[OpenLayers-Commits] r11908 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 21 19:04:39 EDT 2011
Author: tschaub
Date: 2011-04-21 16:04:39 -0700 (Thu, 21 Apr 2011)
New Revision: 11908
Removed:
   trunk/openlayers/examples/custom-control-point.html
The 'new OpenLayers.Map()' syntax used in this exmaple doesn't work.  Correcting that, it is still unclear if the example works.  I'm removing it to avoid confusion by others.
Deleted: trunk/openlayers/examples/custom-control-point.html
--- trunk/openlayers/examples/custom-control-point.html	2011-04-21 22:44:31 UTC (rev 11907)
+++ trunk/openlayers/examples/custom-control-point.html	2011-04-21 23:04:39 UTC (rev 11908)
@@ -1,59 +0,0 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
-  <head>
-    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
-    <meta name="apple-mobile-web-app-capable" content="yes" />
-    <title>OpenLayers Custom Control Point Examle</title>
-    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-    <link rel="stylesheet" href="style.css" type="text/css" />
-    <script src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        var lon = 5;
-        var lat = 40;
-        var zoom = 5;
-        var map, layer;
-        function init(){
-            map = new OpenLayers.Map( $('map') );
-            layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-                    "http://vmap0.tiles.osgeo.org/wms/vmap0", {layers: 'basic'} );
-            var control = new OpenLayers.Control();
-            OpenLayers.Util.extend(control, {
-                draw: function () {
-                    // this Handler.Point will intercept the shift-mousedown
-                    // before Control.MouseDefault gets to see it
-                    this.point = new OpenLayers.Handler.Point( control,
-                        {"done": this.notice},
-                        {keyMask: OpenLayers.Handler.MOD_SHIFT});
-                    this.point.activate();
-                notice: function (bounds) {
-                    document.getElementById('bounds').innerHTML = bounds;
-            map.addLayer(layer);
-            map.addControl(control);
-            map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
-    </script>
-  </head>
-  <body onload="init()">
-      <h1 id="title">Custom Control Point Example</h1>
-      <div id="tags">
-        control, point, cleanup
-      </div>
-      <p id="shortdesc">
-          Demonstrate the addition of a point reporting control to the OpenLayers window.
-      </p>
-    <div id="map" class="smallmap"></div>
-    <div id="bounds"></div>
-    <div id="docs"></div>
-  </body>
-</html>
More information about the Commits mailing list
