[OpenLayers-Commits] r12448 - in sandbox/august/trunk: . build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Dec 21 15:49:35 EST 2011
Author: augusttown
Date: 2011-12-21 12:49:34 -0800 (Wed, 21 Dec 2011)
New Revision: 12448
Added:
   sandbox/august/trunk/build/OpenLayers-Closure.js
   sandbox/august/trunk/build/OpenLayers-jsmin.js
   sandbox/august/trunk/OpenLayers.js
   sandbox/august/trunk/build/build.full.closure.bat
build OpenLayers with jsmin and closure.
Modified: sandbox/august/trunk/OpenLayers.js
--- sandbox/august/trunk/OpenLayers.js	2011-12-21 20:44:55 UTC (rev 12447)
+++ sandbox/august/trunk/OpenLayers.js	2011-12-21 20:49:34 UTC (rev 12448)
@@ -1643,7 +1643,16 @@
 Style:function(a,b){var c={};c.isDefault="true"===a.getAttribute("isDefault");this.readChildNodes(a,c);b.styles.push(c)},Format:function(a,b){b.formats.push(this.getChildValue(a))},TileMatrixSetLink:function(a,b){var c={};this.readChildNodes(a,c);b.tileMatrixSetLinks.push(c)},TileMatrixSet:function(a,b){if(b.layers){var c={matrixIds:[]};this.readChildNodes(a,c);b.tileMatrixSets[c.identifier]=c}else b.tileMatrixSet=this.getChildValue(a)},TileMatrix:function(a,b){var c={supportedCRS:b.supportedCRS};
 this.readChildNodes(a,c);b.matrixIds.push(c)},ScaleDenominator:function(a,b){b.scaleDenominator=parseFloat(this.getChildValue(a))},TopLeftCorner:function(a,b){var c=this.getChildValue(a).split(" "),d;b.supportedCRS&&(d=!!this.yx[b.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2")]);b.topLeftCorner=d?new OpenLayers.LonLat(c[1],c[0]):new OpenLayers.LonLat(c[0],c[1])},TileWidth:function(a,b){b.tileWidth=parseInt(this.getChildValue(a))},TileHeight:function(a,b){b.tileHeight=
 parseInt(this.getChildValue(a))},MatrixWidth:function(a,b){b.matrixWidth=parseInt(this.getChildValue(a))},MatrixHeight:function(a,b){b.matrixHeight=parseInt(this.getChildValue(a))},ResourceURL:function(a,b){b.resourceUrl=b.resourceUrl||{};b.resourceUrl[a.getAttribute("resourceType")]={format:a.getAttribute("format"),template:a.getAttribute("template")}},WSDL:function(a,b){b.wsdl={};b.wsdl.href=a.getAttribute("xlink:href")},ServiceMetadataURL:function(a,b){b.serviceMetadataUrl={};b.serviceMetadataUrl.href=
-a.getAttribute("xlink:href")},LegendURL:function(a,b){b.legend={};b.legend.href=a.getAttribute("xlink:href");b.legend.format=a.getAttribute("format")},Dimension:function(a,b){var c={values:[]};this.readChildNodes(a,c);b.dimensions.push(c)},Default:function(a,b){b["default"]=this.getChildValue(a)},Value:function(a,b){b.values.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities.v1_0_0"});
+a.getAttribute("xlink:href")},LegendURL:function(a,b){b.legend={};b.legend.href=a.getAttribute("xlink:href");b.legend.format=a.getAttribute("format")},Dimension:function(a,b){var c={values:[]};this.readChildNodes(a,c);b.dimensions.push(c)},Default:function(a,b){b["default"]=this.getChildValue(a)},Value:function(a,b){b.values.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities.v1_0_0"});OpenLayers.Raster={};
+OpenLayers.Raster.Grid=OpenLayers.Class({EVENT_TYPES:["update"],initialize:function(a){OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES)},getValue:function(){throw Error("getValue must be defined");},numCols:function(){throw Error("numCols must be defined");},numRows:function(){throw Error("numRows must be defined");},forEach:function(a){for(var b=this.numCols(),c=this.numRows(),d=0;d<c;++d)for(var e=0;e<b;++e)a(this.getValue(e,d),e+d*b)},CLASS_NAME:"OpenLayers.Raster.Grid"});
+OpenLayers.Raster.Grid.fromArray=function(a){var b=a.length,c=a[0]&&a[0].length||0;return new OpenLayers.Raster.Grid({numCols:function(){return c},numRows:function(){return b},getValue:function(b,c){return a[c][b]}})};
+OpenLayers.Raster.Composite=OpenLayers.Class(OpenLayers.Raster.Grid,function(){var a;return{initialize:function(b){if(b.grids)a=b.grids,delete b.grids;OpenLayers.Raster.Grid.prototype.initialize.apply(this,[b]);if(a)for(var b=0,c=a.length;b<c;++b)a[b].events.register("update",this,function(){this.events.triggerEvent("update")})},numCols:function(){return a&&a[0]&&a[0].numCols()},numRows:function(){return a&&a[0]&&a[0].numRows()},getCount:function(){return a&&a.length},getValue:function(b,c){for(var d=
+a.length,e=Array(d),f=0;f<d;++f)e[f]=a[f].getValue(b,c);return e},getGrid:function(a){if("number"!==typeof a||isNaN(a)||0>a||a>=this.getCount())throw Error("Bad grid index.");var c=this;return new OpenLayers.Raster.Grid({numCols:function(){return c.numCols()},numRows:function(){return c.numRows()},getValue:function(d,e){return c.getValue(d,e)[a]}})},CLASS_NAME:"OpenLayers.Raster.Composite"}}());
+OpenLayers.Raster.Composite.fromLayer=function(a){var b;function c(){b=void 0;var c=a.map,h=a.tileSize,i=c.getSize();d.width=i.w;d.height=i.h;for(var i=c.getExtent(),j=a.grid,k,m,n,l=0,o=j.length;l<o;++l){k=j[l];for(var q=0,r=k.length;q<r;++q)if(m=k[q],n=m.bounds,(m=m.imgDiv)&&"none"!==m.style.display&&i.intersectsBounds(n))n=new OpenLayers.LonLat(n.left,n.top),n=c.getPixelFromLonLat(n),e.drawImage(m,n.x,n.y,h.w,h.h)}f.events.triggerEvent("update")}if(!(a instanceof OpenLayers.Layer.Grid))throw Error("Only OpenLayers.Layer.Grid type layers can be used to create a raster");
+var d=document.createElement("canvas"),e=d.getContext("2d"),f=new OpenLayers.Raster.Composite({numCols:function(){return d.width},numRows:function(){return d.height},getCount:function(){return 4},getValue:function(a,c){if(!b)b=e.getImageData(0,0,d.width,d.height).data;var f=4*(a+c*d.width);return Array.prototype.slice.apply(b,[f,f+4])}});b=void 0;a.map?a.map.events.register("moveend",null,c):a.events.register("added",null,function(){a.map.events.register("moveend",null,c)});a.events.register("tileloaded",
+null,c);return f};
+OpenLayers.Raster.Operation=function(){var a=OpenLayers.Raster.Grid,b=OpenLayers.Raster.Composite,c={};return{create:function(c){return function(){function e(){for(var b,c=0;c<g;++c)if(f[c]instanceof a){b=f[c];break}if(!b)throw Error("Operation must be called with at least one grid.");return b}for(var f=Array.prototype.slice.call(arguments),g=f.length,h=1,i=0;i<g;++i)f[i]instanceof b&&(h=Math.max(h,f[i].getCount()));for(var j=new (1<h?b:a)({numCols:function(){return e().numCols()},numRows:function(){return e().numRows()},
+getValue:function(b,e){for(var h=Array(g),i,j=0;j<g;++j)i=f[j],h[j]=i instanceof a?i.getValue(b,e):i;return c.apply(null,h)},getCount:function(){return h}}),i=0;i<g;++i)f[i]instanceof a&&f[i].events.register("update",null,function(){j.events.triggerEvent("update")});return j}},get:function(a){return c[a]}}}();
 OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:!0,panMapIfOutOfView:!0,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:!1,fixedRelativePosition:!1,positionBlocks:{tl:{offset:new OpenLayers.Pixel(44,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,
 50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},tr:{offset:new OpenLayers.Pixel(-45,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto",
 "auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,
@@ -1774,8 +1783,10 @@
 b)},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon()},dragPanMapObject:function(a,b){this.mapObject.moveByXY({x:-a,y:b})},getMapObjectZoom:function(){return this.mapObject.getZoomLevel()},getMapObjectLonLatFromMapObjectPixel:function(a){return this.mapObject.convertXYLatLon(a)},getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.convertLatLonXY(a)},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Lon,a.Lat).lon:
 a.Lon},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Lon,a.Lat).lat:a.Lat},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new YGeoPoint(c.lat,c.lon)):c=new YGeoPoint(b,a);return c},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},getMapObjectPixelFromXY:function(a,b){return new YCoordPoint(a,b)},getMapObjectSizeFromOLSize:function(a){return new YSize(a.w,
 a.h)},CLASS_NAME:"OpenLayers.Layer.Yahoo"});
-OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(a){a=a||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[a.name,a])},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);a.events.register("moveend",this,this.onMoveEnd)},removeMap:function(a){a.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments)},
-setRatio:function(a){this.ratio=a;this.updateGrid(!0)},setMaxFeatures:function(a){this.maxFeatures=a;this.updateGrid(!0)},setSpacing:function(a,b){this.dx=a;this.dy=b||a;this.updateGrid(!0)},setOrigin:function(a){this.origin=a;this.updateGrid(!0)},getOrigin:function(){if(!this.origin)this.origin=this.map.getExtent().getCenterLonLat();return this.origin},setRotation:function(a){this.rotation=a;this.updateGrid(!0)},onMoveEnd:function(){this.updateGrid()},getViewBounds:function(){var a=this.map.getExtent();
+OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{keydown:this.defaultKeyPress})},defaultKeyPress:function(a){switch(a.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,
+this.slideFactor);break;case 33:a=this.map.getSize();this.map.pan(0,-0.75*a.h);break;case 34:a=this.map.getSize();this.map.pan(0,0.75*a.h);break;case 35:a=this.map.getSize();this.map.pan(0.75*a.w,0);break;case 36:a=this.map.getSize();this.map.pan(-0.75*a.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut()}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});
+OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(a){a=a||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[a.name,a])},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);a.events.register("moveend",this,this.onMoveEnd)},removeMap:function(a){a.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,
+arguments)},setRatio:function(a){this.ratio=a;this.updateGrid(!0)},setMaxFeatures:function(a){this.maxFeatures=a;this.updateGrid(!0)},setSpacing:function(a,b){this.dx=a;this.dy=b||a;this.updateGrid(!0)},setOrigin:function(a){this.origin=a;this.updateGrid(!0)},getOrigin:function(){if(!this.origin)this.origin=this.map.getExtent().getCenterLonLat();return this.origin},setRotation:function(a){this.rotation=a;this.updateGrid(!0)},onMoveEnd:function(){this.updateGrid()},getViewBounds:function(){var a=this.map.getExtent();
 if(this.rotation){var b=this.getOrigin(),b=new OpenLayers.Geometry.Point(b.lon,b.lat),a=a.toGeometry();a.rotate(-this.rotation,b);a=a.getBounds()}return a},updateGrid:function(a){if(a||this.invalidBounds()){var b=this.getViewBounds(),c=this.getOrigin(),a=new OpenLayers.Geometry.Point(c.lon,c.lat),d=b.getWidth(),e=b.getHeight(),f=d/e,g=Math.sqrt(this.dx*this.dy*this.maxFeatures/f),d=Math.min(d*this.ratio,g*f),e=Math.min(e*this.ratio,g),b=b.getCenterLonLat();this.gridBounds=new OpenLayers.Bounds(b.lon-
 d/2,b.lat-e/2,b.lon+d/2,b.lat+e/2);for(var b=Math.floor(e/this.dy),d=Math.floor(d/this.dx),e=c.lon+this.dx*Math.ceil((this.gridBounds.left-c.lon)/this.dx),c=c.lat+this.dy*Math.ceil((this.gridBounds.bottom-c.lat)/this.dy),g=Array(b*d),h,i=0;i<d;++i)for(var f=e+i*this.dx,j=0;j<b;++j)h=c+j*this.dy,h=new OpenLayers.Geometry.Point(f,h),this.rotation&&h.rotate(this.rotation,a),g[i*b+j]=new OpenLayers.Feature.Vector(h);this.destroyFeatures(this.features,{silent:!0});this.addFeatures(g,{silent:!0})}},invalidBounds:function(){return!this.gridBounds||
 !this.gridBounds.containsBounds(this.getViewBounds())},CLASS_NAME:"OpenLayers.Layer.PointGrid"});
@@ -1785,17 +1796,6 @@
 (b*this.tileSize.w)),a=Math.round((this.tileOrigin.lat-a.top)/(b*this.tileSize.h)),b=this.map.getZoom(),c="TileGroup"+Math.floor((c+a*this.tierSizeInTiles[b].w+this.tileCountUpToTier[b])/256)+"/"+b+"-"+c+"-"+a+".jpg",a=this.url;OpenLayers.Util.isArray(a)&&(a=this.selectUrl(c,a));return a+c},getImageSize:function(){if(0<arguments.length){var a=this.adjustBounds(arguments[0]),b=this.map.getResolution(),c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w)),a=Math.round((this.tileOrigin.lat-
 a.top)/(b*this.tileSize.h)),b=this.map.getZoom(),d=this.standardTileSize,e=this.standardTileSize;c==this.tierSizeInTiles[b].w-1&&(d=this.tierImageSize[b].w%this.standardTileSize);a==this.tierSizeInTiles[b].h-1&&(e=this.tierImageSize[b].h%this.standardTileSize);return new OpenLayers.Size(d,e)}return this.tileSize},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.top)},calculateGridLayout:function(a,
 b,c){var d=c*this.tileSize.w,c=c*this.tileSize.h,e=a.left-b.lon,f=Math.floor(e/d)-this.buffer,a=b.lat-a.top+c,g=Math.floor(a/c)-this.buffer;return{tilelon:d,tilelat:c,tileoffsetlon:b.lon+f*d,tileoffsetlat:b.lat-c*g,tileoffsetx:-(e/d-f)*this.tileSize.w,tileoffsety:(g-a/c)*this.tileSize.h}},CLASS_NAME:"OpenLayers.Layer.Zoomify"});
-OpenLayers.Format.CQL=function(){function a(a){function b(){var a=e.pop();switch(a.type){case "LOGICAL":var c=b(),g=b();return new OpenLayers.Filter.Logical({filters:[g,c],type:f[a.text.toUpperCase()]});case "NOT":return c=b(),new OpenLayers.Filter.Logical({filters:[c],type:OpenLayers.Filter.Logical.NOT});case "BETWEEN":return e.pop(),g=b(),a=b(),c=b(),new OpenLayers.Filter.Comparison({property:c,lowerBoundary:a,upperBoundary:g,type:OpenLayers.Filter.Comparison.BETWEEN});case "COMPARISON":return g=
-b(),c=b(),new OpenLayers.Filter.Comparison({property:c,value:g,type:d[a.text.toUpperCase()]});case "VALUE":return/^'.*'$/.test(a.text)?a.text.substr(1,a.text.length-2):Number(a.text);case "SPATIAL":switch(a.text.toUpperCase()){case "BBOX":var c=b(),a=b(),g=b(),h=b(),i=b();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:i,value:OpenLayers.Bounds.fromArray([h,g,a,c])});case "INTERSECTS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,
-property:c,value:g});case "WITHIN":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.WITHIN,property:c,value:g});case "CONTAINS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.CONTAINS,property:c,value:g});case "DWITHIN":return a=b(),g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,value:g,property:c,distance:Number(a)})}case "GEOMETRY":return OpenLayers.Geometry.fromWKT(a.text);default:return a.text}}
-for(var c=[],e=[];a.length;){var g=a.shift();switch(g.type){case "PROPERTY":case "GEOMETRY":case "VALUE":e.push(g);break;case "COMPARISON":case "BETWEEN":case "LOGICAL":for(var i=h[g.type];0<c.length&&h[c[c.length-1].type]<=i;)e.push(c.pop());c.push(g);break;case "SPATIAL":case "NOT":case "LPAREN":c.push(g);break;case "RPAREN":for(;0<c.length&&"LPAREN"!=c[c.length-1].type;)e.push(c.pop());c.pop();0<c.length&&"SPATIAL"==c[c.length-1].type&&e.push(c.pop());case "COMMA":case "END":break;default:throw Error("Unknown token type "+
-g.type);}}for(;0<c.length;)e.push(c.pop());a=b();if(0<e.length){a="Remaining tokens after building AST: \n";for(c=e.length-1;0<=c;c--)a+=e[c].type+": "+e[c].text+"\n";throw Error(a);}return a}var b={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('\w+'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(a){var b=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILINESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(a);
-if(b){var c=a.length,b=a.indexOf("(",b[0].length);if(-1<b)for(var d=1;b<c&&0<d;)switch(b++,a.charAt(b)){case "(":d++;break;case ")":d--}return[a.substr(0,b+1)]}},END:/^$/},c={LPAREN:["GEOMETRY","SPATIAL","PROPERTY","VALUE","LPAREN"],RPAREN:["NOT","LOGICAL","END","RPAREN"],PROPERTY:["COMPARISON","BETWEEN","COMMA"],BETWEEN:["VALUE"],COMPARISON:["VALUE"],COMMA:["GEOMETRY","VALUE","PROPERTY"],VALUE:["LOGICAL","COMMA","RPAREN","END"],SPATIAL:["LPAREN"],LOGICAL:["NOT","VALUE","SPATIAL","PROPERTY","LPAREN"],
-NOT:["PROPERTY","LPAREN"],GEOMETRY:["COMMA","RPAREN"]},d={"=":OpenLayers.Filter.Comparison.EQUAL_TO,"<>":OpenLayers.Filter.Comparison.NOT_EQUAL_TO,"<":OpenLayers.Filter.Comparison.LESS_THAN,"<=":OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,">":OpenLayers.Filter.Comparison.GREATER_THAN,">=":OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,LIKE:OpenLayers.Filter.Comparison.LIKE,BETWEEN:OpenLayers.Filter.Comparison.BETWEEN},e={},f={AND:OpenLayers.Filter.Logical.AND,OR:OpenLayers.Filter.Logical.OR},
-g={},h={RPAREN:3,LOGICAL:2,COMPARISON:1},i;for(i in d)d.hasOwnProperty(i)&&(e[d[i]]=i);for(i in f)f.hasOwnProperty(i)&&(g[f[i]]=i);return OpenLayers.Class(OpenLayers.Format,{read:function(d){var e=d,d=[],f,g=["NOT","GEOMETRY","SPATIAL","PROPERTY","LPAREN"];do{a:{f=g;for(var h=void 0,g=void 0,i=f.length,h=0;h<i;h++){var g=f[h],q=b[g]instanceof RegExp?b[g].exec(e):(0,b[g])(e);if(q){f=q[0];e=e.substr(f.length).replace(/^\s*/,"");f={type:g,text:f,remainder:e};break a}}d="ERROR: In parsing: ["+e+"], expected one of: ";
-for(h=0;h<i;h++)g=f[h],d+="\n    "+g+": "+b[g];throw Error(d);}e=f.remainder;g=c[f.type];if("END"!=f.type&&!g)throw Error("No follows list for "+f.type);d.push(f)}while("END"!=f.type);d=a(d);if(this.keepData)this.data=d;return d},write:function(a){if(a instanceof OpenLayers.Geometry)return a.toString();switch(a.CLASS_NAME){case "OpenLayers.Filter.Spatial":switch(a.type){case OpenLayers.Filter.Spatial.BBOX:return"BBOX("+a.property+","+a.value.toBBOX()+")";case OpenLayers.Filter.Spatial.DWITHIN:return"DWITHIN("+
-a.property+", "+this.write(a.value)+", "+a.distance+")";case OpenLayers.Filter.Spatial.WITHIN:return"WITHIN("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.INTERSECTS:return"INTERSECTS("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.CONTAINS:return"CONTAINS("+a.property+", "+this.write(a.value)+")";default:throw Error("Unknown spatial filter type: "+a.type);}case "OpenLayers.Filter.Logical":if(a.type==OpenLayers.Filter.Logical.NOT)return"NOT ("+this.write(a.filters[0])+
-")";for(var b="(",c=!0,d=0;d<a.filters.length;d++)c?c=!1:b+=") "+g[a.type]+" (",b+=this.write(a.filters[d]);return b+")";case "OpenLayers.Filter.Comparison":return a.type==OpenLayers.Filter.Comparison.BETWEEN?a.property+" BETWEEN "+this.write(a.lowerBoundary)+" AND "+this.write(a.upperBoundary):a.property+" "+e[a.type]+" "+this.write(a.value);case void 0:if("string"===typeof a)return"'"+a+"'";if("number"===typeof a)return""+a;default:throw Error("Can't encode: "+a.CLASS_NAME+" "+a);}},CLASS_NAME:"OpenLayers.Format.CQL"})}();
 OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(a){if(this.supported()){if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);for(var b=document.createStyleSheet(),c="shape,rect,oval,fill,stroke,imagedata,group,textbox".split(","),d=0,e=c.length;d<e;d++)b.addRule("olv\\:"+c[d],"behavior: url(#default#VML); position: absolute; display: inline-block;")}OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
 arguments)}},supported:function(){return!!document.namespaces},setExtent:function(a,b){var c=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments),d=this.getResolution(),e=a.left/d|0,d=a.top/d-this.size.h|0;b||!this.offset?(this.offset={x:e,y:d},d=e=0):(e-=this.offset.x,d-=this.offset.y);this.root.coordorigin=e-this.xOffset+" "+d;for(var e=[this.root,this.vectorRoot,this.textRoot],f=0,g=e.length;f<g;++f)d=e[f],d.coordsize=this.size.w+" "+this.size.h;this.root.style.flip="y";return c},
 setSize:function(a){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);for(var b=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot],c=this.size.w+"px",d=this.size.h+"px",e,f=0,g=b.length;f<g;++f)e=b[f],e.style.width=c,e.style.height=d},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"olv:rect":this.isComplexSymbol(b.graphicName)?"olv:shape":"olv:oval";break;case "OpenLayers.Geometry.Rectangle":c="olv:rect";break;case "OpenLayers.Geometry.LineString":case "OpenLayers.Geometry.LinearRing":case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c=
@@ -1956,6 +1956,17 @@
 d.appendChild(e);c.appendChild(d);b.appendChild(c);for(var f in a.attributes)c=this.createElementNS(this.wfsns,"wfs:Property"),d=this.createElementNS(this.wfsns,"wfs:Name"),d.appendChild(this.createTextNode(f)),c.appendChild(d),d=this.createElementNS(this.wfsns,"wfs:Value"),d.appendChild(this.createTextNode(a.attributes[f])),c.appendChild(d),b.appendChild(c);c=this.createElementNS(this.ogcns,"ogc:Filter");f=this.createElementNS(this.ogcns,"ogc:FeatureId");f.setAttribute("fid",a.fid);c.appendChild(f);
 b.appendChild(c);return b},remove:function(a){if(!a.fid)return OpenLayers.Console.userError(OpenLayers.i18n("noFID")),!1;var b=this.createElementNS(this.wfsns,"wfs:Delete");b.setAttribute("typeName",this.featurePrefix+":"+this.featureName);b.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var c=this.createElementNS(this.ogcns,"ogc:Filter"),d=this.createElementNS(this.ogcns,"ogc:FeatureId");d.setAttribute("fid",a.fid);c.appendChild(d);b.appendChild(c);return b},destroy:function(){this.layer=
 null},CLASS_NAME:"OpenLayers.Format.WFS"});
+OpenLayers.Format.CQL=function(){function a(a){function b(){var a=e.pop();switch(a.type){case "LOGICAL":var c=b(),g=b();return new OpenLayers.Filter.Logical({filters:[g,c],type:f[a.text.toUpperCase()]});case "NOT":return c=b(),new OpenLayers.Filter.Logical({filters:[c],type:OpenLayers.Filter.Logical.NOT});case "BETWEEN":return e.pop(),g=b(),a=b(),c=b(),new OpenLayers.Filter.Comparison({property:c,lowerBoundary:a,upperBoundary:g,type:OpenLayers.Filter.Comparison.BETWEEN});case "COMPARISON":return g=
+b(),c=b(),new OpenLayers.Filter.Comparison({property:c,value:g,type:d[a.text.toUpperCase()]});case "VALUE":return/^'.*'$/.test(a.text)?a.text.substr(1,a.text.length-2):Number(a.text);case "SPATIAL":switch(a.text.toUpperCase()){case "BBOX":var c=b(),a=b(),g=b(),h=b(),i=b();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:i,value:OpenLayers.Bounds.fromArray([h,g,a,c])});case "INTERSECTS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,
+property:c,value:g});case "WITHIN":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.WITHIN,property:c,value:g});case "CONTAINS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.CONTAINS,property:c,value:g});case "DWITHIN":return a=b(),g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,value:g,property:c,distance:Number(a)})}case "GEOMETRY":return OpenLayers.Geometry.fromWKT(a.text);default:return a.text}}
+for(var c=[],e=[];a.length;){var g=a.shift();switch(g.type){case "PROPERTY":case "GEOMETRY":case "VALUE":e.push(g);break;case "COMPARISON":case "BETWEEN":case "LOGICAL":for(var i=h[g.type];0<c.length&&h[c[c.length-1].type]<=i;)e.push(c.pop());c.push(g);break;case "SPATIAL":case "NOT":case "LPAREN":c.push(g);break;case "RPAREN":for(;0<c.length&&"LPAREN"!=c[c.length-1].type;)e.push(c.pop());c.pop();0<c.length&&"SPATIAL"==c[c.length-1].type&&e.push(c.pop());case "COMMA":case "END":break;default:throw Error("Unknown token type "+
+g.type);}}for(;0<c.length;)e.push(c.pop());a=b();if(0<e.length){a="Remaining tokens after building AST: \n";for(c=e.length-1;0<=c;c--)a+=e[c].type+": "+e[c].text+"\n";throw Error(a);}return a}var b={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('\w+'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(a){var b=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILINESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(a);
+if(b){var c=a.length,b=a.indexOf("(",b[0].length);if(-1<b)for(var d=1;b<c&&0<d;)switch(b++,a.charAt(b)){case "(":d++;break;case ")":d--}return[a.substr(0,b+1)]}},END:/^$/},c={LPAREN:["GEOMETRY","SPATIAL","PROPERTY","VALUE","LPAREN"],RPAREN:["NOT","LOGICAL","END","RPAREN"],PROPERTY:["COMPARISON","BETWEEN","COMMA"],BETWEEN:["VALUE"],COMPARISON:["VALUE"],COMMA:["GEOMETRY","VALUE","PROPERTY"],VALUE:["LOGICAL","COMMA","RPAREN","END"],SPATIAL:["LPAREN"],LOGICAL:["NOT","VALUE","SPATIAL","PROPERTY","LPAREN"],
+NOT:["PROPERTY","LPAREN"],GEOMETRY:["COMMA","RPAREN"]},d={"=":OpenLayers.Filter.Comparison.EQUAL_TO,"<>":OpenLayers.Filter.Comparison.NOT_EQUAL_TO,"<":OpenLayers.Filter.Comparison.LESS_THAN,"<=":OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,">":OpenLayers.Filter.Comparison.GREATER_THAN,">=":OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,LIKE:OpenLayers.Filter.Comparison.LIKE,BETWEEN:OpenLayers.Filter.Comparison.BETWEEN},e={},f={AND:OpenLayers.Filter.Logical.AND,OR:OpenLayers.Filter.Logical.OR},
+g={},h={RPAREN:3,LOGICAL:2,COMPARISON:1},i;for(i in d)d.hasOwnProperty(i)&&(e[d[i]]=i);for(i in f)f.hasOwnProperty(i)&&(g[f[i]]=i);return OpenLayers.Class(OpenLayers.Format,{read:function(d){var e=d,d=[],f,g=["NOT","GEOMETRY","SPATIAL","PROPERTY","LPAREN"];do{a:{f=g;for(var h=void 0,g=void 0,i=f.length,h=0;h<i;h++){var g=f[h],q=b[g]instanceof RegExp?b[g].exec(e):(0,b[g])(e);if(q){f=q[0];e=e.substr(f.length).replace(/^\s*/,"");f={type:g,text:f,remainder:e};break a}}d="ERROR: In parsing: ["+e+"], expected one of: ";
+for(h=0;h<i;h++)g=f[h],d+="\n    "+g+": "+b[g];throw Error(d);}e=f.remainder;g=c[f.type];if("END"!=f.type&&!g)throw Error("No follows list for "+f.type);d.push(f)}while("END"!=f.type);d=a(d);if(this.keepData)this.data=d;return d},write:function(a){if(a instanceof OpenLayers.Geometry)return a.toString();switch(a.CLASS_NAME){case "OpenLayers.Filter.Spatial":switch(a.type){case OpenLayers.Filter.Spatial.BBOX:return"BBOX("+a.property+","+a.value.toBBOX()+")";case OpenLayers.Filter.Spatial.DWITHIN:return"DWITHIN("+
+a.property+", "+this.write(a.value)+", "+a.distance+")";case OpenLayers.Filter.Spatial.WITHIN:return"WITHIN("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.INTERSECTS:return"INTERSECTS("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.CONTAINS:return"CONTAINS("+a.property+", "+this.write(a.value)+")";default:throw Error("Unknown spatial filter type: "+a.type);}case "OpenLayers.Filter.Logical":if(a.type==OpenLayers.Filter.Logical.NOT)return"NOT ("+this.write(a.filters[0])+
+")";for(var b="(",c=!0,d=0;d<a.filters.length;d++)c?c=!1:b+=") "+g[a.type]+" (",b+=this.write(a.filters[d]);return b+")";case "OpenLayers.Filter.Comparison":return a.type==OpenLayers.Filter.Comparison.BETWEEN?a.property+" BETWEEN "+this.write(a.lowerBoundary)+" AND "+this.write(a.upperBoundary):a.property+" "+e[a.type]+" "+this.write(a.value);case void 0:if("string"===typeof a)return"'"+a+"'";if("number"===typeof a)return""+a;default:throw Error("Can't encode: "+a.CLASS_NAME+" "+a);}},CLASS_NAME:"OpenLayers.Format.CQL"})}();
 OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{layer:null,source:null,sourceOptions:null,tolerance:null,edge:!0,deferDelete:!1,mutual:!0,targetFilter:null,sourceFilter:null,handler:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.options=a||{};this.options.source&&this.setSource(this.options.source)},setSource:function(a){this.active?(this.deactivate(),this.handler&&(this.handler.destroy(),delete this.handler),this.source=a,this.activate()):this.source=
 a},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a)if(this.source){if(this.source.events)this.source.events.on({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this})}else{if(!this.handler)this.handler=new OpenLayers.Handler.Path(this,{done:function(a){this.onSketchComplete({feature:new OpenLayers.Feature.Vector(a)})}},{layerOptions:this.sourceOptions});this.handler.activate()}return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.call(this);
 a&&this.source&&this.source.events&&this.layer.events.un({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});return a},onSketchComplete:function(a){this.feature=null;return!this.considerSplit(a.feature)},afterFeatureModified:function(a){if(a.modified){var b=a.feature;if(b.geometry instanceof OpenLayers.Geometry.LineString||b.geometry instanceof OpenLayers.Geometry.MultiLineString)this.feature=a.feature,this.considerSplit(a.feature)}},removeByGeometry:function(a,
@@ -2023,8 +2034,9 @@
 c)}c=c.components;if((d=this.getElementsByTagNameNS(a,b,"point"))&&0<d.length){e=0;for(f=d.length;e<f;e++){var g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s+/);2!=g.length&&(g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s*,\s*/));c.push(new OpenLayers.Geometry.Point(g[1],g[0]))}}var h=this.getElementsByTagNameNS(a,b,"line");if(h&&0<h.length)for(var i,e=0,f=h.length;e<f;e++){d=OpenLayers.String.trim(h[e].firstChild.nodeValue).split(/\s+/);i=[];for(var j=0,k=d.length;j<
 k;j+=2)g=new OpenLayers.Geometry.Point(d[j+1],d[j]),i.push(g);c.push(new OpenLayers.Geometry.LineString(i))}if((a=this.getElementsByTagNameNS(a,b,"polygon"))&&0<a.length){e=0;for(f=a.length;e<f;e++){d=OpenLayers.String.trim(a[e].firstChild.nodeValue).split(/\s+/);i=[];j=0;for(k=d.length;j<k;j+=2)g=new OpenLayers.Geometry.Point(d[j+1],d[j]),i.push(g);c.push(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(c)]))}}if(this.internalProjection&&this.externalProjection){e=0;for(f=c.length;e<
 f;e++)c[e]&&c[e].transform(this.externalProjection,this.internalProjection)}return c},parsePersonConstructs:function(a,b,c){for(var d=[],e=this.namespaces.atom,a=this.getElementsByTagNameNS(a,e,b),f=["uri","email"],g=0,h=a.length;g<h;g++){var i={};i.name=this.getFirstChildValue(a[g],e,"name",null);for(var j=0,k=f.length;j<k;j++){var m=this.getFirstChildValue(a[g],e,f[j],null);m&&(i[f[j]]=m)}d.push(i)}0<d.length&&(c[b+"s"]=d)},CLASS_NAME:"OpenLayers.Format.Atom"});
-OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{keydown:this.defaultKeyPress})},defaultKeyPress:function(a){switch(a.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,
-this.slideFactor);break;case 33:a=this.map.getSize();this.map.pan(0,-0.75*a.h);break;case 34:a=this.map.getSize();this.map.pan(0,0.75*a.h);break;case 35:a=this.map.getSize();this.map.pan(0.75*a.w,0);break;case 36:a=this.map.getSize();this.map.pan(-0.75*a.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut()}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});
+OpenLayers.Layer.Raster=OpenLayers.Class(OpenLayers.Layer,{needsUpdate:!1,initialize:function(a){var a=a||{},b=a.data;delete a.data;OpenLayers.Layer.prototype.initialize.apply(this,[a.name,a]);this.canvas=document.createElement("canvas");this.canvas.style.position="absolute";this.div.appendChild(this.canvas);this.context=this.canvas.getContext("2d");b&&this.setData(b)},setData:function(a){this.clearData();this.data=a;a.events.register("update",this,this.onDataUpdate)},clearData:function(){this.data&&
+(this.data.events.unregister("update",this,this.onDataUpdate),delete this.data)},moveTo:function(){this.needsUpdate=!0;OpenLayers.Layer.prototype.moveTo.apply(this,arguments);window.setTimeout(OpenLayers.Function.bind(this.afterMoveTo,this),0)},afterMoveTo:function(){if(this.needsUpdate)this.onDataUpdate()},onDataUpdate:function(){var a=this.map;if(a){var b=a.getSize(),c=this.data.numCols(),d=this.data.numRows(),a=a.layerContainerDiv.style;this.canvas.width=c;this.canvas.height=d;this.canvas.style.top=
+-parseInt(a.top)+"px";this.canvas.style.left=-parseInt(a.left)+"px";this.canvas.style.width=b.w+"px";this.canvas.style.height=b.h+"px";var b=this.context.createImageData(c,d),e=b.data;this.data.forEach(function(a,b){var c=4*b;a.length||(a=[a,a,a]);e[c+0]=a[0];e[c+1]=a[1];e[c+2]=a[2];e[c+3]=3<a.length?a[3]:255});this.context.putImageData(b,0,0);this.needsUpdate=!1}},CLASS_NAME:"OpenLayers.Layer.Raster"});
 OpenLayers.Control.AgsFindTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!1,asynchronous:!1,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={contains:!1,outSpatialReference:null,returnGeometry:!0,layerIds:[],searchFields:[],searchText:""};this._resultsParser={parser:this.adapter.parseAgsResults.findResults,context:this.adapter};this.execute=this._bindFunction(this.execute,this);this.active=!1;this.activate=function(){return!1};
 this.deactivate=function(){return!1}},execute:function(a,b){var c=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(c,this.taskParameters);var d=[],d=d.concat(this.taskCallbacks),d=d.concat(b),e=this._createCallbacks(this,d,{});if(!1==this.asynchronous){var d=new esri.tasks.FindTask(this.url),e=this._createCallbacks(this,[this.onExecuteComplete],{callback:e}),f=this.errback||null;try{var g=this.adapter.encodeAgsFindParameters(c)}catch(h){throw h;}d.execute(g,e,f)}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsFindTask ..."),
 "...'asynchronous' should always be set to 'false' for AgsFindTask ...";},CLASS_NAME:"OpenLayers.Control.AgsFindTask"});
Added: sandbox/august/trunk/build/OpenLayers-Closure.js
--- sandbox/august/trunk/build/OpenLayers-Closure.js	                        (rev 0)
+++ sandbox/august/trunk/build/OpenLayers-Closure.js	2011-12-21 20:49:34 UTC (rev 12448)
@@ -0,0 +1,2042 @@
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */(function(){if(!window.google||!google.gears){var a=null;if("undefined"!=typeof GearsFactory)a=new GearsFactory;else try{a=new ActiveXObject("Gears.Factory"),-1!=a.getBuildInfo().indexOf("ie_mobile")&&a.privateSetGlobalObject(this)}catch(b){if("undefined"!=typeof navigator.mimeTypes&&navigator.mimeTypes["application/x-googlegears"])a=document.createElement("object"),a.style.display="none",a.width=0,a.height=0,a.type="application/x-googlegears",document.documentElement.appendChild(a)}if(a&&(window.google||
+(google={}),!google.gears))google.gears={factory:a}}})();var OpenLayers={VERSION_NUMBER:"$Revision: 11704 $",singleFile:!0,_getScriptLocation:function(){for(var a=/(^|(.*?\/))(OpenLayers.js)(\?|$)/,b=document.getElementsByTagName("script"),c,d="",e=0,f=b.length;e<f;e++)if(c=b[e].getAttribute("src"))if(c=c.match(a)){d=c[1];break}return function(){return d}}()};
+OpenLayers.Class=function(){var a=arguments.length,b=arguments[0],c=arguments[a-1],d="function"==typeof c.initialize?c.initialize:function(){b.prototype.initialize.apply(this,arguments)};1<a?(a=[d,b].concat(Array.prototype.slice.call(arguments).slice(1,a-1),c),OpenLayers.inherit.apply(null,a)):d.prototype=c;return d};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){arguments&&arguments[0]!=OpenLayers.Class.isPrototype&&this.initialize.apply(this,arguments)}};
+OpenLayers.Class.inherit=function(a){var b=function(){a.call(this)},c=[b].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,c);return b.prototype};OpenLayers.inherit=function(a,b){var c=function(){};c.prototype=b.prototype;a.prototype=new c;var d,e;for(c=2,d=arguments.length;c<d;c++){e=arguments[c];if("function"===typeof e)e=e.prototype;OpenLayers.Util.extend(a.prototype,e)}};OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.extend=function(a,b){a=a||{};if(b){for(var c in b){var d=b[c];void 0!==d&&(a[c]=d)}if(!("function"==typeof window.Event&&b instanceof window.Event)&&b.hasOwnProperty&&b.hasOwnProperty("toString"))a.toString=b.toString}return a};
+OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:!0,defaultFilter:null,initialize:function(a){a=a||{};OpenLayers.Util.extend(this,a);this.options=a},mergeWithDefaultFilter:function(a){return a&&this.defaultFilter?new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,a]}):a||this.defaultFilter||void 0},destroy:function(){this.format=this.options=null},read:function(a){a=a||{};a.filter=this.mergeWithDefaultFilter(a.filter)},create:function(){},
+update:function(){},"delete":function(){},commit:function(){},abort:function(){},createCallback:function(a,b,c){return OpenLayers.Function.bind(function(){a.apply(this,[b,c])},this)},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:!0,features:null,reqFeatures:null,priv:null,error:null,initialize:function(a){OpenLayers.Util.extend(this,a)},success:function(){return 0<this.code},CLASS_NAME:"OpenLayers.Protocol.Response"});
+OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.SQL=OpenLayers.Class(OpenLayers.Protocol,{databaseName:"ol",tableName:"ol_vector_features",postReadFiltering:!0,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a])},destroy:function(){OpenLayers.Protocol.prototype.destroy.apply(this)},supported:function(){return!1},evaluateFilter:function(a,b){return b&&this.postReadFiltering?b.evaluate(a):!0},CLASS_NAME:"OpenLayers.Protocol.SQL"});
+OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(a){alert(a)},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};
+(function(){for(var a=document.getElementsByTagName("script"),b=0,c=a.length;b<c;++b)if(-1!=a[b].src.indexOf("firebug.js")&&console){OpenLayers.Util.extend(OpenLayers.Console,console);break}})();
+OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){OpenLayers.Lang.code||OpenLayers.Lang.setCode();return OpenLayers.Lang.code},setCode:function(a){var b;a||(a="msie"==OpenLayers.BROWSER_NAME?navigator.userLanguage:navigator.language);a=a.split("-");a[0]=a[0].toLowerCase();"object"==typeof OpenLayers.Lang[a[0]]&&(b=a[0]);if(a[1]){var c=a[0]+"-"+a[1].toUpperCase();"object"==typeof OpenLayers.Lang[c]&&(b=c)}if(!b)OpenLayers.Console.warn("Failed to find OpenLayers.Lang."+a.join("-")+" dictionary, falling back to default language"),
+b=OpenLayers.Lang.defaultCode;OpenLayers.Lang.code=b},translate:function(a,b){var c=OpenLayers.Lang[OpenLayers.Lang.getCode()];(c=c&&c[a])||(c=a);b&&(c=OpenLayers.String.format(c,b));return c}};OpenLayers.i18n=OpenLayers.Lang.translate;
+OpenLayers.String={startsWith:function(a,b){return 0==a.indexOf(b)},contains:function(a,b){return-1!=a.indexOf(b)},trim:function(a){return a.replace(/^\s\s*/,"").replace(/\s\s*$/,"")},camelize:function(a){for(var a=a.split("-"),b=a[0],c=1,d=a.length;c<d;c++)var e=a[c],b=b+(e.charAt(0).toUpperCase()+e.substring(1));return b},format:function(a,b,c){b||(b=window);return a.replace(OpenLayers.String.tokenRegEx,function(a,e){for(var f,g=e.split(/\.+/),h=0;h<g.length;h++)0==h&&(f=b),f=f[g[h]];"function"==
+typeof f&&(f=c?f.apply(null,c):f());return"undefined"==typeof f?"undefined":f})},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(a){return OpenLayers.String.numberRegEx.test(a)},numericIf:function(a){return OpenLayers.String.isNumeric(a)?parseFloat(a):a}};
+if(!String.prototype.startsWith)String.prototype.startsWith=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.startsWith"}));return OpenLayers.String.startsWith(this,a)};if(!String.prototype.contains)String.prototype.contains=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.contains"}));return OpenLayers.String.contains(this,a)};
+if(!String.prototype.trim)String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.trim"}));return OpenLayers.String.trim(this)};if(!String.prototype.camelize)String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.camelize"}));return OpenLayers.String.camelize(this)};
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(a,b){var c=0;0<b&&(c=parseFloat(a.toPrecision(b)));return c},format:function(a,b,c,d){b="undefined"!=typeof b?b:0;c="undefined"!=typeof c?c:OpenLayers.Number.thousandsSeparator;d="undefined"!=typeof d?d:OpenLayers.Number.decimalSeparator;null!=b&&(a=parseFloat(a.toFixed(b)));var e=a.toString().split(".");1==e.length&&null==b&&(b=0);a=e[0];if(c)for(var f=/(-?[0-9]+)([0-9]{3})/;f.test(a);)a=a.replace(f,"$1"+c+"$2");
+0==b?b=a:(c=1<e.length?e[1]:"0",null!=b&&(c+=Array(b-c.length+1).join("0")),b=a+d+c);return b}};if(!Number.prototype.limitSigDigs)Number.prototype.limitSigDigs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Number.limitSigDigs"}));return OpenLayers.Number.limitSigDigs(this,a)};
+OpenLayers.Function={bind:function(a,b){var c=Array.prototype.slice.apply(arguments,[2]);return function(){var d=c.concat(Array.prototype.slice.apply(arguments,[0]));return a.apply(b,d)}},bindAsEventListener:function(a,b){return function(c){return a.call(b,c||window.event)}},False:function(){return!1},True:function(){return!0},Void:function(){}};
+if(!Function.prototype.bind)Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bind"}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments)};
+if(!Function.prototype.bindAsEventListener)Function.prototype.bindAsEventListener=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bindAsEventListener"}));return OpenLayers.Function.bindAsEventListener(this,a)};OpenLayers.Array={filter:function(a,b,c){var d=[];if(Array.prototype.filter)d=a.filter(b,c);else{var e=a.length;if("function"!=typeof b)throw new TypeError;for(var f=0;f<e;f++)if(f in a){var g=a[f];b.call(c,g,f,a)&&d.push(g)}}return d}};
+OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(a,b,c,d){if(null!=a)this.left=OpenLayers.Util.toFloat(a);if(null!=b)this.bottom=OpenLayers.Util.toFloat(b);if(null!=c)this.right=OpenLayers.Util.toFloat(c);if(null!=d)this.top=OpenLayers.Util.toFloat(d)},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top)},equals:function(a){var b=!1;null!=a&&(b=this.left==a.left&&this.right==a.right&&this.top==a.top&&
+this.bottom==a.bottom);return b},toString:function(){return[this.left,this.bottom,this.right,this.top].join()},toArray:function(a){return!0===a?[this.bottom,this.left,this.top,this.right]:[this.left,this.bottom,this.right,this.top]},toBBOX:function(a,b){null==a&&(a=6);var c=Math.pow(10,a),d=Math.round(this.left*c)/c,e=Math.round(this.bottom*c)/c,f=Math.round(this.right*c)/c,c=Math.round(this.top*c)/c;return!0===b?e+","+d+","+c+","+f:d+","+e+","+f+","+c},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,
+this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])])},getWidth:function(){return this.right-this.left},getHeight:function(){return this.top-this.bottom},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight())},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2)},getCenterLonLat:function(){if(!this.centerLonLat)this.centerLonLat=
+new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);return this.centerLonLat},scale:function(a,b){null==b&&(b=this.getCenterLonLat());var c,d;"OpenLayers.LonLat"==b.CLASS_NAME?(c=b.lon,d=b.lat):(c=b.x,d=b.y);return new OpenLayers.Bounds((this.left-c)*a+c,(this.bottom-d)*a+d,(this.right-c)*a+c,(this.top-d)*a+d)},add:function(a,b){if(null==a||null==b)throw new TypeError("Bounds.add cannot receive null values");return new OpenLayers.Bounds(this.left+a,this.bottom+b,this.right+a,
+this.top+b)},extend:function(a){var b=null;if(a){switch(a.CLASS_NAME){case "OpenLayers.LonLat":b=new OpenLayers.Bounds(a.lon,a.lat,a.lon,a.lat);break;case "OpenLayers.Geometry.Point":b=new OpenLayers.Bounds(a.x,a.y,a.x,a.y);break;case "OpenLayers.Bounds":b=a}if(b){this.centerLonLat=null;if(null==this.left||b.left<this.left)this.left=b.left;if(null==this.bottom||b.bottom<this.bottom)this.bottom=b.bottom;if(null==this.right||b.right>this.right)this.right=b.right;if(null==this.top||b.top>this.top)this.top=
+b.top}}},containsLonLat:function(a,b){"boolean"===typeof b&&(b={inclusive:b});var b=b||{},c=this.contains(a.lon,a.lat,b.inclusive),d=b.worldBounds;d&&!c&&(c=d.getWidth(),a=a.clone(),d=Math.round((a.lon-(d.left+d.right)/2)/c),a.lon-=d*c,c=this.containsLonLat(a,{inclusive:b.inclusive}));return c},containsPixel:function(a,b){return this.contains(a.x,a.y,b)},contains:function(a,b,c){null==c&&(c=!0);if(null==a||null==b)return!1;var a=OpenLayers.Util.toFloat(a),b=OpenLayers.Util.toFloat(b),d=!1;return d=
+c?a>=this.left&&a<=this.right&&b>=this.bottom&&b<=this.top:a>this.left&&a<this.right&&b>this.bottom&&b<this.top},intersectsBounds:function(a,b){"boolean"===typeof b&&(b={inclusive:b});b=b||{};if(b.worldBounds)var c=this.wrapDateLine(b.worldBounds),a=a.wrapDateLine(b.worldBounds);else c=this;if(null==b.inclusive)b.inclusive=!0;var d=!1,e=c.left==a.right||c.right==a.left||c.top==a.bottom||c.bottom==a.top;if(b.inclusive||!e)var d=a.top>=c.bottom&&a.top<=c.top||c.top>a.bottom&&c.top<a.top,e=a.left>=c.left&&
+a.left<=c.right||c.left>=a.left&&c.left<=a.right,f=a.right>=c.left&&a.right<=c.right||c.right>=a.left&&c.right<=a.right,d=(a.bottom>=c.bottom&&a.bottom<=c.top||c.bottom>=a.bottom&&c.bottom<=a.top||d)&&(e||f);if(b.worldBounds&&!d){var g=b.worldBounds,e=g.getWidth(),f=!g.containsBounds(c),g=!g.containsBounds(a);f&&!g?(a=a.add(-e,0),d=c.intersectsBounds(a,{inclusive:b.inclusive})):g&&!f&&(c=c.add(-e,0),d=a.intersectsBounds(c,{inclusive:b.inclusive}))}return d},containsBounds:function(a,b,c){null==b&&
+(b=!1);null==c&&(c=!0);var d=this.contains(a.left,a.bottom,c),e=this.contains(a.right,a.bottom,c),f=this.contains(a.left,a.top,c),a=this.contains(a.right,a.top,c);return b?d||e||f||a:d&&e&&f&&a},determineQuadrant:function(a){var b="",c=this.getCenterLonLat(),b=b+(a.lat<c.lat?"b":"t");return b+=a.lon<c.lon?"l":"r"},transform:function(a,b){this.centerLonLat=null;var c=OpenLayers.Projection.transform({x:this.left,y:this.bottom},a,b),d=OpenLayers.Projection.transform({x:this.right,y:this.bottom},a,b),
+e=OpenLayers.Projection.transform({x:this.left,y:this.top},a,b),f=OpenLayers.Projection.transform({x:this.right,y:this.top},a,b);this.left=Math.min(c.x,e.x);this.bottom=Math.min(c.y,d.y);this.right=Math.max(d.x,f.x);this.top=Math.max(e.y,f.y);return this},wrapDateLine:function(a,b){var b=b||{},c=b.leftTolerance||0,d=b.rightTolerance||0,e=this.clone();if(a){for(var f=a.getWidth();e.left<a.left&&e.right-d<=a.left;)e=e.add(f,0);for(;e.left+c>=a.right&&e.right>a.right;)e=e.add(-f,0);c=e.left+c;c<a.right&&
+c>a.left&&e.right-d>a.right&&(e=e.add(-f,0))}return e},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(a,b){var c=a.split(",");return OpenLayers.Bounds.fromArray(c,b)};OpenLayers.Bounds.fromArray=function(a,b){return!0===b?new OpenLayers.Bounds(a[1],a[0],a[3],a[2]):new OpenLayers.Bounds(a[0],a[1],a[2],a[3])};OpenLayers.Bounds.fromSize=function(a){return new OpenLayers.Bounds(0,a.h,a.w,0)};
+OpenLayers.Bounds.oppositeQuadrant=function(a){var b;b=""+("t"==a.charAt(0)?"b":"t");return b+="l"==a.charAt(1)?"r":"l"};
+OpenLayers.Element={visible:function(a){return"none"!=OpenLayers.Util.getElement(a).style.display},toggle:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]),d=OpenLayers.Element.visible(c)?"hide":"show";OpenLayers.Element[d](c)}},hide:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = 'none';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=
+"none"}},show:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = '';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=""}},remove:function(a){a=OpenLayers.Util.getElement(a);a.parentNode.removeChild(a)},getHeight:function(a){a=OpenLayers.Util.getElement(a);return a.offsetHeight},getDimensions:function(a){a=OpenLayers.Util.getElement(a);if("none"!=OpenLayers.Element.getStyle(a,"display"))return{width:a.offsetWidth,
+height:a.offsetHeight};var b=a.style,c=b.visibility,d=b.position,e=b.display;b.visibility="hidden";b.position="absolute";b.display="";var f=a.clientWidth,a=a.clientHeight;b.display=e;b.position=d;b.visibility=c;return{width:f,height:a}},hasClass:function(a,b){var c=a.className;return!!c&&RegExp("(^|\\s)"+b+"(\\s|$)").test(c)},addClass:function(a,b){OpenLayers.Element.hasClass(a,b)||(a.className+=(a.className?" ":"")+b);return a},removeClass:function(a,b){var c=a.className;if(c)a.className=OpenLayers.String.trim(c.replace(RegExp("(^|\\s+)"+
+b+"(\\s+|$)")," "));return a},toggleClass:function(a,b){OpenLayers.Element.hasClass(a,b)?OpenLayers.Element.removeClass(a,b):OpenLayers.Element.addClass(a,b);return a},getStyle:function(a,b){var a=OpenLayers.Util.getElement(a),c=null;if(a&&a.style){c=a.style[OpenLayers.String.camelize(b)];c||(document.defaultView&&document.defaultView.getComputedStyle?c=(c=document.defaultView.getComputedStyle(a,null))?c.getPropertyValue(b):null:a.currentStyle&&(c=a.currentStyle[OpenLayers.String.camelize(b)]));var d=
+["left","top","right","bottom"];window.opera&&-1!=OpenLayers.Util.indexOf(d,b)&&"static"==OpenLayers.Element.getStyle(a,"position")&&(c="auto")}return"auto"==c?null:c}};
+OpenLayers.LonLat=OpenLayers.Class({lon:0,lat:0,initialize:function(a,b){this.lon=OpenLayers.Util.toFloat(a);this.lat=OpenLayers.Util.toFloat(b)},toString:function(){return"lon="+this.lon+",lat="+this.lat},toShortString:function(){return this.lon+", "+this.lat},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat)},add:function(a,b){if(null==a||null==b)throw new TypeError("LonLat.add cannot receive null values");return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(a),this.lat+
+OpenLayers.Util.toFloat(b))},equals:function(a){var b=!1;null!=a&&(b=this.lon==a.lon&&this.lat==a.lat||isNaN(this.lon)&&isNaN(this.lat)&&isNaN(a.lon)&&isNaN(a.lat));return b},transform:function(a,b){var c=OpenLayers.Projection.transform({x:this.lon,y:this.lat},a,b);this.lon=c.x;this.lat=c.y;return this},wrapDateLine:function(a){var b=this.clone();if(a){for(;b.lon<a.left;)b.lon+=a.getWidth();for(;b.lon>a.right;)b.lon-=a.getWidth()}return b},CLASS_NAME:"OpenLayers.LonLat"});
+OpenLayers.LonLat.fromString=function(a){a=a.split(",");return new OpenLayers.LonLat(a[0],a[1])};OpenLayers.LonLat.fromArray=function(a){var b=OpenLayers.Util.isArray(a);return new OpenLayers.LonLat(b&&a[0],b&&a[1])};
+OpenLayers.Pixel=OpenLayers.Class({x:0,y:0,initialize:function(a,b){this.x=parseFloat(a);this.y=parseFloat(b)},toString:function(){return"x="+this.x+",y="+this.y},clone:function(){return new OpenLayers.Pixel(this.x,this.y)},equals:function(a){var b=!1;null!=a&&(b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y));return b},distanceTo:function(a){return Math.sqrt(Math.pow(this.x-a.x,2)+Math.pow(this.y-a.y,2))},add:function(a,b){if(null==a||null==b)throw new TypeError("Pixel.add cannot receive null values");
+return new OpenLayers.Pixel(this.x+a,this.y+b)},offset:function(a){var b=this.clone();a&&(b=this.add(a.x,a.y));return b},CLASS_NAME:"OpenLayers.Pixel"});
+OpenLayers.Size=OpenLayers.Class({w:0,h:0,initialize:function(a,b){this.w=parseFloat(a);this.h=parseFloat(b)},toString:function(){return"w="+this.w+",h="+this.h},clone:function(){return new OpenLayers.Size(this.w,this.h)},equals:function(a){var b=!1;null!=a&&(b=this.w==a.w&&this.h==a.h||isNaN(this.w)&&isNaN(this.h)&&isNaN(a.w)&&isNaN(a.h));return b},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.getElement=function(){for(var a=[],b=0,c=arguments.length;b<c;b++){var d=arguments[b];"string"==typeof d&&(d=document.getElementById(d));if(1==arguments.length)return d;a.push(d)}return a};OpenLayers.Util.isElement=function(a){return!!(a&&1===a.nodeType)};OpenLayers.Util.isArray=function(a){return"[object Array]"===Object.prototype.toString.call(a)};if("undefined"===typeof window.$)window.$=OpenLayers.Util.getElement;
+OpenLayers.Util.removeItem=function(a,b){for(var c=a.length-1;0<=c;c--)a[c]==b&&a.splice(c,1);return a};OpenLayers.Util.clearArray=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"array = []"}));a.length=0};OpenLayers.Util.indexOf=function(a,b){if("function"==typeof a.indexOf)return a.indexOf(b);for(var c=0,d=a.length;c<d;c++)if(a[c]==b)return c;return-1};
+OpenLayers.Util.modifyDOMElement=function(a,b,c,d,e,f,g,h){if(b)a.id=b;if(c)a.style.left=c.x+"px",a.style.top=c.y+"px";if(d)a.style.width=d.w+"px",a.style.height=d.h+"px";if(e)a.style.position=e;if(f)a.style.border=f;if(g)a.style.overflow=g;if(0<=parseFloat(h)&&1>parseFloat(h))a.style.filter="alpha(opacity="+100*h+")",a.style.opacity=h;else if(1==parseFloat(h))a.style.filter="",a.style.opacity=""};
+OpenLayers.Util.createDiv=function(a,b,c,d,e,f,g,h){var i=document.createElement("div");if(d)i.style.backgroundImage="url("+d+")";a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="absolute");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,g,h);return i};
+OpenLayers.Util.createImage=function(a,b,c,d,e,f,g,h){var i=document.createElement("img");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="relative");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,null,g);if(h)i.style.display="none",b=function(){i.style.display="";OpenLayers.Event.stopObservingElement(i)},OpenLayers.Event.observe(i,"load",b),OpenLayers.Event.observe(i,"error",b);i.style.alt=a;i.galleryImg="no";if(d)i.src=d;return i};
+OpenLayers.Util.setOpacity=function(a,b){OpenLayers.Util.modifyDOMElement(a,null,null,null,null,null,null,b)};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(null==OpenLayers.Util.alphaHackNeeded){var a=navigator.appVersion.split("MSIE"),a=parseFloat(a[1]),b=!1;try{b=!!document.body.filters}catch(c){}OpenLayers.Util.alphaHackNeeded=b&&5.5<=a&&7>a}return OpenLayers.Util.alphaHackNeeded};
+OpenLayers.Util.modifyAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){OpenLayers.Util.modifyDOMElement(a,b,c,d,f,null,null,i);b=a.childNodes[0];if(e)b.src=e;OpenLayers.Util.modifyDOMElement(b,a.id+"_innerImage",null,d,"relative",g);if(OpenLayers.Util.alphaHack()){if("none"!=a.style.display)a.style.display="inline-block";null==h&&(h="scale");a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+b.src+"', sizingMethod='"+h+"')";0<=parseFloat(a.style.opacity)&&1>parseFloat(a.style.opacity)&&
+(a.style.filter+=" alpha(opacity="+100*a.style.opacity+")");b.style.filter="alpha(opacity=0)"}};OpenLayers.Util.createAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){var j=OpenLayers.Util.createDiv(),i=OpenLayers.Util.createImage(null,null,null,null,null,null,null,i);j.appendChild(i);OpenLayers.Util.modifyAlphaImageDiv(j,a,b,c,d,e,f,g,h);return j};OpenLayers.Util.upperCaseObject=function(a){var b={},c;for(c in a)b[c.toUpperCase()]=a[c];return b};
+OpenLayers.Util.applyDefaults=function(a,b){var a=a||{},c="function"==typeof window.Event&&b instanceof window.Event,d;for(d in b)if(void 0===a[d]||!c&&b.hasOwnProperty&&b.hasOwnProperty(d)&&!a.hasOwnProperty(d))a[d]=b[d];if(!c&&b&&b.hasOwnProperty&&b.hasOwnProperty("toString")&&!a.hasOwnProperty("toString"))a.toString=b.toString;return a};
+OpenLayers.Util.getParameterString=function(a){var b=[],c;for(c in a){var d=a[c];if(null!=d&&"function"!=typeof d){if("object"==typeof d&&d.constructor==Array){for(var e=[],f,g=0,h=d.length;g<h;g++)f=d[g],e.push(encodeURIComponent(null===f||void 0===f?"":f));d=e.join(",")}else d=encodeURIComponent(d);b.push(encodeURIComponent(c)+"="+d)}}return b.join("&")};OpenLayers.Util.urlAppend=function(a,b){var c=a;if(b)var d=(a+" ").split(/[?&]/),c=c+(" "===d.pop()?b:d.length?"&"+b:"?"+b);return c};
+OpenLayers.ImgPath="";OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||OpenLayers._getScriptLocation()+"img/"};OpenLayers.Util.Try=function(){for(var a=null,b=0,c=arguments.length;b<c;b++){var d=arguments[b];try{a=d();break}catch(e){}}return a};OpenLayers.Util.getXmlNodeValue=function(a){var b=null;OpenLayers.Util.Try(function(){b=a.text;if(!b)b=a.textContent;if(!b)b=a.firstChild.nodeValue},function(){b=a.textContent});return b};
+OpenLayers.Util.mouseLeft=function(a,b){for(var c=a.relatedTarget?a.relatedTarget:a.toElement;c!=b&&null!=c;)c=c.parentNode;return c!=b};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(a,b){if(null==b)b=OpenLayers.Util.DEFAULT_PRECISION;"number"!==typeof a&&(a=parseFloat(a));return 0===b?a:parseFloat(a.toPrecision(b))};OpenLayers.Util.rad=function(a){return a*Math.PI/180};OpenLayers.Util.deg=function(a){return 180*a/Math.PI};
+OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};
+OpenLayers.Util.distVincenty=function(a,b){for(var c=OpenLayers.Util.VincentyConstants,d=c.a,e=c.b,c=c.f,f=OpenLayers.Util.rad(b.lon-a.lon),g=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(a.lat))),h=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(b.lat))),i=Math.sin(g),g=Math.cos(g),j=Math.sin(h),h=Math.cos(h),k=f,m=2*Math.PI,n=20;1.0E-12<Math.abs(k-m)&&0<--n;){var l=Math.sin(k),o=Math.cos(k),q=Math.sqrt(h*l*h*l+(g*j-i*h*o)*(g*j-i*h*o));if(0==q)return 0;var o=i*j+g*h*o,r=Math.atan2(q,o),p=Math.asin(g*
+h*l/q),s=Math.cos(p)*Math.cos(p),l=o-2*i*j/s,t=c/16*s*(4+c*(4-3*s)),m=k,k=f+(1-t)*c*Math.sin(p)*(r+t*q*(l+t*o*(-1+2*l*l)))}if(0==n)return NaN;d=s*(d*d-e*e)/(e*e);c=d/1024*(256+d*(-128+d*(74-47*d)));return(e*(1+d/16384*(4096+d*(-768+d*(320-175*d))))*(r-c*q*(l+c/4*(o*(-1+2*l*l)-c/6*l*(-3+4*q*q)*(-3+4*l*l))))).toFixed(3)/1E3};
+OpenLayers.Util.destinationVincenty=function(a,b,c){for(var d=OpenLayers.Util,e=d.VincentyConstants,f=e.a,g=e.b,h=e.f,e=a.lon,a=a.lat,i=d.rad(b),b=Math.sin(i),i=Math.cos(i),a=(1-h)*Math.tan(d.rad(a)),j=1/Math.sqrt(1+a*a),k=a*j,m=Math.atan2(a,i),a=j*b,n=1-a*a,f=n*(f*f-g*g)/(g*g),l=1+f/16384*(4096+f*(-768+f*(320-175*f))),o=f/1024*(256+f*(-128+f*(74-47*f))),f=c/(g*l),q=2*Math.PI;1.0E-12<Math.abs(f-q);)var r=Math.cos(2*m+f),p=Math.sin(f),s=Math.cos(f),t=o*p*(r+o/4*(s*(-1+2*r*r)-o/6*r*(-3+4*p*p)*(-3+4*
+r*r))),q=f,f=c/(g*l)+t;c=k*p-j*s*i;g=Math.atan2(k*s+j*p*i,(1-h)*Math.sqrt(a*a+c*c));b=Math.atan2(p*b,j*s-k*p*i);i=h/16*n*(4+h*(4-3*n));r=b-(1-i)*h*a*(f+i*p*(r+i*s*(-1+2*r*r)));Math.atan2(a,-c);return new OpenLayers.LonLat(e+d.deg(r),d.deg(g))};
+OpenLayers.Util.getParameters=function(a){var a=null===a||void 0===a?window.location.href:a,b="";if(OpenLayers.String.contains(a,"?"))var b=a.indexOf("?")+1,c=OpenLayers.String.contains(a,"#")?a.indexOf("#"):a.length,b=a.substring(b,c);for(var a={},b=b.split(/[&;]/),c=0,d=b.length;c<d;++c){var e=b[c].split("=");if(e[0]){var f=e[0];try{f=decodeURIComponent(f)}catch(g){f=unescape(f)}e=(e[1]||"").replace(/\+/g," ");try{e=decodeURIComponent(e)}catch(h){e=unescape(e)}e=e.split(",");1==e.length&&(e=e[0]);
+a[f]=e}}return a};OpenLayers.Util.getArgs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Util.getParameters"}));return OpenLayers.Util.getParameters(a)};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(a){null==a&&(a="id_");OpenLayers.Util.lastSeqID+=1;return a+OpenLayers.Util.lastSeqID};OpenLayers.INCHES_PER_UNIT={inches:1,ft:12,mi:63360,m:39.3701,km:39370.1,dd:4374754,yd:36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;
+OpenLayers.INCHES_PER_UNIT.degrees=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT.nmi=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.0254000508001016;
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{Inch:OpenLayers.INCHES_PER_UNIT.inches,Meter:1/OpenLayers.METERS_PER_INCH,Foot:0.3048006096012192/OpenLayers.METERS_PER_INCH,IFoot:0.3048/OpenLayers.METERS_PER_INCH,ClarkeFoot:0.3047972651151/OpenLayers.METERS_PER_INCH,SearsFoot:0.30479947153867626/OpenLayers.METERS_PER_INCH,GoldCoastFoot:0.3047997101815088/OpenLayers.METERS_PER_INCH,IInch:0.0254/OpenLayers.METERS_PER_INCH,MicroInch:2.54E-5/OpenLayers.METERS_PER_INCH,Mil:2.54E-8/OpenLayers.METERS_PER_INCH,
+Centimeter:0.01/OpenLayers.METERS_PER_INCH,Kilometer:1E3/OpenLayers.METERS_PER_INCH,Yard:0.9144018288036576/OpenLayers.METERS_PER_INCH,SearsYard:0.914398414616029/OpenLayers.METERS_PER_INCH,IndianYard:0.9143985307444408/OpenLayers.METERS_PER_INCH,IndianYd37:0.91439523/OpenLayers.METERS_PER_INCH,IndianYd62:0.9143988/OpenLayers.METERS_PER_INCH,IndianYd75:0.9143985/OpenLayers.METERS_PER_INCH,IndianFoot:0.30479951/OpenLayers.METERS_PER_INCH,IndianFt37:0.30479841/OpenLayers.METERS_PER_INCH,IndianFt62:0.3047996/
+OpenLayers.METERS_PER_INCH,IndianFt75:0.3047995/OpenLayers.METERS_PER_INCH,Mile:1609.3472186944373/OpenLayers.METERS_PER_INCH,IYard:0.9144/OpenLayers.METERS_PER_INCH,IMile:1609.344/OpenLayers.METERS_PER_INCH,NautM:1852/OpenLayers.METERS_PER_INCH,"Lat-66":110943.31648893273/OpenLayers.METERS_PER_INCH,"Lat-83":110946.25736872235/OpenLayers.METERS_PER_INCH,Decimeter:0.1/OpenLayers.METERS_PER_INCH,Millimeter:0.0010/OpenLayers.METERS_PER_INCH,Dekameter:10/OpenLayers.METERS_PER_INCH,Decameter:10/OpenLayers.METERS_PER_INCH,
+Hectometer:100/OpenLayers.METERS_PER_INCH,GermanMeter:1.0000135965/OpenLayers.METERS_PER_INCH,CaGrid:0.999738/OpenLayers.METERS_PER_INCH,ClarkeChain:20.1166194976/OpenLayers.METERS_PER_INCH,GunterChain:20.11684023368047/OpenLayers.METERS_PER_INCH,BenoitChain:20.116782494375872/OpenLayers.METERS_PER_INCH,SearsChain:20.11676512155/OpenLayers.METERS_PER_INCH,ClarkeLink:0.201166194976/OpenLayers.METERS_PER_INCH,GunterLink:0.2011684023368047/OpenLayers.METERS_PER_INCH,BenoitLink:0.20116782494375873/OpenLayers.METERS_PER_INCH,
+SearsLink:0.2011676512155/OpenLayers.METERS_PER_INCH,Rod:5.02921005842012/OpenLayers.METERS_PER_INCH,IntnlChain:20.1168/OpenLayers.METERS_PER_INCH,IntnlLink:0.201168/OpenLayers.METERS_PER_INCH,Perch:5.02921005842012/OpenLayers.METERS_PER_INCH,Pole:5.02921005842012/OpenLayers.METERS_PER_INCH,Furlong:201.1684023368046/OpenLayers.METERS_PER_INCH,Rood:3.778266898/OpenLayers.METERS_PER_INCH,CapeFoot:0.3047972615/OpenLayers.METERS_PER_INCH,Brealey:375/OpenLayers.METERS_PER_INCH,ModAmFt:0.304812252984506/
+OpenLayers.METERS_PER_INCH,Fathom:1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":5E4/OpenLayers.METERS_PER_INCH,"150kilometers":15E4/OpenLayers.METERS_PER_INCH});
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{mm:OpenLayers.INCHES_PER_UNIT.Meter/1E3,cm:OpenLayers.INCHES_PER_UNIT.Meter/100,dm:100*OpenLayers.INCHES_PER_UNIT.Meter,km:1E3*OpenLayers.INCHES_PER_UNIT.Meter,kmi:OpenLayers.INCHES_PER_UNIT.nmi,fath:OpenLayers.INCHES_PER_UNIT.Fathom,ch:OpenLayers.INCHES_PER_UNIT.IntnlChain,link:OpenLayers.INCHES_PER_UNIT.IntnlLink,"us-in":OpenLayers.INCHES_PER_UNIT.inches,"us-ft":OpenLayers.INCHES_PER_UNIT.Foot,"us-yd":OpenLayers.INCHES_PER_UNIT.Yard,"us-ch":OpenLayers.INCHES_PER_UNIT.GunterChain,
+"us-mi":OpenLayers.INCHES_PER_UNIT.Mile,"ind-yd":OpenLayers.INCHES_PER_UNIT.IndianYd37,"ind-ft":OpenLayers.INCHES_PER_UNIT.IndianFt37,"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(a){return 1<a?1/a:a};OpenLayers.Util.getResolutionFromScale=function(a,b){var c;a&&(null==b&&(b="degrees"),c=1/(OpenLayers.Util.normalizeScale(a)*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH));return c};
+OpenLayers.Util.getScaleFromResolution=function(a,b){null==b&&(b="degrees");return a*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH};OpenLayers.Util.safeStopPropagation=function(a){OpenLayers.Event.stop(a,!0)};
+OpenLayers.Util.pagePosition=function(a){var b=[0,0],c=OpenLayers.Util.getViewportElement();if(!a||a==window||a==c)return b;var d=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&"absolute"==OpenLayers.Element.getStyle(a,"position")&&(""==a.style.top||""==a.style.left),e=null;if(a.getBoundingClientRect)a=a.getBoundingClientRect(),e=c.scrollTop,b[0]=a.left+c.scrollLeft,b[1]=a.top+e;else if(document.getBoxObjectFor&&!d)a=document.getBoxObjectFor(a),c=document.getBoxObjectFor(c),b[0]=a.screenX-c.screenX,
+b[1]=a.screenY-c.screenY;else{b[0]=a.offsetLeft;b[1]=a.offsetTop;e=a.offsetParent;if(e!=a)for(;e;)b[0]+=e.offsetLeft,b[1]+=e.offsetTop,e=e.offsetParent;c=OpenLayers.BROWSER_NAME;if("opera"==c||"safari"==c&&"absolute"==OpenLayers.Element.getStyle(a,"position"))b[1]-=document.body.offsetTop;for(e=a.offsetParent;e&&e!=document.body;){b[0]-=e.scrollLeft;if("opera"!=c||"TR"!=e.tagName)b[1]-=e.scrollTop;e=e.offsetParent}}return b};
+OpenLayers.Util.getViewportElement=function(){var a=arguments.callee.viewportElement;if(void 0==a)a="msie"==OpenLayers.BROWSER_NAME&&"CSS1Compat"!=document.compatMode?document.body:document.documentElement,arguments.callee.viewportElement=a;return a};
+OpenLayers.Util.isEquivalentUrl=function(a,b,c){c=c||{};OpenLayers.Util.applyDefaults(c,{ignoreCase:!0,ignorePort80:!0,ignoreHash:!0});var a=OpenLayers.Util.createUrlObject(a,c),b=OpenLayers.Util.createUrlObject(b,c),d;for(d in a)if("args"!==d&&a[d]!=b[d])return!1;for(d in a.args){if(a.args[d]!=b.args[d])return!1;delete b.args[d]}for(d in b.args)return!1;return!0};
+OpenLayers.Util.createUrlObject=function(a,b){b=b||{};if(!/^\w+:\/\//.test(a)){var c=window.location,d=c.port?":"+c.port:"",d=c.protocol+"//"+c.host.split(":").shift()+d;0===a.indexOf("/")?a=d+a:(c=c.pathname.split("/"),c.pop(),a=d+c.join("/")+"/"+a)}b.ignoreCase&&(a=a.toLowerCase());c=document.createElement("a");c.href=a;d={};d.host=c.host.split(":").shift();d.protocol=c.protocol;d.port=b.ignorePort80?"80"==c.port||"0"==c.port?"":c.port:""==c.port||"0"==c.port?"80":c.port;d.hash=b.ignoreHash||"#"===
+c.hash?"":c.hash;var e=c.search;e||(e=a.indexOf("?"),e=-1!=e?a.substr(e):"");d.args=OpenLayers.Util.getParameters(e);d.pathname="/"==c.pathname.charAt(0)?c.pathname:"/"+c.pathname;return d};OpenLayers.Util.removeTail=function(a){var b=null,b=a.indexOf("?"),c=a.indexOf("#");return b=-1==b?-1!=c?a.substr(0,c):a:-1!=c?a.substr(0,Math.min(b,c)):a.substr(0,b)};OpenLayers.IS_GECKO=function(){var a=navigator.userAgent.toLowerCase();return-1==a.indexOf("webkit")&&-1!=a.indexOf("gecko")}();
+OpenLayers.BROWSER_NAME=function(){var a="",b=navigator.userAgent.toLowerCase();-1!=b.indexOf("opera")?a="opera":-1!=b.indexOf("msie")?a="msie":-1!=b.indexOf("safari")?a="safari":-1!=b.indexOf("mozilla")&&(a=-1!=b.indexOf("firefox")?"firefox":"mozilla");return a}();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME};
+OpenLayers.Util.getRenderedDimensions=function(a,b,c){var d,e,f=document.createElement("div");f.style.visibility="hidden";var g=c&&c.containerElement?c.containerElement:document.body;if(b)if(b.w)d=b.w,f.style.width=d+"px";else if(b.h)e=b.h,f.style.height=e+"px";if(c&&c.displayClass)f.className=c.displayClass;b=document.createElement("div");b.innerHTML=a;b.style.overflow="visible";if(b.childNodes){a=0;for(c=b.childNodes.length;a<c;a++)if(b.childNodes[a].style)b.childNodes[a].style.overflow="visible"}f.appendChild(b);
+g.appendChild(f);a=!1;for(c=f.parentNode;c&&"body"!=c.tagName.toLowerCase();){var h=OpenLayers.Element.getStyle(c,"position");if("absolute"==h){a=!0;break}else if(h&&"static"!=h)break;c=c.parentNode}if(!a)f.style.position="absolute";if(!d)d=parseInt(b.scrollWidth),f.style.width=d+"px";e||(e=parseInt(b.scrollHeight));f.removeChild(b);g.removeChild(f);return new OpenLayers.Size(d,e)};
+OpenLayers.Util.getScrollbarWidth=function(){var a=OpenLayers.Util._scrollbarWidth;if(null==a){var b=null,c=null,b=a=0,b=document.createElement("div");b.style.position="absolute";b.style.top="-1000px";b.style.left="-1000px";b.style.width="100px";b.style.height="50px";b.style.overflow="hidden";c=document.createElement("div");c.style.width="100%";c.style.height="200px";b.appendChild(c);document.body.appendChild(b);a=c.offsetWidth;b.style.overflow="scroll";b=c.offsetWidth;document.body.removeChild(document.body.lastChild);
+OpenLayers.Util._scrollbarWidth=a-b;a=OpenLayers.Util._scrollbarWidth}return a};
+OpenLayers.Util.getFormattedLonLat=function(a,b,c){c||(c="dms");var a=(a+540)%360-180,d=Math.abs(a),e=Math.floor(d),f=d=(d-e)/(1/60),d=Math.floor(d),f=Math.round(10*((f-d)/(1/60))),f=f/10;60<=f&&(f-=60,d+=1,60<=d&&(d-=60,e+=1));10>e&&(e="0"+e);e+="\u00b0";0<=c.indexOf("dm")&&(10>d&&(d="0"+d),e+=d+"'",0<=c.indexOf("dms")&&(10>f&&(f="0"+f),e+=f+'"'));return e="lon"==b?e+(0>a?OpenLayers.i18n("W"):OpenLayers.i18n("E")):e+(0>a?OpenLayers.i18n("S"):OpenLayers.i18n("N"))};
+OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:!1,initialize:function(a){OpenLayers.Util.extend(this,a);this.options=a},destroy:function(){},read:function(){throw Error("Read not implemented.");},write:function(){throw Error("Write not implemented.");},CLASS_NAME:"OpenLayers.Format"});
+OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:!1,nativeJSON:function(){return!(!window.JSON||!("function"==typeof JSON.parse&&"function"==typeof JSON.stringify))}(),read:function(a,b){var c;if(this.nativeJSON)c=JSON.parse(a,b);else try{if(/^[\],:{}\s]*$/.test(a.replace(/\\["\\\/bfnrtu]/g,"@").replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,"]").replace(/(?:^|:|,)(?:\s*\[)+/g,""))&&(c=eval("("+a+")"),"function"===
+typeof b)){var d=function(a,c){if(c&&"object"===typeof c)for(var e in c)c.hasOwnProperty(e)&&(c[e]=d(e,c[e]));return b(a,c)};c=d("",c)}}catch(e){}if(this.keepData)this.data=c;return c},write:function(a,b){this.pretty=!!b;var c=null,d=typeof a;if(this.serialize[d])try{c=!this.pretty&&this.nativeJSON?JSON.stringify(a):this.serialize[d].apply(this,[a])}catch(e){OpenLayers.Console.error("Trouble serializing: "+e)}return c},writeIndent:function(){var a=[];if(this.pretty)for(var b=0;b<this.level;++b)a.push(this.indent);
+return a.join("")},writeNewline:function(){return this.pretty?this.newline:""},writeSpace:function(){return this.pretty?this.space:""},serialize:{object:function(a){if(null==a)return"null";if(a.constructor==Date)return this.serialize.date.apply(this,[a]);if(a.constructor==Array)return this.serialize.array.apply(this,[a]);var b=["{"];this.level+=1;var c,d,e,f=!1;for(c in a)a.hasOwnProperty(c)&&(d=OpenLayers.Format.JSON.prototype.write.apply(this,[c,this.pretty]),e=OpenLayers.Format.JSON.prototype.write.apply(this,
+[a[c],this.pretty]),null!=d&&null!=e&&(f&&b.push(","),b.push(this.writeNewline(),this.writeIndent(),d,":",this.writeSpace(),e),f=!0));this.level-=1;b.push(this.writeNewline(),this.writeIndent(),"}");return b.join("")},array:function(a){var b,c=["["];this.level+=1;for(var d=0,e=a.length;d<e;++d)b=OpenLayers.Format.JSON.prototype.write.apply(this,[a[d],this.pretty]),null!=b&&(0<d&&c.push(","),c.push(this.writeNewline(),this.writeIndent(),b));this.level-=1;c.push(this.writeNewline(),this.writeIndent(),
+"]");return c.join("")},string:function(a){var b={"\u0008":"\\b","\t":"\\t","\n":"\\n","\u000c":"\\f","\r":"\\r",'"':'\\"',"\\":"\\\\"};return/["\\\x00-\x1f]/.test(a)?'"'+a.replace(/([\x00-\x1f\\"])/g,function(a,d){var e=b[d];if(e)return e;e=d.charCodeAt();return"\\u00"+Math.floor(e/16).toString(16)+(e%16).toString(16)})+'"':'"'+a+'"'},number:function(a){return isFinite(a)?""+a:"null"},"boolean":function(a){return""+a},date:function(a){function b(a){return 10>a?"0"+a:a}return'"'+a.getFullYear()+"-"+
+b(a.getMonth()+1)+"-"+b(a.getDate())+"T"+b(a.getHours())+":"+b(a.getMinutes())+":"+b(a.getSeconds())+'"'}},CLASS_NAME:"OpenLayers.Format.JSON"});
+OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(a,b,c){this.layer=a;this.lonlat=b;this.data=null!=c?c:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){null!=this.layer&&null!=this.layer.map&&null!=this.popup&&this.layer.map.removePopup(this.popup);null!=this.layer&&null!=this.marker&&this.layer.removeMarker(this.marker);this.data=this.lonlat=this.id=this.layer=null;if(null!=this.marker)this.destroyMarker(this.marker),
+this.marker=null;if(null!=this.popup)this.destroyPopup(this.popup),this.popup=null},onScreen:function(){var a=!1;null!=this.layer&&null!=this.layer.map&&(a=this.layer.map.getExtent().containsLonLat(this.lonlat));return a},createMarker:function(){if(null!=this.lonlat)this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);return this.marker},destroyMarker:function(){this.marker.destroy()},createPopup:function(a){if(null!=this.lonlat){if(!this.popup)this.popup=new (this.popupClass?this.popupClass:
+OpenLayers.Popup.AnchoredBubble)(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,this.marker?this.marker.icon:null,a);if(null!=this.data.overflow)this.popup.contentDiv.style.overflow=this.data.overflow;this.popup.feature=this}return this.popup},destroyPopup:function(){if(this.popup)this.popup.feature=null,this.popup.destroy(),this.popup=null},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:"Unknown",INSERT:"Insert",UPDATE:"Update",DELETE:"Delete"};
+OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(a,b,c){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,b]);this.lonlat=null;this.geometry=a?a:null;this.state=null;this.attributes={};if(b)this.attributes=OpenLayers.Util.extend(this.attributes,b);this.style=c?c:null},destroy:function(){if(this.layer)this.layer.removeFeatures(this),this.layer=
+null;this.modified=this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments)},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style)},onScreen:function(a){var b=!1;this.layer&&this.layer.map&&(b=this.layer.map.getExtent(),a?(a=this.geometry.getBounds(),b=b.intersectsBounds(a)):b=b.toGeometry().intersects(this.geometry));return b},getVisibility:function(){return!(this.style&&"none"==this.style.display||!this.layer||
+this.layer&&this.layer.styleMap&&"none"==this.layer.styleMap.createSymbolizer(this,this.renderIntent).display||this.layer&&!this.layer.getVisibility())},createMarker:function(){return null},destroyMarker:function(){},createPopup:function(){return null},atPoint:function(a,b,c){var d=!1;this.geometry&&(d=this.geometry.atPoint(a,b,c));return d},destroyPopup:function(){},move:function(a){if(this.layer&&this.geometry.move){var a="OpenLayers.LonLat"==a.CLASS_NAME?this.layer.getViewPortPxFromLonLat(a):a,
+b=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat()),c=this.layer.map.getResolution();this.geometry.move(c*(a.x-b.x),c*(b.y-a.y));this.layer.drawFeature(this);return b}},toState:function(a){if(a==OpenLayers.State.UPDATE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=a}else if(a==OpenLayers.State.INSERT)switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=a}else if(a==OpenLayers.State.DELETE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=
+a}else if(a==OpenLayers.State.UNKNOWN)this.state=a},CLASS_NAME:"OpenLayers.Feature.Vector"});
+OpenLayers.Feature.Vector.style={"default":{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},select:{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,
+strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},temporary:{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,
+hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},"delete":{display:"none"}};
+OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(a){this.regExes={typeStr:/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,spaces:/\s+/,parenComma:/\)\s*,\s*\(/,doubleParenComma:/\)\s*\)\s*,\s*\(\s*\(/,trimParens:/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){var b,c,a=a.replace(/[\n\r]/g," ");if(c=this.regExes.typeStr.exec(a))if(a=c[1].toLowerCase(),c=c[2],this.parse[a]&&(b=this.parse[a].apply(this,[c])),this.internalProjection&&this.externalProjection)if(b&&
+"OpenLayers.Feature.Vector"==b.CLASS_NAME)b.geometry.transform(this.externalProjection,this.internalProjection);else if(b&&"geometrycollection"!=a&&"object"==typeof b){a=0;for(c=b.length;a<c;a++)b[a].geometry.transform(this.externalProjection,this.internalProjection)}return b},write:function(a){var b,c;a.constructor==Array?c=!0:(a=[a],c=!1);var d=[];c&&d.push("GEOMETRYCOLLECTION(");for(var e=0,f=a.length;e<f;++e)c&&0<e&&d.push(","),b=a[e].geometry,d.push(this.extractGeometry(b));c&&d.push(")");return d.join("")},
+extractGeometry:function(a){var b=a.CLASS_NAME.split(".")[2].toLowerCase();if(!this.extract[b])return null;this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));return("collection"==b?"GEOMETRYCOLLECTION":b.toUpperCase())+"("+this.extract[b].apply(this,[a])+")"},extract:{point:function(a){return a.x+" "+a.y},multipoint:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.point.apply(this,[a.components[c]])+
+")");return b.join(",")},linestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b.join(",")},multilinestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},polygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},multipolygon:function(a){for(var b=
+[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.polygon.apply(this,[a.components[c]])+")");return b.join(",")},collection:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extractGeometry.apply(this,[a.components[c]]));return b.join(",")}},parse:{point:function(a){a=OpenLayers.String.trim(a).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(a[0],a[1]))},multipoint:function(a){for(var b=OpenLayers.String.trim(a).split(","),
+c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.point.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(c))},linestring:function(a){for(var a=OpenLayers.String.trim(a).split(","),b=[],c=0,d=a.length;c<d;++c)b.push(this.parse.point.apply(this,[a[c]]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(b))},multilinestring:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.parenComma),
+c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.linestring.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(c))},polygon:function(a){for(var b,a=OpenLayers.String.trim(a).split(this.regExes.parenComma),c=[],d=0,e=a.length;d<e;++d)b=a[d].replace(this.regExes.trimParens,"$1"),b=this.parse.linestring.apply(this,[b]).geometry,b=new OpenLayers.Geometry.LinearRing(b.components),c.push(b);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(c))},
+multipolygon:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.doubleParenComma),c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.polygon.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(c))},geometrycollection:function(a){for(var a=a.replace(/,\s*([A-Za-z])/g,"|$1"),a=OpenLayers.String.trim(a).split("|"),b=[],c=0,d=a.length;c<d;++c)b.push(OpenLayers.Format.WKT.prototype.read.apply(this,[a[c]]));
+return b}},CLASS_NAME:"OpenLayers.Format.WKT"});
+OpenLayers.Protocol.SQL.Gears=OpenLayers.Class(OpenLayers.Protocol.SQL,{FID_PREFIX:"__gears_fid__",NULL_GEOMETRY:"__gears_null_geometry__",NULL_FEATURE_STATE:"__gears_null_feature_state__",jsonParser:null,wktParser:null,fidRegExp:null,saveFeatureState:!0,typeOfFid:"string",db:null,initialize:function(a){if(this.supported())OpenLayers.Protocol.SQL.prototype.initialize.apply(this,[a]),this.jsonParser=new OpenLayers.Format.JSON,this.wktParser=new OpenLayers.Format.WKT,this.fidRegExp=RegExp("^"+this.FID_PREFIX),
+this.initializeDatabase()},initializeDatabase:function(){this.db=google.gears.factory.create("beta.database");this.db.open(this.databaseName);this.db.execute("CREATE TABLE IF NOT EXISTS "+this.tableName+" (fid TEXT UNIQUE, geometry TEXT, properties TEXT,  state TEXT)")},destroy:function(){this.db.close();this.wktParser=this.jsonParser=this.db=null;OpenLayers.Protocol.SQL.prototype.destroy.apply(this)},supported:function(){return!(!window.google||!google.gears)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,
+arguments);for(var a=OpenLayers.Util.applyDefaults(a,this.options),b,c=[],d=this.db.execute("SELECT * FROM "+this.tableName);d.isValidRow();){b=this.unfreezeFeature(d);if(this.evaluateFilter(b,a.filter)){if(!a.noFeatureStateReset)b.state=null;c.push(b)}d.next()}d.close();b=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"read",features:c});a&&a.callback&&a.callback.call(a.scope,b);return b},unfreezeFeature:function(a){var b;b=a.fieldByName("geometry");b=b==
+this.NULL_GEOMETRY?new OpenLayers.Feature.Vector:this.wktParser.read(b);b.attributes=this.jsonParser.read(a.fieldByName("properties"));b.fid=this.extractFidFromField(a.fieldByName("fid"));a=a.fieldByName("state");a==this.NULL_FEATURE_STATE&&(a=null);b.state=a;return b},extractFidFromField:function(a){!a.match(this.fidRegExp)&&"number"==this.typeOfFid&&(a=parseFloat(a));return a},create:function(a,b){var b=OpenLayers.Util.applyDefaults(b,this.options),c=this.createOrUpdate(a);c.requestType="create";
+b&&b.callback&&b.callback.call(b.scope,c);return c},update:function(a,b){var b=OpenLayers.Util.applyDefaults(b,this.options),c=this.createOrUpdate(a);c.requestType="update";b&&b.callback&&b.callback.call(b.scope,c);return c},createOrUpdate:function(a){OpenLayers.Util.isArray(a)||(a=[a]);var b,c=a.length,d,e=Array(c);for(b=0;b<c;b++){d=a[b];var f=this.freezeFeature(d);this.db.execute("REPLACE INTO "+this.tableName+" (fid, geometry, properties, state) VALUES (?, ?, ?, ?)",f);d=d.clone();d.fid=this.extractFidFromField(f[0]);
+e[b]=d}return new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,features:e,reqFeatures:a})},freezeFeature:function(a){a.fid=null!=a.fid?""+a.fid:OpenLayers.Util.createUniqueID(this.FID_PREFIX);var b=null!=a.geometry?a.geometry.toString():this.NULL_GEOMETRY,c=this.jsonParser.write(a.attributes),d=this.getFeatureStateForFreeze(a);return[a.fid,b,c,d]},getFeatureStateForFreeze:function(a){return this.saveFeatureState?this.createdOffline(a)?OpenLayers.State.INSERT:a.state:this.NULL_FEATURE_STATE},
+"delete":function(a,b){OpenLayers.Util.isArray(a)||(a=[a]);var b=OpenLayers.Util.applyDefaults(b,this.options),c,d,e;for(c=0,d=a.length;c<d;c++)if(e=a[c],this.saveFeatureState&&!this.createdOffline(e)){var f=e.clone();f.fid=e.fid;if(f.geometry)f.geometry.destroy(),f.geometry=null;f.state=e.state;this.createOrUpdate(f)}else this.db.execute("DELETE FROM "+this.tableName+" WHERE fid = ?",[e.fid]);c=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"delete",reqFeatures:a});
+b&&b.callback&&b.callback.call(b.scope,c);return c},createdOffline:function(a){return"string"==typeof a.fid&&!!a.fid.match(this.fidRegExp)},commit:function(a,b){function c(a){if(++g<f)a.last=!1;this.callUserCallback(b,a)}for(var d,e=[],f=0,g=0,h=[],i=[],j=[],k=a.length-1;0<=k;k--)switch(d=a[k],d.state){case OpenLayers.State.INSERT:h.push(d);break;case OpenLayers.State.UPDATE:i.push(d);break;case OpenLayers.State.DELETE:j.push(d)}0<h.length&&(f++,d=OpenLayers.Util.applyDefaults({callback:c,scope:this},
+b.create),e.push(this.create(h,d)));0<i.length&&(f++,d=OpenLayers.Util.applyDefaults({callback:c,scope:this},b.update),e.push(this.update(i,d)));0<j.length&&(f++,d=OpenLayers.Util.applyDefaults({callback:c,scope:this},b["delete"]),e.push(this["delete"](j,d)));return e},clear:function(){this.db.execute("DELETE FROM "+this.tableName)},callUserCallback:function(a,b){var c=a[b.requestType];c&&c.callback&&c.callback.call(c.scope,b);b.last&&a.callback&&a.callback.call(a.scope)},CLASS_NAME:"OpenLayers.Protocol.SQL.Gears"});
+OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(a){if(window.ActiveXObject)this.xmldom=new ActiveXObject("Microsoft.XMLDOM");OpenLayers.Format.prototype.initialize.apply(this,[a]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var b in this.namespaces)this.namespaceAlias[this.namespaces[b]]=b},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,
+arguments)},setNamespace:function(a,b){this.namespaces[a]=b;this.namespaceAlias[b]=a},read:function(a){var b=a.indexOf("<");0<b&&(a=a.substring(b));b=OpenLayers.Util.Try(OpenLayers.Function.bind(function(){var b;b=window.ActiveXObject&&!this.xmldom?new ActiveXObject("Microsoft.XMLDOM"):this.xmldom;b.loadXML(a);return b},this),function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var b=new XMLHttpRequest;b.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),!1);b.overrideMimeType&&
+b.overrideMimeType("text/xml");b.send(null);return b.responseXML});if(this.keepData)this.data=b;return b},write:function(a){if(this.xmldom)a=a.xml;else{var b=new XMLSerializer;if(1==a.nodeType){var c=document.implementation.createDocument("","",null);c.importNode&&(a=c.importNode(a,!0));c.appendChild(a);a=b.serializeToString(c)}else a=b.serializeToString(a)}return a},createElementNS:function(a,b){return this.xmldom?"string"==typeof a?this.xmldom.createNode(1,b,a):this.xmldom.createNode(1,b,""):document.createElementNS(a,
+b)},createTextNode:function(a){"string"!==typeof a&&(a=""+a);return this.xmldom?this.xmldom.createTextNode(a):document.createTextNode(a)},getElementsByTagNameNS:function(a,b,c){var d=[];if(a.getElementsByTagNameNS)d=a.getElementsByTagNameNS(b,c);else for(var a=a.getElementsByTagName("*"),e,f,g=0,h=a.length;g<h;++g)if(e=a[g],f=e.prefix?e.prefix+":"+c:c,"*"==c||f==e.nodeName)("*"==b||b==e.namespaceURI)&&d.push(e);return d},getAttributeNodeNS:function(a,b,c){var d=null;if(a.getAttributeNodeNS)d=a.getAttributeNodeNS(b,
+c);else for(var a=a.attributes,e,f,g=0,h=a.length;g<h;++g)if(e=a[g],e.namespaceURI==b&&(f=e.prefix?e.prefix+":"+c:c,f==e.nodeName)){d=e;break}return d},getAttributeNS:function(a,b,c){var d="";if(a.getAttributeNS)d=a.getAttributeNS(b,c)||"";else if(a=this.getAttributeNodeNS(a,b,c))d=a.nodeValue;return d},getChildValue:function(a,b){var c=b||"";if(a)for(var d=a.firstChild;d;d=d.nextSibling)switch(d.nodeType){case 3:case 4:c+=d.nodeValue}return c},concatChildValues:function(a,b){for(var c="",d=a.firstChild,
+e;d;)(e=d.nodeValue)&&(c+=e),d=d.nextSibling;""==c&&void 0!=b&&(c=b);return c},isSimpleContent:function(a){for(var b=!0,a=a.firstChild;a;a=a.nextSibling)if(1===a.nodeType){b=!1;break}return b},contentType:function(a){for(var b=!1,c=!1,d=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY,a=a.firstChild;a;a=a.nextSibling){switch(a.nodeType){case 1:c=!0;break;case 8:break;default:b=!0}if(c&&b)break}if(c&&b)d=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;else{if(c)return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;if(b)return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE}return d},
+hasAttributeNS:function(a,b,c){var d=!1;return d=a.hasAttributeNS?a.hasAttributeNS(b,c):!!this.getAttributeNodeNS(a,b,c)},setAttributeNS:function(a,b,c,d){if(a.setAttributeNS)a.setAttributeNS(b,c,d);else if(this.xmldom)b?(b=a.ownerDocument.createNode(2,c,b),b.nodeValue=d,a.setAttributeNode(b)):a.setAttribute(c,d);else throw"setAttributeNS not implemented";},createElementNSPlus:function(a,b){var b=b||{},c=b.uri||this.namespaces[b.prefix];c||(c=a.indexOf(":"),c=this.namespaces[a.substring(0,c)]);c||
+(c=this.namespaces[this.defaultPrefix]);c=this.createElementNS(c,a);b.attributes&&this.setAttributes(c,b.attributes);var d=b.value;null!=d&&c.appendChild(this.createTextNode(d));return c},setAttributes:function(a,b){var c,d,e;for(e in b)null!=b[e]&&b[e].toString&&(c=b[e].toString(),d=this.namespaces[e.substring(0,e.indexOf(":"))]||null,this.setAttributeNS(a,d,e,c))},readNode:function(a,b){b||(b={});var c=this.readers[a.namespaceURI?this.namespaceAlias[a.namespaceURI]:this.defaultPrefix];if(c){var d=
+a.localName||a.nodeName.split(":").pop();(c=c[d]||c["*"])&&c.apply(this,[a,b])}return b},readChildNodes:function(a,b){b||(b={});for(var c=a.childNodes,d,e=0,f=c.length;e<f;++e)d=c[e],1==d.nodeType&&this.readNode(d,b);return b},writeNode:function(a,b,c){var d,e=a.indexOf(":");0<e?(d=a.substring(0,e),a=a.substring(e+1)):d=c?this.namespaceAlias[c.namespaceURI]:this.defaultPrefix;b=this.writers[d][a].apply(this,[b]);c&&c.appendChild(b);return b},getChildEl:function(a,b,c){return a&&this.getThisOrNextEl(a.firstChild,
+b,c)},getNextEl:function(a,b,c){return a&&this.getThisOrNextEl(a.nextSibling,b,c)},getThisOrNextEl:function(a,b,c){a:for(;a;a=a.nextSibling)switch(a.nodeType){case 1:if((!b||b===(a.localName||a.nodeName.split(":").pop()))&&(!c||c===a.namespaceURI))break a;a=null;break a;case 3:if(/^\s*$/.test(a.nodeValue))break;case 4:case 6:case 12:case 10:case 11:a=null;break a}return a||null},lookupNamespaceURI:function(a,b){var c=null;if(a)if(a.lookupNamespaceURI)c=a.lookupNamespaceURI(b);else a:switch(a.nodeType){case 1:if(null!==
+a.namespaceURI&&a.prefix===b){c=a.namespaceURI;break a}if(c=a.attributes.length)for(var d,e=0;e<c;++e)if(d=a.attributes[e],"xmlns"===d.prefix&&d.name==="xmlns:"+b){c=d.value||null;break a}else if("xmlns"===d.name&&null===b){c=d.value||null;break a}c=this.lookupNamespaceURI(a.parentNode,b);break a;case 2:c=this.lookupNamespaceURI(a.ownerElement,b);break a;case 9:c=this.lookupNamespaceURI(a.documentElement,b);break a;case 6:case 12:case 10:case 11:break a;default:c=this.lookupNamespaceURI(a.parentNode,
+b)}return c},getXMLDoc:function(){if(!OpenLayers.Format.XML.document&&!this.xmldom)if(document.implementation&&document.implementation.createDocument)OpenLayers.Format.XML.document=document.implementation.createDocument("","",null);else if(!this.xmldom&&window.ActiveXObject)this.xmldom=new ActiveXObject("Microsoft.XMLDOM");return OpenLayers.Format.XML.document||this.xmldom},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};
+OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;
+OpenLayers.Date={toISOString:function(){if("toISOString"in Date.prototype)return function(a){return a.toISOString()};var a=function(a,c){for(var d=a+"";d.length<c;)d="0"+d;return d};return function(b){return isNaN(b.getTime())?"Invalid Date":b.getUTCFullYear()+"-"+a(b.getUTCMonth()+1,2)+"-"+a(b.getUTCDate(),2)+"T"+a(b.getUTCHours(),2)+":"+a(b.getUTCMinutes(),2)+":"+a(b.getUTCSeconds(),2)+"."+a(b.getUTCMilliseconds(),3)+"Z"}}(),parse:function(a){var b;if((a=a.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))|Z)?$/))&&
+(a[1]||a[7])){b=parseInt(a[1],10)||0;var c=parseInt(a[2],10)-1||0,d=parseInt(a[3],10)||1;b=new Date(Date.UTC(b,c,d));if(c=a[7]){var d=parseInt(a[4],10),e=parseInt(a[5],10),f=parseFloat(a[6]),g=f|0,f=Math.round(1E3*(f-g));b.setUTCHours(d,e,g,f);"Z"!==c&&(c=parseInt(c,10),a=parseInt(a[8],10)||0,b=new Date(b.getTime()+-1E3*(60*60*c+60*a)))}}else b=new Date("invalid");return b}};
+OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.bounds=this.id=null},clone:function(){return new OpenLayers.Geometry},setBounds:function(a){if(a)this.bounds=a.clone()},clearBounds:function(){this.bounds=null;this.parent&&this.parent.clearBounds()},extendBounds:function(a){this.getBounds()?this.bounds.extend(a):this.setBounds(a)},getBounds:function(){null==this.bounds&&this.calculateBounds();
+return this.bounds},calculateBounds:function(){},distanceTo:function(){},getVertices:function(){},atPoint:function(a,b,c){var d=!1;null!=this.getBounds()&&null!=a&&(b=null!=b?b:0,c=null!=c?c:0,d=(new OpenLayers.Bounds(this.bounds.left-b,this.bounds.bottom-c,this.bounds.right+b,this.bounds.top+c)).containsLonLat(a));return d},getLength:function(){return 0},getArea:function(){return 0},getCentroid:function(){return null},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this))},
+CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(a){var b=arguments.callee.format;if(!b)b=new OpenLayers.Format.WKT,arguments.callee.format=b;var c,b=b.read(a);if(b instanceof OpenLayers.Feature.Vector)c=b.geometry;else if(OpenLayers.Util.isArray(b)){c=b.length;for(var d=Array(c),e=0;e<c;++e)d[e]=b[e].geometry;c=new OpenLayers.Geometry.Collection(d)}return c};
+OpenLayers.Geometry.segmentsIntersect=function(a,b,c){var d=c&&c.point,c=c&&c.tolerance,e=!1,f=a.x1-b.x1,g=a.y1-b.y1,h=a.x2-a.x1,i=a.y2-a.y1,j=b.y2-b.y1,k=b.x2-b.x1,m=j*h-k*i,j=k*g-j*f,g=h*g-i*f;0==m?0==j&&0==g&&(e=!0):(f=j/m,m=g/m,0<=f&&1>=f&&0<=m&&1>=m&&(d?(h=a.x1+f*h,m=a.y1+f*i,e=new OpenLayers.Geometry.Point(h,m)):e=!0));if(c)if(e){if(d){a=[a,b];b=0;a:for(;2>b;++b){f=a[b];for(i=1;3>i;++i)if(h=f["x"+i],m=f["y"+i],d=Math.sqrt(Math.pow(h-e.x,2)+Math.pow(m-e.y,2)),d<c){e.x=h;e.y=m;break a}}}}else{a=
+[a,b];b=0;a:for(;2>b;++b){h=a[b];m=a[(b+1)%2];for(i=1;3>i;++i)if(f={x:h["x"+i],y:h["y"+i]},g=OpenLayers.Geometry.distanceToSegment(f,m),g.distance<c){e=d?new OpenLayers.Geometry.Point(f.x,f.y):!0;break a}}}return e};OpenLayers.Geometry.distanceToSegment=function(a,b){var c=a.x,d=a.y,e=b.x1,f=b.y1,g=b.x2,h=b.y2,i=g-e,j=h-f,k=(i*(c-e)+j*(d-f))/(Math.pow(i,2)+Math.pow(j,2));0>=k||(1<=k?(e=g,f=h):(e+=k*i,f+=k*j));return{distance:Math.sqrt(Math.pow(e-c,2)+Math.pow(f-d,2)),x:e,y:f}};
+OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(a,b){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(a);this.y=parseFloat(b)},clone:function(a){null==a&&(a=new OpenLayers.Geometry.Point(this.x,this.y));OpenLayers.Util.applyDefaults(a,this);return a},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y)},distanceTo:function(a,b){var c=!(b&&!1===b.edge)&&b&&b.details,d,e,f,g,h;a instanceof
+OpenLayers.Geometry.Point?(e=this.x,f=this.y,g=a.x,h=a.y,d=Math.sqrt(Math.pow(e-g,2)+Math.pow(f-h,2)),d=!c?d:{x0:e,y0:f,x1:g,y1:h,distance:d}):(d=a.distanceTo(this,b),c&&(d={x0:d.x1,y0:d.y1,x1:d.x0,y1:d.y0,distance:d.distance}));return d},equals:function(a){var b=!1;null!=a&&(b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y));return b},toShortString:function(){return this.x+", "+this.y},move:function(a,b){this.x+=a;this.y+=b;this.clearBounds()},rotate:function(a,b){var a=
+a*(Math.PI/180),c=this.distanceTo(b),d=a+Math.atan2(this.y-b.y,this.x-b.x);this.x=b.x+c*Math.cos(d);this.y=b.y+c*Math.sin(d);this.clearBounds()},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y)},resize:function(a,b,c){this.x=b.x+a*(void 0==c?1:c)*(this.x-b.x);this.y=b.y+a*(this.y-b.y);this.clearBounds();return this},intersects:function(a){var b=!1;return b="OpenLayers.Geometry.Point"==a.CLASS_NAME?this.equals(a):a.intersects(this)},transform:function(a,b){if(a&&b)OpenLayers.Projection.transform(this,
+a,b),this.bounds=null;return this},getVertices:function(){return[this]},CLASS_NAME:"OpenLayers.Geometry.Point"});
+OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(a){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];null!=a&&this.addComponents(a)},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments)},clone:function(){for(var a=eval("new "+this.CLASS_NAME+"()"),b=0,c=this.components.length;b<c;b++)a.addComponent(this.components[b].clone());
+OpenLayers.Util.applyDefaults(a,this);return a},getComponentsString:function(){for(var a=[],b=0,c=this.components.length;b<c;b++)a.push(this.components[b].toShortString());return a.join(",")},calculateBounds:function(){this.bounds=null;var a=new OpenLayers.Bounds,b=this.components;if(b)for(var c=0,d=b.length;c<d;c++)a.extend(b[c].getBounds());null!=a.left&&null!=a.bottom&&null!=a.right&&null!=a.top&&this.setBounds(a)},addComponents:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0,c=a.length;b<
+c;b++)this.addComponent(a[b])},addComponent:function(a,b){var c=!1;if(a&&(null==this.componentTypes||-1<OpenLayers.Util.indexOf(this.componentTypes,a.CLASS_NAME))){if(null!=b&&b<this.components.length){var c=this.components.slice(0,b),d=this.components.slice(b,this.components.length);c.push(a);this.components=c.concat(d)}else this.components.push(a);a.parent=this;this.clearBounds();c=!0}return c},removeComponents:function(a){var b=!1;OpenLayers.Util.isArray(a)||(a=[a]);for(var c=a.length-1;0<=c;--c)b=
+this.removeComponent(a[c])||b;return b},removeComponent:function(a){OpenLayers.Util.removeItem(this.components,a);this.clearBounds();return!0},getLength:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getLength();return a},getArea:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getArea();return a},getGeodesicArea:function(a){for(var b=0,c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicArea(a);return b},getCentroid:function(a){if(!a)return this.components.length&&
+this.components[0].getCentroid();a=this.components.length;if(!a)return!1;for(var b=[],c=[],d=0,e=Number.MAX_VALUE,f,g=0;g<a;++g){f=this.components[g];var h=f.getArea();f=f.getCentroid(!0);!isNaN(h)&&!isNaN(f.x)&&!isNaN(f.y)&&(b.push(h),d+=h,e=h<e&&0<h?h:e,c.push(f))}a=b.length;if(0===d){for(g=0;g<a;++g)b[g]=1;d=b.length}else{for(g=0;g<a;++g)b[g]/=e;d/=e}for(var i=e=0,g=0;g<a;++g)f=c[g],h=b[g],e+=f.x*h,i+=f.y*h;return new OpenLayers.Geometry.Point(e/d,i/d)},getGeodesicLength:function(a){for(var b=
+0,c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicLength(a);return b},move:function(a,b){for(var c=0,d=this.components.length;c<d;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0;d<this.components.length;++d)this.components[d].resize(a,b,c);return this},distanceTo:function(a,b){for(var c=!(b&&!1===b.edge)&&b&&b.details,d,e,f,g=Number.POSITIVE_INFINITY,h=0,i=this.components.length;h<
+i&&!(d=this.components[h].distanceTo(a,b),f=c?d.distance:d,f<g&&(g=f,e=d,0==g));++h);return e},equals:function(a){var b=!0;if(!a||!a.CLASS_NAME||this.CLASS_NAME!=a.CLASS_NAME)b=!1;else if(!OpenLayers.Util.isArray(a.components)||a.components.length!=this.components.length)b=!1;else for(var c=0,d=this.components.length;c<d;++c)if(!this.components[c].equals(a.components[c])){b=!1;break}return b},transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<d;c++)this.components[c].transform(a,
+b);this.bounds=null}return this},intersects:function(a){for(var b=!1,c=0,d=this.components.length;c<d&&!(b=a.intersects(this.components[c]));++c);return b},getVertices:function(a){for(var b=[],c=0,d=this.components.length;c<d;++c)Array.prototype.push.apply(b,this.components[c].getVertices(a));return b},CLASS_NAME:"OpenLayers.Geometry.Collection"});
+OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],addPoint:function(a,b){this.addComponent(a,b)},removePoint:function(a){this.removeComponent(a)},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});
+OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],getLength:function(){var a=0;if(this.components&&1<this.components.length)for(var b=1,c=this.components.length;b<c;b++)a+=this.components[b-1].distanceTo(this.components[b]);return a},getGeodesicLength:function(a){var b=this;if(a){var c=new OpenLayers.Projection("EPSG:4326");c.equals(a)||(b=this.clone().transform(a,c))}a=0;if(b.components&&1<b.components.length)for(var d,e=1,f=b.components.length;e<
+f;e++)c=b.components[e-1],d=b.components[e],a+=OpenLayers.Util.distVincenty({lon:c.x,lat:c.y},{lon:d.x,lat:d.y});return 1E3*a},CLASS_NAME:"OpenLayers.Geometry.Curve"});
+OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{removeComponent:function(a){var b=this.components&&2<this.components.length;b&&OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);return b},intersects:function(a){var b=!1,c=a.CLASS_NAME;if("OpenLayers.Geometry.LineString"==c||"OpenLayers.Geometry.LinearRing"==c||"OpenLayers.Geometry.Point"==c){var d=this.getSortedSegments(),a="OpenLayers.Geometry.Point"==c?[{x1:a.x,y1:a.y,x2:a.x,y2:a.y}]:a.getSortedSegments(),
+e,f,g,h,i,j,k,m=0,n=d.length;a:for(;m<n;++m){c=d[m];e=c.x1;f=c.x2;g=c.y1;h=c.y2;var l=0,o=a.length;for(;l<o;++l){i=a[l];if(i.x1>f)break;if(!(i.x2<e)&&(j=i.y1,k=i.y2,!(Math.min(j,k)>Math.max(g,h))&&!(Math.max(j,k)<Math.min(g,h))&&OpenLayers.Geometry.segmentsIntersect(c,i))){b=!0;break a}}}}else b=a.intersects(this);return b},getSortedSegments:function(){for(var a=this.components.length-1,b=Array(a),c,d,e=0;e<a;++e)c=this.components[e],d=this.components[e+1],b[e]=c.x<d.x?{x1:c.x,y1:c.y,x2:d.x,y2:d.y}:
+{x1:d.x,y1:d.y,x2:c.x,y2:c.y};return b.sort(function(a,b){return a.x1-b.x1})},splitWithSegment:function(a,b){for(var c=!(b&&!1===b.edge),d=b&&b.tolerance,e=[],f=this.getVertices(),g=[],h=[],i=!1,j,k,m,n={point:!0,tolerance:d},l=null,o=0,q=f.length-2;o<=q;++o)if(d=f[o],g.push(d.clone()),j=f[o+1],k={x1:d.x,y1:d.y,x2:j.x,y2:j.y},k=OpenLayers.Geometry.segmentsIntersect(a,k,n),k instanceof OpenLayers.Geometry.Point&&((m=k.x===a.x1&&k.y===a.y1||k.x===a.x2&&k.y===a.y2||k.equals(d)||k.equals(j)?!0:!1)||c))k.equals(h[h.length-
+1])||h.push(k.clone()),!(0===o&&k.equals(d))&&!k.equals(j)&&(i=!0,k.equals(d)||g.push(k),e.push(new OpenLayers.Geometry.LineString(g)),g=[k.clone()]);i&&(g.push(j.clone()),e.push(new OpenLayers.Geometry.LineString(g)));if(0<h.length)var r=a.x1<a.x2?1:-1,p=a.y1<a.y2?1:-1,l={lines:e,points:h.sort(function(a,b){return r*a.x-r*b.x||p*a.y-p*b.y})};return l},split:function(a,b){var c=null,d=b&&b.mutual,e,f,g,h;if(a instanceof OpenLayers.Geometry.LineString){var i=this.getVertices(),j,k,m,n,l,o=[];g=[];
+for(var q=0,r=i.length-2;q<=r;++q){j=i[q];k=i[q+1];m={x1:j.x,y1:j.y,x2:k.x,y2:k.y};h=h||[a];d&&o.push(j.clone());for(var p=0;p<h.length;++p)if(n=h[p].splitWithSegment(m,b))if(l=n.lines,0<l.length&&(l.unshift(p,1),Array.prototype.splice.apply(h,l),p+=l.length-2),d)for(var s=0,t=n.points.length;s<t;++s)l=n.points[s],l.equals(j)||(o.push(l),g.push(new OpenLayers.Geometry.LineString(o)),o=l.equals(k)?[]:[l.clone()])}d&&0<g.length&&0<o.length&&(o.push(k.clone()),g.push(new OpenLayers.Geometry.LineString(o)))}else c=
+a.splitWith(this,b);h&&1<h.length?f=!0:h=[];g&&1<g.length?e=!0:g=[];if(f||e)c=d?[g,h]:h;return c},splitWith:function(a,b){return a.split(this,b)},getVertices:function(a){return!0===a?[this.components[0],this.components[this.components.length-1]]:!1===a?this.components.slice(1,this.components.length-1):this.components.slice()},distanceTo:function(a,b){var c=!(b&&!1===b.edge)&&b&&b.details,d,e={},f=Number.POSITIVE_INFINITY;if(a instanceof OpenLayers.Geometry.Point){for(var g=this.getSortedSegments(),
+h=a.x,i=a.y,j,k=0,m=g.length;k<m;++k)if(j=g[k],d=OpenLayers.Geometry.distanceToSegment(a,j),d.distance<f){if(f=d.distance,e=d,0===f)break}else if(j.x2>h&&(i>j.y1&&i<j.y2||i<j.y1&&i>j.y2))break;e=c?{distance:e.distance,x0:e.x,y0:e.y,x1:h,y1:i}:e.distance}else if(a instanceof OpenLayers.Geometry.LineString){var g=this.getSortedSegments(),h=a.getSortedSegments(),n,l,o=h.length,q={point:!0},k=0,m=g.length;a:for(;k<m;++k){i=g[k];j=i.x1;l=i.y1;for(var r=0;r<o;++r)if(d=h[r],n=OpenLayers.Geometry.segmentsIntersect(i,
+d,q)){f=0;e={distance:0,x0:n.x,y0:n.y,x1:n.x,y1:n.y};break a}else if(d=OpenLayers.Geometry.distanceToSegment({x:j,y:l},d),d.distance<f)f=d.distance,e={distance:f,x0:j,y0:l,x1:d.x,y1:d.y}}if(!c)e=e.distance;0!==f&&i&&(d=a.distanceTo(new OpenLayers.Geometry.Point(i.x2,i.y2),b),k=c?d.distance:d,k<f&&(e=c?{distance:f,x0:d.x1,y0:d.y1,x1:d.x0,y1:d.y0}:k))}else e=a.distanceTo(this,b),c&&(e={distance:e.distance,x0:e.x1,y0:e.y1,x1:e.x0,y1:e.y0});return e},simplify:function(a){if(this&&null!==this){var b=this.getVertices();
+if(3>b.length)return this;var c=function(a,b,d,i){for(var j=0,k=0,m=b,n;m<d;m++){n=a[b];var l=a[d],o=a[m],o=Math.abs(0.5*(n.x*l.y+l.x*o.y+o.x*n.y-l.x*n.y-o.x*l.y-n.x*o.y));n=Math.sqrt(Math.pow(n.x-l.x,2)+Math.pow(n.y-l.y,2));n=2*(o/n);n>j&&(j=n,k=m)}j>i&&k!=b&&(e.push(k),c(a,b,k,i),c(a,k,d,i))},d=b.length-1,e=[];e.push(0);for(e.push(d);b[0].equals(b[d]);)d--,e.push(d);c(b,0,d,a);a=[];e.sort(function(a,b){return a-b});for(d=0;d<e.length;d++)a.push(b[e[d]]);return new OpenLayers.Geometry.LineString(a)}return this},
+CLASS_NAME:"OpenLayers.Geometry.LineString"});
+OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],addComponent:function(a,b){var c=!1,d=this.components.pop();if(null!=b||!a.equals(d))c=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]]);return c},removeComponent:function(a){var b=this.components&&3<this.components.length;b&&(this.components.pop(),OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,
+arguments),OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]]));return b},move:function(a,b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d-1;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0,e=this.components.length;d<e-1;++d)this.components[d].resize(a,b,c);return this},transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].transform(a,
+b);this.bounds=null}return this},getCentroid:function(){if(this.components&&2<this.components.length){for(var a=0,b=0,c=0;c<this.components.length-1;c++)var d=this.components[c],e=this.components[c+1],a=a+(d.x+e.x)*(d.x*e.y-e.x*d.y),b=b+(d.y+e.y)*(d.x*e.y-e.x*d.y);c=-1*this.getArea();return new OpenLayers.Geometry.Point(a/(6*c),b/(6*c))}return null},getArea:function(){var a=0;if(this.components&&2<this.components.length){for(var b=a=0,c=this.components.length;b<c-1;b++)var d=this.components[b],e=
+this.components[b+1],a=a+(d.x+e.x)*(e.y-d.y);a=-a/2}return a},getGeodesicArea:function(a){var b=this;if(a){var c=new OpenLayers.Projection("EPSG:4326");c.equals(a)||(b=this.clone().transform(a,c))}a=0;c=b.components&&b.components.length;if(2<c){for(var d,e,f=0;f<c-1;f++)d=b.components[f],e=b.components[f+1],a+=OpenLayers.Util.rad(e.x-d.x)*(2+Math.sin(OpenLayers.Util.rad(d.y))+Math.sin(OpenLayers.Util.rad(e.y)));a=40680631590769*a/2}return a},containsPoint:function(a){for(var b=OpenLayers.Number.limitSigDigs,
+c=b(a.x,14),a=b(a.y,14),d=this.components.length-1,e,f,g,h,i,j=0,k=0;k<d;++k)if(e=this.components[k],g=b(e.x,14),e=b(e.y,14),f=this.components[k+1],h=b(f.x,14),f=b(f.y,14),e==f){if(a==e&&(g<=h&&c>=g&&c<=h||g>=h&&c<=g&&c>=h)){j=-1;break}}else{i=b(((g-h)*a+(h*e-g*f))/(e-f),14);if(i==c&&(e<f&&a>=e&&a<=f||e>f&&a<=e&&a>=f)){j=-1;break}i<=c||g!=h&&(i<Math.min(g,h)||i>Math.max(g,h))||(e<f&&a>=e&&a<f||e>f&&a<e&&a>=f)&&++j}return-1==j?1:!!(j&1)},intersects:function(a){var b=!1;if("OpenLayers.Geometry.Point"==
+a.CLASS_NAME)b=this.containsPoint(a);else if("OpenLayers.Geometry.LineString"==a.CLASS_NAME)b=a.intersects(this);else if("OpenLayers.Geometry.LinearRing"==a.CLASS_NAME)b=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[a]);else for(var c=0,d=a.components.length;c<d&&!(b=a.components[c].intersects(this));++c);return b},getVertices:function(a){return!0===a?[]:this.components.slice(0,this.components.length-1)},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});
+OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var a=0;if(this.components&&0<this.components.length)for(var a=a+Math.abs(this.components[0].getArea()),b=1,c=this.components.length;b<c;b++)a-=Math.abs(this.components[b].getArea());return a},getGeodesicArea:function(a){var b=0;if(this.components&&0<this.components.length)for(var b=b+Math.abs(this.components[0].getGeodesicArea(a)),c=1,d=this.components.length;c<
+d;c++)b-=Math.abs(this.components[c].getGeodesicArea(a));return b},containsPoint:function(a){var b=this.components.length,c=!1;if(0<b&&(c=this.components[0].containsPoint(a),1!==c&&c&&1<b))for(var d,e=1;e<b;++e)if(d=this.components[e].containsPoint(a)){c=1===d?1:!1;break}return c},intersects:function(a){var b=!1,c,d;if("OpenLayers.Geometry.Point"==a.CLASS_NAME)b=this.containsPoint(a);else if("OpenLayers.Geometry.LineString"==a.CLASS_NAME||"OpenLayers.Geometry.LinearRing"==a.CLASS_NAME){for(c=0,d=
+this.components.length;c<d&&!(b=a.intersects(this.components[c]));++c);if(!b)for(c=0,d=a.components.length;c<d&&!(b=this.containsPoint(a.components[c]));++c);}else for(c=0,d=a.components.length;c<d&&!(b=this.intersects(a.components[c]));++c);if(!b&&"OpenLayers.Geometry.Polygon"==a.CLASS_NAME){var e=this.components[0];for(c=0,d=e.components.length;c<d&&!(b=a.containsPoint(e.components[c]));++c);}return b},distanceTo:function(a,b){return b&&!1===b.edge&&this.intersects(a)?0:OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,
+[a,b])},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(a,b,c,d){var e=Math.PI*(1/c-0.5);d&&(e+=d/180*Math.PI);for(var f,g=[],h=0;h<c;++h)f=e+2*h*Math.PI/c,d=a.x+b*Math.cos(f),f=a.y+b*Math.sin(f),g.push(new OpenLayers.Geometry.Point(d,f));a=new OpenLayers.Geometry.LinearRing(g);return new OpenLayers.Geometry.Polygon([a])};
+OpenLayers.Event={observers:!1,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(a){return a.target||a.srcElement},isSingleTouch:function(a){return a.touches&&1==a.touches.length},isMultiTouch:function(a){return a.touches&&1<a.touches.length},isLeftClick:function(a){return a.which&&1==a.which||a.button&&1==a.button},isRightClick:function(a){return a.which&&3==a.which||a.button&&2==a.button},stop:function(a,b){if(!b)a.preventDefault?
+a.preventDefault():a.returnValue=!1;a.stopPropagation?a.stopPropagation():a.cancelBubble=!0},findElement:function(a,b){for(var c=OpenLayers.Event.element(a);c.parentNode&&(!c.tagName||c.tagName.toUpperCase()!=b.toUpperCase());)c=c.parentNode;return c},observe:function(a,b,c,d){a=OpenLayers.Util.getElement(a);d=d||!1;if("keypress"==b&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.attachEvent))b="keydown";if(!this.observers)this.observers={};if(!a._eventCacheID){var e="eventCacheID_";a.id&&
+(e=a.id+"_"+e);a._eventCacheID=OpenLayers.Util.createUniqueID(e)}e=a._eventCacheID;this.observers[e]||(this.observers[e]=[]);this.observers[e].push({element:a,name:b,observer:c,useCapture:d});a.addEventListener?a.addEventListener(b,c,d):a.attachEvent&&a.attachEvent("on"+b,c)},stopObservingElement:function(a){a=OpenLayers.Util.getElement(a)._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[a])},_removeElementObservers:function(a){if(a)for(var b=a.length-1;0<=b;b--){var c=a[b];OpenLayers.Event.stopObserving.apply(this,
+[c.element,c.name,c.observer,c.useCapture])}},stopObserving:function(a,b,c,d){var d=d||!1,a=OpenLayers.Util.getElement(a),e=a._eventCacheID;if("keypress"==b&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.detachEvent))b="keydown";var f=!1,g=OpenLayers.Event.observers[e];if(g)for(var h=0;!f&&h<g.length;){var i=g[h];if(i.name==b&&i.observer==c&&i.useCapture==d){g.splice(h,1);0==g.length&&delete OpenLayers.Event.observers[e];f=!0;break}h++}f&&(a.removeEventListener?a.removeEventListener(b,
+c,d):a&&a.detachEvent&&a.detachEvent("on"+b,c));return f},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var a in OpenLayers.Event.observers)OpenLayers.Event._removeElementObservers.apply(this,[OpenLayers.Event.observers[a]]);OpenLayers.Event.observers=!1}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,"unload",OpenLayers.Event.unloadCache,!1);if(window.Event)OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);else var Event=OpenLayers.Event;
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:"mouseover,mouseout,mousedown,mouseup,mousemove,click,dblclick,rightclick,dblrightclick,resize,focus,blur,touchstart,touchmove,touchend".split(","),listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:!1,clearMouseListener:null,initialize:function(a,b,c,d,e){OpenLayers.Util.extend(this,e);this.object=a;this.fallThrough=d;this.listeners={};if(null!=b)this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,
+this),this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this),this.attachToElement(b)},destroy:function(){this.element&&(OpenLayers.Event.stopObservingElement(this.element),this.element.hasScrollEvent&&OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener));this.eventHandler=this.fallThrough=this.object=this.listeners=this.element=null},addEventType:function(){},attachToElement:function(a){this.element&&OpenLayers.Event.stopObservingElement(this.element);this.element=
+a;for(var b=0,c=this.BROWSER_EVENTS.length;b<c;b++)OpenLayers.Event.observe(a,this.BROWSER_EVENTS[b],this.eventHandler);OpenLayers.Event.observe(a,"dragstart",OpenLayers.Event.stop)},on:function(a){for(var b in a)"scope"!=b&&a.hasOwnProperty(b)&&this.register(b,a.scope,a[b])},register:function(a,b,c,d){if(null!=c){if(null==b)b=this.object;var e=this.listeners[a];e||(e=[],this.listeners[a]=e);d?e.unshift({obj:b,func:c}):e.push({obj:b,func:c})}},registerPriority:function(a,b,c){this.register(a,b,c,
+!0)},un:function(a){for(var b in a)"scope"!=b&&a.hasOwnProperty(b)&&this.unregister(b,a.scope,a[b])},unregister:function(a,b,c){if(null==b)b=this.object;a=this.listeners[a];if(null!=a)for(var d=0,e=a.length;d<e;d++)if(a[d].obj==b&&a[d].func==c){a.splice(d,1);break}},remove:function(a){null!=this.listeners[a]&&(this.listeners[a]=[])},triggerEvent:function(a,b){var c=this.listeners[a];if(c&&0!=c.length){null==b&&(b={});b.object=this.object;b.element=this.element;if(!b.type)b.type=a;for(var c=c.slice(),
+d,e=0,f=c.length;e<f&&!(d=c[e],d=d.func.apply(d.obj,[b]),void 0!=d&&!1==d);e++);this.fallThrough||OpenLayers.Event.stop(b,!0);return d}},handleBrowserEvent:function(a){var b=a.type,c=this.listeners[b];if(c&&0!=c.length){if((c=a.touches)&&c[0]){for(var d=0,e=0,f=c.length,g,h=0;h<f;++h)g=c[h],d+=g.clientX,e+=g.clientY;a.clientX=d/f;a.clientY=e/f}if(this.includeXY)a.xy=this.getMousePosition(a);this.triggerEvent(b,a)}},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;var a=
+document.body;if(a&&(!(0!=a.scrollTop||0!=a.scrollLeft)||!navigator.userAgent.match(/iPhone/i)))this.element.offsets=null},getMousePosition:function(a){if(this.includeXY){if(!this.element.hasScrollEvent)OpenLayers.Event.observe(window,"scroll",this.clearMouseListener),this.element.hasScrollEvent=!0}else this.clearMouseCache();if(!this.element.scrolls){var b=OpenLayers.Util.getViewportElement();this.element.scrolls=[b.scrollLeft,b.scrollTop]}if(!this.element.lefttop)this.element.lefttop=[document.documentElement.clientLeft||
+0,document.documentElement.clientTop||0];if(!this.element.offsets)this.element.offsets=OpenLayers.Util.pagePosition(this.element);return new OpenLayers.Pixel(a.clientX+this.element.scrolls[0]-this.element.offsets[0]-this.element.lefttop[0],a.clientY+this.element.scrolls[1]-this.element.offsets[1]-this.element.lefttop[1])},CLASS_NAME:"OpenLayers.Events"});
+OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:!0,user:void 0,password:void 0,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),issue:function(a){var b=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost}),a=OpenLayers.Util.applyDefaults(a,b),b=!1,c;for(c in a.headers)a.headers.hasOwnProperty(c)&&
+"x-requested-with"===c.toLowerCase()&&(b=!0);!1===b&&(a.headers["X-Requested-With"]="XMLHttpRequest");var d=new OpenLayers.Request.XMLHttpRequest,e=OpenLayers.Util.urlAppend(a.url,OpenLayers.Util.getParameterString(a.params||{}));c=0!=e.indexOf("http");var f=!c&&e.match(this.URL_SPLIT_REGEX);if(f&&(b=window.location,c=f[1]==b.protocol&&f[3]==b.hostname,f=f[4],b=b.port,80!=f&&""!=f||"80"!=b&&""!=b))c=c&&f==b;c||(a.proxy?e="function"==typeof a.proxy?a.proxy(e):a.proxy+encodeURIComponent(e):OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),
+{url:e}));d.open(a.method,e,a.async,a.user,a.password);for(var g in a.headers)d.setRequestHeader(g,a.headers[g]);var h=this.events,i=this;d.onreadystatechange=function(){d.readyState==OpenLayers.Request.XMLHttpRequest.DONE&&!1!==h.triggerEvent("complete",{request:d,config:a,requestUrl:e})&&i.runCallbacks({request:d,config:a,requestUrl:e})};!1===a.async?d.send(a.data):window.setTimeout(function(){0!==d.readyState&&d.send(a.data)},0);return d},runCallbacks:function(a){var b=a.request,c=a.config,d=c.scope?
