[OpenLayers-Commits] r11871 - in trunk/openlayers: lib/OpenLayers/Format lib/OpenLayers/Format/WMC tests/Format tests/Format/WMC
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Apr 4 13:15:17 EDT 2011
Author: tschaub
Date: 2011-04-04 10:15:14 -0700 (Mon, 04 Apr 2011)
New Revision: 11871
   trunk/openlayers/lib/OpenLayers/Format/Context.js
   trunk/openlayers/lib/OpenLayers/Format/WMC.js
   trunk/openlayers/lib/OpenLayers/Format/WMC/v1.js
   trunk/openlayers/lib/OpenLayers/Format/WMC/v1_0_0.js
   trunk/openlayers/lib/OpenLayers/Format/WMC/v1_1_0.js
   trunk/openlayers/tests/Format/WMC.html
   trunk/openlayers/tests/Format/WMC/v1.html
Enhancements to the WMC parser for better contact information, SRS, and style support. p=trondmm, r=me (closes #3236)
Modified: trunk/openlayers/lib/OpenLayers/Format/Context.js
--- trunk/openlayers/lib/OpenLayers/Format/Context.js	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/lib/OpenLayers/Format/Context.js	2011-04-04 17:15:14 UTC (rev 11871)
@@ -122,7 +122,11 @@
             visibility: layerContext.visibility,
             maxExtent: layerContext.maxExtent,
             metadata: OpenLayers.Util.applyDefaults(layerContext.metadata,
-                {styles: layerContext.styles}),
+            {styles: layerContext.styles,
+             formats: layerContext.formats,
+             "abstract": layerContext["abstract"],
+             dataURL: layerContext.dataURL
             numZoomLevels: layerContext.numZoomLevels,
             units: layerContext.units,
             isBaseLayer: layerContext.isBaseLayer,
@@ -135,7 +139,10 @@
                     layerContext.tileSize.height
                 ) : undefined,
             minScale: layerContext.minScale || layerContext.maxScaleDenominator,
-            maxScale: layerContext.maxScale || layerContext.minScaleDenominator
+            maxScale: layerContext.maxScale || layerContext.minScaleDenominator,
+            srs: layerContext.srs,
+            dimensions: layerContext.dimensions,
+            metadataURL: layerContext.metadataURL
         if (this.layerOptions) {
             OpenLayers.Util.applyDefaults(options, this.layerOptions);
@@ -273,10 +280,22 @@
             projection: context.projection,
             units:      context.units
         }, options);
         if (options.maxExtent) {
             options.maxResolution =
                 options.maxExtent.getWidth() / OpenLayers.Map.TILE_WIDTH;
+        var metadata = {
+            contactInformation: context.contactInformation,
+            "abstract":         context["abstract"],
+            keywords:           context.keywords,
+            logo:               context.logo,
+            descriptionURL:     context.descriptionURL
+        options.metadata = metadata;
         var map = new OpenLayers.Map(options);
         map.addLayers(this.getLayersFromContext(context.layersContext));
         map.setCenter(
Modified: trunk/openlayers/lib/OpenLayers/Format/WMC/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WMC/v1.js	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/lib/OpenLayers/Format/WMC/v1.js	2011-04-04 17:15:14 UTC (rev 11871)
@@ -171,7 +171,8 @@
             visibility: (node.getAttribute("hidden") != "1"),
             queryable: (node.getAttribute("queryable") == "1"),
             formats: [],
-            styles: []
+             styles: [],
+             metadata: {}
         this.runChildNodes(layerContext, node);
@@ -259,12 +260,8 @@
     read_wmc_Server: function(layerContext, node) {
         layerContext.version = node.getAttribute("version");
-        var server = {};
-        var links = node.getElementsByTagName("OnlineResource");
-        if(links.length > 0) {
-            this.read_wmc_OnlineResource(server, links[0]);
-        layerContext.url = server.href;
+         layerContext.url = this.getOnlineResource_href(node);
+         layerContext.metadata.servertitle = node.getAttribute("title");
@@ -323,6 +320,14 @@
+      * Method: read_sld_FeatureTypeStyle
+     read_sld_FeatureTypeStyle: function(sld, node) {
+         var xml = OpenLayers.Format.XML.prototype.write.apply(this, [node]);
+         sld.body = xml;
      * Method: read_wmc_OnlineResource
     read_wmc_OnlineResource: function(obj, node) {
@@ -355,16 +360,25 @@
      * Method: read_wmc_MetadataURL
     read_wmc_MetadataURL: function(layerContext, node) {
-        var metadataURL = {};
-            this.read_wmc_OnlineResource(metadataURL, links[0]);
-        layerContext.metadataURL = metadataURL.href;
+         layerContext.metadataURL = this.getOnlineResource_href(node);
+      * Method: read_wmc_KeywordList
+     read_wmc_KeywordList: function(context, node) {
+         context.keywords = [];
+         this.runChildNodes(context.keywords, node);
+     read_wmc_Keyword: function(keywords, node) {
+         keywords.push(this.getChildValue(node));
      * Method: read_wmc_Abstract
     read_wmc_Abstract: function(obj, node) {
@@ -375,21 +389,221 @@
+      * Method: read_wmc_LogoURL
+     read_wmc_LogoURL: function(context, node) {
+         context.logo = {
+             width:  node.getAttribute("width"),
+             height: node.getAttribute("height"),
+             format: node.getAttribute("format"),
+             href:   this.getOnlineResource_href(node)
+      * Method: read_wmc_DescriptionURL
+     read_wmc_DescriptionURL: function(context, node) {
+         context.descriptionURL = this.getOnlineResource_href(node);
+      * Method: read_wmc_ContactInformation
+     read_wmc_ContactInformation: function(obj, node) {
+         var contact = {};
+         this.runChildNodes(contact, node);
+         obj.contactInformation = contact;
+      * Method: read_wmc_ContactPersonPrimary
+     read_wmc_ContactPersonPrimary: function(contact, node) {
+         var personPrimary = {};
+         this.runChildNodes(personPrimary, node);
+         contact.personPrimary = personPrimary;
+     read_wmc_ContactPerson: function(primaryPerson, node) {
+         var person = this.getChildValue(node);
+         if (person) {
+             primaryPerson.person = person;
+      * Method: read_wmc_ContactOrganization
+     read_wmc_ContactOrganization: function(primaryPerson, node) {
+         var organization = this.getChildValue(node);
+         if (organization) {
+             primaryPerson.organization = organization;
+      * Method: read_wmc_ContactPosition
+     read_wmc_ContactPosition: function(contact, node) {
+         var position = this.getChildValue(node);
+         if (position) {
+             contact.position = position;
+      * Method: read_wmc_ContactAddress
+     read_wmc_ContactAddress: function(contact, node) {
+         var contactAddress = {};
+         this.runChildNodes(contactAddress, node);
+         contact.contactAddress = contactAddress;
+      * Method: read_wmc_AddressType
+     read_wmc_AddressType: function(contactAddress, node) {
+         var type = this.getChildValue(node);
+         if (type) {
+             contactAddress.type = type;
+     read_wmc_Address: function(contactAddress, node) {
+         var address = this.getChildValue(node);
+         if (address) {
