[OpenLayers-Commits] r12207 - trunk/openlayers/lib/OpenLayers/Lang
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Aug 5 03:51:21 EDT 2011
Author: fredj
Date: 2011-08-05 00:51:20 -0700 (Fri, 05 Aug 2011)
New Revision: 12207
   trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js
   trunk/openlayers/lib/OpenLayers/Lang/br.js
   trunk/openlayers/lib/OpenLayers/Lang/ca.js
   trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js
   trunk/openlayers/lib/OpenLayers/Lang/da-DK.js
   trunk/openlayers/lib/OpenLayers/Lang/de.js
   trunk/openlayers/lib/OpenLayers/Lang/en.js
   trunk/openlayers/lib/OpenLayers/Lang/es.js
   trunk/openlayers/lib/OpenLayers/Lang/fi.js
   trunk/openlayers/lib/OpenLayers/Lang/fr.js
   trunk/openlayers/lib/OpenLayers/Lang/gl.js
   trunk/openlayers/lib/OpenLayers/Lang/gsw.js
   trunk/openlayers/lib/OpenLayers/Lang/hr.js
   trunk/openlayers/lib/OpenLayers/Lang/hsb.js
   trunk/openlayers/lib/OpenLayers/Lang/hu.js
   trunk/openlayers/lib/OpenLayers/Lang/ia.js
   trunk/openlayers/lib/OpenLayers/Lang/id.js
   trunk/openlayers/lib/OpenLayers/Lang/is.js
   trunk/openlayers/lib/OpenLayers/Lang/it.js
   trunk/openlayers/lib/OpenLayers/Lang/ja.js
   trunk/openlayers/lib/OpenLayers/Lang/ksh.js
   trunk/openlayers/lib/OpenLayers/Lang/lt.js
   trunk/openlayers/lib/OpenLayers/Lang/nb.js
   trunk/openlayers/lib/OpenLayers/Lang/nds.js
   trunk/openlayers/lib/OpenLayers/Lang/nl.js
   trunk/openlayers/lib/OpenLayers/Lang/oc.js
   trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js
   trunk/openlayers/lib/OpenLayers/Lang/pt.js
   trunk/openlayers/lib/OpenLayers/Lang/ru.js
   trunk/openlayers/lib/OpenLayers/Lang/sk.js
   trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js
   trunk/openlayers/lib/OpenLayers/Lang/vi.js
   trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js
   trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js
remove 'sameProjection' from Lang/*.js (not used, see r7864). Non-functional change.
Modified: trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js
--- trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "Базавы слой",
-    'sameProjection': "Аглядная мапа працуе толькі калі яна мае тую ж праекцыю, што і асноўная мапа",
     'readNotImplemented': "Функцыянальнасьць чытаньня ня створаная.",
     'writeNotImplemented': "Функцыянальнасьць запісу ня створаная.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/br.js
--- trunk/openlayers/lib/OpenLayers/Lang/br.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/br.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Gwiskad diazez",
-    'sameProjection': "Ne\'z ar gartenn lec\'hiañ en-dro nemet pa vez heñvel ar banndres anezhi ha hini ar gartenn bennañ",
     'readNotImplemented': "N\'eo ket emplementet al lenn.",
     'writeNotImplemented': "N\'eo ket emplementet ar skrivañ.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/ca.js
--- trunk/openlayers/lib/OpenLayers/Lang/ca.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/ca.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Capa Base",
-    'sameProjection':
-        "El mapa de referència només funciona si té la mateixa projecció que el mapa principal",
     'readNotImplemented': "Lectura no implementada.",
     'writeNotImplemented': "Escriptura no implementada.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js
--- trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Podkladové vrstvy",
-    'sameProjection': "Přehledka pracuje správně pouze tehdy, pokud je ve stejné projekci jako hlavní mapa",
     'readNotImplemented': "Read není implementováno.",
     'writeNotImplemented': "Write není implementováno.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/da-DK.js
--- trunk/openlayers/lib/OpenLayers/Lang/da-DK.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/da-DK.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Baggrundslag",
-    'sameProjection':
-        "Oversigtskortet fungerer kun når det har samme projektion som hovedkortet",
     'readNotImplemented': "Læsning er ikke implementeret.",
     'writeNotImplemented': "Skrivning er ikke implementeret.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/de.js
--- trunk/openlayers/lib/OpenLayers/Lang/de.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/de.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -24,8 +24,6 @@
     'Base Layer': "Grundkarte",
-    'sameProjection': "Die Übersichtskarte funktioniert nur, wenn sie dieselbe Projektion wie die Hauptkarte verwendet",
     'readNotImplemented': "Lesen nicht implementiert.",
     'writeNotImplemented': "Schreiben nicht implementiert.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/en.js
--- trunk/openlayers/lib/OpenLayers/Lang/en.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/en.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Base Layer",
-    'sameProjection':
-        "The overview map only works when it is in the same projection as the main map",
     'readNotImplemented': "Read not implemented.",
     'writeNotImplemented': "Write not implemented.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/es.js
--- trunk/openlayers/lib/OpenLayers/Lang/es.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/es.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
-    'sameProjection':
-        "El mapa de vista general sólo funciona si está en la misma proyección que el mapa principal",
     'writeNotImplemented': "Escritura no implementada.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/fi.js
--- trunk/openlayers/lib/OpenLayers/Lang/fi.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/fi.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -21,8 +21,6 @@