+OpenLayers.Function.bind(c.callback,c.scope):c.callback,e;c.success&&(e=c.scope?OpenLayers.Function.bind(c.success,c.scope):c.success);var f;c.failure&&(f=c.scope?OpenLayers.Function.bind(c.failure,c.scope):c.failure);if("file:"==OpenLayers.Util.createUrlObject(c.url).protocol&&b.responseText)b.status=200;d(b);if(!b.status||200<=b.status&&300>b.status)this.events.triggerEvent("success",a),e&&e(b);if(b.status&&(200>b.status||300<=b.status))this.events.triggerEvent("failure",a),f&&f(b)},GET:function(a){a=
+OpenLayers.Util.extend(a,{method:"GET"});return OpenLayers.Request.issue(a)},POST:function(a){a=OpenLayers.Util.extend(a,{method:"POST"});a.headers=a.headers?a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");return OpenLayers.Request.issue(a)},PUT:function(a){a=OpenLayers.Util.extend(a,{method:"PUT"});a.headers=a.headers?a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");
+return OpenLayers.Request.issue(a)},DELETE:function(a){a=OpenLayers.Util.extend(a,{method:"DELETE"});return OpenLayers.Request.issue(a)},HEAD:function(a){a=OpenLayers.Util.extend(a,{method:"HEAD"});return OpenLayers.Request.issue(a)},OPTIONS:function(a){a=OpenLayers.Util.extend(a,{method:"OPTIONS"});return OpenLayers.Request.issue(a)}};
+(function(){function a(){this._object=f&&!i?new f:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[]}function b(){return new a}function c(a){b.onreadystatechange&&b.onreadystatechange.apply(a);a.dispatchEvent({type:"readystatechange",bubbles:!1,cancelable:!1,timeStamp:new Date+0})}function d(a){try{a.responseText=a._object.responseText}catch(b){}try{var c=a._object,d=c.responseXML,e=c.responseText;if(h&&e&&d&&!d.documentElement&&c.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/))d=
+new window.ActiveXObject("Microsoft.XMLDOM"),d.async=!1,d.validateOnParse=!1,d.loadXML(e);a.responseXML=d&&(h&&0!=d.parseError||!d.documentElement||d.documentElement&&"parsererror"==d.documentElement.tagName)?null:d}catch(f){}try{a.status=a._object.status}catch(g){}try{a.statusText=a._object.statusText}catch(i){}}function e(a){a._object.onreadystatechange=new window.Function}var f=window.XMLHttpRequest,g=!!window.controllers,h=window.document.all&&!window.opera,i=h&&window.navigator.userAgent.match(/MSIE 7.0/);
+b.prototype=a.prototype;if(g&&f.wrapped)b.wrapped=f.wrapped;b.UNSENT=0;b.OPENED=1;b.HEADERS_RECEIVED=2;b.LOADING=3;b.DONE=4;b.prototype.readyState=b.UNSENT;b.prototype.responseText="";b.prototype.responseXML=null;b.prototype.status=0;b.prototype.statusText="";b.prototype.priority="NORMAL";b.prototype.onreadystatechange=null;b.onreadystatechange=null;b.onopen=null;b.onsend=null;b.onabort=null;b.prototype.open=function(a,f,i,n,l){delete this._headers;3>arguments.length&&(i=!0);this._async=i;var o=this,
+q=this.readyState,r;h&&i&&(r=function(){q!=b.DONE&&(e(o),o.abort())},window.attachEvent("onunload",r));b.onopen&&b.onopen.apply(this,arguments);4<arguments.length?this._object.open(a,f,i,n,l):3<arguments.length?this._object.open(a,f,i,n):this._object.open(a,f,i);this.readyState=b.OPENED;c(this);this._object.onreadystatechange=function(){if(!g||i)o.readyState=o._object.readyState,d(o),o._aborted?o.readyState=b.UNSENT:(o.readyState==b.DONE&&(delete o._data,e(o),h&&i&&window.detachEvent("onunload",r)),
+q!=o.readyState&&c(o),q=o.readyState)}};b.prototype.send=function(a){b.onsend&&b.onsend.apply(this,arguments);arguments.length||(a=null);a&&a.nodeType&&(a=window.XMLSerializer?(new window.XMLSerializer).serializeToString(a):a.xml,oRequest._headers["Content-Type"]||oRequest._object.setRequestHeader("Content-Type","application/xml"));this._data=a;this._object.send(this._data);if(g&&!this._async){this.readyState=b.OPENED;for(d(this);this.readyState<b.DONE&&!(this.readyState++,c(this),this._aborted););
+}};b.prototype.abort=function(){b.onabort&&b.onabort.apply(this,arguments);if(this.readyState>b.UNSENT)this._aborted=!0;this._object.abort();e(this);this.readyState=b.UNSENT;delete this._data};b.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders()};b.prototype.getResponseHeader=function(a){return this._object.getResponseHeader(a)};b.prototype.setRequestHeader=function(a,b){if(!this._headers)this._headers={};this._headers[a]=b;return this._object.setRequestHeader(a,
+b)};b.prototype.addEventListener=function(a,b,c){for(var d=0,e;e=this._listeners[d];d++)if(e[0]==a&&e[1]==b&&e[2]==c)return;this._listeners.push([a,b,c])};b.prototype.removeEventListener=function(a,b,c){for(var d=0,e;(e=this._listeners[d])&&!(e[0]==a&&e[1]==b&&e[2]==c);d++);e&&this._listeners.splice(d,1)};b.prototype.dispatchEvent=function(a){a={type:a.type,target:this,currentTarget:this,eventPhase:2,bubbles:a.bubbles,cancelable:a.cancelable,timeStamp:a.timeStamp,stopPropagation:function(){},preventDefault:function(){},
+initEvent:function(){}};"readystatechange"==a.type&&this.onreadystatechange&&(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[a]);for(var b=0,c;c=this._listeners[b];b++)c[0]==a.type&&!c[2]&&(c[1].handleEvent||c[1]).apply(this,[a])};b.prototype.toString=function(){return"[object XMLHttpRequest]"};b.toString=function(){return"[XMLHttpRequest]"};if(!window.Function.prototype.apply)window.Function.prototype.apply=function(a,b){b||(b=[]);a.__func=this;a.__func(b[0],b[1],b[2],
+b[3],b[4]);delete a.__func};OpenLayers.Request.XMLHttpRequest=b})();
+OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.projCode=a;if(window.Proj4js)this.proj=new Proj4js.Proj(a)},getCode:function(){return this.proj?this.proj.srsCode:this.projCode},getUnits:function(){return this.proj?this.proj.units:null},toString:function(){return this.getCode()},equals:function(a){var b=!1;a&&(window.Proj4js&&this.proj.defData&&a.proj.defData?b=this.proj.defData.replace(this.titleRegEx,
+"")==a.proj.defData.replace(this.titleRegEx,""):a.getCode&&(b=this.getCode(),a=a.getCode(),b=b==a||!!OpenLayers.Projection.transforms[b]&&OpenLayers.Projection.transforms[b][a]===OpenLayers.Projection.nullTransform));return b},destroy:function(){delete this.proj;delete this.projCode},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};
+OpenLayers.Projection.addTransform=function(a,b,c){OpenLayers.Projection.transforms[a]||(OpenLayers.Projection.transforms[a]={});OpenLayers.Projection.transforms[a][b]=c};OpenLayers.Projection.transform=function(a,b,c){if(b.proj&&c.proj)a=Proj4js.transform(b.proj,c.proj,a);else if(b&&c&&OpenLayers.Projection.transforms[b.getCode()]&&OpenLayers.Projection.transforms[b.getCode()][c.getCode()])OpenLayers.Projection.transforms[b.getCode()][c.getCode()](a);return a};
+OpenLayers.Projection.nullTransform=function(a){return a};
+OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date,extractAttributes:!0,extractStyles:!1,extractTracks:!1,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(a){this.regExes={trimSpace:/^\s*|\s*$/g,
+removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g,kmlColor:/(\w{2})(\w{2})(\w{2})(\w{2})/,kmlIconPalette:/root:\/\/icons\/palette-(\d+)(\.\w+)/,straightBracket:/\$\[(.*?)\]/g};this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){this.features=[];this.styles={};this.fetched={};return this.parseData(a,{depth:0,styleBaseUrl:this.styleBaseUrl})},parseData:function(a,b){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,
+[a]));for(var c=["Link","NetworkLink","Style","StyleMap","Placemark"],d=0,e=c.length;d<e;++d){var f=c[d],g=this.getElementsByTagNameNS(a,"*",f);if(0!=g.length)switch(f.toLowerCase()){case "link":case "networklink":this.parseLinks(g,b);break;case "style":this.extractStyles&&this.parseStyles(g,b);break;case "stylemap":this.extractStyles&&this.parseStyleMaps(g,b);break;case "placemark":this.parseFeatures(g,b)}}return this.features},parseLinks:function(a,b){if(b.depth>=this.maxDepth)return!1;var c=OpenLayers.Util.extend({},
+b);c.depth++;for(var d=0,e=a.length;d<e;d++){var f=this.parseProperty(a[d],"*","href");f&&!this.fetched[f]&&(this.fetched[f]=!0,(f=this.fetchLink(f))&&this.parseData(f,c))}},fetchLink:function(a){if(a=OpenLayers.Request.GET({url:a,async:!1}))return a.responseText},parseStyles:function(a,b){for(var c=0,d=a.length;c<d;c++){var e=this.parseStyle(a[c]);e&&(this.styles[(b.styleBaseUrl||"")+"#"+e.id]=e)}},parseKmlColor:function(a){var b=null;a&&(a=a.match(this.regExes.kmlColor))&&(b={color:"#"+a[4]+a[3]+
+a[2],opacity:parseInt(a[1],16)/255});return b},parseStyle:function(a){for(var b={},c=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"],d,e,f=0,g=c.length;f<g;++f)if(d=c[f],e=this.getElementsByTagNameNS(a,"*",d)[0])switch(d.toLowerCase()){case "linestyle":d=this.parseProperty(e,"*","color");if(d=this.parseKmlColor(d))b.strokeColor=d.color,b.strokeOpacity=d.opacity;(d=this.parseProperty(e,"*","width"))&&(b.strokeWidth=d);break;case "polystyle":d=this.parseProperty(e,"*","color");if(d=
+this.parseKmlColor(d))b.fillOpacity=d.opacity,b.fillColor=d.color;"0"==this.parseProperty(e,"*","fill")&&(b.fillColor="none");"0"==this.parseProperty(e,"*","outline")&&(b.strokeWidth="0");break;case "iconstyle":var h=parseFloat(this.parseProperty(e,"*","scale")||1);d=32*h;var i=32*h,j=this.getElementsByTagNameNS(e,"*","Icon")[0];if(j){var k=this.parseProperty(j,"*","href");if(k){var m=this.parseProperty(j,"*","w"),n=this.parseProperty(j,"*","h");OpenLayers.String.startsWith(k,"http://maps.google.com/mapfiles/kml")&&
+!m&&!n&&(n=m=64,h/=2);m=m||n;n=n||m;m&&(d=parseInt(m)*h);n&&(i=parseInt(n)*h);if(n=k.match(this.regExes.kmlIconPalette))m=n[1],n=n[2],k=this.parseProperty(j,"*","x"),j=this.parseProperty(j,"*","y"),k="http://maps.google.com/mapfiles/kml/pal"+m+"/icon"+(8*(j?7-j/32:7)+(k?k/32:0))+n;b.graphicOpacity=1;b.externalGraphic=k}}if(e=this.getElementsByTagNameNS(e,"*","hotSpot")[0])k=parseFloat(e.getAttribute("x")),j=parseFloat(e.getAttribute("y")),m=e.getAttribute("xunits"),"pixels"==m?b.graphicXOffset=-k*
+h:"insetPixels"==m?b.graphicXOffset=-d+k*h:"fraction"==m&&(b.graphicXOffset=-d*k),e=e.getAttribute("yunits"),"pixels"==e?b.graphicYOffset=-i+j*h+1:"insetPixels"==e?b.graphicYOffset=-(j*h)+1:"fraction"==e&&(b.graphicYOffset=-i*(1-j)+1);b.graphicWidth=d;b.graphicHeight=i;break;case "balloonstyle":(e=OpenLayers.Util.getXmlNodeValue(e))&&(b.balloonStyle=e.replace(this.regExes.straightBracket,"${$1}"));break;case "labelstyle":if(d=this.parseProperty(e,"*","color"),d=this.parseKmlColor(d))b.fontColor=d.color,
+b.fontOpacity=d.opacity}!b.strokeColor&&b.fillColor&&(b.strokeColor=b.fillColor);if((a=a.getAttribute("id"))&&b)b.id=a;return b},parseStyleMaps:function(a,b){for(var c=0,d=a.length;c<d;c++)for(var e=a[c],f=this.getElementsByTagNameNS(e,"*","Pair"),e=e.getAttribute("id"),g=0,h=f.length;g<h;g++){var i=f[g],j=this.parseProperty(i,"*","key");(i=this.parseProperty(i,"*","styleUrl"))&&"normal"==j&&(this.styles[(b.styleBaseUrl||"")+"#"+e]=this.styles[(b.styleBaseUrl||"")+i])}},parseFeatures:function(a,b){for(var c=
+[],d=0,e=a.length;d<e;d++){var f=a[d],g=this.parseFeature.apply(this,[f]);if(g){if(this.extractStyles&&g.attributes&&g.attributes.styleUrl)g.style=this.getStyle(g.attributes.styleUrl,b);if(this.extractStyles){var h=this.getElementsByTagNameNS(f,"*","Style")[0];if(h&&(h=this.parseStyle(h)))g.style=OpenLayers.Util.extend(g.style,h)}if(this.extractTracks){if((f=this.getElementsByTagNameNS(f,this.namespaces.gx,"Track"))&&0<f.length)g={features:[],feature:g},this.readNode(f[0],g),0<g.features.length&&
+c.push.apply(c,g.features)}else c.push(g)}else throw"Bad Placemark: "+d;}this.features=this.features.concat(c)},readers:{kml:{when:function(a,b){b.whens.push(OpenLayers.Date.parse(this.getChildValue(a)))},_trackPointAttribute:function(a,b){var c=a.nodeName.split(":").pop();b.attributes[c].push(this.getChildValue(a))}},gx:{Track:function(a,b){var c={whens:[],points:[],angles:[]};if(this.trackAttributes){var d;c.attributes={};for(var e=0,f=this.trackAttributes.length;e<f;++e)if(d=this.trackAttributes[e],
+c.attributes[d]=[],!(d in this.readers.kml))this.readers.kml[d]=this.readers.kml._trackPointAttribute}this.readChildNodes(a,c);if(c.whens.length!==c.points.length)throw Error("gx:Track with unequal number of when ("+c.whens.length+") and gx:coord ("+c.points.length+") elements.");var g=0<c.angles.length;if(g&&c.whens.length!==c.angles.length)throw Error("gx:Track with unequal number of when ("+c.whens.length+") and gx:angles ("+c.angles.length+") elements.");for(var h,i,e=0,f=c.whens.length;e<f;++e){h=
+b.feature.clone();h.fid=b.feature.fid||b.feature.id;i=c.points[e];h.geometry=i;if("z"in i)h.attributes.altitude=i.z;this.internalProjection&&this.externalProjection&&h.geometry.transform(this.externalProjection,this.internalProjection);if(this.trackAttributes){i=0;for(var j=this.trackAttributes.length;i<j;++i)h.attributes[d]=c.attributes[this.trackAttributes[i]][e]}h.attributes.when=c.whens[e];h.attributes.trackId=b.feature.id;if(g)i=c.angles[e],h.attributes.heading=parseFloat(i[0]),h.attributes.tilt=
+parseFloat(i[1]),h.attributes.roll=parseFloat(i[2]);b.features.push(h)}},coord:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(/\s+/),d=new OpenLayers.Geometry.Point(c[0],c[1]);if(2<c.length)d.z=parseFloat(c[2]);b.points.push(d)},angles:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(/\s+/);b.angles.push(c)}}},parseFeature:function(a){for(var b=["MultiGeometry","Polygon","LineString","Point"],c,d,e,f=0,g=b.length;f<g;++f)if(c=b[f],
+this.internalns=a.namespaceURI?a.namespaceURI:this.kmlns,d=this.getElementsByTagNameNS(a,this.internalns,c),0<d.length){if(b=this.parseGeometry[c.toLowerCase()])e=b.apply(this,[d[0]]),this.internalProjection&&this.externalProjection&&e.transform(this.externalProjection,this.internalProjection);else throw new TypeError("Unsupported geometry type: "+c);break}var h;this.extractAttributes&&(h=this.parseAttributes(a));c=new OpenLayers.Feature.Vector(e,h);a=a.getAttribute("id")||a.getAttribute("name");
+if(null!=a)c.fid=a;return c},getStyle:function(a,b){var c=OpenLayers.Util.removeTail(a),d=OpenLayers.Util.extend({},b);d.depth++;d.styleBaseUrl=c;!this.styles[a]&&!OpenLayers.String.startsWith(a,"#")&&d.depth<=this.maxDepth&&!this.fetched[c]&&(c=this.fetchLink(c))&&this.parseData(c,d);return OpenLayers.Util.extend({},this.styles[a])},parseGeometry:{point:function(a){var b=this.getElementsByTagNameNS(a,this.internalns,"coordinates"),a=[];if(0<b.length)var c=b[0].firstChild.nodeValue,c=c.replace(this.regExes.removeSpace,
+""),a=c.split(",");b=null;if(1<a.length)2==a.length&&(a[2]=null),b=new OpenLayers.Geometry.Point(a[0],a[1],a[2]);else throw"Bad coordinate string: "+c;return b},linestring:function(a,b){var c=this.getElementsByTagNameNS(a,this.internalns,"coordinates"),d=null;if(0<c.length){for(var c=this.getChildValue(c[0]),c=c.replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),d=c.split(this.regExes.splitSpace),e=d.length,f=Array(e),g,h,i=0;i<e;++i)if(g=d[i].split(","),h=g.length,1<h)2==
+g.length&&(g[2]=null),f[i]=new OpenLayers.Geometry.Point(g[0],g[1],g[2]);else throw"Bad LineString point coordinates: "+d[i];if(e)d=b?new OpenLayers.Geometry.LinearRing(f):new OpenLayers.Geometry.LineString(f);else throw"Bad LineString coordinates: "+c;}return d},polygon:function(a){var a=this.getElementsByTagNameNS(a,this.internalns,"LinearRing"),b=a.length,c=Array(b);if(0<b)for(var d=0,e=a.length;d<e;++d)if(b=this.parseGeometry.linestring.apply(this,[a[d],!0]))c[d]=b;else throw"Bad LinearRing geometry: "+
+d;return new OpenLayers.Geometry.Polygon(c)},multigeometry:function(a){for(var b,c=[],d=a.childNodes,e=0,f=d.length;e<f;++e)a=d[e],1==a.nodeType&&(b=this.parseGeometry[(a.prefix?a.nodeName.split(":")[1]:a.nodeName).toLowerCase()])&&c.push(b.apply(this,[a]));return new OpenLayers.Geometry.Collection(c)}},parseAttributes:function(a){var b={},c=a.getElementsByTagName("ExtendedData");c.length&&(b=this.parseExtendedData(c[0]));for(var d,e,f,a=a.childNodes,c=0,g=a.length;c<g;++c)if(d=a[c],1==d.nodeType&&
+(e=d.childNodes,1<=e.length&&3>=e.length)){switch(e.length){case 1:f=e[0];break;case 2:f=e[0];e=e[1];f=3==f.nodeType||4==f.nodeType?f:e;break;default:f=e[1]}if(3==f.nodeType||4==f.nodeType)if(d=d.prefix?d.nodeName.split(":")[1]:d.nodeName,f=OpenLayers.Util.getXmlNodeValue(f))f=f.replace(this.regExes.trimSpace,""),b[d]=f}return b},parseExtendedData:function(a){var b={},c,d,e,f,g=a.getElementsByTagName("Data");for(c=0,d=g.length;c<d;c++){e=g[c];f=e.getAttribute("name");var h={},i=e.getElementsByTagName("value");
+i.length&&(h.value=this.getChildValue(i[0]));e=e.getElementsByTagName("displayName");e.length&&(h.displayName=this.getChildValue(e[0]));b[f]=h}a=a.getElementsByTagName("SimpleData");for(c=0,d=a.length;c<d;c++)h={},e=a[c],f=e.getAttribute("name"),h.value=this.getChildValue(e),h.displayName=f,b[f]=h;return b},parseProperty:function(a,b,c){var d,a=this.getElementsByTagNameNS(a,b,c);try{d=OpenLayers.Util.getXmlNodeValue(a[0])}catch(e){d=null}return d},write:function(a){OpenLayers.Util.isArray(a)||(a=
+[a]);for(var b=this.createElementNS(this.kmlns,"kml"),c=this.createFolderXML(),d=0,e=a.length;d<e;++d)c.appendChild(this.createPlacemarkXML(a[d]));b.appendChild(c);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFolderXML:function(){var a=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var b=this.createElementNS(this.kmlns,"name"),c=this.createTextNode(this.foldersName);b.appendChild(c);a.appendChild(b)}this.foldersDesc&&(b=this.createElementNS(this.kmlns,"description"),
+c=this.createTextNode(this.foldersDesc),b.appendChild(c),a.appendChild(b));return a},createPlacemarkXML:function(a){var b=this.createElementNS(this.kmlns,"name");b.appendChild(this.createTextNode(a.style&&a.style.label?a.style.label:a.attributes.name||a.id));var c=this.createElementNS(this.kmlns,"description");c.appendChild(this.createTextNode(a.attributes.description||this.placemarksDesc));var d=this.createElementNS(this.kmlns,"Placemark");null!=a.fid&&d.setAttribute("id",a.fid);d.appendChild(b);
+d.appendChild(c);a=this.buildGeometryNode(a.geometry);d.appendChild(a);return d},buildGeometryNode:function(a){var b=a.CLASS_NAME,b=this.buildGeometry[b.substring(b.lastIndexOf(".")+1).toLowerCase()],c=null;b&&(c=b.apply(this,[a]));return c},buildGeometry:{point:function(a){var b=this.createElementNS(this.kmlns,"Point");b.appendChild(this.buildCoordinatesNode(a));return b},multipoint:function(a){return this.buildGeometry.collection.apply(this,[a])},linestring:function(a){var b=this.createElementNS(this.kmlns,
+"LineString");b.appendChild(this.buildCoordinatesNode(a));return b},multilinestring:function(a){return this.buildGeometry.collection.apply(this,[a])},linearring:function(a){var b=this.createElementNS(this.kmlns,"LinearRing");b.appendChild(this.buildCoordinatesNode(a));return b},polygon:function(a){for(var b=this.createElementNS(this.kmlns,"Polygon"),a=a.components,c,d,e=0,f=a.length;e<f;++e)c=0==e?"outerBoundaryIs":"innerBoundaryIs",c=this.createElementNS(this.kmlns,c),d=this.buildGeometry.linearring.apply(this,
+[a[e]]),c.appendChild(d),b.appendChild(c);return b},multipolygon:function(a){return this.buildGeometry.collection.apply(this,[a])},collection:function(a){for(var b=this.createElementNS(this.kmlns,"MultiGeometry"),c,d=0,e=a.components.length;d<e;++d)(c=this.buildGeometryNode.apply(this,[a.components[d]]))&&b.appendChild(c);return b}},buildCoordinatesNode:function(a){var b=this.createElementNS(this.kmlns,"coordinates"),c;if(c=a.components){for(var d=c.length,e=Array(d),f=0;f<d;++f)a=c[f],e[f]=this.buildCoordinates(a);
+c=e.join(" ")}else c=this.buildCoordinates(a);c=this.createTextNode(c);b.appendChild(c);return b},buildCoordinates:function(a){this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));return a.x+","+a.y},CLASS_NAME:"OpenLayers.Format.KML"});
+OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(a,b){for(var c=null,d=b&&b.mutual,e,f,g,h,i=[],j=[a],k=0,m=this.components.length;k<m;++k){f=this.components[k];g=!1;for(var n=0;n<j.length;++n)if(e=f.split(j[n],b)){if(d){g=e[0];for(var l=0,o=g.length;l<o;++l)0===l&&i.length?i[i.length-1].addComponent(g[l]):i.push(new OpenLayers.Geometry.MultiLineString([g[l]]));g=!0;e=e[1]}if(e.length){e.unshift(n,
+1);Array.prototype.splice.apply(j,e);break}}g||(i.length?i[i.length-1].addComponent(f.clone()):i=[new OpenLayers.Geometry.MultiLineString(f.clone())])}i&&1<i.length?g=!0:i=[];j&&1<j.length?h=!0:j=[];if(g||h)c=d?[i,j]:j;return c},splitWith:function(a,b){var c=null,d=b&&b.mutual,e,f,g,h,i,j;if(a instanceof OpenLayers.Geometry.LineString){j=[];i=[a];for(var k=0,m=this.components.length;k<m;++k){g=!1;f=this.components[k];for(var n=0;n<i.length;++n)if(e=i[n].split(f,b)){d&&(g=e[0],g.length&&(g.unshift(n,
+1),Array.prototype.splice.apply(i,g),n+=g.length-2),e=e[1],0===e.length&&(e=[f.clone()]));g=0;for(var l=e.length;g<l;++g)0===g&&j.length?j[j.length-1].addComponent(e[g]):j.push(new OpenLayers.Geometry.MultiLineString([e[g]]));g=!0}g||(j.length?j[j.length-1].addComponent(f.clone()):j=[new OpenLayers.Geometry.MultiLineString([f.clone()])])}}else c=a.split(this);i&&1<i.length?h=!0:i=[];j&&1<j.length?g=!0:j=[];if(h||g)c=d?[i,j]:j;return c},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});
+OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});
+OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:!0,xy:!0,initialize:function(a){this.regExes={trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g};OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));for(var a=this.getElementsByTagNameNS(a.documentElement,this.gmlns,this.featureName),b=[],c=0;c<a.length;c++){var d=this.parseFeature(a[c]);d&&b.push(d)}return b},parseFeature:function(a){for(var b="MultiPolygon,Polygon,MultiLineString,LineString,MultiPoint,Point,Envelope".split(","),c,d,e,f=0;f<b.length;++f)if(c=b[f],d=this.getElementsByTagNameNS(a,this.gmlns,c),0<d.length){if(e=this.parseGeometry[c.toLowerCase()])e=e.apply(this,
+[d[0]]),this.internalProjection&&this.externalProjection&&e.transform(this.externalProjection,this.internalProjection);else throw new TypeError("Unsupported geometry type: "+c);break}var g;c=this.getElementsByTagNameNS(a,this.gmlns,"Box");for(f=0;f<c.length;++f)b=c[f],d=this.parseGeometry.box.apply(this,[b]),b=b.parentNode,"boundedBy"===(b.localName||b.nodeName.split(":").pop())?g=d:e=d.toGeometry();var h;this.extractAttributes&&(h=this.parseAttributes(a));h=new OpenLayers.Feature.Vector(e,h);h.bounds=
+g;h.gml={featureType:a.firstChild.nodeName.split(":")[1],featureNS:a.firstChild.namespaceURI,featureNSPrefix:a.firstChild.prefix};for(var a=a.firstChild,i;a&&!(1==a.nodeType&&(i=a.getAttribute("fid")||a.getAttribute("id")));)a=a.nextSibling;h.fid=i;return h},parseGeometry:{point:function(a){var b,c;c=[];b=this.getElementsByTagNameNS(a,this.gmlns,"pos");if(0<b.length)c=b[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace);if(0==c.length&&(b=this.getElementsByTagNameNS(a,
+this.gmlns,"coordinates"),0<b.length))c=b[0].firstChild.nodeValue,c=c.replace(this.regExes.removeSpace,""),c=c.split(",");0==c.length&&(b=this.getElementsByTagNameNS(a,this.gmlns,"coord"),0<b.length&&(a=this.getElementsByTagNameNS(b[0],this.gmlns,"X"),b=this.getElementsByTagNameNS(b[0],this.gmlns,"Y"),0<a.length&&0<b.length&&(c=[a[0].firstChild.nodeValue,b[0].firstChild.nodeValue])));2==c.length&&(c[2]=null);return this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],
+c[0],c[2])},multipoint:function(a){var a=this.getElementsByTagNameNS(a,this.gmlns,"Point"),b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.point.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPoint(b)},linestring:function(a,b){var c,d;d=[];var e=[];c=this.getElementsByTagNameNS(a,this.gmlns,"posList");if(0<c.length){d=this.getChildValue(c[0]);d=d.replace(this.regExes.trimSpace,"");d=d.split(this.regExes.splitSpace);var f=parseInt(c[0].getAttribute("dimension")),
+g,h,i;for(c=0;c<d.length/f;++c)g=c*f,h=d[g],i=d[g+1],g=2==f?null:d[g+2],this.xy?e.push(new OpenLayers.Geometry.Point(h,i,g)):e.push(new OpenLayers.Geometry.Point(i,h,g))}if(0==d.length&&(c=this.getElementsByTagNameNS(a,this.gmlns,"coordinates"),0<c.length)){d=this.getChildValue(c[0]);d=d.replace(this.regExes.trimSpace,"");d=d.replace(this.regExes.trimComma,",");f=d.split(this.regExes.splitSpace);for(c=0;c<f.length;++c)d=f[c].split(","),2==d.length&&(d[2]=null),this.xy?e.push(new OpenLayers.Geometry.Point(d[0],
+d[1],d[2])):e.push(new OpenLayers.Geometry.Point(d[1],d[0],d[2]))}d=null;0!=e.length&&(d=b?new OpenLayers.Geometry.LinearRing(e):new OpenLayers.Geometry.LineString(e));return d},multilinestring:function(a){var a=this.getElementsByTagNameNS(a,this.gmlns,"LineString"),b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiLineString(b)},polygon:function(a){var a=this.getElementsByTagNameNS(a,this.gmlns,"LinearRing"),
+b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d],!0]))&&b.push(c);return new OpenLayers.Geometry.Polygon(b)},multipolygon:function(a){var a=this.getElementsByTagNameNS(a,this.gmlns,"Polygon"),b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.polygon.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPolygon(b)},envelope:function(a){var b=[],c,d,e=this.getElementsByTagNameNS(a,this.gmlns,"lowerCorner");if(0<e.length){c=
+[];if(0<e.length)c=e[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace);2==c.length&&(c[2]=null);var f=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}a=this.getElementsByTagNameNS(a,this.gmlns,"upperCorner");if(0<a.length){c=[];if(0<a.length)c=a[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace);2==c.length&&(c[2]=null);var g=this.xy?new OpenLayers.Geometry.Point(c[0],
+c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}f&&g&&(b.push(new OpenLayers.Geometry.Point(f.x,f.y)),b.push(new OpenLayers.Geometry.Point(g.x,f.y)),b.push(new OpenLayers.Geometry.Point(g.x,g.y)),b.push(new OpenLayers.Geometry.Point(f.x,g.y)),b.push(new OpenLayers.Geometry.Point(f.x,f.y)),b=new OpenLayers.Geometry.LinearRing(b),d=new OpenLayers.Geometry.Polygon([b]));return d},box:function(a){var b=this.getElementsByTagNameNS(a,this.gmlns,"coordinates"),c=a=null;if(0<b.length)b=b[0].firstChild.nodeValue,
+b=b.split(" "),2==b.length&&(a=b[0].split(","),c=b[1].split(","));if(null!==a&&null!==c)return new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(c[0]),parseFloat(c[1]))}},parseAttributes:function(a){for(var b={},a=a.firstChild,c,d,e;a;){if(1==a.nodeType){a=a.childNodes;for(c=0;c<a.length;++c)if(d=a[c],1==d.nodeType)if(e=d.childNodes,1==e.length){if(e=e[0],3==e.nodeType||4==e.nodeType)d=d.prefix?d.nodeName.split(":")[1]:d.nodeName,e=e.nodeValue.replace(this.regExes.trimSpace,""),b[d]=
+e}else b[d.nodeName.split(":").pop()]=null;break}a=a.nextSibling}return b},write:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName),c=0;c<a.length;c++)b.appendChild(this.createFeatureXML(a[c]));return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.featureNS,this.featurePrefix+":"+this.geometryName);c.appendChild(b);
+var b=this.createElementNS(this.gmlns,"gml:"+this.featureName),d=this.createElementNS(this.featureNS,this.featurePrefix+":"+this.layerName);d.setAttribute("fid",a.fid||a.id);d.appendChild(c);for(var e in a.attributes){var c=this.createTextNode(a.attributes[e]),f=this.createElementNS(this.featureNS,this.featurePrefix+":"+e.substring(e.lastIndexOf(":")+1));f.appendChild(c);d.appendChild(f)}b.appendChild(d);return b},buildGeometryNode:function(a){this.externalProjection&&this.internalProjection&&(a=
+a.clone(),a.transform(this.internalProjection,this.externalProjection));var b=a.CLASS_NAME;return this.buildGeometry[b.substring(b.lastIndexOf(".")+1).toLowerCase()].apply(this,[a])},buildGeometry:{point:function(a){var b=this.createElementNS(this.gmlns,"gml:Point");b.appendChild(this.buildCoordinatesNode(a));return b},multipoint:function(a){for(var b=this.createElementNS(this.gmlns,"gml:MultiPoint"),a=a.components,c,d,e=0;e<a.length;e++)c=this.createElementNS(this.gmlns,"gml:pointMember"),d=this.buildGeometry.point.apply(this,
+[a[e]]),c.appendChild(d),b.appendChild(c);return b},linestring:function(a){var b=this.createElementNS(this.gmlns,"gml:LineString");b.appendChild(this.buildCoordinatesNode(a));return b},multilinestring:function(a){for(var b=this.createElementNS(this.gmlns,"gml:MultiLineString"),a=a.components,c,d,e=0;e<a.length;++e)c=this.createElementNS(this.gmlns,"gml:lineStringMember"),d=this.buildGeometry.linestring.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},linearring:function(a){var b=this.createElementNS(this.gmlns,
+"gml:LinearRing");b.appendChild(this.buildCoordinatesNode(a));return b},polygon:function(a){for(var b=this.createElementNS(this.gmlns,"gml:Polygon"),a=a.components,c,d,e=0;e<a.length;++e)c=0==e?"outerBoundaryIs":"innerBoundaryIs",c=this.createElementNS(this.gmlns,"gml:"+c),d=this.buildGeometry.linearring.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},multipolygon:function(a){for(var b=this.createElementNS(this.gmlns,"gml:MultiPolygon"),a=a.components,c,d,e=0;e<a.length;++e)c=this.createElementNS(this.gmlns,
+"gml:polygonMember"),d=this.buildGeometry.polygon.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},bounds:function(a){var b=this.createElementNS(this.gmlns,"gml:Box");b.appendChild(this.buildCoordinatesNode(a));return b}},buildCoordinatesNode:function(a){var b=this.createElementNS(this.gmlns,"gml:coordinates");b.setAttribute("decimal",".");b.setAttribute("cs",",");b.setAttribute("ts"," ");var c=[];if(a instanceof OpenLayers.Bounds)c.push(a.left+","+a.bottom),c.push(a.right+","+a.top);
+else for(var a=a.components?a.components:[a],d=0;d<a.length;d++)c.push(a[d].x+","+a[d].y);c=this.createTextNode(c.join(" "));b.appendChild(c);return b},CLASS_NAME:"OpenLayers.Format.GML"});if(!OpenLayers.Format.GML)OpenLayers.Format.GML={};
+OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:!0,srsName:null,xy:!0,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g,featureMember:/^(.*:)?featureMembers?$/},
+initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.setGeometryTypes();a&&a.featureNS&&this.setNamespace("feature",a.featureNS);this.singleFeatureType=!a||"string"===typeof a.featureType},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b=[];this.readNode(a,{features:b},!0);if(0==b.length){var c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMember");if(c.length)for(var a=
+0,d=c.length;a<d;++a)this.readNode(c[a],{features:b},!0);else c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMembers"),c.length&&this.readNode(c[0],{features:b},!0)}return b},readNode:function(a,b,c){if(!0===c&&!0===this.autoConfig)this.featureType=null,delete this.namespaceAlias[this.featureNS],delete this.namespaces.feature,this.featureNS=null;if(!this.featureNS&&!(a.prefix in this.namespaces)&&a.parentNode.namespaceURI==this.namespaces.gml&&this.regExes.featureMember.test(a.parentNode.nodeName))this.featureType=
+a.nodeName.split(":").pop(),this.setNamespace("feature",a.namespaceURI),this.featureNS=a.namespaceURI,this.autoConfig=!0;return OpenLayers.Format.XML.prototype.readNode.apply(this,[a,b])},readers:{gml:{featureMember:function(a,b){this.readChildNodes(a,b)},featureMembers:function(a,b){this.readChildNodes(a,b)},name:function(a,b){b.name=this.getChildValue(a)},boundedBy:function(a,b){var c={};this.readChildNodes(a,c);if(c.components&&0<c.components.length)b.bounds=c.components[0]},Point:function(a,b){var c=
+{points:[]};this.readChildNodes(a,c);if(!b.components)b.components=[];b.components.push(c.points[0])},coordinates:function(a,b){for(var c=this.getChildValue(a).replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace),d,e=c.length,f=Array(e),g=0;g<e;++g)d=c[g].split(","),f[g]=this.xy?new OpenLayers.Geometry.Point(d[0],d[1],d[2]):new OpenLayers.Geometry.Point(d[1],d[0],d[2]);b.points=f},coord:function(a,b){var c={};this.readChildNodes(a,c);if(!b.points)b.points=
+[];b.points.push(new OpenLayers.Geometry.Point(c.x,c.y,c.z))},X:function(a,b){b.x=this.getChildValue(a)},Y:function(a,b){b.y=this.getChildValue(a)},Z:function(a,b){b.z=this.getChildValue(a)},MultiPoint:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPoint(c.components)]},pointMember:function(a,b){this.readChildNodes(a,b)},LineString:function(a,b){var c={};this.readChildNodes(a,c);if(!b.components)b.components=[];b.components.push(new OpenLayers.Geometry.LineString(c.points))},
+MultiLineString:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiLineString(c.components)]},lineStringMember:function(a,b){this.readChildNodes(a,b)},Polygon:function(a,b){var c={outer:null,inner:[]};this.readChildNodes(a,c);c.inner.unshift(c.outer);if(!b.components)b.components=[];b.components.push(new OpenLayers.Geometry.Polygon(c.inner))},LinearRing:function(a,b){var c={};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.LinearRing(c.points)]},
+MultiPolygon:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)]},polygonMember:function(a,b){this.readChildNodes(a,b)},GeometryCollection:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.Collection(c.components)]},geometryMember:function(a,b){this.readChildNodes(a,b)}},feature:{"*":function(a,b){var c,d=a.localName||a.nodeName.split(":").pop();b.features?!this.singleFeatureType&&
+-1!==OpenLayers.Util.indexOf(this.featureType,d)?c="_typeName":d===this.featureType?c="_typeName":"*"===this.featureType&&(c="_typeName"):0==a.childNodes.length||1==a.childNodes.length&&3==a.firstChild.nodeType?this.extractAttributes&&(c="_attribute"):c="_geometry";c&&this.readers.feature[c].apply(this,[a,b])},_typeName:function(a,b){var c={components:[],attributes:{}};this.readChildNodes(a,c);if(c.name)c.attributes.name=c.name;var d=new OpenLayers.Feature.Vector(c.components[0],c.attributes);if(!this.singleFeatureType)d.type=
+a.nodeName.split(":").pop(),d.namespace=a.namespaceURI;var e=a.getAttribute("fid")||this.getAttributeNS(a,this.namespaces.gml,"id");if(e)d.fid=e;this.internalProjection&&this.externalProjection&&d.geometry&&d.geometry.transform(this.externalProjection,this.internalProjection);if(c.bounds)d.bounds=c.bounds;b.features.push(d)},_geometry:function(a,b){if(!this.geometryName)this.geometryName=a.nodeName.split(":").pop();this.readChildNodes(a,b)},_attribute:function(a,b){var c=a.localName||a.nodeName.split(":").pop(),
+d=this.getChildValue(a);b.attributes[c]=d}},wfs:{FeatureCollection:function(a,b){this.readChildNodes(a,b)}}},write:function(a){a=this.writeNode("gml:"+(OpenLayers.Util.isArray(a)?"featureMembers":"featureMember"),a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:{featureMember:function(a){var b=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",a,b);return b},
+MultiPoint:function(a){for(var b=this.createElementNSPlus("gml:MultiPoint"),a=a.components||[a],c=0,d=a.length;c<d;++c)this.writeNode("pointMember",a[c],b);return b},pointMember:function(a){var b=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",a,b);return b},MultiLineString:function(a){for(var b=this.createElementNSPlus("gml:MultiLineString"),a=a.components||[a],c=0,d=a.length;c<d;++c)this.writeNode("lineStringMember",a[c],b);return b},lineStringMember:function(a){var b=this.createElementNSPlus("gml:lineStringMember");
+this.writeNode("LineString",a,b);return b},MultiPolygon:function(a){for(var b=this.createElementNSPlus("gml:MultiPolygon"),a=a.components||[a],c=0,d=a.length;c<d;++c)this.writeNode("polygonMember",a[c],b);return b},polygonMember:function(a){var b=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",a,b);return b},GeometryCollection:function(a){for(var b=this.createElementNSPlus("gml:GeometryCollection"),c=0,d=a.components.length;c<d;++c)this.writeNode("geometryMember",a.components[c],
+b);return b},geometryMember:function(a){var b=this.createElementNSPlus("gml:geometryMember"),a=this.writeNode("feature:_geometry",a);b.appendChild(a.firstChild);return b}},feature:{_typeName:function(a){var b=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:a.fid}});a.geometry&&this.writeNode("feature:_geometry",a.geometry,b);for(var c in a.attributes){var d=a.attributes[c];null!=d&&this.writeNode("feature:_attribute",{name:c,value:d},b)}return b},_geometry:function(a){this.externalProjection&&
+this.internalProjection&&(a=a.clone().transform(this.internalProjection,this.externalProjection));var b=this.createElementNSPlus("feature:"+this.geometryName),a=this.writeNode("gml:"+this.geometryTypes[a.CLASS_NAME],a,b);this.srsName&&a.setAttribute("srsName",this.srsName);return b},_attribute:function(a){return this.createElementNSPlus("feature:"+a.name,{value:a.value})}},wfs:{FeatureCollection:function(a){for(var b=this.createElementNSPlus("wfs:FeatureCollection"),c=0,d=a.length;c<d;++c)this.writeNode("gml:featureMember",
+a[c],b);return b}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.Base"});
+OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({outerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.outer=c.components[0]},innerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},Box:function(a,b){var c=
+{};this.readChildNodes(a,c);if(!b.components)b.components=[];var d=c.points[0],c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){a=this.writeNode(OpenLayers.Util.isArray(a)?"wfs:FeatureCollection":"gml:featureMember",a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);
+return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[a],b);return b},coordinates:function(a){for(var b=a.length,c=Array(b),d,e=0;e<b;++e)d=a[e],c[e]=this.xy?d.x+","+d.y:d.y+","+d.x,void 0!=d.z&&(c[e]+=","+d.z);return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:1==b?c[0]:c.join(" ")})},LineString:function(a){var b=
+this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",a.components,b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",a.components[0],b);for(var c=1;c<a.components.length;++c)this.writeNode("innerBoundaryIs",a.components[c],b);return b},outerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",a,b);return b},innerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:innerBoundaryIs");
+this.writeNode("LinearRing",a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",a.components,b);return b},Box:function(a){var b=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:a.left,y:a.bottom},{x:a.right,y:a.top}],b);this.srsName&&b.setAttribute("srsName",this.srsName);return b}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},
+CLASS_NAME:"OpenLayers.Format.GML.v2"});
+OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:!1,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:!1,propertyStyles:null,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.rules=[];b&&b.rules&&this.addRules(b.rules);this.setDefaultStyle(a||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a=0,b=this.rules.length;a<b;a++)this.rules[a].destroy(),
+this.rules[a]=null;this.defaultStyle=this.rules=null},createSymbolizer:function(a){for(var b=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),a),c=this.rules,d,e=[],f=!1,g=0,h=c.length;g<h;g++)d=c[g],d.evaluate(a)&&(d instanceof OpenLayers.Rule&&d.elseFilter?e.push(d):(f=!0,this.applySymbolizer(d,b,a)));if(!1==f&&0<e.length){f=!0;g=0;for(h=e.length;g<h;g++)this.applySymbolizer(e[g],b,a)}if(0<c.length&&!1==f)b.display="none";if(null!=b.label&&"string"!==
+typeof b.label)b.label=""+b.label;return b},applySymbolizer:function(a,b,c){var d=c.geometry?this.getSymbolizerPrefix(c.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0],a=a.symbolizer[d]||a.symbolizer;if(!0===this.defaultsPerSymbolizer)d=this.defaultStyle,OpenLayers.Util.applyDefaults(a,{pointRadius:d.pointRadius}),(!0===a.stroke||!0===a.graphic)&&OpenLayers.Util.applyDefaults(a,{strokeWidth:d.strokeWidth,strokeColor:d.strokeColor,strokeOpacity:d.strokeOpacity,strokeDashstyle:d.strokeDashstyle,strokeLinecap:d.strokeLinecap}),
+(!0===a.fill||!0===a.graphic)&&OpenLayers.Util.applyDefaults(a,{fillColor:d.fillColor,fillOpacity:d.fillOpacity}),!0===a.graphic&&OpenLayers.Util.applyDefaults(a,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});
+return this.createLiterals(OpenLayers.Util.extend(b,a),c)},createLiterals:function(a,b){var c=OpenLayers.Util.extend({},b.attributes||b.data);OpenLayers.Util.extend(c,this.context);for(var d in this.propertyStyles)a[d]=OpenLayers.Style.createLiteral(a[d],c,b,d);return a},findPropertyStyles:function(){var a={};this.addPropertyStyles(a,this.defaultStyle);for(var b=this.rules,c,d,e=0,f=b.length;e<f;e++){c=b[e].symbolizer;for(var g in c)if(d=c[g],"object"==typeof d)this.addPropertyStyles(a,d);else{this.addPropertyStyles(a,
+c);break}}return a},addPropertyStyles:function(a,b){var c,d;for(d in b)c=b[d],"string"==typeof c&&c.match(/\$\{\w+\}/)&&(a[d]=!0);return a},addRules:function(a){Array.prototype.push.apply(this.rules,a);this.propertyStyles=this.findPropertyStyles()},setDefaultStyle:function(a){this.defaultStyle=a;this.propertyStyles=this.findPropertyStyles()},getSymbolizerPrefix:function(a){for(var b=OpenLayers.Style.SYMBOLIZER_PREFIXES,c=0,d=b.length;c<d;c++)if(-1!=a.CLASS_NAME.indexOf(b[c]))return b[c]},clone:function(){var a=
+OpenLayers.Util.extend({},this);if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}a.context=this.context&&OpenLayers.Util.extend({},this.context);b=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(b,a)},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(a,b,c,d){"string"==typeof a&&-1!=a.indexOf("${")&&(a=OpenLayers.String.format(a,b,[c,d]),a=isNaN(a)||!a?a:parseFloat(a));return a};
+OpenLayers.Style.SYMBOLIZER_PREFIXES=["Point","Line","Polygon","Text","Raster"];OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(a){OpenLayers.Util.extend(this,a)},clone:function(){return new (eval(this.CLASS_NAME))(OpenLayers.Util.extend({},this))},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Point"});
+OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});
+OpenLayers.Symbolizer.Text=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});
+OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:!1,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(a){this.symbolizer={};OpenLayers.Util.extend(this,a);this.symbolizers&&delete this.symbolizer;this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a in this.symbolizer)this.symbolizer[a]=null;this.symbolizer=null;delete this.symbolizers},evaluate:function(a){var b=
+this.getContext(a),c=!0;if(this.minScaleDenominator||this.maxScaleDenominator)var d=a.layer.map.getScale();this.minScaleDenominator&&(c=d>=OpenLayers.Style.createLiteral(this.minScaleDenominator,b));c&&this.maxScaleDenominator&&(c=d<OpenLayers.Style.createLiteral(this.maxScaleDenominator,b));c&&this.filter&&(c="OpenLayers.Filter.FeatureId"==this.filter.CLASS_NAME?this.filter.evaluate(a):this.filter.evaluate(b));return c},getContext:function(a){var b=this.context;b||(b=a.attributes||a.data);"function"==
+typeof this.context&&(b=this.context(a));return b},clone:function(){var a=OpenLayers.Util.extend({},this);if(this.symbolizers){var b=this.symbolizers.length;a.symbolizers=Array(b);for(var c=0;c<b;++c)a.symbolizers[c]=this.symbolizers[c].clone()}else{a.symbolizer={};for(var d in this.symbolizer)b=this.symbolizer[d],c=typeof b,"object"===c?a.symbolizer[d]=OpenLayers.Util.extend({},b):"string"===c&&(a.symbolizer[d]=b)}a.filter=this.filter&&this.filter.clone();a.context=this.context&&OpenLayers.Util.extend({},
+this.context);return new OpenLayers.Rule(a)},CLASS_NAME:"OpenLayers.Rule"});
+OpenLayers.Format.OGCExceptionReport=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},defaultPrefix:"ogc",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b={exceptionReport:null};a.documentElement&&(this.readChildNodes(a,b),null===b.exceptionReport&&(b=(new OpenLayers.Format.OWSCommon).read(a)));return b},readers:{ogc:{ServiceExceptionReport:function(a,
+b){b.exceptionReport={exceptions:[]};this.readChildNodes(a,b.exceptionReport)},ServiceException:function(a,b){var c={code:a.getAttribute("code"),locator:a.getAttribute("locator"),text:this.getChildValue(a)};b.exceptions.push(c)}}},CLASS_NAME:"OpenLayers.Format.OGCExceptionReport"});
+OpenLayers.Format.XML.VersionedOGC=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:null,version:null,profile:null,errorProperty:null,name:null,stringifyOutput:!1,parser:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);a=this.CLASS_NAME;this.name=a.substring(a.lastIndexOf(".")+1)},getVersion:function(a,b){var c;if(a){if(c=this.version,!c&&(c=a.getAttribute("version"),!c))c=this.defaultVersion}else c=b&&b.version||this.version||this.defaultVersion;return c},
+getParser:function(a){var a=a||this.defaultVersion,b=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.VERSION!=a){var c=OpenLayers.Format[this.name]["v"+a.replace(/\./g,"_")+b];if(!c)throw"Can't find a "+this.name+" parser for version "+a+b;this.parser=new c(this.options)}return this.parser},write:function(a,b){this.parser=this.getParser(this.getVersion(null,b));var c=this.parser.write(a,b);return!1===this.stringifyOutput?c:OpenLayers.Format.XML.prototype.write.apply(this,[c])},read:function(a,
+b){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var c=this.getVersion(a.documentElement);this.parser=this.getParser(c);var d=this.parser.read(a,b);if(null!==this.errorProperty&&void 0===d[this.errorProperty]){var e=new OpenLayers.Format.OGCExceptionReport;d.error=e.read(a)}d.version=c;return d},CLASS_NAME:"OpenLayers.Format.XML.VersionedOGC"});
+OpenLayers.Filter=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},destroy:function(){},evaluate:function(){return!0},clone:function(){return null},CLASS_NAME:"OpenLayers.Filter"});
+OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,type:"FID",initialize:function(a){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},evaluate:function(a){for(var b=0,c=this.fids.length;b<c;b++)if((a.fid||a.id)==this.fids[b])return!0;return!1},clone:function(){var a=new OpenLayers.Filter.FeatureId;OpenLayers.Util.extend(a,this);a.fids=this.fids.slice();return a},CLASS_NAME:"OpenLayers.Filter.FeatureId"});
+OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(a){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this)},evaluate:function(a){var b,c;switch(this.type){case OpenLayers.Filter.Logical.AND:for(b=0,c=this.filters.length;b<c;b++)if(!1==this.filters[b].evaluate(a))return!1;return!0;case OpenLayers.Filter.Logical.OR:for(b=0,c=this.filters.length;b<
+c;b++)if(!0==this.filters[b].evaluate(a))return!0;return!1;case OpenLayers.Filter.Logical.NOT:return!this.filters[0].evaluate(a)}},clone:function(){for(var a=[],b=0,c=this.filters.length;b<c;++b)a.push(this.filters[b].clone());return new OpenLayers.Filter.Logical({type:this.type,filters:a})},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";
+OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:!0,lowerBoundary:null,upperBoundary:null,initialize:function(a){OpenLayers.Filter.prototype.initialize.apply(this,[a]);if(this.type===OpenLayers.Filter.Comparison.LIKE&&void 0===a.matchCase)this.matchCase=null},evaluate:function(a){if(a instanceof OpenLayers.Feature.Vector)a=a.attributes;var b=!1,a=a[this.property];switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:b=this.value;
+b=!this.matchCase&&"string"==typeof a&&"string"==typeof b?a.toUpperCase()==b.toUpperCase():a==b;break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:b=this.value;b=!this.matchCase&&"string"==typeof a&&"string"==typeof b?a.toUpperCase()!=b.toUpperCase():a!=b;break;case OpenLayers.Filter.Comparison.LESS_THAN:b=a<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:b=a>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:b=a<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:b=
+a>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:b=a>=this.lowerBoundary&&a<=this.upperBoundary;break;case OpenLayers.Filter.Comparison.LIKE:b=RegExp(this.value,"gi").test(a)}return b},value2regex:function(a,b,c){if("."==a)throw Error("'.' is an unsupported wildCard character for OpenLayers.Filter.Comparison");a=a?a:"*";b=b?b:".";this.value=this.value.replace(RegExp("\\"+(c?c:"!")+"(.|$)","g"),"\\$1");this.value=this.value.replace(RegExp("\\"+b,"g"),".");this.value=this.value.replace(RegExp("\\"+
+a,"g"),".*");this.value=this.value.replace(RegExp("\\\\.\\*","g"),"\\"+a);return this.value=this.value.replace(RegExp("\\\\\\.","g"),"\\"+b)},regex2value:function(){var a=this.value,a=a.replace(/!/g,"!!"),a=a.replace(/(\\)?\\\./g,function(a,c){return c?a:"!."}),a=a.replace(/(\\)?\\\*/g,function(a,c){return c?a:"!*"}),a=a.replace(/\\\\/g,"\\");return a=a.replace(/\.\*/g,"*")},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison,this)},CLASS_NAME:"OpenLayers.Filter.Comparison"});
+OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";
+OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,evaluate:function(a){var b=!1;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(a.geometry){var c=this.value;"OpenLayers.Bounds"==this.value.CLASS_NAME&&(c=this.value.toGeometry());a.geometry.intersects(c)&&(b=!0)}break;default:throw Error("evaluate is not implemented for this filter type.");}return b},clone:function(){var a=
+OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(a)},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";
+OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",stringifyOutput:!0,namedLayersAsArray:!1,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,CLASS_NAME:"OpenLayers.Filter.Function"});
+OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){var b={};this.readers.ogc.Filter.apply(this,[a,b]);return b.filter},readers:{ogc:{Filter:function(a,b){var c={fids:[],filters:[]};
+this.readChildNodes(a,c);if(0<c.fids.length)b.filter=new OpenLayers.Filter.FeatureId({fids:c.fids});else if(0<c.filters.length)b.filter=c.filters[0]},FeatureId:function(a,b){var c=a.getAttribute("fid");c&&b.fids.push(c)},And:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(a,c);b.filters.push(c)},Or:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(a,c);b.filters.push(c)},Not:function(a,
+b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThan:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThan:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThanOrEqualTo:function(a,b){var c=
+new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThanOrEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsBetween:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(a,c);b.filters.push(c)},Literal:function(a,
+b){b.value=OpenLayers.String.numericIf(this.getChildValue(a))},PropertyName:function(a,b){b.property=this.getChildValue(a)},LowerBoundary:function(a,b){b.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(a))},UpperBoundary:function(a,b){b.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(a))},Intersects:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.INTERSECTS)},Within:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.WITHIN)},Contains:function(a,
+b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.CONTAINS)},DWithin:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.DWITHIN)},Distance:function(a,b){b.distance=parseInt(this.getChildValue(a));b.distanceUnits=a.getAttribute("units")},Function:function(){}}},readSpatial:function(a,b,c){c=new OpenLayers.Filter.Spatial({type:c});this.readChildNodes(a,c);c.value=c.components[0];delete c.components;b.filters.push(c)},readOgcExpression:function(a){var b={};this.readChildNodes(a,b);b=b.value;
+void 0===b&&(b=this.getChildValue(a));return b},writeOgcExpression:function(a,b){if(a instanceof OpenLayers.Filter.Function){var c=this.writeNode("Function",a,b);b.appendChild(c)}else this.writeNode("Literal",a,b);return b},write:function(a){return this.writers.ogc.Filter.apply(this,[a])},writeFeatureIdNodes:function(a,b){for(var c=0,d=a.fids.length;c<d;++c)this.writeNode("FeatureId",a.fids[c],b)},writers:{ogc:{Filter:function(a){var b=this.createElementNSPlus("ogc:Filter");"FID"===a.type?OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,
+a,b):this.writeNode(this.getFilterType(a),a,b);return b},FeatureId:function(a){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:a}})},And:function(a){for(var b=this.createElementNSPlus("ogc:And"),c,d=0,e=a.filters.length;d<e;++d)c=a.filters[d],"FID"===c.type?OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,c,b):this.writeNode(this.getFilterType(c),c,b);return b},Or:function(a){for(var b=this.createElementNSPlus("ogc:Or"),c,d=0,e=a.filters.length;d<e;++d)c=a.filters[d],
+"FID"===c.type?OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,c,b):this.writeNode(this.getFilterType(c),c,b);return b},Not:function(a){var b=this.createElementNSPlus("ogc:Not"),a=a.filters[0];"FID"===a.type?OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,a,b):this.writeNode(this.getFilterType(a),a,b);return b},PropertyIsLessThan:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,
+b);return b},PropertyIsGreaterThan:function(a){var b=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLessThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsGreaterThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",
+a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsBetween:function(a){var b=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",a,b);this.writeNode("LowerBoundary",a,b);this.writeNode("UpperBoundary",a,b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",{value:a.property})},Literal:function(a){return this.createElementNSPlus("ogc:Literal",{value:a})},LowerBoundary:function(a){var b=this.createElementNSPlus("ogc:LowerBoundary");
+this.writeOgcExpression(a.lowerBoundary,b);return b},UpperBoundary:function(a){var b=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",a.upperBoundary,b);return b},INTERSECTS:function(a){return this.writeSpatial(a,"Intersects")},WITHIN:function(a){return this.writeSpatial(a,"Within")},CONTAINS:function(a){return this.writeSpatial(a,"Contains")},DWITHIN:function(a){var b=this.writeSpatial(a,"DWithin");this.writeNode("Distance",a,b);return b},Distance:function(a){return this.createElementNSPlus("ogc:Distance",
+{attributes:{units:a.distanceUnits},value:a.distance})},Function:function(a){for(var b=this.createElementNSPlus("ogc:Function",{attributes:{name:a.name}}),a=a.params,c=0,d=a.length;c<d;c++)this.writeOgcExpression(a[c],b);return b}}},getFilterType:function(a){var b=this.filterMap[a.type];if(!b)throw"Filter writing not supported for rule type: "+a.type;return b},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan",
+"<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike",BBOX:"BBOX",DWITHIN:"DWITHIN",WITHIN:"WITHIN",CONTAINS:"CONTAINS",INTERSECTS:"INTERSECTS",FID:"FeatureId"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});
+OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,
+b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escape");c.value2regex(d,e,f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,
+feature:OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",
+{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");a.property&&this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Box",a.value,b);a.projection&&c.setAttribute("srsName",a.projection);return b}},OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Format.GML.v2.prototype.writers.feature},
+writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);if(a.value instanceof OpenLayers.Filter.Function)this.writeNode("Function",a.value,c);else{var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Box",a.value);a.projection&&d.setAttribute("srsName",a.projection);c.appendChild(d)}return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});
+OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,multipleSymbolizers:!1,featureTypeCounter:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,strokeDashstyle:"solid",pointRadius:3,
+graphicName:"square"},initialize:function(a){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[a])},read:function(a,b){var b=OpenLayers.Util.applyDefaults(b,this.options),c={namedLayers:!0===b.namedLayersAsArray?[]:{}};this.readChildNodes(a,c);return c},readers:OpenLayers.Util.applyDefaults({sld:{StyledLayerDescriptor:function(a,b){b.version=a.getAttribute("version");this.readChildNodes(a,b)},Name:function(a,b){b.name=this.getChildValue(a)},Title:function(a,b){b.title=this.getChildValue(a)},
+Abstract:function(a,b){b.description=this.getChildValue(a)},NamedLayer:function(a,b){var c={userStyles:[],namedStyles:[]};this.readChildNodes(a,c);for(var d=0,e=c.userStyles.length;d<e;++d)c.userStyles[d].layerName=c.name;OpenLayers.Util.isArray(b.namedLayers)?b.namedLayers.push(c):b.namedLayers[c.name]=c},NamedStyle:function(a,b){b.namedStyles.push(this.getChildValue(a.firstChild))},UserStyle:function(a,b){var c={defaultsPerSymbolizer:!0,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(a,
+c);this.multipleSymbolizers?(delete c.defaultsPerSymbolizer,c=new OpenLayers.Style2(c)):c=new OpenLayers.Style(this.defaultSymbolizer,c);b.userStyles.push(c)},IsDefault:function(a,b){if("1"==this.getChildValue(a))b.isDefault=!0},FeatureTypeStyle:function(a,b){++this.featureTypeCounter;var c={rules:this.multipleSymbolizers?b.rules:[]};this.readChildNodes(a,c);if(!this.multipleSymbolizers)b.rules=c.rules},Rule:function(a,b){var c;this.multipleSymbolizers&&(c={symbolizers:[]});c=new OpenLayers.Rule(c);
+this.readChildNodes(a,c);b.rules.push(c)},ElseFilter:function(a,b){b.elseFilter=!0},MinScaleDenominator:function(a,b){b.minScaleDenominator=parseFloat(this.getChildValue(a))},MaxScaleDenominator:function(a,b){b.maxScaleDenominator=parseFloat(this.getChildValue(a))},TextSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Text(c))):b.symbolizer.Text=OpenLayers.Util.applyDefaults(c,b.symbolizer.Text)},
+Label:function(a,b){var c={};this.readChildNodes(a,c);if(c.property)b.label="${"+c.property+"}";else if(c=this.readOgcExpression(a))b.label=c},Font:function(a,b){this.readChildNodes(a,b)},Halo:function(a,b){var c={};this.readChildNodes(a,c);b.haloRadius=c.haloRadius;b.haloColor=c.fillColor;b.haloOpacity=c.fillOpacity},Radius:function(a,b){var c=this.readOgcExpression(a);if(null!=c)b.haloRadius=c},RasterSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,
+b.symbolizers.push(new OpenLayers.Symbolizer.Raster(c))):b.symbolizer.Raster=OpenLayers.Util.applyDefaults(c,b.symbolizer.Raster)},Geometry:function(a,b){b.geometry={};this.readChildNodes(a,b.geometry)},ColorMap:function(a,b){b.colorMap=[];this.readChildNodes(a,b.colorMap)},ColorMapEntry:function(a,b){var c=a.getAttribute("quantity"),d=a.getAttribute("opacity");b.push({color:a.getAttribute("color"),quantity:null!==c?parseFloat(c):void 0,label:a.getAttribute("label")||void 0,opacity:null!==d?parseFloat(d):
+void 0})},LineSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Line(c))):b.symbolizer.Line=OpenLayers.Util.applyDefaults(c,b.symbolizer.Line)},PolygonSymbolizer:function(a,b){var c={fill:!1,stroke:!1};this.multipleSymbolizers||(c=b.symbolizer.Polygon||c);this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Polygon(c))):
+b.symbolizer.Polygon=c},PointSymbolizer:function(a,b){var c={fill:!1,stroke:!1,graphic:!1};this.multipleSymbolizers||(c=b.symbolizer.Point||c);this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Point(c))):b.symbolizer.Point=c},Stroke:function(a,b){b.stroke=!0;this.readChildNodes(a,b)},Fill:function(a,b){b.fill=!0;this.readChildNodes(a,b)},CssParameter:function(a,b){var c=this.cssMap[a.getAttribute("name")];if(c){var d=this.readOgcExpression(a);
+d&&(b[c]=d)}},Graphic:function(a,b){b.graphic=!0;var c={};this.readChildNodes(a,c);for(var d="stroke,strokeColor,strokeWidth,strokeOpacity,strokeLinecap,fill,fillColor,fillOpacity,graphicName,rotation,graphicFormat".split(","),e,f,g=0,h=d.length;g<h;++g)e=d[g],f=c[e],void 0!=f&&(b[e]=f);if(void 0!=c.opacity)b.graphicOpacity=c.opacity;if(void 0!=c.size)b.pointRadius=c.size/2;if(void 0!=c.href)b.externalGraphic=c.href;if(void 0!=c.rotation)b.rotation=c.rotation},ExternalGraphic:function(a,b){this.readChildNodes(a,
+b)},Mark:function(a,b){this.readChildNodes(a,b)},WellKnownName:function(a,b){b.graphicName=this.getChildValue(a)},Opacity:function(a,b){var c=this.readOgcExpression(a);if(c)b.opacity=c},Size:function(a,b){var c=this.readOgcExpression(a);if(c)b.size=c},Rotation:function(a,b){var c=this.readOgcExpression(a);if(c)b.rotation=c},OnlineResource:function(a,b){b.href=this.getAttributeNS(a,this.namespaces.xlink,"href")},Format:function(a,b){b.graphicFormat=this.getChildValue(a)}}},OpenLayers.Format.Filter.v1_0_0.prototype.readers),
+cssMap:{stroke:"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","stroke-dasharray":"strokeDashstyle",fill:"fillColor","fill-opacity":"fillOpacity","font-family":"fontFamily","font-size":"fontSize","font-weight":"fontWeight","font-style":"fontStyle"},getCssProperty:function(a){var b=null,c;for(c in this.cssMap)if(this.cssMap[c]==a){b=c;break}return b},getGraphicFormat:function(a){var b,c;for(c in this.graphicFormats)if(this.graphicFormats[c].test(a)){b=
+c;break}return b||this.defautlGraphicFormat},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(a){return this.writers.sld.StyledLayerDescriptor.apply(this,[a])},writers:OpenLayers.Util.applyDefaults({sld:{StyledLayerDescriptor:function(a){var b=this.createElementNSPlus("sld:StyledLayerDescriptor",{attributes:{version:this.VERSION,"xsi:schemaLocation":this.schemaLocation}});b.setAttribute("xmlns:ogc",this.namespaces.ogc);
+b.setAttribute("xmlns:gml",this.namespaces.gml);a.name&&this.writeNode("Name",a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&this.writeNode("Abstract",a.description,b);if(OpenLayers.Util.isArray(a.namedLayers))for(var c=0,d=a.namedLayers.length;c<d;++c)this.writeNode("NamedLayer",a.namedLayers[c],b);else for(c in a.namedLayers)this.writeNode("NamedLayer",a.namedLayers[c],b);return b},Name:function(a){return this.createElementNSPlus("sld:Name",{value:a})},Title:function(a){return this.createElementNSPlus("sld:Title",
+{value:a})},Abstract:function(a){return this.createElementNSPlus("sld:Abstract",{value:a})},NamedLayer:function(a){var b=this.createElementNSPlus("sld:NamedLayer");this.writeNode("Name",a.name,b);if(a.namedStyles)for(var c=0,d=a.namedStyles.length;c<d;++c)this.writeNode("NamedStyle",a.namedStyles[c],b);if(a.userStyles){c=0;for(d=a.userStyles.length;c<d;++c)this.writeNode("UserStyle",a.userStyles[c],b)}return b},NamedStyle:function(a){var b=this.createElementNSPlus("sld:NamedStyle");this.writeNode("Name",
+a,b);return b},UserStyle:function(a){var b=this.createElementNSPlus("sld:UserStyle");a.name&&this.writeNode("Name",a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&this.writeNode("Abstract",a.description,b);a.isDefault&&this.writeNode("IsDefault",a.isDefault,b);if(this.multipleSymbolizers&&a.rules){for(var c={"0":[]},d=[0],e,f,g,h,i,j=0,k=a.rules.length;j<k;++j)if(e=a.rules[j],e.symbolizers){f={};for(var m=0,n=e.symbolizers.length;m<n;++m){g=e.symbolizers[m];h=g.zIndex;if(!(h in
+f))i=e.clone(),i.symbolizers=[],f[h]=i;f[h].symbolizers.push(g.clone())}for(h in f)h in c||(d.push(h),c[h]=[]),c[h].push(f[h])}else c[0].push(e.clone());d.sort();j=0;for(k=d.length;j<k;++j)if(e=c[d[j]],0<e.length)i=a.clone(),i.rules=c[d[j]],this.writeNode("FeatureTypeStyle",i,b)}else this.writeNode("FeatureTypeStyle",a,b);return b},IsDefault:function(a){return this.createElementNSPlus("sld:IsDefault",{value:a?"1":"0"})},FeatureTypeStyle:function(a){for(var b=this.createElementNSPlus("sld:FeatureTypeStyle"),
+c=0,d=a.rules.length;c<d;++c)this.writeNode("Rule",a.rules[c],b);return b},Rule:function(a){var b=this.createElementNSPlus("sld:Rule");a.name&&this.writeNode("Name",a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&this.writeNode("Abstract",a.description,b);a.elseFilter?this.writeNode("ElseFilter",null,b):a.filter&&this.writeNode("ogc:Filter",a.filter,b);void 0!=a.minScaleDenominator&&this.writeNode("MinScaleDenominator",a.minScaleDenominator,b);void 0!=a.maxScaleDenominator&&this.writeNode("MaxScaleDenominator",
+a.maxScaleDenominator,b);var c,d;if(this.multipleSymbolizers&&a.symbolizers)for(var e=0,f=a.symbolizers.length;e<f;++e)d=a.symbolizers[e],c=d.CLASS_NAME.split(".").pop(),this.writeNode(c+"Symbolizer",d,b);else for(var f=OpenLayers.Style.SYMBOLIZER_PREFIXES,e=0,g=f.length;e<g;++e)c=f[e],(d=a.symbolizer[c])&&this.writeNode(c+"Symbolizer",d,b);return b},ElseFilter:function(){return this.createElementNSPlus("sld:ElseFilter")},MinScaleDenominator:function(a){return this.createElementNSPlus("sld:MinScaleDenominator",
+{value:a})},MaxScaleDenominator:function(a){return this.createElementNSPlus("sld:MaxScaleDenominator",{value:a})},LineSymbolizer:function(a){var b=this.createElementNSPlus("sld:LineSymbolizer");this.writeNode("Stroke",a,b);return b},Stroke:function(a){var b=this.createElementNSPlus("sld:Stroke");void 0!=a.strokeColor&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeColor"},b);void 0!=a.strokeOpacity&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeOpacity"},b);void 0!=a.strokeWidth&&
+this.writeNode("CssParameter",{symbolizer:a,key:"strokeWidth"},b);void 0!=a.strokeDashstyle&&"solid"!==a.strokeDashstyle&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeDashstyle"},b);void 0!=a.strokeLinecap&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeLinecap"},b);return b},CssParameter:function(a){return this.createElementNSPlus("sld:CssParameter",{attributes:{name:this.getCssProperty(a.key)},value:a.symbolizer[a.key]})},TextSymbolizer:function(a){var b=this.createElementNSPlus("sld:TextSymbolizer");
+null!=a.label&&this.writeNode("Label",a.label,b);(null!=a.fontFamily||null!=a.fontSize||null!=a.fontWeight||null!=a.fontStyle)&&this.writeNode("Font",a,b);(null!=a.haloRadius||null!=a.haloColor||null!=a.haloOpacity)&&this.writeNode("Halo",a,b);(null!=a.fillColor||null!=a.fillOpacity)&&this.writeNode("Fill",a,b);return b},Font:function(a){var b=this.createElementNSPlus("sld:Font");a.fontFamily&&this.writeNode("CssParameter",{symbolizer:a,key:"fontFamily"},b);a.fontSize&&this.writeNode("CssParameter",
+{symbolizer:a,key:"fontSize"},b);a.fontWeight&&this.writeNode("CssParameter",{symbolizer:a,key:"fontWeight"},b);a.fontStyle&&this.writeNode("CssParameter",{symbolizer:a,key:"fontStyle"},b);return b},Label:function(a){var b=this.createElementNSPlus("sld:Label"),a=a.split("${");b.appendChild(this.createTextNode(a[0]));for(var c,d,e=1,f=a.length;e<f;e++)c=a[e],d=c.indexOf("}"),0<d?(this.writeNode("ogc:PropertyName",{property:c.substring(0,d)},b),b.appendChild(this.createTextNode(c.substring(++d)))):
+b.appendChild(this.createTextNode("${"+c));return b},Halo:function(a){var b=this.createElementNSPlus("sld:Halo");a.haloRadius&&this.writeNode("Radius",a.haloRadius,b);(a.haloColor||a.haloOpacity)&&this.writeNode("Fill",{fillColor:a.haloColor,fillOpacity:a.haloOpacity},b);return b},Radius:function(a){return this.createElementNSPlus("sld:Radius",{value:a})},RasterSymbolizer:function(a){var b=this.createElementNSPlus("sld:RasterSymbolizer");a.geometry&&this.writeNode("Geometry",a.geometry,b);a.opacity&&
+this.writeNode("Opacity",a.opacity,b);a.colorMap&&this.writeNode("ColorMap",a.colorMap,b);return b},Geometry:function(a){var b=this.createElementNSPlus("sld:Geometry");a.property&&this.writeNode("ogc:PropertyName",a,b);return b},ColorMap:function(a){for(var b=this.createElementNSPlus("sld:ColorMap"),c=0,d=a.length;c<d;++c)this.writeNode("ColorMapEntry",a[c],b);return b},ColorMapEntry:function(a){var b=this.createElementNSPlus("sld:ColorMapEntry");b.setAttribute("color",a.color);void 0!==a.opacity&&
+b.setAttribute("opacity",parseFloat(a.opacity));void 0!==a.quantity&&b.setAttribute("quantity",parseFloat(a.quantity));void 0!==a.label&&b.setAttribute("label",a.label);return b},PolygonSymbolizer:function(a){var b=this.createElementNSPlus("sld:PolygonSymbolizer");!1!==a.fill&&this.writeNode("Fill",a,b);!1!==a.stroke&&this.writeNode("Stroke",a,b);return b},Fill:function(a){var b=this.createElementNSPlus("sld:Fill");a.fillColor&&this.writeNode("CssParameter",{symbolizer:a,key:"fillColor"},b);null!=
+a.fillOpacity&&this.writeNode("CssParameter",{symbolizer:a,key:"fillOpacity"},b);return b},PointSymbolizer:function(a){var b=this.createElementNSPlus("sld:PointSymbolizer");this.writeNode("Graphic",a,b);return b},Graphic:function(a){var b=this.createElementNSPlus("sld:Graphic");void 0!=a.externalGraphic?this.writeNode("ExternalGraphic",a,b):this.writeNode("Mark",a,b);void 0!=a.graphicOpacity&&this.writeNode("Opacity",a.graphicOpacity,b);void 0!=a.pointRadius&&this.writeNode("Size",2*a.pointRadius,
+b);void 0!=a.rotation&&this.writeNode("Rotation",a.rotation,b);return b},ExternalGraphic:function(a){var b=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",a.externalGraphic,b);this.writeNode("Format",a.graphicFormat||this.getGraphicFormat(a.externalGraphic),b);return b},Mark:function(a){var b=this.createElementNSPlus("sld:Mark");a.graphicName&&this.writeNode("WellKnownName",a.graphicName,b);!1!==a.fill&&this.writeNode("Fill",a,b);!1!==a.stroke&&this.writeNode("Stroke",
+a,b);return b},WellKnownName:function(a){return this.createElementNSPlus("sld:WellKnownName",{value:a})},Opacity:function(a){return this.createElementNSPlus("sld:Opacity",{value:a})},Size:function(a){return this.createElementNSPlus("sld:Size",{value:a})},Rotation:function(a){return this.createElementNSPlus("sld:Rotation",{value:a})},OnlineResource:function(a){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":a}})},Format:function(a){return this.createElementNSPlus("sld:Format",
+{value:a})}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(a){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[a])},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});
+OpenLayers.Format.Context=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{layerOptions:null,layerParams:null,read:function(a,b){var c=OpenLayers.Format.XML.VersionedOGC.prototype.read.apply(this,arguments);if(b&&b.map)if(this.context=c,b.map instanceof OpenLayers.Map)c=this.mergeContextToMap(c,b.map);else{var d=b.map;if(OpenLayers.Util.isElement(d)||"string"==typeof d)d={div:d};c=this.contextToMap(c,d)}return c},getLayerFromContext:function(a){var b,c,d={queryable:a.queryable,visibility:a.visibility,
+maxExtent:a.maxExtent,metadata:OpenLayers.Util.applyDefaults(a.metadata,{styles:a.styles,formats:a.formats,"abstract":a["abstract"],dataURL:a.dataURL}),numZoomLevels:a.numZoomLevels,units:a.units,isBaseLayer:a.isBaseLayer,opacity:a.opacity,displayInLayerSwitcher:a.displayInLayerSwitcher,singleTile:a.singleTile,tileSize:a.tileSize?new OpenLayers.Size(a.tileSize.width,a.tileSize.height):void 0,minScale:a.minScale||a.maxScaleDenominator,maxScale:a.maxScale||a.minScaleDenominator,srs:a.srs,dimensions:a.dimensions,
+metadataURL:a.metadataURL};this.layerOptions&&OpenLayers.Util.applyDefaults(d,this.layerOptions);var e={layers:a.name,transparent:a.transparent,version:a.version};if(a.formats&&0<a.formats.length){e.format=a.formats[0].value;for(b=0,c=a.formats.length;b<c;b++){var f=a.formats[b];if(!0==f.current){e.format=f.value;break}}}if(a.styles&&0<a.styles.length)for(b=0,c=a.styles.length;b<c;b++)if(f=a.styles[b],!0==f.current){f.href?e.sld=f.href:f.body?e.sld_body=f.body:e.styles=f.name;break}this.layerParams&&
+OpenLayers.Util.applyDefaults(e,this.layerParams);b=null;c=a.service;c==OpenLayers.Format.Context.serviceTypes.WFS?(d.strategies=[new OpenLayers.Strategy.BBOX],d.protocol=new OpenLayers.Protocol.WFS({url:a.url,featurePrefix:a.name.split(":")[0],featureType:a.name.split(":").pop()}),b=new OpenLayers.Layer.Vector(a.title||a.name,d)):c==OpenLayers.Format.Context.serviceTypes.KML?(d.strategies=[new OpenLayers.Strategy.Fixed],d.protocol=new OpenLayers.Protocol.HTTP({url:a.url,format:new OpenLayers.Format.KML}),
+b=new OpenLayers.Layer.Vector(a.title||a.name,d)):c==OpenLayers.Format.Context.serviceTypes.GML?(d.strategies=[new OpenLayers.Strategy.Fixed],d.protocol=new OpenLayers.Protocol.HTTP({url:a.url,format:new OpenLayers.Format.GML}),b=new OpenLayers.Layer.Vector(a.title||a.name,d)):a.features?(b=new OpenLayers.Layer.Vector(a.title||a.name,d),b.addFeatures(a.features)):!0!==a.categoryLayer&&(b=new OpenLayers.Layer.WMS(a.title||a.name,a.url,e,d));return b},getLayersFromContext:function(a){for(var b=[],c=
+0,d=a.length;c<d;c++){var e=this.getLayerFromContext(a[c]);null!==e&&b.push(e)}return b},contextToMap:function(a,b){b=OpenLayers.Util.applyDefaults({maxExtent:a.maxExtent,projection:a.projection,units:a.units},b);if(b.maxExtent)b.maxResolution=b.maxExtent.getWidth()/OpenLayers.Map.TILE_WIDTH;b.metadata={contactInformation:a.contactInformation,"abstract":a["abstract"],keywords:a.keywords,logo:a.logo,descriptionURL:a.descriptionURL};var c=new OpenLayers.Map(b);c.addLayers(this.getLayersFromContext(a.layersContext));
+c.setCenter(a.bounds.getCenterLonLat(),c.getZoomForExtent(a.bounds,!0));return c},mergeContextToMap:function(a,b){b.addLayers(this.getLayersFromContext(a.layersContext));return b},write:function(a,b){a=this.toContext(a);return OpenLayers.Format.XML.VersionedOGC.prototype.write.apply(this,arguments)},CLASS_NAME:"OpenLayers.Format.Context"});
+OpenLayers.Format.Context.serviceTypes={WMS:"urn:ogc:serviceType:WMS",WFS:"urn:ogc:serviceType:WFS",WCS:"urn:ogc:serviceType:WCS",GML:"urn:ogc:serviceType:GML",SLD:"urn:ogc:serviceType:SLD",FES:"urn:ogc:serviceType:FES",KML:"urn:ogc:serviceType:KML"};
+OpenLayers.Format.OWSContext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getVersion:function(a,b){var c=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);if("0.3.0"===c)c=this.defaultVersion;return c},toContext:function(a){var b={};if("OpenLayers.Map"==a.CLASS_NAME)b.bounds=a.getExtent(),b.maxExtent=a.maxExtent,b.projection=a.projection,b.size=a.getSize(),b.layers=a.layers;return b},CLASS_NAME:"OpenLayers.Format.OWSContext"});
+OpenLayers.Format.OWSCommon=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",getVersion:function(a){var b=this.version;if(!b&&((a=a.getAttribute("xmlns:ows"))&&"1.1"===a.substring(a.lastIndexOf("/")+1)&&(b="1.1.0"),!b))b=this.defaultVersion;return b},CLASS_NAME:"OpenLayers.Format.OWSCommon"});
+OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a,b){OpenLayers.Util.applyDefaults(b,this.options);var c={};this.readChildNodes(a,c);return c},readers:{ows:{Exception:function(a,b){var c={code:a.getAttribute("exceptionCode"),locator:a.getAttribute("locator"),texts:[]};b.exceptions.push(c);this.readChildNodes(a,c)},ExceptionText:function(a,b){var c=this.getChildValue(a);b.texts.push(c)},
+ServiceIdentification:function(a,b){b.serviceIdentification={};this.readChildNodes(a,b.serviceIdentification)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},Keywords:function(a,b){b.keywords={};this.readChildNodes(a,b.keywords)},Keyword:function(a,b){b[this.getChildValue(a)]=!0},ServiceType:function(a,b){b.serviceType={codeSpace:a.getAttribute("codeSpace"),value:this.getChildValue(a)}},ServiceTypeVersion:function(a,b){b.serviceTypeVersion=
+this.getChildValue(a)},Fees:function(a,b){b.fees=this.getChildValue(a)},AccessConstraints:function(a,b){b.accessConstraints=this.getChildValue(a)},ServiceProvider:function(a,b){b.serviceProvider={};this.readChildNodes(a,b.serviceProvider)},ProviderName:function(a,b){b.providerName=this.getChildValue(a)},ProviderSite:function(a,b){b.providerSite=this.getAttributeNS(a,this.namespaces.xlink,"href")},ServiceContact:function(a,b){b.serviceContact={};this.readChildNodes(a,b.serviceContact)},IndividualName:function(a,
+b){b.individualName=this.getChildValue(a)},PositionName:function(a,b){b.positionName=this.getChildValue(a)},ContactInfo:function(a,b){b.contactInfo={};this.readChildNodes(a,b.contactInfo)},Phone:function(a,b){b.phone={};this.readChildNodes(a,b.phone)},Voice:function(a,b){b.voice=this.getChildValue(a)},Address:function(a,b){b.address={};this.readChildNodes(a,b.address)},DeliveryPoint:function(a,b){b.deliveryPoint=this.getChildValue(a)},City:function(a,b){b.city=this.getChildValue(a)},AdministrativeArea:function(a,
+b){b.administrativeArea=this.getChildValue(a)},PostalCode:function(a,b){b.postalCode=this.getChildValue(a)},Country:function(a,b){b.country=this.getChildValue(a)},ElectronicMailAddress:function(a,b){b.electronicMailAddress=this.getChildValue(a)},Role:function(a,b){b.role=this.getChildValue(a)},OperationsMetadata:function(a,b){b.operationsMetadata={};this.readChildNodes(a,b.operationsMetadata)},Operation:function(a,b){var c=a.getAttribute("name");b[c]={};this.readChildNodes(a,b[c])},DCP:function(a,
+b){b.dcp={};this.readChildNodes(a,b.dcp)},HTTP:function(a,b){b.http={};this.readChildNodes(a,b.http)},Get:function(a,b){b.get=[];b.get.push(this.getAttributeNS(a,this.namespaces.xlink,"href"))},Post:function(a,b){b.post=this.getAttributeNS(a,this.namespaces.xlink,"href")},Parameter:function(a,b){if(!b.parameters)b.parameters={};var c=a.getAttribute("name");b.parameters[c]={};this.readChildNodes(a,b.parameters[c])},Value:function(a,b){b[this.getChildValue(a)]=!0},OutputFormat:function(a,b){b.formats.push({value:this.getChildValue(a)});
+this.readChildNodes(a,b)},WGS84BoundingBox:function(a,b){var c={};c.crs=a.getAttribute("crs");b.boundingBox?b.boundingBox.push(c):(b.projection=c.crs,c=b);this.readChildNodes(a,c)},BoundingBox:function(a,b){this.readers.ows.WGS84BoundingBox.apply(this,[a,b])},LowerCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace);b.left=c[0];b.bottom=c[1]},UpperCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,
+""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace);b.right=c[0];b.top=c[1];b.bounds=new OpenLayers.Bounds(b.left,b.bottom,b.right,b.top);delete b.left;delete b.bottom;delete b.right;delete b.top},Language:function(a,b){b.language=this.getChildValue(a)}}},writers:{ows:{BoundingBox:function(a){var b=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:a.projection}});this.writeNode("ows:LowerCorner",a,b);this.writeNode("ows:UpperCorner",a,b);return b},LowerCorner:function(a){return this.createElementNSPlus("ows:LowerCorner",
+{value:a.bounds.left+" "+a.bounds.bottom})},UpperCorner:function(a){return this.createElementNSPlus("ows:UpperCorner",{value:a.bounds.right+" "+a.bounds.top})},Identifier:function(a){return this.createElementNSPlus("ows:Identifier",{value:a})},Title:function(a){return this.createElementNSPlus("ows:Title",{value:a})},Abstract:function(a){return this.createElementNSPlus("ows:Abstract",{value:a})},OutputFormat:function(a){return this.createElementNSPlus("ows:OutputFormat",{value:a})},Identifier:function(a){return this.createElementNSPlus("ows:Identifier",
+{attributes:{},value:a})},Version:function(a){return this.createElementNSPlus("ows:Version",{attributes:{},value:a})}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});
+OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink"},readers:{ows:OpenLayers.Util.applyDefaults({ExceptionReport:function(a,b){b.success=!1;b.exceptionReport={version:a.getAttribute("version"),language:a.getAttribute("language"),exceptions:[]};this.readChildNodes(a,b.exceptionReport)}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{ows:OpenLayers.Format.OWSCommon.v1.prototype.writers.ows},
+CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_0_0"});
+OpenLayers.Format.OWSContext.v0_3_1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",
+extractAttributes:!0,xy:!0,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:"vector",geometryName:"geometry",nestingLayerLookup:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this)},setNestingPath:function(a){if(a.layersContext)for(var b=0,c=a.layersContext.length;b<c;b++){var d=a.layersContext[b],e=
+[],f=a.title||"";a.metadata&&a.metadata.nestingPath&&(e=a.metadata.nestingPath.slice());""!=f&&e.push(f);d.metadata.nestingPath=e;d.layersContext&&this.setNestingPath(d)}},decomposeNestingPath:function(a){var b=[];if(OpenLayers.Util.isArray(a)){for(a=a.slice();0<a.length;)b.push(a.slice()),a.pop();b.reverse()}return b},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);this.setNestingPath({layersContext:b.layersContext});
+a=[];this.processLayer(a,b);delete b.layersContext;b.layersContext=a;return b},processLayer:function(a,b){if(b.layersContext)for(var c=0,d=b.layersContext.length;c<d;c++){var e=b.layersContext[c];a.push(e);e.layersContext&&this.processLayer(a,e)}},write:function(a,b){this.nestingLayerLookup={};b=b||{};OpenLayers.Util.applyDefaults(b,a);var c=this.writeNode("OWSContext",b);this.nestingLayerLookup=null;this.setAttributeNS(c,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,
+[c])},readers:{kml:{Document:function(a,b){b.features=(new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:!0})).read(a)}},owc:{OWSContext:function(a,b){this.readChildNodes(a,b)},General:function(a,b){this.readChildNodes(a,b)},ResourceList:function(a,b){this.readChildNodes(a,b)},Layer:function(a,b){var c={metadata:{},visibility:"1"!=a.getAttribute("hidden"),queryable:"1"==a.getAttribute("queryable"),opacity:null!=a.getAttribute("opacity")?parseFloat(a.getAttribute("opacity")):null,
+name:a.getAttribute("name"),categoryLayer:null==a.getAttribute("name"),formats:[],styles:[]};if(!b.layersContext)b.layersContext=[];b.layersContext.push(c);this.readChildNodes(a,c)},InlineGeometry:function(a,b){b.features=[];var c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMember"),d;1<=c.length&&(d=c[0]);if(d&&d.firstChild)c=d.firstChild.nextSibling?d.firstChild.nextSibling:d.firstChild,this.setNamespace("feature",c.namespaceURI),this.featureType=c.localName||c.nodeName.split(":").pop(),
+this.readChildNodes(a,b)},Server:function(a,b){if(!b.service&&!b.version||b.service!=OpenLayers.Format.Context.serviceTypes.WMS)b.service=a.getAttribute("service"),b.version=a.getAttribute("version"),this.readChildNodes(a,b)},Name:function(a,b){b.name=this.getChildValue(a);this.readChildNodes(a,b)},Title:function(a,b){b.title=this.getChildValue(a);this.readChildNodes(a,b)},StyleList:function(a,b){this.readChildNodes(a,b.styles)},Style:function(a,b){var c={};b.push(c);this.readChildNodes(a,c)},LegendURL:function(a,
+b){var c={};b.legend=c;this.readChildNodes(a,c)},OnlineResource:function(a,b){b.url=this.getAttributeNS(a,this.namespaces.xlink,"href");this.readChildNodes(a,b)}},ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,gml:OpenLayers.Format.GML.v2.prototype.readers.gml,sld:OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,feature:OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{owc:{OWSContext:function(a){var b=this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,
+id:a.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",a,b);this.writeNode("ResourceList",a,b);return b},General:function(a){var b=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",a,b);this.writeNode("ows:Title",a.title||"OpenLayers OWSContext",b);return b},ResourceList:function(a){for(var b=this.createElementNSPlus("ResourceList"),c=0,d=a.layers.length;c<d;c++){var e=a.layers[c],f=this.decomposeNestingPath(e.metadata.nestingPath);this.writeNode("_Layer",
+{layer:e,subPaths:f},b)}return b},Server:function(a){var b=this.createElementNSPlus("Server",{attributes:{version:a.version,service:a.service}});this.writeNode("OnlineResource",a,b);return b},OnlineResource:function(a){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":a.url}})},InlineGeometry:function(a){var b=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",a.getDataExtent(),b);for(var c=0,d=a.features.length;c<d;c++)this.writeNode("gml:featureMember",
+a.features[c],b);return b},StyleList:function(a){for(var b=this.createElementNSPlus("StyleList"),c=0,d=a.length;c<d;c++)this.writeNode("Style",a[c],b);return b},Style:function(a){var b=this.createElementNSPlus("Style");this.writeNode("Name",a,b);this.writeNode("Title",a,b);a.legend&&this.writeNode("LegendURL",a,b);return b},Name:function(a){return this.createElementNSPlus("Name",{value:a.name})},Title:function(a){return this.createElementNSPlus("Title",{value:a.title})},LegendURL:function(a){var b=
+this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",a.legend,b);return b},_WMS:function(a){var b=this.createElementNSPlus("Layer",{attributes:{name:a.params.LAYERS,queryable:a.queryable?"1":"0",hidden:a.visibility?"0":"1",opacity:a.hasOwnProperty("opacity")?a.opacity:null}});this.writeNode("ows:Title",a.name,b);this.writeNode("ows:OutputFormat",a.params.FORMAT,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:a.params.VERSION,url:a.url},b);a.metadata.styles&&
+0<a.metadata.styles.length&&this.writeNode("StyleList",a.metadata.styles,b);return b},_Layer:function(a){var b,c,d;b=a.layer;c=a.subPaths;d=null;if(0<c.length)b=c[0].join("/"),c=b.lastIndexOf("/"),d=this.nestingLayerLookup[b],c=0<c?b.substring(c+1,b.length):b,d||(d=this.createElementNSPlus("Layer"),this.writeNode("ows:Title",c,d),this.nestingLayerLookup[b]=d),a.subPaths.shift(),this.writeNode("_Layer",a,d);else{if(b instanceof OpenLayers.Layer.WMS)d=this.writeNode("_WMS",b);else if(b instanceof OpenLayers.Layer.Vector)if(b.protocol instanceof
+OpenLayers.Protocol.WFS.v1)d=this.writeNode("_WFS",b);else if(b.protocol instanceof OpenLayers.Protocol.HTTP)if(b.protocol.format instanceof OpenLayers.Format.GML)b.protocol.format.version="2.1.2",d=this.writeNode("_GML",b);else{if(b.protocol.format instanceof OpenLayers.Format.KML)b.protocol.format.version="2.2",d=this.writeNode("_KML",b)}else this.setNamespace("feature",this.featureNS),d=this.writeNode("_InlineGeometry",b);b.options.maxScale&&this.writeNode("sld:MinScaleDenominator",b.options.maxScale,
+d);b.options.minScale&&this.writeNode("sld:MaxScaleDenominator",b.options.minScale,d);this.nestingLayerLookup[b.name]=d}return d},_WFS:function(a){var b=this.createElementNSPlus("Layer",{attributes:{name:a.protocol.featurePrefix+":"+a.protocol.featureType,hidden:a.visibility?"0":"1"}});this.writeNode("ows:Title",a.name,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:a.protocol.version,url:a.protocol.url},b);return b},_InlineGeometry:function(a){var b=this.createElementNSPlus("Layer",
+{attributes:{name:this.featureType,hidden:a.visibility?"0":"1"}});this.writeNode("ows:Title",a.name,b);this.writeNode("InlineGeometry",a,b);return b},_GML:function(a){var b=this.createElementNSPlus("Layer");this.writeNode("ows:Title",a.name,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:a.protocol.url,version:a.protocol.format.version},b);return b},_KML:function(a){var b=this.createElementNSPlus("Layer");this.writeNode("ows:Title",a.name,b);this.writeNode("Server",
+{service:OpenLayers.Format.Context.serviceTypes.KML,version:a.protocol.format.version,url:a.protocol.url},b);return b}},gml:OpenLayers.Util.applyDefaults({boundedBy:function(a){var b=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",a,b);return b}},OpenLayers.Format.GML.v2.prototype.writers.gml),ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,sld:OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,feature:OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});
+OpenLayers.Format.CSWGetRecords=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetRecords.DEFAULTS),b=OpenLayers.Format.CSWGetRecords["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetRecords version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetRecords.DEFAULTS={version:"2.0.2"};
+OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:!1,displayClass:"",title:"",autoActivate:!1,active:null,handler:null,eventListeners:null,events:null,initialize:function(a){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);if(null==this.id)this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+
+"_")},destroy:function(){if(this.events)this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy(),this.events=null;this.eventListeners=null;if(this.handler)this.handler.destroy(),this.handler=null;if(this.handlers){for(var a in this.handlers)this.handlers.hasOwnProperty(a)&&"function"==typeof this.handlers[a].destroy&&this.handlers[a].destroy();this.handlers=null}if(this.map)this.map.removeControl(this),this.map=null;this.div=null},setMap:function(a){this.map=a;this.handler&&
+this.handler.setMap(a)},draw:function(a){if(null==this.div){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection)this.div.className+=" olControlNoSelect",this.div.setAttribute("unselectable","on",0),this.div.onselectstart=OpenLayers.Function.False;if(""!=this.title)this.div.title=this.title}if(null!=a)this.position=a.clone();this.moveTo(this.position);return this.div},moveTo:function(a){if(null!=a&&null!=this.div)this.div.style.left=a.x+"px",this.div.style.top=
+a.y+"px"},activate:function(){if(this.active)return!1;this.handler&&this.handler.activate();this.active=!0;this.map&&OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");this.events.triggerEvent("activate");return!0},deactivate:function(){return this.active?(this.handler&&this.handler.deactivate(),this.active=!1,this.map&&OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active"),this.events.triggerEvent("deactivate"),
+!0):!1},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;
+OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:!1,handlers:null,resolutionFactor:1,maximized:!1,initialize:function(a){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[a])},destroy:function(){if(this.mapDiv){this.handlers.click&&this.handlers.click.destroy();this.handlers.drag&&
+this.handlers.drag.destroy();this.ovmap&&this.ovmap.eventsDiv.removeChild(this.extentRectangle);this.extentRectangle=null;if(this.rectEvents)this.rectEvents.destroy(),this.rectEvents=null;if(this.ovmap)this.ovmap.destroy(),this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv)OpenLayers.Event.stopObservingElement(this.maximizeDiv),this.div.removeChild(this.maximizeDiv),this.maximizeDiv=null;if(this.minimizeDiv)OpenLayers.Event.stopObservingElement(this.minimizeDiv),
+this.div.removeChild(this.minimizeDiv),this.minimizeDiv=null;this.map.events.un({moveend:this.update,changebaselayer:this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(0<this.layers.length))if(this.map.baseLayer)this.layers=[this.map.baseLayer.clone()];else return this.map.events.register("changebaselayer",this,this.baseLayerDraw),this.div;this.element=document.createElement("div");
+this.element.className=this.displayClass+"Element";this.element.style.display="none";this.mapDiv=document.createElement("div");this.mapDiv.style.width=this.size.w+"px";this.mapDiv.style.height=this.size.h+"px";this.mapDiv.style.position="relative";this.mapDiv.style.overflow="hidden";this.mapDiv.id=OpenLayers.Util.createUniqueID("overviewMap");this.extentRectangle=document.createElement("div");this.extentRectangle.style.position="absolute";this.extentRectangle.style.zIndex=1E3;this.extentRectangle.className=
+this.displayClass+"ExtentRectangle";this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(this.outsideViewport)this.element.style.display="";else{this.div.className+=" "+this.displayClass+"Container";var a=OpenLayers.Util.getImagesLocation();this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+"MaximizeButton",null,new OpenLayers.Size(18,18),a+"layer-switcher-maximize.png","absolute");this.maximizeDiv.style.display="none";this.maximizeDiv.className=this.displayClass+
+"MaximizeButton";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_minimizeDiv",null,new OpenLayers.Size(18,18),a+"layer-switcher-minimize.png","absolute");this.minimizeDiv.style.display="none";this.minimizeDiv.className=this.displayClass+"MinimizeButton";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,
+this));this.div.appendChild(this.minimizeDiv);for(var a=["dblclick","mousedown"],b=0,c=a.length;b<c;b++)OpenLayers.Event.observe(this.maximizeDiv,a[b],OpenLayers.Event.stop),OpenLayers.Event.observe(this.minimizeDiv,a[b],OpenLayers.Event.stop);this.minimizeControl()}this.map.getExtent()&&this.update();this.map.events.register("moveend",this,this.update);this.maximized&&this.maximizeControl();return this.div},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw)},
+rectDrag:function(a){var b=this.handlers.drag.last.x-a.x,c=this.handlers.drag.last.y-a.y;if(0!=b||0!=c){var d=this.rectPxBounds.top,e=this.rectPxBounds.left,a=Math.abs(this.rectPxBounds.getHeight()),f=this.rectPxBounds.getWidth(),c=Math.max(0,d-c),c=Math.min(c,this.ovmap.size.h-this.hComp-a),b=Math.max(0,e-b),b=Math.min(b,this.ovmap.size.w-this.wComp-f);this.setRectPxBounds(new OpenLayers.Bounds(b,c+a,b+f,c))}},mapDivClick:function(a){var b=this.rectPxBounds.getCenterPixel(),c=a.xy.x-b.x,d=a.xy.y-
+b.y,e=this.rectPxBounds.top,f=this.rectPxBounds.left,a=Math.abs(this.rectPxBounds.getHeight()),b=this.rectPxBounds.getWidth(),d=Math.max(0,e+d),d=Math.min(d,this.ovmap.size.h-a),c=Math.max(0,f+c),c=Math.min(c,this.ovmap.size.w-b);this.setRectPxBounds(new OpenLayers.Bounds(c,d+a,c+b,d));this.updateMapToRect()},maximizeControl:function(a){this.element.style.display="";this.showToggle(!1);null!=a&&OpenLayers.Event.stop(a)},minimizeControl:function(a){this.element.style.display="none";this.showToggle(!0);
+null!=a&&OpenLayers.Event.stop(a)},showToggle:function(a){this.maximizeDiv.style.display=a?"":"none";this.minimizeDiv.style.display=a?"none":""},update:function(){null==this.ovmap&&this.createMap();(this.autoPan||!this.isSuitableOverview())&&this.updateOverview();this.updateRectToMap()},isSuitableOverview:function(){var a=this.map.getExtent(),b=this.map.maxExtent,a=new OpenLayers.Bounds(Math.max(a.left,b.left),Math.max(a.bottom,b.bottom),Math.min(a.right,b.right),Math.min(a.top,b.top));this.ovmap.getProjection()!=
+this.map.getProjection()&&(a=a.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject()));b=this.ovmap.getResolution()/this.map.getResolution();return b>this.minRatio&&b<=this.maxRatio&&this.ovmap.getExtent().containsBounds(a)},updateOverview:function(){var a=this.map.getResolution(),b=this.ovmap.getResolution(),c=b/a;c>this.maxRatio?b=this.minRatio*a:c<=this.minRatio&&(b=this.maxRatio*a);this.ovmap.getProjection()!=this.map.getProjection()?(a=this.map.center.clone(),a.transform(this.map.getProjectionObject(),
+this.ovmap.getProjectionObject())):a=this.map.center;this.ovmap.setCenter(a,this.ovmap.getZoomForResolution(b*this.resolutionFactor));this.updateRectToMap()},createMap:function(){var a=OpenLayers.Util.extend({controls:[],maxResolution:"auto",fallThrough:!1},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,a);this.ovmap.eventsDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,"unload",this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();
+this.wComp=(this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-right-width")))?this.wComp:2;this.hComp=(this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-bottom-width")))?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});
+this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.mapDivClick},{single:!0,"double":!1,stopSingle:!0,stopDouble:!0,pixelTolerance:1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,!0);this.rectEvents.register("mouseover",this,function(){!this.handlers.drag.active&&!this.map.dragging&&this.handlers.drag.activate()});this.rectEvents.register("mouseout",this,function(){this.handlers.drag.dragging||this.handlers.drag.deactivate()});
+if(this.ovmap.getProjection()!=this.map.getProjection()){var a=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units,b=this.ovmap.getProjectionObject().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=a&&b?OpenLayers.INCHES_PER_UNIT[a]/OpenLayers.INCHES_PER_UNIT[b]:1}},updateRectToMap:function(){var a=this.getRectBoundsFromMapBounds(this.ovmap.getProjection()!=this.map.getProjection()?this.map.getExtent().transform(this.map.getProjectionObject(),
+this.ovmap.getProjectionObject()):this.map.getExtent());a&&this.setRectPxBounds(a)},updateMapToRect:function(){var a=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.ovmap.getProjection()!=this.map.getProjection()&&(a=a.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject()));this.map.panTo(a.getCenterLonLat())},setRectPxBounds:function(a){var b=Math.max(a.top,0),c=Math.max(a.left,0),d=Math.min(a.top+Math.abs(a.getHeight()),this.ovmap.size.h-this.hComp),a=Math.min(a.left+
+a.getWidth(),this.ovmap.size.w-this.wComp),e=Math.max(a-c,0),f=Math.max(d-b,0);e<this.minRectSize||f<this.minRectSize?(this.extentRectangle.className=this.displayClass+this.minRectDisplayClass,e=c+e/2-this.minRectSize/2,this.extentRectangle.style.top=Math.round(b+f/2-this.minRectSize/2)+"px",this.extentRectangle.style.left=Math.round(e)+"px",this.extentRectangle.style.height=this.minRectSize+"px",this.extentRectangle.style.width=this.minRectSize+"px"):(this.extentRectangle.className=this.displayClass+
+"ExtentRectangle",this.extentRectangle.style.top=Math.round(b)+"px",this.extentRectangle.style.left=Math.round(c)+"px",this.extentRectangle.style.height=Math.round(f)+"px",this.extentRectangle.style.width=Math.round(e)+"px");this.rectPxBounds=new OpenLayers.Bounds(Math.round(c),Math.round(d),Math.round(a),Math.round(b))},getRectBoundsFromMapBounds:function(a){var b=new OpenLayers.LonLat(a.left,a.bottom),a=new OpenLayers.LonLat(a.right,a.top),b=this.getOverviewPxFromLonLat(b),a=this.getOverviewPxFromLonLat(a),
+c=null;b&&a&&(c=new OpenLayers.Bounds(b.x,b.y,a.x,a.y));return c},getMapBoundsFromRectBounds:function(a){var b=new OpenLayers.Pixel(a.left,a.bottom),a=new OpenLayers.Pixel(a.right,a.top),b=this.getLonLatFromOverviewPx(b),a=this.getLonLatFromOverviewPx(a);return new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat)},getLonLatFromOverviewPx:function(a){var b=this.ovmap.size,c=this.ovmap.getResolution(),d=this.ovmap.getExtent().getCenterLonLat();return new OpenLayers.LonLat(d.lon+(a.x-b.w/2)*c,d.lat-(a.y-b.h/
+2)*c)},getOverviewPxFromLonLat:function(a){var b=this.ovmap.getResolution(),c=this.ovmap.getExtent(),d=null;c&&(d=new OpenLayers.Pixel(Math.round(1/b*(a.lon-c.left)),Math.round(1/b*(c.top-a.lat))));return d},CLASS_NAME:"OpenLayers.Control.OverviewMap"});
+OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:!1,initialize:function(a){this.easing=a?a:OpenLayers.Easing.Expo.easeOut},start:function(a,b,c,d){this.playing=!0;this.begin=a;this.finish=b;this.duration=c;this.callbacks=d.callbacks;this.time=0;if(this.interval)window.clearInterval(this.interval),this.interval=null;this.callbacks&&this.callbacks.start&&this.callbacks.start.call(this,this.begin);this.interval=
+window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL)},stop:function(){if(this.playing)this.callbacks&&this.callbacks.done&&this.callbacks.done.call(this,this.finish),window.clearInterval(this.interval),this.interval=null,this.playing=!1},play:function(){var a={},b;for(b in this.begin){var c=this.begin[b],d=this.finish[b];if(null==c||null==d||isNaN(c)||isNaN(d))throw new TypeError("invalid value for Tween");a[b]=this.easing.apply(this,[this.time,c,d-c,this.duration])}this.time++;
+this.callbacks&&this.callbacks.eachStep&&this.callbacks.eachStep.call(this,a);this.time>this.duration&&this.stop()},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(a,b,c,d){return c*a/d+b},easeOut:function(a,b,c,d){return c*a/d+b},easeInOut:function(a,b,c,d){return c*a/d+b},CLASS_NAME:"OpenLayers.Easing.Linear"};
+OpenLayers.Easing.Expo={easeIn:function(a,b,c,d){return 0==a?b:c*Math.pow(2,10*(a/d-1))+b},easeOut:function(a,b,c,d){return a==d?b+c:c*(-Math.pow(2,-10*a/d)+1)+b},easeInOut:function(a,b,c,d){return 0==a?b:a==d?b+c:1>(a/=d/2)?c/2*Math.pow(2,10*(a-1))+b:c/2*(-Math.pow(2,-10*--a)+2)+b},CLASS_NAME:"OpenLayers.Easing.Expo"};
+OpenLayers.Easing.Quad={easeIn:function(a,b,c,d){return c*(a/=d)*a+b},easeOut:function(a,b,c,d){return-c*(a/=d)*(a-2)+b},easeInOut:function(a,b,c,d){return 1>(a/=d/2)?c/2*a*a+b:-c/2*(--a*(a-2)-1)+b},CLASS_NAME:"OpenLayers.Easing.Quad"};
+OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1E3},id:null,fractionalZoom:!1,events:null,allOverlays:!1,div:null,dragging:!1,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,tileSize:null,projection:"EPSG:4326",units:"degrees",resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,
+minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:!0,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(a,b){1===arguments.length&&"object"===typeof a&&(a=(b=a)&&b.div);this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,
+15,15,15);this.theme=OpenLayers._getScriptLocation()+"theme/default/style.css";OpenLayers.Util.extend(this,b);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(a);if(!this.div)this.div=document.createElement("div"),this.div.style.height="1px",this.div.style.width="1px";OpenLayers.Element.addClass(this.div,"olMap");var c=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(c,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width=
+"100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);c=document.createElement("div");c.id=this.id+"_events";c.style.position="absolute";c.style.width="100%";c.style.height="100%";c.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(c);this.eventsDiv=c;this.events=new OpenLayers.Events(this,this.eventsDiv,null,this.fallThrough,{includeXY:!0});c=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(c);
+this.layerContainerDiv.style.width="100px";this.layerContainerDiv.style.height="100px";this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE.Popup-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);this.events.register("movestart",this,this.updateSize);OpenLayers.String.contains(navigator.appName,"Microsoft")?this.events.register("resize",this,this.updateSize):(this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,
+this),OpenLayers.Event.observe(window,"resize",this.updateSizeDestroy));if(this.theme){for(var c=!0,d=document.getElementsByTagName("link"),e=0,f=d.length;e<f;++e)if(OpenLayers.Util.isEquivalentUrl(d.item(e).href,this.theme)){c=!1;break}c&&(c=document.createElement("link"),c.setAttribute("rel","stylesheet"),c.setAttribute("type","text/css"),c.setAttribute("href",this.theme),document.getElementsByTagName("head")[0].appendChild(c))}if(null==this.controls)this.controls=null!=OpenLayers.Control?[new OpenLayers.Control.Navigation,
+new OpenLayers.Control.PanZoom,new OpenLayers.Control.ArgParser,new OpenLayers.Control.Attribution]:[];e=0;for(f=this.controls.length;e<f;e++)this.addControlToMap(this.controls[e]);this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,"unload",this.unloadDestroy);b&&b.layers&&(delete this.center,this.addLayers(b.layers),b.center&&this.setCenter(b.center,b.zoom))},render:function(a){this.div=OpenLayers.Util.getElement(a);OpenLayers.Element.addClass(this.div,
+"olMap");this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize()},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy)return!1;if(this.panTween)this.panTween.stop(),this.panTween=null;OpenLayers.Event.stopObserving(window,"unload",this.unloadDestroy);this.unloadDestroy=null;this.updateSizeDestroy?OpenLayers.Event.stopObserving(window,"resize",this.updateSizeDestroy):this.events.unregister("resize",this,this.updateSize);
+this.paddingForPopups=null;if(null!=this.controls){for(var a=this.controls.length-1;0<=a;--a)this.controls[a].destroy();this.controls=null}if(null!=this.layers){for(a=this.layers.length-1;0<=a;--a)this.layers[a].destroy(!1);this.layers=null}this.viewPortDiv&&this.div.removeChild(this.viewPortDiv);this.viewPortDiv=null;if(this.eventListeners)this.events.un(this.eventListeners),this.eventListeners=null;this.events.destroy();this.events=null},setOptions:function(a){var b=this.minPx&&a.restrictedExtent!=
+this.restrictedExtent;OpenLayers.Util.extend(this,a);b&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:!0})},getTileSize:function(){return this.tileSize},getBy:function(a,b,c){var d="function"==typeof c.test;return OpenLayers.Array.filter(this[a],function(a){return a[b]==c||d&&c.test(a[b])})},getLayersBy:function(a,b){return this.getBy("layers",a,b)},getLayersByName:function(a){return this.getLayersBy("name",a)},getLayersByClass:function(a){return this.getLayersBy("CLASS_NAME",a)},
+getControlsBy:function(a,b){return this.getBy("controls",a,b)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},getLayer:function(a){for(var b=null,c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.id==a){b=e;break}}return b},setLayerZIndex:function(a,b){a.setZIndex(this.Z_INDEX_BASE[a.isBaseLayer?"BaseLayer":"Overlay"]+5*b)},resetLayersZIndex:function(){for(var a=0,b=this.layers.length;a<b;a++)this.setLayerZIndex(this.layers[a],a)},addLayer:function(a){for(var b=
+0,c=this.layers.length;b<c;b++)if(this.layers[b]==a)throw Error("You tried to add the layer: "+a.name+" to the map, but it has already been added");if(!1!==this.events.triggerEvent("preaddlayer",{layer:a})){if(this.allOverlays)a.isBaseLayer=!1;a.div.className="olLayerDiv";a.div.style.overflow="";this.setLayerZIndex(a,this.layers.length);a.isFixed?this.viewPortDiv.appendChild(a.div):this.layerContainerDiv.appendChild(a.div);this.layers.push(a);a.setMap(this);a.isBaseLayer||this.allOverlays&&!this.baseLayer?
+null==this.baseLayer?this.setBaseLayer(a):a.setVisibility(!1):a.redraw();this.events.triggerEvent("addlayer",{layer:a});a.events.triggerEvent("added",{map:this,layer:a});a.afterAdd()}},addLayers:function(a){for(var b=0,c=a.length;b<c;b++)this.addLayer(a[b])},removeLayer:function(a,b){if(!1!==this.events.triggerEvent("preremovelayer",{layer:a})){null==b&&(b=!0);a.isFixed?this.viewPortDiv.removeChild(a.div):this.layerContainerDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.layers,a);a.removeMap(this);
+a.map=null;if(this.baseLayer==a&&(this.baseLayer=null,b))for(var c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.isBaseLayer||this.allOverlays){this.setBaseLayer(e);break}}this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:a});a.events.triggerEvent("removed",{map:this,layer:a})}},getNumLayers:function(){return this.layers.length},getLayerIndex:function(a){return OpenLayers.Util.indexOf(this.layers,a)},setLayerIndex:function(a,b){var c=this.getLayerIndex(a);if(0>b)b=
+0;else if(b>this.layers.length)b=this.layers.length;if(c!=b){this.layers.splice(c,1);this.layers.splice(b,0,a);for(var c=0,d=this.layers.length;c<d;c++)this.setLayerZIndex(this.layers[c],c);this.events.triggerEvent("changelayer",{layer:a,property:"order"});this.allOverlays&&(0===b?this.setBaseLayer(a):this.baseLayer!==this.layers[0]&&this.setBaseLayer(this.layers[0]))}},raiseLayer:function(a,b){var c=this.getLayerIndex(a)+b;this.setLayerIndex(a,c)},setBaseLayer:function(a){if(a!=this.baseLayer&&-1!=
+OpenLayers.Util.indexOf(this.layers,a)){var b=this.getCachedCenter(),c=OpenLayers.Util.getResolutionFromScale(this.getScale(),a.units);null!=this.baseLayer&&!this.allOverlays&&this.baseLayer.setVisibility(!1);this.baseLayer=a;(!this.allOverlays||this.baseLayer.visibility)&&this.baseLayer.setVisibility(!0);null!=b&&(a=this.getZoomForResolution(c||this.resolution,!0),this.setCenter(b,a,!1,!0));this.events.triggerEvent("changebaselayer",{layer:this.baseLayer})}},addControl:function(a,b){this.controls.push(a);
+this.addControlToMap(a,b)},addControls:function(a,b){for(var c=1===arguments.length?[]:b,d=0,e=a.length;d<e;d++)this.addControl(a[d],c[d]?c[d]:null)},addControlToMap:function(a,b){a.outsideViewport=null!=a.div;if(this.displayProjection&&!a.displayProjection)a.displayProjection=this.displayProjection;a.setMap(this);var c=a.draw(b);if(c&&!a.outsideViewport)c.style.zIndex=this.Z_INDEX_BASE.Control+this.controls.length,this.viewPortDiv.appendChild(c);a.autoActivate&&a.activate()},getControl:function(a){for(var b=
+null,c=0,d=this.controls.length;c<d;c++){var e=this.controls[c];if(e.id==a){b=e;break}}return b},removeControl:function(a){a&&a==this.getControl(a.id)&&(a.div&&a.div.parentNode==this.viewPortDiv&&this.viewPortDiv.removeChild(a.div),OpenLayers.Util.removeItem(this.controls,a))},addPopup:function(a,b){if(b)for(var c=this.popups.length-1;0<=c;--c)this.removePopup(this.popups[c]);a.map=this;this.popups.push(a);if(c=a.draw())c.style.zIndex=this.Z_INDEX_BASE.Popup+this.popups.length,this.layerContainerDiv.appendChild(c)},
+removePopup:function(a){OpenLayers.Util.removeItem(this.popups,a);if(a.div)try{this.layerContainerDiv.removeChild(a.div)}catch(b){}a.map=null},getSize:function(){var a=null;null!=this.size&&(a=this.size.clone());return a},updateSize:function(){var a=this.getCurrentSize();if(a&&!isNaN(a.h)&&!isNaN(a.w)){this.events.clearMouseCache();var b=this.getSize();if(null==b)this.size=b=a;if(!a.equals(b)){this.size=a;a=0;for(b=this.layers.length;a<b;a++)this.layers[a].onMapResize();a=this.getCachedCenter();if(null!=
+this.baseLayer&&null!=a)b=this.getZoom(),this.zoom=null,this.setCenter(a,b)}}},getCurrentSize:function(){var a=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(0==a.w&&0==a.h||isNaN(a.w)&&isNaN(a.h))a.w=this.div.offsetWidth,a.h=this.div.offsetHeight;if(0==a.w&&0==a.h||isNaN(a.w)&&isNaN(a.h))a.w=parseInt(this.div.style.width),a.h=parseInt(this.div.style.height);return a},calculateBounds:function(a,b){var c=null;null==a&&(a=this.getCachedCenter());null==b&&(b=this.getResolution());
+if(null!=a&&null!=b)var d=this.getSize(),c=d.w*b,d=d.h*b,c=new OpenLayers.Bounds(a.lon-c/2,a.lat-d/2,a.lon+c/2,a.lat+d/2);return c},getCenter:function(){var a=null,b=this.getCachedCenter();b&&(a=b.clone());return a},getCachedCenter:function(){if(!this.center&&this.size)this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));return this.center},getZoom:function(){return this.zoom},pan:function(a,b,c){c=OpenLayers.Util.applyDefaults(c,{animate:!0,dragging:!1});if(c.dragging)(0!=
+a||0!=b)&&this.moveByPx(a,b);else{var d=this.getViewPortPxFromLonLat(this.getCachedCenter()),a=d.add(a,b);if(this.dragging||!a.equals(d))d=this.getLonLatFromViewPortPx(a),c.animate?this.panTo(d):(this.moveTo(d),this.dragging=!1,this.events.triggerEvent("moveend"))}},panTo:function(a){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(a)){if(!this.panTween)this.panTween=new OpenLayers.Tween(this.panMethod);var b=this.getCachedCenter();if(!a.equals(b)){var b=this.getPixelFromLonLat(b),
+c=this.getPixelFromLonLat(a),d=0,e=0;this.panTween.start({x:0,y:0},{x:c.x-b.x,y:c.y-b.y},this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(a){this.moveByPx(a.x-d,a.y-e);d=Math.round(a.x);e=Math.round(a.y)},this),done:OpenLayers.Function.bind(function(){this.moveTo(a);this.dragging=!1;this.events.triggerEvent("moveend")},this)}})}}else this.setCenter(a)},setCenter:function(a,b,c,d){this.panTween&&this.panTween.stop();this.moveTo(a,b,{dragging:c,forceZoomChange:d})},moveByPx:function(a,
+b){var c=this.size.w/2,d=this.size.h/2,e=c+a,f=d+b,g=this.baseLayer.wrapDateLine,h=0,i=0;this.restrictedExtent&&(h=c,i=d,g=!1);a=g||e<=this.maxPx.x-h&&e>=this.minPx.x+h?Math.round(a):0;b=f<=this.maxPx.y-i&&f>=this.minPx.y+i?Math.round(b):0;if(a||b){if(!this.dragging)this.dragging=!0,this.events.triggerEvent("movestart");this.center=null;if(a)this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-a+"px",this.minPx.x-=a,this.maxPx.x-=a;if(b)this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-
+b+"px",this.minPx.y-=b,this.maxPx.y-=b;for(d=0,e=this.layers.length;d<e;++d)if(c=this.layers[d],c.visibility&&(c===this.baseLayer||c.inRange))c.moveByPx(a,b),c.events.triggerEvent("move");this.events.triggerEvent("move")}},moveTo:function(a,b,c){c||(c={});null!=b&&(b=parseFloat(b),this.fractionalZoom||(b=Math.round(b)));var d=c.dragging||this.dragging,e=c.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(a))a=this.maxExtent.getCenterLonLat(),this.center=a.clone();if(null!=this.restrictedExtent){if(null==
+a)a=this.center;null==b&&(b=this.getZoom());var f=this.getResolutionForZoom(b),f=this.calculateBounds(a,f);if(!this.restrictedExtent.containsBounds(f)){var g=this.restrictedExtent.getCenterLonLat();f.getWidth()>this.restrictedExtent.getWidth()?a=new OpenLayers.LonLat(g.lon,a.lat):f.left<this.restrictedExtent.left?a=a.add(this.restrictedExtent.left-f.left,0):f.right>this.restrictedExtent.right&&(a=a.add(this.restrictedExtent.right-f.right,0));f.getHeight()>this.restrictedExtent.getHeight()?a=new OpenLayers.LonLat(a.lon,
+g.lat):f.bottom<this.restrictedExtent.bottom?a=a.add(0,this.restrictedExtent.bottom-f.bottom):f.top>this.restrictedExtent.top&&(a=a.add(0,this.restrictedExtent.top-f.top))}}e=e||this.isValidZoomLevel(b)&&b!=this.getZoom();f=this.isValidLonLat(a)&&!a.equals(this.center);if(e||f||d){d||this.events.triggerEvent("movestart");if(f)!e&&this.center&&this.centerLayerContainer(a),this.center=a.clone();a=e?this.getResolutionForZoom(b):this.getResolution();if(e||null==this.layerContainerOrigin){this.layerContainerOrigin=
+this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var h=this.getMaxExtent({restricted:!0}),f=h.getCenterLonLat(),g=this.center.lon-f.lon,i=f.lat-this.center.lat,f=Math.round(h.getWidth()/a),h=Math.round(h.getHeight()/a),g=(this.size.w-f)/2-g/a,i=(this.size.h-h)/2-i/a;this.minPx=new OpenLayers.Pixel(g,i);this.maxPx=new OpenLayers.Pixel(g+f,i+h)}if(e)this.zoom=b,this.resolution=a;a=this.getExtent();this.baseLayer.visibility&&(this.baseLayer.moveTo(a,
+e,c.dragging),c.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:e}));a=this.baseLayer.getExtent();for(b=this.layers.length-1;0<=b;--b)if(f=this.layers[b],f!==this.baseLayer&&!f.isBaseLayer){g=f.calculateInRange();if(f.inRange!=g)(f.inRange=g)||f.display(!1),this.events.triggerEvent("changelayer",{layer:f,property:"visibility"});g&&f.visibility&&(f.moveTo(a,e,c.dragging),c.dragging||f.events.triggerEvent("moveend",{zoomChanged:e}))}this.events.triggerEvent("move");d||this.events.triggerEvent("moveend");
+if(e){b=0;for(c=this.popups.length;b<c;b++)this.popups[b].updatePosition();this.events.triggerEvent("zoomend")}}},centerLayerContainer:function(a){var b=this.getViewPortPxFromLonLat(this.layerContainerOrigin),c=this.getViewPortPxFromLonLat(a);if(null!=b&&null!=c){var d=parseInt(this.layerContainerDiv.style.left),a=parseInt(this.layerContainerDiv.style.top),e=Math.round(b.x-c.x),b=Math.round(b.y-c.y);this.layerContainerDiv.style.left=e+"px";this.layerContainerDiv.style.top=b+"px";d-=e;a-=b;this.minPx.x-=
+d;this.maxPx.x-=d;this.minPx.y-=a;this.maxPx.y-=a}},isValidZoomLevel:function(a){return null!=a&&0<=a&&a<this.getNumZoomLevels()},isValidLonLat:function(a){var b=!1;null!=a&&(b=this.getMaxExtent(),b=b.containsLonLat(a,{worldBounds:this.baseLayer.wrapDateLine&&b}));return b},getProjection:function(){var a=this.getProjectionObject();return a?a.getCode():null},getProjectionObject:function(){var a=null;if(null!=this.baseLayer)a=this.baseLayer.projection;return a},getMaxResolution:function(){var a=null;
+if(null!=this.baseLayer)a=this.baseLayer.maxResolution;return a},getMaxExtent:function(a){var b=null;if(a&&a.restricted&&this.restrictedExtent)b=this.restrictedExtent;else if(null!=this.baseLayer)b=this.baseLayer.maxExtent;return b},getNumZoomLevels:function(){var a=null;if(null!=this.baseLayer)a=this.baseLayer.numZoomLevels;return a},getExtent:function(){var a=null;null!=this.baseLayer&&(a=this.baseLayer.getExtent());return a},getResolution:function(){var a=null;null!=this.baseLayer?a=this.baseLayer.getResolution():
+!0===this.allOverlays&&0<this.layers.length&&(a=this.layers[0].getResolution());return a},getUnits:function(){var a=null;if(null!=this.baseLayer)a=this.baseLayer.units;return a},getScale:function(){var a=null;null!=this.baseLayer&&(a=this.getResolution(),a=OpenLayers.Util.getScaleFromResolution(a,this.baseLayer.units));return a},getZoomForExtent:function(a,b){var c=null;null!=this.baseLayer&&(c=this.baseLayer.getZoomForExtent(a,b));return c},getResolutionForZoom:function(a){var b=null;this.baseLayer&&
+(b=this.baseLayer.getResolutionForZoom(a));return b},getZoomForResolution:function(a,b){var c=null;null!=this.baseLayer&&(c=this.baseLayer.getZoomForResolution(a,b));return c},zoomTo:function(a){this.isValidZoomLevel(a)&&this.setCenter(null,a)},zoomIn:function(){this.zoomTo(this.getZoom()+1)},zoomOut:function(){this.zoomTo(this.getZoom()-1)},zoomToExtent:function(a,b){var c=a.getCenterLonLat();if(this.baseLayer.wrapDateLine){c=this.getMaxExtent();for(a=a.clone();a.right<a.left;)a.right+=c.getWidth();
+c=a.getCenterLonLat().wrapDateLine(c)}this.setCenter(c,this.getZoomForExtent(a,b))},zoomToMaxExtent:function(a){this.zoomToExtent(this.getMaxExtent({restricted:a?a.restricted:!0}))},zoomToScale:function(a,b){var c=OpenLayers.Util.getResolutionFromScale(a,this.baseLayer.units),d=this.getSize(),e=d.w*c,c=d.h*c,d=this.getCachedCenter();this.zoomToExtent(new OpenLayers.Bounds(d.lon-e/2,d.lat-c/2,d.lon+e/2,d.lat+c/2),b)},getLonLatFromViewPortPx:function(a){var b=null;null!=this.baseLayer&&(b=this.baseLayer.getLonLatFromViewPortPx(a));
+return b},getViewPortPxFromLonLat:function(a){var b=null;null!=this.baseLayer&&(b=this.baseLayer.getViewPortPxFromLonLat(a));return b},getLonLatFromPixel:function(a){return this.getLonLatFromViewPortPx(a)},getPixelFromLonLat:function(a){a=this.getViewPortPxFromLonLat(a);a.x=Math.round(a.x);a.y=Math.round(a.y);return a},getGeodesicPixelSize:function(a){var b=a?this.getLonLatFromPixel(a):this.getCachedCenter()||new OpenLayers.LonLat(0,0),c=this.getResolution(),a=b.add(-c/2,0),d=b.add(c/2,0),e=b.add(0,
+-c/2),b=b.add(0,c/2),c=new OpenLayers.Projection("EPSG:4326"),f=this.getProjectionObject()||c;f.equals(c)||(a.transform(f,c),d.transform(f,c),e.transform(f,c),b.transform(f,c));return new OpenLayers.Size(OpenLayers.Util.distVincenty(a,d),OpenLayers.Util.distVincenty(e,b))},getViewPortPxFromLayerPx:function(a){var b=null;if(null!=a)var b=parseInt(this.layerContainerDiv.style.left),c=parseInt(this.layerContainerDiv.style.top),b=a.add(b,c);return b},getLayerPxFromViewPortPx:function(a){var b=null;if(null!=
+a){var b=-parseInt(this.layerContainerDiv.style.left),c=-parseInt(this.layerContainerDiv.style.top),b=a.add(b,c);if(isNaN(b.x)||isNaN(b.y))b=null}return b},getLonLatFromLayerPx:function(a){a=this.getViewPortPxFromLayerPx(a);return this.getLonLatFromViewPortPx(a)},getLayerPxFromLonLat:function(a){return this.getLayerPxFromViewPortPx(this.getPixelFromLonLat(a))},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;
+OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:"scales,resolutions,maxScale,minScale,maxResolution,minResolution,numZoomLevels,maxZoomLevel".split(","),events:null,map:null,isBaseLayer:!1,alpha:!1,displayInLayerSwitcher:!0,visibility:!0,attribution:null,inRange:!1,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,
+minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:!1,wrapDateLine:!1,transitionEffect:null,metadata:{},initialize:function(a,b){this.addOptions(b);this.name=a;if(null==this.id&&(this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_"),this.div=OpenLayers.Util.createDiv(this.id),this.div.style.width="100%",this.div.style.height="100%",this.div.dir="ltr",this.events=new OpenLayers.Events(this,this.div),this.eventListeners instanceof Object))this.events.on(this.eventListeners);
+if(this.wrapDateLine)this.displayOutsideMaxExtent=!0},destroy:function(a){null==a&&(a=!0);null!=this.map&&this.map.removeLayer(this,a);this.options=this.div=this.name=this.map=this.projection=null;this.events&&(this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy());this.events=this.eventListeners=null},clone:function(a){null==a&&(a=new OpenLayers.Layer(this.name,this.getOptions()));OpenLayers.Util.applyDefaults(a,this);a.map=null;return a},getOptions:function(){var a={},b;
+for(b in this.options)a[b]=this[b];return a},setName:function(a){if(a!=this.name)this.name=a,null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"name"})},addOptions:function(a,b){if(null==this.options)this.options={};OpenLayers.Util.extend(this.options,a);OpenLayers.Util.extend(this,a);if("string"==typeof this.projection)this.projection=new OpenLayers.Projection(this.projection);if(this.projection&&this.projection.getUnits())this.units=this.projection.getUnits();if(this.map){var c=
+this.map.getResolution(),d=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]),e;for(e in a)if(a.hasOwnProperty(e)&&0<=OpenLayers.Util.indexOf(d,e)){this.initResolutions();b&&this.map.baseLayer===this&&(this.map.setCenter(this.map.getCenter(),this.map.getZoomForResolution(c),!1,!0),this.map.events.triggerEvent("changebaselayer",{layer:this}));break}}},onMapResize:function(){},redraw:function(){var a=!1;if(this.map){this.inRange=this.calculateInRange();var b=this.getExtent();
+b&&this.inRange&&this.visibility&&(this.moveTo(b,!0,!1),this.events.triggerEvent("moveend",{zoomChanged:!0}),a=!0)}return a},moveTo:function(){var a=this.visibility;this.isBaseLayer||(a=a&&this.inRange);this.display(a)},moveByPx:function(){},setMap:function(a){if(null==this.map){this.map=a;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if("string"==typeof this.projection)this.projection=new OpenLayers.Projection(this.projection);
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer)this.inRange=this.calculateInRange(),this.div.style.display=this.visibility&&this.inRange?"":"none";this.setTileSize()}},afterAdd:function(){},removeMap:function(){},getImageSize:function(){return this.imageSize||this.tileSize},setTileSize:function(a){this.tileSize=a=a?a:this.tileSize?this.tileSize:this.map.getTileSize();if(this.gutter)this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter),
+this.imageSize=new OpenLayers.Size(a.w+2*this.gutter,a.h+2*this.gutter)},getVisibility:function(){return this.visibility},setVisibility:function(a){if(a!=this.visibility)this.visibility=a,this.display(a),this.redraw(),null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"}),this.events.triggerEvent("visibilitychanged")},display:function(a){if(a!=("none"!=this.div.style.display))this.div.style.display=a&&this.calculateInRange()?"block":"none"},calculateInRange:function(){var a=
+!1;this.alwaysInRange?a=!0:this.map&&(a=this.map.getResolution(),a=a>=this.minResolution&&a<=this.maxResolution);return a},setIsBaseLayer:function(a){if(a!=this.isBaseLayer)this.isBaseLayer=a,null!=this.map&&this.map.events.triggerEvent("changebaselayer",{layer:this})},initResolutions:function(){var a,b,c,d={},e=!0;for(a=0,b=this.RESOLUTION_PROPERTIES.length;a<b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=this.options[c],e&&this.options[c]&&(e=!1);if(null==this.alwaysInRange)this.alwaysInRange=e;if(null==
+d.resolutions)d.resolutions=this.resolutionsFromScales(d.scales);if(null==d.resolutions)d.resolutions=this.calculateResolutions(d);if(null==d.resolutions){for(a=0,b=this.RESOLUTION_PROPERTIES.length;a<b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=null!=this.options[c]?this.options[c]:this.map[c];if(null==d.resolutions)d.resolutions=this.resolutionsFromScales(d.scales);if(null==d.resolutions)d.resolutions=this.calculateResolutions(d)}var f;if(this.options.maxResolution&&"auto"!==this.options.maxResolution)f=
+this.options.maxResolution;this.options.minScale&&(f=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units));var g;if(this.options.minResolution&&"auto"!==this.options.minResolution)g=this.options.minResolution;this.options.maxScale&&(g=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units));d.resolutions&&(d.resolutions.sort(function(a,b){return b-a}),f||(f=d.resolutions[0]),g||(g=d.resolutions[d.resolutions.length-1]));if(this.resolutions=d.resolutions){b=this.resolutions.length;
+this.scales=Array(b);for(a=0;a<b;a++)this.scales[a]=OpenLayers.Util.getScaleFromResolution(this.resolutions[a],this.units);this.numZoomLevels=b}if(this.minResolution=g)this.maxScale=OpenLayers.Util.getScaleFromResolution(g,this.units);if(this.maxResolution=f)this.minScale=OpenLayers.Util.getScaleFromResolution(f,this.units)},resolutionsFromScales:function(a){if(null!=a){var b,c,d;d=a.length;b=Array(d);for(c=0;c<d;c++)b[c]=OpenLayers.Util.getResolutionFromScale(a[c],this.units);return b}},calculateResolutions:function(a){var b,
+c,d=a.maxResolution;null!=a.minScale?d=OpenLayers.Util.getResolutionFromScale(a.minScale,this.units):"auto"==d&&null!=this.maxExtent&&(b=this.map.getSize(),c=this.maxExtent.getWidth()/b.w,b=this.maxExtent.getHeight()/b.h,d=Math.max(c,b));c=a.minResolution;null!=a.maxScale?c=OpenLayers.Util.getResolutionFromScale(a.maxScale,this.units):"auto"==a.minResolution&&null!=this.minExtent&&(b=this.map.getSize(),c=this.minExtent.getWidth()/b.w,b=this.minExtent.getHeight()/b.h,c=Math.max(c,b));b=a.maxZoomLevel;
+a=a.numZoomLevels;"number"===typeof c&&"number"===typeof d&&void 0===a?a=Math.floor(Math.log(d/c)/Math.log(2))+1:void 0===a&&null!=b&&(a=b+1);if(!("number"!==typeof a||0>=a||"number"!==typeof d&&"number"!==typeof c)){b=Array(a);var e=2;"number"==typeof c&&"number"==typeof d&&(e=Math.pow(d/c,1/(a-1)));var f;if("number"===typeof d)for(f=0;f<a;f++)b[f]=d/Math.pow(e,f);else for(f=0;f<a;f++)b[a-1-f]=c*Math.pow(e,f);return b}},getResolution:function(){return this.getResolutionForZoom(this.map.getZoom())},
+getExtent:function(){return this.map.calculateBounds()},getZoomForExtent:function(a,b){var c=this.map.getSize();return this.getZoomForResolution(Math.max(a.getWidth()/c.w,a.getHeight()/c.h),b)},getDataExtent:function(){},getResolutionForZoom:function(a){a=Math.max(0,Math.min(a,this.resolutions.length-1));if(this.map.fractionalZoom)var b=Math.floor(a),c=Math.ceil(a),a=this.resolutions[b]-(a-b)*(this.resolutions[b]-this.resolutions[c]);else a=this.resolutions[Math.round(a)];return a},getZoomForResolution:function(a,
+b){var c,d;if(this.map.fractionalZoom){var e=0,f=this.resolutions[e],g=this.resolutions[this.resolutions.length-1],h;for(c=0,d=this.resolutions.length;c<d;++c)if(h=this.resolutions[c],h>=a&&(f=h,e=c),h<=a){g=h;break}c=f-g;c=0<c?e+(f-a)/c:e}else{f=Number.POSITIVE_INFINITY;for(c=0,d=this.resolutions.length;c<d;c++)if(b){e=Math.abs(this.resolutions[c]-a);if(e>f)break;f=e}else if(this.resolutions[c]<a)break;c=Math.max(0,c-1)}return c},getLonLatFromViewPortPx:function(a){var b=null,c=this.map;if(null!=
+a&&c.minPx){var b=c.getResolution(),d=c.getMaxExtent({restricted:!0}),b=new OpenLayers.LonLat((a.x-c.minPx.x)*b+d.left,(c.minPx.y-a.y)*b+d.top);this.wrapDateLine&&(b=b.wrapDateLine(this.maxExtent))}return b},getViewPortPxFromLonLat:function(a,b){var c=null;null!=a&&(b=b||this.map.getResolution(),c=this.map.calculateBounds(null,b),c=new OpenLayers.Pixel(1/b*(a.lon-c.left),1/b*(c.top-a.lat)));return c},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;for(var b=0,c=this.div.childNodes.length;b<
+c;++b)OpenLayers.Util.modifyDOMElement(this.div.childNodes[b].firstChild,null,null,null,null,null,null,a);null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"})}},getZIndex:function(){return this.div.style.zIndex},setZIndex:function(a){this.div.style.zIndex=a},adjustBounds:function(a){if(this.gutter)var b=this.gutter*this.map.getResolution(),a=new OpenLayers.Bounds(a.left-b,a.bottom-b,a.right+b,a.top+b);this.wrapDateLine&&(b={rightTolerance:this.getResolution(),
+leftTolerance:this.getResolution()},a=a.wrapDateLine(this.maxExtent,b));return a},CLASS_NAME:"OpenLayers.Layer"});
+OpenLayers.Layer.SphericalMercator={getExtent:function(){var a=null;return a=this.sphericalMercator?this.map.calculateBounds():OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this)},getLonLatFromViewPortPx:function(a){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments)},getViewPortPxFromLonLat:function(a){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments)},initMercatorParameters:function(){this.RESOLUTIONS=[];for(var a=0;a<=this.MAX_ZOOM_LEVEL;++a)this.RESOLUTIONS[a]=
+156543.03390625/Math.pow(2,a);this.units="m";this.projection=this.projection||"EPSG:900913"},forwardMercator:function(a,b){var c=2.003750834E7*a/180,d=Math.log(Math.tan((90+b)*Math.PI/360))/(Math.PI/180);return new OpenLayers.LonLat(c,2.003750834E7*d/180)},inverseMercator:function(a,b){var c=180*(a/2.003750834E7),d;d=180/Math.PI*(2*Math.atan(Math.exp(180*(b/2.003750834E7)*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(c,d)},projectForward:function(a){var b=OpenLayers.Layer.SphericalMercator.forwardMercator(a.x,
+a.y);a.x=b.lon;a.y=b.lat;return a},projectInverse:function(a){var b=OpenLayers.Layer.SphericalMercator.inverseMercator(a.x,a.y);a.x=b.lon;a.y=b.lat;return a}};(function(){var a=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"],b=OpenLayers.Projection.addTransform,c=OpenLayers.Layer.SphericalMercator,d=OpenLayers.Projection.nullTransform,e,f,g,h,i;for(e=0,f=a.length;e<f;++e){g=a[e];b("EPSG:4326",g,c.projectForward);b(g,"EPSG:4326",c.projectInverse);for(i=e+1;i<f;++i)h=a[i],b(g,h,d),b(h,g,d)}})();
+OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:!0,isBaseLayer:!0,isFixed:!0,pane:null,mapObject:null,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(null==this.pane)this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane")},destroy:function(){this.pane=this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=
+parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if("msie"==OpenLayers.BROWSER_NAME)this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";this.isFixed?this.map.eventsDiv.appendChild(this.pane):this.map.layerContainerDiv.appendChild(this.pane);this.loadMapObject();null==this.mapObject&&this.loadWarningMessage()},removeMap:function(a){this.pane&&this.pane.parentNode&&this.pane.parentNode.removeChild(this.pane);
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments)},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var a=this.map.getSize(),b=Math.min(a.w,300),c=Math.min(a.h,200),b=new OpenLayers.Size(b,c),a=(new OpenLayers.Pixel(a.w/2,a.h/2)).add(-b.w/2,-b.h/2),a=OpenLayers.Util.createDiv(this.name+"_warning",a,b,null,null,null,"auto");a.style.padding="7px";a.style.backgroundColor="yellow";a.innerHTML=this.getWarningHTML();this.div.appendChild(a)},getWarningHTML:function(){return""},
+display:function(a){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display},setZIndex:function(a){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1},moveByPx:function(a,b){OpenLayers.Layer.prototype.moveByPx.apply(this,arguments);this.dragPanMapObject?this.dragPanMapObject(a,-b):this.moveTo(this.map.getCachedCenter())},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,
+arguments);if(null!=this.mapObject){var d=this.map.getCenter(),e=this.map.getZoom();if(null!=d){var f=this.getOLLonLatFromMapObjectLonLat(this.getMapObjectCenter()),g=this.getOLZoomFromMapObjectZoom(this.getMapObjectZoom());if(!d.equals(f)||e!=g)!b&&f&&this.dragPanMapObject&&this.smoothDragPan?(e=this.map.getViewPortPxFromLonLat(f),d=this.map.getViewPortPxFromLonLat(d),this.dragPanMapObject(d.x-e.x,e.y-d.y)):(d=this.getMapObjectLonLatFromOLLonLat(d),e=this.getMapObjectZoomFromOLZoom(e),this.setMapObjectCenter(d,
+e,c))}}},getLonLatFromViewPortPx:function(a){var b=null;null!=this.mapObject&&null!=this.getMapObjectCenter()&&(b=this.getOLLonLatFromMapObjectLonLat(this.getMapObjectLonLatFromMapObjectPixel(this.getMapObjectPixelFromOLPixel(a))));return b},getViewPortPxFromLonLat:function(a){var b=null;null!=this.mapObject&&null!=this.getMapObjectCenter()&&(b=this.getOLPixelFromMapObjectPixel(this.getMapObjectPixelFromMapObjectLonLat(this.getMapObjectLonLatFromOLLonLat(a))));return b},getOLLonLatFromMapObjectLonLat:function(a){var b=
+null;null!=a&&(b=this.getLongitudeFromMapObjectLonLat(a),a=this.getLatitudeFromMapObjectLonLat(a),b=new OpenLayers.LonLat(b,a));return b},getMapObjectLonLatFromOLLonLat:function(a){var b=null;null!=a&&(b=this.getMapObjectLonLatFromLonLat(a.lon,a.lat));return b},getOLPixelFromMapObjectPixel:function(a){var b=null;null!=a&&(b=this.getXFromMapObjectPixel(a),a=this.getYFromMapObjectPixel(a),b=new OpenLayers.Pixel(b,a));return b},getMapObjectPixelFromOLPixel:function(a){var b=null;null!=a&&(b=this.getMapObjectPixelFromXY(a.x,
+a.y));return b},CLASS_NAME:"OpenLayers.Layer.EventPane"});
+OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){for(var a=["minZoomLevel","maxZoomLevel","numZoomLevels"],b=0,c=a.length;b<c;b++){var d=a[b];this[d]=null!=this.options[d]?this.options[d]:this.map[d]}if(null==this.minZoomLevel||this.minZoomLevel<this.MIN_ZOOM_LEVEL)this.minZoomLevel=this.MIN_ZOOM_LEVEL;a=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;b=null==this.options.numZoomLevels&&null!=this.options.maxZoomLevel||null==this.numZoomLevels&&null!=this.maxZoomLevel?
+this.maxZoomLevel-this.minZoomLevel+1:this.numZoomLevels;this.numZoomLevels=null!=b?Math.min(b,a):a;this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(null!=this.RESOLUTIONS){a=0;this.resolutions=[];for(b=this.minZoomLevel;b<=this.maxZoomLevel;b++)this.resolutions[a++]=this.RESOLUTIONS[b];this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1]}},getResolution:function(){if(null!=this.resolutions)return OpenLayers.Layer.prototype.getResolution.apply(this,
+arguments);var a=null,b=this.map.getSize(),c=this.getExtent();null!=b&&null!=c&&(a=Math.max(c.getWidth()/b.w,c.getHeight()/b.h));return a},getExtent:function(){var a=null,b=this.map.getSize(),c=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(0,0)),b=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(b.w,b.h));null!=c&&null!=b&&(a=new OpenLayers.Bounds(c.lon,b.lat,b.lon,c.lat));return a},getZoomForResolution:function(a){return null!=this.resolutions?OpenLayers.Layer.prototype.getZoomForResolution.apply(this,
+arguments):this.getZoomForExtent(OpenLayers.Layer.prototype.getExtent.apply(this,[]))},getOLZoomFromMapObjectZoom:function(a){var b=null;null!=a&&(b=a-this.minZoomLevel,this.map.baseLayer!==this&&(b=this.map.baseLayer.getZoomForResolution(this.getResolutionForZoom(b))));return b},getMapObjectZoomFromOLZoom:function(a){var b=null;null!=a&&(b=a+this.minZoomLevel,this.map.baseLayer!==this&&(b=this.getZoomForResolution(this.map.baseLayer.getResolutionForZoom(b))));return b},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});
+OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.145767211914062E-5,1.072883605957031E-5,5.36441802978515E-6,2.68220901489257E-6,1.341104507446289E-6,6.705522537231445E-7],
+type:null,wrapDateLine:!0,sphericalMercator:!1,version:null,initialize:function(a,b){b=b||{};if(!b.version)b.version="function"===typeof GMap2?"2":"3";var c=OpenLayers.Layer.Google["v"+b.version.replace(/\./g,"_")];if(c)OpenLayers.Util.applyDefaults(b,c);else throw"Unsupported Google Maps API version: "+b.version;OpenLayers.Util.applyDefaults(b,c.DEFAULTS);if(b.maxExtent)b.maxExtent=b.maxExtent.clone();OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[a,b]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,
+[a,b]);this.sphericalMercator&&(OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator),this.initMercatorParameters())},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions())},setVisibility:function(a){var b=null==this.opacity?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(b)},display:function(a){this._dragging||this.setGMapVisibility(a);OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments)},moveTo:function(a,
+b,c){this._dragging=c;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging},setOpacity:function(a){if(a!==this.opacity)null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"}),this.opacity=a;if(this.getVisibility()){var b=this.getMapContainer();OpenLayers.Util.modifyDOMElement(b,null,null,null,null,null,null,a)}},destroy:function(){if(this.map){this.setGMapVisibility(!1);var a=OpenLayers.Layer.Google.cache[this.map.id];a&&1>=a.count&&
+this.removeGMapElements()}OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments)},removeGMapElements:function(){var a=OpenLayers.Layer.Google.cache[this.map.id];if(a){var b=this.mapObject&&this.getMapContainer();b&&b.parentNode&&b.parentNode.removeChild(b);(b=a.termsOfUse)&&b.parentNode&&b.parentNode.removeChild(b);(a=a.poweredBy)&&a.parentNode&&a.parentNode.removeChild(a)}},removeMap:function(a){this.visibility&&this.mapObject&&this.setGMapVisibility(!1);var b=OpenLayers.Layer.Google.cache[a.id];
+b&&(1>=b.count?(this.removeGMapElements(),delete OpenLayers.Layer.Google.cache[a.id]):--b.count);delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments)},getOLBoundsFromMapObjectBounds:function(a){var b=null;null!=a&&(b=a.getSouthWest(),a=a.getNorthEast(),this.sphericalMercator?(b=this.forwardMercator(b.lng(),b.lat()),a=this.forwardMercator(a.lng(),a.lat())):(b=new OpenLayers.LonLat(b.lng(),b.lat()),
+a=new OpenLayers.LonLat(a.lng(),a.lat())),b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat));return b},getWarningHTML:function(){return OpenLayers.i18n("googleWarning")},getMapObjectCenter:function(){return this.mapObject.getCenter()},getMapObjectZoom:function(){return this.mapObject.getZoom()},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.lng(),a.lat()).lon:a.lng()},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.lng(),
+a.lat()).lat:a.lat()},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};
+OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){if(!this.type)this.type=G_NORMAL_MAP;var a,b,c,d=OpenLayers.Layer.Google.cache[this.map.id];if(d)a=d.mapObject,b=d.termsOfUse,c=d.poweredBy,++d.count;else{var d=this.map.viewPortDiv,e=document.createElement("div");e.id=this.map.id+"_GMap2Container";e.style.position="absolute";e.style.width="100%";e.style.height="100%";d.appendChild(e);try{a=new GMap2(e),b=e.lastChild,d.appendChild(b),b.style.zIndex=
+"1100",b.style.right="",b.style.bottom="",b.className="olLayerGoogleCopyright",c=e.lastChild,d.appendChild(c),c.style.zIndex="1100",c.style.right="",c.style.bottom="",c.className="olLayerGooglePoweredBy gmnoprint"}catch(f){throw f;}OpenLayers.Layer.Google.cache[this.map.id]={mapObject:a,termsOfUse:b,poweredBy:c,count:1}}this.mapObject=a;this.termsOfUse=b;this.poweredBy=c;-1===OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)&&this.mapObject.addMapType(this.type);"function"==typeof a.getDragObject?
+this.dragObject=a.getDragObject():this.dragPanMapObject=null;!1===this.isBaseLayer&&this.setGMapVisibility("none"!==this.div.style.display)},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded())this.mapObject.checkResize();else{if(!this._resized)var a=this,b=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(b);delete a._resized;a.mapObject.checkResize();a.moveTo(a.map.getCenter(),a.map.getZoom())});this._resized=!0}},setGMapVisibility:function(a){var b=OpenLayers.Layer.Google.cache[this.map.id];
+if(b){var c=this.mapObject.getContainer();if(!0===a)this.mapObject.setMapType(this.type),c.style.display="",this.termsOfUse.style.left="",this.termsOfUse.style.display="",this.poweredBy.style.display="",b.displayed=this.id;else if(b.displayed===this.id&&delete b.displayed,!b.displayed)c.style.display="none",this.termsOfUse.style.display="none",this.termsOfUse.style.left="-9999px",this.poweredBy.style.display="none"}},getMapContainer:function(){return this.mapObject.getContainer()},getMapObjectBoundsFromOLBounds:function(a){var b=
+null;null!=a&&(b=this.sphericalMercator?this.inverseMercator(a.bottom,a.left):new OpenLayers.LonLat(a.bottom,a.left),a=this.sphericalMercator?this.inverseMercator(a.top,a.right):new OpenLayers.LonLat(a.top,a.right),b=new GLatLngBounds(new GLatLng(b.lat,b.lon),new GLatLng(a.lat,a.lon)));return b},setMapObjectCenter:function(a,b){this.mapObject.setCenter(a,b)},dragPanMapObject:function(a,b){this.dragObject.moveBy(new GSize(-a,b))},getMapObjectLonLatFromMapObjectPixel:function(a){return this.mapObject.fromContainerPixelToLatLng(a)},
+getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.fromLatLngToContainerPixel(a)},getMapObjectZoomFromMapObjectBounds:function(a){return this.mapObject.getBoundsZoomLevel(a)},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new GLatLng(c.lat,c.lon)):c=new GLatLng(b,a);return c},getMapObjectPixelFromXY:function(a,b){return new GPoint(a,b)}};
+OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:!1,initialize:function(a,b,c,d){OpenLayers.Layer.prototype.initialize.apply(this,[a,d]);this.url=b;this.params=OpenLayers.Util.extend({},c)},destroy:function(){this.params=this.url=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.prototype.clone.apply(this,
+[a])},setUrl:function(a){this.url=a},mergeNewParams:function(a){this.params=OpenLayers.Util.extend(this.params,a);a=this.redraw();null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});return a},redraw:function(a){return a?this.mergeNewParams({_olSalt:Math.random()}):OpenLayers.Layer.prototype.redraw.apply(this,[])},selectUrl:function(a,b){for(var c=1,d=0,e=a.length;d<e;d++)c*=a.charCodeAt(d)*this.URL_HASH_FACTOR,c-=Math.floor(c);return b[Math.floor(c*b.length)]},
+getFullRequestString:function(a,b){var c=b||this.url,d=OpenLayers.Util.extend({},this.params),d=OpenLayers.Util.extend(d,a),e=OpenLayers.Util.getParameterString(d);OpenLayers.Util.isArray(c)&&(c=this.selectUrl(e,c));var e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),f;for(f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);return OpenLayers.Util.urlAppend(c,e)},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});
+OpenLayers.Tile=OpenLayers.Class({events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:!1,initialize:function(a,b,c,d,e,f){this.layer=a;this.position=b.clone();this.setBounds(c);this.url=d;if(e)this.size=e.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this);OpenLayers.Util.extend(this,f)},unload:function(){if(this.isLoading)this.isLoading=!1,this.events.triggerEvent("unload")},destroy:function(){this.position=this.size=this.bounds=
+this.layer=null;this.events.destroy();this.events=null},draw:function(){this.clear();return this.shouldDraw()},shouldDraw:function(){var a=!1,b=this.layer.maxExtent;if(b){var c=this.layer.map,c=c.baseLayer.wrapDateLine&&c.getMaxExtent();this.bounds.intersectsBounds(b,{inclusive:!1,worldBounds:c})&&(a=!0)}return a||this.layer.displayOutsideMaxExtent},setBounds:function(a){a=a.clone();if(this.layer.map.baseLayer.wrapDateLine)var b=this.layer.map.getMaxExtent(),c=this.layer.map.getResolution(),a=a.wrapDateLine(b,
+{leftTolerance:c,rightTolerance:c});this.bounds=a},moveTo:function(a,b,c){null==c&&(c=!0);this.setBounds(a);this.position=b.clone();c&&this.draw()},clear:function(){},getBoundsFromBaseLayer:function(a){var b=OpenLayers.i18n("reprojectDeprecated",{layerName:this.layer.name});OpenLayers.Console.warn(b);b=this.layer.map.getLonLatFromLayerPx(a);a=a.clone();a.x+=this.size.w;a.y+=this.size.h;a=this.layer.map.getLonLatFromLayerPx(a);if(b.lon>a.lon)0>b.lon?b.lon=-180-(b.lon+180):a.lon=180+a.lon+180;return new OpenLayers.Bounds(b.lon,
+a.lat,a.lon,b.lat)},CLASS_NAME:"OpenLayers.Tile"});
+OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,blankImageUrl:"data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",maxGetUrlLength:null,initialize:function(a,b,c,d,e,f){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=d;this.frame=document.createElement("div");this.frame.style.position="absolute";this.frame.style.overflow="hidden";this.layerAlphaHack=
+this.layer.alpha&&OpenLayers.Util.alphaHack();null!=this.maxGetUrlLength&&OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame)},destroy:function(){if(null!=this.frame)this.clear(),this.frame=this.imgDiv=null;this.asyncRequestId=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments)},draw:function(){var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(a){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject)this.bounds=this.getBoundsFromBaseLayer(this.position);this.isLoading?
+this.events.triggerEvent("reload"):(this.isLoading=!0,this.events.triggerEvent("loadstart"));this.positionTile();this.renderTile()}else this.unload();return a},renderTile:function(){this.layer.div.appendChild(this.frame);if(this.layer.async){var a=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,this,"url",function(){a==this.asyncRequestId&&this.initImage()})}else this.url=this.layer.getURL(this.bounds),this.initImage()},positionTile:function(){var a=this.frame.style;
+a.left=this.position.x+"%";a.top=this.position.y+"%";a.width=this.size.w+"%";a.height=this.size.h+"%"},clear:function(){var a=this.imgDiv;if(a){OpenLayers.Event.stopObservingElement(a);this.frame.parentNode===this.layer.div&&this.layer.div.removeChild(this.frame);this.setImgSrc();if(!0===this.layerAlphaHack)a.style.filter="";OpenLayers.Element.removeClass(a,"olImageLoadError")}},createImage:function(){var a=document.createElement("img");this.imgDiv=a;a.className="olTileImage";a.galleryImg="no";var b=
+a.style,c=this.layer.gutter;if(c){var d=this.layer.tileSize,e=100*(c/d.w),c=100*(c/d.h);b.left=-e+"%";b.top=-c+"%";b.width=2*e+100+"%";b.height=2*c+100+"%";b.position="absolute"}else b.width="100%",b.height="100%";b.display="none";1>this.layer.opacity&&OpenLayers.Util.modifyDOMElement(a,null,null,null,null,null,null,this.layer.opacity);if(this.layerAlphaHack)b.paddingTop=b.height,b.height="0";this.frame.appendChild(a);return a},initImage:function(){var a=this.imgDiv||this.createImage();if(this.url&&
+a.getAttribute("src")==this.url)this.onImageLoad();else{var b=OpenLayers.Function.bind(function(){OpenLayers.Event.stopObservingElement(a);OpenLayers.Event.observe(a,"load",OpenLayers.Function.bind(this.onImageLoad,this));OpenLayers.Event.observe(a,"error",OpenLayers.Function.bind(this.onImageError,this));this.imageReloadAttempts=0;this.setImgSrc(this.url)},this);a.getAttribute("src")==this.blankImageUrl?b():(OpenLayers.Event.observe(a,"load",b),OpenLayers.Event.observe(a,"error",b),a.src=this.blankImageUrl)}},
+setImgSrc:function(a){var b=this.imgDiv;b.style.display="none";if(a)b.src=a},getTile:function(){return this.frame},createBackBuffer:function(){if(this.imgDiv&&!this.isLoading){var a=this.frame.cloneNode(!1);a.appendChild(this.imgDiv);this.imgDiv=null;return a}},onImageLoad:function(){var a=this.imgDiv;OpenLayers.Event.stopObservingElement(a);a.style.display="";this.isLoading=!1;this.events.triggerEvent("loadend");if(7>parseFloat(navigator.appVersion.split("MSIE")[1])&&this.layer&&this.layer.div){var b=
+document.createElement("span");b.style.display="none";var c=this.layer.div;c.appendChild(b);window.setTimeout(function(){b.parentNode===c&&b.parentNode.removeChild(b)},0)}if(!0===this.layerAlphaHack)a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+a.src+"', sizingMethod='scale')"},onImageError:function(){var a=this.imgDiv;null!=a.src&&(this.imageReloadAttempts++,this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS?this.setImgSrc(this.layer.getURL(this.bounds)):(OpenLayers.Element.addClass(a,
+"olImageLoadError"),this.onImageLoad()))},CLASS_NAME:"OpenLayers.Tile.Image"});
+OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:!1,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,serverResolutions:null,timerId:null,backBuffer:null,gridResolution:null,backBufferResolution:null,backBufferLonLat:null,initialize:function(a,b,c,d){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=
+OpenLayers.Function.bind(this.moveGriddedTiles,this)},removeMap:function(){if(null!=this.timerId)window.clearTimeout(this.timerId),this.timerId=null},destroy:function(){this.clearGrid();this.tileSize=this.grid=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments)},clearGrid:function(){if(this.grid){for(var a=0,b=this.grid.length;a<b;a++)for(var c=this.grid[a],d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}this.grid=[];this.gridResolution=null}},
+clone:function(a){null==a&&(a=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions()));a=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[a]);if(null!=this.tileSize)a.tileSize=this.tileSize.clone();a.grid=[];a.gridResolution=null;return a},moveTo:function(a,b,c){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);a=a||this.map.getExtent();if(null!=a){var d=!this.grid.length||b,e=this.getTilesBounds(),f=this.map.getResolution(),g=this.getServerResolution(f);
+if(this.singleTile){if(d||!c&&!e.containsBounds(a))b&&"resize"!==this.transitionEffect&&this.removeBackBuffer(),(!b||"resize"===this.transitionEffect)&&this.applyBackBuffer(g),this.initSingleTile(a)}else d=d||!e.containsBounds(a,!0),f!==g?(a=this.map.calculateBounds(null,g),d&&this.transformDiv(g/f)):(this.div.style.width="100%",this.div.style.height="100%",this.div.style.left="0%",this.div.style.top="0%"),d?(b&&"resize"===this.transitionEffect&&this.applyBackBuffer(g),this.initGriddedTiles(a)):this.scheduleMoveGriddedTiles()}},
+getServerResolution:function(a){a=a||this.map.getResolution();if(this.serverResolutions&&-1===OpenLayers.Util.indexOf(this.serverResolutions,a)){var b,c;for(b=this.serverResolutions.length-1;0<=b;b--)if(c=this.serverResolutions[b],c>a){a=c;break}if(-1===b)throw"no appropriate resolution in serverResolutions";}return a},getServerZoom:function(){return this.map.getZoomForResolution(this.getServerResolution())},transformDiv:function(a){this.div.style.width=100*a+"%";this.div.style.height=100*a+"%";var b=
+this.map.getSize(),c=parseInt(this.map.layerContainerDiv.style.left,10),d=(parseInt(this.map.layerContainerDiv.style.top,10)-b.h/2)*(a-1);this.div.style.left=(c-b.w/2)*(a-1)+"%";this.div.style.top=d+"%"},getResolutionScale:function(){return parseInt(this.div.style.width,10)/100},applyBackBuffer:function(a){var b=this.backBuffer;if(!b){b=this.createBackBuffer();if(!b)return;this.div.insertBefore(b,this.div.firstChild);this.backBuffer=b;var c=this.grid[0][0].bounds;this.backBufferLonLat={lon:c.left,
+lat:c.top};this.backBufferResolution=this.gridResolution}var c=b.style,d=this.backBufferResolution/a;c.width=100*d+"%";c.height=100*d+"%";a=this.getViewPortPxFromLonLat(this.backBufferLonLat,a);c=parseInt(this.map.layerContainerDiv.style.left,10);d=parseInt(this.map.layerContainerDiv.style.top,10);b.style.left=a.x-c+"%";b.style.top=a.y-d+"%"},createBackBuffer:function(){var a;if(0<this.grid.length){a=document.createElement("div");a.id=this.div.id+"_bb";a.className="olBackBuffer";a.style.position=
+"absolute";a.style.width="100%";a.style.height="100%";for(var b=0,c=this.grid.length;b<c;b++)for(var d=0,e=this.grid[b].length;d<e;d++){var f=this.grid[b][d].createBackBuffer();if(f)f.style.top=b*this.tileSize.h+"%",f.style.left=d*this.tileSize.w+"%",a.appendChild(f)}}return a},removeBackBuffer:function(){if(this.backBuffer&&this.backBuffer.parentNode)this.div.removeChild(this.backBuffer),this.backBufferResolution=this.backBuffer=null},moveByPx:function(){this.singleTile||this.scheduleMoveGriddedTiles()},
+scheduleMoveGriddedTiles:function(){null!=this.timerId&&window.clearTimeout(this.timerId);this.timerId=window.setTimeout(this._moveGriddedTiles,this.tileLoadingDelay)},setTileSize:function(a){if(this.singleTile)a=this.map.getSize(),a.h=parseInt(a.h*this.ratio),a.w=parseInt(a.w*this.ratio);OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[a])},getGridBounds:function(){OpenLayers.Console.warn("The getGridBounds() function is deprecated. It will be removed in 3.0. Please use getTilesBounds() instead.");
+return this.getTilesBounds()},getTilesBounds:function(){var a=null;if(this.grid.length)var a=this.grid[this.grid.length-1][0],b=this.grid[0][this.grid[0].length-1],a=new OpenLayers.Bounds(a.bounds.left,a.bounds.bottom,b.bounds.right,b.bounds.top);return a},initSingleTile:function(a){var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio,a=a.getHeight()*this.ratio,b=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2),c=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(b.left,b.top));this.grid.length||
+(this.grid[0]=[]);(a=this.grid[0][0])?a.moveTo(b,c):(a=this.addTile(b,c),this.addTileMonitoringHooks(a),a.draw(),this.grid[0][0]=a);this.removeExcessTiles(1,1);this.gridResolution=this.getServerResolution()},calculateGridLayout:function(a,b,c){var a=a.clone(),d=this.map;d.wrapDateLine&&(a=a.wrapDateLine(d.getMaxExtent()));var d=c*this.tileSize.w,c=c*this.tileSize.h,e=a.left-b.lon,f=Math.floor(e/d)-this.buffer,e=-(e/d-f)*this.tileSize.w,f=b.lon+f*d,a=a.top-(b.lat+c),g=Math.ceil(a/c)+this.buffer;return{tilelon:d,
+tilelat:c,tileoffsetlon:f,tileoffsetlat:b.lat+g*c,tileoffsetx:e,tileoffsety:-(g-a/c)*this.tileSize.h}},getTileOrigin:function(){var a=this.tileOrigin;if(!a)var a=this.getMaxExtent(),b={tl:["left","top"],tr:["right","top"],bl:["left","bottom"],br:["right","bottom"]}[this.tileOriginCorner],a=new OpenLayers.LonLat(a[b[0]],a[b[1]]);return a},initGriddedTiles:function(a){var b=this.map.getSize(),c=Math.ceil(b.h/this.tileSize.h)+Math.max(1,2*this.buffer),b=Math.ceil(b.w/this.tileSize.w)+Math.max(1,2*this.buffer),
+d=this.getTileOrigin(),e=this.getServerResolution(),f=this.calculateGridLayout(a,d,e),d=Math.round(f.tileoffsetx),e=Math.round(f.tileoffsety),g=f.tileoffsetlon,h=f.tileoffsetlat,i=f.tilelon,f=f.tilelat;this.origin=new OpenLayers.Pixel(d,e);var j=d,k=g,m=0,n=parseInt(this.map.layerContainerDiv.style.left),l=parseInt(this.map.layerContainerDiv.style.top);do{var o=this.grid[m++];o||(o=[],this.grid.push(o));var g=k,d=j,q=0;do{var r=new OpenLayers.Bounds(g,h,g+i,h+f),p=d,p=p-n,s=e,s=s-l,p=new OpenLayers.Pixel(p,
+s);(s=o[q++])?s.moveTo(r,p,!1):(s=this.addTile(r,p),this.addTileMonitoringHooks(s),o.push(s));g+=i;d+=this.tileSize.w}while(g<=a.right+i*this.buffer||q<b);h-=f;e+=this.tileSize.h}while(h>=a.bottom-f*this.buffer||m<c);this.removeExcessTiles(m,q);this.gridResolution=this.getServerResolution();this.spiralTileLoad()},getMaxExtent:function(){return this.maxExtent},spiralTileLoad:function(){for(var a=[],b=["right","down","left","up"],c=0,d=-1,e=OpenLayers.Util.indexOf(b,"right"),f=0;f<b.length;){var g=
+c,h=d;switch(b[e]){case "right":h++;break;case "down":g++;break;case "left":h--;break;case "up":g--}var i=null;g<this.grid.length&&0<=g&&h<this.grid[0].length&&0<=h&&(i=this.grid[g][h]);null!=i&&!i.queued?(a.unshift(i),i.queued=!0,f=0,c=g,d=h):(e=(e+1)%4,f++)}b=0;for(c=a.length;b<c;b++)i=a[b],i.draw(),i.queued=!1},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize,this.tileOptions)},addTileMonitoringHooks:function(a){a.onLoadStart=function(){0==this.numLoadingTiles&&
+this.events.triggerEvent("loadstart");this.numLoadingTiles++};a.events.register("loadstart",this,a.onLoadStart);a.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");0==this.numLoadingTiles&&(this.events.triggerEvent("loadend"),this.removeBackBuffer())};a.events.register("loadend",this,a.onLoadEnd);a.events.register("unload",this,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,
+scope:this})},moveGriddedTiles:function(){var a=!0,b=this.buffer||1,c=this.getResolutionScale(),d=this.grid[0][0].position.clone();d.x*=c;d.y*=c;var d=d.add(parseInt(this.div.style.left,10),parseInt(this.div.style.top,10)),e=parseInt(this.map.layerContainerDiv.style.left),f=parseInt(this.map.layerContainerDiv.style.top),d=d.add(e,f),e=this.tileSize.clone();e.w*=c;e.h*=c;d.x>-e.w*(b-1)?this.shiftColumn(!0):d.x<-e.w*b?this.shiftColumn(!1):d.y>-e.h*(b-1)?this.shiftRow(!0):d.y<-e.h*b?this.shiftRow(!1):
+a=!1;if(a)this.timerId=window.setTimeout(this._moveGriddedTiles,0)},shiftRow:function(a){for(var b=this.grid,c=b[a?0:this.grid.length-1],d=this.getServerResolution(),e=a?-this.tileSize.h:this.tileSize.h,d=d*-e,f=a?b.pop():b.shift(),g=0,h=c.length;g<h;g++){var i=c[g],j=i.bounds.clone(),i=i.position.clone();j.bottom+=d;j.top+=d;i.y+=e;f[g].moveTo(j,i)}a?b.unshift(f):b.push(f)},shiftColumn:function(a){for(var b=a?-this.tileSize.w:this.tileSize.w,c=this.getServerResolution()*b,d=0,e=this.grid.length;d<
+e;d++){var f=this.grid[d],g=f[a?0:f.length-1],h=g.bounds.clone(),g=g.position.clone();h.left+=c;h.right+=c;g.x+=b;var i=a?this.grid[d].pop():this.grid[d].shift();i.moveTo(h,g);a?f.unshift(i):f.push(i)}},removeExcessTiles:function(a,b){for(;this.grid.length>a;)for(var c=this.grid.pop(),d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}for(;this.grid[0].length>b;){d=0;for(e=this.grid.length;d<e;d++)c=this.grid[d],f=c.pop(),this.removeTileMonitoringHooks(f),f.destroy()}},
+onMapResize:function(){this.singleTile&&(this.clearGrid(),this.setTileSize())},getTileBounds:function(a){var b=this.maxExtent,c=this.getResolution(),d=c*this.tileSize.w,c=c*this.tileSize.h,e=this.getLonLatFromViewPortPx(a),a=b.left+d*Math.floor((e.lon-b.left)/d),b=b.bottom+c*Math.floor((e.lat-b.bottom)/c);return new OpenLayers.Bounds(a,b,a+d,b+c)},CLASS_NAME:"OpenLayers.Layer.Grid"});
+OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,sphericalMercator:!1,zoomOffset:0,serverResolutions:null,initialize:function(a,b,c){if(c&&c.sphericalMercator||this.sphericalMercator)c=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-2.003750834E7,-2.003750834E7,2.003750834E7,2.003750834E7),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},c);b=b||this.url;a=a||this.name;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,
+{},c])},clone:function(a){null==a&&(a=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.getXYZ(a),b=this.url;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(""+a.x+a.y+a.z,b));return OpenLayers.String.format(b,a)},getXYZ:function(a){var b=this.getServerResolution(),c=Math.round((a.left-this.maxExtent.left)/(b*this.tileSize.w)),a=Math.round((this.maxExtent.top-a.top)/(b*this.tileSize.h)),d=this.serverResolutions||
+this.resolutions,b=0==this.zoomOffset?OpenLayers.Util.indexOf(d,b):this.getServerZoom()+this.zoomOffset,d=Math.pow(2,b);this.wrapDateLine&&(c=(c%d+d)%d);return{x:c,y:a,z:b}},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin)this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom)},CLASS_NAME:"OpenLayers.Layer.XYZ"});
+OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:!0,url:"http://tile.openstreetmap.org/${z}/${x}/${y}.png",clone:function(a){null==a&&(a=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},wrapDateLine:!0,CLASS_NAME:"OpenLayers.Layer.OSM"});
+OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:!1,evt:null,initialize:function(a,b,c){OpenLayers.Util.extend(this,c);this.control=a;this.callbacks=b;(a=this.map||a.map)&&this.setMap(a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},setMap:function(a){this.map=a},checkModifiers:function(a){return null==this.keyMask?!0:((a.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(a.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(a.altKey?OpenLayers.Handler.MOD_ALT:0))==
+this.keyMask},activate:function(){if(this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.register(a[b],this[a[b]]);return this.active=!0},deactivate:function(){if(!this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]]);this.active=!1;return!0},callback:function(a,b){a&&this.callbacks[a]&&this.callbacks[a].apply(this.control,b)},register:function(a,b){this.map.events.registerPriority(a,
+this,b);this.map.events.registerPriority(a,this,this.setEvent)},unregister:function(a,b){this.map.events.unregister(a,this,b);this.map.events.unregister(a,this,this.setEvent)},setEvent:function(a){this.evt=a;return!0},destroy:function(){this.deactivate();this.control=this.map=null},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;
+OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:!1,citeCompliant:!1,mouseDown:!1,stoppedDown:null,lastDown:null,lastUp:null,persist:!1,stopDown:!1,stopUp:!1,layerOptions:null,pixelTolerance:5,touch:!1,lastTouchPx:null,initialize:function(a,b,c){if(!c||!c.layerOptions||!c.layerOptions.styleMap)this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style["default"],{});OpenLayers.Handler.prototype.initialize.apply(this,arguments)},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,
+arguments))return!1;var a=OpenLayers.Util.extend({displayInLayerSwitcher:!1,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,a);this.map.addLayer(this.layer);return!0},createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();
+this.layer.addFeatures([this.point],{silent:!0})},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments))return!1;this.cancel();null!=this.layer.map&&(this.destroyFeature(!0),this.layer.destroy(!1));this.layer=null;this.touch=!1;return!0},destroyFeature:function(a){this.layer&&(a||!this.persist)&&this.layer.destroyFeatures();this.point=null},destroyPersistedFeature:function(){var a=this.layer;a&&1<a.features.length&&this.layer.features[0].destroy()},finalize:function(a){this.mouseDown=
+!1;this.lastTouchPx=this.lastUp=this.lastDown=null;this.callback(a?"cancel":"done",[this.geometryClone()]);this.destroyFeature(a)},cancel:function(){this.finalize(!0)},click:function(a){OpenLayers.Event.stop(a);return!1},dblclick:function(a){OpenLayers.Event.stop(a);return!1},modifyFeature:function(a){this.point||this.createFeature(a);a=this.layer.getLonLatFromViewPortPx(a);this.point.geometry.x=a.lon;this.point.geometry.y=a.lat;this.callback("modify",[this.point.geometry,this.point,!1]);this.point.geometry.clearBounds();
+this.drawFeature()},drawFeature:function(){this.layer.drawFeature(this.point,this.style)},getGeometry:function(){var a=this.point&&this.point.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiPoint([a]));return a},geometryClone:function(){var a=this.getGeometry();return a&&a.clone()},mousedown:function(a){return this.down(a)},touchstart:function(a){if(!this.touch)this.touch=!0,this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,
+scope:this});this.lastTouchPx=a.xy;return this.down(a)},mousemove:function(a){return this.move(a)},touchmove:function(a){this.lastTouchPx=a.xy;return this.move(a)},mouseup:function(a){return this.up(a)},touchend:function(a){a.xy=this.lastTouchPx;return this.up(a)},down:function(a){this.mouseDown=!0;this.lastDown=a.xy;this.touch||this.modifyFeature(a.xy);this.stoppedDown=this.stopDown;return!this.stopDown},move:function(a){!this.touch&&(!this.mouseDown||this.stoppedDown)&&this.modifyFeature(a.xy);
+return!0},up:function(a){this.mouseDown=!1;this.stoppedDown=this.stopDown;return this.checkModifiers(a)&&(!this.lastUp||!this.lastUp.equals(a.xy))&&this.lastDown&&this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance)?(this.touch&&this.modifyFeature(a.xy),this.persist&&this.destroyPersistedFeature(),this.lastUp=a.xy,this.finalize(),!this.stopUp):!0},mouseout:function(a){if(OpenLayers.Util.mouseLeft(a,this.map.eventsDiv))this.stoppedDown=this.stopDown,this.mouseDown=!1},passesTolerance:function(a,
+b,c){var d=!0;null!=c&&a&&b&&a.distanceTo(b)>c&&(d=!1);return d},CLASS_NAME:"OpenLayers.Handler.Point"});
+OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:!1,freehandToggle:"shiftKey",timerId:null,redoStack:null,createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);
+this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:!0})},destroyFeature:function(a){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,a);this.line=null},destroyPersistedFeature:function(){var a=this.layer;a&&2<a.features.length&&this.layer.features[0].destroy()},removePoint:function(){this.point&&this.layer.removeFeatures([this.point])},addPoint:function(a){this.layer.removeFeatures([this.point]);a=this.layer.getLonLatFromViewPortPx(a);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(a.lon,
+a.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack},insertXY:function(a,b){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(a,b),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack},insertDeltaXY:function(a,b){var c=this.line.geometry.components[this.getCurrentPointIndex()-
+1];c&&!isNaN(c.x)&&!isNaN(c.y)&&this.insertXY(c.x+a,c.y+b)},insertDirectionLength:function(a,b){var a=a*(Math.PI/180),c=b*Math.cos(a),d=b*Math.sin(a);this.insertDeltaXY(c,d)},insertDeflectionLength:function(a,b){var c=this.getCurrentPointIndex()-1;if(0<c){var d=this.line.geometry.components[c],c=this.line.geometry.components[c-1];this.insertDirectionLength(180*Math.atan2(d.y-c.y,d.x-c.x)/Math.PI+a,b)}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1},undo:function(){var a=
+this.line.geometry,b=a.components,c=this.getCurrentPointIndex()-1,b=b[c];if(a=a.removeComponent(b)){if(!this.redoStack)this.redoStack=[];this.redoStack.push(b);this.drawFeature()}return a},redo:function(){var a=this.redoStack&&this.redoStack.pop();a&&(this.line.geometry.addComponent(a,this.getCurrentPointIndex()),this.drawFeature());return!!a},freehandMode:function(a){return this.freehandToggle&&a[this.freehandToggle]?!this.freehand:this.freehand},modifyFeature:function(a,b){this.line||this.createFeature(a);
+var c=this.layer.getLonLatFromViewPortPx(a);this.point.geometry.x=c.lon;this.point.geometry.y=c.lat;this.callback("modify",[this.point.geometry,this.getSketch(),b]);this.point.geometry.clearBounds();this.drawFeature()},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style)},getSketch:function(){return this.line},getGeometry:function(){var a=this.line&&this.line.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiLineString([a]));return a},
+touchstart:function(a){if(this.timerId&&this.passesTolerance(this.lastTouchPx,a.xy,this.doubleTouchTolerance))return this.finishGeometry(),window.clearTimeout(this.timerId),this.timerId=null,!1;if(this.timerId)window.clearTimeout(this.timerId),this.timerId=null;this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,a)},down:function(a){var b=this.stopDown;this.freehandMode(a)&&(b=!0,this.touch&&
+(this.modifyFeature(a.xy,!!this.lastUp),OpenLayers.Event.stop(a)));!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance))&&this.modifyFeature(a.xy,!!this.lastUp);this.mouseDown=!0;this.lastDown=a.xy;this.stoppedDown=b;return!b},move:function(a){if(this.stoppedDown&&this.freehandMode(a))return this.persist&&this.destroyPersistedFeature(),this.addPoint(a.xy),!1;!this.touch&&(!this.mouseDown||this.stoppedDown)&&this.modifyFeature(a.xy,!!this.lastUp);return!0},up:function(a){if(this.mouseDown&&
+(!this.lastUp||!this.lastUp.equals(a.xy)))if(this.stoppedDown&&this.freehandMode(a))this.persist&&this.destroyPersistedFeature(),this.removePoint(),this.finalize();else if(this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance))this.touch&&this.modifyFeature(a.xy),null==this.lastUp&&this.persist&&this.destroyPersistedFeature(),this.addPoint(a.xy),this.lastUp=a.xy,this.line.geometry.components.length===this.maxVertices+1&&this.finishGeometry();this.stoppedDown=this.stopDown;this.mouseDown=!1;
+return!this.stopUp},finishGeometry:function(){this.line.geometry.removeComponent(this.line.geometry.components[this.line.geometry.components.length-1]);this.removePoint();this.finalize()},dblclick:function(a){this.freehandMode(a)||this.finishGeometry();return!1},CLASS_NAME:"OpenLayers.Handler.Path"});
+OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:!1,polygon:null,createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,
+this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:!0})},addPoint:function(a){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier])for(var b=this.point.geometry,c=this.control.layer.features,d,e=c.length-1;0<=e;--e)if(d=c[e].geometry,(d instanceof OpenLayers.Geometry.Polygon||d instanceof OpenLayers.Geometry.MultiPolygon)&&d.intersects(b)){b=c[e];this.control.layer.removeFeatures([b],{silent:!0});this.control.layer.events.registerPriority("sketchcomplete",
+this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);b.geometry.addComponent(this.line.geometry);this.polygon=b;this.drawingHole=!0;break}OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments)},getCurrentPointIndex:function(){return this.line.geometry.components.length-2},enforceTopology:function(a){var a=a.vertex,b=this.line.geometry.components;if(!this.polygon.geometry.intersects(a))b=b[b.length-3],a.x=b.x,a.y=b.y},finishGeometry:function(){this.line.geometry.removeComponent(this.line.geometry.components[this.line.geometry.components.length-
+2]);this.removePoint();this.finalize()},finalizeInteriorRing:function(){var a=this.line.geometry,b=0!==a.getArea();if(b){for(var c=this.polygon.geometry.components,d=c.length-2;0<=d;--d)if(a.intersects(c[d])){b=!1;break}if(b){d=c.length-2;a:for(;0<d;--d)for(var e=c[d].components,f=0,g=e.length;f<g;++f)if(a.containsPoint(e[f])){b=!1;break a}}}if(b){if(this.polygon.state!==OpenLayers.State.INSERT)this.polygon.state=OpenLayers.State.UPDATE}else this.polygon.geometry.removeComponent(a);this.restoreFeature();
+return!1},cancel:function(){this.drawingHole&&(this.polygon.geometry.removeComponent(this.line.geometry),this.restoreFeature(!0));return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments)},restoreFeature:function(a){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:!0});this.control.layer.addFeatures([this.polygon],{silent:!0});
+this.drawingHole=!1;a||this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon})},destroyFeature:function(a){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,a);this.polygon=null},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style)},getSketch:function(){return this.polygon},getGeometry:function(){var a=this.polygon&&this.polygon.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiPolygon([a]));return a},
+CLASS_NAME:"OpenLayers.Handler.Polygon"});
+OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:!1,adapter:null,handlers:null,displayResults:!0,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:!1,toggle:!0,multiple:!1,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(a,b,c,d){OpenLayers.Control.prototype.initialize.apply(this,
+[d]);this.url=a;this.layer=b&&b instanceof OpenLayers.Layer.Vector?b:new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:!1,isBaseLayer:!1});if(c)this.taskCallbacks=c;a={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,multiple:this.multiple,callbacks:{dblclick:dojo.hitch(this,this._execute)}};this.selectControl=new OpenLayers.Control.SelectFeature(this.layer,a);a=OpenLayers.Util.extend({callbacks:{done:dojo.hitch(this,this._execute)}},this.drawCtrlHandlerOptions);
+this.drawControl=new OpenLayers.Control.DrawFeature(this.layer,this.drawCtrlHandler,a);this.handlers={};this.adapter=new OpenLayers.Format.AgsJsAdapter;this._resultFeatures=[];this._resultImages=[];OpenLayers.Util.applyDefaults(this.resultImageOptions,{opacity:1});this._isDefined=OpenLayers.Util.AgsUtil.isDefined;this._isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;this._isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction},destroy:function(){this.layer=
+null;this.selectControl.destroy();this.drawControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){return"select"==this.mode?this.selectControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments):"draw"==this.mode?this.drawControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments):!1},deactivate:function(){var a=!1;OpenLayers.Control.prototype.deactivate.apply(this,arguments)&&(this.drawControl.deactivate(),this.selectControl.deactivate(),
+a=!0);return a},_execute:function(a){var b=null;if(this._isOLGeometry(a)){if(!0==this.multiple)return OpenLayers.Console.log("...to allow multiple features as operation input..."),OpenLayers.Console.log("..._execute will not be triggered by 'done' drawing a geometry on map..."),this.drawControl.drawFeature(a),!0;OpenLayers.Console.log("..._execute triggered by 'done' drawing a geometry on map...");OpenLayers.Console.log("...single feature as operation input...");b=[new OpenLayers.Feature.Vector(a)]}else if(a instanceof
+OpenLayers.Feature.Vector)OpenLayers.Console.log("..._execute triggered by 'dblclick' a feature on map..."),!0==this.multiple?(OpenLayers.Console.log("...allow multiple features as operation input..."),b=this.layer.selectedFeatures):(OpenLayers.Console.log("...single feature as operation input..."),b=[a]);else if(a instanceof Array)OpenLayers.Console.log("..._execute triggered by using all selected features on the map..."),b=a;else throw OpenLayers.Console.error("...input geometry or feature is missing or invalid..."),
+"...input geometry or feature is missing or invalid...";this.execute(b,{},[])},execute:function(){OpenLayers.Console.error("...execute of OpenLayers.Control.AgsControl is not implemented...");throw"...execute of OpenLayers.Control.AgsControl is not implemented...";},onExecuteComplete:function(a,b){OpenLayers.Console.debug("...AgsControl OnExecuteComplete is called...");var c=null;try{if(this._resultsParser.context&&"function"===typeof this._resultsParser.parser)c=this._resultsParser.parser.apply(this._resultsParser.context,
+[a,b.args_list]);else throw OpenLayers.Console.error("..._resultsParser is missing or invalid..."),"..._resultsParser is missing or invalid...";}catch(d){throw OpenLayers.Console.error(d.message),d.message;}c instanceof OpenLayers.Feature.Vector&&(c=[c]);this.cleanupResults();this.addResults(c);!0===this.displayResults&&this.showResults();b.callback.apply(this,[c])},onExecuteAsynComplete:function(a,b){OpenLayers.Util.extend({resultFeatures:this._resultFeatures,resultImages:this._resultImages},b);
+try{if(this._resultsParser.context&&"function"===typeof this._resultsParser.parser)this._resultsParser.parser.apply(this._resultsParser.context,[a,b]);else throw OpenLayers.Console.error("..._resultsParser is missing or invalid..."),"..._resultsParser is missing or invalid...";}catch(c){throw c;}},setTaskParameters:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.taskParameters);OpenLayers.Util.extend(this.taskParameters,a)},addResults:function(a){for(var b=0;b<a.length;b++){var c=
+a[b];c instanceof OpenLayers.Feature.Vector?this._resultFeatures.push(c):c instanceof OpenLayers.Layer.Image?(c.setVisibility(!1),c.setOpacity(this.resultImageOptions.opacity),this.map.addLayer(c),this.map.setLayerIndex(c,this.map.getLayerIndex(this.layer)+1),this._resultImages.push(c)):OpenLayers.Console.log("...skip adding because it's not OpenLayers.Feature.Vector or OpenLayers.Layer.Image...")}},cleanupResults:function(){this.hideResults();if(this._resultFeatures&&0<this._resultFeatures.length)for(var a=
+0;a<this._resultFeatures.length;a++)this._resultFeatures[a].destroy();this._resultFeatures.length=0;if(this._resultImages&&0<this._resultImages.length)for(a=0;a<this._resultImages.length;a++)this.map.removeLayer(this._resultImages[a]);this._resultImages.length=0},hideResults:function(){this._resultFeatures&&0<this._resultFeatures.length&&this.layer.removeFeatures(this._resultFeatures);if(this._resultImages&&0<this._resultImages.length)for(var a=0;a<this._resultImages.length;a++)this._resultImages[a].setVisibility(!1)},
+showResults:function(){this._resultFeatures&&0<this._resultFeatures.length&&this.layer.addFeatures(this._resultFeatures);if(this._resultImages&&0<this._resultImages.length)for(var a=0;a<this._resultImages.length;a++)this._resultImages[a].setVisibility(!0)},switchMode:function(a){var b=this.active;!0===this.active&&this.deactivate();"select"===this.mode&&this.selectControl.unselectAll();if("select"===a||"draw"===a)this.mode=a;!0===b&&this.activate();OpenLayers.Console.log("...control mode switched...current control mode: "+
+this.mode+"...")},switchDrawCtrlHandler:function(a){var b=this.active;!0===this.active&&this.deactivate();"select"===this.mode&&this.selectControl.unselectAll();this.drawControl.handler=new a(this.drawControl,this.drawControl.callbacks,this.drawControl.handlerOptions);this.drawCtrlHandler=this.drawControl.handler;!0===b&&this.activate();OpenLayers.Console.log("...DrawCtrlHandler switched...current DrawCtrlHandler: "+this.drawCtrlHandler.CLASS_NAME+"...")},setMap:function(a){(!this.layer.map||!(this.layer.map instanceof
+OpenLayers.Map))&&a.addLayer(this.layer);this.selectControl.setMap(a);this.drawControl.setMap(a);OpenLayers.Util.extend(this.adapter.config,{defaultEncodeWkid:this.layer.map.projection});OpenLayers.Control.prototype.setMap.apply(this,arguments);OpenLayers.Console.debug("...current control mode: "+this.mode+"...");OpenLayers.Console.debug("...current DrawCtrlHandler: "+this.drawCtrlHandler.prototype.CLASS_NAME+"...");OpenLayers.Console.log("...adapter defaultEncodeWkid: "+this.adapter.config.defaultEncodeWkid+
+"...")},_createCallbacks:function(a,b,c){return dojo.hitch(this,function(d){for(var e=null,f=0;f<b.length;f++)if(e=b[f],"function"==typeof e)c.args_list=arguments,e.apply(a,[d,c])})},CLASS_NAME:"OpenLayers.Control.AgsControl"});
+OpenLayers.Control.AgsQueryTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!1,asynchronous:!1,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={geometry:null,outFields:[0],returnGeometry:!0,outSpatialReference:null,spatialRelationship:null,text:"",where:""};this._resultsParser={parser:this.adapter.parseAgsResults.featureSet,context:this.adapter};this.execute=this._bindFunction(this.execute,this)},execute:function(a,
