[OpenLayers-Commits] r12241 - in trunk/openlayers: examples lib
lib/OpenLayers lib/OpenLayers/Layer lib/OpenLayers/Tile
lib/OpenLayers/Tile/Image tests tests/Layer/WMS tests/Tile
tests/Tile/Image
commits-20090109 at openlayers.org
Fri Aug 12 20:59:02 EDT 2011
Author: ahocevar
Date: 2011-08-12 17:59:01 -0700 (Fri, 12 Aug 2011)
New Revision: 12241
Added:
trunk/openlayers/lib/OpenLayers/Tile/BackBufferable.js
trunk/openlayers/tests/Tile/BackBufferable.html
trunk/openlayers/examples/wms-long-url.js
trunk/openlayers/lib/OpenLayers.js
trunk/openlayers/lib/OpenLayers/Layer/Bing.js
trunk/openlayers/lib/OpenLayers/Tile.js
trunk/openlayers/lib/OpenLayers/Tile/Image.js
trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
trunk/openlayers/tests/Layer/WMS/Post.html
trunk/openlayers/tests/Tile.html
trunk/openlayers/tests/Tile/Image.html
trunk/openlayers/tests/Tile/Image/IFrame.html
trunk/openlayers/tests/list-tests.html
trunk/openlayers/tests/run-tests.html
Tile.Image improvements and partial rewrite. Thanks erilem for the excellent collaboration during the review phase. p=me,erilem r=erilem (closes #3419)
Modified: trunk/openlayers/examples/wms-long-url.js
--- trunk/openlayers/examples/wms-long-url.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/examples/wms-long-url.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -5,12 +5,12 @@
var base = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://vmap0.tiles.osgeo.org/wms/vmap0",
{layers: 'basic', makeTheUrlLong: longText},
- {tileOptions: {maxGetUrlLength: 2048}}
+ {tileOptions: {maxGetUrlLength: 2048}, transitionEffect: 'resize'}
var overlay = new OpenLayers.Layer.WMS("Overlay",
"http://suite.opengeo.org/geoserver/wms",
{layers: "usa:states", transparent: true, makeTheUrlLong: longText},
- {ratio: 1, singleTile: true, tileOptions: {maxGetUrlLength: 2048}}
+ {ratio: 1, singleTile: true, tileOptions: {maxGetUrlLength: 2048}, transitionEffect: 'resize'}
map.addLayers([base, overlay]);
map.zoomToMaxExtent();
Modified: trunk/openlayers/lib/OpenLayers/Layer/Bing.js
--- trunk/openlayers/lib/OpenLayers/Layer/Bing.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/lib/OpenLayers/Layer/Bing.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -159,7 +159,7 @@
getURL: function(bounds) {
if (!this.url) {
- return OpenLayers.Util.getImagesLocation() + "blank.gif";
+ return;
var xyz = this.getXYZ(bounds), x = xyz.x, y = xyz.y, z = xyz.z;
var quadDigits = [];
Added: trunk/openlayers/lib/OpenLayers/Tile/BackBufferable.js
--- trunk/openlayers/lib/OpenLayers/Tile/BackBufferable.js (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Tile/BackBufferable.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -0,0 +1,201 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Tile.js
+ * @requires OpenLayers/Util.js
+ * Class: OpenLayers.Tile.BackBufferable
+ * Base class for tiles that can have backbuffers during transitions. Do not
+ * create instances of this class.
+OpenLayers.Tile.BackBufferable = OpenLayers.Class(OpenLayers.Tile, {
+ * Property: backBufferMode
+ * {Integer} Bitmap: 0 for no backbuffering at all, 1 for singleTile
+ * layers, 2 for transition effect set, 3 for both.
+ backBufferMode: null,
+ * Property: backBufferData
+ * {Object} Object including the necessary data for the back
+ * buffer.
+ * The object includes three properties:
+ * tile - {DOMElement} The DOM element for the back buffer.
+ * bounds - {<OpenLayers.Bounds>} The bounds of the tile to back.
+ * resolution - {Number} The resolution of the tile to back.
+ backBufferData: null,
+ * Method: initialize
+ * Determines the backBuffer mode and registers events
+ initialize: function() {
+ OpenLayers.Tile.prototype.initialize.apply(this, arguments);
+ var transitionSupported = OpenLayers.Util.indexOf(
+ this.layer.SUPPORTED_TRANSITIONS,
+ this.layer.transitionEffect) != -1;
+ this.backBufferMode = (this.layer.singleTile && 1) |
+ (transitionSupported && 2);
+ this.backBufferData = {};
+ if (!this.size) {
+ this.size = new OpenLayers.Size(256, 256);
+ * Method: draw
+ * Check that a tile should be drawn, and draw it.
+ * Returns:
+ * {Boolean} Was a tile drawn?
+ draw: function() {
+ var draw = OpenLayers.Tile.prototype.shouldDraw.apply(this, arguments),
+ backBufferMode = this.backBufferMode;
+ if (draw) {
+ this.updateBackBuffer();
+ this.clear();
+ if (!draw) {
+ this.resetBackBuffer();
+ return draw;
+ * Method: getTile
+ * Get the tile's markup. To be implemented by subclasses.
+ * Returns:
+ * {DOMElement} The tile's markup
+ * Method: createBackBuffer
+ * Create a copy of this tile's markup for the back buffer. To be
+ * implemented by subclasses.
+ * Returns:
+ * {DOMElement} A copy of the tile's markup.
+ * Method: setBackBufferData
+ * Stores the current bounds and resolution, for offset and ratio
+ * calculations
+ setBackBufferData: function() {
+ this.backBufferData = OpenLayers.Util.extend(this.backBufferData, {
+ bounds: this.bounds,
+ resolution: this.layer.map.getResolution()
+ * Method: updateBackBuffer
+ * Update the <backBufferData>, and return a new or reposition the
+ * backBuffer. When a backbuffer is returned, the tile's markup is not
+ * available any more.
+ * Returns:
+ * {HTMLDivElement} the tile's markup in a cloned element, or undefined if
+ * no backbuffer is currently available or needed
+ updateBackBuffer: function() {
+ var layer = this.layer, map = layer.map,
+ backBufferMode = this.backBufferMode,
+ data = this.backBufferData,
+ tile = this.getTile(),
+ backBuffer = data.tile,
+ resolution = data.resolution,
+ ratio = resolution ? resolution / map.getResolution() : 1,
+ // Cases where we don't position and return a back buffer, but only
+ // update backBufferData and return undefined:
+ // (1) current ratio and backBufferMode dont't require a backbuffer
+ notNeeded = !(ratio == 1 ? backBufferMode & 1 : backBufferMode & 2),
+ // (2) the tile is not appended to the layer's div
+ noParent = tile && tile.parentNode !== layer.div,
+ // (3) we don't have a tile available that we could use as buffer
+ noTile = !(tile && tile.childNodes.length > 0),
+ // (4) no backbuffer is displayed for a tile that's still loading
+ noBackBuffer = data.tile && !this.isLoading;
+ if (notNeeded || noParent || noTile || noBackBuffer) {
+ this.setBackBufferData();
+ return;
+ // Create a back buffer tile and add it to the DOM
+ if (!backBuffer) {
+ backBuffer = this.createBackBuffer();
+ // some browsers fire the onload event before the image is
+ // displayed, so we keep the buffer until the whole layer finished
+ // loading to avoid visual glitches
+ layer.events.register("loadend", this, this.resetBackBuffer);
+ data.tile = backBuffer;
+ layer.div.insertBefore(backBuffer, tile);
+ // Position the back buffer now that we have one
+ var lonLat = {lon: data.bounds.left, lat: data.bounds.top},
+ position = map.getPixelFromLonLat(lonLat),
+ containerStyle = map.layerContainerDiv.style,
+ leftOffset = parseInt(containerStyle.left, 10),
+ topOffset = parseInt(containerStyle.top, 10),
+ style = backBuffer.style;
+ style.left = (position.x - leftOffset) + "px";
+ style.top = (position.y - topOffset) + "px";
+ style.width = (this.size.w * ratio) + "px";
+ style.height = (this.size.h * ratio) + "px";
+ return backBuffer;
+ * Method: resetBackBuffer
+ * Handler for the layer's loadend event.
