[OpenLayers-Commits] r11904 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 21 18:07:18 EDT 2011
Author: tschaub
Date: 2011-04-21 15:07:17 -0700 (Thu, 21 Apr 2011)
New Revision: 11904
Removed:
   trunk/openlayers/examples/WMSPost.html
This example says it is deprecated (in favor of wms-long-url.html).  Removing examples of deprecated code will ease the eventual deprecated code removal.
Deleted: trunk/openlayers/examples/WMSPost.html
--- trunk/openlayers/examples/WMSPost.html	2011-04-21 22:05:02 UTC (rev 11903)
+++ trunk/openlayers/examples/WMSPost.html	2011-04-21 22:07:17 UTC (rev 11904)
@@ -1,181 +0,0 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
-  <head>
-    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
-    <meta name="apple-mobile-web-app-capable" content="yes" />
-    <title>OpenLayers Basic WMS Example via HTTP-POST protocol</title>
-    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-    <link rel="stylesheet" href="style.css" type="text/css" />
-    <script src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        var map;
-        function init(){
-            var sld = '<StyledLayerDescriptor version="1.0.0">';
-                sld+= '<NamedLayer>';
-                sld+= '<Name>topp:tasmania_roads</Name>';
-                sld+= '<UserStyle>';
-                sld+= '<IsDefault>1</IsDefault>';
-                sld+= '<FeatureTypeStyle>';
-                sld+= '<Rule>';
-                sld+= '<LineSymbolizer>';
-                sld+= '<Stroke>';
-                sld+= '<CssParameter name="stroke">';
-                sld+= '<Literal>#787878</Literal>';
-                sld+= '</CssParameter>';
-                sld+= '<CssParameter name="stroke-width">';
-                sld+= '<Literal>2</Literal>';
-                sld+= '</Stroke>';
-                sld+= '</LineSymbolizer>';
-                sld+= '</Rule>';
-                sld+= '</FeatureTypeStyle>';
-                sld+= '</UserStyle>';
-                sld+= '</NamedLayer>';
-                sld+= '<Name>topp:tasmania_water_bodies</Name>';
-                sld+= '<Rule>';
-                sld+= '<Stroke>';
-                sld+= '<Literal>#4F94CD</Literal>';
-                sld+= '<Literal>3</Literal>';
-                sld+= '<PolygonSymbolizer>';
-                sld+= '<Fill>';
-                sld+= '<CssParameter name="fill">';
-                sld+= '<Literal>#63B8FF</Literal>';
-                sld+= '</Fill>';
-                sld+= '</PolygonSymbolizer>';
-                sld+= '</Rule>';
-                sld+= '<Name>topp:tasmania_cities</Name>';
-                sld+= '<Rule>';
-                sld+= '<PointSymbolizer>';
-                sld+= '<Graphic>';
-                sld+= '<Mark>';
-                sld+= '<WellKnownName>cross</WellKnownName>';
-                sld+= '<Fill>';
-                sld+= '<Literal>#00FF00</Literal>';
-                sld+= '</Fill>';
-                sld+= '</Mark>';
-                sld+= '<Size>15</Size>';
-                sld+= '</Graphic>';
-                sld+= '</PointSymbolizer>';
-                sld+= '<TextSymbolizer>';
-                sld+= '<Label><PropertyName>CITY_NAME</PropertyName></Label>';
-                sld+= '<Font>';
-                sld+= '<SvgParameter name="font-size">15</SvgParameter>';
-                sld+= '</Font>';
-                sld+= '</TextSymbolizer>';
-                sld+= '</Rule>';
-                sld+= '<Name>topp:tasmania_state_boundaries</Name>';
-                sld+= '<Rule>';
-                sld+= '<Fill>';
-                sld+= '<Literal>#8B8989</Literal>';
-                sld+= '<CssParameter name="fill-opacity">';
-                sld+= '<Literal>0.2</Literal>';
-                sld+= '</Fill>';
-                sld+= '<Stroke>';
-                sld+= '<Literal>#FF4040</Literal>';
-                sld+= '</Rule>';
-                sld+= '</StyledLayerDescriptor>';
-            map = new OpenLayers.Map('map');
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
-            var layer = new OpenLayers.Layer.WMS(
-                "OpenLayers WMS",
-                "http://vmap0.tiles.osgeo.org/wms/vmap0",
-                    layers: 'basic'
-            var rcbw = new OpenLayers.Layer.WMS.Post("Roads, Cities, Boundaries, Water",
-                "http://demo.opengeo.org/geoserver/wms",
-                    'layers': 'topp:tasmania_roads,topp:tasmania_water_bodies,topp:tasmania_state_boundaries,topp:tasmania_cities',
-                    transparent: true,
-                    format: 'image/jpeg',
-                    sld_body: sld
-                    isBaseLayer: false,
-                    unsupportedBrowsers: []
-            map.addLayers([layer, rcbw]);
-            map.setCenter(new OpenLayers.LonLat(146.65748632815,-42.230763671875), 7);
-    </script>
-  </head>
-  <body onload="init()">
-    <h1 id="title">Basic WMS Example via HTTP-POST protocol with a large SLD
-    included</h1>
-    <div id="tags">
-        sld, advanced
-    </div>
-    <div id="shortdesc">Creating a WMS layer with a large SLD in the sld_body</div>
-    <div id="map" style="width: 512; height: 256; border: 1px solid red;"></div>
-    <div id="docs">
-        <p><b>Deprecated.</b> See <a href="wms-long-url.html">wms-long-url.html</a>
-            for the recommended way to avoid long URLs.</p><p>
-        This example uses a large SLD created on the client side to style a WMS
-        layer.  This example uses a WMS.Post layer which transfers data via the
-        HTTP-POST protocol. <br>
-        NOTE: Opera is not able to display transparent tiles with this layer,
-        and in some Firefox browsers can appear ugly viewport-shaking effects
-        while dragging arround. Use the 'unsupportedBrowsers' property to
-        control which browsers should use plain image tiles (like Layer.WMS)
-        instead. The default setting (["mozilla", "firefox", "opera"])
-        excludes problematic browsers without removing the ability to use long
-        request parameters, because all these browsers support long urls via
-        GET.</p>
-    </div>
-  </body>
-</html>
More information about the Commits mailing list