+b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);this._isDefined(this.layer.map)&&(b.outSpatialReference=this.layer.map.projection?this.layer.map.projection:b.outSpatialReference);if(a[0]instanceof OpenLayers.Feature.Vector)b.geometry=a[0].geometry?a[0].geometry:b.geometry;else throw OpenLayers.Console.error("...can not execute query task...input geometry is not valid..."),"...can not execute query task...input geometry is not valid...";a=[];a=a.concat(this.taskCallbacks);
+a=a.concat(c);a=this._createCallbacks(this,a,{});if(!1==this.asynchronous){var c=new esri.tasks.QueryTask(this.url),a=this._createCallbacks(this,[this.onExecuteComplete],{callback:a}),d=this.errback||null;try{var e=this.adapter.encodeAgsQuery(b)}catch(f){throw f;}c.execute(e,a,d)}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsQueryTask ..."),"...'asynchronous' should always be set to 'false' for AgsQueryTask ...";},CLASS_NAME:"OpenLayers.Control.AgsQueryTask"});
+OpenLayers.Format.WFST=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WFST.DEFAULTS),b=OpenLayers.Format.WFST["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFST version: "+a.version;return new b(a)};OpenLayers.Format.WFST.DEFAULTS={version:"1.0.0"};
+OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:!0,xy:!0,stateName:null,initialize:function(a){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]=
+"wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},getSrsName:function(a,b){var c=b&&b.srsName;c||(c=a&&a.layer?a.layer.projection.getCode():this.srsName);return c},read:function(a,b){b=b||{};OpenLayers.Util.applyDefaults(b,{output:"features"});"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var c={};a&&this.readNode(a,c,!0);if(c.features&&"features"===b.output)c=
+c.features;return c},readers:{wfs:{FeatureCollection:function(a,b){b.features=[];this.readChildNodes(a,b)}}},write:function(a,b){var c=this.writeNode("wfs:Transaction",{features:a,options:b}),d=this.schemaLocationAttr();d&&this.setAttributeNS(c,this.namespaces.xsi,"xsi:schemaLocation",d);return OpenLayers.Format.XML.prototype.write.apply(this,[c])},writers:{wfs:{GetFeature:function(a){var b=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,handle:a&&a.handle,
+outputFormat:a&&a.outputFormat,maxFeatures:a&&a.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(a)}});if("string"==typeof this.featureType)this.writeNode("Query",a,b);else for(var c=0,d=this.featureType.length;c<d;c++)a.featureType=this.featureType[c],this.writeNode("Query",a,b);return b},Transaction:function(a){var a=a||{},b=a.options||{},c=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,handle:b.handle}}),d,e=a.features;if(e){!0===b.multi&&OpenLayers.Util.extend(this.geometryTypes,
+{"OpenLayers.Geometry.Point":"MultiPoint","OpenLayers.Geometry.LineString":!0===this.multiCurve?"MultiCurve":"MultiLineString","OpenLayers.Geometry.Polygon":!0===this.multiSurface?"MultiSurface":"MultiPolygon"});var f,g;for(a=0,d=e.length;a<d;++a)g=e[a],(f=this.stateName[g.state])&&this.writeNode(f,{feature:g,options:b},c);!0===b.multi&&this.setGeometryTypes()}if(b.nativeElements)for(a=0,d=b.nativeElements.length;a<d;++a)this.writeNode("wfs:Native",b.nativeElements[a],c);return c},Native:function(a){return this.createElementNSPlus("wfs:Native",
+{attributes:{vendorId:a.vendorId,safeToIgnore:a.safeToIgnore},value:a.value})},Insert:function(a){var b=a.feature,a=a.options,a=this.createElementNSPlus("wfs:Insert",{attributes:{handle:a&&a.handle}});this.srsName=this.getSrsName(b);this.writeNode("feature:_typeName",b,a);return a},Update:function(a){var b=a.feature,a=a.options,a=this.createElementNSPlus("wfs:Update",{attributes:{handle:a&&a.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+this.featureType}});this.featureNS&&a.setAttribute("xmlns:"+
+this.featurePrefix,this.featureNS);var c=b.modified;if(null!==this.geometryName&&(!c||void 0!==c.geometry))this.srsName=this.getSrsName(b),this.writeNode("Property",{name:this.geometryName,value:b.geometry},a);for(var d in b.attributes)void 0!==b.attributes[d]&&(!c||!c.attributes||c.attributes&&void 0!==c.attributes[d])&&this.writeNode("Property",{name:d,value:b.attributes[d]},a);this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[b.fid]}),a);return a},Property:function(a){var b=this.createElementNSPlus("wfs:Property");
+this.writeNode("Name",a.name,b);null!==a.value&&this.writeNode("Value",a.value,b);return b},Name:function(a){return this.createElementNSPlus("wfs:Name",{value:a})},Value:function(a){var b;a instanceof OpenLayers.Geometry?(b=this.createElementNSPlus("wfs:Value"),a=this.writeNode("feature:_geometry",a).firstChild,b.appendChild(a)):b=this.createElementNSPlus("wfs:Value",{value:a});return b},Delete:function(a){var b=a.feature,a=a.options,a=this.createElementNSPlus("wfs:Delete",{attributes:{handle:a&&
+a.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+this.featureType}});this.featureNS&&a.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[b.fid]}),a);return a}}},schemaLocationAttr:function(a){var a=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},a),b=OpenLayers.Util.extend({},this.schemaLocations);if(a.schema)b[a.featurePrefix]=a.schema;var a=[],c,d;for(d in b)(c=this.namespaces[d])&&
+a.push(c+" "+b[d]);return a.join(" ")||void 0},setFilterProperty:function(a){if(a.filters)for(var b=0,c=a.filters.length;b<c;++b)OpenLayers.Format.WFST.v1.prototype.setFilterProperty.call(this,a.filters[b]);else if(a instanceof OpenLayers.Filter.Spatial&&!a.property)a.property=this.geometryName},CLASS_NAME:"OpenLayers.Format.WFST.v1"});
+OpenLayers.Format.GML.v3=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/1.0.0/gmlsf.xsd",curve:!1,multiCurve:!0,surface:!1,multiSurface:!0,initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({featureMembers:function(a,b){this.readChildNodes(a,b)},Curve:function(a,b){var c={points:[]};this.readChildNodes(a,c);if(!b.components)b.components=
+[];b.components.push(new OpenLayers.Geometry.LineString(c.points))},segments:function(a,b){this.readChildNodes(a,b)},LineStringSegment:function(a,b){var c={};this.readChildNodes(a,c);c.points&&Array.prototype.push.apply(b.points,c.points)},pos:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(this.regExes.splitSpace),c=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2]);b.points=[c]},posList:function(a,b){for(var c=this.getChildValue(a).replace(this.regExes.trimSpace,
+"").split(this.regExes.splitSpace),d=parseInt(a.getAttribute("dimension"))||2,e,f,g,h=Array(c.length/d),i=0,j=c.length;i<j;i+=d)e=c[i],f=c[i+1],g=2==d?void 0:c[i+2],h[i/d]=this.xy?new OpenLayers.Geometry.Point(e,f,g):new OpenLayers.Geometry.Point(f,e,g);b.points=h},Surface:function(a,b){this.readChildNodes(a,b)},patches:function(a,b){this.readChildNodes(a,b)},PolygonPatch:function(a,b){this.readers.gml.Polygon.apply(this,[a,b])},exterior:function(a,b){var c={};this.readChildNodes(a,c);b.outer=c.components[0]},
+interior:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},MultiCurve:function(a,b){var c={components:[]};this.readChildNodes(a,c);if(0<c.components.length)b.components=[new OpenLayers.Geometry.MultiLineString(c.components)]},curveMember:function(a,b){this.readChildNodes(a,b)},MultiSurface:function(a,b){var c={components:[]};this.readChildNodes(a,c);if(0<c.components.length)b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)]},surfaceMember:function(a,b){this.readChildNodes(a,
+b)},surfaceMembers:function(a,b){this.readChildNodes(a,b)},pointMembers:function(a,b){this.readChildNodes(a,b)},lineStringMembers:function(a,b){this.readChildNodes(a,b)},polygonMembers:function(a,b){this.readChildNodes(a,b)},geometryMembers:function(a,b){this.readChildNodes(a,b)},Envelope:function(a,b){var c={points:Array(2)};this.readChildNodes(a,c);if(!b.components)b.components=[];var d=c.points[0],c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))},lowerCorner:function(a,b){var c=
+{};this.readers.gml.pos.apply(this,[a,c]);b.points[0]=c.points[0]},upperCorner:function(a,b){var c={};this.readers.gml.pos.apply(this,[a,c]);b.points[1]=c.points[0]}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){a=this.writeNode("gml:"+(OpenLayers.Util.isArray(a)?"featureMembers":"featureMember"),a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",
+this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({featureMembers:function(a){for(var b=this.createElementNSPlus("gml:featureMembers"),c=0,d=a.length;c<d;++c)this.writeNode("feature:_typeName",a[c],b);return b},Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("pos",a,b);return b},pos:function(a){return this.createElementNSPlus("gml:pos",{value:this.xy?a.x+" "+a.y:a.y+" "+a.x})},LineString:function(a){var b=
+this.createElementNSPlus("gml:LineString");this.writeNode("posList",a.components,b);return b},Curve:function(a){var b=this.createElementNSPlus("gml:Curve");this.writeNode("segments",a,b);return b},segments:function(a){var b=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",a,b);return b},LineStringSegment:function(a){var b=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",a.components,b);return b},posList:function(a){for(var b=a.length,c=Array(b),
+d,e=0;e<b;++e)d=a[e],c[e]=this.xy?d.x+" "+d.y:d.y+" "+d.x;return this.createElementNSPlus("gml:posList",{value:c.join(" ")})},Surface:function(a){var b=this.createElementNSPlus("gml:Surface");this.writeNode("patches",a,b);return b},patches:function(a){var b=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",a,b);return b},PolygonPatch:function(a){var b=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",a.components[0],b);
+for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",a.components[0],b);for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},exterior:function(a){var b=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",a,b);return b},interior:function(a){var b=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",
+a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",a.components,b);return b},MultiCurve:function(a){for(var b=this.createElementNSPlus("gml:MultiCurve"),a=a.components||[a],c=0,d=a.length;c<d;++c)this.writeNode("curveMember",a[c],b);return b},curveMember:function(a){var b=this.createElementNSPlus("gml:curveMember");this.curve?this.writeNode("Curve",a,b):this.writeNode("LineString",a,b);return b},MultiSurface:function(a){for(var b=this.createElementNSPlus("gml:MultiSurface"),
+a=a.components||[a],c=0,d=a.length;c<d;++c)this.writeNode("surfaceMember",a[c],b);return b},surfaceMember:function(a){var b=this.createElementNSPlus("gml:surfaceMember");this.surface?this.writeNode("Surface",a,b):this.writeNode("Polygon",a,b);return b},Envelope:function(a){var b=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",a,b);this.writeNode("upperCorner",a,b);this.srsName&&b.setAttribute("srsName",this.srsName);return b},lowerCorner:function(a){return this.createElementNSPlus("gml:lowerCorner",
+{value:this.xy?a.left+" "+a.bottom:a.bottom+" "+a.left})},upperCorner:function(a){return this.createElementNSPlus("gml:upperCorner",{value:this.xy?a.right+" "+a.top:a.top+" "+a.right})}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":!0===
+this.curve?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":!1===this.multiCurve?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":!0===this.surface?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":!1===this.multiSurface?"MultiPolygon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.v3"});
+OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=a.getAttribute("matchCase"),c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!("false"===c||"0"===c)});this.readChildNodes(a,
+c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,b){var c=a.getAttribute("matchCase"),c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!("false"===c||"0"===c)});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escapeChar");c.value2regex(d,e,
+f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v3.prototype.readers.gml,feature:OpenLayers.Format.GML.v3.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",
+{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:a.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");a.property&&this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Envelope",
+a.value);a.projection&&c.setAttribute("srsName",a.projection);b.appendChild(c);return b},SortBy:function(a){for(var b=this.createElementNSPlus("ogc:SortBy"),c=0,d=a.length;c<d;c++)this.writeNode("ogc:SortProperty",a[c],b);return b},SortProperty:function(a){var b=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",a,b);this.writeNode("ogc:SortOrder","DESC"==a.order?"DESC":"ASC",b);return b},SortOrder:function(a){return this.createElementNSPlus("ogc:SortOrder",{value:a})}},
+OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature},writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);if(a.value instanceof OpenLayers.Filter.Function)this.writeNode("Function",a.value,c);else{var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Envelope",a.value);a.projection&&
+d.setAttribute("srsName",a.projection);c.appendChild(d)}return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});
+OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(a){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[a])},readNode:function(a,b){return OpenLayers.Format.GML.v3.prototype.readNode.apply(this,[a,b])},readers:{wfs:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,
+b){b.numberOfFeatures=parseInt(a.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers.wfs.FeatureCollection.apply(this,arguments)},TransactionResponse:function(a,b){b.insertIds=[];b.success=!1;this.readChildNodes(a,b)},TransactionSummary:function(a,b){b.success=!0},InsertResults:function(a,b){this.readChildNodes(a,b)},Feature:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds.push(c.fids[0])}},OpenLayers.Format.WFST.v1.prototype.readers.wfs),gml:OpenLayers.Format.GML.v3.prototype.readers.gml,
+feature:OpenLayers.Format.GML.v3.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.readers.ogc,ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows},writers:{wfs:OpenLayers.Util.applyDefaults({GetFeature:function(a){var b=OpenLayers.Format.WFST.v1.prototype.writers.wfs.GetFeature.apply(this,arguments);a&&this.setAttributes(b,{resultType:a.resultType,startIndex:a.startIndex,count:a.count});return b},Query:function(a){var a=OpenLayers.Util.extend({featureNS:this.featureNS,
+featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},a),b=a.featurePrefix,c=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(b?b+":":"")+a.featureType,srsName:a.srsName}});a.featureNS&&c.setAttribute("xmlns:"+b,a.featureNS);if(a.propertyNames)for(var b=0,d=a.propertyNames.length;b<d;b++)this.writeNode("wfs:PropertyName",{property:a.propertyNames[b]},c);a.filter&&(OpenLayers.Format.WFST.v1_1_0.prototype.setFilterProperty.call(this,a.filter),this.writeNode("ogc:Filter",
+a.filter,c));return c},PropertyName:function(a){return this.createElementNSPlus("wfs:PropertyName",{value:a.property})}},OpenLayers.Format.WFST.v1.prototype.writers.wfs),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});
+OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(a){var b=this.getParser(),c={queryable:a.queryable,visibility:a.visibility,name:a.params.LAYERS,title:a.name,"abstract":a.metadata["abstract"],dataURL:a.metadata.dataURL,metadataURL:a.metadataURL,server:{version:a.params.VERSION,url:a.url},maxExtent:a.maxExtent,transparent:a.params.TRANSPARENT,numZoomLevels:a.numZoomLevels,units:a.units,isBaseLayer:a.isBaseLayer,opacity:1==a.opacity?void 0:
+a.opacity,displayInLayerSwitcher:a.displayInLayerSwitcher,singleTile:a.singleTile,tileSize:a.singleTile||!a.tileSize?void 0:{width:a.tileSize.w,height:a.tileSize.h},minScale:a.options.resolutions||a.options.scales||a.options.maxResolution||a.options.minScale?a.minScale:void 0,maxScale:a.options.resolutions||a.options.scales||a.options.minResolution||a.options.maxScale?a.maxScale:void 0,formats:[],styles:[],srs:a.srs,dimensions:a.dimensions};if(a.metadata.servertitle)c.server.title=a.metadata.servertitle;
+if(a.metadata.formats&&0<a.metadata.formats.length)for(var d=0,e=a.metadata.formats.length;d<e;d++){var f=a.metadata.formats[d];c.formats.push({value:f.value,current:f.value==a.params.FORMAT})}else c.formats.push({value:a.params.FORMAT,current:!0});if(a.metadata.styles&&0<a.metadata.styles.length){d=0;for(e=a.metadata.styles.length;d<e;d++)b=a.metadata.styles[d],b.current=b.href==a.params.SLD||b.body==a.params.SLD_BODY||b.name==a.params.STYLES?!0:!1,c.styles.push(b)}else c.styles.push({href:a.params.SLD,
+body:a.params.SLD_BODY,name:a.params.STYLES||b.defaultStyleName,title:b.defaultStyleTitle,current:!0});return c},toContext:function(a){var b={},c=a.layers;if("OpenLayers.Map"==a.CLASS_NAME){var d=a.metadata||{};b.size=a.getSize();b.bounds=a.getExtent();b.projection=a.projection;b.title=a.title;b.keywords=d.keywords;b["abstract"]=d["abstract"];b.logo=d.logo;b.descriptionURL=d.descriptionURL;b.contactInformation=d.contactInformation;b.maxExtent=a.maxExtent}else OpenLayers.Util.applyDefaults(b,a),void 0!=
+b.layers&&delete b.layers;if(void 0==b.layersContext)b.layersContext=[];if(void 0!=c&&OpenLayers.Util.isArray(c)){a=0;for(d=c.length;a<d;a++){var e=c[a];e instanceof OpenLayers.Layer.WMS&&b.layersContext.push(this.layerToContext(e))}}return b},CLASS_NAME:"OpenLayers.Format.WMC"});
+OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(a){var b=null;if(null==a)b=this.namespaces[this.defaultPrefix];else for(b in this.namespaces)if(this.namespaces[b]==a)break;return b},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",
+defaultStyleTitle:"Default",initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a=a.documentElement;this.rootPrefix=a.prefix;var b={version:a.getAttribute("version")};this.runChildNodes(b,a);return b},runChildNodes:function(a,b){for(var c=b.childNodes,d,e,f,g=0,h=c.length;g<h;++g)d=c[g],1==d.nodeType&&(e=this.getNamespacePrefix(d.namespaceURI),f=d.nodeName.split(":").pop(),
+(e=this["read_"+e+"_"+f])&&e.apply(this,[a,d]))},read_wmc_General:function(a,b){this.runChildNodes(a,b)},read_wmc_BoundingBox:function(a,b){a.projection=b.getAttribute("SRS");a.bounds=new OpenLayers.Bounds(b.getAttribute("minx"),b.getAttribute("miny"),b.getAttribute("maxx"),b.getAttribute("maxy"))},read_wmc_LayerList:function(a,b){a.layersContext=[];this.runChildNodes(a,b)},read_wmc_Layer:function(a,b){var c={visibility:"1"!=b.getAttribute("hidden"),queryable:"1"==b.getAttribute("queryable"),formats:[],
+styles:[],metadata:{}};this.runChildNodes(c,b);a.layersContext.push(c)},read_wmc_Extension:function(a,b){this.runChildNodes(a,b)},read_ol_units:function(a,b){a.units=this.getChildValue(b)},read_ol_maxExtent:function(a,b){var c=new OpenLayers.Bounds(b.getAttribute("minx"),b.getAttribute("miny"),b.getAttribute("maxx"),b.getAttribute("maxy"));a.maxExtent=c},read_ol_transparent:function(a,b){a.transparent=this.getChildValue(b)},read_ol_numZoomLevels:function(a,b){a.numZoomLevels=parseInt(this.getChildValue(b))},
+read_ol_opacity:function(a,b){a.opacity=parseFloat(this.getChildValue(b))},read_ol_singleTile:function(a,b){a.singleTile="true"==this.getChildValue(b)},read_ol_tileSize:function(a,b){var c={width:b.getAttribute("width"),height:b.getAttribute("height")};a.tileSize=c},read_ol_isBaseLayer:function(a,b){a.isBaseLayer="true"==this.getChildValue(b)},read_ol_displayInLayerSwitcher:function(a,b){a.displayInLayerSwitcher="true"==this.getChildValue(b)},read_wmc_Server:function(a,b){a.version=b.getAttribute("version");
+a.url=this.getOnlineResource_href(b);a.metadata.servertitle=b.getAttribute("title")},read_wmc_FormatList:function(a,b){this.runChildNodes(a,b)},read_wmc_Format:function(a,b){var c={value:this.getChildValue(b)};if("1"==b.getAttribute("current"))c.current=!0;a.formats.push(c)},read_wmc_StyleList:function(a,b){this.runChildNodes(a,b)},read_wmc_Style:function(a,b){var c={};this.runChildNodes(c,b);if("1"==b.getAttribute("current"))c.current=!0;a.styles.push(c)},read_wmc_SLD:function(a,b){this.runChildNodes(a,
+b)},read_sld_StyledLayerDescriptor:function(a,b){var c=OpenLayers.Format.XML.prototype.write.apply(this,[b]);a.body=c},read_sld_FeatureTypeStyle:function(a,b){var c=OpenLayers.Format.XML.prototype.write.apply(this,[b]);a.body=c},read_wmc_OnlineResource:function(a,b){a.href=this.getAttributeNS(b,this.namespaces.xlink,"href")},read_wmc_Name:function(a,b){var c=this.getChildValue(b);if(c)a.name=c},read_wmc_Title:function(a,b){var c=this.getChildValue(b);if(c)a.title=c},read_wmc_MetadataURL:function(a,
+b){a.metadataURL=this.getOnlineResource_href(b)},read_wmc_KeywordList:function(a,b){a.keywords=[];this.runChildNodes(a.keywords,b)},read_wmc_Keyword:function(a,b){a.push(this.getChildValue(b))},read_wmc_Abstract:function(a,b){var c=this.getChildValue(b);c&&(a["abstract"]=c)},read_wmc_LogoURL:function(a,b){a.logo={width:b.getAttribute("width"),height:b.getAttribute("height"),format:b.getAttribute("format"),href:this.getOnlineResource_href(b)}},read_wmc_DescriptionURL:function(a,b){a.descriptionURL=
+this.getOnlineResource_href(b)},read_wmc_ContactInformation:function(a,b){var c={};this.runChildNodes(c,b);a.contactInformation=c},read_wmc_ContactPersonPrimary:function(a,b){var c={};this.runChildNodes(c,b);a.personPrimary=c},read_wmc_ContactPerson:function(a,b){var c=this.getChildValue(b);if(c)a.person=c},read_wmc_ContactOrganization:function(a,b){var c=this.getChildValue(b);if(c)a.organization=c},read_wmc_ContactPosition:function(a,b){var c=this.getChildValue(b);if(c)a.position=c},read_wmc_ContactAddress:function(a,
+b){var c={};this.runChildNodes(c,b);a.contactAddress=c},read_wmc_AddressType:function(a,b){var c=this.getChildValue(b);if(c)a.type=c},read_wmc_Address:function(a,b){var c=this.getChildValue(b);if(c)a.address=c},read_wmc_City:function(a,b){var c=this.getChildValue(b);if(c)a.city=c},read_wmc_StateOrProvince:function(a,b){var c=this.getChildValue(b);if(c)a.stateOrProvince=c},read_wmc_PostCode:function(a,b){var c=this.getChildValue(b);if(c)a.postcode=c},read_wmc_Country:function(a,b){var c=this.getChildValue(b);
+if(c)a.country=c},read_wmc_ContactVoiceTelephone:function(a,b){var c=this.getChildValue(b);if(c)a.phone=c},read_wmc_ContactFacsimileTelephone:function(a,b){var c=this.getChildValue(b);if(c)a.fax=c},read_wmc_ContactElectronicMailAddress:function(a,b){var c=this.getChildValue(b);if(c)a.email=c},read_wmc_DataURL:function(a,b){a.dataURL=this.getOnlineResource_href(b)},read_wmc_LegendURL:function(a,b){var c={width:b.getAttribute("width"),height:b.getAttribute("height"),format:b.getAttribute("format"),
+href:this.getOnlineResource_href(b)};a.legend=c},read_wmc_DimensionList:function(a,b){a.dimensions={};this.runChildNodes(a.dimensions,b)},read_wmc_Dimension:function(a,b){var c={name:b.getAttribute("name").toLowerCase(),units:b.getAttribute("units")||"",unitSymbol:b.getAttribute("unitSymbol")||"",userValue:b.getAttribute("userValue")||"",nearestValue:"1"===b.getAttribute("nearestValue"),multipleValues:"1"===b.getAttribute("multipleValues"),current:"1"===b.getAttribute("current"),"default":b.getAttribute("default")||
+""},d=this.getChildValue(b);c.values=d.split(",");a[c.name]=c},write:function(a,b){var c=this.createElementDefaultNS("ViewContext");this.setAttributes(c,{version:this.VERSION,id:b&&"string"==typeof b.id?b.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(c,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);c.appendChild(this.write_wmc_General(a));c.appendChild(this.write_wmc_LayerList(a));return OpenLayers.Format.XML.prototype.write.apply(this,[c])},createElementDefaultNS:function(a,
+b,c){a=this.createElementNS(this.namespaces[this.defaultPrefix],a);b&&a.appendChild(this.createTextNode(b));c&&this.setAttributes(a,c);return a},setAttributes:function(a,b){var c,d;for(d in b)c=b[d].toString(),c.match(/[A-Z]/)?this.setAttributeNS(a,null,d,c):a.setAttribute(d,c)},write_wmc_General:function(a){var b=this.createElementDefaultNS("General");a.size&&b.appendChild(this.createElementDefaultNS("Window",null,{width:a.size.w,height:a.size.h}));var c=a.bounds;b.appendChild(this.createElementDefaultNS("BoundingBox",
+null,{minx:c.left.toPrecision(18),miny:c.bottom.toPrecision(18),maxx:c.right.toPrecision(18),maxy:c.top.toPrecision(18),SRS:a.projection}));b.appendChild(this.createElementDefaultNS("Title",a.title));a.keywords&&b.appendChild(this.write_wmc_KeywordList(a.keywords));a["abstract"]&&b.appendChild(this.createElementDefaultNS("Abstract",a["abstract"]));a.logo&&b.appendChild(this.write_wmc_URLType("LogoURL",a.logo.href,a.logo));a.descriptionURL&&b.appendChild(this.write_wmc_URLType("DescriptionURL",a.descriptionURL));
+a.contactInformation&&b.appendChild(this.write_wmc_ContactInformation(a.contactInformation));b.appendChild(this.write_ol_MapExtension(a));return b},write_wmc_KeywordList:function(a){for(var b=this.createElementDefaultNS("KeywordList"),c=0,d=a.length;c<d;c++)b.appendChild(this.createElementDefaultNS("Keyword",a[c]));return b},write_wmc_ContactInformation:function(a){var b=this.createElementDefaultNS("ContactInformation");a.personPrimary&&b.appendChild(this.write_wmc_ContactPersonPrimary(a.personPrimary));
+a.position&&b.appendChild(this.createElementDefaultNS("ContactPosition",a.position));a.contactAddress&&b.appendChild(this.write_wmc_ContactAddress(a.contactAddress));a.phone&&b.appendChild(this.createElementDefaultNS("ContactVoiceTelephone",a.phone));a.fax&&b.appendChild(this.createElementDefaultNS("ContactFacsimileTelephone",a.fax));a.email&&b.appendChild(this.createElementDefaultNS("ContactElectronicMailAddress",a.email));return b},write_wmc_ContactPersonPrimary:function(a){var b=this.createElementDefaultNS("ContactPersonPrimary");
+a.person&&b.appendChild(this.createElementDefaultNS("ContactPerson",a.person));a.organization&&b.appendChild(this.createElementDefaultNS("ContactOrganization",a.organization));return b},write_wmc_ContactAddress:function(a){var b=this.createElementDefaultNS("ContactAddress");a.type&&b.appendChild(this.createElementDefaultNS("AddressType",a.type));a.address&&b.appendChild(this.createElementDefaultNS("Address",a.address));a.city&&b.appendChild(this.createElementDefaultNS("City",a.city));a.stateOrProvince&&
+b.appendChild(this.createElementDefaultNS("StateOrProvince",a.stateOrProvince));a.postcode&&b.appendChild(this.createElementDefaultNS("PostCode",a.postcode));a.country&&b.appendChild(this.createElementDefaultNS("Country",a.country));return b},write_ol_MapExtension:function(a){var b=this.createElementDefaultNS("Extension");if(a=a.maxExtent){var c=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(c,{minx:a.left.toPrecision(18),miny:a.bottom.toPrecision(18),maxx:a.right.toPrecision(18),
+maxy:a.top.toPrecision(18)});b.appendChild(c)}return b},write_wmc_LayerList:function(a){for(var b=this.createElementDefaultNS("LayerList"),c=0,d=a.layersContext.length;c<d;++c)b.appendChild(this.write_wmc_Layer(a.layersContext[c]));return b},write_wmc_Layer:function(a){var b=this.createElementDefaultNS("Layer",null,{queryable:a.queryable?"1":"0",hidden:a.visibility?"0":"1"});b.appendChild(this.write_wmc_Server(a));b.appendChild(this.createElementDefaultNS("Name",a.name));b.appendChild(this.createElementDefaultNS("Title",
+a.title));a["abstract"]&&b.appendChild(this.createElementDefaultNS("Abstract",a["abstract"]));a.dataURL&&b.appendChild(this.write_wmc_URLType("DataURL",a.dataURL));a.metadataURL&&b.appendChild(this.write_wmc_URLType("MetadataURL",a.metadataURL));return b},write_wmc_LayerExtension:function(a){var b=this.createElementDefaultNS("Extension"),c=a.maxExtent,d=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(d,{minx:c.left.toPrecision(18),miny:c.bottom.toPrecision(18),maxx:c.right.toPrecision(18),
+maxy:c.top.toPrecision(18)});b.appendChild(d);a.tileSize&&!a.singleTile&&(c=this.createElementNS(this.namespaces.ol,"ol:tileSize"),this.setAttributes(c,a.tileSize),b.appendChild(c));for(var c="transparent,numZoomLevels,units,isBaseLayer,opacity,displayInLayerSwitcher,singleTile".split(","),e=0,f=c.length;e<f;++e)(d=this.createOLPropertyNode(a,c[e]))&&b.appendChild(d);return b},createOLPropertyNode:function(a,b){var c=null;null!=a[b]&&(c=this.createElementNS(this.namespaces.ol,"ol:"+b),c.appendChild(this.createTextNode(a[b].toString())));
+return c},write_wmc_Server:function(a){var a=a.server,b=this.createElementDefaultNS("Server"),c={service:"OGC:WMS",version:a.version};if(a.title)c.title=a.title;this.setAttributes(b,c);b.appendChild(this.write_wmc_OnlineResource(a.url));return b},write_wmc_URLType:function(a,b,c){a=this.createElementDefaultNS(a);a.appendChild(this.write_wmc_OnlineResource(b));if(c)for(var b=["width","height","format"],d=0;d<b.length;d++)b[d]in c&&a.setAttribute(b[d],c[b[d]]);return a},write_wmc_DimensionList:function(a){var b=
+this.createElementDefaultNS("DimensionList"),c;for(c in a.dimensions){var d={},e=a.dimensions[c],f;for(f in e)d[f]="boolean"==typeof e[f]?Number(e[f]):e[f];e="";d.values&&(e=d.values.join(","),delete d.values);b.appendChild(this.createElementDefaultNS("Dimension",e,d))}return b},write_wmc_FormatList:function(a){for(var b=this.createElementDefaultNS("FormatList"),c=0,d=a.formats.length;c<d;c++){var e=a.formats[c];b.appendChild(this.createElementDefaultNS("Format",e.value,e.current&&!0==e.current?{current:"1"}:
+null))}return b},write_wmc_StyleList:function(a){var b=this.createElementDefaultNS("StyleList");if((a=a.styles)&&OpenLayers.Util.isArray(a))for(var c,d=0,e=a.length;d<e;d++){var f=a[d],g=this.createElementDefaultNS("Style",null,f.current&&!0==f.current?{current:"1"}:null);f.href?(c=this.createElementDefaultNS("SLD"),f.name&&c.appendChild(this.createElementDefaultNS("Name",f.name)),f.title&&c.appendChild(this.createElementDefaultNS("Title",f.title)),f.legend&&c.appendChild(this.write_wmc_URLType("LegendURL",
+f.legend.href,f.legend)),f=this.write_wmc_OnlineResource(f.href),c.appendChild(f),g.appendChild(c)):f.body?(c=this.createElementDefaultNS("SLD"),f.name&&c.appendChild(this.createElementDefaultNS("Name",f.name)),f.title&&c.appendChild(this.createElementDefaultNS("Title",f.title)),f.legend&&c.appendChild(this.write_wmc_URLType("LegendURL",f.legend.href,f.legend)),f=OpenLayers.Format.XML.prototype.read.apply(this,[f.body]).documentElement,c.ownerDocument&&c.ownerDocument.importNode&&(f=c.ownerDocument.importNode(f,
+!0)),c.appendChild(f),g.appendChild(c)):(g.appendChild(this.createElementDefaultNS("Name",f.name)),g.appendChild(this.createElementDefaultNS("Title",f.title)),f["abstract"]&&g.appendChild(this.createElementDefaultNS("Abstract",f["abstract"])),f.legend&&g.appendChild(this.write_wmc_URLType("LegendURL",f.legend.href,f.legend)));b.appendChild(g)}return b},write_wmc_OnlineResource:function(a){var b=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(b,this.namespaces.xlink,"xlink:type",
+"simple");this.setAttributeNS(b,this.namespaces.xlink,"xlink:href",a);return b},getOnlineResource_href:function(a){var b={},a=a.getElementsByTagName("OnlineResource");0<a.length&&this.read_wmc_OnlineResource(b,a[0]);return b.href},CLASS_NAME:"OpenLayers.Format.WMC.v1"});
+OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(a){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[a])},read_sld_MinScaleDenominator:function(a,b){var c=parseFloat(this.getChildValue(b));if(0<c)a.maxScale=c},read_sld_MaxScaleDenominator:function(a,b){a.minScale=parseFloat(this.getChildValue(b))},read_wmc_SRS:function(a,b){if(!("srs"in
+a))a.srs={};a.srs[this.getChildValue(b)]=!0},write_wmc_Layer:function(a){var b=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[a]);if(a.maxScale){var c=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");c.appendChild(this.createTextNode(a.maxScale.toPrecision(16)));b.appendChild(c)}a.minScale&&(c=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator"),c.appendChild(this.createTextNode(a.minScale.toPrecision(16))),b.appendChild(c));if(a.srs)for(var d in a.srs)b.appendChild(this.createElementDefaultNS("SRS",
+d));b.appendChild(this.write_wmc_FormatList(a));b.appendChild(this.write_wmc_StyleList(a));a.dimensions&&b.appendChild(this.write_wmc_DimensionList(a));b.appendChild(this.write_wmc_LayerExtension(a));return b},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",errorProperty:"service",CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});
+OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.options=a},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b={};this.runChildNodes(b,a.documentElement);return b},runChildNodes:function(a,b){for(var c=b.childNodes,d,e,f=0;f<c.length;++f)d=c[f],1==d.nodeType&&(e=this["read_cap_"+d.nodeName])&&e.apply(this,[a,d])},read_cap_FeatureTypeList:function(a,
+b){var c={featureTypes:[]};this.runChildNodes(c,b);a.featureTypeList=c},read_cap_FeatureType:function(a,b){var c={};this.runChildNodes(c,b);a.featureTypes.push(c)},read_cap_Name:function(a,b){var c=this.getChildValue(b);if(c&&(c=c.split(":"),a.name=c.pop(),0<c.length))a.featureNS=this.lookupNamespaceURI(b,c[0])},read_cap_Title:function(a,b){var c=this.getChildValue(b);if(c)a.title=c},read_cap_Abstract:function(a,b){var c=this.getChildValue(b);c&&(a["abstract"]=c)},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});
+OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.145767211914062E-5,1.072883605957031E-5,5.36441802978515E-6],type:null,wrapDateLine:!0,sphericalMercator:!1,
+animationEnabled:!0,initialize:function(a,b){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.sphericalMercator&&(OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator),this.initMercatorParameters())},loadMapObject:function(){var a=OpenLayers.Util.createDiv(this.name),b=this.map.getSize();a.style.width=b.w+"px";a.style.height=b.h+"px";this.div.appendChild(a);try{this.mapObject=new VEMap(this.name)}catch(c){}if(null!=
+this.mapObject){try{this.mapObject.LoadMap(null,null,this.type,!0),this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True)}catch(d){}this.mapObject.HideDashboard();"function"==typeof this.mapObject.SetAnimationEnabled&&this.mapObject.SetAnimationEnabled(this.animationEnabled)}if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||"function"!=typeof this.mapObject.vemapcontrol.PanMap)this.dragPanMapObject=null},onMapResize:function(){this.mapObject.Resize(this.map.size.w,
+this.map.size.h)},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{layerType:"VE",layerLib:"VirtualEarth"})},setMapObjectCenter:function(a,b){this.mapObject.SetCenterAndZoom(a,b)},getMapObjectCenter:function(){return this.mapObject.GetCenter()},dragPanMapObject:function(a,b){this.mapObject.vemapcontrol.PanMap(a,-b)},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel()},getMapObjectLonLatFromMapObjectPixel:function(a){return"undefined"!=typeof VEPixel?this.mapObject.PixelToLatLong(a):
+this.mapObject.PixelToLatLong(a.x,a.y)},getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.LatLongToPixel(a)},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Longitude,a.Latitude).lon:a.Longitude},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Longitude,a.Latitude).lat:a.Latitude},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),
+c=new VELatLong(c.lat,c.lon)):c=new VELatLong(b,a);return c},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},getMapObjectPixelFromXY:function(a,b){return"undefined"!=typeof VEPixel?new VEPixel(a,b):new Msn.VE.Pixel(a,b)},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});
+OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:!0,defaultControl:null,saveState:!1,allowDepress:!1,activeState:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.controls=[];this.activeState={}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var a,b=this.controls.length-1;0<=b;b--)a=this.controls[b],a.events&&a.events.un({activate:this.iconOn,deactivate:this.iconOff}),OpenLayers.Event.stopObservingElement(a.panel_div),
+a.panel_div=null;this.activeState=null},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var a,b=0,c=this.controls.length;b<c;b++)a=this.controls[b],(a===this.defaultControl||this.saveState&&this.activeState[a.id])&&a.activate();if(!0===this.saveState)this.defaultControl=null;this.redraw();return!0}return!1},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var a,b=0,c=this.controls.length;b<c;b++)a=this.controls[b],
+this.activeState[a.id]=a.deactivate();this.redraw();return!0}return!1},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.addControlsToMap(this.controls);return this.div},redraw:function(){for(var a=this.div.childNodes.length-1;0<=a;a--)this.div.removeChild(this.div.childNodes[a]);this.div.innerHTML="";if(this.active)for(var a=0,b=this.controls.length;a<b;a++)this.div.appendChild(this.controls[a].panel_div)},activateControl:function(a){if(!this.active)return!1;if(a.type==
+OpenLayers.Control.TYPE_BUTTON)a.trigger();else if(a.type==OpenLayers.Control.TYPE_TOGGLE)a.active?a.deactivate():a.activate();else if(this.allowDepress&&a.active)a.deactivate();else{for(var b,c=0,d=this.controls.length;c<d;c++)b=this.controls[c],b!=a&&(b.type===OpenLayers.Control.TYPE_TOOL||null==b.type)&&b.deactivate();a.activate()}},addControls:function(a){OpenLayers.Util.isArray(a)||(a=[a]);this.controls=this.controls.concat(a);for(var b=0,c=a.length;b<c;b++){var d=document.createElement("div");
+d.className=a[b].displayClass+"ItemInactive";a[b].panel_div=d;if(""!=a[b].title)a[b].panel_div.title=a[b].title;OpenLayers.Event.observe(a[b].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,a[b]));OpenLayers.Event.observe(a[b].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,a[b]));OpenLayers.Event.observe(a[b].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop))}this.map&&(this.addControlsToMap(a),this.redraw())},addControlsToMap:function(a){for(var b,
+c=0,d=a.length;c<d;c++)b=a[c],!0===b.autoActivate?(b.autoActivate=!1,this.map.addControl(b),b.autoActivate=!0):(this.map.addControl(b),b.deactivate()),b.events.on({activate:this.iconOn,deactivate:this.iconOff})},iconOn:function(){var a=this.panel_div;a.className=a.className.replace(/ItemInactive$/,"ItemActive")},iconOff:function(){var a=this.panel_div;a.className=a.className.replace(/ItemActive$/,"ItemInactive")},onClick:function(a,b){OpenLayers.Event.stop(b?b:window.event);this.activateControl(a)},
+onDoubleClick:function(a,b){OpenLayers.Event.stop(b?b:window.event)},getControlsBy:function(a,b){var c="function"==typeof b.test;return OpenLayers.Array.filter(this.controls,function(d){return d[a]==b||c&&b.test(d[a])})},getControlsByName:function(a){return this.getControlsBy("name",a)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},CLASS_NAME:"OpenLayers.Control.Panel"});
+OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomIn()},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomOut()},CLASS_NAME:"OpenLayers.Control.ZoomOut"});
+OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map&&this.map.zoomToMaxExtent()},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);this.addControls([new OpenLayers.Control.ZoomIn,new OpenLayers.Control.ZoomToMaxExtent,new OpenLayers.Control.ZoomOut])},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});
+OpenLayers.Format.WPSCommon=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WPSCommon.DEFAULTS),b=OpenLayers.Format.WPSCommon["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WPSCommon version: "+a.version;return new b(a)};OpenLayers.Format.WPSCommon.DEFAULTS={version:"1.0.0",defaultVersion:"1.0.0"};
+OpenLayers.Format.WPSCommon.Capabilities=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WPSCommon.DEFAULTS),b=OpenLayers.Format.WPSCommon["v"+a.version.replace(/\./g,"_")].Capabilities;if(!b)throw"Unsupported WPSCommon.Capabilities version: "+a.version;return new b(a)};
+OpenLayers.Format.WPSCommon.Request=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WPSCommon.DEFAULTS),b=OpenLayers.Format.WPSCommon["v"+a.version.replace(/\./g,"_")].Request;if(!b)throw"Unsupported WPSCommon.Request version: "+a.version;return new b(a)};
+OpenLayers.Format.WPSCommon.ProcessDescription=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WPSCommon.DEFAULTS),b=OpenLayers.Format.WPSCommon["v"+a.version.replace(/\./g,"_")].ProcessDescription;if(!b)throw"Unsupported WPSCommon.ProcessDescription version: "+a.version;return new b(a)};
+OpenLayers.Format.WPSCommon.ExecuteResponse=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WPSCommon.DEFAULTS),b=OpenLayers.Format.WPSCommon["v"+a.version.replace(/\./g,"_")].ExecuteResponse;if(!b)throw"Unsupported WPSCommon.ExecuteResponse version: "+a.version;return new b(a)};OpenLayers.Test=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},CLASS_NAME:"OpenLayers.Test"});
+OpenLayers.Test.AgsOgcRegression=OpenLayers.Class(OpenLayers.Test,{url:"",initialize:function(a){OpenLayers.Test.prototype.initialize.apply(this,[a])},_run_get_:function(a,b,c){new OpenLayers.Format.XML;var d=this;OpenLayers.Request.GET({url:this.url,params:a,success:function(a){OpenLayers.loadURL(b,null,d,function(b){c.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...")})},failure:function(){c.ok(!1,"......")},scope:d})},_run_get_mimeType:function(a,b,c,d){OpenLayers.Request.GET({url:d||
+this.url,params:a,success:function(a){"OK"==a.statusText&&200==a.status?c.ok(!0,"...execute check result status..."):c.ok(!1,"...execute check result status...");-1!=a.getAllResponseHeaders().indexOf(b)?c.ok(!0,"...execute check result header content type..."):c.ok(!1,"...execute check result header content type...")},failure:function(){c.ok(!1,"......")},scope:this})},_run_post_:function(a,b,c){new OpenLayers.Format.XML;var a=document.getElementById(a).firstChild.nodeValue,d=this;OpenLayers.Request.POST({url:this.url,
+success:function(a){OpenLayers.loadURL(b,null,d,function(b){c.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...")})},failure:function(){c.ok(!1,"......")},params:{},headers:{},data:a})},_run_post_wpsStoredResult:function(a,b,c,d,e){var a=document.getElementById(a).firstChild.nodeValue,f=this;OpenLayers.Request.POST({url:this.url,success:function(a){OpenLayers.loadURL(b,null,f,function(b){e.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...");b=a.responseXML;
+if(!b||!b.documentElement)b=a.responseText;(b=(new OpenLayers.Format.WPSCommon({})).read(b).processoutputs[0].data.complexData[0])&&""!=b?e.ok(!0,"...async execute check result reference url..."):e.ok(!1,"...async execute check result reference url...");OpenLayers.loadURL(b,{},this,function(a){"OK"==a.statusText&&200==a.status?e.ok(!0,"...execute check result status..."):e.ok(!1,"...execute check result status...");-1!=a.getAllResponseHeaders().indexOf(c)?e.ok(!0,"...execute check result header content type..."):
+e.ok(!1,"...execute check result header content type...");d&&""!=d&&OpenLayers.loadURL(d,null,this,function(b){e.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...execute check result...")})},function(){e.ok(!1,"...async execute check result...")})})},failure:function(){e.ok(!1,"......")},params:{},headers:{},data:a})},_verify_features_number:function(a,b,c,d){OpenLayers.Request.GET({url:this.url,params:a,success:function(a){a=(new OpenLayers.Format.WFSTWithLock({version:"1.1.0",
+featureType:b,geometryName:"Shape",featureNS:"http://www.esri.com",featurePrefix:"esri",extractAttributes:!1})).read(a.responseXML);d.eq(a.length,c,"...verify features number...")},failure:function(){d.ok(!1,"......")},scope:this})},_run_wfst_post_:function(a,b,c,d,e){var a=document.getElementById(a).firstChild.nodeValue,f=this;OpenLayers.Request.POST({url:this.url,success:function(a){var b=a.responseXML.firstChild.getAttribute("lockId");!b||""==b?e.ok(!1,"...test failed...null or invalid lockId"):
+e.ok(!0,"...test succeeded...valid lockId retrieved...");var i=document.getElementById(c).firstChild.nodeValue,a=new OpenLayers.Format.XML({namespaces:{wfs:"http://www.opengis.net/wfs"}}),i=a.read(i),b=a.createElementNSPlus("wfs:LockId",{value:b});i.firstChild.insertBefore(b,i.firstChild.firstChild);a=a.write(i);OpenLayers.Request.POST({url:f.url,success:function(a){OpenLayers.loadURL(d,null,f,function(b){e.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...")})},failure:function(){e.ok(!1,
+"......")},params:{},headers:{},data:a})},failure:function(){e.ok(!1,"......")},params:{},headers:{},data:a})},_run_wfst_post_without_locks:function(a,b,c){var a=document.getElementById(a).firstChild.nodeValue,d=this;OpenLayers.Request.POST({url:this.url,success:function(a){OpenLayers.loadURL(b,null,d,function(b){c.html_eq(this._stripXmlDeclaration(a.responseText),b.responseText,"...")})},failure:function(){c.ok(!1,"......")},params:{},headers:{},data:a})},_stripXmlDeclaration:function(a){var b=a.indexOf('<?xml version="1.0" encoding="utf-8" ?>'),
+c=a.indexOf('<?xml version="1.0" encoding="UTF-8"?>');if(0<=b||0<=c)return OpenLayers.Console.debug("..."+a.substring(39,a.length-1)),a.substring(39,a.length-1);OpenLayers.Console.debug(a);return a},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});
+OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:"antialiasing,blockout,font,fontcolor,fontsize,fontstyle,glowing,interval,outline,printmode,shadow,transparency".split(","),request:null,response:null,initialize:function(a){this.request=new OpenLayers.Format.ArcXML.Request;this.response=new OpenLayers.Format.ArcXML.Response;if(a)if("feature"==a.requesttype){this.request.get_image=null;var b=this.request.get_feature.query;this.addCoordSys(b.featurecoordsys,a.featureCoordSys);
+this.addCoordSys(b.filtercoordsys,a.filterCoordSys);if(a.polygon)b.isspatial=!0,b.spatialfilter.polygon=a.polygon;else if(a.envelope)b.isspatial=!0,b.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0},this.parseEnvelope(b.spatialfilter.envelope,a.envelope)}else"image"==a.requesttype?(this.request.get_feature=null,b=this.request.get_image.properties,this.parseEnvelope(b.envelope,a.envelope),this.addLayers(b.layerlist,a.layers),this.addImageSize(b.imagesize,a.tileSize),this.addCoordSys(b.featurecoordsys,
+a.featureCoordSys),this.addCoordSys(b.filtercoordsys,a.filterCoordSys)):this.request=null;OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},parseEnvelope:function(a,b){if(b&&4==b.length)a.minx=b[0],a.miny=b[1],a.maxx=b[2],a.maxy=b[3]},addLayers:function(a,b){for(var c=0,d=b.length;c<d;c++)a.push(b[c])},addImageSize:function(a,b){if(null!==b)a.width=b.w,a.height=b.h,a.printwidth=b.w,a.printheight=b.h},addCoordSys:function(a,b){if("string"==typeof b)a.id=parseInt(b),a.string=b;else if("object"==
+typeof b&&null!==b.proj)a.id=b.proj.srsProjNumber,a.string=b.proj.srsCode},iserror:function(a){var b=null;a?(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]),a=a.documentElement.getElementsByTagName("ERROR"),b=null!==a&&0<a.length):b=""!==this.response.error;return b},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=null;a&&a.documentElement&&(b="ARCXML"==a.documentElement.nodeName?a.documentElement:a.documentElement.getElementsByTagName("ARCXML")[0]);
+if(!b||"parsererror"===b.firstChild.nodeName){var c,d;try{c=a.firstChild.nodeValue,d=a.firstChild.childNodes[1].firstChild.nodeValue}catch(e){}throw{message:"Error parsing the ArcXML request",error:c,source:d};}return this.parseResponse(b)},write:function(a){if(!a)a=this.request;var b=this.createElementNS("","ARCXML");b.setAttribute("version","1.1");var c=this.createElementNS("","REQUEST");if(null!=a.get_image){var d=this.createElementNS("","GET_IMAGE");c.appendChild(d);var e=this.createElementNS("",
+"PROPERTIES");d.appendChild(e);a=a.get_image.properties;null!=a.featurecoordsys&&(d=this.createElementNS("","FEATURECOORDSYS"),e.appendChild(d),0===a.featurecoordsys.id?d.setAttribute("string",a.featurecoordsys.string):d.setAttribute("id",a.featurecoordsys.id));null!=a.filtercoordsys&&(d=this.createElementNS("","FILTERCOORDSYS"),e.appendChild(d),0===a.filtercoordsys.id?d.setAttribute("string",a.filtercoordsys.string):d.setAttribute("id",a.filtercoordsys.id));null!=a.envelope&&(d=this.createElementNS("",
+"ENVELOPE"),e.appendChild(d),d.setAttribute("minx",a.envelope.minx),d.setAttribute("miny",a.envelope.miny),d.setAttribute("maxx",a.envelope.maxx),d.setAttribute("maxy",a.envelope.maxy));d=this.createElementNS("","IMAGESIZE");e.appendChild(d);d.setAttribute("height",a.imagesize.height);d.setAttribute("width",a.imagesize.width);if(a.imagesize.height!=a.imagesize.printheight||a.imagesize.width!=a.imagesize.printwidth)d.setAttribute("printheight",a.imagesize.printheight),d.setArrtibute("printwidth",a.imagesize.printwidth);
+null!=a.background&&(d=this.createElementNS("","BACKGROUND"),e.appendChild(d),d.setAttribute("color",a.background.color.r+","+a.background.color.g+","+a.background.color.b),null!==a.background.transcolor&&d.setAttribute("transcolor",a.background.transcolor.r+","+a.background.transcolor.g+","+a.background.transcolor.b));if(null!=a.layerlist&&0<a.layerlist.length){d=this.createElementNS("","LAYERLIST");e.appendChild(d);for(e=0;e<a.layerlist.length;e++){var f=this.createElementNS("","LAYERDEF");d.appendChild(f);
+f.setAttribute("id",a.layerlist[e].id);f.setAttribute("visible",a.layerlist[e].visible);if("object"==typeof a.layerlist[e].query){var g=a.layerlist[e].query;if(0>g.where.length)continue;var h=null,h="boolean"==typeof g.spatialfilter&&g.spatialfilter?this.createElementNS("","SPATIALQUERY"):this.createElementNS("","QUERY");h.setAttribute("where",g.where);"number"==typeof g.accuracy&&0<g.accuracy&&h.setAttribute("accuracy",g.accuracy);"number"==typeof g.featurelimit&&2E3>g.featurelimit&&h.setAttribute("featurelimit",
+g.featurelimit);"string"==typeof g.subfields&&"#ALL#"!=g.subfields&&h.setAttribute("subfields",g.subfields);"string"==typeof g.joinexpression&&0<g.joinexpression.length&&h.setAttribute("joinexpression",g.joinexpression);"string"==typeof g.jointables&&0<g.jointables.length&&h.setAttribute("jointables",g.jointables);f.appendChild(h)}"object"==typeof a.layerlist[e].renderer&&this.addRenderer(f,a.layerlist[e].renderer)}}}else if(null!=a.get_feature)d=this.createElementNS("","GET_FEATURES"),d.setAttribute("outputmode",
+"newxml"),d.setAttribute("checkesc","true"),a.get_feature.geometry?d.setAttribute("geometry",a.get_feature.geometry):d.setAttribute("geometry","false"),a.get_feature.compact&&d.setAttribute("compact",a.get_feature.compact),"number"==a.get_feature.featurelimit&&d.setAttribute("featurelimit",a.get_feature.featurelimit),d.setAttribute("globalenvelope","true"),c.appendChild(d),null!=a.get_feature.layer&&0<a.get_feature.layer.length&&(e=this.createElementNS("","LAYER"),e.setAttribute("id",a.get_feature.layer),
+d.appendChild(e)),a=a.get_feature.query,null!=a&&(e=null,e=a.isspatial?this.createElementNS("","SPATIALQUERY"):this.createElementNS("","QUERY"),d.appendChild(e),"number"==typeof a.accuracy&&e.setAttribute("accuracy",a.accuracy),null!=a.featurecoordsys&&(d=this.createElementNS("","FEATURECOORDSYS"),0==a.featurecoordsys.id?d.setAttribute("string",a.featurecoordsys.string):d.setAttribute("id",a.featurecoordsys.id),e.appendChild(d)),null!=a.filtercoordsys&&(d=this.createElementNS("","FILTERCOORDSYS"),
+0===a.filtercoordsys.id?d.setAttribute("string",a.filtercoordsys.string):d.setAttribute("id",a.filtercoordsys.id),e.appendChild(d)),0<a.buffer&&(d=this.createElementNS("","BUFFER"),d.setAttribute("distance",a.buffer),e.appendChild(d)),a.isspatial&&(d=this.createElementNS("","SPATIALFILTER"),d.setAttribute("relation",a.spatialfilter.relation),e.appendChild(d),a.spatialfilter.envelope?(f=this.createElementNS("","ENVELOPE"),f.setAttribute("minx",a.spatialfilter.envelope.minx),f.setAttribute("miny",a.spatialfilter.envelope.miny),
+f.setAttribute("maxx",a.spatialfilter.envelope.maxx),f.setAttribute("maxy",a.spatialfilter.envelope.maxy),d.appendChild(f)):"object"==typeof a.spatialfilter.polygon&&d.appendChild(this.writePolygonGeometry(a.spatialfilter.polygon))),null!=a.where&&0<a.where.length&&e.setAttribute("where",a.where));b.appendChild(c);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},addGroupRenderer:function(a,b){var c=this.createElementNS("","GROUPRENDERER");a.appendChild(c);for(var d=0;d<b.length;d++)this.addRenderer(c,
+b[d])},addRenderer:function(a,b){if(OpenLayers.Util.isArray(b))this.addGroupRenderer(a,b);else{var c=this.createElementNS("",b.type.toUpperCase()+"RENDERER");a.appendChild(c);"VALUEMAPRENDERER"==c.tagName?this.addValueMapRenderer(c,b):"VALUEMAPLABELRENDERER"==c.tagName?this.addValueMapLabelRenderer(c,b):"SIMPLELABELRENDERER"==c.tagName?this.addSimpleLabelRenderer(c,b):"SCALEDEPENDENTRENDERER"==c.tagName&&this.addScaleDependentRenderer(c,b)}},addScaleDependentRenderer:function(a,b){("string"==typeof b.lower||
+"number"==typeof b.lower)&&a.setAttribute("lower",b.lower);("string"==typeof b.upper||"number"==typeof b.upper)&&a.setAttribute("upper",b.upper);this.addRenderer(a,b.renderer)},addValueMapLabelRenderer:function(a,b){a.setAttribute("lookupfield",b.lookupfield);a.setAttribute("labelfield",b.labelfield);if("object"==typeof b.exacts)for(var c=0,d=b.exacts.length;c<d;c++){var e=b.exacts[c],f=this.createElementNS("","EXACT");"string"==typeof e.value&&f.setAttribute("value",e.value);"string"==typeof e.label&&
+f.setAttribute("label",e.label);"string"==typeof e.method&&f.setAttribute("method",e.method);a.appendChild(f);if("object"==typeof e.symbol){var g=null;"text"==e.symbol.type&&(g=this.createElementNS("","TEXTSYMBOL"));if(null!=g){for(var h=this.fontStyleKeys,i=0,j=h.length;i<j;i++){var k=h[i];e.symbol[k]&&g.setAttribute(k,e.symbol[k])}f.appendChild(g)}}}},addValueMapRenderer:function(a,b){a.setAttribute("lookupfield",b.lookupfield);if("object"==typeof b.ranges)for(var c=0,d=b.ranges.length;c<d;c++){var e=
+b.ranges[c],f=this.createElementNS("","RANGE");f.setAttribute("lower",e.lower);f.setAttribute("upper",e.upper);a.appendChild(f);if("object"==typeof e.symbol){var g=null;"simplepolygon"==e.symbol.type&&(g=this.createElementNS("","SIMPLEPOLYGONSYMBOL"));null!=g&&("string"==typeof e.symbol.boundarycolor&&g.setAttribute("boundarycolor",e.symbol.boundarycolor),"string"==typeof e.symbol.fillcolor&&g.setAttribute("fillcolor",e.symbol.fillcolor),"number"==typeof e.symbol.filltransparency&&g.setAttribute("filltransparency",
+e.symbol.filltransparency),f.appendChild(g))}}else if("object"==typeof b.exacts){c=0;for(d=b.exacts.length;c<d;c++)e=b.exacts[c],f=this.createElementNS("","EXACT"),"string"==typeof e.value&&f.setAttribute("value",e.value),"string"==typeof e.label&&f.setAttribute("label",e.label),"string"==typeof e.method&&f.setAttribute("method",e.method),a.appendChild(f),"object"==typeof e.symbol&&(g=null,"simplemarker"==e.symbol.type&&(g=this.createElementNS("","SIMPLEMARKERSYMBOL")),null!=g&&("string"==typeof e.symbol.antialiasing&&
+g.setAttribute("antialiasing",e.symbol.antialiasing),"string"==typeof e.symbol.color&&g.setAttribute("color",e.symbol.color),"string"==typeof e.symbol.outline&&g.setAttribute("outline",e.symbol.outline),"string"==typeof e.symbol.overlap&&g.setAttribute("overlap",e.symbol.overlap),"string"==typeof e.symbol.shadow&&g.setAttribute("shadow",e.symbol.shadow),"number"==typeof e.symbol.transparency&&g.setAttribute("transparency",e.symbol.transparency),"string"==typeof e.symbol.usecentroid&&g.setAttribute("usecentroid",
+e.symbol.usecentroid),"number"==typeof e.symbol.width&&g.setAttribute("width",e.symbol.width),f.appendChild(g)))}},addSimpleLabelRenderer:function(a,b){a.setAttribute("field",b.field);for(var c="featureweight,howmanylabels,labelbufferratio,labelpriorities,labelweight,linelabelposition,rotationalangles".split(","),d=0,e=c.length;d<e;d++){var f=c[d];b[f]&&a.setAttribute(f,b[f])}if("text"==b.symbol.type){var g=b.symbol,h=this.createElementNS("","TEXTSYMBOL");a.appendChild(h);c=this.fontStyleKeys;d=0;
+for(e=c.length;d<e;d++)f=c[d],g[f]&&h.setAttribute(f,b[f])}},writePolygonGeometry:function(a){if(!(a instanceof OpenLayers.Geometry.Polygon))throw{message:"Cannot write polygon geometry to ArcXML with an "+a.CLASS_NAME+" object.",geometry:a};for(var b=this.createElementNS("","POLYGON"),c=0,d=a.components.length;c<d;c++){for(var e=a.components[c],f=this.createElementNS("","RING"),g=0,h=e.components.length;g<h;g++){var i=e.components[g],j=this.createElementNS("","POINT");j.setAttribute("x",i.x);j.setAttribute("y",
+i.y);f.appendChild(j)}b.appendChild(f)}return b},parseResponse:function(a){"string"==typeof a&&(a=(new OpenLayers.Format.XML).read(a));var b=new OpenLayers.Format.ArcXML.Response,c=a.getElementsByTagName("ERROR");if(null!=c&&0<c.length)b.error=this.getChildValue(c,"Unknown error.");else{c=a.getElementsByTagName("RESPONSE");if(null==c||0==c.length)return b.error="No RESPONSE tag found in ArcXML response.",b;var d=c[0].firstChild.nodeName;if("#text"==d)d=c[0].firstChild.nextSibling.nodeName;if("IMAGE"==
+d)c=a.getElementsByTagName("ENVELOPE"),a=a.getElementsByTagName("OUTPUT"),null==c||0==c.length?b.error="No ENVELOPE tag found in ArcXML response.":null==a||0==a.length?b.error="No OUTPUT tag found in ArcXML response.":(c=this.parseAttributes(c[0]),d=this.parseAttributes(a[0]),b.image="string"==typeof d.type?{envelope:c,output:{type:d.type,data:this.getChildValue(a[0])}}:{envelope:c,output:d});else if("FEATURES"==d){if(a=c[0].getElementsByTagName("FEATURES"),c=a[0].getElementsByTagName("FEATURECOUNT"),
+b.features.featurecount=c[0].getAttribute("count"),0<b.features.featurecount){c=a[0].getElementsByTagName("ENVELOPE");b.features.envelope=this.parseAttributes(c[0],"number");a=a[0].getElementsByTagName("FEATURE");for(c=0;c<a.length;c++){for(var d=new OpenLayers.Feature.Vector,e=a[c].getElementsByTagName("FIELD"),f=0;f<e.length;f++){var g=e[f].getAttribute("name"),h=e[f].getAttribute("value");d.attributes[g]=h}e=a[c].getElementsByTagName("POLYGON");if(0<e.length){e=e[0].getElementsByTagName("RING");
+f=[];for(g=0;g<e.length;g++){h=[];h.push(this.parsePointGeometry(e[g]));for(var i=e[g].getElementsByTagName("HOLE"),j=0;j<i.length;j++)h.push(this.parsePointGeometry(i[j]));f.push(new OpenLayers.Geometry.Polygon(h))}d.geometry=1==f.length?f[0]:new OpenLayers.Geometry.MultiPolygon(f)}b.features.feature.push(d)}}}else b.error="Unidentified response type."}return b},parseAttributes:function(a,b){for(var c={},d=0;d<a.attributes.length;d++)c[a.attributes[d].nodeName]="number"==b?parseFloat(a.attributes[d].nodeValue):
+a.attributes[d].nodeValue;return c},parsePointGeometry:function(a){var b=[],c=a.getElementsByTagName("COORDS");if(0<c.length){a=this.getChildValue(c[0]);a=a.split(/;/);for(c=0;c<a.length;c++){var d=a[c].split(/ /);b.push(new OpenLayers.Geometry.Point(d[0],d[1]))}}else if(a=a.getElementsByTagName("POINT"),0<a.length)for(c=0;c<a.length;c++)b.push(new OpenLayers.Geometry.Point(parseFloat(a[c].getAttribute("x")),parseFloat(a[c].getAttribute("y"))));return new OpenLayers.Geometry.LinearRing(b)},CLASS_NAME:"OpenLayers.Format.ArcXML"});
+OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(){return OpenLayers.Util.extend(this,{get_image:{properties:{background:null,draw:!0,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:!1},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",
+legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:!1,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]})},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});
+OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(){return OpenLayers.Util.extend(this,{image:{envelope:null,output:""},features:{featurecount:0,envelope:null,feature:[]},error:""})},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});
+OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:""},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:!0,name:"ArcIMS",isBaseLayer:!0,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:!0,async:!0,name:"ArcIMS"},initialize:function(a,b,c){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:c.serviceName},
+this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(c,this.DEFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,this.params,c]);if(this.transparent){if(!this.isBaseLayer)this.isBaseLayer=!1;if("image/jpeg"==this.format)this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png"}if(null===this.options.layers)this.options.layers=[]},getURL:function(a){var b="",a=this.adjustBounds(a),a=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",
+envelope:a.toArray(),tileSize:this.tileSize})),a=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:a.write(),async:!1});if(null!=a){b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;b=this.getUrlOrImage((new OpenLayers.Format.ArcXML).read(b).image.output)}return b},getURLasync:function(a,b,c,d){a=this.adjustBounds(a);a=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:a.toArray(),tileSize:this.tileSize}));OpenLayers.Request.POST({url:this.getFullRequestString(),
+async:!0,data:a.write(),callback:function(a){var f=a.responseXML;if(!f||!f.documentElement)f=a.responseText;a=(new OpenLayers.Format.ArcXML).read(f);b[c]=this.getUrlOrImage(a.image.output);d.apply(b)},scope:this})},getUrlOrImage:function(a){var b="";a.url?b=a.url:a.data&&(b="data:image/"+a.type+";base64,"+a.data);return b},setLayerQuery:function(a,b){for(var c=0;c<this.options.layers.length;c++)if(a==this.options.layers[c].id){this.options.layers[c].query=b;return}this.options.layers.push({id:a,visible:!0,
+query:b})},getFeatureInfo:function(a,b,c){var d=c.buffer||1,e=c.callback||function(){},f=c.scope||window,g={};OpenLayers.Util.extend(g,this.options);g.requesttype="feature";if(a instanceof OpenLayers.LonLat)g.polygon=null,g.envelope=[a.lon-d,a.lat-d,a.lon+d,a.lat+d];else if(a instanceof OpenLayers.Geometry.Polygon)g.envelope=null,g.polygon=a;var h=new OpenLayers.Format.ArcXML(g);OpenLayers.Util.extend(h.request.get_feature,c);h.request.get_feature.layer=b.id;"number"==typeof b.query.accuracy?h.request.get_feature.query.accuracy=
+b.query.accuracy:(a=this.map.getCenter(),c=this.map.getViewPortPxFromLonLat(a),c.x++,c=this.map.getLonLatFromPixel(c),h.request.get_feature.query.accuracy=c.lon-a.lon);h.request.get_feature.query.where=b.query.where;h.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({CustomService:"Query"}),data:h.write(),callback:function(a){a=h.parseResponse(a.responseText);h.iserror()?e.call(f,null):e.call(f,a.features)}})},clone:function(a){null==
+a&&(a=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});
+OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:!0,autoDestroy:!0,initialize:function(a){OpenLayers.Util.extend(this,a);this.options=a;this.active=!1},destroy:function(){this.deactivate();this.options=this.layer=null},setLayer:function(a){this.layer=a},activate:function(){return!this.active?this.active=!0:!1},deactivate:function(){return this.active?(this.active=!1,!0):!1},CLASS_NAME:"OpenLayers.Strategy"});
+OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:!1,activate:function(){var a=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(a)this.cache=[],this.layer.events.on({beforefeaturesadded:this.handleAdd,beforefeaturesremoved:this.handleRemove,scope:this});return a},deactivate:function(){this.cache=null;this.layer&&this.layer.events&&this.layer.events.un({beforefeaturesadded:this.handleAdd,beforefeaturesremoved:this.handleRemove,scope:this});
+return OpenLayers.Strategy.prototype.deactivate.apply(this,arguments)},handleAdd:function(a){if(!this.caching&&this.filter){var b=a.features;a.features=[];for(var c,d=0,e=b.length;d<e;++d)c=b[d],this.filter.evaluate(c)?a.features.push(c):this.cache.push(c)}},handleRemove:function(){if(!this.caching)this.cache=[]},setFilter:function(a){this.filter=a;a=this.cache;this.cache=[];this.handleAdd({features:this.layer.features});if(0<this.cache.length)this.caching=!0,this.layer.removeFeatures(this.cache.slice()),
+this.caching=!1;if(0<a.length&&(a={features:a},this.handleAdd(a),0<a.features.length))this.caching=!0,this.layer.addFeatures(a.features),this.caching=!1},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(a){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[a])},read_cap_DefaultSRS:function(a,b){var c=this.getChildValue(b);if(c)a.srs=c},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});
+OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!0,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(a,b,c,d,e){this.url=b;this.maxExtent=this.extent=c;this.size=d;OpenLayers.Layer.prototype.initialize.apply(this,[a,e]);this.aspectRatio=this.extent.getHeight()/this.size.h/(this.extent.getWidth()/this.size.w)},destroy:function(){if(this.tile)this.removeTileMonitoringHooks(this.tile),this.tile.destroy(),this.tile=null;OpenLayers.Layer.prototype.destroy.apply(this,
+arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions()));return a=OpenLayers.Layer.prototype.clone.apply(this,[a])},setMap:function(a){if(null==this.options.maxResolution)this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;OpenLayers.Layer.prototype.setMap.apply(this,arguments)},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var d=null==this.tile;if(b||d){this.setTileSize();
+var e=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(this.extent.left,this.extent.top));d?(this.tile=new OpenLayers.Tile.Image(this,e,this.extent,null,this.tileSize),this.addTileMonitoringHooks(this.tile)):(this.tile.size=this.tileSize.clone(),this.tile.position=e.clone());this.tile.draw()}},setTileSize:function(){var a=this.extent.getWidth()/this.map.getResolution(),b=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(a,b)},addTileMonitoringHooks:function(a){a.onLoadStart=
+function(){this.events.triggerEvent("loadstart")};a.events.register("loadstart",this,a.onLoadStart);a.onLoadEnd=function(){this.events.triggerEvent("loadend")};a.events.register("loadend",this,a.onLoadEnd);a.events.register("unload",this,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,scope:this})},setUrl:function(a){this.url=a;this.tile.draw()},getURL:function(){return this.url},CLASS_NAME:"OpenLayers.Layer.Image"});
+OpenLayers.Process=OpenLayers.Class({events:null,eventListeners:null,EVENT_TYPES:["beforeprocessstart","processstarted","processsucceeded","processfailed","afterprocesscompleted"],initialize:function(a){a=a||{};OpenLayers.Util.extend(this,a);this.options=a;this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners)},CLASS_NAME:"OpenLayers.Process"});
+OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{defaultDesc:"No description available",extractWaypoints:!0,extractTracks:!0,extractRoutes:!0,extractAttributes:!0,gpxns:"http://www.topografix.com/GPX/1/1",initialize:function(a){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=[];if(this.extractTracks)for(var c=a.getElementsByTagName("trk"),
+d=0,e=c.length;d<e;d++){var f={};this.extractAttributes&&(f=this.parseAttributes(c[d]));for(var g=this.getElementsByTagNameNS(c[d],c[d].namespaceURI,"trkseg"),h=0,i=g.length;h<i;h++){var j=this.extractSegment(g[h],"trkpt");b.push(new OpenLayers.Feature.Vector(j,f))}}if(this.extractRoutes){e=a.getElementsByTagName("rte");c=0;for(d=e.length;c<d;c++)f={},this.extractAttributes&&(f=this.parseAttributes(e[c])),g=this.extractSegment(e[c],"rtept"),b.push(new OpenLayers.Feature.Vector(g,f))}if(this.extractWaypoints){a=
+a.getElementsByTagName("wpt");c=0;for(e=a.length;c<e;c++)f={},this.extractAttributes&&(f=this.parseAttributes(a[c])),d=new OpenLayers.Geometry.Point(a[c].getAttribute("lon"),a[c].getAttribute("lat")),b.push(new OpenLayers.Feature.Vector(d,f))}if(this.internalProjection&&this.externalProjection){f=0;for(a=b.length;f<a;f++)b[f].geometry.transform(this.externalProjection,this.internalProjection)}return b},extractSegment:function(a,b){for(var c=this.getElementsByTagNameNS(a,a.namespaceURI,b),d=[],e=0,
+f=c.length;e<f;e++)d.push(new OpenLayers.Geometry.Point(c[e].getAttribute("lon"),c[e].getAttribute("lat")));return new OpenLayers.Geometry.LineString(d)},parseAttributes:function(a){for(var b={},a=a.firstChild,c,d;a;){if(1==a.nodeType&&(c=a.firstChild,3==c.nodeType||4==c.nodeType))if(d=a.prefix?a.nodeName.split(":")[1]:a.nodeName,"trkseg"!=d&&"rtept"!=d)b[d]=c.nodeValue;a=a.nextSibling}return b},write:function(a,b){var c,a=OpenLayers.Util.isArray(a)?a:[a];c=this.createElementNS(this.gpxns,"gpx");
+for(var d=0,e=a.length;d<e;d++)c.appendChild(this.buildFeatureNode(a[d]));b&&"object"==typeof b&&c.appendChild(this.buildMetadataNode(b));return OpenLayers.Format.XML.prototype.write.apply(this,[c])},buildMetadataNode:function(a){for(var b=["name","desc","author"],c=this.createElementNS(this.gpxns,"metadata"),d=0;d<b.length;d++){var e=b[d];if(a[e]){var f=this.createElementNS(this.gpxns,e);f.appendChild(this.createTextNode(a[e]));c.appendChild(f)}}return c},buildFeatureNode:function(a){var b=a.geometry,
+b=b.clone();this.internalProjection&&this.externalProjection&&b.transform(this.internalProjection,this.externalProjection);if("OpenLayers.Geometry.Point"==b.CLASS_NAME)return this.buildWptNode(a);var c=this.createElementNS(this.gpxns,"trk");this.appendAttributesNode(c,a);for(var a=this.buildTrkSegNode(b),a=OpenLayers.Util.isArray(a)?a:[a],b=0,d=a.length;b<d;b++)c.appendChild(a[b]);return c},buildTrkSegNode:function(a){var b,c,d,e;if("OpenLayers.Geometry.LineString"==a.CLASS_NAME||"OpenLayers.Geometry.LinearRing"==
+a.CLASS_NAME){b=this.createElementNS(this.gpxns,"trkseg");for(c=0,d=a.components.length;c<d;c++)e=a.components[c],b.appendChild(this.buildTrkPtNode(e));return b}b=[];for(c=0,d=a.components.length;c<d;c++)b.push(this.buildTrkSegNode(a.components[c]));return b},buildTrkPtNode:function(a){var b=this.createElementNS(this.gpxns,"trkpt");b.setAttribute("lon",a.x);b.setAttribute("lat",a.y);return b},buildWptNode:function(a){var b=this.createElementNS(this.gpxns,"wpt");b.setAttribute("lon",a.geometry.x);
+b.setAttribute("lat",a.geometry.y);this.appendAttributesNode(b,a);return b},appendAttributesNode:function(a,b){var c=this.createElementNS(this.gpxns,"name");c.appendChild(this.createTextNode(b.attributes.name||b.id));a.appendChild(c);c=this.createElementNS(this.gpxns,"desc");c.appendChild(this.createTextNode(b.attributes.description||this.defaultDesc));a.appendChild(c)},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Util.AgsUtil=function(){return function(){}}();
+OpenLayers.Util.AgsUtil.isDefined=function(a){return void 0===a||null===a||""===a?!1:!0};OpenLayers.Util.AgsUtil.isNumber=function(a){return void 0===a||null===a||""===a?!1:"number"===typeof a?!0:!1};OpenLayers.Util.AgsUtil.isBoolean=function(a){return void 0===a||null===a||""===a?!1:"boolean"===typeof a?!0:!1};
+OpenLayers.Util.AgsUtil.isAgsGeometry=function(a){return void 0===a||null===a||""===a?!1:a instanceof esri.geometry.Point?!0:a instanceof esri.geometry.Polyline?!0:a instanceof esri.geometry.Polygon?!0:a instanceof esri.geometry.Extent?!0:!1};
+OpenLayers.Util.AgsUtil.isOLGeometry=function(a){return void 0===a||null===a||""===a?!1:a instanceof OpenLayers.Geometry.Point?!0:a instanceof OpenLayers.Geometry.LineString?!0:a instanceof OpenLayers.Geometry.LinearRing?!0:a instanceof OpenLayers.Geometry.MultiLineString?!0:a instanceof OpenLayers.Geometry.MultiPoint?!0:a instanceof OpenLayers.Geometry.MultiPolygon?!0:a instanceof OpenLayers.Geometry.Polygon?!0:a instanceof OpenLayers.Bounds?!0:!1};
+OpenLayers.Util.AgsUtil.isSameOLPoint=function(a,b){return"number"===typeof a.x&&"number"===typeof a.y&&"number"===typeof b.x&&"number"===typeof b.y&&a.x==b.x&&a.y==b.y?!0:!1};OpenLayers.Util.AgsUtil.dispatch=function(a,b,c){function d(){++g;g===f&&b.call(c,h)}function e(b){window.setTimeout(function(){a[b].apply(c,[d,h])})}for(var f=a.length,g=0,h={},i=0;i<f;++i)e(i)};
+OpenLayers.Util.AgsUtil.bindFunction=function(a,b){if(void 0!==window.dojo)return dojo.hitch(b,a);OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(a,b)};
+OpenLayers.Util.AgsUtil.createSingleCallback=function(a,b,c){return void 0!==window.dojo?dojo.hitch(c,function(d){for(var e=null,f=0;f<a.length;f++)e=a[f],"function"==typeof e&&e.apply(c,[d,b])}):OpenLayers.Function.bind(function(d){for(var e=null,f=0;f<a.length;f++)e=a[f],"function"==typeof e&&e.apply(c,[d,b])},c)};
+OpenLayers.Util.AgsUtil.createProtocolCallback=function(a,b,c,d){return void 0!==window.dojo?dojo.hitch(d,function(){"function"==typeof a&&a.apply(this,[b,c])}):OpenLayers.Function.bind(function(){"function"==typeof a&&a.apply(this,[b,c])},d)};
+OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},readers:{xsd:{schema:function(a,b){var c=[],d={};this.readChildNodes(a,{complexTypes:c,customTypes:d});for(var e=a.attributes,f,g,h=0,i=e.length;h<i;++h)f=e[h],g=f.name,0==g.indexOf("xmlns")?this.setNamespace(g.split(":")[1]||"",f.value):b[g]=f.value;b.featureTypes=c;b.targetPrefix=this.namespaceAlias[b.targetNamespace];h=0;for(i=c.length;h<i;++h)if(e=c[h],f=d[e.typeName],
+d[e.typeName])e.typeName=f.name},complexType:function(a,b){var c={typeName:a.getAttribute("name")};this.readChildNodes(a,c);b.complexTypes.push(c)},complexContent:function(a,b){this.readChildNodes(a,b)},extension:function(a,b){this.readChildNodes(a,b)},sequence:function(a,b){var c={elements:[]};this.readChildNodes(a,c);b.properties=c.elements},element:function(a,b){if(b.elements){for(var c={},d=a.attributes,e,f=0,g=d.length;f<g;++f)e=d[f],c[e.name]=e.value;d=c.type;if(!d)d={},this.readChildNodes(a,
+d),c.restriction=d,c.type=d.base;c.localType=(d.base||d).split(":").pop();b.elements.push(c)}b.complexTypes&&(d=a.getAttribute("type"),c=d.split(":").pop(),b.customTypes[c]={name:a.getAttribute("name"),type:d})},simpleType:function(a,b){this.readChildNodes(a,b)},restriction:function(a,b){b.base=a.getAttribute("base");this.readRestriction(a,b)}}},readRestriction:function(a,b){for(var c=a.childNodes,d,e,f=0,g=c.length;f<g;++f)d=c[f],1==d.nodeType&&(e=d.nodeName.split(":").pop(),d=d.getAttribute("value"),
+b[e]?("string"==typeof b[e]&&(b[e]=[b[e]]),b[e].push(d)):b[e]=d)},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);return b},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});
+OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:!1,size:null,resolution:null,map:null,featureDx:0,initialize:function(a,b){this.container=OpenLayers.Util.getElement(a);OpenLayers.Util.extend(this,b)},destroy:function(){this.map=this.resolution=this.size=this.extent=this.container=null},supported:function(){return!1},setExtent:function(a,b){this.extent=a.clone();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine)this.extent=a.wrapDateLine(this.map.getMaxExtent());
+if(b)this.resolution=null;return!0},setSize:function(a){this.size=a.clone();this.resolution=null},getResolution:function(){return this.resolution=this.resolution||this.map.getResolution()},drawFeature:function(a,b){if(null==b)b=a.style;if(a.geometry){var c=a.geometry.getBounds();if(c){var d;this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&(d=this.map.getMaxExtent());c.intersectsBounds(this.extent,{worldBounds:d})?this.calculateFeatureDx(c,d):b={display:"none"};c=this.drawGeometry(a.geometry,b,
+a.id);if("none"!=b.display&&b.label&&!1!==c){d=a.geometry.getCentroid();if(b.labelXOffset||b.labelYOffset){var e=isNaN(b.labelXOffset)?0:b.labelXOffset,f=isNaN(b.labelYOffset)?0:b.labelYOffset,g=this.getResolution();d.move(e*g,f*g)}this.drawText(a.id,b,d)}else this.removeText(a.id);return c}}},calculateFeatureDx:function(a,b){this.featureDx=0;if(b){var c=b.getWidth();this.featureDx=Math.round(((a.left+a.right)/2-(this.extent.left+this.extent.right)/2)/c)*c}},drawGeometry:function(){},drawText:function(){},
+removeText:function(){},clear:function(){},getFeatureIdFromEvent:function(){},eraseFeatures:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0,c=a.length;b<c;++b){var d=a[b];this.eraseGeometry(d.geometry,d.id);this.removeText(d.id)}},eraseGeometry:function(){},moveRoot:function(){},getRenderLayerId:function(){return this.container.id},applyDefaultSymbolizer:function(a){var b=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);!1===a.stroke&&(delete b.strokeWidth,delete b.strokeColor);
+!1===a.fill&&delete b.fillColor;OpenLayers.Util.extend(b,a);return b},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};
+OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:!0,hitOverflow:0,canvas:null,features:null,pendingRedraw:!1,initialize:function(a,b){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection)this.hitCanvas=document.createElement("canvas"),this.hitContext=this.hitCanvas.getContext("2d")},setExtent:function(){OpenLayers.Renderer.prototype.setExtent.apply(this,
+arguments);return!1},eraseGeometry:function(a,b){this.eraseFeatures(this.features[b][0])},supported:function(){return!!document.createElement("canvas").getContext},setSize:function(a){this.size=a.clone();var b=this.root;b.style.width=a.w+"px";b.style.height=a.h+"px";b.width=a.w;b.height=a.h;this.resolution=null;if(this.hitDetection)b=this.hitCanvas,b.style.width=a.w+"px",b.style.height=a.h+"px",b.width=a.w,b.height=a.h},drawFeature:function(a,b){var c;if(a.geometry){b=this.applyDefaultSymbolizer(b||
+a.style);c=a.geometry.getBounds();var d;this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&(d=this.map.getMaxExtent());d=c&&c.intersectsBounds(this.extent,{worldBounds:d});(c="none"!==b.display&&!!c&&d)?this.features[a.id]=[a,b]:delete this.features[a.id];this.pendingRedraw=!0}if(this.pendingRedraw&&!this.locked)this.redraw(),this.pendingRedraw=!1;return c},drawGeometry:function(a,b,c){var d=a.CLASS_NAME;if("OpenLayers.Geometry.Collection"==d||"OpenLayers.Geometry.MultiPoint"==d||"OpenLayers.Geometry.MultiLineString"==
+d||"OpenLayers.Geometry.MultiPolygon"==d)for(d=0;d<a.components.length;d++)this.drawGeometry(a.components[d],b,c);else switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":this.drawPoint(a,b,c);break;case "OpenLayers.Geometry.LineString":this.drawLineString(a,b,c);break;case "OpenLayers.Geometry.LinearRing":this.drawLinearRing(a,b,c);break;case "OpenLayers.Geometry.Polygon":this.drawPolygon(a,b,c)}},drawExternalGraphic:function(a,b,c){var d=new Image;if(b.graphicTitle)d.title=b.graphicTitle;var e=
+b.graphicWidth||b.graphicHeight,f=b.graphicHeight||b.graphicWidth,e=e?e:2*b.pointRadius,f=f?f:2*b.pointRadius,g=void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*e),h=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*f),i=b.graphicOpacity||b.fillOpacity;d.onload=OpenLayers.Function.bind(function(){if(this.features[c]){var b=this.getLocalXY(a),k=b[0],b=b[1];if(!isNaN(k)&&!isNaN(b)){var k=k+g|0,b=b+h|0,m=this.canvas;m.globalAlpha=i;var n=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=
+/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);m.drawImage(d,k*n,b*n,e*n,f*n);this.hitDetection&&(this.setHitContextStyle("fill",c),this.hitContext.fillRect(k,b,e,f))}}},this);d.src=b.externalGraphic},setCanvasStyle:function(a,b){"fill"===a?(this.canvas.globalAlpha=b.fillOpacity,this.canvas.fillStyle=b.fillColor):"stroke"===a?(this.canvas.globalAlpha=b.strokeOpacity,this.canvas.strokeStyle=b.strokeColor,this.canvas.lineWidth=b.strokeWidth):(this.canvas.globalAlpha=
+0,this.canvas.lineWidth=1)},featureIdToHex:function(a){a=Number(a.split("_").pop())+1;if(16777216<=a)this.hitOverflow=a-16777215,a=a%16777216+1;var a="000000"+a.toString(16),b=a.length;return a="#"+a.substring(b-6,b)},setHitContextStyle:function(a,b,c){b=this.featureIdToHex(b);"fill"==a?(this.hitContext.globalAlpha=1,this.hitContext.fillStyle=b):"stroke"==a?(this.hitContext.globalAlpha=1,this.hitContext.strokeStyle=b,this.hitContext.lineWidth=c.strokeWidth+2):(this.hitContext.globalAlpha=0,this.hitContext.lineWidth=
+1)},drawPoint:function(a,b,c){if(!1!==b.graphic)if(b.externalGraphic)this.drawExternalGraphic(a,b,c);else{var d=this.getLocalXY(a),a=d[0],d=d[1];if(!isNaN(a)&&!isNaN(d)){var e=2*Math.PI,f=b.pointRadius;!1!==b.fill&&(this.setCanvasStyle("fill",b),this.canvas.beginPath(),this.canvas.arc(a,d,f,0,e,!0),this.canvas.fill(),this.hitDetection&&(this.setHitContextStyle("fill",c,b),this.hitContext.beginPath(),this.hitContext.arc(a,d,f,0,e,!0),this.hitContext.fill()));!1!==b.stroke&&(this.setCanvasStyle("stroke",
+b),this.canvas.beginPath(),this.canvas.arc(a,d,f,0,e,!0),this.canvas.stroke(),this.hitDetection&&(this.setHitContextStyle("stroke",c,b),this.hitContext.beginPath(),this.hitContext.arc(a,d,f,0,e,!0),this.hitContext.stroke()),this.setCanvasStyle("reset"))}}},drawLineString:function(a,b,c){b=OpenLayers.Util.applyDefaults({fill:!1},b);this.drawLinearRing(a,b,c)},drawLinearRing:function(a,b,c){!1!==b.fill&&(this.setCanvasStyle("fill",b),this.renderPath(this.canvas,a,b,c,"fill"),this.hitDetection&&(this.setHitContextStyle("fill",
+c,b),this.renderPath(this.hitContext,a,b,c,"fill")));!1!==b.stroke&&(this.setCanvasStyle("stroke",b),this.renderPath(this.canvas,a,b,c,"stroke"),this.hitDetection&&(this.setHitContextStyle("stroke",c,b),this.renderPath(this.hitContext,a,b,c,"stroke")));this.setCanvasStyle("reset")},renderPath:function(a,b,c,d,e){b=b.components;c=b.length;a.beginPath();var d=this.getLocalXY(b[0]),f=d[1];if(!isNaN(d[0])&&!isNaN(f)){a.moveTo(d[0],d[1]);for(d=1;d<c;++d)f=this.getLocalXY(b[d]),a.lineTo(f[0],f[1]);"fill"===
+e?a.fill():a.stroke()}},drawPolygon:function(a,b,c){var a=a.components,d=a.length;this.drawLinearRing(a[0],b,c);for(var e=1;e<d;++e){this.canvas.globalCompositeOperation="destination-out";if(this.hitDetection)this.hitContext.globalCompositeOperation="destination-out";this.drawLinearRing(a[e],OpenLayers.Util.applyDefaults({stroke:!1,fillOpacity:1},b),c);this.canvas.globalCompositeOperation="source-over";if(this.hitDetection)this.hitContext.globalCompositeOperation="source-over";this.drawLinearRing(a[e],
+OpenLayers.Util.applyDefaults({fill:!1},b),c)}},drawText:function(a,b){var b=OpenLayers.Util.extend({fontColor:"#000000",labelAlign:"cm"},b),c=this.getLocalXY(a);this.setCanvasStyle("reset");this.canvas.fillStyle=b.fontColor;this.canvas.globalAlpha=b.fontOpacity||1;var d=[b.fontStyle?b.fontStyle:"normal","normal",b.fontWeight?b.fontWeight:"normal",b.fontSize?b.fontSize:"1em",b.fontFamily?b.fontFamily:"sans-serif"].join(" "),e=b.label.split("\n"),f=e.length;if(this.canvas.fillText){this.canvas.font=
+d;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[b.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[b.labelAlign[1]]||"middle";var g=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[1]];null==g&&(g=-0.5);d=this.canvas.measureText("Mg").height||this.canvas.measureText("xx").width;c[1]+=d*g*(f-1);for(g=0;g<f;g++)this.canvas.fillText(e[g],c[0],c[1]+d*g)}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=d;var h=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[0]];
+null==h&&(h=-0.5);g=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[1]];null==g&&(g=-0.5);d=this.canvas.mozMeasureText("xx");c[1]+=d*(1+g*f);for(g=0;g<f;g++){var i=c[0]+h*this.canvas.mozMeasureText(e[g]),j=c[1]+g*d;this.canvas.translate(i,j);this.canvas.mozDrawText(e[g]);this.canvas.translate(-i,-j)}}this.setCanvasStyle("reset")},getLocalXY:function(a){var b=this.getResolution(),c=this.extent;return[(a.x-this.featureDx)/b+-c.left/b,c.top/b-a.y/b]},clear:function(){var a=this.root.height,b=this.root.width;
+this.canvas.clearRect(0,0,b,a);this.features={};this.hitDetection&&this.hitContext.clearRect(0,0,b,a)},getFeatureIdFromEvent:function(a){var b=null;if(this.hitDetection&&!this.map.dragging)a=a.xy,a=this.hitContext.getImageData(a.x|0,a.y|0,1,1).data,255===a[3]&&(a=a[2]+256*(a[1]+256*a[0]))&&(b=this.features["OpenLayers.Feature.Vector_"+(a-1+this.hitOverflow)][0]);return b},eraseFeatures:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0;b<a.length;++b)delete this.features[a[b].id];this.redraw()},
+redraw:function(){if(!this.locked){var a=this.root.height,b=this.root.width;this.canvas.clearRect(0,0,b,a);this.hitDetection&&this.hitContext.clearRect(0,0,b,a);var a=[],c,d,e=this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&this.map.getMaxExtent(),f;for(f in this.features)if(this.features.hasOwnProperty(f))b=this.features[f][0],c=b.geometry,this.calculateFeatureDx(c.getBounds(),e),d=this.features[f][1],this.drawGeometry(c,d,b.id),d.label&&a.push([b,d]);b=0;for(c=a.length;b<c;++b)f=a[b],this.drawText(f[0].geometry.getCentroid(),
+f[1])}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={l:"left",r:"right",t:"top",b:"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={l:0,r:-1,t:0,b:-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;
+OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:!1,interestingTagsExclude:null,areaTags:null,initialize:function(a){for(var b={interestingTagsExclude:"source,source_ref,source:ref,history,attribution,created_by".split(","),areaTags:"area,building,leisure,tourism,ruins,historic,landuse,military,natural,sport".split(",")},b=OpenLayers.Util.extend(b,a),c={},a=0;a<b.interestingTagsExclude.length;a++)c[b.interestingTagsExclude[a]]=!0;b.interestingTagsExclude=c;c={};for(a=0;a<b.areaTags.length;a++)c[b.areaTags[a]]=
+!0;b.areaTags=c;this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[b])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));for(var b=this.getNodes(a),c=this.getWays(a),a=Array(c.length),d=0;d<c.length;d++){for(var e=Array(c[d].nodes.length),f=this.isWayArea(c[d])?1:0,g=0;g<c[d].nodes.length;g++){var h=b[c[d].nodes[g]],i=new OpenLayers.Geometry.Point(h.lon,h.lat);i.osm_id=parseInt(c[d].nodes[g]);
+e[g]=i;h.used=!0}h=null;h=f?new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(e)):new OpenLayers.Geometry.LineString(e);this.internalProjection&&this.externalProjection&&h.transform(this.externalProjection,this.internalProjection);e=new OpenLayers.Feature.Vector(h,c[d].tags);e.osm_id=parseInt(c[d].id);e.fid="way."+e.osm_id;a[d]=e}for(var j in b){h=b[j];if(!h.used||this.checkTags){c=null;if(this.checkTags){c=this.getTags(h.node,!0);if(h.used&&!c[1])continue;c=c[0]}else c=this.getTags(h.node);
+e=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(h.lon,h.lat),c);this.internalProjection&&this.externalProjection&&e.geometry.transform(this.externalProjection,this.internalProjection);e.osm_id=parseInt(j);e.fid="node."+e.osm_id;a.push(e)}h.node=null}return a},getNodes:function(a){for(var a=a.getElementsByTagName("node"),b={},c=0;c<a.length;c++){var d=a[c],e=d.getAttribute("id");b[e]={lat:d.getAttribute("lat"),lon:d.getAttribute("lon"),node:d}}return b},getWays:function(a){for(var a=
+a.getElementsByTagName("way"),b=[],c=0;c<a.length;c++){var d=a[c],e={id:d.getAttribute("id")};e.tags=this.getTags(d);d=d.getElementsByTagName("nd");e.nodes=Array(d.length);for(var f=0;f<d.length;f++)e.nodes[f]=d[f].getAttribute("ref");b.push(e)}return b},getTags:function(a,b){for(var c=a.getElementsByTagName("tag"),d={},e=!1,f=0;f<c.length;f++){var g=c[f].getAttribute("k");d[g]=c[f].getAttribute("v");b&&(this.interestingTagsExclude[g]||(e=!0))}return b?[d,e]:d},isWayArea:function(a){var b=!1,c=!1;
+a.nodes[0]==a.nodes[a.nodes.length-1]&&(b=!0);if(this.checkTags)for(var d in a.tags)if(this.areaTags[d]){c=!0;break}return b&&(this.checkTags?c:!0)},write:function(a){OpenLayers.Util.isArray(a)||(a=[a]);this.osm_id=1;this.created_nodes={};var b=this.createElementNS(null,"osm");b.setAttribute("version","0.5");b.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var c=a.length-1;0<=c;c--)for(var d=this.createFeatureNodes(a[c]),e=0;e<d.length;e++)b.appendChild(d[e]);return OpenLayers.Format.XML.prototype.write.apply(this,
+[b])},createFeatureNodes:function(a){var b=[],c=a.geometry.CLASS_NAME,c=c.substring(c.lastIndexOf(".")+1),c=c.toLowerCase();(c=this.createXML[c])&&(b=c.apply(this,[a]));return b},createXML:{point:function(a){var b=null,c=a.geometry?a.geometry:a;this.internalProjection&&this.externalProjection&&(c=c.clone(),c.transform(this.internalProjection,this.externalProjection));var d=!1;a.osm_id?(b=a.osm_id,this.created_nodes[b]&&(d=!0)):(b=-this.osm_id,this.osm_id++);var e=d?this.created_nodes[b]:this.createElementNS(null,
+"node");this.created_nodes[b]=e;e.setAttribute("id",b);e.setAttribute("lon",c.x);e.setAttribute("lat",c.y);a.attributes&&this.serializeTags(a,e);this.setState(a,e);return d?[]:[e]},linestring:function(a){var b,c=[],d=a.geometry;a.osm_id?b=a.osm_id:(b=-this.osm_id,this.osm_id++);var e=this.createElementNS(null,"way");e.setAttribute("id",b);for(b=0;b<d.components.length;b++){var f=this.createXML.point.apply(this,[d.components[b]]);if(f.length){var f=f[0],g=f.getAttribute("id");c.push(f)}else g=d.components[b].osm_id,
+f=this.created_nodes[g];this.setState(a,f);f=this.createElementNS(null,"nd");f.setAttribute("ref",g);e.appendChild(f)}this.serializeTags(a,e);c.push(e);return c},polygon:function(a){var b=OpenLayers.Util.extend({area:"yes"},a.attributes),b=new OpenLayers.Feature.Vector(a.geometry.components[0],b);b.osm_id=a.osm_id;return this.createXML.linestring.apply(this,[b])}},serializeTags:function(a,b){for(var c in a.attributes){var d=this.createElementNS(null,"tag");d.setAttribute("k",c);d.setAttribute("v",
+a.attributes[c]);b.appendChild(d)}},setState:function(a,b){if(a.state){var c=null;switch(a.state){case OpenLayers.State.UPDATE:case OpenLayers.State.DELETE:c="delete"}c&&b.setAttribute("action",c)}},CLASS_NAME:"OpenLayers.Format.OSM"});
+OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!0,dragging:!1,touch:!1,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:!1,documentEvents:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(!0===this.documentDrag){var d=this;this._docMove=function(a){d.mousemove({xy:{x:a.clientX,y:a.clientY},element:document})};this._docUp=function(a){d.mouseup({xy:{x:a.clientX,y:a.clientY}})}}},
+dragstart:function(a){var b=!0;this.dragging=!1;if(this.checkModifiers(a)&&(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))){this.started=!0;this.last=this.start=a.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(a);this.callback("down",[a.xy]);OpenLayers.Event.stop(a);if(!this.oldOnselectstart)this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;document.onselectstart=OpenLayers.Function.False;b=!this.stopDown}else this.started=
+!1,this.last=this.start=null;return b},dragmove:function(a){this.lastMoveEvt=a;if(this.started&&!this.timeoutId&&(a.xy.x!=this.last.x||a.xy.y!=this.last.y)){!0===this.documentDrag&&this.documentEvents&&(a.element===document?(this.adjustXY(a),this.setEvent(a)):this.removeDocumentEvents());if(0<this.interval)this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);this.dragging=!0;this.move(a);this.callback("move",[a.xy]);if(!this.oldOnselectstart)this.oldOnselectstart=
+document.onselectstart,document.onselectstart=OpenLayers.Function.False;this.last=a.xy}return!0},dragend:function(a){if(this.started){!0===this.documentDrag&&this.documentEvents&&(this.adjustXY(a),this.removeDocumentEvents());var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(a);this.callback("up",[a.xy]);b&&this.callback("done",[a.xy]);document.onselectstart=this.oldOnselectstart}return!0},down:function(){},move:function(){},
+up:function(){},out:function(){},mousedown:function(a){return this.dragstart(a)},touchstart:function(a){if(!this.touch)this.touch=!0,this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,scope:this});return this.dragstart(a)},mousemove:function(a){return this.dragmove(a)},touchmove:function(a){return this.dragmove(a)},removeTimeout:function(){this.timeoutId=null;this.dragging&&this.mousemove(this.lastMoveEvt)},mouseup:function(a){return this.dragend(a)},
+touchend:function(a){a.xy=this.last;return this.dragend(a)},mouseout:function(a){if(this.started&&OpenLayers.Util.mouseLeft(a,this.map.eventsDiv))if(!0===this.documentDrag)this.addDocumentEvents();else{var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(a);this.callback("out",[]);b&&this.callback("done",[a.xy]);if(document.onselectstart)document.onselectstart=this.oldOnselectstart}return!0},click:function(){return this.start==
+this.last},activate:function(){var a=!1;if(OpenLayers.Handler.prototype.activate.apply(this,arguments))this.dragging=!1,a=!0;return a},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.dragging=this.started=this.touch=!1,this.last=this.start=null,a=!0,OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");return a},adjustXY:function(a){var b=OpenLayers.Util.pagePosition(this.map.viewPortDiv);a.xy.x-=b[0];a.xy.y-=b[1]},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,
+"olDragDown");this.documentEvents=!0;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp)},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=!1;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp)},CLASS_NAME:"OpenLayers.Handler.Drag"});
+OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{click:{"in":"click",out:"clickout"},mousemove:{"in":"over",out:"out"},dblclick:{"in":"dblclick",out:null},mousedown:{"in":null,out:null},mouseup:{"in":null,out:null},touchstart:{"in":"click",out:"clickout"}},feature:null,lastFeature:null,down:null,up:null,touch:!1,clickTolerance:4,geometryTypes:null,stopClick:!0,stopDown:!0,stopUp:!1,initialize:function(a,b,c,d){OpenLayers.Handler.prototype.initialize.apply(this,[a,c,d]);this.layer=
+b},touchstart:function(a){if(!this.touch)this.touch=!0,this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});return OpenLayers.Event.isMultiTouch(a)?!0:this.mousedown(a)},touchmove:function(a){OpenLayers.Event.stop(a)},mousedown:function(a){this.down=a.xy;return this.handle(a)?!this.stopDown:!0},mouseup:function(a){this.up=a.xy;return this.handle(a)?!this.stopUp:!0},click:function(a){return this.handle(a)?!this.stopClick:
+!0},mousemove:function(a){if(!this.callbacks.over&&!this.callbacks.out)return!0;this.handle(a);return!0},dblclick:function(a){return!this.handle(a)},geometryTypeMatches:function(a){return null==this.geometryTypes||-1<OpenLayers.Util.indexOf(this.geometryTypes,a.geometry.CLASS_NAME)},handle:function(a){if(this.feature&&!this.feature.layer)this.feature=null;var b=a.type,c=!1,d=!!this.feature,e="click"==b||"dblclick"==b||"touchstart"==b;if((this.feature=this.layer.getFeatureFromEvent(a))&&!this.feature.layer)this.feature=
+null;if(this.lastFeature&&!this.lastFeature.layer)this.lastFeature=null;this.feature?("touchstart"===b&&OpenLayers.Event.stop(a),a=this.feature!=this.lastFeature,this.geometryTypeMatches(this.feature)?(d&&a?(this.lastFeature&&this.triggerCallback(b,"out",[this.lastFeature]),this.triggerCallback(b,"in",[this.feature])):(!d||e)&&this.triggerCallback(b,"in",[this.feature]),this.lastFeature=this.feature,c=!0):(this.lastFeature&&(d&&a||e)&&this.triggerCallback(b,"out",[this.lastFeature]),this.feature=
+null)):this.lastFeature&&(d||e)&&this.triggerCallback(b,"out",[this.lastFeature]);return c},triggerCallback:function(a,b,c){(b=this.EVENTMAP[a][b])&&("click"==a&&this.up&&this.down?Math.sqrt(Math.pow(this.up.x-this.down.x,2)+Math.pow(this.up.y-this.down.y,2))<=this.clickTolerance&&this.callback(b,c):this.callback(b,c))},activate:function(){var a=!1;OpenLayers.Handler.prototype.activate.apply(this,arguments)&&(this.moveLayerToTop(),this.map.events.on({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,
+scope:this}),a=!0);return a},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.moveLayerBack(),this.up=this.down=this.lastFeature=this.feature=null,this.touch=!1,this.map.events.un({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this}),a=!0;return a},handleMapEvents:function(a){("removelayer"==a.type||"order"==a.property)&&this.moveLayerToTop()},moveLayerToTop:function(){this.layer.setZIndex(Math.max(this.map.Z_INDEX_BASE.Feature-
+1,this.layer.getZIndex())+1)},moveLayerBack:function(){var a=this.layer.getZIndex()-1;a>=this.map.Z_INDEX_BASE.Feature?this.layer.setZIndex(a):this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer))},CLASS_NAME:"OpenLayers.Handler.Feature"});
+OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(){},onDrag:function(){},onComplete:function(){},onEnter:function(){},onLeave:function(){},documentDrag:!1,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.layer=a;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,
+up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})}},clickFeature:function(a){if(this.handlers.feature.touch&&!this.over&&this.overFeature(a))this.handlers.drag.dragstart(this.handlers.feature.evt),this.handlers.drag.stopDown=
+!1},clickoutFeature:function(a){if(this.handlers.feature.touch&&this.over)this.outFeature(a),this.handlers.drag.stopDown=!0},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){return this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=!1;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,
+this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},overFeature:function(a){var b=!1;this.handlers.drag.dragging?this.over=this.feature.id==a.id?!0:!1:(this.feature=a,this.handlers.drag.activate(),this.over=b=!0,OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over"),this.onEnter(a));return b},downFeature:function(a){this.lastPixel=a;this.onStart(this.feature,a)},moveFeature:function(a){var b=this.map.getResolution();this.feature.geometry.move(b*
+(a.x-this.lastPixel.x),b*(this.lastPixel.y-a.y));this.layer.drawFeature(this.feature);this.lastPixel=a;this.onDrag(this.feature,a)},upFeature:function(){this.over||this.handlers.drag.deactivate()},doneDragging:function(a){this.onComplete(this.feature,a)},outFeature:function(a){if(this.handlers.drag.dragging){if(this.feature.id==a.id)this.over=!1}else this.over=!1,this.handlers.drag.deactivate(),OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over"),this.onLeave(a),this.feature=
+null},cancel:function(){this.handlers.drag.deactivate();this.over=!1},setMap:function(a){this.handlers.drag.setMap(a);this.handlers.feature.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.DragFeature"});
+OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:!0,initialize:function(a,b){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),select:new OpenLayers.Style(OpenLayers.Feature.Vector.style.select),temporary:new OpenLayers.Style(OpenLayers.Feature.Vector.style.temporary),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(a instanceof OpenLayers.Style)this.styles["default"]=a,this.styles.select=a,this.styles.temporary=a,this.styles["delete"]=
+a;else if("object"==typeof a)for(var c in a)if(a[c]instanceof OpenLayers.Style)this.styles[c]=a[c];else if("object"==typeof a[c])this.styles[c]=new OpenLayers.Style(a[c]);else{this.styles["default"]=new OpenLayers.Style(a);this.styles.select=new OpenLayers.Style(a);this.styles.temporary=new OpenLayers.Style(a);this.styles["delete"]=new OpenLayers.Style(a);break}OpenLayers.Util.extend(this,b)},destroy:function(){for(var a in this.styles)this.styles[a].destroy();this.styles=null},createSymbolizer:function(a,
+b){a||(a=new OpenLayers.Feature.Vector);this.styles[b]||(b="default");a.renderIntent=b;var c={};this.extendDefault&&"default"!=b&&(c=this.styles["default"].createSymbolizer(a));return OpenLayers.Util.extend(c,this.styles[b].createSymbolizer(a))},addUniqueValueRules:function(a,b,c,d){var e=[],f;for(f in c)e.push(new OpenLayers.Rule({symbolizer:c[f],context:d,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:b,value:f})}));this.styles[a].addRules(e)},CLASS_NAME:"OpenLayers.StyleMap"});
+OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!1,isFixed:!1,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:!0,style:null,styleMap:null,strategies:null,protocol:null,renderers:["SVG","VML","Canvas"],renderer:null,rendererOptions:null,geometryType:null,drawn:!1,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);(!this.renderer||!this.renderer.supported())&&this.assignRenderer();if(!this.renderer||!this.renderer.supported())this.renderer=
+null,this.displayError();if(!this.styleMap)this.styleMap=new OpenLayers.StyleMap;this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies)for(var c=0,d=this.strategies.length;c<d;c++)this.strategies[c].setLayer(this)},destroy:function(){if(this.strategies){var a,b,c;for(b=0,c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoDestroy&&a.destroy();this.strategies=null}if(this.protocol)this.protocol.autoDestroy&&this.protocol.destroy(),this.protocol=null;this.destroyFeatures();
+this.unrenderedFeatures=this.selectedFeatures=this.features=null;this.renderer&&this.renderer.destroy();this.drawn=this.geometryType=this.renderer=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Vector(this.name,this.getOptions()));for(var a=OpenLayers.Layer.prototype.clone.apply(this,[a]),b=this.features,c=b.length,d=Array(c),e=0;e<c;++e)d[e]=b[e].clone();a.features=d;return a},refresh:function(a){this.calculateInRange()&&this.visibility&&
+this.events.triggerEvent("refresh",a)},assignRenderer:function(){for(var a=0,b=this.renderers.length;a<b;a++){var c=this.renderers[a];if((c="function"==typeof c?c:OpenLayers.Renderer[c])&&c.prototype.supported()){this.renderer=new c(this.div,this.rendererOptions);break}}},displayError:function(){this.reportError&&OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{renderers:this.renderers.join("\n")}))},setMap:function(a){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.renderer?
+(this.renderer.map=this.map,this.renderer.setSize(this.map.getSize())):this.map.removeLayer(this)},afterAdd:function(){if(this.strategies){var a,b,c;for(b=0,c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoActivate&&a.activate()}},removeMap:function(){this.drawn=!1;if(this.strategies){var a,b,c;for(b=0,c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoActivate&&a.deactivate()}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize())},
+moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var d=OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG;if(d)c||this.renderer.updateDimensions(b);else{var e=!0;if(!c){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";e=this.renderer.setExtent(this.map.getExtent(),b);this.renderer.root.style.visibility="visible";
+if(!0===OpenLayers.IS_GECKO)this.div.scrollLeft=this.div.scrollLeft;if(!b&&e)for(var f in this.unrenderedFeatures){var g=this.unrenderedFeatures[f];this.drawFeature(g)}}}if(!this.drawn||!d&&(b||!e)){this.drawn=!0;f=0;for(d=this.features.length;f<d;f++)this.renderer.locked=f!==d-1,g=this.features[f],this.drawFeature(g)}},redraw:function(){if(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG)this.drawn=!1;return OpenLayers.Layer.prototype.redraw.apply(this,arguments)},display:function(a){OpenLayers.Layer.prototype.display.apply(this,
+arguments);var b=this.div.style.display;if(b!=this.renderer.root.style.display)this.renderer.root.style.display=b},addFeatures:function(a,b){OpenLayers.Util.isArray(a)||(a=[a]);var c=!b||!b.silent;if(c){var d={features:a};if(!1===this.events.triggerEvent("beforefeaturesadded",d))return;a=d.features}for(var d=[],e=0,f=a.length;e<f;e++){this.renderer.locked=e!=a.length-1?!0:!1;var g=a[e];if(this.geometryType&&!(g.geometry instanceof this.geometryType))throw new TypeError("addFeatures: component should be an "+
+this.geometryType.prototype.CLASS_NAME);g.layer=this;if(!g.style&&this.style)g.style=OpenLayers.Util.extend({},this.style);if(c){if(!1===this.events.triggerEvent("beforefeatureadded",{feature:g}))continue;this.preFeatureInsert(g)}d.push(g);this.features.push(g);this.drawFeature(g);c&&(this.events.triggerEvent("featureadded",{feature:g}),this.onFeatureInsert(g))}c&&this.events.triggerEvent("featuresadded",{features:d})},removeFeatures:function(a,b){if(a&&0!==a.length){if(a===this.features)return this.removeAllFeatures(b);
+OpenLayers.Util.isArray(a)||(a=[a]);a===this.selectedFeatures&&(a=a.slice());var c=!b||!b.silent;c&&this.events.triggerEvent("beforefeaturesremoved",{features:a});for(var d=a.length-1;0<=d;d--){this.renderer.locked=0!=d&&a[d-1].geometry?!0:!1;var e=a[d];delete this.unrenderedFeatures[e.id];c&&this.events.triggerEvent("beforefeatureremoved",{feature:e});this.features=OpenLayers.Util.removeItem(this.features,e);e.layer=null;e.geometry&&this.renderer.eraseFeatures(e);-1!=OpenLayers.Util.indexOf(this.selectedFeatures,
+e)&&OpenLayers.Util.removeItem(this.selectedFeatures,e);c&&this.events.triggerEvent("featureremoved",{feature:e})}c&&this.events.triggerEvent("featuresremoved",{features:a})}},removeAllFeatures:function(a){var a=!a||!a.silent,b=this.features;a&&this.events.triggerEvent("beforefeaturesremoved",{features:b});for(var c,d=b.length-1;0<=d;d--)c=b[d],a&&this.events.triggerEvent("beforefeatureremoved",{feature:c}),c.layer=null,a&&this.events.triggerEvent("featureremoved",{feature:c});this.renderer.clear();
+this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];a&&this.events.triggerEvent("featuresremoved",{features:b})},destroyFeatures:function(a,b){if(void 0==a)a=this.features;if(a){this.removeFeatures(a,b);for(var c=a.length-1;0<=c;c--)a[c].destroy()}},drawFeature:function(a,b){if(this.drawn){if("object"!=typeof b){!b&&a.state===OpenLayers.State.DELETE&&(b="delete");var c=b||a.renderIntent;(b=a.style||this.style)||(b=this.styleMap.createSymbolizer(a,c))}c=this.renderer.drawFeature(a,
+b);!1===c||null===c?this.unrenderedFeatures[a.id]=a:delete this.unrenderedFeatures[a.id]}},eraseFeatures:function(a){this.renderer.eraseFeatures(a)},getFeatureFromEvent:function(a){if(!this.renderer)throw Error("getFeatureFromEvent called on layer with no renderer. This usually means you destroyed a layer, but not some handler which is associated with it.");var b=null;(a=this.renderer.getFeatureIdFromEvent(a))&&(b="string"===typeof a?this.getFeatureById(a):a);return b},getFeatureBy:function(a,b){for(var c=
+null,d=0,e=this.features.length;d<e;++d)if(this.features[d][a]==b){c=this.features[d];break}return c},getFeatureById:function(a){return this.getFeatureBy("id",a)},getFeatureByFid:function(a){return this.getFeatureBy("fid",a)},getFeaturesByAttribute:function(a,b){var c,d,e=this.features.length,f=[];for(c=0;c<e;c++)(d=this.features[c])&&d.attributes&&d.attributes[a]===b&&f.push(d);return f},onFeatureInsert:function(){},preFeatureInsert:function(){},getDataExtent:function(){var a=null,b=this.features;
+if(b&&0<b.length)for(var c=null,d=0,e=b.length;d<e;d++)if(c=b[d].geometry)null===a&&(a=new OpenLayers.Bounds),a.extend(c.getBounds());return a},CLASS_NAME:"OpenLayers.Layer.Vector"});
+OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:!1,layers:null,display:function(){},getFeatureFromEvent:function(a){for(var b=this.layers,c,d=0;d<b.length;d++)if(c=b[d].getFeatureFromEvent(a))return c},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();a.events.register("changelayer",this,this.handleChangeLayer)},removeMap:function(a){a.events.unregister("changelayer",this,this.handleChangeLayer);
+this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments)},collectRoots:function(){for(var a,b=0;b<this.map.layers.length;++b)a=this.map.layers[b],-1!=OpenLayers.Util.indexOf(this.layers,a)&&a.renderer.moveRoot(this.renderer)},resetRoots:function(){for(var a,b=0;b<this.layers.length;++b)a=this.layers[b],this.renderer&&a.renderer.getRenderLayerId()==this.id&&this.renderer.moveRoot(a.renderer)},handleChangeLayer:function(a){var b=a.layer;"order"==a.property&&-1!=OpenLayers.Util.indexOf(this.layers,
+b)&&(this.resetRoots(),this.collectRoots())},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});
+OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:!1,clickout:!0,toggle:!1,hover:!1,highlightOnly:!1,box:!1,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);if(null===this.scope)this.scope=this;this.initLayer(a);var c=
+{click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover)c.over=this.overFeature,c.out=this.outFeature;this.callbacks=OpenLayers.Util.extend(c,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box)this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"})},initLayer:function(a){OpenLayers.Util.isArray(a)?(this.layers=a,this.layer=
+new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:a})):this.layer=a},destroy:function(){this.active&&this.layers&&this.map.removeLayer(this.layer);OpenLayers.Control.prototype.destroy.apply(this,arguments);this.layers&&this.layer.destroy()},activate:function(){this.active||(this.layers&&this.map.addLayer(this.layer),this.handlers.feature.activate(),this.box&&this.handlers.box&&this.handlers.box.activate());return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.active&&
+(this.handlers.feature.deactivate(),this.handlers.box&&this.handlers.box.deactivate(),this.layers&&this.map.removeLayer(this.layer));return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},unselectAll:function(a){for(var b=this.layers||[this.layer],c,d,e=0;e<b.length;++e){c=b[e];for(var f=c.selectedFeatures.length-1;0<=f;--f)d=c.selectedFeatures[f],(!a||a.except!=d)&&this.unselect(d)}},clickFeature:function(a){this.hover||(-1<OpenLayers.Util.indexOf(a.layer.selectedFeatures,a)?this.toggleSelect()?
+this.unselect(a):this.multipleSelect()||this.unselectAll({except:a}):(this.multipleSelect()||this.unselectAll({except:a}),this.select(a)))},multipleSelect:function(){return this.multiple||this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]},toggleSelect:function(){return this.toggle||this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]},clickoutFeature:function(){!this.hover&&this.clickout&&this.unselectAll()},overFeature:function(a){var b=a.layer;this.hover&&(this.highlightOnly?
+this.highlight(a):-1==OpenLayers.Util.indexOf(b.selectedFeatures,a)&&this.select(a))},outFeature:function(a){if(this.hover)if(this.highlightOnly){if(a._lastHighlighter==this.id)if(a._prevHighlighter&&a._prevHighlighter!=this.id){delete a._lastHighlighter;var b=this.map.getControl(a._prevHighlighter);b&&b.highlight(a)}else this.unhighlight(a)}else this.unselect(a)},highlight:function(a){var b=a.layer;if(!1!==this.events.triggerEvent("beforefeaturehighlighted",{feature:a}))a._prevHighlighter=a._lastHighlighter,
+a._lastHighlighter=this.id,b.drawFeature(a,this.selectStyle||this.renderIntent),this.events.triggerEvent("featurehighlighted",{feature:a})},unhighlight:function(a){var b=a.layer;if(void 0==a._prevHighlighter)delete a._lastHighlighter;else{if(a._prevHighlighter!=this.id)a._lastHighlighter=a._prevHighlighter;delete a._prevHighlighter}b.drawFeature(a,a.style||a.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:a})},select:function(a){var b=this.onBeforeSelect.call(this.scope,
+a),c=a.layer;if(!1!==b&&(b=c.events.triggerEvent("beforefeatureselected",{feature:a}),!1!==b)){c.selectedFeatures.push(a);this.highlight(a);if(!this.handlers.feature.lastFeature)this.handlers.feature.lastFeature=c.selectedFeatures[0];c.events.triggerEvent("featureselected",{feature:a});this.onSelect.call(this.scope,a)}},unselect:function(a){var b=a.layer;this.unhighlight(a);OpenLayers.Util.removeItem(b.selectedFeatures,a);b.events.triggerEvent("featureunselected",{feature:a});this.onUnselect.call(this.scope,
+a)},selectBox:function(a){if(a instanceof OpenLayers.Bounds){var b=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.left,a.bottom)),a=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.right,a.top)),b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat);this.multipleSelect()||this.unselectAll();a=this.multiple;this.multiple=!0;for(var c=this.layers||[this.layer],d,e=0;e<c.length;++e){d=c[e];for(var f=0,g=d.features.length;f<g;++f){var h=d.features[f];h.getVisibility()&&(null==this.geometryTypes||-1<OpenLayers.Util.indexOf(this.geometryTypes,
+h.geometry.CLASS_NAME))&&b.toGeometry().intersects(h.geometry)&&-1==OpenLayers.Util.indexOf(d.selectedFeatures,h)&&this.select(h)}}this.multiple=a}},setMap:function(a){this.handlers.feature.setMap(a);this.box&&this.handlers.box.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},setLayer:function(a){var b=this.active;this.unselectAll();this.deactivate();if(this.layers)this.layer.destroy(),this.layers=null;this.initLayer(a);this.handlers.feature.layer=this.layer;b&&this.activate()},
+CLASS_NAME:"OpenLayers.Control.SelectFeature"});
+OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this)},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments)},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var a=
+0,b=this.KEY_EVENTS.length;a<b;a++)OpenLayers.Event.observe(document,this.KEY_EVENTS[a],this.eventListener);return!0}return!1},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var a=0,b=this.KEY_EVENTS.length;a<b;a++)OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[a],this.eventListener);a=!0}return a},handleKeyEvent:function(a){this.checkModifiers(a)&&this.callback(a.type,[a])},CLASS_NAME:"OpenLayers.Handler.Keyboard"});
+OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:!0,toggle:!0,standalone:!1,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:!1,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(a,b){b=b||{};this.layer=a;this.vertices=
+[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,b.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[b]);if(!OpenLayers.Util.isArray(this.deleteCodes))this.deleteCodes=[this.deleteCodes];var c=this,d={geometryTypes:this.geometryTypes,clickout:this.clickout,
+toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(!1===this.standalone)this.selectControl=new OpenLayers.Control.SelectFeature(a,d);this.dragControl=new OpenLayers.Control.DragFeature(a,{geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(a,b){c.dragStart.apply(c,[a,b])},onDrag:function(a,b){c.dragVertex.apply(c,[a,b])},onComplete:function(a){c.dragComplete.apply(c,[a])},
+featureCallbacks:{over:function(a){(!0!==c.standalone||a._sketch||c.feature===a)&&c.dragControl.overFeature.apply(c.dragControl,[a])}}});this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,{keydown:this.handleKeypress})}},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){return(this.standalone||this.selectControl.activate())&&this.handlers.keyboard.activate()&&
+OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){var a=!1;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:!0});this.layer.removeFeatures(this.virtualVertices,{silent:!0});this.vertices=[];this.dragControl.deactivate();var b=(a=this.feature)&&a.geometry&&a.layer;!1===this.standalone?(b&&this.selectControl.unselect.apply(this.selectControl,[a]),this.selectControl.deactivate()):b&&this.unselectFeature(a);
+this.handlers.keyboard.deactivate();a=!0}return a},beforeSelectFeature:function(a){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:a})},selectFeature:function(a){if(!this.standalone||!1!==this.beforeSelectFeature(a))this.feature=a,this.modified=!1,this.resetVertices(),this.dragControl.activate(),this.onModificationStart(this.feature);var b=a.modified;if(a.geometry&&(!b||!b.geometry))this._originalGeometry=a.geometry.clone()},unselectFeature:function(a){this.layer.removeFeatures(this.vertices,
+{silent:!0});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:!0});this.virtualVertices=[];this.dragHandle&&(this.layer.destroyFeatures([this.dragHandle],{silent:!0}),delete this.dragHandle);this.radiusHandle&&(this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),delete this.radiusHandle);this.feature=null;this.dragControl.deactivate();this.onModificationEnd(a);this.layer.events.triggerEvent("afterfeaturemodified",{feature:a,modified:this.modified});this.modified=!1},
+dragStart:function(a,b){if(a!=this.feature&&!a.geometry.parent&&a!=this.dragHandle&&a!=this.radiusHandle&&(!1===this.standalone&&this.feature&&this.selectControl.clickFeature.apply(this.selectControl,[this.feature]),null==this.geometryTypes||-1!=OpenLayers.Util.indexOf(this.geometryTypes,a.geometry.CLASS_NAME)))this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[a]),this.dragControl.overFeature.apply(this.dragControl,[a]),this.dragControl.lastPixel=b,this.dragControl.handlers.drag.started=
+!0,this.dragControl.handlers.drag.start=b,this.dragControl.handlers.drag.last=b},dragVertex:function(a,b){this.modified=!0;if("OpenLayers.Geometry.Point"==this.feature.geometry.CLASS_NAME){if(this.feature!=a)this.feature=a;this.layer.events.triggerEvent("vertexmodified",{vertex:a.geometry,feature:this.feature,pixel:b})}else{if(a._index)a.geometry.parent.addComponent(a.geometry,a._index),delete a._index,OpenLayers.Util.removeItem(this.virtualVertices,a),this.vertices.push(a);else if(a==this.dragHandle){if(this.layer.removeFeatures(this.vertices,
+{silent:!0}),this.vertices=[],this.radiusHandle)this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),this.radiusHandle=null}else a!==this.radiusHandle&&this.layer.events.triggerEvent("vertexmodified",{vertex:a.geometry,feature:this.feature,pixel:b});if(0<this.virtualVertices.length)this.layer.destroyFeatures(this.virtualVertices,{silent:!0}),this.virtualVertices=[];this.layer.drawFeature(this.feature,this.standalone?void 0:this.selectControl.renderIntent)}this.layer.drawFeature(a)},dragComplete:function(){this.resetVertices();
+this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature})},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE&&(this.feature.state=OpenLayers.State.UPDATE,this.modified&&this._originalGeometry)){var a=this.feature;a.modified=OpenLayers.Util.extend(a.modified,{geometry:this._originalGeometry});delete this._originalGeometry}},resetVertices:function(){this.dragControl.feature&&
+this.dragControl.outFeature(this.dragControl.feature);if(0<this.vertices.length)this.layer.removeFeatures(this.vertices,{silent:!0}),this.vertices=[];if(0<this.virtualVertices.length)this.layer.removeFeatures(this.virtualVertices,{silent:!0}),this.virtualVertices=[];if(this.dragHandle)this.layer.destroyFeatures([this.dragHandle],{silent:!0}),this.dragHandle=null;if(this.radiusHandle)this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),this.radiusHandle=null;this.feature&&"OpenLayers.Geometry.Point"!=
+this.feature.geometry.CLASS_NAME&&(this.mode&OpenLayers.Control.ModifyFeature.DRAG&&this.collectDragHandle(),this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE)&&this.collectRadiusHandle(),this.mode&OpenLayers.Control.ModifyFeature.RESHAPE&&(this.mode&OpenLayers.Control.ModifyFeature.RESIZE||this.collectVertices()))},handleKeypress:function(a){var b=a.keyCode;if(this.feature&&-1!=OpenLayers.Util.indexOf(this.deleteCodes,b)&&(b=this.dragControl.feature)&&-1!=
+OpenLayers.Util.indexOf(this.vertices,b)&&!this.dragControl.handlers.drag.dragging&&b.geometry.parent)b.geometry.parent.removeComponent(b.geometry),this.layer.events.triggerEvent("vertexremoved",{vertex:b.geometry,feature:this.feature,pixel:a.xy}),this.layer.drawFeature(this.feature,this.standalone?void 0:this.selectControl.renderIntent),this.modified=!0,this.resetVertices(),this.setFeatureState(),this.onModification(this.feature),this.layer.events.triggerEvent("featuremodified",{feature:this.feature})},
+collectVertices:function(){function a(c){var d,e,f;if("OpenLayers.Geometry.Point"==c.CLASS_NAME)e=new OpenLayers.Feature.Vector(c),e._sketch=!0,e.renderIntent=b.vertexRenderIntent,b.vertices.push(e);else{f=c.components.length;"OpenLayers.Geometry.LinearRing"==c.CLASS_NAME&&(f-=1);for(d=0;d<f;++d)e=c.components[d],"OpenLayers.Geometry.Point"==e.CLASS_NAME?(e=new OpenLayers.Feature.Vector(e),e._sketch=!0,e.renderIntent=b.vertexRenderIntent,b.vertices.push(e)):a(e);if("OpenLayers.Geometry.MultiPoint"!=
+c.CLASS_NAME)for(d=0,f=c.components.length;d<f-1;++d){e=c.components[d];var g=c.components[d+1];if("OpenLayers.Geometry.Point"==e.CLASS_NAME&&"OpenLayers.Geometry.Point"==g.CLASS_NAME)e=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point((e.x+g.x)/2,(e.y+g.y)/2),null,b.virtualStyle),e.geometry.parent=c,e._index=d+1,e._sketch=!0,b.virtualVertices.push(e)}}}this.vertices=[];this.virtualVertices=[];var b=this;a.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:!0});
+this.layer.addFeatures(this.vertices,{silent:!0})},collectDragHandle:function(){var a=this.feature.geometry,b=a.getBounds().getCenterLonLat(),b=new OpenLayers.Geometry.Point(b.lon,b.lat),c=new OpenLayers.Feature.Vector(b);b.move=function(b,c){OpenLayers.Geometry.Point.prototype.move.call(this,b,c);a.move(b,c)};c._sketch=!0;this.dragHandle=c;this.layer.addFeatures([this.dragHandle],{silent:!0})},collectRadiusHandle:function(){var a=this.feature.geometry,b=a.getBounds(),c=b.getCenterLonLat(),d=new OpenLayers.Geometry.Point(c.lon,
+c.lat),b=new OpenLayers.Geometry.Point(b.right,b.bottom),c=new OpenLayers.Feature.Vector(b),e=this.mode&OpenLayers.Control.ModifyFeature.RESIZE,f=this.mode&OpenLayers.Control.ModifyFeature.RESHAPE,g=this.mode&OpenLayers.Control.ModifyFeature.ROTATE;b.move=function(b,c){OpenLayers.Geometry.Point.prototype.move.call(this,b,c);var j=this.x-d.x,k=this.y-d.y,m=j-b,n=k-c;if(g){var l=Math.atan2(n,m),l=Math.atan2(k,j)-l,l=l*(180/Math.PI);a.rotate(l,d)}if(e){var o;f?(k/=n,o=j/m/k):(m=Math.sqrt(m*m+n*n),k=
+Math.sqrt(j*j+k*k)/m);a.resize(k,d,o)}};c._sketch=!0;this.radiusHandle=c;this.layer.addFeatures([this.radiusHandle],{silent:!0})},setMap:function(a){this.standalone||this.selectControl.setMap(a);this.dragControl.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;
+OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338,0.07464553542435169],attributionTemplate:'<span class="olBingAttribution ${type}"><div><a target="_blank" href="http://www.bing.com/maps/"><img src="${logo}" /></a></div>${copyrights}<a style="white-space: nowrap" target="_blank" href="http://www.microsoft.com/maps/product/terms.html">Terms of Use</a></span>',
+metadata:null,type:"Road",metadataParams:null,initialize:function(a){a=OpenLayers.Util.applyDefaults({sphericalMercator:!0},a);OpenLayers.Layer.XYZ.prototype.initialize.apply(this,[a.name||"Bing "+(a.type||this.type),null,a]);this.loadMetadata()},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var a=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},
+this.metadataParams),a="http://dev.virtualearth.net/REST/v1/Imagery/Metadata/"+this.type+"?"+OpenLayers.Util.getParameterString(a),b=document.createElement("script");b.type="text/javascript";b.src=a;b.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(b)},initLayer:function(){var a=this.metadata.resourceSets[0].resources[0],b=a.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var c=0;c<a.imageUrlSubdomains.length;++c)this.url.push(b.replace("{subdomain}",a.imageUrlSubdomains[c]));
+this.addOptions({maxResolution:Math.min(this.serverResolutions[a.zoomMin],this.maxResolution),zoomOffset:a.zoomMin,numZoomLevels:Math.min(a.zoomMax+1-a.zoomMin,this.numZoomLevels)},!0)},getURL:function(a){if(this.url){for(var b=this.getXYZ(a),a=b.x,c=b.y,b=b.z,d=[],e=b;0<e;--e){var f="0",g=1<<e-1;0!=(a&g)&&f++;0!=(c&g)&&(f++,f++);d.push(f)}d=d.join("");a=this.selectUrl(""+a+c+b,this.url);return OpenLayers.String.format(a,{quadkey:d})}},updateAttribution:function(){var a=this.metadata;if(a&&this.map&&
+this.map.center){var b=a.resourceSets[0].resources[0],c=this.map.getExtent().transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326")),b=b.imageryProviders,d=this.map.getZoom()+1,e="",f,g,h,i,j,k,m;for(g=0,h=b.length;g<h;++g){f=b[g];for(i=0,j=f.coverageAreas.length;i<j;++i)m=f.coverageAreas[i],k=OpenLayers.Bounds.fromArray(m.bbox),c.intersectsBounds(k)&&d<=m.zoomMax&&d>=m.zoomMin&&(e+=f.attribution+" ")}this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),
+logo:a.brandLogoUri,copyrights:e});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"})}},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Bing(this.options));return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);
+OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(a){this.metadata=a;this.initLayer();a=document.getElementById(this._callbackId);a.parentNode.removeChild(a);window[this._callbackId]=void 0;delete this._callbackId};
+OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={features:[]};this.readNode(a,b);for(var a=[],c=0,d=b.features.length;c<d;c++){var e=b.features[c];this.internalProjection&&this.externalProjection&&e.components[0]&&e.components[0].transform(this.externalProjection,this.internalProjection);e=new OpenLayers.Feature.Vector(e.components[0],e.attributes);a.push(e)}return a},readers:{sa:{SamplingPoint:function(a,b){if(!b.attributes){var c=
+{attributes:{}};b.features.push(c);b=c}b.attributes.id=this.getAttributeNS(a,this.namespaces.gml,"id");this.readChildNodes(a,b)},position:function(a,b){this.readChildNodes(a,b)}},gml:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,b){this.readChildNodes(a,b)},featureMember:function(a,b){var c={attributes:{}};b.features.push(c);this.readChildNodes(a,c)},name:function(a,b){b.attributes.name=this.getChildValue(a)},pos:function(a,b){if(!this.externalProjection)this.externalProjection=new OpenLayers.Projection(a.getAttribute("srsName"));
+OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[a,b])}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{sos:{GetFeatureOfInterest:function(a){for(var b=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:"SOS","xsi:schemaLocation":this.schemaLocation}}),c=0,d=a.fois.length;c<d;c++)this.writeNode("FeatureOfInterestId",{foi:a.fois[c]},b);return b},FeatureOfInterestId:function(a){return this.createElementNSPlus("FeatureOfInterestId",{value:a.foi})}}},
+CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});
+OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
+defaultPrefix:"sos",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={measurements:[],observations:[]};this.readNode(a,b);return b},write:function(a){a=this.writeNode("sos:GetObservation",a);a.setAttribute("xmlns:om",this.namespaces.om);a.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,
+[a])},readers:{om:{ObservationCollection:function(a,b){b.id=this.getAttributeNS(a,this.namespaces.gml,"id");this.readChildNodes(a,b)},member:function(a,b){this.readChildNodes(a,b)},Measurement:function(a,b){var c={};b.measurements.push(c);this.readChildNodes(a,c)},Observation:function(a,b){var c={};b.observations.push(c);this.readChildNodes(a,c)},samplingTime:function(a,b){var c={};b.samplingTime=c;this.readChildNodes(a,c)},observedProperty:function(a,b){b.observedProperty=this.getAttributeNS(a,this.namespaces.xlink,
+"href");this.readChildNodes(a,b)},procedure:function(a,b){b.procedure=this.getAttributeNS(a,this.namespaces.xlink,"href");this.readChildNodes(a,b)},featureOfInterest:function(a,b){var c={features:[]};b.fois=[];b.fois.push(c);this.readChildNodes(a,c);for(var d=[],e=0,f=c.features.length;e<f;e++){var g=c.features[e];d.push(new OpenLayers.Feature.Vector(g.components[0],g.attributes))}c.features=d},result:function(a,b){var c={};b.result=c;""!==this.getChildValue(a)?(c.value=this.getChildValue(a),c.uom=
+a.getAttribute("uom")):this.readChildNodes(a,c)}},sa:OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,gml:OpenLayers.Util.applyDefaults({TimeInstant:function(a,b){var c={};b.timeInstant=c;this.readChildNodes(a,c)},timePosition:function(a,b){b.timePosition=this.getChildValue(a)}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{sos:{GetObservation:function(a){var b=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:"SOS"}});this.writeNode("offering",
+a,b);a.eventTime&&this.writeNode("eventTime",a,b);for(var c in a.procedures)this.writeNode("procedure",a.procedures[c],b);for(var d in a.observedProperties)this.writeNode("observedProperty",a.observedProperties[d],b);a.foi&&this.writeNode("featureOfInterest",a.foi,b);this.writeNode("responseFormat",a,b);a.resultModel&&this.writeNode("resultModel",a,b);a.responseMode&&this.writeNode("responseMode",a,b);return b},featureOfInterest:function(a){var b=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",
+a.objectId,b);return b},ObjectID:function(a){return this.createElementNSPlus("ObjectID",{value:a})},responseFormat:function(a){return this.createElementNSPlus("responseFormat",{value:a.responseFormat})},procedure:function(a){return this.createElementNSPlus("procedure",{value:a})},offering:function(a){return this.createElementNSPlus("offering",{value:a.offering})},observedProperty:function(a){return this.createElementNSPlus("observedProperty",{value:a})},eventTime:function(a){var b=this.createElementNSPlus("eventTime");
+"latest"===a.eventTime&&this.writeNode("ogc:TM_Equals",a,b);return b},resultModel:function(a){return this.createElementNSPlus("resultModel",{value:a.resultModel})},responseMode:function(a){return this.createElementNSPlus("responseMode",{value:a.responseMode})}},ogc:{TM_Equals:function(a){var b=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},b);"latest"===a.eventTime&&this.writeNode("gml:TimeInstant",{value:"latest"},b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",
+{value:a.property})}},gml:{TimeInstant:function(a){var b=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",a,b);return b},timePosition:function(a){return this.createElementNSPlus("gml:timePosition",{value:a.value})}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});
+OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:!0,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this)},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null},onWheelEvent:function(a){if(this.map&&this.checkModifiers(a)){for(var b=!1,c=!1,d=!1,e=
+OpenLayers.Event.element(a);null!=e&&!d&&!b;){if(!b)try{var f=e.currentStyle?e.currentStyle.overflow:document.defaultView.getComputedStyle(e,null).getPropertyValue("overflow"),b=f&&"auto"==f||"scroll"==f}catch(g){}if(!c)for(var d=0,h=this.map.layers.length;d<h;d++)if(e==this.map.layers[d].div||e==this.map.layers[d].pane){c=!0;break}d=e==this.map.div;e=e.parentNode}if(!b&&d){if(c){b=0;if(!a)a=window.event;a.wheelDelta?(b=a.wheelDelta/120,window.opera&&9.2>window.opera.version()&&(b=-b)):a.detail&&
+(b=-a.detail/3);this.delta+=b;this.interval?(window.clearTimeout(this._timeoutId),this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(a)},this),this.interval)):this.wheelZoom(a)}OpenLayers.Event.stop(a)}}},wheelZoom:function(a){var b=this.delta;this.delta=0;if(b){if(this.mousePosition)a.xy=this.mousePosition;if(!a.xy)a.xy=this.map.getPixelFromLonLat(this.map.getCenter());0>b?this.callback("down",[a,this.cumulative?b:-1]):this.callback("up",[a,this.cumulative?b:1])}},
+mousemove:function(a){this.mousePosition=a.xy},activate:function(a){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var b=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",b);OpenLayers.Event.observe(window,"mousewheel",b);OpenLayers.Event.observe(document,"mousewheel",b);return!0}return!1},deactivate:function(a){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var b=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",b);OpenLayers.Event.stopObserving(window,
+"mousewheel",b);OpenLayers.Event.stopObserving(document,"mousewheel",b);return!0}return!1},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});
+OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:!1,schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(a){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[a])},readNode:function(a,b){return OpenLayers.Format.GML.v2.prototype.readNode.apply(this,[a,b])},readers:{wfs:OpenLayers.Util.applyDefaults({WFS_TransactionResponse:function(a,
+b){b.insertIds=[];b.success=!1;this.readChildNodes(a,b)},InsertResult:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds.push(c.fids[0])},TransactionResult:function(a,b){this.readChildNodes(a,b)},Status:function(a,b){this.readChildNodes(a,b)},SUCCESS:function(a,b){b.success=!0}},OpenLayers.Format.WFST.v1.prototype.readers.wfs),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,feature:OpenLayers.Format.GML.v2.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_0_0.prototype.readers.ogc},
+writers:{wfs:OpenLayers.Util.applyDefaults({Query:function(a){var a=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},a),b=a.featurePrefix,c=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(b?b+":":"")+a.featureType}});a.srsNameInQuery&&a.srsName&&c.setAttribute("srsName",a.srsName);a.featureNS&&c.setAttribute("xmlns:"+b,a.featureNS);if(a.propertyNames)for(var b=0,d=a.propertyNames.length;b<
+d;b++)this.writeNode("ogc:PropertyName",{property:a.propertyNames[b]},c);a.filter&&(this.setFilterProperty(a.filter),this.writeNode("ogc:Filter",a.filter,c));return c}},OpenLayers.Format.WFST.v1.prototype.writers.wfs),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Format.GML.v2.prototype.writers.feature,ogc:OpenLayers.Format.Filter.v1_0_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});
+OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(a){this.compare=a?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear()},insert:function(a){this.exists(a)&&this.remove(a);var b=a.id;this.determineZIndex(a);for(var c=-1,d=this.order.length,e;1<d-c;)e=parseInt((c+d)/2),0<this.compare(this,a,OpenLayers.Util.getElement(this.order[e]))?c=e:d=e;this.order.splice(d,
+0,b);this.indices[b]=this.getZIndex(a);return this.getNextElement(d)},remove:function(a){var a=a.id,b=OpenLayers.Util.indexOf(this.order,a);if(0<=b)this.order.splice(b,1),delete this.indices[a],this.maxZIndex=0<this.order.length?this.indices[this.order[this.order.length-1]]:0},clear:function(){this.order=[];this.indices={};this.maxZIndex=0},exists:function(a){return null!=this.indices[a.id]},getZIndex:function(a){return a._style.graphicZIndex},determineZIndex:function(a){var b=a._style.graphicZIndex;
+if(null==b)b=this.maxZIndex,a._style.graphicZIndex=b;else if(b>this.maxZIndex)this.maxZIndex=b},getNextElement:function(a){a+=1;if(a<this.order.length){var b=OpenLayers.Util.getElement(this.order[a]);void 0==b&&(b=this.getNextElement(a));return b}return null},CLASS_NAME:"OpenLayers.ElementsIndexer"});
+OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(a,b,c){var b=a.getZIndex(b),d=0;c&&(a=a.getZIndex(c),d=b-a);return d},Z_ORDER_DRAWING_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);c&&0==a&&(a=1);return a},Z_ORDER_Y_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);c&&0===a&&(b=c._boundsBottom-b._boundsBottom,a=0===b?1:b);return a}};
+OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,xOffset:0,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",initialize:function(a,b){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);
+this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(b&&(b.zIndexing||b.yOrdering))this.indexer=new OpenLayers.ElementsIndexer(b.yOrdering)},destroy:function(){this.clear();this.xmlns=this.root=this.rendererRoot=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments)},clear:function(){var a,b=this.vectorRoot;if(b)for(;a=b.firstChild;)b.removeChild(a);if(b=this.textRoot)for(;a=b.firstChild;)b.removeChild(a);this.indexer&&
+this.indexer.clear()},setExtent:function(a,b){var c=OpenLayers.Renderer.prototype.setExtent.apply(this,arguments),d=this.getResolution();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var c=0===this.featureDx,e,f=this.map.getMaxExtent();f.right>a.left&&f.right<a.right?e=!0:f.left>a.left&&f.left<a.right&&(e=!1);if(e!==this.rightOfDateLine||b)c=!1,this.xOffset=!0===e?f.getWidth()/d:0;this.rightOfDateLine=e}return c},getNodeType:function(){},drawGeometry:function(a,b,c){var d=a.CLASS_NAME,e=
+!0;if("OpenLayers.Geometry.Collection"==d||"OpenLayers.Geometry.MultiPoint"==d||"OpenLayers.Geometry.MultiLineString"==d||"OpenLayers.Geometry.MultiPolygon"==d){for(var d=0,f=a.components.length;d<f;d++)e=this.drawGeometry(a.components[d],b,c)&&e;return e}d=e=!1;"none"!=b.display&&(b.backgroundGraphic?this.redrawBackgroundNode(a.id,a,b,c):d=!0,e=this.redrawNode(a.id,a,b,c));if(!1==e&&(b=document.getElementById(a.id)))b._style.backgroundGraphic&&(d=!0),b.parentNode.removeChild(b);d&&(b=document.getElementById(a.id+
+this.BACKGROUND_ID_SUFFIX))&&b.parentNode.removeChild(b);return e},redrawNode:function(a,b,c,d){c=this.applyDefaultSymbolizer(c);a=this.nodeFactory(a,this.getNodeType(b,c));a._featureId=d;a._boundsBottom=b.getBounds().bottom;a._geometryClass=b.CLASS_NAME;a._style=c;b=this.drawGeometryNode(a,b,c);if(!1===b)return!1;a=b.node;this.indexer?(c=this.indexer.insert(a))?this.vectorRoot.insertBefore(a,c):this.vectorRoot.appendChild(a):a.parentNode!==this.vectorRoot&&this.vectorRoot.appendChild(a);this.postDraw(a);
+return b.complete},redrawBackgroundNode:function(a,b,c){c=OpenLayers.Util.extend({},c);c.externalGraphic=c.backgroundGraphic;c.graphicXOffset=c.backgroundXOffset;c.graphicYOffset=c.backgroundYOffset;c.graphicZIndex=c.backgroundGraphicZIndex;c.graphicWidth=c.backgroundWidth||c.graphicWidth;c.graphicHeight=c.backgroundHeight||c.graphicHeight;c.backgroundGraphic=null;c.backgroundXOffset=null;c.backgroundYOffset=null;c.backgroundGraphicZIndex=null;return this.redrawNode(a+this.BACKGROUND_ID_SUFFIX,b,
+c,null)},drawGeometryNode:function(a,b,c){var c=c||a._style,d={isFilled:void 0===c.fill?!0:c.fill,isStroked:void 0===c.stroke?!!c.strokeWidth:c.stroke},e;switch(b.CLASS_NAME){case "OpenLayers.Geometry.Point":if(!1===c.graphic)d.isFilled=!1,d.isStroked=!1;e=this.drawPoint(a,b);break;case "OpenLayers.Geometry.LineString":d.isFilled=!1;e=this.drawLineString(a,b);break;case "OpenLayers.Geometry.LinearRing":e=this.drawLinearRing(a,b);break;case "OpenLayers.Geometry.Polygon":e=this.drawPolygon(a,b);break;
+case "OpenLayers.Geometry.Surface":e=this.drawSurface(a,b);break;case "OpenLayers.Geometry.Rectangle":e=this.drawRectangle(a,b)}a._options=d;return!1!=e?{node:this.setStyle(a,c,d,b),complete:e}:!1},postDraw:function(){},drawPoint:function(){},drawLineString:function(){},drawLinearRing:function(){},drawPolygon:function(){},drawRectangle:function(){},drawCircle:function(){},drawSurface:function(){},removeText:function(a){(a=document.getElementById(a+this.LABEL_ID_SUFFIX))&&this.textRoot.removeChild(a)},
+getFeatureIdFromEvent:function(a){var b=a.target,c=b&&b.correspondingUseElement;return(c?c:b||a.srcElement)._featureId},eraseGeometry:function(a,b){if("OpenLayers.Geometry.MultiPoint"==a.CLASS_NAME||"OpenLayers.Geometry.MultiLineString"==a.CLASS_NAME||"OpenLayers.Geometry.MultiPolygon"==a.CLASS_NAME||"OpenLayers.Geometry.Collection"==a.CLASS_NAME)for(var c=0,d=a.components.length;c<d;c++)this.eraseGeometry(a.components[c],b);else if((c=OpenLayers.Util.getElement(a.id))&&c.parentNode){if(c.geometry)c.geometry.destroy(),
+c.geometry=null;c.parentNode.removeChild(c);this.indexer&&this.indexer.remove(c);c._style.backgroundGraphic&&(c=OpenLayers.Util.getElement(a.id+this.BACKGROUND_ID_SUFFIX))&&c.parentNode&&c.parentNode.removeChild(c)}},nodeFactory:function(a,b){var c=OpenLayers.Util.getElement(a);c?this.nodeTypeCompare(c,b)||(c.parentNode.removeChild(c),c=this.nodeFactory(a,b)):c=this.createNode(b,a);return c},nodeTypeCompare:function(){},createNode:function(){},moveRoot:function(a){var b=this.root;if(a.root.parentNode==
+this.rendererRoot)b=a.root;b.parentNode.removeChild(b);a.rendererRoot.appendChild(b)},getRenderLayerId:function(){return this.root.parentNode.parentNode.id},isComplexSymbol:function(a){return"circle"!=a&&!!a},CLASS_NAME:"OpenLayers.Renderer.Elements"});
+OpenLayers.Renderer.symbol={star:[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],cross:[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],x:[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],square:[0,0,0,1,1,1,1,0,0,0],triangle:[0,10,10,10,5,0,0,10]};
+OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,getParameters:function(a){var a=a||window.location.href,b=OpenLayers.Util.getParameters(a),c=a.indexOf("#");0<c&&(a="?"+a.substring(c+1,a.length),OpenLayers.Util.extend(b,OpenLayers.Util.getParameters(a)));return b},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var b=0,c=this.map.controls.length;b<c;b++){var d=this.map.controls[b];if(d!=this&&
+"OpenLayers.Control.ArgParser"==d.CLASS_NAME){if(d.displayProjection!=this.displayProjection)this.displayProjection=d.displayProjection;break}}if(b==this.map.controls.length){b=this.getParameters();if(b.layers)this.layers=b.layers,this.map.events.register("addlayer",this,this.configureLayers),this.configureLayers();if(b.lat&&b.lon){this.center=new OpenLayers.LonLat(parseFloat(b.lon),parseFloat(b.lat));if(b.zoom)this.zoom=parseFloat(b.zoom);this.map.events.register("changebaselayer",this,this.setCenter);
+this.setCenter()}}},setCenter:function(){this.map.baseLayer&&(this.map.events.unregister("changebaselayer",this,this.setCenter),this.displayProjection&&this.center.transform(this.displayProjection,this.map.getProjectionObject()),this.map.setCenter(this.center,this.zoom))},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister("addlayer",this,this.configureLayers);for(var a=0,b=this.layers.length;a<b;a++){var c=this.map.layers[a],d=this.layers.charAt(a);
+"B"==d?this.map.setBaseLayer(c):("T"==d||"F"==d)&&c.setVisibility("T"==d)}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});
+OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:!1,base:"",displayProjection:null,initialize:function(a,b,c){if(null!==a&&"object"==typeof a&&!OpenLayers.Util.isElement(a)){if(this.base=document.location.href,OpenLayers.Control.prototype.initialize.apply(this,[a]),null!=this.element)this.element=OpenLayers.Util.getElement(this.element)}else OpenLayers.Control.prototype.initialize.apply(this,[c]),this.element=OpenLayers.Util.getElement(a),
+this.base=b||document.location.href},destroy:function(){this.element.parentNode==this.div&&this.div.removeChild(this.element);this.element=null;this.map.events.unregister("moveend",this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var b=0,c=this.map.controls.length;b<c;b++){var d=this.map.controls[b];if(d.CLASS_NAME==this.argParserClass.CLASS_NAME){if(d.displayProjection!=this.displayProjection)this.displayProjection=
+d.displayProjection;break}}b==this.map.controls.length&&this.map.addControl(new this.argParserClass({displayProjection:this.displayProjection}))},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor)this.element=document.createElement("a"),this.element.innerHTML=OpenLayers.i18n("Permalink"),this.element.href="",this.div.appendChild(this.element);this.map.events.on({moveend:this.updateLink,changelayer:this.updateLink,changebaselayer:this.updateLink,
+scope:this});this.updateLink();return this.div},updateLink:function(){var a=this.anchor?"#":"?",b=this.base;-1!=b.indexOf(a)&&(b=b.substring(0,b.indexOf(a)));b+=a+OpenLayers.Util.getParameterString(this.createParams());this.anchor&&!this.element?window.location.href=b:this.element.href=b},createParams:function(a,b,c){var a=a||this.map.getCenter(),d=OpenLayers.Util.getParameters(this.base);if(a){d.zoom=b||this.map.getZoom();b=a.lat;a=a.lon;if(this.displayProjection)b=OpenLayers.Projection.transform({x:a,
+y:b},this.map.getProjectionObject(),this.displayProjection),a=b.x,b=b.y;d.lat=Math.round(1E5*b)/1E5;d.lon=Math.round(1E5*a)/1E5;c=c||this.map.layers;d.layers="";a=0;for(b=c.length;a<b;a++){var e=c[a];d.layers=e.isBaseLayer?d.layers+(e==this.map.baseLayer?"B":"0"):d.layers+(e.getVisibility()?"T":"F")}}return d},CLASS_NAME:"OpenLayers.Control.Permalink"});
+OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:!0,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(a,b,c){var d=[];d.push(a,b,{},c);OpenLayers.Layer.Grid.prototype.initialize.apply(this,d)},clone:function(a){null==a&&(a=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.adjustBounds(a),b=this.getServerResolution(),
+c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w)),a=Math.round((a.bottom-this.tileOrigin.lat)/(b*this.tileSize.h)),b=this.serviceVersion+"/"+this.layername+"/"+(null!=this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,b):this.getServerZoom()+this.zoomOffset)+"/"+c+"/"+a+"."+this.type,c=this.url;OpenLayers.Util.isArray(c)&&(c=this.selectUrl(b,c));return c+b},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin)this.tileOrigin=
+new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom)},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Protocol.AgsFeatureAccess=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS),b=OpenLayers.Protocol.AgsFeatureAccess["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported AgsFeatureAccess version: "+a.version;return new b(a)};OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS={version:"2.0"};
+OpenLayers.Format.AgsJsAdapter=function(){function a(a,b){if(void 0!==window.dojo)return dojo.hitch(b,a);OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(a,b)}var b={UNIT_METER:9001,UNIT_FOOT:9002,UNIT_KILOMETER:9036,UNIT_DEGREE:9102},c={INTERSECTS:"esriSpatialRelIntersects",CONTAINS:"esriSpatialRelContains",CROSSES:"esriSpatialRelCrosses",ENVELOPE_INTERSECTS:"esriSpatialRelEnvelopeIntersects",INDEX_INTERSECTS:"esriSpatialRelIndexIntersects",
+OVERLAPS:"esriSpatialRelOverlaps",TOUCHES:"esriSpatialRelTouches",WITHIN:"esriSpatialRelWithin"},d={CROSS:"esriGeometryRelationCross",DISJOINT:"esriGeometryRelationDisjoint",IN:"esriGeometryRelationIn",INTERIOR_INTERSECTION:"esriGeometryRelationInteriorIntersection",INTERSECTION:"esriGeometryRelationIntersection",LINE_COINCIDENCE:"esriGeometryRelationLineCoincidence",LINE_TOUCHE:"esriGeometryRelationLineTouch",OVERLAP:"esriGeometryRelationOverlap",POINT_TOUCH:"esriGeometryRelationPointTouch",RELATION:"esriGeometryRelationRelation",
+TOUCH:"esriGeometryRelationTouch",WITHIN:"esriGeometryRelationWithin"},e={900913:"102113"},f={102113:"900913"},g={"OpenLayers.Geometry.Point":"point","OpenLayers.Geometry.MultiLineString":"polyline","OpenLayers.Geometry.LineString":"polyline","OpenLayers.Geometry.MultiPolygon":"polygon","OpenLayers.Geometry.Polygon":"polygon","OpenLayers.Bounds":"extent"},h={"OpenLayers.Geometry.Point":"SimpleMarkerSymbol","OpenLayers.Geometry.MultiLineString":"SimpleLineSymbol","OpenLayers.Geometry.Polygon":"SimpleFillSymbol",
+"OpenLayers.Bounds":"SimpleFillSymbol",simplemarkersymbol:"SimpleMarkerSymbol",picturemarkersymbol:"PictureMarkerSymbol",simplelinesymbol:"SimpleLineSymbol",cartographiclinesymbol:"CartographicLineSymbol",simplefillsymbol:"SimleFillSymbol",picturefillsymbol:"PictureFillSymbol"},i={simplemarkersymbol:"SimpleMarkerSymbol",picturemarkersymbol:"PictureMarkerSymbol",simplelinesymbol:"SimpleLineSymbol",cartographiclinesymbol:"CartographicLineSymbol",simplefillsymbol:"SimpleFillSymbol",picturefillsymbol:"PictureFillSymbol"},
+j={STYLE_CIRCLE:"circle",STYLE_CROSS:"cross",STYLE_DIAMOND:"diamond",STYLE_SQUARE:"square",STYLE_X:"x"},k={dash:"STYLE_DASH",dashdot:"STYLE_DASHDOT",longdashdot:"STYLE_DASHDOTDOT",dot:"STYLE_DOT",solid:"STYLE_NULL",solid:"STYLE_SOLID"},m={STYLE_DASH:"dash",STYLE_DASHDOT:"dashdot",STYLE_DASHDOTDOT:"longdashdot",STYLE_DOT:"dot",STYLE_NULL:"solid",STYLE_SOLID:"solid"},n={route:{strokeColor:"#00FF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid"},stop:{fillColor:"#FFFF00",
+fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10},barrier:{fillColor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10}},l=OpenLayers.Util.AgsUtil.isDefined,o=OpenLayers.Util.AgsUtil.isNumber,q=OpenLayers.Util.AgsUtil.isBoolean,r=OpenLayers.Util.AgsUtil.isAgsGeometry,p=OpenLayers.Util.AgsUtil.isOLGeometry,s=OpenLayers.Util.AgsUtil.isSameOLPoint;
+return function(t){this.config={defaultEncodeWkid:"EPSG:900913"};this.parseAgsGeometry={point:function(a){var b=null;if(a instanceof esri.geometry.Point&&o(a.x)&&o(a.y))return b=new OpenLayers.Geometry.Point(a.x,a.y);OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point...");throw"...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point..."+a;},coordinate:function(a){var b=null;if(a instanceof Array&&o(a[0])&&o(a[1]))return b=new OpenLayers.Geometry.Point(a[0],
+a[1]);OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]...");throw"...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]..."+a;},path:function(a){var b=null;if(a instanceof Array){for(var b=[],c=0;c<a.length;c++){var d=null;try{d=this.parseAgsGeometry.coordinate.apply(this,[a[c]]),b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}}return b=new OpenLayers.Geometry.LineString(b)}OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.path...invalid array of coordinates...");
+throw"...AgsAdapter.parseAgsGeometry.path...invalid array of array [x,y]..."+a;},ring:function(a){var b=a[0],c=a[a.length-1];if(b[0]!=c[0]||b[1]!=c[1])throw OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.ring...not a closed ring..."),"...AgsAdapter.parseAgsGeometry.ring...not a closed ring..."+a;b=b=null;try{b=this.parseAgsGeometry.path.apply(this,[a])}catch(d){throw OpenLayers.Console.error(d.toString()),d;}return b=new OpenLayers.Geometry.LinearRing(b.components)},polyline:function(a){var b=
+null;if(l(a.paths)&&a.paths instanceof Array){for(var a=a.paths,b=[],c=0;c<a.length;c++)try{var d=this.parseAgsGeometry.path.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b=new OpenLayers.Geometry.MultiLineString(b)}OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline...");throw"...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline..."+a;},polygon:function(a){var b=null;if(l(a.rings)&&a.rings instanceof
+Array){for(var a=a.rings,b=[],c=0;c<a.length;c++)try{var d=this.parseAgsGeometry.ring.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b=new OpenLayers.Geometry.Polygon(b)}OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon...");throw"...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon..."+a;},multipoint:function(a){var b=[];if(l(a.points)&&a.points instanceof Array){for(var a=a.points,c=0;c<
+a.length;c++)try{var d=this.parseAgsGeometry.coordinate.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint...");throw"...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint..."+agsPolygon;},extent:function(a){var b=null;if(l(a.xmin)&&l(a.xmax)&&l(a.ymin)&&l(a.ymax))return b=new OpenLayers.Bounds(a.xmin,a.ymin,a.xmax,a.ymax);OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent...");
+throw"...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent..."+a;}};this.parseAgsSymbol={SimpleMarkerSymbol:function(a){if(l(a)&&a instanceof esri.symbol.SimpleMarkerSymbol){var b=new OpenLayers.Symbolizer.Point({});b.strokeColor=a.outline.color.toHex()||b.strokeColor;b.strokeWidth=a.outline.width;b.strokeOpacity=a.outline.color.toRgba()[3]||b.strokeOpacity;b.strokeDashstyle=m[a.outline.style]||b.strokeDashstyle;b.fillColor=a.color.toHex()||b.fillColor;b.fillOpacity=a.color.toRgba()[3]||
+b.fillOpacity;b.pointRadius=a.size||b.pointRadius;b.graphicName=j[a.style]||b.graphicName;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+a;},PictureMarkerSymbol:function(a){if(l(a)&&a instanceof esri.symbol.PictureMarkerSymbol){var b=new OpenLayers.Symbolizer.Point({});b.pointRadius=a.size/2||b.pointRadius;b.externalGraphic=
+a.url||b.externalGraphic;b.graphicWidth=Math.floor(a.width)||b.graphicWidth;b.graphicHeight=Math.floor(a.height)||b.graphicHeight;b.graphicXOffset=a.xoffset||b.graphicXOffset;b.graphicYOffset=a.yoffset||b.graphicYOffset;b.graphicOpacity=1;b.rotation=a.angle;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSimpleMarkerSymbol;
+},SimpleLineSymbol:function(a){if(l(a)&&a instanceof esri.symbol.SimpleLineSymbol){var b=new OpenLayers.Symbolizer.Line({});b.strokeColor=a.color.toHex()||b.strokeColor;b.strokeWidth=Math.floor(a.width);b.strokeOpacity=a.color.toRgba()[3]||b.strokeOpacity;b.strokeDashstyle=m[a.style]||b.strokeDashstyle;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol..."+
+a;},CartographicLineSymbol:function(a){if(l(a)&&a instanceof esri.symbol.CartographicLineSymbol)return this.parseAgsSymbol.SimpleLineSymbol.apply(this,[a]);OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol..."+a;},SimpleFillSymbol:function(a){if(l(a)&&a instanceof esri.symbol.SimpleFillSymbol){var b=new OpenLayers.Symbolizer.Polygon({});
+b.strokeColor=a.outline.color.toHex()||b.strokeColor;b.strokeWidth=Math.floor(a.outline.width);b.strokeOpacity=a.outline.color.toRgba()[3]||b.strokeOpacity;b.strokeDashstyle=m[a.outline.style]||b.strokeDashstyle;b.fillColor=a.color.toHex()||b.fillColor;b.fillOpacity=a.color.toRgba()[3]||b.fillOpacity;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol..."+
+a;},PictureFillSymbol:function(a){if(l(a)&&a instanceof esri.symbol.PictureFillSymbol)return this.parseAgsSymbol.SimpleFillSymbol.apply(this,[a]);OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol..."+a;},TextSymbol:function(a){if(l(a)&&a instanceof esri.symbol.TextSymbol){var b=new OpenLayers.Symbolizer.Text({});b.label=a.text||b.label;b.fontFamily=
+a.font.family||b.fontFamily;b.fontSize=a.font.size||b.fontSize;b.fontWeight=a.font.weight||b.fontWeight;b.fontStyle=a.font.style||b.fontStyle;b.color=a.color.toHex()||b.color;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol...");throw"...AgsAdapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol..."+a;}};this.parseAgsRenderer={SimpleRenderer:function(a){if(l(a)&&a instanceof esri.renderer.SimpleRenderer){var b=this.parseAgsSymbol[i[a.symbol.type]].apply(this,
+[a.symbol]),b=new OpenLayers.Rule({symbolizers:[b]});b.name=a.label;b.title=a.label;b.description=a.description;b=new OpenLayers.Style(null,{rules:[b]});b.name=a.label;b.title=a.label;b.description="An OpenLayers Style converted from an esri SimpleRenderer";return b}OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer...");throw"...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer..."+a;
+},ClassBreaksRenderer:function(a){if(l(a)&&a instanceof esri.renderer.ClassBreaksRenderer){var b=a.attributeField;if(null!=a.infos&&0<a.infos.length){var c=[],d=a.defaultSymbol;if(null!=d)d=this.parseAgsSymbol[i[d.type]].apply(this,[d]),d=new OpenLayers.Rule({symbolizers:[d],elseFilter:!0}),d.name="defaultRuleName",d.title="default rule title",d.description="default rule description",c.push(d);for(d=0;d<a.infos.length;d++){var e=a.infos[d],f=this.parseAgsSymbol[i[e.symbol.type]].apply(this,[e.symbol]),
+g=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN,property:b,lowerBoundary:e.minValue,upperBoundary:e.maxValue}),f=new OpenLayers.Rule({symbolizers:[f],filter:g});f.name=e.label;f.title=e.label;f.description=e.description;c.push(f)}b=new OpenLayers.Style(null,{rules:c});b.name=a.label;b.title=a.label;b.description="An OpenLayers Style converted from an esri ClassBreaksRenderer";return b}return new OpenLayers.Style(null,{})}OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer...");
+throw"...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer..."+a;},UniqueValueRenderer:function(a){if(l(a)&&a instanceof esri.renderer.UniqueValueRenderer){var b=a.attributeField;if(null!=a.infos&&0<a.infos.length){var c=[],d=a.defaultSymbol;if(null!=d){var d=this.parseAgsSymbol[i[d.type]].apply(this,[d]),e=[];e.push(d);d=new OpenLayers.Rule({symbolizers:e,elseFilter:!0});d.name="defaultRuleName";d.title="default rule title";d.description="default rule description";
+c.push(d)}for(d=0;d<a.infos.length;d++){var e=a.infos[d],f=this.parseAgsSymbol[i[e.symbol.type]].apply(this,[e.symbol]),g=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:b,value:e.value}),h=[];h.push(f);f=new OpenLayers.Rule({symbolizers:h,filter:g});f.name=e.label;f.title=e.label;f.description=e.description;c.push(f)}b=new OpenLayers.Style(null,{rules:c});b.name=a.label;b.title=a.label;b.description="An OpenLayers Style converted from an esri UniqueValueRenderer";
+return b}return new OpenLayers.Style(null,{})}OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer...");throw"...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer..."+a;},TemporalRenderer:function(){}};this.parseAgsFeatureTemplate=function(a){if(l(a)&&"esri.layers.FeatureTemplate"==a.declaredClass){var b={};if(null!=a.name)b.name=a.name;if(null!=a.description)b.description=
+a.description;b.prototype=this.parseNoGeometryAgsGraphic.apply(this,[a.prototype]);return b}OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate...");throw"...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate..."+a;};this.parseAgsFeatureTemplates=function(a){var b=[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsFeatureTemplate.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),
+e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array...");throw"...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array..."+a;};this.parseAgsFeatureType=function(a){if(l(a)&&"esri.layers.FeatureType"==a.declaredClass){var b={};if(null!=a.name)b.name=a.name;if(null!=a.id)b.id=a.id;b.templates=this.parseAgsFeatureTemplates.apply(this,[a.templates]);return b}OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureType...missing or invalid esri.layers.FeatureType...");
+throw"...AgsAdapter.parseAgsFeatureType...missing or invalid esri.layers.FeatureType..."+a;};this.parseAgsFeatureTypes=function(a){var b=[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsFeatureType.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTypes...invalid esri.layers.FeatureType array...");throw"...AgsAdapter.parseAgsFeatureTypes...invalid esri.layers.FeatureType array..."+
+a;};this.parseAgsSpatialReference=function(a){var b=null;if(l(a.wkid)&&a instanceof esri.SpatialReference)return b="EPSG:"+(l(f[a.wkid])?f[a.wkid]:a.wkid);OpenLayers.Console.error("...AgsAdapter.parseAgsSpatialReference...missing or invalid esri.SpatialReference...");throw"...AgsAdapter.parseAgsSpatialReference...missing or invalid esri.SpatialReference..."+a;};this.parseAgsGraphic=function(a){var b=null,c=null,b=null;if(l(a.geometry.type))c=a.geometry.type;else throw OpenLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic..."),
+"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic..."+a;try{b=this.parseAgsGeometry[c].apply(this,[a.geometry])}catch(d){throw OpenLayers.Console.error(d.toString()),d;}if(l(b)){c=a.attributes;if(l(a.infoTemplate))c.infoTemplateTitle=a.infoTemplate.title?a.infoTemplate.title:"",c.infoTemplateContent=a.infoTemplate.content?a.infoTemplate.content:"";if(l(a.symbol))try{l(a.symbol.type)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b=new OpenLayers.Feature.Vector(b,c,null)}OpenLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.geometry...");
+throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.geometry..."+a;};this.parseNoGeometryAgsGraphic=function(a){var b=null;if(l(a.attributes)){b=a.attributes;if(l(a.infoTemplate))b.infoTemplateTitle=a.infoTemplate.title?a.infoTemplate.title:"",b.infoTemplateContent=a.infoTemplate.content?a.infoTemplate.content:"";if(l(a.symbol))try{l(a.symbol.type)}catch(c){throw OpenLayers.Console.error(c.toString()),c;}return b=new OpenLayers.Feature.Vector(null,b,null)}OpenLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.attributes...");
+throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.attributes..."+a;};this.parseAgsGraphics=function(a){var b=[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsGraphic.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsGraphics...invalid esri.Graphic array...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic array..."+a;};this.parseNoGeometryAgsGraphics=function(a){var b=
+[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseNoGemetryAgsGraphic.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsGraphics...invalid esri.Graphic array...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic array..."+a;};this.parseAgsResults={identifyResult:function(a){var b=null;if(l(a.feature)){try{b=this.parseAgsGraphic.apply(this,[a.feature])}catch(c){throw OpenLayers.Console.error(c.toString()),
+c;}if(l(a.displayFieldName))b.attributes.displayFieldName=a.displayFieldName;if(o(a.layerId)&&0<=a.layerId)b.attributes.layerId=a.layerId;if(l(a.layerName))b.attributes.layerName=a.layerName;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.identifyResult...parses esri.tasks.IdentifyResult...missing or invalid feature in IdentifyResult...");throw"...AgsAdapter.parseAgsResults.identifyResult...parses esri.tasks.IdentifyResult...missing or invalid feature in IdentifyResult..."+a;},identifyResults:function(a){var b=
+[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsResults.identifyResult.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.identifyResults...parses array esri.tasks.IdentifyResult...missing or invalid array...");throw"...AgsAdapter.parseAgsResults.identifyResults...parses array esri.tasks.IdentifyResult...missing or invalid array..."+a;},addressCandidate:function(a){var b=
+null,b=null,c={};if(l(a.location)){try{b=this.parseAgsGeometry.point.apply(this,[a.location])}catch(d){throw OpenLayers.Console.error(d.toString()),d;}if(l(a.address))if("string"===typeof a.address)c.address=a.address;else for(key in a.address)"string"===typeof a.address[key]&&(c["addr_"+key]=a.address[key]);if(l(a.attributes))for(key in a.attributes)"string"===typeof a.attributes[key]&&(c["attr_"+key]=a.attributes[key]);if(l(a.score))c.score=a.score;return b=new OpenLayers.Feature.Vector(b,c)}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.addressCandidate...parses an agsAddressCandidates...missing or invalid 'location'...");
+throw"...AgsAdapter.parseAgsResults.addressCandidate...parses an agsAddressCandidates...missing or invalid 'location'..."+a;},addressCandidates:function(a){var b=[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsResults.addressCandidate.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.addressCandidates...parses array agsAddressCandidates...missing or invalid array...");
+throw"...AgsAdapter.parseAgsResults.addressCandidates...parses array agsAddressCandidates...missing or invalid array..."+a;},findResult:function(a){var b=null;if(l(a.feature)){var c=a.feature;try{b=this.parseAgsGraphic.apply(this,[c])}catch(d){throw OpenLayers.Console.error(d.toString()),d;}if(l(a.displayFieldName))b.attributes.displayFieldName=a.displayFieldName;if(l(a.foundFieldName))b.attributes.foundFieldName=a.foundFieldName;if(o(a.layerId)&&0<=a.layerId)b.attributes.layerId=a.layerId;if(l(a.layerName))b.attributes.layerName=
+a.layerName;return b}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.findResult...parse esri.tasks.FindResult...missing or invalid FindResult...");throw"...AgsAdapter.parseAgsResults.findResult...parse esri.tasks.FindResult...missing or invalid FindResult..."+a;},findResults:function(a){var b=[];if(l(a)&&a instanceof Array){for(var c=0;c<a.length;c++)try{var d=this.parseAgsResults.findResult.apply(this,[a[c]]);b.push(d)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}return b}OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.findResults...parse array of agsFindResults...missing or invalid array...");
+throw"...AgsAdapter.parseAgsResults.findResults...parse array of agsFindResults...missing or invalid array..."+a;},featureSet:function(a){var b=[];if(l(a.features)){try{b=this.parseAgsGraphics.apply(this,[a.features])}catch(c){throw OpenLayers.Console.error(c.toString()),c;}return b}OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.featureSet...parse esri.tasks.FeatureSet...missing or invalid FeatureSet...");throw"...AgsAdapter.parseAgsResults.featureSet...parse esri.tasks.FeatureSet...missing or invalid FeatureSet..."+
+a;},areasAndLengths:function(a){if(l(a.areas)||l(a.lengths))return a;OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.areasAndLengths...parse esri areasAndLengths...missing or invalid areasAndLengths...");throw"...AgsAdapter.parseAgsResults.areasAndLengths...parse esri areasAndLengths...missing or invalid areasAndLengths..."+a;},relation:function(a){var b={};if(l(a.geometry1Index)&&l(a.geometry2Index))b.geometry1Index=a.geometry1Index,b.geometry2Index=a.geometry2Index;else throw OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."),
+"...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."+a;if(l(a.graphic1)&&l(a.graphic2))try{b.feature1=this.parseAgsGraphic.apply(this,[a.graphic1]),b.feature2=this.parseAgsGraphic.apply(this,[a.graphic2])}catch(c){throw OpenLayers.Console.error(c.toString()),c;}else throw OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."),"...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."+
+a;return b},relations:function(a){var b=[];if(l(a)&&a instanceof Array)try{for(var c=0;c<a.length;c++){var d=this.parseAgsResults.relation.apply(this,[a[c]]);b.push(d)}}catch(e){throw OpenLayers.Console.error(e.toString()),e;}else throw OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relationw...parse esri relation result array...missing or invalid relation result array..."),"...AgsAdapter.parseAgsResults.relationw...parse esri relation result array...missing or invalid relation result array..."+
+a;return b},directionsFeatureSet:function(a){var b=null;if(l(a.mergedGeometry)){var c=a.extent,b=this.parseAgsGeometry.polyline.apply(this,[a.mergedGeometry]),d={};if(null!=c)c=this.parseAgsGeometry.extent.apply(this,[c]),d.extent=c;d.routeId=a.routeId||"";d.routeName=a.routeName||"";d.totalDriveTime=a.totalDriveTime||0;d.totalLength=a.totalLength||0;d.totalTime=a.totalTime||0;return b=new OpenLayers.Feature.Vector(b,d)}OpenLayers.Console.error("...AgsAdapter.parseAgsResults.directionsFeatureSet...parse esri.tasks.DirectionFeatureSet...missing or invalid FindResult...");
+throw"...AgsAdapter.parseAgsResults.directionsFeatureSet...parse esri.tasks.DirectionFeatureSet...missing or invalid DirectionFeatureSet..."+agsDirectionFeatureSet;},routeResult:function(a){var b={};try{if(l(a.directions))b.directions=this.parseAgsResults.directionsFeatureSet.apply(this,[a.directions]);if(l(a.route))b.route=this.parseAgsGraphic.apply(this,[a.route]);if(l(a.routeName))b.routeName=a.routeName;if(l(a.stops))b.stops=this.parseAgsGraphics.apply(this,[a.stops]);return b}catch(c){throw OpenLayers.Console.error(c.toString()),
+c;}},routeResults:function(a,b){var c=[];if(l(a)&&a instanceof Array)try{for(var d=0;d<a.length;d++){var e=this.parseAgsResults.routeResult.apply(this,[a[d]]);if(l(e.route)&&e.route instanceof OpenLayers.Feature.Vector)e.route.style=n.route,c.push(e.route);else if(l(e.directions)&&e.directions instanceof OpenLayers.Feature.Vector)e.directions.style=n.route,c.push(e.directions);if(l(e.stops)&&e.stops instanceof Array)for(d=0;d<e.stops.length;d++){if(e.stops[d]instanceof OpenLayers.Feature.Vector)e.stops[d].style=
+n.stop;c.push(e.stops[d]);OpenLayers.Console.debug("...stop in route results has been added...")}}if(l(b[1])&&b[1]instanceof Array)for(var f=this.parseAgsGraphics.apply(this,[b[1]]),d=0;d<f.length;d++){if(f[d]instanceof OpenLayers.Feature.Vector)f[d].style=n.barrier;c.push(f[d])}}catch(g){throw OpenLayers.Console.error(g.toString()),g;}else throw OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relations...parse esri route results array...missing or invalid route results array..."),"...AgsAdapter.parseAgsResults.relations...parse esri route results array...missing or invalid route results array..."+
+a;return c}};this.encodeAgsUnit=function(a){if(l(a)){if(l(b[a]))return b[a];OpenLayers.Console.error("...AgsAdapter.encodeAgsUnit...encode ags unit...unit string not supported...");throw"...AgsAdapter.encodeAgsUnit...encode ags unit...unit string not supported..."+a;}OpenLayers.Console.error("...AgsAdapter.encodeAgsUnit...encode ags unit...missing or invalid unit string...");throw"...AgsAdapter.encodeAgsUnit...encode ags unit...missing or invalid unit string..."+a;};this.encodeAgsSpatialReference=
+function(a){if(!l(a))throw OpenLayers.Console.error("...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...missing or invalid input spatial reference..."),"...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...missing or invalid input spatial reference..."+a;var b=a.split(":")[0],c=a.split(":")[1];if("EPSG"===b&&l(c))return a={},a.wkid=parseInt(l(e[c])?e[c]:c),new esri.SpatialReference(a);OpenLayers.Console.error("...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...invalid spatial reference in EPSG:XXXXX syntax...");
+throw"...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...invalid spatial reference in EPSG:XXXXX syntax..."+a;};this.encodeAgsGeometry={point:function(a,b){if(l(a)&&a instanceof OpenLayers.Geometry.Point){var c=null,c=null;try{c=l(b)?this.encodeAgsSpatialReference(b):this.encodeAgsSpatialReference(this.config.defaultEncodeWkid)}catch(d){throw OpenLayers.Console.error(d.toString()),d;}return c=new esri.geometry.Point(a.x,a.y,c)}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.point...encode esri.geometry.Point...missing or invalid OpenLayers.Geometry.Point...");
+throw"...AgsAdapter.encodeAgsGeometry.point...encode esri.geometry.Point...missing or invalid OpenLayers.Geometry.Point..."+a;},coordinate:function(a){if(l(a)&&a instanceof OpenLayers.Geometry.Point){var b=[];b.push(a.x);b.push(a.y);return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.coordinate...encode [x, y]...missing or invalid OpenLayers.Geometry.Point...");throw"...AgsAdapter.encodeAgsGeometry.coordinate...encode [x, y]...missing or invalid OpenLayers.Geometry.Point..."+a;},path:function(a){if(l(a)&&
+a instanceof OpenLayers.Geometry.LineString){for(var b=[],c=0;c<a.components.length;c++){var d=a.components[c];try{var e=this.encodeAgsGeometry.coordinate.apply(this,[d]);b.push(e)}catch(f){throw OpenLayers.Console.error(f.toString()),f;}}return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.path...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LineString...");throw"...AgsAdapter.encodeAgsGeometry.path...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LineString..."+
+a;},linearring:function(a){if(l(a)&&a instanceof OpenLayers.Geometry.LinearRing){var b=[];if(!1==s(a.components[0],a.components[a.components.length-1]))throw OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.ring...not a closed ring..."),"...AgsAdapter.encodeAgsGeometry.linearring...not a closed ring..."+a;for(var c=0;c<a.components.length;c++){var d=a.components[c];try{var e=this.encodeAgsGeometry.coordinate.apply(this,[d]);b.push(e)}catch(f){throw OpenLayers.Console.error(f.toString()),f;
+}}return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.linearring...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LinearRing...");throw"...AgsAdapter.encodeAgsGeometry.linearring...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LinearRing..."+a;},polyline:function(a,b){if(l(a)&&a instanceof OpenLayers.Geometry.MultiLineString){var c=new esri.geometry.Polyline,d=null;try{d=l(b)?this.encodeAgsSpatialReference(b):this.encodeAgsSpatialReference(this.config.defaultEncodeWkid)}catch(e){throw OpenLayers.Console.error(e.toString()),
+e;}c.spatialReference=d;for(d=0;d<a.components.length;d++){var f=a.components[d];try{var g=this.encodeAgsGeometry.path.apply(this,[f]);c.addPath(g)}catch(h){throw OpenLayers.Console.error(h.toString()),h;}}return c}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.polyline...encode esri.geometry.polyline...missing or invalid OpenLayers.Geometry.MultiLineString...");throw"...AgsAdapter.encodeAgsGeometry.polyline...encode esri.geometry.polyline...missing or invalid OpenLayers.Geometry.MultiLineString..."+
+a;},polygon:function(a,b){if(l(a)&&a instanceof OpenLayers.Geometry.Polygon){var c=new esri.geometry.Polygon,d=null;try{d=l(b)?this.encodeAgsSpatialReference(b):this.encodeAgsSpatialReference(this.config.defaultEncodeWkid)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}c.spatialReference=d;for(d=0;d<a.components.length;d++){var f=a.components[d];try{var g=this.encodeAgsGeometry.linearring.apply(this,[f]);c.addRing(g)}catch(h){throw OpenLayers.Console.error(h.toString()),h;}}return c}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.polygon...encode esri.geometry.polygon...missing or invalid OpenLayers.Geometry.Polygon...");
+throw"...AgsAdapter.encodeAgsGeometry.polygon...encode esri.geometry.polygon...missing or invalid OpenLayers.Geometry.Polygon..."+a;},extent:function(a,b){if(l(a)&&a instanceof OpenLayers.Bounds){var c=null,c=null;try{c=l(b)?this.encodeAgsSpatialReference(b):this.encodeAgsSpatialReference(this.config.defaultEncodeWkid)}catch(d){throw OpenLayers.Console.error(d.toString()),d;}return c=new esri.geometry.Extent(a.toArray()[0],a.toArray()[1],a.toArray()[2],a.toArray()[3],c)}OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.extent...encode esri.geometry.Extent...missing or invalid OpenLayers.Bounds...");
+throw"...AgsAdapter.encodeAgsGeometry.extent...encode esri.geometry.Extent...missing or invalid OpenLayers.Bounds..."+a;}};this.encodeAgsSymbol={SimpleMarkerSymbol:function(a){if(l(a)){var b=null,b=a.pointRadius||6,c=null,d=a.fillOpacity||1;if(l(a.fillColor))c=new dojo.Color(a.fillColor),c.a=d;var d=a.graphicXOffset||0,e=a.graphicYOffset||0,f=null,g=a.strokeOpacity||1;if(l(a.strokeColor))f=new dojo.Color(a.strokeColor),f.a=g;a=new esri.symbol.SimpleLineSymbol(k[a.strokeDashstyle]||"STYLE_SOLID",f,
+a.strokeWidth||1);b=new esri.symbol.SimpleMarkerSymbol("STYLE_CIRCLE",b,a,c);b.setOffset(d,e);return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleMarkerSymbol...encode esri.symbol.SimpleMarkerSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.SimpleMarkerSymbol...encode esri.symbol.SimpleMarkerSymbol...missing or invalid openlayers style..."+a;},PictureMarkerSymbol:function(a){if(l(a)){var b=null,c=a.pointRadius||6,d=a.graphicXOffset||0,e=a.graphicYOffset||
+0,b=new esri.symbol.PictureMarkerSymbol(a.externalGraphic||"../../img/marker.png",a.graphicWidth||21,a.graphicHeight||25);b.setSize(c);b.setOffset(d,e);return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.PictureMarkerSymbol...encode esri.symbol.PictureMarkerSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.PictureMarkerSymbol...encode esri.symbol.PictureMarkerSymbol...missing or invalid openlayers style..."+a;},SimpleLineSymbol:function(a){if(l(a)){var b=
+null,c=a.strokeOpacity||1;if(l(a.strokeColor))b=new dojo.Color(a.strokeColor),b.a=c;return new esri.symbol.SimpleLineSymbol(k[a.strokeDashstyle]||"STYLE_SOLID",b,a.strokeWidth||1)}OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleLineSymbol...encode esri.symbol.SimpleLineSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.SimpleLineSymbol...encode esri.symbol.SimpleLineSymbol...missing or invalid openlayers style..."+a;},CartographicLineSymbol:function(){OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.CartographicLineSymbol is not implemented yet...");
+throw"...AgsAdapter.encodeAgsSymbol.CartographicLineSymbol is not implemented yet...";},SimpleFillSymbol:function(a){if(l(a)){var b=null,b=null,c=a.fillOpacity||1;if(l(a.fillColor))b=new dojo.Color(a.fillColor),b.a=c;var c=null,d=a.strokeOpacity||1;if(l(a.strokeColor))c=new dojo.Color(a.strokeColor),c.a=d;a=new esri.symbol.SimpleLineSymbol(k[a.strokeDashstyle]||"STYLE_SOLID",c,a.strokeWidth||1);return b=new esri.symbol.SimpleFillSymbol("STYLE_SOLID",a,b)}OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleFillSymbol...encode esri.symbol.SimpleFillSymbol...missing or invalid openlayers style...");
+throw"...AgsAdapter.encodeAgsSymbol.SimpleFillSymbol...encode esri.symbol.SimpleFillSymbol...missing or invalid openlayers style..."+a;},PictureFillSymbol:function(){OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.PictureFillSymbol is not implemented yet...");throw"...AgsAdapter.encodeAgsSymbol.PictureFillSymbol is not implemented yet...";}};this.encodeAgsGraphic=function(a,b){if(a instanceof OpenLayers.Feature.Vector&&l(a.geometry)){var c=null,d=g[a.geometry.CLASS_NAME],c=null;try{c=this.encodeAgsGeometry[d].apply(this,
+[a.geometry,b])}catch(e){throw OpenLayers.Console.error(e.toString()),e;}var d=l(a.attributes)?a.attributes:{},f=null;if(l(a.style)){var i=h[a.geometry.CLASS_NAME];try{f=this.encodeAgsSymbol[i].apply(this,[a.style])}catch(j){throw OpenLayers.Console.error(j.toString()),j;}}i=null;l(d.infoTemplateTitle)&&l(d.infoTemplateContent)&&(i=new esri.InfoTemplate(d.infoTemplateTitle,d.infoTemplateContent));return c=new esri.Graphic(c,f,d,i)}OpenLayers.Console.error("...AgsAdapter.encodeAgsGraphic...encode esri.geometry.Geometry...missing or invalid OpenLayers.Feature.Vector...");
+throw"...AgsAdapter.encodeAgsGraphic...encode esri.geometry.Geometry...missing or invalid OpenLayers.Feature.Vector..."+a;};this.encodeAgsGraphics=function(a,b){var c=[];if(l(a)&&a instanceof Array){for(var d=0;d<a.length;d++)try{var e=this.encodeAgsGraphic.apply(this,[a[d],b]);c.push(e)}catch(f){throw OpenLayers.Console.error(f.toString()),f;}return c}OpenLayers.Console.error("...AgsAdapter.encodeAgsGraphics...encode array esri.Graphic...missing or invalid array of OpenLayers.Feture.Vector...");
+throw"...AgsAdapter.encodeAgsGraphics...encode array esri.Graphic...missing or invalid array of OpenLayers.Feture.Vector..."+a;};this.encodeAgsFindParameters=function(a){if(l(a)){var b=new esri.tasks.FindParameters;b.contains=a.contains||!1;if(l(a.outSpatialReference)){if(!(a.outSpatialReference instanceof esri.SpatialReference))try{a.outSpatialReference=this.encodeAgsSpatialReference(a.outSpatialReference)}catch(c){throw OpenLayers.Console.error(c.toString()),c;}b.outSpatialReference=a.outSpatialReference}else b.outSpatialReference=
