[OpenLayers-Commits] r12231 - in trunk/openlayers: lib/OpenLayers lib/OpenLayers/Layer tests tests/Layer theme/default
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 10 04:35:29 EDT 2011
Author: ahocevar
Date: 2011-08-10 01:35:27 -0700 (Wed, 10 Aug 2011)
New Revision: 12231
   trunk/openlayers/lib/OpenLayers/Layer.js
   trunk/openlayers/lib/OpenLayers/Layer/Markers.js
   trunk/openlayers/lib/OpenLayers/Layer/WFS.js
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/tests/Layer.html
   trunk/openlayers/tests/Layer/ArcGIS93Rest.html
   trunk/openlayers/tests/Layer/MapServer.html
   trunk/openlayers/tests/Layer/Markers.html
   trunk/openlayers/tests/Layer/WFS.html
   trunk/openlayers/tests/Layer/WMS.html
   trunk/openlayers/theme/default/style.css
reverting r12228 and r12185 (closes #3431)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Markers.js
--- trunk/openlayers/lib/OpenLayers/Layer/Markers.js	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/lib/OpenLayers/Layer/Markers.js	2011-08-10 08:35:27 UTC (rev 12231)
@@ -60,6 +60,22 @@
         OpenLayers.Layer.prototype.destroy.apply(this, arguments);
+     * APIMethod: setOpacity
+     * Sets the opacity for all the markers.
+     * Parameter:
+     * opacity - {Float}
+    setOpacity: function(opacity) {
+        if (opacity != this.opacity) {
+            this.opacity = opacity;
+            for (var i=0, len=this.markers.length; i<len; i++) {
+                this.markers[i].setOpacity(this.opacity);
      * Method: moveTo
Modified: trunk/openlayers/lib/OpenLayers/Layer/WFS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WFS.js	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/lib/OpenLayers/Layer/WFS.js	2011-08-10 08:35:27 UTC (rev 12231)
@@ -590,5 +590,21 @@
         return extent;
+     * Call the setOpacity method of the appropriate parent class to set the
+     *     opacity.
+     * Parameter:
+    setOpacity: function (opacity) {
+        if (this.vectorMode) {
+            OpenLayers.Layer.Vector.prototype.setOpacity.apply(this, [opacity]);
+        } else {
+            OpenLayers.Layer.Markers.prototype.setOpacity.apply(this, [opacity]);
     CLASS_NAME: "OpenLayers.Layer.WFS"
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/lib/OpenLayers/Layer.js	2011-08-10 08:35:27 UTC (rev 12231)
@@ -347,17 +347,9 @@
             this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
             this.div = OpenLayers.Util.createDiv(this.id);
-            var style = this.div.style;
-            style.width = "100%";
-            style.height = "100%";
-            style.overflow = "";
-            this.div.className = "olLayerDiv";
+            this.div.style.width = "100%";
+            this.div.style.height = "100%";
             this.div.dir = "ltr";
-            if (this.opacity != null && this.opacity < 1) {
-                OpenLayers.Util.modifyDOMElement(
-                    this.div, null, null, null, null, null, null, this.opacity
             this.events = new OpenLayers.Events(this, this.div,
                                                 this.EVENT_TYPES);
@@ -370,19 +362,6 @@
         if (this.wrapDateLine) {
             this.displayOutsideMaxExtent = true;
-        //TODO remove the if block below when we drop support for IE8.