     'Base Layer': "Peruskerros",
-    'sameProjection': "Yleiskuvakarttaa voi käyttää vain, kun sillä on sama projektio kuin pääkartalla.",
     'W': "L",
     'E': "I",
Modified: trunk/openlayers/lib/OpenLayers/Lang/fr.js
--- trunk/openlayers/lib/OpenLayers/Lang/fr.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/fr.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "Calque de base",
-    'sameProjection': "La carte de situation ne fonctionne que lorsque sa projection est la même que celle de la carte principale",
     'readNotImplemented': "Lecture non implémentée.",
     'writeNotImplemented': "Ecriture non implémentée.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/gl.js
--- trunk/openlayers/lib/OpenLayers/Lang/gl.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/gl.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Capa base",
-    'sameProjection': "A vista xeral do mapa só funciona cando está na mesma proxección có mapa principal",
     'readNotImplemented': "Lectura non implementada.",
     'writeNotImplemented': "Escritura non implementada.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/gsw.js
--- trunk/openlayers/lib/OpenLayers/Lang/gsw.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/gsw.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Grundcharte",
-    'sameProjection': "D Ibersichts-Charte funktioniert nume, wänn si di glych Projäktion brucht wie d Hauptcharte",
     'readNotImplemented': "Läse nit implementiert.",
     'writeNotImplemented': "Schrybe nit implementiert.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/hr.js
--- trunk/openlayers/lib/OpenLayers/Lang/hr.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/hr.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Osnovna karta",
-    'sameProjection': "Pregledna karta radi jedino kao je u istoj projekciji kao i glava karta",
     'readNotImplemented': "Čitanje nije implementirano.",
     'writeNotImplemented': "Pisanje nije implementirano.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/hsb.js
--- trunk/openlayers/lib/OpenLayers/Lang/hsb.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/hsb.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Zakładna runina",
-    'sameProjection': "Přehladowa karta jenož funguje, hdyž je w samsnej projekciji kaž hłowna karta",
     'readNotImplemented': "Čitanje njeimplementowane.",
     'writeNotImplemented': "Pisanje njeimplementowane.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/hu.js
--- trunk/openlayers/lib/OpenLayers/Lang/hu.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/hu.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "Alapréteg",
-    'sameProjection': "Az áttekintő térkép csak abban az esetben működik, ha ugyanazon a vetületen van, mint a fő térkép.",
     'readNotImplemented': "Olvasás nincs végrehajtva.",
     'writeNotImplemented': "Írás nincs végrehajtva.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/ia.js
--- trunk/openlayers/lib/OpenLayers/Lang/ia.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/ia.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Strato de base",
-    'sameProjection': "Le mini-carta functiona solmente si illo es in le mesme projection que le carta principal",
     'readNotImplemented': "Lectura non implementate.",
     'writeNotImplemented': "Scriptura non implementate.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/id.js
--- trunk/openlayers/lib/OpenLayers/Lang/id.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/id.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "Lapisan Dasar",
-    'sameProjection': "Peta tinjauan hanya bekerja bila dalam proyeksi yang sama dengan peta utama",
     'readNotImplemented': "Membaca tidak diterapkan.",
     'writeNotImplemented': "Menyimpan tidak diterapkan.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/is.js
--- trunk/openlayers/lib/OpenLayers/Lang/is.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/is.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -20,8 +20,6 @@
     'Base Layer': "Grunnlag",
-    'sameProjection': "Yfirlitskortið virkar aðeins ef það er í sömu vörpun og aðalkortið",
     'readNotImplemented': "Skrifun er óútfærð.",
     'writeNotImplemented': "Lestur er óútfærður.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/it.js
--- trunk/openlayers/lib/OpenLayers/Lang/it.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/it.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Livello base",
-    'sameProjection':
-        "La mini mappa funziona solamente se ha la stessa proiezione della mappa principale",
     'readNotImplemented': "Lettura non implementata.",
     'writeNotImplemented': "Scrittura non implementata.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/ja.js
--- trunk/openlayers/lib/OpenLayers/Lang/ja.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/ja.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "基底レイヤー",
-    'sameProjection': "概観地図はメインの地図と同じ投影法をとる場合のみ機能します",
     'readNotImplemented': "読み込みは実装されていません。",
     'writeNotImplemented': "書き込みは実装されていません。",
Modified: trunk/openlayers/lib/OpenLayers/Lang/ksh.js
--- trunk/openlayers/lib/OpenLayers/Lang/ksh.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/ksh.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Jrund-Nivoh",
-    'sameProjection': "De Övverseeschs_Kaat deiht et bloß, wann se de sälve Projäxjuhn bruche deiht, wi de Houp_Kaat",
     'readNotImplemented': "„\x3ccode lang=\"en\"\x3eread\x3c/code\x3e“ is em Projramm nit fürjesinn.",