+ resetBackBuffer: function() {
+ this.layer.events.unregister("loadend", this, this.resetBackBuffer);
+ this.removeBackBuffer();
+ * Method: removeBackBuffer
+ * Removes the backBuffer for this tile.
+ removeBackBuffer: function() {
+ var backBufferData = this.backBufferData;
+ var backBuffer = backBufferData.tile;
+ delete backBufferData.tile;
+ var parent = backBuffer && backBuffer.parentNode;
+ if (backBuffer) {
+ parent.removeChild(backBuffer);
+ * APIMethod: destroy
+ * nullify references to prevent circular references and memory leaks
+ destroy: function() {
+ this.backBufferData = null;
+ OpenLayers.Tile.prototype.destroy.apply(this, arguments);
\ No newline at end of file
Modified: trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
--- trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -14,14 +14,13 @@
* remote services. Images will be loaded using HTTP-POST into an IFrame.
* This mixin will be applied to <OpenLayers.Tile.Image> instances
- * configured with <OpenLayers.Tile.Image.allowPost> or
- * <OpenLayers.Tile.Image.enforcePost> set to true.
+ * configured with <OpenLayers.Tile.Image.maxGetUrlLength> set.
* Inherits from:
* - <OpenLayers.Tile.Image>
OpenLayers.Tile.Image.IFrame = {
* Property: useIFrame
* {Boolean} true if we are currently using an IFrame to render POST
@@ -30,159 +29,111 @@
useIFrame: null,
- * Method: clear
- * Removes the iframe from DOM (avoids back-button problems).
+ * Property: blankImageUrl
+ * {String} This is only used as background image for the eventPane, so we
+ * don't care that this doesn't actually result in a blank image on all
+ * browsers
- clear: function() {
- if (this.useIFrame) {
- if (this.imgDiv) {
- var iFrame = this.imgDiv.firstChild;
- OpenLayers.Event.stopObservingElement(iFrame);
- this.imgDiv.removeChild(iFrame);
- delete iFrame;
- } else {
- OpenLayers.Tile.Image.prototype.clear.apply(this, arguments);
+ blankImageUrl: "data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",
- * Method: renderTile
+ * Returns:
- renderTile: function() {
- if (OpenLayers.Tile.Image.prototype.renderTile.apply(this, arguments) &&
- this.useIFrame) {
- // create a html form and add it temporary to the layer div
- var form = this.createRequestForm();
- this.imgDiv.appendChild(form);
- // submit the form (means fetching the image)
- form.submit();
- this.imgDiv.removeChild(form);
- delete form;
+ this.url = this.layer.getURL(this.bounds);
+ var usedIFrame = this.useIFrame;
+ this.useIFrame = this.maxGetUrlLength !== null && !this.layer.async &&
+ this.url.length > this.maxGetUrlLength;
+ var fromIFrame = usedIFrame && !this.useIFrame;
+ var toIFrame = !usedIFrame && this.useIFrame;
+ if (fromIFrame || toIFrame) {
+ // switch between get (image) and post (iframe)
+ this.clear();
+ if (this.imgDiv && this.imgDiv.parentNode === this.frame) {
+ this.frame.removeChild(this.imgDiv);
+ this.imgDiv = null;
+ if (fromIFrame) {
+ // remove eventPane
+ this.frame.removeChild(this.frame.firstChild);
- return true;
+ if (!this.useIFrame) {
+ OpenLayers.Tile.Image.prototype.updateBackBuffer.apply(this, arguments);
- * Method: initImgDiv
- * Creates the imgDiv property on the tile.
+ * Method: createImage
+ * Creates the content for the frame on the tile.
- initImgDiv: function() {
- this.useIFrame = this.maxGetUrlLength !== null && !this.layer.async &&
- this.url.length > this.maxGetUrlLength;
- if (this.imgDiv != null) {
- var nodeName = this.imgDiv.nodeName.toLowerCase();
- if ((this.useIFrame && nodeName == "img") ||
- (!this.useIFrame && nodeName == "div")) {
- // switch between get and post
- this.removeImgDiv();
- this.imgDiv = null;
+ createImage: function() {
+ if (this.useIFrame === true) {
+ if (!this.frame.childNodes.length) {
+ var eventPane = document.createElement("div"),
+ style = eventPane.style;
+ style.position = "absolute";
+ style.width = "100%";
+ style.height = "100%";
+ style.zIndex = 1;
+ style.backgroundImage = "url(" + this.blankImageUrl + ")";
+ this.frame.appendChild(eventPane);
- if (this.imgDiv == null) {
- var eventPane = document.createElement("div");
- if(OpenLayers.BROWSER_NAME == "msie") {
- // IE cannot handle events on elements without backgroundcolor.
- // So we use this little hack to make elements transparent
- eventPane.style.backgroundColor = '#FFFFFF';
- eventPane.style.filter = 'chroma(color=#FFFFFF)';
+ var id = this.id + '_iFrame', iframe;
+ if (parseFloat(navigator.appVersion.split("MSIE")[1]) < 9) {
+ // Older IE versions do not set the name attribute of an iFrame
+ // properly via DOM manipulation, so we need to do it on our own with
+ // this hack.
+ iframe = document.createElement('<iframe name="'+id+'">');
- OpenLayers.Util.modifyDOMElement(eventPane, null,
- new OpenLayers.Pixel(0,0), this.layer.getImageSize(), "absolute");
+ // IFrames in older IE versions are not transparent, if you set
+ // the backgroundColor transparent. This is a workaround to get
+ // transparent iframes.
+ iframe.style.backgroundColor = '#FFFFFF';
+ iframe.style.filter = 'chroma(color=#FFFFFF)';
+ else {
+ iframe = document.createElement('iframe');
+ iframe.style.backgroundColor = 'transparent';
- this.imgDiv = document.createElement("div");
- this.imgDiv.appendChild(eventPane);
+ // iframe.name needs to be an unique id, otherwise it
+ // could happen that other iframes are overwritten.
+ iframe.name = id;
- OpenLayers.Util.modifyDOMElement(this.imgDiv, this.id, null,
- this.layer.getImageSize(), "relative");
- this.imgDiv.className = 'olTileImage';
+ // some special properties to avoid scaling the images and scrollbars
+ // in the iframe
+ iframe.scrolling = 'no';
+ iframe.marginWidth = '0px';
+ iframe.marginHeight = '0px';
+ iframe.frameBorder = '0';
- this.frame.appendChild(this.imgDiv);
- this.layer.div.appendChild(this.frame);
+ iframe.style.position = "absolute";
+ iframe.style.width = "100%";
+ iframe.style.height = "100%";
- if(this.layer.opacity != null) {
- OpenLayers.Util.modifyDOMElement(this.imgDiv, null, null,
- null, null, null, null,
- this.layer.opacity);
- // we need this reference to check back the viewRequestID
- this.imgDiv.map = this.layer.map;
+ if (this.layer.opacity < 1) {
+ OpenLayers.Util.modifyDOMElement(iframe, null, null, null,
+ null, null, null, this.layer.opacity);
- this.imgDiv.viewRequestID = this.layer.map.viewRequestID;
+ this.frame.appendChild(iframe);
+ this.imgDiv = iframe;
+ return iframe;
} else {
- OpenLayers.Tile.Image.prototype.initImgDiv.apply(this, arguments);
+ return OpenLayers.Tile.Image.prototype.createImage.apply(this, arguments);
- * Method: createIFrame
- * Create the IFrame which shows the image.