+             contactAddress.address = address;
+      * Method: read_wmc_City
+     read_wmc_City: function(contactAddress, node) {
+         var city = this.getChildValue(node);
+         if (city) {
+             contactAddress.city = city;
+      * Method: read_wmc_StateOrProvince
+     read_wmc_StateOrProvince: function(contactAddress, node) {
+         var stateOrProvince = this.getChildValue(node);
+         if (stateOrProvince) {
+             contactAddress.stateOrProvince = stateOrProvince;
+      * Method: read_wmc_PostCode
+     read_wmc_PostCode: function(contactAddress, node) {
+         var postcode = this.getChildValue(node);
+         if (postcode) {
+             contactAddress.postcode = postcode;
+      * Method: read_wmc_Country
+     read_wmc_Country: function(contactAddress, node) {
+         var country = this.getChildValue(node);
+         if (country) {
+             contactAddress.country = country;
+      * Method: read_wmc_ContactVoiceTelephone
+     read_wmc_ContactVoiceTelephone: function(contact, node) {
+         var phone = this.getChildValue(node);
+         if (phone) {
+             contact.phone = phone;
+      * Method: read_wmc_ContactFacsimileTelephone
+     read_wmc_ContactFacsimileTelephone: function(contact, node) {
+         var fax = this.getChildValue(node);
+         if (fax) {
+             contact.fax = fax;
+      * Method: read_wmc_ContactElectronicMailAddress
+     read_wmc_ContactElectronicMailAddress: function(contact, node) {
+         var email = this.getChildValue(node);
+         if (email) {
+             contact.email = email;
+      * Method: read_wmc_DataURL
+     read_wmc_DataURL: function(layerContext, node) {
+         layerContext.dataURL = this.getOnlineResource_href(node);
      * Method: read_wmc_LegendURL
     read_wmc_LegendURL: function(style, node) {
         var legend = {
             width: node.getAttribute('width'),
-            height: node.getAttribute('height')
+             height: node.getAttribute('height'),
+             format: node.getAttribute('format'),
-            this.read_wmc_OnlineResource(legend, links[0]);
         style.legend = legend;
+      * Method: read_wmc_DimensionList
+     read_wmc_DimensionList: function(layerContext, node) {
+         layerContext.dimensions = {};
+         this.runChildNodes(layerContext.dimensions, node);
+     read_wmc_Dimension: function(dimensions, node) {
+         var name = node.getAttribute("name").toLowerCase();
+         var dim = {
+             name:           name,
+             units:          node.getAttribute("units")          ||  "",
+             unitSymbol:     node.getAttribute("unitSymbol")     ||  "",
+             userValue:      node.getAttribute("userValue")      ||  "",
+             nearestValue:   node.getAttribute("nearestValue")   === "1",
+             multipleValues: node.getAttribute("multipleValues") === "1",
+             current:        node.getAttribute("current")        === "1",
+             "default":      node.getAttribute("default")        ||  ""
+         var values = this.getChildValue(node);
+         dim.values = values.split(",");
+         dimensions[dim.name] = dim;
      * Method: write
      * Parameters:
@@ -514,6 +728,33 @@
             "Title", context.title
+         // optional KeywordList element
+         if (context.keywords) {
+             node.appendChild(this.write_wmc_KeywordList(context.keywords));
+         // optional Abstract element
+         if (context["abstract"]) {
+             node.appendChild(this.createElementDefaultNS(
+                 "Abstract", context["abstract"]
+         // Optional LogoURL element
+         if (context.logo) {
+             node.appendChild(this.write_wmc_URLType("LogoURL", context.logo.href, context.logo));
+         // Optional DescriptionURL element
+         if (context.descriptionURL) {
+             node.appendChild(this.write_wmc_URLType("DescriptionURL", context.descriptionURL));
+         // Optional ContactInformation element
+         if (context.contactInformation) {
+             node.appendChild(this.write_wmc_ContactInformation(context.contactInformation));
         // OpenLayers specific map properties
         node.appendChild(this.write_ol_MapExtension(context));
@@ -521,6 +762,110 @@
+      * Method: write_wmc_KeywordList
+     write_wmc_KeywordList: function(keywords) {
+         var node = this.createElementDefaultNS("KeywordList");
+         for (var i=0, len=keywords.length; i<len; i++) {
+                 "Keyword", keywords[i]
+         return node;
+      * Method: write_wmc_ContactInformation
+     write_wmc_ContactInformation: function(contact) {
+         var node = this.createElementDefaultNS("ContactInformation");
+         if (contact.personPrimary) {
+             node.appendChild(this.write_wmc_ContactPersonPrimary(contact.personPrimary));
+         if (contact.position) {
+                 "ContactPosition", contact.position
+         if (contact.contactAddress) {
+             node.appendChild(this.write_wmc_ContactAddress(contact.contactAddress));
+         if (contact.phone) {
+                 "ContactVoiceTelephone", contact.phone
+         if (contact.fax) {
+                 "ContactFacsimileTelephone", contact.fax
+         if (contact.email) {
+                 "ContactElectronicMailAddress", contact.email
+         return node;
+      * Method: write_wmc_ContactPersonPrimary
+     write_wmc_ContactPersonPrimary: function(personPrimary) {
+         var node = this.createElementDefaultNS("ContactPersonPrimary");
+         if (personPrimary.person) {
+                 "ContactPerson", personPrimary.person
+         if (personPrimary.organization) {
+                 "ContactOrganization", personPrimary.organization
+         return node;
+      * Method: write_wmc_ContactAddress
+     write_wmc_ContactAddress: function(contactAddress) {
+         var node = this.createElementDefaultNS("ContactAddress");
+         if (contactAddress.type) {
+                 "AddressType", contactAddress.type
+         if (contactAddress.address) {
+                 "Address", contactAddress.address
+         if (contactAddress.city) {
+                 "City", contactAddress.city
+         if (contactAddress.stateOrProvince) {
+                 "StateOrProvince", contactAddress.stateOrProvince
+         if (contactAddress.postcode) {
+                 "PostCode", contactAddress.postcode
+         if (contactAddress.country) {
+                 "Country", contactAddress.country
+         return node;
      * Method: write_ol_MapExtension
     write_ol_MapExtension: function(context) {
@@ -594,9 +939,21 @@
+         // optional DataURL element
+         if (context.dataURL) {
+             node.appendChild(this.write_wmc_URLType("DataURL", context.dataURL));
         // optional MetadataURL element
         if (context.metadataURL) {
-            node.appendChild(this.write_wmc_MetadataURL(context.metadataURL));
+             node.appendChild(this.write_wmc_URLType("MetadataURL", context.metadataURL));
         return node;
@@ -682,34 +1039,79 @@
      * {Element} A WMC Server element node.
