[OpenLayers-Commits] r11863 - trunk/openlayers/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Apr 4 03:19:50 EDT 2011
Author: erilem
Date: 2011-04-04 00:19:46 -0700 (Mon, 04 Apr 2011)
New Revision: 11863
   trunk/openlayers/tests/Handler/Box.html
fix test_Handler_Box_draw by using another method to check whether we can get computed dimensions of an element (closes #3240)
Modified: trunk/openlayers/tests/Handler/Box.html
--- trunk/openlayers/tests/Handler/Box.html	2011-04-03 19:49:01 UTC (rev 11862)
+++ trunk/openlayers/tests/Handler/Box.html	2011-04-04 07:19:46 UTC (rev 11863)
@@ -18,15 +18,6 @@
     function test_Handler_Box_draw(t) {
-        var testAll = true;
-        if (document.defaultView && document.defaultView.getComputedStyle &&
-                    !document.defaultView.getComputedStyle(document.body, null)) {
-            // we don't get dimensions for hidden frames in FF4, and our test
-            // runs in a hidden frame.
-            testAll = false;
-        t.plan(testAll ? 12 : 2);
         var map = new OpenLayers.Map('map');
         var control = new OpenLayers.Control();
@@ -35,9 +26,38 @@
             t.ok(e.equals(new OpenLayers.Bounds(5, 11, 11, 5)), "box result correct");
         handler.activate();
+        // determine whether we can test the box position, the hidden frame
+        // our tests run in causes us problem here in FF and IE:
+        // IE8: left is NaN
+        // FF3: left is NaN
+        // FF4; left is NaN
+        // Chromium 10: left is 0
+        var testdiv = OpenLayers.Util.createDiv('testdiv', new OpenLayers.Pixel(5, 5));
+        map.div.appendChild(testdiv);
+        var left = parseInt(OpenLayers.Element.getStyle(testdiv, 'border-left-width'));
+        map.div.removeChild(testdiv);
+        var testAll = !isNaN(left);
+        t.plan(testAll ? 12 : 2);
+        // we change NaN values to 0 values in the handler's
+        // boxOffsets object, this is to prevent "invalid
+        // "argument" errors in IE
+        if(!testAll) {
+            var offset = handler.getBoxOffsets();
+            offset.left = 0;
+            offset.right = 0;
+            offset.top = 0;
+            offset.bottom = 0;
+            offset.width = 0;
+            offset.height = 0;
         handler.dragHandler.start = {x: 5, y: 5};
-        handler.startBox({x: 5, y: 5});
-        var offset = handler.getBoxOffsets();
+        handler.startBox();
+        offset = handler.getBoxOffsets();
         if (testAll) {
             t.eq(parseInt(handler.zoomBox.style.left), 5 - offset.left, "x position of box correct");
             t.eq(parseInt(handler.zoomBox.style.top), 5 - offset.top, "y position of box correct");
More information about the Commits mailing list