- * Returns:
- * {DOMElement} Iframe
- createIFrame: function() {
- var id = this.id+'_iFrame';
- var iframe;
- // InternetExplorer does not set the name attribute of an iFrame
- // properly via DOM manipulation, so we need to do it on our own with
- // this hack.
- iframe = document.createElement('<iframe name="'+id+'">');
- // IFrames in InternetExplorer are not transparent, if you set the
- // backgroundColor transparent. This is a workarround to get
- // transparent iframes.
- iframe.style.backgroundColor = '#FFFFFF';
- iframe.style.filter = 'chroma(color=#FFFFFF)';
- else {
- iframe = document.createElement('iframe');
- iframe.style.backgroundColor = 'transparent';
- // iframe.name needs to be an unique id, otherwise it
- // could happen that other iframes are overwritten.
- iframe.name = id;
- iframe.id = id;
- // some special properties to avoid scaling the images and scrollbars
- // in the iframe
- iframe.scrolling = 'no';
- iframe.marginWidth = '0px';
- iframe.marginHeight = '0px';
- iframe.frameBorder = '0';
- OpenLayers.Util.modifyDOMElement(iframe, id,
- //bind a listener to the onload of the iframe so that we
- // can register when a tile has finished loading.
- var onload = function() {
- //normally isLoading should always be true here but there are some
- // right funky conditions where loading and then reloading a tile
- // with the same url *really*fast*. this check prevents sending
- // a 'loadend' if the msg has already been sent
- if (this.isLoading) {
- this.isLoading = false;
- this.events.triggerEvent("loadend");
- OpenLayers.Event.observe(iframe, 'load',
- OpenLayers.Function.bind(onload, this));
- return iframe;
* Method: createRequestForm
* Create the html <form> element with width, height, bbox and all
* parameters specified in the layer params.
@@ -198,20 +149,16 @@
var cacheId = this.layer.params["_OLSALT"];
cacheId = (cacheId ? cacheId + "_" : "") + this.bounds.toBBOX();
form.action = OpenLayers.Util.urlAppend(this.layer.url, cacheId);
+ form.target = this.id + '_iFrame';
- // insert the iframe, which has been removed to avoid back-button
- // problems
- this.imgDiv.insertBefore(this.createIFrame(), this.imgDiv.firstChild);
- form.target = this.id+'_iFrame';
// adding all parameters in layer params as hidden fields to the html
// form element
- var imageSize = this.layer.getImageSize();
- var params = OpenLayers.Util.getParameters(this.url);
+ var imageSize = this.layer.getImageSize(),
+ params = OpenLayers.Util.getParameters(this.url),
+ field;
for(var par in params) {
- var field = document.createElement('input');
+ field = document.createElement('input');
field.type = 'hidden';
field.name = par;
field.value = params[par];
@@ -219,6 +166,31 @@
return form;
+ * Method: setImgSrc
+ * Sets the source for the tile image
+ * Parameters:
+ * url - {String}
+ setImgSrc: function(url) {
+ if (url) {
+ var form = this.createRequestForm();
+ this.frame.appendChild(this.imgDiv);
+ this.frame.appendChild(form);
+ form.submit();
+ this.frame.removeChild(form);
+ } else if (this.imgDiv.parentNode === this.frame) {
+ // we don't reuse iframes to avoid caching issues
+ } else {
+ OpenLayers.Tile.Image.prototype.setImgSrc.apply(this, arguments);
Modified: trunk/openlayers/lib/OpenLayers/Tile/Image.js
--- trunk/openlayers/lib/OpenLayers/Tile/Image.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/lib/OpenLayers/Tile/Image.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -5,7 +5,7 @@
- * @requires OpenLayers/Tile.js
+ * @requires OpenLayers/Tile/BackBufferable.js
@@ -15,9 +15,9 @@
* <OpenLayers.Tile.Image> constructor.
* Inherits from:
- * - <OpenLayers.Tile>
+ * - <OpenLayers.Tile.BackBufferable>
-OpenLayers.Tile.Image = OpenLayers.Class(OpenLayers.Tile, {
+OpenLayers.Tile.Image = OpenLayers.Class(OpenLayers.Tile.BackBufferable, {
* Property: url
@@ -28,16 +28,22 @@
* Property: imgDiv
- * {DOMElement} The div element which wraps the image.
+ * {HTMLImageElement} The image for this tile.
imgDiv: null,
* Property: frame
* {DOMElement} The image element is appended to the frame. Any gutter on
* the image will be hidden behind the frame.
frame: null,
+ * Property: imageReloadAttempts
+ * {Integer} Attempts to load the image.
+ imageReloadAttempts: null,
* Property: layerAlphaHack
@@ -46,30 +52,13 @@
layerAlphaHack: null,
- * Property: isBackBuffer
- * {Boolean} Is this tile a back buffer tile?
+ * Property: asyncRequestId
+ * {Integer} ID of an request to see if request is still valid. This is a
+ * number which increments by 1 for each asynchronous request.
- isBackBuffer: false,
+ asyncRequestId: null,
- * Property: isFirstDraw
- * {Boolean} Is this the first time the tile is being drawn?
- * This is used to force resetBackBuffer to synchronize
- * the backBufferTile with the foreground tile the first time
- * the foreground tile loads so that if the user zooms
- * before the layer has fully loaded, the backBufferTile for
- * tiles that have been loaded can be used.
- isFirstDraw: true,
- * Property: backBufferTile
- * {<OpenLayers.Tile>} A clone of the tile used to create transition
- * effects when the tile is moved or changes resolution.
- backBufferTile: null,
* APIProperty: maxGetUrlLength
* {Number} If set, requests that would result in GET urls with more
* characters than the number provided will be made using form-encoded
@@ -77,12 +66,9 @@
* characters.
* Caution:
- * Older versions of Gecko based browsers (e.g. Firefox < 3.5) and
- * Opera < 10.0 do not fully support this option.
- * Note:
- * Do not use this option for layers that have a transitionEffect
- * configured - IFrame tiles from POST requests can not be resized.