     write_wmc_Server: function(context) {
+         var server = context.server;
         var node = this.createElementDefaultNS("Server");
-        this.setAttributes(node, {
+         var attributes = {
             service: "OGC:WMS",
-            version: context.version
+             version: server.version
+         if (server.title) {
+             attributes.title = server.title
+         this.setAttributes(node, attributes);
         // required OnlineResource element
-        node.appendChild(this.write_wmc_OnlineResource(context.url));
+         node.appendChild(this.write_wmc_OnlineResource(server.url));
         return node;
-     * Method: write_wmc_MetadataURL
-     * Create a MetadataURL node given a metadataURL string.
+      * Method: write_wmc_URLType
+      * Create a LogoURL/DescriptionURL/MetadataURL/DataURL/LegendURL node given a object and elementName.
      * Parameters:
-     * metadataURL - {String} MetadataURL string value.
+      * elName - {String} Name of element (LogoURL/DescriptionURL/MetadataURL/LegendURL)
+      * url - {String} URL string value
+      * attr - {Object} Optional attributes (width, height, format)
      * Returns:
-     * {Element} A WMC metadataURL element node.
+      * {Element} A WMC element node.
-    write_wmc_MetadataURL: function(metadataURL) {
-        var node = this.createElementDefaultNS("MetadataURL");
+     write_wmc_URLType: function(elName, url, attr) {
+         var node = this.createElementDefaultNS(elName);
+         node.appendChild(this.write_wmc_OnlineResource(url));
+         if (attr) {
+             var optionalAttributes = ["width", "height", "format"];
+             for (var i=0; i<optionalAttributes.length; i++) {
+                 if (optionalAttributes[i] in attr) {
+                     node.setAttribute(optionalAttributes[i], attr[optionalAttributes[i]]);
+         return node;
-        // required OnlineResource element
-        node.appendChild(this.write_wmc_OnlineResource(metadataURL));
+      * Method: write_wmc_DimensionList
+     write_wmc_DimensionList: function(context) {
+         var node = this.createElementDefaultNS("DimensionList");
+         var required_attributes = {
+             name: true,
+             units: true,
+             unitSymbol: true,
+             userValue: true
+         for (var dim in context.dimensions) {
+             var attributes = {};
+             var dimension = context.dimensions[dim];
+             for (var name in dimension) {
+                 if (typeof dimension[name] == "boolean") {
+                     attributes[name] = Number(dimension[name]);
+                 } else {
+                     attributes[name] = dimension[name];
+             var values = "";
+             if (attributes.values) {
+                 values = attributes.values.join(",");
+                 delete attributes.values;
+                 "Dimension", values, attributes
         return node;
@@ -769,17 +1171,37 @@
                 if(s.href) { // [1]
                     sld = this.createElementDefaultNS("SLD");
-                    var link = this.write_wmc_OnlineResource(s.href);
-                    sld.appendChild(link);
-                    // Name is required.
+                     // Name is optional.
+                     if (s.name) {
                     sld.appendChild(this.createElementDefaultNS("Name", s.name));
                     // Title is optional.
                     if (s.title) {
                         sld.appendChild(this.createElementDefaultNS("Title", s.title));
+                     // LegendURL is optional
+                     if (s.legend) {
+                         sld.appendChild(this.write_wmc_URLType("LegendURL", s.legend.href, s.legend));
+                     var link = this.write_wmc_OnlineResource(s.href);
+                     sld.appendChild(link);
                     style.appendChild(sld);
                 } else if(s.body) { // [2]
+                     if (s.name) {
+                         sld.appendChild(this.createElementDefaultNS("Name", s.name));
+                     // Title is optional.
+                     if (s.title) {
+                         sld.appendChild(this.createElementDefaultNS("Title", s.title));
+                     if (s.legend) {
                     // read in body as xml doc - assume proper namespace declarations
                     var doc = OpenLayers.Format.XML.prototype.read.apply(this, [s.body]);
                     // append to StyledLayerDescriptor node
@@ -788,12 +1210,6 @@
                         imported = sld.ownerDocument.importNode(imported, true);
                     sld.appendChild(imported);
-                    sld.appendChild(this.createElementDefaultNS("Name", s.name));
-                    // Title is optional.
-                    if (s.title) {
-                        sld.appendChild(this.createElementDefaultNS("Title", s.title));
                 } else { // [3]
                     // both Name and Title are required.
@@ -805,7 +1221,11 @@
                             "Abstract", s['abstract']
+                     if (s.legend) {
+                         style.appendChild(this.write_wmc_URLType("LegendURL", s.legend.href, s.legend));
                 node.appendChild(style);
@@ -830,6 +1250,19 @@
         return node;
+      * Method: getOnlineResource_href
+     getOnlineResource_href: function(node) {
+         var object = {};
+         var links = node.getElementsByTagName("OnlineResource");
+         if(links.length > 0) {
+             this.read_wmc_OnlineResource(object, links[0]);
+         return object.href;
     CLASS_NAME: "OpenLayers.Format.WMC.v1"
Modified: trunk/openlayers/lib/OpenLayers/Format/WMC/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WMC/v1_0_0.js	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/lib/OpenLayers/Format/WMC/v1_0_0.js	2011-04-04 17:15:14 UTC (rev 11871)
@@ -46,6 +46,20 @@
+     * Method: read_wmc_SRS
+    read_wmc_SRS: function(layerContext, node) {
+        var srs    = this.getChildValue(node);
+        if (typeof layerContext.projections != "object") {
+            layerContext.projections = {};
+        var values = srs.split(/ +/);
+        for (var i=0, len=values.length; i<len; i++) {
+            layerContext.projections[values[i]] = true;
      * Method: write_wmc_Layer
      * Create a Layer node given a layer context object. This method adds
      *     elements specific to version 1.0.0.
