[OpenLayers-Commits] r12229 - in trunk/openlayers: lib/OpenLayers theme/default
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 10 04:28:49 EDT 2011
Author: ahocevar
Date: 2011-08-10 01:28:47 -0700 (Wed, 10 Aug 2011)
New Revision: 12229
   trunk/openlayers/lib/OpenLayers/Layer.js
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/theme/default/style.css
reverting r12228
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js	2011-08-10 08:04:53 UTC (rev 12228)
+++ trunk/openlayers/lib/OpenLayers/Layer.js	2011-08-10 08:28:47 UTC (rev 12229)
@@ -347,11 +347,8 @@
             this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
             this.div = OpenLayers.Util.createDiv(this.id);
-            var style = this.div.style;
-            style.width = "100%";
-            style.height = "100%";
-            style.overflow = "";
-            this.div.className = "olLayerDiv";
+            this.div.style.width = "100%";
+            this.div.style.height = "100%";
             this.div.dir = "ltr";
             if (this.opacity != null && this.opacity < 1) {
                 OpenLayers.Util.modifyDOMElement(
@@ -370,19 +367,6 @@
         if (this.wrapDateLine) {
             this.displayOutsideMaxExtent = true;
-        //TODO remove the if block below when we drop support for IE8.
-        if (parseInt(navigator.appVersion.split("MSIE")[1], 10) == 8) {
-            // Workaround for opacity handling in IE8 - also see
-            // .ie8-opacity-hack selectors in theme/default/style.css
-            this.events.register("loadend", this, function() {
-                var opacity = this.opacity;
-                if (opacity != null && opacity >= 0 && opacity < 1) {
-                    OpenLayers.Element.addClass(this.div, "ie8-opacity-hack");
-                    this.div.style.filter = "alpha(opacity=" + (opacity * 100) + ")";
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-08-10 08:04:53 UTC (rev 12228)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-08-10 08:28:47 UTC (rev 12229)
@@ -971,6 +971,8 @@
+        layer.div.className = "olLayerDiv";
+        layer.div.style.overflow = "";
         this.setLayerZIndex(layer, this.layers.length);
         if (layer.isFixed) {
Modified: trunk/openlayers/theme/default/style.css
--- trunk/openlayers/theme/default/style.css	2011-08-10 08:04:53 UTC (rev 12228)
+++ trunk/openlayers/theme/default/style.css	2011-08-10 08:28:47 UTC (rev 12229)
@@ -14,15 +14,6 @@
    -khtml-user-select: none;
-/* TODO remove the two style definitions below when we drop support for IE8 */
-div.olLayerDiv.ie8-opacity-hack {
-    width: 9999px !important;
-    height: 9999px !important;
-div.olLayerDiv.ie8-opacity-hack div, .ie8-opacity-hack img.olTileImage {
-    filter: inherit;
 .olLayerGoogleCopyright {
     left: 2px;
     bottom: 2px;
More information about the Commits mailing list