+ * Older versions of Gecko based browsers (e.g. Firefox < 3.5) and most
+ * Opera versions do not fully support this option. On all browsers,
+ * transition effects are not supported if POST requests are used.
maxGetUrlLength: null,
@@ -102,502 +88,258 @@
* options - {Object}
initialize: function(layer, position, bounds, url, size, options) {
- OpenLayers.Tile.prototype.initialize.apply(this, arguments);
+ OpenLayers.Tile.BackBufferable.prototype.initialize.apply(this, arguments);
- if (this.maxGetUrlLength != null) {
- OpenLayers.Util.extend(this, OpenLayers.Tile.Image.IFrame);
this.url = url; //deprecated remove me
+ this.frame = document.createElement("div");
+ this.frame.style.position = "absolute";
+ this.frame.style.overflow = "hidden";
- this.frame = document.createElement('div');
- this.frame.style.overflow = 'hidden';
- this.frame.style.position = 'absolute';
+ this.layerAlphaHack = this.layer.alpha && OpenLayers.Util.alphaHack();
- this.layerAlphaHack = this.layer.alpha && OpenLayers.Util.alphaHack();
+ if (this.maxGetUrlLength != null) {
+ OpenLayers.Util.extend(this, OpenLayers.Tile.Image.IFrame);
+ if (this.frame != null) {
+ this.clear();
+ this.frame = null;
- if ((this.frame != null) && (this.frame.parentNode == this.layer.div)) {
- this.layer.div.removeChild(this.frame);
- this.frame = null;
- /* clean up the backBufferTile if it exists */
- if (this.backBufferTile) {
- this.backBufferTile.destroy();
- this.backBufferTile = null;
- this.layer.events.unregister("loadend", this, this.resetBackBuffer);
- OpenLayers.Tile.prototype.destroy.apply(this, arguments);
+ // don't handle async requests any more
+ this.asyncRequestId = null;
+ OpenLayers.Tile.BackBufferable.prototype.destroy.apply(this, arguments);
- * Method: clone
- * Parameters:
- * obj - {<OpenLayers.Tile.Image>} The tile to be cloned
- * Returns:
- * {<OpenLayers.Tile.Image>} An exact clone of this <OpenLayers.Tile.Image>
- clone: function (obj) {
- if (obj == null) {
- obj = new OpenLayers.Tile.Image(this.layer,
- this.position,
- this.bounds,
- this.url,
- this.size);
- //pick up properties from superclass
- obj = OpenLayers.Tile.prototype.clone.apply(this, [obj]);
- //dont want to directly copy the image div
- obj.imgDiv = null;
- return obj;
* Method: draw
* Returns:
- * {Boolean} Always returns true.
draw: function() {
- if (this.layer != this.layer.map.baseLayer && this.layer.reproject) {
- this.bounds = this.getBoundsFromBaseLayer(this.position);
- var drawTile = OpenLayers.Tile.prototype.draw.apply(this, arguments);
- if ((OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS, this.layer.transitionEffect) != -1) ||
- this.layer.singleTile) {
- if (drawTile) {
- //we use a clone of this tile to create a double buffer for visual
- //continuity. The backBufferTile is used to create transition
- //effects while the tile in the grid is repositioned and redrawn
- if (!this.backBufferTile) {
- this.backBufferTile = this.clone();
- this.backBufferTile.hide();
- // this is important. It allows the backBuffer to place itself
- // appropriately in the DOM. The Image subclass needs to put
- // the backBufferTile behind the main tile so the tiles can
- // load over top and display as soon as they are loaded.
- this.backBufferTile.isBackBuffer = true;
- // potentially end any transition effects when the tile loads
- this.events.register('loadend', this, this.resetBackBuffer);
- // clear transition back buffer tile only after all tiles in
- // this layer have loaded to avoid visual glitches
- this.layer.events.register("loadend", this, this.resetBackBuffer);
- // run any transition effects
- this.startTransition();
+ var drawn = OpenLayers.Tile.BackBufferable.prototype.draw.apply(this, arguments);
+ if (drawn) {
+ if (this.layer != this.layer.map.baseLayer && this.layer.reproject) {
+ this.bounds = this.getBoundsFromBaseLayer(this.position);
+ if (this.isLoading) {
+ //if we're already loading, send 'reload' instead of 'loadstart'.
+ this.events.triggerEvent("reload");
} else {
- // if we aren't going to draw the tile, then the backBuffer should
- // be hidden too!
- this.backBufferTile.clear();
+ this.isLoading = true;
+ this.events.triggerEvent("loadstart");
+ this.positionTile();
+ this.renderTile();
} else {
- if (drawTile && this.isFirstDraw) {
- this.events.register('loadend', this, this.showTile);
- this.isFirstDraw = false;
- if (!drawTile) {
- return false;
+ this.unload();
- //if we're already loading, send 'reload' instead of 'loadstart'.
- this.events.triggerEvent("reload");
- } else {
- this.isLoading = true;
- this.events.triggerEvent("loadstart");
- return this.renderTile();
+ return drawn;
- * Method: resetBackBuffer
- * Triggered by two different events, layer loadend, and tile loadend.
- * In any of these cases, we check to see if we can hide the
- * backBufferTile yet and update its parameters to match the
- * foreground tile.
- * Basic logic:
- * - If the backBufferTile hasn't been drawn yet, reset it
- * - If layer is still loading, show foreground tile but don't hide
- * the backBufferTile yet
- * - If layer is done loading, reset backBuffer tile and show
- * foreground tile
- resetBackBuffer: function() {
- this.showTile();
- if (this.backBufferTile &&
- (this.isFirstDraw || !this.layer.numLoadingTiles)) {
- // check to see if the backBufferTile is within the max extents
- // before rendering it
- var maxExtent = this.layer.maxExtent;
- var withinMaxExtent = (maxExtent &&
- this.bounds.intersectsBounds(maxExtent, false));
- if (withinMaxExtent) {
- this.backBufferTile.position = this.position;
- this.backBufferTile.bounds = this.bounds;
- this.backBufferTile.size = this.size;
- this.backBufferTile.imageSize = this.layer.getImageSize(this.bounds) || this.size;
- this.backBufferTile.imageOffset = this.layer.imageOffset;
- this.backBufferTile.resolution = this.layer.getResolution();
- this.backBufferTile.renderTile();
* Internal function to actually initialize the image tile,
* position it correctly, and set its url.
+ this.layer.div.appendChild(this.frame);
if (this.layer.async) {
- this.initImgDiv();
- // Asyncronous image requests call the asynchronous getURL method
+ // Asynchronous image requests call the asynchronous getURL method
// on the layer to fetch an image that covers 'this.bounds', in the scope of
// 'this', setting the 'url' property of the layer itself, and running
- // the callback 'positionFrame' when the image request returns.
- this.layer.getURLasync(this.bounds, this, "url", this.positionImage);
+ // the callback 'initImage' when the image request returns.
+ var myId = this.asyncRequestId = (this.asyncRequestId || 0) + 1;
+ this.layer.getURLasync(this.bounds, this, "url", function() {
+ if (myId == this.asyncRequestId) {
+ this.initImage();
} else {
- // syncronous image requests get the url and position the frame immediately,
- // and don't wait for an image request to come back.
+ // synchronous image requests get the url immediately.
- // position the frame immediately
- this.positionImage();
+ this.initImage();
- return true;
- * Method: positionImage
+ * Method: positionTile
* Using the properties currenty set on the layer, position the tile correctly.
* This method is used both by the async and non-async versions of the Tile.Image
* code.
- positionImage: function() {
- // if the this layer doesn't exist at the point the image is
- // returned, do not attempt to use it for size computation
- if (this.layer === null) {
- return;
- OpenLayers.Util.modifyDOMElement(this.frame,
- null, this.position, this.size);
- var imageSize = this.layer.getImageSize(this.bounds);
- if (this.layerAlphaHack) {
- OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,
- null, null, imageSize, this.url);
- } else {
- null, null, imageSize) ;
- this.imgDiv.src = this.url;
+ positionTile: function() {
+ var style = this.frame.style;
+ style.left = this.position.x + "px";
+ style.top = this.position.y + "px";
+ style.width = this.size.w + "px";
+ style.height = this.size.h + "px";
* Method: clear
- * Clear the tile of any bounds/position-related data so that it can
- * be reused in a new location.