+null;b.returnGeometry=a.returnGeometry||!0;if(l(a.layerIds))b.layerIds=a.layerIds;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'layerIds' can not be null or empty..."),"...AgsAdapter.encodeAgsFindParameters...parameter 'layerIds' can not be null or empty...";if(l(a.searchFields))b.searchFields=a.searchFields;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'searchFields' can not be null or empty..."),"...AgsAdapter.encodeAgsFindParameters...parameter 'searchFields' can not be null or empty...";
+if(l(a.searchText))b.searchText=a.searchText;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'searchText' can not be null or empty..."),"...AgsAdapter.encodeAgsFindParameters...parameter 'searchText' can not be null or empty...";return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...encode ags FindParameter...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsFindParameters...encode ags FindParameter...missing or invalid input object literal..."+
+a;};this.encodeAgsIdentifyParameters=function(a){if(l(a)){var b=new esri.tasks.IdentifyParameters;b.dpi=o(a.dpi)?a.dpi:96;if(r(a.geometry))b.geometry=a.geometry;else if(p(a.geometry)){var c=g[a.geometry.CLASS_NAME],c=this.encodeAgsGeometry[c].apply(this,[a.geometry,this.config.defaultEncodeWkid]);b.geometry=c}else if(a.geometry instanceof OpenLayers.Feature.Vector)c=g[a.geometry.geometry.CLASS_NAME],c=this.encodeAgsGeometry[c].apply(this,[a.geometry.geometry,this.config.defaultEncodeWkid]),b.geometry=
+c;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'geometry' missing or invalid..."),"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'geometry' missing or invalid...";if(o(a.height))b.height=a.height;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'height' is missing or invalid..."),"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'height' is missing or invalid...";if(l(a.layerIds))b.layerIds=a.layerIds;
+else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'layerIds' is missing or invalid..."),"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'layerIds' is missing or invalid...";b.layerOption=l(a.layerOption)?a.layerOption:"all";if(a.mapExtent instanceof OpenLayers.Bounds)try{b.mapExtent=this.encodeAgsGeometry.extent.apply(this,[a.mapExtent,this.config.defaultEncodeWkid])}catch(d){throw OpenLayers.Console.error(d.toString()),d;}else if(a.mapExtent instanceof
+esri.geometry.Extent)b.mapExtent=a.mapExtent;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'mapExtent' is missing or invalid..."),"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'mapExtent' is missing or invalid...";b.returnGeometry=q(a.returnGeometry)?a.returnGeometry:!0;if(l(a.spatialReference))if(a.spatialReference instanceof esri.SpatialReference)b.spatialReference=a.spatialReference;else try{b.spatialReference=this.encodeAgsSpatialReference(a.spatialReference)}catch(e){throw OpenLayers.Console.error(e.toString()),
+e;}else b.spatialReference=null;b.tolerance=l(a.tolerance)?a.tolerance:0;if(o(a.width))b.width=a.width;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'width' is missing or invalid..."),"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'width' is missing or invalid...";return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...encode ags IdentifyParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsIdentifyParameters...encode ags IdentifyParameters...missing or invalid input object literal..."+
+a;};this.encodeAgsBufferParameters=function(a){if(l(a)){var c=new esri.tasks.BufferParameters;if(l(a.bufferSpatialReference))if(a.bufferSpatialReference instanceof esri.SpatialReference)c.bufferSpatialReference=a.bufferSpatialReference;else try{c.bufferSpatialReference=this.encodeAgsSpatialReference(a.bufferSpatialReference)}catch(d){throw OpenLayers.Console.error(d.toString()),d;}else c.bufferSpatialReference=null;c.distances=a.distances instanceof Array?a.distances:[50];if(l(a.features)&&a.features instanceof
+Array){for(var e=[],f=0;f<a.features.length;f++)if(a.features[f]instanceof esri.Graphic)e.push(a.features[f]);else if(a.features[f]instanceof OpenLayers.Feature.Vector)e.push(this.encodeAgsGraphic(a.features[f],this.config.defaultEncodeWkid));else if(p(a.features[f])){var g=new OpenLayers.Feature.Vector(a.features[f]);e.push(this.encodeAgsGraphic(g,this.config.defaultEncodeWkid))}else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid..."),
+"...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...";c.features=e}else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid..."),"...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...";if(l(a.outSpatialReference))if(a.outSpatialReference instanceof esri.SpatialReference)c.outSpatialReference=a.outSpatialReference;else try{c.outSpatialReference=this.encodeAgsSpatialReference(a.outSpatialReference)}catch(h){throw OpenLayers.Console.error(h.toString()),
+h;}else c.outSpatialReference=null;c.unionResults=l(a.unionResults)?a.unionResults:!1;c.unit=l(b[a.unit])?b[a.unit]:b.UNIT_KILOMETER;return c}OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...encode ags BufferParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsBufferParameters...encode ags BufferParameters...missing or invalid input object literal..."+a;};this.encodeAgsRouteParameters=function(a){if(l(a)){var b=new esri.tasks.RouteParameters;if(l(a.barriers))try{b.barriers=
+this.encodeAgsFeatureSet(a.barriers,this.config.defaultEncodeWkid,{})}catch(c){throw OpenLayers.Console.error("...error encoding esri.tasks.RouteParameters.barriers..."),c;}if(l(a.outSpatialReference))if(a.outSpatialReference instanceof esri.SpatialReference)b.outSpatialReference=a.outSpatialReference;else try{b.outSpatialReference=this.encodeAgsSpatialReference(a.outSpatialReference)}catch(d){throw OpenLayers.Console.error(d.toString()),d;}else b.outSpatialReference=null;l(a.restrictionAttributes);
+l(a.returnBarriers)&&(b.returnBarriers=a.returnBarriers);l(a.returnDirections)&&(b.returnDirections=a.returnDirections);l(a.returnRoutes)&&(b.returnRoutes=a.returnRoutes);l(a.returnStops)&&(b.returnStops=a.returnStops);if(l(a.stops)&&a.stops instanceof Array){for(var e=new esri.tasks.FeatureSet,f=0;f<a.stops.length;f++)if(a.stops[f]instanceof esri.Graphic)e.features.push(a.stops[f]);else if(a.stops[f]instanceof OpenLayers.Feature.Vector)e.features.push(this.encodeAgsGraphic(a.stops[f],this.config.defaultEncodeWkid));
+else if(p(a.stops[f])){var g=new OpenLayers.Feature.Vector(a.stops[f]);e.features.push(this.encodeAgsGraphic(g,this.config.defaultEncodeWkid))}else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsRouteParameters...one of the 'stops' is invalid..."),"...AgsAdapter.encodeAgsRouteParameters...one of the 'stops' is invalid...";b.stops=e}else throw OpenLayers.Console.error("...error encoding esri.tasks.RouteParameters.stops...invalid array input..."),"...error encoding esri.tasks.RouteParameters.stops...invalid array input...";
+return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsRouteParameters...encode ags routeParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsRouteParameters...encode ags routeParameters...missing or invalid input object literal..."+a;};this.encodeAgsQuery=function(a){if(l(a)){var b=new esri.tasks.Query;if(r(a.geometry))b.geometry=a.geometry;else if(p(a.geometry)){var d=g[a.geometry.CLASS_NAME],d=this.encodeAgsGeometry[d].apply(this,[a.geometry,this.config.defaultEncodeWkid]);
+b.geometry=d}else if(a.geometry instanceof OpenLayers.Feature.Vector)d=g[a.geometry.geometry.CLASS_NAME],d=this.encodeAgsGeometry[d].apply(this,[a.geometry.geometry,this.config.defaultEncodeWkid]),b.geometry=d;if(l(a.outFields))b.outFields=a.outFields;else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsQuery...parameter 'outFields' is mandatory..."),"...AgsAdapter.encodeAgsQuery...parameter 'outFields' is mandatory...";if(l(a.outSpatialReference))if(a.outSpatialReference instanceof esri.SpatialReference)b.outSpatialReference=
+a.outSpatialReference;else try{b.outSpatialReference=this.encodeAgsSpatialReference(a.outSpatialReference)}catch(e){throw OpenLayers.Console.error(e.toString()),e;}else b.outSpatialReference=null;b.returnGeometry=l(a.returnGeometry)?a.returnGeometry:!0;b.spatialRelationship=l(c[a.spatialRelationship])?c[a.spatialRelationship]:c.INTERSECTS;b.text=a.text?a.text:"";b.where=a.where?a.where:"";return b}OpenLayers.Console.error("...AgsAdapter.encodeAgsQuery...encode ags Query...missing or invalid input object literal...");
+throw"...AgsAdapter.encodeAgsQuery...encode ags Query...missing or invalid input object literal..."+a;};this.encodeAgsLocation=function(a){if(l(a))try{if(a instanceof esri.geometry.Point)return a;if(a instanceof OpenLayers.Geometry.Point){var b=this.encodeAgsGeometry.point.apply(this,[a,this.config.defaultEncodeWkid]);return b}if(a instanceof OpenLayers.Feature.Vector)return b=this.encodeAgsGeometry.point.apply(this,[a.geometry,this.config.defaultEncodeWkid]);OpenLayers.Console.error("...AgsAdapter.encodeAgsLocation...'location' is invalid...");
+throw"...AgsAdapter.encodeAgsLocation...'location' is invalid...";}catch(c){throw OpenLayers.Console.error(c.toString()),c;}else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsLocation...encode location...missing or invalid 'location'..."),"...AgsAdapter.encodeAgsLocation...encode location...missing or invalid 'location'...";};this.encodeAgsFeatureSet=function(a,b,c){if(l(a)){var d=new esri.tasks.FeatureSet;try{d.features=this.encodeAgsGraphics.apply(this,[a,b]),d.spatialReference=this.encodeAgsSpatialReference.apply(this,
+[b]),d.displayFieldName=c.displayFieldName||void 0,d.fieldAliases=c.fieldAliases||void 0,d.geometryType=c.geometryType||void 0}catch(e){throw OpenLayers.Console.error(e.toString()),e;}}else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsFeatureSet...encode FeatureSet...missing or invalid OpenLayers.Feature.Vector array..."),"...AgsAdapter.encodeAgsFeatureSet...encode FeatureSet...missing or invalid OpenLayers.Feature.Vector array...";return d};this.encodeAgsGeometrySpatialRelationship=function(a){if(l(a))var b=
+null,b=d[a];else throw OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometrySpatialRelationship...encode AgsGeometrySpatialRelationship...missing or invalid input OpenLayers GeometrySpatialRelationship..."),"...AgsAdapter.encodeAgsGeometrySpatialRelationship...encode AgsGeometrySpatialRelationship...missing or invalid input OpenLayers GeometrySpatialRelationship...";return b};OpenLayers.Util.extend(this.config,t);this.parseAgsGeometry.point=a(this.parseAgsGeometry.point,this);this.parseAgsGeometry.path=
+a(this.parseAgsGeometry.path,this);this.encodeAgsFeatureSet=a(this.encodeAgsFeatureSet,this);this.encodeAgsFindParameters=a(this.encodeAgsFindParameters,this)}}();
+OpenLayers.Protocol.AgsFeatureAccess.v2=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",format:null,formatOptions:null,agsFeatureLayer:null,isAgsFeatureLayerLoaded:!1,_query:null,defaultQuery:{outFields:["*"],returnGeometry:!0,where:"",outSpatialReference:this.srsName},style:null,templates:null,currentFeatureTemplate:null,layer:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);if(!this.format)this.format=new OpenLayers.Format.AgsJsAdapter;
+if(null!=this.url&&""!=this.url)this.agsFeatureLayer=new esri.layers.FeatureLayer(this.url,{}),dojo.connect(this.agsFeatureLayer,"onLoad",this,function(a){OpenLayers.Console.debug("...feature layer loaded successfully...");this.isAgsFeatureLayerLoaded=!0;this.style=this.format.parseAgsRenderer[a.renderer.declaredClass.split(".")[2]].apply(this.format,[a.renderer]);OpenLayers.Console.debug("...feature layer renderer parsed successfully...");this.templates=this.format.parseAgsFeatureTypes.apply(this.format,
+[a.types]);OpenLayers.Console.debug("...feature layer feature types parsed successfully...");if(this.currentFeatureTemplate=this.templates[0])this.layer.events.on({sketchcomplete:function(a){this.applyCurrentFeatureTemplate(a.feature||a)},scope:this})});else throw OpenLayers.Console.error("...fail to initialize OpenLayers.Protocol.AgsFeatureAccess.v2...invalid or null url..."),"...fail to initialize OpenLayers.Protocol.AgsFeatureAccess.v2...invalid or null url...";if(a.query)this._query=OpenLayers.Util.extend(this.defaultQuery,
+a.query)},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||{});if(a.filter instanceof OpenLayers.Filter.Spatial&&a.filter.type==OpenLayers.Filter.Spatial.BBOX)this._query.geometry=a.filter.value,this._query.spatialRelationship="INTERSECTS";var b=this.format.encodeAgsQuery.apply(this.format,
+[this._query]);a.parser=this.format;a.layer=this.layer;if(this.style&&this.style instanceof OpenLayers.Style)a.style=this.style;!0==this.isAgsFeatureLayerLoaded?this.agsFeatureLayer.queryFeatures(b,OpenLayers.Util.AgsUtil.createSingleCallback([this.handleRead],a,a.scope),this.handleError):(OpenLayers.Console.warn("...features not loaded..."),OpenLayers.Console.warn("...this.agsFeatureLayer feature layer is not loaded yet...try query feature later..."))},handleRead:function(a,b){if(b.callback){var c=
+b.parser.parseAgsResults.featureSet.apply(b.parser,[a]);if(b.style)if(b.layer)b.layer.styleMap=new OpenLayers.StyleMap({"default":b.style},{});else for(var d=0;d<c.length;d++);b.callback.call(b.scope,{features:c})}},commit:function(a,b){var c=null,b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);for(var d=[],e=[],f=[],g=[],h=0;h<a.length;h++)if(a[h].state==OpenLayers.State.INSERT)e.push(a[h]),d.push(a[h]);else if(a[h].state==OpenLayers.State.UPDATE)if(null!=a[h].attributes.objectid&&
+""!=a[h].attributes.objectid||null!=a[h].attributes.OBJECTID&&""!=a[h].attributes.OBJECTID||null!=a[h].fid&&""!=a[h].fid){if(a[h].fid&&!a[h].attributes.objectid&&!a[h].attributes.OBJECTID)a[h].attributes.objectid=a[h].fid,a[h].attributes.OBJECTID=a[h].fid;f.push(a[h]);d.push(a[h])}else OpenLayers.Console.debug("...skip commiting changes of feature: + "+a[h].id+"...no valid objectid found...");else if(a[h].state==OpenLayers.State.DELETE)if(null!=a[h].attributes.objectid&&""!=a[h].attributes.objectid||
+null!=a[h].attributes.OBJECTID&&""!=a[h].attributes.OBJECTID||null!=a[h].fid&&""!=a[h].fid){if(a[h].fid&&!a[h].attributes.objectid&&!a[h].attributes.OBJECTID)a[h].attributes.objectid=a[h].fid,a[h].attributes.OBJECTID=a[h].fid;g.push(a[h]);d.push(a[h])}else OpenLayers.Console.debug("...skip commiting changes of feature: + "+a[h].id+"...no valid objectid found...");b.featuresToEdit=d;d=null;d=void 0!==window.dojo?dojo.hitch(this,function(a,c,d){this.handleCommit.apply(b.scope,[a,c,d,b])}):OpenLayers.Function.bind(function(a,
+c,d){this.handleCommit.apply(b.scope,[a,c,d,b])},this);e=this.format.encodeAgsGraphics.apply(this.format,[e,this.srsName||this.layer.map.projection]);f=this.format.encodeAgsGraphics.apply(this.format,[f,this.srsName||this.layer.map.projection]);g=this.format.encodeAgsGraphics.apply(this.format,[g,this.srsName||this.layer.map.projection]);!0==this.isAgsFeatureLayerLoaded?c=this.agsFeatureLayer.applyEdits(e,f,g,d,this.handleError):(OpenLayers.Console.warn("...features not loaded..."),OpenLayers.Console.warn("...this.agsFeatureLayer feature layer is not loaded yet...try commit changes later..."));
+return c},handleCommit:function(a,b,c,d){if(d.callback){b=[];for(c=0;c<a.length;c++)!0==a[c].success&&(b.push(a[c].objectId),OpenLayers.Console.debug("...Collect objectId for inserted features..."));a=new OpenLayers.Protocol.Response({requestType:"commit",code:OpenLayers.Protocol.Response.SUCCESS,reqFeatures:d.featuresToEdit,insertIds:b});d.callback.call(d.scope,a)}},handleError:function(a){OpenLayers.Console.error(a)},setLayer:function(a){this.layer=a},getFeatureTemplateByRule:function(a){for(var b=
+0;b<this.templates.length;b++)if(a.name==this.templates[b].templates[0].name)return OpenLayers.Console.debug("...match a rule with a template..."),OpenLayers.Console.debug("...rule name: "+a.name+"..."),OpenLayers.Console.debug("...template name: "+this.templates[b].templates[0].name+"..."),this.templates[b]},setCurrentFeatureTemplate:function(a){a?this.currentFeatureTemplate=a:OpenLayers.Console.warn("...setCurrentFeatureTemplate...invalid feature template...skip setting...")},applyCurrentFeatureTemplate:function(a){a&&
+(OpenLayers.Util.extend(a.attributes,this.currentFeatureTemplate.templates[0].prototype.attributes),OpenLayers.Console.debug("...current feature template applied..."))},CLASS_NAME:"OpenLayers.Protocol.AgsFeatureAccess.v2"});
+OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:!1,activate:function(){if(OpenLayers.Strategy.prototype.activate.apply(this,arguments)){this.layer.events.on({refresh:this.load,scope:this});if(!0==this.layer.visibility||this.preload)this.load();else this.layer.events.on({visibilitychanged:this.load,scope:this});return!0}return!1},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.layer.events.un({refresh:this.load,visibilitychanged:this.load,
+scope:this});return a},load:function(a){var b=this.layer;b.events.triggerEvent("loadstart");b.protocol.read(OpenLayers.Util.applyDefaults({callback:OpenLayers.Function.bind(this.merge,this,b.map.getProjectionObject()),filter:b.filter},a));b.events.un({visibilitychanged:this.load,scope:this})},merge:function(a,b){var c=this.layer;c.destroyFeatures();var d=b.features;if(d&&0<d.length){if(!a.equals(c.projection))for(var e,f=0,g=d.length;f<g;++f)(e=d[f].geometry)&&e.transform(c.projection,a);c.addFeatures(d)}c.events.triggerEvent("loadend")},
+CLASS_NAME:"OpenLayers.Strategy.Fixed"});
+OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:!1,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.handler&&this.handler.destroy();this.handler=null;this.map.events.un({click:this.defaultClick,dblclick:this.defaultDblClick,mousedown:this.defaultMouseDown,mouseup:this.defaultMouseUp,mousemove:this.defaultMouseMove,mouseout:this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,
+"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){this.map.events.on({click:this.defaultClick,dblclick:this.defaultDblClick,mousedown:this.defaultMouseDown,mouseup:this.defaultMouseUp,mousemove:this.defaultMouseMove,mouseout:this.defaultMouseOut,scope:this});this.registerWheelEvents()},
+registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver)},defaultClick:function(a){if(OpenLayers.Event.isLeftClick(a))return a=!this.performedDrag,this.performedDrag=!1,a},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),
+this.map.zoom+1);OpenLayers.Event.stop(a);return!1},defaultMouseDown:function(a){if(OpenLayers.Event.isLeftClick(a)){this.mouseDragStart=a.xy.clone();this.performedDrag=!1;if(a.shiftKey)this.map.div.style.cursor="crosshair",this.zoomBox=OpenLayers.Util.createDiv("zoomBox",this.mouseDragStart,null,null,"absolute","2px solid red"),this.zoomBox.style.backgroundColor="white",this.zoomBox.style.filter="alpha(opacity=50)",this.zoomBox.style.opacity="0.50",this.zoomBox.style.fontSize="1px",this.zoomBox.style.zIndex=
+this.map.Z_INDEX_BASE.Popup-1,this.map.eventsDiv.appendChild(this.zoomBox);document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(a)}},defaultMouseMove:function(a){this.mousePosition=a.xy.clone();if(null!=this.mouseDragStart){if(this.zoomBox){var b=Math.abs(this.mouseDragStart.x-a.xy.x),c=Math.abs(this.mouseDragStart.y-a.xy.y);this.zoomBox.style.width=Math.max(1,b)+"px";this.zoomBox.style.height=Math.max(1,c)+"px";if(a.xy.x<this.mouseDragStart.x)this.zoomBox.style.left=a.xy.x+"px";
+if(a.xy.y<this.mouseDragStart.y)this.zoomBox.style.top=a.xy.y+"px"}else{var b=this.mouseDragStart.x-a.xy.x,c=this.mouseDragStart.y-a.xy.y,d=this.map.getSize();this.map.setCenter(this.map.getLonLatFromViewPortPx(new OpenLayers.Pixel(d.w/2+b,d.h/2+c)),null,!0);this.mouseDragStart=a.xy.clone();this.map.div.style.cursor="move"}this.performedDrag=!0}},defaultMouseUp:function(a){if(OpenLayers.Event.isLeftClick(a))this.zoomBox?this.zoomBoxEnd(a):this.performedDrag&&this.map.setCenter(this.map.center),this.mouseDragStart=
+document.onselectstart=null,this.map.div.style.cursor=""},defaultMouseOut:function(a){if(null!=this.mouseDragStart&&OpenLayers.Util.mouseLeft(a,this.map.eventsDiv))this.zoomBox&&this.removeZoomBox(),this.mouseDragStart=null},defaultWheelUp:function(a){this.map.getZoom()<=this.map.getNumZoomLevels()&&this.map.setCenter(this.map.getLonLatFromPixel(a.xy),this.map.getZoom()+1)},defaultWheelDown:function(a){0<this.map.getZoom()&&this.map.setCenter(this.map.getLonLatFromPixel(a.xy),this.map.getZoom()-1)},
+zoomBoxEnd:function(a){if(null!=this.mouseDragStart){if(5<Math.abs(this.mouseDragStart.x-a.xy.x)||5<Math.abs(this.mouseDragStart.y-a.xy.y)){var b=this.map.getLonLatFromViewPortPx(this.mouseDragStart),c=this.map.getLonLatFromViewPortPx(a.xy),a=Math.max(b.lat,c.lat),d=Math.min(b.lat,c.lat),e=Math.min(b.lon,c.lon),b=Math.max(b.lon,c.lon);this.map.zoomToExtent(new OpenLayers.Bounds(e,d,b,a))}else c=this.map.getLonLatFromViewPortPx(a.xy),this.map.setCenter(new OpenLayers.LonLat(c.lon,c.lat),this.map.getZoom()+
+1);this.removeZoomBox()}},removeZoomBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null},onWheelEvent:function(a){for(var b=!1,c=OpenLayers.Event.element(a);null!=c;){if(this.map&&c==this.map.div){b=!0;break}c=c.parentNode}if(b){b=0;if(!a)a=window.event;a.wheelDelta?(b=a.wheelDelta/120,window.opera&&9.2>window.opera.version()&&(b=-b)):a.detail&&(b=-a.detail/3);if(b)a.xy=this.mousePosition,0>b?this.defaultWheelDown(a):this.defaultWheelUp(a);OpenLayers.Event.stop(a)}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});
+OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(a)this.position=a;if(b)this.direction=b;this.measureDivs=[]},destroy:function(){for(var a in this.buttons){var b=this.buttons[a];b.map=null;b.events.destroy()}OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,
+arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var a=new OpenLayers.Size(28,28),b=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",b,a,"Shift->Drag to zoom to area");b=b.add("vertical"==this.direction?0:a.w,"vertical"==this.direction?a.h:0);this._addButton("pan","panning-hand-off.png","panning-hand-on.png",
+b,a,"Drag the map to pan.");b.add("vertical"==this.direction?0:a.w,"vertical"==this.direction?a.h:0);this.switchModeTo("pan");return this.div},_addButton:function(a,b,c,d,e,f){b=OpenLayers.Util.getImagesLocation()+b;c=OpenLayers.Util.getImagesLocation()+c;d=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+a,d,e,b,"absolute");this.div.appendChild(d);d.imgLocation=b;d.activeImgLocation=c;d.events=new OpenLayers.Events(this,d,null,!0);d.events.on({mousedown:this.buttonDown,mouseup:this.buttonUp,
+dblclick:OpenLayers.Event.stop,scope:this});d.action=a;d.title=f;d.alt=f;d.map=this.map;return this.buttons[a]=d},buttonDown:function(a){if(OpenLayers.Event.isLeftClick(a))this.buttonClicked=a.element.action,OpenLayers.Event.stop(a)},buttonUp:function(a){if(OpenLayers.Event.isLeftClick(a)&&null!=this.buttonClicked)this.buttonClicked==a.element.action&&this.switchModeTo(a.element.action),OpenLayers.Event.stop(a),this.buttonClicked=null},defaultDblClick:function(a){this.switchModeTo("pan");this.performedDrag=
+!1;this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom+1);OpenLayers.Event.stop(a);return!1},defaultMouseDown:function(a){if(OpenLayers.Event.isLeftClick(a)){this.mouseDragStart=a.xy.clone();this.startViaKeyboard=this.performedDrag=!1;a.shiftKey&&"zoombox"!=this.mode?(this.switchModeTo("zoombox"),this.startViaKeyboard=!0):a.altKey&&"measure"!=this.mode?this.switchModeTo("measure"):this.mode||this.switchModeTo("pan");switch(this.mode){case "zoombox":this.map.div.style.cursor="crosshair";
+this.zoomBox=OpenLayers.Util.createDiv("zoomBox",this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.eventsDiv.appendChild(this.zoomBox);this.performedDrag=!0;break;case "measure":var b="";if(this.measureStart)b=this.map.getLonLatFromViewPortPx(this.mouseDragStart),b=OpenLayers.Util.distVincenty(this.measureStart,
+b),b=Math.round(100*b)/100,b+="km",this.measureStartBox=this.measureBox;this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=
+this.map.Z_INDEX_BASE.Popup-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(b)this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute"),this.measureBoxDistance.innerHTML=b,this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE.Popup-1,this.map.layerContainerDiv.appendChild(this.measureBoxDistance),this.measureDivs.push(this.measureBoxDistance);
+this.measureBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move"}document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(a)}},switchModeTo:function(a){if(a!=this.mode){this.mode&&this.buttons[this.mode]&&OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);if("measure"==this.mode&&"measure"!=
+a){for(var b=0,c=this.measureDivs.length;b<c;b++)this.measureDivs[b]&&this.map.layerContainerDiv.removeChild(this.measureDivs[b]);this.measureDivs=[];this.measureStart=null}this.mode=a;this.buttons[a]&&OpenLayers.Util.modifyAlphaImageDiv(this.buttons[a],null,null,null,this.buttons[a].activeImgLocation);switch(this.mode){case "zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor=""}}},leaveMode:function(){this.switchModeTo("pan")},defaultMouseMove:function(a){if(null!=
+this.mouseDragStart){switch(this.mode){case "zoombox":var b=Math.abs(this.mouseDragStart.x-a.xy.x),c=Math.abs(this.mouseDragStart.y-a.xy.y);this.zoomBox.style.width=Math.max(1,b)+"px";this.zoomBox.style.height=Math.max(1,c)+"px";if(a.xy.x<this.mouseDragStart.x)this.zoomBox.style.left=a.xy.x+"px";if(a.xy.y<this.mouseDragStart.y)this.zoomBox.style.top=a.xy.y+"px";break;default:var b=this.mouseDragStart.x-a.xy.x,c=this.mouseDragStart.y-a.xy.y,d=this.map.getSize();this.map.setCenter(this.map.getLonLatFromViewPortPx(new OpenLayers.Pixel(d.w/
+2+b,d.h/2+c)),null,!0);this.mouseDragStart=a.xy.clone()}this.performedDrag=!0}},defaultMouseUp:function(a){if(OpenLayers.Event.isLeftClick(a)){switch(this.mode){case "zoombox":this.zoomBoxEnd(a);this.startViaKeyboard&&this.leaveMode();break;case "pan":this.performedDrag&&this.map.setCenter(this.map.center)}this.mouseDragStart=document.onselectstart=null;this.map.div.style.cursor="default"}},defaultMouseOut:function(a){if(null!=this.mouseDragStart&&OpenLayers.Util.mouseLeft(a,this.map.eventsDiv))this.zoomBox&&
+(this.removeZoomBox(),this.startViaKeyboard&&this.leaveMode()),this.mouseDragStart=null,this.map.div.style.cursor="default"},defaultClick:function(){if(this.performedDrag)return this.performedDrag=!1},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;
+OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,styleFrom:null,initialize:function(a,b){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments)},addNodes:function(a,b){if(2>a.length)throw Error("At least two point features have to be added to create a line from");for(var c=Array(a.length-1),d,e,f,g=0,h=a.length;g<h;g++){d=a[g];if(f=d.geometry){if("OpenLayers.Geometry.Point"!=f.CLASS_NAME)throw new TypeError("Only features with point geometries are supported.");
+}else f=d.lonlat,f=new OpenLayers.Geometry.Point(f.lon,f.lat);if(0<g){d=null!=this.dataFrom?a[g+this.dataFrom].data||a[g+this.dataFrom].attributes:null;var i=null!=this.styleFrom?a[g+this.styleFrom].style:null;e=new OpenLayers.Geometry.LineString([e,f]);c[g-1]=new OpenLayers.Feature.Vector(e,d,i)}e=f}this.addFeatures(c,b)},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.SOURCE_NODE=-1;OpenLayers.Layer.PointTrack.TARGET_NODE=0;
+OpenLayers.Layer.PointTrack.dataFrom={SOURCE_NODE:-1,TARGET_NODE:0};OpenLayers.Protocol.WFS=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.WFS.DEFAULTS),b=OpenLayers.Protocol.WFS["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFS version: "+a.version;return new b(a)};
+OpenLayers.Protocol.WFS.fromWMSLayer=function(a,b){var c,d;c=a.params.LAYERS;c=(OpenLayers.Util.isArray(c)?c[0]:c).split(":");1<c.length&&(d=c[0]);c=c.pop();d={url:a.url,featureType:c,featurePrefix:d,srsName:a.projection&&a.projection.getCode()||a.map&&a.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(b,d))};OpenLayers.Protocol.WFS.DEFAULTS={version:"1.0.0"};
+OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!1,markers:null,drawn:!1,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[]},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;for(var a=0,b=this.markers.length;a<b;a++)this.markers[a].setOpacity(this.opacity)}},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,
+arguments);if(b||!this.drawn){for(var d=0,e=this.markers.length;d<e;d++)this.drawMarker(this.markers[d]);this.drawn=!0}},addMarker:function(a){this.markers.push(a);1>this.opacity&&a.setOpacity(this.opacity);if(this.map&&this.map.getExtent())a.map=this.map,this.drawMarker(a)},removeMarker:function(a){this.markers&&this.markers.length&&(OpenLayers.Util.removeItem(this.markers,a),a.erase())},clearMarkers:function(){if(null!=this.markers)for(;0<this.markers.length;)this.removeMarker(this.markers[0])},
+drawMarker:function(a){var b=this.map.getLayerPxFromLonLat(a.lonlat);null==b?a.display(!1):a.isDrawn()?a.icon&&a.icon.moveTo(b):this.div.appendChild(a.draw(b))},getDataExtent:function(){var a=null;if(this.markers&&0<this.markers.length)for(var a=new OpenLayers.Bounds,b=0,c=this.markers.length;b<c;b++)a.extend(this.markers[b].lonlat);return a},CLASS_NAME:"OpenLayers.Layer.Markers"});
+OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:!1,adapter:null,handlers:null,displayResults:!0,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:!1,toggle:!0,multiple:!1,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(a,b,c,d){OpenLayers.Control.prototype.initialize.apply(this,
+[d]);this.url=a;this.layer=b&&b instanceof OpenLayers.Layer.Vector?b:new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:!1,isBaseLayer:!1});if(c)this.taskCallbacks=c;a={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,multiple:this.multiple,callbacks:{dblclick:dojo.hitch(this,this._execute)}};this.selectControl=new OpenLayers.Control.SelectFeature(this.layer,a);a=OpenLayers.Util.extend({callbacks:{done:dojo.hitch(this,this._execute)}},this.drawCtrlHandlerOptions);
+this.drawControl=new OpenLayers.Control.DrawFeature(this.layer,this.drawCtrlHandler,a);this.handlers={};this.adapter=new OpenLayers.Format.AgsJsAdapter;this._resultFeatures=[];this._resultImages=[];OpenLayers.Util.applyDefaults(this.resultImageOptions,{opacity:1});this._isDefined=OpenLayers.Util.AgsUtil.isDefined;this._isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;this._isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction},destroy:function(){this.layer=
+null;this.selectControl.destroy();this.drawControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){return"select"==this.mode?this.selectControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments):"draw"==this.mode?this.drawControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments):!1},deactivate:function(){var a=!1;OpenLayers.Control.prototype.deactivate.apply(this,arguments)&&(this.drawControl.deactivate(),this.selectControl.deactivate(),
+a=!0);return a},_execute:function(a){var b=null;if(this._isOLGeometry(a)){if(!0==this.multiple)return OpenLayers.Console.log("...to allow multiple features as operation input..."),OpenLayers.Console.log("..._execute will not be triggered by 'done' drawing a geometry on map..."),this.drawControl.drawFeature(a),!0;OpenLayers.Console.log("..._execute triggered by 'done' drawing a geometry on map...");OpenLayers.Console.log("...single feature as operation input...");b=[new OpenLayers.Feature.Vector(a)]}else if(a instanceof
+OpenLayers.Feature.Vector)OpenLayers.Console.log("..._execute triggered by 'dblclick' a feature on map..."),!0==this.multiple?(OpenLayers.Console.log("...allow multiple features as operation input..."),b=this.layer.selectedFeatures):(OpenLayers.Console.log("...single feature as operation input..."),b=[a]);else if(a instanceof Array)OpenLayers.Console.log("..._execute triggered by using all selected features on the map..."),b=a;else throw OpenLayers.Console.error("...input geometry or feature is missing or invalid..."),
+"...input geometry or feature is missing or invalid...";this.execute(b,{},[])},execute:function(){OpenLayers.Console.error("...execute of OpenLayers.Control.AgsControl is not implemented...");throw"...execute of OpenLayers.Control.AgsControl is not implemented...";},onExecuteComplete:function(a,b){OpenLayers.Console.debug("...AgsControl OnExecuteComplete is called...");var c=null;try{if(this._resultsParser.context&&"function"===typeof this._resultsParser.parser)c=this._resultsParser.parser.apply(this._resultsParser.context,
+[a,b.args_list]);else throw OpenLayers.Console.error("..._resultsParser is missing or invalid..."),"..._resultsParser is missing or invalid...";}catch(d){throw OpenLayers.Console.error(d.message),d.message;}c instanceof OpenLayers.Feature.Vector&&(c=[c]);this.cleanupResults();this.addResults(c);!0===this.displayResults&&this.showResults();b.callback.apply(this,[c])},onExecuteAsynComplete:function(a,b){OpenLayers.Util.extend({resultFeatures:this._resultFeatures,resultImages:this._resultImages},b);
+try{if(this._resultsParser.context&&"function"===typeof this._resultsParser.parser)this._resultsParser.parser.apply(this._resultsParser.context,[a,b]);else throw OpenLayers.Console.error("..._resultsParser is missing or invalid..."),"..._resultsParser is missing or invalid...";}catch(c){throw c;}},setTaskParameters:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.taskParameters);OpenLayers.Util.extend(this.taskParameters,a)},addResults:function(a){for(var b=0;b<a.length;b++){var c=
+a[b];c instanceof OpenLayers.Feature.Vector?this._resultFeatures.push(c):c instanceof OpenLayers.Layer.Image?(c.setVisibility(!1),c.setOpacity(this.resultImageOptions.opacity),this.map.addLayer(c),this.map.setLayerIndex(c,this.map.getLayerIndex(this.layer)+1),this._resultImages.push(c)):OpenLayers.Console.log("...skip adding because it's not OpenLayers.Feature.Vector or OpenLayers.Layer.Image...")}},cleanupResults:function(){this.hideResults();if(this._resultFeatures&&0<this._resultFeatures.length)for(var a=
+0;a<this._resultFeatures.length;a++)this._resultFeatures[a].destroy();this._resultFeatures.length=0;if(this._resultImages&&0<this._resultImages.length)for(a=0;a<this._resultImages.length;a++)this.map.removeLayer(this._resultImages[a]);this._resultImages.length=0},hideResults:function(){this._resultFeatures&&0<this._resultFeatures.length&&this.layer.removeFeatures(this._resultFeatures);if(this._resultImages&&0<this._resultImages.length)for(var a=0;a<this._resultImages.length;a++)this._resultImages[a].setVisibility(!1)},
+showResults:function(){this._resultFeatures&&0<this._resultFeatures.length&&this.layer.addFeatures(this._resultFeatures);if(this._resultImages&&0<this._resultImages.length)for(var a=0;a<this._resultImages.length;a++)this._resultImages[a].setVisibility(!0)},switchMode:function(a){var b=this.active;!0===this.active&&this.deactivate();"select"===this.mode&&this.selectControl.unselectAll();if("select"===a||"draw"===a)this.mode=a;!0===b&&this.activate();OpenLayers.Console.log("...control mode switched...current control mode: "+
+this.mode+"...")},switchDrawCtrlHandler:function(a){var b=this.active;!0===this.active&&this.deactivate();"select"===this.mode&&this.selectControl.unselectAll();this.drawControl.handler=new a(this.drawControl,this.drawControl.callbacks,this.drawControl.handlerOptions);this.drawCtrlHandler=this.drawControl.handler;!0===b&&this.activate();OpenLayers.Console.log("...DrawCtrlHandler switched...current DrawCtrlHandler: "+this.drawCtrlHandler.CLASS_NAME+"...")},setMap:function(a){(!this.layer.map||!(this.layer.map instanceof
+OpenLayers.Map))&&a.addLayer(this.layer);this.selectControl.setMap(a);this.drawControl.setMap(a);OpenLayers.Util.extend(this.adapter.config,{defaultEncodeWkid:this.layer.map.projection});OpenLayers.Control.prototype.setMap.apply(this,arguments);OpenLayers.Console.debug("...current control mode: "+this.mode+"...");OpenLayers.Console.debug("...current DrawCtrlHandler: "+this.drawCtrlHandler.prototype.CLASS_NAME+"...");OpenLayers.Console.log("...adapter defaultEncodeWkid: "+this.adapter.config.defaultEncodeWkid+
+"...")},_createCallbacks:function(a,b,c){return dojo.hitch(this,function(d){for(var e=null,f=0;f<b.length;f++)if(e=b[f],"function"==typeof e)c.args_list=arguments,e.apply(a,[d,c])})},CLASS_NAME:"OpenLayers.Control.AgsControl"});
+OpenLayers.Control.AgsIdentifyTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!1,asynchronous:!1,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={dpi:96,geometry:null,height:0,layerIds:[0],layerOption:"all",mapExtent:null,returnGeometry:!0,spatialReference:null,tolerance:1,width:0};this._resultsParser={parser:this.adapter.parseAgsResults.identifyResults,context:this.adapter};this.execute=this._bindFunction(this.execute,
+this)},execute:function(a,b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);if(this._isDefined(this.layer.map))b.width=this.layer.map.getSize().w?this.layer.map.getSize().w:b.width,b.height=this.layer.map.getSize().h?this.layer.map.getSize().h:b.height,b.mapExtent=this.layer.map.getExtent()?this.layer.map.getExtent():b.mapExtent,b.spatialReference=this.layer.map.projection?this.layer.map.projection:b.spatialReference;else throw OpenLayers.Console.error("...can not execute identify task...this.layer.map is not valid..."),
+"...can not execute identify task...this.layer.map is not valid...";if(a[0]instanceof OpenLayers.Feature.Vector)b.geometry=a[0].geometry;else throw OpenLayers.Console.error("...can not execute identify task...input geometry is not valid..."),"...can not execute identify task...input geometry is not valid...";a=[];a=a.concat(this.taskCallbacks);a=a.concat(c);a=this._createCallbacks(this,a,{});if(!1==this.asynchronous){var c=new esri.tasks.IdentifyTask(this.url),a=this._createCallbacks(this,[this.onExecuteComplete],
+{callback:a}),d=this.errback||null;try{var e=this.adapter.encodeAgsIdentifyParameters(b)}catch(f){throw f;}c.execute(e,a,d)}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsIdentifyTask ..."),"...'asynchronous' should always be set to 'false' for AgsIdentifyTask ...";},CLASS_NAME:"OpenLayers.Control.AgsIdentifyTask"});
+OpenLayers.Control.Pan=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,direction:null,type:OpenLayers.Control.TYPE_BUTTON,initialize:function(a,b){this.direction=a;this.CLASS_NAME+=this.direction;OpenLayers.Control.prototype.initialize.apply(this,[b])},trigger:function(){var a=OpenLayers.Function.bind(function(a){return this.slideRatio?this.map.getSize()[a]*this.slideRatio:this.slideFactor},this);switch(this.direction){case OpenLayers.Control.Pan.NORTH:this.map.pan(0,-a("h"));
+break;case OpenLayers.Control.Pan.SOUTH:this.map.pan(0,a("h"));break;case OpenLayers.Control.Pan.WEST:this.map.pan(-a("w"),0);break;case OpenLayers.Control.Pan.EAST:this.map.pan(a("w"),0)}},CLASS_NAME:"OpenLayers.Control.Pan"});OpenLayers.Control.Pan.NORTH="North";OpenLayers.Control.Pan.SOUTH="South";OpenLayers.Control.Pan.EAST="East";OpenLayers.Control.Pan.WEST="West";
+OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",format:"image/jpeg"},reproject:!1,isBaseLayer:!0,encodeBBOX:!1,noMagic:!1,yx:{"EPSG:4326":!0},initialize:function(a,b,c,d){var e=[],c=OpenLayers.Util.upperCaseObject(c);if(1.3<=parseFloat(c.VERSION)&&!c.EXCEPTIONS)c.EXCEPTIONS="INIMAGE";e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));
+if(!this.noMagic&&this.params.TRANSPARENT&&"true"==this.params.TRANSPARENT.toString().toLowerCase()){if(null==d||!d.isBaseLayer)this.isBaseLayer=!1;if("image/jpeg"==this.params.FORMAT)this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png"}},clone:function(a){null==a&&(a=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},reverseAxisOrder:function(){return 1.3<=parseFloat(this.params.VERSION)&&!!this.yx[this.map.getProjectionObject().getCode()]},
+getURL:function(a){var a=this.adjustBounds(a),b=this.getImageSize(),c={},d=this.reverseAxisOrder();c.BBOX=this.encodeBBOX?a.toBBOX(null,d):a.toArray(d);c.WIDTH=b.w;c.HEIGHT=b.h;return this.getFullRequestString(c)},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize,this.tileOptions)},mergeNewParams:function(a){a=[OpenLayers.Util.upperCaseObject(a)];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,a)},getFullRequestString:function(a,b){var c=this.map.getProjectionObject(),
+c=this.projection&&this.projection.equals(c)?this.projection.getCode():c.getCode(),c="none"==c?null:c;1.3<=parseFloat(this.params.VERSION)?(this.params.CRS=this.params.CRS||c,this.params.SRS=null):(this.params.SRS=this.params.SRS||c,this.params.CRS=null);if("boolean"==typeof this.params.TRANSPARENT)a.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments)},CLASS_NAME:"OpenLayers.Layer.WMS"});
+OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:!0,initialize:function(a,b,c,d){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);OpenLayers.Console.warn("The OpenLayers.Layer.WMS.Untiled class is deprecated and will be removed in 3.0. Instead, you should use the normal OpenLayers.Layer.WMS class, passing it the option 'singleTile' as true.")},clone:function(a){null==a&&(a=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.getOptions()));
+return a=OpenLayers.Layer.WMS.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){return(new OpenLayers.Format.ArcXML).read(a).features.feature}});
+OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{DEFAULTS:{tolerance:10,node:!0,edge:!0,vertex:!0},greedy:!0,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.options=a||{};this.options.layer&&this.setLayer(this.options.layer);a=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(a,this.DEFAULTS);this.setTargets(this.options.targets);
+0===this.targets.length&&this.layer&&this.addTargetLayer(this.layer);this.geoToleranceCache={}},setLayer:function(a){this.active?(this.deactivate(),this.layer=a,this.activate()):this.layer=a},setTargets:function(a){this.targets=[];if(a&&a.length)for(var b,c=0,d=a.length;c<d;++c)b=a[c],b instanceof OpenLayers.Layer.Vector?this.addTargetLayer(b):this.addTarget(b)},addTargetLayer:function(a){this.addTarget({layer:a})},addTarget:function(a){a=OpenLayers.Util.applyDefaults(a,this.defaults);a.nodeTolerance=
+a.nodeTolerance||a.tolerance;a.vertexTolerance=a.vertexTolerance||a.tolerance;a.edgeTolerance=a.edgeTolerance||a.tolerance;this.targets.push(a)},removeTargetLayer:function(a){for(var b,c=this.targets.length-1;0<=c;--c)b=this.targets[c],b.layer===a&&this.removeTarget(b)},removeTarget:function(a){return OpenLayers.Util.removeItem(this.targets,a)},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a&&this.layer&&this.layer.events)this.layer.events.on({sketchstarted:this.onSketchModified,
+sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.call(this);a&&this.layer&&this.layer.events&&this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});this.point=this.feature=null;return a},onSketchModified:function(a){this.feature=a.feature;this.considerSnapping(a.vertex,a.vertex)},onVertexModified:function(a){this.feature=
+a.feature;var b=this.layer.map.getLonLatFromViewPortPx(a.pixel);this.considerSnapping(a.vertex,new OpenLayers.Geometry.Point(b.lon,b.lat))},considerSnapping:function(a,b){for(var c={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY,x:null,y:null},d=!1,e,f,g=0,h=this.targets.length;g<h;++g)if(f=this.targets[g],e=this.testTarget(f,b))if(this.greedy){c=e;c.target=f;d=!0;break}else if(e.rank<c.rank||e.rank===c.rank&&e.dist<c.dist)c=e,c.target=f,d=!0;if(d)!1!==this.events.triggerEvent("beforesnap",
+{point:a,x:c.x,y:c.y,distance:c.dist,layer:c.target.layer,snapType:this.precedence[c.rank]})?(a.x=c.x,a.y=c.y,this.point=a,this.events.triggerEvent("snap",{point:a,snapType:this.precedence[c.rank],layer:c.target.layer,distance:c.dist})):d=!1;if(this.point&&!d)a.x=b.x,a.y=b.y,this.point=null,this.events.triggerEvent("unsnap",{point:a})},testTarget:function(a,b){var c=this.layer.map.getResolution();if("minResolution"in a&&c<a.minResolution||"maxResolution"in a&&c>=a.maxResolution)return null;for(var c=
+{node:this.getGeoTolerance(a.nodeTolerance,c),vertex:this.getGeoTolerance(a.vertexTolerance,c),edge:this.getGeoTolerance(a.edgeTolerance,c)},d=Math.max(c.node,c.vertex,c.edge),e={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY},f=!1,g=a.layer.features,h,i,j,k,m,n,l=this.precedence.length,o=new OpenLayers.LonLat(b.x,b.y),q=0,r=g.length;q<r;++q)if(h=g[q],h!==this.feature&&!h._sketch&&h.state!==OpenLayers.State.DELETE&&(!a.filter||a.filter.evaluate(h))&&h.atPoint(o,d,d))for(var p=0,s=Math.min(e.rank+
+1,l);p<s;++p)if(i=this.precedence[p],a[i])if("edge"===i){if(j=h.geometry.distanceTo(b,{details:!0}),m=j.distance,m<=c[i]&&m<e.dist){e={rank:p,dist:m,x:j.x0,y:j.y0};f=!0;break}}else{j=h.geometry.getVertices("node"===i);n=!1;for(var t=0,u=j.length;t<u;++t)if(k=j[t],m=k.distanceTo(b),m<=c[i]&&(p<e.rank||p===e.rank&&m<e.dist))e={rank:p,dist:m,x:k.x,y:k.y},n=f=!0;if(n)break}return f?e:null},getGeoTolerance:function(a,b){if(b!==this.resolution)this.resolution=b,this.geoToleranceCache={};var c=this.geoToleranceCache[a];
+void 0===c&&(c=a*b,this.geoToleranceCache[a]=c);return c},destroy:function(){this.active&&this.deactivate();delete this.layer;delete this.targets;OpenLayers.Control.prototype.destroy.call(this)},CLASS_NAME:"OpenLayers.Control.Snapping"});OpenLayers.Format.CSWGetDomain=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetDomain.DEFAULTS),b=OpenLayers.Format.CSWGetDomain["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetDomain version: "+a.version;return new b(a)};
+OpenLayers.Format.CSWGetDomain.DEFAULTS={version:"2.0.2"};
+OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{csw:{GetDomainResponse:function(a,b){this.readChildNodes(a,b)},DomainValues:function(a,b){if(!OpenLayers.Util.isArray(b.DomainValues))b.DomainValues=[];for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;this.readChildNodes(a,d);b.DomainValues.push(d)},PropertyName:function(a,b){b.PropertyName=this.getChildValue(a)},ParameterName:function(a,
+b){b.ParameterName=this.getChildValue(a)},ListOfValues:function(a,b){if(!OpenLayers.Util.isArray(b.ListOfValues))b.ListOfValues=[];this.readChildNodes(a,b.ListOfValues)},Value:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.push({Value:d})},ConceptualScheme:function(a,b){b.ConceptualScheme={};this.readChildNodes(a,b.ConceptualScheme)},Name:function(a,b){b.Name=this.getChildValue(a)},Document:function(a,b){b.Document=this.getChildValue(a)},
+Authority:function(a,b){b.Authority=this.getChildValue(a)},RangeOfValues:function(a,b){b.RangeOfValues={};this.readChildNodes(a,b.RangeOfValues)},MinValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MinValue=d},MaxValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MaxValue=d}}},write:function(a){a=this.writeNode("csw:GetDomain",a);return OpenLayers.Format.XML.prototype.write.apply(this,
+[a])},writers:{csw:{GetDomain:function(a){var b=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(a.PropertyName||this.PropertyName)this.writeNode("csw:PropertyName",a.PropertyName||this.PropertyName,b);else if(a.ParameterName||this.ParameterName)this.writeNode("csw:ParameterName",a.ParameterName||this.ParameterName,b);this.readChildNodes(b,a);return b},PropertyName:function(a){return this.createElementNSPlus("csw:PropertyName",{value:a})},ParameterName:function(a){return this.createElementNSPlus("csw:ParameterName",
+{value:a})}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});
+OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{ows:OpenLayers.Util.applyDefaults({ExceptionReport:function(a,b){b.exceptionReport={version:a.getAttribute("version"),language:a.getAttribute("xml:lang"),exceptions:[]};this.readChildNodes(a,b.exceptionReport)},AllowedValues:function(a,b){b.allowedValues={};this.readChildNodes(a,b.allowedValues)},AnyValue:function(a,b){b.anyValue=
+!0},DataType:function(a,b){b.dataType=this.getChildValue(a)},Range:function(a,b){b.range={};this.readChildNodes(a,b.range)},MinimumValue:function(a,b){b.minValue=this.getChildValue(a)},MaximumValue:function(a,b){b.maxValue=this.getChildValue(a)},Identifier:function(a,b){b.identifier=this.getChildValue(a)},SupportedCRS:function(a,b){b.supportedCRS=this.getChildValue(a)}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{ows:OpenLayers.Util.applyDefaults({Range:function(a){var b=this.createElementNSPlus("ows:Range",
+{attributes:{"ows:rangeClosure":a.closure}});this.writeNode("ows:MinimumValue",a.minValue,b);this.writeNode("ows:MaximumValue",a.maxValue,b);return b},MinimumValue:function(a){return this.createElementNSPlus("ows:MinimumValue",{value:a})},MaximumValue:function(a){return this.createElementNSPlus("ows:MaximumValue",{value:a})},Value:function(a){return this.createElementNSPlus("ows:Value",{value:a})}},OpenLayers.Format.OWSCommon.v1.prototype.writers.ows)},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});
+OpenLayers.Format.WCSGetCoverage=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wcs:"http://www.opengis.net/wcs/1.1",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.1.2",schemaLocation:"http://www.opengis.net/wcs/1.1 http://schemas.opengis.net/wcs/1.1/wcsGetCoverage.xsd",write:function(a){a=this.writeNode("wcs:GetCoverage",
+a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{wcs:{GetCoverage:function(a){var b=this.createElementNSPlus("wcs:GetCoverage",{attributes:{version:a.version||this.VERSION,service:"WCS"}});this.writeNode("ows:Identifier",a.identifier,b);this.writeNode("wcs:DomainSubset",a.domainSubset,b);this.writeNode("wcs:Output",a.output,b);return b},DomainSubset:function(a){var b=this.createElementNSPlus("wcs:DomainSubset",
+{});this.writeNode("ows:BoundingBox",a.boundingBox,b);a.temporalSubset&&this.writeNode("wcs:TemporalSubset",a.temporalSubset,b);return b},TemporalSubset:function(a){for(var b=this.createElementNSPlus("wcs:TemporalSubset",{}),c=0,d=a.timePeriods.length;c<d;++c)this.writeNode("wcs:TimePeriod",a.timePeriods[c],b);return b},TimePeriod:function(a){var b=this.createElementNSPlus("wcs:TimePeriod",{});this.writeNode("wcs:BeginPosition",a.begin,b);this.writeNode("wcs:EndPosition",a.end,b);a.resolution&&this.writeNode("wcs:TimeResolution",
+a.resolution,b);return b},BeginPosition:function(a){return this.createElementNSPlus("wcs:BeginPosition",{value:a})},EndPosition:function(a){return this.createElementNSPlus("wcs:EndPosition",{value:a})},TimeResolution:function(a){return this.createElementNSPlus("wcs:TimeResolution",{value:a})},Output:function(a){var b=this.createElementNSPlus("wcs:Output",{attributes:{format:a.format,store:a.store}});a.gridCRS&&this.writeNode("wcs:GridCRS",a.gridCRS,b);return b},GridCRS:function(a){var b=this.createElementNSPlus("wcs:GridCRS",
+{});this.writeNode("wcs:GridBaseCRS",a.baseCRS,b);a.type&&this.writeNode("wcs:GridType",a.type,b);a.origin&&this.writeNode("wcs:GridOrigin",a.origin,b);this.writeNode("wcs:GridOffsets",a.offsets,b);a.CS&&this.writeNode("wcs:GridCS",a.CS,b);return b},GridBaseCRS:function(a){return this.createElementNSPlus("wcs:GridBaseCRS",{value:a})},GridOrigin:function(a){return this.createElementNSPlus("wcs:GridOrigin",{value:a})},GridType:function(a){return this.createElementNSPlus("wcs:GridType",{value:a})},GridOffsets:function(a){return this.createElementNSPlus("wcs:GridOffsets",
+{value:a})},GridCS:function(a){return this.createElementNSPlus("wcs:GridCS",{value:a})}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WCSGetCoverage"});
+OpenLayers.Control.AgsGeometryService=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!0,asynchronous:!1,geometryServiceType:"buffer",initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={bufferSpatialReference:null,distances:[1],features:null,outSpatialReference:null,unionResults:!1,unit:"UNIT_KILOMETER",spatialRelationship:"INTERSECTION",inSpatialReference:"EPSG:4326",comparisonString:null};this._resultsParser={parser:this.adapter.parseAgsGraphics,
+context:this.adapter};this.execute=this._bindFunction(this.execute,this)},execute:function(a,b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);var d=[],d=d.concat(this.taskCallbacks),d=d.concat(c),d=this._createCallbacks(this,d,{});if(!1==this.asynchronous){var c=new esri.tasks.GeometryService(this.url),d=this._createCallbacks(this,[this.onExecuteComplete],{callback:d}),e=this.errback||null;try{switch(this.geometryServiceType){case "buffer":b.bufferSpatialReference=
+this.layer.map.projection?this.layer.map.projection:b.bufferSpatialReference;b.features=a?a:b.features;var f=this.adapter.encodeAgsBufferParameters(b);c.buffer(f,d,e);break;case "project":b.inSpatialReference=this.layer.map.projection?this.layer.map.projection:b.inSpatialReference;b.outSpatialReference=b.outSpatialReference||b.inSpatialReference;var g=this.adapter.encodeAgsGraphics(a,b.inSpatialReference),h=this.adapter.encodeAgsSpatialReference(b.outSpatialReference);c.project(g,h,d,e);break;case "relation":b.inSpatialReference=
+this.layer.map.projection?this.layer.map.projection:b.inSpatialReference;var i=this.adapter.encodeAgsGraphics([a[0]],b.inSpatialReference),j=this.adapter.encodeAgsGraphics([a[1]],b.inSpatialReference),k=this.adapter.encodeAgsGeometrySpatialRelationship(b.spatialRelationship);c.relation(i,j,k,b.comparisonString,d,e);break;case "areasAndLengths":case "lengths":case "simplify":case "labelPoints":b.inSpatialReference=this.layer.map.projection?this.layer.map.projection:b.inSpatialReference;g=this.adapter.encodeAgsGraphics(a,
+b.inSpatialReference);c[this.geometryServiceType].apply(c,[g,d,e]);break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...")}}catch(m){throw m;}}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsGeometryService..."),"...'asynchronous' should always be set to 'false' for AgsGeometryService...";},setGeometryServiceType:function(a){this.geometryServiceType=a||this.geometryServiceType;
+switch(this.geometryServiceType){case "buffer":case "labelPoints":case "project":case "simplify":this._resultsParser.parser=this.adapter.parseAgsGraphics;break;case "relation":this._resultsParser.parser=this.adapter.parseAgsResults.relations;break;case "areasAndLengths":case "lengths":this._resultsParser.parser=this.adapter.parseAgsResults.areasAndLengths;break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...")}},
+CLASS_NAME:"OpenLayers.Control.AgsGeometryService"});
+OpenLayers.Control.AgsLocator=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!1,asynchronous:!1,reverseGeocoding:!1,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={address:{},distance:50,outFields:[],location:null};this._resultsParser=!0==this.reverseGeocoding?{parser:this.adapter.parseAgsResults.addressCandidate,context:this.adapter}:{parser:this.adapter.parseAgsResults.addressCandidates,context:this.adapter};this.execute=
+this._bindFunction(this.execute,this)},execute:function(a,b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);var d=[],d=d.concat(this.taskCallbacks),d=d.concat(c),d=this._createCallbacks(this,d,{});if(!1==this.asynchronous){var c=new esri.tasks.Locator(this.url),d=this._createCallbacks(this,[this.onExecuteComplete],{callback:d}),e=this.errback||null;if(!0==this.reverseGeocoding){if(a[0]instanceof OpenLayers.Feature.Vector&&a[0].geometry instanceof OpenLayers.Geometry.Point)b.location=
+a[0].geometry;if(!b.location)throw OpenLayers.Console.error("...'location' missing or invalid..."),"...'location' missing or invalid...";if(!b.distance)throw OpenLayers.Console.error("...'distance' missing or invalid..."),"...'distance' missing or invalid...";a=null;a=this.adapter.encodeAgsLocation(b.location);c.locationToAddress(a,b.distance,d,e)}else{if(!b.address)throw OpenLayers.Console.error("...'address' missing or invalid..."),"...'address' missing or invalid...";if(!b.outFields)throw OpenLayers.Console.error("...'outFields' missing or invalid..."),
+"...'outFields' missing or invalid...";c.addressToLocations(b.address,b.outFields,d,e)}}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator..."),"...'asynchronous' should always be set to 'false' for AgsLocator...";},setReverseGeocoding:function(a){!0==a?(this.reverseGeocoding=!0,this._resultsParser.parser=this.adapter.parseAgsResults.addressCandidate):(this.reverseGeocoding=!1,this._resultsParser.parser=this.adapter.parseAgsResults.addressCandidates)},
+CLASS_NAME:"OpenLayers.Control.AgsLocator"});
+OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);if(!a.format)this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,
+geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));!a.geometryName&&1<parseFloat(this.format.version)&&this.setGeometryName(null)},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||{});var b=new OpenLayers.Protocol.Response({requestType:"read"}),
+c=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",a)]);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,b,a),params:a.params,headers:a.headers,data:c});return b},setFeatureType:function(a){this.featureType=a;this.format.featureType=a},setGeometryName:function(a){this.geometryName=a;this.format.geometryName=a},handleRead:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);if(b.callback){var c=
+a.priv;200<=c.status&&300>c.status?(c=this.parseResponse(c,b.readOptions))&&!1!==c.success?(b.readOptions&&"object"==b.readOptions.output?OpenLayers.Util.extend(a,c):a.features=c,a.code=OpenLayers.Protocol.Response.SUCCESS):(a.code=OpenLayers.Protocol.Response.FAILURE,a.error=c):a.code=OpenLayers.Protocol.Response.FAILURE;b.callback.call(b.scope,a)}},parseResponse:function(a,b){var c=a.responseXML;if(!c||!c.documentElement)c=a.responseText;if(!c||0>=c.length)return null;c=null!==this.readFormat?this.readFormat.read(c):
+this.format.read(c,b);if(!this.featureNS){var d=this.readFormat||this.format;this.featureNS=d.featureNS;d.autoConfig=!1;this.geometryName||this.setGeometryName(d.geometryName)}return c},commit:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);var c=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:a});c.priv=OpenLayers.Request.POST({url:b.url,headers:b.headers,data:this.format.write(a,b),callback:this.createCallback(this.handleCommit,c,b)});
+return c},handleCommit:function(a,b){if(b.callback){var c=a.priv,d=c.responseXML;if(!d||!d.documentElement)d=c.responseText;c=this.format.read(d)||{};a.insertIds=c.insertIds||[];c.success?a.code=OpenLayers.Protocol.Response.SUCCESS:(a.code=OpenLayers.Protocol.Response.FAILURE,a.error=c);b.callback.call(b.scope,a)}},filterDelete:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);new OpenLayers.Protocol.Response({requestType:"commit"});var c=this.format.createElementNSPlus("wfs:Transaction",
+{attributes:{service:"WFS",version:this.version}}),d=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(b.featureNS?this.featurePrefix+":":"")+b.featureType}});b.featureNS&&d.setAttribute("xmlns:"+this.featurePrefix,b.featureNS);var e=this.format.writeNode("ogc:Filter",a);d.appendChild(e);c.appendChild(d);c=OpenLayers.Format.XML.prototype.write.apply(this.format,[c]);return OpenLayers.Request.POST({url:this.url,callback:b.callback||function(){},data:c})},abort:function(a){a&&a.priv.abort()},
+CLASS_NAME:"OpenLayers.Protocol.WFS.v1"});
+OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:!1,format:null,formatOptions:null,initialize:function(a,b,c){var d=[];d.push(a,c);OpenLayers.Layer.Vector.prototype.initialize.apply(this,d);this.url=b},setVisibility:function(a,b){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);this.visibility&&!this.loaded&&this.loadGML()},moveTo:function(a,b,c){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);this.visibility&&!this.loaded&&this.loadGML()},
+loadGML:function(){if(!this.loaded)this.events.triggerEvent("loadstart"),OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this}),this.loaded=!0},setUrl:function(a){this.url=a;this.destroyFeatures();this.loaded=!1;this.loadGML()},requestSuccess:function(a){var b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;a={};OpenLayers.Util.extend(a,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject()))a.externalProjection=
+this.projection,a.internalProjection=this.map.getProjectionObject();this.addFeatures((this.format?new this.format(a):new OpenLayers.Format.GML(a)).read(b));this.events.triggerEvent("loadend")},requestFailure:function(){OpenLayers.Console.userError("Error in loading GML file "+this.url);this.events.triggerEvent("loadend")},CLASS_NAME:"OpenLayers.Layer.GML"});
+OpenLayers.Format.WFSTWithLock=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WFSTWithLock.DEFAULTS),b=OpenLayers.Format.WFSTWithLock["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFSTWithLock version: "+a.version;return new b(a)};OpenLayers.Format.WFSTWithLock.DEFAULTS={version:"1.1.0"};
+OpenLayers.Format.WFSTWithLock.v1=OpenLayers.Class(OpenLayers.Format.WFST.v1,{lockExpiry:"1",releaseAction:"ALL",attributes:{},attribute_alias:{},encodeAttributes:!1,xy:!1,initialize:function(a){if(a.featureNS)this.namespaces=OpenLayers.Util.extend({feature:a.featureNS},OpenLayers.Format.WFST.v1.prototype.namespaces);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[a]);this.namespaces[this.featurePrefix]=this.featureNS;OpenLayers.Util.extend(this,{readOgcExpression:this.readOgcExpression||
+OpenLayers.Format.Filter.v1.prototype.readOgcExpression,getFilterType:this.getFilterType||OpenLayers.Format.Filter.v1.prototype.getFilterType,filterMap:this.filterMap||OpenLayers.Format.Filter.v1.prototype.filterMap,setGeometryTypes:this.setGeometryTypes||OpenLayers.Format.GML.Base.prototype.setGeometryTypes,regExes:this.regExes||OpenLayers.Format.GML.Base.prototype.regExes});OpenLayers.Format.GML.Base.prototype.setGeometryTypes.call(this);this.geometryTypes["OpenLayers.Geometry.MultiLineString"]=
+"MultiCurve";this.geometryTypes["OpenLayers.Geometry.MultiPolygon"]="MultiSurface";this.schema&&""!=this.schema&&OpenLayers.loadURL(this.schema,null,null,OpenLayers.Function.bind(function(a){var c=(new OpenLayers.Format.WFSDescribeFeatureType).read(a.responseXML||a.responseText);this.attributes={};if(c.targetNamespace==this.featureNS&&c.targetPrefix==this.featurePrefix)for(var d=0;d<c.featureTypes.length;d++)if(a=c.featureTypes[d],a.typeName==this.featureType){for(c=0;c<a.properties.length;c++)"gml"!=
+a.properties[c].type.split(":")[0]&&(this.attributes[a.properties[c].name]=a.properties[c]);break}},this))},read:function(a,b){b=b||{};OpenLayers.Util.applyDefaults(b,{output:"features"});"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var c={};this.readNode(a,c);var d=c.lockId;if(c.features&&"features"===b.output)for(var c=c.features,e=0;e<c.length;e++)c[e].lockId=d;return c},readers:{wfs:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,
+b){b.features=[];var c=a.getAttribute("lockId");b.lockId=""===c?null:c;this.readChildNodes(a,b)}},OpenLayers.Format.WFST.v1.prototype.readers.wfs)},writers:{wfs:OpenLayers.Util.applyDefaults({GetFeatureWithLock:function(a){var b=this.createElementNSPlus("wfs:GetFeatureWithLock",{attributes:{service:"WFS",version:this.version,outputFormat:a&&a.outputFormat,maxFeatures:a&&a.maxFeatures,expiry:this.lockExpiry,"xsi:schemaLocation":this.schemaLocationAttr()}});this.writeNode("Query",a,b);return b},Transaction:function(a){var b=
+this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,releaseAction:this.releaseAction}});if(a){var c,d;c=!0;d={};c=!1;for(var e=0,f=a.length;e<f&&!(null===a[e].lockId);++e)d[a[e].lockId]=a[e].lockId;var e=0,f=null,g;for(g in d)f!=d[g]&&(e++,f=d[g]);1==e&&null!=f&&""!=f&&(c=!0);if(!0===c){"__insert__"!=f&&this.writeNode("LockId",f,b);e=0;for(f=a.length;e<f;++e)d=a[e],(c=this.stateName[d.state])&&this.writeNode(c,d,b)}}return b},UnlockFeature:function(a){var b=
+this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,releaseAction:this.releaseAction}});this.writeNode("LockId",a.lockId,b);return b},LockId:function(a){return this.createElementNSPlus("wfs:LockId",{attributes:{},value:a})}},OpenLayers.Format.WFST.v1.prototype.writers.wfs)},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1"});
+OpenLayers.Format.WFSTWithLock.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFSTWithLock.v1,{version:"1.1.0",schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},xy:!1,initialize:function(a){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFSTWithLock.v1.prototype.initialize.apply(this,[a])},readers:{wfs:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,b){b.numberOfFeatures=parseInt(a.getAttribute("numberOfFeatures"));
+OpenLayers.Format.WFSTWithLock.v1.prototype.readers.wfs.FeatureCollection.apply(this,arguments)},TransactionResponse:function(a,b){b.insertIds=[];b.success=!1;this.readChildNodes(a,b)},TransactionSummary:function(a,b){b.success=!0},InsertResults:function(a,b){this.readChildNodes(a,b)},Feature:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds.push(c.fids[0])}},OpenLayers.Format.WFSTWithLock.v1.prototype.readers.wfs),gml:OpenLayers.Util.applyDefaults({srsName:this.srsName},OpenLayers.Format.GML.v3.prototype.readers.gml),
+feature:OpenLayers.Format.GML.v3.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.readers.ogc},writers:{wfs:OpenLayers.Util.applyDefaults({GetFeature:function(a){var b=OpenLayers.Format.WFSTWithLock.v1.prototype.writers.wfs.GetFeature.apply(this,arguments);a&&a.resultType&&this.setAttributes(b,{resultType:a.resultType});return b},Query:function(a){var a=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},
+a),b=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(a.featureNS?a.featurePrefix+":":"")+a.featureType,srsName:a.srsName}});a.featureNS&&b.setAttribute("xmlns:"+a.featurePrefix,a.featureNS);if(a.propertyNames)for(var c=0,d=a.propertyNames.length;c<d;c++)this.writeNode("wfs:PropertyName",{property:a.propertyNames[c]},b);a.filter&&(this.setFilterProperty(a.filter),this.writeNode("ogc:Filter",a.filter,b));return b},PropertyName:function(a){return this.createElementNSPlus("wfs:PropertyName",
+{value:a.property})}},OpenLayers.Format.WFSTWithLock.v1.prototype.writers.wfs),gml:OpenLayers.Util.applyDefaults({},OpenLayers.Format.GML.v3.prototype.writers.gml),feature:OpenLayers.Util.applyDefaults({_typeName:function(a){var b=this.createElementNSPlus(this.featurePrefix+":"+this.featureType,{attributes:{fid:a.fid}});a.geometry&&this.writeNode("feature:_geometry",a.geometry,b);if(!0==this.encodeAttributes)for(var c in a.attributes){var d=a.attributes[c];this.attributes[c]?null!=d&&this.writeNode("feature:_attribute",
+{name:c,value:d},b):this.attributes[this.attribute_alias[c]]&&null!=d&&this.writeNode("feature:_attribute",{name:this.attribute_alias[c],value:d},b)}return b},_geometry:function(a){this.externalProjection&&this.internalProjection&&(a=a.clone().transform(this.internalProjection,this.externalProjection));var b=this.createElementNSPlus(this.featurePrefix+":"+this.geometryName),a=this.writeNode("gml:"+this.geometryTypes[a.CLASS_NAME],a,b);this.srsName&&a.setAttribute("srsName",this.srsName);return b},
+_attribute:function(a){return this.createElementNSPlus(this.featurePrefix+":"+a.name,{value:a.value})}},OpenLayers.Format.GML.v3.prototype.writers.feature),ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1_1_0"});
+OpenLayers.Control.PanPanel=OpenLayers.Class(OpenLayers.Control.Panel,{slideFactor:50,slideRatio:null,initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);a={slideFactor:this.slideFactor,slideRatio:this.slideRatio};this.addControls([new OpenLayers.Control.Pan(OpenLayers.Control.Pan.NORTH,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.SOUTH,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.EAST,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.WEST,a)])},
+CLASS_NAME:"OpenLayers.Control.PanPanel"});
+OpenLayers.Strategy.Lock=OpenLayers.Class(OpenLayers.Strategy,{response:null,lockedFeatures:[],_styleMap:null,initialize:function(a){OpenLayers.Strategy.prototype.initialize.apply(this,[a])},activate:function(){var a="function"==typeof this.layer.protocol.readWithLock?!0:!1,b="function"==typeof this.layer.protocol.unlock?!0:!1;if(!this.layer.protocol||!1==a||!1==b)return OpenLayers.Console.error("...can not activate Lock strategy...vector layer protocol does not support readWithLock or unlock interfaces..."),!1;
+if(a=OpenLayers.Strategy.prototype.activate.call(this))this.layer.events.addEventType("afterfeatureslocked"),this.layer.events.addEventType("afterfeaturesunlocked"),this.layer.getFeatureByFid=OpenLayers.Function.bind(function(a){for(var b=null,e=0,f=this.features.length;e<f;++e)if(this.features[e].fid&&this.features[e].fid==a){b=this.features[e];break}return b},this.layer),this.layer.getSelectedFeatureByFid=OpenLayers.Function.bind(function(a){for(var b=null,e=0,f=this.selectedFeatures.length;e<f;++e)if(this.selectedFeatures[e].fid&&
+this.selectedFeatures[e].fid==a){b=this.selectedFeatures[e];break}return b},this.layer),this.layer.events.on({beforefeatureselected:this.synchronizeFeaturesStyle,featureselected:this.synchronizeFeaturesStyle,featureunselected:this.synchronizeFeaturesStyle,afterfeatureslocked:this.synchronizeFeatures,afterfeaturesunlocked:this.synchronizeFeatures,scope:this}),this._styleMap=this.layer.styleMap||new OpenLayers.StyleMap,this._defaultStyle=this._styleMap.styles["default"],this._selectStyle=this._styleMap.styles.select,
+this._lockedStyle=this._styleMap.styles.locked?this._styleMap.styles.locked:this.options&&this.options.styleMap?this.options.styleMap.styles.locked||this._styleMap.styles.temporary:this._styleMap.styles.temporary;return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);if(a)this.layer.getFeatureByFid=null,this.layer.getSelectedFeatureByFid=null,this.layer.events.un({beforefeatureselected:this.synchronizeFeaturesStyle,featureselected:this.synchronizeFeaturesStyle,featureunselected:this.synchronizeFeaturesStyle,
+afterfeatureslocked:this.synchronizeFeatures,afterfeaturesunlocked:this.synchronizeFeatures,scope:this}),this._lockedStyle=this._selectStyle=this._defaultStyle=this._styleMap=null;return a},isFeatureLocked:function(a){if(a.lockId&&""!==a.lockId)return OpenLayers.Console.log("...feature: "+a.fid+"...is locked with lockId: "+a.lockId+"..."),!0;OpenLayers.Console.log("...feature: "+a.fid+"...is not locked...");return!1},lockFeatures:function(a){if(!0==this.active)a=this.createFeatureIdFilter(a),this.response&&
+this.response.priv&&"function"==typeof this.response.priv.abort&&this.response.priv.abort(),this.response=this.layer.protocol.readWithLock({filter:a,callback:this.onFeaturesLocked,scope:this});else throw OpenLayers.Console.error("...can not call lockFeatures...Lock strategy is not activated..."),"...can not call lockFeatures...Lock strategy is not activated...";},lockFeaturesWithinExtent:function(){},unlockFeatures:function(a){if(!0==this.active){this.response&&this.response.priv&&"function"==typeof this.response.priv.abort&&
+this.response.priv.abort();for(var b={},c=0;c<a.length;c++){var d=a[c].lockId;d&&null==b[d]&&(b[d]=d)}for(var e in b)this.response=this.layer.protocol.unlock({lockId:b[e],callback:this.onFeaturesUnlocked,scope:this})}else throw OpenLayers.Console.error("...can not call unlockFeatures...Lock strategy is not activated..."),"...can not call unlockFeatures...Lock strategy is not activated...";},unlockAllFeatures:function(){this.unlockFeatures(this.lockedFeatures)},onFeaturesLocked:function(a){if(a.success()&&
+a.features){for(var b=0;b<a.features.length;b++){var c=a.features[b];c.lockId&&""!=c.lockId&&this.lockedFeatures.push(c)}b={};b.features=a.features;this.layer.events.triggerEvent("afterfeatureslocked",b)}else OpenLayers.Console.log("...lock features failed...")},onFeaturesUnlocked:function(a){a.success()?(OpenLayers.Console.log("...locked features with lockId "+a.lockId+" are unlocked..."),this.layer.events.triggerEvent("afterfeaturesunlocked",{lockId:a.lockId}),this.layer.events.triggerEvent("refresh",
+{force:!0})):OpenLayers.Console.log("...unlock features with lockId "+a.lockId+" failed...")},synchronizeFeatures:function(a){switch(a.type){case "afterfeatureslocked":for(var b=0;b<this.lockedFeatures.length;b++){var c=this.lockedFeatures[b].fid;if(a=this.layer.getFeatureByFid(c))this.layer.eraseFeatures([a]),this.layer.removeFeatures([a],{slient:!1}),a=this.lockedFeatures[b].clone(),a.fid=this.lockedFeatures[b].fid,a.lockId=this.lockedFeatures[b].lockId,a.style=this._lockedStyle.createSymbolizer(a),
+this.layer.addFeatures([a],{slient:!1})}OpenLayers.Console.log("...total features number: "+this.layer.features.length+"...locked features number: "+this.lockedFeatures.length+"...selected features number: "+this.layer.selectedFeatures.length);break;case "afterfeaturesunlocked":for(var d=[],b=0;b<this.lockedFeatures.length;b++){var e=this.lockedFeatures[b].lockId,c=this.lockedFeatures[b].fid;e==a.lockId?(e=this.layer.getFeatureByFid(c),e.style=null,e.lockId=null,this.layer.getSelectedFeatureByFid(c)?
+this.layer.drawFeature(e,this._selectStyle.createSymbolizer(e)):this.layer.drawFeature(e,this._defaultStyle.createSymbolizer(e))):d.push(this.lockedFeatures[b])}this.lockedFeatures=null;this.lockedFeatures=d;OpenLayers.Console.log("...total features number: "+this.layer.features.length+"...locked features number: "+this.lockedFeatures.length+"...selected features number: "+this.layer.selectedFeatures.length)}},synchronizeFeaturesStyle:function(a){switch(a.type){case "beforefeatureselected":if(a.feature.lockId&&
+""!=a.feature.lockId)a.feature.style=null;break;case "featureselected":if(a.feature.lockId&&""!=a.feature.lockId)a.feature.style=this._lockedStyle.createSymbolizer(a.feature)}},createFeatureIdFilter:function(a){for(var b=[],c=0;c<a.length;c++)a[c].fid&&b.push(a[c].fid);return new OpenLayers.Filter.FeatureId({fids:b})},createBBOXFilter:function(){},setStyleMap:function(a){if(a)this._defaultStyle=a.styles["default"]||this._defaultStyle,this._selectStyle=a.styles.select||this._selectStyle,this._lockedStyle=
+a.styles.locked||this._lockedStyle},CLASS_NAME:"OpenLayers.Strategy.Lock"});
+OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({removelayer:this.updateAttribution,addlayer:this.updateAttribution,changelayer:this.updateAttribution,changebaselayer:this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({changebaselayer:this.updateAttribution,changelayer:this.updateAttribution,
+addlayer:this.updateAttribution,removelayer:this.updateAttribution,scope:this});this.updateAttribution();return this.div},updateAttribution:function(){var a=[];if(this.map&&this.map.layers){for(var b=0,c=this.map.layers.length;b<c;b++){var d=this.map.layers[b];d.attribution&&d.getVisibility()&&-1===OpenLayers.Util.indexOf(a,d.attribution)&&a.push(d.attribution)}this.div.innerHTML=a.join(this.separator)}},CLASS_NAME:"OpenLayers.Control.Attribution"});
+OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,updateDimensions:function(){var a=this.map.getExtent(),b=a.scale(3);this.setExtent(b,!0);var c=this.getResolution(),d=this.rendererRoot.parentNode,e=parseFloat(d.parentNode.style.left),f=parseFloat(d.parentNode.style.top);d.style.left=(b.left-a.left)/c-e+"px";d.style.top=(a.top-b.top)/c-f+"px"},setSize:function(){this.map.getExtent()&&this.updateDimensions()},drawFeature:function(a,b){if(null==b)b=a.style;if(a.geometry){var c=
+this.drawGeometry(a.geometry,b,a.id);if(!1!==c&&b.label){var d=a.geometry.getCentroid();this.drawText(a.id,b,d)}else this.removeText(a.id);return c}},drawText:function(a,b,c){var d;"string"!==typeof a?d=a:(d=this.nodeFactory(a+this.LABEL_ID_SUFFIX,this.labelNodeType),d._featureId=a);d._style=b;d._x=c.x;d._y=c.y;if(b.labelXOffset||b.labelYOffset){var a=isNaN(b.labelXOffset)?0:b.labelXOffset,b=isNaN(b.labelYOffset)?0:b.labelYOffset,e=this.getResolution();c.move(a*e,b*e)}d.parentNode!==this.textRoot&&
+this.textRoot.appendChild(d);return d},CLASS_NAME:"OpenLayers.Renderer.NG"});
+OpenLayers.Renderer.SVG2=OpenLayers.Class(OpenLayers.Renderer.NG,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",symbolMetrics:null,labelNodeType:"g",initialize:function(a){if(this.supported())OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments),this.symbolMetrics={}},supported:function(){return document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#SVG",
+"1.1")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure","1.1"))},updateDimensions:function(a){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var b=this.getResolution(),c=this.extent.getWidth(),d=this.extent.getHeight();this.rendererRoot.setAttributeNS(null,"viewBox",[this.extent.left,-this.extent.top,c,d].join(" "));this.rendererRoot.setAttributeNS(null,"width",c/b);this.rendererRoot.setAttributeNS(null,"height",d/b);if(!0===a){d=this.vectorRoot.childNodes;
+for(b=0,c=d.length;b<c;++b)this.setStyle(d[b]);var d=this.textRoot.childNodes,e;for(b=0,c=d.length;b<c;++b)e=d[b],this.drawText(e,e._style,new OpenLayers.Geometry.Point(e._x,e._y))}},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"image":this.isComplexSymbol(b.graphicName)?"svg":"circle";break;case "OpenLayers.Geometry.Rectangle":c="rect";break;case "OpenLayers.Geometry.LineString":c="polyline";break;case "OpenLayers.Geometry.LinearRing":c=
+"polygon";break;case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c="path"}return c},setStyle:function(a,b,c){var b=b||a._style,c=c||a._options,d=this.getResolution(),e=a._radius,f=d;if("OpenLayers.Geometry.Point"==a._geometryClass&&e){a.style.visibility="";if(!1===b.graphic)a.style.visibility="hidden";else if(b.externalGraphic){if(b.graphicTitle)a.setAttributeNS(null,"title",b.graphicTitle),e=this.nodeFactory(null,"title"),e.textContent=b.graphicTitle,
+a.appendChild(e);b.graphicWidth&&b.graphicHeight&&a.setAttributeNS(null,"preserveAspectRatio","none");var e=b.graphicWidth||b.graphicHeight,g=b.graphicHeight||b.graphicWidth,e=e?e:2*b.pointRadius,g=g?g:2*b.pointRadius,e=e*d,g=g*d,h=void 0!=b.graphicYOffset?b.graphicYOffset*d:-(0.5*g),i=b.graphicOpacity||b.fillOpacity;a.setAttributeNS(null,"x",a._x+(void 0!=b.graphicXOffset?b.graphicXOffset*d:-(0.5*e)));a.setAttributeNS(null,"y",a._y+h);a.setAttributeNS(null,"width",e);a.setAttributeNS(null,"height",
+g);a.setAttributeNS(this.xlinkns,"href",b.externalGraphic);a.setAttributeNS(null,"style","opacity: "+i);a.onclick=OpenLayers.Renderer.SVG2.preventDefault}else if(this.isComplexSymbol(b.graphicName)){var e=3*b.pointRadius*d,g=2*e,j=this.importSymbol(b.graphicName),f=3*this.symbolMetrics[j.id].size/g*d,d=a.parentNode,h=a.nextSibling;d&&d.removeChild(a);a.firstChild&&a.removeChild(a.firstChild);a.appendChild(j.firstChild.cloneNode(!0));a.setAttributeNS(null,"viewBox",j.getAttributeNS(null,"viewBox"));
+a.setAttributeNS(null,"width",g);a.setAttributeNS(null,"height",g);a.setAttributeNS(null,"x",a._x-e);a.setAttributeNS(null,"y",a._y-e);h?d.insertBefore(a,h):d&&d.appendChild(a)}else a.setAttributeNS(null,"r",b.pointRadius*d);d=b.rotation;if(void 0!==d||void 0!==a._rotation)a._rotation=d,d|=0,"svg"!==a.nodeName?a.setAttributeNS(null,"transform",["rotate(",d,a._x,a._y,")"].join(" ")):(j=this.symbolMetrics[j.id],a.firstChild.setAttributeNS(null,"transform",["rotate(",d,j.x,j.y,")"].join(" ")))}c.isFilled?
+(a.setAttributeNS(null,"fill",b.fillColor),a.setAttributeNS(null,"fill-opacity",b.fillOpacity)):a.setAttributeNS(null,"fill","none");c.isStroked?(a.setAttributeNS(null,"stroke",b.strokeColor),a.setAttributeNS(null,"stroke-opacity",b.strokeOpacity),a.setAttributeNS(null,"stroke-width",b.strokeWidth*f),a.setAttributeNS(null,"stroke-linecap",b.strokeLinecap||"round"),a.setAttributeNS(null,"stroke-linejoin","round"),b.strokeDashstyle&&a.setAttributeNS(null,"stroke-dasharray",this.dashStyle(b,f))):a.setAttributeNS(null,
+"stroke","none");b.pointerEvents&&a.setAttributeNS(null,"pointer-events",b.pointerEvents);null!=b.cursor&&a.setAttributeNS(null,"cursor",b.cursor);return a},dashStyle:function(a,b){var c=a.strokeWidth*b,d=a.strokeDashstyle;switch(d){case "solid":return"none";case "dot":return[b,4*c].join();case "dash":return[4*c,4*c].join();case "dashdot":return[4*c,4*c,b,4*c].join();case "longdash":return[8*c,4*c].join();case "longdashdot":return[8*c,4*c,b,4*c].join();default:for(var c=OpenLayers.String.trim(d).split(/\s+/g),
+d=0,e=c.length;d<e;d++)c[d]*=b;return c.join()}},createNode:function(a,b){var c=document.createElementNS(this.xmlns,a);b&&c.setAttributeNS(null,"id",b);return c},nodeTypeCompare:function(a,b){return b==a.nodeName},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg")},createRoot:function(a){return this.nodeFactory(this.container.id+a,"g")},createDefs:function(){var a=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(a);return a},drawPoint:function(a,
+b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){var d=b.x,b=-b.y;a.setAttributeNS(null,"cx",d);a.setAttributeNS(null,"cy",b);a._x=d;a._y=b;a._radius=c;return a},drawLineString:function(a,b){var c=this.getComponentsString(b.components);a.setAttributeNS(null,"points",c);return a},drawLinearRing:function(a,b){var c=this.getComponentsString(b.components);a.setAttributeNS(null,"points",c);return a},drawPolygon:function(a,b){for(var c=[],d,e=0,f=b.components.length;e<f;e++)c.push("M"),d=this.getComponentsString(b.components[e].components,
+" "),c.push(d);c.push("z");a.setAttributeNS(null,"d",c.join(" "));a.setAttributeNS(null,"fill-rule","evenodd");return a},drawRectangle:function(a,b){a.setAttributeNS(null,"x",b.x);a.setAttributeNS(null,"y",-b.y);a.setAttributeNS(null,"width",b.width);a.setAttributeNS(null,"height",b.height);return a},drawSurface:function(a,b){for(var c=[],d=0,e=b.components.length;d<e;d++)if(0==d%3&&0==d/3){var f=this.getShortString(b.components[d]);c.push("M",f)}else 1==d%3?(f=this.getShortString(b.components[d]),
+c.push("C",f)):(f=this.getShortString(b.components[d]),c.push(f));c.push("Z");a.setAttributeNS(null,"d",c.join(" "));return a},drawText:function(a,b,c){var d=OpenLayers.Renderer.NG.prototype.drawText.apply(this,arguments),e=d.firstChild||this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_text","text"),f=this.getResolution();e.setAttributeNS(null,"x",c.x/f);e.setAttributeNS(null,"y",-c.y/f);d.setAttributeNS(null,"transform","scale("+f+")");b.fontColor&&e.setAttributeNS(null,"fill",b.fontColor);b.fontOpacity&&
+e.setAttributeNS(null,"opacity",b.fontOpacity);b.fontFamily&&e.setAttributeNS(null,"font-family",b.fontFamily);b.fontSize&&e.setAttributeNS(null,"font-size",b.fontSize);b.fontWeight&&e.setAttributeNS(null,"font-weight",b.fontWeight);b.fontStyle&&e.setAttributeNS(null,"font-style",b.fontStyle);!0===b.labelSelect?(e.setAttributeNS(null,"pointer-events","visible"),e._featureId=a):e.setAttributeNS(null,"pointer-events","none");var g=b.labelAlign||"cm";e.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG2.LABEL_ALIGN[g[0]]||
+"middle");!0===OpenLayers.IS_GECKO&&e.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG2.LABEL_ALIGN[g[1]]||"central");for(var h=b.label.split("\n"),i=h.length;e.childNodes.length>i;)e.removeChild(e.lastChild);for(var j=0;j<i;j++){var k=e.childNodes[j]||this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_tspan_"+j,"tspan");if(!0===b.labelSelect)k._featureId=a;!1===OpenLayers.IS_GECKO&&k.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG2.LABEL_VSHIFT[g[1]]||"-35%");k.setAttribute("x",
+c.x/f);if(0==j){var m=OpenLayers.Renderer.SVG2.LABEL_VFACTOR[g[1]];null==m&&(m=-0.5);k.setAttribute("dy",m*(i-1)+"em")}else k.setAttribute("dy","1em");k.textContent=""===h[j]?" ":h[j];k.parentNode||e.appendChild(k)}e.parentNode||d.appendChild(e);return d},getComponentsString:function(a,b){for(var c=a.length,d=Array(c),e=0;e<c;e++)d[e]=this.getShortString(a[e]);return d.join(b||",")},getShortString:function(a){return a.x+","+-a.y},importSymbol:function(a){if(!this.defs)this.defs=this.createDefs();
+var b=this.container.id+"-"+a,c=document.getElementById(b);if(null!=c)return c;var d=OpenLayers.Renderer.symbol[a];if(!d)throw Error(a+" is not a valid symbol name");var a=this.nodeFactory(b,"symbol"),e=this.nodeFactory(null,"polygon");a.appendChild(e);for(var c=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0),f=[],g,h,i=0,j=d.length;i<j;i+=2)g=d[i],h=d[i+1],c.left=Math.min(c.left,g),c.bottom=Math.min(c.bottom,h),c.right=Math.max(c.right,g),c.top=Math.max(c.top,h),f.push(g,",",h);e.setAttributeNS(null,
+"points",f.join(" "));d=c.getWidth();e=c.getHeight();a.setAttributeNS(null,"viewBox",[c.left-d,c.bottom-e,3*d,3*e].join(" "));this.symbolMetrics[b]={size:Math.max(d,e),x:c.getCenterLonLat().lon,y:c.getCenterLonLat().lat};this.defs.appendChild(a);return a},getFeatureIdFromEvent:function(a){var b=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!b)b=a.target,b=b.parentNode&&b!=this.rendererRoot&&b.parentNode._featureId;return b},CLASS_NAME:"OpenLayers.Renderer.SVG2"});
+OpenLayers.Renderer.SVG2.LABEL_ALIGN={l:"start",r:"end",b:"bottom",t:"hanging"};OpenLayers.Renderer.SVG2.LABEL_VSHIFT={t:"-70%",b:"0"};OpenLayers.Renderer.SVG2.LABEL_VFACTOR={t:0,b:-1};OpenLayers.Renderer.SVG2.preventDefault=function(a){a.preventDefault&&a.preventDefault()};
+OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:void 0,timerId:void 0,initialize:function(a){OpenLayers.Util.extend(this,a)},begin:function(){clearInterval(this.timerId);this.timerId=void 0;this.points=[]},update:function(a){this.points.unshift({xy:a,tick:(new Date).getTime()});this.points.length>this.nbPoints&&this.points.pop()},end:function(a){for(var b,c=(new Date).getTime(),d=0,e=this.points.length,f;d<e;d++){f=this.points[d];if(c-
+f.tick>this.delay)break;b=f}if(b&&(d=(new Date).getTime()-b.tick,c=Math.sqrt(Math.pow(a.x-b.xy.x,2)+Math.pow(a.y-b.xy.y,2)),d=c/d,!(0==d||d<this.threshold)))return c=Math.asin((a.y-b.xy.y)/c),b.xy.x<=a.x&&(c=Math.PI-c),{speed:d,theta:c}},move:function(a,b){var c=a.speed,d=Math.cos(a.theta),e=-Math.sin(a.theta),f=0,g=(new Date).getTime(),h=0,i=0;this.timerId=window.setInterval(OpenLayers.Function.bind(function(){if(null!=this.timerId){f+=this.interval;var a=(new Date).getTime()-g,k=(f+a)/2,m=-this.deceleration*
+Math.pow(k,2)/2+c*k,a=m*d,m=m*e,n,l;n=!1;if(0>=-this.deceleration*k+c)clearInterval(this.timerId),this.timerId=null,n=!0;k=a-h;l=m-i;h=a;i=m;b(k,l,n)}},this),this.interval)},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Protocol.WFSTWithLock=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.WFSTWithLock.DEFAULTS),b=OpenLayers.Protocol.WFSTWithLock["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFSTWithLock version: "+a.version;return new b(a)};
+OpenLayers.Protocol.WFSTWithLock.fromWMSLayer=OpenLayers.Protocol.WFS.fromWMSLayer;OpenLayers.Protocol.WFSTWithLock.DEFAULTS={version:"1.1.0"};
+OpenLayers.Protocol.WFSTWithLock.v1=new OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:null,srsName:"urn:x-ogc:def:crs:EPSG:6.9:4326",bboxSrsName:"urn:x-ogc:def:crs:EPSG:6.9:4326",featureType:null,featureNS:"http://www.esri.com",geometryName:"Shape",featurePrefix:"esri",formatOptions:{xy:!1,lockExpiry:"1",releaseAction:"ALL"},initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);if(!a.format)this.format=OpenLayers.Format.WFSTWithLock(OpenLayers.Util.extend({version:this.version,
+featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));if(!this.featureNS&&this.featurePrefix){var b=this.format.readNode;this.format.readNode=function(a,d){if(!this.featureNS&&a.prefix==this.featurePrefix)this.featureNS=a.namespaceURI,this.setNamespace("feature",this.featureNS);return b.apply(this,arguments)}}},readWithLock:function(a){OpenLayers.Protocol.prototype.read.apply(this,
+arguments);a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||{});var b=new OpenLayers.Protocol.Response({requestType:"readWithLock"}),c=this.format.writeNode("wfs:GetFeatureWithLock",a),c=OpenLayers.Format.XML.prototype.write.apply(this.format,[c]);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleReadWithLock,b,a),params:a.params,headers:a.headers,data:c});return b},unlock:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,
+this.options);OpenLayers.Console.log("...wfs:Transaction request...");var b=this.format.writeNode("wfs:UnlockFeature",a);OpenLayers.Console.dirxml(b);var b=OpenLayers.Format.XML.prototype.write.apply(this.format,[b]),c=new OpenLayers.Protocol.Response({requestType:"unlock",lockId:a.lockId});c.priv=OpenLayers.Request.POST({url:a.url,data:b,callback:this.createCallback(this.handleUnlock,c,a)});return c},commitWithLock:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);
+for(var c={},d={},e=0;e<a.length;e++)if(a[e].lockId&&""!=a[e].lockId)null==c[a[e].lockId]&&(c[a[e].lockId]=[]),c[a[e].lockId].push(a[e]);else if(a[e].state==OpenLayers.State.INSERT)null==c.__insert__&&(c.__insert__=[]),a[e].lockId="__insert__",c.__insert__.push(a[e]);for(var f in c)if(f&&""!==f)e=c[f],d[f]=new OpenLayers.Protocol.Response({requestType:"commitWithLock",reqFeatures:e,lockId:f}),e=this.format.writeNode("wfs:Transaction",e),e=OpenLayers.Format.XML.prototype.write.apply(this,[e]),d[f].priv=
+OpenLayers.Request.POST({url:b.url,data:e,callback:this.createCallback(this.handleCommitWithLock,d[f],b)});return d},filterDeleteWithLock:function(){},handleReadWithLock:function(a,b){this.handleRead(a,b)},handleUnlock:function(a,b){this.handleCommit(a,b)},handleCommitWithLock:function(a,b){this.handleCommit(a,b)},CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1"});
+OpenLayers.Format.WFSTWithLock.v1_0_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,OpenLayers.Format.WFSTWithLock.v1,{version:"1.0.0",srsNameInQuery:!1,schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},xy:!0,initialize:function(a){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFSTWithLock.v1.prototype.initialize.apply(this,[a])},readers:{wfs:OpenLayers.Util.applyDefaults({WFS_TransactionResponse:function(a,b){b.insertIds=
+[];b.success=!1;this.readChildNodes(a,b)},InsertResult:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds.push(c.fids[0])},TransactionResult:function(a,b){this.readChildNodes(a,b)},Status:function(a,b){this.readChildNodes(a,b)},SUCCESS:function(a,b){b.success=!0}},OpenLayers.Format.WFSTWithLock.v1.prototype.readers.wfs),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,feature:OpenLayers.Format.GML.v2.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_0_0.prototype.readers.ogc},
+writers:{wfs:OpenLayers.Util.applyDefaults({Query:function(a){var a=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},a),b=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(a.featureNS?a.featurePrefix+":":"")+a.featureType}});a.srsNameInQuery&&a.srsName&&b.setAttribute("srsName",a.srsName);a.featureNS&&b.setAttribute("xmlns:"+a.featurePrefix,a.featureNS);if(a.propertyNames)for(var c=
+0,d=a.propertyNames.length;c<d;c++)this.writeNode("ogc:PropertyName",{property:a.propertyNames[c]},b);a.filter&&(this.setFilterProperty(a.filter),this.writeNode("ogc:Filter",a.filter,b));return b}},OpenLayers.Format.WFSTWithLock.v1.prototype.writers.wfs),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Util.applyDefaults({_typeName:function(a){var b=this.createElementNSPlus(this.featurePrefix+":"+this.featureType,{attributes:{fid:a.fid}});a.geometry&&this.writeNode("feature:_geometry",
+a.geometry,b);for(var c in a.attributes){var d=a.attributes[c];this.attributes[c]?null!=d&&this.writeNode("feature:_attribute",{name:c,value:d},b):this.attributes[this.attribute_alias[c]]&&null!=d&&this.writeNode("feature:_attribute",{name:this.attribute_alias[c],value:d},b)}return b},_geometry:function(a){this.externalProjection&&this.internalProjection&&(a=a.clone().transform(this.internalProjection,this.externalProjection));var b=this.createElementNSPlus(this.featurePrefix+":"+this.geometryName),
+a=this.writeNode("gml:"+this.geometryTypes[a.CLASS_NAME],a,b);this.srsName&&a.setAttribute("srsName",this.srsName);return b},_attribute:function(a){return this.createElementNSPlus(this.featurePrefix+":"+a.name,{value:a.value})}},OpenLayers.Format.GML.v2.prototype.writers.feature),ogc:OpenLayers.Format.Filter.v1_0_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1_0_0"});
+OpenLayers.Protocol.WFSTWithLock.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFSTWithLock.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1_0_0"});OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(a){OpenLayers.Console.userError(OpenLayers.i18n("unhandledRequest",{statusText:a.statusText}))};
+OpenLayers.loadURL=function(a,b,c,d,e){"string"==typeof b&&(b=OpenLayers.Util.getParameters(b));return OpenLayers.Request.GET({url:a,params:b,success:d?d:OpenLayers.nullHandler,failure:e?e:OpenLayers.nullHandler,scope:c})};
+OpenLayers.parseXMLString=function(a){var b=a.indexOf("<");0<b&&(a=a.substring(b));return OpenLayers.Util.Try(function(){var b=new ActiveXObject("Microsoft.XMLDOM");b.loadXML(a);return b},function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var b=new XMLHttpRequest;b.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),!1);b.overrideMimeType&&b.overrideMimeType("text/xml");b.send(null);return b.responseXML})};
+OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest},function(){return new ActiveXObject("Msxml2.XMLHTTP")},function(){return new ActiveXObject("Microsoft.XMLHTTP")})||!1},activeRequestCount:0};
+OpenLayers.Ajax.Responders={responders:[],register:function(a){for(var b=0;b<this.responders.length;b++)if(a==this.responders[b])return;this.responders.push(a)},unregister:function(a){OpenLayers.Util.removeItem(this.reponders,a)},dispatch:function(a,b,c){for(var d,e=0;e<this.responders.length;e++)if(d=this.responders[e],d[a]&&"function"==typeof d[a])try{d[a].apply(d,[b,c])}catch(f){}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++},onComplete:function(){OpenLayers.Ajax.activeRequestCount--}});
+OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(a){this.options={method:"post",asynchronous:!0,contentType:"application/xml",parameters:""};OpenLayers.Util.extend(this.options,a||{});this.options.method=this.options.method.toLowerCase();if("string"==typeof this.options.parameters)this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters)}});
+OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:!1,initialize:function(a,b){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[b]);OpenLayers.ProxyHost&&OpenLayers.String.startsWith(a,"http")&&(a=OpenLayers.ProxyHost+encodeURIComponent(a));this.transport=OpenLayers.Ajax.getTransport();this.request(a)},request:function(a){this.url=a;this.method=this.options.method;a=OpenLayers.Util.extend({},this.options.parameters);if("get"!=this.method&&"post"!=this.method)a._method=this.method,
+this.method="post";this.parameters=a;if(a=OpenLayers.Util.getParameterString(a))"get"==this.method?this.url+=(-1<this.url.indexOf("?")?"&":"?")+a:/Konqueror|Safari|KHTML/.test(navigator.userAgent)&&(a+="&_=");try{var b=new OpenLayers.Ajax.Response(this);if(this.options.onCreate)this.options.onCreate(b);OpenLayers.Ajax.Responders.dispatch("onCreate",this,b);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);this.options.asynchronous&&window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,
+this,1),10);this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body="post"==this.method?this.options.postBody||a:null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType)this.onStateChange()}catch(c){this.dispatchException(c)}},onStateChange:function(){var a=this.transport.readyState;1<a&&!(4==a&&this._complete)&&this.respondToReadyState(this.transport.readyState)},setRequestHeaders:function(){var a=
+{"X-Requested-With":"XMLHttpRequest",Accept:"text/javascript, text/html, application/xml, text/xml, */*",OpenLayers:!0};if("post"==this.method&&(a["Content-type"]=this.options.contentType+(this.options.encoding?"; charset="+this.options.encoding:""),this.transport.overrideMimeType&&2005>(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]))a.Connection="close";if("object"==typeof this.options.requestHeaders){var b=this.options.requestHeaders;if("function"==typeof b.push)for(var c=0,d=b.length;c<
+d;c+=2)a[b[c]]=b[c+1];else for(c in b)a[c]=b[c]}for(var e in a)this.transport.setRequestHeader(e,a[e])},success:function(){var a=this.getStatus();return!a||200<=a&&300>a},getStatus:function(){try{return this.transport.status||0}catch(a){return 0}},respondToReadyState:function(a){var a=OpenLayers.Ajax.Request.Events[a],b=new OpenLayers.Ajax.Response(this);if("Complete"==a){try{this._complete=!0,(this.options["on"+b.status]||this.options["on"+(this.success()?"Success":"Failure")]||OpenLayers.Ajax.emptyFunction)(b)}catch(c){this.dispatchException(c)}b.getHeader("Content-type")}try{(this.options["on"+
+a]||OpenLayers.Ajax.emptyFunction)(b),OpenLayers.Ajax.Responders.dispatch("on"+a,this,b)}catch(d){this.dispatchException(d)}if("Complete"==a)this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction},getHeader:function(a){try{return this.transport.getResponseHeader(a)}catch(b){return null}},dispatchException:function(a){var b=this.options.onException;if(b)b(this,a),OpenLayers.Ajax.Responders.dispatch("onException",this,a);else{for(var b=!1,c=OpenLayers.Ajax.Responders.responders,d=0;d<c.length;d++)if(c[d].onException){b=
+!0;break}if(b)OpenLayers.Ajax.Responders.dispatch("onException",this,a);else throw a;}}});OpenLayers.Ajax.Request.Events=["Uninitialized","Loading","Loaded","Interactive","Complete"];
+OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:"",initialize:function(a){this.request=a;var a=this.transport=a.transport,b=this.readyState=a.readyState;if(2<b&&(!window.attachEvent||window.opera)||4==b)this.status=this.getStatus(),this.statusText=this.getStatusText(),this.responseText=null==a.responseText?"":""+a.responseText;if(4==b)a=a.responseXML,this.responseXML=void 0===a?null:a},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||
+""}catch(a){return""}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(a){return this.transport.getResponseHeader(a)}});OpenLayers.Ajax.getElementsByTagNameNS=function(a,b,c,d){var e=null;return e=a.getElementsByTagNameNS?a.getElementsByTagNameNS(b,d):a.getElementsByTagName(c+":"+d)};OpenLayers.Ajax.serializeXMLToString=function(a){return(new XMLSerializer).serializeToString(a)};
+OpenLayers.Format.WPSExecute=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",gml:"http://www.opengis.net/gml",wps:"http://www.opengis.net/wps/1.0.0",wfs:"http://www.opengis.net/wfs",ogc:"http://www.opengis.net/ogc",wcs:"http://www.opengis.net/wcs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",
+schemaLocationAttr:function(){},write:function(a){var b;window.ActiveXObject?this.xmldom=b=new ActiveXObject("Microsoft.XMLDOM"):b=document.implementation.createDocument("","",null);a=this.writeNode("wps:Execute",a,b);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{wps:{Execute:function(a){var b=this.createElementNSPlus("wps:Execute",{attributes:{version:this.VERSION,service:"WPS"}});this.writeNode("ows:Identifier",
+a.identifier,b);this.writeNode("wps:DataInputs",a.dataInputs,b);this.writeNode("wps:ResponseForm",a.responseForm,b);return b},ResponseForm:function(a){var b=this.createElementNSPlus("wps:ResponseForm",{});a.rawDataOutput&&this.writeNode("wps:RawDataOutput",a.rawDataOutput,b);a.responseDocument&&this.writeNode("wps:ResponseDocument",a.responseDocument,b);return b},ResponseDocument:function(a){var b=this.createElementNSPlus("wps:ResponseDocument",{attributes:{storeExecuteResponse:a.storeExecuteResponse,
+lineage:a.lineage,status:a.status}});a.output&&this.writeNode("wps:Output",a.output,b);return b},Output:function(a){var b=this.createElementNSPlus("wps:Output",{attributes:{asReference:a.asReference}});this.writeNode("ows:Identifier",a.identifier,b);this.writeNode("ows:Title",a.title,b);this.writeNode("ows:Abstract",a["abstract"],b);return b},RawDataOutput:function(a){var b=this.createElementNSPlus("wps:RawDataOutput",{attributes:{mimeType:a.mimeType}});this.writeNode("ows:Identifier",a.identifier,
+b);return b},DataInputs:function(a){for(var b=this.createElementNSPlus("wps:DataInputs",{}),c=0,d=a.length;c<d;++c)this.writeNode("wps:Input",a[c],b);return b},Input:function(a){var b=this.createElementNSPlus("wps:Input",{});this.writeNode("ows:Identifier",a.identifier,b);a.title&&this.writeNode("ows:Title",a.title,b);a.data&&this.writeNode("wps:Data",a.data,b);a.reference&&this.writeNode("wps:Reference",a.reference,b);return b},Data:function(a){var b=this.createElementNSPlus("wps:Data",{});a.literalData?
+this.writeNode("wps:LiteralData",a.literalData,b):a.complexData&&this.writeNode("wps:ComplexData",a.complexData,b);return b},LiteralData:function(a){return this.createElementNSPlus("wps:LiteralData",{attributes:{uom:a.uom},value:a.value})},ComplexData:function(a){var b=this.createElementNSPlus("wps:ComplexData",{attributes:{mimeType:a.mimeType,encoding:a.encoding,schema:a.schema}});b.appendChild(this.getXMLDoc().createCDATASection(a.value));return b},Reference:function(a){var b=this.createElementNSPlus("wps:Reference",
+{attributes:{mimeType:a.mimeType,"xlink:href":a.href,method:a.method,encoding:a.encoding,schema:a.schema}});a.body&&this.writeNode("wps:Body",a.body,b);return b},Body:function(a){var b=this.createElementNSPlus("wps:Body",{});a.wcs?this.writeNode("wcs:GetCoverage",a.wcs,b):a.wfs?(this.featureType=a.wfs.featureType,this.version=a.wfs.version,this.writeNode("wfs:GetFeature",a.wfs,b)):this.writeNode("wps:Execute",a,b);return b}},wcs:OpenLayers.Format.WCSGetCoverage.prototype.writers.wcs,wfs:OpenLayers.Format.WFST.v1_1_0.prototype.writers.wfs,
+ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc,ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WPSExecute"});
+OpenLayers.Test.AgsRestAdmin=OpenLayers.Class(OpenLayers.Test,{url:"",_run_admin_createService_post_:function(a,b,c){new OpenLayers.Format.JSON;a=document.getElementById(a).firstChild.nodeValue;b.token&&(a=a+"&token="+b.token);OpenLayers.Request.POST({url:this.url+"/createService",success:function(a){-1!=a.responseText.indexOf("success")?c.ok(!0,"...create service success..."):c.ok(!1,"...create service failure...")},failure:function(){c.ok(!1,"...create service failure...")},params:{service:a},headers:{}})},
+_run_admin_deleteService_post_:function(a,b,c){var a=document.getElementById(a).firstChild.nodeValue,d="json";b.token&&(d=d+"&token="+b.token);OpenLayers.Request.POST({url:this.url+"/"+a+"/delete",success:function(a){-1!=a.responseText.indexOf("success")?c.ok(!0,"...delete service success..."):c.ok(!1,"...delete service failure...")},failure:function(){c.ok(!1,"...delete service failure...")},params:{f:d},headers:{}})},CLASS_NAME:"OpenLayers.Test.AgsRestAdmin"});
+OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:!0,initialize:function(a,b,c){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[a,c]);this.location=b;this.features=[]},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null},loadRSS:function(){if(!this.loaded)this.events.triggerEvent("loadstart"),OpenLayers.Request.GET({url:this.location,
+success:this.parseData,scope:this}),this.loaded=!0},moveTo:function(a,b,c){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);this.visibility&&!this.loaded&&this.loadRSS()},parseData:function(a){var b=a.responseXML;if(!b||!b.documentElement)b=OpenLayers.Format.XML.prototype.read(a.responseText);if(this.useFeedTitle){a=null;try{a=b.getElementsByTagNameNS("*","title")[0].firstChild.nodeValue}catch(c){a=b.getElementsByTagName("title")[0].firstChild.nodeValue}a&&this.setName(a)}a={};OpenLayers.Util.extend(a,
+this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject()))a.externalProjection=this.projection,a.internalProjection=this.map.getProjectionObject();for(var b=(new OpenLayers.Format.GeoRSS(a)).read(b),a=0,d=b.length;a<d;a++){var e={},f=b[a];if(f.geometry){var g=f.attributes.title?f.attributes.title:"Untitled",h=f.attributes.description?f.attributes.description:"No description.",i=f.attributes.link?f.attributes.link:"",f=f.geometry.getBounds().getCenterLonLat();e.icon=
+null==this.icon?OpenLayers.Marker.defaultIcon():this.icon.clone();e.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(g||h){e.title=g;e.description=h;var j='<div class="olLayerGeoRSSClose">[x]</div>',j=j+'<div class="olLayerGeoRSSTitle">';i&&(j+='<a class="link" href="'+i+'" target="_blank">');j+=g;i&&(j+="</a>");j+="</div>";j+='<div style="" class="olLayerGeoRSSDescription">';j+=h;j+="</div>";e.popupContentHTML=j}f=new OpenLayers.Feature(this,f,e);this.features.push(f);
+e=f.createMarker();e.events.register("click",f,this.markerClick);this.addMarker(e)}}this.events.triggerEvent("loadend")},markerClick:function(a){var b=this==this.layer.selectedFeature;this.layer.selectedFeature=!b?this:null;for(var c=0,d=this.layer.map.popups.length;c<d;c++)this.layer.map.removePopup(this.layer.map.popups[c]);b||(b=this.createPopup(),OpenLayers.Event.observe(b.div,"click",OpenLayers.Function.bind(function(){for(var a=0,b=this.layer.map.popups.length;a<b;a++)this.layer.map.removePopup(this.layer.map.popups[a])},
+this)),this.layer.map.addPopup(b));OpenLayers.Event.stop(a)},clearFeatures:function(){if(null!=this.features)for(;0<this.features.length;){var a=this.features[0];OpenLayers.Util.removeItem(this.features,a);a.destroy()}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});
+OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(a){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.removeButtons();this.position=this.buttons=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(a){OpenLayers.Control.prototype.draw.apply(this,arguments);
+a=this.position;this.buttons=[];var b=new OpenLayers.Size(18,18),c=new OpenLayers.Pixel(a.x+b.w/2,a.y);this._addButton("panup","north-mini.png",c,b);a.y=c.y+b.h;this._addButton("panleft","west-mini.png",a,b);this._addButton("panright","east-mini.png",a.add(b.w,0),b);this._addButton("pandown","south-mini.png",c.add(0,2*b.h),b);this._addButton("zoomin","zoom-plus-mini.png",c.add(0,3*b.h+5),b);this._addButton("zoomworld","zoom-world-mini.png",c.add(0,4*b.h+5),b);this._addButton("zoomout","zoom-minus-mini.png",
+c.add(0,5*b.h+5),b);return this.div},_addButton:function(a,b,c,d){b=OpenLayers.Util.getImagesLocation()+b;c=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+a,c,d,b,"absolute");c.style.cursor="pointer";this.div.appendChild(c);OpenLayers.Event.observe(c,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,c));OpenLayers.Event.observe(c,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,c));OpenLayers.Event.observe(c,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,
+c));c.action=a;c.map=this.map;if(this.slideRatio)var e=this.slideRatio,a=function(a){return this.map.getSize()[a]*e};else var f=this.slideFactor,a=function(){return f};c.getSlideFactor=a;this.buttons.push(c);return c},_removeButton:function(a){OpenLayers.Event.stopObservingElement(a);a.map=null;a.getSlideFactor=null;this.div.removeChild(a);OpenLayers.Util.removeItem(this.buttons,a)},removeButtons:function(){for(var a=this.buttons.length-1;0<=a;--a)this._removeButton(this.buttons[a])},doubleClick:function(a){OpenLayers.Event.stop(a);
+return!1},buttonDown:function(a){if(OpenLayers.Event.isLeftClick(a)){switch(this.action){case "panup":this.map.pan(0,-this.getSlideFactor("h"));break;case "pandown":this.map.pan(0,this.getSlideFactor("h"));break;case "panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case "panright":this.map.pan(this.getSlideFactor("w"),0);break;case "zoomin":this.map.zoomIn();break;case "zoomout":this.map.zoomOut();break;case "zoomworld":this.map.zoomToMaxExtent()}OpenLayers.Event.stop(a)}},CLASS_NAME:"OpenLayers.Control.PanZoom"});
+OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;
+OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,divEvents:null,zoomWorldIcon:!1,panIcons:!0,forceFixedZoomLevel:!1,mouseDragStart:null,deltaY:null,zoomStart:null,destroy:function(){this._removeZoomBar();this.map.events.un({changebaselayer:this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart},setMap:function(a){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,
+arguments);this.map.events.register("changebaselayer",this,this.redraw)},redraw:function(){null!=this.div&&(this.removeButtons(),this._removeZoomBar());this.draw()},draw:function(a){OpenLayers.Control.prototype.draw.apply(this,arguments);a=this.position.clone();this.buttons=[];var b=new OpenLayers.Size(18,18);if(this.panIcons){var c=new OpenLayers.Pixel(a.x+b.w/2,a.y),d=b.w;this.zoomWorldIcon&&(c=new OpenLayers.Pixel(a.x+b.w,a.y));this._addButton("panup","north-mini.png",c,b);a.y=c.y+b.h;this._addButton("panleft",
+"west-mini.png",a,b);this.zoomWorldIcon&&(this._addButton("zoomworld","zoom-world-mini.png",a.add(b.w,0),b),d*=2);this._addButton("panright","east-mini.png",a.add(d,0),b);this._addButton("pandown","south-mini.png",c.add(0,2*b.h),b);this._addButton("zoomin","zoom-plus-mini.png",c.add(0,3*b.h+5),b);c=this._addZoomBar(c.add(0,4*b.h+5));this._addButton("zoomout","zoom-minus-mini.png",c,b)}else this._addButton("zoomin","zoom-plus-mini.png",a,b),c=this._addZoomBar(a.add(0,b.h)),this._addButton("zoomout",
+"zoom-minus-mini.png",c,b),this.zoomWorldIcon&&(c=c.add(0,b.h+3),this._addButton("zoomworld","zoom-world-mini.png",c,b));return this.div},_addZoomBar:function(a){var b=OpenLayers.Util.getImagesLocation(),c=this.id+"_"+this.map.id,d=this.map.getNumZoomLevels()-1-this.map.getZoom(),d=OpenLayers.Util.createAlphaImageDiv(c,a.add(-1,d*this.zoomStopHeight),new OpenLayers.Size(20,9),b+"slider.png","absolute");d.style.cursor="move";this.slider=d;this.sliderEvents=new OpenLayers.Events(this,d,null,!0,{includeXY:!0});
+this.sliderEvents.on({touchstart:this.zoomBarDown,touchmove:this.zoomBarDrag,touchend:this.zoomBarUp,mousedown:this.zoomBarDown,mousemove:this.zoomBarDrag,mouseup:this.zoomBarUp,dblclick:this.doubleClick,click:this.doubleClick});var e=new OpenLayers.Size;e.h=this.zoomStopHeight*this.map.getNumZoomLevels();e.w=this.zoomStopWidth;c=null;OpenLayers.Util.alphaHack()?(c=this.id+"_"+this.map.id,c=OpenLayers.Util.createAlphaImageDiv(c,a,new OpenLayers.Size(e.w,this.zoomStopHeight),b+"zoombar.png","absolute",
+null,"crop"),c.style.height=e.h+"px"):c=OpenLayers.Util.createDiv("OpenLayers_Control_PanZoomBar_Zoombar"+this.map.id,a,e,b+"zoombar.png");c.style.cursor="pointer";this.zoombarDiv=c;this.divEvents=new OpenLayers.Events(this,c,null,!0,{includeXY:!0});this.divEvents.on({touchmove:this.passEventToSlider,mousedown:this.divClick,mousemove:this.passEventToSlider,dblclick:this.doubleClick,click:this.doubleClick});this.div.appendChild(c);this.startTop=parseInt(c.style.top);this.div.appendChild(d);this.map.events.register("zoomend",
+this,this.moveZoomBar);return a=a.add(0,this.zoomStopHeight*this.map.getNumZoomLevels())},_removeZoomBar:function(){this.sliderEvents.un({touchmove:this.zoomBarDrag,mousedown:this.zoomBarDown,mousemove:this.zoomBarDrag,mouseup:this.zoomBarUp,dblclick:this.doubleClick,click:this.doubleClick});this.sliderEvents.destroy();this.divEvents.un({touchmove:this.passEventToSlider,mousedown:this.divClick,mousemove:this.passEventToSlider,dblclick:this.doubleClick,click:this.doubleClick});this.divEvents.destroy();
+this.div.removeChild(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar)},passEventToSlider:function(a){this.sliderEvents.handleBrowserEvent(a)},divClick:function(a){if(OpenLayers.Event.isLeftClick(a)){var b=a.xy.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom)b=Math.floor(b);b=this.map.getNumZoomLevels()-1-b;b=Math.min(Math.max(b,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(b);
+OpenLayers.Event.stop(a)}},zoomBarDown:function(a){if(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))this.map.events.on({touchmove:this.passEventToSlider,mousemove:this.passEventToSlider,mouseup:this.passEventToSlider,scope:this}),this.mouseDragStart=a.xy.clone(),this.zoomStart=a.xy.clone(),this.div.style.cursor="move",this.zoombarDiv.offsets=null,OpenLayers.Event.stop(a)},zoomBarDrag:function(a){if(null!=this.mouseDragStart){var b=this.mouseDragStart.y-a.xy.y,c=OpenLayers.Util.pagePosition(this.zoombarDiv);
+if(0<a.clientY-c[1]&&a.clientY-c[1]<parseInt(this.zoombarDiv.style.height)-2)this.slider.style.top=parseInt(this.slider.style.top)-b+"px",this.mouseDragStart=a.xy.clone();this.deltaY=this.zoomStart.y-a.xy.y;OpenLayers.Event.stop(a)}},zoomBarUp:function(a){if((OpenLayers.Event.isLeftClick(a)||"touchend"===a.type)&&this.mouseDragStart){this.div.style.cursor="";this.map.events.un({touchmove:this.passEventToSlider,mouseup:this.passEventToSlider,mousemove:this.passEventToSlider,scope:this});var b=this.map.zoom;
+!this.forceFixedZoomLevel&&this.map.fractionalZoom?(b+=this.deltaY/this.zoomStopHeight,b=Math.min(Math.max(b,0),this.map.getNumZoomLevels()-1)):(b+=this.deltaY/this.zoomStopHeight,b=Math.max(Math.round(b),0));this.map.zoomTo(b);this.zoomStart=this.mouseDragStart=null;this.deltaY=0;OpenLayers.Event.stop(a)}},moveZoomBar:function(){this.slider.style.top=(this.map.getNumZoomLevels()-1-this.map.getZoom())*this.zoomStopHeight+this.startTop+1+"px"},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});
+OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});
+OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:"jpeg",map:""},initialize:function(a,b,c,d){var e=[];e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS)},getURL:function(a){var a=this.adjustBounds(a),b=this.map.getResolution(),c=Math.round(1E4*this.map.getScale())/1E4,d=Math.round(a.left/b);return this.getFullRequestString({t:-Math.round(a.top/
+b),l:d,s:c})},calculateGridLayout:function(a,b,c){var b=c*this.tileSize.w,c=c*this.tileSize.h,d=a.left,e=Math.floor(d/b)-this.buffer,d=-(d/b-e)*this.tileSize.w,e=e*b,a=a.top,f=Math.ceil(a/c)+this.buffer;return{tilelon:b,tilelat:c,tileoffsetlon:e,tileoffsetlat:f*c,tileoffsetx:d,tileoffsety:-(f-a/c+1)*this.tileSize.h}},clone:function(a){null==a&&(a=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions()));a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a]);if(null!=this.tileSize)a.tileSize=
+this.tileSize.clone();a.grid=[];return a},getTileBounds:function(a){var b=this.getResolution(),c=b*this.tileSize.w,b=b*this.tileSize.h,d=this.getLonLatFromViewPortPx(a),a=c*Math.floor(d.lon/c),d=b*Math.floor(d.lat/b);return new OpenLayers.Bounds(a,d,a+c,d+b)},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Protocol.AgsFeatureAccess.v2_0=OpenLayers.Class(OpenLayers.Protocol.AgsFeatureAccess.v2,{version:"2.0",CLASS_NAME:"OpenLayers.Protocol.AgsFeatureAccess.v2_0"});
+OpenLayers.Layer.AgsTiled=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,tileOrigin:null,tileFullExtent:null,tileFormat:"",initialize:function(a,b,c){OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,{},c]);this._isDefined=OpenLayers.Util.AgsUtil.isDefined;if(this._isDefined(c.tileFormat))this.tileFormat=c.tileFormat;else throw OpenLayers.Console.error("...tileFormat missing or empty..."),"...tileFormat missing or empty...";if(this._isDefined(c.tileFullExtent)&&c.tileFullExtent instanceof
+OpenLayers.Bounds)this.tileFullExtent=c.tileFullExtent;if(this._isDefined(c.tileOrigin)&&c.tileOrigin instanceof OpenLayers.Pixel)this.tileOrigin=c.tileOrigin},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.AgsTiled(this.name,this.url,this.options));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.adjustBounds(a),b=this.map.getResolution(),c=null,d=null;if(this.tileFullExtent.intersectsBounds(a)){c=
+null;if(this.tileOrigin.lon<=a.left)c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w));else if(this.tileOrigin.lon>=a.right)c=Math.round((this.tileOrigin.lon-a.right)/(b*this.tileSize.w));else return"";d=null;if(this.tileOrigin.lat>=a.top)d=Math.round((this.tileOrigin.lat-a.top)/(b*this.tileSize.h));else if(this.tileOrigin.lat<=a.bottom)d=Math.round((a.bottom-this.tileOrigin.lat)/(b*this.tileSize.h));else return"";c=this.map.getZoom()+"/"+d+"/"+c+"."+this.tileFormat;d=this.url;d instanceof
+Array&&(d=this.selectUrl(c,d));return d+c}return""},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize)},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin)this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);if(!this.tileFullExtent)this.tileFullExtent=this.map.maxExtent},CLASS_NAME:"OpenLayers.Layer.AgsTiled"});
+OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",stringifyOutput:!0,CLASS_NAME:"OpenLayers.Format.XLS"});
+OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},xy:!0,defaultPrefix:"xls",schemaLocation:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a,b){OpenLayers.Util.applyDefaults(b,this.options);var c={};this.readChildNodes(a,
+c);return c},readers:{xls:{XLS:function(a,b){b.version=a.getAttribute("version");this.readChildNodes(a,b)},Response:function(a,b){this.readChildNodes(a,b)},GeocodeResponse:function(a,b){b.responseLists=[];this.readChildNodes(a,b)},GeocodeResponseList:function(a,b){var c={features:[],numberOfGeocodedAddresses:parseInt(a.getAttribute("numberOfGeocodedAddresses"))};b.responseLists.push(c);this.readChildNodes(a,c)},GeocodedAddress:function(a,b){var c=new OpenLayers.Feature.Vector;b.features.push(c);this.readChildNodes(a,
+c);c.geometry=c.components[0]},GeocodeMatchCode:function(a,b){b.attributes.matchCode={accuracy:parseFloat(a.getAttribute("accuracy")),matchType:a.getAttribute("matchType")}},Address:function(a,b){var c={countryCode:a.getAttribute("countryCode"),addressee:a.getAttribute("addressee"),street:[],place:[]};b.attributes.address=c;this.readChildNodes(a,c)},freeFormAddress:function(a,b){b.freeFormAddress=this.getChildValue(a)},StreetAddress:function(a,b){this.readChildNodes(a,b)},Building:function(a,b){b.building=
+{number:a.getAttribute("number"),subdivision:a.getAttribute("subdivision"),buildingName:a.getAttribute("buildingName")}},Street:function(a,b){b.street.push(this.getChildValue(a))},Place:function(a,b){b.place[a.getAttribute("type")]=this.getChildValue(a)},PostalCode:function(a,b){b.postalCode=this.getChildValue(a)}},gml:OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(a){return this.writers.xls.XLS.apply(this,[a])},writers:{xls:{XLS:function(a){var b=this.createElementNSPlus("xls:XLS",
+{attributes:{version:this.VERSION,"xsi:schemaLocation":this.schemaLocation}});this.writeNode("RequestHeader",a.header,b);this.writeNode("Request",a,b);return b},RequestHeader:function(){return this.createElementNSPlus("xls:RequestHeader")},Request:function(a){var b=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequest",requestID:a.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",a.addresses,b);return b},GeocodeRequest:function(a){for(var b=this.createElementNSPlus("xls:GeocodeRequest"),
+c=0,d=a.length;c<d;c++)this.writeNode("Address",a[c],b);return b},Address:function(a){var b=this.createElementNSPlus("xls:Address",{attributes:{countryCode:a.countryCode}});a.freeFormAddress?this.writeNode("freeFormAddess",a.freeFormAddress,b):(a.street&&this.writeNode("StreetAddress",a,b),a.municipality&&this.writeNode("Municipality",a.municipality,b),a.countrySubdivision&&this.writeNode("CountrySubdivision",a.countrySubdivision,b),a.postalCode&&this.writeNode("PostalCode",a.postalCode,b));return b},
+freeFormAddress:function(a){return this.createElementNSPlus("freeFormAddress",{value:a})},StreetAddress:function(a){var b=this.createElementNSPlus("xls:StreetAddress");a.building&&this.writeNode(b,"Building",a.building);a=a.street;OpenLayers.Util.isArray(a)||(a=[a]);for(var c=0,d=a.length;c<d;c++)this.writeNode("Street",a[c],b);return b},Building:function(a){return this.createElementNSPlus("xls:Building",{attributes:{number:a.number,subdivision:a.subdivision,buildingName:a.buildingName}})},Street:function(a){return this.createElementNSPlus("xls:Street",
+{value:a})},Municipality:function(a){return this.createElementNSPlus("xls:Place",{attributes:{type:"Municipality"},value:a})},CountrySubdivision:function(a){return this.createElementNSPlus("xls:Place",{attributes:{type:"CountrySubdivision"},value:a})},PostalCode:function(a){return this.createElementNSPlus("xls:PostalCode",{value:a})}}},CLASS_NAME:"OpenLayers.Format.XLS.v1"});
+OpenLayers.Format.XLS.v1_1_0=OpenLayers.Class(OpenLayers.Format.XLS.v1,{VERSION:"1.1",schemaLocation:"http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",initialize:function(a){OpenLayers.Format.XLS.v1.prototype.initialize.apply(this,[a])},CLASS_NAME:"OpenLayers.Format.XLS.v1_1_0"});OpenLayers.Format.XLS.v1_1=OpenLayers.Format.XLS.v1_1_0;
+OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15E3,translationParameters:null,symbolMetrics:null,initialize:function(a){if(this.supported())OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments),this.translationParameters={x:0,y:0},this.symbolMetrics={}},supported:function(){return document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#SVG",
+"1.1")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure","1.1"))},inValidRange:function(a,b,c){a+=c?0:this.translationParameters.x;b+=c?0:this.translationParameters.y;return a>=-this.MAX_PIXEL&&a<=this.MAX_PIXEL&&b>=-this.MAX_PIXEL&&b<=this.MAX_PIXEL},setExtent:function(a,b){var c=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments),d=this.getResolution(),e=-a.left/d,d=a.top/d;if(b)return this.left=e,this.top=d,this.rendererRoot.setAttributeNS(null,
+"viewBox","0 0 "+this.size.w+" "+this.size.h),this.translate(this.xOffset,0),!0;(e=this.translate(e-this.left+this.xOffset,d-this.top))||this.setExtent(a,!0);return c&&e},translate:function(a,b){if(this.inValidRange(a,b,!0)){var c="";if(a||b)c="translate("+a+","+b+")";this.root.setAttributeNS(null,"transform",c);this.translationParameters={x:a,y:b};return!0}return!1},setSize:function(a){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);
+this.rendererRoot.setAttributeNS(null,"height",this.size.h)},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"image":this.isComplexSymbol(b.graphicName)?"svg":"circle";break;case "OpenLayers.Geometry.Rectangle":c="rect";break;case "OpenLayers.Geometry.LineString":c="polyline";break;case "OpenLayers.Geometry.LinearRing":c="polygon";break;case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c=
+"path"}return c},setStyle:function(a,b,c){var b=b||a._style,c=c||a._options,d=parseFloat(a.getAttributeNS(null,"r")),e=1,f;if("OpenLayers.Geometry.Point"==a._geometryClass&&d){a.style.visibility="";if(!1===b.graphic)a.style.visibility="hidden";else if(b.externalGraphic){f=this.getPosition(a);if(b.graphicTitle)a.setAttributeNS(null,"title",b.graphicTitle),d=this.nodeFactory(null,"title"),d.textContent=b.graphicTitle,a.appendChild(d);b.graphicWidth&&b.graphicHeight&&a.setAttributeNS(null,"preserveAspectRatio",
+"none");var d=b.graphicWidth||b.graphicHeight,g=b.graphicHeight||b.graphicWidth,d=d?d:2*b.pointRadius,g=g?g:2*b.pointRadius,h=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*g),i=b.graphicOpacity||b.fillOpacity;a.setAttributeNS(null,"x",(f.x+(void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*d))).toFixed());a.setAttributeNS(null,"y",(f.y+h).toFixed());a.setAttributeNS(null,"width",d);a.setAttributeNS(null,"height",g);a.setAttributeNS(this.xlinkns,"href",b.externalGraphic);a.setAttributeNS(null,"style",
+"opacity: "+i);a.onclick=OpenLayers.Renderer.SVG.preventDefault}else if(this.isComplexSymbol(b.graphicName)){var d=3*b.pointRadius,g=2*d,j=this.importSymbol(b.graphicName);f=this.getPosition(a);e=3*this.symbolMetrics[j.id][0]/g;h=a.parentNode;i=a.nextSibling;h&&h.removeChild(a);a.firstChild&&a.removeChild(a.firstChild);a.appendChild(j.firstChild.cloneNode(!0));a.setAttributeNS(null,"viewBox",j.getAttributeNS(null,"viewBox"));a.setAttributeNS(null,"width",g);a.setAttributeNS(null,"height",g);a.setAttributeNS(null,
+"x",f.x-d);a.setAttributeNS(null,"y",f.y-d);i?h.insertBefore(a,i):h&&h.appendChild(a)}else a.setAttributeNS(null,"r",b.pointRadius);d=b.rotation;if((void 0!==d||void 0!==a._rotation)&&f)a._rotation=d,d|=0,"svg"!==a.nodeName?a.setAttributeNS(null,"transform","rotate("+d+" "+f.x+" "+f.y+")"):(f=this.symbolMetrics[j.id],a.firstChild.setAttributeNS(null,"transform","rotate("+d+" "+f[1]+" "+f[2]+")"))}c.isFilled?(a.setAttributeNS(null,"fill",b.fillColor),a.setAttributeNS(null,"fill-opacity",b.fillOpacity)):
+a.setAttributeNS(null,"fill","none");c.isStroked?(a.setAttributeNS(null,"stroke",b.strokeColor),a.setAttributeNS(null,"stroke-opacity",b.strokeOpacity),a.setAttributeNS(null,"stroke-width",b.strokeWidth*e),a.setAttributeNS(null,"stroke-linecap",b.strokeLinecap||"round"),a.setAttributeNS(null,"stroke-linejoin","round"),b.strokeDashstyle&&a.setAttributeNS(null,"stroke-dasharray",this.dashStyle(b,e))):a.setAttributeNS(null,"stroke","none");b.pointerEvents&&a.setAttributeNS(null,"pointer-events",b.pointerEvents);
+null!=b.cursor&&a.setAttributeNS(null,"cursor",b.cursor);return a},dashStyle:function(a,b){var c=a.strokeWidth*b,d=a.strokeDashstyle;switch(d){case "solid":return"none";case "dot":return[1,4*c].join();case "dash":return[4*c,4*c].join();case "dashdot":return[4*c,4*c,1,4*c].join();case "longdash":return[8*c,4*c].join();case "longdashdot":return[8*c,4*c,1,4*c].join();default:return OpenLayers.String.trim(d).replace(/\s+/g,",")}},createNode:function(a,b){var c=document.createElementNS(this.xmlns,a);b&&
+c.setAttributeNS(null,"id",b);return c},nodeTypeCompare:function(a,b){return b==a.nodeName},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg")},createRoot:function(a){return this.nodeFactory(this.container.id+a,"g")},createDefs:function(){var a=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(a);return a},drawPoint:function(a,b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){var d=this.getResolution(),e=(b.x-this.featureDx)/
+d+this.left,b=this.top-b.y/d;return this.inValidRange(e,b)?(a.setAttributeNS(null,"cx",e),a.setAttributeNS(null,"cy",b),a.setAttributeNS(null,"r",c),a):!1},drawLineString:function(a,b){var c=this.getComponentsString(b.components);return c.path?(a.setAttributeNS(null,"points",c.path),c.complete?a:null):!1},drawLinearRing:function(a,b){var c=this.getComponentsString(b.components);return c.path?(a.setAttributeNS(null,"points",c.path),c.complete?a:null):!1},drawPolygon:function(a,b){for(var c="",d=!0,
+e=!0,f,g,h=0,i=b.components.length;h<i;h++)c+=" M",f=this.getComponentsString(b.components[h].components," "),(g=f.path)?(c+=" "+g,e=f.complete&&e):d=!1;return d?(a.setAttributeNS(null,"d",c+" z"),a.setAttributeNS(null,"fill-rule","evenodd"),e?a:null):!1},drawRectangle:function(a,b){var c=this.getResolution(),d=(b.x-this.featureDx)/c+this.left,e=this.top-b.y/c;return this.inValidRange(d,e)?(a.setAttributeNS(null,"x",d),a.setAttributeNS(null,"y",e),a.setAttributeNS(null,"width",b.width/c),a.setAttributeNS(null,
+"height",b.height/c),a):!1},drawSurface:function(a,b){for(var c=null,d=!0,e=0,f=b.components.length;e<f;e++)if(0==e%3&&0==e/3){var g=this.getShortString(b.components[e]);g||(d=!1);c="M "+g}else 1==e%3?((g=this.getShortString(b.components[e]))||(d=!1),c+=" C "+g):((g=this.getShortString(b.components[e]))||(d=!1),c+=" "+g);return d?(a.setAttributeNS(null,"d",c+" Z"),a):!1},drawText:function(a,b,c){var d=this.getResolution(),e=(c.x-this.featureDx)/d+this.left,f=c.y/d-this.top,d=this.nodeFactory(a+this.LABEL_ID_SUFFIX,
+"text");d.setAttributeNS(null,"x",e);d.setAttributeNS(null,"y",-f);b.fontColor&&d.setAttributeNS(null,"fill",b.fontColor);b.fontOpacity&&d.setAttributeNS(null,"opacity",b.fontOpacity);b.fontFamily&&d.setAttributeNS(null,"font-family",b.fontFamily);b.fontSize&&d.setAttributeNS(null,"font-size",b.fontSize);b.fontWeight&&d.setAttributeNS(null,"font-weight",b.fontWeight);b.fontStyle&&d.setAttributeNS(null,"font-style",b.fontStyle);!0===b.labelSelect?(d.setAttributeNS(null,"pointer-events","visible"),
+d._featureId=a):d.setAttributeNS(null,"pointer-events","none");f=b.labelAlign||"cm";d.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[f[0]]||"middle");!0===OpenLayers.IS_GECKO&&d.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG.LABEL_ALIGN[f[1]]||"central");for(var g=b.label.split("\n"),h=g.length;d.childNodes.length>h;)d.removeChild(d.lastChild);for(var i=0;i<h;i++){var j=this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_tspan_"+i,"tspan");if(!0===b.labelSelect)j._featureId=
+a,j._geometry=c,j._geometryClass=c.CLASS_NAME;!1===OpenLayers.IS_GECKO&&j.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[f[1]]||"-35%");j.setAttribute("x",e);if(0==i){var k=OpenLayers.Renderer.SVG.LABEL_VFACTOR[f[1]];null==k&&(k=-0.5);j.setAttribute("dy",k*(h-1)+"em")}else j.setAttribute("dy","1em");j.textContent=""===g[i]?" ":g[i];j.parentNode||d.appendChild(j)}d.parentNode||this.textRoot.appendChild(d)},getComponentsString:function(a,b){for(var c=[],d=!0,e=a.length,f=
+[],g,h=0;h<e;h++)g=a[h],c.push(g),(g=this.getShortString(g))?f.push(g):(0<h&&this.getShortString(a[h-1])&&f.push(this.clipLine(a[h],a[h-1])),h<e-1&&this.getShortString(a[h+1])&&f.push(this.clipLine(a[h],a[h+1])),d=!1);return{path:f.join(b||","),complete:d}},clipLine:function(a,b){if(b.equals(a))return"";var c=this.getResolution(),d=this.MAX_PIXEL-this.translationParameters.x,e=this.MAX_PIXEL-this.translationParameters.y,f=(b.x-this.featureDx)/c+this.left,g=this.top-b.y/c,h=(a.x-this.featureDx)/c+
+this.left,c=this.top-a.y/c,i;if(h<-d||h>d)i=(c-g)/(h-f),h=0>h?-d:d,c=g+(h-f)*i;if(c<-e||c>e)i=(h-f)/(c-g),c=0>c?-e:e,h=f+(c-g)*i;return h+","+c},getShortString:function(a){var b=this.getResolution(),c=(a.x-this.featureDx)/b+this.left,a=this.top-a.y/b;return this.inValidRange(c,a)?c+","+a:!1},getPosition:function(a){return{x:parseFloat(a.getAttributeNS(null,"cx")),y:parseFloat(a.getAttributeNS(null,"cy"))}},importSymbol:function(a){if(!this.defs)this.defs=this.createDefs();var b=this.container.id+
+"-"+a,c=document.getElementById(b);if(null!=c)return c;var d=OpenLayers.Renderer.symbol[a];if(!d)throw Error(a+" is not a valid symbol name");var a=this.nodeFactory(b,"symbol"),e=this.nodeFactory(null,"polygon");a.appendChild(e);for(var c=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0),f=[],g,h,i=0;i<d.length;i+=2)g=d[i],h=d[i+1],c.left=Math.min(c.left,g),c.bottom=Math.min(c.bottom,h),c.right=Math.max(c.right,g),c.top=Math.max(c.top,h),f.push(g,",",h);e.setAttributeNS(null,"points",f.join(" "));
+d=c.getWidth();e=c.getHeight();a.setAttributeNS(null,"viewBox",[c.left-d,c.bottom-e,3*d,3*e].join(" "));this.symbolMetrics[b]=[Math.max(d,e),c.getCenterLonLat().lon,c.getCenterLonLat().lat];this.defs.appendChild(a);return a},getFeatureIdFromEvent:function(a){var b=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!b)b=a.target,b=b.parentNode&&b!=this.rendererRoot&&b.parentNode._featureId;return b},CLASS_NAME:"OpenLayers.Renderer.SVG"});
+OpenLayers.Renderer.SVG.LABEL_ALIGN={l:"start",r:"end",b:"bottom",t:"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={t:"-70%",b:"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={t:0,b:-1};OpenLayers.Renderer.SVG.preventDefault=function(a){a.preventDefault&&a.preventDefault()};
+OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",getVersion:function(a,b){var c=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);if("1.1.1"==c||"1.1.0"==c)c="1.1";return c},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});
+OpenLayers.Format.WMSDescribeLayer.v1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(a){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));for(var a=a.documentElement.childNodes,b=[],c,d,e=0;e<a.length;++e)if(c=a[e],d=c.nodeName,"LayerDescription"==d){d=c.getAttribute("name");var f="",g="",h="";c.getAttribute("owsType")?(f=c.getAttribute("owsType"),g=c.getAttribute("owsURL")):
+""!=c.getAttribute("wfs")?(f="WFS",g=c.getAttribute("wfs")):""!=c.getAttribute("wcs")&&(f="WCS",g=c.getAttribute("wcs"));c=c.getElementsByTagName("Query");0<c.length&&((h=c[0].getAttribute("typeName"))||(h=c[0].getAttribute("typename")));b.push({layerName:d,owsType:f,owsURL:g,typeName:h})}return b},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer.v1_1"});
+OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,contentSize:null,size:null,contentHTML:null,backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:!1,minSize:null,maxSize:null,displayClass:"olPopup",contentDisplayClass:"olPopupContent",padding:0,disableFirefoxOverflowHack:!1,fixPadding:function(){if("number"==typeof this.padding)this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding)},panMapIfOutOfView:!1,
+keepInMap:!1,closeOnMove:!1,map:null,initialize:function(a,b,c,d,e,f){null==a&&(a=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_"));this.id=a;this.lonlat=b;this.contentSize=null!=c?c:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(null!=d)this.contentHTML=d;this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className=this.displayClass;
+this.groupDiv=OpenLayers.Util.createDiv(this.id+"_GroupDiv",null,null,null,"relative",null,"hidden");a=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(a,null,this.contentSize.clone(),null,"relative");this.contentDiv.className=this.contentDisplayClass;this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);e&&this.addCloseBox(f);this.registerEvents()},destroy:function(){this.border=this.opacity=this.backgroundColor=this.contentHTML=this.size=this.lonlat=this.id=
+null;this.closeOnMove&&this.map&&this.map.events.unregister("movestart",this,this.hide);this.events.destroy();this.events=null;this.closeDiv&&(OpenLayers.Event.stopObservingElement(this.closeDiv),this.groupDiv.removeChild(this.closeDiv));this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;null!=this.map&&this.map.removePopup(this);this.panMapIfOutOfView=this.padding=this.maxSize=this.minSize=this.autoSize=this.div=this.map=null},draw:function(a){null==a&&null!=this.lonlat&&null!=
+this.map&&(a=this.map.getLayerPxFromLonLat(this.lonlat));this.closeOnMove&&this.map.events.register("movestart",this,this.hide);!this.disableFirefoxOverflowHack&&"firefox"==OpenLayers.BROWSER_NAME&&(this.map.events.register("movestart",this,function(){var a=document.defaultView.getComputedStyle(this.contentDiv,null).getPropertyValue("overflow");if("hidden"!=a)this.contentDiv._oldOverflow=a,this.contentDiv.style.overflow="hidden"}),this.map.events.register("moveend",this,function(){var a=this.contentDiv._oldOverflow;
+if(a)this.contentDiv.style.overflow=a,this.contentDiv._oldOverflow=null}));this.moveTo(a);!this.autoSize&&!this.size&&this.setSize(this.contentSize);this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();this.panMapIfOutOfView&&this.panIntoView();return this.div},updatePosition:function(){if(this.lonlat&&this.map){var a=this.map.getLayerPxFromLonLat(this.lonlat);a&&this.moveTo(a)}},moveTo:function(a){if(null!=a&&null!=this.div)this.div.style.left=a.x+"px",this.div.style.top=
+a.y+"px"},visible:function(){return OpenLayers.Element.visible(this.div)},toggle:function(){this.visible()?this.hide():this.show()},show:function(){this.div.style.display="";this.panMapIfOutOfView&&this.panIntoView()},hide:function(){this.div.style.display="none"},setSize:function(a){this.size=a.clone();var b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;if(this.closeDiv)var e=parseInt(this.closeDiv.style.width),
+c=c+(e+b.right);this.size.w+=c;this.size.h+=d;"msie"==OpenLayers.BROWSER_NAME&&(this.contentSize.w+=b.left+b.right,this.contentSize.h+=b.bottom+b.top);if(null!=this.div)this.div.style.width=this.size.w+"px",this.div.style.height=this.size.h+"px";if(null!=this.contentDiv)this.contentDiv.style.width=a.w+"px",this.contentDiv.style.height=a.h+"px"},updateSize:function(){var a="<div class='"+this.contentDisplayClass+"'>"+this.contentDiv.innerHTML+"</div>",b=this.map?this.map.layerContainerDiv:document.body,
+c=OpenLayers.Util.getRenderedDimensions(a,null,{displayClass:this.displayClass,containerElement:b}),d=this.getSafeContentSize(c),e=null;d.equals(c)?e=c:(e=new OpenLayers.Size,e.w=d.w<c.w?d.w:null,e.h=d.h<c.h?d.h:null,e.w&&e.h?e=d:(a=OpenLayers.Util.getRenderedDimensions(a,e,{displayClass:this.contentDisplayClass,containerElement:b}),"hidden"!=OpenLayers.Element.getStyle(this.contentDiv,"overflow")&&a.equals(d)&&(d=OpenLayers.Util.getScrollbarWidth(),e.w?a.h+=d:a.w+=d),e=this.getSafeContentSize(a)));
+this.setSize(e)},setBackgroundColor:function(a){if(void 0!=a)this.backgroundColor=a;if(null!=this.div)this.div.style.backgroundColor=this.backgroundColor},setOpacity:function(a){if(void 0!=a)this.opacity=a;if(null!=this.div)this.div.style.opacity=this.opacity,this.div.style.filter="alpha(opacity="+100*this.opacity+")"},setBorder:function(a){if(void 0!=a)this.border=a;if(null!=this.div)this.div.style.border=this.border},setContentHTML:function(a){if(null!=a)this.contentHTML=a;if(null!=this.contentDiv&&
+null!=this.contentHTML&&this.contentHTML!=this.contentDiv.innerHTML)this.contentDiv.innerHTML=this.contentHTML,this.autoSize&&(this.registerImageListeners(),this.updateSize())},registerImageListeners:function(){for(var a=function(){this.popup.updateSize();this.popup.visible()&&this.popup.panMapIfOutOfView&&this.popup.panIntoView();OpenLayers.Event.stopObserving(this.img,"load",this.img._onImageLoad)},b=this.contentDiv.getElementsByTagName("img"),c=0,d=b.length;c<d;c++){var e=b[c];if(0==e.width||0==
+e.height)e._onImgLoad=OpenLayers.Function.bind(a,{popup:this,img:e}),OpenLayers.Event.observe(e,"load",e._onImgLoad)}},getSafeContentSize:function(a){var a=a.clone(),b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;if(this.closeDiv)var e=parseInt(this.closeDiv.style.width),c=c+(e+b.right);if(this.minSize)a.w=Math.max(a.w,this.minSize.w-c),a.h=Math.max(a.h,this.minSize.h-d);if(this.maxSize)a.w=
+Math.min(a.w,this.maxSize.w-c),a.h=Math.min(a.h,this.maxSize.h-d);if(this.map&&this.map.size){e=b=0;if(this.keepInMap&&!this.panMapIfOutOfView)switch(e=this.map.getPixelFromLonLat(this.lonlat),this.relativePosition){case "tr":b=e.x;e=this.map.size.h-e.y;break;case "tl":b=this.map.size.w-e.x;e=this.map.size.h-e.y;break;case "bl":b=this.map.size.w-e.x;e=e.y;break;case "br":b=e.x;e=e.y;break;default:b=e.x,e=this.map.size.h-e.y}d=this.map.size.h-this.map.paddingForPopups.top-this.map.paddingForPopups.bottom-
+d-e;a.w=Math.min(a.w,this.map.size.w-this.map.paddingForPopups.left-this.map.paddingForPopups.right-c-b);a.h=Math.min(a.h,d)}return a},getContentDivPadding:function(){var a=this._contentDivPadding;if(!a){if(null==this.div.parentNode)this.div.style.display="none",document.body.appendChild(this.div);this._contentDivPadding=a=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,
+"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));if(this.div.parentNode==document.body)document.body.removeChild(this.div),this.div.style.display=""}return a},addCloseBox:function(a){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var b=this.getContentDivPadding();this.closeDiv.style.right=b.right+"px";this.closeDiv.style.top=b.top+"px";this.groupDiv.appendChild(this.closeDiv);a=a||function(a){this.hide();
+OpenLayers.Event.stop(a)};OpenLayers.Event.observe(this.closeDiv,"touchend",OpenLayers.Function.bindAsEventListener(a,this));OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(a,this))},panIntoView:function(){var a=this.map.getSize(),b=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top))),c=b.clone();if(b.x<this.map.paddingForPopups.left)c.x=this.map.paddingForPopups.left;else if(b.x+this.size.w>a.w-
+this.map.paddingForPopups.right)c.x=a.w-this.map.paddingForPopups.right-this.size.w;if(b.y<this.map.paddingForPopups.top)c.y=this.map.paddingForPopups.top;else if(b.y+this.size.h>a.h-this.map.paddingForPopups.bottom)c.y=a.h-this.map.paddingForPopups.bottom-this.size.h;this.map.pan(b.x-c.x,b.y-c.y)},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,!0);this.events.on({mousedown:this.onmousedown,mousemove:this.onmousemove,mouseup:this.onmouseup,click:this.onclick,mouseout:this.onmouseout,
+dblclick:this.ondblclick,touchstart:function(a){OpenLayers.Event.stop(a,!0)},scope:this})},onmousedown:function(a){this.mousedown=!0;OpenLayers.Event.stop(a,!0)},onmousemove:function(a){this.mousedown&&OpenLayers.Event.stop(a,!0)},onmouseup:function(a){if(this.mousedown)this.mousedown=!1,OpenLayers.Event.stop(a,!0)},onclick:function(a){OpenLayers.Event.stop(a,!0)},onmouseout:function(){this.mousedown=!1},ondblclick:function(a){OpenLayers.Event.stop(a,!0)},CLASS_NAME:"OpenLayers.Popup"});
+OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";
+OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:!1,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop)this.eTop=document.createElement("div"),this.eTop.className=this.displayClass+"Top",this.div.appendChild(this.eTop),this.eTop.style.visibility=""==this.topOutUnits||""==this.topInUnits?"hidden":"visible",this.eBottom=document.createElement("div"),
+this.eBottom.className=this.displayClass+"Bottom",this.div.appendChild(this.eBottom),this.eBottom.style.visibility=""==this.bottomOutUnits||""==this.bottomInUnits?"hidden":"visible";this.map.events.register("moveend",this,this.update);this.update();return this.div},getBarLen:function(a){var b=parseInt(Math.log(a)/Math.log(10)),b=Math.pow(10,b),a=parseInt(a/b);return(5<a?5:2<a?2:1)*b},update:function(){var a=this.map.getResolution();if(a){var b=this.map.getUnits(),c=OpenLayers.INCHES_PER_UNIT,d=this.maxWidth*
+a*c[b],e=1;!0===this.geodesic&&(e=(this.map.getGeodesicPixelSize().w||1.0E-6)*this.maxWidth/(d/c.km),d*=e);var f,g;1E5<d?(f=this.topOutUnits,g=this.bottomOutUnits):(f=this.topInUnits,g=this.bottomInUnits);var h=d/c[f],i=d/c[g],d=this.getBarLen(h),j=this.getBarLen(i),h=d/c[b]*c[f],i=j/c[b]*c[g],b=h/a/e,a=i/a/e;if("visible"==this.eBottom.style.visibility)this.eBottom.style.width=Math.round(a)+"px",this.eBottom.innerHTML=j+" "+g;if("visible"==this.eTop.style.visibility)this.eTop.style.width=Math.round(b)+
+"px",this.eTop.innerHTML=d+" "+f}},CLASS_NAME:"OpenLayers.Control.ScaleLine"});
+OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(a,b,c,d){this.url=a;this.size=b?b:new OpenLayers.Size(20,20);this.offset=c?c:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=d;a=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(a)},destroy:function(){this.erase();OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML=
+"";this.imageDiv=null},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset)},setSize:function(a){if(null!=a)this.size=a;this.draw()},setUrl:function(a){if(null!=a)this.url=a;this.draw()},draw:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(a);return this.imageDiv},erase:function(){null!=this.imageDiv&&null!=this.imageDiv.parentNode&&OpenLayers.Element.remove(this.imageDiv)},setOpacity:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,
+null,null,null,null,null,null,null,a)},moveTo:function(a){if(null!=a)this.px=a;if(null!=this.imageDiv)if(null==this.px)this.display(!1);else{if(this.calculateOffset)this.offset=this.calculateOffset(this.size);a=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,a)}},display:function(a){this.imageDiv.style.display=a?"":"none"},isDrawn:function(){return this.imageDiv&&this.imageDiv.parentNode&&11!=this.imageDiv.parentNode.nodeType},CLASS_NAME:"OpenLayers.Icon"});
+OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(a,b){this.lonlat=a;var c=b?b:OpenLayers.Marker.defaultIcon();null==this.icon?this.icon=c:(this.icon.url=c.url,this.icon.size=c.size,this.icon.offset=c.offset,this.icon.calculateOffset=c.calculateOffset);this.events=new OpenLayers.Events(this,this.icon.imageDiv)},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(null!=this.icon)this.icon.destroy(),this.icon=null},
+draw:function(a){return this.icon.draw(a)},erase:function(){null!=this.icon&&this.icon.erase()},moveTo:function(a){null!=a&&null!=this.icon&&this.icon.moveTo(a);this.lonlat=this.map.getLonLatFromLayerPx(a)},isDrawn:function(){return this.icon&&this.icon.isDrawn()},onScreen:function(){var a=!1;this.map&&(a=this.map.getExtent().containsLonLat(this.lonlat));return a},inflate:function(a){this.icon&&this.icon.setSize(new OpenLayers.Size(this.icon.size.w*a,this.icon.size.h*a))},setOpacity:function(a){this.icon.setOpacity(a)},
+setUrl:function(a){this.icon.setUrl(a)},display:function(a){this.icon.display(a)},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var a=OpenLayers.Util.getImagesLocation()+"marker.png",b=new OpenLayers.Size(21,25);return new OpenLayers.Icon(a,b,null,function(a){return new OpenLayers.Pixel(-(a.w/2),-a.h)})};
+OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:!1,read:function(a,b,c){var b=b?b:"FeatureCollection",d=null,e=null;if(e="string"==typeof a?OpenLayers.Format.JSON.prototype.read.apply(this,[a,c]):a)if("string"!=typeof e.type)OpenLayers.Console.error("Bad GeoJSON - no type: "+a);else{if(this.isValidType(e,b))switch(b){case "Geometry":try{d=this.parseGeometry(e)}catch(f){OpenLayers.Console.error(f)}break;case "Feature":try{d=this.parseFeature(e),d.type="Feature"}catch(g){OpenLayers.Console.error(g)}break;
+case "FeatureCollection":switch(d=[],e.type){case "Feature":try{d.push(this.parseFeature(e))}catch(h){d=null,OpenLayers.Console.error(h)}break;case "FeatureCollection":a=0;for(b=e.features.length;a<b;++a)try{d.push(this.parseFeature(e.features[a]))}catch(i){d=null,OpenLayers.Console.error(i)}break;default:try{var j=this.parseGeometry(e);d.push(new OpenLayers.Feature.Vector(j))}catch(k){d=null,OpenLayers.Console.error(k)}}}}else OpenLayers.Console.error("Bad JSON: "+a);return d},isValidType:function(a,
+b){var c=!1;switch(b){case "Geometry":-1==OpenLayers.Util.indexOf("Point,MultiPoint,LineString,MultiLineString,Polygon,MultiPolygon,Box,GeometryCollection".split(","),a.type)?OpenLayers.Console.error("Unsupported geometry type: "+a.type):c=!0;break;case "FeatureCollection":c=!0;break;default:a.type==b?c=!0:OpenLayers.Console.error("Cannot convert types from "+a.type+" to "+b)}return c},parseFeature:function(a){var b,c,d;c=a.properties?a.properties:{};d=a.geometry&&a.geometry.bbox||a.bbox;try{b=this.parseGeometry(a.geometry)}catch(e){throw e;
+}b=new OpenLayers.Feature.Vector(b,c);if(d)b.bounds=OpenLayers.Bounds.fromArray(d);if(a.id)b.fid=a.id;return b},parseGeometry:function(a){if(null==a)return null;var b,c=!1;if("GeometryCollection"==a.type){if(!OpenLayers.Util.isArray(a.geometries))throw"GeometryCollection must have geometries array: "+a;b=a.geometries.length;for(var c=Array(b),d=0;d<b;++d)c[d]=this.parseGeometry.apply(this,[a.geometries[d]]);b=new OpenLayers.Geometry.Collection(c);c=!0}else{if(!OpenLayers.Util.isArray(a.coordinates))throw"Geometry must have coordinates array: "+
+a;if(!this.parseCoords[a.type.toLowerCase()])throw"Unsupported geometry type: "+a.type;try{b=this.parseCoords[a.type.toLowerCase()].apply(this,[a.coordinates])}catch(e){throw e;}}this.internalProjection&&this.externalProjection&&!c&&b.transform(this.externalProjection,this.internalProjection);return b},parseCoords:{point:function(a){if(!1==this.ignoreExtraDims&&2!=a.length)throw"Only 2D points are supported: "+a;return new OpenLayers.Geometry.Point(a[0],a[1])},multipoint:function(a){for(var b=[],
+c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.point.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiPoint(b)},linestring:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.point.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.LineString(b)},multilinestring:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.linestring.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiLineString(b)},
+polygon:function(a){for(var b=[],c,d,e=0,f=a.length;e<f;++e){try{d=this.parseCoords.linestring.apply(this,[a[e]])}catch(g){throw g;}c=new OpenLayers.Geometry.LinearRing(d.components);b.push(c)}return new OpenLayers.Geometry.Polygon(b)},multipolygon:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.polygon.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiPolygon(b)},box:function(a){if(2!=a.length)throw"GeoJSON box coordinates must have 2 elements";
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(a[0][0],a[0][1]),new OpenLayers.Geometry.Point(a[1][0],a[0][1]),new OpenLayers.Geometry.Point(a[1][0],a[1][1]),new OpenLayers.Geometry.Point(a[0][0],a[1][1]),new OpenLayers.Geometry.Point(a[0][0],a[0][1])])])}},write:function(a,b){var c={type:null};if(OpenLayers.Util.isArray(a)){c.type="FeatureCollection";var d=a.length;c.features=Array(d);for(var e=0;e<d;++e){var f=a[e];if(!f instanceof OpenLayers.Feature.Vector)throw"FeatureCollection only supports collections of features: "+
+f;c.features[e]=this.extract.feature.apply(this,[f])}}else if(0==a.CLASS_NAME.indexOf("OpenLayers.Geometry"))c=this.extract.geometry.apply(this,[a]);else if(a instanceof OpenLayers.Feature.Vector&&(c=this.extract.feature.apply(this,[a]),a.layer&&a.layer.projection))c.crs=this.createCRSObject(a);return OpenLayers.Format.JSON.prototype.write.apply(this,[c,b])},createCRSObject:function(a){var a=a.layer.projection.toString(),b={};a.match(/epsg:/i)&&(a=parseInt(a.substring(a.indexOf(":")+1)),b=4326==a?
+{type:"name",properties:{name:"urn:ogc:def:crs:OGC:1.3:CRS84"}}:{type:"name",properties:{name:"EPSG:"+a}});return b},extract:{feature:function(a){var b=this.extract.geometry.apply(this,[a.geometry]),b={type:"Feature",properties:a.attributes,geometry:b};if(null!=a.fid)b.id=a.fid;return b},geometry:function(a){if(null==a)return null;this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));var b=a.CLASS_NAME.split(".")[2],a=this.extract[b.toLowerCase()].apply(this,
+[a]);return"Collection"==b?{type:"GeometryCollection",geometries:a}:{type:b,coordinates:a}},point:function(a){return[a.x,a.y]},multipoint:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b},linestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b},multilinestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.linestring.apply(this,
+[a.components[c]]));return b},polygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.linestring.apply(this,[a.components[c]]));return b},multipolygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.polygon.apply(this,[a.components[c]]));return b},collection:function(a){for(var b=a.components.length,c=Array(b),d=0;d<b;++d)c[d]=this.extract.geometry.apply(this,[a.components[d]]);return c}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});
+OpenLayers.Strategy.Paging=OpenLayers.Class(OpenLayers.Strategy,{features:null,length:10,num:null,paging:!1,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a)this.layer.events.on({beforefeaturesadded:this.cacheFeatures,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&(this.clearCache(),this.layer.events.un({beforefeaturesadded:this.cacheFeatures,scope:this}));return a},cacheFeatures:function(a){if(!this.paging)this.clearCache(),
+this.features=a.features,this.pageNext(a)},clearCache:function(){if(this.features)for(var a=0;a<this.features.length;++a)this.features[a].destroy();this.num=this.features=null},pageCount:function(){return Math.ceil((this.features?this.features.length:0)/this.length)},pageNum:function(){return this.num},pageLength:function(a){if(a&&0<a)this.length=a;return this.length},pageNext:function(a){var b=!1;if(this.features){if(null===this.num)this.num=-1;b=this.page((this.num+1)*this.length,a)}return b},pagePrevious:function(){var a=
+!1;if(this.features){if(null===this.num)this.num=this.pageCount();a=this.page((this.num-1)*this.length)}return a},page:function(a,b){var c=!1;if(this.features&&0<=a&&a<this.features.length){var d=Math.floor(a/this.length);if(d!=this.num)this.paging=!0,c=this.features.slice(a,a+this.length),this.layer.removeFeatures(this.layer.features),this.num=d,b&&b.features?b.features=c:this.layer.addFeatures(c),this.paging=!1,c=!0}return c},CLASS_NAME:"OpenLayers.Strategy.Paging"});
+OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,keepInMap:!0,anchor:null,initialize:function(a,b,c,d,e,f,g){OpenLayers.Popup.prototype.initialize.apply(this,[a,b,c,d,f,g]);this.anchor=null!=e?e:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)}},destroy:function(){this.relativePosition=this.anchor=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments)},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments)},
+moveTo:function(a){var b=this.relativePosition;this.relativePosition=this.calculateRelativePosition(a);a=this.calculateNewPx(a);OpenLayers.Popup.prototype.moveTo.apply(this,Array(a));this.relativePosition!=b&&this.updateRelativePosition()},setSize:function(a){OpenLayers.Popup.prototype.setSize.apply(this,arguments);this.lonlat&&this.map&&this.moveTo(this.map.getLayerPxFromLonLat(this.lonlat))},calculateRelativePosition:function(a){a=this.map.getLonLatFromLayerPx(a);a=this.map.getExtent().determineQuadrant(a);
+return OpenLayers.Bounds.oppositeQuadrant(a)},updateRelativePosition:function(){},calculateNewPx:function(a){var a=a.offset(this.anchor.offset),b=this.size||this.contentSize,c="t"==this.relativePosition.charAt(0);a.y+=c?-b.h:this.anchor.size.h;c="l"==this.relativePosition.charAt(1);a.x+=c?-b.w:this.anchor.size.w;return a},CLASS_NAME:"OpenLayers.Popup.Anchored"});
+OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:!1,positionBlocks:null,blocks:null,fixedRelativePosition:!1,initialize:function(a,b,c,d,e,f,g){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition)this.updateRelativePosition(),this.calculateRelativePosition=function(){return this.relativePosition};this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(f)this.closeDiv.style.zIndex=
+1;this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%"},destroy:function(){this.isAlphaImage=this.imageSize=this.imageSrc=null;this.fixedRelativePosition=!1;this.positionBlocks=null;for(var a=0;a<this.blocks.length;a++){var b=this.blocks[a];b.image&&b.div.removeChild(b.image);b.image=null;b.div&&this.groupDiv.removeChild(b.div);b.div=null}this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,
+arguments)},setBackgroundColor:function(){},setBorder:function(){},setOpacity:function(){},setSize:function(a){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks()},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var a=this.getContentDivPadding();this.closeDiv.style.right=a.right+this.padding.right+"px";this.closeDiv.style.top=a.top+this.padding.top+"px"}this.updateBlocks()},calculateNewPx:function(a){var b=
+OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);return b=b.offset(this.positionBlocks[this.relativePosition].offset)},createBlocks:function(){this.blocks=[];var a=null,b;for(b in this.positionBlocks){a=b;break}a=this.positionBlocks[a];for(b=0;b<a.blocks.length;b++){var c={};this.blocks.push(c);c.div=OpenLayers.Util.createDiv(this.id+"_FrameDecorationDiv_"+b,null,null,null,"absolute",null,"hidden",null);c.image=(this.isAlphaImage?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage)(this.id+
+"_FrameDecorationImg_"+b,null,this.imageSize,this.imageSrc,"absolute",null,null,null);c.div.appendChild(c.image);this.groupDiv.appendChild(c.div)}},updateBlocks:function(){this.blocks||this.createBlocks();if(this.size&&this.relativePosition){for(var a=this.positionBlocks[this.relativePosition],b=0;b<a.blocks.length;b++){var c=a.blocks[b],d=this.blocks[b],e=c.anchor.left,f=c.anchor.bottom,g=c.anchor.right,h=c.anchor.top,i=isNaN(c.size.w)?this.size.w-(g+e):c.size.w,j=isNaN(c.size.h)?this.size.h-(f+
+h):c.size.h;d.div.style.width=(0>i?0:i)+"px";d.div.style.height=(0>j?0:j)+"px";d.div.style.left=null!=e?e+"px":"";d.div.style.bottom=null!=f?f+"px":"";d.div.style.right=null!=g?g+"px":"";d.div.style.top=null!=h?h+"px":"";d.image.style.left=c.position.x+"px";d.image.style.top=c.position.y+"px"}this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px"}},CLASS_NAME:"OpenLayers.Popup.Framed"});
+OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:"olHandlerBoxZoomBox",boxOffsets:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask})},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler)this.dragHandler.destroy(),this.dragHandler=
+null},setMap:function(a){OpenLayers.Handler.prototype.setMap.apply(this,arguments);this.dragHandler&&this.dragHandler.setMap(a)},startBox:function(){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv("zoomBox",new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox")},moveBox:function(a){var b=this.dragHandler.start.x,
+c=this.dragHandler.start.y,d=Math.abs(b-a.x),e=Math.abs(c-a.y),f=this.getBoxOffsets();this.zoomBox.style.width=d+f.width+1+"px";this.zoomBox.style.height=e+f.height+1+"px";this.zoomBox.style.left=(a.x<b?b-d-f.left:b-f.left)+"px";this.zoomBox.style.top=(a.y<c?c-e-f.top:c-f.top)+"px"},endBox:function(a){var b;if(5<Math.abs(this.dragHandler.start.x-a.x)||5<Math.abs(this.dragHandler.start.y-a.y)){var c=this.dragHandler.start;b=Math.min(c.y,a.y);var d=Math.max(c.y,a.y),e=Math.min(c.x,a.x),a=Math.max(c.x,
+a.x);b=new OpenLayers.Bounds(e,d,a,b)}else b=this.dragHandler.start.clone();this.removeBox();this.callback("done",[b])},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.boxOffsets=this.zoomBox=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox")},activate:function(){return OpenLayers.Handler.prototype.activate.apply(this,arguments)?(this.dragHandler.activate(),!0):!1},deactivate:function(){return OpenLayers.Handler.prototype.deactivate.apply(this,arguments)?(this.dragHandler.deactivate()&&
+this.zoomBox&&this.removeBox(),!0):!1},getBoxOffsets:function(){if(!this.boxOffsets){var a=document.createElement("div");a.style.position="absolute";a.style.border="1px solid black";a.style.width="3px";document.body.appendChild(a);var b=3==a.clientWidth;document.body.removeChild(a);var a=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width")),c=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width")),d=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width")),
+e=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:a,right:c,top:d,bottom:e,width:!1===b?a+c:0,height:!1===b?d+e:0}}return this.boxOffsets},CLASS_NAME:"OpenLayers.Handler.Box"});
+OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:!1,alwaysZoom:!1,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask})},zoomBox:function(a){if(a instanceof OpenLayers.Bounds){var b;if(this.out){b=Math.abs(a.right-a.left);var c=Math.abs(a.top-a.bottom);b=Math.min(this.map.size.h/c,this.map.size.w/b);var c=this.map.getExtent(),d=this.map.getLonLatFromPixel(a.getCenterPixel()),a=d.lon-c.getWidth()/
+2*b,e=d.lon+c.getWidth()/2*b,f=d.lat-c.getHeight()/2*b;b=d.lat+c.getHeight()/2*b;b=new OpenLayers.Bounds(a,f,e,b)}else b=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.left,a.bottom)),c=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.right,a.top)),b=new OpenLayers.Bounds(b.lon,b.lat,c.lon,c.lat);c=this.map.getZoom();this.map.zoomToExtent(b);c==this.map.getZoom()&&!0==this.alwaysZoom&&this.map.zoomTo(c+(this.out?-1:1))}else this.out?this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()-
+1):this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()+1)},CLASS_NAME:"OpenLayers.Control.ZoomBox"});
+OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:!1,interval:1,documentDrag:!1,kinetic:null,enableKinetic:!1,kineticInterval:10,draw:function(){if(this.enableKinetic){var a={interval:this.kineticInterval};"object"===typeof this.enableKinetic&&(a=OpenLayers.Util.extend(a,this.enableKinetic));this.kinetic=new OpenLayers.Kinetic(a)}this.handler=new OpenLayers.Handler.Drag(this,{move:this.panMap,done:this.panMapDone,down:this.panMapStart},{interval:this.interval,
+documentDrag:this.documentDrag})},panMapStart:function(){this.kinetic&&this.kinetic.begin()},panMap:function(a){this.kinetic&&this.kinetic.update(a);this.panned=!0;this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!0,animate:!1})},panMapDone:function(a){if(this.panned){var b=null;this.kinetic&&(b=this.kinetic.end(a));this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!!b,animate:!1});if(b){var c=this;this.kinetic.move(b,function(a,b,f){c.map.pan(a,b,{dragging:!f,
+animate:!1})})}this.panned=!1}},CLASS_NAME:"OpenLayers.Control.DragPan"});
+OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:!0,"double":!1,pixelTolerance:0,dblclickTolerance:13,stopSingle:!1,stopDouble:!1,timerId:null,touch:!1,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(a){if(!this.touch)this.unregisterMouseListeners(),this.touch=!0;this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},touchmove:function(a){this.last=this.getEventInfo(a);return!0},touchend:function(a){if(this.down)a.xy=this.last.xy,
+a.lastTouches=this.last.touches,this.handleSingle(a),this.down=null;return!0},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this})},mousedown:function(a){this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},mouseup:function(a){var b=!0;this.checkModifiers(a)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(a)&&(b=this.rightclick(a));return b},rightclick:function(a){if(this.passesTolerance(a)){if(null!=
+this.rightclickTimerId)return this.clearTimer(),this.callback("dblrightclick",[a]),!this.stopDouble;a=this["double"]?OpenLayers.Util.extend({},a):this.callback("rightclick",[a]);a=OpenLayers.Function.bind(this.delayedRightCall,this,a);this.rightclickTimerId=window.setTimeout(a,this.delay)}return!this.stopSingle},delayedRightCall:function(a){this.rightclickTimerId=null;a&&this.callback("rightclick",[a])},click:function(a){if(!this.last)this.last=this.getEventInfo(a);this.handleSingle(a);return!this.stopSingle},
+dblclick:function(a){this.handleDouble(a);return!this.stopDouble},handleDouble:function(a){this["double"]&&this.passesDblclickTolerance(a)&&this.callback("dblclick",[a])},handleSingle:function(a){if(this.passesTolerance(a))null!=this.timerId?(this.last.touches&&1===this.last.touches.length&&(this["double"]&&OpenLayers.Event.stop(a),this.handleDouble(a)),(!this.last.touches||2!==this.last.touches.length)&&this.clearTimer()):(this.first=this.getEventInfo(a),this.queuePotentialClick(this.single?OpenLayers.Util.extend({},
+a):null))},queuePotentialClick:function(a){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay)},passesTolerance:function(a){var b=!0;if(null!=this.pixelTolerance&&this.down&&this.down.xy&&(b=this.pixelTolerance>=this.down.xy.distanceTo(a.xy))&&this.touch&&this.down.touches.length===this.last.touches.length)for(var a=0,c=this.down.touches.length;a<c;++a)if(this.getTouchDistance(this.down.touches[a],this.last.touches[a])>this.pixelTolerance){b=!1;break}return b},
+getTouchDistance:function(a,b){return Math.sqrt(Math.pow(a.clientX-b.clientX,2)+Math.pow(a.clientY-b.clientY,2))},passesDblclickTolerance:function(){var a=!0;this.down&&this.first&&(a=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance);return a},clearTimer:function(){if(null!=this.timerId)window.clearTimeout(this.timerId),this.timerId=null;if(null!=this.rightclickTimerId)window.clearTimeout(this.rightclickTimerId),this.rightclickTimerId=null},delayedCall:function(a){this.timerId=null;
+a&&this.callback("click",[a])},getEventInfo:function(a){var b;if(a.touches){var c=a.touches.length;b=Array(c);for(var d,e=0;e<c;e++)d=a.touches[e],b[e]={clientX:d.clientX,clientY:d.clientY}}return{xy:a.xy,touches:b}},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.clearTimer(),this.last=this.first=this.down=null,this.touch=!1,a=!0;return a},CLASS_NAME:"OpenLayers.Handler.Click"});
+OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:!1,zoomBox:null,zoomBoxEnabled:!0,zoomWheelEnabled:!0,mouseWheelOptions:null,handleRightClicks:!1,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:!0,initialize:function(a){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;
+this.zoomBox&&this.zoomBox.destroy();this.zoomBox=null;this.pinchZoom&&this.pinchZoom.destroy();this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){this.dragPan.activate();this.zoomWheelEnabled&&this.handlers.wheel.activate();this.handlers.click.activate();this.zoomBoxEnabled&&this.zoomBox.activate();this.pinchZoom&&this.pinchZoom.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.pinchZoom&&this.pinchZoom.deactivate();
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},draw:function(){if(this.handleRightClicks)this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.defaultClick,dblclick:this.defaultDblClick,dblrightclick:this.defaultDblRightClick},{"double":!0,stopDouble:!0});this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,
+documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{up:this.wheelUp,down:this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom)this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions))},defaultClick:function(a){a.lastTouches&&2==a.lastTouches.length&&
+this.map.zoomOut()},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom+1)},defaultDblRightClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom-1)},wheelChange:function(a,b){var c=this.map.getZoom(),d=this.map.getZoom()+Math.round(b),d=Math.max(d,0),d=Math.min(d,this.map.getNumZoomLevels());if(d!==c){var e=this.map.getSize(),c=e.w/2-a.xy.x,e=a.xy.y-e.h/2,f=this.map.baseLayer.getResolutionForZoom(d),g=this.map.getLonLatFromPixel(a.xy);
+this.map.setCenter(new OpenLayers.LonLat(g.lon+c*f,g.lat+e*f),d)}},wheelUp:function(a,b){this.wheelChange(a,b||1)},wheelDown:function(a,b){this.wheelChange(a,b||-1)},disableZoomBox:function(){this.zoomBoxEnabled=!1;this.zoomBox.deactivate()},enableZoomBox:function(){this.zoomBoxEnabled=!0;this.active&&this.zoomBox.activate()},disableZoomWheel:function(){this.zoomWheelEnabled=!1;this.handlers.wheel.deactivate()},enableZoomWheel:function(){this.zoomWheelEnabled=!0;this.active&&this.handlers.wheel.activate()},
+CLASS_NAME:"OpenLayers.Control.Navigation"});
+OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:!1,featureAdded:function(){},handlerOptions:null,initialize:function(a,b,c){OpenLayers.Control.prototype.initialize.apply(this,[c]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(a,b){this.layer.events.triggerEvent("sketchmodified",{vertex:a,feature:b})},create:function(a,b){this.layer.events.triggerEvent("sketchstarted",{vertex:a,feature:b})}},this.callbacks);this.layer=
+a;this.handlerOptions=this.handlerOptions||{};this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{renderers:a.renderers,rendererOptions:a.rendererOptions});if(!("multi"in this.handlerOptions))this.handlerOptions.multi=this.multi;if(a=this.layer.styleMap&&this.layer.styleMap.styles.temporary)this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":a})});this.handler=new b(this,
+this.callbacks,this.handlerOptions)},drawFeature:function(a){a=new OpenLayers.Feature.Vector(a);if(!1!==this.layer.events.triggerEvent("sketchcomplete",{feature:a}))a.state=OpenLayers.State.INSERT,this.layer.addFeatures([a]),this.featureAdded(a),this.events.triggerEvent("featureadded",{feature:a})},insertXY:function(a,b){this.handler&&this.handler.line&&this.handler.insertXY(a,b)},insertDeltaXY:function(a,b){this.handler&&this.handler.line&&this.handler.insertDeltaXY(a,b)},insertDirectionLength:function(a,
+b){this.handler&&this.handler.line&&this.handler.insertDirectionLength(a,b)},insertDeflectionLength:function(a,b){this.handler&&this.handler.line&&this.handler.insertDeflectionLength(a,b)},undo:function(){return this.handler.undo&&this.handler.undo()},redo:function(){return this.handler.redo&&this.handler.redo()},finishSketch:function(){this.handler.finishGeometry()},cancel:function(){this.handler.cancel()},CLASS_NAME:"OpenLayers.Control.DrawFeature"});
+OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{citeCompliant:!1,initialize:function(a,b){OpenLayers.Control.Panel.prototype.initialize.apply(this,[b]);this.addControls([new OpenLayers.Control.Navigation]);this.addControls([new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Point,{displayClass:"olControlDrawFeaturePoint",handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Path,{displayClass:"olControlDrawFeaturePath",
+handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Polygon,{displayClass:"olControlDrawFeaturePolygon",handlerOptions:{citeCompliant:this.citeCompliant}})])},draw:function(){var a=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(null===this.defaultControl)this.defaultControl=this.controls[0];return a},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});
+OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:"_layer",featureIdentifier:"_feature",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},gmlFormat:null,read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=a.documentElement;if(b)var c=this["read_"+b.nodeName],a=c?c.call(this,b):(new OpenLayers.Format.GML(this.options?this.options:{})).read(a);return a},read_msGMLOutput:function(a){var b=
+[];if(a=this.getSiblingNodesByTagCriteria(a,this.layerIdentifier))for(var c=0,d=a.length;c<d;++c){var e=a[c],f=e.nodeName;e.prefix&&(f=f.split(":")[1]);f=f.replace(this.layerIdentifier,"");if(e=this.getSiblingNodesByTagCriteria(e,this.featureIdentifier))for(var g=0;g<e.length;g++){var h=e[g],i=this.parseGeometry(h),h=this.parseAttributes(h),h=new OpenLayers.Feature.Vector(i.geometry,h,null);h.bounds=i.bounds;h.type=f;b.push(h)}}return b},read_FeatureInfoResponse:function(a){for(var b=[],a=this.getElementsByTagNameNS(a,
+"*","FIELDS"),c=0,d=a.length;c<d;c++){var e=a[c],f={},g,h=e.attributes.length;if(0<h)for(g=0;g<h;g++){var i=e.attributes[g];f[i.nodeName]=i.nodeValue}else{e=e.childNodes;for(g=0,h=e.length;g<h;++g)i=e[g],3!=i.nodeType&&(f[i.getAttribute("name")]=i.getAttribute("value"))}b.push(new OpenLayers.Feature.Vector(null,f,null))}return b},getSiblingNodesByTagCriteria:function(a,b){var c=[],d,e,f,g;if(a&&a.hasChildNodes()){d=a.childNodes;f=d.length;for(var h=0;h<f;h++){for(g=d[h];g&&1!=g.nodeType;)g=g.nextSibling,
+h++;e=g?g.nodeName:"";0<e.length&&-1<e.indexOf(b)?c.push(g):(e=this.getSiblingNodesByTagCriteria(g,b),0<e.length&&(0==c.length?c=e:c.push(e)))}}return c},parseAttributes:function(a){var b={};if(1==a.nodeType)for(var a=a.childNodes,c=a.length,d=0;d<c;++d){var e=a[d];if(1==e.nodeType){var f=e.childNodes,e=e.prefix?e.nodeName.split(":")[1]:e.nodeName;if(0==f.length)b[e]=null;else if(1==f.length&&(f=f[0],3==f.nodeType||4==f.nodeType))f=f.nodeValue.replace(this.regExes.trimSpace,""),b[e]=f}}return b},
+parseGeometry:function(a){if(!this.gmlFormat)this.gmlFormat=new OpenLayers.Format.GML;var a=this.gmlFormat.parseFeature(a),b,c=null;a&&(b=a.geometry&&a.geometry.clone(),c=a.bounds&&a.bounds.clone(),a.destroy());return{geometry:b,bounds:c}},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(a,b,c){this.rgb={r:a,g:b,b:c}},setRed:function(a){this.rgb.r=a},setGreen:function(a){this.rgb.g=a},setBlue:function(a){this.rgb.b=a},setHue:function(a){var b=this.asHSB();b.h=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setSaturation:function(a){var b=this.asHSB();b.s=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setBrightness:function(a){var b=this.asHSB();b.b=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},
+darken:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.max(b.b-a,0))},brighten:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.min(b.b+a,1))},blend:function(a){this.rgb.r=Math.floor((this.rgb.r+a.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+a.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+a.rgb.b)/2)},isBright:function(){this.asHSB();return 0.5<this.asHSB().b},isDark:function(){return!this.isBright()},asRGB:function(){return"rgb("+
+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")"},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart()},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b)},toString:function(){return this.asHex()}});
+OpenLayers.Rico.Color.createFromHex=function(a){if(4==a.length)for(var b=a,a="#",c=1;4>c;c++)a+=b.charAt(c)+b.charAt(c);0==a.indexOf("#")&&(a=a.substring(1));b=a.substring(0,2);c=a.substring(2,4);a=a.substring(4,6);return new OpenLayers.Rico.Color(parseInt(b,16),parseInt(c,16),parseInt(a,16))};
+OpenLayers.Rico.Color.createColorFromBackground=function(a){var b=OpenLayers.Element.getStyle(OpenLayers.Util.getElement(a),"backgroundColor");if("transparent"==b&&a.parentNode)return OpenLayers.Rico.Color.createColorFromBackground(a.parentNode);if(null==b)return new OpenLayers.Rico.Color(255,255,255);return 0==b.indexOf("rgb(")?(a=b.substring(4,b.length-1).split(","),new OpenLayers.Rico.Color(parseInt(a[0]),parseInt(a[1]),parseInt(a[2]))):0==b.indexOf("#")?OpenLayers.Rico.Color.createFromHex(b):
+new OpenLayers.Rico.Color(255,255,255)};
+OpenLayers.Rico.Color.HSBtoRGB=function(a,b,c){var d=0,e=0,f=0;if(0==b)f=e=d=parseInt(255*c+0.5);else{var a=6*(a-Math.floor(a)),g=a-Math.floor(a),h=c*(1-b),i=c*(1-b*g),b=c*(1-b*(1-g));switch(parseInt(a)){case 0:d=255*c+0.5;e=255*b+0.5;f=255*h+0.5;break;case 1:d=255*i+0.5;e=255*c+0.5;f=255*h+0.5;break;case 2:d=255*h+0.5;e=255*c+0.5;f=255*b+0.5;break;case 3:d=255*h+0.5;e=255*i+0.5;f=255*c+0.5;break;case 4:d=255*b+0.5;e=255*h+0.5;f=255*c+0.5;break;case 5:d=255*c+0.5,e=255*h+0.5,f=255*i+0.5}}return{r:parseInt(d),
+g:parseInt(e),b:parseInt(f)}};OpenLayers.Rico.Color.RGBtoHSB=function(a,b,c){var d,e=a>b?a:b;c>e&&(e=c);var f=a<b?a:b;c<f&&(f=c);d=0!=e?(e-f)/e:0;if(0==d)a=0;else{var g=(e-a)/(e-f),h=(e-b)/(e-f),c=(e-c)/(e-f),a=(a==e?c-h:b==e?2+g-c:4+h-g)/6;0>a&&(a+=1)}return{h:a,s:d,b:e/255}};OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Corner={round:function(a,b){a=OpenLayers.Util.getElement(a);this._setOptions(b);var c=this.options.color;"fromElement"==this.options.color&&(c=this._background(a));var d=this.options.bgColor;"fromParent"==this.options.bgColor&&(d=this._background(a.offsetParent));this._roundCornersImpl(a,c,d)},changeColor:function(a,b){a.style.backgroundColor=b;for(var c=a.parentNode.getElementsByTagName("span"),d=0;d<c.length;d++)c[d].style.backgroundColor=b},changeOpacity:function(a,b){var c="alpha(opacity="+
+100*b+")";a.style.opacity=b;a.style.filter=c;for(var d=a.parentNode.getElementsByTagName("span"),e=0;e<d.length;e++)d[e].style.opacity=b,d[e].style.filter=c},reRound:function(a,b){var c=a.parentNode.childNodes[2];a.parentNode.removeChild(a.parentNode.childNodes[0]);a.parentNode.removeChild(c);this.round(a.parentNode,b)},_roundCornersImpl:function(a,b,c){this.options.border&&this._renderBorder(a,c);this._isTopRounded()&&this._roundTopCorners(a,b,c);this._isBottomRounded()&&this._roundBottomCorners(a,
+b,c)},_renderBorder:function(a,b){var c="1px solid "+this._borderColor(b);a.innerHTML="<div "+("style='border-left: "+c+";"+("border-right: "+c)+"'")+">"+a.innerHTML+"</div>"},_roundTopCorners:function(a,b,c){for(var d=this._createCorner(c),e=0;e<this.options.numSlices;e++)d.appendChild(this._createCornerSlice(b,c,e,"top"));a.style.paddingTop=0;a.insertBefore(d,a.firstChild)},_roundBottomCorners:function(a,b,c){for(var d=this._createCorner(c),e=this.options.numSlices-1;0<=e;e--)d.appendChild(this._createCornerSlice(b,
+c,e,"bottom"));a.style.paddingBottom=0;a.appendChild(d)},_createCorner:function(a){var b=document.createElement("div");b.style.backgroundColor=this._isTransparent()?"transparent":a;return b},_createCornerSlice:function(a,b,c,d){var e=document.createElement("span"),f=e.style;f.backgroundColor=a;f.display="block";f.height="1px";f.overflow="hidden";f.fontSize="1px";a=this._borderColor(a,b);if(this.options.border&&0==c)f.borderTopStyle="solid",f.borderTopWidth="1px",f.borderLeftWidth="0px",f.borderRightWidth=
+"0px",f.borderBottomWidth="0px",f.height="0px",f.borderColor=a;else if(a)f.borderColor=a,f.borderStyle="solid",f.borderWidth="0px 1px";if(!this.options.compact&&c==this.options.numSlices-1)f.height="2px";this._setMargin(e,c,d);this._setBorder(e,c,d);return e},_setOptions:function(a){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:!0,border:!1,compact:!1};OpenLayers.Util.extend(this.options,a||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent())this.options.blend=
+!1},_whichSideTop:function(){return this._hasString(this.options.corners,"all","top")||0<=this.options.corners.indexOf("tl")&&0<=this.options.corners.indexOf("tr")?"":0<=this.options.corners.indexOf("tl")?"left":0<=this.options.corners.indexOf("tr")?"right":""},_whichSideBottom:function(){return this._hasString(this.options.corners,"all","bottom")||0<=this.options.corners.indexOf("bl")&&0<=this.options.corners.indexOf("br")?"":0<=this.options.corners.indexOf("bl")?"left":0<=this.options.corners.indexOf("br")?
