[OpenLayers-Commits] r11916 - sandbox/elemoine/3272/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Apr 27 05:21:13 EDT 2011
Author: erilem
Date: 2011-04-27 02:21:12 -0700 (Wed, 27 Apr 2011)
New Revision: 11916
   sandbox/elemoine/3272/build/OpenLayers.js
update OpenLayers.js build
Modified: sandbox/elemoine/3272/build/OpenLayers.js
--- sandbox/elemoine/3272/build/OpenLayers.js	2011-04-27 09:20:20 UTC (rev 11915)
+++ sandbox/elemoine/3272/build/OpenLayers.js	2011-04-27 09:21:12 UTC (rev 11916)
@@ -504,34 +504,34 @@
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
 this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(control,callbacks,optio
 ns){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,dblclickTolerance:"ontouchend"in document?20:0,touch:false,lastTouchPx:n
 ull,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
 OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
 var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);this.createFeature();return true;},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
 this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
 this.cancel(true);if(this.layer.map!=null){this.destroyFeature();this.layer.destroy(false);}
 this.layer=null;this.touch=false;return true;},destroyFeature:function(){if(this.layer){this.layer.destroyFeatures();}
-this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finishTouchGeometry:function(){this.finalize();},finalize:function(cancel,noNew){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}
+this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel,noNew){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}
 if(!noNew&&this.active){this.createFeature();}},cancel:function(noNew){this.finalize(true,noNew);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
 return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
 this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
 this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
 return true;},up:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
-if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
+if(this.lastUp&&this.passesTolerance(this.lastUp,evt.xy,this.dblclickTolerance)){return true;}
 if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
 if(this.persist){this.destroyPersistedFeature();}
 this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
-return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
+return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,freehand:false,freehandToggle:'shiftKey',timerId:null,acceptDblclick:false,initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
 this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[th
 is.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
-return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;this.mouseDown=false;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
+return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.dblclickTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;this.mouseDown=false;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
 this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;}
 if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
-this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+this.mouseDown=true;this.lastDown=evt.xy;this.acceptDblclick=false;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
 this.addPoint(evt.xy);return false;}
 if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy,!!this.lastUp);}
-return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+return true;},up:function(evt){if(this.mouseDown){var samePlace=this.lastUp&&this.passesTolerance(this.lastUp,evt.xy,this.dblclickTolerance);if(!samePlace){if(this.stoppedDown&&this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
 if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
-this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
-this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
+this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}else{this.acceptDblclick=true;}}
+this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){var accept=this.acceptDblclick||(this.lastUp&&this.passesTolerance(this.lastUp,evt.xy,this.dblclickTolerance));if(accept){this.finishGeometry();}}
 return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
 return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
 return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
More information about the Commits mailing list