+ * Remove the tile from the DOM, clear it of any image related data so that
+ * it can be reused in a new location.
clear: function() {
- if(this.imgDiv) {
- this.hide();
- if (OpenLayers.Tile.Image.useBlankTile) {
- this.imgDiv.src = OpenLayers.Util.getImagesLocation() + "blank.gif";
+ var img = this.imgDiv;
+ if (img) {
+ OpenLayers.Event.stopObservingElement(img);
+ if (this.frame.parentNode === this.layer.div) {
+ this.layer.div.removeChild(this.frame);
+ this.setImgSrc();
+ if (this.layerAlphaHack === true) {
+ img.style.filter = "";
+ OpenLayers.Element.removeClass(img, "olImageLoadError");
- var offset = this.layer.imageOffset;
- var size = this.layer.getImageSize(this.bounds);
+ var img = document.createElement("img");
+ this.imgDiv = img;
- this.imgDiv = OpenLayers.Util.createAlphaImageDiv(null,
- offset,
- size,
- null,
- "relative",
- null,
- null,
- null,
- true);
- } else {
- this.imgDiv = OpenLayers.Util.createImage(null,
- offset,
- size,
- null,
- "relative",
- null,
- null,
- true);
+ img.className = "olTileImage";
+ // avoid image gallery menu in IE6
+ img.galleryImg = "no";
- // needed for changing to a different server for onload error
- if (OpenLayers.Util.isArray(this.layer.url)) {
- this.imgDiv.urls = this.layer.url.slice();
- /* checkImgURL used to be used to called as a work around, but it
- ended up hiding problems instead of solving them and broke things
- like relative URLs. See discussion on the dev list:
- http://openlayers.org/pipermail/dev/2007-January/000205.html
- OpenLayers.Event.observe( this.imgDiv, "load",
- OpenLayers.Function.bind(this.checkImgURL, this) );
- this.frame.style.zIndex = this.isBackBuffer ? 0 : 1;
- if(this.layer.opacity < 1) {
- OpenLayers.Util.modifyDOMElement(this.imgDiv, null, null, null,
- null, null, null,
- //bind a listener to the onload of the image div so that we
- OpenLayers.Event.observe(this.imgDiv.childNodes[0], 'load',
- } else {
- OpenLayers.Event.observe(this.imgDiv, 'load',
- // Bind a listener to the onerror of the image div so that we
- // can registere when a tile has finished loading with errors.
- var onerror = function() {
- // If we have gone through all image reload attempts, it is time
- // to realize that we are done with this image. Since
- // OpenLayers.Util.onImageLoadError already has taken care about
- // the error, we can continue as if the image was loaded
- // successfully.
- if (this.imgDiv._attempts > OpenLayers.IMAGE_RELOAD_ATTEMPTS) {
- onload.call(this);
- OpenLayers.Event.observe(this.imgDiv, "error",
- OpenLayers.Function.bind(onerror, this));
+ var style = img.style,
+ gutter = this.layer.gutter;
+ if (gutter) {
+ var tileSize = this.layer.tileSize,
+ left = (gutter / tileSize.w * 100),
+ top = (gutter / tileSize.h * 100);
+ style.left = -left + "%";
+ style.top = -top + "%";
+ style.width = (2 * left + 100) + "%";
+ style.height = (2 * top + 100) + "%";
+ } else {
+ OpenLayers.Util.modifyDOMElement(img, null, null, null, null, null,
+ null, this.layer.opacity);
+ if (this.layerAlphaHack) {
+ // move the image out of sight
+ style.paddingTop = style.height;
+ style.height = "0";
+ this.frame.appendChild(img);
+ return img;
- * Method: removeImgDiv
- * Removes the imgDiv from the DOM and stops listening to events on it.
+ * Method: initImage
- removeImgDiv: function() {
- // unregister the "load" and "error" handlers. Only the "error" handler if
- // this.layerAlphaHack is true.
- OpenLayers.Event.stopObservingElement(this.imgDiv);
- if (this.imgDiv.parentNode == this.frame) {
- this.frame.removeChild(this.imgDiv);
- this.imgDiv.map = null;
- this.imgDiv.urls = null;
- var child = this.imgDiv.firstChild;
- //check for children (alphaHack img or IFrame)
- if (child) {
- OpenLayers.Event.stopObservingElement(child);
- this.imgDiv.removeChild(child);
- delete child;
+ initImage: function() {
+ var img = this.imgDiv || this.createImage();
+ if (this.url && img.getAttribute("src") == this.url) {
+ this.onImageLoad();
} else {
- // abort any currently loading image
+ OpenLayers.Event.observe(
+ img, "load", OpenLayers.Function.bind(this.onImageLoad, this)
+ img, "error", OpenLayers.Function.bind(this.onImageError, this)
+ this.imageReloadAttempts = 0;
+ this.setImgSrc(this.url);
- * Method: checkImgURL
- * Make sure that the image that just loaded is the one this tile is meant
- * to display, since panning/zooming might have changed the tile's URL in
- * the meantime. If the tile URL did change before the image loaded, set
- * the imgDiv display to 'none', as either (a) it will be reset to visible
- * when the new URL loads in the image, or (b) we don't want to display
- * this tile after all because its new bounds are outside our maxExtent.
- * This function should no longer be neccesary with the improvements to
- * Grid.js in OpenLayers 2.3. The lack of a good isEquivilantURL function
- * caused problems in 2.2, but it's possible that with the improved
- * isEquivilant URL function, this might be neccesary at some point.
- * See discussion in the thread at
- * http://openlayers.org/pipermail/dev/2007-January/000205.html
+ * Parameters:
+ * url - {String} or undefined to hide the image
- checkImgURL: function () {
- // Sometimes our image will load after it has already been removed
- // from the map, in which case this check is not needed.
- if (this.layer) {
- var loaded = this.layerAlphaHack ? this.imgDiv.firstChild.src : this.imgDiv.src;
- if (!OpenLayers.Util.isEquivalentUrl(loaded, this.url)) {
- this.hide();
+ this.imgDiv.style.display = "none";
+ if (url) {
+ this.imgDiv.src = url;
- * Method: startTransition
- * This method is invoked on tiles that are backBuffers for tiles in the
- * grid. The grid tile is about to be cleared and a new tile source
- * loaded. This is where the transition effect needs to be started
- * to provide visual continuity.
+ * Method: getTile
+ * Returns:
- startTransition: function() {
- // backBufferTile has to be valid and ready to use
- if (!this.backBufferTile || !this.backBufferTile.imgDiv) {
- return;
+ getTile: function() {
+ return this.frame;
- // calculate the ratio of change between the current resolution of the
- // backBufferTile and the layer. If several animations happen in a
- // row, then the backBufferTile will scale itself appropriately for
- // each request.
- var ratio = 1;
- if (this.backBufferTile.resolution) {
- ratio = this.backBufferTile.resolution / this.layer.getResolution();
- // if the ratio is not the same as it was last time (i.e. we are
- // zooming), then we need to adjust the backBuffer tile
- if (ratio != 1) {
- if (this.layer.transitionEffect == 'resize') {
- // In this case, we can just immediately resize the
- // backBufferTile.