-        if (parseInt(navigator.appVersion.split("MSIE")[1], 10) == 8) {
-            // Workaround for opacity handling in IE8 - also see
-            // .ie8-opacity-hack selectors in theme/default/style.css
-            this.events.register("loadend", this, function() {
-                var opacity = this.opacity;
-                if (opacity != null && opacity >= 0 && opacity < 1) {
-                    OpenLayers.Element.addClass(this.div, "ie8-opacity-hack");
-                    this.div.style.filter = "alpha(opacity=" + (opacity * 100) + ")";
@@ -1291,8 +1270,11 @@
-            OpenLayers.Util.modifyDOMElement(this.div, null, null, null,
-                                             null, null, null, opacity);
+            for(var i=0, len=this.div.childNodes.length; i<len; ++i) {
+                var element = this.div.childNodes[i].firstChild;
+                OpenLayers.Util.modifyDOMElement(element, null, null, null,
+                                                 null, null, null, opacity);
             if (this.map != null) {
                 this.map.events.triggerEvent("changelayer", {
                     layer: this,
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-08-10 08:35:27 UTC (rev 12231)
@@ -971,6 +971,8 @@
+        layer.div.className = "olLayerDiv";
+        layer.div.style.overflow = "";
         this.setLayerZIndex(layer, this.layers.length);
         if (layer.isFixed) {
Modified: trunk/openlayers/tests/Layer/ArcGIS93Rest.html
--- trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -195,6 +195,31 @@
+    function test_Layer_AGS93_setOpacity (t) {
+        var params = {layers: "show:0,2"};
+        t.plan( 5 );
+        var map = new OpenLayers.Map('map');
+        map.projection = "xx";
+        tParams = { layers: 'show:0,2',
+                   format: 'png'};
+        tOptions = { 'opacity': '0.5' };
+        var tLayer = new OpenLayers.Layer.ArcGIS93Rest(name, url, tParams, tOptions);
+        map.addLayer(tLayer);
+        map.zoomToMaxExtent();
+        t.eq(tLayer.opacity, "0.5", "Opacity is set correctly");
+        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.5, "Opacity on tile is correct");
+        tLayer.setOpacity("0.6");
+        t.eq(tLayer.opacity, "0.6", "setOpacity works properly");
+        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.6, "Opacity on tile is changed correctly");
+        var pixel = new OpenLayers.Pixel(5,6);
+        var tile = tLayer.addTile(new OpenLayers.Bounds(1,2,3,4), pixel);
+        tile.draw();
+        t.eq(parseFloat(tile.imgDiv.style.opacity), 0.6, "Tile opacity is set correctly");
+        map.destroy();
     function test_Layer_AGS93_noGutters (t) {
         t.plan(2);
Modified: trunk/openlayers/tests/Layer/MapServer.html
--- trunk/openlayers/tests/Layer/MapServer.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer/MapServer.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -196,6 +196,31 @@
+    function test_Layer_MapServer_setOpacity (t) {
+        t.plan( 5 );
+        tUrl = "http://labs.metacarta.com/cgi-bin/mapserv";
+        tParams = { layers: 'basic',
+                   format: 'image/png'};
+        var tLayer = new OpenLayers.Layer.MapServer(name, tUrl, tParams, tOptions);
+        tile.draw();
+        map.destroy();
     function test_Layer_MapServer_Reproject (t) {
         var validkey = (window.location.protocol == "file:") ||
                        (window.location.host == "localhost") ||
@@ -386,6 +411,27 @@
+    function test_Layer_MapServer_Untiled_setOpacity (t) {
+        t.plan( 4 );
+        var tLayer = new OpenLayers.Layer.MapServer.Untiled(name, tUrl, tParams, tOptions);
+        map.destroy();
     // DEPRECATED -- REMOVE IN 3.0
     function test_Layer_Untiled_MapServer(t) {
         t.plan(1);
Modified: trunk/openlayers/tests/Layer/Markers.html
--- trunk/openlayers/tests/Layer/Markers.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer/Markers.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -121,6 +121,33 @@
+    function test_setOpacity(t) {
+        t.plan(1);
+        layer = new OpenLayers.Layer.Markers('Test Layer');
