[OpenLayers-Commits] r12444 - in sandbox/august/trunk: . lib
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Dec 4 16:26:54 EST 2011
Author: augusttown
Date: 2011-12-04 13:26:53 -0800 (Sun, 04 Dec 2011)
New Revision: 12444
Added:
   sandbox/august/trunk/lib/OpenLayers.js.r12437
add backup of OpenLayers.js (@ revision 12437)
Property changes on: sandbox/august/trunk
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/openlayers:10329-10354,10357-10502,10504-12437
   + /trunk/openlayers:10329-10354,10357-10502,10504-12437,12439
Added: sandbox/august/trunk/lib/OpenLayers.js.r12437
--- sandbox/august/trunk/lib/OpenLayers.js.r12437	                        (rev 0)
+++ sandbox/august/trunk/lib/OpenLayers.js.r12437	2011-12-04 21:26:53 UTC (rev 12444)
@@ -0,0 +1,397 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/BaseTypes.js
+ * @requires OpenLayers/Lang/en.js
+ * @requires OpenLayers/Console.js
+ * TODO: In 3.0, we will stop supporting build profiles that include
+ * OpenLayers.js. This means we will not need the singleFile and scriptFile
+ * variables, because we don't have to handle the singleFile case any more.
+(function() {
+     * Before creating the OpenLayers namespace, check to see if
+     * OpenLayers.singleFile is true.  This occurs if the
+     * OpenLayers/SingleFile.js script is included before this one - as is the
+     * case with old single file build profiles that included both
+     * OpenLayers.js and OpenLayers/SingleFile.js.
+    var singleFile = (typeof OpenLayers == "object" && OpenLayers.singleFile);
+     * Relative path of this script.
+    var scriptName = (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js";
+     * If window.OpenLayers isn't set when this script (OpenLayers.js) is
+     * evaluated (and if singleFile is false) then this script will load
+     * *all* OpenLayers scripts. If window.OpenLayers is set to an array
+     * then this script will attempt to load scripts for each string of
+     * the array, using the string as the src of the script.
+     * Example:
+     * (code)
+     *     <script type="text/javascript">
+     *         window.OpenLayers = [
+     *             "OpenLayers/Util.js",
+     *             "OpenLayers/BaseTypes.js"
+     *     </script>
+     *     <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+     * (end)
+     * In this example OpenLayers.js will load Util.js and BaseTypes.js only.
+    var jsFiles = window.OpenLayers;
+     * Namespace: OpenLayers
+     * The OpenLayers object provides a namespace for all things OpenLayers
+    window.OpenLayers = {
+         * Method: _getScriptLocation
+         * Return the path to this script. This is also implemented in
+         * Returns:
+         * {String} Path to this script
+        _getScriptLocation: (function() {
+            var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)"),
+                s = document.getElementsByTagName('script'),
+                src, m, l = "";
+            for(var i=0, len=s.length; i<len; i++) {
+                src = s[i].getAttribute('src');
+                if(src) {
+                    var m = src.match(r);
+                    if(m) {
+                        l = m[1];
+                        break;
+            return (function() { return l; });
+     * OpenLayers.singleFile is a flag indicating this file is being included
+     * in a Single File Library build of the OpenLayers Library.
+     * When we are *not* part of a SFL build we dynamically include the
+     * OpenLayers library code.
+     * When we *are* part of a SFL build we do not dynamically include the
+     * OpenLayers library code as it will be appended at the end of this file.