- var upperLeft = new OpenLayers.LonLat(
- this.backBufferTile.bounds.left,
- this.backBufferTile.bounds.top
- var size = new OpenLayers.Size(
- this.backBufferTile.size.w * ratio,
- this.backBufferTile.size.h * ratio
+ * Create a copy of this tile's markup for the <layer>'s backBufferDiv
+ * Returns:
+ * {DOMElement} a clone of the tile content
+ createBackBuffer: function() {
+ var frame = this.frame.cloneNode(false);
+ OpenLayers.Event.stopObservingElement(this.imgDiv);
+ frame.appendChild(this.imgDiv);
+ return frame;
- var px = this.layer.map.getLayerPxFromLonLat(upperLeft);
- OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,
- null, px, size);
- var imageSize = this.backBufferTile.imageSize;
- imageSize = new OpenLayers.Size(imageSize.w * ratio,
- imageSize.h * ratio);
- var imageOffset = this.backBufferTile.imageOffset;
- if(imageOffset) {
- imageOffset = new OpenLayers.Pixel(
- imageOffset.x * ratio, imageOffset.y * ratio
+ * Method: onImageLoad
+ * Handler for the image onload event
+ onImageLoad: function() {
+ img.style.display = "";
+ this.isLoading = false;
+ this.events.triggerEvent("loadend");
- this.backBufferTile.imgDiv, null, imageOffset, imageSize
- this.backBufferTile.show();
- } else {
- // default effect is just to leave the existing tile
- // until the new one loads if this is a singleTile and
- // there was no change in resolution. Otherwise we
- // don't bother to show the backBufferTile at all
- if (this.layer.singleTile) {
- } else {
+ "progid:DXImageTransform.Microsoft.AlphaImageLoader(src='" +
+ img.src + "', sizingMethod='scale')";
- * Method: show
- * Show the tile by showing its frame.
+ * Method: onImageError
+ * Handler for the image onerror event
- show: function() {
- this.frame.style.display = '';
- // Force a reflow on gecko based browsers to actually show the element
- // before continuing execution.
- if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,
- this.layer.transitionEffect) != -1) {
- if (OpenLayers.IS_GECKO === true) {
- this.frame.scrollLeft = this.frame.scrollLeft;
+ onImageError: function() {
+ if (img.src != null) {
+ this.imageReloadAttempts++;
+ if (this.imageReloadAttempts <= OpenLayers.IMAGE_RELOAD_ATTEMPTS) {
+ this.setImgSrc(this.layer.getURL(this.bounds));
+ } else {
+ OpenLayers.Element.addClass(img, "olImageLoadError");
- * Method: hide
- * Hide the tile by hiding its frame.
- hide: function() {
- this.frame.style.display = 'none';
CLASS_NAME: "OpenLayers.Tile.Image"
-OpenLayers.Tile.Image.useBlankTile = (
- OpenLayers.BROWSER_NAME == "safari" ||
- OpenLayers.BROWSER_NAME == "opera");
Modified: trunk/openlayers/lib/OpenLayers/Tile.js
--- trunk/openlayers/lib/OpenLayers/Tile.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/lib/OpenLayers/Tile.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -77,7 +77,7 @@
* {<OpenLayers.Pixel>} Top Left pixel of the tile
position: null,
* Property: isLoading
* {Boolean} Is the tile loading?
@@ -144,53 +144,37 @@
- * Method: clone
- * Parameters:
- * obj - {<OpenLayers.Tile>} The tile to be cloned
+ * Method: draw
+ * Clear whatever is currently in the tile, then return whether or not
+ * it should actually be re-drawn. This is an example implementation
+ * that can be overridden by subclasses. The minimum thing to do here
+ * is to call <clear> and return the result from <shouldDraw>.
* Returns:
- * {<OpenLayers.Tile>} An exact clone of this <OpenLayers.Tile>
+ * {Boolean} Whether or not the tile should actually be drawn.
- obj = new OpenLayers.Tile(this.layer,
- this.position,
- this.bounds,
- this.url,
- this.size);
+ //clear tile's contents and mark as not drawn
+ this.clear();
- // catch any randomly tagged-on properties
- OpenLayers.Util.applyDefaults(obj, this);
- return obj;
+ return this.shouldDraw();
- * Method: draw
- * Clear whatever is currently in the tile, then return whether or not
- * it should actually be re-drawn.
+ * Method: shouldDraw
+ * Return whether or not the tile should actually be (re-)drawn. The only
+ * case where we *wouldn't* want to draw the tile is if the tile is outside
+ * its layer's maxExtent
* Returns:
- * {Boolean} Whether or not the tile should actually be drawn. Note that
- * this is not really the best way of doing things, but such is
- * the way the code has been developed. Subclasses call this and
- * depend on the return to know if they should draw or not.
- draw: function() {
+ shouldDraw: function() {
- // The only case where we *wouldn't* want to draw the tile is if the
- // tile is outside its layer's maxExtent.
- this.shouldDraw = (withinMaxExtent || this.layer.displayOutsideMaxExtent);
- //clear tile's contents and mark as not drawn
- this.clear();
- return this.shouldDraw;
+ return withinMaxExtent || this.layer.displayOutsideMaxExtent;
@@ -220,7 +204,7 @@
* be reused in a new location. To be implemented by subclasses.
+ clear: function(draw) {
// to be implemented by subclasses
@@ -260,29 +244,7 @@
bottomRight.lon,
topLeft.lat);
return bounds;
- * Method: showTile
- * Show the tile only if it should be drawn.
- showTile: function() {
- if (this.shouldDraw) {
- this.show();
- * Method: show
- * Show the tile. To be implemented by subclasses.
- show: function() { },
- * Method: hide
- * Hide the tile. To be implemented by subclasses.
- hide: function() { },
CLASS_NAME: "OpenLayers.Tile"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/lib/OpenLayers.js 2011-08-13 00:59:01 UTC (rev 12241)
@@ -121,6 +121,7 @@
"OpenLayers/Marker/Box.js",
"OpenLayers/Popup.js",
"OpenLayers/Tile.js",
+ "OpenLayers/Tile/BackBufferable.js",
"OpenLayers/Tile/Google.js",
"OpenLayers/Tile/Image.js",
"OpenLayers/Tile/Image/IFrame.js",
Modified: trunk/openlayers/tests/Layer/WMS/Post.html
--- trunk/openlayers/tests/Layer/WMS/Post.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/Layer/WMS/Post.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -73,8 +73,9 @@
map.addLayer(layer);
var tile2 = layer.addTile(bounds, pixel);
- t.ok(
- tile2.createIFrame,
+ tile2.draw();
+ t.eq(
+ tile2.useIFrame, true,
"supported browser: tile is created with the Tile.Image.IFrame mixin");
map.destroy();
Added: trunk/openlayers/tests/Tile/BackBufferable.html
--- trunk/openlayers/tests/Tile/BackBufferable.html (rev 0)
+++ trunk/openlayers/tests/Tile/BackBufferable.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -0,0 +1,114 @@
+<html>
+<head>
+ <script src="../OLLoader.js"></script>
+ <script type="text/javascript">
+ var tile;
+ var layer = new OpenLayers.Layer.WMS(
+ "WMS",
+ window.location.href + "#",
+ null,
+ {transitionEffect: "resize"});
+ var position = new OpenLayers.Pixel(20,30);
+ var bounds = new OpenLayers.Bounds(1,2,3,4);
