[OpenLayers-Commits] r12290 - sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 31 02:49:41 EDT 2011
Author: erilem
Date: 2011-08-30 23:49:40 -0700 (Tue, 30 Aug 2011)
New Revision: 12290
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
modify Grid.moveTo not to do anything if the bounds are null
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js	2011-08-31 06:49:32 UTC (rev 12289)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js	2011-08-31 06:49:40 UTC (rev 12290)
@@ -228,15 +228,8 @@
     moveTo:function(bounds, zoomChanged, dragging) {
-        var resolution = this.map.getResolution(),
-            availableResolution = this.getAvailableResolution();
-        if(resolution !== availableResolution) {
-            bounds = this.map.calculateBounds(null, availableResolution);
         OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this, arguments);
         bounds = bounds || this.map.getExtent();
         if (bounds != null) {
@@ -244,6 +237,12 @@
             // if grid is empty or zoom has changed, we *must* re-tile
             var forceReTile = !this.grid.length || zoomChanged;
+            var resolution = this.map.getResolution(),
+                availableResolution = this.getAvailableResolution();
+            if (resolution !== availableResolution) {
+                bounds = this.map.calculateBounds(null, availableResolution);
             // total bounds of the tiles
             var tilesBounds = this.getTilesBounds();
@@ -269,21 +268,21 @@
                     this.scheduleMoveGriddedTiles();
-            if(zoomChanged) {
-                // apply "client zoom"
-                var scale = availableResolution / resolution;
-                this.transformDiv(scale);
+                if (forceReTile) {
+                    // stretch the layer div
+                    this.transformDiv(availableResolution / resolution);
+            } else {
+                // reset the layer width, height, left, top, to deal with
+                // the case where the layer has been transformDivd
+                this.div.style.width = '100%';
+                this.div.style.height = '100%';
+                this.div.style.left = '0%';
+                this.div.style.top = '0%';
-        } else {
-            // reset the layer width, height, left, top, to deal with
-            // the case where the layer has been transformDivd
-            this.div.style.width = '100%';
-            this.div.style.height = '100%';
-            this.div.style.left = '0%';
-            this.div.style.top = '0%';
@@ -340,11 +339,6 @@
     transformDiv: function(scale) {
-        // TODO
-        // - serverResolutions should be documented
         // scale the layer div with the map center as the
         // origin
More information about the Commits mailing list