@@ -61,12 +75,26 @@
             this, [context]
+        // optional SRS element(s)
+        if (context.srs) {
+            var projections = [];
+            for(var name in context.srs) {
+                projections.push(name);
+            node.appendChild(this.createElementDefaultNS("SRS", projections.join(" ")));
         // optional FormatList element
         node.appendChild(this.write_wmc_FormatList(context));
         // optional StyleList element
         node.appendChild(this.write_wmc_StyleList(context));
+        // optional DimensionList element
+        if (context.dimensions) {
+            node.appendChild(this.write_wmc_DimensionList(layer));
         // OpenLayers specific properties go in an Extension element
         node.appendChild(this.write_wmc_LayerExtension(context));
Modified: trunk/openlayers/lib/OpenLayers/Format/WMC/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WMC/v1_1_0.js	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/lib/OpenLayers/Format/WMC/v1_1_0.js	2011-04-04 17:15:14 UTC (rev 11871)
@@ -77,6 +77,16 @@
+        if (! ("srs" in layerContext)) {
+            layerContext.srs = {};
+        layerContext.srs[this.getChildValue(node)] = true;
      *     elements specific to version 1.1.0.
@@ -109,12 +119,24 @@
             node.appendChild(maxSD);
+                node.appendChild(this.createElementDefaultNS("SRS", name));
+            node.appendChild(this.write_wmc_DimensionList(context));
Modified: trunk/openlayers/lib/OpenLayers/Format/WMC.js
--- trunk/openlayers/lib/OpenLayers/Format/WMC.js	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/lib/OpenLayers/Format/WMC.js	2011-04-04 17:15:14 UTC (rev 11871)
@@ -74,9 +74,13 @@
             visibility: layer.visibility,
             title: layer.name,
+            "abstract": layer.metadata["abstract"],
+            dataURL: layer.metadata.dataURL,
             metadataURL: layer.metadataURL,
+            server: {
             version: layer.params["VERSION"],
-            url: layer.url,
+                url: layer.url
             maxExtent: layer.maxExtent,
             transparent: layer.params["TRANSPARENT"],
             numZoomLevels: layer.numZoomLevels,
@@ -97,18 +101,54 @@
                         layer.options.minResolution ||
                         layer.options.maxScale) ?
                         layer.maxScale : undefined,
-            formats: [{
+            formats: [],
+            styles: [],
+            srs: layer.srs,
+            dimensions: layer.dimensions
+        if (layer.metadata.servertitle) {
+            layerContext.server.title = layer.metadata.servertitle;
+        if (layer.metadata.formats && layer.metadata.formats.length > 0) {
+            for (var i=0, len=layer.metadata.formats.length; i<len; i++) {
+                var format = layer.metadata.formats[i];
+                layerContext.formats.push({
+                    value: format.value,
+                    current: (format.value == layer.params["FORMAT"])
+        } else {
                 value: layer.params["FORMAT"],
                 current: true
-            styles: [{
+        if (layer.metadata.styles && layer.metadata.styles.length > 0) {
+            for (var i=0, len=layer.metadata.styles.length; i<len; i++) {
+                var style = layer.metadata.styles[i];
+                if ((style.href == layer.params["SLD"]) ||
+                    (style.body == layer.params["SLD_BODY"]) ||
+                    (style.name == layer.params["STYLES"])) {
+                    style.current = true;
+                } else {
+                    style.current = false;
+                layerContext.styles.push(style);
+        } else {
+            layerContext.styles.push({
                 href: layer.params["SLD"],
                 body: layer.params["SLD_BODY"],
                 name: layer.params["STYLES"] || parser.defaultStyleName,
                 title: parser.defaultStyleTitle,
                 current: true
         return layerContext;
@@ -126,16 +166,22 @@
     toContext: function(obj) {
         var context = {};
         var layers = obj.layers;
-        if(obj.CLASS_NAME == "OpenLayers.Map") {
+        if (obj.CLASS_NAME == "OpenLayers.Map") {
+            var metadata = obj.metadata || {};
+            context.size = obj.getSize();
             context.bounds = obj.getExtent();
+            context.projection = obj.projection;
+            context.title = obj.title;
+            context.keywords = metadata.keywords;
+            context["abstract"] = metadata["abstract"];
+            context.logo = metadata.logo;
+            context.descriptionURL = metadata.descriptionURL;
+            context.contactInformation = metadata.contactInformation;
             context.maxExtent = obj.maxExtent;
-            context.projection = obj.projection;
-            context.size = obj.getSize();
-        else {
+        } else {
             // copy all obj properties except the "layers" property
             OpenLayers.Util.applyDefaults(context, obj);
-            if(context.layers != undefined) {
+            if (context.layers != undefined) {
                 delete(context.layers);
@@ -148,7 +194,7 @@
         if (layers != undefined && layers instanceof Array) {
             for (var i=0, len=layers.length; i<len; i++) {
                 var layer = layers[i];
-                if(layer instanceof OpenLayers.Layer.WMS) {
+                if (layer instanceof OpenLayers.Layer.WMS) {
                     context.layersContext.push(this.layerToContext(layer));
Modified: trunk/openlayers/tests/Format/WMC/v1.html
--- trunk/openlayers/tests/Format/WMC/v1.html	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/tests/Format/WMC/v1.html	2011-04-04 17:15:14 UTC (rev 11871)
@@ -4,7 +4,7 @@
     <script type="text/javascript">
     function test_write_wmc_StyleList(t) {
-        t.plan(3);
+        t.plan(4);
         var layer, layerContext, got, expected;
@@ -39,10 +39,10 @@
             "<StyleList xmlns='http://www.opengis.net/context'>" +
                 "<Style current='1'>" +
                     "<SLD>" +
+                        "<Title>Default</Title>" +
                         "<OnlineResource xmlns:xlink='http://www.w3.org/1999/xlink' "+
                                         "xlink:type='simple' " +
                                         "xlink:href='http://linked.sld' />" +
-                        "<Name></Name><Title>Default</Title>" +
                     "</SLD>" +
                 "</Style>" +
             "</StyleList>";
@@ -88,6 +88,7 @@
                     "<SLD>" +
                         "<sld:StyledLayerDescriptor version='1.0.0' " +
                             "xmlns:sld='http://www.opengis.net/sld' " +
                             "xmlns:ogc='http://www.opengis.net/ogc' " +
@@ -115,13 +116,71 @@
                                 "</sld:UserStyle>" +
                             "</sld:NamedLayer>" +
                         "</sld:StyledLayerDescriptor>" +