+    if(!singleFile) {
+        var jsFiles = new Array(
+            "OpenLayers/BaseTypes/Class.js",
+            "OpenLayers/Util.js",
+            "OpenLayers/BaseTypes.js",
+            "OpenLayers/BaseTypes/Bounds.js",
+            "OpenLayers/BaseTypes/Element.js",
+            "OpenLayers/BaseTypes/LonLat.js",
+            "OpenLayers/BaseTypes/Pixel.js",
+            "OpenLayers/BaseTypes/Size.js",
+            "OpenLayers/Console.js",
+            "OpenLayers/Tween.js",
+            "Rico/Corner.js",
+            "Rico/Color.js",
+            "OpenLayers/Ajax.js",
+            "OpenLayers/Events.js",
+            "OpenLayers/Request.js",
+            "OpenLayers/Request/XMLHttpRequest.js",
+            "OpenLayers/Projection.js",
+            "OpenLayers/Map.js",
+            "OpenLayers/Layer.js",
+            "OpenLayers/Icon.js",
+            "OpenLayers/Marker.js",
+            "OpenLayers/Marker/Box.js",
+            "OpenLayers/Popup.js",
+            "OpenLayers/Util/AgsUtil.js",
+            "OpenLayers/Tile.js",
+            "OpenLayers/Tile/BackBufferable.js",
+            "OpenLayers/Tile/Image.js",
+            "OpenLayers/Tile/Image/IFrame.js",
+            "OpenLayers/Tile/WFS.js",
+            "OpenLayers/Layer/Image.js",
+            "OpenLayers/Layer/SphericalMercator.js",
+            "OpenLayers/Layer/EventPane.js",
+            "OpenLayers/Layer/FixedZoomLevels.js",
+            "OpenLayers/Layer/Google.js",
+            "OpenLayers/Layer/Google/v3.js",
+            "OpenLayers/Layer/VirtualEarth.js",
+            "OpenLayers/Layer/Yahoo.js",
+            "OpenLayers/Layer/HTTPRequest.js",
+            "OpenLayers/Layer/Grid.js",
+            "OpenLayers/Layer/MapGuide.js",
+            "OpenLayers/Layer/MapServer.js",
+            "OpenLayers/Layer/MapServer/Untiled.js",
+            "OpenLayers/Layer/KaMap.js",
+            "OpenLayers/Layer/KaMapCache.js",
+            "OpenLayers/Layer/MultiMap.js",
+            "OpenLayers/Layer/Markers.js",
+            "OpenLayers/Layer/Text.js",
+            "OpenLayers/Layer/WorldWind.js",
+            "OpenLayers/Layer/ArcGIS93Rest.js",
+            "OpenLayers/Layer/AgsTiled.js",
+            "OpenLayers/Layer/WMS.js",
+            "OpenLayers/Layer/WMS/Untiled.js",
+            "OpenLayers/Layer/WMS/Post.js",
+            "OpenLayers/Layer/WMTS.js",
+            "OpenLayers/Layer/ArcIMS.js",
+            "OpenLayers/Layer/GeoRSS.js",
+            "OpenLayers/Layer/Boxes.js",
+            "OpenLayers/Layer/XYZ.js",
+            "OpenLayers/Layer/Bing.js",
+            "OpenLayers/Layer/TMS.js",
+            "OpenLayers/Layer/TileCache.js",
+            "OpenLayers/Layer/Zoomify.js",
+            "OpenLayers/Layer/Process.js",
+            "OpenLayers/Popup/Anchored.js",
+            "OpenLayers/Popup/AnchoredBubble.js",
+            "OpenLayers/Popup/Framed.js",
+            "OpenLayers/Popup/FramedCloud.js",
+            "OpenLayers/Feature.js",
+            "OpenLayers/Feature/Vector.js",
+            "OpenLayers/Feature/WFS.js",
+            "OpenLayers/Handler.js",
+            "OpenLayers/Handler/Click.js",
+            "OpenLayers/Handler/Hover.js",
+            "OpenLayers/Handler/Point.js",
+            "OpenLayers/Handler/Path.js",
+            "OpenLayers/Handler/Polygon.js",
+            "OpenLayers/Handler/Feature.js",
+            "OpenLayers/Handler/Drag.js",
+            "OpenLayers/Handler/RegularPolygon.js",