     'writeNotImplemented': "„\x3ccode lang=\"en\"\x3ewrite\x3c/code\x3e“ is em Projramm nit fürjesinn.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/lt.js
--- trunk/openlayers/lib/OpenLayers/Lang/lt.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/lt.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Pagrindinis sluoksnis",
-    'sameProjection':
-	"Apžvalginis žemėlapis veikia tik tada, kai jis yra tos pačios projekcijos kaip ir pagrindinis",
     'readNotImplemented': "Skaitymas nėra įgyvendintas.",
     'writeNotImplemented': "Rašymas nėra įgyvendintas.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/nb.js
--- trunk/openlayers/lib/OpenLayers/Lang/nb.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/nb.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "Bakgrunnskart",
-    'sameProjection':
-        "Oversiktskartet fungerer bare når det har samme projeksjon som hovedkartet",
     'readNotImplemented': "Lesing er ikke implementert.",
     'writeNotImplemented': "Skriving er ikke implementert.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/nds.js
--- trunk/openlayers/lib/OpenLayers/Lang/nds.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/nds.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Achtergrundkoort",
-    'sameProjection': "De Översichtskoort geiht blot, wenn de sülve Projekschoon as bi de Hööftkoort bruukt warrt",
     'readNotImplemented': "Lesen is nich inricht.",
     'writeNotImplemented': "Schrieven is nich inricht.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/nl.js
--- trunk/openlayers/lib/OpenLayers/Lang/nl.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/nl.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Achtergrondkaart",
-    'sameProjection': "De overzichtskaart werkt alleen als de projectie gelijk is aan de projectie van de hoofdkaart",
     'readNotImplemented': "Lezen is niet geïmplementeerd.",
     'writeNotImplemented': "Schrijven is niet geïmplementeerd.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/oc.js
--- trunk/openlayers/lib/OpenLayers/Lang/oc.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/oc.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Calc de basa",
-    'sameProjection': "La carta de situacion fonciona pas que quora sa projeccion es la meteissa que la de la carta principala",
     'readNotImplemented': "Lectura pas implementada.",
     'writeNotImplemented': "Escritura pas implementada.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js
--- trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -23,8 +23,6 @@
     'Base Layer': "Camada Base",
-    'sameProjection': "O mapa de referência só funciona quando ele está na mesma projeção do mapa principal",
     'readNotImplemented': "Leitura não implementada.",
     'writeNotImplemented': "Escrita não implementada.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/pt.js
--- trunk/openlayers/lib/OpenLayers/Lang/pt.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/pt.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -24,8 +24,6 @@
-    'sameProjection': "O mapa panorâmico só funciona quando está na mesma projeção que o mapa principal",
Modified: trunk/openlayers/lib/OpenLayers/Lang/ru.js
--- trunk/openlayers/lib/OpenLayers/Lang/ru.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/ru.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -25,8 +25,6 @@
     'Base Layer': "Основной слой",
-    'sameProjection': "Обзорная карта работает только тогда, когда имеет ту же проекцию, что и основная",
     'readNotImplemented': "Чтение не реализовано.",
     'writeNotImplemented': "Запись не реализована.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/sk.js
--- trunk/openlayers/lib/OpenLayers/Lang/sk.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/sk.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Základná vrstva",
-    'sameProjection': "Prehľadová mapka funguje iba vtedy, keď je v rovnakej projekcii ako hlavná mapa",
     'readNotImplemented': "Čítanie nie je implementované.",
     'writeNotImplemented': "Zápis nie je implementovaný.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js
--- trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Bakgrundskarta",
-    'sameProjection': "Översiktskartan fungerar endast när den har samma projektion som huvudkartan",
     'readNotImplemented': "Läsning ej implementerad.",
     'writeNotImplemented': "Skrivning ej implementerad.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/vi.js
--- trunk/openlayers/lib/OpenLayers/Lang/vi.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/vi.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -22,8 +22,6 @@
     'Base Layer': "Lớp nền",
-    'sameProjection': "Bản đồ toàn cảnh chỉ hoạt động khi cùng phép chiếu với bản đồ chính",
     'readNotImplemented': "Chưa hỗ trợ chức năng đọc.",
     'writeNotImplemented': "Chưa hỗ trợ chức năng viết.",
Modified: trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js
--- trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -18,9 +18,6 @@
     'Base Layer': "基础图层",
-    'sameProjection':
-        "鹰眼地图只有在和主地图使用相同的投影的时候才能正常共工作",
     'readNotImplemented': "读取功能没有实现。",
     'writeNotImplemented': "写入功能没有实现。",
Modified: trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js
--- trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js	2011-08-03 15:55:14 UTC (rev 12206)
+++ trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js	2011-08-05 07:51:20 UTC (rev 12207)
@@ -19,9 +19,6 @@
     'Base Layer': "基礎圖層",
-    'sameProjection':
-        "地圖縮覽(OverviewMap)只能在跟主地圖相同投影時起作用。",
     'readNotImplemented': "沒有實作讀取的功能。",
     'writeNotImplemented': "沒有實作寫入的功能。",
More information about the Commits mailing list