+ function test_initialize (t) {
+ t.plan(2);
+ tile = new OpenLayers.Tile.Image(layer, position, bounds, null);
+ t.eq(tile.backBufferData, {}, "back buffer data initialized");
+ t.eq(tile.size.w, 256, "size object with default width created");
+ function test_backBufferMode(t) {
+ t.plan(4);
+ var l;
+ l = new OpenLayers.Layer.WMS('', window.location.href + '#');
+ tile = new OpenLayers.Tile.Image(l, position, bounds, null);
+ t.eq(tile.backBufferMode, 0,
+ 'backBufferMode correctly set [tiled]');
+ l = new OpenLayers.Layer.WMS('', window.location.href + '#',
+ null, {singleTile: true});
+ t.eq(tile.backBufferMode, 1,
+ 'backBufferMode correctly set [singleTile]');
+ null, {transitionEffect: 'resize'});
+ t.eq(tile.backBufferMode, 2,
+ 'backBufferMode correctly set [tiled, transition]');
+ null, {singleTile: true,
+ transitionEffect: 'resize'});
+ t.eq(tile.backBufferMode, 3,
+ 'backBufferMode correctly set [singleTile, transition]');
+ function test_setBackBufferData(t) {
+ t.plan(2);
+ var map = new OpenLayers.Map("map");
+ map.addLayer(layer);
+ map.zoomToMaxExtent();
+ tile.draw();
+ // moveTo calls setBackBufferData
+ tile.moveTo(new OpenLayers.Bounds(1,2,3,4),
+ new OpenLayers.Pixel(30,40), true);
+ t.eq(tile.backBufferData.bounds.toString(), bounds.toString(),
+ "bounds stored correctly");
+ t.eq(tile.backBufferData.resolution, map.getResolution(),
+ "resolution stored correctly");
+ map.removeLayer(layer);
+ map.destroy();
+ function test_updateBackBuffer(t) {
+ t.plan(1);
+ tile.draw();
+ tile.isLoading = false;
+ map.zoomIn();
+ tile.updateBackBuffer();
+ t.eq(tile.backBufferData.tile.style.width, (layer.tileSize.w*2)+"px",
+ "backBuffer frame correctly resized");
+ map.destroy();
+ function test_removeBackBuffer(t) {
+ t.plan(2);
+ tile.draw();
+ map.zoomIn();
+ var backBuffer = tile.backBufferData.tile;
+ tile.removeBackBuffer();
+ t.eq(tile.backBufferData.tile, null,
+ "backBuffer reference removed");
+ t.ok(backBuffer.parentNode !== layer.div,
+ "backBuffer removed from layer");
+ map.destroy();
+ </script>
+</head>
+<body>
+<div id="map" style="height:550px;width:500px"></div>
+</body>
+</html>
Modified: trunk/openlayers/tests/Tile/Image/IFrame.html
--- trunk/openlayers/tests/Tile/Image/IFrame.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/Tile/Image/IFrame.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -15,26 +15,29 @@
var wmsUrl = "http://labs.metacarta.com/wms/vmap0?";
function test_Tile_Image_IFrame_create (t) {
- t.plan( 3 );
+ t.plan( 5 );
map = new OpenLayers.Map('map');
var bar = new Array(205).join("1234567890");
- layer = new OpenLayers.Layer.WMS(name, wmsUrl, {layers: 'basic', foo: bar}, {tileOptions: {maxGetUrlLength: 2048}});
+ layer = new OpenLayers.Layer.WMS(name, wmsUrl,
+ {layers: 'basic', foo: bar},
var tile = layer.addTile(bounds, position);
- tile.renderTile();
- tile.positionImage();
- t.eq(tile.imgDiv.firstChild.nodeName.toLowerCase(), "iframe", "IFrame used for long URL");
+ t.eq(tile.backBufferMode, 2, "backBufferMode is 2 after tile creation");
+ tile.draw();
+ t.eq(tile.imgDiv.nodeName.toLowerCase(), "iframe", "IFrame used for long URL");
layer.mergeNewParams({foo: null});
+ tile.draw();
t.eq(tile.imgDiv.nodeName.toLowerCase(), "img", "IMG used for short URL");
+ t.eq(tile.backBufferMode, 2, "backBufferMode reset to 2");
tile.maxGetUrlLength = 0;
- t.eq(tile.imgDiv.firstChild.nodeName.toLowerCase(), "iframe", "IFrame used when maxGetUrlLength is 0");
+ tile.draw();
+ t.eq(tile.imgDiv.nodeName.toLowerCase(), "iframe", "IFrame used when maxGetUrlLength is 0");
tile.destroy();
layer.destroy();
@@ -52,22 +55,22 @@
tile.clear();
t.eq(
- tile.imgDiv.firstChild.nodeName.toLowerCase(), "div",
- "IFrame successfully removed from DOM");
+ tile.frame.getElementsByTagName("iframe").length, 0,
+ "IFrame removed on clear()");
tile.destroy();
layer.destroy();
map.destroy();
- function test_Tile_Image_IFrame_initImgDiv (t) {
- t.plan( 4 );
+ function test_Tile_Image_IFrame_initImage (t) {
+ t.plan( 2 );
layer = new OpenLayers.Layer.WMS(name, wmsUrl, {layers: 'basic'}, {tileOptions: {maxGetUrlLength: 0}});
tile.url = layer.getURL(bounds);
- tile.initImgDiv();
+ tile.initImage();
if(isMozilla) {
t.ok( tile.imgDiv instanceof HTMLElement, "tile.iFrame successfully created.");
@@ -75,63 +78,41 @@
else {
t.ok( tile.imgDiv != null, "tile.iFrame successfully created.");
- t.eq( tile.imgDiv.id, tile.id, "imgDiv id correctly set.");
t.eq( tile.imgDiv.className, "olTileImage", "iFrame's className correctly set.");
- t.ok( tile.imgDiv.map == map, "map correctly added to iFrame.");
map.destroy();
- function test_Tile_Image_IFrame_createImgDiv (t) {
- t.plan( 3 );
+ function test_Tile_Image_IFrame_createImage (t) {
+ t.plan( 9 );
- var imgDiv = tile.imgDiv;
- var iFrame = imgDiv.firstChild;
- var eventPane = imgDiv.childNodes[1];
+ tile.draw();
+ var iFrame = tile.imgDiv;
+ var eventPane = tile.frame.childNodes[0];
+ t.ok(OpenLayers.String.contains(eventPane.style.backgroundImage,
+ tile.blankImageUrl),
+ "backgroundImage of eventPane is set.");
+ t.eq(parseInt(eventPane.style.zIndex, 10), 1, "zIndex of eventPane is set.");
if(isIE) {
t.ok(iFrame != null, "IFrame successfully created.");
- t.eq(eventPane.style.backgroundColor, '#ffffff', "backgroundColor of overlay pane is set in InternetExplorer.");
- t.eq(eventPane.style.filter, 'chroma(color=#FFFFFF)', "filter of overlay pane is set in InternetExplorer.");
- else {
- t.ok(iFrame instanceof HTMLElement, "IFrame successfully created.");
- t.ok(true, 'Skip eventPane backgroundColor test outside IE');
- t.ok(true, 'Skip eventPane filter test outside IE');
- map.destroy();
- function test_Tile_Image_IFrame_createIFrame (t) {
- t.plan( 8 );
- map = new OpenLayers.Map('map');
- layer = new OpenLayers.Layer.WMS(name, wmsUrl, {layers: 'basic'}, {tileOptions: {maxGetUrlLength: 0}});
- map.addLayer(layer);
- var tile = layer.addTile(bounds, position);
- var iFrame = tile.createIFrame();
- var id = tile.id+'_iFrame';
- t.eq(iFrame.id, id, "iframe id correctly set.");
- t.eq(iFrame.name, id, "iframe name correctly set.");
- if(isIE) {
t.eq(iFrame.style.backgroundColor, '#ffffff', "backgroundColor correctly set.");
t.eq(iFrame.style.filter, 'chroma(color=#FFFFFF)', "filter correctly set.");
+ } else {
+ t.ok(iFrame instanceof HTMLElement, "IFrame successfully created.");
+ t.ok(true, 'Skip IFrame backgroundColor test outside IE');
+ t.ok(true, 'Skip IFrame filter test outside IE');
- else {
- t.eq(iFrame.style.backgroundColor, 'transparent', "backgroundColor correctly set.");
- t.ok(true, "Skip filter test outside InternetExplorer.");
t.eq( iFrame.scrolling, 'no', "no scrolling");
t.eq( parseFloat(iFrame.marginWidth), 0, "no margin width");
