[OpenLayers-Commits] r12216 - in trunk/openlayers: lib/OpenLayers/Protocol lib/OpenLayers/Protocol/WFS tests/Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Aug 8 09:23:01 EDT 2011
Author: ahocevar
Date: 2011-08-08 06:22:59 -0700 (Mon, 08 Aug 2011)
New Revision: 12216
   trunk/openlayers/lib/OpenLayers/Protocol/WFS.js
   trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
   trunk/openlayers/tests/Protocol/WFS.html
don't use null geometryName for WFS versions < 1.1. r=elemoine (closes #3415)
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-08-08 12:43:47 UTC (rev 12215)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-08-08 13:22:59 UTC (rev 12216)
@@ -43,7 +43,7 @@
      * Property: geometryName
      * {String} Name of the geometry attribute for features.  Default is
-     *     "the_geom".
+     *     "the_geom" for WFS <version> 1.0, and null for higher versions.
     geometryName: "the_geom",
@@ -102,19 +102,16 @@
      *     for this featureType).
      * featurePrefix - {String} Feature namespace alias (optional - only used
      *     for writing if featureNS is provided).  Default is 'feature'.
-     * geometryName - {String} Name of geometry attribute.  If featureNS is not
-     *     configured, the default is null to avoid failing on BBOX filters,
-     *     and it will be set on <read>. Otherwise, the default is 'the_geom'.
+     * geometryName - {String} Name of geometry attribute.  The default is
+     *     'the_geom' for WFS <version> 1.0, and null for higher versions. If
+     *     null, it will be set to the name of the first geometry found in the
+     *     first read operation.
      * multi - {Boolean} If set to true, geometries will be casted to Multi
      *     geometries before they are written in a transaction. No casting will
      *     be done when reading features.
     initialize: function(options) {
         OpenLayers.Protocol.prototype.initialize.apply(this, [options]);
-        if (!options.geometryName && !options.featureNS) {
-            // poorly configured protocol - try to not fail on BBOX filters
-            this.geometryName = null;
         if(!options.format) {
             this.format = OpenLayers.Format.WFST(OpenLayers.Util.extend({
                 version: this.version,
@@ -126,6 +123,9 @@
                 schema: this.schema
             }, this.formatOptions));
+        if (!options.geometryName && parseFloat(this.format.version) > 1.0) {
+            this.setGeometryName(null);
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS.js	2011-08-08 12:43:47 UTC (rev 12215)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS.js	2011-08-08 13:22:59 UTC (rev 12216)
@@ -47,7 +47,7 @@
  * This function is designed to auto-configure <url>, <featureType>,
  *     <featurePrefix> and <srsName> for WFS <version> 1.1.0. Note that
- *     srsName matching with the WMS layer will not work with WFS 1.0.0..
+ *     srsName matching with the WMS layer will not work with WFS 1.0.0.
  * Parameters:
  * layer - {<OpenLayers.Layer.WMS>} WMS layer that has a matching WFS
Modified: trunk/openlayers/tests/Protocol/WFS.html
--- trunk/openlayers/tests/Protocol/WFS.html	2011-08-08 12:43:47 UTC (rev 12215)
+++ trunk/openlayers/tests/Protocol/WFS.html	2011-08-08 13:22:59 UTC (rev 12216)
@@ -111,7 +111,8 @@
         var protocol = new OpenLayers.Protocol.WFS({
             url: "http://some.url.org",
             featurePrefix: "topp",
-            featureType: "tasmania_roads"
+            featureType: "tasmania_roads",
+            geometryName: null
         protocol.parseResponse({responseText: document.getElementById("query_response").firstChild.nodeValue});
@@ -299,7 +300,7 @@
     function test_fromWMSLayer(t) {
-        t.plan(8);
+        t.plan(9);
         var map = new OpenLayers.Map("map", {
             projection: "EPSG:1234"
@@ -313,6 +314,7 @@
         t.eq(protocol.featureType, "states", "typeName correctly extracted");
         t.eq(protocol.srsName, "EPSG:1234", "srsName set correctly");
         t.eq(protocol.version, "1.1.0", "version set correctly");
+        t.eq(protocol.format.geometryName, null, "format's geometryName set to null");
         layer.params["LAYERS"] = ["topp:street_centerline", "topp:states"];
         layer.projection = new OpenLayers.Projection("EPSG:900913");
More information about the Commits mailing list
