[OpenLayers-Commits] r12302 - sandbox/camptocamp/clientzoom/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 31 07:42:35 EDT 2011
Author: erilem
Date: 2011-08-31 04:42:34 -0700 (Wed, 31 Aug 2011)
New Revision: 12302
Removed:
   sandbox/camptocamp/clientzoom/examples/zoomclient.html
   sandbox/camptocamp/clientzoom/examples/zoomclient.js
remove the zoomclient example
Deleted: sandbox/camptocamp/clientzoom/examples/zoomclient.html
--- sandbox/camptocamp/clientzoom/examples/zoomclient.html	2011-08-31 11:39:40 UTC (rev 12301)
+++ sandbox/camptocamp/clientzoom/examples/zoomclient.html	2011-08-31 11:42:34 UTC (rev 12302)
@@ -1,55 +0,0 @@
-<!DOCTYPE html>
-<html>
-    <head>
-    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
-    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
-    <meta name="apple-mobile-web-app-capable" content="yes">
-        <title>OpenLayers Zoom Client Example</title>
-        <link rel="stylesheet" href="../theme/default/style.css" type="text/css"/>
-        <link rel="stylesheet" href="style.css" type="text/css">
-        <script src="../lib/Firebug/firebug.js"></script>
-        <script src="../lib/OpenLayers.js"></script>
-        <script src="zoomclient.js"></script>
-        <style>
-            .olControlAttribution {
-                bottom: 5px;
-        </style>
-    </head>
-    <body onload="init();">
-        <h1 id="title">Client Zoom</h1>
-        <div id="tags">
-            clientzoom
-        </div>
-        <p id="shortdesc">
-            This example demonstrates the <strong>"client zoom"</strong>
-            functionality, where OpenLayers stretches the layer div if the
-            current resolution isn't supported by the tile server.
-        </p>
-        <div id="map" class="smallmap"></div>
-        <div id="docs">
-            <p>
-                Ths map is configured with 22 resolutions, while the OSM tile
-                server supports only 19 of these resolutions. The resolutions
-                for the zoom levels 20, 21 and 22 are indeed not included in
-                the OSM layer's <code>serverResolutions</code> option. The
-                map's initial zoom is 18. So if you zoom in or out you'll see
-                that "client zoom" is applied
-            </p>
-            <p>
-                See the <a href="zoomclient.js" target="_blank">
-                zoomclient.js source</a> to see how this is done.
-            </p>
-        </div>
-    </body>
-</html>
Deleted: sandbox/camptocamp/clientzoom/examples/zoomclient.js
--- sandbox/camptocamp/clientzoom/examples/zoomclient.js	2011-08-31 11:39:40 UTC (rev 12301)
+++ sandbox/camptocamp/clientzoom/examples/zoomclient.js	2011-08-31 11:42:34 UTC (rev 12302)
@@ -1,22 +0,0 @@
-var map;
-function init() {
-    map = new OpenLayers.Map({
-        div: "map",
-        projection: "EPSG:900913",
-        units: "m",
-        maxExtent: new OpenLayers.Bounds(
-            -20037508.34, -20037508.34, 20037508.34, 20037508.34
-    var osm = new OpenLayers.Layer.OSM(null, null, {
-        resolutions: [156543.03390625, 78271.516953125, 39135.7584765625, 19567.87923828125, 9783.939619140625, 4891.9698095703125, 2445.9849047851562, 1222.9924523925781, 611.4962261962891, 305.74811309814453, 152.87405654907226, 76.43702827453613, 38.218514137268066, 19.109257068634033, 9.554628534317017, 4.777314267158508, 2.388657133579254, 1.194328566789627, 0.5971642833948135,0.25,0.1,0.05],
-        serverResolutions: [156543.03390625, 78271.516953125, 39135.7584765625, 19567.87923828125, 9783.939619140625, 4891.9698095703125, 2445.9849047851562, 1222.9924523925781, 611.4962261962891, 305.74811309814453, 152.87405654907226, 76.43702827453613, 38.218514137268066, 19.109257068634033, 9.554628534317017, 4.777314267158508, 2.388657133579254, 1.194328566789627, 0.5971642833948135]
-    map.addLayers([osm]);
-    map.addControl(new OpenLayers.Control.LayerSwitcher());
-    map.setCenter(new OpenLayers.LonLat(667393.040812,lat=5668008.8022737), 18);
More information about the Commits mailing list
