[OpenLayers-Commits] r12282 - sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Aug 29 04:37:59 EDT 2011
Author: erilem
Date: 2011-08-29 01:37:58 -0700 (Mon, 29 Aug 2011)
New Revision: 12282
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
make Layer.WMTS rely on getAvailableResolution and getAvailableZoom
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-08-29 08:37:46 UTC (rev 12281)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-08-29 08:37:58 UTC (rev 12282)
@@ -314,9 +314,10 @@
      * Get the appropriate matrix definition for the current map resolution.
     getMatrix: function() {
-        var matrix;
+        var matrix, zoom;
         if (!this.matrixIds || this.matrixIds.length === 0) {
-            matrix = {identifier: this.map.getZoom() + this.zoomOffset};
+            zoom = this.getAvailableZoom();
+            matrix = {identifier: zoom + this.zoomOffset};
         } else {
             // get appropriate matrix given the map scale if possible
             if ("scaleDenominator" in this.matrixIds[0]) {
@@ -324,7 +325,7 @@
                 var denom =
                     OpenLayers.METERS_PER_INCH *
                     OpenLayers.INCHES_PER_UNIT[this.units] *
-                    this.map.getResolution() / 0.28E-3;
+                    this.getAvailableResolution() / 0.28E-3;
                 var diff = Number.POSITIVE_INFINITY;
                 var delta;
                 for (var i=0, ii=this.matrixIds.length; i<ii; ++i) {
@@ -336,7 +337,8 @@
             } else {
                 // fall back on zoom as index
-                matrix = this.matrixIds[this.map.getZoom() + this.zoomOffset];
+                matrix = this.matrixIds[zoom + this.zoomOffset];
         return matrix;
@@ -356,7 +358,7 @@
      *     (respectively) of the given location within the target tile.
     getTileInfo: function(loc) {
-        var res = this.map.getResolution();
+        var res = this.getAvailableResolution();
         var fx = (loc.lon - this.tileOrigin.lon) / (res * this.tileSize.w);
         var fy = (this.tileOrigin.lat - loc.lat) / (res * this.tileSize.h);
More information about the Commits mailing list