t.eq( parseFloat(iFrame.marginHeight), 0, "no margin height");
t.eq( parseFloat(iFrame.frameBorder), 0, "no iframe border");
+ map.destroy();
function test_Tile_Image_IFrame_createRequestForm (t) {
@@ -152,7 +133,7 @@
map.addLayer(newLayer);
tile = newLayer.addTile(bounds, position);
tile.url = newLayer.getURL(bounds);
+ tile.initImage();
var form = tile.createRequestForm();
@@ -182,9 +163,10 @@
tile.draw();
tile.clear();
+ tile.initImage();
t.ok(
- tile.imgDiv.firstChild.nodeName == "IFRAME",
+ tile.imgDiv.nodeName == "IFRAME",
"Iframe has been reinserted properly"
Modified: trunk/openlayers/tests/Tile/Image.html
--- trunk/openlayers/tests/Tile/Image.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/Tile/Image.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -62,38 +62,16 @@
map.destroy();
- function test_Tile_Image_clone (t) {
- t.plan( 9 );
- var layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
- "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
- var position = new OpenLayers.Pixel(20,30);
- var bounds = new OpenLayers.Bounds(1,2,3,4);
- var url = "http://www.openlayers.org/dev/tests/tileimage";
- var size = new OpenLayers.Size(5,6);
- tile = new OpenLayers.Tile.Image(layer, position, bounds, url, size);
- tile.imgDiv = {};
- var clone = tile.clone();
- t.ok( clone instanceof OpenLayers.Tile.Image, "OpenLayers.Tile.clone returns Tile.Image object" );
- t.ok( clone.layer == layer, "clone.layer is set correctly");
- t.ok( clone.position.equals(position), "clone.position is set correctly");
- t.ok( clone.bounds.equals(bounds), "clone.bounds is set correctly");
- t.eq( clone.url, url, "clone.url is set correctly");
- t.ok( clone.size.equals(size), "clone.size is set correctly");
- t.ok( clone.frame, "clone has a frame");
- t.ok( clone.frame != tile.frame, "clone's frame is a new one");
- t.ok( clone.imgDiv == null, "clone's imgDiv was not copied");
- function test_Tile_Image_IFrame_viewRequestID (t) {
- t.plan( 2 );
+ function test_Tile_Image_async (t) {
+ t.plan( 3 );
var map = new OpenLayers.Map('map');
"Name",
"http://labs.metacarta.com/TESTURL?",
- {layers: 'basic'}
+ {layers: 'basic'}, {async: true, getURLasync: function(bounds, scope, url, callback) {
+ scope.url = this.getURL(bounds);
+ callback.call(scope);
@@ -101,10 +79,10 @@
tile.renderTile();
- t.eq(tile.imgDiv.viewRequestID, map.viewRequestID, "viewRequestID correct after renderTile");
- map.viewRequestID++;
+ t.eq(tile.imgDiv.src, layer.getURL(bounds), "image src correct for async request");
+ t.eq(tile.asyncRequestId, 1, "asyncRequestId correct after renderTile");
tile.renderTile();
- t.eq(tile.imgDiv.viewRequestID, map.viewRequestID, "viewRequestID correct after subsequent renderTile");
+ t.eq(tile.asyncRequestId, 2, "asyncRequestId correct after subsequent renderTile");
tile.destroy();
layer.destroy();
map.destroy();
@@ -156,8 +134,8 @@
t.eq( img.src,
"http://labs.metacarta.com/TESTURL?" + OpenLayers.Util.getParameterString(tParams),
"tile.draw creates an image");
- t.eq( tile.imgDiv.style.width, "5px", "Image width is correct" );
- t.eq( tile.imgDiv.style.height, "6px", "Image height is correct" );
+ t.eq( tile.imgDiv.style.width, "100%", "Image width is correct" );
+ t.eq( tile.imgDiv.style.height, "100%", "Image height is correct" );
// this should trigger a "reload" event (since the image never actually
// loads in tests)
@@ -260,14 +238,14 @@
tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-90,-85,-90,85), url, size);
tile.draw();
tile.moveTo(new OpenLayers.Bounds(-185,-90,-180,-80), new OpenLayers.Pixel(-180,-85), true);
- t.delay_call( 1, function() { t.eq(tile.imgDiv, null, "Tile imgDiv is null.") } );
+ t.delay_call( 1, function() { t.eq(tile.imgDiv.style.display, "none", "Tile image is invisible.") } );
"http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'}, {'reproject': true, 'alpha':true});
tile.draw();
- t.delay_call( 1, function() { t.eq(tile.imgDiv, null, "Alpha tile imgDiv is null.") } );
+ t.delay_call( 1, function() { t.eq(tile.imgDiv.style.display, "none", "Alpha tile image is invisible.") } );
@@ -316,6 +294,23 @@
map.destroy();
+ function test_createBackBuffer(t) {
+ t.plan(3);
+ var map = new OpenLayers.Map('map');
+ var layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+ "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
+ map.setCenter(new OpenLayers.LonLat(0,0), 5);
+ var tile = layer.grid[0][0];
+ var img = tile.imgDiv;
+ var backBuffer = tile.createBackBuffer();
+ t.eq(backBuffer.style.left, tile.frame.style.left, "backBuffer tile has same left style as frame");
+ t.ok(backBuffer.firstChild === img, "image appended to backBuffer");
+ t.ok(tile.imgDiv == null, "image reference removed from tile");
+ map.destroy();
</script>
</head>
<body>
Modified: trunk/openlayers/tests/Tile.html
--- trunk/openlayers/tests/Tile.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/Tile.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -31,32 +31,6 @@
t.ok( tile.events != null, "tile's events intitialized");
- function test_Tile_clone (t) {
- t.plan( 10 );
- var layer = {}; // bogus layer
- var position = new OpenLayers.Pixel(10,20);
- var url = "bobob";
- tile = new OpenLayers.Tile(layer, position, bounds, url, size);
- t.ok( clone instanceof OpenLayers.Tile, "OpenLayers.Tile.clone returns Tile object" );
- t.eq( clone.layer, layer, "clone.layer set correctly");
- t.ok( clone.position.equals(position), "clone.position set correctly");
- t.ok( clone.bounds.equals(bounds), "clone.bounds set correctly");
- t.eq( clone.url, url, "clone.url set correctly");
- t.ok( clone.size.equals(size), "clone.size is set correctly" );
- t.ok( clone.id != null, "clone is given an id");
- t.ok( clone.id != tile.id, "clone is given a new id");
- t.ok(OpenLayers.String.startsWith(clone.id, "Tile_"),
- "clone's id starts correctly");
- t.ok( clone.events != null, "clone's events intitialized");
function test_Tile_destroy(t) {
t.plan( 6 );
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/list-tests.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -226,6 +226,7 @@
<li>Tile.html</li>
<li>Tile/Google.html</li>
<li>Tile/Image.html</li>
+ <li>Tile/BackBufferable.html</li>
<li>Tile/Image/IFrame.html</li>
<li>Tile/WFS.html</li>
<li>Tween.html</li>
Modified: trunk/openlayers/tests/run-tests.html
--- trunk/openlayers/tests/run-tests.html 2011-08-12 21:17:22 UTC (rev 12240)
+++ trunk/openlayers/tests/run-tests.html 2011-08-13 00:59:01 UTC (rev 12241)
@@ -1102,7 +1102,7 @@
if( finished ) {
try {
action.call_fn();
- }catch( e ) {
+ }catch( e ) {
Test.AnotherWay._handle_exception( test_object, e, "in delay_call" );
More information about the Commits