+"right":""},_borderColor:function(a,b){return"transparent"==a?b:this.options.border?this.options.border:this.options.blend?this._blend(b,a):""},_setMargin:function(a,b,c){b=this._marginSize(b);c="top"==c?this._whichSideTop():this._whichSideBottom();"left"==c?(a.style.marginLeft=b+"px",a.style.marginRight="0px"):"right"==c?(a.style.marginRight=b+"px",a.style.marginLeft="0px"):(a.style.marginLeft=b+"px",a.style.marginRight=b+"px")},_setBorder:function(a,b,c){b=this._borderSize(b);c="top"==c?this._whichSideTop():
+this._whichSideBottom();"left"==c?(a.style.borderLeftWidth=b+"px",a.style.borderRightWidth="0px"):"right"==c?(a.style.borderRightWidth=b+"px",a.style.borderLeftWidth="0px"):(a.style.borderLeftWidth=b+"px",a.style.borderRightWidth=b+"px");if(!1!=this.options.border)a.style.borderLeftWidth=b+"px",a.style.borderRightWidth=b+"px"},_marginSize:function(a){if(this._isTransparent())return 0;var b=[5,3,2,1],c=[3,2,1,0],d=[2,1],e=[1,0];return this.options.compact&&this.options.blend?e[a]:this.options.compact?
+d[a]:this.options.blend?c[a]:b[a]},_borderSize:function(a){var b=[5,3,2,1],c=[2,1,1,1],d=[1,0],e=[0,2,0,0];return this.options.compact&&(this.options.blend||this._isTransparent())?1:this.options.compact?d[a]:this.options.blend?c[a]:this.options.border?e[a]:this._isTransparent()?b[a]:0},_hasString:function(a){for(var b=1;b<arguments.length;b++)if(0<=a.indexOf(arguments[b]))return!0;return!1},_blend:function(a,b){var c=OpenLayers.Rico.Color.createFromHex(a);c.blend(OpenLayers.Rico.Color.createFromHex(b));
+return c},_background:function(a){try{return OpenLayers.Rico.Color.createColorFromBackground(a).asHex()}catch(b){return"#ffffff"}},_isTransparent:function(){return"transparent"==this.options.color},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr")},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br")},_hasSingleTextChild:function(a){return 1==a.childNodes.length&&3==a.childNodes[0].nodeType}};
+OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:!1,initialize:function(a,b,c,d,e,f,g){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments)},draw:function(a){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div},updateRelativePosition:function(){this.setRicoCorners()},
+setSize:function(a){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners()},setBackgroundColor:function(a){if(void 0!=a)this.backgroundColor=a;if(null!=this.div&&null!=this.contentDiv)this.div.style.background="transparent",OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor)},setOpacity:function(a){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,a);null!=this.div&&null!=this.groupDiv&&OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity)},
+setBorder:function(){this.border=0},setRicoCorners:function(){var a={corners:this.getCornersToRound(this.relativePosition),color:this.backgroundColor,bgColor:"transparent",blend:!1};this.rounded?(OpenLayers.Rico.Corner.reRound(this.groupDiv,a),this.setBackgroundColor(),this.setOpacity()):(OpenLayers.Rico.Corner.round(this.div,a),this.rounded=!0)},getCornersToRound:function(){var a=["tl","tr","bl","br"],b=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(a,b);return a.join(" ")},
+CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;
+OpenLayers.Strategy.Save=OpenLayers.Class(OpenLayers.Strategy,{events:null,auto:!1,timer:null,initialize:function(a){OpenLayers.Strategy.prototype.initialize.apply(this,[a]);this.events=new OpenLayers.Events(this)},activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a&&this.auto)if("number"===typeof this.auto)this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),1E3*this.auto);else this.layer.events.on({featureadded:this.triggerSave,afterfeaturemodified:this.triggerSave,
+scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.auto&&("number"===typeof this.auto?window.clearInterval(this.timer):this.layer.events.un({featureadded:this.triggerSave,afterfeaturemodified:this.triggerSave,scope:this}));return a},triggerSave:function(a){var b=a.feature;(b.state===OpenLayers.State.INSERT||b.state===OpenLayers.State.UPDATE||b.state===OpenLayers.State.DELETE)&&this.save([a.feature])},save:function(a){if(!a)a=this.layer.features;
+this.events.triggerEvent("start",{features:a});var b=this.layer.projection,c=this.layer.map.getProjectionObject();if(!c.equals(b)){for(var d=a.length,e=Array(d),f,g,h=0;h<d;++h){f=a[h];g=f.clone();g.fid=f.fid;g.state=f.state;if(f.url)g.url=f.url;g._original=f;g.geometry.transform(c,b);e[h]=g}a=e}this.layer.protocol.commit(a,{callback:this.onCommit,scope:this})},onCommit:function(a){var b={response:a};if(a.success()){for(var c=a.reqFeatures,d,e=[],f=a.insertIds||[],g=0,h=0,i=c.length;h<i;++h)if(d=
+c[h],d=d._original||d,a=d.state){if(a==OpenLayers.State.DELETE)e.push(d);else if(a==OpenLayers.State.INSERT)d.fid=f[g],++g;d.state=null}0<e.length&&this.layer.destroyFeatures(e);this.events.triggerEvent("success",b)}else this.events.triggerEvent("fail",b)},CLASS_NAME:"OpenLayers.Strategy.Save"});
+OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a)if(this.layer.events.on({moveend:this.update,scope:this}),this.layer.events.on({refresh:this.update,scope:this}),!0===this.layer.visibility&&!0===this.layer.inRange)this.update();else this.layer.events.on({visibilitychanged:this.update,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);
+a&&this.layer.events.un({moveend:this.update,refresh:this.update,visibilitychanged:this.update,scope:this});return a},update:function(a){var b=this.getMapBounds();if(null!==b&&(a&&a.force||this.invalidBounds(b)))this.calculateBounds(b),this.resolution=this.layer.map.getResolution(),this.triggerRead(a)},getMapBounds:function(){if(null===this.layer.map)return null;var a=this.layer.map.getExtent();a&&!this.layer.projection.equals(this.layer.map.getProjectionObject())&&(a=a.clone().transform(this.layer.map.getProjectionObject(),
+this.layer.projection));return a},invalidBounds:function(a){a||(a=this.getMapBounds());a=!this.bounds||!this.bounds.containsBounds(a);!a&&this.resFactor&&(a=this.resolution/this.layer.map.getResolution(),a=a>=this.resFactor||a<=1/this.resFactor);return a},calculateBounds:function(a){a||(a=this.getMapBounds());var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio,a=a.getHeight()*this.ratio;this.bounds=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2)},triggerRead:function(a){this.response&&
+(this.layer.protocol.abort(this.response),this.layer.events.triggerEvent("loadend"));this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:this.createFilter(),callback:this.merge,scope:this},a))},createFilter:function(){var a=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});this.layer.filter&&(a=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,
+filters:[this.layer.filter,a]}));return a},merge:function(a){this.layer.destroyFeatures();if((a=a.features)&&0<a.length){var b=this.layer.projection,c=this.layer.map.getProjectionObject();if(!c.equals(b))for(var d,e=0,f=a.length;e<f;++e)(d=a[e].geometry)&&d.transform(b,c);this.layer.addFeatures(a)}this.response=null;this.layer.events.triggerEvent("loadend")},CLASS_NAME:"OpenLayers.Strategy.BBOX"});
+OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:!0,lzd:null,zoomLevels:null,initialize:function(a,b,c,d,e,f){this.lzd=c;this.zoomLevels=d;c=[];c.push(a,b,e,f);OpenLayers.Layer.Grid.prototype.initialize.apply(this,c);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS)},getZoom:function(){var a=this.map.getZoom();this.map.getMaxExtent();return a-=Math.log(this.maxResolution/(this.lzd/512))/Math.log(2)},getURL:function(a){var a=
+this.adjustBounds(a),b=this.getZoom(),c=this.map.getMaxExtent(),d=this.lzd/Math.pow(2,this.getZoom()),e=Math.floor((a.left-c.left)/d),a=Math.floor((a.bottom-c.bottom)/d);return this.map.getResolution()<=this.lzd/512&&this.getZoom()<=this.zoomLevels?this.getFullRequestString({L:b,X:e,Y:a}):OpenLayers.Util.getImagesLocation()+"blank.gif"},CLASS_NAME:"OpenLayers.Layer.WorldWind"});
+OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(a){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat)if("gml2"==this.outputFormat.toLowerCase())this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});else if("json"==this.outputFormat.toLowerCase())this.readFormat=new OpenLayers.Format.GeoJSON},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});
+OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":!0},createLayer:function(a,b){var c,d={layer:!0,matrixSet:!0},e;for(e in d)if(!(e in b))throw Error("Missing property '"+e+"' in layer configuration.");d=a.contents;e=d.tileMatrixSets[b.matrixSet];for(var f,g=0,h=d.layers.length;g<h;++g)if(d.layers[g].identifier===b.layer){f=d.layers[g];break}if(f&&e){for(var i,g=0,h=f.styles.length;g<h&&!(i=f.styles[g],i.isDefault);++g);
+c=new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(b,{url:a.operationsMetadata.GetTile.dcp.http.get,name:f.title,style:i.identifier,matrixIds:e.matrixIds}))}return c},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities"});
+OpenLayers.Strategy.SaveWithLock=OpenLayers.Class(OpenLayers.Strategy.Save,{initialize:function(a){OpenLayers.Strategy.Save.prototype.initialize.apply(this,[a])},activate:function(){var a="function"==typeof this.layer.protocol.commitWithLock?!0:!1;if(!this.layer.protocol||!1==a)return OpenLayers.Console.error("...can not activate SaveWithLock strategy...vector layer protocol does not support commitWithLock interface..."),!1;if(a=OpenLayers.Strategy.Save.prototype.activate.call(this))this.layer.events.addEventType("transactionsucceeded"),
+this.layer.events.addEventType("transactionfailed");return a},deactivate:function(){return OpenLayers.Strategy.Save.prototype.deactivate.call(this)},saveWithLock:function(a){if(!0==this.active){if(!a)a=this.layer.features;this.events.triggerEvent("start",{features:a});this.layer.protocol.commitWithLock(a,{callback:this.onSaveWithLock,scope:this})}else throw OpenLayers.Console.error("...can not call saveWithLock...SaveWithLock strategy is not activated..."),"...can not call saveWithLock...SaveWithLock strategy is not activated...";
+},triggerSave:function(a){var b=a.feature;(b.state===OpenLayers.State.INSERT||b.state===OpenLayers.State.UPDATE||b.state===OpenLayers.State.DELETE)&&this.saveWithLock([a.feature])},onSaveWithLock:function(a){if("ALL"==this.layer.protocol.releaseAction){var b={lockId:a.lockId};this.layer.events.triggerEvent("afterfeaturesunlocked",b)}if(a.success()){OpenLayers.Console.log("...transaction succeeded...");for(var c=a.reqFeatures,d,e,f=[],b=[],g=a.insertIds||[],h=0,i=0,j=c.length;i<j;++i)if(e=c[i],d=e.state){if(d==
+OpenLayers.State.DELETE)f.push(e);else if(d==OpenLayers.State.UPDATE)b.push(e);else if(d==OpenLayers.State.INSERT)e.fid=g[h],++h;e.state=null}OpenLayers.Console.log("...synchronize deleted features......features number: "+f.length);0<f.length&&this.layer.destroyFeatures(f);if(0<b.length||0<a.insertIds.length){a=a.insertIds||[];for(i=0;i<b.length;i++)b[i].fid&&a.push(b[i].fid);b=new OpenLayers.Filter.FeatureId({fids:a});OpenLayers.Console.log("...synchronize inserted/updated features...features number: "+
+a.length);this.layer.protocol.read({filter:b,callback:this.synchronizeFeatures,scope:this})}}else OpenLayers.Console.log("...transaction failed..."),b={response:a},this.events.triggerEvent("fail",b),this.layer.events.triggerEvent("transactionfailed",b)},synchronizeFeatures:function(a){if(a.success()&&a.features){for(var b=a.features,c=[],d=0;d<b.length;d++){for(var e=this.layer.getFeatureByFid(b[d].fid),f=0;f<this.layer.strategies.length;f++){var g=this.layer.strategies[f];if(g instanceof OpenLayers.Strategy.Lock){OpenLayers.Console.debug("...layer has lock strategy...");
+for(var h=0;h<g.lockedFeatures.length;h++)null!=e&&g.lockedFeatures[h].fid===e.fid&&(OpenLayers.Console.debug("...remove commited feature from locked feature list..."),OpenLayers.Util.removeItem(g.lockedFeatures,g.lockedFeatures[h]))}}e&&c.push(e)}this.layer.destroyFeatures(c);this.layer.addFeatures(b);OpenLayers.Console.log("...inserted/updated features synchronized...features number: "+b.length);a={response:a};this.events.triggerEvent("success",a);this.layer.events.triggerEvent("transactionsucceeded",
+a)}},CLASS_NAME:"OpenLayers.Strategy.SaveWithLock"});
+OpenLayers.Control.AgsRouteTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!0,asynchronous:!1,stopsAdded:null,barriersAdded:null,stopOrBarrier:"stop",initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.stopsAdded=[];this.barriersAdded=[];this.drawControl.layer.events.register("sketchcomplete",this,function(a){this.hideStopsAndBarriers();if("stop"==this.stopOrBarrier)OpenLayers.Console.debug("...add 'stop'..."),this.addStops([a.feature]);
+else if("barrier"==this.stopOrBarrier)OpenLayers.Console.debug("...add 'barrier'..."),this.addBarriers([a.feature]);else throw OpenLayers.Console.error("...invalid 'stopOrBarrier' value...please set it to 'stop' or 'barrier'..."),"...invalid 'stopOrBarrier' value...please set it to 'stop' or 'barrier'...";this.showStopsAndBarriers();return!1});this.taskParameters={returnDirections:!0,returnRoutes:!0,returnStops:!0,returnBarriers:!0};this._resultsParser={parser:this.adapter.parseAgsResults.routeResults,
+context:this.adapter};this.execute=this._bindFunction(this.execute,this)},execute:function(a,b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);this._isDefined(this.layer.map)&&(b.outSpatialReference=this.layer.map.projection?this.layer.map.projection:b.outSpatialReference);if(a instanceof Array)b.stops=a;else if(!this._isDefined(b.stops))throw OpenLayers.Console.error("...can not execute route task...input geometry is not valid..."),"...can not execute route task...input geometry is not valid...";
+a=[];a=a.concat(this.taskCallbacks);a=a.concat(c);a=this._createCallbacks(this,a,{});if(!1==this.asynchronous){var c=new esri.tasks.RouteTask(this.url),a=this._createCallbacks(this,[this.onExecuteComplete],{callback:a}),d=this.errback||null;try{var e=this.adapter.encodeAgsRouteParameters(b)}catch(f){throw OpenLayers.Console.error(f.toString()),f;}c.solve(e,a,d)}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsRouteTask ..."),"...'asynchronous' should always be set to 'false' for AgsRouteTask ...";
+},addStops:function(a){for(var b=0;b<a.length;b++){var c=a[b];c instanceof OpenLayers.Feature.Vector&&c.geometry instanceof OpenLayers.Geometry.Point?(c.style={fillColor:"#FFFF00",fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10},this.stopsAdded.push(c)):OpenLayers.Console.debug("...skip adding 'stop' because it's not OpenLayers.Feature.Vector")}},hideStops:function(){this.stopsAdded&&0<this.stopsAdded.length&&this.layer.removeFeatures(this.stopsAdded)},
+cleanupStops:function(){this.hideStops();if(this.stopsAdded&&0<this.stopsAdded.length)for(var a=0;a<this.stopsAdded.length;a++)this.stopsAdded[a].destroy();this.stopsAdded.length=0},addBarriers:function(a){for(var b=0;b<a.length;b++){var c=a[b];c instanceof OpenLayers.Feature.Vector&&c.geometry instanceof OpenLayers.Geometry.Point?(c.style={fillColor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10},this.barriersAdded.push(c)):
+OpenLayers.Console.debug("...skip adding 'barrier' because it's not OpenLayers.Feature.Vector")}},cleanupBarriers:function(){this.hideBarriers();if(this.barriersAdded&&0<this.barriersAdded.length)for(var a=0;a<this.barriersAdded.length;a++)this.barriersAdded[a].destroy();this.barriersAdded.length=0},hideBarriers:function(){this.barriersAdded&&0<this.barriersAdded.length&&this.layer.removeFeatures(this.barriersAdded)},hideStopsAndBarriers:function(){this.hideStops();this.hideBarriers()},showStopsAndBarriers:function(){this.stopsAdded&&
+0<this.stopsAdded.length&&this.layer.addFeatures(this.stopsAdded);this.barriersAdded&&0<this.barriersAdded.length&&this.layer.addFeatures(this.barriersAdded)},CLASS_NAME:"OpenLayers.Control.AgsRouteTask"});
+OpenLayers.Layer.Google.v3={DEFAULTS:{maxExtent:new OpenLayers.Bounds(-2.003750834E7,-2.003750834E7,2.003750834E7,2.003750834E7),sphericalMercator:!0,maxResolution:156543.03390625,units:"m",projection:"EPSG:900913"},animationEnabled:!0,loadMapObject:function(){if(!this.type)this.type=google.maps.MapTypeId.ROADMAP;var a,b=OpenLayers.Layer.Google.cache[this.map.id];b?(a=b.mapObject,++b.count):(b=this.map.viewPortDiv,a=document.createElement("div"),a.id=this.map.id+"_GMapContainer",a.style.position=
+"absolute",a.style.width="100%",a.style.height="100%",b.appendChild(a),b=this.map.getCenter(),a=new google.maps.Map(a,{center:b?new google.maps.LatLng(b.lat,b.lon):new google.maps.LatLng(0,0),zoom:this.map.getZoom()||0,mapTypeId:this.type,disableDefaultUI:!0,keyboardShortcuts:!1,draggable:!1,disableDoubleClickZoom:!0,scrollwheel:!1,streetViewControl:!1}),b={mapObject:a,count:1},OpenLayers.Layer.Google.cache[this.map.id]=b,this.repositionListener=google.maps.event.addListenerOnce(a,"center_changed",
+OpenLayers.Function.bind(this.repositionMapElements,this)));this.mapObject=a;this.setGMapVisibility(this.visibility)},repositionMapElements:function(){google.maps.event.trigger(this.mapObject,"resize");var a=this.mapObject.getDiv().firstChild;if(!a||3>a.childNodes.length)return this.repositionTimer=window.setTimeout(OpenLayers.Function.bind(this.repositionMapElements,this),250),!1;for(var b=OpenLayers.Layer.Google.cache[this.map.id],c=this.map.viewPortDiv;"none"==a.lastChild.style.display;)c.appendChild(a.lastChild);
+var d=a.lastChild;c.appendChild(d);d.style.zIndex="1100";d.style.bottom="";d.className="olLayerGoogleCopyright olLayerGoogleV3";d.style.display="";b.termsOfUse=d;a=a.lastChild;c.appendChild(a);a.style.zIndex="1100";a.style.bottom="";a.className="olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";a.style.display="";b.poweredBy=a;this.setGMapVisibility(this.visibility)},onMapResize:function(){if(this.visibility)google.maps.event.trigger(this.mapObject,"resize");else{var a=OpenLayers.Layer.Google.cache[this.map.id];
+if(!a.resized){var b=this;google.maps.event.addListenerOnce(this.mapObject,"tilesloaded",function(){google.maps.event.trigger(b.mapObject,"resize");b.moveTo(b.map.getCenter(),b.map.getZoom());delete a.resized})}a.resized=!0}},setGMapVisibility:function(a){var b=OpenLayers.Layer.Google.cache[this.map.id];if(b){for(var c=this.type,d=this.map.layers,e,f=d.length-1;0<=f;--f)if(e=d[f],e instanceof OpenLayers.Layer.Google&&!0===e.visibility&&!0===e.inRange){c=e.type;a=!0;break}d=this.mapObject.getDiv();
+if(!0===a){this.mapObject.setMapTypeId(c);d.style.left="";if(b.termsOfUse&&b.termsOfUse.style)b.termsOfUse.style.left="",b.termsOfUse.style.display="",b.poweredBy.style.display="";b.displayed=this.id}else if(delete b.displayed,d.style.left="-9999px",b.termsOfUse&&b.termsOfUse.style)b.termsOfUse.style.display="none",b.termsOfUse.style.left="-9999px",b.poweredBy.style.display="none"}},getMapContainer:function(){return this.mapObject.getDiv()},getMapObjectBoundsFromOLBounds:function(a){var b=null;null!=
+a&&(b=this.sphericalMercator?this.inverseMercator(a.bottom,a.left):new OpenLayers.LonLat(a.bottom,a.left),a=this.sphericalMercator?this.inverseMercator(a.top,a.right):new OpenLayers.LonLat(a.top,a.right),b=new google.maps.LatLngBounds(new google.maps.LatLng(b.lat,b.lon),new google.maps.LatLng(a.lat,a.lon)));return b},getMapObjectLonLatFromMapObjectPixel:function(a){var b=this.map.getSize(),c=this.getLongitudeFromMapObjectLonLat(this.mapObject.center),d=this.getLatitudeFromMapObjectLonLat(this.mapObject.center),
+e=this.map.getResolution(),a=new OpenLayers.LonLat(c+(a.x-b.w/2)*e,d-(a.y-b.h/2)*e);this.wrapDateLine&&(a=a.wrapDateLine(this.maxExtent));return this.getMapObjectLonLatFromLonLat(a.lon,a.lat)},getMapObjectPixelFromMapObjectLonLat:function(a){var b=this.getLongitudeFromMapObjectLonLat(a),a=this.getLatitudeFromMapObjectLonLat(a),c=this.map.getResolution(),d=this.map.getExtent(),b=new OpenLayers.Pixel(1/c*(b-d.left),1/c*(d.top-a));return this.getMapObjectPixelFromXY(b.x,b.y)},setMapObjectCenter:function(a,
+b){if(!1===this.animationEnabled&&b!=this.mapObject.zoom){var c=this.getMapContainer();google.maps.event.addListenerOnce(this.mapObject,"idle",function(){c.style.visibility=""});c.style.visibility="hidden"}this.mapObject.setOptions({center:a,zoom:b})},getMapObjectZoomFromMapObjectBounds:function(a){return this.mapObject.getBoundsZoomLevel(a)},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new google.maps.LatLng(c.lat,c.lon)):c=new google.maps.LatLng(b,
+a);return c},getMapObjectPixelFromXY:function(a,b){return new google.maps.Point(a,b)},destroy:function(){this.repositionListener&&google.maps.event.removeListener(this.repositionListener);this.repositionTimer&&window.clearTimeout(this.repositionTimer);OpenLayers.Layer.Google.prototype.destroy.apply(this,arguments)}};
+OpenLayers.Format.WPSDescribeProcess=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{wps:"http://www.opengis.net/wps/1.0.0",ows:"http://www.opengis.net/ows/1.1",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",defaultPrefix:"wps",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,
+[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{wps:{ProcessDescriptions:function(a,b){b.processDescriptions={};this.readChildNodes(a,b.processDescriptions)},ProcessDescription:function(a,b){var c={processVersion:this.getAttributeNS(a,this.namespaces.wps,"processVersion"),statusSupported:"true"===a.getAttribute("statusSupported"),storeSupported:"true"===a.getAttribute("storeSupported")};this.readChildNodes(a,c);b[c.identifier]=c},DataInputs:function(a,
+b){b.dataInputs=[];this.readChildNodes(a,b.dataInputs)},ProcessOutputs:function(a,b){b.processOutputs=[];this.readChildNodes(a,b.processOutputs)},Output:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)},ComplexOutput:function(a,b){b.complexOutput={};this.readChildNodes(a,b.complexOutput)},Input:function(a,b){var c={maxOccurs:parseInt(a.getAttribute("maxOccurs")),minOccurs:parseInt(a.getAttribute("minOccurs"))};this.readChildNodes(a,c);b.push(c)},BoundingBoxData:function(a,b){b.boundingBoxData=
+{};this.readChildNodes(a,b.boundingBoxData)},CRS:function(a,b){if(!b.CRSs)b.CRSs={};b.CRSs[this.getChildValue(a)]=!0},LiteralData:function(a,b){b.literalData={};this.readChildNodes(a,b.literalData)},ComplexData:function(a,b){b.complexData={};this.readChildNodes(a,b.complexData)},Default:function(a,b){b["default"]={};this.readChildNodes(a,b["default"])},Supported:function(a,b){b.supported={};this.readChildNodes(a,b.supported)},Format:function(a,b){var c={};this.readChildNodes(a,c);if(!b.formats)b.formats=
+{};b.formats[c.mimeType]=!0},MimeType:function(a,b){b.mimeType=this.getChildValue(a)}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WPSDescribeProcess"});
+OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",geonet:"http://www.fao.org/geonetwork",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",
+requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);return b},
+readers:{csw:{GetRecordsResponse:function(a,b){b.records=[];this.readChildNodes(a,b);var c=this.getAttributeNS(a,"","version");if(""!=c)b.version=c},RequestId:function(a,b){b.RequestId=this.getChildValue(a)},SearchStatus:function(a,b){b.SearchStatus={};var c=this.getAttributeNS(a,"","timestamp");if(""!=c)b.SearchStatus.timestamp=c},SearchResults:function(a,b){this.readChildNodes(a,b);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]="numberOfRecordsMatched"==c[e].name||"numberOfRecordsReturned"==
+c[e].name||"nextRecord"==c[e].name?parseInt(c[e].nodeValue):c[e].nodeValue;b.SearchResults=d},SummaryRecord:function(a,b){var c={type:"SummaryRecord"};this.readChildNodes(a,c);b.records.push(c)},BriefRecord:function(a,b){var c={type:"BriefRecord"};this.readChildNodes(a,c);b.records.push(c)},DCMIRecord:function(a,b){var c={type:"DCMIRecord"};this.readChildNodes(a,c);b.records.push(c)},Record:function(a,b){var c={type:"Record"};this.readChildNodes(a,c);b.records.push(c)},"*":function(a,b){var c=a.localName||
+a.nodeName.split(":").pop();b[c]=this.getChildValue(a)}},geonet:{info:function(a,b){var c={};this.readChildNodes(a,c);b.gninfo=c}},dc:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();OpenLayers.Util.isArray(b[c])||(b[c]=[]);for(var d={},e=a.attributes,f=0,g=e.length;f<g;++f)d[e[f].name]=e[f].nodeValue;d.value=this.getChildValue(a);b[c].push(d)}},dct:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();OpenLayers.Util.isArray(b[c])||(b[c]=[]);b[c].push(this.getChildValue(a))}},
+ows:OpenLayers.Util.applyDefaults({BoundingBox:function(a,b){if(b.bounds)b.BoundingBox=[{crs:b.projection,value:[b.bounds.left,b.bounds.bottom,b.bounds.right,b.bounds.top]}],delete b.projection,delete b.bounds;OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows.BoundingBox.apply(this,arguments)}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows)},write:function(a){a=this.writeNode("csw:GetRecords",a);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{csw:{GetRecords:function(a){a||
+(a={});var b=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:a.requestId||this.requestId,resultType:a.resultType||this.resultType,outputFormat:a.outputFormat||this.outputFormat,outputSchema:a.outputSchema||this.outputSchema,startPosition:a.startPosition||this.startPosition,maxRecords:a.maxRecords||this.maxRecords}});if(a.DistributedSearch||this.DistributedSearch)this.writeNode("csw:DistributedSearch",a.DistributedSearch||this.DistributedSearch,b);
+var c=a.ResponseHandler||this.ResponseHandler;if(OpenLayers.Util.isArray(c)&&0<c.length)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ResponseHandler",c[d],b);this.writeNode("Query",a.Query||this.Query,b);return b},DistributedSearch:function(a){return this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:a.hopCount}})},ResponseHandler:function(a){return this.createElementNSPlus("csw:ResponseHandler",{value:a.value})},Query:function(a){a||(a={});var b=this.createElementNSPlus("csw:Query",
+{attributes:{typeNames:a.typeNames||"csw:Record"}}),c=a.ElementName;if(OpenLayers.Util.isArray(c)&&0<c.length)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ElementName",c[d],b);else this.writeNode("csw:ElementSetName",a.ElementSetName||{value:"summary"},b);a.Constraint&&this.writeNode("csw:Constraint",a.Constraint,b);a.SortBy&&this.writeNode("ogc:SortBy",a.SortBy,b);return b},ElementName:function(a){return this.createElementNSPlus("csw:ElementName",{value:a.value})},ElementSetName:function(a){return this.createElementNSPlus("csw:ElementSetName",
+{attributes:{typeNames:a.typeNames},value:a.value})},Constraint:function(a){var b=this.createElementNSPlus("csw:Constraint",{attributes:{version:a.version}});if(a.Filter){var c=new OpenLayers.Format.Filter({version:a.version});b.appendChild(c.write(a.Filter))}else a.CqlText&&(a=this.createElementNSPlus("CqlText",{value:a.CqlText.value}),b.appendChild(a));return b}},ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});
+OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(a,b,c){this.bounds=a;this.div=OpenLayers.Util.createDiv();this.div.style.overflow="hidden";this.events=new OpenLayers.Events(this,this.div);this.setBorder(b,c)},destroy:function(){this.div=this.bounds=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments)},setBorder:function(a,b){a||(a="red");b||(b=2);this.div.style.border=b+"px solid "+a},draw:function(a,b){OpenLayers.Util.modifyDOMElement(this.div,
+null,a,b);return this.div},onScreen:function(){var a=!1;this.map&&(a=this.map.getExtent().containsBounds(this.bounds,!0,!0));return a},display:function(a){this.div.style.display=a?"":"none"},CLASS_NAME:"OpenLayers.Marker.Box"});
+OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:!0,initialize:function(a){a=a||{};if(!1!==a.extractStyles)a.defaultStyle={externalGraphic:OpenLayers.Util.getImagesLocation()+"marker.png",graphicWidth:21,graphicHeight:25,graphicXOffset:-10.5,graphicYOffset:-12.5};OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){for(var a=a.split("\n"),b,c=[],d=0;d<a.length-1;d++){var e=a[d].replace(/^\s*/,"").replace(/\s*$/,"");if("#"!=e.charAt(0))if(b){for(var e=
+e.split("\t"),f=new OpenLayers.Geometry.Point(0,0),g={},h=this.defaultStyle?OpenLayers.Util.applyDefaults({},this.defaultStyle):null,i=!1,j=0;j<e.length;j++)if(e[j])if("point"==b[j])i=e[j].split(","),f.y=parseFloat(i[0]),f.x=parseFloat(i[1]),i=!0;else if("lat"==b[j])f.y=parseFloat(e[j]),i=!0;else if("lon"==b[j])f.x=parseFloat(e[j]),i=!0;else if("title"==b[j])g.title=e[j];else if("image"==b[j]||"icon"==b[j]&&h)h.externalGraphic=e[j];else if("iconSize"==b[j]&&h){var k=e[j].split(",");h.graphicWidth=
+parseFloat(k[0]);h.graphicHeight=parseFloat(k[1])}else"iconOffset"==b[j]&&h?(k=e[j].split(","),h.graphicXOffset=parseFloat(k[0]),h.graphicYOffset=parseFloat(k[1])):"description"==b[j]?g.description=e[j]:"overflow"==b[j]?g.overflow=e[j]:g[b[j]]=e[j];i&&(this.internalProjection&&this.externalProjection&&f.transform(this.externalProjection,this.internalProjection),e=new OpenLayers.Feature.Vector(f,g,h),c.push(e))}else b=e.split("\t")}return c},CLASS_NAME:"OpenLayers.Format.Text"});
+OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(a,b){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=[]},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null},loadText:function(){if(!this.loaded&&null!=this.location)this.events.triggerEvent("loadstart"),OpenLayers.Request.GET({url:this.location,
+success:this.parseData,failure:function(){this.events.triggerEvent("loadend")},scope:this}),this.loaded=!0},moveTo:function(a,b,c){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);this.visibility&&!this.loaded&&this.loadText()},parseData:function(a){var a=a.responseText,b={};OpenLayers.Util.extend(b,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject()))b.externalProjection=this.projection,b.internalProjection=this.map.getProjectionObject();for(var a=
+(new OpenLayers.Format.Text(b)).read(a),b=0,c=a.length;b<c;b++){var d={},e=a[b],f,g,h;f=new OpenLayers.LonLat(e.geometry.x,e.geometry.y);e.style.graphicWidth&&e.style.graphicHeight&&(g=new OpenLayers.Size(e.style.graphicWidth,e.style.graphicHeight));void 0!==e.style.graphicXOffset&&void 0!==e.style.graphicYOffset&&(h=new OpenLayers.Pixel(e.style.graphicXOffset,e.style.graphicYOffset));null!=e.style.externalGraphic?d.icon=new OpenLayers.Icon(e.style.externalGraphic,g,h):(d.icon=OpenLayers.Marker.defaultIcon(),
+null!=g&&d.icon.setSize(g));null!=e.attributes.title&&null!=e.attributes.description&&(d.popupContentHTML="<h2>"+e.attributes.title+"</h2><p>"+e.attributes.description+"</p>");d.overflow=e.attributes.overflow||"auto";d=new OpenLayers.Feature(this,f,d);this.features.push(d);f=d.createMarker();null!=e.attributes.title&&null!=e.attributes.description&&f.events.register("click",d,this.markerClick);this.addMarker(f)}this.events.triggerEvent("loadend")},markerClick:function(a){var b=this==this.layer.selectedFeature;
+this.layer.selectedFeature=!b?this:null;for(var c=0,d=this.layer.map.popups.length;c<d;c++)this.layer.map.removePopup(this.layer.map.popups[c]);b||this.layer.map.addPopup(this.createPopup());OpenLayers.Event.stop(a)},clearFeatures:function(){if(null!=this.features)for(;0<this.features.length;){var a=this.features[0];OpenLayers.Util.removeItem(this.features,a);a.destroy()}},CLASS_NAME:"OpenLayers.Layer.Text"});
+OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:"shiftKey",layerOptions:null,persist:!1,irregular:!1,citeCompliant:!1,angle:null,fixedRadius:!1,feature:null,layer:null,origin:null,initialize:function(a,b,c){if(!c||!c.layerOptions||!c.layerOptions.styleMap)this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style["default"],{});OpenLayers.Handler.Drag.prototype.initialize.apply(this,[a,b,c]);this.options=c?c:{}},setOptions:function(a){OpenLayers.Util.extend(this.options,
+a);OpenLayers.Util.extend(this,a)},activate:function(){var a=!1;if(OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments))a=OpenLayers.Util.extend({displayInLayerSwitcher:!1,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions),this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,a),this.map.addLayer(this.layer),a=!0;return a},deactivate:function(){var a=!1;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments))this.dragging&&this.cancel(),
+null!=this.layer.map&&(this.layer.destroy(!1),this.feature&&this.feature.destroy()),this.feature=this.layer=null,a=!0;return a},down:function(a){this.fixedRadius=!!this.radius;a=this.layer.getLonLatFromViewPortPx(a.xy);this.origin=new OpenLayers.Geometry.Point(a.lon,a.lat);if(!this.fixedRadius||this.irregular)this.radius=this.map.getResolution();this.persist&&this.clear();this.feature=new OpenLayers.Feature.Vector;this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],
+{silent:!0});this.layer.drawFeature(this.feature,this.style)},move:function(a){var b=this.layer.getLonLatFromViewPortPx(a.xy),b=new OpenLayers.Geometry.Point(b.lon,b.lat);this.irregular?(a=Math.sqrt(2)*Math.abs(b.y-this.origin.y)/2,this.radius=Math.max(this.map.getResolution()/2,a)):this.fixedRadius?this.origin=b:(this.calculateAngle(b,a),this.radius=Math.max(this.map.getResolution()/2,b.distanceTo(this.origin)));this.modifyGeometry();this.irregular&&(a=b.x-this.origin.x,b=b.y-this.origin.y,this.feature.geometry.resize(1,
+this.origin,0==b?a/(this.radius*Math.sqrt(2)):a/b),this.feature.geometry.move(a/2,b/2));this.layer.drawFeature(this.feature,this.style)},up:function(a){this.finalize();this.start==this.last&&this.callback("done",[a.xy])},out:function(){this.finalize()},createGeometry:function(){this.angle=Math.PI*(1/this.sides-0.5);this.snapAngle&&(this.angle+=this.snapAngle*(Math.PI/180));this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle)},modifyGeometry:function(){var a,
+b,c=this.feature.geometry.components[0];c.components.length!=this.sides+1&&(this.createGeometry(),c=this.feature.geometry.components[0]);for(var d=0;d<this.sides;++d)b=c.components[d],a=this.angle+2*d*Math.PI/this.sides,b.x=this.origin.x+this.radius*Math.cos(a),b.y=this.origin.y+this.radius*Math.sin(a),b.clearBounds()},calculateAngle:function(a,b){var c=Math.atan2(a.y-this.origin.y,a.x-this.origin.x);if(this.snapAngle&&this.snapToggle&&!b[this.snapToggle]){var d=Math.PI/180*this.snapAngle;this.angle=
+Math.round(c/d)*d}else this.angle=c},cancel:function(){this.callback("cancel",null);this.finalize()},finalize:function(){this.origin=null;this.radius=this.options.radius},clear:function(){this.layer&&(this.layer.renderer.clear(),this.layer.destroyFeatures())},callback:function(a){this.callbacks[a]&&this.callbacks[a].apply(this.control,[this.feature.geometry.clone()]);!this.persist&&("done"==a||"cancel"==a)&&this.clear()},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});
+OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{clearOnDeactivate:!1,layers:null,callbacks:null,selectionSymbolizer:{Polygon:{fillColor:"#FF0000",stroke:!1},Line:{strokeColor:"#FF0000",strokeWidth:2},Point:{graphicName:"square",fillColor:"#FF0000",pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},
+this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:!1,tileOptions:{maxGetUrlLength:2048}});if(this.sketchStyle)this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})});this.handler=new a(this,this.callbacks,this.handlerOptions)},destroy:function(){for(var a in this.layerCache)delete this.layerCache[a];
+for(a in this.wfsCache)delete this.wfsCache[a];OpenLayers.Control.prototype.destroy.apply(this,arguments)},coupleLayerVisiblity:function(a){this.setVisibility(a.object.getVisibility())},createSelectionLayer:function(a){var b;if(this.layerCache[a.id])b=this.layerCache[a.id];else{b=new OpenLayers.Layer.WMS(a.name,a.url,a.params,OpenLayers.Util.applyDefaults(this.layerOptions,a.getOptions()));this.layerCache[a.id]=b;if(!1===this.layerOptions.displayInLayerSwitcher)a.events.on({visibilitychanged:this.coupleLayerVisiblity,
+scope:b});this.map.addLayer(b)}return b},createSLD:function(a,b,c){for(var d={version:"1.0.0",namedLayers:{}},e=(""+a.params.LAYERS).split(","),f=0,g=e.length;f<g;f++){var h=e[f];d.namedLayers[h]={name:h,userStyles:[]};var i=this.selectionSymbolizer,j=c[f];0<=j.type.indexOf("Polygon")?i={Polygon:this.selectionSymbolizer.Polygon}:0<=j.type.indexOf("LineString")?i={Line:this.selectionSymbolizer.Line}:0<=j.type.indexOf("Point")&&(i={Point:this.selectionSymbolizer.Point});d.namedLayers[h].userStyles.push({name:"default",
+rules:[new OpenLayers.Rule({symbolizer:i,filter:b[f],maxScaleDenominator:a.options.minScale})]})}return(new OpenLayers.Format.SLD({srsName:this.map.getProjection()})).write(d)},parseDescribeLayer:function(a){var b=new OpenLayers.Format.WMSDescribeLayer,c=a.responseXML;if(!c||!c.documentElement)c=a.responseText;for(var a=b.read(c),b=[],c=null,d=0,e=a.length;d<e;d++)if("WFS"==a[d].owsType)b.push(a[d].typeName),c=a[d].owsURL;OpenLayers.Request.GET({url:c,params:{SERVICE:"WFS",TYPENAME:b.toString(),REQUEST:"DescribeFeatureType",
+VERSION:"1.0.0"},callback:function(a){var b=new OpenLayers.Format.WFSDescribeFeatureType,c=a.responseXML;if(!c||!c.documentElement)c=a.responseText;this.control.wfsCache[this.layer.id]=b.read(c);this.control._queue&&this.control.applySelection()},scope:this})},getGeometryAttributes:function(a){for(var b=[],a=this.wfsCache[a.id],c=0,d=a.featureTypes.length;c<d;c++)for(var e=a.featureTypes[c].properties,f=0,g=e.length;f<g;f++){var h=e[f],i=h.type;(0<=i.indexOf("LineString")||0<=i.indexOf("GeometryAssociationType")||
+0<=i.indexOf("GeometryPropertyType")||0<=i.indexOf("Point")||0<=i.indexOf("Polygon"))&&b.push(h)}return b},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a)for(var b=0,c=this.layers.length;b<c;b++){var d=this.layers[b];d&&!this.wfsCache[d.id]&&OpenLayers.Request.GET({url:d.url,params:{SERVICE:"WMS",VERSION:d.params.VERSION,LAYERS:d.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:d,control:this}})}return a},deactivate:function(){var a=
+OpenLayers.Control.prototype.deactivate.call(this);if(a)for(var b=0,c=this.layers.length;b<c;b++){var d=this.layers[b];if(d&&!0===this.clearOnDeactivate){var e=this.layerCache,f=e[d.id];f&&(d.events.un({visibilitychanged:this.coupleLayerVisiblity,scope:f}),f.destroy(),delete e[d.id])}}return a},setLayers:function(a){this.active?(this.deactivate(),this.layers=a,this.activate()):this.layers=a},createFilter:function(a,b){var c=null;this.handler instanceof OpenLayers.Handler.RegularPolygon?c=!0===this.handler.irregular?
+new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:a.name,value:b.getBounds()}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Polygon?c=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Path?c=0<=a.type.indexOf("Point")?new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,
+property:a.name,distance:0.01*this.map.getExtent().getWidth(),distanceUnits:this.map.getUnits(),value:b}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Click&&(c=0<=a.type.indexOf("Polygon")?new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:a.name,distance:0.01*this.map.getExtent().getWidth(),
+distanceUnits:this.map.getUnits(),value:b}));return c},select:function(a){this._queue=function(){for(var b=0,c=this.layers.length;b<c;b++){for(var d=this.layers[b],e=this.getGeometryAttributes(d),f=[],g=0,h=e.length;g<h;g++){var i=e[g];if(null!==i){if(!(a instanceof OpenLayers.Geometry)){var j=this.map.getLonLatFromPixel(a.xy);a=new OpenLayers.Geometry.Point(j.lon,j.lat)}i=this.createFilter(i,a);null!==i&&f.push(i)}}g=this.createSelectionLayer(d);e=this.createSLD(d,f,e);this.events.triggerEvent("selected",
+{layer:d,filters:f});g.mergeNewParams({SLD_BODY:e});delete this._queue}};this.applySelection()},applySelection:function(){for(var a=!0,b=0,c=this.layers.length;b<c;b++)if(!this.wfsCache[this.layers[b].id]){a=!1;break}a&&this._queue.call(this)},CLASS_NAME:"OpenLayers.Control.SLDSelect"});
+OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:!1,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.element=OpenLayers.Util.getElement(a)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element)this.element=document.createElement("div"),this.div.appendChild(this.element);this.map.events.register("moveend",this,this.updateScale);this.updateScale();return this.div},updateScale:function(){var a;
+if(!0===this.geodesic){if(!this.map.getUnits())return;a=OpenLayers.INCHES_PER_UNIT;a=(this.map.getGeodesicPixelSize().w||1.0E-6)*a.km*OpenLayers.DOTS_PER_INCH}else a=this.map.getScale();if(a)a=9500<=a&&95E4>=a?Math.round(a/1E3)+"K":95E4<=a?Math.round(a/1E6)+"M":Math.round(a),this.element.innerHTML=OpenLayers.i18n("Scale = 1 : ${scaleDenom}",{scaleDenom:a})},CLASS_NAME:"OpenLayers.Control.Scale"});
+OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,useHttpTile:!1,singleTile:!1,useOverlay:!1,useAsyncOverlay:!0,TILE_PARAMS:{operation:"GETTILEIMAGE",version:"1.2.0"},SINGLE_TILE_PARAMS:{operation:"GETMAPIMAGE",format:"PNG",locale:"en",clip:"1",version:"1.0.0"},OVERLAY_PARAMS:{operation:"GETDYNAMICMAPOVERLAYIMAGE",format:"PNG",locale:"en",clip:"1",version:"2.0.0"},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:"png",querystring:null},defaultSize:new OpenLayers.Size(300,
+300),tileOriginCorner:"tl",initialize:function(a,b,c,d){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(null==d||null==d.isBaseLayer)this.isBaseLayer="true"!=this.transparent&&!0!=this.transparent;if(d&&null!=d.useOverlay)this.useOverlay=d.useOverlay;if(this.singleTile)if(this.useOverlay){if(OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS),!this.useAsyncOverlay)this.params.version="1.0.0"}else OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);else this.useHttpTile?
+OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS):OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS),this.setTileSize(this.defaultSize)},clone:function(a){null==a&&(a=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var b;b=a.getCenterLonLat();var c=this.map.getSize();if(this.singleTile){a={setdisplaydpi:OpenLayers.DOTS_PER_INCH,setdisplayheight:c.h*this.ratio,setdisplaywidth:c.w*
+this.ratio,setviewcenterx:b.lon,setviewcentery:b.lat,setviewscale:this.map.getScale()};if(this.useOverlay&&!this.useAsyncOverlay)b={},b=OpenLayers.Util.extend(b,a),b.operation="GETVISIBLEMAPEXTENT",b.version="1.0.0",b.session=this.params.session,b.mapName=this.params.mapName,b.format="text/xml",b=this.getFullRequestString(b),OpenLayers.Request.GET({url:b,async:!1});b=this.getFullRequestString(a)}else c=this.map.getResolution(),b=Math.floor((a.left-this.maxExtent.left)/c),b=Math.round(b/this.tileSize.w),
+a=Math.floor((this.maxExtent.top-a.top)/c),a=Math.round(a/this.tileSize.h),b=this.useHttpTile?this.getImageFilePath({tilecol:b,tilerow:a,scaleindex:this.resolutions.length-this.map.zoom-1}):this.getFullRequestString({tilecol:b,tilerow:a,scaleindex:this.resolutions.length-this.map.zoom-1});return b},getFullRequestString:function(a,b){var c=null==b?this.url:b;"object"==typeof c&&(c=c[Math.floor(Math.random()*c.length)]);var d=c,e=OpenLayers.Util.extend({},this.params),e=OpenLayers.Util.extend(e,a),
+f=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),g;for(g in e)g.toUpperCase()in f&&delete e[g];e=OpenLayers.Util.getParameterString(e);e=e.replace(/,/g,"+");""!=e&&(f=c.charAt(c.length-1),d="&"==f||"?"==f?d+e:-1==c.indexOf("?")?d+("?"+e):d+("&"+e));return d},getImageFilePath:function(a,b){var c=null==b?this.url:b;"object"==typeof c&&(c=c[Math.floor(Math.random()*c.length)]);var d="",e="";0>a.tilerow&&(d="-");d=0==a.tilerow?d+"0":d+Math.floor(Math.abs(a.tilerow/this.params.tileRowsPerFolder))*
+this.params.tileRowsPerFolder;0>a.tilecol&&(e="-");e=0==a.tilecol?e+"0":e+Math.floor(Math.abs(a.tilecol/this.params.tileColumnsPerFolder))*this.params.tileColumnsPerFolder;d="/S"+Math.floor(a.scaleindex)+"/"+this.params.basemaplayergroupname+"/R"+d+"/C"+e+"/"+a.tilerow%this.params.tileRowsPerFolder+"_"+a.tilecol%this.params.tileColumnsPerFolder+"."+this.params.format;this.params.querystring&&(d+="?"+this.params.querystring);return c+d},calculateGridLayout:function(a,b,c){var d=c*this.tileSize.w,c=
+c*this.tileSize.h,e=a.left-b.lon,f=Math.floor(e/d)-this.buffer,a=b.lat-a.top+c,g=Math.floor(a/c)-this.buffer;return{tilelon:d,tilelat:c,tileoffsetlon:b.lon+f*d,tileoffsetlat:b.lat-c*g,tileoffsetx:-(e/d-f)*this.tileSize.w,tileoffsety:(g-a/c)*this.tileSize.h}},CLASS_NAME:"OpenLayers.Layer.MapGuide"});
+OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{handlerOptions:null,callbacks:null,displaySystem:"metric",geodesic:!1,displaySystemUnits:{geographic:["dd"],english:["mi","ft","in"],metric:["km","m"]},partialDelay:300,delayedTrigger:null,persist:!1,immediate:!1,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);var c={done:this.measureComplete,point:this.measurePartial};if(this.immediate)c.modify=this.measureImmediate;this.callbacks=OpenLayers.Util.extend(c,
+this.callbacks);this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new a(this,this.callbacks,this.handlerOptions)},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},cancel:function(){this.cancelDelay();this.handler.cancel()},setImmediate:function(a){(this.immediate=a)?this.callbacks.modify=this.measureImmediate:delete this.callbacks.modify},updateHandler:function(a,b){var c=this.active;c&&
+this.deactivate();this.handler=new a(this,this.callbacks,b);c&&this.activate()},measureComplete:function(a){this.cancelDelay();this.measure(a,"measure")},measurePartial:function(a,b){this.cancelDelay();b=b.clone();this.handler.freehandMode(this.handler.evt)?this.measure(b,"measurepartial"):this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(b,"measurepartial")},this),this.partialDelay)},measureImmediate:function(a,b,c){c&&null===this.delayedTrigger&&
+!this.handler.freehandMode(this.handler.evt)&&this.measure(b.geometry,"measurepartial")},cancelDelay:function(){if(null!==this.delayedTrigger)window.clearTimeout(this.delayedTrigger),this.delayedTrigger=null},measure:function(a,b){var c,d;-1<a.CLASS_NAME.indexOf("LineString")?(c=this.getBestLength(a),d=1):(c=this.getBestArea(a),d=2);this.events.triggerEvent(b,{measure:c[0],units:c[1],order:d,geometry:a})},getBestArea:function(a){for(var b=this.displaySystemUnits[this.displaySystem],c,d,e=0,f=b.length;e<
+f&&!(c=b[e],d=this.getArea(a,c),1<d);++e);return[d,c]},getArea:function(a,b){var c,d;this.geodesic?(c=a.getGeodesicArea(this.map.getProjectionObject()),d="m"):(c=a.getArea(),d=this.map.getUnits());var e=OpenLayers.INCHES_PER_UNIT[b];e&&(c*=Math.pow(OpenLayers.INCHES_PER_UNIT[d]/e,2));return c},getBestLength:function(a){for(var b=this.displaySystemUnits[this.displaySystem],c,d,e=0,f=b.length;e<f&&!(c=b[e],d=this.getLength(a,c),1<d);++e);return[d,c]},getLength:function(a,b){var c,d;this.geodesic?(c=
+a.getGeodesicLength(this.map.getProjectionObject()),d="m"):(c=a.getLength(),d=this.map.getUnits());var e=OpenLayers.INCHES_PER_UNIT[b];e&&(c*=OpenLayers.INCHES_PER_UNIT[d]/e);return c},CLASS_NAME:"OpenLayers.Control.Measure"});
+OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(a){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[a])},read_wmc_SRS:function(a,b){var c=this.getChildValue(b);if("object"!=typeof a.projections)a.projections={};for(var c=c.split(/ +/),d=0,e=c.length;d<e;d++)a.projections[c[d]]=!0},write_wmc_Layer:function(a){var b=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,
+[a]);if(a.srs){var c=[],d;for(d in a.srs)c.push(d);b.appendChild(this.createElementDefaultNS("SRS",c.join(" ")))}b.appendChild(this.write_wmc_FormatList(a));b.appendChild(this.write_wmc_StyleList(a));a.dimensions&&b.appendChild(this.write_wmc_DimensionList(a));b.appendChild(this.write_wmc_LayerExtension(a))},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});
+OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.options=a;a=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(a,this.yx)},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);b.version=this.version;return b},readers:{wmts:{Capabilities:function(a,b){this.readChildNodes(a,b)},Contents:function(a,b){b.contents={};b.contents.layers=[];b.contents.tileMatrixSets={};this.readChildNodes(a,b.contents)},Layer:function(a,b){var c={styles:[],formats:[],dimensions:[],tileMatrixSetLinks:[],layers:[],boundingBox:[]};this.readChildNodes(a,c);b.layers.push(c)},
+Style:function(a,b){var c={};c.isDefault="true"===a.getAttribute("isDefault");this.readChildNodes(a,c);b.styles.push(c)},Format:function(a,b){b.formats.push(this.getChildValue(a))},TileMatrixSetLink:function(a,b){var c={};this.readChildNodes(a,c);b.tileMatrixSetLinks.push(c)},TileMatrixSet:function(a,b){if(b.layers){var c={matrixIds:[]};this.readChildNodes(a,c);b.tileMatrixSets[c.identifier]=c}else b.tileMatrixSet=this.getChildValue(a)},TileMatrix:function(a,b){var c={supportedCRS:b.supportedCRS};
+this.readChildNodes(a,c);b.matrixIds.push(c)},ScaleDenominator:function(a,b){b.scaleDenominator=parseFloat(this.getChildValue(a))},TopLeftCorner:function(a,b){var c=this.getChildValue(a).split(" "),d;b.supportedCRS&&(d=!!this.yx[b.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2")]);b.topLeftCorner=d?new OpenLayers.LonLat(c[1],c[0]):new OpenLayers.LonLat(c[0],c[1])},TileWidth:function(a,b){b.tileWidth=parseInt(this.getChildValue(a))},TileHeight:function(a,b){b.tileHeight=
+parseInt(this.getChildValue(a))},MatrixWidth:function(a,b){b.matrixWidth=parseInt(this.getChildValue(a))},MatrixHeight:function(a,b){b.matrixHeight=parseInt(this.getChildValue(a))},ResourceURL:function(a,b){b.resourceUrl=b.resourceUrl||{};b.resourceUrl[a.getAttribute("resourceType")]={format:a.getAttribute("format"),template:a.getAttribute("template")}},WSDL:function(a,b){b.wsdl={};b.wsdl.href=a.getAttribute("xlink:href")},ServiceMetadataURL:function(a,b){b.serviceMetadataUrl={};b.serviceMetadataUrl.href=
+a.getAttribute("xlink:href")},LegendURL:function(a,b){b.legend={};b.legend.href=a.getAttribute("xlink:href");b.legend.format=a.getAttribute("format")},Dimension:function(a,b){var c={values:[]};this.readChildNodes(a,c);b.dimensions.push(c)},Default:function(a,b){b["default"]=this.getChildValue(a)},Value:function(a,b){b.values.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities.v1_0_0"});OpenLayers.Raster={};
+OpenLayers.Raster.Grid=OpenLayers.Class({EVENT_TYPES:["update"],initialize:function(a){OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES)},getValue:function(){throw Error("getValue must be defined");},numCols:function(){throw Error("numCols must be defined");},numRows:function(){throw Error("numRows must be defined");},forEach:function(a){for(var b=this.numCols(),c=this.numRows(),d=0;d<c;++d)for(var e=0;e<b;++e)a(this.getValue(e,d),e+d*b)},CLASS_NAME:"OpenLayers.Raster.Grid"});
+OpenLayers.Raster.Grid.fromArray=function(a){var b=a.length,c=a[0]&&a[0].length||0;return new OpenLayers.Raster.Grid({numCols:function(){return c},numRows:function(){return b},getValue:function(b,c){return a[c][b]}})};
+OpenLayers.Raster.Composite=OpenLayers.Class(OpenLayers.Raster.Grid,function(){var a;return{initialize:function(b){if(b.grids)a=b.grids,delete b.grids;OpenLayers.Raster.Grid.prototype.initialize.apply(this,[b]);if(a)for(var b=0,c=a.length;b<c;++b)a[b].events.register("update",this,function(){this.events.triggerEvent("update")})},numCols:function(){return a&&a[0]&&a[0].numCols()},numRows:function(){return a&&a[0]&&a[0].numRows()},getCount:function(){return a&&a.length},getValue:function(b,c){for(var d=
+a.length,e=Array(d),f=0;f<d;++f)e[f]=a[f].getValue(b,c);return e},getGrid:function(a){if("number"!==typeof a||isNaN(a)||0>a||a>=this.getCount())throw Error("Bad grid index.");var c=this;return new OpenLayers.Raster.Grid({numCols:function(){return c.numCols()},numRows:function(){return c.numRows()},getValue:function(d,e){return c.getValue(d,e)[a]}})},CLASS_NAME:"OpenLayers.Raster.Composite"}}());
+OpenLayers.Raster.Composite.fromLayer=function(a){var b;function c(){b=void 0;var c=a.map,h=a.tileSize,i=c.getSize();d.width=i.w;d.height=i.h;for(var i=c.getExtent(),j=a.grid,k,m,n,l=0,o=j.length;l<o;++l){k=j[l];for(var q=0,r=k.length;q<r;++q)if(m=k[q],n=m.bounds,(m=m.imgDiv)&&"none"!==m.style.display&&i.intersectsBounds(n))n=new OpenLayers.LonLat(n.left,n.top),n=c.getPixelFromLonLat(n),e.drawImage(m,n.x,n.y,h.w,h.h)}f.events.triggerEvent("update")}if(!(a instanceof OpenLayers.Layer.Grid))throw Error("Only OpenLayers.Layer.Grid type layers can be used to create a raster");
+var d=document.createElement("canvas"),e=d.getContext("2d"),f=new OpenLayers.Raster.Composite({numCols:function(){return d.width},numRows:function(){return d.height},getCount:function(){return 4},getValue:function(a,c){if(!b)b=e.getImageData(0,0,d.width,d.height).data;var f=4*(a+c*d.width);return Array.prototype.slice.apply(b,[f,f+4])}});b=void 0;a.map?a.map.events.register("moveend",null,c):a.events.register("added",null,function(){a.map.events.register("moveend",null,c)});a.events.register("tileloaded",
+null,c);return f};
+OpenLayers.Raster.Operation=function(){var a=OpenLayers.Raster.Grid,b=OpenLayers.Raster.Composite,c={};return{create:function(c){return function(){function e(){for(var b,c=0;c<g;++c)if(f[c]instanceof a){b=f[c];break}if(!b)throw Error("Operation must be called with at least one grid.");return b}for(var f=Array.prototype.slice.call(arguments),g=f.length,h=1,i=0;i<g;++i)f[i]instanceof b&&(h=Math.max(h,f[i].getCount()));for(var j=new (1<h?b:a)({numCols:function(){return e().numCols()},numRows:function(){return e().numRows()},
+getValue:function(b,e){for(var h=Array(g),i,j=0;j<g;++j)i=f[j],h[j]=i instanceof a?i.getValue(b,e):i;return c.apply(null,h)},getCount:function(){return h}}),i=0;i<g;++i)f[i]instanceof a&&f[i].events.register("update",null,function(){j.events.triggerEvent("update")});return j}},get:function(a){return c[a]}}}();
+OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:!0,panMapIfOutOfView:!0,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:!1,fixedRelativePosition:!1,positionBlocks:{tl:{offset:new OpenLayers.Pixel(44,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,
+50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},tr:{offset:new OpenLayers.Pixel(-45,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto",
+"auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,
+0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},bl:{offset:new OpenLayers.Pixel(45,0),padding:new OpenLayers.Bounds(8,9,8,40),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,
+21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},br:{offset:new OpenLayers.Pixel(-44,0),padding:new OpenLayers.Bounds(8,9,8,40),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,
+0)},{size:new OpenLayers.Size("auto",21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(a,b,c,d,e,f,g){this.imageSrc=OpenLayers.Util.getImagesLocation()+
+"cloud-popup-relative.png";OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});
+OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!0,asynchronous:!1,asynJobCompleteCallback:null,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;a=this._bindFunction(function(a){this.cleanupResults();this.addResults(a.results);this.showResults()},this);b=[];b=b.concat(this.taskCallbacks);b=b.concat([a]);
+this.asynJobCompleteCallback=this._createCallbacks(this,b,{});this.events.on({asynjobcomplete:this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this)},destroy:function(){this.events.un({asynjobcomplete:this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[])},execute:function(a,b,c){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.taskParameters);var d=[],d=d.concat(this.taskCallbacks),d=d.concat(c),
+c=this._createCallbacks(this,d,{});this._resultsParser={parser:this.geoprocessingResultsParser,context:this};d=this.adapter.encodeAgsFeatureSet(a,this.layer.map.projection,{});a=new esri.tasks.Geoprocessor(this.url);b=this.geoprocessingParamsEnocoder(d,b);!1==this.asynchronous?(c=this._createCallbacks(this,[this.onExecuteComplete],{callback:c}),a.execute(b,c)):(c=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:a}),a.submitJob(b,c,null))},geoprocessingParamsEnocoder:function(a,
+b){return b},geoprocessingResultsParser:function(){return{}},CLASS_NAME:"OpenLayers.Control.AgsGeoprocessor"});
+OpenLayers.Control.ModifyFeatureWithLock=OpenLayers.Class(OpenLayers.Control.ModifyFeature,{deleteFeatureCodes:null,initialize:function(a,b){OpenLayers.Control.ModifyFeature.prototype.initialize.apply(this,[a,b]);if(b)this.deleteFeatureCodes=b.deleteFeatureCodes?b.deleteFeatureCodes:[81];this.layer.events.on({transactionsucceeded:function(){this.deactivate();this.activate()},transactionfailed:function(){this.deactivate();this.activate()},scope:this})},selectFeature:function(a){this.feature=a;a.lockId&&
+""!=a.lockId?this.mode==OpenLayers.Control.ModifyFeature.DELETE?OpenLayers.Console.log("...feature is locked...control in DELETE mode...it can only be deleted..."):(this.resetVertices(),this.dragControl.activate(),this.onModificationStart(this.feature),OpenLayers.Console.log("...feature is locked...so it can be modified...")):OpenLayers.Console.log("...feature is not locked...so it can not be modified/deleted...")},dragStart:function(a,b){if(a!=this.feature&&!a.geometry.parent&&a!=this.dragHandle&&
+a!=this.radiusHandle&&(!1===this.standalone&&this.feature&&this.selectControl.clickFeature.apply(this.selectControl,[this.feature]),null==this.geometryTypes||-1!=OpenLayers.Util.indexOf(this.geometryTypes,a.geometry.CLASS_NAME)))a.lockId&&""!=a.lockId?(this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[a]),OpenLayers.Console.log("...feature is locked...drag start..."),this.dragControl.overFeature.apply(this.dragControl,[a]),this.dragControl.lastPixel=b,this.dragControl.handlers.drag.started=
+!0,this.dragControl.handlers.drag.start=b,this.dragControl.handlers.drag.last=b):OpenLayers.Console.log("...feature is not locked...drag not start...")},handleKeypress:function(a){a=a.keyCode;if(this.mode==OpenLayers.Control.ModifyFeatureWithLock.DELETE){if(this.feature&&-1!=OpenLayers.Util.indexOf(this.deleteFeatureCodes,a))this.feature.lockId&&""!=this.feature.lockId?(this.feature.state=OpenLayers.State.DELETE,this.layer.eraseFeatures([this.feature]),-1!=OpenLayers.Util.indexOf(this.layer.selectedFeatures,
+this.feature)&&OpenLayers.Util.removeItem(this.layer.selectedFeatures,this.feature),console.log("...delete feature at client side..."),this.layer.events.triggerEvent("featuremodified",{feature:this.feature})):console.log("...can not delete feature...feature must be locked first...")}else if(this.feature&&-1!=OpenLayers.Util.indexOf(this.deleteCodes,a)&&(a=this.dragControl.feature)&&-1!=OpenLayers.Util.indexOf(this.vertices,a)&&!this.dragControl.handlers.drag.dragging&&a.geometry.parent)a.geometry.parent.removeComponent(a.geometry),
+this.layer.drawFeature(this.feature,this.standalone?void 0:this.selectControl.renderIntent),this.resetVertices(),this.setFeatureState(),this.onModification(this.feature),this.layer.events.triggerEvent("featuremodified",{feature:this.feature})},CLASS_NAME:"OpenLayers.Control.ModifyFeatureWithLock"});OpenLayers.Control.ModifyFeatureWithLock.RESHAPE=1;OpenLayers.Control.ModifyFeatureWithLock.RESIZE=2;OpenLayers.Control.ModifyFeatureWithLock.ROTATE=4;OpenLayers.Control.ModifyFeatureWithLock.DRAG=8;
+OpenLayers.Control.ModifyFeatureWithLock.DELETE=16;
+OpenLayers.Tile.Image.IFrame={useIFrame:null,draw:function(){if(OpenLayers.Tile.Image.prototype.shouldDraw.call(this)){var a=this.layer.getURL(this.bounds),b=this.useIFrame;this.useIFrame=null!==this.maxGetUrlLength&&!this.layer.async&&a.length>this.maxGetUrlLength;a=b&&!this.useIFrame;b=!b&&this.useIFrame;if(a||b)this.imgDiv&&this.imgDiv.parentNode===this.frame&&this.frame.removeChild(this.imgDiv),this.imgDiv=null,a&&this.frame.removeChild(this.frame.firstChild)}return OpenLayers.Tile.Image.prototype.draw.apply(this,arguments)},
+createImage:function(){if(!0===this.useIFrame){if(!this.frame.childNodes.length){var a=document.createElement("div"),b=a.style;b.position="absolute";b.width="100%";b.height="100%";b.zIndex=1;b.backgroundImage="url("+this.blankImageUrl+")";this.frame.appendChild(a)}a=this.id+"_iFrame";9>parseFloat(navigator.appVersion.split("MSIE")[1])?(b=document.createElement('<iframe name="'+a+'">'),b.style.backgroundColor="#FFFFFF",b.style.filter="chroma(color=#FFFFFF)"):(b=document.createElement("iframe"),b.style.backgroundColor=
+"transparent",b.name=a);b.scrolling="no";b.marginWidth="0px";b.marginHeight="0px";b.frameBorder="0";b.style.position="absolute";b.style.width="100%";b.style.height="100%";1>this.layer.opacity&&OpenLayers.Util.modifyDOMElement(b,null,null,null,null,null,null,this.layer.opacity);this.frame.appendChild(b);return this.imgDiv=b}return OpenLayers.Tile.Image.prototype.createImage.apply(this,arguments)},createRequestForm:function(){var a=document.createElement("form");a.method="POST";var b=this.layer.params._OLSALT,
+b=(b?b+"_":"")+this.bounds.toBBOX();a.action=OpenLayers.Util.urlAppend(this.layer.url,b);a.target=this.id+"_iFrame";this.layer.getImageSize();var b=OpenLayers.Util.getParameters(this.url),c,d;for(d in b)c=document.createElement("input"),c.type="hidden",c.name=d,c.value=b[d],a.appendChild(c);return a},setImgSrc:function(a){if(!0===this.useIFrame)if(a){var b=this.createRequestForm();this.frame.appendChild(this.imgDiv);this.frame.appendChild(b);b.submit();this.frame.removeChild(b)}else{if(this.imgDiv.parentNode===
+this.frame)this.frame.removeChild(this.imgDiv),this.imgDiv=null}else OpenLayers.Tile.Image.prototype.setImgSrc.apply(this,arguments)},createBackBuffer:function(){var a;this.useIFrame||(a=OpenLayers.Tile.Image.prototype.createBackBuffer.call(this));return a}};
+OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(a,b,c,d){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=a;this.y=b;this.width=c;this.height=d},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height)},getLength:function(){return 2*this.width+2*this.height},getArea:function(){return this.width*this.height},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});
+OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:!1,interval:0,timer:null,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);a&&(!0===this.layer.visibility&&this.start(),this.layer.events.on({visibilitychanged:this.reset,scope:this}));return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.stop();return a},reset:function(){!0===this.layer.visibility?this.start():this.stop()},start:function(){if(this.interval&&
+"number"===typeof this.interval&&0<this.interval)this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval)},refresh:function(){this.layer&&this.layer.refresh&&"function"==typeof this.layer.refresh&&this.layer.refresh({force:this.force})},stop:function(){if(null!==this.timer)window.clearInterval(this.timer),this.timer=null},CLASS_NAME:"OpenLayers.Strategy.Refresh"});
+OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.options=a},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,
+[a]));if(a&&9==a.nodeType)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{gml:OpenLayers.Util.applyDefaults({name:function(a,b){b.name=this.getChildValue(a)},TimePeriod:function(a,b){b.timePeriod={};this.readChildNodes(a,b.timePeriod)},beginPosition:function(a,b){b.beginPosition=this.getChildValue(a)},endPosition:function(a,b){b.endPosition=this.getChildValue(a)}},OpenLayers.Format.GML.v3.prototype.readers.gml),sos:{Capabilities:function(a,b){this.readChildNodes(a,b)},Contents:function(a,
+b){b.contents={};this.readChildNodes(a,b.contents)},ObservationOfferingList:function(a,b){b.offeringList={};this.readChildNodes(a,b.offeringList)},ObservationOffering:function(a,b){var c=this.getAttributeNS(a,this.namespaces.gml,"id");b[c]={procedures:[],observedProperties:[],featureOfInterestIds:[],responseFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(a,b[c])},time:function(a,b){b.time={};this.readChildNodes(a,b.time)},procedure:function(a,b){b.procedures.push(this.getAttributeNS(a,
+this.namespaces.xlink,"href"))},observedProperty:function(a,b){b.observedProperties.push(this.getAttributeNS(a,this.namespaces.xlink,"href"))},featureOfInterest:function(a,b){b.featureOfInterestIds.push(this.getAttributeNS(a,this.namespaces.xlink,"href"))},responseFormat:function(a,b){b.responseFormats.push(this.getChildValue(a))},resultModel:function(a,b){b.resultModels.push(this.getChildValue(a))},responseMode:function(a,b){b.responseModes.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},
+CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});
+OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!1,pinching:!1,last:null,start:null,touchstart:function(a){var b=!0;this.pinching=!1;OpenLayers.Event.isMultiTouch(a)?(this.started=!0,this.last=this.start={distance:this.getDistance(a.touches),delta:0,scale:1},this.callback("start",[a,this.start]),b=!this.stopDown):(this.started=!1,this.last=this.start=null);OpenLayers.Event.stop(a);return b},touchmove:function(a){if(this.started&&OpenLayers.Event.isMultiTouch(a)){this.pinching=
+!0;var b=this.getPinchData(a);this.callback("move",[a,b]);this.last=b;OpenLayers.Event.stop(a)}return!0},touchend:function(a){if(this.started)this.pinching=this.started=!1,this.callback("done",[a,this.start,this.last]),this.last=this.start=null;return!0},activate:function(){var a=!1;if(OpenLayers.Handler.prototype.activate.apply(this,arguments))this.pinching=!1,a=!0;return a},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.pinching=this.started=
+!1,this.last=this.start=null,a=!0;return a},getDistance:function(a){var b=a[0],a=a[1];return Math.sqrt(Math.pow(b.clientX-a.clientX,2)+Math.pow(b.clientY-a.clientY,2))},getPinchData:function(a){a=this.getDistance(a.touches);return{distance:a,delta:this.last.distance-a,scale:a/this.start.distance}},CLASS_NAME:"OpenLayers.Handler.Pinch"});
+OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);this.addControls([new OpenLayers.Control.Navigation,new OpenLayers.Control.ZoomBox])},draw:function(){var a=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(null===this.defaultControl)this.defaultControl=this.controls[0];return a},CLASS_NAME:"OpenLayers.Control.NavToolbar"});
+OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,serverResolutions:null,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png",png:"png","image/jpeg":"jpg","image/jpg":"jpg",jpeg:"jpg",jpg:"jpg"},matrix:null,initialize:function(a){var b=
+{url:!0,layer:!0,style:!0,matrixSet:!0},c;for(c in b)if(!(c in a))throw Error("Missing property '"+c+"' in layer configuration.");a.params=OpenLayers.Util.upperCaseObject(a.params);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a.name,a.url,a.params,a]);if(!this.formatSuffix)this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();if(this.matrixIds&&(a=this.matrixIds.length)&&"string"===typeof this.matrixIds[0]){b=this.matrixIds;this.matrixIds=Array(a);for(c=0;c<a;++c)this.matrixIds[c]=
+{identifier:b[c]}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties()},updateMatrixProperties:function(){if(this.matrix=this.getMatrix()){if(this.matrix.topLeftCorner)this.tileOrigin=this.matrix.topLeftCorner;if(this.matrix.tileWidth&&this.matrix.tileHeight)this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);if(!this.tileOrigin)this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);if(!this.tileFullExtent)this.tileFullExtent=
+this.maxExtent}},moveTo:function(a,b,c){(b||!this.matrix)&&this.updateMatrixProperties();return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.WMTS(this.options));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getIdentifier:function(){return null!=this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,this.getServerResolution()):this.getServerZoom()+this.zoomOffset},getMatrix:function(){var a;if(!this.matrixIds||
+0===this.matrixIds.length)a={identifier:this.getIdentifier()};else if("scaleDenominator"in this.matrixIds[0])for(var b=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.getServerResolution()/2.8E-4,c=Number.POSITIVE_INFINITY,d,e=0,f=this.matrixIds.length;e<f;++e)d=Math.abs(1-this.matrixIds[e].scaleDenominator/b),d<c&&(c=d,a=this.matrixIds[e]);else a=this.matrixIds[this.getIdentifier()];return a},getTileInfo:function(a){var b=this.getServerResolution(),c=(a.lon-this.tileOrigin.lon)/
+(b*this.tileSize.w),a=(this.tileOrigin.lat-a.lat)/(b*this.tileSize.h),b=Math.floor(c),d=Math.floor(a);return{col:b,row:d,i:Math.floor((c-b)*this.tileSize.w),j:Math.floor((a-d)*this.tileSize.h)}},getURL:function(a){var a=this.adjustBounds(a),b="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(a))if(a=this.getTileInfo(a.getCenterLonLat()),"REST"===this.requestEncoding.toUpperCase()){var c=this.version+"/"+this.layer+"/"+this.style+"/";if(this.dimensions)for(b=0;b<this.dimensions.length;b++)this.params[this.dimensions[b]]&&
+(c=c+this.params[this.dimensions[b]]+"/");c=c+this.matrixSet+"/"+this.matrix.identifier+"/"+a.row+"/"+a.col+"."+this.formatSuffix;b=OpenLayers.Util.isArray(this.url)?this.selectUrl(c,this.url):this.url;b.match(/\/$/)||(b+="/");b+=c}else"KVP"===this.requestEncoding.toUpperCase()&&(b=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[{SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:a.row,
+TILECOL:a.col,FORMAT:this.format}]));return b},mergeNewParams:function(a){if("KVP"===this.requestEncoding.toUpperCase())return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(a)])},CLASS_NAME:"OpenLayers.Layer.WMTS"});
+OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,autoActivate:!0,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions)},activate:function(){var a=OpenLayers.Control.prototype.activate.apply(this,arguments);a&&(this.map.events.on({moveend:this.updateContainerOrigin,
+scope:this}),this.updateContainerOrigin());return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.apply(this,arguments);this.map&&this.map.events&&this.map.events.un({moveend:this.updateContainerOrigin,scope:this});return a},updateContainerOrigin:function(){var a=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(a.style.left,10),y:parseInt(a.style.top,10)}},pinchStart:function(a){this.currentCenter=this.pinchOrigin=a.xy},pinchMove:function(a,b){var c=b.scale,d=this.containerOrigin,
+e=this.pinchOrigin,f=a.xy,g=Math.round(f.x-e.x+(c-1)*(d.x-e.x)),d=Math.round(f.y-e.y+(c-1)*(d.y-e.y));this.applyTransform("translate("+g+"px, "+d+"px) scale("+c+")");this.currentCenter=f},applyTransform:function(a){var b=this.map.layerContainerDiv.style;b["-webkit-transform"]=a;b["-moz-transform"]=a},pinchDone:function(a,b,c){this.applyTransform("");a=this.map.getZoomForResolution(this.map.getResolution()/c.scale,!0);if(a!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var b=this.map.getResolutionForZoom(a),
+c=this.map.getLonLatFromPixel(this.pinchOrigin),d=this.currentCenter,e=this.map.getSize();c.lon+=b*(e.w/2-d.x);c.lat-=b*(e.h/2-d.y);this.map.setCenter(c,a)}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});
+OpenLayers.Control.AgsWFSTLockControl=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,layer:null,lockStrategy:null,lock:null,lockOptions:null,unlock:null,unlockOptions:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);if(a instanceof OpenLayers.Layer.Vector)for(var c=0;c<a.strategies.length;c++){if(a.strategies[c]instanceof OpenLayers.Strategy.Lock)this.layer=a,this.lockStrategy=a.strategies[c]}else OpenLayers.Console.error("...lock control error...");
+if(this.layer&&this.lockStrategy){c={trigger:OpenLayers.Function.bind(this.lockTrigger,this)};OpenLayers.Util.extend(c,this.lockOptions);this.lock=new OpenLayers.Control.Button(c);c={trigger:OpenLayers.Function.bind(this.unlockTrigger,this)};OpenLayers.Util.extend(c,this.unlockOptions);this.unlock=new OpenLayers.Control.Button(c);var c=OpenLayers.Util.AgsUtil.bindFunction(function(a){this.lockStrategy.isFeatureLocked(a.feature)?(this.lock.deactivate(),this.unlock.activate()):(this.lock.activate(),
+this.unlock.deactivate())},this),d=OpenLayers.Util.AgsUtil.bindFunction(function(){this.lock.deactivate();this.unlock.deactivate()},this);this.layer.events.on({featureselected:c,featureunselected:d,afterfeatureslocked:d,afterfeaturesunlocked:d})}else OpenLayers.Console.error("...lock control error...")},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.lock.destroy();this.unlock.destroy();this.deactivate()},setMap:function(a){this.map=a},draw:function(){OpenLayers.Control.prototype.draw.apply(this,
+arguments);this.lock.draw();this.unlock.draw()},activate:function(){return OpenLayers.Control.prototype.activate.apply(this)},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this)},lockTrigger:function(){0<this.layer.selectedFeatures.length&&this.lockStrategy.lockFeatures(this.layer.selectedFeatures)},unlockTrigger:function(){this.lockStrategy.unlockAllFeatures()},CLASS_NAME:"OpenLayers.Control.AgsWFSTLockControl"});
+OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(a,b,c,d,e){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=d;this.features=[]},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.url=this.features=null;if(this.request)this.request.abort(),this.request=null},clear:function(){this.destroyAllFeatures()},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments))this.isLoading?
+this.events.triggerEvent("reload"):(this.isLoading=!0,this.events.triggerEvent("loadstart")),this.loadFeaturesForRegion(this.requestSuccess)},loadFeaturesForRegion:function(a,b){this.request&&this.request.abort();this.request=OpenLayers.Request.GET({url:this.url,success:a,failure:b,scope:this})},requestSuccess:function(a){if(this.features){var b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;this.layer.vectorMode?this.layer.addFeatures(this.layer.formatObject.read(b)):(a=new OpenLayers.Format.XML,
+"string"==typeof b&&(b=a.read(b)),this.addResults(a.getElementsByTagNameNS(b,"http://www.opengis.net/gml","featureMember")))}this.events&&this.events.triggerEvent("loadend");this.request=null},addResults:function(a){for(var b=0;b<a.length;b++)this.features.push(new this.layer.featureClass(this.layer,a[b]))},destroyAllFeatures:function(){for(;0<this.features.length;)this.features.shift().destroy()},CLASS_NAME:"OpenLayers.Tile.WFS"});
+OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{geolocation:navigator.geolocation,bind:!0,watch:!1,geolocationOptions:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){if(!this.geolocation)return this.events.triggerEvent("locationuncapable"),!1;return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.watch?this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),
+OpenLayers.Function.bind(this.failure,this),this.geolocationOptions):this.getCurrentLocation(),!0):!1},deactivate:function(){this.active&&null!==this.watchId&&this.geolocation.clearWatch(this.watchId);return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},geolocate:function(a){var b=(new OpenLayers.LonLat(a.coords.longitude,a.coords.latitude)).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());this.bind&&this.map.setCenter(b);this.events.triggerEvent("locationupdated",
+{position:a,point:new OpenLayers.Geometry.Point(b.lon,b.lat)})},getCurrentLocation:function(){if(!this.active||this.watch)return!1;this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return!0},failure:function(a){this.events.triggerEvent("locationfailed",{error:a})},CLASS_NAME:"OpenLayers.Control.Geolocate"});
+OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:!0,initialize:function(a,b,c,d){var e=[],c=OpenLayers.Util.upperCaseObject(c);e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&"true"==this.params.TRANSPARENT.toString().toLowerCase()){if(null==d||!d.isBaseLayer)this.isBaseLayer=!1;if("jpg"==
+this.params.FORMAT)this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png"}},clone:function(a){null==a&&(a=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.adjustBounds(a),b=this.projection.getCode().split(":"),b=b[b.length-1],c=this.getImageSize(),a={BBOX:a.toBBOX(),SIZE:c.w+","+c.h,F:"image",BBOXSR:b,IMAGESR:b};if(this.layerDefs){var b=[],d;for(d in this.layerDefs)this.layerDefs.hasOwnProperty(d)&&
+this.layerDefs[d]&&(b.push(d),b.push(":"),b.push(this.layerDefs[d]),b.push(";"));0<b.length&&(a.LAYERDEFS=b.join(""))}return this.getFullRequestString(a)},setLayerFilter:function(a,b){if(!this.layerDefs)this.layerDefs={};b?this.layerDefs[a]=b:delete this.layerDefs[a]},clearLayerFilter:function(a){a?delete this.layerDefs[a]:delete this.layerDefs},mergeNewParams:function(a){a=[OpenLayers.Util.upperCaseObject(a)];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,a)},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});
+OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(a,b,c,d){var e=[];e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(null==d||null==d.isBaseLayer)this.isBaseLayer="true"!=this.params.transparent&&!0!=this.params.transparent},clone:function(a){null==a&&(a=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,
+this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.adjustBounds(a),a=[a.left,a.bottom,a.right,a.top],b=this.getImageSize();return this.getFullRequestString({mapext:a,imgext:a,map_size:[b.w,b.h],imgx:b.w/2,imgy:b.h/2,imgxy:[b.w,b.h]})},getFullRequestString:function(a,b){var c=null==b?this.url:b,d=OpenLayers.Util.extend({},this.params),d=OpenLayers.Util.extend(d,a),e=OpenLayers.Util.getParameterString(d);OpenLayers.Util.isArray(c)&&(c=this.selectUrl(e,
+c));var e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),f;for(f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);d=c;e=e.replace(/,/g,"+");""!=e&&(f=c.charAt(c.length-1),d="&"==f||"?"==f?d+e:-1==c.indexOf("?")?d+("?"+e):d+("&"+e));return d},CLASS_NAME:"OpenLayers.Layer.MapServer"});
+OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:!0,initialize:function(a,b,c,d){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);OpenLayers.Console.warn("The OpenLayers.Layer.MapServer.Untiled class is deprecated and will be removed in 3.0. Instead, you should use the normal OpenLayers.Layer.MapServer class, passing it the option 'singleTile' as true.")},clone:function(a){null==a&&(a=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,
+this.params,this.getOptions()));return a=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});
+OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:!1,px:null,timerId:null,mousemove:function(a){if(this.passesTolerance(a.xy))this.clearTimer(),this.callback("move",[a]),this.px=a.xy,a=OpenLayers.Util.extend({},a),this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay);return!this.stopMove},mouseout:function(a){OpenLayers.Util.mouseLeft(a,this.map.eventsDiv)&&(this.clearTimer(),this.callback("move",[a]));return!0},
+passesTolerance:function(a){var b=!0;this.pixelTolerance&&this.px&&Math.sqrt(Math.pow(this.px.x-a.x,2)+Math.pow(this.px.y-a.y,2))<this.pixelTolerance&&(b=!1);return b},clearTimer:function(){if(null!=this.timerId)window.clearTimeout(this.timerId),this.timerId=null},delayedCall:function(a){this.callback("pause",[a])},deactivate:function(){var a=!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.clearTimer(),a=!0);return a},CLASS_NAME:"OpenLayers.Handler.Hover"});
+OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:!1,click:!0,single:!0,clickout:!0,toggle:!1,clickTolerance:5,hover:!1,box:!1,maxFeatures:10,features:null,hoverFeature:null,handlerOptions:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,initialize:function(a){a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);this.features={};this.handlers=
+{};if(this.click)this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.selectClick},this.handlerOptions.click||{});if(this.box)this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},OpenLayers.Util.extend(this.handlerOptions.box,{boxDivClassName:"olHandlerBoxSelectFeature"}));if(this.hover)this.handlers.hover=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.selectHover},OpenLayers.Util.extend(this.handlerOptions.hover,{delay:250}))},activate:function(){if(!this.active)for(var a in this.handlers)this.handlers[a].activate();
+return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){if(this.active)for(var a in this.handlers)this.handlers[a].deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},selectClick:function(a){var b=this.pixelToBounds(a.xy);this.setModifiers(a);this.request(b,{single:this.single})},selectBox:function(a){var b;if(a instanceof OpenLayers.Bounds)b=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.left,a.bottom)),a=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.right,
+a.top)),b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat);else{if(this.click)return;b=this.pixelToBounds(a)}this.setModifiers(this.handlers.box.dragHandler.evt);this.request(b)},selectHover:function(a){this.request(this.pixelToBounds(a.xy),{single:!0,hover:!0})},cancelHover:function(){if(this.hoverResponse)this.protocol.abort(this.hoverResponse),this.hoverResponse=null,OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait")},request:function(a,b){var b=b||{},c=new OpenLayers.Filter.Spatial({type:this.filterType,
+value:a});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");c=this.protocol.read({maxFeatures:!0==b.single?this.maxFeatures:void 0,filter:c,callback:function(c){c.success()&&(c.features.length?!0==b.single?this.selectBestFeature(c.features,a.getCenterLonLat(),b):this.select(c.features):b.hover?this.hoverSelect():(this.events.triggerEvent("clickout"),this.clickout&&this.unselectAll()));OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait")},scope:this});if(!0==b.hover)this.hoverResponse=
+c},selectBestFeature:function(a,b,c){c=c||{};if(a.length){for(var b=new OpenLayers.Geometry.Point(b.lon,b.lat),d,e,f,g=Number.MAX_VALUE,h=0;h<a.length&&!(d=a[h],d.geometry&&(f=b.distanceTo(d.geometry,{edge:!1}),f<g&&(g=f,e=d,0==g)));++h);!0==c.hover?this.hoverSelect(e):this.select(e||a)}},setModifiers:function(a){this.modifiers={multiple:this.multiple||this.multipleKey&&a[this.multipleKey],toggle:this.toggle||this.toggleKey&&a[this.toggleKey]}},select:function(a){!this.modifiers.multiple&&!this.modifiers.toggle&&
+this.unselectAll();OpenLayers.Util.isArray(a)||(a=[a]);var b=this.events.triggerEvent("beforefeaturesselected",{features:a});if(!1!==b){for(var c=[],d,e=0,f=a.length;e<f;++e)d=a[e],this.features[d.fid||d.id]?this.modifiers.toggle&&this.unselect(this.features[d.fid||d.id]):(b=this.events.triggerEvent("beforefeatureselected",{feature:d}),!1!==b&&(this.features[d.fid||d.id]=d,c.push(d),this.events.triggerEvent("featureselected",{feature:d})));this.events.triggerEvent("featuresselected",{features:c})}},
+hoverSelect:function(a){var b=a?a.fid||a.id:null,c=this.hoverFeature?this.hoverFeature.fid||this.hoverFeature.id:null;if(c&&c!=b)this.events.triggerEvent("outfeature",{feature:this.hoverFeature}),this.hoverFeature=null;if(b&&b!=c)this.events.triggerEvent("hoverfeature",{feature:a}),this.hoverFeature=a},unselect:function(a){delete this.features[a.fid||a.id];this.events.triggerEvent("featureunselected",{feature:a})},unselectAll:function(){for(var a in this.features)this.unselect(this.features[a])},
+setMap:function(a){for(var b in this.handlers)this.handlers[b].setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},pixelToBounds:function(a){var b=a.add(-this.clickTolerance/2,this.clickTolerance/2),a=a.add(this.clickTolerance/2,-this.clickTolerance/2),b=this.map.getLonLatFromPixel(b),a=this.map.getLonLatFromPixel(a);return new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat)},CLASS_NAME:"OpenLayers.Control.GetFeature"});
+OpenLayers.Format.QueryStringFilter=function(){function a(a){a=a.replace(/%/g,"\\%");a=a.replace(/\\\\\.(\*)?/g,function(a,b){return b?a:"\\\\_"});a=a.replace(/\\\\\.\*/g,"\\\\%");a=a.replace(/(\\)?\.(\*)?/g,function(a,b,c){return b||c?a:"_"});a=a.replace(/(\\)?\.\*/g,function(a,b){return b?a:"%"});a=a.replace(/\\\./g,".");return a=a.replace(/(\\)?\\\*/g,function(a,b){return b?a:"*"})}var b={};b[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";b[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";b[OpenLayers.Filter.Comparison.LESS_THAN]=
+"lt";b[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";b[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";b[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";b[OpenLayers.Filter.Comparison.LIKE]="ilike";return OpenLayers.Class(OpenLayers.Format,{wildcarded:!1,srsInBBOX:!1,write:function(c,d){var d=d||{},e=c.CLASS_NAME,e=e.substring(e.lastIndexOf(".")+1);switch(e){case "Spatial":switch(c.type){case OpenLayers.Filter.Spatial.BBOX:d.bbox=c.value.toArray();this.srsInBBOX&&c.projection&&
+d.bbox.push(c.projection.getCode());break;case OpenLayers.Filter.Spatial.DWITHIN:d.tolerance=c.distance;case OpenLayers.Filter.Spatial.WITHIN:d.lon=c.value.x;d.lat=c.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+c.type)}break;case "Comparison":e=b[c.type];if(void 0!==e){var f=c.value;c.type==OpenLayers.Filter.Comparison.LIKE&&(f=a(f),this.wildcarded&&(f="%"+f+"%"));d[c.property+"__"+e]=f;d.queryable=d.queryable||[];d.queryable.push(c.property)}else OpenLayers.Console.warn("Unknown comparison filter type "+
+c.type);break;case "Logical":if(c.type===OpenLayers.Filter.Logical.AND){e=0;for(f=c.filters.length;e<f;e++)d=this.write(c.filters[e],d)}else OpenLayers.Console.warn("Unsupported logical filter type "+c.type);break;default:OpenLayers.Console.warn("Unknown filter type "+e)}return d},CLASS_NAME:"OpenLayers.Format.QueryStringFilter"})}();
+OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,element:null,prefix:"",separator:", ",suffix:"",numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.map.events.register("mousemove",this,this.redraw),this.map.events.register("mouseout",this,this.reset),
+this.redraw(),!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments)?(this.map.events.unregister("mousemove",this,this.redraw),this.map.events.unregister("mouseout",this,this.reset),this.element.innerHTML="",!0):!1},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element)this.div.left="",this.div.top="",this.element=this.div;return this.div},redraw:function(a){var b;if(null==a)this.reset();else if(null==this.lastXy||Math.abs(a.xy.x-
+this.lastXy.x)>this.granularity||Math.abs(a.xy.y-this.lastXy.y)>this.granularity)this.lastXy=a.xy;else if(b=this.map.getLonLatFromPixel(a.xy))if(this.displayProjection&&b.transform(this.map.getProjectionObject(),this.displayProjection),this.lastXy=a.xy,a=this.formatOutput(b),a!=this.element.innerHTML)this.element.innerHTML=a},reset:function(){if(null!=this.emptyString)this.element.innerHTML=this.emptyString},formatOutput:function(a){var b=parseInt(this.numDigits);return this.prefix+a.lon.toFixed(b)+
+this.separator+a.lat.toFixed(b)+this.suffix},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Layer.Process=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!1,displayInLayerSwitcher:!1,visibility:!1,describeProcessUrl:"",executeUrl:"",processIdentifier:null,process:null,autoLoad:!1,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Layer.Process"});
+OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:!1,wildcarded:!1,srsInBBOX:!1,initialize:function(a){a=a||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var b=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=function(a,d){return b.write(a,
+d)}}},destroy:function(){this.headers=this.params=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=a||{};a.params=OpenLayers.Util.applyDefaults(a.params,this.options.params);a=OpenLayers.Util.applyDefaults(a,this.options);if(a.filter&&this.filterToParams)a.params=this.filterToParams(a.filter,a.params);var b=void 0!==a.readWithPOST?a.readWithPOST:this.readWithPOST,c=new OpenLayers.Protocol.Response({requestType:"read"});
+c.priv=b?OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,c,a),data:OpenLayers.Util.getParameterString(a.params),headers:{"Content-Type":"application/x-www-form-urlencoded"}}):OpenLayers.Request.GET({url:a.url,callback:this.createCallback(this.handleRead,c,a),params:a.params,headers:a.headers});return c},handleRead:function(a,b){this.handleResponse(a,b)},create:function(a,b){var b=OpenLayers.Util.applyDefaults(b,this.options),c=new OpenLayers.Protocol.Response({reqFeatures:a,
+requestType:"create"});c.priv=OpenLayers.Request.POST({url:b.url,callback:this.createCallback(this.handleCreate,c,b),headers:b.headers,data:this.format.write(a)});return c},handleCreate:function(a,b){this.handleResponse(a,b)},update:function(a,b){var b=b||{},c=b.url||a.url||this.options.url+"/"+a.fid,b=OpenLayers.Util.applyDefaults(b,this.options),d=new OpenLayers.Protocol.Response({reqFeatures:a,requestType:"update"});d.priv=OpenLayers.Request.PUT({url:c,callback:this.createCallback(this.handleUpdate,
+d,b),headers:b.headers,data:this.format.write(a)});return d},handleUpdate:function(a,b){this.handleResponse(a,b)},"delete":function(a,b){var b=b||{},c=b.url||a.url||this.options.url+"/"+a.fid,b=OpenLayers.Util.applyDefaults(b,this.options),d=new OpenLayers.Protocol.Response({reqFeatures:a,requestType:"delete"});d.priv=OpenLayers.Request.DELETE({url:c,callback:this.createCallback(this.handleDelete,d,b),headers:b.headers});return d},handleDelete:function(a,b){this.handleResponse(a,b)},handleResponse:function(a,
+b){var c=a.priv;if(b.callback){if(200<=c.status&&300>c.status){if("delete"!=a.requestType)a.features=this.parseFeatures(c);a.code=OpenLayers.Protocol.Response.SUCCESS}else a.code=OpenLayers.Protocol.Response.FAILURE;b.callback.call(b.scope,a)}},parseFeatures:function(a){var b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;return!b||0>=b.length?null:this.format.read(b)},commit:function(a,b){function c(a){for(var b=a.features?a.features.length:0,c=Array(b),e=0;e<b;++e)c[e]=a.features[e].fid;
+o.insertIds=c;d.apply(this,[a])}function d(a){this.callUserCallback(a,b);l=l&&a.success();f++;if(f>=n&&b.callback)o.code=l?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE,b.callback.apply(b.scope,[o])}var b=OpenLayers.Util.applyDefaults(b,this.options),e=[],f=0,g={};g[OpenLayers.State.INSERT]=[];g[OpenLayers.State.UPDATE]=[];g[OpenLayers.State.DELETE]=[];for(var h,i,j=[],k=0,m=a.length;k<m;++k)if(h=a[k],i=g[h.state])i.push(h),j.push(h);var n=(0<g[OpenLayers.State.INSERT].length?
+1:0)+g[OpenLayers.State.UPDATE].length+g[OpenLayers.State.DELETE].length,l=!0,o=new OpenLayers.Protocol.Response({reqFeatures:j});h=g[OpenLayers.State.INSERT];0<h.length&&e.push(this.create(h,OpenLayers.Util.applyDefaults({callback:c,scope:this},b.create)));h=g[OpenLayers.State.UPDATE];for(k=h.length-1;0<=k;--k)e.push(this.update(h[k],OpenLayers.Util.applyDefaults({callback:d,scope:this},b.update)));h=g[OpenLayers.State.DELETE];for(k=h.length-1;0<=k;--k)e.push(this["delete"](h[k],OpenLayers.Util.applyDefaults({callback:d,
+scope:this},b["delete"])));return e},abort:function(a){a&&a.priv.abort()},callUserCallback:function(a,b){var c=b[a.requestType];c&&c.callback&&c.callback.call(c.scope,a)},CLASS_NAME:"OpenLayers.Protocol.HTTP"});
+OpenLayers.Strategy.Cluster=OpenLayers.Class(OpenLayers.Strategy,{distance:20,threshold:null,features:null,clusters:null,clustering:!1,resolution:null,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a)this.layer.events.on({beforefeaturesadded:this.cacheFeatures,moveend:this.cluster,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&(this.clearCache(),this.layer.events.un({beforefeaturesadded:this.cacheFeatures,moveend:this.cluster,
+scope:this}));return a},cacheFeatures:function(a){var b=!0;if(!this.clustering)this.clearCache(),this.features=a.features,this.cluster(),b=!1;return b},clearCache:function(){this.features=null},cluster:function(a){if((!a||a.zoomChanged)&&this.features)if(a=this.layer.map.getResolution(),a!=this.resolution||!this.clustersExist()){this.resolution=a;for(var a=[],b,c,d,e=0;e<this.features.length;++e)if(b=this.features[e],b.geometry){c=!1;for(var f=a.length-1;0<=f;--f)if(d=a[f],this.shouldCluster(d,b)){this.addToCluster(d,
+b);c=!0;break}c||a.push(this.createCluster(this.features[e]))}this.layer.removeAllFeatures();if(0<a.length){if(1<this.threshold){b=a.slice();a=[];e=0;for(d=b.length;e<d;++e)c=b[e],c.attributes.count<this.threshold?Array.prototype.push.apply(a,c.cluster):a.push(c)}this.clustering=!0;this.layer.addFeatures(a);this.clustering=!1}this.clusters=a}},clustersExist:function(){var a=!1;if(this.clusters&&0<this.clusters.length&&this.clusters.length==this.layer.features.length)for(var a=!0,b=0;b<this.clusters.length;++b)if(this.clusters[b]!=
+this.layer.features[b]){a=!1;break}return a},shouldCluster:function(a,b){var c=a.geometry.getBounds().getCenterLonLat(),d=b.geometry.getBounds().getCenterLonLat();return Math.sqrt(Math.pow(c.lon-d.lon,2)+Math.pow(c.lat-d.lat,2))/this.resolution<=this.distance},addToCluster:function(a,b){a.cluster.push(b);a.attributes.count+=1},createCluster:function(a){var b=a.geometry.getBounds().getCenterLonLat(),b=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(b.lon,b.lat),{count:1});b.cluster=[a];
+return b},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Protocol.SOS=function(a){var a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.SOS.DEFAULTS),b=OpenLayers.Protocol.SOS["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported SOS version: "+a.version;return new b(a)};OpenLayers.Protocol.SOS.DEFAULTS={version:"1.0.0"};
+OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:!1,createGeometryFromItem:function(a){var b=this.getElementsByTagNameNS(a,this.georssns,"point"),c=this.getElementsByTagNameNS(a,this.geons,"lat"),d=this.getElementsByTagNameNS(a,
+this.geons,"long"),e=this.getElementsByTagNameNS(a,this.georssns,"line"),f=this.getElementsByTagNameNS(a,this.georssns,"polygon"),g=this.getElementsByTagNameNS(a,this.georssns,"where"),a=this.getElementsByTagNameNS(a,this.georssns,"box");if(0<b.length||0<c.length&&0<d.length){0<b.length?(c=OpenLayers.String.trim(b[0].firstChild.nodeValue).split(/\s+/),2!=c.length&&(c=OpenLayers.String.trim(b[0].firstChild.nodeValue).split(/\s*,\s*/))):c=[parseFloat(c[0].firstChild.nodeValue),parseFloat(d[0].firstChild.nodeValue)];
+var h=new OpenLayers.Geometry.Point(c[1],c[0])}else if(0<e.length){c=OpenLayers.String.trim(this.concatChildValues(e[0])).split(/\s+/);d=[];e=0;for(f=c.length;e<f;e+=2)b=new OpenLayers.Geometry.Point(c[e+1],c[e]),d.push(b);h=new OpenLayers.Geometry.LineString(d)}else if(0<f.length){c=OpenLayers.String.trim(this.concatChildValues(f[0])).split(/\s+/);d=[];e=0;for(f=c.length;e<f;e+=2)b=new OpenLayers.Geometry.Point(c[e+1],c[e]),d.push(b);h=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(d)])}else if(0<
+g.length){if(!this.gmlParser)this.gmlParser=new OpenLayers.Format.GML({xy:this.xy});h=this.gmlParser.parseFeature(g[0]).geometry}else 0<a.length&&(c=OpenLayers.String.trim(a[0].firstChild.nodeValue).split(/\s+/),d=[],3<c.length&&(b=new OpenLayers.Geometry.Point(c[1],c[0]),d.push(b),b=new OpenLayers.Geometry.Point(c[1],c[2]),d.push(b),b=new OpenLayers.Geometry.Point(c[3],c[2]),d.push(b),b=new OpenLayers.Geometry.Point(c[3],c[0]),d.push(b),b=new OpenLayers.Geometry.Point(c[1],c[0]),d.push(b)),h=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(d)]));
+h&&this.internalProjection&&this.externalProjection&&h.transform(this.externalProjection,this.internalProjection);return h},createFeatureFromItem:function(a){var b=this.createGeometryFromItem(a),c=this.getChildValue(a,"*","title",this.featureTitle),d=this.getChildValue(a,"*","description",this.getChildValue(a,"*","content",this.getChildValue(a,"*","summary",this.featureDescription))),e=this.getChildValue(a,"*","link");if(!e)try{e=this.getElementsByTagNameNS(a,"*","link")[0].getAttribute("href")}catch(f){e=
+null}a=this.getChildValue(a,"*","id",null);b=new OpenLayers.Feature.Vector(b,{title:c,description:d,link:e});b.fid=a;return b},getChildValue:function(a,b,c,d){return(a=this.getElementsByTagNameNS(a,b,c))&&a[0]&&a[0].firstChild&&a[0].firstChild.nodeValue?OpenLayers.Format.XML.prototype.getChildValue(a[0]):void 0==d?"":d},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=null,b=this.getElementsByTagNameNS(a,"*","item");0==b.length&&(b=this.getElementsByTagNameNS(a,
+"*","entry"));for(var a=b.length,c=Array(a),d=0;d<a;d++)c[d]=this.createFeatureFromItem(b[d]);return c},write:function(a){var b;if(OpenLayers.Util.isArray(a)){b=this.createElementNS(this.rssns,"rss");for(var c=0,d=a.length;c<d;c++)b.appendChild(this.createFeatureXML(a[c]))}else b=this.createFeatureXML(a);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.rssns,"item"),d=this.createElementNS(this.rssns,
+"title");d.appendChild(this.createTextNode(a.attributes.title?a.attributes.title:""));var e=this.createElementNS(this.rssns,"description");e.appendChild(this.createTextNode(a.attributes.description?a.attributes.description:""));c.appendChild(d);c.appendChild(e);a.attributes.link&&(d=this.createElementNS(this.rssns,"link"),d.appendChild(this.createTextNode(a.attributes.link)),c.appendChild(d));for(var f in a.attributes)"link"==f||"title"==f||"description"==f||(d=this.createTextNode(a.attributes[f]),
+e=f,-1!=f.search(":")&&(e=f.split(":")[1]),e=this.createElementNS(this.featureNS,"feature:"+e),e.appendChild(d),c.appendChild(e));c.appendChild(b);return c},buildGeometryNode:function(a){this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));var b;if("OpenLayers.Geometry.Polygon"==a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:polygon"),b.appendChild(this.buildCoordinatesNode(a.components[0]));else if("OpenLayers.Geometry.LineString"==
+a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:line"),b.appendChild(this.buildCoordinatesNode(a));else if("OpenLayers.Geometry.Point"==a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:point"),b.appendChild(this.buildCoordinatesNode(a));else throw"Couldn't parse "+a.CLASS_NAME;return b},buildCoordinatesNode:function(a){var b=null;if(a.components)b=a.components;if(b){for(var a=b.length,c=Array(a),d=0;d<a;d++)c[d]=b[d].y+" "+b[d].x;b=c.join(" ")}else b=a.y+" "+a.x;return this.createTextNode(b)},
+CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.WPSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.WPSCapabilities"});
+OpenLayers.Format.WPSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wps:"http://www.opengis.net/wps/1.0.0",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;
+var b={};this.readNode(a,b);return b},readers:{wps:{Capabilities:function(a,b){this.readChildNodes(a,b)},ProcessOfferings:function(a,b){b.processOfferings={};this.readChildNodes(a,b.processOfferings)},Process:function(a,b){var c={processVersion:this.getAttributeNS(a,this.namespaces.wps,"processVersion")};this.readChildNodes(a,c);b[c.identifier]=c},Languages:function(a,b){b.languages=[];this.readChildNodes(a,b.languages)},Default:function(a,b){var c={isDefault:!0};this.readChildNodes(a,c);b.push(c)},
+Supported:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WPSCapabilities.v1_0_0"});
+OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:!1,autoActivate:!0,initialize:function(a){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;this.pinchZoom&&(this.pinchZoom.destroy(),delete this.pinchZoom);OpenLayers.Control.prototype.destroy.apply(this,
+arguments)},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.dragPan.activate(),this.handlers.click.activate(),this.pinchZoom.activate(),!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments)?(this.dragPan.deactivate(),this.handlers.click.deactivate(),this.pinchZoom.deactivate(),!0):!1},draw:function(){var a={click:this.defaultClick,dblclick:this.defaultDblClick},b=OpenLayers.Util.extend({"double":!0,stopDouble:!0,
+pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,a,b);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions))},defaultClick:function(a){a.lastTouches&&2==a.lastTouches.length&&this.map.zoomOut()},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),
+this.map.zoom+1)},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});
+OpenLayers.Style2=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:!1,rules:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a=0,b=this.rules.length;a<b;a++)this.rules[a].destroy();delete this.rules},clone:function(){var a=OpenLayers.Util.extend({},this);if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}return new OpenLayers.Style2(a)},
+CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Protocol.WFSTWithLock.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFSTWithLock.v1,{version:"1.1.0",CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1_1_0"});
+OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(a,b){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments)},drawMarker:function(a){var b=a.bounds,c=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(b.left,b.top)),b=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(b.right,b.bottom));if(null==b||null==c)a.display(!1);else if(b=new OpenLayers.Size(Math.max(1,b.x-c.x),Math.max(1,b.y-c.y)),c=a.draw(c,b),!a.drawn)this.div.appendChild(c),a.drawn=!0},
+removeMarker:function(a){OpenLayers.Util.removeItem(this.markers,a);null!=a.div&&a.div.parentNode==this.div&&this.div.removeChild(a.div)},CLASS_NAME:"OpenLayers.Layer.Boxes"});
+OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(a){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[a])},read_cap_Service:function(a,b){var c={};this.runChildNodes(c,b);a.service=c},read_cap_Fees:function(a,b){var c=this.getChildValue(b);if(c&&"none"!=c.toLowerCase())a.fees=c},read_cap_AccessConstraints:function(a,b){var c=this.getChildValue(b);if(c&&"none"!=c.toLowerCase())a.accessConstraints=c},read_cap_OnlineResource:function(a,
+b){var c=this.getChildValue(b);if(c&&"none"!=c.toLowerCase())a.onlineResource=c},read_cap_Keywords:function(a,b){var c=this.getChildValue(b);if(c&&"none"!=c.toLowerCase())a.keywords=c.split(", ")},read_cap_Capability:function(a,b){var c={};this.runChildNodes(c,b);a.capability=c},read_cap_Request:function(a,b){var c={};this.runChildNodes(c,b);a.request=c},read_cap_GetFeature:function(a,b){var c={href:{},formats:[]};this.runChildNodes(c,b);a.getfeature=c},read_cap_ResultFormat:function(a,b){for(var c=
+b.childNodes,d,e=0;e<c.length;e++)d=c[e],1==d.nodeType&&a.formats.push(d.nodeName)},read_cap_DCPType:function(a,b){this.runChildNodes(a,b)},read_cap_HTTP:function(a,b){this.runChildNodes(a.href,b)},read_cap_Get:function(a,b){a.get=b.getAttribute("onlineResource")},read_cap_Post:function(a,b){a.post=b.getAttribute("onlineResource")},read_cap_SRS:function(a,b){var c=this.getChildValue(b);if(c)a.srs=c},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});
+OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.145767211914062E-5,1.072883605957031E-5],type:null,wrapDateLine:!0,sphericalMercator:!1,initialize:function(a,
+b){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.sphericalMercator&&(OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator),this.initMercatorParameters())},loadMapObject:function(){try{var a=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,a);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||"function"!=
+typeof this.mapObject.moveByXY)this.dragPanMapObject=null}catch(b){}},onMapResize:function(){try{this.mapObject.resizeTo(this.getMapObjectSizeFromOLSize(this.map.getSize()))}catch(a){}},setMap:function(a){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane)},fixYahooEventPane:function(){var a=OpenLayers.Util.getElement("ygddfdiv");null!=a&&(null!=a.parentNode&&a.parentNode.removeChild(a),this.map.events.unregister("moveend",
+this,this.fixYahooEventPane))},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{layerType:"Yahoo",layerLib:"Yahoo"})},getOLZoomFromMapObjectZoom:function(a){var b=null;null!=a&&(b=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[a]),b=18-b);return b},getMapObjectZoomFromOLZoom:function(a){var b=null;null!=a&&(b=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[a]),b=18-b);return b},setMapObjectCenter:function(a,b){this.mapObject.drawZoomAndCenter(a,
+b)},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon()},dragPanMapObject:function(a,b){this.mapObject.moveByXY({x:-a,y:b})},getMapObjectZoom:function(){return this.mapObject.getZoomLevel()},getMapObjectLonLatFromMapObjectPixel:function(a){return this.mapObject.convertXYLatLon(a)},getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.convertLatLonXY(a)},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Lon,a.Lat).lon:
+a.Lon},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.Lon,a.Lat).lat:a.Lat},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new YGeoPoint(c.lat,c.lon)):c=new YGeoPoint(b,a);return c},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},getMapObjectPixelFromXY:function(a,b){return new YCoordPoint(a,b)},getMapObjectSizeFromOLSize:function(a){return new YSize(a.w,
+a.h)},CLASS_NAME:"OpenLayers.Layer.Yahoo"});
+OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{keydown:this.defaultKeyPress})},defaultKeyPress:function(a){switch(a.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,
+this.slideFactor);break;case 33:a=this.map.getSize();this.map.pan(0,-0.75*a.h);break;case 34:a=this.map.getSize();this.map.pan(0,0.75*a.h);break;case 35:a=this.map.getSize();this.map.pan(0.75*a.w,0);break;case 36:a=this.map.getSize();this.map.pan(-0.75*a.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut()}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});
+OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(a){a=a||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[a.name,a])},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);a.events.register("moveend",this,this.onMoveEnd)},removeMap:function(a){a.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,
+arguments)},setRatio:function(a){this.ratio=a;this.updateGrid(!0)},setMaxFeatures:function(a){this.maxFeatures=a;this.updateGrid(!0)},setSpacing:function(a,b){this.dx=a;this.dy=b||a;this.updateGrid(!0)},setOrigin:function(a){this.origin=a;this.updateGrid(!0)},getOrigin:function(){if(!this.origin)this.origin=this.map.getExtent().getCenterLonLat();return this.origin},setRotation:function(a){this.rotation=a;this.updateGrid(!0)},onMoveEnd:function(){this.updateGrid()},getViewBounds:function(){var a=this.map.getExtent();
+if(this.rotation){var b=this.getOrigin(),b=new OpenLayers.Geometry.Point(b.lon,b.lat),a=a.toGeometry();a.rotate(-this.rotation,b);a=a.getBounds()}return a},updateGrid:function(a){if(a||this.invalidBounds()){var b=this.getViewBounds(),c=this.getOrigin(),a=new OpenLayers.Geometry.Point(c.lon,c.lat),d=b.getWidth(),e=b.getHeight(),f=d/e,g=Math.sqrt(this.dx*this.dy*this.maxFeatures/f),d=Math.min(d*this.ratio,g*f),e=Math.min(e*this.ratio,g),b=b.getCenterLonLat();this.gridBounds=new OpenLayers.Bounds(b.lon-
+d/2,b.lat-e/2,b.lon+d/2,b.lat+e/2);for(var b=Math.floor(e/this.dy),d=Math.floor(d/this.dx),e=c.lon+this.dx*Math.ceil((this.gridBounds.left-c.lon)/this.dx),c=c.lat+this.dy*Math.ceil((this.gridBounds.bottom-c.lat)/this.dy),g=Array(b*d),h,i=0;i<d;++i)for(var f=e+i*this.dx,j=0;j<b;++j)h=c+j*this.dy,h=new OpenLayers.Geometry.Point(f,h),this.rotation&&h.rotate(this.rotation,a),g[i*b+j]=new OpenLayers.Feature.Vector(h);this.destroyFeatures(this.features,{silent:!0});this.addFeatures(g,{silent:!0})}},invalidBounds:function(){return!this.gridBounds||
+!this.gridBounds.containsBounds(this.getViewBounds())},CLASS_NAME:"OpenLayers.Layer.PointGrid"});
+OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:!0,standardTileSize:256,tileOriginCorner:"tl",numberOfTiers:0,tileCountUpToTier:[],tierSizeInTiles:[],tierImageSize:[],initialize:function(a,b,c,d){this.initializeZoomify(c);var e=[];e.push(a,b,c,{},d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e)},initializeZoomify:function(a){var a=a.clone(),b=new OpenLayers.Size(Math.ceil(a.w/this.standardTileSize),Math.ceil(a.h/this.standardTileSize));this.tierSizeInTiles.push(b);
+for(this.tierImageSize.push(a);a.w>this.standardTileSize||a.h>this.standardTileSize;)a=new OpenLayers.Size(Math.floor(a.w/2),Math.floor(a.h/2)),b=new OpenLayers.Size(Math.ceil(a.w/this.standardTileSize),Math.ceil(a.h/this.standardTileSize)),this.tierSizeInTiles.push(b),this.tierImageSize.push(a);this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;this.tileCountUpToTier[0]=0;for(a=1;a<this.numberOfTiers;a++)this.tileCountUpToTier.push(this.tierSizeInTiles[a-
+1].w*this.tierSizeInTiles[a-1].h+this.tileCountUpToTier[a-1])},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0},clone:function(a){null==a&&(a=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.adjustBounds(a),b=this.map.getResolution(),c=Math.round((a.left-this.tileOrigin.lon)/
+(b*this.tileSize.w)),a=Math.round((this.tileOrigin.lat-a.top)/(b*this.tileSize.h)),b=this.map.getZoom(),c="TileGroup"+Math.floor((c+a*this.tierSizeInTiles[b].w+this.tileCountUpToTier[b])/256)+"/"+b+"-"+c+"-"+a+".jpg",a=this.url;OpenLayers.Util.isArray(a)&&(a=this.selectUrl(c,a));return a+c},getImageSize:function(){if(0<arguments.length){var a=this.adjustBounds(arguments[0]),b=this.map.getResolution(),c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w)),a=Math.round((this.tileOrigin.lat-
+a.top)/(b*this.tileSize.h)),b=this.map.getZoom(),d=this.standardTileSize,e=this.standardTileSize;c==this.tierSizeInTiles[b].w-1&&(d=this.tierImageSize[b].w%this.standardTileSize);a==this.tierSizeInTiles[b].h-1&&(e=this.tierImageSize[b].h%this.standardTileSize);return new OpenLayers.Size(d,e)}return this.tileSize},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.top)},calculateGridLayout:function(a,
+b,c){var d=c*this.tileSize.w,c=c*this.tileSize.h,e=a.left-b.lon,f=Math.floor(e/d)-this.buffer,a=b.lat-a.top+c,g=Math.floor(a/c)-this.buffer;return{tilelon:d,tilelat:c,tileoffsetlon:b.lon+f*d,tileoffsetlat:b.lat-c*g,tileoffsetx:-(e/d-f)*this.tileSize.w,tileoffsety:(g-a/c)*this.tileSize.h}},CLASS_NAME:"OpenLayers.Layer.Zoomify"});
+OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(a){if(this.supported()){if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);for(var b=document.createStyleSheet(),c="shape,rect,oval,fill,stroke,imagedata,group,textbox".split(","),d=0,e=c.length;d<e;d++)b.addRule("olv\\:"+c[d],"behavior: url(#default#VML); position: absolute; display: inline-block;")}OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
+arguments)}},supported:function(){return!!document.namespaces},setExtent:function(a,b){var c=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments),d=this.getResolution(),e=a.left/d|0,d=a.top/d-this.size.h|0;b||!this.offset?(this.offset={x:e,y:d},d=e=0):(e-=this.offset.x,d-=this.offset.y);this.root.coordorigin=e-this.xOffset+" "+d;for(var e=[this.root,this.vectorRoot,this.textRoot],f=0,g=e.length;f<g;++f)d=e[f],d.coordsize=this.size.w+" "+this.size.h;this.root.style.flip="y";return c},
+setSize:function(a){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);for(var b=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot],c=this.size.w+"px",d=this.size.h+"px",e,f=0,g=b.length;f<g;++f)e=b[f],e.style.width=c,e.style.height=d},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"olv:rect":this.isComplexSymbol(b.graphicName)?"olv:shape":"olv:oval";break;case "OpenLayers.Geometry.Rectangle":c="olv:rect";break;case "OpenLayers.Geometry.LineString":case "OpenLayers.Geometry.LinearRing":case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c=
+"olv:shape"}return c},setStyle:function(a,b,c,d){var b=b||a._style,c=c||a._options,e=b.fillColor;if("OpenLayers.Geometry.Point"===a._geometryClass)if(b.externalGraphic){c.isFilled=!0;if(b.graphicTitle)a.title=b.graphicTitle;var e=b.graphicWidth||b.graphicHeight,f=b.graphicHeight||b.graphicWidth,e=e?e:2*b.pointRadius,f=f?f:2*b.pointRadius,g=this.getResolution(),h=void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*e),i=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*f);a.style.left=((d.x-this.featureDx)/
+g-this.offset.x+h|0)+"px";a.style.top=(d.y/g-this.offset.y-(i+f)|0)+"px";a.style.width=e+"px";a.style.height=f+"px";a.style.flip="y";e="none";c.isStroked=!1}else this.isComplexSymbol(b.graphicName)?(f=this.importSymbol(b.graphicName),a.path=f.path,a.coordorigin=f.left+","+f.bottom,f=f.size,a.coordsize=f+","+f,this.drawCircle(a,d,b.pointRadius),a.style.flip="y"):this.drawCircle(a,d,b.pointRadius);c.isFilled?a.fillcolor=e:a.filled="false";d=a.getElementsByTagName("fill");d=0==d.length?null:d[0];if(c.isFilled){d||
+(d=this.createNode("olv:fill",a.id+"_fill"));d.opacity=b.fillOpacity;if("OpenLayers.Geometry.Point"===a._geometryClass&&b.externalGraphic){if(b.graphicOpacity)d.opacity=b.graphicOpacity;d.src=b.externalGraphic;d.type="frame";if(!b.graphicWidth||!b.graphicHeight)d.aspect="atmost"}d.parentNode!=a&&a.appendChild(d)}else d&&a.removeChild(d);e=b.rotation;if(void 0!==e||void 0!==a._rotation)if(a._rotation=e,b.externalGraphic)this.graphicRotate(a,h,i,b),d.opacity=0;else if("OpenLayers.Geometry.Point"===
+a._geometryClass)a.style.rotation=e||0;h=a.getElementsByTagName("stroke");h=0==h.length?null:h[0];if(c.isStroked){if(h||(h=this.createNode("olv:stroke",a.id+"_stroke"),a.appendChild(h)),h.on=!0,h.color=b.strokeColor,h.weight=b.strokeWidth+"px",h.opacity=b.strokeOpacity,h.endcap="butt"==b.strokeLinecap?"flat":b.strokeLinecap||"round",b.strokeDashstyle)h.dashstyle=this.dashStyle(b)}else if(a.stroked=!1,h)h.on=!1;if("inherit"!=b.cursor&&null!=b.cursor)a.style.cursor=b.cursor;return a},graphicRotate:function(a,
+b,c,d){var d=d||a._style,e=d.rotation||0,f,g;if(!d.graphicWidth||!d.graphicHeight){var h=new Image;h.onreadystatechange=OpenLayers.Function.bind(function(){if("complete"==h.readyState||"interactive"==h.readyState)f=h.width/h.height,g=Math.max(2*d.pointRadius,d.graphicWidth||0,d.graphicHeight||0),b*=f,d.graphicWidth=g*f,d.graphicHeight=g,this.graphicRotate(a,b,c,d)},this);h.src=d.externalGraphic}else{g=Math.max(d.graphicWidth,d.graphicHeight);f=d.graphicWidth/d.graphicHeight;var i=Math.round(d.graphicWidth||
+g*f),j=Math.round(d.graphicHeight||g);a.style.width=i+"px";a.style.height=j+"px";var k=document.getElementById(a.id+"_image");k||(k=this.createNode("olv:imagedata",a.id+"_image"),a.appendChild(k));k.style.width=i+"px";k.style.height=j+"px";k.src=d.externalGraphic;k.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='', sizingMethod='scale')";k=e*Math.PI/180;e=Math.sin(k);k=Math.cos(k);e="progid:DXImageTransform.Microsoft.Matrix(M11="+k+",M12="+-e+",M21="+e+",M22="+k+",SizingMethod='auto expand')\n";
+(k=d.graphicOpacity||d.fillOpacity)&&1!=k&&(e+="progid:DXImageTransform.Microsoft.BasicImage(opacity="+k+")\n");a.style.filter=e;e=new OpenLayers.Geometry.Point(-b,-c);i=(new OpenLayers.Bounds(0,0,i,j)).toGeometry();i.rotate(d.rotation,e);i=i.getBounds();a.style.left=Math.round(parseInt(a.style.left)+i.left)+"px";a.style.top=Math.round(parseInt(a.style.top)-i.bottom)+"px"}},postDraw:function(a){a.style.visibility="visible";var b=a._style.fillColor,c=a._style.strokeColor;if("none"==b&&a.fillcolor!=
+b)a.fillcolor=b;if("none"==c&&a.strokecolor!=c)a.strokecolor=c},setNodeDimension:function(a,b){var c=b.getBounds();if(c){var d=this.getResolution(),c=new OpenLayers.Bounds((c.left-this.featureDx)/d-this.offset.x|0,c.bottom/d-this.offset.y|0,(c.right-this.featureDx)/d-this.offset.x|0,c.top/d-this.offset.y|0);a.style.left=c.left+"px";a.style.top=c.top+"px";a.style.width=c.getWidth()+"px";a.style.height=c.getHeight()+"px";a.coordorigin=c.left+" "+c.top;a.coordsize=c.getWidth()+" "+c.getHeight()}},dashStyle:function(a){a=
+a.strokeDashstyle;switch(a){case "solid":case "dot":case "dash":case "dashdot":case "longdash":case "longdashdot":return a;default:return a=a.split(/[ ,]/),2==a.length?1*a[0]>=2*a[1]?"longdash":1==a[0]||1==a[1]?"dot":"dash":4==a.length?1*a[0]>=2*a[1]?"longdashdot":"dashdot":"solid"}},createNode:function(a,b){var c=document.createElement(a);if(b)c.id=b;c.unselectable="on";c.onselectstart=OpenLayers.Function.False;return c},nodeTypeCompare:function(a,b){var c=b,d=c.indexOf(":");-1!=d&&(c=c.substr(d+
+1));var e=a.nodeName,d=e.indexOf(":");-1!=d&&(e=e.substr(d+1));return c==e},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div")},createRoot:function(a){return this.nodeFactory(this.container.id+a,"olv:group")},drawPoint:function(a,b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){if(!isNaN(b.x)&&!isNaN(b.y)){var d=this.getResolution();a.style.left=((b.x-this.featureDx)/d-this.offset.x|0)-c+"px";a.style.top=(b.y/d-this.offset.y|0)-c+"px";b=2*c;a.style.width=
+b+"px";a.style.height=b+"px";return a}return!1},drawLineString:function(a,b){return this.drawLine(a,b,!1)},drawLinearRing:function(a,b){return this.drawLine(a,b,!0)},drawLine:function(a,b,c){this.setNodeDimension(a,b);for(var d=this.getResolution(),e=b.components.length,f=Array(e),g,h,i=0;i<e;i++)g=b.components[i],h=(g.x-this.featureDx)/d-this.offset.x|0,g=g.y/d-this.offset.y|0,f[i]=" "+h+","+g+" l ";a.path="m"+f.join("")+(c?" x e":" e");return a},drawPolygon:function(a,b){this.setNodeDimension(a,
+b);var c=this.getResolution(),d=[],e,f,g,h,i,j,k,m,n,l;for(e=0,f=b.components.length;e<f;e++){d.push("m");g=b.components[e].components;h=0===e;j=i=null;for(k=0,m=g.length;k<m;k++)n=g[k],l=(n.x-this.featureDx)/c-this.offset.x|0,n=n.y/c-this.offset.y|0,l=" "+l+","+n,d.push(l),0==k&&d.push(" l"),h||(i?i!=l&&(j?j!=l&&(h=!0):j=l):i=l);d.push(h?" x ":" ")}d.push("e");a.path=d.join("");return a},drawRectangle:function(a,b){var c=this.getResolution();a.style.left=((b.x-this.featureDx)/c-this.offset.x|0)+
+"px";a.style.top=(b.y/c-this.offset.y|0)+"px";a.style.width=(b.width/c|0)+"px";a.style.height=(b.height/c|0)+"px";return a},drawText:function(a,b,c){var d=this.nodeFactory(a+this.LABEL_ID_SUFFIX,"olv:rect"),e=this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox"),f=this.getResolution();d.style.left=((c.x-this.featureDx)/f-this.offset.x|0)+"px";d.style.top=(c.y/f-this.offset.y|0)+"px";d.style.flip="y";e.innerText=b.label;if("inherit"!=b.cursor&&null!=b.cursor)e.style.cursor=b.cursor;if(b.fontColor)e.style.color=
+b.fontColor;if(b.fontOpacity)e.style.filter="alpha(opacity="+100*b.fontOpacity+")";if(b.fontFamily)e.style.fontFamily=b.fontFamily;if(b.fontSize)e.style.fontSize=b.fontSize;if(b.fontWeight)e.style.fontWeight=b.fontWeight;if(b.fontStyle)e.style.fontStyle=b.fontStyle;if(!0===b.labelSelect)d._featureId=a,e._featureId=a,e._geometry=c,e._geometryClass=c.CLASS_NAME;e.style.whiteSpace="nowrap";e.inset="1px,0px,0px,0px";d.parentNode||(d.appendChild(e),this.textRoot.appendChild(d));b=b.labelAlign||"cm";1==
+b.length&&(b+="m");a=e.clientWidth*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(0,1)];e=e.clientHeight*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(1,1)];d.style.left=parseInt(d.style.left)-a-1+"px";d.style.top=parseInt(d.style.top)+e+"px"},drawSurface:function(a,b){this.setNodeDimension(a,b);for(var c=this.getResolution(),d=[],e,f,g=0,h=b.components.length;g<h;g++)e=b.components[g],f=(e.x-this.featureDx)/c-this.offset.x|0,e=e.y/c-this.offset.y|0,0==g%3&&0==g/3?d.push("m"):1==g%3&&d.push(" c"),d.push(" "+
+f+","+e);d.push(" x e");a.path=d.join("");return a},moveRoot:function(a){var b=this.map.getLayer(a.container.id);b instanceof OpenLayers.Layer.Vector.RootContainer&&(b=this.map.getLayer(this.container.id));b&&b.renderer.clear();OpenLayers.Renderer.Elements.prototype.moveRoot.apply(this,arguments);b&&b.redraw()},importSymbol:function(a){var b=this.container.id+"-"+a,c=this.symbolCache[b];if(c)return c;c=OpenLayers.Renderer.symbol[a];if(!c)throw Error(a+" is not a valid symbol name");for(var a=new OpenLayers.Bounds(Number.MAX_VALUE,
+Number.MAX_VALUE,0,0),d=["m"],e=0;e<c.length;e+=2){var f=c[e],g=c[e+1];a.left=Math.min(a.left,f);a.bottom=Math.min(a.bottom,g);a.right=Math.max(a.right,f);a.top=Math.max(a.top,g);d.push(f);d.push(g);0==e&&d.push("l")}d.push("x e");c=d.join(" ");d=(a.getWidth()-a.getHeight())/2;0<d?(a.bottom-=d,a.top+=d):(a.left+=d,a.right-=d);c={path:c,size:a.getWidth(),left:a.left,bottom:a.bottom};return this.symbolCache[b]=c},CLASS_NAME:"OpenLayers.Renderer.VML"});
+OpenLayers.Renderer.VML.LABEL_SHIFT={l:0,c:0.5,r:1,t:0,m:0.5,b:1};
+OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5],type:null,initialize:function(a,b){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);
+OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.sphericalMercator&&(OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator),this.initMercatorParameters(),this.RESOLUTIONS.unshift(10))},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div)}catch(a){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{layerType:"MM",layerLib:"MultiMap"})},setMapObjectCenter:function(a,b){this.mapObject.goToPosition(a,b)},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition()},
+getMapObjectZoom:function(){return this.mapObject.getZoomFactor()},getMapObjectLonLatFromMapObjectPixel:function(a){a.x-=this.map.getSize().w/2;a.y-=this.map.getSize().h/2;return this.mapObject.getMapPositionAt(a)},getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.geoPosToContainerPixels(a)},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.lon,a.lat).lon:a.lon},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?
+this.forwardMercator(a.lon,a.lat).lat:a.lat},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new MMLatLon(c.lat,c.lon)):c=new MMLatLon(b,a);return c},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},getMapObjectPixelFromXY:function(a,b){return new MMPoint(a,b)},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});
+OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:!1,requestEncoding:"KVP",drillDown:!1,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:!0,infoFormat:"text/html",vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,pending:0,initialize:function(a){a=a||{};a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);if(!this.format)this.format=new OpenLayers.Format.WMSGetFeatureInfo(a.formatOptions);
+if(!0===this.drillDown)this.hover=!1;this.hover?this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250})):(a={},a[this.clickCallback]=this.getInfoForClick,this.handler=new OpenLayers.Handler.Click(this,a,this.handlerOptions.click||{}))},getInfoForClick:function(a){this.request(a.xy,{})},getInfoForHover:function(a){this.request(a.xy,{hover:!0})},cancelHover:function(){if(this.hoverRequest){--this.pending;
+if(0>=this.pending)OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait"),this.pending=0;this.hoverRequest.abort();this.hoverRequest=null}},findLayers:function(){for(var a=this.layers||this.map.layers,b=[],c,d=a.length-1;0<=d;--d)if(c=a[d],c instanceof OpenLayers.Layer.WMTS&&c.requestEncoding===this.requestEncoding&&(!this.queryVisible||c.getVisibility()))if(b.push(c),!this.drillDown||this.hover)break;return b},buildRequestOptions:function(a,b){var c=this.map.getLonLatFromPixel(b),d=
+a.getURL(new OpenLayers.Bounds(c.lon,c.lat,c.lon,c.lat)),d=OpenLayers.Util.getParameters(d),c=a.getTileInfo(c);OpenLayers.Util.extend(d,{service:"WMTS",version:a.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:c.i,j:c.j});OpenLayers.Util.applyDefaults(d,this.vendorParams);return{url:OpenLayers.Util.isArray(a.url)?a.url[0]:a.url,params:OpenLayers.Util.upperCaseObject(d),callback:function(c){this.handleResponse(b,c,a)},scope:this}},request:function(a,b){var b=b||{},c=this.findLayers();
+if(0<c.length){for(var d,e,f=0,g=c.length;f<g;f++)if(e=c[f],d=this.events.triggerEvent("beforegetfeatureinfo",{xy:a,layer:e}),!1!==d&&(++this.pending,d=this.buildRequestOptions(e,a),d=OpenLayers.Request.GET(d),!0===b.hover))this.hoverRequest=d;0<this.pending&&OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait")}},handleResponse:function(a,b,c){--this.pending;if(0>=this.pending)OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait"),this.pending=0;if(b.status&&(200>b.status||
+300<=b.status))this.events.triggerEvent("exception",{xy:a,request:b,layer:c});else{var d=b.responseXML;if(!d||!d.documentElement)d=b.responseText;var e,f;try{e=this.format.read(d)}catch(g){f=!0,this.events.triggerEvent("exception",{xy:a,request:b,error:g,layer:c})}f||this.events.triggerEvent("getfeatureinfo",{text:b.responseText,features:e,request:b,xy:a,layer:c})}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});
+OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",profile:null,CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});
+OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=a;if(a&&9==a.nodeType)a=a.documentElement;var c={};this.readNode(a,c);void 0===c.service?(a=
+new OpenLayers.Format.OGCExceptionReport,c.error=a.read(b)):this.postProcessLayers(c);return c},postProcessLayers:function(a){if(a.capability){a.capability.layers=[];for(var b=a.capability.nestedLayers,c=0,d=b.length;c<d;++c)this.processLayer(a.capability,b[c])}},processLayer:function(a,b,c){if(void 0===b.formats)b.formats=a.request.getmap.formats;if(void 0===b.infoFormats&&a.request.getfeatureinfo)b.infoFormats=a.request.getfeatureinfo.formats;var d,e;if(c){b.styles=b.styles.concat(c.styles);var f=
+"queryable,cascaded,fixedWidth,fixedHeight,opaque,noSubsets,llbbox,minScale,maxScale,attribution".split(","),g=["srs","bbox","dimensions","authorityURLs"],h;for(d=0,e=f.length;d<e;d++)h=f[d],h in c&&(null==b[h]&&(b[h]=c[h]),null==b[h]&&(-1!=OpenLayers.Util.indexOf(["cascaded","fixedWidth","fixedHeight"],h)&&(b[h]=0),-1!=OpenLayers.Util.indexOf(["queryable","opaque","noSubsets"],h)&&(b[h]=!1)));for(d=0,e=g.length;d<e;d++)h=g[d],b[h]=OpenLayers.Util.applyDefaults(b[h],c[h])}for(d=0,e=b.nestedLayers.length;d<
+e;d++)this.processLayer(a,b.nestedLayers[d],b);b.name&&a.layers.push(b)},readers:{wms:{Service:function(a,b){b.service={};this.readChildNodes(a,b.service)},Name:function(a,b){b.name=this.getChildValue(a)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},BoundingBox:function(a){var b={};b.bbox=[parseFloat(a.getAttribute("minx")),parseFloat(a.getAttribute("miny")),parseFloat(a.getAttribute("maxx")),parseFloat(a.getAttribute("maxy"))];a={x:parseFloat(a.getAttribute("resx")),
+y:parseFloat(a.getAttribute("resy"))};if(!isNaN(a.x)||!isNaN(a.y))b.res=a;return b},OnlineResource:function(a,b){b.href=this.getAttributeNS(a,this.namespaces.xlink,"href")},ContactInformation:function(a,b){b.contactInformation={};this.readChildNodes(a,b.contactInformation)},ContactPersonPrimary:function(a,b){b.personPrimary={};this.readChildNodes(a,b.personPrimary)},ContactPerson:function(a,b){b.person=this.getChildValue(a)},ContactOrganization:function(a,b){b.organization=this.getChildValue(a)},
+ContactPosition:function(a,b){b.position=this.getChildValue(a)},ContactAddress:function(a,b){b.contactAddress={};this.readChildNodes(a,b.contactAddress)},AddressType:function(a,b){b.type=this.getChildValue(a)},Address:function(a,b){b.address=this.getChildValue(a)},City:function(a,b){b.city=this.getChildValue(a)},StateOrProvince:function(a,b){b.stateOrProvince=this.getChildValue(a)},PostCode:function(a,b){b.postcode=this.getChildValue(a)},Country:function(a,b){b.country=this.getChildValue(a)},ContactVoiceTelephone:function(a,
+b){b.phone=this.getChildValue(a)},ContactFacsimileTelephone:function(a,b){b.fax=this.getChildValue(a)},ContactElectronicMailAddress:function(a,b){b.email=this.getChildValue(a)},Fees:function(a,b){var c=this.getChildValue(a);if(c&&"none"!=c.toLowerCase())b.fees=c},AccessConstraints:function(a,b){var c=this.getChildValue(a);if(c&&"none"!=c.toLowerCase())b.accessConstraints=c},Capability:function(a,b){b.capability={nestedLayers:[]};this.readChildNodes(a,b.capability)},Request:function(a,b){b.request=
+{};this.readChildNodes(a,b.request)},GetCapabilities:function(a,b){b.getcapabilities={formats:[]};this.readChildNodes(a,b.getcapabilities)},Format:function(a,b){OpenLayers.Util.isArray(b.formats)?b.formats.push(this.getChildValue(a)):b.format=this.getChildValue(a)},DCPType:function(a,b){this.readChildNodes(a,b)},HTTP:function(a,b){this.readChildNodes(a,b)},Get:function(a,b){b.get={};this.readChildNodes(a,b.get);if(!b.href)b.href=b.get.href},Post:function(a,b){b.post={};this.readChildNodes(a,b.post);
+if(!b.href)b.href=b.get.href},GetMap:function(a,b){b.getmap={formats:[]};this.readChildNodes(a,b.getmap)},GetFeatureInfo:function(a,b){b.getfeatureinfo={formats:[]};this.readChildNodes(a,b.getfeatureinfo)},Exception:function(a,b){b.exception={formats:[]};this.readChildNodes(a,b.exception)},Layer:function(a,b){var c=a.getAttributeNode("queryable"),d=c&&c.specified?a.getAttribute("queryable"):null,e=(c=a.getAttributeNode("cascaded"))&&c.specified?a.getAttribute("cascaded"):null,c=(c=a.getAttributeNode("opaque"))&&
+c.specified?a.getAttribute("opaque"):null,f=a.getAttribute("noSubsets"),g=a.getAttribute("fixedWidth"),h=a.getAttribute("fixedHeight"),d={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:d&&""!==d?"1"===d||"true"===d:null,cascaded:null!==e?parseInt(e):null,opaque:c?"1"===c||"true"===c:null,noSubsets:null!==f?"1"===f||"true"===f:null,fixedWidth:null!=g?parseInt(g):null,fixedHeight:null!=h?parseInt(h):null};b.nestedLayers.push(d);
+this.readChildNodes(a,d);if(d.name&&(e=d.name.split(":"),0<e.length))d.prefix=e[0]},Attribution:function(a,b){b.attribution={};this.readChildNodes(a,b.attribution)},LogoURL:function(a,b){b.logo={width:a.getAttribute("width"),height:a.getAttribute("height")};this.readChildNodes(a,b.logo)},Style:function(a,b){var c={};b.styles.push(c);this.readChildNodes(a,c)},LegendURL:function(a,b){var c={width:a.getAttribute("width"),height:a.getAttribute("height")};b.legend=c;this.readChildNodes(a,c)},MetadataURL:function(a,
+b){var c={type:a.getAttribute("type")};b.metadataURLs.push(c);this.readChildNodes(a,c)},DataURL:function(a,b){b.dataURL={};this.readChildNodes(a,b.dataURL)},FeatureListURL:function(a,b){b.featureListURL={};this.readChildNodes(a,b.featureListURL)},AuthorityURL:function(a,b){var c=a.getAttribute("name"),d={};this.readChildNodes(a,d);b.authorityURLs[c]=d.href},Identifier:function(a,b){var c=a.getAttribute("authority");b.identifiers[c]=this.getChildValue(a)},KeywordList:function(a,b){this.readChildNodes(a,
+b)},SRS:function(a,b){b.srs[this.getChildValue(a)]=!0}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});
+OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{wms:OpenLayers.Util.applyDefaults({WMT_MS_Capabilities:function(a,b){this.readChildNodes(a,b)},Keyword:function(a,b){b.keywords&&b.keywords.push(this.getChildValue(a))},DescribeLayer:function(a,b){b.describelayer={formats:[]};this.readChildNodes(a,b.describelayer)},GetLegendGraphic:function(a,b){b.getlegendgraphic={formats:[]};this.readChildNodes(a,b.getlegendgraphic)},GetStyles:function(a,b){b.getstyles=
+{formats:[]};this.readChildNodes(a,b.getstyles)},PutStyles:function(a,b){b.putstyles={formats:[]};this.readChildNodes(a,b.putstyles)},UserDefinedSymbolization:function(a,b){var c={supportSLD:1==parseInt(a.getAttribute("SupportSLD")),userLayer:1==parseInt(a.getAttribute("UserLayer")),userStyle:1==parseInt(a.getAttribute("UserStyle")),remoteWFS:1==parseInt(a.getAttribute("RemoteWFS"))};b.userSymbols=c},LatLonBoundingBox:function(a,b){b.llbbox=[parseFloat(a.getAttribute("minx")),parseFloat(a.getAttribute("miny")),
+parseFloat(a.getAttribute("maxx")),parseFloat(a.getAttribute("maxy"))]},BoundingBox:function(a,b){var c=OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms.BoundingBox.apply(this,[a,b]);c.srs=a.getAttribute("SRS");b.bbox[c.srs]=c},ScaleHint:function(a,b){var c=a.getAttribute("min"),d=a.getAttribute("max"),e=Math.pow(2,0.5),f=OpenLayers.INCHES_PER_UNIT.m;b.maxScale=parseFloat((c/e*f*OpenLayers.DOTS_PER_INCH).toPrecision(13));b.minScale=parseFloat((d/e*f*OpenLayers.DOTS_PER_INCH).toPrecision(13))},
+Dimension:function(a,b){var c={name:a.getAttribute("name").toLowerCase(),units:a.getAttribute("units"),unitsymbol:a.getAttribute("unitSymbol")};b.dimensions[c.name]=c},Extent:function(a,b){var c=a.getAttribute("name").toLowerCase();if(c in b.dimensions){c=b.dimensions[c];c.nearestVal="1"===a.getAttribute("nearestValue");c.multipleVal="1"===a.getAttribute("multipleValues");c.current="1"===a.getAttribute("current");c["default"]=a.getAttribute("default")||"";var d=this.getChildValue(a);c.values=d.split(",")}}},
+OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});
+OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.0050,0.0020,0.0010],displayInLayerSwitcher:!0,visible:!0,numPoints:50,targetSize:200,layerName:null,labelled:!0,labelFormat:"dm",lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(a){a=a||{};a.layerName=a.layerName||OpenLayers.i18n("Graticule");OpenLayers.Control.prototype.initialize.apply(this,
+[a]);this.labelSymbolizer.stroke=!1;this.labelSymbolizer.fill=!1;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}"},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer)this.gratLayer.destroy(),this.gratLayer=null},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var a=
+new OpenLayers.Style({},{rules:[new OpenLayers.Rule({symbolizer:{Point:this.labelSymbolizer,Line:this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({"default":a}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher})}return this.div},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.map.addLayer(this.gratLayer),this.map.events.register("moveend",this,this.update),this.update(),
+!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments)?(this.map.events.unregister("moveend",this,this.update),this.map.removeLayer(this.gratLayer),!0):!1},update:function(){var a=this.map.getExtent();if(a){this.gratLayer.destroyFeatures();var b=new OpenLayers.Projection("EPSG:4326"),c=this.map.getProjectionObject(),d=this.map.getResolution();if(c.proj&&"longlat"==c.proj.projName)this.numPoints=1;var e=this.map.getCenter(),f=new OpenLayers.Pixel(e.lon,e.lat);
+OpenLayers.Projection.transform(f,c,b);for(var e=this.targetSize*d,e=e*e,g,d=0;d<this.intervals.length;++d){g=this.intervals[d];var h=g/2,i=f.offset(new OpenLayers.Pixel(-h,-h)),h=f.offset(new OpenLayers.Pixel(h,h));OpenLayers.Projection.transform(i,b,c);OpenLayers.Projection.transform(h,b,c);if((i.x-h.x)*(i.x-h.x)+(i.y-h.y)*(i.y-h.y)<=e)break}f.x=Math.floor(f.x/g)*g;f.y=Math.floor(f.y/g)*g;var d=0,e=[f.clone()],h=f.clone(),j;do h=h.offset(new OpenLayers.Pixel(0,g)),j=OpenLayers.Projection.transform(h.clone(),
+b,c),e.unshift(h);while(a.containsPixel(j)&&1E3>++d);h=f.clone();do h=h.offset(new OpenLayers.Pixel(0,-g)),j=OpenLayers.Projection.transform(h.clone(),b,c),e.push(h);while(a.containsPixel(j)&&1E3>++d);d=0;i=[f.clone()];h=f.clone();do h=h.offset(new OpenLayers.Pixel(-g,0)),j=OpenLayers.Projection.transform(h.clone(),b,c),i.unshift(h);while(a.containsPixel(j)&&1E3>++d);h=f.clone();do h=h.offset(new OpenLayers.Pixel(g,0)),j=OpenLayers.Projection.transform(h.clone(),b,c),i.push(h);while(a.containsPixel(j)&&
+1E3>++d);g=[];for(d=0;d<i.length;++d){j=i[d].x;for(var f=[],k=null,m=Math.min(e[0].y,90),h=Math.max(e[e.length-1].y,-90),n=(m-h)/this.numPoints,m=h,h=0;h<=this.numPoints;++h){var l=new OpenLayers.Geometry.Point(j,m);l.transform(b,c);f.push(l);m+=n;l.y>=a.bottom&&!k&&(k=l)}this.labelled&&(k=new OpenLayers.Geometry.Point(k.x,a.bottom),j={value:j,label:this.labelled?OpenLayers.Util.getFormattedLonLat(j,"lon",this.labelFormat):"",labelAlign:"cb",xOffset:0,yOffset:2},this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(k,
+j)));f=new OpenLayers.Geometry.LineString(f);g.push(new OpenLayers.Feature.Vector(f))}for(h=0;h<e.length;++h)if(m=e[h].y,!(-90>m||90<m)){f=[];d=i[0].x;n=(i[i.length-1].x-d)/this.numPoints;j=d;k=null;for(d=0;d<=this.numPoints;++d)l=new OpenLayers.Geometry.Point(j,m),l.transform(b,c),f.push(l),j+=n,l.x<a.right&&(k=l);this.labelled&&(k=new OpenLayers.Geometry.Point(a.right,k.y),j={value:m,label:this.labelled?OpenLayers.Util.getFormattedLonLat(m,"lat",this.labelFormat):"",labelAlign:"rb",xOffset:-2,yOffset:2},
+this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(k,j)));f=new OpenLayers.Geometry.LineString(f);g.push(new OpenLayers.Feature.Vector(f))}this.gratLayer.addFeatures(g)}},CLASS_NAME:"OpenLayers.Control.Graticule"});
+OpenLayers.Format.WPSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.XML,{version:"1.0.0",namespaces:{ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows/1.1",wps:"http://www.opengis.net/wps/1.0.0",xlink:"http://www.w3.org/1999/xlink"},defaultPrefix:"wps",defaultSchemaLocation:"http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",complexDataInputEncoders:{},complexDataOutputParsers:{},encodeComplexDataInput:!0,parseComplexDataOutput:!0,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,
+[a]);this.options=a;this.regExes=OpenLayers.Format.OWSCommon.v1.prototype.regExes},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));if(a&&9==a.nodeType)a=a.documentElement;if("ProcessDescriptions"===a.localName)var b={service:"WPS",version:this.version};else"ExecuteResponse"===a.localName?b=new OpenLayers.Format.WPSCommon.v1_0_0.ExecuteResponse({}):"Capabilities"===a.localName&&(b=new OpenLayers.Format.WPSCommon.v1_0_0.Capabilities({}));this.readNode(a,
+b);return b},readers:{wps:{Capabilities:function(a,b){b.service=a.getAttribute("service")||"WPS";b.version=a.getAttribute("version")||this.version;if(a.getAttribute("updateSequence"))b.updateSequence=a.getAttribute("updateSequence");this.readChildNodes(a,b)},ProcessOfferings:function(a,b){b.processOfferings=[];this.readChildNodes(a,b.processOfferings)},ExecuteResponse:function(a,b){b.service=a.getAttribute("service")||"WPS";b.version=a.getAttribute("version")||this.version;if(a.getAttribute("serviceInstance"))b.serviceInstance=
+a.getAttribute("serviceInstance");if(a.getAttribute("statusLocation"))b.statusLocation=a.getAttribute("statusLocation");this.readChildNodes(a,b)},Process:function(a,b){var c={};if(a.getAttribute("wps:processVersion"))c.processVersion=a.getAttribute("wps:processVersion");c.profiles=[];this.readChildNodes(a,c);null!=b&&b instanceof Array?b.push(c):b.process=c},Status:function(a,b){var c={};if(a.getAttribute("creationTime"))c.creationTime=a.getAttribute("creationTime");this.readChildNodes(a,c);b.status=
+c},ProcessAccepted:function(a,b){b.ProcessAccepted=!0},ProcessStarted:function(a,b){b.ProcessStarted=!0;if(a.getAttribute("percentCompleted"))b.percentCompleted=a.getAttribute("percentCompleted")},ProcessPaused:function(a,b){b.processPaused=!0;if(a.getAttribute("percentCompleted"))b.percentCompleted=a.getAttribute("percentCompleted")},ProcessSucceeded:function(a,b){b.ProcessSucceeded=!0},ProcessFailed:function(a,b){b.ProcessFailed=!0},ProcessDescriptions:function(a,b){b.service=a.getAttribute("service")||
+"WPS";b.version=a.getAttribute("version")||this.version;b.processDescriptions=[];this.readChildNodes(a,b.processDescriptions)},ProcessDescription:function(a,b){var c=new OpenLayers.Format.WPSCommon.v1_0_0.ProcessDescription({});if(a.getAttribute("statusSupported"))c.statusSupported=a.getAttribute("statusSupported");if(a.getAttribute("storeSupported"))c.storeSupported=a.getAttribute("storeSupported");if(a.getAttribute("wps:processVersion"))c.processVersion=a.getAttribute("wps:processVersion");c.profiles=
+[];c.datainputs=[];c.processoutputs=[];this.readChildNodes(a,c);null!=b&&b instanceof Array?b.push(c):OpenLayers.Console.warn("...obj is not an array...")},Profile:function(a,b){var c=this.getChildValue(a);null!=b.profiles&&b.profiles instanceof Array?b.profiles.push(c):OpenLayers.Console.warn("...obj.profiles is not an array...")},WSDL:function(a,b){if(!b.wsdl)b.wsdl={};if(a.getAttribute("xlink:href"))b.wsdl=a.getAttribute("xlink:href")},DataInputs:function(a,b){if(null!=b&&!(b.datainputs instanceof
+Array))b.datainputs=[];this.readChildNodes(a,b.datainputs)},Input:function(a,b){var c={};if(a.getAttribute("minOccurs"))c.minoccurs=a.getAttribute("minOccurs");if(a.getAttribute("maxOccurs"))c.maxoccurs=a.getAttribute("maxOccurs");this.readChildNodes(a,c);null!=b&&b instanceof Array?b.push(c):OpenLayers.Console.error("...obj is not an array...")},ComplexData:function(a,b){b.type="ComplexData";if(a.getAttribute("encoding"))b.encoding=a.getAttribute("encoding");if(a.getAttribute("mimeType"))b.mimeType=
+a.getAttribute("mimeType");if(a.getAttribute("schema"))b.schema=a.getAttribute("schema");if(a.firstChild&&("Default"==a.firstChild.localName||"Supported"==a.firstChild.localName)){if(a.getAttribute("maximumMegabytes"))b.maximumMegabytes=a.getAttribute("maximumMegabytes");b["default"]={};b.supported=[];this.readChildNodes(a,b)}else if(b.complexData=[],a.firstChild)if(3==a.firstChild.nodeType||4==a.firstChild.nodeType){if(!0==this.parseComplexDataOutput&&b.identifier&&""!=b.identifier&&this.complexDataOutputParsers[b.identifier]){var c=
+this.complexDataOutputParsers[b.identifier];b.complexData.push(c.read(this.getChildValue(a)))}}else if(!0==this.parseComplexDataOutput&&b.identifier&&""!=b.identifier)for(var d=a.childNodes,e=0;e<d.length;e++)this.complexDataOutputParsers[b.identifier]&&(c=this.complexDataOutputParsers[b.identifier],b.complexData.push(c.read(d[e])));else for(e=0;e<d.length;e++)b.complexData.push(d[e])},LiteralData:function(a,b){b.type="LiteralData";if(a.getAttribute("datatype"))b.datatype=a.getAttribute("datatype");
+if(a.getAttribute("uom"))b.uom=a.getAttribute("uom");!a.firstChild||3==a.firstChild.nodeType||4==a.firstChild.nodeType?b.value=this.getChildValue(a):this.readChildNodes(a,b)},DefaultValue:function(a,b){b.defaultValue=this.getChildValue(a)},ValuesReference:function(a,b){b.valuesReference={};if(a.getAttribute("ows:reference"))b.valuesReference.reference=a.getAttribute("ows:reference");if(a.getAttribute("valuesForm"))b.valuesReference.valuesForm=a.getAttribute("valuesForm")},UOMs:function(a,b){b.uoms=
+{};b.uoms["default"]={};b.uoms.supported=[];this.readChildNodes(a,b.uoms)},BoundingBoxData:function(a,b){b.type="BoundingBoxData";if(a.getAttribute("crs"))b.crs=a.getAttribute("crs");if(a.getAttribute("dimensions"))b.dimensions=a.getAttribute("dimensions");b["default"]={};b.supported=[];this.readChildNodes(a,b)},CRS:function(a,b){var c=this.getChildValue(a);b instanceof Array?b.push(c):b.crs=c},ProcessOutputs:function(a,b){if(null!=b&&!(b.processoutputs instanceof Array))b.processoutputs=[];this.readChildNodes(a,
+b.processoutputs)},Output:function(a,b){var c={};if(a.getAttribute("asReference"))c.asReference=a.getAttribute("asReference");if(a.getAttribute("encoding"))c.encoding=a.getAttribute("encoding");if(a.getAttribute("uom"))c.uom=a.getAttribute("uom");if(a.getAttribute("schema"))c.schema=a.getAttribute("schema");if(a.getAttribute("mimeType"))c.schema=a.getAttribute("mimeType");this.readChildNodes(a,c);null!=b&&b instanceof Array&&b.push(c)},ComplexOutput:function(a,b){b.type="ComplexOutput";b["default"]=
+{};b.supported=[];this.readChildNodes(a,b)},LiteralOutput:function(a,b){b.type="LiteralOutput";b["default"]={};b.supported=[];this.readChildNodes(a,b)},BoundingBoxOutput:function(a,b){b.type="BoundingBoxOutput";b["default"]={};b.supported=[];this.readChildNodes(a,b)},Default:function(a,b){var c={};this.readChildNodes(a,c);b["default"]=c},Supported:function(a,b){var c=[];this.readChildNodes(a,c);b.supported=c},Format:function(a,b){var c={};this.readChildNodes(a,c);b instanceof Array?b.push(c):b.format=
+c},MimeType:function(a,b){b.mimetype=this.getChildValue(a)},Encoding:function(a,b){b.encoding=this.getChildValue(a)},Schema:function(a,b){b.schema=this.getChildValue(a)},Reference:function(a,b){var c={};if(a.getAttribute("xlink:href"))c.xlinkhref=a.getAttribute("xlink:href");if(a.getAttribute("href"))c.href=a.getAttribute("href");if(a.getAttribute("schema"))c.schema=a.getAttribute("schema");if(a.getAttribute("encoding"))c.encoding=a.getAttribute("encoding");if(a.getAttribute("mimeType"))c.mimeType=
+a.getAttribute("mimeType");if(a.getAttribute("method"))c.method=a.getAttribute("method");if("wps:Output"==a.parentNode.localName||"Output"==a.parentNode.localName){if(""!=c.href&&b.identifier&&""!=b.identifier)b.data={},b.data.complexData=[],b.data.complexData.push(c.href)}else if("wps:Input"==a.parentNode.locaName||"Input"==a.parentNode.locaName)c.headers=[],this.readChildNodes(a,c),b.reference=c},Body:function(a,b){var c={};c.value=this.getChildValue(a);b.body=c},BodyReference:function(a,b){b.bodyReference=
+a.getAttribute("xlink:href")||""},Data:function(a,b){var c={};if(b.identifier&&""!=b.identifier)c.identifier=b.identifier;this.readChildNodes(a,c);b.data=c},OutputDefinitions:function(a,b){if(!(b.outputdefinitions instanceof Array))b.outputdefinitions=[];this.readChildNodes(a,b.outputdefinitions)},Languages:function(a,b){var c={"default":{},supported:[]};this.readChildNodes(a,c);b.languages=c},Header:function(a,b){var c={};if(a.getAttribute("key"))c.key=a.getAttribute("key");if(a.getAttribute("value"))c.value=
+a.getAttribute("value");b.headers instanceof Array?b.headers.push(c):b.header=c}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},write:function(a){var b=null;if("GetCapabilities"==a.type)b=this.writeNode("wps:GetCapabilities",a);else if("DescribeProcess"==a.type)b=this.writeNode("wps:DescribeProcess",a);else if("Execute"==a.type)b=this.writeNode("wps:Execute",a);else throw OpenLayers.Console.error("...invalid wps request type..."),"...invalid wps request type...";(a=this.schemaLocationAttr())&&
+this.setAttributeNS(b,this.namespaces.xsi,"xsi:schemaLocation",a);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},writers:{wps:{GetCapabilities:function(a){var b=this.createElementNSPlus("wps:GetCapabilities",{attributes:{service:a.service||"WPS",language:a.language||"en-US","xsi:schemaLocation":this.schemaLocationAttr(a)}});this.writeNode("wps:AcceptVersions",a.acceptVersions,b);return b},AcceptVersions:function(a){var b=this.createElementNSPlus("wps:AcceptVersions",{});if(a instanceof
+Array)for(var c=0;c<a.length;c++)this.writeNode("ows:Version",a[c],b);return b},DescribeProcess:function(a){var b=this.createElementNSPlus("wps:DescribeProcess",{attributes:{service:a.service||"WPS",version:a.version||this.version,language:a.language||"en-US","xsi:schemaLocation":this.schemaLocationAttr(a)}});if(a.identifiers instanceof Array)for(var c=0;c<a.identifiers.length;c++)this.writeNode("ows:Identifier",a.identifiers[c],b);return b},Execute:function(a){var b=this.createElementNSPlus("wps:Execute",
+{attributes:{service:a.service||"WPS",version:a.version||this.version,language:a.language||"en-US","xsi:schemaLocation":this.schemaLocationAttr(a)}});this.writeNode("ows:Identifier",a.identifier,b);a.inputs&&0<a.inputs.length&&this.writeNode("wps:DataInputs",a.inputs,b);this.writeNode("wps:ResponseForm",a,b);return b},DataInputs:function(a){var b=this.createElementNSPlus("wps:DataInputs",{});if(a instanceof Array)for(var c=0;c<a.length;c++)this.writeNode("wps:Input",a[c],b);return b},Input:function(a){var b=
+this.createElementNSPlus("wps:Input",{});this.writeNode("ows:Identifier",a.identifier,b);switch(a.type){case "Reference":this.writeNode("wps:Reference",a.options,b);break;case "Body":var c=this.writeNode("wps:Reference",a.options,b);this.writeNode("wps:Body",a.options,c);break;case "BodyReference":c=this.writeNode("wps:Reference",a.options,b);this.writeNode("wps:BodyReference",a.options,c);break;case "ComplexData":c=this.writeNode("wps:Data",a.options,b);this.writeNode("wps:ComplexData",a.options,
+c);break;case "LiteralData":c=this.writeNode("wps:Data",a.options,b);this.writeNode("wps:LiteralData",a.options,c);break;case "BoundingBoxData":c=this.writeNode("wps:Data",a.options,b),this.writeNode("wps:BoundingBoxData",a.options,c)}return b},Reference:function(a){var b={};if(a.href)b["xlink:href"]=a.href;if(a.schema)b.schema=a.schema;if(a.encoding)b.encoding=a.encoding;if(a.mimeType)b.mimeType=a.mimeType;return this.createElementNSPlus("wps:Reference",{attributes:b})},Body:function(a){return this.createElementNSPlus("wps:Body",
+{value:a.body})},BodyReference:function(a){return this.createElementNSPlus("wps:BodyReference",{attributes:{"xlink:href":a.xlinkhref||""},value:a.bodyReference})},Data:function(){return this.createElementNSPlus("wps:Data",{})},ComplexData:function(a){var b=this.createElementNSPlus("wps:ComplexData",{attributes:{mimeType:a.mimeType||"",encoding:a.encoding||"UTF-8",schema:a.schema||""}});if(0<a.complexData.nodeType)b.appendChild(a.complexData);else if(!0==(a.encodeComplexData||this.encodeComplexDataInput)){var c=
+this.complexDataInputEncoders[a.identifier],d=a.complexDataRoot;c&&d?(a=c.writeNode(d,a.complexData,null),b.appendChild(a)):b.appendChild(this.createTextNode(a.complexData))}else b.appendChild(this.createTextNode(a.complexData));return b},LiteralData:function(a){return this.createElementNSPlus("wps:LiteralData",{attributes:{uom:a.uom,dataType:a.dataType},value:a.literalData||void 0})},BoundingBoxData:function(a){var b=this.createElementNSPlus("wps:BoundingBoxData",{attributes:{crs:a.crs||"EPSG:4326",
+dimensions:a.dimensions||""}});a.bounds=a.boundingBoxData;this.writeNode("ows:LowerCorner",a,b);this.writeNode("ows:UpperCorner",a,b);return b},ResponseForm:function(a){for(var b=this.createElementNSPlus("wps:ResponseForm",{}),c=!1,d=0;d<a.outputs.length;d++)if("ResponseDocument"==a.outputs[d].type){c=!0;break}else"RawDataOutput"==a.outputs[d].type&&this.writeNode("wps:RawDataOutput",a.outputs[d],b);if(!0==c){c=this.writeNode("wps:ResponseDocument",a,b);for(d=0;d<a.outputs.length;d++)"ResponseDocument"==
+a.outputs[d].type&&this.writeNode("wps:Output",a.outputs[d],c)}return b},RawDataOutput:function(a){var b={};if(a.options.uom)b.uom=a.options.uom;if(a.options.schema)b.schema=a.options.schema;if(a.options.mimeType)b.mimeType=a.options.mimeType;if(a.options.encoding)b.encoding=a.options.encoding;b=this.createElementNSPlus("wps:RawDataOutput",{attributes:b});this.writeNode("ows:Identifier",a.identifier,b);return b},ResponseDocument:function(a){var b={};if(null!=a.storeExecuteResponse&&void 0!=a.storeExecuteResponse)b.storeExecuteResponse=
+a.storeExecuteResponse;if(null!=a.lineage&&void 0!=a.lineage)b.lineage=a.lineage;if(null!=a.status&&void 0!=a.status)b.status=a.status;return this.createElementNSPlus("wps:ResponseDocument",{attributes:b})},Output:function(a){var b={};if(a.options.uom)b.uom=a.options.uom;if(a.options.schema)b.schema=a.options.schema;if(a.options.mimeType)b.mimeType=a.options.mimeType;if(a.options.encoding)b.encoding=a.options.encoding;if(null!=a.options.asReference&&void 0!=a.options.asReference)b.asReference=a.options.asReference;
+b=this.createElementNSPlus("wps:Output",{attributes:b});this.writeNode("ows:Identifier",a.identifier,b);return b}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},regComplexDataInputEncoder:function(a,b){this.complexDataInputEncoders[a]=b},unregComplexDataInputEncoder:function(a){this.complexDataInputEncoders[a]=void 0},regComplexDataOutputParser:function(a,b){this.complexDataOutputParsers[a]=b},unregComplexDataOutputParser:function(a){this.complexDataOutputParsers[a]=void 0},encodeDescribeProcessRequest:function(a){a.type=
+"DescribeProcess";return this.write(a)},encodeExecuteRequest:function(a){a.type="Execute";return this.write(a)},schemaLocationAttr:function(a){var a=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},a),b=OpenLayers.Util.extend({},this.schemaLocations);if(a.schema)b[a.featurePrefix]=a.schema;var a=[],c,d;for(d in b)(c=this.namespaces[d])&&a.push(c+" "+b[d]);return a.join(" ")||void 0},CLASS_NAME:"OpenLayers.Format.WPSCommon.v1_0_0"});
+OpenLayers.Format.WPSCommon.v1_0_0.Request=OpenLayers.Class({type:"Execute",identifier:"",service:"WPS",version:"1.0.0",inputs:[],outputs:[],acceptVersions:[],identifiers:[],storeExecuteResponse:!0,lineage:!0,status:!1,initialize:function(a){OpenLayers.Util.extend(this,a)},addDataInput:function(a){if(!this.inputs)this.inputs=[];if(!a.identifier)throw OpenLayers.Console.error("...missing 'identifier' from wps data input..."),"...missing 'identifier' from wps data input...";if(!a.type)throw OpenLayers.Console.error("...missing 'type' from wps data input...type must be one of the following: 'Reference', 'Body', 'BodyReference' 'ComplexData', 'LiteralData', 'BoundingBoxData'"),
+"...missing 'type' from wps data input...type must be one of the following: 'Reference', 'Body', 'BodyReference' 'ComplexData', 'LiteralData', 'BoundingBoxData'";a.options.identifier=a.identifier;this.inputs.push(a)},validateDataInputs:function(){return!0},addDataOutput:function(a){if(!this.outputs)this.outputs=[];if(!a.identifier)throw OpenLayers.Console.error("...missing 'identifier' from wps data output..."),"...missing 'identifier' from wps data output...";if(!a.type)throw OpenLayers.Console.error("...missing 'type' from wps data output...type must be one of the following: 'ResponseDocumentOutput', 'RawDataOutput'"),
+"...missing 'type' from wps data output...type must be one of the following: 'ResponseDocumentOutput', 'RawDataOutput'";this.outputs.push(a)},cleanupDataInput:function(){this.inputs=[];this.inputs.length=0},cleanupDataOutput:function(){this.outputs=[];this.outputs.length=0},CLASS_NAME:"OpenLayers.Format.WPSCommon.v1_0_0.Request"});
+OpenLayers.Format.WPSCommon.v1_0_0.Capabilities=OpenLayers.Class({service:"WPS",version:"1.0.0",processOfferings:[],languages:{},wsdl:"",initialize:function(a){OpenLayers.Util.extend(this,a)},CLASS_NAME:"OpenLayers.Format.WPSCommon.v1_0_0.Capabilities"});
+OpenLayers.Format.WPSCommon.v1_0_0.ProcessDescription=OpenLayers.Class({processVersion:"",storeSupported:!1,statusSupported:!1,identifier:"",title:"","abstract":"",profiles:[],wsdl:"",datainputs:[],processoutputs:[],initialize:function(a){OpenLayers.Util.extend(this,a)},isDataInputOptional:function(a){for(var b=0;b<this.datainputs.length;b++)if(this.datainputs[b].identifier==a&&0<this.datainputs[b].minOccurs)return!1;return!0},CLASS_NAME:"OpenLayers.Format.WPSCommon.v1_0_0.ProcessDescription"});
+OpenLayers.Format.WPSCommon.v1_0_0.ExecuteResponse=OpenLayers.Class({service:"WPS",version:"1.0.0",serviceInstance:"",statusLocation:"",process:null,status:{},datainputs:null,outputdefinitions:null,processoutputs:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.datainputs=[];this.datainputs.length=0;this.outputdefinitions=[];this.outputdefinitions.length=0;this.processoutputs=[];this.processoutputs.length=0},CLASS_NAME:"OpenLayers.Format.WPSCommon.v1_0_0.ExecuteResponse"});
+OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,autoActivate:!0,clearOnDeactivate:!1,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:!1,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.registry=OpenLayers.Util.extend({moveend:this.getState},this.registry);a={trigger:OpenLayers.Function.bind(this.previousTrigger,
+this),displayClass:this.displayClass+" "+this.displayClass+"Previous"};OpenLayers.Util.extend(a,this.previousOptions);this.previous=new OpenLayers.Control.Button(a);a={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+" "+this.displayClass+"Next"};OpenLayers.Util.extend(a,this.nextOptions);this.next=new OpenLayers.Control.Button(a);this.clear()},onPreviousChange:function(a){a&&!this.previous.active?this.previous.activate():!a&&this.previous.active&&this.previous.deactivate()},
+onNextChange:function(a){a&&!this.next.active?this.next.activate():!a&&this.next.active&&this.next.deactivate()},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var a in this)this[a]=null},setMap:function(a){this.map=a;this.next.setMap(a);this.previous.setMap(a)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw()},previousTrigger:function(){var a=this.previousStack.shift(),
+b=this.previousStack.shift();void 0!=b?(this.nextStack.unshift(a),this.previousStack.unshift(b),this.restoring=!0,this.restore(b),this.restoring=!1,this.onNextChange(this.nextStack[0],this.nextStack.length),this.onPreviousChange(this.previousStack[1],this.previousStack.length-1)):this.previousStack.unshift(a);return b},nextTrigger:function(){var a=this.nextStack.shift();if(void 0!=a)this.previousStack.unshift(a),this.restoring=!0,this.restore(a),this.restoring=!1,this.onNextChange(this.nextStack[0],
+this.nextStack.length),this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);return a},clear:function(){this.previousStack=[];this.previous.deactivate();this.nextStack=[];this.next.deactivate()},getState:function(){return{center:this.map.getCenter(),resolution:this.map.getResolution(),projection:this.map.getProjectionObject(),units:this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units}},restore:function(a){var b,c;if(this.map.getProjectionObject()==
+a.projection)c=this.map.getZoomForResolution(a.resolution),b=a.center;else{b=a.center.clone();b.transform(a.projection,this.map.getProjectionObject());c=a.units;var d=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;c=this.map.getZoomForResolution((c&&d?OpenLayers.INCHES_PER_UNIT[c]/OpenLayers.INCHES_PER_UNIT[d]:1)*a.resolution)}this.map.setCenter(b,c)},setListeners:function(){this.listeners={};for(var a in this.registry)this.listeners[a]=OpenLayers.Function.bind(function(){if(!this.restoring){this.previousStack.unshift(this.registry[a].apply(this,
+arguments));if(1<this.previousStack.length)this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);this.previousStack.length>this.limit+1&&this.previousStack.pop();if(0<this.nextStack.length)this.nextStack=[],this.onNextChange(null,0)}return!0},this)},activate:function(){var a=!1;if(this.map&&OpenLayers.Control.prototype.activate.apply(this)){null==this.listeners&&this.setListeners();for(var b in this.listeners)this.map.events.register(b,this,this.listeners[b]);a=!0;0==this.previousStack.length&&
+this.initStack()}return a},initStack:function(){this.map.getCenter()&&this.listeners.moveend()},deactivate:function(){var a=!1;if(this.map&&OpenLayers.Control.prototype.deactivate.apply(this)){for(var b in this.listeners)this.map.events.unregister(b,this,this.listeners[b]);this.clearOnDeactivate&&this.clear();a=!0}return a},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});
+OpenLayers.Protocol.Script=OpenLayers.Class(OpenLayers.Protocol,{url:null,params:null,callback:null,scope:null,format:null,callbackKey:"callback",callbackPrefix:"",pendingRequests:null,srsInBBOX:!1,initialize:function(a){a=a||{};this.params={};this.pendingRequests={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.format)this.format=new OpenLayers.Format.GeoJSON;if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var b=new OpenLayers.Format.QueryStringFilter({srsInBBOX:this.srsInBBOX});
+this.filterToParams=function(a,d){return b.write(a,d)}}},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=OpenLayers.Util.applyDefaults(a,this.options);a.params=OpenLayers.Util.applyDefaults(a.params,this.options.params);if(a.filter&&this.filterToParams)a.params=this.filterToParams(a.filter,a.params);var b=new OpenLayers.Protocol.Response({requestType:"read"}),c=this.createRequest(a.url,a.params,OpenLayers.Function.bind(function(c){b.data=c;this.handleRead(b,a)},this));
+b.priv=c;return b},createRequest:function(a,b,c){var c=OpenLayers.Protocol.Script.register(c),d="OpenLayers.Protocol.Script.registry["+c+"]",b=OpenLayers.Util.extend({},b);b[this.callbackKey]=this.callbackPrefix+d;a=OpenLayers.Util.urlAppend(a,OpenLayers.Util.getParameterString(b));b=document.createElement("script");b.type="text/javascript";b.src=a;b.id="OpenLayers_Protocol_Script_"+c;this.pendingRequests[b.id]=b;document.getElementsByTagName("head")[0].appendChild(b);return b},destroyRequest:function(a){OpenLayers.Protocol.Script.unregister(a.id.split("_").pop());
+delete this.pendingRequests[a.id];a.parentNode&&a.parentNode.removeChild(a)},handleRead:function(a,b){this.handleResponse(a,b)},handleResponse:function(a,b){if(b.callback)a.data?(a.features=this.parseFeatures(a.data),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE,this.destroyRequest(a.priv),b.callback.call(b.scope,a)},parseFeatures:function(a){return this.format.read(a)},abort:function(a){if(a)this.destroyRequest(a.priv);else for(var b in this.pendingRequests)this.destroyRequest(this.pendingRequests[b])},
+destroy:function(){this.abort();delete this.params;delete this.format;OpenLayers.Protocol.prototype.destroy.apply(this)},CLASS_NAME:"OpenLayers.Protocol.Script"});(function(){var a=OpenLayers.Protocol.Script,b=0;a.registry=[];a.register=function(c){var d=++b;a.registry[d]=function(){a.unregister(d);c.apply(this,arguments)};return d};a.unregister=function(b){delete a.registry[b]}})();
+OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(a,b,c,d){var e=[];e.push(a,b,c,d);OpenLayers.Layer.WMS.prototype.initialize.apply(this,e);this.usePost=-1==OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null})},CLASS_NAME:"OpenLayers.Layer.WMS.Post"});
+OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,layer:null,preserveAspectRatio:!1,rotate:!0,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.layer=a;if(!this.rotationHandleSymbolizer)this.rotationHandleSymbolizer={stroke:!1,pointRadius:10,fillOpacity:0,
+cursor:"pointer"};this.createBox();this.createControl()},activate:function(){var a=!1;OpenLayers.Control.prototype.activate.apply(this,arguments)&&(this.dragControl.activate(),this.layer.addFeatures([this.box]),this.rotate&&this.layer.addFeatures(this.rotationHandles),this.layer.addFeatures(this.handles),a=!0);return a},deactivate:function(){var a=!1;OpenLayers.Control.prototype.deactivate.apply(this,arguments)&&(this.layer.removeFeatures(this.handles),this.rotate&&this.layer.removeFeatures(this.rotationHandles),
+this.layer.removeFeatures([this.box]),this.dragControl.deactivate(),a=!0);a&&this.unsetFeature();return a},setMap:function(a){this.dragControl.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},setFeature:function(a,b){var b=OpenLayers.Util.applyDefaults(b,{rotation:0,scale:1,ratio:1}),c=this.rotation,d=this.center;OpenLayers.Util.extend(this,b);if(!1!==this.events.triggerEvent("beforesetfeature",{feature:a})){this.feature=a;this.activate();this._setfeature=!0;var e=this.feature.geometry.getBounds();
+this.box.move(e.getCenterLonLat());this.box.geometry.rotate(-c,d);this._angle=0;this.rotation?(c=a.geometry.clone(),c.rotate(-this.rotation,this.center),c=new OpenLayers.Feature.Vector(c.getBounds().toGeometry()),c.geometry.rotate(this.rotation,this.center),this.box.geometry.rotate(this.rotation,this.center),this.box.move(c.geometry.getBounds().getCenterLonLat()),c=c.geometry.components[0].components[0].getBounds().getCenterLonLat()):c=new OpenLayers.LonLat(e.left,e.bottom);this.handles[0].move(c);
+delete this._setfeature;this.events.triggerEvent("setfeature",{feature:a})}},unsetFeature:function(){this.active?this.deactivate():(this.feature=null,this.rotation=0,this.ratio=this.scale=1)},createBox:function(){var a=this;this.center=new OpenLayers.Geometry.Point(0,0);var b=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,
+1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,"string"==typeof this.renderIntent?null:this.renderIntent);b.geometry.move=function(b,c){a._moving=!0;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);a.center.move(b,c);delete a._moving};for(var c=function(a,b){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(a,
+b);this._handle.geometry.move(a,b)},d=function(a,b,c){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(a,b,c);this._handle.geometry.resize(a,b,c)},e=function(a,b){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(a,b);this._handle.geometry.rotate(a,b)},f=function(b,c){var d=this.x,e=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,b,c);if(!a._moving){var f=
+a.dragControl.handlers.drag.evt,g=!(!a._setfeature&&a.preserveAspectRatio)&&!(f&&f.shiftKey),h=new OpenLayers.Geometry.Point(d,e),f=a.center;this.rotate(-a.rotation,f);h.rotate(-a.rotation,f);var i=this.x-f.x,j=this.y-f.y,k=i-(this.x-h.x),h=j-(this.y-h.y);this.x=d;this.y=e;d=1;g?(j=1.0E-5>Math.abs(h)?1:j/h,d=(1.0E-5>Math.abs(k)?1:i/k)/j):(k=Math.sqrt(k*k+h*h),j=Math.sqrt(i*i+j*j)/k);a._moving=!0;a.box.geometry.rotate(-a.rotation,f);delete a._moving;a.box.geometry.resize(j,f,d);a.box.geometry.rotate(a.rotation,
+f);a.transformFeature({scale:j,ratio:d})}},g=function(b,c){var d=this.x,e=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,b,c);if(!a._moving){var f=a.dragControl.handlers.drag.evt,f=f&&f.shiftKey?45:1,g=a.center,h=this.x-g.x,i=this.y-g.y;this.x=d;this.y=e;d=Math.atan2(i-c,h-b);d=Math.atan2(i,h)-d;d*=180/Math.PI;a._angle=(a._angle+d)%360;d=a.rotation%f;if(Math.abs(a._angle)>=f||0!==d)d=Math.round(a._angle/f)*f-d,a._angle=0,a.box.geometry.rotate(d,g),a.transformFeature({rotation:d})}},h=Array(8),
+i=Array(4),j,k,m,n=0;8>n;++n){j=b.geometry.components[n];k=new OpenLayers.Feature.Vector(j.clone(),null,"string"==typeof this.renderIntent?null:this.renderIntent);if(0==n%2)m=new OpenLayers.Feature.Vector(j.clone(),null,"string"==typeof this.rotationHandleSymbolizer?null:this.rotationHandleSymbolizer),m.geometry.move=g,j._rotationHandle=m,i[n/2]=m;j.move=c;j.resize=d;j.rotate=e;k.geometry.move=f;j._handle=k;h[n]=k}this.box=b;this.rotationHandles=i;this.handles=h},createControl:function(){var a=this;
+this.dragControl=new OpenLayers.Control.DragFeature(this.layer,{documentDrag:!0,moveFeature:function(b){if(this.feature===a.feature)this.feature=a.box;OpenLayers.Control.DragFeature.prototype.moveFeature.apply(this,arguments)},onDrag:function(b){b===a.box&&(a.transformFeature({center:a.center}),a.drawHandles())},onStart:function(b){var c=!a.geometryTypes||-1!==OpenLayers.Util.indexOf(a.geometryTypes,b.geometry.CLASS_NAME),d=OpenLayers.Util.indexOf(a.handles,b),d=d+OpenLayers.Util.indexOf(a.rotationHandles,
+b);b!==a.feature&&b!==a.box&&-2==d&&c&&a.setFeature(b)},onComplete:function(){a.events.triggerEvent("transformcomplete",{feature:a.feature})}})},drawHandles:function(){for(var a=this.layer,b=0;8>b;++b)this.rotate&&0===b%2&&a.drawFeature(this.rotationHandles[b/2],this.rotationHandleSymbolizer),a.drawFeature(this.handles[b],this.renderIntent)},transformFeature:function(a){if(!this._setfeature){this.scale*=a.scale||1;this.ratio*=a.ratio||1;var b=this.rotation;this.rotation=(this.rotation+(a.rotation||
+0))%360;if(!1!==this.events.triggerEvent("beforetransform",a)){var c=this.feature,d=c.geometry,e=this.center;d.rotate(-b,e);a.scale||a.ratio?d.resize(a.scale,e,a.ratio):a.center&&c.move(a.center.getBounds().getCenterLonLat());d.rotate(this.rotation,e);this.layer.drawFeature(c);c.toState(OpenLayers.State.UPDATE);this.events.triggerEvent("transform",a)}}this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles()},destroy:function(){for(var a,b=0;8>b;++b)a=this.box.geometry.components[b],a._handle.destroy(),
+a._handle=null,a._rotationHandle&&a._rotationHandle.destroy(),a._rotationHandle=null;this.box.destroy();this.layer=this.box=null;this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.TransformFeature"});
+OpenLayers.Layer.ArcGISCache=OpenLayers.Class(OpenLayers.Layer.XYZ,{url:null,tileOrigin:null,tileSize:new OpenLayers.Size(256,256),useArcGISServer:!0,type:"png",useScales:!1,overrideDPI:!1,initialize:function(a,b,c){OpenLayers.Layer.XYZ.prototype.initialize.apply(this,arguments);if(this.resolutions)this.serverResolutions=this.resolutions,this.maxExtent=this.getMaxExtentForResolution(this.resolutions[0]);if(this.layerInfo){var d=this.layerInfo,e=new OpenLayers.Bounds(d.fullExtent.xmin,d.fullExtent.ymin,
+d.fullExtent.xmax,d.fullExtent.ymax);this.projection="EPSG:"+d.spatialReference.wkid;this.sphericalMercator=102100==d.spatialReference.wkid;this.units="esriFeet"==d.units?"ft":"m";if(d.tileInfo){this.tileSize=new OpenLayers.Size(d.tileInfo.width||d.tileInfo.cols,d.tileInfo.height||d.tileInfo.rows);this.tileOrigin=new OpenLayers.LonLat(d.tileInfo.origin.x,d.tileInfo.origin.y);var f=new OpenLayers.Geometry.Point(e.left,e.top),e=new OpenLayers.Geometry.Point(e.right,e.bottom);this.useScales?this.scales=
+[]:this.resolutions=[];this.lods=[];for(var g in d.tileInfo.lods)if(d.tileInfo.lods.hasOwnProperty(g)){var h=d.tileInfo.lods[g];this.useScales?this.scales.push(h.scale):this.resolutions.push(h.resolution);var i=this.getContainingTileCoords(f,h.resolution);h.startTileCol=i.x;h.startTileRow=i.y;i=this.getContainingTileCoords(e,h.resolution);h.endTileCol=i.x;h.endTileRow=i.y;this.lods.push(h)}this.maxExtent=this.calculateMaxExtentWithLOD(this.lods[0]);this.serverResolutions=this.resolutions;if(this.overrideDPI&&
+d.tileInfo.dpi)OpenLayers.DOTS_PER_INCH=d.tileInfo.dpi}}},getContainingTileCoords:function(a,b){return new OpenLayers.Pixel(Math.max(Math.floor((a.x-this.tileOrigin.lon)/(this.tileSize.w*b)),0),Math.max(Math.floor((this.tileOrigin.lat-a.y)/(this.tileSize.h*b)),0))},calculateMaxExtentWithLOD:function(a){var b=this.tileOrigin.lon+a.startTileCol*this.tileSize.w*a.resolution,c=this.tileOrigin.lat-a.startTileRow*this.tileSize.h*a.resolution;return new OpenLayers.Bounds(b,c-(a.endTileRow-a.startTileRow+
+1)*this.tileSize.h*a.resolution,b+(a.endTileCol-a.startTileCol+1)*this.tileSize.w*a.resolution,c)},calculateMaxExtentWithExtent:function(a,b){var c=new OpenLayers.Geometry.Point(a.left,a.top),d=new OpenLayers.Geometry.Point(a.right,a.bottom),c=this.getContainingTileCoords(c,b),d=this.getContainingTileCoords(d,b);return this.calculateMaxExtentWithLOD({resolution:b,startTileCol:c.x,startTileRow:c.y,endTileCol:d.x,endTileRow:d.y})},getUpperLeftTileCoord:function(a){return this.getContainingTileCoords(new OpenLayers.Geometry.Point(this.maxExtent.left,
+this.maxExtent.top),a)},getLowerRightTileCoord:function(a){return this.getContainingTileCoords(new OpenLayers.Geometry.Point(this.maxExtent.right,this.maxExtent.bottom),a)},getMaxExtentForResolution:function(a){var b=this.getUpperLeftTileCoord(a),c=this.getLowerRightTileCoord(a),d=this.tileOrigin.lon+b.x*this.tileSize.w*a,e=this.tileOrigin.lat-b.y*this.tileSize.h*a;return new OpenLayers.Bounds(d,e-(c.y-b.y+1)*this.tileSize.h*a,d+(c.x-b.x+1)*this.tileSize.w*a,e)},clone:function(a){null==a&&(a=new OpenLayers.Layer.ArcGISCache(this.name,
+this.url,this.options));return OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},getMaxExtent:function(){return this.maxExtent=this.getMaxExtentForResolution(this.map.getResolution())},getTileOrigin:function(){var a=this.getMaxExtent();return new OpenLayers.LonLat(a.left,a.bottom)},getURL:function(a){var b=this.getResolution(),c=this.tileOrigin.lon+b*this.tileSize.w/2,d=this.tileOrigin.lat-b*this.tileSize.h/2,a=a.getCenterLonLat(),c=Math.round(Math.abs((a.lon-c)/(b*this.tileSize.w))),d=Math.round(Math.abs((d-
+a.lat)/(b*this.tileSize.h))),a=this.map.getZoom();if(this.lods){if(b=this.lods[this.map.getZoom()],c<b.startTileCol||c>b.endTileCol||d<b.startTileRow||d>b.endTileRow)return null}else{var e=this.getUpperLeftTileCoord(b),b=this.getLowerRightTileCoord(b);if(c<e.x||c>=b.x||d<e.y||d>=b.y)return null}b=this.url;e=""+c+d+a;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(e,b));this.useArcGISServer?b+="/tile/${z}/${y}/${x}":(c="C"+this.zeroPad(c,8,16),d="R"+this.zeroPad(d,8,16),a="L"+this.zeroPad(a,2,16),b=
+b+"/${z}/${y}/${x}."+this.type);return b=OpenLayers.String.format(b,{x:c,y:d,z:a})},zeroPad:function(a,b,c){for(a=a.toString(c||10);a.length<b;)a="0"+a;return a},CLASS_NAME:"OpenLayers.Layer.ArcGISCache"});
+OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:!1,drillDown:!1,maxFeatures:10,clickCallback:"click",output:"features",layers:null,queryVisible:!1,url:null,layerUrls:null,infoFormat:"text/html",vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,initialize:function(a){a=a||{};a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);if(!this.format)this.format=new OpenLayers.Format.WMSGetFeatureInfo(a.formatOptions);
+if(!0===this.drillDown)this.hover=!1;this.hover?this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250})):(a={},a[this.clickCallback]=this.getInfoForClick,this.handler=new OpenLayers.Handler.Click(this,a,this.handlerOptions.click||{}))},getInfoForClick:function(a){this.events.triggerEvent("beforegetfeatureinfo",{xy:a.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(a.xy,
+{})},getInfoForHover:function(a){this.events.triggerEvent("beforegetfeatureinfo",{xy:a.xy});this.request(a.xy,{hover:!0})},cancelHover:function(){if(this.hoverRequest)this.hoverRequest.abort(),this.hoverRequest=null},findLayers:function(){for(var a=this.layers||this.map.layers,b=[],c,d,e=a.length-1;0<=e;--e)if(c=a[e],c instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||c.getVisibility())){d=OpenLayers.Util.isArray(c.url)?c.url[0]:c.url;if(!1===this.drillDown&&!this.url)this.url=d;(!0===this.drillDown||
+this.urlMatches(d))&&b.push(c)}return b},urlMatches:function(a){var b=OpenLayers.Util.isEquivalentUrl(this.url,a);if(!b&&this.layerUrls)for(var c=0,d=this.layerUrls.length;c<d;++c)if(OpenLayers.Util.isEquivalentUrl(this.layerUrls[c],a)){b=!0;break}return b},buildWMSOptions:function(a,b,c,d){for(var e=[],f=[],g=0,h=b.length;g<h;g++)e=e.concat(b[g].params.LAYERS),f=f.concat(this.getStyleNames(b[g]));b=b[0];g=b.projection;d=OpenLayers.Util.extend({service:"WMS",version:b.params.VERSION,request:"GetFeatureInfo",
+layers:e,query_layers:e,styles:f,bbox:this.map.getExtent().toBBOX(null,b.reverseAxisOrder()),feature_count:this.maxFeatures,height:this.map.getSize().h,width:this.map.getSize().w,format:d,info_format:b.params.INFO_FORMAT||this.infoFormat},1.3<=parseFloat(b.params.VERSION)?{crs:g,i:parseInt(c.x),j:parseInt(c.y)}:{srs:g,x:parseInt(c.x),y:parseInt(c.y)});OpenLayers.Util.applyDefaults(d,this.vendorParams);return{url:a,params:OpenLayers.Util.upperCaseObject(d),callback:function(b){this.handleResponse(c,
+b,a)},scope:this}},getStyleNames:function(a){return a.params.STYLES?a.params.STYLES:OpenLayers.Util.isArray(a.params.LAYERS)?Array(a.params.LAYERS.length):a.params.LAYERS.replace(/[^,]/g,"")},request:function(a,b){var c=this.findLayers();if(0==c.length)this.events.triggerEvent("nogetfeatureinfo"),OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");else if(b=b||{},!1===this.drillDown){var c=this.buildWMSOptions(this.url,c,a,c[0].params.FORMAT),d=OpenLayers.Request.GET(c);if(!0===b.hover)this.hoverRequest=
+d}else{this._numRequests=this._requestCount=0;this.features=[];for(var d={},e,f=0,g=c.length;f<g;f++){var h=c[f];e=OpenLayers.Util.isArray(h.url)?h.url[0]:h.url;e in d?d[e].push(h):(this._numRequests++,d[e]=[h])}for(e in d)c=d[e],c=this.buildWMSOptions(e,c,a,c[0].params.FORMAT),OpenLayers.Request.GET(c)}},triggerGetFeatureInfo:function(a,b,c){this.events.triggerEvent("getfeatureinfo",{text:a.responseText,features:c,request:a,xy:b});OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait")},
+handleResponse:function(a,b,c){var d=b.responseXML;if(!d||!d.documentElement)d=b.responseText;d=this.format.read(d);!1===this.drillDown?this.triggerGetFeatureInfo(b,a,d):(this._requestCount++,this._features="object"===this.output?(this._features||[]).concat({url:c,features:d}):(this._features||[]).concat(d),this._requestCount===this._numRequests&&(this.triggerGetFeatureInfo(b,a,this._features.concat()),delete this._features,delete this._requestCount,delete this._numRequests))},CLASS_NAME:"OpenLayers.Control.WMSGetFeatureInfo"});
+OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{wms:OpenLayers.Util.applyDefaults({WMS_Capabilities:function(a,b){this.readChildNodes(a,b)},LayerLimit:function(a,b){b.layerLimit=parseInt(this.getChildValue(a))},MaxWidth:function(a,b){b.maxWidth=parseInt(this.getChildValue(a))},MaxHeight:function(a,b){b.maxHeight=parseInt(this.getChildValue(a))},BoundingBox:function(a,b){var c=OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms.BoundingBox.apply(this,
+[a,b]);c.srs=a.getAttribute("CRS");b.bbox[c.srs]=c},CRS:function(a,b){this.readers.wms.SRS.apply(this,[a,b])},EX_GeographicBoundingBox:function(a,b){b.llbbox=[];this.readChildNodes(a,b.llbbox)},westBoundLongitude:function(a,b){b[0]=this.getChildValue(a)},eastBoundLongitude:function(a,b){b[2]=this.getChildValue(a)},southBoundLatitude:function(a,b){b[1]=this.getChildValue(a)},northBoundLatitude:function(a,b){b[3]=this.getChildValue(a)},MinScaleDenominator:function(a,b){b.maxScale=parseFloat(this.getChildValue(a)).toPrecision(16)},
+MaxScaleDenominator:function(a,b){b.minScale=parseFloat(this.getChildValue(a)).toPrecision(16)},Dimension:function(a,b){var c={name:a.getAttribute("name").toLowerCase(),units:a.getAttribute("units"),unitsymbol:a.getAttribute("unitSymbol"),nearestVal:"1"===a.getAttribute("nearestValue"),multipleVal:"1"===a.getAttribute("multipleValues"),"default":a.getAttribute("default")||"",current:"1"===a.getAttribute("current"),values:this.getChildValue(a).split(",")};b.dimensions[c.name]=c},Keyword:function(a,
+b){var c={value:this.getChildValue(a),vocabulary:a.getAttribute("vocabulary")};b.keywords&&b.keywords.push(c)}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms),sld:{UserDefinedSymbolization:function(a,b){this.readers.wms.UserDefinedSymbolization.apply(this,[a,b]);b.userSymbols.inlineFeature=1==parseInt(a.getAttribute("InlineFeature"));b.userSymbols.remoteWCS=1==parseInt(a.getAttribute("RemoteWCS"))},DescribeLayer:function(a,b){this.readers.wms.DescribeLayer.apply(this,[a,b])},GetLegendGraphic:function(a,
+b){this.readers.wms.GetLegendGraphic.apply(this,[a,b])}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Format.WMSCapabilities.v1_3_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_3,{version:"1.3.0",CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3_0"});
+OpenLayers.Process.WPS=OpenLayers.Class(OpenLayers.Process,{map:null,format:null,url:"",identifier:"",request:null,processDescription:null,executeOnInputReady:!1,callbacks:null,checkStatusInterval:2E3,initialize:function(a){OpenLayers.Process.prototype.initialize.apply(this,[a]);if(!this.url||""==this.url)throw OpenLayers.Console.error("...invalid wps end point url..."),"...invalid wps end point url...";this.events.on({processsucceeded:this._processSucceeded,processfailed:this._processFailed,processstarted:this._processCheckStatus,
+scope:this});if(!this.callbacks)this.callbacks=[];if(!this.request)this.request=OpenLayers.Format.WPSCommon.Request({identifier:a.identifier,type:"Execute",language:"en-US",storeExecuteResponse:a.storeExecuteResponse,lineage:a.lineage,status:a.status});if(!this.format)this.format=new OpenLayers.Format.WPSCommon({});this.createCallback=OpenLayers.Util.AgsUtil.createProtocolCallback;this.dispatch=OpenLayers.Util.AgsUtil.dispatch},addDataInput:function(a){this.request&&this.request.addDataInput(a)},
+addDataOutput:function(a){this.request&&this.request.addDataOutput(a)},cleanupDataInput:function(){this.request&&this.request.cleanupDataInput()},cleanupDataOutput:function(){this.request&&this.request.cleanupDataOutput()},regDataInputEncoder:function(a,b){this.format&&this.format.regComplexDataInputEncoder(a,b)},unregDataInputEncoder:function(a){this.format&&this.format.unregComplexDataInputEncoder(a)},regDataOutputParser:function(a,b){this.format&&this.format.regComplexDataOutputParser(a,b)},unregDataInputParser:function(a){this.format&&
+this.format.unregComplexDataOutputParser(a)},generateUniqueExecuteId:function(){},execute:function(a){var b=new OpenLayers.Protocol.Response({requestType:"wps:Execute"}),a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||{});var c=this.format.write(this.request);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleExecuteResponse,b,a,this),params:a.params,headers:a.headers,data:c});return b},handleExecuteResponse:function(a,b){OpenLayers.Console.debug("...handleExecuteResponse is called...");
+for(var c=[],d=0;d<this.callbacks.length;d++)"function"==typeof this.callbacks[d]&&c.push(this.callbacks[d]);for(d=0;d<b.callbacks.length;d++)"function"==typeof b.callbacks[d]&&c.push(b.callbacks[d]);d=null;if(!0==b.isRawDataOutput)d=a.priv;else{d=a.priv.responseXML;if(!d||!d.documentElement)d=a.priv.responseText;d=this.format.read(d);if(!0==d.status.ProcessSucceeded)this.events.triggerEvent("processsucceeded",{callbacks:c,executeResponse:d,scope:this});else if(!0==d.status.ProcessFailed)this.events.triggerEvent("processfailed",
+{});else if(!0==d.status.ProcessStarted||"100"!=d.status.percentCompleted||100!=d.status.percentCompleted){OpenLayers.Console.debug("...asynchronize execute...");var e=this,f=d.statusLocation,g=window.setInterval(function(){OpenLayers.loadURL(f,{},e,function(a){var b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;a=this.format.read(b);a.status.ProcessSucceeded?(a={callbacks:c,executeResponse:a,scope:this},this.events.triggerEvent("processsucceeded",a),window.clearInterval(g)):a.status.ProcessStarted?
