSM();
+ var gmap = new OpenLayers.Layer.Google("Google Streets");
+ map.addLayers([ osm, gmap ]);
+ swipe = new OpenLayers.Control.Swipe(osm);
+ map.addControl(swipe);
+ map.setCenter(new OpenLayers.LonLat(10.2, 48.9).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject()), 9);
+function toggleControl(element) {
+ if (element.checked) {
+ swipe.activate();
+ } else {
+ swipe.deactivate();
Property changes on: sandbox/bjornharrtell/swipe/examples/swipe.js
+ text/plain
Added: sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
--- sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js (rev 0)
+++ sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js 2010-10-16 13:10:31 UTC (rev 10841)
@@ -0,0 +1,67 @@
+ * @requires OpenLayers/Control.js
+ * Class: OpenLayers.Control.Swipe
+ * Inherits from: - <OpenLayers.Control>
+OpenLayers.Control.Swipe = OpenLayers.Class(OpenLayers.Control, {
+ map: null,
+ layer: null,
+ layerContainerDiv: null,
+ div: null,
+ * Property: type {OpenLayers.Control.TYPES}
+ type : OpenLayers.Control.TYPE_TOOL,
+ * Constructor: OpenLayers.Control.Swipe
+ * Parameters:
+ * layer - {OpenLayers.Layer}
+ * options - {Object} An optional object whose properties will be used to extend the control.
+ initialize : function(layer, options) {
+ this.map = layer.map;
+ this.layer = layer;
+ this.div = this.layer.div;
+ this.layerContainerDiv = this.layer.map.layerContainerDiv;
+ OpenLayers.Control.prototype.initialize.apply(this, [ options ]);
+ activate : function() {
+ var activated = OpenLayers.Control.prototype.activate.call(this);
+ if (activated) {
+ this.map.events.on({
+ mousemove : this.onMousemove,
+ scope : this
+ deactivate : function() {
+ var deactivated = OpenLayers.Control.prototype.deactivate.call(this);
+ if (deactivated) {
+ this.div.style.clip = '';
+ this.map.events.un({
+ scope : this
+ onMousemove : function(e) {
+ var offset = (e.clientX - 20) - this.layerContainerDiv.offsetLeft;
+ this.div.style.clip = 'rect(0px, '+ this.map.getSize().w +'px, '+ this.map.getSize().h +'px, ' + offset + 'px)';
+ CLASS_NAME : "OpenLayers.Control.Swipe"
Property changes on: sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
+ text/plain
Modified: sandbox/bjornharrtell/swipe/lib/OpenLayers.js
--- sandbox/bjornharrtell/swipe/lib/OpenLayers.js 2010-10-16 12:43:16 UTC (rev 10840)
+++ sandbox/bjornharrtell/swipe/lib/OpenLayers.js 2010-10-16 13:10:31 UTC (rev 10841)
@@ -159,6 +159,7 @@
"OpenLayers/Control/ScaleLine.js",
"OpenLayers/Control/Snapping.js",
"OpenLayers/Control/Split.js",
+ "OpenLayers/Control/Swipe.js",
"OpenLayers/Control/LayerSwitcher.js",
"OpenLayers/Control/DrawFeature.js",
"OpenLayers/Control/DragFeature.js",
More information about the Commits
