[OpenLayers-Commits] r11923 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 28 03:09:03 EDT 2011
Author: pgiraud
Date: 2011-04-28 00:09:01 -0700 (Thu, 28 Apr 2011)
New Revision: 11923
   trunk/openlayers/lib/OpenLayers/Handler/Box.js
   trunk/openlayers/tests/Handler/Box.html
Don't put the box under the cursor until the mouse moved, prevent errors with the GetFeature and click events. I also removed the no longer valid (and failing) tests. r=elemoine, (Closes #2993)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Box.js
--- trunk/openlayers/lib/OpenLayers/Handler/Box.js	2011-04-28 06:04:47 UTC (rev 11922)
+++ trunk/openlayers/lib/OpenLayers/Handler/Box.js	2011-04-28 07:09:01 UTC (rev 11923)
@@ -99,11 +99,6 @@
         this.map.eventsDiv.appendChild(this.zoomBox);
-        var offset = this.getBoxOffsets();
-        var pos = this.dragHandler.start;
-        this.zoomBox.style.left = (pos.x - offset.left) + "px";
-        this.zoomBox.style.top = (pos.y - offset.top) + "px";
         OpenLayers.Element.addClass(
             this.map.eventsDiv, "olDrawBox"
Modified: trunk/openlayers/tests/Handler/Box.html
--- trunk/openlayers/tests/Handler/Box.html	2011-04-28 06:04:47 UTC (rev 11922)
+++ trunk/openlayers/tests/Handler/Box.html	2011-04-28 07:09:01 UTC (rev 11923)
@@ -39,7 +39,7 @@
         map.div.removeChild(testdiv);
         var testAll = !isNaN(left);
-        t.plan(testAll ? 12 : 2);
+        t.plan(testAll ? 10 : 2);
         // we change NaN values to 0 values in the handler's
         // boxOffsets object, this is to prevent "invalid
@@ -58,14 +58,10 @@
         handler.dragHandler.start = {x: 5, y: 5};
         handler.startBox();
         offset = handler.getBoxOffsets();
+        handler.moveBox({x: 10, y: 10});
         if (testAll) {
             t.eq(parseInt(handler.zoomBox.style.left), 5 - offset.left, "x position of box correct");
             t.eq(parseInt(handler.zoomBox.style.top), 5 - offset.top, "y position of box correct");
-        handler.moveBox({x: 10, y: 10});
-        if (testAll) {
-            t.eq(parseInt(handler.zoomBox.style.left), 5 - offset.left, "x position of box still correct");
-            t.eq(parseInt(handler.zoomBox.style.top), 5 - offset.top, "y position of box still correct");
             t.eq(parseInt(handler.zoomBox.style.width), 5 + offset.width + 1, "x dimension of box correct");
             t.eq(parseInt(handler.zoomBox.style.height), 5 + offset.height + 1, "y dimension of box correct");
More information about the Commits mailing list