+(a={callbacks:c,executeResponse:a,scope:this},this.events.triggerEvent("processstarted",a)):a.status.ProcessFailed&&(this.events.triggerEvent("processfailed",{}),window.clearInterval(g))},function(){this.events.triggerEvent("processfailed",{})})},this.checkStatusInterval)}}},_processSucceeded:function(a){for(var b=a.callbacks,a=a.executeResponse,c=0;c<b.length;c++){var d=b[c];"function"==typeof d&&d.apply(this,[a])}this.onProcessSucceeded(a)},_processFailed:function(a){this.onProcessFailed(a.executeResponse)},
+_processCheckStatus:function(a){this.onProcessCheckStatus(a.executeResponse)},onProcessSucceeded:function(){OpenLayers.Console.debug("...process succeeded...")},onProcessFailed:function(){OpenLayers.Console.debug("...process failed...")},onProcessCheckStatus:function(){OpenLayers.Console.debug("...process started...")},CLASS_NAME:"OpenLayers.Process.WPS"});
+OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(a,b){OpenLayers.Format.GML.prototype.initialize.apply(this,[a]);this.layer=b;if(this.layer.featureNS)this.featureNS=this.layer.featureNS;if(this.layer.options.geometry_column)this.geometryName=this.layer.options.geometry_column;if(this.layer.options.typename)this.featureName=this.layer.options.typename},write:function(a){var b=this.createElementNS(this.wfsns,
+"wfs:Transaction");b.setAttribute("version","1.0.0");b.setAttribute("service","WFS");for(var c=0;c<a.length;c++)switch(a[c].state){case OpenLayers.State.INSERT:b.appendChild(this.insert(a[c]));break;case OpenLayers.State.UPDATE:b.appendChild(this.update(a[c]));break;case OpenLayers.State.DELETE:b.appendChild(this.remove(a[c]))}return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.featureNS,"feature:"+
+this.geometryName);c.appendChild(b);b=this.createElementNS(this.featureNS,"feature:"+this.featureName);b.appendChild(c);for(var d in a.attributes){var c=this.createTextNode(a.attributes[d]),e=d;-1!=d.search(":")&&(e=d.split(":")[1]);e=this.createElementNS(this.featureNS,"feature:"+e);e.appendChild(c);b.appendChild(e)}return b},insert:function(a){var b=this.createElementNS(this.wfsns,"wfs:Insert");b.appendChild(this.createFeatureXML(a));return b},update:function(a){a.fid||OpenLayers.Console.userError(OpenLayers.i18n("noFID"));
+var b=this.createElementNS(this.wfsns,"wfs:Update");b.setAttribute("typeName",this.featurePrefix+":"+this.featureName);b.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var c=this.createElementNS(this.wfsns,"wfs:Property"),d=this.createElementNS(this.wfsns,"wfs:Name"),e=this.createTextNode(this.geometryName);d.appendChild(e);c.appendChild(d);d=this.createElementNS(this.wfsns,"wfs:Value");e=this.buildGeometryNode(a.geometry);a.layer&&e.setAttribute("srsName",a.layer.projection.getCode());
+d.appendChild(e);c.appendChild(d);b.appendChild(c);for(var f in a.attributes)c=this.createElementNS(this.wfsns,"wfs:Property"),d=this.createElementNS(this.wfsns,"wfs:Name"),d.appendChild(this.createTextNode(f)),c.appendChild(d),d=this.createElementNS(this.wfsns,"wfs:Value"),d.appendChild(this.createTextNode(a.attributes[f])),c.appendChild(d),b.appendChild(c);c=this.createElementNS(this.ogcns,"ogc:Filter");f=this.createElementNS(this.ogcns,"ogc:FeatureId");f.setAttribute("fid",a.fid);c.appendChild(f);
+b.appendChild(c);return b},remove:function(a){if(!a.fid)return OpenLayers.Console.userError(OpenLayers.i18n("noFID")),!1;var b=this.createElementNS(this.wfsns,"wfs:Delete");b.setAttribute("typeName",this.featurePrefix+":"+this.featureName);b.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var c=this.createElementNS(this.ogcns,"ogc:Filter"),d=this.createElementNS(this.ogcns,"ogc:FeatureId");d.setAttribute("fid",a.fid);c.appendChild(d);b.appendChild(c);return b},destroy:function(){this.layer=
+null},CLASS_NAME:"OpenLayers.Format.WFS"});
+OpenLayers.Format.CQL=function(){function a(a){function b(){var a=e.pop();switch(a.type){case "LOGICAL":var c=b(),g=b();return new OpenLayers.Filter.Logical({filters:[g,c],type:f[a.text.toUpperCase()]});case "NOT":return c=b(),new OpenLayers.Filter.Logical({filters:[c],type:OpenLayers.Filter.Logical.NOT});case "BETWEEN":return e.pop(),g=b(),a=b(),c=b(),new OpenLayers.Filter.Comparison({property:c,lowerBoundary:a,upperBoundary:g,type:OpenLayers.Filter.Comparison.BETWEEN});case "COMPARISON":return g=
+b(),c=b(),new OpenLayers.Filter.Comparison({property:c,value:g,type:d[a.text.toUpperCase()]});case "VALUE":return/^'.*'$/.test(a.text)?a.text.substr(1,a.text.length-2):Number(a.text);case "SPATIAL":switch(a.text.toUpperCase()){case "BBOX":var c=b(),a=b(),g=b(),h=b(),i=b();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:i,value:OpenLayers.Bounds.fromArray([h,g,a,c])});case "INTERSECTS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,
+property:c,value:g});case "WITHIN":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.WITHIN,property:c,value:g});case "CONTAINS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.CONTAINS,property:c,value:g});case "DWITHIN":return a=b(),g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,value:g,property:c,distance:Number(a)})}case "GEOMETRY":return OpenLayers.Geometry.fromWKT(a.text);default:return a.text}}
+for(var c=[],e=[];a.length;){var g=a.shift();switch(g.type){case "PROPERTY":case "GEOMETRY":case "VALUE":e.push(g);break;case "COMPARISON":case "BETWEEN":case "LOGICAL":for(var i=h[g.type];0<c.length&&h[c[c.length-1].type]<=i;)e.push(c.pop());c.push(g);break;case "SPATIAL":case "NOT":case "LPAREN":c.push(g);break;case "RPAREN":for(;0<c.length&&"LPAREN"!=c[c.length-1].type;)e.push(c.pop());c.pop();0<c.length&&"SPATIAL"==c[c.length-1].type&&e.push(c.pop());case "COMMA":case "END":break;default:throw Error("Unknown token type "+
+g.type);}}for(;0<c.length;)e.push(c.pop());a=b();if(0<e.length){a="Remaining tokens after building AST: \n";for(c=e.length-1;0<=c;c--)a+=e[c].type+": "+e[c].text+"\n";throw Error(a);}return a}var b={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('\w+'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(a){var b=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILINESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(a);
+if(b){var c=a.length,b=a.indexOf("(",b[0].length);if(-1<b)for(var d=1;b<c&&0<d;)switch(b++,a.charAt(b)){case "(":d++;break;case ")":d--}return[a.substr(0,b+1)]}},END:/^$/},c={LPAREN:["GEOMETRY","SPATIAL","PROPERTY","VALUE","LPAREN"],RPAREN:["NOT","LOGICAL","END","RPAREN"],PROPERTY:["COMPARISON","BETWEEN","COMMA"],BETWEEN:["VALUE"],COMPARISON:["VALUE"],COMMA:["GEOMETRY","VALUE","PROPERTY"],VALUE:["LOGICAL","COMMA","RPAREN","END"],SPATIAL:["LPAREN"],LOGICAL:["NOT","VALUE","SPATIAL","PROPERTY","LPAREN"],
+NOT:["PROPERTY","LPAREN"],GEOMETRY:["COMMA","RPAREN"]},d={"=":OpenLayers.Filter.Comparison.EQUAL_TO,"<>":OpenLayers.Filter.Comparison.NOT_EQUAL_TO,"<":OpenLayers.Filter.Comparison.LESS_THAN,"<=":OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,">":OpenLayers.Filter.Comparison.GREATER_THAN,">=":OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,LIKE:OpenLayers.Filter.Comparison.LIKE,BETWEEN:OpenLayers.Filter.Comparison.BETWEEN},e={},f={AND:OpenLayers.Filter.Logical.AND,OR:OpenLayers.Filter.Logical.OR},
+g={},h={RPAREN:3,LOGICAL:2,COMPARISON:1},i;for(i in d)d.hasOwnProperty(i)&&(e[d[i]]=i);for(i in f)f.hasOwnProperty(i)&&(g[f[i]]=i);return OpenLayers.Class(OpenLayers.Format,{read:function(d){var e=d,d=[],f,g=["NOT","GEOMETRY","SPATIAL","PROPERTY","LPAREN"];do{a:{f=g;for(var h=void 0,g=void 0,i=f.length,h=0;h<i;h++){var g=f[h],q=b[g]instanceof RegExp?b[g].exec(e):(0,b[g])(e);if(q){f=q[0];e=e.substr(f.length).replace(/^\s*/,"");f={type:g,text:f,remainder:e};break a}}d="ERROR: In parsing: ["+e+"], expected one of: ";
+for(h=0;h<i;h++)g=f[h],d+="\n    "+g+": "+b[g];throw Error(d);}e=f.remainder;g=c[f.type];if("END"!=f.type&&!g)throw Error("No follows list for "+f.type);d.push(f)}while("END"!=f.type);d=a(d);if(this.keepData)this.data=d;return d},write:function(a){if(a instanceof OpenLayers.Geometry)return a.toString();switch(a.CLASS_NAME){case "OpenLayers.Filter.Spatial":switch(a.type){case OpenLayers.Filter.Spatial.BBOX:return"BBOX("+a.property+","+a.value.toBBOX()+")";case OpenLayers.Filter.Spatial.DWITHIN:return"DWITHIN("+
+a.property+", "+this.write(a.value)+", "+a.distance+")";case OpenLayers.Filter.Spatial.WITHIN:return"WITHIN("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.INTERSECTS:return"INTERSECTS("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.CONTAINS:return"CONTAINS("+a.property+", "+this.write(a.value)+")";default:throw Error("Unknown spatial filter type: "+a.type);}case "OpenLayers.Filter.Logical":if(a.type==OpenLayers.Filter.Logical.NOT)return"NOT ("+this.write(a.filters[0])+
+")";for(var b="(",c=!0,d=0;d<a.filters.length;d++)c?c=!1:b+=") "+g[a.type]+" (",b+=this.write(a.filters[d]);return b+")";case "OpenLayers.Filter.Comparison":return a.type==OpenLayers.Filter.Comparison.BETWEEN?a.property+" BETWEEN "+this.write(a.lowerBoundary)+" AND "+this.write(a.upperBoundary):a.property+" "+e[a.type]+" "+this.write(a.value);case void 0:if("string"===typeof a)return"'"+a+"'";if("number"===typeof a)return""+a;default:throw Error("Can't encode: "+a.CLASS_NAME+" "+a);}},CLASS_NAME:"OpenLayers.Format.CQL"})}();
+OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{layer:null,source:null,sourceOptions:null,tolerance:null,edge:!0,deferDelete:!1,mutual:!0,targetFilter:null,sourceFilter:null,handler:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.options=a||{};this.options.source&&this.setSource(this.options.source)},setSource:function(a){this.active?(this.deactivate(),this.handler&&(this.handler.destroy(),delete this.handler),this.source=a,this.activate()):this.source=
+a},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a)if(this.source){if(this.source.events)this.source.events.on({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this})}else{if(!this.handler)this.handler=new OpenLayers.Handler.Path(this,{done:function(a){this.onSketchComplete({feature:new OpenLayers.Feature.Vector(a)})}},{layerOptions:this.sourceOptions});this.handler.activate()}return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.call(this);
+a&&this.source&&this.source.events&&this.layer.events.un({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});return a},onSketchComplete:function(a){this.feature=null;return!this.considerSplit(a.feature)},afterFeatureModified:function(a){if(a.modified){var b=a.feature;if(b.geometry instanceof OpenLayers.Geometry.LineString||b.geometry instanceof OpenLayers.Geometry.MultiLineString)this.feature=a.feature,this.considerSplit(a.feature)}},removeByGeometry:function(a,
+b){for(var c=0,d=a.length;c<d;++c)if(a[c].geometry===b){a.splice(c,1);break}},isEligible:function(a){return a.state!==OpenLayers.State.DELETE&&(a.geometry instanceof OpenLayers.Geometry.LineString||a.geometry instanceof OpenLayers.Geometry.MultiLineString)&&this.feature!==a&&(!this.targetFilter||this.targetFilter.evaluate(a.attributes))},considerSplit:function(a){var b=!1,c=!1;if(!this.sourceFilter||this.sourceFilter.evaluate(a.attributes)){for(var d=this.layer&&this.layer.features||[],e,f,g=[],h=
+[],i=this.layer===this.source&&this.mutual,j={edge:this.edge,tolerance:this.tolerance,mutual:i},k=[a.geometry],m,n,l,o=0,q=d.length;o<q;++o)if(m=d[o],this.isEligible(m)){n=[m.geometry];for(var r=0;r<k.length;++r){l=k[r];for(var p=0;p<n.length;++p)if(e=n[p],l.getBounds().intersectsBounds(e.getBounds())&&(e=l.split(e,j)))f=this.events.triggerEvent("beforesplit",{source:a,target:m}),!1!==f&&(i&&(f=e[0],1<f.length&&(f.unshift(r,1),Array.prototype.splice.apply(k,f),r+=f.length-3),e=e[1]),1<e.length&&(e.unshift(p,
+1),Array.prototype.splice.apply(n,e),p+=e.length-3))}n&&1<n.length&&(this.geomsToFeatures(m,n),this.events.triggerEvent("split",{original:m,features:n}),Array.prototype.push.apply(g,n),h.push(m),c=!0)}k&&1<k.length&&(this.geomsToFeatures(a,k),this.events.triggerEvent("split",{original:a,features:k}),Array.prototype.push.apply(g,k),h.push(a),b=!0);if(b||c){if(this.deferDelete){d=[];o=0;for(q=h.length;o<q;++o)c=h[o],c.state===OpenLayers.State.INSERT?d.push(c):(c.state=OpenLayers.State.DELETE,this.layer.drawFeature(c));
+this.layer.destroyFeatures(d,{silent:!0});o=0;for(q=g.length;o<q;++o)g[o].state=OpenLayers.State.INSERT}else this.layer.destroyFeatures(h,{silent:!0});this.layer.addFeatures(g,{silent:!0});this.events.triggerEvent("aftersplit",{source:a,features:g})}}return b},geomsToFeatures:function(a,b){var c=a.clone();delete c.geometry;for(var d,e=0,f=b.length;e<f;++e)d=c.clone(),d.geometry=b[e],d.state=OpenLayers.State.INSERT,b[e]=d},destroy:function(){this.active&&this.deactivate();OpenLayers.Control.prototype.destroy.call(this)},
+CLASS_NAME:"OpenLayers.Control.Split"});
+OpenLayers.Protocol.SOS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol,{fois:null,formatOptions:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);if(!a.format)this.format=new OpenLayers.Format.SOSGetFeatureOfInterest(this.formatOptions)},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||
+{});var b=new OpenLayers.Protocol.Response({requestType:"read"}),c=this.format,c=OpenLayers.Format.XML.prototype.write.apply(c,[c.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,b,a),data:c});return b},handleRead:function(a,b){if(b.callback){var c=a.priv;200<=c.status&&300>c.status?(a.features=this.parseFeatures(c),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE;
+b.callback.call(b.scope,a)}},parseFeatures:function(a){var b=a.responseXML;if(!b||!b.documentElement)b=a.responseText;return!b||0>=b.length?null:this.format.read(b)},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});
+OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{jpeg:"jpg",gif:"gif",png:"png",png8:"png",png24:"png",dithered:"png"},DEFAULT_FORMAT:"jpeg",initialize:function(a,b,c,d){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT]},getURL:function(a){var a=this.adjustBounds(a),b=this.map.getResolution(),c=Math.round(1E4*this.map.getScale())/1E4,d=Math.round(a.left/b),a=-Math.round(a.top/
+b),b=Math.floor(d/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w,e=Math.floor(a/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h,f=this.url;OpenLayers.Util.isArray(f)&&(f=this.selectUrl(paramsString,f));return[f,"/",this.params.map,"/",c,"/",this.params.g.replace(/\s/g,"_"),"/def/t",e,"/l",b,"/t",a,"l",d,".",this.extension].join("")},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});
+OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(a,b){var c=arguments,c=this.processXMLNode(b),c=[a,c.lonlat,c];OpenLayers.Feature.prototype.initialize.apply(this,c);this.createMarker();this.layer.addMarker(this.marker)},destroy:function(){null!=this.marker&&this.layer.removeMarker(this.marker);OpenLayers.Feature.prototype.destroy.apply(this,arguments)},processXMLNode:function(a){a=OpenLayers.Ajax.getElementsByTagNameNS(a,"http://www.opengis.net/gml","gml","Point");
+a=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(a[0],"http://www.opengis.net/gml","gml","coordinates")[0]).split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(a[0]),parseFloat(a[1])),id:null}},CLASS_NAME:"OpenLayers.Feature.WFS"});
+OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,format:"image/png",serverResolutions:null,initialize:function(a,b,c,d){this.layername=c;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,{},d]);this.extension=this.format.split("/")[1].toLowerCase();this.extension="jpg"==this.extension?"jpeg":this.extension},clone:function(a){null==a&&(a=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,
+[a])},getURL:function(a){function b(a,b){for(var a=""+a,c=[],d=0;d<b;++d)c.push("0");return c.join("").substring(0,b-a.length)+a}var c=this.getServerResolution(),d=this.maxExtent,e=this.tileSize,f=Math.round((a.left-d.left)/(c*e.w)),a=Math.round((a.bottom-d.bottom)/(c*e.h)),c=null!=this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,c):this.map.getZoom(),f=[this.layername,b(c,2),b(parseInt(f/1E6),3),b(parseInt(f/1E3)%1E3,3),b(parseInt(f)%1E3,3),b(parseInt(a/1E6),3),b(parseInt(a/
+1E3)%1E3,3),b(parseInt(a)%1E3,3)+"."+this.extension].join("/"),c=this.url;OpenLayers.Util.isArray(c)&&(c=this.selectUrl(f,c));c="/"==c.charAt(c.length-1)?c:c+"/";return c+f},CLASS_NAME:"OpenLayers.Layer.TileCache"});
+OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",initialize:function(a){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[a])},readers:{wms:OpenLayers.Util.applyDefaults({SRS:function(a,b){b.srs[this.getChildValue(a)]=!0}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});
+OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",initialize:function(a){OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.initialize.apply(this,[a])},readers:{wms:OpenLayers.Util.applyDefaults({VendorSpecificCapabilities:function(a,b){b.vendorSpecific={tileSets:[]};this.readChildNodes(a,b.vendorSpecific)},TileSet:function(a,b){var c={srs:{},bbox:{},resolutions:[]};this.readChildNodes(a,c);b.tileSets.push(c)},Resolutions:function(a,
+b){for(var c=this.getChildValue(a).split(" "),d=0,e=c.length;d<e;d++)""!=c[d]&&b.resolutions.push(parseFloat(c[d]))},Width:function(a,b){b.width=parseInt(this.getChildValue(a))},Height:function(a,b){b.height=parseInt(this.getChildValue(a))},Layers:function(a,b){b.layers=this.getChildValue(a)},Styles:function(a,b){b.styles=this.getChildValue(a)}},OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC"});
+OpenLayers.Format.WMSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",initialize:function(a){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[a])},readers:{wms:OpenLayers.Util.applyDefaults({SRS:function(a,b){for(var c=this.getChildValue(a).split(/ +/),d=0,e=c.length;d<e;d++)b.srs[c[d]]=!0}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});
+OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:!1,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:!0,encodeBBOX:!1,extractAttributes:!1,initialize:function(a,b,c,d){void 0==d&&(d={});if(d.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector)this.vectorMode=!1;c=OpenLayers.Util.upperCaseObject(c);OpenLayers.Util.extend(d,
+{reportError:!1});var e=[];e.push(a,d);OpenLayers.Layer.Vector.prototype.initialize.apply(this,e);if(!this.renderer||!this.vectorMode){this.vectorMode=!1;if(!d.featureClass)d.featureClass=OpenLayers.Feature.WFS;OpenLayers.Layer.Markers.prototype.initialize.apply(this,e)}if(this.params&&this.params.typename&&!this.options.typename)this.options.typename=this.params.typename;if(!this.options.geometry_column)this.options.geometry_column="the_geom";this.params=OpenLayers.Util.applyDefaults(c,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));
+this.url=b},destroy:function(){this.vectorMode?OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments):OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.tile&&this.tile.destroy();this.format=this.featureClass=this.ratio=this.tile=null;this.formatObject&&this.formatObject.destroy&&this.formatObject.destroy();this.extractAttributes=this.encodeBBOX=this.vectorMode=this.formatOptions=this.formatObject=null},setMap:function(a){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,
+arguments);var b={extractAttributes:this.extractAttributes};OpenLayers.Util.extend(b,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject()))b.externalProjection=this.projection,b.internalProjection=this.map.getProjectionObject();this.formatObject=this.format?new this.format(b):new OpenLayers.Format.GML(b)}else OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments)},moveTo:function(a,b,c){this.vectorMode?OpenLayers.Layer.Vector.prototype.moveTo.apply(this,
+arguments):OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(c)return!1;b&&this.vectorMode&&this.renderer.clear();if(this.options.minZoomLevel&&(OpenLayers.Console.warn(OpenLayers.i18n("minZoomLevelError")),this.map.getZoom()<this.options.minZoomLevel))return null;null==a&&(a=this.map.getExtent());var d=null==this.tile,e=!d&&!this.tile.bounds.containsBounds(a);if(b||d||!c&&e){var d=a.getCenterLonLat(),e=a.getWidth()*this.ratio,f=a.getHeight()*this.ratio,d=new OpenLayers.Bounds(d.lon-
+e/2,d.lat-f/2,d.lon+e/2,d.lat+f/2),e=this.map.getSize();e.w*=this.ratio;e.h*=this.ratio;var f=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(d.left,d.top)),g=this.getFullRequestString(),h=null,i=this.params.filter||this.params.FILTER,h=i?{FILTER:i}:{BBOX:this.encodeBBOX?d.toBBOX():d.toArray()};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var j=d.clone();j.transform(this.map.getProjectionObject(),this.projection);if(!i)h.BBOX=this.encodeBBOX?j.toBBOX():j.toArray()}g+=
+"&"+OpenLayers.Util.getParameterString(h);if(this.tile)this.vectorMode?(this.destroyFeatures(),this.renderer.clear()):this.clearMarkers(),this.removeTileMonitoringHooks(this.tile),this.tile.destroy(),this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,f,d,g,e);this.addTileMonitoringHooks(this.tile);this.tile.draw()}},addTileMonitoringHooks:function(a){a.onLoadStart=function(){this==this.layer.tile&&this.layer.events.triggerEvent("loadstart")};a.events.register("loadstart",a,a.onLoadStart);a.onLoadEnd=
+function(){this==this.layer.tile&&(this.layer.events.triggerEvent("tileloaded"),this.layer.events.triggerEvent("loadend"))};a.events.register("loadend",a,a.onLoadEnd);a.events.register("unload",a,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,scope:a})},onMapResize:function(){this.vectorMode?OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments):OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,
+arguments)},display:function(){this.vectorMode?OpenLayers.Layer.Vector.prototype.display.apply(this,arguments):OpenLayers.Layer.Markers.prototype.display.apply(this,arguments)},mergeNewParams:function(a){a=[OpenLayers.Util.upperCaseObject(a)];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,a)},clone:function(a){null==a&&(a=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.getOptions()));return a=this.vectorMode?OpenLayers.Layer.Vector.prototype.clone.apply(this,
+[a]):OpenLayers.Layer.Markers.prototype.clone.apply(this,[a])},getFullRequestString:function(a,b){var c=this.projection.getCode()||this.map.getProjection();this.params.SRS="none"==c?null:c;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments)},commit:function(){if(!this.writer){var a={};if(this.map&&!this.projection.equals(this.map.getProjectionObject()))a.externalProjection=this.projection,a.internalProjection=this.map.getProjectionObject();this.writer=new OpenLayers.Format.WFS(a,
+this)}a=this.writer.write(this.features);OpenLayers.Request.POST({url:this.url,data:a,success:this.commitSuccess,failure:this.commitFailure,scope:this})},commitSuccess:function(a){a=a.responseText;if(-1!=a.indexOf("SUCCESS")){this.commitReport(OpenLayers.i18n("commitSuccess",{response:a}));for(a=0;a<this.features.length;a++)this.features[a].state=null}else(-1!=a.indexOf("FAILED")||-1!=a.indexOf("Exception"))&&this.commitReport(OpenLayers.i18n("commitFailed",{response:a}))},commitFailure:function(){},
+commitReport:function(a){OpenLayers.Console.userError(a)},refresh:function(){if(this.tile)this.vectorMode?(this.renderer.clear(),this.features.length=0):(this.clearMarkers(),this.markers.length=0),this.tile.draw()},getDataExtent:function(){return this.vectorMode?OpenLayers.Layer.Vector.prototype.getDataExtent.apply(this):OpenLayers.Layer.Markers.prototype.getDataExtent.apply(this)},setOpacity:function(a){this.vectorMode?OpenLayers.Layer.Vector.prototype.setOpacity.apply(this,[a]):OpenLayers.Layer.Markers.prototype.setOpacity.apply(this,
+[a])},CLASS_NAME:"OpenLayers.Layer.WFS"});
+OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{roundedCorner:!0,roundedCornerColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:!0,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[]},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);
+this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({addlayer:this.redraw,changelayer:this.redraw,removelayer:this.redraw,changebaselayer:this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({addlayer:this.redraw,changelayer:this.redraw,removelayer:this.redraw,changebaselayer:this.redraw,scope:this})},draw:function(){OpenLayers.Control.prototype.draw.apply(this);
+this.loadContents();this.outsideViewport||this.minimizeControl();this.redraw();return this.div},clearLayersArray:function(a){var b=this[a+"Layers"];if(b)for(var c=0,d=b.length;c<d;c++){var e=b[c];OpenLayers.Event.stopObservingElement(e.inputElem);OpenLayers.Event.stopObservingElement(e.labelSpan)}this[a+"LayersDiv"].innerHTML="";this[a+"Layers"]=[]},checkRedraw:function(){var a=!1;if(!this.layerStates.length||this.map.layers.length!=this.layerStates.length)a=!0;else for(var b=0,c=this.layerStates.length;b<
+c;b++){var d=this.layerStates[b],e=this.map.layers[b];if(d.name!=e.name||d.inRange!=e.inRange||d.id!=e.id||d.visibility!=e.visibility){a=!0;break}}return a},redraw:function(){if(!this.checkRedraw())return this.div;this.clearLayersArray("base");this.clearLayersArray("data");var a=!1,b=!1,c=this.map.layers.length;this.layerStates=Array(c);for(var d=0;d<c;d++){var e=this.map.layers[d];this.layerStates[d]={name:e.name,visibility:e.visibility,inRange:e.inRange,id:e.id}}var f=this.map.layers.slice();this.ascending||
+f.reverse();d=0;for(c=f.length;d<c;d++){var e=f[d],g=e.isBaseLayer;if(e.displayInLayerSwitcher){g?b=!0:a=!0;var h=g?e==this.map.baseLayer:e.getVisibility(),i=document.createElement("input");i.id=this.id+"_input_"+e.name;i.name=g?this.id+"_baseLayers":e.name;i.type=g?"radio":"checkbox";i.value=e.name;i.checked=h;i.defaultChecked=h;if(!g&&!e.inRange)i.disabled=!0;var j={inputElem:i,layer:e,layerSwitcher:this};OpenLayers.Event.observe(i,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,
+j));h=document.createElement("span");OpenLayers.Element.addClass(h,"labelSpan");if(!g&&!e.inRange)h.style.color="gray";h.innerHTML=e.name;h.style.verticalAlign=g?"bottom":"baseline";OpenLayers.Event.observe(h,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,j));j=document.createElement("br");(g?this.baseLayers:this.dataLayers).push({layer:e,inputElem:i,labelSpan:h});e=g?this.baseLayersDiv:this.dataLayersDiv;e.appendChild(i);e.appendChild(h);e.appendChild(j)}}this.dataLbl.style.display=
+a?"":"none";this.baseLbl.style.display=b?"":"none";return this.div},onInputClick:function(a){if(!this.inputElem.disabled)"radio"==this.inputElem.type?(this.inputElem.checked=!0,this.layer.map.setBaseLayer(this.layer)):(this.inputElem.checked=!this.inputElem.checked,this.layerSwitcher.updateMap());OpenLayers.Event.stop(a)},onLayerClick:function(){this.updateMap()},updateMap:function(){for(var a=0,b=this.baseLayers.length;a<b;a++){var c=this.baseLayers[a];c.inputElem.checked&&this.map.setBaseLayer(c.layer,
+!1)}a=0;for(b=this.dataLayers.length;a<b;a++)c=this.dataLayers[a],c.layer.setVisibility(c.inputElem.checked)},maximizeControl:function(a){this.div.style.width="";this.div.style.height="";this.showControls(!1);null!=a&&OpenLayers.Event.stop(a)},minimizeControl:function(a){this.div.style.width="0px";this.div.style.height="0px";this.showControls(!0);null!=a&&OpenLayers.Event.stop(a)},showControls:function(a){this.maximizeDiv.style.display=a?"":"none";this.minimizeDiv.style.display=a?"none":"";this.layersDiv.style.display=
+a?"none":""},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layersDiv=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");
+this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("Base Layer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("Overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,
+"dataLayersDiv");this.ascending?(this.layersDiv.appendChild(this.baseLbl),this.layersDiv.appendChild(this.baseLayersDiv),this.layersDiv.appendChild(this.dataLbl),this.layersDiv.appendChild(this.dataLayersDiv)):(this.layersDiv.appendChild(this.dataLbl),this.layersDiv.appendChild(this.dataLayersDiv),this.layersDiv.appendChild(this.baseLbl),this.layersDiv.appendChild(this.baseLayersDiv));this.div.appendChild(this.layersDiv);this.roundedCorner&&(OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",
+bgColor:"transparent",color:this.roundedCornerColor,blend:!1}),OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75));var a=OpenLayers.Util.getImagesLocation(),b=new OpenLayers.Size(18,18);this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,b,a+"layer-switcher-maximize.png","absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,
+this));this.div.appendChild(this.maximizeDiv);a+="layer-switcher-minimize.png";b=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,b,a,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv)},ignoreEvent:function(a){OpenLayers.Event.stop(a)},
+mouseDown:function(a){this.isMouseDown=!0;this.ignoreEvent(a)},mouseUp:function(a){if(this.isMouseDown)this.isMouseDown=!1,this.ignoreEvent(a)},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});
+OpenLayers.Tile.BackBufferable=OpenLayers.Class(OpenLayers.Tile,{backBufferMode:null,backBufferData:null,initialize:function(){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.backBufferMode=(this.layer.singleTile&&1)|(-1!=OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)&&2);this.backBufferData={};if(!this.size)this.size=new OpenLayers.Size(256,256)},draw:function(){var a=OpenLayers.Tile.prototype.shouldDraw.apply(this,arguments);a&&this.updateBackBuffer();
+this.clear();a||this.resetBackBuffer();return a},setBackBufferData:function(){this.backBufferData=OpenLayers.Util.extend(this.backBufferData,{bounds:this.bounds,resolution:this.layer.map.getResolution()})},updateBackBuffer:function(){var a=this.layer,b=a.map,c=this.backBufferMode,d=this.backBufferData,e=this.getTile(),f=d.tile,g=d.resolution,g=g?g/b.getResolution():1,h=e&&e.parentNode!==a.div,i=!(e&&0<e.childNodes.length),j=!f&&this.isLoading;if(!(1==g?c&1:c&2)||h||i||j)this.setBackBufferData();else{if(!f)f=
+this.createBackBuffer(),a.events.register("loadend",this,this.resetBackBuffer),d.tile=f,a.div.insertBefore(f,e);a=b.getPixelFromLonLat({lon:d.bounds.left,lat:d.bounds.top});c=b.layerContainerDiv.style;b=parseInt(c.left,10);c=parseInt(c.top,10);d=f.style;d.left=a.x-b+"px";d.top=a.y-c+"px";d.width=this.size.w*g+"px";d.height=this.size.h*g+"px";return f}},resetBackBuffer:function(){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.removeBackBuffer();this.setBackBufferData()},removeBackBuffer:function(){var a=
+this.backBufferData,b=a.tile;delete a.tile;a=b&&b.parentNode;b&&a.removeChild(b)},destroy:function(){this.removeBackBuffer();this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.backBufferData=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments)}});
+OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:!1,read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));return this.parseFeatures(a)},write:function(a){var b;if(OpenLayers.Util.isArray(a)){b=this.createElementNSPlus("atom:feed");b.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));
+for(var c=0,d=a.length;c<d;c++)b.appendChild(this.buildEntryNode(a[c]))}else b=this.buildEntryNode(a);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},buildContentNode:function(a){var b=this.createElementNSPlus("atom:content",{attributes:{type:a.type||null}});if(a.src)b.setAttribute("src",a.src);else if("text"==a.type||null==a.type)b.appendChild(this.createTextNode(a.value));else if("html"==a.type){if("string"!=typeof a.value)throw"HTML content must be in form of an escaped string";b.appendChild(this.createTextNode(a.value))}else"xhtml"==
+a.type?b.appendChild(a.value):"xhtml"==a.type||a.type.match(/(\+|\/)xml$/)?b.appendChild(a.value):b.appendChild(this.createTextNode(a.value));return b},buildEntryNode:function(a){var b=a.attributes,c=b.atom||{},d=this.createElementNSPlus("atom:entry");if(c.authors)for(var e=OpenLayers.Util.isArray(c.authors)?c.authors:[c.authors],f=0,g=e.length;f<g;f++)d.appendChild(this.buildPersonConstructNode("author",e[f]));if(c.categories)for(var e=OpenLayers.Util.isArray(c.categories)?c.categories:[c.categories],
+h,f=0,g=e.length;f<g;f++)h=e[f],d.appendChild(this.createElementNSPlus("atom:category",{attributes:{term:h.term,scheme:h.scheme||null,label:h.label||null}}));c.content&&d.appendChild(this.buildContentNode(c.content));if(c.contributors){e=OpenLayers.Util.isArray(c.contributors)?c.contributors:[c.contributors];f=0;for(g=e.length;f<g;f++)d.appendChild(this.buildPersonConstructNode("contributor",e[f]))}a.fid&&d.appendChild(this.createElementNSPlus("atom:id",{value:a.fid}));if(c.links){e=OpenLayers.Util.isArray(c.links)?
+c.links:[c.links];f=0;for(g=e.length;f<g;f++)h=e[f],d.appendChild(this.createElementNSPlus("atom:link",{attributes:{href:h.href,rel:h.rel||null,type:h.type||null,hreflang:h.hreflang||null,title:h.title||null,length:h.length||null}}))}c.published&&d.appendChild(this.createElementNSPlus("atom:published",{value:c.published}));c.rights&&d.appendChild(this.createElementNSPlus("atom:rights",{value:c.rights}));if(c.summary||b.description)d.appendChild(this.createElementNSPlus("atom:summary",{value:c.summary||
+b.description}));d.appendChild(this.createElementNSPlus("atom:title",{value:c.title||b.title||this.defaultEntryTitle}));c.updated&&d.appendChild(this.createElementNSPlus("atom:updated",{value:c.updated}));a.geometry&&(b=this.createElementNSPlus("georss:where"),b.appendChild(this.buildGeometryNode(a.geometry)),d.appendChild(b));return d},initGmlParser:function(){this.gmlParser=new OpenLayers.Format.GML.v3({xy:this.xy,featureNS:"http://example.com#feature",internalProjection:this.internalProjection,
+externalProjection:this.externalProjection})},buildGeometryNode:function(a){this.gmlParser||this.initGmlParser();return this.gmlParser.writeNode("feature:_geometry",a).firstChild},buildPersonConstructNode:function(a,b){var c=["uri","email"],d=this.createElementNSPlus("atom:"+a);d.appendChild(this.createElementNSPlus("atom:name",{value:b.name}));for(var e=0,f=c.length;e<f;e++)b[c[e]]&&d.appendChild(this.createElementNSPlus("atom:"+c[e],{value:b[c[e]]}));return d},getFirstChildValue:function(a,b,c,
+d){return(a=this.getElementsByTagNameNS(a,b,c))&&0<a.length?this.getChildValue(a[0],d):d},parseFeature:function(a){var b={},c=null,d=null,e=null,f=this.namespaces.atom;this.parsePersonConstructs(a,"author",b);d=this.getElementsByTagNameNS(a,f,"category");if(0<d.length)b.categories=[];for(var g=0,h=d.length;g<h;g++){c={};c.term=d[g].getAttribute("term");if(e=d[g].getAttribute("scheme"))c.scheme=e;if(e=d[g].getAttribute("label"))c.label=e;b.categories.push(c)}d=this.getElementsByTagNameNS(a,f,"content");
+if(0<d.length){c={};if(e=d[0].getAttribute("type"))c.type=e;(e=d[0].getAttribute("src"))?c.src=e:(c.value="text"==c.type||"html"==c.type||null==c.type?this.getFirstChildValue(a,f,"content",null):"xhtml"==c.type||c.type.match(/(\+|\/)xml$/)?this.getChildEl(d[0]):this.getFirstChildValue(a,f,"content",null),b.content=c)}this.parsePersonConstructs(a,"contributor",b);b.id=this.getFirstChildValue(a,f,"id",null);d=this.getElementsByTagNameNS(a,f,"link");if(0<d.length)b.links=Array(d.length);for(var i=["rel",
+"type","hreflang","title","length"],g=0,h=d.length;g<h;g++){c={};c.href=d[g].getAttribute("href");for(var j=0,k=i.length;j<k;j++)(e=d[g].getAttribute(i[j]))&&(c[i[j]]=e);b.links[g]=c}if(c=this.getFirstChildValue(a,f,"published",null))b.published=c;if(c=this.getFirstChildValue(a,f,"rights",null))b.rights=c;if(c=this.getFirstChildValue(a,f,"summary",null))b.summary=c;b.title=this.getFirstChildValue(a,f,"title",null);b.updated=this.getFirstChildValue(a,f,"updated",null);c={title:b.title,description:b.summary,
+atom:b};a=this.parseLocations(a)[0];a=new OpenLayers.Feature.Vector(a,c);a.fid=b.id;return a},parseFeatures:function(a){var b=[],c=this.getElementsByTagNameNS(a,this.namespaces.atom,"entry");0==c.length&&(c=[a]);for(var a=0,d=c.length;a<d;a++)b.push(this.parseFeature(c[a]));return b},parseLocations:function(a){var b=this.namespaces.georss,c={components:[]},d=this.getElementsByTagNameNS(a,b,"where");if(d&&0<d.length){this.gmlParser||this.initGmlParser();for(var e=0,f=d.length;e<f;e++)this.gmlParser.readChildNodes(d[e],
+c)}c=c.components;if((d=this.getElementsByTagNameNS(a,b,"point"))&&0<d.length){e=0;for(f=d.length;e<f;e++){var g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s+/);2!=g.length&&(g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s*,\s*/));c.push(new OpenLayers.Geometry.Point(g[1],g[0]))}}var h=this.getElementsByTagNameNS(a,b,"line");if(h&&0<h.length)for(var i,e=0,f=h.length;e<f;e++){d=OpenLayers.String.trim(h[e].firstChild.nodeValue).split(/\s+/);i=[];for(var j=0,k=d.length;j<
+k;j+=2)g=new OpenLayers.Geometry.Point(d[j+1],d[j]),i.push(g);c.push(new OpenLayers.Geometry.LineString(i))}if((a=this.getElementsByTagNameNS(a,b,"polygon"))&&0<a.length){e=0;for(f=a.length;e<f;e++){d=OpenLayers.String.trim(a[e].firstChild.nodeValue).split(/\s+/);i=[];j=0;for(k=d.length;j<k;j+=2)g=new OpenLayers.Geometry.Point(d[j+1],d[j]),i.push(g);c.push(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(c)]))}}if(this.internalProjection&&this.externalProjection){e=0;for(f=c.length;e<
+f;e++)c[e]&&c[e].transform(this.externalProjection,this.internalProjection)}return c},parsePersonConstructs:function(a,b,c){for(var d=[],e=this.namespaces.atom,a=this.getElementsByTagNameNS(a,e,b),f=["uri","email"],g=0,h=a.length;g<h;g++){var i={};i.name=this.getFirstChildValue(a[g],e,"name",null);for(var j=0,k=f.length;j<k;j++){var m=this.getFirstChildValue(a[g],e,f[j],null);m&&(i[f[j]]=m)}d.push(i)}0<d.length&&(c[b+"s"]=d)},CLASS_NAME:"OpenLayers.Format.Atom"});
+OpenLayers.Layer.Raster=OpenLayers.Class(OpenLayers.Layer,{needsUpdate:!1,initialize:function(a){var a=a||{},b=a.data;delete a.data;OpenLayers.Layer.prototype.initialize.apply(this,[a.name,a]);this.canvas=document.createElement("canvas");this.canvas.style.position="absolute";this.div.appendChild(this.canvas);this.context=this.canvas.getContext("2d");b&&this.setData(b)},setData:function(a){this.clearData();this.data=a;a.events.register("update",this,this.onDataUpdate)},clearData:function(){this.data&&
+(this.data.events.unregister("update",this,this.onDataUpdate),delete this.data)},moveTo:function(){this.needsUpdate=!0;OpenLayers.Layer.prototype.moveTo.apply(this,arguments);window.setTimeout(OpenLayers.Function.bind(this.afterMoveTo,this),0)},afterMoveTo:function(){if(this.needsUpdate)this.onDataUpdate()},onDataUpdate:function(){var a=this.map;if(a){var b=a.getSize(),c=this.data.numCols(),d=this.data.numRows(),a=a.layerContainerDiv.style;this.canvas.width=c;this.canvas.height=d;this.canvas.style.top=
+-parseInt(a.top)+"px";this.canvas.style.left=-parseInt(a.left)+"px";this.canvas.style.width=b.w+"px";this.canvas.style.height=b.h+"px";var b=this.context.createImageData(c,d),e=b.data;this.data.forEach(function(a,b){var c=4*b;a.length||(a=[a,a,a]);e[c+0]=a[0];e[c+1]=a[1];e[c+2]=a[2];e[c+3]=3<a.length?a[3]:255});this.context.putImageData(b,0,0);this.needsUpdate=!1}},CLASS_NAME:"OpenLayers.Layer.Raster"});
+OpenLayers.Control.AgsFindTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:!1,asynchronous:!1,initialize:function(a,b,c,d){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[a,b,c,d]);this.taskParameters={contains:!1,outSpatialReference:null,returnGeometry:!0,layerIds:[],searchFields:[],searchText:""};this._resultsParser={parser:this.adapter.parseAgsResults.findResults,context:this.adapter};this.execute=this._bindFunction(this.execute,this);this.active=!1;this.activate=function(){return!1};
+this.deactivate=function(){return!1}},execute:function(a,b){var c=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(c,this.taskParameters);var d=[],d=d.concat(this.taskCallbacks),d=d.concat(b),e=this._createCallbacks(this,d,{});if(!1==this.asynchronous){var d=new esri.tasks.FindTask(this.url),e=this._createCallbacks(this,[this.onExecuteComplete],{callback:e}),f=this.errback||null;try{var g=this.adapter.encodeAgsFindParameters(c)}catch(h){throw h;}d.execute(g,e,f)}else throw OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsFindTask ..."),
+"...'asynchronous' should always be set to 'false' for AgsFindTask ...";},CLASS_NAME:"OpenLayers.Control.AgsFindTask"});
Added: sandbox/august/trunk/build/OpenLayers-jsmin.js
--- sandbox/august/trunk/build/OpenLayers-jsmin.js	                        (rev 0)
+++ sandbox/august/trunk/build/OpenLayers-jsmin.js	2011-12-21 20:49:34 UTC (rev 12448)
@@ -0,0 +1,3292 @@
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */(function(){if(window.google&&google.gears){return;}
+var factory=null;if(typeof GearsFactory!='undefined'){factory=new GearsFactory();}else{try{factory=new ActiveXObject('Gears.Factory');if(factory.getBuildInfo().indexOf('ie_mobile')!=-1){factory.privateSetGlobalObject(this);}}catch(e){if((typeof navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){factory=document.createElement("object");factory.style.display="none";factory.width=0;factory.height=0;factory.type="application/x-googlegears";document.documentElement.appendChild(factory);}}}
+if(!factory){return;}
+if(!window.google){google={};}
+if(!google.gears){google.gears={factory:factory};}})();var OpenLayers={VERSION_NUMBER:"$Revision: 11704 $",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
+return(function(){return l;});})()};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.prototype.initialize.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
+return C;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(P){var C=function(){P.call(this);};var newArgs=[C].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,newArgs);return C.prototype;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
+OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
+return destination;};OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
+return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,reqFeatures:null,priv:null,error:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.SQL=OpenLayers.Class(OpenLayers.Protocol,{databaseName:'ol',tableName:"ol_vector_features",postReadFiltering:true,initialize:function(options){
 OpenLayers.Protocol.prototype.initialize.apply(this,[options]);},destroy:function(){OpenLayers.Protocol.prototype.destroy.apply(this);},supported:function(){return false;},evaluateFilter:function(feature,filter){return filter&&this.postReadFiltering?filter.evaluate(feature):true;},CLASS_NAME:"OpenLayers.Protocol.SQL"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Lang={code:null,defaultC
 ode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.BROWSER_NAME=="msie")?navigator.userLanguage:navigator.language;}
+var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
+if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
+if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
+OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary&&dictionary[key];if(!message){message=key;}
+if(context){message=OpenLayers.String.format(message,context);}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s\s*/,'').replace(/\s\s*$/,'');},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1,len=oStringList.length;i<len;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
+return camelizedString;},format:function(template,context,args){if(!context){context=window;}
+var replacer=function(str,match){var replacement;var subs=match.split(/\.+/);for(var i=0;i<subs.length;i++){if(i==0){replacement=context;}
+replacement=replacement[subs[i]];}
+if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
+if(typeof replacement=='undefined'){return'undefined';}else{return replacement;}};return template.replace(OpenLayers.String.tokenRegEx,replacer);},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);},numericIf:function(value){return OpenLayers.String.isNumeric(value)?parseFloat(value):value;}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
+if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
+if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
+return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
+var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
+var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
+var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
+str=integer+dsep+rem;}
+return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Number.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
+OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};},False:function(){return false;},True:function(){return true;},Void:function(){}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
+if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
+OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
+for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
+return selected;}};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
+if(bottom!=null){this.bottom=OpenLayers.Util.toFloat(bottom);}
+if(right!=null){this.right=OpenLayers.Util.toFloat(right);}
+if(top!=null){this.top=OpenLayers.Util.toFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
+return equals;},toString:function(){return[this.left,this.bottom,this.right,this.top].join(",");},toArray:function(reverseAxisOrder){if(reverseAxisOrder===true){return[this.bottom,this.left,this.top,this.right];}else{return[this.left,this.bottom,this.right,this.top];}},toBBOX:function(decimal,reverseAxisOrder){if(decimal==null){decimal=6;}
+var mult=Math.pow(10,decimal);var xmin=Math.round(this.left*mult)/mult;var ymin=Math.round(this.bottom*mult)/mult;var xmax=Math.round(this.right*mult)/mult;var ymax=Math.round(this.top*mult)/mult;if(reverseAxisOrder===true){return ymin+","+xmin+","+ymax+","+xmax;}else{return xmin+","+ymin+","+xmax+","+ymax;}},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){if(!this.centerLonLat){this.centerLonLat=new Op
 enLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);}
+return this.centerLonLat;},scale:function(ratio,origin){if(origin==null){origin=this.getCenterLonLat();}
+var origx,origy;if(origin.CLASS_NAME=="OpenLayers.LonLat"){origx=origin.lon;origy=origin.lat;}else{origx=origin.x;origy=origin.y;}
+var left=(this.left-origx)*ratio+origx;var bottom=(this.bottom-origy)*ratio+origy;var right=(this.right-origx)*ratio+origx;var top=(this.top-origy)*ratio+origy;return new OpenLayers.Bounds(left,bottom,right,top);},add:function(x,y){if((x==null)||(y==null)){throw new TypeError('Bounds.add cannot receive null values');}
+return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
+if(bounds){this.centerLonLat=null;if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
+if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
+if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
+if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,options){if(typeof options==="boolean"){options={inclusive:options};}
+options=options||{};var contains=this.contains(ll.lon,ll.lat,options.inclusive),worldBounds=options.worldBounds;if(worldBounds&&!contains){var worldWidth=worldBounds.getWidth();ll=ll.clone();var worldCenterX=(worldBounds.left+worldBounds.right)/2;var worldsAway=Math.round((ll.lon-worldCenterX)/worldWidth);ll.lon-=(worldsAway*worldWidth);contains=this.containsLonLat(ll,{inclusive:options.inclusive});}
+return contains;},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
+if(x==null||y==null){return false;}
+x=OpenLayers.Util.toFloat(x);y=OpenLayers.Util.toFloat(y);var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
+return contains;},intersectsBounds:function(bounds,options){if(typeof options==="boolean"){options={inclusive:options};}
+options=options||{};if(options.worldBounds){var self=this.wrapDateLine(options.worldBounds);bounds=bounds.wrapDateLine(options.worldBounds);}else{self=this;}
+if(options.inclusive==null){options.inclusive=true;}
+var intersects=false;var mightTouch=(self.left==bounds.right||self.right==bounds.left||self.top==bounds.bottom||self.bottom==bounds.top);if(options.inclusive||!mightTouch){var inBottom=(((bounds.bottom>=self.bottom)&&(bounds.bottom<=self.top))||((self.bottom>=bounds.bottom)&&(self.bottom<=bounds.top)));var inTop=(((bounds.top>=self.bottom)&&(bounds.top<=self.top))||((self.top>bounds.bottom)&&(self.top<bounds.top)));var inLeft=(((bounds.left>=self.left)&&(bounds.left<=self.right))||((self.left>=bounds.left)&&(self.left<=bounds.right)));var inRight=(((bounds.right>=self.left)&&(bounds.right<=self.right))||((self.right>=bounds.left)&&(self.right<=bounds.right)));intersects=((inBottom||inTop)&&(inLeft||inRight));}
+if(options.worldBounds&&!intersects){var world=options.worldBounds;var width=world.getWidth();var selfCrosses=!world.containsBounds(self);var boundsCrosses=!world.containsBounds(bounds);if(selfCrosses&&!boundsCrosses){bounds=bounds.add(-width,0);intersects=self.intersectsBounds(bounds,{inclusive:options.inclusive});}else if(boundsCrosses&&!selfCrosses){self=self.add(-width,0);intersects=bounds.intersectsBounds(self,{inclusive:options.inclusive});}}
+return intersects;},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
+if(inclusive==null){inclusive=true;}
+var bottomLeft=this.contains(bounds.left,bounds.bottom,inclusive);var bottomRight=this.contains(bounds.right,bounds.bottom,inclusive);var topLeft=this.contains(bounds.left,bounds.top,inclusive);var topRight=this.contains(bounds.right,bounds.top,inclusive);return(partial)?(bottomLeft||bottomRight||topLeft||topRight):(bottomLeft&&bottomRight&&topLeft&&topRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){this.centerLonLat=null;var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(
 ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){var width=maxExtent.getWidth();while(newBounds.left<maxExtent.left&&newBounds.right-rightTolerance<=maxExtent.left){newBounds=newBounds.add(width,0);}
+while(newBounds.left+leftTolerance>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-width,0);}
+var newLeft=newBounds.left+leftTolerance;if(newLeft<maxExtent.right&&newLeft>maxExtent.left&&newBounds.right-rightTolerance>maxExtent.right){newBounds=newBounds.add(-width,0);}}
+return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str,reverseAxisOrder){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds,reverseAxisOrder);};OpenLayers.Bounds.fromArray=function(bbox,reverseAxisOrder){return reverseAxisOrder===true?new OpenLayers.Bounds(bbox[1],bbox[0],bbox[3],bbox[2]):new OpenLayers.Bounds(bbox[0],bbox[1],bbox[2],bbox[3]);};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=OpenLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:fun
 ction(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = 'none';"}));for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='none';}}},show:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = '';"}));for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='';}}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'display')!='none'){return{width:element.offsetWidth,height:element.offsetHeight};}
+var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;var originalDisplay=els.display;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display=originalDisplay;els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},hasClass:function(element,name){var names=element.className;return(!!names&&new RegExp("(^|\\s)"+name+"(\\s|$)").test(names));},addClass:function(element,name){if(!OpenLayers.Element.hasClass(element,name)){element.className+=(element.className?" ":"")+name;}
+return element;},removeClass:function(element,name){var names=element.className;if(names){element.className=OpenLayers.String.trim(names.replace(new RegExp("(^|\\s+)"+name+"(\\s+|$)")," "));}
+return element;},toggleClass:function(element,name){if(OpenLayers.Element.hasClass(element,name)){OpenLayers.Element.removeClass(element,name);}else{OpenLayers.Element.addClass(element,name);}
+return element;},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=null;if(element&&element.style){value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
+var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}}
+return value=='auto'?null:value;}};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=OpenLayers.Util.toFloat(lon);this.lat=OpenLayers.Util.toFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){throw new TypeError('LonLat.add cannot receive null values');}
+return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(lon),this.lat+OpenLayers.Util.toFloat(lat));},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
+return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
+while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
+return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(pair[0],pair[1]);};OpenLayers.LonLat.fromArray=function(arr){var gotArr=OpenLayers.Util.isArray(arr),lon=gotArr&&arr[0],lat=gotArr&&arr[1];return new OpenLayers.LonLat(lon,lat);};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
+return equals;},distanceTo:function(px){return Math.sqrt(Math.pow(this.x-px.x,2)+
+Math.pow(this.y-px.y,2));},add:function(x,y){if((x==null)||(y==null)){throw new TypeError('Pixel.add cannot receive null values');}
+return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0,len=arguments.length;i<len;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
+if(arguments.length==1){return element;}
+elements.push(element);}
+return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};OpenLayers.Util.isArray=function(a){return(Object.prototype.toString.call(a)==='[object Array]');};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
+OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
+return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){if(typeof array.indexOf=="function"){return array.indexOf(obj);}else{for(var i=0,len=array.length;i<len;i++){if(array[i]==obj){return i;}}
+return-1;}};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
+if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
+if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
+if(position){element.style.position=position;}
+if(border){element.style.border=border;}
+if(overflow){element.style.overflow=overflow;}
+if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
+if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="absolute";}
+OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="relative";}
+OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";function display(){image.style.display="";OpenLayers.Event.stopObservingElement(image);}
+OpenLayers.Event.observe(image,"load",display);OpenLayers.Event.observe(image,"error",display);}
+image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
+return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
+OpenLayers.Util.alphaHackNeeded=(filter&&(version>=5.5)&&(version<7));}
+return OpenLayers.Util.alphaHackNeeded;};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,position,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){if(div.style.display!="none"){div.style.display="inline-block";}
+if(sizing==null){sizing="scale";}
+div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
+img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,delayDisplay);div.appendChild(img);OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){to=to||{};var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+if(!fromIsEvt&&from&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
+return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];var item;for(var itemIndex=0,len=value.length;itemIndex<len;itemIndex++){item=value[itemIndex];encodedItemArray.push(encodeURIComponent((item===null||item===undefined)?"":item));}
+encodedValue=encodedItemArray.join(",");}
+else{encodedValue=encodeURIComponent(value);}
+paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
+return paramsArray.join("&");};OpenLayers.Util.urlAppend=function(url,paramStr){var newUrl=url;if(paramStr){var parts=(url+" ").split(/[?&]/);newUrl+=(parts.pop()===" "?paramStr:parts.length?"&"+paramStr:"?"+paramStr);}
+return newUrl;};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0,len=arguments.length;i<len;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
+return returnValue;};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
+if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
+return(target!=div);};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(number,precision){if(precision==null){precision=OpenLayers.Util.DEFAULT_PRECISION;}
+if(typeof number!=="number"){number=parseFloat(number);}
+return precision===0?number:parseFloat(number.toPrecision(precision));};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.deg=function(x){return x*180/Math.PI;};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};OpenLayers.Util.distVincenty=function(p1,p2){var ct=OpenLayers.Util.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
+(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
+var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
+if(iterLimit==0){return NaN;}
+var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.destinationVincenty=function(lonlat,brng,dist){var u=OpenLayers.Util;var ct=u.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var lon1=lonlat.lon;var lat1=lonlat.lat;var s=dist;var alpha1=u.rad(brng);var sinAlpha1=Math.sin(alpha1);var cosAlpha1=Math.cos(alpha1);var tanU1=(1-f)*Math.tan(u.rad(lat1));var cosU1=1/Math.sqrt((1+tanU1*tanU1)),sinU1=tanU1*cosU1;var sigma1=Math.atan2(tanU1,cosAlpha1);var sinAlpha=cosU1*sinAlpha1;var cosSqAlpha=1-sinAlpha*sinAlpha;var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var sigma=s/(b*A),sigmaP=2*Math.PI;while(Math.abs(sigma-sigmaP)>1e-12){var cos2SigmaM=Math.cos(2*sigma1+sigma);var sinSigma=Math.sin(sigma);var cosSigma=Math.cos(sigma);var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2Sigm
 aM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));sigmaP=sigma;sigma=s/(b*A)+deltaSigma;}
+var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=(url===null||url===undefined)?window.location.href:url;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0,len=pairs.length;i<len;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=keyValue[0];try{key=decodeURIComponent(key);}catch(err){key=unescape(key);}
+var value=(keyValue[1]||'').replace(/\+/g," ");try{value=decodeURIComponent(value);}catch(err){value=unescape(value);}
+value=value.split(",");if(value.length==1){value=value[0];}
+parameters[key]=value;}}
+return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
+OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.02540005080010160020;OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"Inch":OpenLayers.INCHES_PER_UNIT.inches,"Meter":1.0/OpenLayers.METERS_PER_INCH,"Foot":0.30480060960121920243/OpenLayers.METERS_PER_INCH,"IFoot":0.30480000000000000000/OpenLayers.METERS_PER_INCH,"ClarkeFoot":0.3047972651151/OpenLayers.METERS_PER_INCH,"SearsFoot":0.30479947153867624624/OpenLayers.METERS_PER_INCH,"GoldCoastFoot":0.30479971018150881758/OpenLayers.METERS_PER_INCH,"IInch":0.02540000000000000000/OpenLayers.METERS_PER_INCH,"MicroInch":0.00002540000000000000/OpenLayers.METERS_PER_INCH,"Mil
 ":0.00000002540000000000/OpenLayers.METERS_PER_INCH,"Centimeter":0.01000000000000000000/OpenLayers.METERS_PER_INCH,"Kilometer":1000.00000000000000000000/OpenLayers.METERS_PER_INCH,"Yard":0.91440182880365760731/OpenLayers.METERS_PER_INCH,"SearsYard":0.914398414616029/OpenLayers.METERS_PER_INCH,"IndianYard":0.91439853074444079983/OpenLayers.METERS_PER_INCH,"IndianYd37":0.91439523/OpenLayers.METERS_PER_INCH,"IndianYd62":0.9143988/OpenLayers.METERS_PER_INCH,"IndianYd75":0.9143985/OpenLayers.METERS_PER_INCH,"IndianFoot":0.30479951/OpenLayers.METERS_PER_INCH,"IndianFt37":0.30479841/OpenLayers.METERS_PER_INCH,"IndianFt62":0.3047996/OpenLayers.METERS_PER_INCH,"IndianFt75":0.3047995/OpenLayers.METERS_PER_INCH,"Mile":1609.34721869443738887477/OpenLayers.METERS_PER_INCH,"IYard":0.91440000000000000000/OpenLayers.METERS_PER_INCH,"IMile":1609.34400000000000000000/OpenLayers.METERS_PER_INCH,"NautM":1852.00000000000000000000/OpenLayers.METERS_PER_INCH,"Lat-66":110943.316488932731/OpenLayers
 .METERS_PER_INCH,"Lat-83":110946.25736872234125/OpenLayers.METERS_PER_INCH,"Decimeter":0.10000000000000000000/OpenLayers.METERS_PER_INCH,"Millimeter":0.00100000000000000000/OpenLayers.METERS_PER_INCH,"Dekameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Decameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Hectometer":100.00000000000000000000/OpenLayers.METERS_PER_INCH,"GermanMeter":1.0000135965/OpenLayers.METERS_PER_INCH,"CaGrid":0.999738/OpenLayers.METERS_PER_INCH,"ClarkeChain":20.1166194976/OpenLayers.METERS_PER_INCH,"GunterChain":20.11684023368047/OpenLayers.METERS_PER_INCH,"BenoitChain":20.116782494375872/OpenLayers.METERS_PER_INCH,"SearsChain":20.11676512155/OpenLayers.METERS_PER_INCH,"ClarkeLink":0.201166194976/OpenLayers.METERS_PER_INCH,"GunterLink":0.2011684023368047/OpenLayers.METERS_PER_INCH,"BenoitLink":0.20116782494375872/OpenLayers.METERS_PER_INCH,"SearsLink":0.2011676512155/OpenLayers.METERS_PER_INCH,"Rod":5.02921005842012/OpenLayers.METERS_
 PER_INCH,"IntnlChain":20.1168/OpenLayers.METERS_PER_INCH,"IntnlLink":0.201168/OpenLayers.METERS_PER_INCH,"Perch":5.02921005842012/OpenLayers.METERS_PER_INCH,"Pole":5.02921005842012/OpenLayers.METERS_PER_INCH,"Furlong":201.1684023368046/OpenLayers.METERS_PER_INCH,"Rood":3.778266898/OpenLayers.METERS_PER_INCH,"CapeFoot":0.3047972615/OpenLayers.METERS_PER_INCH,"Brealey":375.00000000000000000000/OpenLayers.METERS_PER_INCH,"ModAmFt":0.304812252984505969011938/OpenLayers.METERS_PER_INCH,"Fathom":1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":50000.0/OpenLayers.METERS_PER_INCH,"150kilometers":150000.0/OpenLayers.METERS_PER_INCH});OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"mm":OpenLayers.INCHES_PER_UNIT["Meter"]/1000.0,"cm":OpenLayers.INCHES_PER_UNIT["Meter"]/100.0,"dm":OpenLayers.INCHES_PER_UNIT["Meter"]*100.0,"km":OpenLayers.INCHES_PER_UNIT["Meter"]*1000.0,"kmi":OpenLayers.INCHES_PER_UNIT["nmi"],"fath":OpenLayers.INCHES_PER
 _UNIT["Fathom"],"ch":OpenLayers.INCHES_PER_UNIT["IntnlChain"],"link":OpenLayers.INCHES_PER_UNIT["IntnlLink"],"us-in":OpenLayers.INCHES_PER_UNIT["inches"],"us-ft":OpenLayers.INCHES_PER_UNIT["Foot"],"us-yd":OpenLayers.INCHES_PER_UNIT["Yard"],"us-ch":OpenLayers.INCHES_PER_UNIT["GunterChain"],"us-mi":OpenLayers.INCHES_PER_UNIT["Mile"],"ind-yd":OpenLayers.INCHES_PER_UNIT["IndianYd37"],"ind-ft":OpenLayers.INCHES_PER_UNIT["IndianFt37"],"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){var resolution;if(scale){if(units==null){units="degrees";}
+var normScale=OpenLayers.Util.normalizeScale(scale);resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);}
+return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
+var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var pos=[0,0];var viewportElement=OpenLayers.Util.getViewportElement();if(!forElement||forElement==window||forElement==viewportElement){return pos;}
+var BUGGY_GECKO_BOX_OBJECT=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(forElement,'position')=='absolute'&&(forElement.style.top==''||forElement.style.left=='');var parent=null;var box;if(forElement.getBoundingClientRect){box=forElement.getBoundingClientRect();var scrollTop=viewportElement.scrollTop;var scrollLeft=viewportElement.scrollLeft;pos[0]=box.left+scrollLeft;pos[1]=box.top+scrollTop;}else if(document.getBoxObjectFor&&!BUGGY_GECKO_BOX_OBJECT){box=document.getBoxObjectFor(forElement);var vpBox=document.getBoxObjectFor(viewportElement);pos[0]=box.screenX-vpBox.screenX;pos[1]=box.screenY-vpBox.screenY;}else{pos[0]=forElement.offsetLeft;pos[1]=forElement.offsetTop;parent=forElement.offsetParent;if(parent!=forElement){while(parent){pos[0]+=parent.offsetLeft;pos[1]+=parent.offsetTop;parent=parent.offsetParent;}}
+var browser=OpenLayers.BROWSER_NAME;if(browser=="opera"||(browser=="safari"&&OpenLayers.Element.getStyle(forElement,'position')=='absolute')){pos[1]-=document.body.offsetTop;}
+parent=forElement.offsetParent;while(parent&&parent!=document.body){pos[0]-=parent.scrollLeft;if(browser!="opera"||parent.tagName!='TR'){pos[1]-=parent.scrollTop;}
+parent=parent.offsetParent;}}
+return pos;};OpenLayers.Util.getViewportElement=function(){var viewportElement=arguments.callee.viewportElement;if(viewportElement==undefined){viewportElement=(OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!='CSS1Compat')?document.body:document.documentElement;arguments.callee.viewportElement=viewportElement;}
+return viewportElement;};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(key!=="args"){if(urlObj1[key]!=urlObj2[key]){return false;}}}
+for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
+delete urlObj2.args[key];}
+for(var key in urlObj2.args){return false;}
+return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};if(!(/^\w+:\/\//).test(url)){var loc=window.location;var port=loc.port?":"+loc.port:"";var fullUrl=loc.protocol+"//"+loc.host.split(":").shift()+port;if(url.indexOf("/")===0){url=fullUrl+url;}else{var parts=loc.pathname.split("/");parts.pop();url=fullUrl+parts.join("/")+"/"+url;}}
+if(options.ignoreCase){url=url.toLowerCase();}
+var a=document.createElement('a');a.href=url;var urlObject={};urlObject.host=a.host.split(":").shift();urlObject.protocol=a.protocol;if(options.ignorePort80){urlObject.port=(a.port=="80"||a.port=="0")?"":a.port;}else{urlObject.port=(a.port==""||a.port=="0")?"80":a.port;}
+urlObject.hash=(options.ignoreHash||a.hash==="#")?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
+urlObject.args=OpenLayers.Util.getParameters(queryString);urlObject.pathname=(a.pathname.charAt(0)=="/")?a.pathname:"/"+a.pathname;return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
+return head;};OpenLayers.IS_GECKO=(function(){var ua=navigator.userAgent.toLowerCase();return ua.indexOf("webkit")==-1&&ua.indexOf("gecko")!=-1;})();OpenLayers.BROWSER_NAME=(function(){var name="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){name="opera";}else if(ua.indexOf("msie")!=-1){name="msie";}else if(ua.indexOf("safari")!=-1){name="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){name="firefox";}else{name="mozilla";}}
+return name;})();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size,options){var w,h;var container=document.createElement("div");container.style.visibility="hidden";var containerElement=(options&&options.containerElement)?options.containerElement:document.body;if(size){if(size.w){w=size.w;container.style.width=w+"px";}else if(size.h){h=size.h;container.style.height=h+"px";}}
+if(options&&options.displayClass){container.className=options.displayClass;}
+var content=document.createElement("div");content.innerHTML=contentHTML;content.style.overflow="visible";if(content.childNodes){for(var i=0,l=content.childNodes.length;i<l;i++){if(!content.childNodes[i].style)continue;content.childNodes[i].style.overflow="visible";}}
+container.appendChild(content);containerElement.appendChild(container);var parentHasPositionAbsolute=false;var parent=container.parentNode;while(parent&&parent.tagName.toLowerCase()!="body"){var parentPosition=OpenLayers.Element.getStyle(parent,"position");if(parentPosition=="absolute"){parentHasPositionAbsolute=true;break;}else if(parentPosition&&parentPosition!="static"){break;}
+parent=parent.parentNode;}
+if(!parentHasPositionAbsolute){container.style.position="absolute";}
+if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
+if(!h){h=parseInt(content.scrollHeight);}
+container.removeChild(content);containerElement.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
+return scrollbarWidth;};OpenLayers.Util.getFormattedLonLat=function(coordinate,axis,dmsOption){if(!dmsOption){dmsOption='dms';}
+coordinate=(coordinate+540)%360-180;var abscoordinate=Math.abs(coordinate);var coordinatedegrees=Math.floor(abscoordinate);var coordinateminutes=(abscoordinate-coordinatedegrees)/(1/60);var tempcoordinateminutes=coordinateminutes;coordinateminutes=Math.floor(coordinateminutes);var coordinateseconds=(tempcoordinateminutes-coordinateminutes)/(1/60);coordinateseconds=Math.round(coordinateseconds*10);coordinateseconds/=10;if(coordinateseconds>=60){coordinateseconds-=60;coordinateminutes+=1;if(coordinateminutes>=60){coordinateminutes-=60;coordinatedegrees+=1;}}
+if(coordinatedegrees<10){coordinatedegrees="0"+coordinatedegrees;}
+var str=coordinatedegrees+"\u00B0";if(dmsOption.indexOf('dm')>=0){if(coordinateminutes<10){coordinateminutes="0"+coordinateminutes;}
+str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
+str+=coordinateseconds+'"';}}
+if(axis=="lon"){str+=coordinate<0?OpenLayers.i18n("W"):OpenLayers.i18n("E");}else{str+=coordinate<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");}
+return str;};OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:false,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},destroy:function(){},read:function(data){throw new Error('Read not implemented.');},write:function(object){throw new Error('Write not implemented.');},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,nativeJSON:(function(){return!!(window.JSON&&typeof JSON.parse=="function"&&typeof JSON.stringify=="function");})(),read:function(json,filter){var object;if(this.nativeJSON){object=JSON.parse(json,filter);}else try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){object=eval('('+json+')');if(typeof filter==='function'){function walk(
 k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
+return filter(k,v);}
+object=walk('',object);}}}catch(e){}
+if(this.keepData){this.data=object;}
+return object;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){try{json=(!this.pretty&&this.nativeJSON)?JSON.stringify(value):this.serialize[type].apply(this,[value]);}catch(err){OpenLayers.Console.error("Trouble serializing: "+err);}}
+return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
+return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
+if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
+if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
+var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0,len=array.length;i<len;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),json);}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);})+'"';}
+return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
+return'"'+date.getFullYear()+'-'+
+format(date.getMonth()+1)+'-'+
+format(date.getDate())+'T'+
+format(date.getHours())+':'+
+format(date.getMinutes())+':'+
+format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
+if(this.layer!=null&&this.marker!=null){this.layer.removeMarker(this.marker);}
+this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
+if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
+return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){if(!this.popup){var anchor=(this.marker)?this.marker.icon:null;var popupClass=this.popupClass?this.popupClass:OpenLayers.Popup.AnchoredBubble;this.popup=new popupClass(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
+if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
+this.popup.feature=this;}
+return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
+this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
+this.geometry=null;this.modified=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
+return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
+return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
+var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
+var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
 lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvent
 s:"visiblePainted",cursor:"inherit"},'delete':{display:"none"}};OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;wkt=wkt.replace(/[\n\r]/g," ");var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
+if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&type!="geometrycollection"&&typeof features=="object"){for(var i=0,len=features.length;i<len;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
+return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
+var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
+for(var i=0,len=collection.length;i<len;++i){if(isCollection&&i>0){pieces.push(',');}
+geometry=collection[i].geometry;pieces.push(this.extractGeometry(geometry));}
+if(isCollection){pieces.push(')');}
+return pieces.join('');},extractGeometry:function(geometry){var type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var wktType=type=='collection'?'GEOMETRYCOLLECTION':type.toUpperCase();var data=wktType+'('+this.extract[type].apply(this,[geometry])+')';return data;},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push('('+
+this.extract.point.apply(this,[multipoint.components[i]])+')');}
+return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push('('+
+this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
+return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push('('+
+this.extract.linestring.apply(this,[polygon.components[i]])+')');}
+return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push('('+
+this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
+return array.join(',');},'collection':function(collection){var array=[];for(var i=0,len=collection.components.length;i<len;++i){array.push(this.extractGeometry.apply(this,[collection.components[i]]));}
+return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var point;var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){point=points[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.point.apply(this,[point]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=lines.length;i<len;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=rings.length;i<len;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0,len=polygons.length;i<len;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0,len=wktArray.length;i<len;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
+return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Protocol.SQL.Gears=OpenLayers.Class(OpenLayers.Protocol.SQL,{FID_PREFIX:'__gears_fid__',NULL_GEOMETRY:'__gears_null_geometry__',NULL_FEATURE_STATE:'__gears_null_feature_state__',jsonParser:null,wktParser:null,fidRegExp:null,saveFeatureState:true,typeOfFid:"string",db:null,initialize:function(options){if(!this.supported()){return;}
+OpenLayers.Protocol.SQL.prototype.initialize.apply(this,[options]);this.jsonParser=new OpenLayers.Format.JSON();this.wktParser=new OpenLayers.Format.WKT();this.fidRegExp=new RegExp('^'+this.FID_PREFIX);this.initializeDatabase();},initializeDatabase:function(){this.db=google.gears.factory.create('beta.database');this.db.open(this.databaseName);this.db.execute("CREATE TABLE IF NOT EXISTS "+this.tableName+" (fid TEXT UNIQUE, geometry TEXT, properties TEXT,"+"  state TEXT)");},destroy:function(){this.db.close();this.db=null;this.jsonParser=null;this.wktParser=null;OpenLayers.Protocol.SQL.prototype.destroy.apply(this);},supported:function(){return!!(window.google&&google.gears);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.applyDefaults(options,this.options);var feature,features=[];var rs=this.db.execute("SELECT * FROM "+this.tableName);while(rs.isValidRow()){feature=this.unfreezeFeature(rs);if(this.evaluateFilter(featur
 e,options.filter)){if(!options.noFeatureStateReset){feature.state=null;}
+features.push(feature);}
+rs.next();}
+rs.close();var resp=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"read",features:features});if(options&&options.callback){options.callback.call(options.scope,resp);}
+return resp;},unfreezeFeature:function(row){var feature;var wkt=row.fieldByName('geometry');if(wkt==this.NULL_GEOMETRY){feature=new OpenLayers.Feature.Vector();}else{feature=this.wktParser.read(wkt);}
+feature.attributes=this.jsonParser.read(row.fieldByName('properties'));feature.fid=this.extractFidFromField(row.fieldByName('fid'));var state=row.fieldByName('state');if(state==this.NULL_FEATURE_STATE){state=null;}
+feature.state=state;return feature;},extractFidFromField:function(field){if(!field.match(this.fidRegExp)&&this.typeOfFid=="number"){field=parseFloat(field);}
+return field;},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="create";if(options&&options.callback){options.callback.call(options.scope,resp);}
+return resp;},update:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="update";if(options&&options.callback){options.callback.call(options.scope,resp);}
+return resp;},createOrUpdate:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var i,len=features.length,feature;var insertedFeatures=new Array(len);for(i=0;i<len;i++){feature=features[i];var params=this.freezeFeature(feature);this.db.execute("REPLACE INTO "+this.tableName+" (fid, geometry, properties, state)"+" VALUES (?, ?, ?, ?)",params);var clone=feature.clone();clone.fid=this.extractFidFromField(params[0]);insertedFeatures[i]=clone;}
+return new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,features:insertedFeatures,reqFeatures:features});},freezeFeature:function(feature){feature.fid=feature.fid!=null?""+feature.fid:OpenLayers.Util.createUniqueID(this.FID_PREFIX);var geometry=feature.geometry!=null?feature.geometry.toString():this.NULL_GEOMETRY;var properties=this.jsonParser.write(feature.attributes);var state=this.getFeatureStateForFreeze(feature);return[feature.fid,geometry,properties,state];},getFeatureStateForFreeze:function(feature){var state;if(!this.saveFeatureState){state=this.NULL_FEATURE_STATE;}else if(this.createdOffline(feature)){state=OpenLayers.State.INSERT;}else{state=feature.state;}
+return state;},"delete":function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+options=OpenLayers.Util.applyDefaults(options,this.options);var i,len,feature;for(i=0,len=features.length;i<len;i++){feature=features[i];if(this.saveFeatureState&&!this.createdOffline(feature)){var toDelete=feature.clone();toDelete.fid=feature.fid;if(toDelete.geometry){toDelete.geometry.destroy();toDelete.geometry=null;}
+toDelete.state=feature.state;this.createOrUpdate(toDelete);}else{this.db.execute("DELETE FROM "+this.tableName+" WHERE fid = ?",[feature.fid]);}}
+var resp=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"delete",reqFeatures:features});if(options&&options.callback){options.callback.call(options.scope,resp);}
+return resp;},createdOffline:function(feature){return(typeof feature.fid=="string"&&!!(feature.fid.match(this.fidRegExp)));},commit:function(features,options){var opt,resp=[],nRequests=0,nResponses=0;function callback(resp){if(++nResponses<nRequests){resp.last=false;}
+this.callUserCallback(options,resp);}
+var feature,toCreate=[],toUpdate=[],toDelete=[];for(var i=features.length-1;i>=0;i--){feature=features[i];switch(feature.state){case OpenLayers.State.INSERT:toCreate.push(feature);break;case OpenLayers.State.UPDATE:toUpdate.push(feature);break;case OpenLayers.State.DELETE:toDelete.push(feature);break;}}
+if(toCreate.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options.create);resp.push(this.create(toCreate,opt));}
+if(toUpdate.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options.update);resp.push(this.update(toUpdate,opt));}
+if(toDelete.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options["delete"]);resp.push(this["delete"](toDelete,opt));}
+return resp;},clear:function(){this.db.execute("DELETE FROM "+this.tableName);},callUserCallback:function(options,resp){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}
+if(resp.last&&options.callback){options.callback.call(options.scope);}},CLASS_NAME:"OpenLayers.Protocol.SQL.Gears"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
+OpenLayers.Format.prototype.initialize.apply(this,[options]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var alias in this.namespaces){this.namespaceAlias[this.namespaces[alias]]=alias;}},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,arguments);},setNamespace:function(alias,uri){this.namespaces[alias]=uri;this.namespaceAlias[uri]=alias;},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
+xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
+req.send(null);return req.responseXML;});if(this.keepData){this.data=node;}
+return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
+doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
+return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
+return element;},createTextNode:function(text){var node;if(typeof text!=="string"){text=String(text);}
+if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
+return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0,len=allNodes.length;i<len;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
+return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0,len=attributes.length;i<len;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
+return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
+return attributeValue;},getChildValue:function(node,def){var value=def||"";if(node){for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 3:case 4:value+=child.nodeValue;}}}
+return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
+child=child.nextSibling;}
+if(value==""&&def!=undefined){value=def;}
+return value;},isSimpleContent:function(node){var simple=true;for(var child=node.firstChild;child;child=child.nextSibling){if(child.nodeType===1){simple=false;break;}}
+return simple;},contentType:function(node){var simple=false,complex=false;var type=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY;for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 1:complex=true;break;case 8:break;default:simple=true;}
+if(complex&&simple){break;}}
+if(complex&&simple){type=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;}else if(complex){return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;}else if(simple){return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE;}
+return type;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
+return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},createElementNSPlus:function(name,options){options=options||{};var uri=options.uri||this.namespaces[options.prefix];if(!uri){var loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
+if(!uri){uri=this.namespaces[this.defaultPrefix];}
+var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
+var value=options.value;if(value!=null){node.appendChild(this.createTextNode(value));}
+return node;},setAttributes:function(node,obj){var value,uri;for(var name in obj){if(obj[name]!=null&&obj[name].toString){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}}},readNode:function(node,obj){if(!obj){obj={};}
+var group=this.readers[node.namespaceURI?this.namespaceAlias[node.namespaceURI]:this.defaultPrefix];if(group){var local=node.localName||node.nodeName.split(":").pop();var reader=group[local]||group["*"];if(reader){reader.apply(this,[node,obj]);}}
+return obj;},readChildNodes:function(node,obj){if(!obj){obj={};}
+var children=node.childNodes;var child;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){this.readNode(child,obj);}}
+return obj;},writeNode:function(name,obj,parent){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{if(parent){prefix=this.namespaceAlias[parent.namespaceURI];}else{prefix=this.defaultPrefix;}
+local=name;}
+var child=this.writers[prefix][local].apply(this,[obj]);if(parent){parent.appendChild(child);}
+return child;},getChildEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.firstChild,name,uri);},getNextEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.nextSibling,name,uri);},getThisOrNextEl:function(node,name,uri){outer:for(var sibling=node;sibling;sibling=sibling.nextSibling){switch(sibling.nodeType){case 1:if((!name||name===(sibling.localName||sibling.nodeName.split(":").pop()))&&(!uri||uri===sibling.namespaceURI)){break outer;}
+sibling=null;break outer;case 3:if(/^\s*$/.test(sibling.nodeValue)){break;}
+case 4:case 6:case 12:case 10:case 11:sibling=null;break outer;}}
+return sibling||null;},lookupNamespaceURI:function(node,prefix){var uri=null;if(node){if(node.lookupNamespaceURI){uri=node.lookupNamespaceURI(prefix);}else{outer:switch(node.nodeType){case 1:if(node.namespaceURI!==null&&node.prefix===prefix){uri=node.namespaceURI;break outer;}
+var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
+uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
+return uri;},getXMLDoc:function(){if(!OpenLayers.Format.XML.document&&!this.xmldom){if(document.implementation&&document.implementation.createDocument){OpenLayers.Format.XML.document=document.implementation.createDocument("","",null);}else if(!this.xmldom&&window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}}
+return OpenLayers.Format.XML.document||this.xmldom;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Date={toISOString:(function(){if("toISOString"in Date.prototype){return function(date){return date.toISOString();};}else{function pad(num,len){var str=num+"";while(str.length<len){str="0"+str;}
+return str;}
+return function(date){var str;if(isNaN(date.getTime())){str="Invalid Date";}else{str=date.getUTCFullYear()+"-"+
+pad(date.getUTCMonth()+1,2)+"-"+
+pad(date.getUTCDate(),2)+"T"+
+pad(date.getUTCHours(),2)+":"+
+pad(date.getUTCMinutes(),2)+":"+
+pad(date.getUTCSeconds(),2)+"."+
+pad(date.getUTCMilliseconds(),3)+"Z";}
+return str;};}})(),parse:function(str){var date;var match=str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))|Z)?$/);if(match&&(match[1]||match[7])){var year=parseInt(match[1],10)||0;var month=(parseInt(match[2],10)-1)||0;var day=parseInt(match[3],10)||1;date=new Date(Date.UTC(year,month,day));var type=match[7];if(type){var hours=parseInt(match[4],10);var minutes=parseInt(match[5],10);var secFrac=parseFloat(match[6]);var seconds=secFrac|0;var milliseconds=Math.round(1000*(secFrac-seconds));date.setUTCHours(hours,minutes,seconds,milliseconds);if(type!=="Z"){var hoursOffset=parseInt(type,10);var minutesOffset=parseInt(match[8],10)||0;var offset=-1000*(60*(hoursOffset*60)+minutesOffset*60);date=new Date(date.getTime()+offset);}}}else{date=new Date("invalid");}
+return date;}};OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
+return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
+var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(OpenLayers.Util.isArray(result)){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
+geom=new OpenLayers.Geometry.Collection(components);}
+return geom;};OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,options){var point=options&&options.point;var tolerance=options&&options.tolerance;var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
+if(tolerance){var dist;if(intersection){if(point){var segs=[seg1,seg2];var seg,x,y;outer:for(var i=0;i<2;++i){seg=segs[i];for(var j=1;j<3;++j){x=seg["x"+j];y=seg["y"+j];dist=Math.sqrt(Math.pow(x-intersection.x,2)+
+Math.pow(y-intersection.y,2));if(dist<tolerance){intersection.x=x;intersection.y=y;break outer;}}}}}else{var segs=[seg1,seg2];var source,target,x,y,p,result;outer:for(var i=0;i<2;++i){source=segs[i];target=segs[(i+1)%2];for(var j=1;j<3;++j){p={x:source["x"+j],y:source["y"+j]};result=OpenLayers.Geometry.distanceToSegment(p,target);if(result.distance<tolerance){if(point){intersection=new OpenLayers.Geometry.Point(p.x,p.y);}else{intersection=true;}
+break outer;}}}}}
+return intersection;};OpenLayers.Geometry.distanceToSegment=function(point,segment){var x0=point.x;var y0=point.y;var x1=segment.x1;var y1=segment.y1;var x2=segment.x2;var y2=segment.y2;var dx=x2-x1;var dy=y2-y1;var along=((dx*(x0-x1))+(dy*(y0-y1)))/(Math.pow(dx,2)+Math.pow(dy,2));var x,y;if(along<=0.0){x=x1;y=y1;}else if(along>=1.0){x=x2;y=y2;}else{x=x1+along*dx;y=y1+along*dy;}
+return{distance:Math.sqrt(Math.pow(x-x0,2)+Math.pow(y-y0,2)),x:x,y:y};};OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var distance,x0,y0,x1,y1,result;if(geometry instanceof OpenLayers.Geometry.Point){x0=this.x;y0=this.y;x1=geometry.x;y1=geometry.y;distance=Math.sqrt(Math.pow(x0-x1,2)+Math.pow(y0-y1,2));result=!details?distance:{x0:x0,y0:y0,x1:x1,y1:y1,distance:distance};}else{result=geometry.distanceTo(this,options);if(details){result={x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0,distance:result.distance};}}
+return result;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
+return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y);},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();return this;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
+return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);this.bounds=null;}
+return this;},getVertices:function(nodes){return[this];},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
+OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0,len=this.components.length;i<len;i++){strings.push(this.components[i].toShortString());}
+return strings.join(",");},calculateBounds:function(){this.bounds=null;var bounds=new OpenLayers.Bounds();var components=this.components;if(components){for(var i=0,len=components.length;i<len;i++){bounds.extend(components[i].getBounds());}}
+if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(OpenLayers.Util.isArray(components))){components=[components];}
+for(var i=0,len=components.length;i<len;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
+component.parent=this;this.clearBounds();added=true;}}
+return added;},removeComponents:function(components){var removed=false;if(!(OpenLayers.Util.isArray(components))){components=[components];}
+for(var i=components.length-1;i>=0;--i){removed=this.removeComponent(components[i])||removed;}
+return removed;},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();return true;},getLength:function(){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getLength();}
+return length;},getArea:function(){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getArea();}
+return area;},getGeodesicArea:function(projection){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getGeodesicArea(projection);}
+return area;},getCentroid:function(weighted){if(!weighted){return this.components.length&&this.components[0].getCentroid();}
+var len=this.components.length;if(!len){return false;}
+var areas=[];var centroids=[];var areaSum=0;var minArea=Number.MAX_VALUE;var component;for(var i=0;i<len;++i){component=this.components[i];var area=component.getArea();var centroid=component.getCentroid(true);if(isNaN(area)||isNaN(centroid.x)||isNaN(centroid.y)){continue;}
+areas.push(area);areaSum+=area;minArea=(area<minArea&&area>0)?area:minArea;centroids.push(centroid);}
+len=areas.length;if(areaSum===0){for(var i=0;i<len;++i){areas[i]=1;}
+areaSum=areas.length;}else{for(var i=0;i<len;++i){areas[i]/=minArea;}
+areaSum/=minArea;}
+var xSum=0,ySum=0,centroid,area;for(var i=0;i<len;++i){centroid=centroids[i];area=areas[i];xSum+=centroid.x*area;ySum+=centroid.y*area;}
+return new OpenLayers.Geometry.Point(xSum/areaSum,ySum/areaSum);},getGeodesicLength:function(projection){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getGeodesicLength(projection);}
+return length;},move:function(x,y){for(var i=0,len=this.components.length;i<len;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}
+return this;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best,distance;var min=Number.POSITIVE_INFINITY;for(var i=0,len=this.components.length;i<len;++i){result=this.components[i].distanceTo(geometry,options);distance=details?result.distance:result;if(distance<min){min=distance;best=result;if(min==0){break;}}}
+return best;},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(OpenLayers.Util.isArray(geometry.components))||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0,len=this.components.length;i<len;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
+return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len;i++){var component=this.components[i];component.transform(source,dest);}
+this.bounds=null;}
+return this;},intersects:function(geometry){var intersect=false;for(var i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+return intersect;},getVertices:function(nodes){var vertices=[];for(var i=0,len=this.components.length;i<len;++i){Array.prototype.push.apply(vertices,this.components[i].getVertices(nodes));}
+return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
+return length;},getGeodesicLength:function(projection){var geom=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){geom=this.clone().transform(projection,gg);}}
+var length=0.0;if(geom.components&&(geom.components.length>1)){var p1,p2;for(var i=1,len=geom.components.length;i<len;i++){p1=geom.components[i-1];p2=geom.components[i];length+=OpenLayers.Util.distVincenty({lon:p1.x,lat:p1.y},{lon:p2.x,lat:p2.y});}}
+return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{removeComponent:function(point){var removed=this.components&&(this.components.length>2);if(removed){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}
+return removed;},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
+var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0,len=segs1.length;i<len;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0,jlen=segs2.length;j<jlen;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
+if(seg2.x2<seg1x1){continue;}
+seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
+if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
+if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
+return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg),point1,point2;for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
+function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
+return segments.sort(byX1);},splitWithSegment:function(seg,options){var edge=!(options&&options.edge===false);var tolerance=options&&options.tolerance;var lines=[];var verts=this.getVertices();var points=[];var intersections=[];var split=false;var vert1,vert2,point;var node,vertex,target;var interOptions={point:true,tolerance:tolerance};var result=null;for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];points.push(vert1.clone());vert2=verts[i+1];target={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};point=OpenLayers.Geometry.segmentsIntersect(seg,target,interOptions);if(point instanceof OpenLayers.Geometry.Point){if((point.x===seg.x1&&point.y===seg.y1)||(point.x===seg.x2&&point.y===seg.y2)||point.equals(vert1)||point.equals(vert2)){vertex=true;}else{vertex=false;}
+if(vertex||edge){if(!point.equals(intersections[intersections.length-1])){intersections.push(point.clone());}
+if(i===0){if(point.equals(vert1)){continue;}}
+if(point.equals(vert2)){continue;}
+split=true;if(!point.equals(vert1)){points.push(point);}
+lines.push(new OpenLayers.Geometry.LineString(points));points=[point.clone()];}}}
+if(split){points.push(vert2.clone());lines.push(new OpenLayers.Geometry.LineString(points));}
+if(intersections.length>0){var xDir=seg.x1<seg.x2?1:-1;var yDir=seg.y1<seg.y2?1:-1;result={lines:lines,points:intersections.sort(function(p1,p2){return(xDir*p1.x-xDir*p2.x)||(yDir*p1.y-yDir*p2.y);})};}
+return result;},split:function(target,options){var results=null;var mutual=options&&options.mutual;var sourceSplit,targetSplit,sourceParts,targetParts;if(target instanceof OpenLayers.Geometry.LineString){var verts=this.getVertices();var vert1,vert2,seg,splits,lines,point;var points=[];sourceParts=[];for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];vert2=verts[i+1];seg={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};targetParts=targetParts||[target];if(mutual){points.push(vert1.clone());}
+for(var j=0;j<targetParts.length;++j){splits=targetParts[j].splitWithSegment(seg,options);if(splits){lines=splits.lines;if(lines.length>0){lines.unshift(j,1);Array.prototype.splice.apply(targetParts,lines);j+=lines.length-2;}
+if(mutual){for(var k=0,len=splits.points.length;k<len;++k){point=splits.points[k];if(!point.equals(vert1)){points.push(point);sourceParts.push(new OpenLayers.Geometry.LineString(points));if(point.equals(vert2)){points=[];}else{points=[point.clone()];}}}}}}}
+if(mutual&&sourceParts.length>0&&points.length>0){points.push(vert2.clone());sourceParts.push(new OpenLayers.Geometry.LineString(points));}}else{results=target.splitWith(this,options);}
+if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
+if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
+if(targetSplit||sourceSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){return geometry.split(this,options);},getVertices:function(nodes){var vertices;if(nodes===true){vertices=[this.components[0],this.components[this.components.length-1]];}else if(nodes===false){vertices=this.components.slice(1,this.components.length-1);}else{vertices=this.components.slice();}
+return vertices;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best={};var min=Number.POSITIVE_INFINITY;if(geometry instanceof OpenLayers.Geometry.Point){var segs=this.getSortedSegments();var x=geometry.x;var y=geometry.y;var seg;for(var i=0,len=segs.length;i<len;++i){seg=segs[i];result=OpenLayers.Geometry.distanceToSegment(geometry,seg);if(result.distance<min){min=result.distance;best=result;if(min===0){break;}}else{if(seg.x2>x&&((y>seg.y1&&y<seg.y2)||(y<seg.y1&&y>seg.y2))){break;}}}
+if(details){best={distance:best.distance,x0:best.x,y0:best.y,x1:x,y1:y};}else{best=best.distance;}}else if(geometry instanceof OpenLayers.Geometry.LineString){var segs0=this.getSortedSegments();var segs1=geometry.getSortedSegments();var seg0,seg1,intersection,x0,y0;var len1=segs1.length;var interOptions={point:true};outer:for(var i=0,len=segs0.length;i<len;++i){seg0=segs0[i];x0=seg0.x1;y0=seg0.y1;for(var j=0;j<len1;++j){seg1=segs1[j];intersection=OpenLayers.Geometry.segmentsIntersect(seg0,seg1,interOptions);if(intersection){min=0;best={distance:0,x0:intersection.x,y0:intersection.y,x1:intersection.x,y1:intersection.y};break outer;}else{result=OpenLayers.Geometry.distanceToSegment({x:x0,y:y0},seg1);if(result.distance<min){min=result.distance;best={distance:min,x0:x0,y0:y0,x1:result.x,y1:result.y};}}}}
+if(!details){best=best.distance;}
+if(min!==0){if(seg0){result=geometry.distanceTo(new OpenLayers.Geometry.Point(seg0.x2,seg0.y2),options);var dist=details?result.distance:result;if(dist<min){if(details){best={distance:min,x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0};}else{best=dist;}}}}}else{best=geometry.distanceTo(this,options);if(details){best={distance:best.distance,x0:best.x1,y0:best.y1,x1:best.x0,y1:best.y0};}}
+return best;},simplify:function(tolerance){if(this&&this!==null){var points=this.getVertices();if(points.length<3){return this;}
+var compareNumbers=function(a,b){return(a-b);};var douglasPeuckerReduction=function(points,firstPoint,lastPoint,tolerance){var maxDistance=0;var indexFarthest=0;for(var index=firstPoint,distance;index<lastPoint;index++){distance=perpendicularDistance(points[firstPoint],points[lastPoint],points[index]);if(distance>maxDistance){maxDistance=distance;indexFarthest=index;}}
+if(maxDistance>tolerance&&indexFarthest!=firstPoint){pointIndexsToKeep.push(indexFarthest);douglasPeuckerReduction(points,firstPoint,indexFarthest,tolerance);douglasPeuckerReduction(points,indexFarthest,lastPoint,tolerance);}};var perpendicularDistance=function(point1,point2,point){var area=Math.abs(0.5*(point1.x*point2.y+point2.x*point.y+point.x*point1.y-point2.x*point1.y-point.x*point2.y-point1.x*point.y));var bottom=Math.sqrt(Math.pow(point1.x-point2.x,2)+Math.pow(point1.y-point2.y,2));var height=area/bottom*2;return height;};var firstPoint=0;var lastPoint=points.length-1;var pointIndexsToKeep=[];pointIndexsToKeep.push(firstPoint);pointIndexsToKeep.push(lastPoint);while(points[firstPoint].equals(points[lastPoint])){lastPoint--;pointIndexsToKeep.push(lastPoint);}
+douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
+return new OpenLayers.Geometry.LineString(returnPoints);}
+else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
+var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){var removed=this.components&&(this.components.length>3);if(removed){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}
+return removed;},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
+return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
+this.bounds=null;}
+return this;},getCentroid:function(){if(this.components&&(this.components.length>2)){var sumX=0.0;var sumY=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x)*(b.x*c.y-c.x*b.y);sumY+=(b.y+c.y)*(b.x*c.y-c.x*b.y);}
+var area=-1*this.getArea();var x=sumX/(6*area);var y=sumY/(6*area);return new OpenLayers.Geometry.Point(x,y);}else{return null;}},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0,len=this.components.length;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
+area=-sum/2.0;}
+return area;},getGeodesicArea:function(projection){var ring=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){ring=this.clone().transform(projection,gg);}}
+var area=0.0;var len=ring.components&&ring.components.length;if(len>2){var p1,p2;for(var i=0;i<len-1;i++){p1=ring.components[i];p2=ring.components[i+1];area+=OpenLayers.Util.rad(p2.x-p1.x)*(2+Math.sin(OpenLayers.Util.rad(p1.y))+
+Math.sin(OpenLayers.Util.rad(p2.y)));}
+area=area*6378137.0*6378137.0/2.0;}
+return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
+var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
+continue;}
+cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
+if(cx<=px){continue;}
+if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
+if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
+var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0,len=geometry.components.length;i<len;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
+return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
+return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
+return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
+break;}}}}}
+return contained;},intersects:function(geometry){var intersect=false;var i,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+if(!intersect){for(i=0,len=geometry.components.length;i<len;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0,len=geometry.components.length;i<len;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
+if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0,len=ring.components.length;i<len;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
+return intersect;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var result;if(!edge&&this.intersects(geometry)){result=0;}else{result=OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[geometry,options]);}
+return result;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
+var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
+var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
+return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
+if(!this.observers){this.observers={};}
+if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
+element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
+var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
+this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Sa
 fari|KHTML/)||element.detachEvent){name='keydown';}}
+var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
+foundEntry=true;break;}
+i++;}}
+if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
+return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
+OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};if(element!=null){this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
+this.element=null;this.listeners=null;this.object=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
+this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){OpenLayers.Event.observe(element,this.BROWSER_EVENTS[i],this.eventHandler);}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func,priority){if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(!listeners){listeners=[];this.listeners[type]=listeners;}
+if(priority){listeners.unshift({obj:obj,func:func});}else{listeners.push({obj:obj,func:func});}}},registerPriority:function(type,obj,func){this.register(type,obj,func,true);},un:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return undefined;}
+if(evt==null){evt={};}
+evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
+listeners=listeners.slice();var continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
+if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}
+return continueChain;},handleBrowserEvent:function(evt){var type=evt.type,listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
+var touches=evt.touches;if(touches&&touches[0]){var x=0;var y=0;var num=touches.length;var touch;for(var i=0;i<num;++i){touch=touches[i];x+=touch.clientX;y+=touch.clientY;}
+evt.clientX=x/num;evt.clientY=y/num;}
+if(this.includeXY){evt.xy=this.getMousePosition(evt);}
+this.triggerEvent(type,evt);},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;var body=document.body;if(body&&!((body.scrollTop!=0||body.scrollLeft!=0)&&navigator.userAgent.match(/iPhone/i))){this.element.offsets=null;}},getMousePosition:function(evt){if(!this.includeXY){this.clearMouseCache();}else if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true;}
+if(!this.element.scrolls){var viewportElement=OpenLayers.Util.getViewportElement();this.element.scrolls=[viewportElement.scrollLeft,viewportElement.scrollTop];}
+if(!this.element.lefttop){this.element.lefttop=[(document.documentElement.clientLeft||0),(document.documentElement.clientTop||0)];}
+if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
+return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
+-this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
+-this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var customRequestedWithHeader=false,headerKey;for(headerKey in config.headers){if(config.headers.hasOwnProperty(headerKey)){if(headerKey.toLowerCase()==='x-requested-with'){customRequestedWithHeader=true;}}}
+if(customRequestedWithHeader===false){config.headers['X-Requested-With']='XMLHttpRequest';}
+var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
+if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
+request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
+var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
+return request;},runCallbacks:function(options){var request=options.request;var config=options.config;var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
+var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
+if(OpenLayers.Util.createUrlObject(config.url).protocol=="file:"&&request.responseText){request.status=200;}
+complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
+if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
+cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
+bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
+if(cXMLHttpRequest.onopen)
+cXMLHttpRequest.onopen.apply(this,arguments);if(arguments.length>4)
+this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);else
+if(arguments.length>3)
+this._object.open(sMethod,sUrl,bAsync,sUser);else
+this._object.open(sMethod,sUrl,bAsync);this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
+return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
+if(oRequest.readyState==cXMLHttpRequest.DONE){delete oRequest._data;fCleanTransport(oRequest);if(bIE&&bAsync)
+window.detachEvent("onunload",fOnUnload);}
+if(nState!=oRequest.readyState)
+fReadyStateChange(oRequest);nState=oRequest.readyState;}};function fXMLHttpRequest_send(oRequest){oRequest._object.send(oRequest._data);if(bGecko&&!oRequest._async){oRequest.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(oRequest);while(oRequest.readyState<cXMLHttpRequest.DONE){oRequest.readyState++;fReadyStateChange(oRequest);if(oRequest._aborted)
+return;}}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
+cXMLHttpRequest.onsend.apply(this,arguments);if(!arguments.length)
+vData=null;if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!oRequest._headers["Content-Type"])
+oRequest._object.setRequestHeader("Content-Type","application/xml");}
+this._data=vData;fXMLHttpRequest_send(this);};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
+cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
+this._aborted=true;this._object.abort();fCleanTransport(this);this.readyState=cXMLHttpRequest.UNSENT;delete this._data;};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
+this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.addEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==sName&&oListener[1]==fHandler&&oListener[2]==bUseCapture)
+return;this._listeners.push([sName,fHandler,bUseCapture]);};cXMLHttpRequest.prototype.removeEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+break;if(oListener)
+this._listeners.splice(nIndex,1);};cXMLHttpRequest.prototype.dispatchEvent=function(oEvent){var oEventPseudo={'type':oEvent.type,'target':this,'currentTarget':this,'eventPhase':2,'bubbles':oEvent.bubbles,'cancelable':oEvent.cancelable,'timeStamp':oEvent.timeStamp,'stopPropagation':function(){},'preventDefault':function(){},'initEvent':function(){}};if(oEventPseudo.type=="readystatechange"&&this.onreadystatechange)
+(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[oEventPseudo]);for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==oEventPseudo.type&&!oListener[2])
+(oListener[1].handleEvent||oListener[1]).apply(this,[oEventPseudo]);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(cXMLHttpRequest.onreadystatechange)
+cXMLHttpRequest.onreadystatechange.apply(oRequest);oRequest.dispatchEvent({'type':"readystatechange",'bubbles':false,'cancelable':false,'timeStamp':new Date+0});};function fGetDocument(oRequest){var oDocument=oRequest.responseXML,sResponse=oRequest.responseText;if(bIE&&sResponse&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new window.ActiveXObject("Microsoft.XMLDOM");oDocument.async=false;oDocument.validateOnParse=false;oDocument.loadXML(sResponse);}
+if(oDocument)
+if((bIE&&oDocument.parseError!=0)||!oDocument.documentElement||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
+return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
+try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
+try{oRequest.status=oRequest._object.status;}catch(e){}
+try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Proj
 ection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,extractTracks:false,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.sty
 les={};this.fetched={};var options={depth:0,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0,len=types.length;i<len;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
+switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
+break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
+break;case"placemark":this.parseFeatures(nodes,options);break;}}
+return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
+var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0,len=nodes.length;i<len;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=OpenLayers.Request.GET({url:href,async:false});if(request){return request.responseText;}},parseStyles:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var style=this.parseStyle(nodes[i]);if(style){var styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseKmlColor:function(kmlColor){var color=null;if(kmlColor){var matches=kmlColor.match(this.regExes.kmlColor);if(matches){color={color:'#'+matches[4]+matches[3]+matches[2],opacity:parseInt(matches[1],16)/255};}}
+return color;},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"];var type,styleTypeNode,nodeList,geometry,parser;for(var i=0,len=types.length;i<len;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
+switch(type.toLowerCase()){case"linestyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["strokeColor"]=color.color;style["strokeOpacity"]=color.opacity;}
+var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
+break;case"polystyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fillOpacity"]=color.opacity;style["fillColor"]=color.color;}
+var fill=this.parseProperty(styleTypeNode,"*","fill");if(fill=="0"){style["fillColor"]="none";}
+var outline=this.parseProperty(styleTypeNode,"*","outline");if(outline=="0"){style["strokeWidth"]="0";}
+break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
+w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
+if(h){height=parseInt(h)*scale;}
+var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
++palette+"/icon"+pos+file_extension;}
+style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
+var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
+else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
+else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
+var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
+else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
+else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
+style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
+break;case"labelstyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fontColor"]=color.color;style["fontOpacity"]=color.opacity;}
+break;default:}}
+if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
+var id=node.getAttribute("id");if(id&&style){style.id=id;}
+return style;},parseStyleMaps:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0,jlen=pairs.length;j<jlen;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
+if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=[];for(var i=0,len=nodes.length;i<len;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl,options);}
+if(this.extractStyles){var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend(feature.style,inlineStyle);}}}
+if(this.extractTracks){var tracks=this.getElementsByTagNameNS(featureNode,this.namespaces.gx,"Track");if(tracks&&tracks.length>0){var track=tracks[0];var container={features:[],feature:feature};this.readNode(track,container);if(container.features.length>0){features.push.apply(features,container.features);}}}else{features.push(feature);}}else{throw"Bad Placemark: "+i;}}
+this.features=this.features.concat(features);},readers:{"kml":{"when":function(node,container){container.whens.push(OpenLayers.Date.parse(this.getChildValue(node)));},"_trackPointAttribute":function(node,container){var name=node.nodeName.split(":").pop();container.attributes[name].push(this.getChildValue(node));}},"gx":{"Track":function(node,container){var obj={whens:[],points:[],angles:[]};if(this.trackAttributes){var name;obj.attributes={};for(var i=0,ii=this.trackAttributes.length;i<ii;++i){name=this.trackAttributes[i];obj.attributes[name]=[];if(!(name in this.readers.kml)){this.readers.kml[name]=this.readers.kml._trackPointAttribute;}}}
+this.readChildNodes(node,obj);if(obj.whens.length!==obj.points.length){throw new Error("gx:Track with unequal number of when ("+
+obj.whens.length+") and gx:coord ("+
+obj.points.length+") elements.");}
+var hasAngles=obj.angles.length>0;if(hasAngles&&obj.whens.length!==obj.angles.length){throw new Error("gx:Track with unequal number of when ("+
+obj.whens.length+") and gx:angles ("+
+obj.angles.length+") elements.");}
+var feature,point,angles;for(var i=0,ii=obj.whens.length;i<ii;++i){feature=container.feature.clone();feature.fid=container.feature.fid||container.feature.id;point=obj.points[i];feature.geometry=point;if("z"in point){feature.attributes.altitude=point.z;}
+if(this.internalProjection&&this.externalProjection){feature.geometry.transform(this.externalProjection,this.internalProjection);}
+if(this.trackAttributes){for(var j=0,jj=this.trackAttributes.length;j<jj;++j){feature.attributes[name]=obj.attributes[this.trackAttributes[j]][i];}}
+feature.attributes.when=obj.whens[i];feature.attributes.trackId=container.feature.id;if(hasAngles){angles=obj.angles[i];feature.attributes.heading=parseFloat(angles[0]);feature.attributes.tilt=parseFloat(angles[1]);feature.attributes.roll=parseFloat(angles[2]);}
+container.features.push(feature);}},"coord":function(node,container){var str=this.getChildValue(node);var coords=str.replace(this.regExes.trimSpace,"").split(/\s+/);var point=new OpenLayers.Geometry.Point(coords[0],coords[1]);if(coords.length>2){point.z=parseFloat(coords[2]);}
+container.points.push(point);},"angles":function(node,container){var str=this.getChildValue(node);var parts=str.replace(this.regExes.trimSpace,"").split(/\s+/);container.angles.push(parts);}}},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0,len=order.length;i<len;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{throw new TypeError("Unsupported geometry type: "+type);}
+break;}}
+var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
+return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
+var style=OpenLayers.Util.extend({},this.styles[styleUrl]);return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
+var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
+point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
+return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
+points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
+pointList[i];}}
+if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
+return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0,len=nodeList.length;i<len;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
+return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
+return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var edNodes=node.getElementsByTagName("ExtendedData");if(edNodes.length){attributes=this.parseExtendedData(edNodes[0]);}
+var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length>=1&&grandchildren.length<=3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 2:var c1=grandchildren[0];var c2=grandchildren[1];grandchild=(c1.nodeType==3||c1.nodeType==4)?c1:c2;break;case 3:default:grandchild=grandchildren[1];break;}
+if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseExtendedData:function(node){var attributes={};var i,len,data,key;var dataNodes=node.getElementsByTagName("Data");for(i=0,len=dataNodes.length;i<len;i++){data=dataNodes[i];key=data.getAttribute("name");var ed={};var valueNode=data.getElementsByTagName("value");if(valueNode.length){ed['value']=this.getChildValue(valueNode[0]);}
+var nameNode=data.getElementsByTagName("displayName");if(nameNode.length){ed['displayName']=this.getChildValue(nameNode[0]);}
+attributes[key]=ed;}
+var simpleDataNodes=node.getElementsByTagName("SimpleData");for(i=0,len=simpleDataNodes.length;i<len;i++){var ed={};data=simpleDataNodes[i];key=data.getAttribute("name");ed['value']=this.getChildValue(data);ed['displayName']=key;attributes[key]=ed;}
+return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
+return value;},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0,len=features.length;i<len;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
+kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
+if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
+return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=feature.style&&feature.style.label?feature.style.label:feature.attributes.name||feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=feature.attributes.description||this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
+placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
+return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0,len=rings.length;i<len;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[
 i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
+return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0,len=geometry.components.length;i<len;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
+return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=this.buildCoordinates(point);}
+path=parts.join(" ");}else{path=this.buildCoordinates(geometry);}
+var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},buildCoordinates:function(point){if(this.internalProjection&&this.externalProjection){point=point.clone();point.transform(this.internalProjection,this.externalProjection);}
+return point.x+","+point.y;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
+sourceSplit=true;splits=splits[1];}
+if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
+if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
+if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
+splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
+for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
+targetSplit=true;}}
+if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
+return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
+return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{throw new TypeError("Unsupported geometry type: "+type);}
+break;}}
+var bounds;var boxNodes=this.getElementsByTagNameNS(node,this.gmlns,"Box");for(i=0;i<boxNodes.length;++i){var boxNode=boxNodes[i];var box=this.parseGeometry["box"].apply(this,[boxNode]);var parentNode=boxNode.parentNode;var parentName=parentNode.localName||parentNode.nodeName.split(":").pop();if(parentName==="boundedBy"){bounds=box;}else{geometry=box.toGeometry();}}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes);feature.bounds=bounds;feature.gml={featureType:node.firstChild.nodeName.split(":")[1],featureNS:node.firstChild.namespaceURI,featureNSPrefix:node.firstChild.prefix};var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
+childNode=childNode.nextSibling;}
+feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
+if(coords.length==2){coords[2]=null;}
+if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
+else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
+return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
+if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
+if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
+var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
+return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
+return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
+return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
+return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
+var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
+if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
+if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
+return envelope;},box:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");var coordString;var coords,beginPoint=null,endPoint=null;if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coords=coordString.split(" ");if(coords.length==2){beginPoint=coords[0].split(",");endPoint=coords[1].split(",");}}
+if(beginPoint!==null&&endPoint!==null){return new OpenLayers.Bounds(parseFloat(beginPoint[0]),parseFloat(beginPoint[1]),parseFloat(endPoint[0]),parseFloat(endPoint[1]));}}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}else{attributes[child.nodeName.split(":").pop()]=null;}}}
+break;}
+return attributes;},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
+return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
+featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
+return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
+return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
+return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
+return gml;},bounds:function(bounds){var gml=this.createElementNS(this.gmlns,"gml:Box");gml.appendChild(this.buildCoordinatesNode(bounds));return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var parts=[];if(geometry instanceof OpenLayers.Bounds){parts.push(geometry.left+","+geometry.bottom);parts.push(geometry.right+","+geometry.top);}else{var points=(geometry.components)?geometry.components:[geometry];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}}
+var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});if(!OpenLayers.Format.GML){OpenLayers.Format.GML={};}
+OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:true,srsName:null,xy:true,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),featureMember:(/^(.*:)?featureMembers?$/)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.setGeometryTypes();if(options&&options.featureNS){this.setNamespace("feature",options.featureNS);}
+this.singleFeatureType=!options||(typeof options.featureType==="string");},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var features=[];this.readNode(data,{features:features},true);if(features.length==0){var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMember");if(elements.length){for(var i=0,len=elements.length;i<len;++i){this.readNode(elements[i],{features:features},true);}}else{var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMembers");if(elements.length){this.readNode(elements[0],{features:features},true);}}}
+return features;},readNode:function(node,obj,first){if(first===true&&this.autoConfig===true){this.featureType=null;delete this.namespaceAlias[this.featureNS];delete this.namespaces["feature"];this.featureNS=null;}
+if(!this.featureNS&&(!(node.prefix in this.namespaces)&&node.parentNode.namespaceURI==this.namespaces["gml"]&&this.regExes.featureMember.test(node.parentNode.nodeName))){this.featureType=node.nodeName.split(":").pop();this.setNamespace("feature",node.namespaceURI);this.featureNS=node.namespaceURI;this.autoConfig=true;}
+return OpenLayers.Format.XML.prototype.readNode.apply(this,[node,obj]);},readers:{"gml":{"featureMember":function(node,obj){this.readChildNodes(node,obj);},"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"name":function(node,obj){obj.name=this.getChildValue(node);},"boundedBy":function(node,obj){var container={};this.readChildNodes(node,container);if(container.components&&container.components.length>0){obj.bounds=container.components[0];}},"Point":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+container.components.push(obj.points[0]);},"coordinates":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);var coords;var numPoints=pointList.length;var points=new Array(numPoints);for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");if(this.xy){points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{points[i]=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
+obj.points=points;},"coord":function(node,obj){var coord={};this.readChildNodes(node,coord);if(!obj.points){obj.points=[];}
+obj.points.push(new OpenLayers.Geometry.Point(coord.x,coord.y,coord.z));},"X":function(node,coord){coord.x=this.getChildValue(node);},"Y":function(node,coord){coord.y=this.getChildValue(node);},"Z":function(node,coord){coord.z=this.getChildValue(node);},"MultiPoint":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiPoint(obj.components)];},"pointMember":function(node,obj){this.readChildNodes(node,obj);},"LineString":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+container.components.push(new OpenLayers.Geometry.LineString(obj.points));},"MultiLineString":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiLineString(obj.components)];},"lineStringMember":function(node,obj){this.readChildNodes(node,obj);},"Polygon":function(node,container){var obj={outer:null,inner:[]};this.readChildNodes(node,obj);obj.inner.unshift(obj.outer);if(!container.components){container.components=[];}
+container.components.push(new OpenLayers.Geometry.Polygon(obj.inner));},"LinearRing":function(node,obj){var container={};this.readChildNodes(node,container);obj.components=[new OpenLayers.Geometry.LinearRing(container.points)];},"MultiPolygon":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiPolygon(obj.components)];},"polygonMember":function(node,obj){this.readChildNodes(node,obj);},"GeometryCollection":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.Collection(obj.components)];},"geometryMember":function(node,obj){this.readChildNodes(node,obj);}},"feature":{"*":function(node,obj){var name;var local=node.localName||node.nodeName.split(":").pop();if(obj.features){if(!this.singleFeatureType&&(OpenLayers.Util.indexOf(this.featureType,local)!==-1)){name="_typeName";}else if(local===this.featureType){name="_typeName";}else
 if(this.featureType==="*"){name="_typeName";}}else{if(node.childNodes.length==0||(node.childNodes.length==1&&node.firstChild.nodeType==3)){if(this.extractAttributes){name="_attribute";}}else{name="_geometry";}}
+if(name){this.readers.feature[name].apply(this,[node,obj]);}},"_typeName":function(node,obj){var container={components:[],attributes:{}};this.readChildNodes(node,container);if(container.name){container.attributes.name=container.name;}
+var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);if(!this.singleFeatureType){feature.type=node.nodeName.split(":").pop();feature.namespace=node.namespaceURI;}
+var fid=node.getAttribute("fid")||this.getAttributeNS(node,this.namespaces["gml"],"id");if(fid){feature.fid=fid;}
+if(this.internalProjection&&this.externalProjection&&feature.geometry){feature.geometry.transform(this.externalProjection,this.internalProjection);}
+if(container.bounds){feature.bounds=container.bounds;}
+obj.features.push(feature);},"_geometry":function(node,obj){if(!this.geometryName){this.geometryName=node.nodeName.split(":").pop();}
+this.readChildNodes(node,obj);},"_attribute":function(node,obj){var local=node.localName||node.nodeName.split(":").pop();var value=this.getChildValue(node);obj.attributes[local]=value;}},"wfs":{"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);}}},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="featureMembers";}else{name="featureMember";}
+var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":{"featureMember":function(feature){var node=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",feature,node);return node;},"MultiPoint":function(geometry){var node=this.createElementNSPlus("gml:MultiPoint");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("pointMember",components[i],node);}
+return node;},"pointMember":function(geometry){var node=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",geometry,node);return node;},"MultiLineString":function(geometry){var node=this.createElementNSPlus("gml:MultiLineString");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("lineStringMember",components[i],node);}
+return node;},"lineStringMember":function(geometry){var node=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",geometry,node);return node;},"MultiPolygon":function(geometry){var node=this.createElementNSPlus("gml:MultiPolygon");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("polygonMember",components[i],node);}
+return node;},"polygonMember":function(geometry){var node=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",geometry,node);return node;},"GeometryCollection":function(geometry){var node=this.createElementNSPlus("gml:GeometryCollection");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("geometryMember",geometry.components[i],node);}
+return node;},"geometryMember":function(geometry){var node=this.createElementNSPlus("gml:geometryMember");var child=this.writeNode("feature:_geometry",geometry);node.appendChild(child.firstChild);return node;}},"feature":{"_typeName":function(feature){var node=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:feature.fid}});if(feature.geometry){this.writeNode("feature:_geometry",feature.geometry,node);}
+for(var name in feature.attributes){var value=feature.attributes[name];if(value!=null){this.writeNode("feature:_attribute",{name:name,value:value},node);}}
+return node;},"_geometry":function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone().transform(this.internalProjection,this.externalProjection);}
+var node=this.createElementNSPlus("feature:"+this.geometryName);var type=this.geometryTypes[geometry.CLASS_NAME];var child=this.writeNode("gml:"+type,geometry,node);if(this.srsName){child.setAttribute("srsName",this.srsName);}
+return node;},"_attribute":function(obj){return this.createElementNSPlus("feature:"+obj.name,{value:obj.value});}},"wfs":{"FeatureCollection":function(features){var node=this.createElementNSPlus("wfs:FeatureCollection");for(var i=0,len=features.length;i<len;++i){this.writeNode("gml:featureMember",features[i],node);}
+return node;}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.Base"});OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(options){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[options]);},readers:{"gml":OpenLayers.Util.applyDefaults({"outerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"innerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]
 );},"Box":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="wfs:FeatureCollection";}else{name="gml:featureMember";}
+var root=this.writeNode(name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[geometry],node);return node;},"coordinates":function(points){var numPoints=points.length;var parts=new Array(numPoints);var point;for(var i=0;i<numPoints;++i){point=points[i];if(this.xy){parts[i]=point.x+","+point.y;}else{parts[i]=point.y+","+point.x;}
+if(point.z!=undefined){parts[i]+=","+point.z;}}
+return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:(numPoints==1)?parts[0]:parts.join(" ")});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",geometry.components,node);return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",geometry.components[0],node);for(var i=1;i<geometry.components.length;++i){this.writeNode("innerBoundaryIs",geometry.components[i],node);}
+return node;},"outerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"innerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:innerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",ring.components,node);return node;},"Box":function(bounds){var node=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:bounds.left,y:bounds.bottom},{x:bounds.right,y:bounds.top}],node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
+return node;}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},CLASS_NAME:"OpenLayers.Format.GML.v2"});OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
+this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
+this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
+if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
+if(rules.length>0&&appliedRules==false){style.display="none";}
+if(style.label!=null&&typeof style.label!=="string"){style.label=String(style.label);}
+return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
+if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
+if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
+return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
+return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
+return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
+return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
+options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
+return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(config){OpenLayers.Util.extend(this,config);},clone:function(){var Type=eval(this.CLASS_NAME);return new Type(OpenLayers.Util.extend({},this));},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Point"});OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});OpenLayers.Symbolizer.T
 ext=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
+this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
+if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
+if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
+if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
+return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
+if(typeof this.context=="function"){context=this.context(feature);}
+return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
+options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Format.OGCExceptionReport=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},defaultPrefix:"ogc",read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var exceptionInfo={exceptionReport:null};if(root){this.readChildNodes(data,exceptionInfo);if(exceptionInfo.exceptionReport===null){exceptionInfo=new OpenLayers.Format.OWSCommon().read(data);}}
+return exceptionInfo;},readers:{"ogc":{"ServiceExceptionReport":function(node,obj){obj.exceptionReport={exceptions:[]};this.readChildNodes(node,obj.exceptionReport);},"ServiceException":function(node,exceptionReport){var exception={code:node.getAttribute("code"),locator:node.getAttribute("locator"),text:this.getChildValue(node)};exceptionReport.exceptions.push(exception);}}},CLASS_NAME:"OpenLayers.Format.OGCExceptionReport"});OpenLayers.Format.XML.VersionedOGC=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:null,version:null,profile:null,errorProperty:null,name:null,stringifyOutput:false,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);var className=this.CLASS_NAME;this.name=className.substring(className.lastIndexOf(".")+1);},getVersion:function(root,options){var version;if(root){version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}}else{version=(optio
 ns&&options.version)||this.version||this.defaultVersion;}
+return version;},getParser:function(version){version=version||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format[this.name]["v"+version.replace(/\./g,"_")+profile];if(!format){throw"Can't find a "+this.name+" parser for version "+
+version+profile;}
+this.parser=new format(this.options);}
+return this.parser;},write:function(obj,options){var version=this.getVersion(null,options);this.parser=this.getParser(version);var root=this.parser.write(obj,options);if(this.stringifyOutput===false){return root;}else{return OpenLayers.Format.XML.prototype.write.apply(this,[root]);}},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.getVersion(root);this.parser=this.getParser(version);var obj=this.parser.read(data,options);if(this.errorProperty!==null&&obj[this.errorProperty]===undefined){var format=new OpenLayers.Format.OGCExceptionReport();obj.error=format.read(data);}
+obj.version=version;return obj;},CLASS_NAME:"OpenLayers.Format.XML.VersionedOGC"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,type:"FID",initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
+return false;},clone:function(){var filter=new OpenLayers.Filter.FeatureId();OpenLayers.Util.extend(filter,this);filter.fids=this.fids.slice();return filter;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
+return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
+return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
+return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
+return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);if(this.type===OpenLayers.Filter.Comparison.LIKE&&options.matchCase===undefined){this.matchCase=null;}},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
+var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
+break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
+break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
+return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){throw new Error("'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison");}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
+if(feature.geometry.intersects(geom)){intersect=true;}}
+break;default:throw new Error('evaluate is not implemented for this filter type.');}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",stringifyOutput:true,namedLayersAsArray:false,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,CLASS_NAME:"OpenLayers.Filter.Function"});OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http:
 //www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.O
 R});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});thi
 s.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.CONTAINS);},"DWithin":function(node,obj){this.readSpatial(nod
 e,obj,OpenLayers.Filter.Spatial.DWITHIN);},"Distance":function(node,obj){obj.distance=parseInt(this.getChildValue(node));obj.distanceUnits=node.getAttribute("units");},"Function":function(node,obj){return;}}},readSpatial:function(node,obj,type){var filter=new OpenLayers.Filter.Spatial({type:type});this.readChildNodes(node,filter);filter.value=filter.components[0];delete filter.components;obj.filters.push(filter);},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(value===undefined){value=this.getChildValue(node);}
+return value;},writeOgcExpression:function(value,node){if(value instanceof OpenLayers.Filter.Function){var child=this.writeNode("Function",value,node);node.appendChild(child);}else{this.writeNode("Literal",value,node);}
+return node;},write:function(filter){return this.writers.ogc["Filter"].apply(this,[filter]);},writeFeatureIdNodes:function(filter,node){for(var i=0,ii=filter.fids.length;i<ii;++i){this.writeNode("FeatureId",filter.fids[i],node);}},writers:{"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");if(filter.type==="FID"){OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,filter,node);}else{this.writeNode(this.getFilterType(filter),filter,node);}
+return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0,ii=filter.filters.length;i<ii;++i){childFilter=filter.filters[i];if(childFilter.type==="FID"){OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}}
+return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0,ii=filter.filters.length;i<ii;++i){childFilter=filter.filters[i];if(childFilter.type==="FID"){OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}}
+return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];if(childFilter.type==="FID"){OpenLayers.Format.Filter.v1.prototype.writeFeatureIdNodes.call(this,childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}
+return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",filter,no
 de);this.writeNode("LowerBoundary",filter,node);this.writeNode("UpperBoundary",filter,node);return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeOgcExpression(filter.lowerBoundary,node);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",filter.upperBoundary,node);return node;},"INTERSECTS":function(filter){return this.writeSpatial(filter,"Intersects");},"WITHIN":function(filter){return this.writeSpatial(filter,"Within");},"CONTAINS":function(filter){return this.writeSpatial(filter,"Contains");},"DWITHIN":function(filter){var node=this.writeSpatial(filter,"DWithin");this.writeNode("Distance",filter,node);return node;},"Distance":function(filter){re
 turn this.createElementNSPlus("ogc:Distance",{attributes:{units:filter.distanceUnits},value:filter.distance});},"Function":function(filter){var node=this.createElementNSPlus("ogc:Function",{attributes:{name:filter.name}});var params=filter.params;for(var i=0,len=params.length;i<len;i++){this.writeOgcExpression(params[i],node);}
+return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"Filter writing not supported for rule type: "+filter.type;}
+return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike","BBOX":"BBOX","DWITHIN":"DWITHIN","WITHIN":"WITHIN","CONTAINS":"CONTAINS","INTERSECTS":"INTERSECTS","FID":"FeatureId"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqual
 To":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){va
 r node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");filter.property&&this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Box",filter.value,node);if(filter.projection){box.setAttribute("srsName",filter.projection);}
+return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);if(filter.value instanceof OpenLayers.Filter.Function){this.writeNode("Function",filter.value,node);}else{var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Box",filter.value);}
+if(filter.projection){child.setAttribute("srsName",filter.projection);}
+node.appendChild(child);}
+return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,multipleSymbolizers:false,featureTypeCounter:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,strokeDashstyle:"solid",pointRadius:3,graphicName:"square"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var sld={namedLayers:options.namedLayersAsArray===true?[]:{}};this.readChildNodes(data,sld);return sld;},readers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=n
 ode.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0,len=layer.userStyles.length;i<len;++i){layer.userStyles[i].layerName=layer.name;}
+if(OpenLayers.Util.isArray(sld.namedLayers)){sld.namedLayers.push(layer);}else{sld.namedLayers[layer.name]=layer;}},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildValue(node.firstChild));},"UserStyle":function(node,layer){var obj={defaultsPerSymbolizer:true,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(node,obj);var style;if(this.multipleSymbolizers){delete obj.defaultsPerSymbolizer;style=new OpenLayers.Style2(obj);}else{style=new OpenLayers.Style(this.defaultSymbolizer,obj);}
+layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){++this.featureTypeCounter;var obj={rules:this.multipleSymbolizers?style.rules:[]};this.readChildNodes(node,obj);if(!this.multipleSymbolizers){style.rules=obj.rules;}},"Rule":function(node,obj){var config;if(this.multipleSymbolizers){config={symbolizers:[]};}
+var rule=new OpenLayers.Rule(config);this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=parseFloat(this.getChildValue(node));},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=parseFloat(this.getChildValue(node));},"TextSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Text(config));}else{rule.symbolizer["Text"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Text"]);}},"Label":function(node,symbolizer){var obj={};this.readChildNodes(node,obj);if(obj.property){symbolizer.label="${"+obj.property+"}";}else{var value=this.readOgcExpression(node);if(value){symbolizer.label=value;}}},"Font":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Halo":function(node,symbolizer){var
 obj={};this.readChildNodes(node,obj);symbolizer.haloRadius=obj.haloRadius;symbolizer.haloColor=obj.fillColor;symbolizer.haloOpacity=obj.fillOpacity;},"Radius":function(node,symbolizer){var radius=this.readOgcExpression(node);if(radius!=null){symbolizer.haloRadius=radius;}},"RasterSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Raster(config));}else{rule.symbolizer["Raster"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Raster"]);}},"Geometry":function(node,obj){obj.geometry={};this.readChildNodes(node,obj.geometry);},"ColorMap":function(node,symbolizer){symbolizer.colorMap=[];this.readChildNodes(node,symbolizer.colorMap);},"ColorMapEntry":function(node,colorMap){var q=node.getAttribute("quantity");var o=node.getAttribute("opacity");colorMap.push({color:node.getAttribute("color"),quantity:q!==null?parseFloat(q):undefined,lab
 el:node.getAttribute("label")||undefined,opacity:o!==null?parseFloat(o):undefined});},"LineSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Line(config));}else{rule.symbolizer["Line"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Line"]);}},"PolygonSymbolizer":function(node,rule){var config={fill:false,stroke:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Polygon"]||config;}
+this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Polygon(config));}else{rule.symbolizer["Polygon"]=config;}},"PointSymbolizer":function(node,rule){var config={fill:false,stroke:false,graphic:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Point"]||config;}
+this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Point(config));}else{rule.symbolizer["Point"]=config;}},"Stroke":function(node,symbolizer){symbolizer.stroke=true;this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){symbolizer.fill=true;this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){symbolizer.graphic=true;var graphic={};this.readChildNodes(node,graphic);var properties=["stroke","strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fill","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0,len=properties.length;i<len;++i){prop=properties[i];value=graphic[prop];if(v
 alue!=undefined){symbolizer[prop]=value;}}
+if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
+if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size/2;}
+if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}
+if(graphic.rotation!=undefined){symbolizer.rotation=graphic.rotation;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.readOgcExpression(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.readOgcExpression(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.readOgcExpression(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}}},OpenLayers.Format.Filter.v1_0_0.prototype.readers),cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","stroke-dasharray":"s
 trokeDashstyle","fill":"fillColor","fill-opacity":"fillOpacity","font-family":"fontFamily","font-size":"fontSize","font-weight":"fontWeight","font-style":"fontStyle"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
+return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
+return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("sld:StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});root.setAttribute("xmlns:ogc",this.namespaces.ogc);root.setAttribute("xmlns:gml",this.namespaces.gml);if(sld.name){this.writeNode("Name",sld.name,root);}
+if(sld.title){this.writeNode("Title",sld.title,root);}
+if(sld.description){this.writeNode("Abstract",sld.description,root);}
+if(OpenLayers.Util.isArray(sld.namedLayers)){for(var i=0,len=sld.namedLayers.length;i<len;++i){this.writeNode("NamedLayer",sld.namedLayers[i],root);}}else{for(var name in sld.namedLayers){this.writeNode("NamedLayer",sld.namedLayers[name],root);}}
+return root;},"Name":function(name){return this.createElementNSPlus("sld:Name",{value:name});},"Title":function(title){return this.createElementNSPlus("sld:Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("sld:Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("sld:NamedLayer");this.writeNode("Name",layer.name,node);if(layer.namedStyles){for(var i=0,len=layer.namedStyles.length;i<len;++i){this.writeNode("NamedStyle",layer.namedStyles[i],node);}}
+if(layer.userStyles){for(var i=0,len=layer.userStyles.length;i<len;++i){this.writeNode("UserStyle",layer.userStyles[i],node);}}
+return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("sld:NamedStyle");this.writeNode("Name",name,node);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("sld:UserStyle");if(style.name){this.writeNode("Name",style.name,node);}
+if(style.title){this.writeNode("Title",style.title,node);}
+if(style.description){this.writeNode("Abstract",style.description,node);}
+if(style.isDefault){this.writeNode("IsDefault",style.isDefault,node);}
+if(this.multipleSymbolizers&&style.rules){var rulesByZ={0:[]};var zValues=[0];var rule,ruleMap,symbolizer,zIndex,clone;for(var i=0,ii=style.rules.length;i<ii;++i){rule=style.rules[i];if(rule.symbolizers){ruleMap={};for(var j=0,jj=rule.symbolizers.length;j<jj;++j){symbolizer=rule.symbolizers[j];zIndex=symbolizer.zIndex;if(!(zIndex in ruleMap)){clone=rule.clone();clone.symbolizers=[];ruleMap[zIndex]=clone;}
+ruleMap[zIndex].symbolizers.push(symbolizer.clone());}
+for(zIndex in ruleMap){if(!(zIndex in rulesByZ)){zValues.push(zIndex);rulesByZ[zIndex]=[];}
+rulesByZ[zIndex].push(ruleMap[zIndex]);}}else{rulesByZ[0].push(rule.clone());}}
+zValues.sort();var rules;for(var i=0,ii=zValues.length;i<ii;++i){rules=rulesByZ[zValues[i]];if(rules.length>0){clone=style.clone();clone.rules=rulesByZ[zValues[i]];this.writeNode("FeatureTypeStyle",clone,node);}}}else{this.writeNode("FeatureTypeStyle",style,node);}
+return node;},"IsDefault":function(bool){return this.createElementNSPlus("sld:IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("sld:FeatureTypeStyle");for(var i=0,len=style.rules.length;i<len;++i){this.writeNode("Rule",style.rules[i],node);}
+return node;},"Rule":function(rule){var node=this.createElementNSPlus("sld:Rule");if(rule.name){this.writeNode("Name",rule.name,node);}
+if(rule.title){this.writeNode("Title",rule.title,node);}
+if(rule.description){this.writeNode("Abstract",rule.description,node);}
+if(rule.elseFilter){this.writeNode("ElseFilter",null,node);}else if(rule.filter){this.writeNode("ogc:Filter",rule.filter,node);}
+if(rule.minScaleDenominator!=undefined){this.writeNode("MinScaleDenominator",rule.minScaleDenominator,node);}
+if(rule.maxScaleDenominator!=undefined){this.writeNode("MaxScaleDenominator",rule.maxScaleDenominator,node);}
+var type,symbolizer;if(this.multipleSymbolizers&&rule.symbolizers){var symbolizer;for(var i=0,ii=rule.symbolizers.length;i<ii;++i){symbolizer=rule.symbolizers[i];type=symbolizer.CLASS_NAME.split(".").pop();this.writeNode(type+"Symbolizer",symbolizer,node);}}else{var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=types.length;i<len;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(type+"Symbolizer",symbolizer,node);}}}
+return node;},"ElseFilter":function(){return this.createElementNSPlus("sld:ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("sld:MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("sld:MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:LineSymbolizer");this.writeNode("Stroke",symbolizer,node);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("sld:Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeColor"},node);}
+if(symbolizer.strokeOpacity!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"},node);}
+if(symbolizer.strokeWidth!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeWidth"},node);}
+if(symbolizer.strokeDashstyle!=undefined&&symbolizer.strokeDashstyle!=="solid"){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeDashstyle"},node);}
+if(symbolizer.strokeLinecap!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeLinecap"},node);}
+return node;},"CssParameter":function(obj){return this.createElementNSPlus("sld:CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"TextSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:TextSymbolizer");if(symbolizer.label!=null){this.writeNode("Label",symbolizer.label,node);}
+if(symbolizer.fontFamily!=null||symbolizer.fontSize!=null||symbolizer.fontWeight!=null||symbolizer.fontStyle!=null){this.writeNode("Font",symbolizer,node);}
+if(symbolizer.haloRadius!=null||symbolizer.haloColor!=null||symbolizer.haloOpacity!=null){this.writeNode("Halo",symbolizer,node);}
+if(symbolizer.fillColor!=null||symbolizer.fillOpacity!=null){this.writeNode("Fill",symbolizer,node);}
+return node;},"Font":function(symbolizer){var node=this.createElementNSPlus("sld:Font");if(symbolizer.fontFamily){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontFamily"},node);}
+if(symbolizer.fontSize){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontSize"},node);}
+if(symbolizer.fontWeight){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontWeight"},node);}
+if(symbolizer.fontStyle){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontStyle"},node);}
+return node;},"Label":function(label){var node=this.createElementNSPlus("sld:Label");var tokens=label.split("${");node.appendChild(this.createTextNode(tokens[0]));var item,last;for(var i=1,len=tokens.length;i<len;i++){item=tokens[i];last=item.indexOf("}");if(last>0){this.writeNode("ogc:PropertyName",{property:item.substring(0,last)},node);node.appendChild(this.createTextNode(item.substring(++last)));}else{node.appendChild(this.createTextNode("${"+item));}}
+return node;},"Halo":function(symbolizer){var node=this.createElementNSPlus("sld:Halo");if(symbolizer.haloRadius){this.writeNode("Radius",symbolizer.haloRadius,node);}
+if(symbolizer.haloColor||symbolizer.haloOpacity){this.writeNode("Fill",{fillColor:symbolizer.haloColor,fillOpacity:symbolizer.haloOpacity},node);}
+return node;},"Radius":function(value){return this.createElementNSPlus("sld:Radius",{value:value});},"RasterSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:RasterSymbolizer");if(symbolizer.geometry){this.writeNode("Geometry",symbolizer.geometry,node);}
+if(symbolizer.opacity){this.writeNode("Opacity",symbolizer.opacity,node);}
+if(symbolizer.colorMap){this.writeNode("ColorMap",symbolizer.colorMap,node);}
+return node;},"Geometry":function(geometry){var node=this.createElementNSPlus("sld:Geometry");if(geometry.property){this.writeNode("ogc:PropertyName",geometry,node);}
+return node;},"ColorMap":function(colorMap){var node=this.createElementNSPlus("sld:ColorMap");for(var i=0,len=colorMap.length;i<len;++i){this.writeNode("ColorMapEntry",colorMap[i],node);}
+return node;},"ColorMapEntry":function(colorMapEntry){var node=this.createElementNSPlus("sld:ColorMapEntry");var a=colorMapEntry;node.setAttribute("color",a.color);a.opacity!==undefined&&node.setAttribute("opacity",parseFloat(a.opacity));a.quantity!==undefined&&node.setAttribute("quantity",parseFloat(a.quantity));a.label!==undefined&&node.setAttribute("label",a.label);return node;},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:PolygonSymbolizer");if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
+if(symbolizer.stroke!==false){this.writeNode("Stroke",symbolizer,node);}
+return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("sld:Fill");if(symbolizer.fillColor){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fillColor"},node);}
+if(symbolizer.fillOpacity!=null){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fillOpacity"},node);}
+return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:PointSymbolizer");this.writeNode("Graphic",symbolizer,node);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("sld:Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode("ExternalGraphic",symbolizer,node);}else{this.writeNode("Mark",symbolizer,node);}
+if(symbolizer.graphicOpacity!=undefined){this.writeNode("Opacity",symbolizer.graphicOpacity,node);}
+if(symbolizer.pointRadius!=undefined){this.writeNode("Size",symbolizer.pointRadius*2,node);}
+if(symbolizer.rotation!=undefined){this.writeNode("Rotation",symbolizer.rotation,node);}
+return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",symbolizer.externalGraphic,node);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode("Format",format,node);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("sld:Mark");if(symbolizer.graphicName){this.writeNode("WellKnownName",symbolizer.graphicName,node);}
+if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
+return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[option
 s]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{layerOptions:null,layerParams:null,read:function(data,options){var context=OpenLayers.Format.XML.VersionedOGC.prototype.read.apply(this,arguments);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
+map=this.contextToMap(context,mapOptions);}}else{map=context;}
+return map;},getLayerFromContext:function(layerContext){var i,len;var options={queryable:layerContext.queryable,visibility:layerContext.visibility,maxExtent:layerContext.maxExtent,metadata:OpenLayers.Util.applyDefaults(layerContext.metadata,{styles:layerContext.styles,formats:layerContext.formats,"abstract":layerContext["abstract"],dataURL:layerContext.dataURL}),numZoomLevels:layerContext.numZoomLevels,units:layerContext.units,isBaseLayer:layerContext.isBaseLayer,opacity:layerContext.opacity,displayInLayerSwitcher:layerContext.displayInLayerSwitcher,singleTile:layerContext.singleTile,tileSize:(layerContext.tileSize)?new OpenLayers.Size(layerContext.tileSize.width,layerContext.tileSize.height):undefined,minScale:layerContext.minScale||layerContext.maxScaleDenominator,maxScale:layerContext.maxScale||layerContext.minScaleDenominator,srs:layerContext.srs,dimensions:layerContext.dimensions,metadataURL:layerContext.metadataURL};if(this.layerOptions){OpenLayers.Util.applyDefaults(o
 ptions,this.layerOptions);}
+var params={layers:layerContext.name,transparent:layerContext.transparent,version:layerContext.version};if(layerContext.formats&&layerContext.formats.length>0){params.format=layerContext.formats[0].value;for(i=0,len=layerContext.formats.length;i<len;i++){var format=layerContext.formats[i];if(format.current==true){params.format=format.value;break;}}}
+if(layerContext.styles&&layerContext.styles.length>0){for(i=0,len=layerContext.styles.length;i<len;i++){var style=layerContext.styles[i];if(style.current==true){if(style.href){params.sld=style.href;}else if(style.body){params.sld_body=style.body;}else{params.styles=style.name;}
+break;}}}
+if(this.layerParams){OpenLayers.Util.applyDefaults(params,this.layerParams);}
+var layer=null;var service=layerContext.service;if(service==OpenLayers.Format.Context.serviceTypes.WFS){options.strategies=[new OpenLayers.Strategy.BBOX()];options.protocol=new OpenLayers.Protocol.WFS({url:layerContext.url,featurePrefix:layerContext.name.split(":")[0],featureType:layerContext.name.split(":").pop()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.KML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.KML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.GML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.GML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.na
 me,options);}else if(layerContext.features){layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);layer.addFeatures(layerContext.features);}else if(layerContext.categoryLayer!==true){layer=new OpenLayers.Layer.WMS(layerContext.title||layerContext.name,layerContext.url,params,options);}
+return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
+return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection,units:context.units},options);if(options.maxExtent){options.maxResolution=options.maxExtent.getWidth()/OpenLayers.Map.TILE_WIDTH;}
+var metadata={contactInformation:context.contactInformation,"abstract":context["abstract"],keywords:context.keywords,logo:context.logo,descriptionURL:context.descriptionURL};options.metadata=metadata;var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);return OpenLayers.Format.XML.VersionedOGC.prototype.write.apply(this,arguments);},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSContext=
 OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getVersion:function(root,options){var version=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);if(version==="0.3.0"){version=this.defaultVersion;}
+return version;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
+return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});OpenLayers.Format.OWSCommon=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",getVersion:function(root,options){var version=this.version;if(!version){var uri=root.getAttribute("xmlns:ows");if(uri&&uri.substring(uri.lastIndexOf("/")+1)==="1.1"){version="1.1.0";}
+if(!version){version=this.defaultVersion;}}
+return version;},CLASS_NAME:"OpenLayers.Format.OWSCommon"});OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var ows={};this.readChildNodes(data,ows);return ows;},readers:{"ows":{"Exception":function(node,exceptionReport){var exception={code:node.getAttribute('exceptionCode'),locator:node.getAttribute('locator'),texts:[]};exceptionReport.exceptions.push(exception);this.readChildNodes(node,exception);},"ExceptionText":function(node,exception){var text=this.getChildValue(node);exception.texts.push(text);},"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=
 this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(no
 de,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.readChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=
 this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadata={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=[];http.get.push(this.getAttributeNS(no
 de,this.namespaces.xlink,"href"));},"Post":function(node,http){http.post=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Parameter":function(node,operation){if(!operation.parameters){operation.parameters={};}
+var name=node.getAttribute("name");operation.parameters[name]={};this.readChildNodes(node,operation.parameters[name]);},"Value":function(node,allowedValues){allowedValues[this.getChildValue(node)]=true;},"OutputFormat":function(node,obj){obj.formats.push({value:this.getChildValue(node)});this.readChildNodes(node,obj);},"WGS84BoundingBox":function(node,obj){var boundingBox={};boundingBox.crs=node.getAttribute("crs");if(obj.boundingBox){obj.boundingBox.push(boundingBox);}else{obj.projection=boundingBox.crs;boundingBox=obj;}
+this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;},"Language":function(node,obj){obj.language=this.getChildValue(node);}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:
 LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,node);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Identifier":function(identifier){var node=this.createElementNSPlus("ows:Identifier",{value:identifier});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"Abstract":function(abstractValue){var node=this.createElementNSPlus("ows:Abstract",{value:abstractValue});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;},"Identifier":function(identifier){var node=this.createElementNSPlus("ows:Identifier",{attributes:{},value:identifier});return node;},"Version":
 function(version){var node=this.createElementNSPlus("ows:Version",{attributes:{},value:version});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"ExceptionReport":function(node,obj){obj.success=false;obj.exceptionReport={version:node.getAttribute('version'),language:node.getAttribute('language'),exceptions:[]};this.readChildNodes(node,obj.exceptionReport);}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_0_0"});OpenLayers.Format.OWSContext.v0_3_1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/
 ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<len;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
+if(nTitle!=""){nPath.push(nTitle);}
+layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(OpenLayers.Util.isArray(nPath)){var path=nPath.slice();while(path.length>0){a.push(path.slice());path.pop();}
+a.reverse();}
+return a;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var context={};this.readNode(data,context);this.setNestingPath({layersContext:context.layersContext});var layers=[];this.processLayer(layers,context);delete context.layersContext;context.layersContext=layers;return context;},processLayer:function(layerArray,layer){if(layer.layersContext){for(var i=0,len=layer.layersContext.length;i<len;i++){var l=layer.layersContext[i];layerArray.push(l);if(l.layersContext){this.processLayer(layerArray,l);}}}},write:function(context,options){var name="OWSContext";this.nestingLayerLookup={};options=options||{};OpenLayers.Util.applyDefaults(options,context);var root=this.writeNode(name,options);this.nestingLayerLookup=null;this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},readers:{"kml":{"Document":function(node,obj){obj.features=new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:true}).read(node);}},"owc":{"OWSContext":fun
 ction(node,obj){this.readChildNodes(node,obj);},"General":function(node,obj){this.readChildNodes(node,obj);},"ResourceList":function(node,obj){this.readChildNodes(node,obj);},"Layer":function(node,obj){var layerContext={metadata:{},visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),opacity:((node.getAttribute("opacity")!=null)?parseFloat(node.getAttribute("opacity")):null),name:node.getAttribute("name"),categoryLayer:(node.getAttribute("name")==null),formats:[],styles:[]};if(!obj.layersContext){obj.layersContext=[];}
+obj.layersContext.push(layerContext);this.readChildNodes(node,layerContext);},"InlineGeometry":function(node,obj){obj.features=[];var elements=this.getElementsByTagNameNS(node,this.namespaces.gml,"featureMember");var el;if(elements.length>=1){el=elements[0];}
+if(el&&el.firstChild){var featurenode=(el.firstChild.nextSibling)?el.firstChild.nextSibling:el.firstChild;this.setNamespace("feature",featurenode.namespaceURI);this.featureType=featurenode.localName||featurenode.nodeName.split(":").pop();this.readChildNodes(node,obj);}},"Server":function(node,obj){if((!obj.service&&!obj.version)||(obj.service!=OpenLayers.Format.Context.serviceTypes.WMS)){obj.service=node.getAttribute("service");obj.version=node.getAttribute("version");this.readChildNodes(node,obj);}},"Name":function(node,obj){obj.name=this.getChildValue(node);this.readChildNodes(node,obj);},"Title":function(node,obj){obj.title=this.getChildValue(node);this.readChildNodes(node,obj);},"StyleList":function(node,obj){this.readChildNodes(node,obj.styles);},"Style":function(node,obj){var style={};obj.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={};obj.legend=legend;this.readChildNodes(node,legend);},"OnlineResource":function(node,obj){obj
 .url=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,obj);}},"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,"gml":OpenLayers.Format.GML.v2.prototype.readers.gml,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,"feature":OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{"owc":{"OWSContext":function(options){var node=this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,id:options.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",options,node);this.writeNode("ResourceList",options,node);return node;},"General":function(options){var node=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",options,node);this.writeNode("ows:Title",options.title||'OpenLayers OWSContext',node);return node;},"ResourceList":function(options){var node=this.createElementNSPlus("ResourceList");for(var i=0,len=options.layers.length;i<len;i++){var layer=options.layer
 s[i];var decomposedPath=this.decomposeNestingPath(layer.metadata.nestingPath);this.writeNode("_Layer",{layer:layer,subPaths:decomposedPath},node);}
+return node;},"Server":function(options){var node=this.createElementNSPlus("Server",{attributes:{version:options.version,service:options.service}});this.writeNode("OnlineResource",options,node);return node;},"OnlineResource":function(options){var node=this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":options.url}});return node;},"InlineGeometry":function(layer){var node=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",layer.getDataExtent(),node);for(var i=0,len=layer.features.length;i<len;i++){this.writeNode("gml:featureMember",layer.features[i],node);}
+return node;},"StyleList":function(styles){var node=this.createElementNSPlus("StyleList");for(var i=0,len=styles.length;i<len;i++){this.writeNode("Style",styles[i],node);}
+return node;},"Style":function(style){var node=this.createElementNSPlus("Style");this.writeNode("Name",style,node);this.writeNode("Title",style,node);if(style.legend){this.writeNode("LegendURL",style,node);}
+return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.hasOwnProperty("opacity")?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.metadata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
+return node;},"_Layer":function(options){var layer,subPaths,node,title;layer=options.layer;subPaths=options.subPaths;node=null;title=null;if(subPaths.length>0){var path=subPaths[0].join("/");var index=path.lastIndexOf("/");node=this.nestingLayerLookup[path];title=(index>0)?path.substring(index+1,path.length):path;if(!node){node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",title,node);this.nestingLayerLookup[path]=node;}
+options.subPaths.shift();this.writeNode("_Layer",options,node);return node;}else{if(layer instanceof OpenLayers.Layer.WMS){node=this.writeNode("_WMS",layer);}else if(layer instanceof OpenLayers.Layer.Vector){if(layer.protocol instanceof OpenLayers.Protocol.WFS.v1){node=this.writeNode("_WFS",layer);}else if(layer.protocol instanceof OpenLayers.Protocol.HTTP){if(layer.protocol.format instanceof OpenLayers.Format.GML){layer.protocol.format.version="2.1.2";node=this.writeNode("_GML",layer);}else if(layer.protocol.format instanceof OpenLayers.Format.KML){layer.protocol.format.version="2.2";node=this.writeNode("_KML",layer);}}else{this.setNamespace("feature",this.featureNS);node=this.writeNode("_InlineGeometry",layer);}}
+if(layer.options.maxScale){this.writeNode("sld:MinScaleDenominator",layer.options.maxScale,node);}
+if(layer.options.minScale){this.writeNode("sld:MaxScaleDenominator",layer.options.minScale,node);}
+this.nestingLayerLookup[layer.name]=node;return node;}},"_WFS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.protocol.featurePrefix+":"+layer.protocol.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:layer.protocol.version,url:layer.protocol.url},node);return node;},"_InlineGeometry":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("InlineGeometry",layer,node);return node;},"_GML":function(layer){var node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:layer.protocol.url,version:layer.protocol.format.version},node);return node;},"_KML":function(layer){var node=this.createE
 lementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:layer.protocol.format.version,url:layer.protocol.url},node);return node;}},"gml":OpenLayers.Util.applyDefaults({"boundedBy":function(bounds){var node=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",bounds,node);return node;}},OpenLayers.Format.GML.v2.prototype.writers.gml),"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,"feature":OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Format.CSWGetRecords=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetRecords.DEFAULTS);var cls=OpenLayers.Format.CSWGetRecords["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetRecords version: "+options.version;}
+return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.events=null;}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}
+this.div=null;},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:false,handlers:null,resolutionFactor:1,maximized:false,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
+if(this.handlers.click){this.handlers.click.destroy();}
+if(this.handlers.drag){this.handlers.drag.destroy();}
+this.ovmap&&this.ovmap.eventsDiv.removeChild(this.extentRectangle);this.extentRectangle=null;if(this.rectEvents){this.rectEvents.destroy();this.rectEvents=null;}
+if(this.ovmap){this.ovmap.destroy();this.ovmap=null;}
+this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
+if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
+this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
+this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.m
 aximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0,len=eventsToStop.length;i<len;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
+this.minimizeControl();}else{this.element.style.display='';}
+if(this.map.getExtent()){this.update();}
+this.map.events.register('moveend',this,this.update);if(this.maximized){this.maximizeControl();}
+return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var
 width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
+if(this.autoPan||!this.isSuitableOverview()){this.updateOverview();}
+this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));if(this.ovmap.getProjection()!=this.map.getProjection()){testExtent=testExtent.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}
+var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
+var center;if(this.ovmap.getProjection()!=this.map.getProjection()){center=this.map.center.clone();center.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{center=this.map.center;}
+this.ovmap.setCenter(center,this.ovmap.getZoomForResolution(targetRes*this.resolutionFactor));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);this.ovmap.eventsDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});if(this.ovmap.getProjection()!=this.map.getProjection()){var sourceUnits=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;var targetUnits=this.ovmap.getProjectionObject
 ().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=sourceUnits&&targetUnits?OpenLayers.INCHES_PER_UNIT[sourceUnits]/OpenLayers.INCHES_PER_UNIT[targetUnits]:1;}},updateRectToMap:function(){var bounds;if(this.ovmap.getProjection()!=this.map.getProjection()){bounds=this.map.getExtent().transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{bounds=this.map.getExtent();}
+var pxBounds=this.getRectBoundsFromMapBounds(bounds);if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);if(this.ovmap.getProjection()!=this.map.getProjection()){lonLatBounds=lonLatBounds.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject());}
+this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
+this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
+this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
+return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat))
