[OpenLayers-Commits] r12298 - in sandbox/camptocamp/clientzoom: lib/OpenLayers/Layer tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 31 05:40:23 EDT 2011
Author: erilem
Date: 2011-08-31 02:40:23 -0700 (Wed, 31 Aug 2011)
New Revision: 12298
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
   sandbox/camptocamp/clientzoom/tests/Layer/WMTS.html
add tests for serverResolutions and zoomOffset in WMTS, plus minor refactoring in WMTS
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-08-31 09:24:14 UTC (rev 12297)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/WMTS.js	2011-08-31 09:40:23 UTC (rev 12298)
@@ -324,19 +324,26 @@
         // copy/set any non-init, non-simple values here
         return obj;
+     * Method: getIdentifier
+     * Get the current index in the matrixIds array.
+    getIdentifier: function() {
+        return this.serverResolutions != null ?
+            OpenLayers.Util.indexOf(this.serverResolutions,
+                                    this.getServerSupportedResolution()) :
+            this.getServerSupportedZoom() + this.zoomOffset;
      * Method: getMatrix
      * Get the appropriate matrix definition for the current map resolution.
     getMatrix: function() {
-        var matrix, identifier;
+        var matrix;
         if (!this.matrixIds || this.matrixIds.length === 0) {
-            identifier = this.serverResolutions != null ?
-                OpenLayers.Util.indexOf(this.serverResolutions,
-                                        this.getServerSupportedResolution()) :
-                this.getServerSupportedZoom() + this.zoomOffset;
-            matrix = {identifier: identifier};
+            matrix = {identifier: this.getIdentifier()};
         } else {
             // get appropriate matrix given the map scale if possible
             if ("scaleDenominator" in this.matrixIds[0]) {
@@ -356,11 +363,7 @@
             } else {
                 // fall back on zoom as index
-                matrix = this.matrixIds[identifier];
+                matrix = this.matrixIds[this.getIdentifier()];
         return matrix;
Modified: sandbox/camptocamp/clientzoom/tests/Layer/WMTS.html
--- sandbox/camptocamp/clientzoom/tests/Layer/WMTS.html	2011-08-31 09:24:14 UTC (rev 12297)
+++ sandbox/camptocamp/clientzoom/tests/Layer/WMTS.html	2011-08-31 09:40:23 UTC (rev 12298)
@@ -258,6 +258,37 @@
                 t.ok( layer2.grid == null, "tiles appropriately destroyed");
                 map.destroy();
+            function test_getIdentifier(t) {
+                t.plan(2);
+                var map = new OpenLayers.Map('map');
+                var layer, identifier;
+                layer = new OpenLayers.Layer.WMTS({
+                    name: "Blue Marble WMTS",
+                    url: "http://example.com/wmts/",
+                    layer: "world",
+                    style: "blue_marble",
+                    matrixSet: "arcgis_online",
+                    tileSize: new OpenLayers.Size(512, 512),
+                    requestEncoding: "REST",
+                map.addLayer(layer);
+                map.setCenter(new OpenLayers.LonLat(0,0), 5);
+                layer.zoomOffset = 2;
+                identifier = layer.getIdentifier();
+                t.eq(identifier, 7, '[zoomOffset] getIdentifier return value is correct');
+                layer.serverResolutions = ['offset', 1.40625, 0.703125, 0.3515625, 0.17578125,
+                                           0.087890625, 0.0439453125];
+                t.eq(identifier, 6, '[serverResolutions] getIdentifier return value is correct');
+                map.destroy();
         </script>
     </head>
     <body>
More information about the Commits mailing list
