[OpenLayers-Commits] r12205 - in trunk/openlayers: lib/OpenLayers/Renderer tests/Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 3 11:47:07 EDT 2011
Author: fredj
Date: 2011-08-03 08:47:06 -0700 (Wed, 03 Aug 2011)
New Revision: 12205
   trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js
   trunk/openlayers/tests/Renderer/Canvas.html
handle features with null bounds in OpenLayers.Renderer.Canvas.drawFeature. p=arublev,me r=erilem (closes #3442)
Modified: trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js
--- trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-08-03 14:39:55 UTC (rev 12204)
+++ trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-08-03 15:47:06 UTC (rev 12205)
@@ -140,8 +140,9 @@
         if (feature.geometry) {
             style = this.applyDefaultSymbolizer(style || feature.style);
             // don't render if display none or feature outside extent
-            rendered = (style.display !== "none") &&
-                feature.geometry.getBounds().intersectsBounds(this.extent);
+            var bounds = feature.geometry.getBounds();
+            rendered = (style.display !== "none") && !!bounds &&
+                bounds.intersectsBounds(this.extent);
             if (rendered) {
                 // keep track of what we have rendered for redraw
                 this.features[feature.id] = [feature, style];
Modified: trunk/openlayers/tests/Renderer/Canvas.html
--- trunk/openlayers/tests/Renderer/Canvas.html	2011-08-03 14:39:55 UTC (rev 12204)
+++ trunk/openlayers/tests/Renderer/Canvas.html	2011-08-03 15:47:06 UTC (rev 12205)
@@ -123,7 +123,7 @@
             return;
-        t.plan(8);
+        t.plan(10);
         var layer = new OpenLayers.Layer.Vector(null, {
             isBaseLayer: true,
             renderers: ["Canvas"]
@@ -183,6 +183,15 @@
         t.eq(count, 1, "d) redraw is called when drawing a feature outside renderer extent");
         renderer.clear();
+        // e) draw a polygon feature without bounds
+        count = 0;
+        exp = renderer.drawFeature(
+            new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon()), {}
+        t.eq(exp, false, "d) drawFeature returns false");
+        t.eq(count, 1, "d) redraw is called when drawing a feature without bounds");
+        renderer.clear();
         map.destroy();
More information about the Commits mailing list