+            "OpenLayers/Handler/Box.js",
+            "OpenLayers/Handler/MouseWheel.js",
+            "OpenLayers/Handler/Keyboard.js",
+            "OpenLayers/Control.js",
+            "OpenLayers/Control/Attribution.js",
+            "OpenLayers/Control/Button.js",
+            "OpenLayers/Control/ZoomBox.js",
+            "OpenLayers/Control/ZoomToMaxExtent.js",
+            "OpenLayers/Control/DragPan.js",
+            "OpenLayers/Control/Navigation.js",
+            "OpenLayers/Control/MouseDefaults.js",
+            "OpenLayers/Control/MousePosition.js",
+            "OpenLayers/Control/OverviewMap.js",
+            "OpenLayers/Control/KeyboardDefaults.js",
+            "OpenLayers/Control/PanZoom.js",
+            "OpenLayers/Control/PanZoomBar.js",
+            "OpenLayers/Control/ArgParser.js",
+            "OpenLayers/Control/Permalink.js",
+            "OpenLayers/Control/Scale.js",
+            "OpenLayers/Control/ScaleLine.js",
+            "OpenLayers/Control/Snapping.js",
+            "OpenLayers/Control/Split.js",
+            "OpenLayers/Control/LayerSwitcher.js",
+            "OpenLayers/Control/DrawFeature.js",
+            "OpenLayers/Control/DragFeature.js",
+            "OpenLayers/Control/ModifyFeature.js",
+            "OpenLayers/Control/Panel.js",
+            "OpenLayers/Control/SelectFeature.js",
+            "OpenLayers/Control/NavigationHistory.js",
+            "OpenLayers/Control/Measure.js",
+            "OpenLayers/Control/WMSGetFeatureInfo.js",
+            "OpenLayers/Control/WMTSGetFeatureInfo.js",
+            "OpenLayers/Control/Graticule.js",
+            "OpenLayers/Control/TransformFeature.js",
+            "OpenLayers/Control/SLDSelect.js",
+            "OpenLayers/Control/AgsControl.js",
+            "OpenLayers/Control/AgsGeometryService.js",
+            "OpenLayers/Control/AgsGeoprocessor.js",
+            "OpenLayers/Control/AgsIdentifyTask.js",
+            "OpenLayers/Control/AgsFindTask.js",
+            "OpenLayers/Control/AgsQueryTask.js",
+            "OpenLayers/Control/AgsLocator.js",
+			"OpenLayers/Control/AgsRouteTask.js",
+			"OpenLayers/Control/AgsWFSTLockControl.js",
+			"OpenLayers/Control/ModifyFeatureWithLock.js",
+            "OpenLayers/Geometry.js",
+            "OpenLayers/Geometry/Rectangle.js",
+            "OpenLayers/Geometry/Collection.js",
+            "OpenLayers/Geometry/Point.js",
+            "OpenLayers/Geometry/MultiPoint.js",
+            "OpenLayers/Geometry/Curve.js",
+            "OpenLayers/Geometry/LineString.js",
+            "OpenLayers/Geometry/LinearRing.js",
+            "OpenLayers/Geometry/Polygon.js",
+            "OpenLayers/Geometry/MultiLineString.js",
+            "OpenLayers/Geometry/MultiPolygon.js",
+            "OpenLayers/Geometry/Surface.js",
+            "OpenLayers/Renderer.js",
+            "OpenLayers/Renderer/Elements.js",
+            "OpenLayers/Renderer/SVG.js",
+            "OpenLayers/Renderer/Canvas.js",
+            "OpenLayers/Renderer/VML.js",
+            "OpenLayers/Layer/Vector.js",
+            "OpenLayers/Layer/Vector/RootContainer.js",
+            "OpenLayers/Strategy.js",
+            "OpenLayers/Strategy/Filter.js",
+            "OpenLayers/Strategy/Fixed.js",
+            "OpenLayers/Strategy/Cluster.js",
+            "OpenLayers/Strategy/Paging.js",
+            "OpenLayers/Strategy/BBOX.js",
+            "OpenLayers/Strategy/Save.js",
+            "OpenLayers/Strategy/Lock.js",