+return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){throw new TypeError('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,null,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.width='100px';this.layerContainerDiv.style.height='100px';this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContai
 nerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
+if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
+if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
+for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){delete this.center;this.addLayers(options.layers);if(options.center){this.setCenter(options.center,options.zoom);}}},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+if(this.panTween){this.panTween.stop();this.panTween=null;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
+this.controls=null;}
+if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
+this.layers=null;}
+if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+this.events.destroy();this.events=null;},setOptions:function(options){var updatePxExtent=this.minPx&&options.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,options);updatePxExtent&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:true});},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(
 var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
+return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
++zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){throw new Error("You tried to add the layer: "+layer.name+" to the map, but it has already been added");}}
+if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
+if(this.allOverlays){layer.isBaseLayer=false;}
+layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
+this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
+this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(this.events.triggerEvent("preremovelayer",{layer:layer})===false){return;}
+if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
+OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
+this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});layer.events.triggerEvent("removed",{map:this,layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
+if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0,len=this.layers.length;i<len;i++){this.setLayerZIndex(this.layers[i],i);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"order"});if(this.allOverlays){if(idx===0){this.setBaseLayer(layer);}else if(this.baseLayer!==this.layers[0]){this.setBaseLayer(this.layers[0]);}}}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){var center=this.getCachedCenter();var newResolution=OpenLayers.Util.getResolutionFromScale(this.getScale(),newBaseLayer.units);if(this.baseLayer!=null&&!this.allOverlays){this.baseLayer.setVisibility(false);}
+this.baseLayer=newBaseLayer;if(!this.allOverlays||this.baseLayer.visibility){this.baseLayer.setVisibility(true);}
+if(center!=null){var newZoom=this.getZoomForResolution(newResolution||this.resolution,true);this.setCenter(center,newZoom,false,true);}
+this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControls:function(controls,pixels){var pxs=(arguments.length===1)?[]:pixels;for(var i=0,len=controls.length;i<len;i++){var ctrl=controls[i];var px=(pxs[i])?pxs[i]:null;this.addControl(ctrl,px);}},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
+control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
+this.controls.length;this.viewPortDiv.appendChild(div);}}
+if(control.autoActivate){control.activate();}},getControl:function(id){var returnControl=null;for(var i=0,len=this.controls.length;i<len;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
+return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
+OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
+popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
+this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
+catch(e){}}
+popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
+return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
+if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
+var center=this.getCachedCenter();if(this.baseLayer!=null&&center!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
+if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
+return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCachedCenter();}
+if(resolution==null){resolution=this.getResolution();}
+if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
+return extent;},getCenter:function(){var center=null;var cachedCenter=this.getCachedCenter();if(cachedCenter){center=cachedCenter.clone();}
+return center;},getCachedCenter:function(){if(!this.center&&this.size){this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));}
+return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});if(options.dragging){if(dx!=0||dy!=0){this.moveByPx(dx,dy);}}else{var centerPx=this.getViewPortPxFromLonLat(this.getCachedCenter());var newCenterPx=centerPx.add(dx,dy);if(this.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.moveTo(newCenterLonLat);this.dragging=false;this.events.triggerEvent("moveend");}}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCachedCenter();if(lonlat.equals(center)){return;}
+var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
+dx=wrapDateLine||x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction?Math.round(dx):0;dy=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction?Math.round(dy):0;var minX=this.minPx.x,maxX=this.maxPx.x;if(dx||dy){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
+this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;}
+if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
+var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility&&(layer===this.baseLayer||layer.inRange)){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
+this.events.triggerEvent("move");}},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
+var dragging=options.dragging||this.dragging;var forceZoomChange=options.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();this.center=lonlat.clone();}
+if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.center;}
+if(zoom==null){zoom=this.getZoom();}
+var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
+extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
+extent.right,0);}
+if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
+extent.bottom);}
+else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
+extent.top);}}}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||dragging){dragging||this.events.triggerEvent("movestart");if(centerChanged){if(!zoomChanged&&this.center){this.centerLayerContainer(lonlat);}
+this.center=lonlat.clone();}
+var res=zoomChanged?this.getResolutionForZoom(zoom):this.getResolution();if(zoomChanged||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var maxExtent=this.getMaxExtent({restricted:true});var maxExtentCenter=maxExtent.getCenterLonLat();var lonDelta=this.center.lon-maxExtentCenter.lon;var latDelta=maxExtentCenter.lat-this.center.lat;var extentWidth=Math.round(maxExtent.getWidth()/res);var extentHeight=Math.round(maxExtent.getHeight()/res);var left=(this.size.w-extentWidth)/2-lonDelta/res;var top=(this.size.h-extentHeight)/2-latDelta/res;this.minPx=new OpenLayers.Pixel(left,top);this.maxPx=new OpenLayers.Pixel(left+extentWidth,top+extentHeight);}
+if(zoomChanged){this.zoom=zoom;this.resolution=res;}
+var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}
+bounds=this.baseLayer.getExtent();for(var i=this.layers.length-1;i>=0;--i){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
+if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||layer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}}}
+this.events.triggerEvent("move");dragging||this.events.triggerEvent("moveend");if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}
+this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=parseInt(this.layerContainerDiv.style.left);var oldTop=parseInt(this.layerContainerDiv.style.top);var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.layerContainerDiv.style.left=newLeft+"px";this.layerContainerDiv.style.top=newTop+"px";var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();var worldBounds=this.baseLayer.wrapDateLine&&maxExtent;valid=maxExtent.containsLonLat(lonlat,{worldBounds:worldBounds});}
+return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
+return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
+return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
+return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
+return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
+return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
+return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
+center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
+this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCachedCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
+return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
+return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,trans
 itionEffect:null,metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
+this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();}
+this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
+OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
+return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions,reinitialize){if(this.options==null){this.options={};}
+OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
+if(this.map){var resolution=this.map.getResolution();var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();if(reinitialize&&this.map.baseLayer===this){this.map.setCenter(this.map.getCenter(),this.map.getZoomForResolution(resolution),false,true);this.map.events.triggerEvent("changebaselayer",{layer:this});}
+break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
+return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
+this.display(display);},moveByPx:function(dx,dy){},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
+this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
+return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len,p;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
+if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
+if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
+if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}}
+var maxResolution;if(this.options.maxResolution&&this.options.maxResolution!=="auto"){maxResolution=this.options.maxResolution;}
+if(this.options.minScale){maxResolution=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);}
+var minResolution;if(this.options.minResolution&&this.options.minResolution!=="auto"){minResolution=this.options.minResolution;}
+if(this.options.maxScale){minResolution=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);}
+if(props.resolutions){props.resolutions.sort(function(a,b){return(b-a);});if(!maxResolution){maxResolution=props.resolutions[0];}
+if(!minResolution){var lastIdx=props.resolutions.length-1;minResolution=props.resolutions[lastIdx];}}
+this.resolutions=props.resolutions;if(this.resolutions){len=this.resolutions.length;this.scales=new Array(len);for(i=0;i<len;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(this.resolutions[i],this.units);}
+this.numZoomLevels=len;}
+this.minResolution=minResolution;if(minResolution){this.maxScale=OpenLayers.Util.getScaleFromResolution(minResolution,this.units);}
+this.maxResolution=maxResolution;if(maxResolution){this.minScale=OpenLayers.Util.getScaleFromResolution(maxResolution,this.units);}},resolutionsFromScales:function(scales){if(scales==null){return;}
+var resolutions,i,len;len=scales.length;resolutions=new Array(len);for(i=0;i<len;i++){resolutions[i]=OpenLayers.Util.getResolutionFromScale(scales[i],this.units);}
+return resolutions;},calculateResolutions:function(props){var viewSize,wRes,hRes;var maxResolution=props.maxResolution;if(props.minScale!=null){maxResolution=OpenLayers.Util.getResolutionFromScale(props.minScale,this.units);}else if(maxResolution=="auto"&&this.maxExtent!=null){viewSize=this.map.getSize();wRes=this.maxExtent.getWidth()/viewSize.w;hRes=this.maxExtent.getHeight()/viewSize.h;maxResolution=Math.max(wRes,hRes);}
+var minResolution=props.minResolution;if(props.maxScale!=null){minResolution=OpenLayers.Util.getResolutionFromScale(props.maxScale,this.units);}else if(props.minResolution=="auto"&&this.minExtent!=null){viewSize=this.map.getSize();wRes=this.minExtent.getWidth()/viewSize.w;hRes=this.minExtent.getHeight()/viewSize.h;minResolution=Math.max(wRes,hRes);}
+var maxZoomLevel=props.maxZoomLevel;var numZoomLevels=props.numZoomLevels;if(typeof minResolution==="number"&&typeof maxResolution==="number"&&numZoomLevels===undefined){var ratio=maxResolution/minResolution;numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}else if(numZoomLevels===undefined&&maxZoomLevel!=null){numZoomLevels=maxZoomLevel+1;}
+if(typeof numZoomLevels!=="number"||numZoomLevels<=0||(typeof maxResolution!=="number"&&typeof minResolution!=="number")){return;}
+var resolutions=new Array(numZoomLevels);var base=2;if(typeof minResolution=="number"&&typeof maxResolution=="number"){base=Math.pow((maxResolution/minResolution),(1/(numZoomLevels-1)));}
+var i;if(typeof maxResolution==="number"){for(i=0;i<numZoomLevels;i++){resolutions[i]=maxResolution/Math.pow(base,i);}}else{for(i=0;i<numZoomLevels;i++){resolutions[numZoomLevels-1-i]=minResolution*Math.pow(base,i);}}
+return resolutions;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[low]-
+((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom,i,len;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(i=0,len=this.resolutions.length;i<len;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
+if(res<=resolution){lowRes=res;highZoom=i;break;}}
+var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
+minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
+zoom=Math.max(0,i-1);}
+return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;var map=this.map;if(viewPortPx!=null&&map.minPx){var res=map.getResolution();var maxExtent=map.getMaxExtent({restricted:true});var lon=(viewPortPx.x-map.minPx.x)*res+maxExtent.left;var lat=(map.minPx.y-viewPortPx.y)*res+maxExtent.top;lonlat=new OpenLayers.LonLat(lon,lat);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat,resolution){var px=null;if(lonlat!=null){resolution=resolution||this.map.getResolution();var extent=this.map.calculateBounds(null,resolution);px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
+return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
+if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
+if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution(),'leftTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
+return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
+this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
 er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;this.pane=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLo
 cation()+"blank.gif)";}
+if(this.isFixed){this.map.eventsDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
+this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);}
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveByPx:function(dx,dy){OpenLayers.Layer.prototype.moveByPx.apply(this,arguments
 );if(this.dragPanMapObject){this.dragPanMapObject(dx,-dy);}else{this.moveTo(this.map.getCachedCenter());}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(!zoomChanged&&oldCenter&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromVie
 wPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
+return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
+return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
+return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
+return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
+return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0,len=props.length;i<len;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
+if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
+var desiredZoomLevels;var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(((this.options.numZoomLevels==null)&&(this.options.maxZoomLevel!=null))||((this.numZoomLevels==null)&&(this.maxZoomLevel!=null))){desiredZoomLevels=this.maxZoomLevel-this.minZoomLevel+1;}else{desiredZoomLevels=this.numZoomLevels;}
+if(desiredZoomLevels!=null){this.numZoomLevels=Math.min(desiredZoomLevels,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}
+this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
+this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
+return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
+return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;if(this.map.baseLayer!==this){zoom=this.map.baseLayer.getZoomForResolution(this.getResolutionForZoom(zoom))}}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;if(this.map.baseLayer!==this){zoom=this.getZoomForResolution(this.map.baseLayer.getResolutionForZoom(zoom));}}
+return zoom;},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257,0.0000013411045074462891,0.00000067055225372314453],type:null,wrapDateLine:true,sphericalMercator:false,version:null,initialize:function(name,options){options=options||{};if(!options.version){options.version=typeof GMap2==="function"?"2":"3";}
+var mixin=OpenLayers.Layer.Google["v"+
+options.version.replace(/\./g,"_")];if(mixin){OpenLayers.Util.applyDefaults(options,mixin);}else{throw"Unsupported Google Maps API version: "+options.version;}
+OpenLayers.Util.applyDefaults(options,mixin.DEFAULTS);if(options.maxExtent){options.maxExtent=options.maxExtent.clone();}
+OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[name,options]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,[name,options]);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions());},setVisibility:function(visible){var opacity=this.opacity==null?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(opacity);},display:function(visible){if(!this._dragging){this.setGMapVisibility(visible);}
+OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){this._dragging=dragging;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging;},setOpacity:function(opacity){if(opacity!==this.opacity){if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}
+this.opacity=opacity;}
+if(this.getVisibility()){var container=this.getMapContainer();OpenLayers.Util.modifyDOMElement(container,null,null,null,null,null,null,opacity);}},destroy:function(){if(this.map){this.setGMapVisibility(false);var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache&&cache.count<=1){this.removeGMapElements();}}
+OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments);},removeGMapElements:function(){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject&&this.getMapContainer();if(container&&container.parentNode){container.parentNode.removeChild(container);}
+var termsOfUse=cache.termsOfUse;if(termsOfUse&&termsOfUse.parentNode){termsOfUse.parentNode.removeChild(termsOfUse);}
+var poweredBy=cache.poweredBy;if(poweredBy&&poweredBy.parentNode){poweredBy.parentNode.removeChild(poweredBy);}}},removeMap:function(map){if(this.visibility&&this.mapObject){this.setGMapVisibility(false);}
+var cache=OpenLayers.Layer.Google.cache[map.id];if(cache){if(cache.count<=1){this.removeGMapElements();delete OpenLayers.Layer.Google.cache[map.id];}else{--cache.count;}}
+delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments);},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
+olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
+return olBounds;},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){if(!this.type){this.type=G_NORMAL_MAP;}
+var mapObject,termsOfUse,poweredBy;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;termsOfUse=cache.termsOfUse;poweredBy=cache.poweredBy;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMap2Container";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);try{mapObject=new GMap2(div);termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.right="";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright";poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.right="";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy gmnoprint";}catch(e){throw(e);}
+OpenLayers.Layer.Google.cache[this.map.id]={mapObject:mapObject,termsOfUse:termsOfUse,poweredBy:poweredBy,count:1};}
+this.mapObject=mapObject;this.termsOfUse=termsOfUse;this.poweredBy=poweredBy;if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)===-1){this.mapObject.addMapType(this.type);}
+if(typeof mapObject.getDragObject=="function"){this.dragObject=mapObject.getDragObject();}else{this.dragPanMapObject=null;}
+if(this.isBaseLayer===false){this.setGMapVisibility(this.div.style.display!=="none");}},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded()){this.mapObject.checkResize();}else{if(!this._resized){var layer=this;var handle=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(handle);delete layer._resized;layer.mapObject.checkResize();layer.moveTo(layer.map.getCenter(),layer.map.getZoom());});}
+this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject.getContainer();if(visible===true){this.mapObject.setMapType(this.type);container.style.display="";this.termsOfUse.style.left="";this.termsOfUse.style.display="";this.poweredBy.style.display="";cache.displayed=this.id;}else{if(cache.displayed===this.id){delete cache.displayed;}
+if(!cache.displayed){container.style.display="none";this.termsOfUse.style.display="none";this.termsOfUse.style.left="-9999px";this.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getContainer();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
+return moBounds;},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
+return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
+return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
+return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Tile=OpenLayers.Class({events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.setBounds(bounds);this.url=url;if(size){this.size=size.clone();}
+this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},draw:function(){this.clear();return this.shouldDraw();},shouldDraw:function(){var withinMaxExtent=false,maxExtent=this.layer.maxExtent;if(maxExtent){var map=this.layer.map;var worldBounds=map.baseLayer.wrapDateLine&&map.getMaxExtent();if(this.bounds.intersectsBounds(maxExtent,{inclusive:false,worldBounds:worldBounds})){withinMaxExtent=true;}}
+return withinMaxExtent||this.layer.displayOutsideMaxExtent;},setBounds:function(bounds){bounds=bounds.clone();if(this.layer.map.baseLayer.wrapDateLine){var worldExtent=this.layer.map.getMaxExtent(),tolerance=this.layer.map.getResolution();bounds=bounds.wrapDateLine(worldExtent,{leftTolerance:tolerance,rightTolerance:tolerance});}
+this.bounds=bounds;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.setBounds(bounds);this.position=position.clone();if(redraw){this.draw();}},clear:function(draw){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,blankImageUrl:"data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement("div");this.frame.style.position="absolute";this.frame.style.overflow="hidden";this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}},destroy:function(){if(this.frame!=null){this.clear();this.imgDiv=null;this.frame=null;}
+this.asyncRequestId=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},draw:function(){var drawn=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(drawn){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+this.positionTile();this.renderTile();}else{this.unload();}
+return drawn;},renderTile:function(){this.layer.div.appendChild(this.frame);if(this.layer.async){var myId=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,this,"url",function(){if(myId==this.asyncRequestId){this.initImage();}});}else{this.url=this.layer.getURL(this.bounds);this.initImage();}},positionTile:function(){var style=this.frame.style;style.left=this.position.x+"%";style.top=this.position.y+"%";style.width=this.size.w+"%";style.height=this.size.h+"%";},clear:function(){var img=this.imgDiv;if(img){OpenLayers.Event.stopObservingElement(img);if(this.frame.parentNode===this.layer.div){this.layer.div.removeChild(this.frame);}
+this.setImgSrc();if(this.layerAlphaHack===true){img.style.filter="";}
+OpenLayers.Element.removeClass(img,"olImageLoadError");}},createImage:function(){var img=document.createElement("img");this.imgDiv=img;img.className="olTileImage";img.galleryImg="no";var style=img.style,gutter=this.layer.gutter;if(gutter){var tileSize=this.layer.tileSize,left=(gutter/tileSize.w*100),top=(gutter/tileSize.h*100);style.left=-left+"%";style.top=-top+"%";style.width=(2*left+100)+"%";style.height=(2*top+100)+"%";style.position="absolute";}else{style.width="100%";style.height="100%";}
+style.display="none";if(this.layer.opacity<1){OpenLayers.Util.modifyDOMElement(img,null,null,null,null,null,null,this.layer.opacity);}
+if(this.layerAlphaHack){style.paddingTop=style.height;style.height="0";}
+this.frame.appendChild(img);return img;},initImage:function(){var img=this.imgDiv||this.createImage();if(this.url&&img.getAttribute("src")==this.url){this.onImageLoad();}else{var load=OpenLayers.Function.bind(function(){OpenLayers.Event.stopObservingElement(img);OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(this.onImageLoad,this));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(this.onImageError,this));this.imageReloadAttempts=0;this.setImgSrc(this.url);},this);if(img.getAttribute("src")==this.blankImageUrl){load();}else{OpenLayers.Event.observe(img,"load",load);OpenLayers.Event.observe(img,"error",load);img.src=this.blankImageUrl;}}},setImgSrc:function(url){var img=this.imgDiv;img.style.display="none";if(url){img.src=url;}},getTile:function(){return this.frame;},createBackBuffer:function(){if(!this.imgDiv||this.isLoading){return;}
+var backBuffer=this.frame.cloneNode(false);backBuffer.appendChild(this.imgDiv);this.imgDiv=null;return backBuffer;},onImageLoad:function(){var img=this.imgDiv;OpenLayers.Event.stopObservingElement(img);img.style.display="";this.isLoading=false;this.events.triggerEvent("loadend");if(parseFloat(navigator.appVersion.split("MSIE")[1])<7&&this.layer&&this.layer.div){var span=document.createElement("span");span.style.display="none";var layerDiv=this.layer.div;layerDiv.appendChild(span);window.setTimeout(function(){span.parentNode===layerDiv&&span.parentNode.removeChild(span);},0);}
+if(this.layerAlphaHack===true){img.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+
+img.src+"', sizingMethod='scale')";}},onImageError:function(){var img=this.imgDiv;if(img.src!=null){this.imageReloadAttempts++;if(this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.setImgSrc(this.layer.getURL(this.bounds));}else{OpenLayers.Element.addClass(img,"olImageLoadError");this.onImageLoad();}}},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,serverResolutions:null,timerId:null,backBuffer:null,gridResolution:null,backBufferResolution:null,backBufferLonLat:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this);},removeMap:function(map){if(this.timerId!=nul
 l){window.clearTimeout(this.timerId);this.timerId=null;}},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[iRow];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+this.grid=[];this.gridResolution=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];obj.gridResolution=null;return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();var resolution=this.map.getResolution();var serverResolution=this.getServerResolution(resolution);if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){if(zoomChanged&&this.transitionEffect!=='resize'){this.removeBackBuffer();}
+if(!zoomChanged||this.transitionEffect==='resize'){this.applyBackBuffer(serverResolution);}
+this.initSingleTile(bounds);}}else{forceReTile=forceReTile||!tilesBounds.containsBounds(bounds,true);if(resolution!==serverResolution){bounds=this.map.calculateBounds(null,serverResolution);if(forceReTile){var scale=serverResolution/resolution;this.transformDiv(scale);}}else{this.div.style.width='100%';this.div.style.height='100%';this.div.style.left='0%';this.div.style.top='0%';}
+if(forceReTile){if(zoomChanged&&this.transitionEffect==='resize'){this.applyBackBuffer(serverResolution);}
+this.initGriddedTiles(bounds);}else{this.scheduleMoveGriddedTiles();}}}},getServerResolution:function(resolution){resolution=resolution||this.map.getResolution();if(this.serverResolutions&&OpenLayers.Util.indexOf(this.serverResolutions,resolution)===-1){var i,serverResolution;for(i=this.serverResolutions.length-1;i>=0;i--){serverResolution=this.serverResolutions[i];if(serverResolution>resolution){resolution=serverResolution;break;}}
+if(i===-1){throw'no appropriate resolution in serverResolutions';}}
+return resolution;},getServerZoom:function(){return this.map.getZoomForResolution(this.getServerResolution());},transformDiv:function(scale){this.div.style.width=100*scale+'%';this.div.style.height=100*scale+'%';var size=this.map.getSize();var lcX=parseInt(this.map.layerContainerDiv.style.left,10);var lcY=parseInt(this.map.layerContainerDiv.style.top,10);var x=(lcX-(size.w/2.0))*(scale-1);var y=(lcY-(size.h/2.0))*(scale-1);this.div.style.left=x+'%';this.div.style.top=y+'%';},getResolutionScale:function(){return parseInt(this.div.style.width,10)/100;},applyBackBuffer:function(resolution){var backBuffer=this.backBuffer;if(!backBuffer){backBuffer=this.createBackBuffer();if(!backBuffer){return;}
+this.div.insertBefore(backBuffer,this.div.firstChild);this.backBuffer=backBuffer;var topLeftTileBounds=this.grid[0][0].bounds;this.backBufferLonLat={lon:topLeftTileBounds.left,lat:topLeftTileBounds.top};this.backBufferResolution=this.gridResolution;}
+var style=backBuffer.style;var ratio=this.backBufferResolution/resolution;style.width=100*ratio+'%';style.height=100*ratio+'%';var position=this.getViewPortPxFromLonLat(this.backBufferLonLat,resolution);var leftOffset=parseInt(this.map.layerContainerDiv.style.left,10);var topOffset=parseInt(this.map.layerContainerDiv.style.top,10);backBuffer.style.left=(position.x-leftOffset)+'%';backBuffer.style.top=(position.y-topOffset)+'%';},createBackBuffer:function(){var backBuffer;if(this.grid.length>0){backBuffer=document.createElement('div');backBuffer.id=this.div.id+'_bb';backBuffer.className='olBackBuffer';backBuffer.style.position='absolute';backBuffer.style.width='100%';backBuffer.style.height='100%';for(var i=0,lenI=this.grid.length;i<lenI;i++){for(var j=0,lenJ=this.grid[i].length;j<lenJ;j++){var tile=this.grid[i][j].createBackBuffer();if(!tile){continue;}
+tile.style.top=(i*this.tileSize.h)+'%';tile.style.left=(j*this.tileSize.w)+'%';backBuffer.appendChild(tile);}}}
+return backBuffer;},removeBackBuffer:function(){if(this.backBuffer&&this.backBuffer.parentNode){this.div.removeChild(this.backBuffer);this.backBuffer=null;this.backBufferResolution=null;}},moveByPx:function(dx,dy){if(!this.singleTile){this.scheduleMoveGriddedTiles();}},scheduleMoveGriddedTiles:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);}
+this.timerId=window.setTimeout(this._moveGriddedTiles,this.tileLoadingDelay);},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
+OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
+return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
+var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
+this.removeExcessTiles(1,1);this.gridResolution=this.getServerResolution();},calculateGridLayout:function(bounds,origin,resolution){bounds=bounds.clone();var map=this.map;if(map.wrapDateLine){bounds=bounds.wrapDateLine(map.getMaxExtent());}
+var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=bounds.top-(origin.lat+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},getTileOrigin:function(){var origin=this.tileOrigin;if(!origin){var extent=this.getMaxExtent();var edges=({"tl":["left","top"],"tr":["right","top"],"bl":["left","bottom"],"br":["right","bottom"]})[this.tileOriginCorner];origin=new OpenLayers.LonLat(extent[edges[0]],extent[edges[1]]);}
+return origin;},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
+Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
+Math.max(1,2*this.buffer);var origin=this.getTileOrigin();var resolution=this.getServerResolution();var tileLayout=this.calculateGridLayout(bounds,origin,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
+tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols);tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows);this.removeExcessTiles(rowidx,colidx);this.gridResolution=this.getServerResolution();this.spiralTileLoad();},getMaxExtent:function(){return this.maxExtent;},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
+var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
+if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
+for(var i=0,len=tileQueue.length;i<len;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
+this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");this.removeBackBuffer();}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(){var shifted=true;var buffer=this.buffer||1;var scale=this.getResolutionScale();var tlLayer=this.grid[0][0].position.clone();tlLayer.x*=scale;tlLayer.y*=scale;tlLayer=tlLayer.add(parseInt(this.div.style.left,10),parseInt(this.div.style.top,10));var offsetX=parseInt(this.map.layerContainerDiv.style.left);var offsetY=parseInt(this.map.layerContainerDiv.style.top);var tlViewPort=tlLayer.add(offsetX,offsetY);var tileSize=this.tileSiz
 e.clone();tileSize.w*=scale;tileSize.h*=scale;if(tlViewPort.x>-tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-tileSize.h*buffer){this.shiftRow(false);}else{shifted=false;}
+if(shifted){this.timerId=window.setTimeout(this._moveGriddedTiles,0);}},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.getServerResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0,len=modelRow.length;i<len;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
+if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.getServerResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
+url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.getServerResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var resolutions=this.serverResolutions||this.resolutions;var z=this.zoomOffset==0?OpenLayers.Util.indexOf(resolutions,res):this.getServerZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
+{x=((x%limit)+limit)%limit;}
+return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,citeCompliant:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(con
 trol,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
+var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+this.cancel();if(this.layer.map!=null){this.destroyFeature(true);this.layer.destroy(false);}
+this.layer=null;this.touch=false;return true;},destroyFeature:function(force){if(this.layer&&(force||!this.persist)){this.layer.destroyFeatures();}
+this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel){var key=cancel?"cancel":"done";this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);this.destroyFeature(cancel);},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){if(!this.point){this.createFeature(pixel);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
+return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
+this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
+this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
+return true;},up:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
+if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
+if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+if(this.persist){this.destroyPersistedFeature();}
+this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
+return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.la
 yer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousIndex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=len
 gth*Math.cos(direction);var dy=length*Math.sin(direction);this.insertDeltaXY(dx,dy);},insertDeflectionLength:function(deflection,length){var previousIndex=this.getCurrentPointIndex()-1;if(previousIndex>0){var p1=this.line.geometry.components[previousIndex];var p0=this.line.geometry.components[previousIndex-1];var theta=Math.atan2(p1.y-p0.y,p1.x-p0.x);this.insertDirectionLength((theta*180/Math.PI)+deflection,length);}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1;},undo:function(){var geometry=this.line.geometry;var components=geometry.components;var index=this.getCurrentPointIndex()-1;var target=components[index];var undone=geometry.removeComponent(target);if(undone){if(!this.redoStack){this.redoStack=[];}
+this.redoStack.push(target);this.drawFeature();}
+return undone;},redo:function(){var target=this.redoStack&&this.redoStack.pop();if(target){this.line.geometry.addComponent(target,this.getCurrentPointIndex());this.drawFeature();}
+return!!target;},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){if(!this.line){this.createFeature(pixel);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
+return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
+this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;if(this.touch){this.modifyFeature(evt.xy,!!this.lastUp);OpenLayers.Event.stop(evt);}}
+if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
+this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+this.addPoint(evt.xy);return false;}
+if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy,!!this.lastUp);}
+return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
+this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
+this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features
 [i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
+OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},getCurrentPointIndex:function(){return this.line.geometry.components.length-2;},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
+if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
+if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
+this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
+return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(force){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,force);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
+return geometry;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:false,adapter:null,handlers:null,displayResults:true,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:false,toggle:true,multiple:false,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(url,layer,callbacks,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.url=url;if(layer&&layer instanceof OpenLayers.Layer.Vector){this.layer=layer;}else{this.layer=new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:false,isBaseLayer:false});}
+if(callbacks){this.taskCallbacks=callbacks;}
+var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,multiple:this.multiple,callbacks:{dblclick:dojo.hitch(this,this._execute)}};this.selectControl=new OpenLayers.Control.SelectFeature(this.layer,selectOptions);var drawOptions=OpenLayers.Util.extend({callbacks:{done:dojo.hitch(this,this._execute)}},this.drawCtrlHandlerOptions);this.drawControl=new OpenLayers.Control.DrawFeature(this.layer,this.drawCtrlHandler,drawOptions);this.handlers={};this.adapter=new OpenLayers.Format.AgsJsAdapter();this._resultFeatures=[];this._resultImages=[];OpenLayers.Util.applyDefaults(this.resultImageOptions,{opacity:1.0});this._isDefined=OpenLayers.Util.AgsUtil.isDefined;this._isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;this._isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;},destroy:function(){this.layer=null;this.selectControl.destroy();this.drawControl.destroy();OpenLayers.Control.prototyp
 e.destroy.apply(this,[]);},activate:function(){if(this.mode=="select"){return(this.selectControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else if(this.mode=="draw"){return(this.drawControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.drawControl.deactivate();this.selectControl.deactivate();deactivated=true;}
+return deactivated;},_execute:function(data){var olFeatures=null;if(this._isOLGeometry(data)){if(this.multiple==true){OpenLayers.Console.log("...to allow multiple features as operation input...");OpenLayers.Console.log("..._execute will not be triggered by 'done' drawing a geometry on map...");this.drawControl.drawFeature(data);return true;}else{OpenLayers.Console.log("..._execute triggered by 'done' drawing a geometry on map...");OpenLayers.Console.log("...single feature as operation input...");olFeatures=[new OpenLayers.Feature.Vector(data)];}}else if(data instanceof OpenLayers.Feature.Vector){OpenLayers.Console.log("..._execute triggered by 'dblclick' a feature on map...");if(this.multiple==true){OpenLayers.Console.log("...allow multiple features as operation input...");olFeatures=this.layer.selectedFeatures;}else{OpenLayers.Console.log("...single feature as operation input...");olFeatures=[data];}}else if(data instanceof Array){OpenLayers.Console.log("..._execute trigger
 ed by using all selected features on the map...");olFeatures=data;}else{OpenLayers.Console.error("...input geometry or feature is missing or invalid...");throw"...input geometry or feature is missing or invalid...";}
+this.execute(olFeatures,{},[]);},execute:function(olFeatures,taskParameters,callbacks){OpenLayers.Console.error("...execute of OpenLayers.Control.AgsControl is not implemented...");throw"...execute of OpenLayers.Control.AgsControl is not implemented...";},onExecuteComplete:function(agsResults,options){OpenLayers.Console.debug("...AgsControl OnExecuteComplete is called...");var olResults=null;try{if(this._resultsParser.context&&typeof this._resultsParser.parser==="function"){olResults=this._resultsParser.parser.apply(this._resultsParser.context,[agsResults,options['args_list']]);}else{OpenLayers.Console.error("..._resultsParser is missing or invalid...");throw"..._resultsParser is missing or invalid...";}}catch(e){OpenLayers.Console.error(e.message);throw e.message;}
+if(olResults instanceof OpenLayers.Feature.Vector){olResults=[olResults];}
+this.cleanupResults();this.addResults(olResults);if(this.displayResults===true){this.showResults();}
+options.callback.apply(this,[olResults]);},onExecuteAsynComplete:function(agsResults,options){var _options=OpenLayers.Util.extend({'resultFeatures':this._resultFeatures,'resultImages':this._resultImages},options);try{if(this._resultsParser.context&&typeof this._resultsParser.parser==="function"){this._resultsParser.parser.apply(this._resultsParser.context,[agsResults,options]);}else{OpenLayers.Console.error("..._resultsParser is missing or invalid...");throw"..._resultsParser is missing or invalid...";}}catch(e){throw e;}},setTaskParameters:function(taskParameters){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);OpenLayers.Util.extend(this.taskParameters,_taskParameters);},addResults:function(olResults){for(var i=0;i<olResults.length;i++){var olResult=olResults[i];if(olResult instanceof OpenLayers.Feature.Vector){this._resultFeatures.push(olResult);}else if(olResult instanceof OpenLayers.Layer.I
 mage){olResult.setVisibility(false);olResult.setOpacity(this.resultImageOptions.opacity);this.map.addLayer(olResult);this.map.setLayerIndex(olResult,this.map.getLayerIndex(this.layer)+1);this._resultImages.push(olResult);}else{OpenLayers.Console.log("...skip adding because it's not OpenLayers.Feature.Vector or OpenLayers.Layer.Image...");}}},cleanupResults:function(){this.hideResults();if(this._resultFeatures&&this._resultFeatures.length>0){for(var i=0;i<this._resultFeatures.length;i++){this._resultFeatures[i].destroy();}}
+this._resultFeatures.length=0;if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this.map.removeLayer(this._resultImages[i]);}}
+this._resultImages.length=0;},hideResults:function(){if(this._resultFeatures&&this._resultFeatures.length>0){this.layer.removeFeatures(this._resultFeatures);}
+if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this._resultImages[i].setVisibility(false);}}},showResults:function(){if(this._resultFeatures&&this._resultFeatures.length>0){this.layer.addFeatures(this._resultFeatures);}
+if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this._resultImages[i].setVisibility(true);}}},switchMode:function(mode){var wasActive=this.active;if(this.active===true){this.deactivate();}
+if(this.mode==="select"){this.selectControl.unselectAll();}
+if(mode==="select"||mode==="draw"){this.mode=mode;}
+if(wasActive===true){this.activate();}
+OpenLayers.Console.log("...control mode switched...current control mode: "+this.mode+"...");},switchDrawCtrlHandler:function(handler){var wasActive=this.active;if(this.active===true){this.deactivate();}
+this.drawControl.handler=new handler(this.drawControl,this.drawControl.callbacks,this.drawControl.handlerOptions);this.drawCtrlHandler=this.drawControl.handler;if(wasActive===true){this.activate();}
+OpenLayers.Console.log("...DrawCtrlHandler switched...current DrawCtrlHandler: "+this.drawCtrlHandler.CLASS_NAME+"...");},setMap:function(map){if(!this.layer.map||!(this.layer.map instanceof OpenLayers.Map)){map.addLayer(this.layer);}
+this.selectControl.setMap(map);this.drawControl.setMap(map);OpenLayers.Util.extend(this.adapter.config,{'defaultEncodeWkid':this.layer.map['projection']});OpenLayers.Control.prototype.setMap.apply(this,arguments);OpenLayers.Console.debug("...current control mode: "+this.mode+"...");OpenLayers.Console.debug("...current DrawCtrlHandler: "+this.drawCtrlHandler.prototype.CLASS_NAME+"...");OpenLayers.Console.log("...adapter defaultEncodeWkid: "+this.adapter.config.defaultEncodeWkid+"...");},_createCallbacks:function(context,methods,options){return dojo.hitch(this,function(response){var method=null;for(var i=0;i<methods.length;i++){method=methods[i];if(typeof method=="function"){options['args_list']=arguments;method.apply(context,[response,options]);}}});},CLASS_NAME:"OpenLayers.Control.AgsControl"});OpenLayers.Control.AgsQueryTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,initialize:function(url,layer,callbacks,options){OpenLayers.Control.A
 gsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'geometry':null,'outFields':[0],'returnGeometry':true,'outSpatialReference':null,'spatialRelationship':null,'text':"",'where':""};this._resultsParser={'parser':this.adapter.parseAgsResults['featureSet'],'context':this.adapter};this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);if(this._isDefined(this.layer.map)){_taskParameters['outSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['outSpatialReference'];}
+if(olFeatures[0]instanceof OpenLayers.Feature.Vector){_taskParameters['geometry']=olFeatures[0].geometry?olFeatures[0].geometry:_taskParameters['geometry'];}else{OpenLayers.Console.error("...can not execute query task...input geometry is not valid...");throw"...can not execute query task...input geometry is not valid...";}
+var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsQueryTask=new esri.tasks.QueryTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsQuery=this.adapter.encodeAgsQuery(_taskParameters);}
+catch(e){throw e;}
+agsQueryTask.execute(agsQuery,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsQueryTask ...");throw"...'asynchronous' should always be set to 'false' for AgsQueryTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsQueryTask"});OpenLayers.Format.WFST=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFST.DEFAULTS);var cls=OpenLayers.Format.WFST["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFST version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WFST.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:true,xy:true,stateName:null,initialize:function(options){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]="wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},getSrsName:function(feature,options){var srsName=options&&options.srsName;if(!srsName){if(feature&&feature.layer){srsName=feature.layer.projection.getCode();}else{srsName=this.srsName;}}
+return srsName;},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var obj={};if(data){this.readNode(data,obj,true);}
+if(obj.features&&options.output==="features"){obj=obj.features;}
+return obj;},readers:{"wfs":{"FeatureCollection":function(node,obj){obj.features=[];this.readChildNodes(node,obj);}}},write:function(features,options){var node=this.writeNode("wfs:Transaction",{features:features,options:options});var value=this.schemaLocationAttr();if(value){this.setAttributeNS(node,this.namespaces["xsi"],"xsi:schemaLocation",value);}
+return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wfs":{"GetFeature":function(options){var node=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,handle:options&&options.handle,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(options)}});if(typeof this.featureType=="string"){this.writeNode("Query",options,node);}else{for(var i=0,len=this.featureType.length;i<len;i++){options.featureType=this.featureType[i];this.writeNode("Query",options,node);}}
+return node;},"Transaction":function(obj){obj=obj||{};var options=obj.options||{};var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,handle:options.handle}});var i,len;var features=obj.features;if(features){if(options.multi===true){OpenLayers.Util.extend(this.geometryTypes,{"OpenLayers.Geometry.Point":"MultiPoint","OpenLayers.Geometry.LineString":(this.multiCurve===true)?"MultiCurve":"MultiLineString","OpenLayers.Geometry.Polygon":(this.multiSurface===true)?"MultiSurface":"MultiPolygon"});}
+var name,feature;for(i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,{feature:feature,options:options},node);}}
+if(options.multi===true){this.setGeometryTypes();}}
+if(options.nativeElements){for(i=0,len=options.nativeElements.length;i<len;++i){this.writeNode("wfs:Native",options.nativeElements[i],node);}}
+return node;},"Native":function(nativeElement){var node=this.createElementNSPlus("wfs:Native",{attributes:{vendorId:nativeElement.vendorId,safeToIgnore:nativeElement.safeToIgnore},value:nativeElement.value});return node;},"Insert":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Insert",{attributes:{handle:options&&options.handle}});this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Update",{attributes:{handle:options&&options.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+
+this.featureType}});if(this.featureNS){node.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);}
+var modified=feature.modified;if(this.geometryName!==null&&(!modified||modified.geometry!==undefined)){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
+for(var key in feature.attributes){if(feature.attributes[key]!==undefined&&(!modified||!modified.attributes||(modified.attributes&&modified.attributes[key]!==undefined))){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
+this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;},"Property":function(obj){var node=this.createElementNSPlus("wfs:Property");this.writeNode("Name",obj.name,node);if(obj.value!==null){this.writeNode("Value",obj.value,node);}
+return node;},"Name":function(name){return this.createElementNSPlus("wfs:Name",{value:name});},"Value":function(obj){var node;if(obj instanceof OpenLayers.Geometry){node=this.createElementNSPlus("wfs:Value");var geom=this.writeNode("feature:_geometry",obj).firstChild;node.appendChild(geom);}else{node=this.createElementNSPlus("wfs:Value",{value:obj});}
+return node;},"Delete":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Delete",{attributes:{handle:options&&options.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+
+this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;}}},schemaLocationAttr:function(options){options=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},options);var schemaLocations=OpenLayers.Util.extend({},this.schemaLocations);if(options.schema){schemaLocations[options.featurePrefix]=options.schema;}
+var parts=[];var uri;for(var key in schemaLocations){uri=this.namespaces[key];if(uri){parts.push(uri+" "+schemaLocations[key]);}}
+var value=parts.join(" ")||undefined;return value;},setFilterProperty:function(filter){if(filter.filters){for(var i=0,len=filter.filters.length;i<len;++i){OpenLayers.Format.WFST.v1.prototype.setFilterProperty.call(this,filter.filters[i]);}}else{if(filter instanceof OpenLayers.Filter.Spatial&&!filter.property){filter.property=this.geometryName;}}},CLASS_NAME:"OpenLayers.Format.WFST.v1"});OpenLayers.Format.GML.v3=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/1.0.0/gmlsf.xsd",curve:false,multiCurve:true,surface:false,multiSurface:true,initialize:function(options){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[options]);},readers:{"gml":OpenLayers.Util.applyDefaults({"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"Curve":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+container.components.push(new OpenLayers.Geometry.LineString(obj.points));},"segments":function(node,obj){this.readChildNodes(node,obj);},"LineStringSegment":function(node,container){var obj={};this.readChildNodes(node,obj);if(obj.points){Array.prototype.push.apply(container.points,obj.points);}},"pos":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var point;if(this.xy){point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{point=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}
+obj.points=[point];},"posList":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var dim=parseInt(node.getAttribute("dimension"))||2;var j,x,y,z;var numPoints=coords.length/dim;var points=new Array(numPoints);for(var i=0,len=coords.length;i<len;i+=dim){x=coords[i];y=coords[i+1];z=(dim==2)?undefined:coords[i+2];if(this.xy){points[i/dim]=new OpenLayers.Geometry.Point(x,y,z);}else{points[i/dim]=new OpenLayers.Geometry.Point(y,x,z);}}
+obj.points=points;},"Surface":function(node,obj){this.readChildNodes(node,obj);},"patches":function(node,obj){this.readChildNodes(node,obj);},"PolygonPatch":function(node,obj){this.readers.gml.Polygon.apply(this,[node,obj]);},"exterior":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"interior":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]);},"MultiCurve":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiLineString(obj.components)];}},"curveMember":function(node,obj){this.readChildNodes(node,obj);},"MultiSurface":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiPolygon(obj.components)];}},"surfaceMember":function(node,obj){this.readChildNodes(node,obj
 );},"surfaceMembers":function(node,obj){this.readChildNodes(node,obj);},"pointMembers":function(node,obj){this.readChildNodes(node,obj);},"lineStringMembers":function(node,obj){this.readChildNodes(node,obj);},"polygonMembers":function(node,obj){this.readChildNodes(node,obj);},"geometryMembers":function(node,obj){this.readChildNodes(node,obj);},"Envelope":function(node,container){var obj={points:new Array(2)};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));},"lowerCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[0]=obj.points[0];},"upperCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[1]=obj.points[0];}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="featureMembers";}else{name="featureMember";}
+var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"featureMembers":function(features){var node=this.createElementNSPlus("gml:featureMembers");for(var i=0,len=features.length;i<len;++i){this.writeNode("feature:_typeName",features[i],node);}
+return node;},"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("pos",geometry,node);return node;},"pos":function(point){var pos=(this.xy)?(point.x+" "+point.y):(point.y+" "+point.x);return this.createElementNSPlus("gml:pos",{value:pos});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("posList",geometry.components,node);return node;},"Curve":function(geometry){var node=this.createElementNSPlus("gml:Curve");this.writeNode("segments",geometry,node);return node;},"segments":function(geometry){var node=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",geometry,node);return node;},"LineStringSegment":function(geometry){var node=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",geometry.components,node);return node;},"posList":function(points){var len=points.length;var parts=new Array(len);var point;for(var i=0;i<len;++i){point=points[i];if
 (this.xy){parts[i]=point.x+" "+point.y;}else{parts[i]=point.y+" "+point.x;}}
+return this.createElementNSPlus("gml:posList",{value:parts.join(" ")});},"Surface":function(geometry){var node=this.createElementNSPlus("gml:Surface");this.writeNode("patches",geometry,node);return node;},"patches":function(geometry){var node=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",geometry,node);return node;},"PolygonPatch":function(geometry){var node=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
+return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
+return node;},"exterior":function(ring){var node=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",ring,node);return node;},"interior":function(ring){var node=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",ring.components,node);return node;},"MultiCurve":function(geometry){var node=this.createElementNSPlus("gml:MultiCurve");var components=geometry.components||[geometry];for(var i=0,len=components.length;i<len;++i){this.writeNode("curveMember",components[i],node);}
+return node;},"curveMember":function(geometry){var node=this.createElementNSPlus("gml:curveMember");if(this.curve){this.writeNode("Curve",geometry,node);}else{this.writeNode("LineString",geometry,node);}
+return node;},"MultiSurface":function(geometry){var node=this.createElementNSPlus("gml:MultiSurface");var components=geometry.components||[geometry];for(var i=0,len=components.length;i<len;++i){this.writeNode("surfaceMember",components[i],node);}
+return node;},"surfaceMember":function(polygon){var node=this.createElementNSPlus("gml:surfaceMember");if(this.surface){this.writeNode("Surface",polygon,node);}else{this.writeNode("Polygon",polygon,node);}
+return node;},"Envelope":function(bounds){var node=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",bounds,node);this.writeNode("upperCorner",bounds,node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
+return node;},"lowerCorner":function(bounds){var pos=(this.xy)?(bounds.left+" "+bounds.bottom):(bounds.bottom+" "+bounds.left);return this.createElementNSPlus("gml:lowerCorner",{value:pos});},"upperCorner":function(bounds){var pos=(this.xy)?(bounds.right+" "+bounds.top):(bounds.top+" "+bounds.right);return this.createElementNSPlus("gml:upperCorner",{value:pos});}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":(this.curve===true)?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":(this.multiCurve===false)?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":(this.surface===true)?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":(this.multiSurface===false)?"MultiPoly
 gon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.v3"});OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,
 filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escapeChar");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:filter.matchCase}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",{attributes:{matchCase:filter.matchCa
 se}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:filter.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");filter.property&&this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Envelope",filter.value);if(filter.projection){box.setAttribute("srsName",filter.projection);}
+node.appendChild(box);return node;},"SortBy":function(sortProperties){var node=this.createElementNSPlus("ogc:SortBy");for(var i=0,l=sortProperties.length;i<l;i++){this.writeNode("ogc:SortProperty",sortProperties[i],node);}
+return node;},"SortProperty":function(sortProperty){var node=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",sortProperty,node);this.writeNode("ogc:SortOrder",(sortProperty.order=='DESC')?'DESC':'ASC',node);return node;},"SortOrder":function(value){var node=this.createElementNSPlus("ogc:SortOrder",{value:value});return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);if(filter.value instanceof OpenLayers.Filter.Function){this.writeNode("Function",filter.value,node);}else{var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Envelope",filter.value);}
+if(filter.projection){child.setAttribute("srsName",filter.projection);}
+node.appendChild(child);}
+return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readNode:function(node,obj,first){return OpenLayers.Format.GML.v3.prototype.readNode.apply(this,[node,obj]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.numberOfFeatures=parseInt(node.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers["wfs"]["FeatureCollection"].apply(this,arguments);},"TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"TransactionSummary":function(node,obj){obj.success=true;},"InsertResults":function(node,obj
 ){this.readChildNodes(node,obj);},"Feature":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.readers["ogc"],"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeature":function(options){var node=OpenLayers.Format.WFST.v1.prototype.writers["wfs"]["GetFeature"].apply(this,arguments);options&&this.setAttributes(node,{resultType:options.resultType,startIndex:options.startIndex,count:options.count});return node;},"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},options);var prefix=options.featurePrefix;var node=this.cre
 ateElementNSPlus("wfs:Query",{attributes:{typeName:(prefix?prefix+":":"")+
+options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+prefix,options.featureNS);}
+if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
+if(options.filter){OpenLayers.Format.WFST.v1_1_0.prototype.setFilterProperty.call(this,options.filter);this.writeNode("ogc:Filter",options.filter,node);}
+return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,"abstract":layer.metadata["abstract"],dataURL:layer.metadata.dataURL,metadataURL:layer.metadataURL,server:{version:layer.params["VERSION"],url:layer.url},maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity=
 =1?undefined:layer.opacity,displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[],styles:[],srs:layer.srs,dimensions:layer.dimensions};if(layer.metadata.servertitle){layerContext.server.title=layer.metadata.servertitle;}
+if(layer.metadata.formats&&layer.metadata.formats.length>0){for(var i=0,len=layer.metadata.formats.length;i<len;i++){var format=layer.metadata.formats[i];layerContext.formats.push({value:format.value,current:(format.value==layer.params["FORMAT"])});}}else{layerContext.formats.push({value:layer.params["FORMAT"],current:true});}
+if(layer.metadata.styles&&layer.metadata.styles.length>0){for(var i=0,len=layer.metadata.styles.length;i<len;i++){var style=layer.metadata.styles[i];if((style.href==layer.params["SLD"])||(style.body==layer.params["SLD_BODY"])||(style.name==layer.params["STYLES"])){style.current=true;}else{style.current=false;}
+layerContext.styles.push(style);}}else{layerContext.styles.push({href:layer.params["SLD"],body:layer.params["SLD_BODY"],name:layer.params["STYLES"]||parser.defaultStyleName,title:parser.defaultStyleTitle,current:true});}
+return layerContext;},toContext:function(obj){var context={};var layers=obj.layers;if(obj.CLASS_NAME=="OpenLayers.Map"){var metadata=obj.metadata||{};context.size=obj.getSize();context.bounds=obj.getExtent();context.projection=obj.projection;context.title=obj.title;context.keywords=metadata.keywords;context["abstract"]=metadata["abstract"];context.logo=metadata.logo;context.descriptionURL=metadata.descriptionURL;context.contactInformation=metadata.contactInformation;context.maxExtent=obj.maxExtent;}else{OpenLayers.Util.applyDefaults(context,obj);if(context.layers!=undefined){delete(context.layers);}}
+if(context.layersContext==undefined){context.layersContext=[];}
+if(layers!=undefined&&OpenLayers.Util.isArray(layers)){for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer instanceof OpenLayers.Layer.WMS){context.layersContext.push(this.layerToContext(layer));}}}
+return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
+return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0,len=children.length;i<len;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));},read_wmc_LayerList:function(context,node){context.layersContext=[];this.runChildNodes(context,node);},read_wmc_Layer:function(context,node
 ){var layerContext={visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[],metadata:{}};this.runChildNodes(layerContext,node);context.layersContext.push(layerContext);},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerContext,node){layerContext.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerContext,node){layerContext.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerContext,node){layerContext.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerContext,node){layerContext.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerContext,node){layerContext.singleTile=(this.getChildVa
 lue(node)=="true");},read_ol_tileSize:function(layerContext,node){var obj={"width":node.getAttribute("width"),"height":node.getAttribute("height")};layerContext.tileSize=obj;},read_ol_isBaseLayer:function(layerContext,node){layerContext.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerContext,node){layerContext.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerContext,node){layerContext.version=node.getAttribute("version");layerContext.url=this.getOnlineResource_href(node);layerContext.metadata.servertitle=node.getAttribute("title");},read_wmc_FormatList:function(layerContext,node){this.runChildNodes(layerContext,node);},read_wmc_Format:function(layerContext,node){var format={value:this.getChildValue(node)};if(node.getAttribute("current")=="1"){format.current=true;}
+layerContext.formats.push(format);},read_wmc_StyleList:function(layerContext,node){this.runChildNodes(layerContext,node);},read_wmc_Style:function(layerContext,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){style.current=true;}
+layerContext.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_sld_FeatureTypeStyle:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_MetadataURL:function(layerContext,node){layerContext.metadataURL=this.getOnlineResource_href(node);},read_wmc_KeywordList:function(context,node){context.keywords=[];this.runChildNodes(context.keywords,node);},read_wmc_Keyword:function(keywords,node){keywords.push(this.getChildValue(node));},read_wmc_Abstract:function(obj,n
 ode){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LogoURL:function(context,node){context.logo={width:node.getAttribute("width"),height:node.getAttribute("height"),format:node.getAttribute("format"),href:this.getOnlineResource_href(node)};},read_wmc_DescriptionURL:function(context,node){context.descriptionURL=this.getOnlineResource_href(node);},read_wmc_ContactInformation:function(obj,node){var contact={};this.runChildNodes(contact,node);obj.contactInformation=contact;},read_wmc_ContactPersonPrimary:function(contact,node){var personPrimary={};this.runChildNodes(personPrimary,node);contact.personPrimary=personPrimary;},read_wmc_ContactPerson:function(primaryPerson,node){var person=this.getChildValue(node);if(person){primaryPerson.person=person;}},read_wmc_ContactOrganization:function(primaryPerson,node){var organization=this.getChildValue(node);if(organization){primaryPerson.organization=organization;}},read_wmc_ContactPosition:function(contact,n
 ode){var position=this.getChildValue(node);if(position){contact.position=position;}},read_wmc_ContactAddress:function(contact,node){var contactAddress={};this.runChildNodes(contactAddress,node);contact.contactAddress=contactAddress;},read_wmc_AddressType:function(contactAddress,node){var type=this.getChildValue(node);if(type){contactAddress.type=type;}},read_wmc_Address:function(contactAddress,node){var address=this.getChildValue(node);if(address){contactAddress.address=address;}},read_wmc_City:function(contactAddress,node){var city=this.getChildValue(node);if(city){contactAddress.city=city;}},read_wmc_StateOrProvince:function(contactAddress,node){var stateOrProvince=this.getChildValue(node);if(stateOrProvince){contactAddress.stateOrProvince=stateOrProvince;}},read_wmc_PostCode:function(contactAddress,node){var postcode=this.getChildValue(node);if(postcode){contactAddress.postcode=postcode;}},read_wmc_Country:function(contactAddress,node){var country=this.getChildValue(node)
 ;if(country){contactAddress.country=country;}},read_wmc_ContactVoiceTelephone:function(contact,node){var phone=this.getChildValue(node);if(phone){contact.phone=phone;}},read_wmc_ContactFacsimileTelephone:function(contact,node){var fax=this.getChildValue(node);if(fax){contact.fax=fax;}},read_wmc_ContactElectronicMailAddress:function(contact,node){var email=this.getChildValue(node);if(email){contact.email=email;}},read_wmc_DataURL:function(layerContext,node){layerContext.dataURL=this.getOnlineResource_href(node);},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height'),format:node.getAttribute('format'),href:this.getOnlineResource_href(node)};style.legend=legend;},read_wmc_DimensionList:function(layerContext,node){layerContext.dimensions={};this.runChildNodes(layerContext.dimensions,node);},read_wmc_Dimension:function(dimensions,node){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.g
 etAttribute("units")||"",unitSymbol:node.getAttribute("unitSymbol")||"",userValue:node.getAttribute("userValue")||"",nearestValue:node.getAttribute("nearestValue")==="1",multipleValues:node.getAttribute("multipleValues")==="1",current:node.getAttribute("current")==="1","default":node.getAttribute("default")||""};var values=this.getChildValue(node);dim.values=values.split(",");dimensions[dim.name]=dim;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS
 (this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
+if(attributes){this.setAttributes(node,attributes);}
+return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
+var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));if(context.keywords){node.appendChild(this.write_wmc_KeywordList(context.keywords));}
+if(context["abstract"]){node.appendChild(this.createElementDefaultNS("Abstract",context["abstract"]));}
+if(context.logo){node.appendChild(this.write_wmc_URLType("LogoURL",context.logo.href,context.logo));}
+if(context.descriptionURL){node.appendChild(this.write_wmc_URLType("DescriptionURL",context.descriptionURL));}
+if(context.contactInformation){node.appendChild(this.write_wmc_ContactInformation(context.contactInformation));}
+node.appendChild(this.write_ol_MapExtension(context));return node;},write_wmc_KeywordList:function(keywords){var node=this.createElementDefaultNS("KeywordList");for(var i=0,len=keywords.length;i<len;i++){node.appendChild(this.createElementDefaultNS("Keyword",keywords[i]));}
+return node;},write_wmc_ContactInformation:function(contact){var node=this.createElementDefaultNS("ContactInformation");if(contact.personPrimary){node.appendChild(this.write_wmc_ContactPersonPrimary(contact.personPrimary));}
+if(contact.position){node.appendChild(this.createElementDefaultNS("ContactPosition",contact.position));}
+if(contact.contactAddress){node.appendChild(this.write_wmc_ContactAddress(contact.contactAddress));}
+if(contact.phone){node.appendChild(this.createElementDefaultNS("ContactVoiceTelephone",contact.phone));}
+if(contact.fax){node.appendChild(this.createElementDefaultNS("ContactFacsimileTelephone",contact.fax));}
+if(contact.email){node.appendChild(this.createElementDefaultNS("ContactElectronicMailAddress",contact.email));}
+return node;},write_wmc_ContactPersonPrimary:function(personPrimary){var node=this.createElementDefaultNS("ContactPersonPrimary");if(personPrimary.person){node.appendChild(this.createElementDefaultNS("ContactPerson",personPrimary.person));}
+if(personPrimary.organization){node.appendChild(this.createElementDefaultNS("ContactOrganization",personPrimary.organization));}
+return node;},write_wmc_ContactAddress:function(contactAddress){var node=this.createElementDefaultNS("ContactAddress");if(contactAddress.type){node.appendChild(this.createElementDefaultNS("AddressType",contactAddress.type));}
+if(contactAddress.address){node.appendChild(this.createElementDefaultNS("Address",contactAddress.address));}
+if(contactAddress.city){node.appendChild(this.createElementDefaultNS("City",contactAddress.city));}
+if(contactAddress.stateOrProvince){node.appendChild(this.createElementDefaultNS("StateOrProvince",contactAddress.stateOrProvince));}
+if(contactAddress.postcode){node.appendChild(this.createElementDefaultNS("PostCode",contactAddress.postcode));}
+if(contactAddress.country){node.appendChild(this.createElementDefaultNS("Country",contactAddress.country));}
+return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18)});node.appendChild(maxExtent);}
+return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");for(var i=0,len=context.layersContext.length;i<len;++i){list.appendChild(this.write_wmc_Layer(context.layersContext[i]));}
+return list;},write_wmc_Layer:function(context){var node=this.createElementDefaultNS("Layer",null,{queryable:context.queryable?"1":"0",hidden:context.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(context));node.appendChild(this.createElementDefaultNS("Name",context.name));node.appendChild(this.createElementDefaultNS("Title",context.title));if(context["abstract"]){node.appendChild(this.createElementDefaultNS("Abstract",context["abstract"]));}
+if(context.dataURL){node.appendChild(this.write_wmc_URLType("DataURL",context.dataURL));}
+if(context.metadataURL){node.appendChild(this.write_wmc_URLType("MetadataURL",context.metadataURL));}
+return node;},write_wmc_LayerExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18)});node.appendChild(maxExtent);if(context.tileSize&&!context.singleTile){var size=this.createElementNS(this.namespaces.ol,"ol:tileSize");this.setAttributes(size,context.tileSize);node.appendChild(size);}
+var properties=["transparent","numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0,len=properties.length;i<len;++i){child=this.createOLPropertyNode(context,properties[i]);if(child){node.appendChild(child);}}
+return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
+return node;},write_wmc_Server:function(context){var server=context.server;var node=this.createElementDefaultNS("Server");var attributes={service:"OGC:WMS",version:server.version};if(server.title){attributes.title=server.title}
+this.setAttributes(node,attributes);node.appendChild(this.write_wmc_OnlineResource(server.url));return node;},write_wmc_URLType:function(elName,url,attr){var node=this.createElementDefaultNS(elName);node.appendChild(this.write_wmc_OnlineResource(url));if(attr){var optionalAttributes=["width","height","format"];for(var i=0;i<optionalAttributes.length;i++){if(optionalAttributes[i]in attr){node.setAttribute(optionalAttributes[i],attr[optionalAttributes[i]]);}}}
+return node;},write_wmc_DimensionList:function(context){var node=this.createElementDefaultNS("DimensionList");var required_attributes={name:true,units:true,unitSymbol:true,userValue:true};for(var dim in context.dimensions){var attributes={};var dimension=context.dimensions[dim];for(var name in dimension){if(typeof dimension[name]=="boolean"){attributes[name]=Number(dimension[name]);}else{attributes[name]=dimension[name];}}
+var values="";if(attributes.values){values=attributes.values.join(",");delete attributes.values;}
+node.appendChild(this.createElementDefaultNS("Dimension",values,attributes));}
+return node;},write_wmc_FormatList:function(context){var node=this.createElementDefaultNS("FormatList");for(var i=0,len=context.formats.length;i<len;i++){var format=context.formats[i];node.appendChild(this.createElementDefaultNS("Format",format.value,(format.current&&format.current==true)?{current:"1"}:null));}
+return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var styles=layer.styles;if(styles&&OpenLayers.Util.isArray(styles)){var sld;for(var i=0,len=styles.length;i<len;i++){var s=styles[i];var style=this.createElementDefaultNS("Style",null,(s.current&&s.current==true)?{current:"1"}:null);if(s.href){sld=this.createElementDefaultNS("SLD");if(s.name){sld.appendChild(this.createElementDefaultNS("Name",s.name));}
+if(s.title){sld.appendChild(this.createElementDefaultNS("Title",s.title));}
+if(s.legend){sld.appendChild(this.write_wmc_URLType("LegendURL",s.legend.href,s.legend));}
+var link=this.write_wmc_OnlineResource(s.href);sld.appendChild(link);style.appendChild(sld);}else if(s.body){sld=this.createElementDefaultNS("SLD");if(s.name){sld.appendChild(this.createElementDefaultNS("Name",s.name));}
+var doc=OpenLayers.Format.XML.prototype.read.apply(this,[s.body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
+sld.appendChild(imported);style.appendChild(sld);}else{style.appendChild(this.createElementDefaultNS("Name",s.name));style.appendChild(this.createElementDefaultNS("Title",s.title));if(s['abstract']){style.appendChild(this.createElementDefaultNS("Abstract",s['abstract']));}
+if(s.legend){style.appendChild(this.write_wmc_URLType("LegendURL",s.legend.href,s.legend));}}
+node.appendChild(style);}}
+return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},getOnlineResource_href:function(node){var object={};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(object,links[0]);}
+return object.href;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerContext,node){var minScaleDenominator=parseFloat(this.getChildValue(node));if(minScaleDenominator>0){layerContext.maxScale=minScaleDenominator;}},read_sld_MaxScaleDenominator:function(layerContext,node){layerContext.minScale=parseFloat(this.getChildValue(node));},read_wmc_SRS:function(layerContext,node){if(!("srs"in layerContext)){layerContext.srs={};}
+layerContext.srs[this.getChildValue(node)]=true;},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[context]);if(context.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(context.maxScale.toPrecision(16)));node.appendChild(minSD);}
+if(context.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(context.minScale.toPrecision(16)));node.appendChild(maxSD);}
+if(context.srs){for(var name in context.srs){node.appendChild(this.createElementDefaultNS("SRS",name));}}
+node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));if(context.dimensions){node.appendChild(this.write_wmc_DimensionList(context));}
+node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",errorProperty:"service",CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var capabilities={};var root=data.documentElement;this.runChildNodes(capabilities,root);return capabilities;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){processor=this["read_cap_"+childNode.nodeName];if(processor){processor.apply(this,[obj,childNode]);}}}},read_cap_FeatureTypeList:function(request,node){var featureTypeList={featureTypes:[]};this.runChildNodes(featureTypeList,node);request.featureTypeList=featureTypeList;},read_cap_FeatureType:function(featureTypeList,node,parentLayer){var featureType={};this.runChildNodes(featureType,node);featureTypeList.featureTypes.push(featureType);},read_cap_Name:function(obj,node){var name=this.getChildValue(node);if(name){var parts=name.split(":");obj.name=parts.pop();if(parts.length>0){obj.featureNS=this.lookupNamespaceURI(node,parts[0]);}}},read_cap_Title:function(obj,node){var title=this.getChildValue(node);
 if(title){obj.title=title;}},read_cap_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515],type:null,wrapDateLine:true,sphericalMercator:false,animationEnabled:true,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.Sphe
 ricalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w+"px";veDiv.style.height=sz.h+"px";this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
+if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True);}catch(e){}
+this.mapObject.HideDashboard();if(typeof this.mapObject.SetAnimationEnabled=="function"){this.mapObject.SetAnimationEnabled(this.animationEnabled);}}
+if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},onMapResize:function(){this.mapObject.Resize(this.map.size.w,this.map.size.h);},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return(typeof VEPixel!='undefined')?this.mapObject.PixelToLatLong(moPixel):this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:f
 unction(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
+return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,allowDepress:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var ctl,i=this.controls.length-1;i>=0;i--){ctl=this.controls[i];if(ctl.events){ctl.events.un({activate:this.iconOn,deactivate:this.iconOff});}
+OpenLayers.Event.stopObservingElement(ctl.panel_div);ctl.panel_div=null;}
+this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
+if(this.saveState===true){this.defaultControl=null;}
+this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];this.activeState[control.id]=control.deactivate();}
+this.redraw();return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.addControlsToMap(this.controls);return this.div;},redraw:function(){for(var l=this.div.childNodes.length,i=l-1;i>=0;i--){this.div.removeChild(this.div.childNodes[i]);}
+this.div.innerHTML="";if(this.active){for(var i=0,len=this.controls.length;i<len;i++){this.div.appendChild(this.controls[i].panel_div);}}},activateControl:function(control){if(!this.active){return false;}
+if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
+if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
+return;}
+if(this.allowDepress&&control.active){control.deactivate();}else{var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
+control.activate();}},addControls:function(controls){if(!(OpenLayers.Util.isArray(controls))){controls=[controls];}
+this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var element=document.createElement("div");element.className=controls[i].displayClass+"ItemInactive";controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
+OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
+if(this.map){this.addControlsToMap(controls);this.redraw();}},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
+control.events.on({activate:this.iconOn,deactivate:this.iconOff});}},iconOn:function(){var d=this.panel_div;d.className=d.className.replace(/ItemInactive$/,"ItemActive");},iconOff:function(){var d=this.panel_div;d.className=d.className.replace(/ItemActive$/,"ItemInactive");},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},onDoubleClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:fu
 nction(){this.map.zoomIn();},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomOut();},CLASS_NAME:"OpenLayers.Control.ZoomOut"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.ZoomIn(),new OpenLayers.Control.ZoomToMaxExtent(),new OpenLayers.Control.ZoomOut()]);},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});OpenLayers.Format.WPSCommon=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+option
 s.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WPSCommon version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WPSCommon.DEFAULTS={'version':"1.0.0",'defaultVersion':"1.0.0"};OpenLayers.Format.WPSCommon.Capabilities=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].Capabilities;if(!cls){throw"Unsupported WPSCommon.Capabilities version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WPSCommon.Request=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].Request;if(!cls){throw"Unsupported WPSCommon.Request version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WPSCommon.ProcessDescription=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].ProcessDescription;if(!cls){throw"Unsupported WPSCommon.ProcessDescription version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WPSCommon.ExecuteResponse=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].ExecuteResponse;if(!cls){throw"Unsupported WPSCommon.ExecuteResponse version: "+options.version;}
+return new cls(options);};OpenLayers.Test=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},CLASS_NAME:"OpenLayers.Test"});OpenLayers.Test.AgsOgcRegression=OpenLayers.Class(OpenLayers.Test,{url:"",initialize:function(options){OpenLayers.Test.prototype.initialize.apply(this,[options]);},_run_get_:function(reqParams,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){OpenLayers.loadURL(resUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},scope:caller});},_run_get_mimeType:function(reqParams,refMimeType,t,optReqUrl){var caller=this;OpenLayers.Request.GET({url:optReqUrl||this.url,params:reqParams,success:function(response){if(response.statusText=="OK"&&response.status==200){t.ok(true,"...execute check result status...");
 }else{t.ok(false,"...execute check result status...");}
+var allResponesHeaders=response.getAllResponseHeaders();if(allResponesHeaders.indexOf(refMimeType)!=-1){t.ok(true,"...execute check result header content type...");}else{t.ok(false,"...execute check result header content type...");}},failure:function(response){t.ok(false,"......");},scope:caller});},_run_post_:function(reqId,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(response){OpenLayers.loadURL(resUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_run_post_wpsStoredResult:function(reqId,docRefUrl,refMimeType,resRefUrl,t){var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:funct
 ion(response){OpenLayers.loadURL(docRefUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");var doc=response.responseXML;if(!doc||!doc.documentElement){doc=response.responseText;}
+var wpsFormat=new OpenLayers.Format.WPSCommon({});var executeResponse=wpsFormat.read(doc);var resUrl=executeResponse.processoutputs[0].data.complexData[0];if(resUrl&&resUrl!=""){t.ok(true,"...async execute check result reference url...");}else{t.ok(false,"...async execute check result reference url...");}
+var scope=this;OpenLayers.loadURL(resUrl,{},scope,function(response){if(response.statusText=="OK"&&response.status==200){t.ok(true,"...execute check result status...");}else{t.ok(false,"...execute check result status...");}
+if(resRefUrl&&resRefUrl!=""){OpenLayers.loadURL(resRefUrl,null,this,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...execute check result...");});}},function(response){t.ok(false,"...async execute check result...");});});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_verify_features_number:function(reqParams,featureType,expectedNumOfFeatures,t){var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){var result_parser=new OpenLayers.Format.WFSTWithLock({version:"1.1.0",featureType:featureType,geometryName:"Shape",featureNS:"http://www.esri.com",featurePrefix:"esri",extractAttributes:false});var features=result_parser.read(response.responseXML);t.eq(features.length,expectedNumOfFeatures,"...verify features number...");},failure:function(response){t.ok(false,"......");},scope:caller});},_run_wfst_post_:function(lockReqId,lockResUrl,
 transactionReqId,transactionResUrl,t){var postLockReqXmlStr=document.getElementById(lockReqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(lockResponse){var lockId=lockResponse.responseXML.firstChild.getAttribute("lockId");if((!lockId)||lockId==""){t.ok(false,"...test failed...null or invalid lockId");}else{t.ok(true,"...test succeeded...valid lockId retrieved...");}
+var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var xmlFormat=new OpenLayers.Format.XML({namespaces:{'wfs':"http://www.opengis.net/wfs"}});var postTransReqXmlDom=xmlFormat.read(postTransReqXmlStr);var lockIdNode=xmlFormat.createElementNSPlus("wfs:LockId",{'value':lockId});postTransReqXmlDom.firstChild.insertBefore(lockIdNode,postTransReqXmlDom.firstChild.firstChild);var postTransReqLockIdXmlStr=xmlFormat.write(postTransReqXmlDom);var innerCaller=caller;OpenLayers.Request.POST({url:caller.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,innerCaller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqLockIdXmlStr});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postLockReqXmlStr});},_run_wfst_post_without_locks:fu
 nction(transactionReqId,transactionResUrl,t){var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,caller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqXmlStr});},_stripXmlDeclaration:function(xmlStr){var idx_l=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");var idx_u=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");if(idx_l>=0||idx_u>=0){OpenLayers.Console.debug("..."+xmlStr.substring(39,xmlStr.length-1));return xmlStr.substring(39,xmlStr.length-1);}else{OpenLayers.Console.debug(xmlStr);return xmlStr;}},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{font
 StyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist
 ,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
+OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},parseEnvelope:function(env,arr){if(arr&&arr.length==4){env.minx=arr[0];env.miny=arr[1];env.maxx=arr[2];env.maxy=arr[3];}},addLayers:function(ll,lyrs){for(var lind=0,len=lyrs.length;lind<len;lind++){ll.push(lyrs[lind]);}},addImageSize:function(imsize,olsize){if(olsize!==null){imsize.width=olsize.w;imsize.height=olsize.h;imsize.printwidth=olsize.w;imsize.printheight=olsize.h;}},addCoordSys:function(featOrFilt,fsys){if(typeof fsys=="string"){featOrFilt.id=parseInt(fsys);featOrFilt.string=fsys;}
+else if(typeof fsys=="object"&&fsys.proj!==null){featOrFilt.id=fsys.proj.srsProjNumber;featOrFilt.string=fsys.proj.srsCode;}else{featOrFilt=fsys;}},iserror:function(data){var ret=null;if(!data){ret=(this.response.error!=='');}else{data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);var errorNodes=data.documentElement.getElementsByTagName("ERROR");ret=(errorNodes!==null&&errorNodes.length>0);}
+return ret;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var arcNode=null;if(data&&data.documentElement){if(data.documentElement.nodeName=="ARCXML"){arcNode=data.documentElement;}else{arcNode=data.documentElement.getElementsByTagName("ARCXML")[0];}}
+if(!arcNode||arcNode.firstChild.nodeName==='parsererror'){var error,source;try{error=data.firstChild.nodeValue;source=data.firstChild.childNodes[1].firstChild.nodeValue;}catch(err){}
+throw{message:"Error parsing the ArcXML request",error:error,source:source};}
+var response=this.parseResponse(arcNode);return response;},write:function(request){if(!request){request=this.request;}
+var root=this.createElementNS("","ARCXML");root.setAttribute("version","1.1");var reqElem=this.createElementNS("","REQUEST");if(request.get_image!=null){var getElem=this.createElementNS("","GET_IMAGE");reqElem.appendChild(getElem);var propElem=this.createElementNS("","PROPERTIES");getElem.appendChild(propElem);var props=request.get_image.properties;if(props.featurecoordsys!=null){var feat=this.createElementNS("","FEATURECOORDSYS");propElem.appendChild(feat);if(props.featurecoordsys.id===0){feat.setAttribute("string",props.featurecoordsys['string']);}
+else{feat.setAttribute("id",props.featurecoordsys.id);}}
+if(props.filtercoordsys!=null){var filt=this.createElementNS("","FILTERCOORDSYS");propElem.appendChild(filt);if(props.filtercoordsys.id===0){filt.setAttribute("string",props.filtercoordsys.string);}
+else{filt.setAttribute("id",props.filtercoordsys.id);}}
+if(props.envelope!=null){var env=this.createElementNS("","ENVELOPE");propElem.appendChild(env);env.setAttribute("minx",props.envelope.minx);env.setAttribute("miny",props.envelope.miny);env.setAttribute("maxx",props.envelope.maxx);env.setAttribute("maxy",props.envelope.maxy);}
+var imagesz=this.createElementNS("","IMAGESIZE");propElem.appendChild(imagesz);imagesz.setAttribute("height",props.imagesize.height);imagesz.setAttribute("width",props.imagesize.width);if(props.imagesize.height!=props.imagesize.printheight||props.imagesize.width!=props.imagesize.printwidth){imagesz.setAttribute("printheight",props.imagesize.printheight);imagesz.setArrtibute("printwidth",props.imagesize.printwidth);}
+if(props.background!=null){var backgrnd=this.createElementNS("","BACKGROUND");propElem.appendChild(backgrnd);backgrnd.setAttribute("color",props.background.color.r+","+
+props.background.color.g+","+
+props.background.color.b);if(props.background.transcolor!==null){backgrnd.setAttribute("transcolor",props.background.transcolor.r+","+
+props.background.transcolor.g+","+
+props.background.transcolor.b);}}
+if(props.layerlist!=null&&props.layerlist.length>0){var layerlst=this.createElementNS("","LAYERLIST");propElem.appendChild(layerlst);for(var ld=0;ld<props.layerlist.length;ld++){var ldef=this.createElementNS("","LAYERDEF");layerlst.appendChild(ldef);ldef.setAttribute("id",props.layerlist[ld].id);ldef.setAttribute("visible",props.layerlist[ld].visible);if(typeof props.layerlist[ld].query=="object"){var query=props.layerlist[ld].query;if(query.where.length<0){continue;}
+var queryElem=null;if(typeof query.spatialfilter=="boolean"&&query.spatialfilter){queryElem=this.createElementNS("","SPATIALQUERY");}
+else{queryElem=this.createElementNS("","QUERY");}
+queryElem.setAttribute("where",query.where);if(typeof query.accuracy=="number"&&query.accuracy>0){queryElem.setAttribute("accuracy",query.accuracy);}
+if(typeof query.featurelimit=="number"&&query.featurelimit<2000){queryElem.setAttribute("featurelimit",query.featurelimit);}
+if(typeof query.subfields=="string"&&query.subfields!="#ALL#"){queryElem.setAttribute("subfields",query.subfields);}
+if(typeof query.joinexpression=="string"&&query.joinexpression.length>0){queryElem.setAttribute("joinexpression",query.joinexpression);}
+if(typeof query.jointables=="string"&&query.jointables.length>0){queryElem.setAttribute("jointables",query.jointables);}
+ldef.appendChild(queryElem);}
+if(typeof props.layerlist[ld].renderer=="object"){this.addRenderer(ldef,props.layerlist[ld].renderer);}}}}else if(request.get_feature!=null){var getElem=this.createElementNS("","GET_FEATURES");getElem.setAttribute("outputmode","newxml");getElem.setAttribute("checkesc","true");if(request.get_feature.geometry){getElem.setAttribute("geometry",request.get_feature.geometry);}
+else{getElem.setAttribute("geometry","false");}
+if(request.get_feature.compact){getElem.setAttribute("compact",request.get_feature.compact);}
+if(request.get_feature.featurelimit=="number"){getElem.setAttribute("featurelimit",request.get_feature.featurelimit);}
+getElem.setAttribute("globalenvelope","true");reqElem.appendChild(getElem);if(request.get_feature.layer!=null&&request.get_feature.layer.length>0){var lyrElem=this.createElementNS("","LAYER");lyrElem.setAttribute("id",request.get_feature.layer);getElem.appendChild(lyrElem);}
+var fquery=request.get_feature.query;if(fquery!=null){var qElem=null;if(fquery.isspatial){qElem=this.createElementNS("","SPATIALQUERY");}else{qElem=this.createElementNS("","QUERY");}
+getElem.appendChild(qElem);if(typeof fquery.accuracy=="number"){qElem.setAttribute("accuracy",fquery.accuracy);}
+if(fquery.featurecoordsys!=null){var fcsElem1=this.createElementNS("","FEATURECOORDSYS");if(fquery.featurecoordsys.id==0){fcsElem1.setAttribute("string",fquery.featurecoordsys.string);}else{fcsElem1.setAttribute("id",fquery.featurecoordsys.id);}
+qElem.appendChild(fcsElem1);}
+if(fquery.filtercoordsys!=null){var fcsElem2=this.createElementNS("","FILTERCOORDSYS");if(fquery.filtercoordsys.id===0){fcsElem2.setAttribute("string",fquery.filtercoordsys.string);}else{fcsElem2.setAttribute("id",fquery.filtercoordsys.id);}
+qElem.appendChild(fcsElem2);}
+if(fquery.buffer>0){var bufElem=this.createElementNS("","BUFFER");bufElem.setAttribute("distance",fquery.buffer);qElem.appendChild(bufElem);}
+if(fquery.isspatial){var spfElem=this.createElementNS("","SPATIALFILTER");spfElem.setAttribute("relation",fquery.spatialfilter.relation);qElem.appendChild(spfElem);if(fquery.spatialfilter.envelope){var envElem=this.createElementNS("","ENVELOPE");envElem.setAttribute("minx",fquery.spatialfilter.envelope.minx);envElem.setAttribute("miny",fquery.spatialfilter.envelope.miny);envElem.setAttribute("maxx",fquery.spatialfilter.envelope.maxx);envElem.setAttribute("maxy",fquery.spatialfilter.envelope.maxy);spfElem.appendChild(envElem);}else if(typeof fquery.spatialfilter.polygon=="object"){spfElem.appendChild(this.writePolygonGeometry(fquery.spatialfilter.polygon));}}
+if(fquery.where!=null&&fquery.where.length>0){qElem.setAttribute("where",fquery.where);}}}
+root.appendChild(reqElem);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},addGroupRenderer:function(ldef,toprenderer){var topRelem=this.createElementNS("","GROUPRENDERER");ldef.appendChild(topRelem);for(var rind=0;rind<toprenderer.length;rind++){var renderer=toprenderer[rind];this.addRenderer(topRelem,renderer);}},addRenderer:function(topRelem,renderer){if(OpenLayers.Util.isArray(renderer)){this.addGroupRenderer(topRelem,renderer);}else{var renderElem=this.createElementNS("",renderer.type.toUpperCase()+"RENDERER");topRelem.appendChild(renderElem);if(renderElem.tagName=="VALUEMAPRENDERER"){this.addValueMapRenderer(renderElem,renderer);}else if(renderElem.tagName=="VALUEMAPLABELRENDERER"){this.addValueMapLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SIMPLELABELRENDERER"){this.addSimpleLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SCALEDEPENDENTRENDERER"){this.addScaleDependentRenderer(renderElem,renderer);}}},addScaleDepe
 ndentRenderer:function(renderElem,renderer){if(typeof renderer.lower=="string"||typeof renderer.lower=="number"){renderElem.setAttribute("lower",renderer.lower);}
+if(typeof renderer.upper=="string"||typeof renderer.upper=="number"){renderElem.setAttribute("upper",renderer.upper);}
+this.addRenderer(renderElem,renderer.renderer);},addValueMapLabelRenderer:function(renderElem,renderer){renderElem.setAttribute("lookupfield",renderer.lookupfield);renderElem.setAttribute("labelfield",renderer.labelfield);if(typeof renderer.exacts=="object"){for(var ext=0,extlen=renderer.exacts.length;ext<extlen;ext++){var exact=renderer.exacts[ext];var eelem=this.createElementNS("","EXACT");if(typeof exact.value=="string"){eelem.setAttribute("value",exact.value);}
+if(typeof exact.label=="string"){eelem.setAttribute("label",exact.label);}
+if(typeof exact.method=="string"){eelem.setAttribute("method",exact.method);}
+renderElem.appendChild(eelem);if(typeof exact.symbol=="object"){var selem=null;if(exact.symbol.type=="text"){selem=this.createElementNS("","TEXTSYMBOL");}
+if(selem!=null){var keys=this.fontStyleKeys;for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(exact.symbol[key]){selem.setAttribute(key,exact.symbol[key]);}}
+eelem.appendChild(selem);}}}}},addValueMapRenderer:function(renderElem,renderer){renderElem.setAttribute("lookupfield",renderer.lookupfield);if(typeof renderer.ranges=="object"){for(var rng=0,rnglen=renderer.ranges.length;rng<rnglen;rng++){var range=renderer.ranges[rng];var relem=this.createElementNS("","RANGE");relem.setAttribute("lower",range.lower);relem.setAttribute("upper",range.upper);renderElem.appendChild(relem);if(typeof range.symbol=="object"){var selem=null;if(range.symbol.type=="simplepolygon"){selem=this.createElementNS("","SIMPLEPOLYGONSYMBOL");}
+if(selem!=null){if(typeof range.symbol.boundarycolor=="string"){selem.setAttribute("boundarycolor",range.symbol.boundarycolor);}
+if(typeof range.symbol.fillcolor=="string"){selem.setAttribute("fillcolor",range.symbol.fillcolor);}
+if(typeof range.symbol.filltransparency=="number"){selem.setAttribute("filltransparency",range.symbol.filltransparency);}
+relem.appendChild(selem);}}}}else if(typeof renderer.exacts=="object"){for(var ext=0,extlen=renderer.exacts.length;ext<extlen;ext++){var exact=renderer.exacts[ext];var eelem=this.createElementNS("","EXACT");if(typeof exact.value=="string"){eelem.setAttribute("value",exact.value);}
+renderElem.appendChild(eelem);if(typeof exact.symbol=="object"){var selem=null;if(exact.symbol.type=="simplemarker"){selem=this.createElementNS("","SIMPLEMARKERSYMBOL");}
+if(selem!=null){if(typeof exact.symbol.antialiasing=="string"){selem.setAttribute("antialiasing",exact.symbol.antialiasing);}
+if(typeof exact.symbol.color=="string"){selem.setAttribute("color",exact.symbol.color);}
+if(typeof exact.symbol.outline=="string"){selem.setAttribute("outline",exact.symbol.outline);}
+if(typeof exact.symbol.overlap=="string"){selem.setAttribute("overlap",exact.symbol.overlap);}
+if(typeof exact.symbol.shadow=="string"){selem.setAttribute("shadow",exact.symbol.shadow);}
+if(typeof exact.symbol.transparency=="number"){selem.setAttribute("transparency",exact.symbol.transparency);}
+if(typeof exact.symbol.usecentroid=="string"){selem.setAttribute("usecentroid",exact.symbol.usecentroid);}
+if(typeof exact.symbol.width=="number"){selem.setAttribute("width",exact.symbol.width);}
+eelem.appendChild(selem);}}}}},addSimpleLabelRenderer:function(renderElem,renderer){renderElem.setAttribute("field",renderer.field);var keys=['featureweight','howmanylabels','labelbufferratio','labelpriorities','labelweight','linelabelposition','rotationalangles'];for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(renderer[key]){renderElem.setAttribute(key,renderer[key]);}}
+if(renderer.symbol.type=="text"){var symbol=renderer.symbol;var selem=this.createElementNS("","TEXTSYMBOL");renderElem.appendChild(selem);var keys=this.fontStyleKeys;for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(symbol[key]){selem.setAttribute(key,renderer[key]);}}}},writePolygonGeometry:function(polygon){if(!(polygon instanceof OpenLayers.Geometry.Polygon)){throw{message:'Cannot write polygon geometry to ArcXML with an '+
+polygon.CLASS_NAME+' object.',geometry:polygon};}
+var polyElem=this.createElementNS("","POLYGON");for(var ln=0,lnlen=polygon.components.length;ln<lnlen;ln++){var ring=polygon.components[ln];var ringElem=this.createElementNS("","RING");for(var rn=0,rnlen=ring.components.length;rn<rnlen;rn++){var point=ring.components[rn];var pointElem=this.createElementNS("","POINT");pointElem.setAttribute("x",point.x);pointElem.setAttribute("y",point.y);ringElem.appendChild(pointElem);}
+polyElem.appendChild(ringElem);}
+return polyElem;},parseResponse:function(data){if(typeof data=="string"){var newData=new OpenLayers.Format.XML();data=newData.read(data);}
+var response=new OpenLayers.Format.ArcXML.Response();var errorNode=data.getElementsByTagName("ERROR");if(errorNode!=null&&errorNode.length>0){response.error=this.getChildValue(errorNode,"Unknown error.");}else{var responseNode=data.getElementsByTagName("RESPONSE");if(responseNode==null||responseNode.length==0){response.error="No RESPONSE tag found in ArcXML response.";return response;}
+var rtype=responseNode[0].firstChild.nodeName;if(rtype=="#text"){rtype=responseNode[0].firstChild.nextSibling.nodeName;}
+if(rtype=="IMAGE"){var envelopeNode=data.getElementsByTagName("ENVELOPE");var outputNode=data.getElementsByTagName("OUTPUT");if(envelopeNode==null||envelopeNode.length==0){response.error="No ENVELOPE tag found in ArcXML response.";}else if(outputNode==null||outputNode.length==0){response.error="No OUTPUT tag found in ArcXML response.";}else{var envAttr=this.parseAttributes(envelopeNode[0]);var outputAttr=this.parseAttributes(outputNode[0]);if(typeof outputAttr.type=="string"){response.image={envelope:envAttr,output:{type:outputAttr.type,data:this.getChildValue(outputNode[0])}};}else{response.image={envelope:envAttr,output:outputAttr};}}}else if(rtype=="FEATURES"){var features=responseNode[0].getElementsByTagName("FEATURES");var featureCount=features[0].getElementsByTagName("FEATURECOUNT");response.features.featurecount=featureCount[0].getAttribute("count");if(response.features.featurecount>0){var envelope=features[0].getElementsByTagName("ENVELOPE");response.features.envelop
 e=this.parseAttributes(envelope[0],typeof(0));var featureList=features[0].getElementsByTagName("FEATURE");for(var fn=0;fn<featureList.length;fn++){var feature=new OpenLayers.Feature.Vector();var fields=featureList[fn].getElementsByTagName("FIELD");for(var fdn=0;fdn<fields.length;fdn++){var fieldName=fields[fdn].getAttribute("name");var fieldValue=fields[fdn].getAttribute("value");feature.attributes[fieldName]=fieldValue;}
+var geom=featureList[fn].getElementsByTagName("POLYGON");if(geom.length>0){var ring=geom[0].getElementsByTagName("RING");var polys=[];for(var rn=0;rn<ring.length;rn++){var linearRings=[];linearRings.push(this.parsePointGeometry(ring[rn]));var holes=ring[rn].getElementsByTagName("HOLE");for(var hn=0;hn<holes.length;hn++){linearRings.push(this.parsePointGeometry(holes[hn]));}
+holes=null;polys.push(new OpenLayers.Geometry.Polygon(linearRings));linearRings=null;}
+ring=null;if(polys.length==1){feature.geometry=polys[0];}else
+{feature.geometry=new OpenLayers.Geometry.MultiPolygon(polys);}}
+response.features.feature.push(feature);}}}else{response.error="Unidentified response type.";}}
+return response;},parseAttributes:function(node,type){var attributes={};for(var attr=0;attr<node.attributes.length;attr++){if(type=="number"){attributes[node.attributes[attr].nodeName]=parseFloat(node.attributes[attr].nodeValue);}else{attributes[node.attributes[attr].nodeName]=node.attributes[attr].nodeValue;}}
+return attributes;},parsePointGeometry:function(node){var ringPoints=[];var coords=node.getElementsByTagName("COORDS");if(coords.length>0){var coordArr=this.getChildValue(coords[0]);coordArr=coordArr.split(/;/);for(var cn=0;cn<coordArr.length;cn++){var coordItems=coordArr[cn].split(/ /);ringPoints.push(new OpenLayers.Geometry.Point(coordItems[0],coordItems[1]));}
+coords=null;}else{var point=node.getElementsByTagName("POINT");if(point.length>0){for(var pn=0;pn<point.length;pn++){ringPoints.push(new OpenLayers.Geometry.Point(parseFloat(point[pn].getAttribute("x")),parseFloat(point[pn].getAttribute("y"))));}}
+point=null;}
+return new OpenLayers.Geometry.LinearRing(ringPoints);},CLASS_NAME:"OpenLayers.Format.ArcXML"});OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(params){var defaults={get_image:{properties:{background:null,draw:true,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:false},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:false,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]};return O
 penLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(params){var defaults={image:{envelope:null,output:''},features:{featurecount:0,envelope:null,feature:[]},error:''};return OpenLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:''},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:true,name:"ArcIMS",isBaseLayer:true,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:true,async:true,name:"ArcIMS"},initialize:function(name,url,options){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:options.serviceName},this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(options,this.D
 EFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,this.params,options]);if(this.transparent){if(!this.isBaseLayer){this.isBaseLayer=false;}
+if(this.format=="image/jpeg"){this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}
+if(this.options.layers===null){this.options.layers=[];}},getURL:function(bounds){var url="";bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));var req=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:axlReq.write(),async:false});if(req!=null){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
+var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);url=this.getUrlOrImage(arcxml.image.output);}
+return url;},getURLasync:function(bounds,scope,prop,callback){bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));OpenLayers.Request.POST({url:this.getFullRequestString(),async:true,data:axlReq.write(),callback:function(req){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
+var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);scope[prop]=this.getUrlOrImage(arcxml.image.output);callback.apply(scope);},scope:this});},getUrlOrImage:function(output){var ret="";if(output.url){ret=output.url;}else if(output.data){ret="data:image/"+output.type+";base64,"+output.data;}
+return ret;},setLayerQuery:function(id,querydef){for(var lyr=0;lyr<this.options.layers.length;lyr++){if(id==this.options.layers[lyr].id){this.options.layers[lyr].query=querydef;return;}}
+this.options.layers.push({id:id,visible:true,query:querydef});},getFeatureInfo:function(geometry,layer,options){var buffer=options.buffer||1;var callback=options.callback||function(){};var scope=options.scope||window;var requestOptions={};OpenLayers.Util.extend(requestOptions,this.options);requestOptions.requesttype="feature";if(geometry instanceof OpenLayers.LonLat){requestOptions.polygon=null;requestOptions.envelope=[geometry.lon-buffer,geometry.lat-buffer,geometry.lon+buffer,geometry.lat+buffer];}else if(geometry instanceof OpenLayers.Geometry.Polygon){requestOptions.envelope=null;requestOptions.polygon=geometry;}
+var arcxml=new OpenLayers.Format.ArcXML(requestOptions);OpenLayers.Util.extend(arcxml.request.get_feature,options);arcxml.request.get_feature.layer=layer.id;if(typeof layer.query.accuracy=="number"){arcxml.request.get_feature.query.accuracy=layer.query.accuracy;}else{var mapCenter=this.map.getCenter();var viewPx=this.map.getViewPortPxFromLonLat(mapCenter);viewPx.x++;var mapOffCenter=this.map.getLonLatFromPixel(viewPx);arcxml.request.get_feature.query.accuracy=mapOffCenter.lon-mapCenter.lon;}
+arcxml.request.get_feature.query.where=layer.query.where;arcxml.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({'CustomService':'Query'}),data:arcxml.write(),callback:function(request){var response=arcxml.parseResponse(request.responseText);if(!arcxml.iserror()){callback.call(scope,response.features);}else{callback.call(scope,null);}}});},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
+return false;},deactivate:function(){if(this.active){this.active=false;return true;}
+return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:false,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.cache=[];this.layer.events.on({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
+return activated;},deactivate:function(){this.cache=null;if(this.layer&&this.layer.events){this.layer.events.un({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
+return OpenLayers.Strategy.prototype.deactivate.apply(this,arguments);},handleAdd:function(event){if(!this.caching&&this.filter){var features=event.features;event.features=[];var feature;for(var i=0,ii=features.length;i<ii;++i){feature=features[i];if(this.filter.evaluate(feature)){event.features.push(feature);}else{this.cache.push(feature);}}}},handleRemove:function(event){if(!this.caching){this.cache=[];}},setFilter:function(filter){this.filter=filter;var previousCache=this.cache;this.cache=[];this.handleAdd({features:this.layer.features});if(this.cache.length>0){this.caching=true;this.layer.removeFeatures(this.cache.slice());this.caching=false;}
+if(previousCache.length>0){var event={features:previousCache};this.handleAdd(event);if(event.features.length>0){this.caching=true;this.layer.addFeatures(event.features);this.caching=false;}}},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},read_cap_DefaultSRS:function(obj,node){var defaultSRS=this.getChildValue(node);if(defaultSRS){obj.srs=defaultSRS;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.maxExtent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(thi
 s.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;}
+OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
+OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);this.addTileMonitoringHooks(this.tile);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
+this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){this.events.triggerEvent("loadstart");};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.events.triggerEvent("loadend");};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Process=OpenLayers.Class({events:null,eventListeners:null,EVENT_TYPES:["beforeprocessstart","processstarted","process
 succeeded","processfailed","afterprocesscompleted"],initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}},CLASS_NAME:"OpenLayers.Process"});OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{defaultDesc:"No description available",extractWaypoints:true,extractTracks:true,extractRoutes:true,extractAttributes:true,gpxns:"http://www.topografix.com/GPX/1/1",initialize:function(options){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var features=[];if(this.extractTracks){var tracks=doc.getElementsByTagName("trk");for(var i=0,len=tracks.length;i<len;i++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(tracks[i]);}
+var segs=this.getElementsByTagNameNS(tracks[i],tracks[i].namespaceURI,"trkseg");for(var j=0,seglen=segs.length;j<seglen;j++){var track=this.extractSegment(segs[j],"trkpt");features.push(new OpenLayers.Feature.Vector(track,attrs));}}}
+if(this.extractRoutes){var routes=doc.getElementsByTagName("rte");for(var k=0,klen=routes.length;k<klen;k++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(routes[k]);}
+var route=this.extractSegment(routes[k],"rtept");features.push(new OpenLayers.Feature.Vector(route,attrs));}}
+if(this.extractWaypoints){var waypoints=doc.getElementsByTagName("wpt");for(var l=0,len=waypoints.length;l<len;l++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(waypoints[l]);}
+var wpt=new OpenLayers.Geometry.Point(waypoints[l].getAttribute("lon"),waypoints[l].getAttribute("lat"));features.push(new OpenLayers.Feature.Vector(wpt,attrs));}}
+if(this.internalProjection&&this.externalProjection){for(var g=0,featLength=features.length;g<featLength;g++){features[g].geometry.transform(this.externalProjection,this.internalProjection);}}
+return features;},extractSegment:function(segment,segmentType){var points=this.getElementsByTagNameNS(segment,segment.namespaceURI,segmentType);var point_features=[];for(var i=0,len=points.length;i<len;i++){point_features.push(new OpenLayers.Geometry.Point(points[i].getAttribute("lon"),points[i].getAttribute("lat")));}
+return new OpenLayers.Geometry.LineString(point_features);},parseAttributes:function(node){var attributes={};var attrNode=node.firstChild,value,name;while(attrNode){if(attrNode.nodeType==1){value=attrNode.firstChild;if(value.nodeType==3||value.nodeType==4){name=(attrNode.prefix)?attrNode.nodeName.split(":")[1]:attrNode.nodeName;if(name!="trkseg"&&name!="rtept"){attributes[name]=value.nodeValue;}}}
+attrNode=attrNode.nextSibling;}
+return attributes;},write:function(features,metadata){var gpx;features=OpenLayers.Util.isArray(features)?features:[features];gpx=this.createElementNS(this.gpxns,"gpx");for(var i=0,len=features.length;i<len;i++){gpx.appendChild(this.buildFeatureNode(features[i]));}
+if(metadata&&typeof metadata=='object'){gpx.appendChild(this.buildMetadataNode(metadata));}
+return OpenLayers.Format.XML.prototype.write.apply(this,[gpx]);},buildMetadataNode:function(metadata){var types=['name','desc','author'],node=this.createElementNS(this.gpxns,'metadata');for(var i=0;i<types.length;i++){var type=types[i];if(metadata[type]){var n=this.createElementNS(this.gpxns,type);n.appendChild(this.createTextNode(metadata[type]));node.appendChild(n);}}
+return node;},buildFeatureNode:function(feature){var geometry=feature.geometry;geometry=geometry.clone();if(this.internalProjection&&this.externalProjection){geometry.transform(this.internalProjection,this.externalProjection);}
+if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){var wpt=this.buildWptNode(feature);return wpt;}else{var trkNode=this.createElementNS(this.gpxns,"trk");this.appendAttributesNode(trkNode,feature);var trkSegNodes=this.buildTrkSegNode(geometry);trkSegNodes=OpenLayers.Util.isArray(trkSegNodes)?trkSegNodes:[trkSegNodes];for(var i=0,len=trkSegNodes.length;i<len;i++){trkNode.appendChild(trkSegNodes[i]);}
+return trkNode;}},buildTrkSegNode:function(geometry){var node,i,len,point,nodes;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){node=this.createElementNS(this.gpxns,"trkseg");for(i=0,len=geometry.components.length;i<len;i++){point=geometry.components[i];node.appendChild(this.buildTrkPtNode(point));}
+return node;}else{nodes=[];for(i=0,len=geometry.components.length;i<len;i++){nodes.push(this.buildTrkSegNode(geometry.components[i]));}
+return nodes;}},buildTrkPtNode:function(point){var node=this.createElementNS(this.gpxns,"trkpt");node.setAttribute("lon",point.x);node.setAttribute("lat",point.y);return node;},buildWptNode:function(feature){var node=this.createElementNS(this.gpxns,"wpt");node.setAttribute("lon",feature.geometry.x);node.setAttribute("lat",feature.geometry.y);this.appendAttributesNode(node,feature);return node;},appendAttributesNode:function(node,feature){var name=this.createElementNS(this.gpxns,'name');name.appendChild(this.createTextNode(feature.attributes.name||feature.id));node.appendChild(name);var desc=this.createElementNS(this.gpxns,'desc');desc.appendChild(this.createTextNode(feature.attributes.description||this.defaultDesc));node.appendChild(desc);},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Util.AgsUtil=(function(){return function(){}})();OpenLayers.Util.AgsUtil.isDefined=function(value){if(value===undefined||value===null||value===""){return false;}
+else{return true;}};OpenLayers.Util.AgsUtil.isNumber=function(value){if(value===undefined||value===null||value===""){return false;}else if(typeof value==="number"){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isBoolean=function(value){if(value===undefined||value===null||value===""){return false;}else if(typeof value==="boolean"){return true;}
+else{return false;}};OpenLayers.Util.AgsUtil.isAgsGeometry=function(value){if(value===undefined||value===null||value===""){return false;}else if(value instanceof esri.geometry.Point){return true;}else if(value instanceof esri.geometry.Polyline){return true;}else if(value instanceof esri.geometry.Polygon){return true;}else if(value instanceof esri.geometry.Extent){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isOLGeometry=function(value){if(value===undefined||value===null||value===""){return false;}else if(value instanceof OpenLayers.Geometry.Point){return true;}else if(value instanceof OpenLayers.Geometry.LineString){return true;}else if(value instanceof OpenLayers.Geometry.LinearRing){return true;}else if(value instanceof OpenLayers.Geometry.MultiLineString){return true;}else if(value instanceof OpenLayers.Geometry.MultiPoint){return true;}else if(value instanceof OpenLayers.Geometry.MultiPolygon){return true;}else if(value instanceof OpenLayers.Geometry.Polygon
 ){return true;}else if(value instanceof OpenLayers.Bounds){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isSameOLPoint=function(point1,point2){if(typeof point1.x==="number"&&typeof point1.y==="number"&&typeof point2.x==="number"&&typeof point2.y==="number"){if(point1.x==point2.x&&point1.y==point2.y){return true;}}
+return false;};OpenLayers.Util.AgsUtil.dispatch=function(functions,complete,scope){var requests=functions.length;var responses=0;var storage={};function respond(){++responses;if(responses===requests){complete.call(scope,storage);}}
+function trigger(index){window.setTimeout(function(){functions[index].apply(scope,[respond,storage]);});}
+for(var i=0;i<requests;++i){trigger(i);}};OpenLayers.Util.AgsUtil.bindFunction=function(func,scope){if(window.dojo!==undefined){return dojo.hitch(scope,func);}else{OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(func,scope);}};OpenLayers.Util.AgsUtil.createSingleCallback=function(methods,options,scope){if(window.dojo!==undefined){return dojo.hitch(scope,function(response){var method=null;for(var i=0;i<methods.length;i++){method=methods[i];if(typeof method=="function"){method.apply(scope,[response,options]);}}});}else{return OpenLayers.Function.bind(function(response){var method=null;for(var i=0;i<methods.length;i++){method=methods[i];if(typeof method=="function"){method.apply(scope,[response,options]);}}},scope);}};OpenLayers.Util.AgsUtil.createProtocolCallback=function(method,response,options,scope){if(window.dojo!==undefined){return dojo.hitch(scope,function(){if(typeof method=="funct
 ion"){method.apply(this,[response,options]);}});}else{return OpenLayers.Function.bind(function(){if(typeof method=="function"){method.apply(this,[response,options]);}},scope);}};OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},readers:{"xsd":{"schema":function(node,obj){var complexTypes=[];var customTypes={};var schema={complexTypes:complexTypes,customTypes:customTypes};this.readChildNodes(node,schema);var attributes=node.attributes;var attr,name;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];name=attr.name;if(name.indexOf("xmlns")==0){this.setNamespace(name.split(":")[1]||"",attr.value);}else{obj[name]=attr.value;}}
+obj.featureTypes=complexTypes;obj.targetPrefix=this.namespaceAlias[obj.targetNamespace];var complexType,customType;for(var i=0,len=complexTypes.length;i<len;++i){complexType=complexTypes[i];customType=customTypes[complexType.typeName];if(customTypes[complexType.typeName]){complexType.typeName=customType.name;}}},"complexType":function(node,obj){var complexType={"typeName":node.getAttribute("name")};this.readChildNodes(node,complexType);obj.complexTypes.push(complexType);},"complexContent":function(node,obj){this.readChildNodes(node,obj);},"extension":function(node,obj){this.readChildNodes(node,obj);},"sequence":function(node,obj){var sequence={elements:[]};this.readChildNodes(node,sequence);obj.properties=sequence.elements;},"element":function(node,obj){if(obj.elements){var element={};var attributes=node.attributes;var attr;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];element[attr.name]=attr.value;}
+var type=element.type;if(!type){type={};this.readChildNodes(node,type);element.restriction=type;element.type=type.base;}
+var fullType=type.base||type;element.localType=fullType.split(":").pop();obj.elements.push(element);}
+if(obj.complexTypes){var type=node.getAttribute("type");var localType=type.split(":").pop();obj.customTypes[localType]={"name":node.getAttribute("name"),"type":type};}},"simpleType":function(node,obj){this.readChildNodes(node,obj);},"restriction":function(node,obj){obj.base=node.getAttribute("base");this.readRestriction(node,obj);}}},readRestriction:function(node,obj){var children=node.childNodes;var child,nodeName,value;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){nodeName=child.nodeName.split(":").pop();value=child.getAttribute("value");if(!obj[nodeName]){obj[nodeName]=value;}else{if(typeof obj[nodeName]=="string"){obj[nodeName]=[obj[nodeName]];}
+obj[nodeName].push(value);}}}},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var schema={};this.readNode(data,schema);return schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,featureDx:0,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){this.extent=extent.wrapDateLine(this.map.getMaxExtent());}
+if(resolutionChanged){this.resolution=null;}
+return true;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMaxExtent();}
+if(!bounds.intersectsBounds(this.extent,{worldBounds:worldBounds})){style={display:"none"};}else{this.calculateFeatureDx(bounds,worldBounds);}
+var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
+this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
+return rendered;}}},calculateFeatureDx:function(bounds,worldBounds){this.featureDx=0;if(worldBounds){var worldWidth=worldBounds.getWidth(),rendererCenterX=(this.extent.left+this.extent.right)/2,featureCenterX=(bounds.left+bounds.right)/2,worldsAway=Math.round((featureCenterX-rendererCenterX)/worldWidth);this.featureDx=worldsAway*worldWidth;}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
+if(symbolizer.fill===false){delete result.fillColor;}
+OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},setExtent:function(){OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);return false;},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canv
 as");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);var bounds=feature.geometry.getBounds();var worldBounds;if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){worldBounds=this.map.getMaxExtent();}
+var intersects=bounds&&bounds.intersectsBounds(this.extent,{worldBounds:worldBounds});rendered=(style.display!=="none")&&!!bounds&&intersects;if(rendered){this.features[feature.id]=[feature,style];}
+else{delete(this.features[feature.id]);}
+this.pendingRedraw=true;}
+if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
+return rendered;},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
+return;}
+switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style,featureId);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style,featureId);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style,featureId);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style,featureId);break;default:break;}},drawExternalGraphic:function(geometry,style,featureId){var img=new Image();if(style.graphicTitle){img.title=style.graphicTitle;}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;var onLoad=function(){if(!this.features[featureId]){return;}
+var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=(p0+xOffset)|0;var y=(p1+yOffset)|0;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},fe
 atureIdToHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
+var hex="000000"+id.toString(16);var len=hex.length;hex="#"+hex.substring(len-6,len);return hex;},setHitContextStyle:function(type,featureId,symbolizer){var hex=this.featureIdToHex(featureId);if(type=="fill"){this.hitContext.globalAlpha=1.0;this.hitContext.fillStyle=hex;}else if(type=="stroke"){this.hitContext.globalAlpha=1.0;this.hitContext.strokeStyle=hex;this.hitContext.lineWidth=symbolizer.strokeWidth+2;}else{this.hitContext.globalAlpha=0;this.hitContext.lineWidth=1;}},drawPoint:function(geometry,style,featureId){if(style.graphic!==false){if(style.externalGraphic){this.drawExternalGraphic(geometry,style,featureId);}else{var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var twoPi=Math.PI*2;var radius=style.pointRadius;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitC
 ontext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.fill();}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.stroke();}
+this.setCanvasStyle("reset");}}}}},drawLineString:function(geometry,style,featureId){style=OpenLayers.Util.applyDefaults({fill:false},style);this.drawLinearRing(geometry,style,featureId);},drawLinearRing:function(geometry,style,featureId){if(style.fill!==false){this.setCanvasStyle("fill",style);this.renderPath(this.canvas,geometry,style,featureId,"fill");if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"fill");}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.renderPath(this.canvas,geometry,style,featureId,"stroke");if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"stroke");}}
+this.setCanvasStyle("reset");},renderPath:function(context,geometry,style,featureId,type){var components=geometry.components;var len=components.length;context.beginPath();var start=this.getLocalXY(components[0]);var x=start[0];var y=start[1];if(!isNaN(x)&&!isNaN(y)){context.moveTo(start[0],start[1]);for(var i=1;i<len;++i){var pt=this.getLocalXY(components[i]);context.lineTo(pt[0],pt[1]);}
+if(type==="fill"){context.fill();}else{context.stroke();}}},drawPolygon:function(geometry,style,featureId){var components=geometry.components;var len=components.length;this.drawLinearRing(components[0],style,featureId);for(var i=1;i<len;++i){this.canvas.globalCompositeOperation="destination-out";if(this.hitDetection){this.hitContext.globalCompositeOperation="destination-out";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({stroke:false,fillOpacity:1.0},style),featureId);this.canvas.globalCompositeOperation="source-over";if(this.hitDetection){this.hitContext.globalCompositeOperation="source-over";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({fill:false},style),featureId);}},drawText:function(location,style){style=OpenLayers.Util.extend({fontColor:"#000000",labelAlign:"cm"},style);var pt=this.getLocalXY(location);this.setCanvasStyle("reset");this.canvas.fillStyle=style.fontColor;this.canvas.globalAlpha=style.fontOpacity||1.0;var fontStyle=[style.fontStyle?style.fontStyle:"normal","normal",style.fontWeight?style.fontWeight:"normal",style.fontSize?style.fontSize:"1em",style.fontFamily?style.fontFamily:"sans-serif"].join(" ");var labelRows=style.label.split('\n');var numRows=labelRows.length;if(this.canvas.fillText){this.canvas.font=fontStyle;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[1]]||"middle";var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.measureText('Mg').height||this.canvas.measureText('xx').width;pt[1]+=lineHeight*vfactor*(numRows-1);for(var i=0;i<numRows;i++){this.canvas.fillText(labelRows[i],pt[0],pt[1]+(lineHeight*i));}}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=fontStyle;var hfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[0]];if(hfactor==null){hfactor=-.5;}
+var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.mozMeasureText('xx');pt[1]+=lineHeight*(1+(vfactor*numRows));for(var i=0;i<numRows;i++){var x=pt[0]+(hfactor*this.canvas.mozMeasureText(labelRows[i]));var y=pt[1]+(i*lineHeight);this.canvas.translate(x,y);this.canvas.mozDrawText(labelRows[i]);this.canvas.translate(-x,-y);}}
+this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=((point.x-this.featureDx)/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);this.features={};if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}},getFeatureIdFromEvent:function(evt){var feature=null;if(this.hitDetection){if(!this.map.dragging){var xy=evt.xy;var x=xy.x|0;var y=xy.y|0;var data=this.hitContext.getImageData(x,y,1,1).data;if(data[3]===255){var id=data[2]+(256*(data[1]+(256*data[0])));if(id){feature=this.features["OpenLayers.Feature.Vector_"+(id-1+this.hitOverflow)][0];}}}}
+return feature;},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
+this.redraw();},redraw:function(){if(!this.locked){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}
+var labelMap=[];var feature,geometry,style;var worldBounds=(this.map.baseLayer&&this.map.baseLayer.wrapDateLine)&&this.map.getMaxExtent();for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
+feature=this.features[id][0];geometry=feature.geometry;this.calculateFeatureDx(geometry.getBounds(),worldBounds);style=this.features[id][1];this.drawGeometry(geometry,style,feature.id);if(style.label){labelMap.push([feature,style]);}}
+var item;for(var i=0,len=labelMap.length;i<len;++i){item=labelMap[i];this.drawText(item[0].geometry.getCentroid(),item[1]);}}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={"l":"left","r":"right","t":"top","b":"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={"l":0,"r":-1,"t":0,"b":-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
+layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
+layer_defaults.areaTags=area;this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
+var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
+if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
+for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
+tags=result[0];}else{tags=this.getTags(node.node);}
+var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
+feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
+node.node=null;}
+return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
+return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
+return_ways.push(way_object);}
+return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
+return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
+if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
+return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
+return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
+return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
+if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
+this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
+this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var id;var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
+var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
+this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
+this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
+if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,touch:false,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.
 Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
+document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},dragmove:function(evt){this.lastMoveEvt=evt;if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
+if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
+this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
+this.last=evt.xy;}
+return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
+var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,scope:this});}
+return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;if(this.dragging){this.mousemove(this.lastMoveEvt);}},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.touch=false;this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null},'touchstart':{'in':'click','out':'clickout'}},feature:null,lastFeature:n
 ull,down:null,up:null,touch:false,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
+return OpenLayers.Event.isMultiTouch(evt)?true:this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.stop(evt);},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
+this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
+var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick"||type=="touchstart");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
+if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
+if(this.feature){if(type==="touchstart"){OpenLayers.Event.stop(evt);}
+var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
+this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
+return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
+Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.touch=false;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
+return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={d
 rag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(this.handlers.feature.touch&&!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.handlers.feature.touch&&this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,ar
 guments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
+return activated;},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},
 CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style
 );this.styles["delete"]=new OpenLayers.Style(style);break;}}}
+OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
+this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
+if(!this.styles[intent]){intent="default";}
+feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
+return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
+this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
+if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
+this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
+this.strategies=null;}
+if(this.protocol){if(this.protocol.autoDestroy){this.protocol.destroy();}
+this.protocol=null;}
+this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
+this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
+obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var ng=(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG);if(ng){dragging||this.renderer.updateDimensions(zoomChanged);}else{var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenL
 ayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
+if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}}
+if(!this.drawn||(!ng&&(zoomChanged||!coordSysUnchanged))){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},redraw:function(){if(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG){this.drawn=false;}
+return OpenLayers.Layer.prototype.redraw.apply(this,arguments);},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
+features=event.features;}
+var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){throw new TypeError('addFeatures: component should be an '+
+this.geometryType.prototype.CLASS_NAME);}
+feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
+if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;}
+this.preFeatureInsert(feature);}
+featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
+if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
+if(features===this.features){return this.removeAllFeatures(options);}
+if(!(OpenLayers.Util.isArray(features))){features=[features];}
+if(features===this.selectedFeatures){features=features.slice();}
+var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];delete this.unrenderedFeatures[feature.id];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+this.features=OpenLayers.Util.removeItem(this.features,feature);feature.layer=null;if(feature.geometry){this.renderer.eraseFeatures(feature);}
+if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
+if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},removeAllFeatures:function(options){var notify=!options||!options.silent;var features=this.features;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+feature.layer=null;if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},destroyFeatures:function(features,options){var all=(features==undefined);if(all){features=this.features;}
+if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
+if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
+var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
+var drawn=this.renderer.drawFeature(feature,style);if(drawn===false||drawn===null){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];}},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){throw new Error('getFeatureFromEvent called on layer with no '+'renderer. This usually means you destroyed a '+'layer, but not some handler which is associated '+'with it.');}
+var feature=null;var featureId=this.renderer.getFeatureIdFromEvent(evt);if(featureId){if(typeof featureId==="string"){feature=this.getFeatureById(featureId);}else{feature=featureId;}}
+return feature;},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
+return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
+return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){if(maxExtent===null){maxExtent=new OpenLayers.Bounds();}
+maxExtent.extend(geometry.getBounds());}}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){laye
 r=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
+this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
+this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
+if(this.layers){this.map.removeLayer(this.layer);}}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
+this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
 =this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;if(feature._prevHighlighter==undefined){delete feature._lastHighlighter;}else if(feature._prevHighlighter==this.id){delete feature._prevHighlighter;}else{feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;}
+layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
+layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
+var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
+this.multiple=prevMultiple;}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
+OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
+this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
+return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
+deactivated=true;}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
 .RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(OpenLayers.Util.isArray(this.deleteCodes))){this.deleteCodes=[this.deleteCodes];}
+var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
+var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyb
 oard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
+this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
+this.handlers.keyboard.deactivate();deactivated=true;}
+return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}
+var modified=feature.modified;if(feature.geometry&&!(modified&&modified.geometry)){this._originalGeometry=feature.geometry.clone();}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
+this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
+this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
+if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
+this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;if(this.modified&&this._originalGeometry){var feature=this.feature;feature.modified=OpenLayers.Util.extend(feature.modified,{geometry:this._originalGeometry});delete this._originalGeometry;}}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
+if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
+if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
+if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
+if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
+if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.modified=true;this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i
 ,vertex,component,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
+for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
+if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
+collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
 penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
+if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
+geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338
 ,0.07464553542435169],attributionTemplate:'<span class="olBingAttribution ${type}">'+'<div><a target="_blank" href="http://www.bing.com/maps/">'+'<img src="${logo}" /></a></div>${copyrights}'+'<a style="white-space: nowrap" target="_blank" '+'href="http://www.microsoft.com/maps/product/terms.html">'+'Terms of Use</a></span>',metadata:null,type:"Road",metadataParams:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({sphericalMercator:true},options);var name=options.name||"Bing "+(options.type||this.type);var newArgs=[name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);this.loadMetadata();},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var params=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams);var url="http://dev.virtualearth.net/RES
 T/v1/Imagery/Metadata/"+
+this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({maxResolution:Math.min(this.serverResolutions[res.zoomMin],this.maxResolution),zoomOffset:res.zoomMin,numZoomLevels:Math.min(res.zoomMax+1-res.zoomMin,this.numZoomLevels)},true);},getURL:function(bounds){if(!this.url){return;}
+var xyz=this.getXYZ(bounds),x=xyz.x,y=xyz.y,z=xyz.z;var quadDigits=[];for(var i=z;i>0;--i){var digit='0';var mask=1<<(i-1);if((x&mask)!=0){digit++;}
+if((y&mask)!=0){digit++;digit++;}
+quadDigits.push(digit);}
+var quadKey=quadDigits.join("");var url=this.selectUrl(''+x+y+z,this.url);return OpenLayers.String.format(url,{'quadkey':quadKey});},updateAttribution:function(){var metadata=this.metadata;if(!metadata||!this.map||!this.map.center){return;}
+var res=metadata.resourceSets[0].resources[0];var extent=this.map.getExtent().transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var providers=res.imageryProviders,zoom=this.map.getZoom()+1,copyrights="",provider,i,ii,j,jj,bbox,coverage;for(i=0,ii=providers.length;i<ii;++i){provider=providers[i];for(j=0,jj=provider.coverageAreas.length;j<jj;++j){coverage=provider.coverageAreas[j];bbox=OpenLayers.Bounds.fromArray(coverage.bbox);if(extent.intersectsBounds(bbox)&&zoom<=coverage.zoomMax&&zoom>=coverage.zoomMin){copyrights+=provider.attribution+" ";}}}
+this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),logo:metadata.brandLogoUri,copyrights:copyrights});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Bing(this.options);}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(metadata){this.metadata=metadata;this.initLayer();var script=document.getElementById(this._callbackId);script.parentNode.removeChild(script);window[this._callbackId]=undefined;delete this._callbackId;};OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\
 s*,\s*/g)},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var info={features:[]};this.readNode(data,info);var features=[];for(var i=0,len=info.features.length;i<len;i++){var container=info.features[i];if(this.internalProjection&&this.externalProjection&&container.components[0]){container.components[0].transform(this.externalProjection,this.internalProjection);}
+var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);features.push(feature);}
+return features;},readers:{"sa":{"SamplingPoint":function(node,obj){if(!obj.attributes){var feature={attributes:{}};obj.features.push(feature);obj=feature;}
+obj.attributes.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"position":function(node,obj){this.readChildNodes(node,obj);}},"gml":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);},"featureMember":function(node,obj){var feature={attributes:{}};obj.features.push(feature);this.readChildNodes(node,feature);},"name":function(node,obj){obj.attributes.name=this.getChildValue(node);},"pos":function(node,obj){if(!this.externalProjection){this.externalProjection=new OpenLayers.Projection(node.getAttribute("srsName"));}
+OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[node,obj]);}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{"sos":{"GetFeatureOfInterest":function(options){var node=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:'SOS',"xsi:schemaLocation":this.schemaLocation}});for(var i=0,len=options.fois.length;i<len;i++){this.writeNode("FeatureOfInterestId",{foi:options.fois[i]},node);}
+return node;},"FeatureOfInterestId":function(options){var node=this.createElementNSPlus("FeatureOfInterestId",{value:options.foi});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",defaultPrefix:"sos",read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var info={measurements:[],observations:[]};this.readNode(data,info);return info;},write:function(options){var node=this.writeNode("sos:GetObservation",options);node.setAttribute("xmlns:om",this.namespaces.om);node.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},readers:{"om":{"ObservationCollection":function(node,obj){obj.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"member":function(node,observationCollection){this.readChildNodes(node,observationCollection);},"Measurement":function(node,observationCollection){var measurement={};observationCollection.measurements.push(measurement);this.readChildNodes(node,measurement);},"Observation":function(node,observationCollection){var observation={};observationCollection.observations.push(observation);this.readChildNodes(node,observation);},"sampl
 ingTime":function(node,measurement){var samplingTime={};measurement.samplingTime=samplingTime;this.readChildNodes(node,samplingTime);},"observedProperty":function(node,measurement){measurement.observedProperty=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"procedure":function(node,measurement){measurement.procedure=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"featureOfInterest":function(node,observation){var foi={features:[]};observation.fois=[];observation.fois.push(foi);this.readChildNodes(node,foi);var features=[];for(var i=0,len=foi.features.length;i<len;i++){var feature=foi.features[i];features.push(new OpenLayers.Feature.Vector(feature.components[0],feature.attributes));}
+foi.features=features;},"result":function(node,measurement){var result={};measurement.result=result;if(this.getChildValue(node)!==''){result.value=this.getChildValue(node);result.uom=node.getAttribute("uom");}else{this.readChildNodes(node,result);}}},"sa":OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,"gml":OpenLayers.Util.applyDefaults({"TimeInstant":function(node,samplingTime){var timeInstant={};samplingTime.timeInstant=timeInstant;this.readChildNodes(node,timeInstant);},"timePosition":function(node,timeInstant){timeInstant.timePosition=this.getChildValue(node);}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{"sos":{"GetObservation":function(options){var node=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:'SOS'}});this.writeNode("offering",options,node);if(options.eventTime){this.writeNode("eventTime",options,node);}
+for(var procedure in options.procedures){this.writeNode("procedure",options.procedures[procedure],node);}
+for(var observedProperty in options.observedProperties){this.writeNode("observedProperty",options.observedProperties[observedProperty],node);}
+if(options.foi){this.writeNode("featureOfInterest",options.foi,node);}
+this.writeNode("responseFormat",options,node);if(options.resultModel){this.writeNode("resultModel",options,node);}
+if(options.responseMode){this.writeNode("responseMode",options,node);}
+return node;},"featureOfInterest":function(foi){var node=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",foi.objectId,node);return node;},"ObjectID":function(options){return this.createElementNSPlus("ObjectID",{value:options});},"responseFormat":function(options){return this.createElementNSPlus("responseFormat",{value:options.responseFormat});},"procedure":function(procedure){return this.createElementNSPlus("procedure",{value:procedure});},"offering":function(options){return this.createElementNSPlus("offering",{value:options.offering});},"observedProperty":function(observedProperty){return this.createElementNSPlus("observedProperty",{value:observedProperty});},"eventTime":function(options){var node=this.createElementNSPlus("eventTime");if(options.eventTime==='latest'){this.writeNode("ogc:TM_Equals",options,node);}
+return node;},"resultModel":function(options){return this.createElementNSPlus("resultModel",{value:options.resultModel});},"responseMode":function(options){return this.createElementNSPlus("responseMode",{value:options.responseMode});}},"ogc":{"TM_Equals":function(options){var node=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},node);if(options.eventTime==='latest'){this.writeNode("gml:TimeInstant",{value:'latest'},node);}
+return node;},"PropertyName":function(options){return this.createElementNSPlus("ogc:PropertyName",{value:options.property});}},"gml":{"TimeInstant":function(options){var node=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",options,node);return node;},"timePosition":function(options){var node=this.createElementNSPlus("gml:timePosition",{value:options.value});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
+overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
+if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
+overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
+if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
+OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
+if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
+if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.For
 mat.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readNode:function(node,obj,first){return OpenLayers.Format.GML.v2.prototype.readNode.apply(this,[node,obj]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Form
 at.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var prefix=options.featurePrefix;var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(prefix?prefix+":":"")+
+options.featureType}});if(options.srsNameInQuery&&options.srsName){node.setAttribute("srsName",options.srsName);}
+if(options.featureNS){node.setAttribute("xmlns:"+prefix,options.featureNS);}
+if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("ogc:PropertyName",{property:options.propertyNames[i]},node);}}
+if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
+return node;}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear();},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
+var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
+this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
 ed){nextElement=this.getNextElement(nextIndex);}
+return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
+return returnVal;},Z_ORDER_DRAWING_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal==0){returnVal=1;}
+return returnVal;},Z_ORDER_Y_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal===0){var result=nextNode._boundsBottom-newNode._boundsBottom;returnVal=(result===0)?1:result;}
+return returnVal;}};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,xOffset:0,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(options&&(options.zIndexing||options.yOrdering)){this.indexer=new OpenLayers.ElementsIndexer(options.yOrdering);}},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){var child;var root=this.vectorRoot;if(roo
 t){while(child=root.firstChild){root.removeChild(child);}}
+root=this.textRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
+if(this.indexer){this.indexer.clear();}},setExtent:function(extent,resolutionChanged){var coordSysUnchanged=OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){coordSysUnchanged=this.featureDx===0;var rightOfDateLine,world=this.map.getMaxExtent();if(world.right>extent.left&&world.right<extent.right){rightOfDateLine=true;}else if(world.left>extent.left&&world.left<extent.right){rightOfDateLine=false;}
+if(rightOfDateLine!==this.rightOfDateLine||resolutionChanged){coordSysUnchanged=false;this.xOffset=rightOfDateLine===true?world.getWidth()/resolution:0;}
+this.rightOfDateLine=rightOfDateLine;}
+return coordSysUnchanged;},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;var rendered=true;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0,len=geometry.components.length;i<len;i++){rendered=this.drawGeometry(geometry.components[i],style,featureId)&&rendered;}
+return rendered;};rendered=false;var removeBackground=false;if(style.display!="none"){if(style.backgroundGraphic){this.redrawBackgroundNode(geometry.id,geometry,style,featureId);}else{removeBackground=true;}
+rendered=this.redrawNode(geometry.id,geometry,style,featureId);}
+if(rendered==false){var node=document.getElementById(geometry.id);if(node){if(node._style.backgroundGraphic){removeBackground=true;}
+node.parentNode.removeChild(node);}}
+if(removeBackground){var node=document.getElementById(geometry.id+this.BACKGROUND_ID_SUFFIX);if(node){node.parentNode.removeChild(node);}}
+return rendered;},redrawNode:function(id,geometry,style,featureId){style=this.applyDefaultSymbolizer(style);var node=this.nodeFactory(id,this.getNodeType(geometry,style));node._featureId=featureId;node._boundsBottom=geometry.getBounds().bottom;node._geometryClass=geometry.CLASS_NAME;node._style=style;var drawResult=this.drawGeometryNode(node,geometry,style);if(drawResult===false){return false;}
+node=drawResult.node;if(this.indexer){var insert=this.indexer.insert(node);if(insert){this.vectorRoot.insertBefore(node,insert);}else{this.vectorRoot.appendChild(node);}}else{if(node.parentNode!==this.vectorRoot){this.vectorRoot.appendChild(node);}}
+this.postDraw(node);return drawResult.complete;},redrawBackgroundNode:function(id,geometry,style,featureId){var backgroundStyle=OpenLayers.Util.extend({},style);backgroundStyle.externalGraphic=backgroundStyle.backgroundGraphic;backgroundStyle.graphicXOffset=backgroundStyle.backgroundXOffset;backgroundStyle.graphicYOffset=backgroundStyle.backgroundYOffset;backgroundStyle.graphicZIndex=backgroundStyle.backgroundGraphicZIndex;backgroundStyle.graphicWidth=backgroundStyle.backgroundWidth||backgroundStyle.graphicWidth;backgroundStyle.graphicHeight=backgroundStyle.backgroundHeight||backgroundStyle.graphicHeight;backgroundStyle.backgroundGraphic=null;backgroundStyle.backgroundXOffset=null;backgroundStyle.backgroundYOffset=null;backgroundStyle.backgroundGraphicZIndex=null;return this.redrawNode(id+this.BACKGROUND_ID_SUFFIX,geometry,backgroundStyle,null);},drawGeometryNode:function(node,geometry,style){style=style||node._style;var options={'isFilled':style.fill===undefined?true:style.
 fill,'isStroked':style.stroke===undefined?!!style.strokeWidth:style.stroke};var drawn;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.graphic===false){options.isFilled=false;options.isStroked=false;}
+drawn=this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;drawn=this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":drawn=this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":drawn=this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":drawn=this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":drawn=this.drawRectangle(node,geometry);break;default:break;}
+node._options=options;if(drawn!=false){return{node:this.setStyle(node,style,options,geometry),complete:drawn};}else{return false;}},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},removeText:function(featureId){var label=document.getElementById(featureId+this.LABEL_ID_SUFFIX);if(label){this.textRoot.removeChild(label);}},getFeatureIdFromEvent:function(evt){var target=evt.target;var useElement=target&&target.correspondingUseElement;var node=useElement?useElement:(target||evt.srcElement);var featureId=node._featureId;return featureId;},eraseGeometry:function(geometry,featureId){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.G
 eometry.MultiPolygon")||(geometry.CLASS_NAME=="OpenLayers.Geometry.Collection")){for(var i=0,len=geometry.components.length;i<len;i++){this.eraseGeometry(geometry.components[i],featureId);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){if(element.geometry){element.geometry.destroy();element.geometry=null;}
+element.parentNode.removeChild(element);if(this.indexer){this.indexer.remove(element);}
+if(element._style.backgroundGraphic){var backgroundId=geometry.id+this.BACKGROUND_ID_SUFFIX;var bElem=OpenLayers.Util.getElement(backgroundId);if(bElem&&bElem.parentNode){bElem.parentNode.removeChild(bElem);}}}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
+return node;},nodeTypeCompare:function(node,type){},createNode:function(type,id){},moveRoot:function(renderer){var root=this.root;if(renderer.root.parentNode==this.rendererRoot){root=renderer.root;}
+root.parentNode.removeChild(root);renderer.rendererRoot.appendChild(root);},getRenderLayerId:function(){return this.root.parentNode.parentNode.id;},isComplexSymbol:function(graphicName){return(graphicName!="circle")&&!!graphicName;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Renderer.symbol={"star":[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],"cross":[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],"x":[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],"square":[0,0,0,1,1,1,1,0,0,0],"triangle":[0,10,10,10,5,0,0,10]};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,getParameters:function(url){url=url||window.location.href;var parameters=OpenLayers.Util.getParameters(url);var index=url.indexOf('#');if(index>0){url='?'+url.substring(index+1,url.length);OpenLayers.Util.extend(parameters,OpenLayers.Util.getParameters(
 url));}
+return parameters;},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){var args=this.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
+if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseFloat(args.zoom);}
+this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
+this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0,len=this.layers.length;i<len;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:false,base:'',displayProjection:null,initialize:function(element,base,options){if(element!==null&&typeof element=='object'&&!OpenLayers.Util.isElement(element)){options=element;this.base=document.location.href;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.element!=null){this.element=OpenLayers.Util.getElement(this.element);}}
+else{OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;}},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
+this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if(control.CLASS_NAME==this.argParserClass.CLASS_NAME){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){this.map.addControl(new this.argParserClass({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("Permalink");this.element.href="";this.div.appendChild(this.element);}
+this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});this.updateLink();return this.div;},updateLink:function(){var separator=this.anchor?'#':'?';var href=this.base;if(href.indexOf(separator)!=-1){href=href.substring(0,href.indexOf(separator));}
+href+=separator+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element){window.location.href=href;}
+else{this.element.href=href;}},createParams:function(center,zoom,layers){center=center||this.map.getCenter();var params=OpenLayers.Util.getParameters(this.base);if(center){params.zoom=zoom||this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
+params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;layers=layers||this.map.layers;params.layers='';for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}}
+return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.getServerResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.getServerZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
+return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Protocol.AgsFeatureAccess=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS);var cls=OpenLayers.Protocol.AgsFeatureAccess["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported AgsFeatureAccess version: "+options.version;}
+return new cls(options);};OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS={"version":"2.0"};OpenLayers.Format.AgsJsAdapter=(function(){var _AGS_UNITS={'UNIT_METER':9001,'UNIT_FOOT':9002,'UNIT_KILOMETER':9036,'UNIT_DEGREE':9102};var _AGS_SPATIALRELATIONSHIP={'INTERSECTS':"esriSpatialRelIntersects",'CONTAINS':"esriSpatialRelContains",'CROSSES':"esriSpatialRelCrosses",'ENVELOPE_INTERSECTS':"esriSpatialRelEnvelopeIntersects",'INDEX_INTERSECTS':"esriSpatialRelIndexIntersects",'OVERLAPS':"esriSpatialRelOverlaps",'TOUCHES':"esriSpatialRelTouches",'WITHIN':"esriSpatialRelWithin"};var _AGS_GEOMETRY_SPATIALRELATIONSHIP={'CROSS':"esriGeometryRelationCross",'DISJOINT':"esriGeometryRelationDisjoint",'IN':"esriGeometryRelationIn",'INTERIOR_INTERSECTION':"esriGeometryRelationInteriorIntersection",'INTERSECTION':"esriGeometryRelationIntersection",'LINE_COINCIDENCE':"esriGeometryRelationLineCoincidence",'LINE_TOUCHE':"esriGeometryRelationLineTouch",'OVERLAP':"esriGeometryRelationOverlap",'POIN
 T_TOUCH':"esriGeometryRelationPointTouch",'RELATION':"esriGeometryRelationRelation",'TOUCH':"esriGeometryRelationTouch",'WITHIN':"esriGeometryRelationWithin"};var _UNMATCH_AGS_WKID={'900913':"102113"};var _UNMATCH_OL_WKID={'102113':"900913"};var _OL_GEOMETRY_MAP={'OpenLayers.Geometry.Point':"point",'OpenLayers.Geometry.MultiLineString':"polyline",'OpenLayers.Geometry.LineString':"polyline",'OpenLayers.Geometry.MultiPolygon':"polygon",'OpenLayers.Geometry.Polygon':"polygon",'OpenLayers.Bounds':"extent"};var _AGS_OL_RENDERER_PARSER_MAP={'esri.renderer.SimpleRenderer':"SimpleRenderer",'esri.renderer.ClassBreaksRenderer':"ClassBreaksRenderer",'esri.renderer.UniqueValueRenderer':"UniqueValueRenderer"};var _OL_AGS_STYLE_MAP={'OpenLayers.Geometry.Point':"SimpleMarkerSymbol",'OpenLayers.Geometry.MultiLineString':"SimpleLineSymbol",'OpenLayers.Geometry.Polygon':"SimpleFillSymbol",'OpenLayers.Bounds':"SimpleFillSymbol",'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"P
 ictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimleFillSymbol",'picturefillsymbol':"PictureFillSymbol"};var _AGS_OL_SYMBOL_PARSER_MAP={'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"PictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimpleFillSymbol",'picturefillsymbol':"PictureFillSymbol"};var _OL_AGS_SIMPLE_MARKERSYMBOL_MAP={'circle':"STYLE_CIRCLE",'cross':"STYLE_CROSS",'diamond':"STYLE_DIAMOND",'square':"STYLE_SQUARE",'x':"STYLE_X"};var _AGS_OL_SIMPLE_MARKERSYMBOL_MAP={'STYLE_CIRCLE':"circle",'STYLE_CROSS':"cross",'STYLE_DIAMOND':"diamond",'STYLE_SQUARE':"square",'STYLE_X':"x"};var _OL_AGS_SIMPLE_LINESYMBOL_MAP={'dash':"STYLE_DASH",'dashdot':"STYLE_DASHDOT",'longdashdot':"STYLE_DASHDOTDOT",'dot':"STYLE_DOT",'solid':"STYLE_NULL",'solid':"STYLE_SOLID"};var _AGS_OL_SIMPLE_LINESYMBOL_MAP={'STYLE_DASH'
 :"dash",'STYLE_DASHDOT':"dashdot",'STYLE_DASHDOTDOT':"longdashdot",'STYLE_DOT':"dot",'STYLE_NULL':"solid",'STYLE_SOLID':"solid"};var _OL_AGS_NAUTURN_MAP={'ALLOW_BACKTRACK':"allow_backtrack",'AT_DEAD_ENDS_ONLY':"at_dead_ends_only",'NO_BACKTRACK':"no_backtrack"};var _AGS_OL_NAUTURN_MAP={'allow_backtrack':"ALLOW_BACKTRACK",'at_dead_ends_only':"AT_DEAD_ENDS_ONLY",'no_backtrack':"NO_BACKTRACK"};var _OL_AGS_NAOUTPUTLINE_MAP={'NONE':"none",'STRAIGHT':"straight",'TRUE_SHAPE':"true_shape",'TRUE_SHAPE_WITH_MEASURE':"true_shape_with_measure"};var _AGS_OL_NAOUTPUTLINE_MAP={'none':"NONE",'straight':"STRAIGHT",'true_shape':"TRUE_SHAPE",'true_shape_with_measure':"TRUE_SHAPE_WITH_MEASURE"};var _OL_ROUTETASK_STYLE={'route':{strokeColor:"#00FF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid"},'stop':{fillColor:"#FFFF00",fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10},'barrier':{fillCo
 lor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10}};var _isDefined=OpenLayers.Util.AgsUtil.isDefined;var _isNumber=OpenLayers.Util.AgsUtil.isNumber;var _isBoolean=OpenLayers.Util.AgsUtil.isBoolean;var _isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;var _isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;var _isSameOLPoint=OpenLayers.Util.AgsUtil.isSameOLPoint;function _toAgsWkid(olWkid){if(_isDefined(_UNMATCH_AGS_WKID[olWkid])){return _UNMATCH_AGS_WKID[olWkid];}else{return olWkid;}};function _toOlWkid(agsWkid){if(_isDefined(_UNMATCH_OL_WKID[agsWkid])){return _UNMATCH_OL_WKID[agsWkid];}else{return agsWkid;}};function __bindFunction(func,scope){if(window.dojo!==undefined){return dojo.hitch(scope,func);}else{OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(func,scope);}}
+return function(config){this.config={'defaultEncodeWkid':"EPSG:900913"};this.parseAgsGeometry={"point":function(agsPoint){var olPoint=null;if(agsPoint instanceof esri.geometry.Point&&_isNumber(agsPoint.x)&&_isNumber(agsPoint.y)){olPoint=new OpenLayers.Geometry.Point(agsPoint.x,agsPoint.y);return olPoint;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point...");throw"...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point..."+agsPoint;}},"coordinate":function(agsCoordinate){var olCoordinate=null;if(agsCoordinate instanceof Array&&_isNumber(agsCoordinate[0])&&_isNumber(agsCoordinate[1])){olCoordinate=new OpenLayers.Geometry.Point(agsCoordinate[0],agsCoordinate[1]);return olCoordinate;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]...");throw"...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]..."+agsCoordinate;}},"path":function(agsPointArray){var olLineString
 =null;if(agsPointArray instanceof Array){var olPoints=[];for(var i=0;i<agsPointArray.length;i++){var olPoint=null;try{olPoint=this.parseAgsGeometry['coordinate'].apply(this,[agsPointArray[i]]);olPoints.push(olPoint);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+olLineString=new OpenLayers.Geometry.LineString(olPoints);return olLineString;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.path...invalid array of coordinates...");throw"...AgsAdapter.parseAgsGeometry.path...invalid array of array [x,y]..."+agsPointArray;}},"ring":function(agsPointArray){var beginPoint=agsPointArray[0];var endPoint=agsPointArray[agsPointArray.length-1];if(beginPoint[0]!=endPoint[0]||beginPoint[1]!=endPoint[1]){OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.ring...not a closed ring...");throw"...AgsAdapter.parseAgsGeometry.ring...not a closed ring..."+agsPointArray;}
+var olLinearRing=null;var olLineString=null;try{olLineString=this.parseAgsGeometry['path'].apply(this,[agsPointArray]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+olLinearRing=new OpenLayers.Geometry.LinearRing(olLineString.components);return olLinearRing;},"polyline":function(agsPolyline){var olMultiLineString=null;if(_isDefined(agsPolyline.paths)&&agsPolyline.paths instanceof Array){var paths=agsPolyline.paths;var lineStrings=[];for(var i=0;i<paths.length;i++){try{var lineString=this.parseAgsGeometry['path'].apply(this,[paths[i]]);lineStrings.push(lineString);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+olMultiLineString=new OpenLayers.Geometry.MultiLineString(lineStrings);return olMultiLineString;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline...");throw"...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline..."+agsPolyline;}},"polygon":function(agsPolygon){var olPolygon=null;if(_isDefined(agsPolygon.rings)&&agsPolygon.rings instanceof Array){var rings=agsPolygon.rings;var linearRings=[];for(var i=0;i<rings.length;i++){try{var linearRing=this.parseAgsGeometry['ring'].apply(this,[rings[i]]);linearRings.push(linearRing);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+olPolygon=new OpenLayers.Geometry.Polygon(linearRings);return olPolygon;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon...");throw"...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon..."+agsPolygon;}},"multipoint":function(agsMultipoint){var olPoints=[];if(_isDefined(agsMultipoint.points)&&agsMultipoint.points instanceof Array){var agsPoints=agsMultipoint.points;for(var i=0;i<agsPoints.length;i++){try{var olPoint=this.parseAgsGeometry['coordinate'].apply(this,[agsPoints[i]]);olPoints.push(olPoint);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olPoints;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint...");throw"...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint..."+agsPolygon;}},"extent":function(agsExtent){var olBounds=null;if(_isDefined(agsExtent.xmin)&&_isDefined(agsExtent.xmax)&&_isDefined(agsExtent.ymin)&&_isDefined(agsExtent.ymax)){olBounds=new OpenLayers.Bounds(agsExtent.xmin,agsExtent.ymin,agsExtent.xmax,agsExtent.ymax);return olBounds;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent...");throw"...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent..."+agsExtent;}}};this.parseAgsSymbol={"SimpleMarkerSymbol":function(agsSimpleMarkerSymbol){if(_isDefined(agsSimpleMarkerSymbol)&&agsSimpleMarkerSymbol instanceof esri.symbol.SimpleMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.strokeColor=agsSimpleMarkerSymbol.outlin
 e.color.toHex()||pointSymbolizer.strokeColor;pointSymbolizer.strokeWidth=agsSimpleMarkerSymbol.outline.width;pointSymbolizer.strokeOpacity=agsSimpleMarkerSymbol.outline.color.toRgba()[3]||pointSymbolizer.strokeOpacity;pointSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleMarkerSymbol.outline.style]||pointSymbolizer.strokeDashstyle;pointSymbolizer.fillColor=agsSimpleMarkerSymbol.color.toHex()||pointSymbolizer.fillColor;pointSymbolizer.fillOpacity=agsSimpleMarkerSymbol.color.toRgba()[3]||pointSymbolizer.fillOpacity;pointSymbolizer.pointRadius=agsSimpleMarkerSymbol.size||pointSymbolizer.pointRadius;pointSymbolizer.graphicName=_AGS_OL_SIMPLE_MARKERSYMBOL_MAP[agsSimpleMarkerSymbol.style]||pointSymbolizer.graphicName;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSi
 mpleMarkerSymbol;}},"PictureMarkerSymbol":function(agsPictureMarkerSymbol){if(_isDefined(agsPictureMarkerSymbol)&&agsPictureMarkerSymbol instanceof esri.symbol.PictureMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.pointRadius=agsPictureMarkerSymbol.size/2||pointSymbolizer.pointRadius;pointSymbolizer.externalGraphic=agsPictureMarkerSymbol.url||pointSymbolizer.externalGraphic;pointSymbolizer.graphicWidth=Math.floor(agsPictureMarkerSymbol.width)||pointSymbolizer.graphicWidth;pointSymbolizer.graphicHeight=Math.floor(agsPictureMarkerSymbol.height)||pointSymbolizer.graphicHeight;pointSymbolizer.graphicXOffset=agsPictureMarkerSymbol.xoffset||pointSymbolizer.graphicXOffset;pointSymbolizer.graphicYOffset=agsPictureMarkerSymbol.yoffset||pointSymbolizer.graphicYOffset;pointSymbolizer.graphicOpacity=1;pointSymbolizer.rotation=agsPictureMarkerSymbol.angle;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarke
 rSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSimpleMarkerSymbol;}},"SimpleLineSymbol":function(agsSimpleLineSymbol){if(_isDefined(agsSimpleLineSymbol)&&agsSimpleLineSymbol instanceof esri.symbol.SimpleLineSymbol){var lineSymbolizer=new OpenLayers.Symbolizer.Line({});lineSymbolizer.strokeColor=agsSimpleLineSymbol.color.toHex()||lineSymbolizer.strokeColor;lineSymbolizer.strokeWidth=Math.floor(agsSimpleLineSymbol.width);lineSymbolizer.strokeOpacity=agsSimpleLineSymbol.color.toRgba()[3]||lineSymbolizer.strokeOpacity;lineSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleLineSymbol.style]||lineSymbolizer.strokeDashstyle;return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol..."+agsSi
 mpleLineSymbol;}},"CartographicLineSymbol":function(agsCartographicLineSymbol){if(_isDefined(agsCartographicLineSymbol)&&agsCartographicLineSymbol instanceof esri.symbol.CartographicLineSymbol){var lineSymbolizer=this.parseAgsSymbol['SimpleLineSymbol'].apply(this,[agsCartographicLineSymbol]);return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol..."+agsCartographicLineSymbol;}},"SimpleFillSymbol":function(agsSimpleFillSymbol){if(_isDefined(agsSimpleFillSymbol)&&agsSimpleFillSymbol instanceof esri.symbol.SimpleFillSymbol){var polygonSymbolizer=new OpenLayers.Symbolizer.Polygon({});polygonSymbolizer.strokeColor=agsSimpleFillSymbol.outline.color.toHex()||polygonSymbolizer.strokeColor;polygonSymbolizer.strokeWidth=Math.floor(agsSimpleFillSymbol.outline.width);polygonSymbolizer.str
 okeOpacity=agsSimpleFillSymbol.outline.color.toRgba()[3]||polygonSymbolizer.strokeOpacity;polygonSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleFillSymbol.outline.style]||polygonSymbolizer.strokeDashstyle;polygonSymbolizer.fillColor=agsSimpleFillSymbol.color.toHex()||polygonSymbolizer.fillColor;polygonSymbolizer.fillOpacity=agsSimpleFillSymbol.color.toRgba()[3]||polygonSymbolizer.fillOpacity;return polygonSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol..."+agsSimpleFillSymbol;}},"PictureFillSymbol":function(agsPictureFillSymbol){if(_isDefined(agsPictureFillSymbol)&&agsPictureFillSymbol instanceof esri.symbol.PictureFillSymbol){var polygonSymbolizer=this.parseAgsSymbol['SimpleFillSymbol'].apply(this,[agsPictureFillSymbol]);return polygonSymbolizer;}else{OpenLayers.Console.error("...AgsA
 dapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol..."+agsPictureFillSymbol;}},"TextSymbol":function(agsTextSymbol){if(_isDefined(agsTextSymbol)&&agsTextSymbol instanceof esri.symbol.TextSymbol){var textSymbolizer=new OpenLayers.Symbolizer.Text({});textSymbolizer.label=agsTextSymbol.text||textSymbolizer.label;textSymbolizer.fontFamily=agsTextSymbol.font.family||textSymbolizer.fontFamily;textSymbolizer.fontSize=agsTextSymbol.font.size||textSymbolizer.fontSize;textSymbolizer.fontWeight=agsTextSymbol.font.weight||textSymbolizer.fontWeight;textSymbolizer.fontStyle=agsTextSymbol.font.style||textSymbolizer.fontStyle;textSymbolizer.color=agsTextSymbol.color.toHex()||textSymbolizer.color;return textSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol...");throw"...AgsAdapter.parseAgsSymbol.TextSymbo
 l...missing or invalid TextSymbol..."+agsTextSymbol;}}};this.parseAgsRenderer={"SimpleRenderer":function(agsSimpleRenderer){if(_isDefined(agsSimpleRenderer)&&agsSimpleRenderer instanceof esri.renderer.SimpleRenderer){var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[agsSimpleRenderer.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[agsSimpleRenderer.symbol]);var olRule=new OpenLayers.Rule({symbolizers:[olSymbolizer]});olRule.name=agsSimpleRenderer.label;olRule.title=agsSimpleRenderer.label;olRule.description=agsSimpleRenderer.description;var olStyle=new OpenLayers.Style(null,{rules:[olRule]});olStyle.name=agsSimpleRenderer.label;olStyle.title=agsSimpleRenderer.label;olStyle.description="An OpenLayers Style converted from an esri SimpleRenderer";return olStyle;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer...");throw"...AgsAdapter.parseAgsRenderer.SimpleRenderer.