                     "</SLD>" +
                 "</Style>" +
             "</StyleList>";
         t.xml_eq(got, expected, "inline style correctly written");
         layer.destroy();
+        // test inline FeatureTypeStyle
+        layer = new OpenLayers.Layer.WMS(name, url, {
+            sld_body:
+                "<sld:FeatureTypeStyle version='1.0.0' " +
+                            "xmlns:sld='http://www.opengis.net/sld' " +
+                            "xmlns:ogc='http://www.opengis.net/ogc' " +
+                            "xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' " +
+                            "xsi:schemaLocation='http://www.opengis.net/sld http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd'>" +
+                    "<sld:Rule>" +
+                        "<sld:TextSymbolizer>" +
+                            "<sld:Label>" +
+                                "<ogc:PropertyName>ZONENR</ogc:PropertyName>" +
+                            "</sld:Label>" +
+                            "<sld:Font>" +
+                                "<sld:CssParameter name='font-family'>Arial</sld:CssParameter>" +
+                                "<sld:CssParameter name='font-size'>10</sld:CssParameter>" +
+                            "</sld:Font>" +
+                            "<sld:Fill>" +
+                                "<sld:CssParameter name='fill'>#FF9900</sld:CssParameter>" +
+                            "</sld:Fill>" +
+                        "</sld:TextSymbolizer>" +
+                    "</sld:Rule>" +
+                "</sld:FeatureTypeStyle>"
+        layerContext = format.layerToContext(layer);
+        got = parser.write_wmc_StyleList(layerContext);
+        expected =
+            "<StyleList xmlns='http://www.opengis.net/context'>" +
+                "<Style current='1'>" +
+                    "<SLD>" +
+                            "<sld:Rule>" +
+                                    "<sld:Label>" +
+                                    "</sld:Label>" +
+                                    "<sld:Font>" +
+                                    "</sld:Font>" +
+                                    "<sld:Fill>" +
+                                    "</sld:Fill>" +
+                            "</sld:Rule>" +
+                        "</sld:FeatureTypeStyle>" +
+                    "</SLD>" +
+                "</Style>" +
+            "</StyleList>";
+        t.xml_eq(got, expected, "inline FeatureTypeStyle correctly written");
+        layer.destroy();
     function test_read_wmc_StyleList(t) {
Modified: trunk/openlayers/tests/Format/WMC.html
--- trunk/openlayers/tests/Format/WMC.html	2011-04-04 17:11:14 UTC (rev 11870)
+++ trunk/openlayers/tests/Format/WMC.html	2011-04-04 17:15:14 UTC (rev 11871)
@@ -6,9 +6,10 @@
     var v1_0_0 = '<ViewContext xmlns="http://www.opengis.net/context" version="1.0.0" id="OpenLayers_Context_233" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><General><Window width="512" height="256"/><BoundingBox minx="-109.9709708" miny="27.01451459" maxx="-80.02902918" maxy="41.98548541" SRS="EPSG:4326"/><Title/><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/></Extension></General><LayerList><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://t1.hypercube.telascience.org/cgi-bin/landsat7"/></Server><Name>landsat7</Name><Title>NASA Global Mosaic</Title><FormatList><Format current="1">image/jpeg</Format></FormatList><StyleList><Style current="1"><N
 ame/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">true</ol:isBaseLayer><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile><ol:tileSize xmlns:ol="http://openlayers.org/context" width="512" height="1024"/></Extension></Layer><Layer queryable="1" hidden="1"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://labs.metacarta.com/wms/vmap0"/></Server><Name>basic</Name><Title>OpenLayers WMS</Title><FormatList><Format current="1">im
 age/jpeg</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">true</ol:isBaseLayer><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile></Extension></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://lioapp.lrc.gov.on.ca/cubeserv/cubeserv.pl"/></Server><Name>na_road:CCRS</Name><Title>Transportation Network</Title><FormatList><Format curre
 nt="1">image/png</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-166.5320000" miny="4.050460000" maxx="-0.2068180000" maxy="70.28700000"/><ol:transparent xmlns:ol="http://openlayers.org/context">TRUE</ol:transparent><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">false</ol:isBaseLayer><ol:opacity xmlns:ol="http://openlayers.org/context">0.6</ol:opacity><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">false</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile></Extension></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" x
 link:href="http://columbo.nrlssc.navy.mil/ogcwms/servlet/WMSServlet/AccuWeather_Maps.wms"/></Server><Name>3:1</Name><Title>Radar 3:1</Title><FormatList><Format current="1">image/png</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-131.0294952" miny="14.56289673" maxx="-61.02950287" maxy="54.56289673"/><ol:transparent xmlns:ol="http://openlayers.org/context">TRUE</ol:transparent><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">false</ol:isBaseLayer><ol:opacity xmlns:ol="http://openlayers.org/context">0.8</ol:opacity><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">false</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">true</ol:singleTile></Extension
 ></Layer></LayerList></ViewContext>';
     var v1_1_0 = '<ViewContext xmlns="http://www.opengis.net/context" version="1.1.0" id="OpenLayers_Context_232" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><General><Window width="512" height="256"/><BoundingBox minx="-109.9709708" miny="27.01451459" maxx="-80.02902918" maxy="41.98548541" SRS="EPSG:4326"/><Title/><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/></Extension></General><LayerList><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://t1.hypercube.telascience.org/cgi-bin/landsat7"/></Server><Name>landsat7</Name><Title>NASA Global Mosaic</Title><sld:MinScaleDenominator xmlns:sld="http://www.opengis.net/sld">6299645.760</sld:MinScaleDenomin
 ator><sld:MaxScaleDenominator xmlns:sld="http://www.opengis.net/sld">31498228.80</sld:MaxScaleDenominator><FormatList><Format current="1">image/jpeg</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/><ol:tileSize xmlns:ol="http://openlayers.org/context" width="512" height="1024"/><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">true</ol:isBaseLayer><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile></Extension></Layer><Layer queryable="1" hidden="1"><Server service="OGC:WMS" version="1.1.1"><OnlineResource x