+            "OpenLayers/Strategy/SaveWithLock.js",
+            "OpenLayers/Strategy/Refresh.js",
+            "OpenLayers/Filter.js",
+            "OpenLayers/Filter/FeatureId.js",
+            "OpenLayers/Filter/Function.js",
+            "OpenLayers/Filter/Logical.js",
+            "OpenLayers/Filter/Comparison.js",
+            "OpenLayers/Filter/Spatial.js",
+            "OpenLayers/Protocol.js",
+            "OpenLayers/Protocol/HTTP.js",
+            "OpenLayers/Protocol/SQL.js",
+            "OpenLayers/Protocol/SQL/Gears.js",
+            "OpenLayers/Protocol/WFS.js",
+            "OpenLayers/Protocol/WFS/v1.js",
+            "OpenLayers/Protocol/WFS/v1_0_0.js",
+            "OpenLayers/Protocol/WFS/v1_1_0.js",
+            "OpenLayers/Protocol/WFSTWithLock.js",
+            "OpenLayers/Protocol/WFSTWithLock/v1.js",
+            "OpenLayers/Protocol/WFSTWithLock/v1_0_0.js",
+            "OpenLayers/Protocol/WFSTWithLock/v1_1_0.js",
+            "OpenLayers/Protocol/AgsFeatureAccess.js",
+            "OpenLayers/Protocol/AgsFeatureAccess/v2.js",
+            "OpenLayers/Protocol/AgsFeatureAccess/v2_0.js",
+            "OpenLayers/Protocol/SOS.js",
+            "OpenLayers/Protocol/SOS/v1_0_0.js",
+            "OpenLayers/Protocol/Script.js",
+            "OpenLayers/Layer/PointTrack.js",
+            "OpenLayers/Layer/GML.js",
+            "OpenLayers/Style.js",
+            "OpenLayers/Style2.js",
+            "OpenLayers/StyleMap.js",
+            "OpenLayers/Rule.js",
+            "OpenLayers/Format.js",
+            "OpenLayers/Format/XML.js",
+            "OpenLayers/Format/XML/VersionedOGC.js",
+            "OpenLayers/Format/Context.js",
+            "OpenLayers/Format/ArcXML.js",
+            "OpenLayers/Format/ArcXML/Features.js",
+            "OpenLayers/Format/AgsJsAdapter.js",
+            "OpenLayers/Format/GML.js",
+            "OpenLayers/Format/GML/Base.js",
+            "OpenLayers/Format/GML/v2.js",
+            "OpenLayers/Format/GML/v3.js",
+            "OpenLayers/Format/Atom.js",
+            "OpenLayers/Format/KML.js",
+            "OpenLayers/Format/GeoRSS.js",
+            "OpenLayers/Format/WFS.js",
+            "OpenLayers/Format/WFSCapabilities.js",
+            "OpenLayers/Format/WFSCapabilities/v1.js",
+            "OpenLayers/Format/WFSCapabilities/v1_0_0.js",
+            "OpenLayers/Format/WFSCapabilities/v1_1_0.js",
+            "OpenLayers/Format/WFSDescribeFeatureType.js",
+            "OpenLayers/Format/WMSDescribeLayer.js",
+            "OpenLayers/Format/WMSDescribeLayer/v1_1.js",
+            "OpenLayers/Format/WKT.js",
+            "OpenLayers/Format/CQL.js",
+            "OpenLayers/Format/OSM.js",
+            "OpenLayers/Format/GPX.js",
+            "OpenLayers/Format/Filter.js",
+            "OpenLayers/Format/Filter/v1.js",
+            "OpenLayers/Format/Filter/v1_0_0.js",
+            "OpenLayers/Format/Filter/v1_1_0.js",
+            "OpenLayers/Format/SLD.js",
+            "OpenLayers/Format/SLD/v1.js",
+            "OpenLayers/Format/SLD/v1_0_0.js",
+            "OpenLayers/Format/OWSCommon.js",
+            "OpenLayers/Format/OWSCommon/v1.js",
+            "OpenLayers/Format/OWSCommon/v1_0_0.js",
+            "OpenLayers/Format/OWSCommon/v1_1_0.js",
+            "OpenLayers/Format/CSWGetDomain.js",
+            "OpenLayers/Format/CSWGetDomain/v2_0_2.js",
+            "OpenLayers/Format/CSWGetRecords.js",
+            "OpenLayers/Format/CSWGetRecords/v2_0_2.js",