+        var opacity = 0.1234;
+        for (var i = 0; i < 12; i++) {
+            layer.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0), new OpenLayers.Icon()));
+        layer.setOpacity(opacity);
+        for (var i = 0; i < 4; i++) {
+        var itWorks = false;
+        for (var i = 0; i < layer.markers.length; i++) {
+            itWorks = parseFloat(layer.markers[i].icon.imageDiv.style.opacity) == opacity;
+            if (!itWorks) {
+                break;
+        t.ok(itWorks, "setOpacity change markers opacity");
   </script>
 </head>
 <body>
Modified: trunk/openlayers/tests/Layer/WFS.html
--- trunk/openlayers/tests/Layer/WFS.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer/WFS.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -25,6 +25,22 @@
+    function test_Layer_WFS_setOpacity(t) {
+        t.plan(3);
+        var layer = new OpenLayers.Layer.WFS(name, "url", {});
+        layer.setOpacity(.5);
+        t.eq(layer.opacity, 0.5, "vector setOpacity didn't fail");
+        var layer = new OpenLayers.Layer.WFS(name, "url", {}, {'featureClass': OpenLayers.Feature.WFS});
+        var marker = new OpenLayers.Marker(new OpenLayers.LonLat(0,0));
+        marker.setOpacity = function() {
+            t.ok(true, "Marker setOpacity was called");
+        layer.addMarker(marker);
+        layer.setOpacity(.6);
+        t.eq(layer.opacity, 0.6, "setOpacity didn't fail on markers");
     function test_Layer_WFS_destroy(t) {
         t.plan(13);
Modified: trunk/openlayers/tests/Layer/WMS.html
--- trunk/openlayers/tests/Layer/WMS.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer/WMS.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -281,6 +281,31 @@
+    function test_Layer_WMS_setOpacity (t) {
+        t.plan( 5 );
+        tUrl = "http://octo.metacarta.com/cgi-bin/mapserv";
+        var tLayer = new OpenLayers.Layer.WMS(name, tUrl, tParams, tOptions);
+        tile.draw();
+        map.destroy();
     function test_Layer_WMS_Reproject (t) {
Modified: trunk/openlayers/tests/Layer.html
--- trunk/openlayers/tests/Layer.html	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/tests/Layer.html	2011-08-10 08:35:27 UTC (rev 12231)
@@ -786,15 +786,14 @@
-        t.plan(8);
+        t.plan(5);
         var map, layer, log;
         map = new OpenLayers.Map("map");
-        layer = new OpenLayers.Layer("", {opacity: 0.56});
+        layer = new OpenLayers.Layer("");
         map.addLayer(layer);
-        t.eq(layer.div.style.opacity, "0.56", "initial opacity correctly applied as layer.div style");
         log = [];
         map.events.register('changelayer', t, function(event) {
             log.push({layer: event.layer, property: event.property});
@@ -802,7 +801,6 @@
         layer.setOpacity(0.42);
         t.eq(layer.opacity, 0.42,
              "setOpacity() set layer.opacity to correct value");
-        t.eq(layer.div.style.opacity, "0.42", "opacity correctly applied as layer.div style");
         t.eq(log.length, 1,
              "setOpacity() triggers changelayer once");
         t.ok(log[0].layer == layer,
@@ -815,12 +813,6 @@
         t.eq(log.length, 0,
              "setOpacity() does not trigger changelayer if the opacity value is the same");
-        // 0 as initial opacity
-        layer.destroy();
-        layer = new OpenLayers.Layer("", {opacity: 0});
-        map.addLayer(layer);
-        t.eq(layer.div.style.opacity, "0", "initial opacity correctly applied as layer.div style");
Modified: trunk/openlayers/theme/default/style.css
--- trunk/openlayers/theme/default/style.css	2011-08-10 08:29:31 UTC (rev 12230)
+++ trunk/openlayers/theme/default/style.css	2011-08-10 08:35:27 UTC (rev 12231)
@@ -14,15 +14,6 @@
    -khtml-user-select: none;
-/* TODO remove the two style definitions below when we drop support for IE8 */
-div.olLayerDiv.ie8-opacity-hack {
-    width: 9999px !important;
-    height: 9999px !important;
-div.olLayerDiv.ie8-opacity-hack div, .ie8-opacity-hack img.olTileImage {
-    filter: inherit;
 .olLayerGoogleCopyright {
     left: 2px;
     bottom: 2px;
More information about the Commits mailing list