 link:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://labs.metacarta.com/wms/vmap0"/></Server><Name>basic</Name><Title>OpenLayers WMS</Title><sld:MinScaleDenominator xmlns:sld="http://www.opengis.net/sld">6299645.760</sld:MinScaleDenominator><sld:MaxScaleDenominator xmlns:sld="http://www.opengis.net/sld">31498228.80</sld:MaxScaleDenominator><FormatList><Format current="1">image/jpeg</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-130.0000000" miny="14.00000000" maxx="-60.00000000" maxy="55.00000000"/><ol:tileSize xmlns:ol="http://openlayers.org/context" width="512" height="1024"/><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">true</ol:isBaseLayer><ol:displayInLayerSwitch
 er xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile></Extension></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://lioapp.lrc.gov.on.ca/cubeserv/cubeserv.pl"/></Server><Name>na_road:CCRS</Name><Title>Transportation Network</Title><sld:MinScaleDenominator xmlns:sld="http://www.opengis.net/sld">6200000.000</sld:MinScaleDenominator><sld:MaxScaleDenominator xmlns:sld="http://www.opengis.net/sld">32000000.00</sld:MaxScaleDenominator><FormatList><Format current="1">image/png</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-166.5320000" miny="4.050460000" maxx="-0.2068180000" maxy="70.28700000"/><ol:tileSize xmlns:ol="http://openlayer
 s.org/context" width="512" height="1024"/><ol:transparent xmlns:ol="http://openlayers.org/context">TRUE</ol:transparent><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">false</ol:isBaseLayer><ol:opacity xmlns:ol="http://openlayers.org/context">0.6</ol:opacity><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">false</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">false</ol:singleTile></Extension></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1"><OnlineResource xlink:type="simple" xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://columbo.nrlssc.navy.mil/ogcwms/servlet/WMSServlet/AccuWeather_Maps.wms"/></Server><Name>3:1</Name><Title>Radar 3:1</Title><sld:MinScaleDenominator xmlns:sld="http://www.opengis.net/sld">6299645.760</sld:
 MinScaleDenominator><sld:MaxScaleDenominator xmlns:sld="http://www.opengis.net/sld">31498228.80</sld:MaxScaleDenominator><FormatList><Format current="1">image/png</Format></FormatList><StyleList><Style current="1"><Name/><Title>Default</Title></Style></StyleList><Extension><ol:maxExtent xmlns:ol="http://openlayers.org/context" minx="-131.0294952" miny="14.56289673" maxx="-61.02950287" maxy="54.56289673"/><ol:transparent xmlns:ol="http://openlayers.org/context">TRUE</ol:transparent><ol:numZoomLevels xmlns:ol="http://openlayers.org/context">4</ol:numZoomLevels><ol:units xmlns:ol="http://openlayers.org/context">degrees</ol:units><ol:isBaseLayer xmlns:ol="http://openlayers.org/context">false</ol:isBaseLayer><ol:opacity xmlns:ol="http://openlayers.org/context">0.8</ol:opacity><ol:displayInLayerSwitcher xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher><ol:singleTile xmlns:ol="http://openlayers.org/context">true</ol:singleTile></Extension></Layer></LayerList
 ></ViewContext>';
     var polar = '<ViewContext xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:default="http://www.opengis.net/context" xmlns:ol="http://openlayers.org/context" xmlns="http://www.opengis.net/context" xmlns:wms="http://www.opengis.net/wms" xmlns:xlink="http://www.w3.org/1999/xlink" version="1.1.0" id="OpenLayers_Context_466" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd"><General><BoundingBox minx="-3000000" miny="-3000000" maxx="7000000" maxy="7000000" SRS="EPSG:32661"/><Title>WMS viewer</Title><Extension><ol:maxExtent minx="-3000000" miny="-3000000" maxx="7000000" maxy="7000000"/><ol:units>m</ol:units></Extension></General><LayerList xmlns="http://www.opengis.net/context"><Layer queryable="0" hidden="0"><Server service="OGC:WMS" version="1.1.1" foo="bar"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://wms.met.no/maps/northpole.map"/></Server><Name>world</Na
 me><Title>The World</Title><FormatList><Format>image/jpeg</Format><Format current="1">image/png</Format></FormatList></Layer></LayerList></ViewContext>';
+    var fulldoc = '<ViewContext xmlns="http://www.opengis.net/context" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:sld="http://www.opengis.net/sld" version="1.1.0" id="eos_data_gateways" xsi:schemaLocation="http://www.opengis.net/context context.xsd"><General><Window width="500" height="300"/><BoundingBox SRS="EPSG:4326" minx="-180.000000" miny="-90.000000" maxx="180.000000" maxy="90.000000"/><Title>EOS Data Gateways</Title><KeywordList><Keyword>EOS</Keyword><Keyword>EOSDIS</Keyword><Keyword>NASA</Keyword><Keyword>CCRS</Keyword><Keyword>CEOS</Keyword><Keyword>OGC</Keyword></KeywordList><Abstract>Map View of EOSDIS partners locations</Abstract><LogoURL width="130" height="74" format="image/gif"><OnlineResource xlink:type="simple" xlink:href="http://redhook.gsfc.nasa.gov/~imswww/pub/icons/logo.gif"/></LogoURL><DescriptionURL format="text/html"><OnlineResource xlink:type="simple" xlink:href="http://eos.nasa.gov/imswelco
 me"/></DescriptionURL><ContactInformation><ContactPersonPrimary><ContactPerson>Tom Kralidis</ContactPerson><ContactOrganization>Environment Canada</ContactOrganization></ContactPersonPrimary><ContactPosition>Systems Scientist</ContactPosition><ContactAddress><AddressType>postal</AddressType><Address>867 Lakeshore Road</Address><City>Burlington</City><StateOrProvince>Ontario</StateOrProvince><PostCode>L7R 4A6</PostCode><Country>Canada</Country></ContactAddress><ContactVoiceTelephone>+01-905-336-4409</ContactVoiceTelephone><ContactFacsimileTelephone>+01-905-336-4499</ContactFacsimileTelephone><ContactElectronicMailAddress>tom.kralidis at ec.gc.ca</ContactElectronicMailAddress></ContactInformation></General><LayerList><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1" title="ESA CubeSERV"><OnlineResource xlink:type="simple" xlink:href="http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi"/></Server><Name>WORLD_MODIS_1KM:MapAdmin</Name><Title>WORLD_MOD
 IS_1KM</Title><Abstract>Global maps derived from various Earth Observation sensors / WORLD_MODIS_1KM:MapAdmin</Abstract><SRS>EPSG:4326</SRS><FormatList><Format current="1">image/png</Format><Format>image/gif</Format><Format>image/jpeg</Format></FormatList><StyleList><Style current="1"><Name>default</Name><Title>default</Title><LegendURL width="16" height="16" format="image/gif"><OnlineResource xlink:type="simple" xlink:href="http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi?version=1.1.1&amp;request=GetLegendGraphic&amp;layer=WORLD_MODIS_1KM:MapAdmin&amp;style=default&amp;format=image/gif"/></LegendURL></Style></StyleList></Layer><Layer queryable="0" hidden="0"><Server service="OGC:WMS" version="1.1.1" title="The GLOBE Program Visualization Server"><OnlineResource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/viz-bin/wmt.cgi"/></Server><Name>COASTLINES</Name><Title>Coastlines</Title><Abstract>Context layer: Coastlines</Abstract><SRS>EPSG:4326</SRS><