+            "OpenLayers/Format/WFST.js",
+            "OpenLayers/Format/WFST/v1.js",
+            "OpenLayers/Format/WFST/v1_0_0.js",
+            "OpenLayers/Format/WFST/v1_1_0.js",
+            "OpenLayers/Format/WFSTWithLock.js",
+            "OpenLayers/Format/WFSTWithLock/v1.js",
+            "OpenLayers/Format/WFSTWithLock/v1_0_0.js",
+            "OpenLayers/Format/WFSTWithLock/v1_1_0.js",
+            "OpenLayers/Format/Text.js",
+            "OpenLayers/Format/JSON.js",
+            "OpenLayers/Format/GeoJSON.js",
+            "OpenLayers/Format/WMC.js",
+            "OpenLayers/Format/WMC/v1.js",
+            "OpenLayers/Format/WMC/v1_0_0.js",
+            "OpenLayers/Format/WMC/v1_1_0.js",
+            "OpenLayers/Format/WMSCapabilities.js",
+            "OpenLayers/Format/WMSCapabilities/v1.js",
+            "OpenLayers/Format/WMSCapabilities/v1_1.js",
+            "OpenLayers/Format/WMSCapabilities/v1_1_0.js",
+            "OpenLayers/Format/WMSCapabilities/v1_1_1.js",
+            "OpenLayers/Format/WMSCapabilities/v1_3.js",
+            "OpenLayers/Format/WMSCapabilities/v1_3_0.js",
+            "OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js",
+            "OpenLayers/Format/WMSGetFeatureInfo.js",
+            "OpenLayers/Format/SOSCapabilities.js",
+            "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
+            "OpenLayers/Format/SOSGetFeatureOfInterest.js",
+            "OpenLayers/Format/SOSGetObservation.js",
+            "OpenLayers/Format/OWSContext.js",
+            "OpenLayers/Format/OWSContext/v0_3_1.js",
+            "OpenLayers/Format/WMTSCapabilities.js",
+            "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+            "OpenLayers/Format/WPSCommon.js",
+            "OpenLayers/Format/WPSCommon/v1_0_0.js",
+            "OpenLayers/Layer/WFS.js",
+            "OpenLayers/Control/GetFeature.js",
+            "OpenLayers/Control/MouseToolbar.js",
+            "OpenLayers/Control/NavToolbar.js",
+            "OpenLayers/Control/PanPanel.js",
+            "OpenLayers/Control/Pan.js",
+            "OpenLayers/Control/ZoomIn.js",
+            "OpenLayers/Control/ZoomOut.js",
+            "OpenLayers/Control/ZoomPanel.js",
+            "OpenLayers/Control/EditingToolbar.js",
+            "OpenLayers/Symbolizer.js",
+            "OpenLayers/Symbolizer/Point.js",
+            "OpenLayers/Symbolizer/Line.js",
+            "OpenLayers/Symbolizer/Polygon.js",
+            "OpenLayers/Symbolizer/Text.js",
+            "OpenLayers/Symbolizer/Raster.js",
+            "OpenLayers/Process.js",
+            "OpenLayers/Process/WPS.js",
+            "OpenLayers/Test.js",
+            "OpenLayers/Test/AgsOgcRegression.js",
+            "OpenLayers/Test/AgsRestAdmin.js",
+            "OpenLayers/Lang.js",
+            "OpenLayers/Lang/en.js"
+        ); // etc.
+        // use "parser-inserted scripts" for guaranteed execution order
+        // http://hsivonen.iki.fi/script-execution/
+        var scriptTags = new Array(jsFiles.length);
+        var host = OpenLayers._getScriptLocation() + "lib/";
+        for (var i=0, len=jsFiles.length; i<len; i++) {
+            scriptTags[i] = "<script src='" + host + jsFiles[i] +
+                                   "'></script>";
+        if (scriptTags.length > 0) {
+            document.write(scriptTags.join(""));
+ * Constant: VERSION_NUMBER
+OpenLayers.VERSION_NUMBER="$Revision: 12440 $";
More information about the Commits mailing list
