[OpenLayers-Commits] r11921 - in sandbox/elemoine/3272: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 28 02:04:11 EDT 2011
Author: erilem
Date: 2011-04-27 23:04:10 -0700 (Wed, 27 Apr 2011)
New Revision: 11921
   sandbox/elemoine/3272/lib/OpenLayers/Handler/Path.js
   sandbox/elemoine/3272/tests/Handler/Path.html
   sandbox/elemoine/3272/tests/Handler/Polygon.html
path handler - finishGeometry will reset mouseDown
Modified: sandbox/elemoine/3272/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/3272/lib/OpenLayers/Handler/Path.js	2011-04-28 06:03:59 UTC (rev 11920)
+++ sandbox/elemoine/3272/lib/OpenLayers/Handler/Path.js	2011-04-28 06:04:10 UTC (rev 11921)
@@ -255,8 +255,6 @@
             this.finishGeometry();
             window.clearTimeout(this.timerId);
             this.timerId = null;
-            // set mouseDown to false for up() to do nothing
-            this.mouseDown = false;
             return false;
         } else {
             if (this.timerId) {
Modified: sandbox/elemoine/3272/tests/Handler/Path.html
--- sandbox/elemoine/3272/tests/Handler/Path.html	2011-04-28 06:03:59 UTC (rev 11920)
+++ sandbox/elemoine/3272/tests/Handler/Path.html	2011-04-28 06:04:10 UTC (rev 11921)
@@ -817,7 +817,7 @@
     // a) tap
     // c) doubletap
     function test_touch_sequence1(t) {
-        t.plan(17);
+        t.plan(19);
         // set up
@@ -886,6 +886,10 @@
                 new OpenLayers.Geometry.Point(-149, 75),  // (1, 0)
                 new OpenLayers.Geometry.Point(-140, 65)   // (10, 10)
             ]), "[touchstart] final geometry is correct");
+        log = null;
+        ret = handler.touchend({});
+        t.ok(ret, '[touchend] event propagates');
+        t.eq(log, null, '[touchend] feature not finalized or modified');
         // tear down
@@ -896,7 +900,7 @@
     // b) tap-move
     // c) doubletap
     function test_touch_sequence2(t) {
-        t.plan(23);
+        t.plan(25);
         // set up
@@ -977,6 +981,10 @@
+        log = null;
         // tear down
Modified: sandbox/elemoine/3272/tests/Handler/Polygon.html
--- sandbox/elemoine/3272/tests/Handler/Polygon.html	2011-04-28 06:03:59 UTC (rev 11920)
+++ sandbox/elemoine/3272/tests/Handler/Polygon.html	2011-04-28 06:04:10 UTC (rev 11921)
@@ -906,7 +906,7 @@
     // b) tap
     // c) doubletap
-        t.plan(24);
+        t.plan(26);
         // set up
@@ -992,6 +992,10 @@
             ]), "[touchstart] geometry is correct");
+        log = null;
         // tear down
@@ -1003,7 +1007,7 @@
     // c) tap
     // d) doubletap
-        t.plan(30);
+        t.plan(32);
         // set up
@@ -1101,6 +1105,10 @@
+        log = null;
         // tear down
More information about the Commits mailing list