 SRS>EPSG:900913</SRS><FormatList><Format current="1">image/gif</Format><Format>image/png</Format></FormatList><StyleList><Style current="1"><Name>default</Name><Title>Default</Title><LegendURL width="180" format="image/gif" height="50"><OnlineResource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/globe/en/icons/colorbars/COASTLINES.gif"/></LegendURL></Style></StyleList><DimensionList><Dimension name="time" units="ISO8601" nearestValue="1">2011-03-31,2011-04-01</Dimension></DimensionList></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1" title="The GLOBE Program Visualization Server"><OnlineResource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/viz-bin/wmt.cgi"/></Server><Name>NATIONAL</Name><Title>National Boundaries</Title><Abstract>Context layer: National Boundaries</Abstract><DataURL><OnlineResource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/data/national.gml"/></DataURL><MetadataURL><Online
 Resource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/metadata/national.txt"/></MetadataURL><SRS>EPSG:4326</SRS><FormatList><Format current="1">image/gif</Format><Format>image/png</Format></FormatList><StyleList><Style current="1"><Name>default</Name><Title>Default</Title><LegendURL width="180" format="image/gif" height="50"><OnlineResource xlink:type="simple" xlink:href="http://globe.digitalearth.gov/globe/en/icons/colorbars/NATIONAL.gif"/></LegendURL></Style></StyleList></Layer><Layer queryable="1" hidden="0"><Server service="OGC:WMS" version="1.1.1" title="Canada Centre for Remote Sensing Web Map Service"><OnlineResource xlink:type="simple" xlink:href="http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi"/></Server><Name>EOS_DATA_GATEWAYS:CEOWARE2</Name><Title>EOS Data Gateways</Title><Abstract>Locations of EOS Data Gateway Locations. The same services and data are available through each gateway location.</Abstract><sld:MinScaleDenominator>1000
 </sld:MinScaleDenominator><sld:MaxScaleDenominator>500000</sld:MaxScaleDenominator><SRS>EPSG:4326</SRS><FormatList><Format current="1">image/gif</Format><Format>image/png</Format><Format>image/jpeg</Format></FormatList><StyleList><Style current="1"><Name>default</Name><Title>default</Title><LegendURL width="16" height="16" format="image/gif"><OnlineResource xlink:type="simple" xlink:href="http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?version=1.1.1&amp;request=GetLegendGraphic&amp;layer=EOS_DATA_GATEWAYS:CEOWARE2&amp;style=default&amp;format=image/gif"/></LegendURL></Style><Style><SLD><Title>Default</Title><sld:StyledLayerDescriptor xmlns:ogc="http://www.opengis.net/ogc" xmlns:sld="http://www.opengis.net/sld" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd"><sld:NamedLayer><sld:Name>AAA212</sld:Name><sld:UserStyle><sld:Fe
 atureTypeStyle><sld:Rule><sld:TextSymbolizer><sld:Label><ogc:PropertyName>ZONENR</ogc:PropertyName></sld:Label><sld:Font><sld:CssParameter name="font-family">Arial</sld:CssParameter><sld:CssParameter name="font-size">10</sld:CssParameter></sld:Font><sld:Fill><sld:CssParameter name="fill">#FF9900</sld:CssParameter></sld:Fill></sld:TextSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor></SLD></Style><Style><SLD><Title>Default</Title><sld:FeatureTypeStyle xmlns:ogc="http://www.opengis.net/ogc" xmlns:sld="http://www.opengis.net/sld" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd"><sld:Rule><sld:TextSymbolizer><sld:Label><PropertyName>ZONENR</PropertyName></sld:Label><sld:Font><sld:CssParameter name="font-family">Arial</sld:CssParameter><sld:CssParameter name="font-size">10</sld:CssParame
 ter></sld:Font><sld:Fill><sld:CssParameter name="fill">#FF9900</sld:CssParameter></sld:Fill></sld:TextSymbolizer></sld:Rule></sld:FeatureTypeStyle></SLD></Style></StyleList></Layer></LayerList></ViewContext>';
     function test_Format_WMC_read(t) {
-        t.plan(37);
+        t.plan(64);
         var format = new OpenLayers.Format.WMC();
         var map, layer;
@@ -104,6 +105,89 @@
             "mapOptions correctly passed to the created map object");
         map.destroy();
+        map = format.read(fulldoc, {map: "map"});
+        var meta = map.metadata;
+        // Check if ContextInformation is set properly
+        var cinfo = meta.contactInformation;
+        t.eq(cinfo.personPrimary.person,       "Tom Kralidis",       "got correct person");
+        t.eq(cinfo.personPrimary.organization, "Environment Canada", "got correct organization");
+        t.eq(cinfo.contactAddress.address,     "867 Lakeshore Road", "got correct address");
+        t.eq(cinfo.contactAddress.city,        "Burlington",         "got correct city");
+        t.eq(cinfo.contactAddress.country,     "Canada",             "got correct country");
+        t.eq(cinfo.contactAddress.postcode,    "L7R 4A6",            "got correct postcode");
+        t.eq(cinfo.contactAddress.stateOrProvince, "Ontario",        "got correct stateOrProvince");
+        t.eq(cinfo.contactAddress.type,        "postal",             "got correct address type");
+        t.eq(cinfo.email,    "tom.kralidis at ec.gc.ca", "got correct email");
+        t.eq(cinfo.fax,      "+01-905-336-4499",      "got correct fax number");
+        t.eq(cinfo.phone,    "+01-905-336-4409",      "got correct phone number");
+        t.eq(cinfo.position, "Systems Scientist",     "got correct position");
+        // Check if LogoURL is read properly
+        var logo = meta.logo;
+        t.eq(logo, {
+                href: "http://redhook.gsfc.nasa.gov/~imswww/pub/icons/logo.gif",
+                width: "130",
+                height: "74",
+                format: "image/gif"},
+            "got currect logo");
+        t.eq(meta.descriptionURL, "http://eos.nasa.gov/imswelcome", "got correct descriptionURL");
+        t.eq(meta.keywords,
+             ["EOS", "EOSDIS", "NASA", "CCRS", "CEOS", "OGC"],
+             "got correct keywords");
+        layer = map.layers[1];
+        t.eq(layer.metadata.servertitle,
+             "The GLOBE Program Visualization Server",
+             "got correct title for server");
+        t.eq(layer.srs,
+             {"EPSG:4326": true, "EPSG:900913": true},
+             "SRS read correctly");
+        t.eq(layer.metadata.formats,
+             [{value: "image/gif", current: true},
+              {value: "image/png"}],
+             "formats read correctly");
+        var style = layer.metadata.styles[0];
+        t.eq(style.legend, {
+                href: "http://globe.digitalearth.gov/globe/en/icons/colorbars/COASTLINES.gif",
+                width: "180",
+                height: "50",
+            "got currect legend");
+        var dim = layer.dimensions["time"];
+        t.eq(dim.name, "time", "got correct name of dimension");
+        t.eq(dim.units, "ISO8601", "got correct units for dimension");
+        t.eq(dim.nearestValue, true, "got correct value for nearestValue");
+        t.eq(dim.values, ["2011-03-31", "2011-04-01"], "got correct values for dimension");
+        layer = map.layers[2];
+        t.eq(layer.metadata.dataURL,
+             "http://globe.digitalearth.gov/data/national.gml",
+             "got correct dataURL");
+        t.eq(layer.metadataURL,
+             "http://globe.digitalearth.gov/metadata/national.txt",
+             "got correct metadataURL");
+        layer = map.layers[3];
+        var sld_body = '<sld:StyledLayerDescriptor xmlns:ogc="http://www.opengis.net/ogc" xmlns:sld="http://www.opengis.net/sld" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd"><sld:NamedLayer><sld:Name>AAA212</sld:Name><sld:UserStyle><sld:FeatureTypeStyle><sld:Rule><sld:TextSymbolizer><sld:Label><ogc:PropertyName>ZONENR</ogc:PropertyName></sld:Label><sld:Font><sld:CssParameter name="font-family">Arial</sld:CssParameter><sld:CssParameter name="font-size">10</sld:CssParameter></sld:Font><sld:Fill><sld:CssParameter name="fill">#FF9900</sld:CssParameter></sld:Fill></sld:TextSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
+        var styles = layer.metadata.styles;
+        t.xml_eq(styles[1].body, sld_body, "StyledLayerDescriptor body read correctly");
+        sld_body = '<sld:FeatureTypeStyle xmlns:ogc="http://www.opengis.net/ogc" xmlns:sld="http://www.opengis.net/sld" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd"><sld:Rule><sld:TextSymbolizer><sld:Label><PropertyName xmlns="http://www.opengis.net/context">ZONENR</PropertyName></sld:Label><sld:Font><sld:CssParameter name="font-family">Arial</sld:CssParameter><sld:CssParameter name="font-size">10</sld:CssParameter></sld:Font><sld:Fill><sld:CssParameter name="fill">#FF9900</sld:CssParameter></sld:Fill></sld:TextSymbolizer></sld:Rule></sld:FeatureTypeStyle>';
+        t.xml_eq(styles[2].body, sld_body, "FeatureTypeStyle body read correctly");
     function test_Format_WMC_write(t) {
@@ -141,7 +225,7 @@
             t.plan(0);
             t.debug_print("WMC writing works but is not tested in Opera");
         } else {
-            t.plan(1);
+            t.plan(11);
             map = format.read(v1_1_0, {map: "map"});
             wmc = format.write(map);
@@ -149,7 +233,78 @@
                  "(v1.1.0) write gives what read got");
             map.destroy();
+            var parser = format.getParser("1.1.0");
+            var context = format.toContext(map);
+            // KeywordList
+            var expected = '<KeywordList xmlns="http://www.opengis.net/context"><Keyword>EOS</Keyword><Keyword>EOSDIS</Keyword><Keyword>NASA</Keyword><Keyword>CCRS</Keyword><Keyword>CEOS</Keyword><Keyword>OGC</Keyword></KeywordList>';
+            t.xml_eq(parser.write_wmc_KeywordList(context.keywords),
+                     expected,
+                     "keywordlist written correctly");
+            // ContactInformation
+            expected = '<ContactInformation xmlns="http://www.opengis.net/context"><ContactPersonPrimary><ContactPerson>Tom Kralidis</ContactPerson><ContactOrganization>Environment Canada</ContactOrganization></ContactPersonPrimary><ContactPosition>Systems Scientist</ContactPosition><ContactAddress><AddressType>postal</AddressType><Address>867 Lakeshore Road</Address><City>Burlington</City><StateOrProvince>Ontario</StateOrProvince><PostCode>L7R 4A6</PostCode><Country>Canada</Country></ContactAddress><ContactVoiceTelephone>+01-905-336-4409</ContactVoiceTelephone><ContactFacsimileTelephone>+01-905-336-4499</ContactFacsimileTelephone><ContactElectronicMailAddress>tom.kralidis at ec.gc.ca</ContactElectronicMailAddress></ContactInformation>';
+            t.xml_eq(parser.write_wmc_ContactInformation(context.contactInformation),
+                     expected,
+                     "contactInformation written correctly");
+            // LogoURL
+            expected = '<LogoURL xmlns="http://www.opengis.net/context" width="130" height="74" format="image/gif"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://redhook.gsfc.nasa.gov/~imswww/pub/icons/logo.gif"/></LogoURL>';
+            t.xml_eq(parser.write_wmc_URLType("LogoURL", context.logo.href, context.logo),
+                     expected,
+                     "LogoURL written correctly");
+            // DescriptionURL
+            expected = '<DescriptionURL xmlns="http://www.opengis.net/context"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://eos.nasa.gov/imswelcome"/></DescriptionURL>';
+            t.xml_eq(parser.write_wmc_URLType("DescriptionURL", context.descriptionURL),
+                     expected,
+                     "DescriptionURL written correctly");
+            var layerContext = context.layersContext[1];
+            // Server
+            expected = '<Server xmlns="http://www.opengis.net/context" service="OGC:WMS" version="1.1.1" title="The GLOBE Program Visualization Server"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://globe.digitalearth.gov/viz-bin/wmt.cgi"/></Server>';
+            t.xml_eq(parser.write_wmc_Server(layerContext),
+                     expected,
+                     "Server written correctly");
+            // FormatList
+            expected = '<FormatList xmlns="http://www.opengis.net/context"><Format current="1">image/gif</Format><Format>image/png</Format></FormatList>';
+            t.xml_eq(parser.write_wmc_FormatList(layerContext),
+                     expected,
+                     "FormatList written correctly");
+            // DimensionList
+            expected = '<DimensionList xmlns="http://www.opengis.net/context"><Dimension name="time" units="ISO8601" nearestValue="1" unitSymbol="" userValue="" multipleValues="0" current="0" default="">2011-03-31,2011-04-01</Dimension></DimensionList>';
+            t.xml_eq(parser.write_wmc_DimensionList(layerContext),
+                     expected,
+                     "DimensionList written correctly");
+            // LegendURL
+            var legend = layerContext.styles[0].legend;
+            expected = '<LegendURL xmlns="http://www.opengis.net/context" width="180" format="image/gif" height="50"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://globe.digitalearth.gov/globe/en/icons/colorbars/COASTLINES.gif"/></LegendURL>';
+            t.xml_eq(parser.write_wmc_URLType("LegendURL", legend.href, legend),
+                     expected,
+                     "LegendURL written correctly");
+            layerContext = context.layersContext[2];
+            // DataURL
+            expected = '<DataURL xmlns="http://www.opengis.net/context"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://globe.digitalearth.gov/data/national.gml" /></DataURL>';
+            t.xml_eq(parser.write_wmc_URLType("DataURL", layerContext.dataURL),
+                     expected,
+                     "DataURL written correctly");
+            // MetadataURL
+            expected = '<MetadataURL xmlns="http://www.opengis.net/context"><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://globe.digitalearth.gov/metadata/national.txt" /></MetadataURL>';
+            t.xml_eq(parser.write_wmc_URLType("MetadataURL", layerContext.metadataURL),
+                     expected,
+                     "MetadataURL written correctly");
     </script>
More information about the Commits mailing list