 ..missing or invalid esri.renderer.SimpleRenderer..."+agsSimpleRenderer;}},"ClassBreaksRenderer":function(agsClassBreaksRenderer){if(_isDefined(agsClassBreaksRenderer)&&agsClassBreaksRenderer instanceof esri.renderer.ClassBreaksRenderer){var filterProperty=agsClassBreaksRenderer.attributeField;if(agsClassBreaksRenderer.infos!=null&&agsClassBreaksRenderer.infos.length>0){var olRules=[];var agsDefaultSymbol=agsClassBreaksRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolizer=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultRule=new OpenLayers.Rule({symbolizers:[olDefaultSymbolizer],elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
+for(var i=0;i<agsClassBreaksRenderer.infos.length;i++){var info=agsClassBreaksRenderer.infos[i];var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN,property:filterProperty,lowerBoundary:info.minValue,upperBoundary:info.maxValue});var olRule=new OpenLayers.Rule({symbolizers:[olSymbolizer],filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;olRules.push(olRule);}
+var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name=agsClassBreaksRenderer.label;olStyle.title=agsClassBreaksRenderer.label;olStyle.description="An OpenLayers Style converted from an esri ClassBreaksRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer...");throw"...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer..."+agsClassBreaksRenderer;}},"UniqueValueRenderer":function(agsUniqueValueRenderer){if(_isDefined(agsUniqueValueRenderer)&&agsUniqueValueRenderer instanceof esri.renderer.UniqueValueRenderer){var filterProperty=agsUniqueValueRenderer.attributeField;if(agsUniqueValueRenderer.infos!=null&&agsUniqueValueRenderer.infos.length>0){var olRules=[];var agsDefaultSymbol=agsUniqueValueRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolize
 r=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultSymbolizers=[];olDefaultSymbolizers.push(olDefaultSymbolizer);var olDefaultRule=new OpenLayers.Rule({symbolizers:olDefaultSymbolizers,elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
+for(var i=0;i<agsUniqueValueRenderer.infos.length;i++){var info=agsUniqueValueRenderer.infos[i];var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:filterProperty,value:info.value});var olSymbolizers=[];olSymbolizers.push(olSymbolizer);var olRule=new OpenLayers.Rule({symbolizers:olSymbolizers,filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;olRules.push(olRule);}
+var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name=agsUniqueValueRenderer.label;olStyle.title=agsUniqueValueRenderer.label;olStyle.description="An OpenLayers Style converted from an esri UniqueValueRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer...");throw"...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer..."+agsUniqueValueRenderer;}},"TemporalRenderer":function(agsTemporalRenderer){}};this.parseAgsFeatureTemplate=function(agsFeatureTemplate){if(_isDefined(agsFeatureTemplate)&&agsFeatureTemplate.declaredClass=="esri.layers.FeatureTemplate"){var olFeatureTemplate={};if(agsFeatureTemplate.name!=null){olFeatureTemplate.name=agsFeatureTemplate.name;}
+if(agsFeatureTemplate.description!=null){olFeatureTemplate.description=agsFeatureTemplate.description;}
+olFeatureTemplate.prototype=this.parseNoGeometryAgsGraphic.apply(this,[agsFeatureTemplate.prototype]);return olFeatureTemplate;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate...");throw"...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate..."+agsFeatureTemplate;}};this.parseAgsFeatureTemplates=function(agsFeatureTemplates){var olFeatureTemplates=[];if(_isDefined(agsFeatureTemplates)&&agsFeatureTemplates instanceof Array){for(var i=0;i<agsFeatureTemplates.length;i++){try{var olFeatureTemplate=this.parseAgsFeatureTemplate.apply(this,[agsFeatureTemplates[i]]);olFeatureTemplates.push(olFeatureTemplate);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatureTemplates;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array...");throw"...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array..."+agsFeatureTemplates;}};this.parseAgsFeatureType=function(agsFeatureType){if(_isDefined(agsFeatureType)&&agsFeatureType.declaredClass=="esri.layers.FeatureType"){var olFeatureType={};if(agsFeatureType.name!=null){olFeatureType.name=agsFeatureType.name;}
+if(agsFeatureType.id!=null){olFeatureType.id=agsFeatureType.id;}
+olFeatureType.templates=this.parseAgsFeatureTemplates.apply(this,[agsFeatureType.templates]);return olFeatureType;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureType...missing or invalid esri.layers.FeatureType...");throw"...AgsAdapter.parseAgsFeatureType...missing or invalid esri.layers.FeatureType..."+agsFeatureType;}};this.parseAgsFeatureTypes=function(agsFeatureTypes){var olFeatureTypes=[];if(_isDefined(agsFeatureTypes)&&agsFeatureTypes instanceof Array){for(var i=0;i<agsFeatureTypes.length;i++){try{var olFeatureType=this.parseAgsFeatureType.apply(this,[agsFeatureTypes[i]]);olFeatureTypes.push(olFeatureType);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatureTypes;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTypes...invalid esri.layers.FeatureType array...");throw"...AgsAdapter.parseAgsFeatureTypes...invalid esri.layers.FeatureType array..."+agsFeatureTypes;}};this.parseAgsSpatialReference=function(agsSpatialReference){var olGeometrySpatialReference=null;if(_isDefined(agsSpatialReference.wkid)&&agsSpatialReference instanceof esri.SpatialReference){var olWkid=_toOlWkid(agsSpatialReference.wkid);olGeometrySpatialReference="EPSG:"+olWkid;return olGeometrySpatialReference;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSpatialReference...missing or invalid esri.SpatialReference...");throw"...AgsAdapter.parseAgsSpatialReference...missing or invalid esri.SpatialReference..."+agsSpatialReference;}};this.parseAgsGraphic=function(agsGraphic){var olFeature=null;var geometryType=null;var geometry=null;var style=null;if(_isDefined(agsGraphic.geometry.type)){geometryType=agsGraphic.geometry.type;}else{Op
 enLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic..."+agsGraphic;}
+try{geometry=this.parseAgsGeometry[geometryType].apply(this,[agsGraphic.geometry]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+if(_isDefined(geometry)){var attributes=agsGraphic.attributes;if(_isDefined(agsGraphic.infoTemplate)){attributes['infoTemplateTitle']=agsGraphic.infoTemplate.title?agsGraphic.infoTemplate.title:"";attributes['infoTemplateContent']=agsGraphic.infoTemplate.content?agsGraphic.infoTemplate.content:"";}
+if(_isDefined(agsGraphic.symbol)){try{if(_isDefined(agsGraphic.symbol.type)){}else{}}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+olFeature=new OpenLayers.Feature.Vector(geometry,attributes,style);return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.geometry...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.geometry..."+agsGraphic;}};this.parseNoGeometryAgsGraphic=function(agsGraphic){var olFeature=null;var style=null;if(_isDefined(agsGraphic.attributes)){var attributes=agsGraphic.attributes;if(_isDefined(agsGraphic.infoTemplate)){attributes['infoTemplateTitle']=agsGraphic.infoTemplate.title?agsGraphic.infoTemplate.title:"";attributes['infoTemplateContent']=agsGraphic.infoTemplate.content?agsGraphic.infoTemplate.content:"";}
+olFeature=new OpenLayers.Feature.Vector(null,attributes,style);return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.attributes...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic.attributes..."+agsGraphic;}};this.parseAgsGraphics=function(agsGraphics){var olFeatures=[];if(_isDefined(agsGraphics)&&agsGraphics instanceof Array){for(var i=0;i<agsGraphics.length;i++){try{var olFeature=this.parseAgsGraphic.apply(this,[agsGraphics[i]]);olFeatures.push(olFeature);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatures;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGraphics...invalid esri.Graphic array...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic array..."+agsGraphics;}};this.parseNoGeometryAgsGraphics=function(agsGraphics){var olFeatures=[];if(_isDefined(agsGraphics)&&agsGraphics instanceof Array){for(var i=0;i<agsGraphics.length;i++){try{var olFeature=this.parseNoGemetryAgsGraphic.apply(this,[agsGraphics[i]]);olFeatures.push(olFeature);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatures;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGraphics...invalid esri.Graphic array...");throw"...AgsAdapter.parseAgsGraphic...invalid esri.Graphic array..."+agsGraphics;}};this.parseAgsResults={'identifyResult':function(agsIdentifyResult){var olFeature=null;if(_isDefined(agsIdentifyResult.feature)){try{olFeature=this.parseAgsGraphic.apply(this,[agsIdentifyResult.feature]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+if(_isDefined(agsIdentifyResult.displayFieldName)){olFeature.attributes['displayFieldName']=agsIdentifyResult.displayFieldName;}
+if(_isNumber(agsIdentifyResult.layerId)&&agsIdentifyResult.layerId>=0){olFeature.attributes['layerId']=agsIdentifyResult.layerId;}
+if(_isDefined(agsIdentifyResult.layerName)){olFeature.attributes['layerName']=agsIdentifyResult.layerName;}
+return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.identifyResult...parses esri.tasks.IdentifyResult...missing or invalid feature in IdentifyResult...");throw"...AgsAdapter.parseAgsResults.identifyResult...parses esri.tasks.IdentifyResult...missing or invalid feature in IdentifyResult..."+agsIdentifyResult;}},'identifyResults':function(agsIdentifyResults){var olFeatures=[];if(_isDefined(agsIdentifyResults)&&agsIdentifyResults instanceof Array){for(var i=0;i<agsIdentifyResults.length;i++){try{var olFeature=this.parseAgsResults['identifyResult'].apply(this,[agsIdentifyResults[i]]);olFeatures.push(olFeature);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatures;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.identifyResults...parses array esri.tasks.IdentifyResult...missing or invalid array...");throw"...AgsAdapter.parseAgsResults.identifyResults...parses array esri.tasks.IdentifyResult...missing or invalid array..."+agsIdentifyResults;}},'addressCandidate':function(agsAddressCandidate){var olFeature=null;var geometry=null;var attributes={};if(_isDefined(agsAddressCandidate.location)){try{geometry=this.parseAgsGeometry['point'].apply(this,[agsAddressCandidate.location]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+if(_isDefined(agsAddressCandidate.address)){if(typeof agsAddressCandidate.address==="string"){attributes['address']=agsAddressCandidate.address;}else{for(key in agsAddressCandidate.address){if(typeof agsAddressCandidate.address[key]==="string"){attributes['addr_'+key]=agsAddressCandidate.address[key];}}}}
+if(_isDefined(agsAddressCandidate.attributes)){for(key in agsAddressCandidate.attributes){if(typeof agsAddressCandidate.attributes[key]==="string"){attributes['attr_'+key]=agsAddressCandidate.attributes[key];}}}
+if(_isDefined(agsAddressCandidate.score)){attributes['score']=agsAddressCandidate.score;}
+olFeature=new OpenLayers.Feature.Vector(geometry,attributes);return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.addressCandidate...parses an agsAddressCandidates...missing or invalid 'location'...");throw"...AgsAdapter.parseAgsResults.addressCandidate...parses an agsAddressCandidates...missing or invalid 'location'..."+agsAddressCandidate;}},'addressCandidates':function(agsAddressCandidates){var olFeatures=[];if(_isDefined(agsAddressCandidates)&&agsAddressCandidates instanceof Array){for(var i=0;i<agsAddressCandidates.length;i++){try{var olFeature=this.parseAgsResults['addressCandidate'].apply(this,[agsAddressCandidates[i]]);olFeatures.push(olFeature);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatures;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.addressCandidates...parses array agsAddressCandidates...missing or invalid array...");throw"...AgsAdapter.parseAgsResults.addressCandidates...parses array agsAddressCandidates...missing or invalid array..."+agsAddressCandidates;}},'findResult':function(agsFindResult){var olFeature=null;if(_isDefined(agsFindResult.feature)){var agsGraphic=agsFindResult.feature;try{olFeature=this.parseAgsGraphic.apply(this,[agsGraphic]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+if(_isDefined(agsFindResult.displayFieldName)){olFeature.attributes['displayFieldName']=agsFindResult.displayFieldName;}
+if(_isDefined(agsFindResult.foundFieldName)){olFeature.attributes['foundFieldName']=agsFindResult.foundFieldName;}
+if(_isNumber(agsFindResult.layerId)&&agsFindResult.layerId>=0){olFeature.attributes['layerId']=agsFindResult.layerId;}
+if(_isDefined(agsFindResult.layerName)){olFeature.attributes['layerName']=agsFindResult.layerName;}
+return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.findResult...parse esri.tasks.FindResult...missing or invalid FindResult...");throw"...AgsAdapter.parseAgsResults.findResult...parse esri.tasks.FindResult...missing or invalid FindResult..."+agsFindResult;}},'findResults':function(agsFindResults){var olFeatures=[];if(_isDefined(agsFindResults)&&agsFindResults instanceof Array){for(var i=0;i<agsFindResults.length;i++){try{var olFeature=this.parseAgsResults['findResult'].apply(this,[agsFindResults[i]]);olFeatures.push(olFeature);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return olFeatures;}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.findResults...parse array of agsFindResults...missing or invalid array...");throw"...AgsAdapter.parseAgsResults.findResults...parse array of agsFindResults...missing or invalid array..."+agsFindResults}},'featureSet':function(agsFeatureSet){var olFeatures=[];if(_isDefined(agsFeatureSet.features)){try{var agsGraphics=agsFeatureSet.features;olFeatures=this.parseAgsGraphics.apply(this,[agsGraphics]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+return olFeatures;}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.featureSet...parse esri.tasks.FeatureSet...missing or invalid FeatureSet...");throw"...AgsAdapter.parseAgsResults.featureSet...parse esri.tasks.FeatureSet...missing or invalid FeatureSet..."+agsFeatureSet;}},'areasAndLengths':function(agsAreasAndLengths){if(_isDefined(agsAreasAndLengths.areas)||_isDefined(agsAreasAndLengths.lengths)){return agsAreasAndLengths;}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.areasAndLengths...parse esri areasAndLengths...missing or invalid areasAndLengths...");throw"...AgsAdapter.parseAgsResults.areasAndLengths...parse esri areasAndLengths...missing or invalid areasAndLengths..."+agsAreasAndLengths;}},'relation':function(agsRelation){var olRelation={};if(_isDefined(agsRelation.geometry1Index)&&_isDefined(agsRelation.geometry2Index)){olRelation.geometry1Index=agsRelation.geometry1Index;olRelation.geometry2Index=agsRelation.geometry2Index;}else{OpenLayers
 .Console.warn("...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result...");throw"...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."+agsRelation;}
+if(_isDefined(agsRelation.graphic1)&&_isDefined(agsRelation.graphic2)){try{olRelation.feature1=this.parseAgsGraphic.apply(this,[agsRelation.graphic1]);;olRelation.feature2=this.parseAgsGraphic.apply(this,[agsRelation.graphic2]);;}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result...");throw"...AgsAdapter.parseAgsResults.relation...parse esri relation result...missing or invalid relation result..."+agsRelation;}
+return olRelation;},'relations':function(agsRelations){var olRelations=[];if(_isDefined(agsRelations)&&agsRelations instanceof Array){try{for(var i=0;i<agsRelations.length;i++){var olRelation=this.parseAgsResults['relation'].apply(this,[agsRelations[i]]);olRelations.push(olRelation);}}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relationw...parse esri relation result array...missing or invalid relation result array...");throw"...AgsAdapter.parseAgsResults.relationw...parse esri relation result array...missing or invalid relation result array..."+agsRelations;}
+return olRelations;},'directionsFeatureSet':function(agsDirectionsFeatureSet){var olFeature=null;if(_isDefined(agsDirectionsFeatureSet.mergedGeometry)){var agsPolyline=agsDirectionsFeatureSet.mergedGeometry;var agsExtent=agsDirectionsFeatureSet.extent;var olMultiLineString=this.parseAgsGeometry['polyline'].apply(this,[agsPolyline]);var attributes={};if(agsExtent!=null){var olExtent=this.parseAgsGeometry['extent'].apply(this,[agsExtent]);attributes['extent']=olExtent;}
+attributes['routeId']=agsDirectionsFeatureSet.routeId||"";attributes['routeName']=agsDirectionsFeatureSet.routeName||"";attributes['totalDriveTime']=agsDirectionsFeatureSet.totalDriveTime||0;attributes['totalLength']=agsDirectionsFeatureSet.totalLength||0;attributes['totalTime']=agsDirectionsFeatureSet.totalTime||0;olFeature=new OpenLayers.Feature.Vector(olMultiLineString,attributes);return olFeature;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsResults.directionsFeatureSet...parse esri.tasks.DirectionFeatureSet...missing or invalid FindResult...");throw"...AgsAdapter.parseAgsResults.directionsFeatureSet...parse esri.tasks.DirectionFeatureSet...missing or invalid DirectionFeatureSet..."+agsDirectionFeatureSet;}},'routeResult':function(agsRouteResult){var olRouteResult={};try{if(_isDefined(agsRouteResult.directions)){olRouteResult.directions=this.parseAgsResults['directionsFeatureSet'].apply(this,[agsRouteResult.directions]);}
+if(_isDefined(agsRouteResult.route)){olRouteResult.route=this.parseAgsGraphic.apply(this,[agsRouteResult.route]);}
+if(_isDefined(agsRouteResult.routeName)){olRouteResult.routeName=agsRouteResult.routeName;}
+if(_isDefined(agsRouteResult.stops)){olRouteResult.stops=this.parseAgsGraphics.apply(this,[agsRouteResult.stops]);}
+return olRouteResult;}catch(e){OpenLayers.Console.error(e.toString());throw e;}},'routeResults':function(agsRouteResults,args_list){var olRouteResults=[];if(_isDefined(agsRouteResults)&&agsRouteResults instanceof Array){try{for(var i=0;i<agsRouteResults.length;i++){var olRouteResult=this.parseAgsResults['routeResult'].apply(this,[agsRouteResults[i]]);if(_isDefined(olRouteResult.route)&&olRouteResult.route instanceof OpenLayers.Feature.Vector){olRouteResult.route.style=_OL_ROUTETASK_STYLE['route'];olRouteResults.push(olRouteResult.route);}else if(_isDefined(olRouteResult.directions)&&olRouteResult.directions instanceof OpenLayers.Feature.Vector){olRouteResult.directions.style=_OL_ROUTETASK_STYLE['route'];olRouteResults.push(olRouteResult.directions);}
+if(_isDefined(olRouteResult.stops)&&olRouteResult.stops instanceof Array){for(var i=0;i<olRouteResult.stops.length;i++){if(olRouteResult.stops[i]instanceof OpenLayers.Feature.Vector){olRouteResult.stops[i].style=_OL_ROUTETASK_STYLE['stop'];}
+olRouteResults.push(olRouteResult.stops[i]);OpenLayers.Console.debug("...stop in route results has been added...");}}}
+if(_isDefined(args_list[1])&&args_list[1]instanceof Array){var barriers=args_list[1];var olBarriers=this.parseAgsGraphics.apply(this,[barriers]);for(var i=0;i<olBarriers.length;i++){if(olBarriers[i]instanceof OpenLayers.Feature.Vector){olBarriers[i].style=_OL_ROUTETASK_STYLE['barrier'];}
+olRouteResults.push(olBarriers[i]);}}}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{OpenLayers.Console.warn("...AgsAdapter.parseAgsResults.relations...parse esri route results array...missing or invalid route results array...");throw"...AgsAdapter.parseAgsResults.relations...parse esri route results array...missing or invalid route results array..."+agsRouteResults;}
+return olRouteResults;}};this.encodeAgsUnit=function(olUnit){if(_isDefined(olUnit)){if(_isDefined(_AGS_UNITS[olUnit])){return _AGS_UNITS[olUnit];}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsUnit...encode ags unit...unit string not supported...");throw"...AgsAdapter.encodeAgsUnit...encode ags unit...unit string not supported..."+olUnit;}}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsUnit...encode ags unit...missing or invalid unit string...");throw"...AgsAdapter.encodeAgsUnit...encode ags unit...missing or invalid unit string..."+olUnit;}};this.encodeAgsSpatialReference=function(olSpatialReference){if(!_isDefined(olSpatialReference)){OpenLayers.Console.error("...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...missing or invalid input spatial reference...");throw"...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...missing or invalid input spatial reference..."+olSpatialReference;}
+var namespace=olSpatialReference.split(":")[0];var identifier=olSpatialReference.split(":")[1];if(namespace==="EPSG"&&_isDefined(identifier)){var agsSpatialReference={};agsSpatialReference['wkid']=parseInt(_toAgsWkid(identifier));return new esri.SpatialReference(agsSpatialReference);}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...invalid spatial reference in EPSG:XXXXX syntax...");throw"...AgsAdapter.encodeAgsSpatialReference...encode ags spatial reference...invalid spatial reference in EPSG:XXXXX syntax..."+olSpatialReference;}};this.encodeAgsGeometry={'point':function(olPoint,olSpatialReference){if(_isDefined(olPoint)&&olPoint instanceof OpenLayers.Geometry.Point){var agsPoint=null;var agsSpatialReference=null;try{if(_isDefined(olSpatialReference)){agsSpatialReference=this.encodeAgsSpatialReference(olSpatialReference);}else{agsSpatialReference=this.encodeAgsSpatialReference(this.config['defaultEncodeWkid']);}}catch(e
+agsPoint=new esri.geometry.Point(olPoint.x,olPoint.y,agsSpatialReference);return agsPoint;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.point...encode esri.geometry.Point...missing or invalid OpenLayers.Geometry.Point...");throw"...AgsAdapter.encodeAgsGeometry.point...encode esri.geometry.Point...missing or invalid OpenLayers.Geometry.Point..."+olPoint;}},'coordinate':function(olPoint){if(_isDefined(olPoint)&&olPoint instanceof OpenLayers.Geometry.Point){var agsCoordinate=new Array();agsCoordinate.push(olPoint.x);agsCoordinate.push(olPoint.y);return agsCoordinate;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.coordinate...encode [x, y]...missing or invalid OpenLayers.Geometry.Point...");throw"...AgsAdapter.encodeAgsGeometry.coordinate...encode [x, y]...missing or invalid OpenLayers.Geometry.Point..."+olPoint;}},'path':function(olLineString){if(_isDefined(olLineString)&&olLineString instanceof OpenLayers.Geometry.LineString){var agsPath=new
 Array();for(var i=0;i<olLineString.components.length;i++){var olPoint=olLineString.components[i];try{var agsCoordinate=this.encodeAgsGeometry['coordinate'].apply(this,[olPoint]);agsPath.push(agsCoordinate);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return agsPath;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.path...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LineString...");throw"...AgsAdapter.encodeAgsGeometry.path...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LineString..."+olLineString;}},'linearring':function(olLinearRing){if(_isDefined(olLinearRing)&&olLinearRing instanceof OpenLayers.Geometry.LinearRing){var agsRing=new Array();var beginPoint=olLinearRing.components[0];var endPoint=olLinearRing.components[olLinearRing.components.length-1];if(_isSameOLPoint(beginPoint,endPoint)==false){OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.ring...not a closed ring...");throw"...AgsAdapter.encodeAgsGeometry.linearring...not a closed ring..."+olLinearRing;}
+for(var i=0;i<olLinearRing.components.length;i++){var olPoint=olLinearRing.components[i];try{var agsCoordinate=this.encodeAgsGeometry['coordinate'].apply(this,[olPoint]);agsRing.push(agsCoordinate);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return agsRing;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.linearring...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LinearRing...");throw"...AgsAdapter.encodeAgsGeometry.linearring...encode array of [x, y]...missing or invalid OpenLayers.Geometry.LinearRing..."+olLinearRing;}},'polyline':function(olMultiLineString,olSpatialReference){if(_isDefined(olMultiLineString)&&olMultiLineString instanceof OpenLayers.Geometry.MultiLineString){var agsPolyline=new esri.geometry.Polyline();var agsSpatialReference=null;try{if(_isDefined(olSpatialReference)){agsSpatialReference=this.encodeAgsSpatialReference(olSpatialReference);}else{agsSpatialReference=this.encodeAgsSpatialReference(this.config['defaultEncodeWkid']);}}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+agsPolyline.spatialReference=agsSpatialReference;for(var i=0;i<olMultiLineString.components.length;i++){var olLineString=olMultiLineString.components[i];try{var agsPath=this.encodeAgsGeometry['path'].apply(this,[olLineString]);agsPolyline.addPath(agsPath);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return agsPolyline;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.polyline...encode esri.geometry.polyline...missing or invalid OpenLayers.Geometry.MultiLineString...");throw"...AgsAdapter.encodeAgsGeometry.polyline...encode esri.geometry.polyline...missing or invalid OpenLayers.Geometry.MultiLineString..."+olMultiLineString;}},'polygon':function(olPolygon,olSpatialReference){if(_isDefined(olPolygon)&&olPolygon instanceof OpenLayers.Geometry.Polygon){var agsPolygon=new esri.geometry.Polygon();var agsSpatialReference=null;try{if(_isDefined(olSpatialReference)){agsSpatialReference=this.encodeAgsSpatialReference(olSpatialReference);}else{agsSpatialReference=this.encodeAgsSpatialReference(this.config['defaultEncodeWkid']);}}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+agsPolygon.spatialReference=agsSpatialReference;for(var i=0;i<olPolygon.components.length;i++){var olLinearRing=olPolygon.components[i];try{var agsRing=this.encodeAgsGeometry['linearring'].apply(this,[olLinearRing]);agsPolygon.addRing(agsRing);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return agsPolygon;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.polygon...encode esri.geometry.polygon...missing or invalid OpenLayers.Geometry.Polygon...");throw"...AgsAdapter.encodeAgsGeometry.polygon...encode esri.geometry.polygon...missing or invalid OpenLayers.Geometry.Polygon..."+olPolygon;}},'extent':function(olBounds,olSpatialReference){if(_isDefined(olBounds)&&olBounds instanceof OpenLayers.Bounds){var agsExtent=null;var agsSpatialReference=null;try{if(_isDefined(olSpatialReference)){agsSpatialReference=this.encodeAgsSpatialReference(olSpatialReference);}else{agsSpatialReference=this.encodeAgsSpatialReference(this.config['defaultEncodeWkid']);}}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+agsExtent=new esri.geometry.Extent(olBounds.toArray()[0],olBounds.toArray()[1],olBounds.toArray()[2],olBounds.toArray()[3],agsSpatialReference);return agsExtent;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometry.extent...encode esri.geometry.Extent...missing or invalid OpenLayers.Bounds...");throw"...AgsAdapter.encodeAgsGeometry.extent...encode esri.geometry.Extent...missing or invalid OpenLayers.Bounds..."+olBounds;}}};this.encodeAgsSymbol={"SimpleMarkerSymbol":function(olStyle){if(_isDefined(olStyle)){var agsSimpleMarkerSymbol=null;var style="STYLE_CIRCLE";var size=olStyle['pointRadius']||6;var color=null
+var opacity=olStyle['fillOpacity']||1;if(_isDefined(olStyle['fillColor'])){color=new dojo.Color(olStyle['fillColor']);color.a=opacity;}
+var xoffset=olStyle['graphicXOffset']||0;var yoffset=olStyle['graphicYOffset']||0;var outline_color=null;var outline_opacity=olStyle['strokeOpacity']||1;if(_isDefined(olStyle['strokeColor'])){outline_color=new dojo.Color(olStyle['strokeColor']);outline_color.a=outline_opacity;}
+var outline_width=olStyle['strokeWidth']||1;var outline_style=_OL_AGS_SIMPLE_LINESYMBOL_MAP[olStyle['strokeDashstyle']]||"STYLE_SOLID";var agsSimpleLineSymbol=new esri.symbol.SimpleLineSymbol(outline_style,outline_color,outline_width);agsSimpleMarkerSymbol=new esri.symbol.SimpleMarkerSymbol(style,size,agsSimpleLineSymbol,color);agsSimpleMarkerSymbol.setOffset(xoffset,yoffset);return agsSimpleMarkerSymbol;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleMarkerSymbol...encode esri.symbol.SimpleMarkerSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.SimpleMarkerSymbol...encode esri.symbol.SimpleMarkerSymbol...missing or invalid openlayers style..."+olStyle;}},"PictureMarkerSymbol":function(olStyle){if(_isDefined(olStyle)){var agsPictureMarkerSymbol=null;var size=olStyle['pointRadius']||6;var offsetX=olStyle['graphicXOffset']||0;var offsetY=olStyle['graphicYOffset']||0;var url=olStyle['externalGraphic']||"../../img/marker.pn
 g";var width=olStyle['graphicWidth']||21;var height=olStyle['graphicHeight']||25;var agsPictureMarkerSymbol=new esri.symbol.PictureMarkerSymbol(url,width,height);agsPictureMarkerSymbol.setSize(size);agsPictureMarkerSymbol.setOffset(offsetX,offsetY);return agsPictureMarkerSymbol;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.PictureMarkerSymbol...encode esri.symbol.PictureMarkerSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.PictureMarkerSymbol...encode esri.symbol.PictureMarkerSymbol...missing or invalid openlayers style..."+olStyle;}},"SimpleLineSymbol":function(olStyle){if(_isDefined(olStyle)){var color=null;var opacity=olStyle['strokeOpacity']||1;if(_isDefined(olStyle['strokeColor'])){color=new dojo.Color(olStyle['strokeColor']);color.a=opacity;}
+var width=olStyle['strokeWidth']||1;var style=_OL_AGS_SIMPLE_LINESYMBOL_MAP[olStyle['strokeDashstyle']]||"STYLE_SOLID";var agsSimpleLineSymbol=new esri.symbol.SimpleLineSymbol(style,color,width);return agsSimpleLineSymbol;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleLineSymbol...encode esri.symbol.SimpleLineSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.SimpleLineSymbol...encode esri.symbol.SimpleLineSymbol...missing or invalid openlayers style..."+olStyle;}},"CartographicLineSymbol":function(olStyle){OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.CartographicLineSymbol is not implemented yet...");throw"...AgsAdapter.encodeAgsSymbol.CartographicLineSymbol is not implemented yet...";},"SimpleFillSymbol":function(olStyle){if(_isDefined(olStyle)){var agsSimpleFillSymbol=null;var style="STYLE_SOLID";var color=null
+var outline_color=null;var outline_opacity=olStyle['strokeOpacity']||1;if(_isDefined(olStyle['strokeColor'])){outline_color=new dojo.Color(olStyle['strokeColor']);outline_color.a=outline_opacity;}
+var outline_width=olStyle['strokeWidth']||1;var outline_style=_OL_AGS_SIMPLE_LINESYMBOL_MAP[olStyle['strokeDashstyle']]||"STYLE_SOLID";var agsSimpleLineSymbol=new esri.symbol.SimpleLineSymbol(outline_style,outline_color,outline_width);agsSimpleFillSymbol=new esri.symbol.SimpleFillSymbol(style,agsSimpleLineSymbol,color);return agsSimpleFillSymbol;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.SimpleFillSymbol...encode esri.symbol.SimpleFillSymbol...missing or invalid openlayers style...");throw"...AgsAdapter.encodeAgsSymbol.SimpleFillSymbol...encode esri.symbol.SimpleFillSymbol...missing or invalid openlayers style..."+olStyle;}},"PictureFillSymbol":function(olStyle){OpenLayers.Console.error("...AgsAdapter.encodeAgsSymbol.PictureFillSymbol is not implemented yet...");throw"...AgsAdapter.encodeAgsSymbol.PictureFillSymbol is not implemented yet...";}};this.encodeAgsGraphic=function(olFeature,olSpatialReference){if(olFeature instanceof OpenLayers.Feature.Vector&&_
 isDefined(olFeature.geometry)){var agsGraphic=null;var geometryType=_OL_GEOMETRY_MAP[olFeature.geometry.CLASS_NAME];var geometry=null;try{geometry=this.encodeAgsGeometry[geometryType].apply(this,[olFeature.geometry,olSpatialReference]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+var attributes=_isDefined(olFeature.attributes)?olFeature.attributes:{};var symbol=null;if(_isDefined(olFeature.style)){var symbol_type=_OL_AGS_STYLE_MAP[olFeature.geometry.CLASS_NAME];try{symbol=this.encodeAgsSymbol[symbol_type].apply(this,[olFeature.style]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+var infoTemplate=null;if(_isDefined(attributes['infoTemplateTitle'])&&_isDefined(attributes['infoTemplateContent'])){infoTemplate=new esri.InfoTemplate(attributes['infoTemplateTitle'],attributes['infoTemplateContent']);}
+agsGraphic=new esri.Graphic(geometry,symbol,attributes,infoTemplate);return agsGraphic;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGraphic...encode esri.geometry.Geometry...missing or invalid OpenLayers.Feature.Vector...");throw"...AgsAdapter.encodeAgsGraphic...encode esri.geometry.Geometry...missing or invalid OpenLayers.Feature.Vector..."+olFeature;}};this.encodeAgsGraphics=function(olFeatures,olSpatialReference){var agsGraphics=[];if(_isDefined(olFeatures)&&olFeatures instanceof Array){for(var i=0;i<olFeatures.length;i++){try{var agsGraphic=this.encodeAgsGraphic.apply(this,[olFeatures[i],olSpatialReference]);agsGraphics.push(agsGraphic);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+return agsGraphics;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGraphics...encode array esri.Graphic...missing or invalid array of OpenLayers.Feture.Vector...");throw"...AgsAdapter.encodeAgsGraphics...encode array esri.Graphic...missing or invalid array of OpenLayers.Feture.Vector..."+olFeatures;}};this.encodeAgsFindParameters=function(findParameters){if(_isDefined(findParameters)){var agsFindParameters=new esri.tasks.FindParameters();agsFindParameters['contains']=findParameters['contains']||false;if(!_isDefined(findParameters['outSpatialReference'])){agsFindParameters['outSpatialReference']=null;}else{if(!(findParameters['outSpatialReference']instanceof esri.SpatialReference)){try{findParameters['outSpatialReference']=this.encodeAgsSpatialReference(findParameters['outSpatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
+agsFindParameters['outSpatialReference']=findParameters['outSpatialReference'];}
+agsFindParameters['returnGeometry']=findParameters['returnGeometry']||true;if(!_isDefined(findParameters['layerIds'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'layerIds' can not be null or empty...");throw"...AgsAdapter.encodeAgsFindParameters...parameter 'layerIds' can not be null or empty...";}else{agsFindParameters['layerIds']=findParameters['layerIds'];}
+if(!_isDefined(findParameters['searchFields'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'searchFields' can not be null or empty...");throw"...AgsAdapter.encodeAgsFindParameters...parameter 'searchFields' can not be null or empty...";}else{agsFindParameters['searchFields']=findParameters['searchFields'];}
+if(!_isDefined(findParameters['searchText'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...parameter 'searchText' can not be null or empty...");throw"...AgsAdapter.encodeAgsFindParameters...parameter 'searchText' can not be null or empty...";}else{agsFindParameters['searchText']=findParameters['searchText'];}
+return agsFindParameters;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsFindParameters...encode ags FindParameter...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsFindParameters...encode ags FindParameter...missing or invalid input object literal..."+findParameters;}};this.encodeAgsIdentifyParameters=function(identifyParameters){if(_isDefined(identifyParameters)){var agsIdentifyParameters=new esri.tasks.IdentifyParameters();if(_isNumber(identifyParameters['dpi'])){agsIdentifyParameters['dpi']=identifyParameters['dpi'];}else{agsIdentifyParameters['dpi']=96;}
+if(_isAgsGeometry(identifyParameters['geometry'])){agsIdentifyParameters['geometry']=identifyParameters['geometry'];}else if(_isOLGeometry(identifyParameters['geometry'])){var geometryType=_OL_GEOMETRY_MAP[identifyParameters['geometry'].CLASS_NAME];var agsGeometry=this.encodeAgsGeometry[geometryType].apply(this,[identifyParameters['geometry'],this.config['defaultEncodeWkid']]);agsIdentifyParameters['geometry']=agsGeometry;}else if(identifyParameters['geometry']instanceof OpenLayers.Feature.Vector){var geometryType=_OL_GEOMETRY_MAP[identifyParameters['geometry'].geometry.CLASS_NAME];var agsGeometry=this.encodeAgsGeometry[geometryType].apply(this,[identifyParameters['geometry'].geometry,this.config['defaultEncodeWkid']]);agsIdentifyParameters['geometry']=agsGeometry;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'geometry' missing or invalid...");throw"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'geometry' missing or invalid..."
+if(!_isNumber(identifyParameters['height'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'height' is missing or invalid...");throw"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'height' is missing or invalid...";}else{agsIdentifyParameters['height']=identifyParameters['height'];}
+if(!_isDefined(identifyParameters['layerIds'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'layerIds' is missing or invalid...");throw"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'layerIds' is missing or invalid...";}else{agsIdentifyParameters['layerIds']=identifyParameters['layerIds'];}
+if(_isDefined(identifyParameters['layerOption'])){agsIdentifyParameters['layerOption']=identifyParameters['layerOption'];}else{agsIdentifyParameters['layerOption']="all";}
+if(identifyParameters['mapExtent']instanceof OpenLayers.Bounds){try{agsIdentifyParameters['mapExtent']=this.encodeAgsGeometry['extent'].apply(this,[identifyParameters['mapExtent'],this.config['defaultEncodeWkid']]);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else if(identifyParameters['mapExtent']instanceof esri.geometry.Extent){agsIdentifyParameters['mapExtent']=identifyParameters['mapExtent'];}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'mapExtent' is missing or invalid...");throw"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'mapExtent' is missing or invalid...";}
+if(_isBoolean(identifyParameters['returnGeometry'])){agsIdentifyParameters['returnGeometry']=identifyParameters['returnGeometry'];}else{agsIdentifyParameters['returnGeometry']=true;}
+if(!_isDefined(identifyParameters['spatialReference'])){agsIdentifyParameters['spatialReference']=null;}else{if(!(identifyParameters['spatialReference']instanceof esri.SpatialReference)){try{agsIdentifyParameters['spatialReference']=this.encodeAgsSpatialReference(identifyParameters['spatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{agsIdentifyParameters['spatialReference']=identifyParameters['spatialReference'];}}
+if(_isDefined(identifyParameters['tolerance'])){agsIdentifyParameters['tolerance']=identifyParameters['tolerance'];}else{agsIdentifyParameters['tolerance']=0;}
+if(!_isNumber(identifyParameters['width'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...parameter 'width' is missing or invalid...");throw"...AgsAdapter.encodeAgsIdentifyParameters...parameter 'width' is missing or invalid...";}else{agsIdentifyParameters['width']=identifyParameters['width'];}
+return agsIdentifyParameters;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsIdentifyParameters...encode ags IdentifyParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsIdentifyParameters...encode ags IdentifyParameters...missing or invalid input object literal..."+identifyParameters;}};this.encodeAgsBufferParameters=function(bufferParameters){if(_isDefined(bufferParameters)){var agsBufferParameters=new esri.tasks.BufferParameters();if(!_isDefined(bufferParameters['bufferSpatialReference'])){agsBufferParameters['bufferSpatialReference']=null;}else{if(!(bufferParameters['bufferSpatialReference']instanceof esri.SpatialReference)){try{agsBufferParameters['bufferSpatialReference']=this.encodeAgsSpatialReference(bufferParameters['bufferSpatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{agsBufferParameters['bufferSpatialReference']=bufferParameters['bufferSpatialReference'];}}
+if(bufferParameters['distances']instanceof Array){agsBufferParameters['distances']=bufferParameters['distances'];}else{agsBufferParameters['distances']=[50];}
+if(_isDefined(bufferParameters['features'])&&bufferParameters['features']instanceof Array){var agsGraphics=[];for(var i=0;i<bufferParameters['features'].length;i++){if(bufferParameters['features'][i]instanceof esri.Graphic){agsGraphics.push(bufferParameters['features'][i]);}else if(bufferParameters['features'][i]instanceof OpenLayers.Feature.Vector){agsGraphics.push(this.encodeAgsGraphic(bufferParameters['features'][i],this.config['defaultEncodeWkid']));}else if(_isOLGeometry(bufferParameters['features'][i])){var olFeature=new OpenLayers.Feature.Vector(bufferParameters['features'][i]);agsGraphics.push(this.encodeAgsGraphic(olFeature,this.config['defaultEncodeWkid']));}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...");throw"...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...";}}
+agsBufferParameters['features']=agsGraphics;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...");throw"...AgsAdapter.encodeAgsBufferParameters...parameter 'features' is missing or invalid...";}
+if(!_isDefined(bufferParameters['outSpatialReference'])){agsBufferParameters['outSpatialReference']=null;}else{if(!(bufferParameters['outSpatialReference']instanceof esri.SpatialReference)){try{agsBufferParameters['outSpatialReference']=this.encodeAgsSpatialReference(bufferParameters['outSpatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{agsBufferParameters['outSpatialReference']=bufferParameters['outSpatialReference'];}}
+if(_isDefined(bufferParameters['unionResults'])){agsBufferParameters['unionResults']=bufferParameters['unionResults'];}else{agsBufferParameters['unionResults']=false;}
+if(_isDefined(_AGS_UNITS[bufferParameters['unit']])){agsBufferParameters['unit']=_AGS_UNITS[bufferParameters['unit']];}else{agsBufferParameters['unit']=_AGS_UNITS["UNIT_KILOMETER"];}
+return agsBufferParameters;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsBufferParameters...encode ags BufferParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsBufferParameters...encode ags BufferParameters...missing or invalid input object literal..."+bufferParameters;}};this.encodeAgsRouteParameters=function(routeParameters){if(_isDefined(routeParameters)){var agsRouteParameters=new esri.tasks.RouteParameters();if(_isDefined(routeParameters['barriers'])){try{agsRouteParameters['barriers']=this.encodeAgsFeatureSet(routeParameters['barriers'],this.config['defaultEncodeWkid'],{});}catch(e){OpenLayers.Console.error("...error encoding esri.tasks.RouteParameters.barriers...");throw e;}}
+if(!_isDefined(routeParameters['outSpatialReference'])){agsRouteParameters['outSpatialReference']=null;}else{if(!(routeParameters['outSpatialReference']instanceof esri.SpatialReference)){try{agsRouteParameters['outSpatialReference']=this.encodeAgsSpatialReference(routeParameters['outSpatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{agsRouteParameters['outSpatialReference']=routeParameters['outSpatialReference'];}}
+if(_isDefined(routeParameters['restrictionAttributes'])){}
+if(_isDefined(routeParameters['returnBarriers'])){agsRouteParameters['returnBarriers']=routeParameters['returnBarriers'];}
+if(_isDefined(routeParameters['returnDirections'])){agsRouteParameters['returnDirections']=routeParameters['returnDirections'];}
+if(_isDefined(routeParameters['returnRoutes'])){agsRouteParameters['returnRoutes']=routeParameters['returnRoutes'];}
+if(_isDefined(routeParameters['returnStops'])){agsRouteParameters['returnStops']=routeParameters['returnStops'];}
+if(_isDefined(routeParameters['stops'])&&routeParameters['stops']instanceof Array){var agsStops=new esri.tasks.FeatureSet();for(var i=0;i<routeParameters['stops'].length;i++){if(routeParameters['stops'][i]instanceof esri.Graphic){agsStops.features.push(routeParameters['stops'][i]);}else if(routeParameters['stops'][i]instanceof OpenLayers.Feature.Vector){agsStops.features.push(this.encodeAgsGraphic(routeParameters['stops'][i],this.config['defaultEncodeWkid']));}else if(_isOLGeometry(routeParameters['stops'][i])){var olFeature=new OpenLayers.Feature.Vector(routeParameters['stops'][i]);agsStops.features.push(this.encodeAgsGraphic(olFeature,this.config['defaultEncodeWkid']));}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsRouteParameters...one of the 'stops' is invalid...");throw"...AgsAdapter.encodeAgsRouteParameters...one of the 'stops' is invalid...";}}
+agsRouteParameters['stops']=agsStops;}else{OpenLayers.Console.error("...error encoding esri.tasks.RouteParameters.stops...invalid array input...");throw"...error encoding esri.tasks.RouteParameters.stops...invalid array input...";}
+return agsRouteParameters;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsRouteParameters...encode ags routeParameters...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsRouteParameters...encode ags routeParameters...missing or invalid input object literal..."+routeParameters;}};this.encodeAgsQuery=function(query){if(_isDefined(query)){var agsQuery=new esri.tasks.Query();if(_isAgsGeometry(query['geometry'])){agsQuery['geometry']=query['geometry'];}else if(_isOLGeometry(query['geometry'])){var geometryType=_OL_GEOMETRY_MAP[query['geometry'].CLASS_NAME];var agsGeometry=this.encodeAgsGeometry[geometryType].apply(this,[query['geometry'],this.config['defaultEncodeWkid']]);agsQuery['geometry']=agsGeometry;}else if(query['geometry']instanceof OpenLayers.Feature.Vector){var geometryType=_OL_GEOMETRY_MAP[query['geometry'].geometry.CLASS_NAME];var agsGeometry=this.encodeAgsGeometry[geometryType].apply(this,[query['geometry'].geometry,this.config['defaul
 tEncodeWkid']]);agsQuery['geometry']=agsGeometry;}else{}
+if(!_isDefined(query['outFields'])){OpenLayers.Console.error("...AgsAdapter.encodeAgsQuery...parameter 'outFields' is mandatory...");throw"...AgsAdapter.encodeAgsQuery...parameter 'outFields' is mandatory...";}else{agsQuery['outFields']=query['outFields'];}
+if(!_isDefined(query['outSpatialReference'])){agsQuery['outSpatialReference']=null;}else{if(!(query['outSpatialReference']instanceof esri.SpatialReference)){try{agsQuery['outSpatialReference']=this.encodeAgsSpatialReference(query['outSpatialReference']);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{agsQuery['outSpatialReference']=query['outSpatialReference'];}}
+if(_isDefined(query['returnGeometry'])){agsQuery['returnGeometry']=query['returnGeometry'];}else{agsQuery['returnGeometry']=true;}
+if(_isDefined(_AGS_SPATIALRELATIONSHIP[query['spatialRelationship']])){agsQuery['spatialRelationship']=_AGS_SPATIALRELATIONSHIP[query['spatialRelationship']];}else{agsQuery['spatialRelationship']=_AGS_SPATIALRELATIONSHIP["INTERSECTS"];}
+agsQuery['text']=query['text']?query['text']:"";agsQuery['where']=query['where']?query['where']:"";return agsQuery;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsQuery...encode ags Query...missing or invalid input object literal...");throw"...AgsAdapter.encodeAgsQuery...encode ags Query...missing or invalid input object literal..."+query;}};this.encodeAgsLocation=function(location){if(_isDefined(location)){try{if(location instanceof esri.geometry.Point){return location;}else if(location instanceof OpenLayers.Geometry.Point){var agsPoint=this.encodeAgsGeometry['point'].apply(this,[location,this.config['defaultEncodeWkid']]);return agsPoint;}else if(location instanceof OpenLayers.Feature.Vector){var agsPoint=this.encodeAgsGeometry['point'].apply(this,[location.geometry,this.config['defaultEncodeWkid']]);return agsPoint;}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsLocation...'location' is invalid...");throw"...AgsAdapter.encodeAgsLocation...'location' is inval
 id...";}}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsLocation...encode location...missing or invalid 'location'...");throw"...AgsAdapter.encodeAgsLocation...encode location...missing or invalid 'location'...";}};this.encodeAgsFeatureSet=function(olFeatures,olSpatialReference,options){if(_isDefined(olFeatures)){var featureSet=new esri.tasks.FeatureSet();try{featureSet.features=this.encodeAgsGraphics.apply(this,[olFeatures,olSpatialReference]);featureSet.spatialReference=this.encodeAgsSpatialReference.apply(this,[olSpatialReference]);featureSet.displayFieldName=options['displayFieldName']||undefined;featureSet.fieldAliases=options['fieldAliases']||undefined;featureSet.geometryType=options['geometryType']||undefined;}catch(e){OpenLayers.Console.error(e.toString());throw e;}}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsFeatureSet...encode FeatureSet...missing or invalid OpenLayers.Feature.Vector array..
 .");throw"...AgsAdapter.encodeAgsFeatureSet...encode FeatureSet...missing or invalid OpenLayers.Feature.Vector array...";}
+return featureSet;},this.encodeAgsGeometrySpatialRelationship=function(olGeometrySpatialRelationship){if(_isDefined(olGeometrySpatialRelationship)){var agsGeometrySpatialRelationship=null;agsGeometrySpatialRelationship=_AGS_GEOMETRY_SPATIALRELATIONSHIP[olGeometrySpatialRelationship];}else{OpenLayers.Console.error("...AgsAdapter.encodeAgsGeometrySpatialRelationship...encode AgsGeometrySpatialRelationship...missing or invalid input OpenLayers GeometrySpatialRelationship...");throw"...AgsAdapter.encodeAgsGeometrySpatialRelationship...encode AgsGeometrySpatialRelationship...missing or invalid input OpenLayers GeometrySpatialRelationship...";}
+return agsGeometrySpatialRelationship;}
+OpenLayers.Util.extend(this.config,config);this.parseAgsGeometry.point=__bindFunction(this.parseAgsGeometry.point,this);this.parseAgsGeometry.path=__bindFunction(this.parseAgsGeometry.path,this);this.encodeAgsFeatureSet=__bindFunction(this.encodeAgsFeatureSet,this);this.encodeAgsFindParameters=__bindFunction(this.encodeAgsFindParameters,this);}})();OpenLayers.Protocol.AgsFeatureAccess.v2=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",format:null,formatOptions:null,agsFeatureLayer:null,isAgsFeatureLayerLoaded:false,_query:null,defaultQuery:{outFields:["*"],returnGeometry:true,where:"",outSpatialReference:this.srsName},style:null,templates:null,currentFeatureTemplate:null,layer:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.AgsJsAdapter();}
+if(this.url!=null&&this.url!=""){this.agsFeatureLayer=new esri.layers.FeatureLayer(this.url,{});dojo.connect(this.agsFeatureLayer,"onLoad",this,function(layer){OpenLayers.Console.debug("...feature layer loaded successfully...");this.isAgsFeatureLayerLoaded=true;var agsRendererType=layer.renderer.declaredClass;var agsRendererParserType=agsRendererType.split(".")[2];this.style=this.format.parseAgsRenderer[agsRendererParserType].apply(this.format,[layer.renderer]);OpenLayers.Console.debug("...feature layer renderer parsed successfully...");this.templates=this.format.parseAgsFeatureTypes.apply(this.format,[layer.types]);OpenLayers.Console.debug("...feature layer feature types parsed successfully...");this.currentFeatureTemplate=this.templates[0];if(this.currentFeatureTemplate){var applyTemplateFunc=function(obj){var feature=obj.feature||obj;this.applyCurrentFeatureTemplate(feature);};this.layer.events.on({'sketchcomplete':applyTemplateFunc,scope:this});}});}else{OpenLayers.Conso
 le.error("...fail to initialize OpenLayers.Protocol.AgsFeatureAccess.v2...invalid or null url...");throw"...fail to initialize OpenLayers.Protocol.AgsFeatureAccess.v2...invalid or null url...";}
+if(options.query){this._query=OpenLayers.Util.extend(this.defaultQuery,options.query);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
+this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});if(options.filter instanceof OpenLayers.Filter.Spatial){if(options.filter.type==OpenLayers.Filter.Spatial.BBOX){var bbox=options.filter.value;this._query.geometry=bbox;this._query.spatialRelationship='INTERSECTS';}else{}}else if(options.filter instanceof OpenLayers.Filter.FeatureId){}else if(options.filter instanceof OpenLayers.Filter.Comparison){}else{}
+var agsQuery=this.format.encodeAgsQuery.apply(this.format,[this._query]);options['parser']=this.format;options['layer']=this.layer;if(this.style&&this.style instanceof OpenLayers.Style){options['style']=this.style;}
+if(this.isAgsFeatureLayerLoaded==true){this.agsFeatureLayer.queryFeatures(agsQuery,OpenLayers.Util.AgsUtil.createSingleCallback([this.handleRead],options,options.scope),this.handleError);}else{OpenLayers.Console.warn("...features not loaded...");OpenLayers.Console.warn("...this.agsFeatureLayer feature layer is not loaded yet...try query feature later...");}},handleRead:function(response,options){if(options.callback){var olFeatures=options.parser.parseAgsResults['featureSet'].apply(options.parser,[response]);if(options['style']){if(options['layer']){options['layer'].styleMap=new OpenLayers.StyleMap({'default':options['style']},{});}else{for(var i=0;i<olFeatures.length;i++){}}}
+options.callback.call(options.scope,{features:olFeatures});}},commit:function(features,options){var deferred=null;options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var featuresToEdit=[];var featuresToAdd=[];var featuresToUpdate=[];var featuresToDelete=[];for(var i=0;i<features.length;i++){if(features[i].state==OpenLayers.State.INSERT){featuresToAdd.push(features[i]);featuresToEdit.push(features[i]);}else if(features[i].state==OpenLayers.State.UPDATE){if((features[i].attributes.objectid!=null&&features[i].attributes.objectid!="")||(features[i].attributes.OBJECTID!=null&&features[i].attributes.OBJECTID!="")||(features[i].fid!=null&&features[i].fid!="")){if(features[i].fid&&(!features[i].attributes.objectid&&!features[i].attributes.OBJECTID)){features[i].attributes.objectid=features[i].fid;features[i].attributes.OBJECTID=features[i].fid;}
+featuresToUpdate.push(features[i]);featuresToEdit.push(features[i]);}else{OpenLayers.Console.debug("...skip commiting changes of feature: + "+features[i].id+"...no valid objectid found...");}}else if(features[i].state==OpenLayers.State.DELETE){if((features[i].attributes.objectid!=null&&features[i].attributes.objectid!="")||(features[i].attributes.OBJECTID!=null&&features[i].attributes.OBJECTID!="")||(features[i].fid!=null&&features[i].fid!="")){if(features[i].fid&&(!features[i].attributes.objectid&&!features[i].attributes.OBJECTID)){features[i].attributes.objectid=features[i].fid;features[i].attributes.OBJECTID=features[i].fid;}
+featuresToDelete.push(features[i]);featuresToEdit.push(features[i]);}else{OpenLayers.Console.debug("...skip commiting changes of feature: + "+features[i].id+"...no valid objectid found...");}}else{}}
+options['featuresToEdit']=featuresToEdit;var singleCallback=null;if(window.dojo!==undefined){singleCallback=dojo.hitch(this,function(addResults,updateResults,deleteResults){this.handleCommit.apply(options.scope,[addResults,updateResults,deleteResults,options]);});}else{singleCallback=OpenLayers.Function.bind(function(addResults,updateResults,deleteResults){this.handleCommit.apply(options.scope,[addResults,updateResults,deleteResults,options]);},this);}
+var agsFeaturesToAdd=this.format.encodeAgsGraphics.apply(this.format,[featuresToAdd,(this.srsName||this.layer.map.projection)]);var agsFeaturesToUpdate=this.format.encodeAgsGraphics.apply(this.format,[featuresToUpdate,(this.srsName||this.layer.map.projection)]);var agsFeaturesToDelete=this.format.encodeAgsGraphics.apply(this.format,[featuresToDelete,(this.srsName||this.layer.map.projection)]);if(this.isAgsFeatureLayerLoaded==true){deferred=this.agsFeatureLayer.applyEdits(agsFeaturesToAdd,agsFeaturesToUpdate,agsFeaturesToDelete,singleCallback,this.handleError);}else{OpenLayers.Console.warn("...features not loaded...");OpenLayers.Console.warn("...this.agsFeatureLayer feature layer is not loaded yet...try commit changes later...");}
+return deferred;},handleCommit:function(addResults,updateResults,deleteResults,options){if(options.callback){var insertIds=[];for(var i=0;i<addResults.length;i++){if(addResults[i].success==true){insertIds.push(addResults[i].objectId);OpenLayers.Console.debug("...Collect objectId for inserted features...");}}
+var response=new OpenLayers.Protocol.Response({requestType:"commit",code:OpenLayers.Protocol.Response.SUCCESS,reqFeatures:options['featuresToEdit'],insertIds:insertIds});options.callback.call(options.scope,response);}},handleError:function(error){OpenLayers.Console.error(error);},setLayer:function(layer){this.layer=layer;},getFeatureTemplateByRule:function(rule){for(var i=0;i<this.templates.length;i++){if(rule.name==this.templates[i].templates[0].name){OpenLayers.Console.debug("...match a rule with a template...");OpenLayers.Console.debug("...rule name: "+rule.name+"...");OpenLayers.Console.debug("...template name: "+this.templates[i].templates[0].name+"...");return this.templates[i];}}},setCurrentFeatureTemplate:function(olFeatureTemplate){if(olFeatureTemplate){this.currentFeatureTemplate=olFeatureTemplate;}else{OpenLayers.Console.warn("...setCurrentFeatureTemplate...invalid feature template...skip setting...");}},applyCurrentFeatureTemplate:function(olFeature){if(olFeature
 ){OpenLayers.Util.extend(olFeature.attributes,this.currentFeatureTemplate.templates[0].prototype.attributes);OpenLayers.Console.debug("...current feature template applied...");}},CLASS_NAME:"OpenLayers.Protocol.AgsFeatureAccess.v2"});OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:false,activate:function(){if(OpenLayers.Strategy.prototype.activate.apply(this,arguments)){this.layer.events.on({"refresh":this.load,scope:this});if(this.layer.visibility==true||this.preload){this.load();}else{this.layer.events.on({"visibilitychanged":this.load,scope:this});}
+return true;}
+return false;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"refresh":this.load,"visibilitychanged":this.load,scope:this});}
+return deactivated;},load:function(options){var layer=this.layer;layer.events.triggerEvent("loadstart");layer.protocol.read(OpenLayers.Util.applyDefaults({callback:OpenLayers.Function.bind(this.merge,this,layer.map.getProjectionObject()),filter:layer.filter},options));layer.events.un({"visibilitychanged":this.load,scope:this});},merge:function(mapProjection,resp){var layer=this.layer;layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){if(!mapProjection.equals(layer.projection)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(layer.projection,mapProjection);}}}
+layer.addFeatures(features);}
+layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
+this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserve
 r);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);}
+document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
+if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
+this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
+document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){if(this.zoomBox){this.removeZoomBox();}
+this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
+this.removeZoomBox();}},removeZoomBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
+elem=elem.parentNode;}
+if(inMap){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
+OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
+if(direction){this.direction=direction;}
+this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
+OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util
 .createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
+OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
+switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
+this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
+this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
+document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
+if(this.mode=="measure"&&mode!="measure"){for(var i=0,len=this.measureDivs.length;i<len;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
+this.measureDivs=[];this.measureStart=null;}
+this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
+switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
+break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
+switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
+break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
+document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
+this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,styleFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures,options){if(pointFeatures.length<2){throw new Error("At least two point features have to be added to "+"create a line from");}
+var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0,len=pointFeatures.length;i<len;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){throw new TypeError("Only features with point geometries are supported.");}
+if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var style=(this.styleFrom!=null)?(pointFeatures[i+this.styleFrom].style):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes,style);}
+startPoint=endPoint;}
+this.addFeatures(lines,options);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.SOURCE_NODE=-1;OpenLayers.Layer.PointTrack.TARGET_NODE=0;OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Protocol.WFS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.WFS.DEFAULTS);var cls=OpenLayers.Protocol.WFS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFS version: "+options.version;}
+return new cls(options);};OpenLayers.Protocol.WFS.fromWMSLayer=function(layer,options){var typeName,featurePrefix;var param=layer.params["LAYERS"];var parts=(OpenLayers.Util.isArray(param)?param[0]:param).split(":");if(parts.length>1){featurePrefix=parts[0];}
+typeName=parts.pop();var protocolOptions={url:layer.url,featureType:typeName,featurePrefix:featurePrefix,srsName:layer.projection&&layer.projection.getCode()||layer.map&&layer.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(options,protocolOptions));};OpenLayers.Protocol.WFS.DEFAULTS={"version":"1.0.0"};OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.markers.length;i<len;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged
 ||!this.drawn){for(var i=0,len=this.markers.length;i<len;i++){this.drawMarker(this.markers[i]);}
+this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity<1){marker.setOpacity(this.opacity);}
+if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);marker.erase();}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{if(!marker.isDrawn()){var markerImg=marker.draw(px);this.div.appendChild(markerImg);}else if(marker.icon){marker.icon.moveTo(px);}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0,len=this.markers.length;i<len;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:false,adapter:null,handlers:null,displayResults:true,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:false,toggle:true,multiple:false,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(url,layer,callbacks,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.url=url;if(layer&&layer instanceof OpenLayers.Layer.Vector){this.layer=layer;}else{this.layer=new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:false,isBaseLayer:false});}
+if(callbacks){this.taskCallbacks=callbacks;}
+var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,multiple:this.multiple,callbacks:{dblclick:dojo.hitch(this,this._execute)}};this.selectControl=new OpenLayers.Control.SelectFeature(this.layer,selectOptions);var drawOptions=OpenLayers.Util.extend({callbacks:{done:dojo.hitch(this,this._execute)}},this.drawCtrlHandlerOptions);this.drawControl=new OpenLayers.Control.DrawFeature(this.layer,this.drawCtrlHandler,drawOptions);this.handlers={};this.adapter=new OpenLayers.Format.AgsJsAdapter();this._resultFeatures=[];this._resultImages=[];OpenLayers.Util.applyDefaults(this.resultImageOptions,{opacity:1.0});this._isDefined=OpenLayers.Util.AgsUtil.isDefined;this._isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;this._isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;},destroy:function(){this.layer=null;this.selectControl.destroy();this.drawControl.destroy();OpenLayers.Control.prototyp
 e.destroy.apply(this,[]);},activate:function(){if(this.mode=="select"){return(this.selectControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else if(this.mode=="draw"){return(this.drawControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.drawControl.deactivate();this.selectControl.deactivate();deactivated=true;}
+return deactivated;},_execute:function(data){var olFeatures=null;if(this._isOLGeometry(data)){if(this.multiple==true){OpenLayers.Console.log("...to allow multiple features as operation input...");OpenLayers.Console.log("..._execute will not be triggered by 'done' drawing a geometry on map...");this.drawControl.drawFeature(data);return true;}else{OpenLayers.Console.log("..._execute triggered by 'done' drawing a geometry on map...");OpenLayers.Console.log("...single feature as operation input...");olFeatures=[new OpenLayers.Feature.Vector(data)];}}else if(data instanceof OpenLayers.Feature.Vector){OpenLayers.Console.log("..._execute triggered by 'dblclick' a feature on map...");if(this.multiple==true){OpenLayers.Console.log("...allow multiple features as operation input...");olFeatures=this.layer.selectedFeatures;}else{OpenLayers.Console.log("...single feature as operation input...");olFeatures=[data];}}else if(data instanceof Array){OpenLayers.Console.log("..._execute trigger
 ed by using all selected features on the map...");olFeatures=data;}else{OpenLayers.Console.error("...input geometry or feature is missing or invalid...");throw"...input geometry or feature is missing or invalid...";}
+this.execute(olFeatures,{},[]);},execute:function(olFeatures,taskParameters,callbacks){OpenLayers.Console.error("...execute of OpenLayers.Control.AgsControl is not implemented...");throw"...execute of OpenLayers.Control.AgsControl is not implemented...";},onExecuteComplete:function(agsResults,options){OpenLayers.Console.debug("...AgsControl OnExecuteComplete is called...");var olResults=null;try{if(this._resultsParser.context&&typeof this._resultsParser.parser==="function"){olResults=this._resultsParser.parser.apply(this._resultsParser.context,[agsResults,options['args_list']]);}else{OpenLayers.Console.error("..._resultsParser is missing or invalid...");throw"..._resultsParser is missing or invalid...";}}catch(e){OpenLayers.Console.error(e.message);throw e.message;}
+if(olResults instanceof OpenLayers.Feature.Vector){olResults=[olResults];}
+this.cleanupResults();this.addResults(olResults);if(this.displayResults===true){this.showResults();}
+options.callback.apply(this,[olResults]);},onExecuteAsynComplete:function(agsResults,options){var _options=OpenLayers.Util.extend({'resultFeatures':this._resultFeatures,'resultImages':this._resultImages},options);try{if(this._resultsParser.context&&typeof this._resultsParser.parser==="function"){this._resultsParser.parser.apply(this._resultsParser.context,[agsResults,options]);}else{OpenLayers.Console.error("..._resultsParser is missing or invalid...");throw"..._resultsParser is missing or invalid...";}}catch(e){throw e;}},setTaskParameters:function(taskParameters){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);OpenLayers.Util.extend(this.taskParameters,_taskParameters);},addResults:function(olResults){for(var i=0;i<olResults.length;i++){var olResult=olResults[i];if(olResult instanceof OpenLayers.Feature.Vector){this._resultFeatures.push(olResult);}else if(olResult instanceof OpenLayers.Layer.I
 mage){olResult.setVisibility(false);olResult.setOpacity(this.resultImageOptions.opacity);this.map.addLayer(olResult);this.map.setLayerIndex(olResult,this.map.getLayerIndex(this.layer)+1);this._resultImages.push(olResult);}else{OpenLayers.Console.log("...skip adding because it's not OpenLayers.Feature.Vector or OpenLayers.Layer.Image...");}}},cleanupResults:function(){this.hideResults();if(this._resultFeatures&&this._resultFeatures.length>0){for(var i=0;i<this._resultFeatures.length;i++){this._resultFeatures[i].destroy();}}
+this._resultFeatures.length=0;if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this.map.removeLayer(this._resultImages[i]);}}
+this._resultImages.length=0;},hideResults:function(){if(this._resultFeatures&&this._resultFeatures.length>0){this.layer.removeFeatures(this._resultFeatures);}
+if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this._resultImages[i].setVisibility(false);}}},showResults:function(){if(this._resultFeatures&&this._resultFeatures.length>0){this.layer.addFeatures(this._resultFeatures);}
+if(this._resultImages&&this._resultImages.length>0){for(var i=0;i<this._resultImages.length;i++){this._resultImages[i].setVisibility(true);}}},switchMode:function(mode){var wasActive=this.active;if(this.active===true){this.deactivate();}
+if(this.mode==="select"){this.selectControl.unselectAll();}
+if(mode==="select"||mode==="draw"){this.mode=mode;}
+if(wasActive===true){this.activate();}
+OpenLayers.Console.log("...control mode switched...current control mode: "+this.mode+"...");},switchDrawCtrlHandler:function(handler){var wasActive=this.active;if(this.active===true){this.deactivate();}
+this.drawControl.handler=new handler(this.drawControl,this.drawControl.callbacks,this.drawControl.handlerOptions);this.drawCtrlHandler=this.drawControl.handler;if(wasActive===true){this.activate();}
+OpenLayers.Console.log("...DrawCtrlHandler switched...current DrawCtrlHandler: "+this.drawCtrlHandler.CLASS_NAME+"...");},setMap:function(map){if(!this.layer.map||!(this.layer.map instanceof OpenLayers.Map)){map.addLayer(this.layer);}
+this.selectControl.setMap(map);this.drawControl.setMap(map);OpenLayers.Util.extend(this.adapter.config,{'defaultEncodeWkid':this.layer.map['projection']});OpenLayers.Control.prototype.setMap.apply(this,arguments);OpenLayers.Console.debug("...current control mode: "+this.mode+"...");OpenLayers.Console.debug("...current DrawCtrlHandler: "+this.drawCtrlHandler.prototype.CLASS_NAME+"...");OpenLayers.Console.log("...adapter defaultEncodeWkid: "+this.adapter.config.defaultEncodeWkid+"...");},_createCallbacks:function(context,methods,options){return dojo.hitch(this,function(response){var method=null;for(var i=0;i<methods.length;i++){method=methods[i];if(typeof method=="function"){options['args_list']=arguments;method.apply(context,[response,options]);}}});},CLASS_NAME:"OpenLayers.Control.AgsControl"});OpenLayers.Control.AgsIdentifyTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,initialize:function(url,layer,callbacks,options){OpenLayers.Contro
 l.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'dpi':96,'geometry':null,'height':0,'layerIds':[0],'layerOption':"all",'mapExtent':null,'returnGeometry':true,'spatialReference':null,'tolerance':1,'width':0};this._resultsParser={'parser':this.adapter.parseAgsResults['identifyResults'],'context':this.adapter};this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);if(this._isDefined(this.layer.map)){_taskParameters['width']=this.layer.map.getSize().w?this.layer.map.getSize().w:_taskParameters['width'];_taskParameters['height']=this.layer.map.getSize().h?this.layer.map.getSize().h:_taskParameters['height'];_taskParameters['mapExtent']=this.layer.map.getExtent()?this.layer.map.getExtent():_taskParameters['mapExtent'];_taskParameters['spatialReference']=t
 his.layer.map['projection']?this.layer.map['projection']:_taskParameters['spatialReference'];}else{OpenLayers.Console.error("...can not execute identify task...this.layer.map is not valid...");throw"...can not execute identify task...this.layer.map is not valid...";}
+if(olFeatures[0]instanceof OpenLayers.Feature.Vector){_taskParameters['geometry']=olFeatures[0].geometry;}else{OpenLayers.Console.error("...can not execute identify task...input geometry is not valid...");throw"...can not execute identify task...input geometry is not valid...";}
+var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsIdentifyTask=new esri.tasks.IdentifyTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsIdentifyParameters=this.adapter.encodeAgsIdentifyParameters(_taskParameters);}catch(e){throw e;}
+agsIdentifyTask.execute(agsIdentifyParameters,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsIdentifyTask ...");throw"...'asynchronous' should always be set to 'false' for AgsIdentifyTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsIdentifyTask"});OpenLayers.Control.Pan=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,direction:null,type:OpenLayers.Control.TYPE_BUTTON,initialize:function(direction,options){this.direction=direction;this.CLASS_NAME+=this.direction;OpenLayers.Control.prototype.initialize.apply(this,[options]);},trigger:function(){var getSlideFactor=OpenLayers.Function.bind(function(dim){return this.slideRatio?this.map.getSize()[dim]*this.slideRatio:this.slideFactor;},this);switch(this.direction){case OpenLayers.Control.Pan.NORTH:this.map.pan(0,-getSlideFactor("h"));break;case OpenLayers.Control.Pan.SOUTH:this.map.pan(0,getSlideFactor("h"));break;case OpenLayers.Contr
 ol.Pan.WEST:this.map.pan(-getSlideFactor("w"),0);break;case OpenLayers.Control.Pan.EAST:this.map.pan(getSlideFactor("w"),0);break;}},CLASS_NAME:"OpenLayers.Control.Pan"});OpenLayers.Control.Pan.NORTH="North";OpenLayers.Control.Pan.SOUTH="South";OpenLayers.Control.Pan.EAST="East";OpenLayers.Control.Pan.WEST="West";OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,noMagic:false,yx:{'EPSG:4326':true},initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);if(parseFloat(params.VERSION)>=1.3&&!params.EXCEPTIONS){params.EXCEPTIONS="INIMAGE";}
+newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){return(parseFloat(this.params.VERSION)>=1.3&&!!this.yx[this.map.getProjectionObject().getCode()]);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=
 this.map.getProjectionObject();var projectionCode=this.projection&&this.projection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=this.params.CRS||value;this.params.SRS=null;}else{this.params.SRS=this.params.SRS||value;this.params.CRS=null;}
+if(typeof this.params.TRANSPARENT=="boolean"){newParams.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";}
+return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.layer){this.setLayer(this.options.layer);}
+var defaults=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(defaults,this.DEFAULTS);this.setTargets(this.options.targets);if(this.targets.length===0&&this.layer){this.addTargetLayer(this.layer);}
+this.geoToleranceCache={};},setLayer:function(layer){if(this.active){this.deactivate();this.layer=layer;this.activate();}else{this.layer=layer;}},setTargets:function(targets){this.targets=[];if(targets&&targets.length){var target;for(var i=0,len=targets.length;i<len;++i){target=targets[i];if(target instanceof OpenLayers.Layer.Vector){this.addTargetLayer(target);}else{this.addTarget(target);}}}},addTargetLayer:function(layer){this.addTarget({layer:layer});},addTarget:function(target){target=OpenLayers.Util.applyDefaults(target,this.defaults);target.nodeTolerance=target.nodeTolerance||target.tolerance;target.vertexTolerance=target.vertexTolerance||target.tolerance;target.edgeTolerance=target.edgeTolerance||target.tolerance;this.targets.push(target);},removeTargetLayer:function(layer){var target;for(var i=this.targets.length-1;i>=0;--i){target=this.targets[i];if(target.layer===layer){this.removeTarget(target);}}},removeTarget:function(target){return OpenLayers.Util.removeItem(t
 his.targets,target);},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(this.layer&&this.layer.events){this.layer.events.on({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.layer&&this.layer.events){this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
+this.feature=null;this.point=null;return deactivated;},onSketchModified:function(event){this.feature=event.feature;this.considerSnapping(event.vertex,event.vertex);},onVertexModified:function(event){this.feature=event.feature;var loc=this.layer.map.getLonLatFromViewPortPx(event.pixel);this.considerSnapping(event.vertex,new OpenLayers.Geometry.Point(loc.lon,loc.lat));},considerSnapping:function(point,loc){var best={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY,x:null,y:null};var snapped=false;var result,target;for(var i=0,len=this.targets.length;i<len;++i){target=this.targets[i];result=this.testTarget(target,loc);if(result){if(this.greedy){best=result;best.target=target;snapped=true;break;}else{if((result.rank<best.rank)||(result.rank===best.rank&&result.dist<best.dist)){best=result;best.target=target;snapped=true;}}}}
+if(snapped){var proceed=this.events.triggerEvent("beforesnap",{point:point,x:best.x,y:best.y,distance:best.dist,layer:best.target.layer,snapType:this.precedence[best.rank]});if(proceed!==false){point.x=best.x;point.y=best.y;this.point=point;this.events.triggerEvent("snap",{point:point,snapType:this.precedence[best.rank],layer:best.target.layer,distance:best.dist});}else{snapped=false;}}
+if(this.point&&!snapped){point.x=loc.x;point.y=loc.y;this.point=null;this.events.triggerEvent("unsnap",{point:point});}},testTarget:function(target,loc){var resolution=this.layer.map.getResolution();if("minResolution"in target){if(resolution<target.minResolution){return null;}}
+if("maxResolution"in target){if(resolution>=target.maxResolution){return null;}}
+var tolerance={node:this.getGeoTolerance(target.nodeTolerance,resolution),vertex:this.getGeoTolerance(target.vertexTolerance,resolution),edge:this.getGeoTolerance(target.edgeTolerance,resolution)};var maxTolerance=Math.max(tolerance.node,tolerance.vertex,tolerance.edge);var result={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY};var eligible=false;var features=target.layer.features;var feature,type,vertices,vertex,closest,dist,found;var numTypes=this.precedence.length;var ll=new OpenLayers.LonLat(loc.x,loc.y);for(var i=0,len=features.length;i<len;++i){feature=features[i];if(feature!==this.feature&&!feature._sketch&&feature.state!==OpenLayers.State.DELETE&&(!target.filter||target.filter.evaluate(feature))){if(feature.atPoint(ll,maxTolerance,maxTolerance)){for(var j=0,stop=Math.min(result.rank+1,numTypes);j<stop;++j){type=this.precedence[j];if(target[type]){if(type==="edge"){closest=feature.geometry.distanceTo(loc,{details:true});dist=closest.distance;if(dist<=tol
 erance[type]&&dist<result.dist){result={rank:j,dist:dist,x:closest.x0,y:closest.y0};eligible=true;break;}}else{vertices=feature.geometry.getVertices(type==="node");found=false;for(var k=0,klen=vertices.length;k<klen;++k){vertex=vertices[k];dist=vertex.distanceTo(loc);if(dist<=tolerance[type]&&(j<result.rank||(j===result.rank&&dist<result.dist))){result={rank:j,dist:dist,x:vertex.x,y:vertex.y};eligible=true;found=true;}}
+if(found){break;}}}}}}}
+return eligible?result:null;},getGeoTolerance:function(tolerance,resolution){if(resolution!==this.resolution){this.resolution=resolution;this.geoToleranceCache={};}
+var geoTolerance=this.geoToleranceCache[tolerance];if(geoTolerance===undefined){geoTolerance=tolerance*resolution;this.geoToleranceCache[tolerance]=geoTolerance;}
+return geoTolerance;},destroy:function(){if(this.active){this.deactivate();}
+delete this.layer;delete this.targets;OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Snapping"});OpenLayers.Format.CSWGetDomain=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetDomain.DEFAULTS);var cls=OpenLayers.Format.CSWGetDomain["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetDomain version: "+options.version;}
+return new cls(options);};OpenLayers.Format.CSWGetDomain.DEFAULTS={"version":"2.0.2"};OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetDomainResponse":function(node,obj){this.readChildNodes(node,obj);},"DomainValues":function(node,obj){if(!(OpenLayers.Util.isArray(obj.DomainValues))){obj.DomainValues=[];}
+var attrs=node.attributes;var domainValue={};for(var i=0,len=attrs.length;i<len;++i){domainValue[attrs[i].name]=attrs[i].nodeValue;}
+this.readChildNodes(node,domainValue);obj.DomainValues.push(domainValue);},"PropertyName":function(node,obj){obj.PropertyName=this.getChildValue(node);},"ParameterName":function(node,obj){obj.ParameterName=this.getChildValue(node);},"ListOfValues":function(node,obj){if(!(OpenLayers.Util.isArray(obj.ListOfValues))){obj.ListOfValues=[];}
+this.readChildNodes(node,obj.ListOfValues);},"Value":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
+value.value=this.getChildValue(node);obj.push({Value:value});},"ConceptualScheme":function(node,obj){obj.ConceptualScheme={};this.readChildNodes(node,obj.ConceptualScheme);},"Name":function(node,obj){obj.Name=this.getChildValue(node);},"Document":function(node,obj){obj.Document=this.getChildValue(node);},"Authority":function(node,obj){obj.Authority=this.getChildValue(node);},"RangeOfValues":function(node,obj){obj.RangeOfValues={};this.readChildNodes(node,obj.RangeOfValues);},"MinValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
+value.value=this.getChildValue(node);obj.MinValue=value;},"MaxValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
+value.value=this.getChildValue(node);obj.MaxValue=value;}}},write:function(options){var node=this.writeNode("csw:GetDomain",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetDomain":function(options){var node=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(options.PropertyName||this.PropertyName){this.writeNode("csw:PropertyName",options.PropertyName||this.PropertyName,node);}else if(options.ParameterName||this.ParameterName){this.writeNode("csw:ParameterName",options.ParameterName||this.ParameterName,node);}
+this.readChildNodes(node,options);return node;},"PropertyName":function(value){var node=this.createElementNSPlus("csw:PropertyName",{value:value});return node;},"ParameterName":function(value){var node=this.createElementNSPlus("csw:ParameterName",{value:value});return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"ExceptionReport":function(node,obj){obj.exceptionReport={version:node.getAttribute('version'),language:node.getAttribute('xml:lang'),exceptions:[]};this.readChildNodes(node,obj.exceptionReport);},"AllowedValues":function(node,parameter){parameter.allowedValues={};this.readChildNodes(node,parameter.allowedValues);},"AnyValue":function(node,parameter){parameter.anyValue=true;},"DataType":function(node,parameter){parameter.dataType=this.ge
 tChildValue(node);},"Range":function(node,allowedValues){allowedValues.range={};this.readChildNodes(node,allowedValues.range);},"MinimumValue":function(node,range){range.minValue=this.getChildValue(node);},"MaximumValue":function(node,range){range.maxValue=this.getChildValue(node);},"Identifier":function(node,obj){obj.identifier=this.getChildValue(node);},"SupportedCRS":function(node,obj){obj.supportedCRS=this.getChildValue(node);}},OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])},writers:{"ows":OpenLayers.Util.applyDefaults({"Range":function(range){var node=this.createElementNSPlus("ows:Range",{attributes:{'ows:rangeClosure':range.closure}});this.writeNode("ows:MinimumValue",range.minValue,node);this.writeNode("ows:MaximumValue",range.maxValue,node);return node;},"MinimumValue":function(minValue){var node=this.createElementNSPlus("ows:MinimumValue",{value:minValue});return node;},"MaximumValue":function(maxValue){var node=this.createElementNSPlus("ows:MaximumValue"
 ,{value:maxValue});return node;},"Value":function(value){var node=this.createElementNSPlus("ows:Value",{value:value});return node;}},OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"])},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.WCSGetCoverage=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wcs:"http://www.opengis.net/wcs/1.1",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.1.2",schemaLocation:"http://www.opengis.net/wcs/1.1 http://schemas.opengis.net/wcs/1.1/wcsGetCoverage.xsd",write:function(options){var node=this.writeNode("wcs:GetCoverage",options);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wcs":{"GetCoverage":function(options){var node=th
 is.createElementNSPlus("wcs:GetCoverage",{attributes:{version:options.version||this.VERSION,service:'WCS'}});this.writeNode("ows:Identifier",options.identifier,node);this.writeNode("wcs:DomainSubset",options.domainSubset,node);this.writeNode("wcs:Output",options.output,node);return node;},"DomainSubset":function(domainSubset){var node=this.createElementNSPlus("wcs:DomainSubset",{});this.writeNode("ows:BoundingBox",domainSubset.boundingBox,node);if(domainSubset.temporalSubset){this.writeNode("wcs:TemporalSubset",domainSubset.temporalSubset,node);}
+return node;},"TemporalSubset":function(temporalSubset){var node=this.createElementNSPlus("wcs:TemporalSubset",{});for(var i=0,len=temporalSubset.timePeriods.length;i<len;++i){this.writeNode("wcs:TimePeriod",temporalSubset.timePeriods[i],node);}
+return node;},"TimePeriod":function(timePeriod){var node=this.createElementNSPlus("wcs:TimePeriod",{});this.writeNode("wcs:BeginPosition",timePeriod.begin,node);this.writeNode("wcs:EndPosition",timePeriod.end,node);if(timePeriod.resolution){this.writeNode("wcs:TimeResolution",timePeriod.resolution,node);}
+return node;},"BeginPosition":function(begin){var node=this.createElementNSPlus("wcs:BeginPosition",{value:begin});return node;},"EndPosition":function(end){var node=this.createElementNSPlus("wcs:EndPosition",{value:end});return node;},"TimeResolution":function(resolution){var node=this.createElementNSPlus("wcs:TimeResolution",{value:resolution});return node;},"Output":function(output){var node=this.createElementNSPlus("wcs:Output",{attributes:{format:output.format,store:output.store}});if(output.gridCRS){this.writeNode("wcs:GridCRS",output.gridCRS,node);}
+return node;},"GridCRS":function(gridCRS){var node=this.createElementNSPlus("wcs:GridCRS",{});this.writeNode("wcs:GridBaseCRS",gridCRS.baseCRS,node);if(gridCRS.type){this.writeNode("wcs:GridType",gridCRS.type,node);}
+if(gridCRS.origin){this.writeNode("wcs:GridOrigin",gridCRS.origin,node);}
+this.writeNode("wcs:GridOffsets",gridCRS.offsets,node);if(gridCRS.CS){this.writeNode("wcs:GridCS",gridCRS.CS,node);}
+return node;},"GridBaseCRS":function(baseCRS){return this.createElementNSPlus("wcs:GridBaseCRS",{value:baseCRS});},"GridOrigin":function(origin){return this.createElementNSPlus("wcs:GridOrigin",{value:origin});},"GridType":function(type){return this.createElementNSPlus("wcs:GridType",{value:type});},"GridOffsets":function(offsets){return this.createElementNSPlus("wcs:GridOffsets",{value:offsets});},"GridCS":function(CS){return this.createElementNSPlus("wcs:GridCS",{value:CS});}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WCSGetCoverage"});OpenLayers.Control.AgsGeometryService=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,geometryServiceType:"buffer",initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'bufferSpatialReference':null,'distances':[1],'features':null,'outSpatialReference
 ':null,'unionResults':false,'unit':"UNIT_KILOMETER",'spatialRelationship':"INTERSECTION",'inSpatialReference':"EPSG:4326",'comparisonString':null};this._resultsParser={'parser':this.adapter.parseAgsGraphics,'context':this.adapter};this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsGeometryService=new esri.tasks.GeometryService(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{switch(this.geometryServiceType){case"buffer":_taskParameters['bufferSpatialRefer
 ence']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['bufferSpatialReference'];_taskParameters['features']=olFeatures?olFeatures:_taskParameters['features'];var agsBufferParameters=this.adapter.encodeAgsBufferParameters(_taskParameters);agsGeometryService.buffer(agsBufferParameters,_onExecuteComplete,_onCompleteError);break;case"project":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];_taskParameters['outSpatialReference']=_taskParameters['outSpatialReference']||_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);var agsSpatialReference=this.adapter.encodeAgsSpatialReference(_taskParameters['outSpatialReference']);agsGeometryService.project(agsGraphics,agsSpatialReference,_onExecuteComplete,_onCompleteError);break;case"relation":_taskParameters['inSpatialReference']=this.layer.map[
 'projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics1=this.adapter.encodeAgsGraphics([olFeatures[0]],_taskParameters['inSpatialReference']);var agsGraphics2=this.adapter.encodeAgsGraphics([olFeatures[1]],_taskParameters['inSpatialReference']);var agsGeometryRelationship=this.adapter.encodeAgsGeometrySpatialRelationship(_taskParameters['spatialRelationship']);var agsComparisonString=_taskParameters['comparisonString'];agsGeometryService.relation(agsGraphics1,agsGraphics2,agsGeometryRelationship,agsComparisonString,_onExecuteComplete,_onCompleteError);break;case"areasAndLengths":case"lengths":case"simplify":case"labelPoints":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);agsGeometryService[this.geometryServiceType].apply(agsGeometryService,[agsGraphics,
 _onExecuteComplete,_onCompleteError]);break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...");return;}}catch(e){throw e;}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsGeometryService...");throw"...'asynchronous' should always be set to 'false' for AgsGeometryService...";}},setGeometryServiceType:function(geometryServiceType){this.geometryServiceType=geometryServiceType||this.geometryServiceType;switch(this.geometryServiceType){case"buffer":case"labelPoints":case"project":case"simplify":this._resultsParser['parser']=this.adapter.parseAgsGraphics;break;case"relation":this._resultsParser['parser']=this.adapter.parseAgsResults.relations;break;case"areasAndLengths":case"lengths":this._resultsParser['parser']=this.adapter.parseAgsResults.areasAndLengths;break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometrySe
 rviceType() with valid geometryServiceType...");return;}},CLASS_NAME:"OpenLayers.Control.AgsGeometryService"});OpenLayers.Control.AgsLocator=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,reverseGeocoding:false,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'address':{},'distance':50,'outFields':[],'location':null};if(this.reverseGeocoding==true){this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidate'],'context':this.adapter};}else{this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidates'],'context':this.adapter};}
+this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsLocator=new esri.tasks.Locator(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;if(this.reverseGeocoding==true){if(olFeatures[0]instanceof OpenLayers.Feature.Vector&&olFeatures[0].geometry instanceof OpenLayers.Geometry.Point){_taskParameters['location']=olFeatures[0].geometry;}
+if(!_taskParameters['location']){OpenLayers.Console.error("...'location' missing or invalid...");throw"...'location' missing or invalid...";}
+if(!_taskParameters['distance']){OpenLayers.Console.error("...'distance' missing or invalid...");throw"...'distance' missing or invalid...";}
+var agsLocation=null;agsLocation=this.adapter.encodeAgsLocation(_taskParameters['location']);agsLocator.locationToAddress(agsLocation,_taskParameters['distance'],_onExecuteComplete,_onCompleteError);}else{if(!_taskParameters['address']){OpenLayers.Console.error("...'address' missing or invalid...");throw"...'address' missing or invalid...";}
+if(!_taskParameters['outFields']){OpenLayers.Console.error("...'outFields' missing or invalid...");throw"...'outFields' missing or invalid...";}
+agsLocator.addressToLocations(_taskParameters['address'],_taskParameters['outFields'],_onExecuteComplete,_onCompleteError);}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator...");throw"...'asynchronous' should always be set to 'false' for AgsLocator...";}},setReverseGeocoding:function(reverseGeocoding){if(reverseGeocoding==true){this.reverseGeocoding=true;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidate'];}else{this.reverseGeocoding=false;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidates'];}},CLASS_NAME:"OpenLayers.Control.AgsLocator"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.for
 mat){this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}
+if(!options.geometryName&&parseFloat(this.format.version)>1.0){this.setGeometryName(null);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
+this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",options)]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),params:options.params,headers:options.headers,data:data});return response;},setFeatureType:function(featureType){this.featureType=featureType;this.format.featureType=featureType;},setGeometryName:function(geometryName){this.geometryName=geometryName;this.format.geometryName=geometryName;},handleRead:function(response,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);if(options.callb
 ack){var request=response.priv;if(request.status>=200&&request.status<300){var result=this.parseResponse(request,options.readOptions);if(result&&result.success!==false){if(options.readOptions&&options.readOptions.output=="object"){OpenLayers.Util.extend(response,result);}else{response.features=result;}
+response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;response.error=result;}}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
+options.callback.call(options.scope,response);}},parseResponse:function(request,options){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(!doc||doc.length<=0){return null;}
+var result=(this.readFormat!==null)?this.readFormat.read(doc):this.format.read(doc,options);if(!this.featureNS){var format=this.readFormat||this.format;this.featureNS=format.featureNS;format.autoConfig=false;if(!this.geometryName){this.setGeometryName(format.geometryName);}}
+return result;},commit:function(features,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:features});response.priv=OpenLayers.Request.POST({url:options.url,headers:options.headers,data:this.format.write(features,options),callback:this.createCallback(this.handleCommit,response,options)});return response;},handleCommit:function(response,options){if(options.callback){var request=response.priv;var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+var obj=this.format.read(data)||{};response.insertIds=obj.insertIds||[];if(obj.success){response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;response.error=obj;}
+options.callback.call(options.scope,response);}},filterDelete:function(filter,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit"});var root=this.format.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var deleteNode=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(options.featureNS?this.featurePrefix+":":"")+
+options.featureType}});if(options.featureNS){deleteNode.setAttribute("xmlns:"+this.featurePrefix,options.featureNS);}
+var filterNode=this.format.writeNode("ogc:Filter",filter);deleteNode.appendChild(filterNode);root.appendChild(deleteNode);var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[root]);return OpenLayers.Request.POST({url:this.url,callback:options.callback||function(){},data:data});},abort:function(response){if(response){response.priv.abort();}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this
 .loadGML();}},loadGML:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this});this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){OpenLayers.Console.userError('Error in loading GML file '+this.url);this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Format.WFSTWithLock=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFSTWithLock.DEFAULTS);var cls=OpenLayers.Format.WFSTWithLock["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFSTWithLock version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WFSTWithLock.DEFAULTS={"version":"1.1.0"};OpenLayers.Format.WFSTWithLock.v1=OpenLayers.Class(OpenLayers.Format.WFST.v1,{lockExpiry:"1",releaseAction:"ALL",attributes:{},attribute_alias:{},encodeAttributes:false,xy:false,initialize:function(options){if(options.featureNS){this.namespaces=OpenLayers.Util.extend({feature:options.featureNS},OpenLayers.Format.WFST.v1.prototype.namespaces);}
+OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);this.namespaces[this.featurePrefix]=this.featureNS;OpenLayers.Util.extend(this,{readOgcExpression:this.readOgcExpression||OpenLayers.Format.Filter.v1.prototype.readOgcExpression,getFilterType:this.getFilterType||OpenLayers.Format.Filter.v1.prototype.getFilterType,filterMap:this.filterMap||OpenLayers.Format.Filter.v1.prototype.filterMap,setGeometryTypes:this.setGeometryTypes||OpenLayers.Format.GML.Base.prototype.setGeometryTypes,regExes:this.regExes||OpenLayers.Format.GML.Base.prototype.regExes});OpenLayers.Format.GML.Base.prototype.setGeometryTypes.call(this);this.geometryTypes['OpenLayers.Geometry.MultiLineString']="MultiCurve";this.geometryTypes['OpenLayers.Geometry.MultiPolygon']="MultiSurface";if(this.schema&&this.schema!=""){OpenLayers.loadURL(this.schema,null,null,OpenLayers.Function.bind(function(request){var schema_format=new OpenLayers.Format.WFSDescribeFeatureType();var schema=schema_format.read(r
 equest.responseXML||request.responseText);this.attributes={};if(schema.targetNamespace==this.featureNS&&schema.targetPrefix==this.featurePrefix){for(var i=0;i<schema.featureTypes.length;i++){var featureType=schema.featureTypes[i];if(featureType.typeName==this.featureType){for(var j=0;j<featureType.properties.length;j++){if(featureType.properties[j].type.split(":")[0]!="gml"){this.attributes[featureType.properties[j].name]=featureType.properties[j];}}
+return;}}}},this));}},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var obj={};this.readNode(data,obj);var lockIdValue=obj.lockId;if(obj.features&&options.output==="features"){obj=obj.features;for(var i=0;i<obj.length;i++){obj[i].lockId=lockIdValue;}}
+return obj;},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.features=[];var lockIdValue=node.getAttribute("lockId");obj.lockId=(lockIdValue==="")?null:lockIdValue;this.readChildNodes(node,obj);}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"])},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeatureWithLock":function(options){var node=this.createElementNSPlus("wfs:GetFeatureWithLock",{attributes:{service:"WFS",version:this.version,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,expiry:this.lockExpiry,"xsi:schemaLocation":this.schemaLocationAttr()}});this.writeNode("Query",options,node);return node;},"Transaction":function(features){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,releaseAction:this.releaseAction}});if(features){var name;var feature;var hasCommonLockId=true;var lockIds={};hasCommonLockId=false;for(var i=0,len=features.length;i
 <len;++i){feature=features[i];if(features[i].lockId===null){break;}
+lockIds[features[i].lockId]=features[i].lockId;}
+var count=0;var lockId=null;for(var key in lockIds){if(lockId!=lockIds[key]){count++;lockId=lockIds[key];}}
+if(count==1&&lockId!=null&&lockId!=""){hasCommonLockId=true;}
+if(hasCommonLockId===true){if(lockId!="__insert__"){this.writeNode("LockId",lockId,node);}
+for(var i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,feature,node);}}}}
+return node;},"UnlockFeature":function(options){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,releaseAction:this.releaseAction}});this.writeNode("LockId",options.lockId,node);return node;},"LockId":function(lockId){var node=this.createElementNSPlus("wfs:LockId",{attributes:{},value:lockId});return node;}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"])},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1"});OpenLayers.Format.WFSTWithLock.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFSTWithLock.v1,{version:"1.1.0",schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},xy:false,initialize:function(options){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFSTWithLock.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.numberOfFeatures=parseInt(node.getAt
 tribute("numberOfFeatures"));OpenLayers.Format.WFSTWithLock.v1.prototype.readers["wfs"]["FeatureCollection"].apply(this,arguments);},"TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"TransactionSummary":function(node,obj){obj.success=true;},"InsertResults":function(node,obj){this.readChildNodes(node,obj);},"Feature":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);}},OpenLayers.Format.WFSTWithLock.v1.prototype.readers["wfs"]),"gml":OpenLayers.Util.applyDefaults({srsName:this.srsName},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeature":function(options){var node=OpenLayers.Format.WFSTWithLock.v1.prototype.writers["wfs"]["GetFeature"].apply(this,arguments);options&&options.re
 sultType&&this.setAttributes(node,{resultType:options.resultType});return node;},"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
+options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
+if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
+if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
+return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFSTWithLock.v1.prototype.writers["wfs"]),"gml":OpenLayers.Util.applyDefaults({},OpenLayers.Format.GML.v3.prototype.writers["gml"]),"feature":OpenLayers.Util.applyDefaults({"_typeName":function(feature){var node=this.createElementNSPlus(this.featurePrefix+":"+this.featureType,{attributes:{fid:feature.fid}});if(feature.geometry){this.writeNode("feature:_geometry",feature.geometry,node);}
+if(this.encodeAttributes==true){for(var name in feature.attributes){var value=feature.attributes[name];if(this.attributes[name]){if(value!=null){this.writeNode("feature:_attribute",{name:name,value:value},node);}}else if(this.attributes[this.attribute_alias[name]]){if(value!=null){this.writeNode("feature:_attribute",{name:this.attribute_alias[name],value:value},node);}}}}
+return node;},"_geometry":function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone().transform(this.internalProjection,this.externalProjection);}
+var node=this.createElementNSPlus(this.featurePrefix+":"+this.geometryName);var type=this.geometryTypes[geometry.CLASS_NAME];var child=this.writeNode("gml:"+type,geometry,node);if(this.srsName){child.setAttribute("srsName",this.srsName);}
+return node;},"_attribute":function(obj){return this.createElementNSPlus(this.featurePrefix+":"+obj.name,{value:obj.value});}},OpenLayers.Format.GML.v3.prototype.writers["feature"]),"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1_1_0"});OpenLayers.Control.PanPanel=OpenLayers.Class(OpenLayers.Control.Panel,{slideFactor:50,slideRatio:null,initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);var options={slideFactor:this.slideFactor,slideRatio:this.slideRatio};this.addControls([new OpenLayers.Control.Pan(OpenLayers.Control.Pan.NORTH,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.SOUTH,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.EAST,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.WEST,options)]);},CLASS_NAME:"OpenLayers.Control.PanPanel"});OpenLayers.Strategy.Lock=OpenLayers.Class(OpenLayers.Strategy,{response:null,lockedFeatures:[],_st
 yleMap:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var canReadWithLock=(typeof this.layer.protocol.readWithLock=="function")?true:false;var canUnLock=(typeof this.layer.protocol.unlock=="function")?true:false;if(!this.layer.protocol||canReadWithLock==false||canUnLock==false){OpenLayers.Console.error("...can not activate Lock strategy...vector layer protocol does not support readWithLock or unlock interfaces...");return false;}
+var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.addEventType("afterfeatureslocked");this.layer.events.addEventType("afterfeaturesunlocked");this.layer.getFeatureByFid=OpenLayers.Function.bind(function(fid){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i].fid&&this.features[i].fid==fid){feature=this.features[i];break;}}
+return feature;},this.layer);this.layer.getSelectedFeatureByFid=OpenLayers.Function.bind(function(fid){var feature=null;for(var i=0,len=this.selectedFeatures.length;i<len;++i){if(this.selectedFeatures[i].fid&&this.selectedFeatures[i].fid==fid){feature=this.selectedFeatures[i];break;}}
+return feature;},this.layer);this.layer.events.on({"beforefeatureselected":this.synchronizeFeaturesStyle,"featureselected":this.synchronizeFeaturesStyle,"featureunselected":this.synchronizeFeaturesStyle,"afterfeatureslocked":this.synchronizeFeatures,"afterfeaturesunlocked":this.synchronizeFeatures,scope:this});this._styleMap=this.layer.styleMap||new OpenLayers.StyleMap();this._defaultStyle=this._styleMap.styles['default'];this._selectStyle=this._styleMap.styles['select'];if(this._styleMap.styles['locked']){this._lockedStyle=this._styleMap.styles['locked'];}else if(this.options&&this.options.styleMap){this._lockedStyle=this.options.styleMap.styles['locked']||this._styleMap.styles['temporary'];}else{this._lockedStyle=this._styleMap.styles['temporary'];}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.getFeatureByFid=null;this.layer.getSelectedFeatureByFid=null;this.layer.events.un({"beforefeatureselected":this.synchronizeFeaturesStyle,"featureselected":this.synchronizeFeaturesStyle,"featureunselected":this.synchronizeFeaturesStyle,"afterfeatureslocked":this.synchronizeFeatures,"afterfeaturesunlocked":this.synchronizeFeatures,scope:this});this._styleMap=null;this._defaultStyle=null;this._selectStyle=null;this._lockedStyle=null;}
+return deactivated;},isFeatureLocked:function(feature){if(feature.lockId&&feature.lockId!==""){OpenLayers.Console.log("...feature: "+feature.fid+"...is locked with lockId: "+feature.lockId+"...");return true;}else{OpenLayers.Console.log("...feature: "+feature.fid+"...is not locked...");return false;}},lockFeatures:function(features){if(this.active==true){var featureIdfilter=this.createFeatureIdFilter(features);if(this.response&&this.response.priv&&typeof this.response.priv.abort=="function"){this.response.priv.abort();}
+this.response=this.layer.protocol.readWithLock({filter:featureIdfilter,callback:this.onFeaturesLocked,scope:this});}else{OpenLayers.Console.error("...can not call lockFeatures...Lock strategy is not activated...");throw"...can not call lockFeatures...Lock strategy is not activated...";}},lockFeaturesWithinExtent:function(features){},unlockFeatures:function(features){if(this.active==true){if(this.response&&this.response.priv&&typeof this.response.priv.abort=="function"){this.response.priv.abort();}
+var lockIds={};for(var i=0;i<features.length;i++){var lockId=features[i].lockId;if(lockId&&lockIds[lockId]==null){lockIds[lockId]=lockId;}}
+for(var key in lockIds){this.response=this.layer.protocol.unlock({lockId:lockIds[key],callback:this.onFeaturesUnlocked,scope:this});}}else{OpenLayers.Console.error("...can not call unlockFeatures...Lock strategy is not activated...");throw"...can not call unlockFeatures...Lock strategy is not activated...";}},unlockAllFeatures:function(){this.unlockFeatures(this.lockedFeatures);},onFeaturesLocked:function(response){if(response.success()&&response.features){for(var i=0;i<response.features.length;i++){var lockedFeature=response.features[i];if(lockedFeature.lockId&&lockedFeature.lockId!=""){this.lockedFeatures.push(lockedFeature);}}
+var evt={};evt.features=response.features;this.layer.events.triggerEvent("afterfeatureslocked",evt);}else{OpenLayers.Console.log("...lock features failed...");}},onFeaturesUnlocked:function(response){if(response.success()){OpenLayers.Console.log("...locked features with lockId "+response.lockId+" are unlocked...");var evt={lockId:response.lockId};this.layer.events.triggerEvent("afterfeaturesunlocked",evt);this.layer.events.triggerEvent("refresh",{force:true});}else{OpenLayers.Console.log("...unlock features with lockId "+response.lockId+" failed...");}},synchronizeFeatures:function(evt){switch(evt.type){case"afterfeatureslocked":for(var i=0;i<this.lockedFeatures.length;i++){var fid=this.lockedFeatures[i].fid;var lockedFeature=this.layer.getFeatureByFid(fid);if(lockedFeature){this.layer.eraseFeatures([lockedFeature]);this.layer.removeFeatures([lockedFeature],{slient:false});var clonedFeature=this.lockedFeatures[i].clone();clonedFeature.fid=this.lockedFeatures[i].fid;clonedFea
 ture.lockId=this.lockedFeatures[i].lockId;clonedFeature.style=this._lockedStyle.createSymbolizer(clonedFeature);this.layer.addFeatures([clonedFeature],{slient:false});}}
+OpenLayers.Console.log("...total features number: "+this.layer.features.length
++"...locked features number: "+this.lockedFeatures.length
++"...selected features number: "+this.layer.selectedFeatures.length);break;case"afterfeaturesunlocked":var __featuresStillLocked=[];for(var i=0;i<this.lockedFeatures.length;i++){var lockId=this.lockedFeatures[i].lockId;var fid=this.lockedFeatures[i].fid;if(lockId==evt.lockId){var unlockedFeature=this.layer.getFeatureByFid(fid);unlockedFeature.style=null;unlockedFeature.lockId=null;if(this.layer.getSelectedFeatureByFid(fid)){this.layer.drawFeature(unlockedFeature,this._selectStyle.createSymbolizer(unlockedFeature));}else{this.layer.drawFeature(unlockedFeature,this._defaultStyle.createSymbolizer(unlockedFeature));}}else{__featuresStillLocked.push(this.lockedFeatures[i]);}}
+this.lockedFeatures=null;this.lockedFeatures=__featuresStillLocked;OpenLayers.Console.log("...total features number: "+this.layer.features.length
++"...selected features number: "+this.layer.selectedFeatures.length);break;default:break;}},synchronizeFeaturesStyle:function(evt){switch(evt.type){case"beforefeatureselected":if(evt.feature.lockId&&evt.feature.lockId!=""){evt.feature.style=null;}
+break;case"featureselected":if(evt.feature.lockId&&evt.feature.lockId!=""){evt.feature.style=this._lockedStyle.createSymbolizer(evt.feature);}
+break;default:break;}},createFeatureIdFilter:function(features){var fids=[];for(var i=0;i<features.length;i++){if(features[i].fid){fids.push(features[i].fid);}}
+var filter=new OpenLayers.Filter.FeatureId({fids:fids});return filter;},createBBOXFilter:function(bounds){},setStyleMap:function(styleMap){if(styleMap){this._defaultStyle=styleMap.styles['default']||this._defaultStyle;this._selectStyle=styleMap.styles['select']||this._selectStyle;this._lockedStyle=styleMap.styles['locked']||this._lockedStyle;}},CLASS_NAME:"OpenLayers.Strategy.Lock"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});thi
 s.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
+this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,updateDimensions:function(zoomChanged){var mapExtent=this.map.getExtent();var renderExtent=mapExtent.scale(3);this.setExtent(renderExtent,true);var res=this.getResolution();var div=this.rendererRoot.parentNode;var layerLeft=parseFloat(div.parentNode.style.left);var layerTop=parseFloat(div.parentNode.style.top);div.style.left=((renderExtent.left-mapExtent.left)/res-layerLeft)+"px";div.style.top=((mapExtent.top-renderExtent.top)/res-layerTop)+"px";},setSize:function(){this.map.getExtent()&&this.updateDimensions();},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+if(feature.geometry){var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(rendered!==false&&style.label){var location=feature.geometry.getCentroid();this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
+return rendered;}},drawText:function(featureId,style,location){var label;if(typeof featureId!=="string"){label=featureId;}else{label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,this.labelNodeType);label._featureId=featureId;}
+label._style=style;label._x=location.x;label._y=location.y;if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
+if(label.parentNode!==this.textRoot){this.textRoot.appendChild(label);}
+return label;},CLASS_NAME:"OpenLayers.Renderer.NG"});OpenLayers.Renderer.SVG2=OpenLayers.Class(OpenLayers.Renderer.NG,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",symbolMetrics:null,labelNodeType:"g",initialize:function(containerID){if(!this.supported()){return;}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},updateDimensions:function(zoomChanged){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var res=this.getResolution();var width=this.extent.getWidth();var height=this.extent.getHeight();var extentString=[this.extent.left,-this.extent.top,width,height].join(" ");this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.rendererRoot.setAttributeNS(null,"width",width/res);this.rendererRoot.setAttributeNS(null,"height",height/res);if(zoomChanged===true){var i,len;var nodes=this.vectorRoot.childNodes;for(i=0,len=nodes.length;i<len;++i){this.setStyle(nodes[i]);}
+var textNodes=this.textRoot.childNodes;var label;for(i=0,len=textNodes.length;i<len;++i){label=textNodes[i];this.drawText(label,label._style,new OpenLayers.Geometry.Point(label._x,label._y));}}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
+break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
+return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var resolution=this.getResolution();var r=node._radius;var widthFactor=resolution;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}
+if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;width*=resolution;height*=resolution;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset*resolution:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset*resolution:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",node._x+xOffset);node.setAttributeNS(null,"y",node._y+yOffset);node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);node.onclick=OpenLayers.Renderer.SVG2.preventDefault;}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3*resolution;var size=offset*2;var src=this.importSymbol(style.graphicName);widthFactor=this.symbolMetrics[src.id]
 .size*3/size*resolution;var parent=node.parentNode;var nextSibling=node.nextSibling;if(parent){parent.removeChild(node);}
+node.firstChild&&node.removeChild(node.firstChild);node.appendChild(src.firstChild.cloneNode(true));node.setAttributeNS(null,"viewBox",src.getAttributeNS(null,"viewBox"));node.setAttributeNS(null,"width",size);node.setAttributeNS(null,"height",size);node.setAttributeNS(null,"x",node._x-offset);node.setAttributeNS(null,"y",node._y-offset);if(nextSibling){parent.insertBefore(node,nextSibling);}else if(parent){parent.appendChild(node);}}else{node.setAttributeNS(null,"r",style.pointRadius*resolution);}
+var rotation=style.rotation;if(rotation!==undefined||node._rotation!==undefined){node._rotation=rotation;rotation|=0;if(node.nodeName!=="svg"){node.setAttributeNS(null,"transform",["rotate(",rotation,node._x,node._y,")"].join(" "));}else{var metrics=this.symbolMetrics[src.id];node.firstChild.setAttributeNS(null,"transform",["rotate(",rotation,metrics.x,metrics.y,")"].join(" "));}}}
+if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
+if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth*widthFactor);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap||"round");node.setAttributeNS(null,"stroke-linejoin","round");style.strokeDashstyle&&node.setAttributeNS(null,"stroke-dasharray",this.dashStyle(style,widthFactor));}else{node.setAttributeNS(null,"stroke","none");}
+if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
+if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
+return node;},dashStyle:function(style,widthFactor){var w=style.strokeWidth*widthFactor;var str=style.strokeDashstyle;switch(str){case'solid':return'none';case'dot':return[widthFactor,4*w].join();case'dash':return[4*w,4*w].join();case'dashdot':return[4*w,4*w,widthFactor,4*w].join();case'longdash':return[8*w,4*w].join();case'longdashdot':return[8*w,4*w,widthFactor,4*w].join();default:var parts=OpenLayers.String.trim(str).split(/\s+/g);for(var i=0,ii=parts.length;i<ii;i++){parts[i]=parts[i]*widthFactor;}
+return parts.join();}},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
+return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"g");},createDefs:function(){var defs=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(defs);return defs;},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var x=geometry.x;var y=-geometry.y;node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node._x=x;node._y=y;node._radius=radius;return node;},drawLineString:function(node,geometry){var path=this.getComponentsString(geometry.components);node.setAttributeNS(null,"points",path);return node;},drawLinearRing:function(node,geometry){var path=this.getComponentsString(geometry.components);node.setAttributeNS(null,"points",path);return node;},drawPolygon:function(node,geometry
 ){var d=[];var draw=true;var complete=true;var linearRingResult,path;for(var j=0,len=geometry.components.length;j<len;j++){d.push("M");path=this.getComponentsString(geometry.components[j].components," ");d.push(path);}
+d.push("z");node.setAttributeNS(null,"d",d.join(" "));node.setAttributeNS(null,"fill-rule","evenodd");return node;},drawRectangle:function(node,geometry){node.setAttributeNS(null,"x",geometry.x);node.setAttributeNS(null,"y",-geometry.y);node.setAttributeNS(null,"width",geometry.width);node.setAttributeNS(null,"height",geometry.height);return node;},drawSurface:function(node,geometry){var d=[];var draw=true;for(var i=0,len=geometry.components.length;i<len;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);d.push("M",component);}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);d.push("C",component);}else{var component=this.getShortString(geometry.components[i]);d.push(component);}}
+d.push("Z");node.setAttributeNS(null,"d",d.join(" "));return node;},drawText:function(featureId,style,location){var g=OpenLayers.Renderer.NG.prototype.drawText.apply(this,arguments);var text=g.firstChild||this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_text","text");var res=this.getResolution();text.setAttributeNS(null,"x",location.x/res);text.setAttributeNS(null,"y",-location.y/res);g.setAttributeNS(null,"transform","scale("+res+")");if(style.fontColor){text.setAttributeNS(null,"fill",style.fontColor);}
+if(style.fontOpacity){text.setAttributeNS(null,"opacity",style.fontOpacity);}
+if(style.fontFamily){text.setAttributeNS(null,"font-family",style.fontFamily);}
+if(style.fontSize){text.setAttributeNS(null,"font-size",style.fontSize);}
+if(style.fontWeight){text.setAttributeNS(null,"font-weight",style.fontWeight);}
+if(style.fontStyle){text.setAttributeNS(null,"font-style",style.fontStyle);}
+if(style.labelSelect===true){text.setAttributeNS(null,"pointer-events","visible");text._featureId=featureId;}else{text.setAttributeNS(null,"pointer-events","none");}
+var align=style.labelAlign||"cm";text.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG2.LABEL_ALIGN[align[0]]||"middle");if(OpenLayers.IS_GECKO===true){text.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG2.LABEL_ALIGN[align[1]]||"central");}
+var labelRows=style.label.split('\n');var numRows=labelRows.length;while(text.childNodes.length>numRows){text.removeChild(text.lastChild);}
+for(var i=0;i<numRows;i++){var tspan=text.childNodes[i]||this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_tspan_"+i,"tspan");if(style.labelSelect===true){tspan._featureId=featureId;}
+if(OpenLayers.IS_GECKO===false){tspan.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG2.LABEL_VSHIFT[align[1]]||"-35%");}
+tspan.setAttribute("x",location.x/res);if(i==0){var vfactor=OpenLayers.Renderer.SVG2.LABEL_VFACTOR[align[1]];if(vfactor==null){vfactor=-.5;}
+tspan.setAttribute("dy",(vfactor*(numRows-1))+"em");}else{tspan.setAttribute("dy","1em");}
+tspan.textContent=(labelRows[i]==='')?' ':labelRows[i];if(!tspan.parentNode){text.appendChild(tspan);}}
+if(!text.parentNode){g.appendChild(text);}
+return g;},getComponentsString:function(components,separator){var len=components.length;var strings=new Array(len);for(var i=0;i<len;i++){strings[i]=this.getShortString(components[i]);}
+return strings.join(separator||",");},getShortString:function(point){return point.x+","+(-point.y);},importSymbol:function(graphicName){if(!this.defs){this.defs=this.createDefs();}
+var id=this.container.id+"-"+graphicName;var existing=document.getElementById(id);if(existing!=null){return existing;}
+var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
+var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0,len=symbol.length;i<len;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
+node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]={size:Math.max(width,height),x:symbolExtent.getCenterLonLat().lon,y:symbolExtent.getCenterLonLat().lat};this.defs.appendChild(symbolNode);return symbolNode;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot&&target.parentNode._featureId;}
+return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG2"});OpenLayers.Renderer.SVG2.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG2.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG2.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG2.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){clearInterval(this.timerId);this.timerId=undefined;this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>this.nbPoints){this.points.pop();}},end:function(xy){var last,now=new Date().getTime();for(var i=0,l=this.points.length,point;i<l;i++){point=this.points[i];if(now-point.tick>this.delay){break;}
+last=point;}
+if(!last){return;}
+var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
+Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
+var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
+return{speed:speed,theta:theta};},move:function(info,callback){var v0=info.speed;var fx=Math.cos(info.theta);var fy=-Math.sin(info.theta);var time=0;var initialTime=new Date().getTime();var lastX=0;var lastY=0;var timerCallback=function(){if(this.timerId==null){return;}
+time+=this.interval;var realTime=new Date().getTime()-initialTime;var t=(time+realTime)/2.0;var p=(-this.deceleration*Math.pow(t,2))/2.0+v0*t;var x=p*fx;var y=p*fy;var args={};args.end=false;var v=-this.deceleration*t+v0;if(v<=0){clearInterval(this.timerId);this.timerId=null;args.end=true;}
+args.x=x-lastX;args.y=y-lastY;lastX=x;lastY=y;callback(args.x,args.y,args.end);};this.timerId=window.setInterval(OpenLayers.Function.bind(timerCallback,this),this.interval);},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Protocol.WFSTWithLock=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.WFSTWithLock.DEFAULTS);var cls=OpenLayers.Protocol.WFSTWithLock["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFSTWithLock version: "+options.version;}
+OpenLayers.Protocol.WFSTWithLock.fromWMSLayer=OpenLayers.Protocol.WFS.fromWMSLayer;OpenLayers.Protocol.WFSTWithLock.DEFAULTS={"version":"1.1.0"};OpenLayers.Protocol.WFSTWithLock.v1=new OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:null,srsName:"urn:x-ogc:def:crs:EPSG:6.9:4326",bboxSrsName:"urn:x-ogc:def:crs:EPSG:6.9:4326",featureType:null,featureNS:"http://www.esri.com",geometryName:"Shape",featurePrefix:"esri",formatOptions:{xy:false,lockExpiry:"1",releaseAction:"ALL"},initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.format){this.format=OpenLayers.Format.WFSTWithLock(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}
+if(!this.featureNS&&this.featurePrefix){var readNode=this.format.readNode;this.format.readNode=function(node,obj){if(!this.featureNS&&node.prefix==this.featurePrefix){this.featureNS=node.namespaceURI;this.setNamespace("feature",this.featureNS);}
+return readNode.apply(this,arguments);};}},readWithLock:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"readWithLock"});var req_node=this.format.writeNode("wfs:GetFeatureWithLock",options);var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[req_node]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleReadWithLock,response,options),params:options.params,headers:options.headers,data:data});return response;},unlock:function(options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);OpenLayers.Console.log("...wfs:Transaction request...");var req_node=this.format.writeNode("wfs:UnlockFeature",options);OpenLayers.Console.dirxml(req_node);var data=OpenLayers.Format.XML.prototype.write.apply(this.f
 ormat,[req_node]);var response=new OpenLayers.Protocol.Response({requestType:"unlock",lockId:options.lockId});response.priv=OpenLayers.Request.POST({url:options.url,data:data,callback:this.createCallback(this.handleUnlock,response,options)});return response;},commitWithLock:function(features,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var lockIds={};var responses={};for(var i=0;i<features.length;i++){if(features[i].lockId&&features[i].lockId!=""){if(lockIds[features[i].lockId]==null){lockIds[features[i].lockId]=[];}
+lockIds[features[i].lockId].push(features[i]);}else if(features[i].state==OpenLayers.State.INSERT){if(lockIds['__insert__']==null){lockIds['__insert__']=[];}
+features[i].lockId="__insert__";lockIds['__insert__'].push(features[i]);}else{}}
+for(var key in lockIds){if(key&&key!==""){var featuresWithCommonLockId=lockIds[key];responses[key]=new OpenLayers.Protocol.Response({requestType:"commitWithLock",reqFeatures:featuresWithCommonLockId,lockId:key});var req_node=this.format.writeNode("wfs:Transaction",featuresWithCommonLockId);var data=OpenLayers.Format.XML.prototype.write.apply(this,[req_node]);responses[key].priv=OpenLayers.Request.POST({url:options.url,data:data,callback:this.createCallback(this.handleCommitWithLock,responses[key],options)});}}
+return responses;},filterDeleteWithLock:function(filter,options){},handleReadWithLock:function(response,options){this.handleRead(response,options);},handleUnlock:function(response,options){var request=response.priv;this.handleCommit(response,options);},handleCommitWithLock:function(response,options){var request=response.priv;this.handleCommit(response,options);},CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1"});OpenLayers.Format.WFSTWithLock.v1_0_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,OpenLayers.Format.WFSTWithLock.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},xy:true,initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFSTWithLock.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChild
 Nodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFSTWithLock.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
+options.featureType}});if(options.srsNameInQuery&&options.srsName){node.setAttribute("srsName",options.srsName);}
+if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
+if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("ogc:PropertyName",{property:options.propertyNames[i]},node);}}
+return node;}},OpenLayers.Format.WFSTWithLock.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Util.applyDefaults({"_typeName":function(feature){var node=this.createElementNSPlus(this.featurePrefix+":"+this.featureType,{attributes:{fid:feature.fid}});if(feature.geometry){this.writeNode("feature:_geometry",feature.geometry,node);}
+for(var name in feature.attributes){var value=feature.attributes[name];if(this.attributes[name]){if(value!=null){this.writeNode("feature:_attribute",{name:name,value:value},node);}}else if(this.attributes[this.attribute_alias[name]]){if(value!=null){this.writeNode("feature:_attribute",{name:this.attribute_alias[name],value:value},node);}}}
+return node;},"_attribute":function(obj){return this.createElementNSPlus(this.featurePrefix+":"+obj.name,{value:obj.value});}},OpenLayers.Format.GML.v2.prototype.writers["feature"]),"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFSTWithLock.v1_0_0"});OpenLayers.Protocol.WFSTWithLock.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFSTWithLock.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1_0_0"});OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){OpenLayers.Console.userError(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){if(typeof params=='string'){params=OpenLayers.Util.getParameters(params);}
+var success=(onComplete)?onComplete:OpenLayers.nullHandler;var failure=(onFailure)?onFailure:OpenLayers.nullHandler;return OpenLayers.Request.GET({url:uri,params:params,success:success,failure:failure,scope:caller});};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
+req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
+this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=Op
 enLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
+this.transport=OpenLayers.Ajax.getTransport();this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=OpenLayers.Util.extend({},this.options.parameters);if(this.method!='get'&&this.method!='post'){params['_method']=this.method;this.method='post';}
+this.parameters=params;if(params=OpenLayers.Util.getParameterString(params)){if(this.method=='get'){this.url+=((this.url.indexOf('?')>-1)?'&':'?')+params;}else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){params+='&_=';}}
+try{var response=new OpenLayers.Ajax.Response(this);if(this.options.onCreate){this.options.onCreate(response);}
+OpenLayers.Ajax.Responders.dispatch('onCreate',this,response);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous){window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,this,1),10);}
+this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType){this.onStateChange();}}catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete)){this.respondToReadyState(this.transport.readyState);}},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','Accept':'text/javascript, text/html, application/xml, text/xml, */*','OpenLayers':true};if(this.method=='post'){headers['Content-type']=this.options.contentType+
+(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005){headers['Connection']='close';}}
+if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function'){for(var i=0,length=extras.length;i<length;i+=2){headers[extras[i]]=extras[i+1];}}else{for(var i in extras){headers[i]=extras[i];}}}
+for(var name in headers){this.transport.setRequestHeader(name,headers[name]);}},success:function(){var status=this.getStatus();return!status||(status>=200&&status<300);},getStatus:function(){try{return this.transport.status||0;}catch(e){return 0;}},respondToReadyState:function(readyState){var state=OpenLayers.Ajax.Request.Events[readyState];var response=new OpenLayers.Ajax.Response(this);if(state=='Complete'){try{this._complete=true;(this.options['on'+response.status]||this.options['on'+(this.success()?'Success':'Failure')]||OpenLayers.Ajax.emptyFunction)(response);}catch(e){this.dispatchException(e);}
+var contentType=response.getHeader('Content-type');}
+try{(this.options['on'+state]||OpenLayers.Ajax.emptyFunction)(response);OpenLayers.Ajax.Responders.dispatch('on'+state,this,response);}catch(e){this.dispatchException(e);}
+if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
+if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
+if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
+return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Format.WPSExecute=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",gml:"http://www.opengis.net/gml",wps:"http://www.opengis.net/wps/1.0.0",wfs:"http://www.opengis.net/wfs",ogc:"http://www.opengis.net/ogc",wcs:"http://www.opengis.net/wcs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",schemaLocationAttr:function(options){return undefined;},write:function(options){var doc;if(window.ActiveXObject){doc=new ActiveXObject("Microsoft.XMLDOM");this.xmldom=doc;}else{doc=document.implementation.createDocument("","",null);}
+var node=this.writeNode("wps:Execute",options,doc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wps":{"Execute":function(options){var node=this.createElementNSPlus("wps:Execute",{attributes:{version:this.VERSION,service:'WPS'}});this.writeNode("ows:Identifier",options.identifier,node);this.writeNode("wps:DataInputs",options.dataInputs,node);this.writeNode("wps:ResponseForm",options.responseForm,node);return node;},"ResponseForm":function(responseForm){var node=this.createElementNSPlus("wps:ResponseForm",{});if(responseForm.rawDataOutput){this.writeNode("wps:RawDataOutput",responseForm.rawDataOutput,node);}
+if(responseForm.responseDocument){this.writeNode("wps:ResponseDocument",responseForm.responseDocument,node);}
+return node;},"ResponseDocument":function(responseDocument){var node=this.createElementNSPlus("wps:ResponseDocument",{attributes:{storeExecuteResponse:responseDocument.storeExecuteResponse,lineage:responseDocument.lineage,status:responseDocument.status}});if(responseDocument.output){this.writeNode("wps:Output",responseDocument.output,node);}
+return node;},"Output":function(output){var node=this.createElementNSPlus("wps:Output",{attributes:{asReference:output.asReference}});this.writeNode("ows:Identifier",output.identifier,node);this.writeNode("ows:Title",output.title,node);this.writeNode("ows:Abstract",output["abstract"],node);return node;},"RawDataOutput":function(rawDataOutput){var node=this.createElementNSPlus("wps:RawDataOutput",{attributes:{mimeType:rawDataOutput.mimeType}});this.writeNode("ows:Identifier",rawDataOutput.identifier,node);return node;},"DataInputs":function(dataInputs){var node=this.createElementNSPlus("wps:DataInputs",{});for(var i=0,ii=dataInputs.length;i<ii;++i){this.writeNode("wps:Input",dataInputs[i],node);}
+return node;},"Input":function(input){var node=this.createElementNSPlus("wps:Input",{});this.writeNode("ows:Identifier",input.identifier,node);if(input.title){this.writeNode("ows:Title",input.title,node);}
+if(input.data){this.writeNode("wps:Data",input.data,node);}
+if(input.reference){this.writeNode("wps:Reference",input.reference,node);}
+return node;},"Data":function(data){var node=this.createElementNSPlus("wps:Data",{});if(data.literalData){this.writeNode("wps:LiteralData",data.literalData,node);}else if(data.complexData){this.writeNode("wps:ComplexData",data.complexData,node);}
+return node;},"LiteralData":function(literalData){var node=this.createElementNSPlus("wps:LiteralData",{attributes:{uom:literalData.uom},value:literalData.value});return node;},"ComplexData":function(complexData){var node=this.createElementNSPlus("wps:ComplexData",{attributes:{mimeType:complexData.mimeType,encoding:complexData.encoding,schema:complexData.schema}});node.appendChild(this.getXMLDoc().createCDATASection(complexData.value));return node;},"Reference":function(reference){var node=this.createElementNSPlus("wps:Reference",{attributes:{mimeType:reference.mimeType,"xlink:href":reference.href,method:reference.method,encoding:reference.encoding,schema:reference.schema}});if(reference.body){this.writeNode("wps:Body",reference.body,node);}
+return node;},"Body":function(body){var node=this.createElementNSPlus("wps:Body",{});if(body.wcs){this.writeNode("wcs:GetCoverage",body.wcs,node);}
+else if(body.wfs){this.featureType=body.wfs.featureType;this.version=body.wfs.version;this.writeNode("wfs:GetFeature",body.wfs,node);}else{this.writeNode("wps:Execute",body,node);}
+return node;}},"wcs":OpenLayers.Format.WCSGetCoverage.prototype.writers.wcs,"wfs":OpenLayers.Format.WFST.v1_1_0.prototype.writers.wfs,"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc,"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WPSExecute"});OpenLayers.Test.AgsRestAdmin=OpenLayers.Class(OpenLayers.Test,{url:"",_run_admin_createService_post_:function(reqId,options,t){var successMsg="...create service success...";var failureMsg="...create service failure...";var jsonFormat=new OpenLayers.Format.JSON();var postReqJsonStr=document.getElementById(reqId).firstChild.nodeValue;if(options.token){postReqJsonStr=postReqJsonStr+"&token="+options.token;}
+var caller=this;OpenLayers.Request.POST({url:this.url+"/createService",success:function(response){if(response.responseText.indexOf("success")!=-1){t.ok(true,successMsg);}else{t.ok(false,failureMsg);}},failure:function(response){t.ok(false,failureMsg);},params:{'service':postReqJsonStr},headers:{}});},_run_admin_deleteService_post_:function(reqId,options,t){var successMsg="...delete service success...";var failureMsg="...delete service failure...";var serviceNameStr=document.getElementById(reqId).firstChild.nodeValue;var queryStr="json";if(options.token){queryStr=queryStr+"&token="+options.token;}
+var caller=this;OpenLayers.Request.POST({url:this.url+"/"+serviceNameStr+"/delete",success:function(response){if(response.responseText.indexOf("success")!=-1){t.ok(true,successMsg);}else{t.ok(false,failureMsg);}},failure:function(response){t.ok(false,failureMsg);},params:{'f':queryStr},headers:{}});},CLASS_NAME:"OpenLayers.Test.AgsRestAdmin"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.location,success:this.parseData,scope:this});this.loaded=true;}},moveTo:fu
 nction(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
+if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
+catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
+if(name){this.setName(name);}}
+var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0,len=features.length;i<len;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
+var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){data.title=title;data.description=description;var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
+contentHTML+=title;if(link){contentHTML+='</a>';}
+contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
+var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
+this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
+if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.removeButtons();this.buttons=null;this.position=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft",
 "west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+id,xy,sz,imgLocation,"absolute");btn.style.cursor="pointer";this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;if(!this.slideRa
 tio){var slideFactorPixels=this.slideFactor;var getSlideFactor=function(){return slideFactorPixels;};}else{var slideRatio=this.slideRatio;var getSlideFactor=function(dim){return this.map.getSize()[dim]*slideRatio;};}
+btn.getSlideFactor=getSlideFactor;this.buttons.push(btn);return btn;},_removeButton:function(btn){OpenLayers.Event.stopObservingElement(btn);btn.map=null;btn.getSlideFactor=null;this.div.removeChild(btn);OpenLayers.Util.removeItem(this.buttons,btn);},removeButtons:function(){for(var i=this.buttons.length-1;i>=0;--i){this._removeButton(this.buttons[i]);}},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+switch(this.action){case"panup":this.map.pan(0,-this.getSlideFactor("h"));break;case"pandown":this.map.pan(0,this.getSlideFactor("h"));break;case"panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case"panright":this.map.pan(this.getSlideFactor("w"),0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
+OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,divEvents:null,zoomWorldIcon:false,panIcons:true,forceFixedZoomLevel:false,mouseDragStart:null,deltaY:null,zoomStart:null,destroy:function(){this._removeZoomBar();this.map.events.un({"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart;},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.removeButtons();this._removeZoomBar();}
+this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);if(this.panIcons){var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
+this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
+this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);}
+else{this._addButton("zoomin","zoom-plus-mini.png",px,sz);centered=this._addZoomBar(px.add(0,sz.h));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);if(this.zoomWorldIcon){centered=centered.add(0,sz.h+3);this._addButton("zoomworld","zoom-world-mini.png",centered,sz);}}
+return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id=this.id+"_"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");slider.style.cursor="move";this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true,{includeXY:true});this.sliderEvents.on({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id=this.id+"_"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,th
 is.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h+"px";}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
+div.style.cursor="pointer";this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true,{includeXY:true});this.divEvents.on({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},_removeZoomBar:function(){this.sliderEvents.un({"touchmove":this.zoomBarDrag,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});this.sliderEvents.destroy();this.divEvents.un({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.divEvents.destroy();this.div.removeChi
 ld(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar);},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+var levels=evt.xy.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom){levels=Math.floor(levels);}
+var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&!OpenLayers.Event.isSingleTouch(evt)){return;}
+this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
+this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
+if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
+this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var
 scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions())
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Protocol.AgsFeatureAccess.v2_0=OpenLayers.Class(OpenLayers.Protocol.AgsFeatureAccess.v2,{version:"2.0",CLASS_NAME:"OpenLayers.Protocol.AgsFeatureAccess.v2_0"});OpenLayers.Layer.AgsTiled=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,tileFullExtent:null,tileFormat:"",initialize:function(name,url,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this._isDefined=OpenLayers.Util.AgsUtil.isDefined;if(this._isD
 efined(options['tileFormat'])){this.tileFormat=options['tileFormat'];}else{OpenLayers.Console.error("...tileFormat missing or empty...");throw"...tileFormat missing or empty...";}
+if(this._isDefined(options['tileFullExtent'])&&options['tileFullExtent']instanceof OpenLayers.Bounds){this.tileFullExtent=options['tileFullExtent'];}
+if(this._isDefined(options['tileOrigin'])&&options['tileOrigin']instanceof OpenLayers.Pixel){this.tileOrigin=options['tileOrigin'];}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.AgsTiled(this.name,this.url,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var path=null;var url=null;if(this.tileFullExtent.intersectsBounds(bounds)){var col=null;if(this.tileOrigin.lon<=bounds.left){col=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));}else if(this.tileOrigin.lon>=bounds.right){col=Math.round((this.tileOrigin.lon-bounds.right)/(res*this.tileSize.w));}else{return"";OpenLayers.Console.warn("...invalid tileOrigin...");}
+var row=null;if(this.tileOrigin.lat>=bounds.top){row=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));}else if(this.tileOrigin.lat<=bounds.bottom){row=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));}else{return"";OpenLayers.Console.warn("...invalid tileOrigin...");}
+var scale=this.map.getZoom();path=scale+"/"+row+"/"+col+"."+this.tileFormat;url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+return url+path;}else{return"";}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}
+if(!this.tileFullExtent){this.tileFullExtent=this.map.maxExtent;}},CLASS_NAME:"OpenLayers.Layer.AgsTiled"});OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",stringifyOutput:true,CLASS_NAME:"OpenLayers.Format.XLS"});OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},xy:true,defaultPrefix:"xls",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var xls={};this.readChildNodes(data,xls);return xls;},readers:{"xls":{"XLS":function(node,xls){xls.version=node.getAttribute("version");this.readChildNodes(node,xls);},"Response":function(node,xls){this.
 readChildNodes(node,xls);},"GeocodeResponse":function(node,xls){xls.responseLists=[];this.readChildNodes(node,xls);},"GeocodeResponseList":function(node,xls){var responseList={features:[],numberOfGeocodedAddresses:parseInt(node.getAttribute("numberOfGeocodedAddresses"))};xls.responseLists.push(responseList);this.readChildNodes(node,responseList);},"GeocodedAddress":function(node,responseList){var feature=new OpenLayers.Feature.Vector();responseList.features.push(feature);this.readChildNodes(node,feature);feature.geometry=feature.components[0];},"GeocodeMatchCode":function(node,feature){feature.attributes.matchCode={accuracy:parseFloat(node.getAttribute("accuracy")),matchType:node.getAttribute("matchType")};},"Address":function(node,feature){var address={countryCode:node.getAttribute("countryCode"),addressee:node.getAttribute("addressee"),street:[],place:[]};feature.attributes.address=address;this.readChildNodes(node,address);},"freeFormAddress":function(node,address){address
 .freeFormAddress=this.getChildValue(node);},"StreetAddress":function(node,address){this.readChildNodes(node,address);},"Building":function(node,address){address.building={'number':node.getAttribute("number"),subdivision:node.getAttribute("subdivision"),buildingName:node.getAttribute("buildingName")};},"Street":function(node,address){address.street.push(this.getChildValue(node));},"Place":function(node,address){address.place[node.getAttribute("type")]=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);}},"gml":OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(request){return this.writers.xls.XLS.apply(this,[request]);},writers:{"xls":{"XLS":function(request){var root=this.createElementNSPlus("xls:XLS",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});this.writeNode("RequestHeader",request.header,root);this.writeNode("Request",request,root);return root;},"RequestHeader":function(
 header){return this.createElementNSPlus("xls:RequestHeader");},"Request":function(request){var node=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequest",requestID:request.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",request.addresses,node);return node;},"GeocodeRequest":function(addresses){var node=this.createElementNSPlus("xls:GeocodeRequest");for(var i=0,len=addresses.length;i<len;i++){this.writeNode("Address",addresses[i],node);}
+return node;},"Address":function(address){var node=this.createElementNSPlus("xls:Address",{attributes:{countryCode:address.countryCode}});if(address.freeFormAddress){this.writeNode("freeFormAddess",address.freeFormAddress,node);}else{if(address.street){this.writeNode("StreetAddress",address,node);}
+if(address.municipality){this.writeNode("Municipality",address.municipality,node);}
+if(address.countrySubdivision){this.writeNode("CountrySubdivision",address.countrySubdivision,node);}
+if(address.postalCode){this.writeNode("PostalCode",address.postalCode,node);}}
+return node;},"freeFormAddress":function(freeFormAddress){return this.createElementNSPlus("freeFormAddress",{value:freeFormAddress});},"StreetAddress":function(address){var node=this.createElementNSPlus("xls:StreetAddress");if(address.building){this.writeNode(node,"Building",address.building);}
+var street=address.street;if(!(OpenLayers.Util.isArray(street))){street=[street];}
+for(var i=0,len=street.length;i<len;i++){this.writeNode("Street",street[i],node);}
+return node;},"Building":function(building){return this.createElementNSPlus("xls:Building",{attributes:{"number":building["number"],"subdivision":building.subdivision,"buildingName":building.buildingName}});},"Street":function(street){return this.createElementNSPlus("xls:Street",{value:street});},"Municipality":function(municipality){return this.createElementNSPlus("xls:Place",{attributes:{type:"Municipality"},value:municipality});},"CountrySubdivision":function(countrySubdivision){return this.createElementNSPlus("xls:Place",{attributes:{type:"CountrySubdivision"},value:countrySubdivision});},"PostalCode":function(postalCode){return this.createElementNSPlus("xls:PostalCode",{value:postalCode});}}},CLASS_NAME:"OpenLayers.Format.XLS.v1"});OpenLayers.Format.XLS.v1_1_0=OpenLayers.Class(OpenLayers.Format.XLS.v1,{VERSION:"1.1",schemaLocation:"http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",initialize:function(options){OpenLayers.Format.X
 LS.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.XLS.v1_1_0"});OpenLayers.Format.XLS.v1_1=OpenLayers.Format.XLS.v1_1_0;OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){var coordSysUnchanged=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution(),left=-extent.left/resolution,top=extent.top/resolution;if(resolutionChanged){this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.si
 ze.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(this.xOffset,0);return true;}else{var inRange=this.translate(left-this.left+this.xOffset,top-this.top);if(!inRange){this.setExtent(extent,true);}
+return coordSysUnchanged&&inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
+this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
+return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));var widthFactor=1;var pos;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){pos=this.getPosition(node);if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(pos.x+xOffset).toFixed());node.setAttributeNS(null,"y",(pos.y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);node.onclick=OpenLayers.Renderer.SVG.preventDefault;}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3;var size=offset*2;var src=this.importSymbol(style.graphicName);pos=this.getPosition(node);widthFactor=this.symbolMetrics[src.id][0]*3/size;var parent=no
+node.firstChild&&node.removeChild(node.firstChild);node.appendChild(src.firstChild.cloneNode(true));node.setAttributeNS(null,"viewBox",src.getAttributeNS(null,"viewBox"));node.setAttributeNS(null,"width",size);node.setAttributeNS(null,"height",size);node.setAttributeNS(null,"x",pos.x-offset);node.setAttributeNS(null,"y",pos.y-offset);if(nextSibling){parent.insertBefore(node,nextSibling);}else if(parent){parent.appendChild(node);}}else{node.setAttributeNS(null,"r",style.pointRadius);}
+var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)&&pos){node._rotation=rotation;rotation|=0;if(node.nodeName!=="svg"){node.setAttributeNS(null,"transform","rotate("+rotation+" "+pos.x+" "+
+pos.y+")");}else{var metrics=this.symbolMetrics[src.id];node.firstChild.setAttributeNS(null,"transform","rotate("
++rotation+" "
++metrics[1]+" "
++metrics[2]+")");}}}
+return node;},dashStyle:function(style,widthFactor){var w=style.strokeWidth*widthFactor;var str=style.strokeDashstyle;switch(str){case'solid':return'none';case'dot':return[1,4*w].join();case'dash':return[4*w,4*w].join();case'dashdot':return[4*w,4*w,1,4*w].join();case'longdash':return[8*w,4*w].join();case'longdashdot':return[8*w,4*w,1,4*w].join();default:return OpenLayers.String.trim(str).replace(/\s+/g,",");}},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
+return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"g");},createDefs:function(){var defs=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(defs);return defs;},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=((geometry.x-this.featureDx)/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);return node;}else{return false;}},drawLineString:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);
 return(componentsResult.complete?node:null);}else{return false;}},drawLinearRing:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(componentsResult.complete?node:null);}else{return false;}},drawPolygon:function(node,geometry){var d="";var draw=true;var complete=true;var linearRingResult,path;for(var j=0,len=geometry.components.length;j<len;j++){d+=" M";linearRingResult=this.getComponentsString(geometry.components[j].components," ");path=linearRingResult.path;if(path){d+=" "+path;complete=linearRingResult.complete&&complete;}else{draw=false;}}
+d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");return complete?node:null;}else{return false;}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=((geometry.x-this.featureDx)/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);return node;}else{return false;}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0,len=geometry.components.length;i<len;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" "+component;}}
+d+=" Z";if(draw){node.setAttributeNS(null,"d",d);return node;}else{return false;}},drawText:function(featureId,style,location){var resolution=this.getResolution();var x=((location.x-this.featureDx)/resolution+this.left);var y=(location.y/resolution-this.top);var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"text");label.setAttributeNS(null,"x",x);label.setAttributeNS(null,"y",-y);if(style.fontColor){label.setAttributeNS(null,"fill",style.fontColor);}
+if(style.fontOpacity){label.setAttributeNS(null,"opacity",style.fontOpacity);}
+if(style.fontFamily){label.setAttributeNS(null,"font-family",style.fontFamily);}
+if(style.fontSize){label.setAttributeNS(null,"font-size",style.fontSize);}
+if(style.fontWeight){label.setAttributeNS(null,"font-weight",style.fontWeight);}
+if(style.fontStyle){label.setAttributeNS(null,"font-style",style.fontStyle);}
+if(style.labelSelect===true){label.setAttributeNS(null,"pointer-events","visible");label._featureId=featureId;}else{label.setAttributeNS(null,"pointer-events","none");}
+var align=style.labelAlign||"cm";label.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]]||"middle");if(OpenLayers.IS_GECKO===true){label.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]]||"central");}
+var labelRows=style.label.split('\n');var numRows=labelRows.length;while(label.childNodes.length>numRows){label.removeChild(label.lastChild);}
+for(var i=0;i<numRows;i++){var tspan=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_tspan_"+i,"tspan");if(style.labelSelect===true){tspan._featureId=featureId;tspan._geometry=location;tspan._geometryClass=location.CLASS_NAME;}
+if(OpenLayers.IS_GECKO===false){tspan.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]]||"-35%");}
+tspan.setAttribute("x",x);if(i==0){var vfactor=OpenLayers.Renderer.SVG.LABEL_VFACTOR[align[1]];if(vfactor==null){vfactor=-.5;}
+tspan.textContent=(labelRows[i]==='')?' ':labelRows[i];if(!tspan.parentNode){label.appendChild(tspan);}}
+if(!label.parentNode){this.textRoot.appendChild(label);}},getComponentsString:function(components,separator){var renderCmp=[];var complete=true;var len=components.length;var strings=[];var str,component;for(var i=0;i<len;i++){component=components[i];renderCmp.push(component);str=this.getShortString(component);if(str){strings.push(str);}else{if(i>0){if(this.getShortString(components[i-1])){strings.push(this.clipLine(components[i],components[i-1]));}}
+if(i<len-1){if(this.getShortString(components[i+1])){strings.push(this.clipLine(components[i],components[i+1]));}}
+complete=false;}}
+return{path:strings.join(separator||","),complete:complete};},clipLine:function(badComponent,goodComponent){if(goodComponent.equals(badComponent)){return"";}
+var resolution=this.getResolution();var maxX=this.MAX_PIXEL-this.translationParameters.x;var maxY=this.MAX_PIXEL-this.translationParameters.y;var x1=(goodComponent.x-this.featureDx)/resolution+this.left;var y1=this.top-goodComponent.y/resolution;var x2=(badComponent.x-this.featureDx)/resolution+this.left;var y2=this.top-badComponent.y/resolution;var k;if(x2<-maxX||x2>maxX){k=(y2-y1)/(x2-x1);x2=x2<0?-maxX:maxX;y2=y1+(x2-x1)*k;}
+if(y2<-maxY||y2>maxY){k=(x2-x1)/(y2-y1);y2=y2<0?-maxY:maxY;x2=x1+(y2-y1)*k;}
+return x2+","+y2;},getShortString:function(point){var resolution=this.getResolution();var x=((point.x-this.featureDx)/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},getPosition:function(node){return({x:parseFloat(node.getAttributeNS(null,"cx")),y:parseFloat(node.getAttributeNS(null,"cy"))});},importSymbol:function(graphicName){if(!this.defs){this.defs=this.createDefs();}
+var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
+node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]=[Math.max(width,height),symbolExtent.getCenterLonLat().lon,symbolExtent.getCenterLonLat().lat];this.defs.appendChild(symbolNode);return symbolNode;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot&&target.parentNode._featureId;}
+return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",getVersion:function(root,options){var version=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);if(version=="1.1.1"||version=="1.1.0"){version="1.1";}
+return version;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});OpenLayers.Format.WMSDescribeLayer.v1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(options){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var children=root.childNodes;var describelayer=[];var childNode,nodeName;for(var i=0;i<children.length;++i){childNode=children[i];nodeName=childNode.nodeName;if(nodeName=='LayerDescription'){var layerName=childNode.getAttribute('name');var owsType='';var owsURL='';var typeName='';if(childNode.getAttribute('owsType')){owsType=childNode.getAttribute('owsType');owsURL=childNode.getAttribute('owsURL');}else{if(childNode.getAttribute('wfs')!=''){owsType='WFS';owsURL=childNode.getAttribute('wfs');}else if(childNode.getAttribute('wcs')!=''){owsType='WCS';owsURL=childNode.getAttribute('wcs');}}
+var query=childNode.getElementsByTagName('Query');if(query.length>0){typeName=query[0].getAttribute('typeName');if(!typeName){typeName=query[0].getAttribute('typename');}}
+describelayer.push({layerName:layerName,owsType:owsType,owsURL:owsURL,typeName:typeName});}}
+return describelayer;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer.v1_1"});OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,contentSize:null,size:null,contentHTML:null,backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,displayClass:"olPopup",contentDisplayClass:"olPopupContent",padding:0,disableFirefoxOverflowHack:false,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,keepInMap:false,closeOnMove:false,map:null,initialize:function(id,lonlat,contentSize,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
+this.id=id;this.lonlat=lonlat;this.contentSize=(contentSize!=null)?contentSize:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
+this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className=this.displayClass;var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.contentSize.clone(),null,"relative");this.contentDiv.className=this.contentDisplayClass;this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
+this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;if(this.closeOnMove&&this.map){this.map.events.unregister("movestart",this,this.hide);}
+this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
+this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
+this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
+if(this.closeOnMove){this.map.events.register("movestart",this,this.hide);}
+if(!this.disableFirefoxOverflowHack&&OpenLayers.BROWSER_NAME=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
+this.moveTo(px);if(!this.autoSize&&!this.size){this.setSize(this.contentSize);}
+this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
+return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){this.div.style.display='';if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){this.div.style.display='none';},setSize:function(contentSize){this.size=contentSize.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivP
 adding.right;}
+this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.BROWSER_NAME=="msie"){this.contentSize.w+=contentDivPadding.left+contentDivPadding.right;this.contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
+if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
+if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},updateSize:function(){var preparedHTML="<div class='"+this.contentDisplayClass+"'>"+
+this.contentDiv.innerHTML+"</div>";var containerElement=(this.map)?this.map.layerContainerDiv:document.body;var realSize=OpenLayers.Util.getRenderedDimensions(preparedHTML,null,{displayClass:this.displayClass,containerElement:containerElement});var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(preparedHTML,fixedSize,{displayClass:this.contentDisplayClass,containerElement:containerElement});var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
+newSize=this.getSafeContentSize(clippedSize);}}
+this.setSize(newSize);},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
+if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
+if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
+if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
+if((this.contentDiv!=null)&&(this.contentHTML!=null)&&(this.contentHTML!=this.contentDiv.innerHTML)){this.contentDiv.innerHTML=this.contentHTML;if(this.autoSize){this.registerImageListeners();this.updateSize();}}},registerImageListeners:function(){var onImgLoad=function(){this.popup.updateSize();if(this.popup.visible()&&this.popup.panMapIfOutOfView){this.popup.panIntoView();}
+OpenLayers.Event.stopObserving(this.img,"load",this.img._onImageLoad);};var images=this.contentDiv.getElementsByTagName("img");for(var i=0,len=images.length;i<len;i++){var img=images[i];if(img.width==0||img.height==0){var context={'popup':this,'img':img};img._onImgLoad=OpenLayers.Function.bind(onImgLoad,context);OpenLayers.Event.observe(img,'load',img._onImgLoad);}}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
+if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
+if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
+if(this.map&&this.map.size){var extraX=0,extraY=0;if(this.keepInMap&&!this.panMapIfOutOfView){var px=this.map.getPixelFromLonLat(this.lonlat);switch(this.relativePosition){case"tr":extraX=px.x;extraY=this.map.size.h-px.y;break;case"tl":extraX=this.map.size.w-px.x;extraY=this.map.size.h-px.y;break;case"bl":extraX=this.map.size.w-px.x;extraY=px.y;break;case"br":extraX=px.x;extraY=px.y;break;default:extraX=px.x;extraY=this.map.size.h-px.y;break;}}
+var maxY=this.map.size.h-
+this.map.paddingForPopups.top-
+this.map.paddingForPopups.bottom-
+hPadding-extraY;var maxX=this.map.size.w-
+this.map.paddingForPopups.left-
+this.map.paddingForPopups.right-
+wPadding-extraX;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
+return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){if(this.div.parentNode==null){this.div.style.display="none";document.body.appendChild(this.div);}
+contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;if(this.div.parentNode==document.body){document.body.removeChild(this.div);this.div.style.display="";}}
+return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"touchend",OpenLayers.Function.bindAsEventListener(closePopup,this));OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
+if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
+if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
+if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
+var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);function onTouchstart(evt){OpenLayers.Event.stop(evt,true);}
+this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,"touchstart":onTouchstart,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geod
 esic:false,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
+this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
+return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
+var curMapUnits=this.map.getUnits();var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var geodesicRatio=1;if(this.geodesic===true){var maxSizeGeodesic=(this.map.getGeodesicPixelSize().w||0.000001)*this.maxWidth;var maxSizeKilometers=maxSizeData/inches["km"];geodesicRatio=maxSizeGeodesic/maxSizeKilometers;maxSizeData*=geodesicRatio;}
+var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
+var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res/geodesicRatio;var bottomPx=bottomMax/res/geodesicRatio;if(this.eBottom.style.visibility=="visible"){this.eBottom.style.width=Math.round(bottomPx)+"px";this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;}
+if(this.eTop.style.visibility=="visible"){this.eTop.style.width=Math.round(topPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;}},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(url,size,offset,calculateOffset){this.url=url;this.size=(size)?size:new OpenLayers.Size(20,20);this.offset=offset?offset:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=calculateOffset;var id=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(id);},destroy:function(){this.erase();OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null;},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset);},setSize:function(size){if(size!=null){this.size=size;}
+this.draw();},setUrl:function(url){if(url!=null){this.url=url;}
+this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},erase:function(){if(this.imageDiv!=null&&this.imageDiv.parentNode!=null){OpenLayers.Element.remove(this.imageDiv);}},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
+if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
+var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},isDrawn:function(){var isDrawn=(this.imageDiv&&this.imageDiv.parentNode&&(this.imageDiv.parentNode.nodeType!=11));return isDrawn;},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
+this.events=new OpenLayers.Events(this,this.icon.imageDiv);},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},erase:function(){if(this.icon!=null){this.icon.erase();}},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
+this.lonlat=this.map.getLonLatFromLayerPx(px);},isDrawn:function(){var isDrawn=(this.icon&&this.icon.isDrawn());return isDrawn;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
+if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
+break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
+break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
+break;case"FeatureCollection":for(var i=0,len=obj.features.length;i<len;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;}}
+return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
+obj.type);}else{valid=true;}
+break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
+obj.type+" to "+type);}}
+return valid;},parseFeature:function(obj){var feature,geometry,attributes,bbox;attributes=(obj.properties)?obj.properties:{};bbox=(obj.geometry&&obj.geometry.bbox)||obj.bbox;try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
+feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
+if(obj.id){feature.fid=obj.id;}
+return feature;},parseGeometry:function(obj){if(obj==null){return null;}
+var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(OpenLayers.Util.isArray(obj.geometries))){throw"GeometryCollection must have geometries array: "+obj;}
+var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
+geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(OpenLayers.Util.isArray(obj.coordinates))){throw"Geometry must have coordinates array: "+obj;}
+if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
+try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
+if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},parseCoords:{"point":function(array){if(this.ignoreExtraDims==false&&array.length!=2){throw"Only 2D points are supported: "+array;}
+return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+lines.push(l);}
+return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
+return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
+polys.push(p);}
+return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(OpenLayers.Util.isArray(obj)){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
+geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
+return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"name","properties":{"name":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"name","properties":{"name":"EPSG:"+code}};}}
+return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);var json={"type":"Feature","properties":feature.attributes,"geometry":geom};if(feature.fid!=null){json.id=feature.fid;}
+return json;},'geometry':function(geometry){if(geometry==null){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
+return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
+return array;},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
+return array;},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
+return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
+return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
+return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Strategy.Paging=OpenLayers.Class(OpenLayers.Strategy,{features:null,length:10,num:null,paging:false,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"beforefeaturesadded":this.cacheFeatures,scope:this});}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.clearCache();this.layer.events.un({"beforefeaturesadded":this.cacheFeatures,scope:this});}
+return deactivated;},cacheFeatures:function(event){if(!this.paging){this.clearCache();this.features=event.features;this.pageNext(event);}},clearCache:function(){if(this.features){for(var i=0;i<this.features.length;++i){this.features[i].destroy();}}
+this.features=null;this.num=null;},pageCount:function(){var numFeatures=this.features?this.features.length:0;return Math.ceil(numFeatures/this.length);},pageNum:function(){return this.num;},pageLength:function(newLength){if(newLength&&newLength>0){this.length=newLength;}
+return this.length;},pageNext:function(event){var changed=false;if(this.features){if(this.num===null){this.num=-1;}
+var start=(this.num+1)*this.length;changed=this.page(start,event);}
+return changed;},pagePrevious:function(){var changed=false;if(this.features){if(this.num===null){this.num=this.pageCount();}
+var start=(this.num-1)*this.length;changed=this.page(start);}
+return changed;},page:function(start,event){var changed=false;if(this.features){if(start>=0&&start<this.features.length){var num=Math.floor(start/this.length);if(num!=this.num){this.paging=true;var features=this.features.slice(start,start+this.length);this.layer.removeFeatures(this.layer.features);this.num=num;if(event&&event.features){event.features=features;}else{this.layer.addFeatures(features);}
+this.paging=false;changed=true;}}}
+return changed;},CLASS_NAME:"OpenLayers.Strategy.Paging"});OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,keepInMap:true,anchor:null,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=[id,lonlat,contentSize,contentHTML,closeBox,closeBoxCallback];OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePositio
 n!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(contentSize){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var size=this.size||this.contentSize;var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixed
 RelativePosition:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
+this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
+this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
+block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
+block.div=null;}
+this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
+this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
+this.padding.top+"px";}
+this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
+var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
+if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
+this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;t
 his.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{
 result=this.dragHandler.start.clone();}
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
+return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
+return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax
 =center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:1,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+this.kinetic=new OpenLayers.Kinetic(config);}
+this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
+this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
+this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
+this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
+return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
+this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this["double"]&&this.passesDblclickTolerance(evt)){this.callback("dblclick",[evt]);}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.stop(evt);}
+this.handleDouble(evt);}
+if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
+return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
+Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.clientX,clientY:touch.clientY};}}
+return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;this.touch=false;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;if(this.pinchZoom){this.pinchZoom.destroy();}
+this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+if(this.pinchZoom){this.pinchZoom.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(
 newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:false,featureAdded:fun
 ction(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{renderers:layer.renderers,rendererOptions:layer.rendererOptions});if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
+var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
 redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{citeCompliant:false,initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{displayClass:'olControlDrawFeaturePoint',handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{displayClass:'olControlDrawFeaturePath',handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{displayClass:'olControlDrawFeaturePolygon',handlerOptions:{citeCompliant:this.citeCompliant}})];this.addControls(controls);},draw:function(){var div=OpenLayers.
 Control.Panel.prototype.draw.apply(this,arguments);if(this.defaultControl===null){this.defaultControl=this.controls[0];}
+return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
+return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
+var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
+return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};var j;var jlen=featureNode.attributes.length;if(jlen>0){for(j=0;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}}else{var nodes=featureNode.childNodes;for(j=0,jlen=nodes.length;j<jlen;++j){var node=nodes[j];if(node.nodeType!=3){attributes[node.getAttribute("name")]=node.getAttribute("value");}}}
+response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
+return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
+tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
+return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;if(grandchildren.length==0){attributes[name]=null}else if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
+var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
+return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((thi
 s.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
+shortHexCode.charAt(i));}}
+if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
+var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=OpenLayers.Element.getStyle(OpenLayers.Util.getElement(elem),"backgroundColor");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
+if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
+if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
+else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
+else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
+else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
+return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
+var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
+brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
+if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
+hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
+return{h:hue,s:saturation,b:brightness};};OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
+var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
+this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColo
 r){if(this.options.border){this._renderBorder(e,bgColor);}
+if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
+if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
+el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
+el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
+else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
+if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
+this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
+if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
+if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
+return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
+if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
+if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
+return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
+else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
+else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
+else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
+else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
+if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
+var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
+return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.Anc
 horedBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
+if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"
 OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Strategy.Save=OpenLayers.Class(OpenLayers.Strategy,{events:null,auto:false,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);this.events=new OpenLayers.Events(this);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.auto){if(typeof this.auto==="number"){this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),this.auto*1000);}else{this.layer.events.on({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){if(this.auto){if(typeof this.auto==="number"){window.clearInterval(this.timer);}else{this.layer.events.un({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
+return deactivated;},triggerSave:function(event){var feature=event.feature;if(feature.state===OpenLayers.State.INSERT||feature.state===OpenLayers.State.UPDATE||feature.state===OpenLayers.State.DELETE){this.save([event.feature]);}},save:function(features){if(!features){features=this.layer.features;}
+this.events.triggerEvent("start",{features:features});var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var len=features.length;var clones=new Array(len);var orig,clone;for(var i=0;i<len;++i){orig=features[i];clone=orig.clone();clone.fid=orig.fid;clone.state=orig.state;if(orig.url){clone.url=orig.url;}
+clone._original=orig;clone.geometry.transform(local,remote);clones[i]=clone;}
+features=clones;}
+this.layer.protocol.commit(features,{callback:this.onCommit,scope:this});},onCommit:function(response){var evt={"response":response};if(response.success()){var features=response.reqFeatures;var state,feature;var destroys=[];var insertIds=response.insertIds||[];var j=0;for(var i=0,len=features.length;i<len;++i){feature=features[i];feature=feature._original||feature;state=feature.state;if(state){if(state==OpenLayers.State.DELETE){destroys.push(feature);}else if(state==OpenLayers.State.INSERT){feature.fid=insertIds[j];++j;}
+feature.state=null;}}
+if(destroys.length>0){this.layer.destroyFeatures(destroys);}
+this.events.triggerEvent("success",evt);}else{this.events.triggerEvent("fail",evt);}},CLASS_NAME:"OpenLayers.Strategy.Save"});OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"moveend":this.update,scope:this});this.layer.events.on({"refresh":this.update,scope:this});if(this.layer.visibility===true&&this.layer.inRange===true){this.update();}else{this.layer.events.on({"visibilitychanged":this.update,scope:this});}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"moveend":this.update,"refresh":this.update,"visibilitychanged":this.update,scope:this});}
+return deactivated;},update:function(options){var mapBounds=this.getMapBounds();if(mapBounds!==null&&((options&&options.force)||this.invalidBounds(mapBounds))){this.calculateBounds(mapBounds);this.resolution=this.layer.map.getResolution();this.triggerRead(options);}},getMapBounds:function(){if(this.layer.map===null){return null;}
+var bounds=this.layer.map.getExtent();if(bounds&&!this.layer.projection.equals(this.layer.map.getProjectionObject())){bounds=bounds.clone().transform(this.layer.map.getProjectionObject(),this.layer.projection);}
+return bounds;},invalidBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
+var invalid=!this.bounds||!this.bounds.containsBounds(mapBounds);if(!invalid&&this.resFactor){var ratio=this.resolution/this.layer.map.getResolution();invalid=(ratio>=this.resFactor||ratio<=(1/this.resFactor));}
+return invalid;},calculateBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
+var center=mapBounds.getCenterLonLat();var dataWidth=mapBounds.getWidth()*this.ratio;var dataHeight=mapBounds.getHeight()*this.ratio;this.bounds=new OpenLayers.Bounds(center.lon-(dataWidth/2),center.lat-(dataHeight/2),center.lon+(dataWidth/2),center.lat+(dataHeight/2));},triggerRead:function(options){if(this.response){this.layer.protocol.abort(this.response);this.layer.events.triggerEvent("loadend");}
+this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:this.createFilter(),callback:this.merge,scope:this},options));},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
+return filter;},merge:function(resp){this.layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
+this.layer.addFeatures(features);}
+this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=
 (this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":true},createLayer:function(capabilities,config){var layer;var required={layer:true,
 matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+var contents=capabilities.contents;var matrixSet=contents.tileMatrixSets[config.matrixSet];var layers=contents.layers;var layerDef;for(var i=0,ii=contents.layers.length;i<ii;++i){if(contents.layers[i].identifier===config.layer){layerDef=contents.layers[i];break;}}
+if(layerDef&&matrixSet){var style;for(var i=0,ii=layerDef.styles.length;i<ii;++i){style=layerDef.styles[i];if(style.isDefault){break;}}
+layer=new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(config,{url:capabilities.operationsMetadata.GetTile.dcp.http.get,name:layerDef.title,style:style.identifier,matrixIds:matrixSet.matrixIds}));}
+return layer;},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities"});OpenLayers.Strategy.SaveWithLock=OpenLayers.Class(OpenLayers.Strategy.Save,{initialize:function(options){OpenLayers.Strategy.Save.prototype.initialize.apply(this,[options]);},activate:function(){var canCommitWithLock=(typeof this.layer.protocol.commitWithLock=="function")?true:false;if(!this.layer.protocol||canCommitWithLock==false){OpenLayers.Console.error("...can not activate SaveWithLock strategy...vector layer protocol does not support commitWithLock interface...");return false;}
+var activated=OpenLayers.Strategy.Save.prototype.activate.call(this);if(activated){this.layer.events.addEventType("transactionsucceeded");this.layer.events.addEventType("transactionfailed");}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.Save.prototype.deactivate.call(this);if(deactivated){}
+return deactivated;},saveWithLock:function(features){if(this.active==true){if(!features){features=this.layer.features;}
+this.events.triggerEvent("start",{'features':features});this.layer.protocol.commitWithLock(features,{callback:this.onSaveWithLock,scope:this});}else{OpenLayers.Console.error("...can not call saveWithLock...SaveWithLock strategy is not activated...");throw"...can not call saveWithLock...SaveWithLock strategy is not activated...";}},triggerSave:function(event){var feature=event.feature;if(feature.state===OpenLayers.State.INSERT||feature.state===OpenLayers.State.UPDATE||feature.state===OpenLayers.State.DELETE){this.saveWithLock([event.feature]);}},onSaveWithLock:function(response){if(this.layer.protocol.releaseAction=="ALL"){var evt={lockId:response.lockId};this.layer.events.triggerEvent("afterfeaturesunlocked",evt);}else if(this.layer.protocol.releaseAction=="SOME"){}
+if(response.success()){OpenLayers.Console.log("...transaction succeeded...");var modifiedFeatures=response.reqFeatures;var state;var modifiedFeature;var toDestroy=[];var toSynchronize=[];var insertIds=response.insertIds||[];var j=0;for(var i=0,len=modifiedFeatures.length;i<len;++i){modifiedFeature=modifiedFeatures[i];state=modifiedFeature.state;if(state){if(state==OpenLayers.State.DELETE){toDestroy.push(modifiedFeature);}else if(state==OpenLayers.State.UPDATE){toSynchronize.push(modifiedFeature);}else if(state==OpenLayers.State.INSERT){modifiedFeature.fid=insertIds[j];++j;}
+modifiedFeature.state=null;}}
+OpenLayers.Console.log("...synchronize deleted features..."+"...features number: "+toDestroy.length);if(toDestroy.length>0){this.layer.destroyFeatures(toDestroy);}
+if(toSynchronize.length>0||response.insertIds.length>0){var fids=response.insertIds||[];for(var i=0;i<toSynchronize.length;i++){if(toSynchronize[i].fid){fids.push(toSynchronize[i].fid);}}
+var featureIdFilter=new OpenLayers.Filter.FeatureId({fids:fids});OpenLayers.Console.log("...synchronize inserted/updated features...features number: "+fids.length);this.layer.protocol.read({filter:featureIdFilter,callback:this.synchronizeFeatures,scope:this});}}else{OpenLayers.Console.log("...transaction failed...");var evt={'response':response};this.events.triggerEvent("fail",evt);this.layer.events.triggerEvent("transactionfailed",evt);}},synchronizeFeatures:function(response){if(response.success()&&response.features){var synchronizedFeatures=response.features;var featuresToSyn=[];for(var i=0;i<synchronizedFeatures.length;i++){var fid=synchronizedFeatures[i].fid;var featureToSyn=this.layer.getFeatureByFid(fid);for(var j=0;j<this.layer.strategies.length;j++){var strategy=this.layer.strategies[j];if(strategy instanceof OpenLayers.Strategy.Lock){OpenLayers.Console.debug("...layer has lock strategy...");for(var k=0;k<strategy.lockedFeatures.length;k++){if(featureToSyn!=null){if
 (strategy.lockedFeatures[k].fid===featureToSyn.fid){OpenLayers.Console.debug("...remove commited feature from locked feature list...");OpenLayers.Util.removeItem(strategy.lockedFeatures,strategy.lockedFeatures[k]);}}}}}
+if(featureToSyn){featuresToSyn.push(featureToSyn);}}
+this.layer.destroyFeatures(featuresToSyn);this.layer.addFeatures(synchronizedFeatures);OpenLayers.Console.log("...inserted/updated features synchronized...features number: "+synchronizedFeatures.length);var evt={'response':response};this.events.triggerEvent("success",evt);this.layer.events.triggerEvent("transactionsucceeded",evt);}},CLASS_NAME:"OpenLayers.Strategy.SaveWithLock"});OpenLayers.Control.AgsRouteTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,stopsAdded:null,barriersAdded:null,stopOrBarrier:"stop",initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.stopsAdded=[];this.barriersAdded=[];this.drawControl.layer.events.register("sketchcomplete",this,function(evt){this.hideStopsAndBarriers();if(this.stopOrBarrier=="stop"){OpenLayers.Console.debug("...add 'stop'...");this.addStops([evt.feature]);}else if(this.stopOrBarrier=="barrier"){OpenLa
 yers.Console.debug("...add 'barrier'...");this.addBarriers([evt.feature]);}else{OpenLayers.Console.error("...invalid 'stopOrBarrier' value...please set it to 'stop' or 'barrier'...");throw"...invalid 'stopOrBarrier' value...please set it to 'stop' or 'barrier'...";}
+this.showStopsAndBarriers();return false;});this.taskParameters={'returnDirections':true,'returnRoutes':true,'returnStops':true,'returnBarriers':true};this._resultsParser={'parser':this.adapter.parseAgsResults['routeResults'],'context':this.adapter};this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);if(this._isDefined(this.layer.map)){_taskParameters['outSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['outSpatialReference'];}
+if(olFeatures instanceof Array){_taskParameters['stops']=olFeatures;}else if(!this._isDefined(_taskParameters['stops'])){OpenLayers.Console.error("...can not execute route task...input geometry is not valid...");throw"...can not execute route task...input geometry is not valid...";}
+var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsRouteTask=new esri.tasks.RouteTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsRouteParameters=this.adapter.encodeAgsRouteParameters(_taskParameters);}catch(e){OpenLayers.Console.error(e.toString());throw e;}
+agsRouteTask.solve(agsRouteParameters,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsRouteTask ...");throw"...'asynchronous' should always be set to 'false' for AgsRouteTask ...";}},addStops:function(olStops){for(var i=0;i<olStops.length;i++){var olStop=olStops[i];if(olStop instanceof OpenLayers.Feature.Vector&&olStop.geometry instanceof OpenLayers.Geometry.Point){olStop.style={fillColor:"#FFFF00",fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10};this.stopsAdded.push(olStop);}else{OpenLayers.Console.debug("...skip adding 'stop' because it's not OpenLayers.Feature.Vector");}}},hideStops:function(){if(this.stopsAdded&&this.stopsAdded.length>0){this.layer.removeFeatures(this.stopsAdded);}},cleanupStops:function(){this.hideStops();if(this.stopsAdded&&this.stopsAdded.length>0){for(var i=0;i<this.stopsAdded.length;i++){this.st
 opsAdded[i].destroy();}}
+this.stopsAdded.length=0;},addBarriers:function(olBarriers){for(var i=0;i<olBarriers.length;i++){var olBarrier=olBarriers[i];if(olBarrier instanceof OpenLayers.Feature.Vector&&olBarrier.geometry instanceof OpenLayers.Geometry.Point){olBarrier.style={fillColor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10};this.barriersAdded.push(olBarrier);}else{OpenLayers.Console.debug("...skip adding 'barrier' because it's not OpenLayers.Feature.Vector");}}},cleanupBarriers:function(){this.hideBarriers();if(this.barriersAdded&&this.barriersAdded.length>0){for(var i=0;i<this.barriersAdded.length;i++){this.barriersAdded[i].destroy();}}
+this.barriersAdded.length=0;;},hideBarriers:function(){if(this.barriersAdded&&this.barriersAdded.length>0){this.layer.removeFeatures(this.barriersAdded);}},hideStopsAndBarriers:function(){this.hideStops();this.hideBarriers();},showStopsAndBarriers:function(){if(this.stopsAdded&&this.stopsAdded.length>0){this.layer.addFeatures(this.stopsAdded);}
+if(this.barriersAdded&&this.barriersAdded.length>0){this.layer.addFeatures(this.barriersAdded);}},CLASS_NAME:"OpenLayers.Control.AgsRouteTask"});OpenLayers.Layer.Google.v3={DEFAULTS:{maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),sphericalMercator:true,maxResolution:156543.03390625,units:"m",projection:"EPSG:900913"},animationEnabled:true,loadMapObject:function(){if(!this.type){this.type=google.maps.MapTypeId.ROADMAP;}
+var mapObject;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMapContainer";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);var center=this.map.getCenter();mapObject=new google.maps.Map(div,{center:center?new google.maps.LatLng(center.lat,center.lon):new google.maps.LatLng(0,0),zoom:this.map.getZoom()||0,mapTypeId:this.type,disableDefaultUI:true,keyboardShortcuts:false,draggable:false,disableDoubleClickZoom:true,scrollwheel:false,streetViewControl:false});cache={mapObject:mapObject,count:1};OpenLayers.Layer.Google.cache[this.map.id]=cache;this.repositionListener=google.maps.event.addListenerOnce(mapObject,"center_changed",OpenLayers.Function.bind(this.repositionMapElements,this));}
+this.mapObject=mapObject;this.setGMapVisibility(this.visibility);},repositionMapElements:function(){google.maps.event.trigger(this.mapObject,"resize");var div=this.mapObject.getDiv().firstChild;if(!div||div.childNodes.length<3){this.repositionTimer=window.setTimeout(OpenLayers.Function.bind(this.repositionMapElements,this),250);return false;}
+var cache=OpenLayers.Layer.Google.cache[this.map.id];var container=this.map.viewPortDiv;while(div.lastChild.style.display=="none"){container.appendChild(div.lastChild);}
+var termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright olLayerGoogleV3";termsOfUse.style.display="";cache.termsOfUse=termsOfUse;var poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";poweredBy.style.display="";cache.poweredBy=poweredBy;this.setGMapVisibility(this.visibility);},onMapResize:function(){if(this.visibility){google.maps.event.trigger(this.mapObject,"resize");}else{var cache=OpenLayers.Layer.Google.cache[this.map.id];if(!cache.resized){var layer=this;google.maps.event.addListenerOnce(this.mapObject,"tilesloaded",function(){google.maps.event.trigger(layer.mapObject,"resize");layer.moveTo(layer.map.getCenter(),layer.map.getZoom());delete cache.resized;});}
+cache.resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var type=this.type;var layers=this.map.layers;var layer;for(var i=layers.length-1;i>=0;--i){layer=layers[i];if(layer instanceof OpenLayers.Layer.Google&&layer.visibility===true&&layer.inRange===true){type=layer.type;visible=true;break;}}
+var container=this.mapObject.getDiv();if(visible===true){this.mapObject.setMapTypeId(type);container.style.left="";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.left="";cache.termsOfUse.style.display="";cache.poweredBy.style.display="";}
+cache.displayed=this.id;}else{delete cache.displayed;container.style.left="-9999px";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.display="none";cache.termsOfUse.style.left="-9999px";cache.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getDiv();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new google.maps.LatLngBounds(new google.maps.LatLng(sw.lat,sw.lon),new google.maps.LatLng(ne.lat,ne.lon));}
+return moBounds;},getMapObjectLonLatFromMapObjectPixel:function(moPixel){var size=this.map.getSize();var lon=this.getLongitudeFromMapObjectLonLat(this.mapObject.center);var lat=this.getLatitudeFromMapObjectLonLat(this.mapObject.center);var res=this.map.getResolution();var delta_x=moPixel.x-(size.w/2);var delta_y=moPixel.y-(size.h/2);var lonlat=new OpenLayers.LonLat(lon+delta_x*res,lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}
+return this.getMapObjectLonLatFromLonLat(lonlat.lon,lonlat.lat);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);var res=this.map.getResolution();var extent=this.map.getExtent();var px=new OpenLayers.Pixel((1/res*(lon-extent.left)),(1/res*(extent.top-lat)));return this.getMapObjectPixelFromXY(px.x,px.y);},setMapObjectCenter:function(center,zoom){if(this.animationEnabled===false&&zoom!=this.mapObject.zoom){var mapContainer=this.getMapContainer();google.maps.event.addListenerOnce(this.mapObject,"idle",function(){mapContainer.style.visibility="";});mapContainer.style.visibility="hidden";}
+this.mapObject.setOptions({center:center,zoom:zoom});},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new google.maps.LatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new google.maps.LatLng(lat,lon);}
+return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new google.maps.Point(x,y);},destroy:function(){if(this.repositionListener){google.maps.event.removeListener(this.repositionListener);}
+if(this.repositionTimer){window.clearTimeout(this.repositionTimer);}
+OpenLayers.Layer.Google.prototype.destroy.apply(this,arguments);}};OpenLayers.Format.WPSDescribeProcess=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{wps:"http://www.opengis.net/wps/1.0.0",ows:"http://www.opengis.net/ows/1.1",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",defaultPrefix:"wps",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var info={};this.readNode(data,info);return info;},readers:{"wps":{"ProcessDescriptions":function(node,obj){obj.processDescriptions={};this.readChildNodes(node,obj.processDescriptions);},"ProcessDescription":function(node,processDescriptions){var processVersion=this.getAttributeNS(node,this.namespaces.wps,"processVersion");var processDescription={processVersion:processVersion,statusSupported:(node.getAttribute("statusSupported")==="true"),storeSupported:(node.getAttribute("storeSupported")==="true")};this.readChildNodes(node,processDescription);processDescriptions[processDescription.identifier]=processDescription;},"DataInputs":function(node,processDescription){processDescription.dataInputs=[];this.readChildNodes(node,processDescription.dataInputs);},"ProcessOutputs":function(node,processDescription){processDescription.processOutputs=[];this.readChildNodes(node,processDescription.processOutputs);},"Output":function(node,processOutputs){var output={};this.readChildNodes(node,
 output);processOutputs.push(output);},"ComplexOutput":function(node,output){output.complexOutput={};this.readChildNodes(node,output.complexOutput);},"Input":function(node,dataInputs){var input={maxOccurs:parseInt(node.getAttribute("maxOccurs")),minOccurs:parseInt(node.getAttribute("minOccurs"))};this.readChildNodes(node,input);dataInputs.push(input);},"BoundingBoxData":function(node,input){input.boundingBoxData={};this.readChildNodes(node,input.boundingBoxData);},"CRS":function(node,obj){if(!obj.CRSs){obj.CRSs={};}
+obj.CRSs[this.getChildValue(node)]=true;},"LiteralData":function(node,input){input.literalData={};this.readChildNodes(node,input.literalData);},"ComplexData":function(node,input){input.complexData={};this.readChildNodes(node,input.complexData);},"Default":function(node,complexData){complexData["default"]={};this.readChildNodes(node,complexData["default"]);},"Supported":function(node,complexData){complexData["supported"]={};this.readChildNodes(node,complexData["supported"]);},"Format":function(node,obj){var format={};this.readChildNodes(node,format);if(!obj.formats){obj.formats={};}
+obj.formats[format.mimeType]=true;},"MimeType":function(node,format){format.mimeType=this.getChildValue(node);}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.WPSDescribeProcess"});OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",geonet:"http://www.fao.org/geonetwork",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),split
 Space:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetRecordsResponse":function(node,obj){obj.records=[];this.readChildNodes(node,obj);var version=this.getAttributeNS(node,"",'version');if(version!=""){obj.version=version;}},"RequestId":function(node,obj){obj.RequestId=this.getChildValue(node);},"SearchStatus":function(node,obj){obj.SearchStatus={};var timestamp=this.getAttributeNS(node,"",'timestamp');if(timestamp!=""){obj.SearchStatus.timestamp=timestamp;}},"SearchResults":function(node,obj){this.readChildNodes(node,obj);var attrs=node.attributes;var SearchResults={};for(var i=0,len=attrs.length;i<len;++i){if((attrs[i].name=="numberOfRecordsMatched")||(attrs[i].name=="numberOfRecordsReturned")||(attrs[i].name=="nextRecord")){SearchResults[attrs[i].name]=parseInt(attrs[i].nodeValue);}else{SearchResults[attrs[i].name]=attrs[i].nodeValue;}}
+obj.SearchResults=SearchResults;},"SummaryRecord":function(node,obj){var record={type:"SummaryRecord"};this.readChildNodes(node,record);obj.records.push(record);},"BriefRecord":function(node,obj){var record={type:"BriefRecord"};this.readChildNodes(node,record);obj.records.push(record);},"DCMIRecord":function(node,obj){var record={type:"DCMIRecord"};this.readChildNodes(node,record);obj.records.push(record);},"Record":function(node,obj){var record={type:"Record"};this.readChildNodes(node,record);obj.records.push(record);},"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();obj[name]=this.getChildValue(node);}},"geonet":{"info":function(node,obj){var gninfo={};this.readChildNodes(node,gninfo);obj.gninfo=gninfo;}},"dc":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(OpenLayers.Util.isArray(obj[name]))){obj[name]=new Array();}
+var dc_element={};var attrs=node.attributes;for(var i=0,len=attrs.length;i<len;++i){dc_element[attrs[i].name]=attrs[i].nodeValue;}
+dc_element.value=this.getChildValue(node);obj[name].push(dc_element);}},"dct":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(OpenLayers.Util.isArray(obj[name]))){obj[name]=new Array();}
+obj[name].push(this.getChildValue(node));}},"ows":OpenLayers.Util.applyDefaults({"BoundingBox":function(node,obj){if(obj.bounds){obj.BoundingBox=[{crs:obj.projection,value:[obj.bounds.left,obj.bounds.bottom,obj.bounds.right,obj.bounds.top]}];delete obj.projection;delete obj.bounds;}
+OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"]["BoundingBox"].apply(this,arguments);}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"])},write:function(options){var node=this.writeNode("csw:GetRecords",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetRecords":function(options){if(!options){options={};}
+var node=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:options.requestId||this.requestId,resultType:options.resultType||this.resultType,outputFormat:options.outputFormat||this.outputFormat,outputSchema:options.outputSchema||this.outputSchema,startPosition:options.startPosition||this.startPosition,maxRecords:options.maxRecords||this.maxRecords}});if(options.DistributedSearch||this.DistributedSearch){this.writeNode("csw:DistributedSearch",options.DistributedSearch||this.DistributedSearch,node);}
+var ResponseHandler=options.ResponseHandler||this.ResponseHandler;if(OpenLayers.Util.isArray(ResponseHandler)&&ResponseHandler.length>0){for(var i=0,len=ResponseHandler.length;i<len;i++){this.writeNode("csw:ResponseHandler",ResponseHandler[i],node);}}
+this.writeNode("Query",options.Query||this.Query,node);return node;},"DistributedSearch":function(options){var node=this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:options.hopCount}});return node;},"ResponseHandler":function(options){var node=this.createElementNSPlus("csw:ResponseHandler",{value:options.value});return node;},"Query":function(options){if(!options){options={};}
+var node=this.createElementNSPlus("csw:Query",{attributes:{typeNames:options.typeNames||"csw:Record"}});var ElementName=options.ElementName;if(OpenLayers.Util.isArray(ElementName)&&ElementName.length>0){for(var i=0,len=ElementName.length;i<len;i++){this.writeNode("csw:ElementName",ElementName[i],node);}}else{this.writeNode("csw:ElementSetName",options.ElementSetName||{value:'summary'},node);}
+if(options.Constraint){this.writeNode("csw:Constraint",options.Constraint,node);}
+if(options.SortBy){this.writeNode("ogc:SortBy",options.SortBy,node);}
+return node;},"ElementName":function(options){var node=this.createElementNSPlus("csw:ElementName",{value:options.value});return node;},"ElementSetName":function(options){var node=this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:options.typeNames},value:options.value});return node;},"Constraint":function(options){var node=this.createElementNSPlus("csw:Constraint",{attributes:{version:options.version}});if(options.Filter){var format=new OpenLayers.Format.Filter({version:options.version});node.appendChild(format.write(options.Filter));}else if(options.CqlText){var child=this.createElementNSPlus("CqlText",{value:options.CqlText.value});node.appendChild(child);}
+return node;}},"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
+if(!width){width=2;}
+this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
+return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:true,initialize:function(options){options=options||{};if(options.extractStyles!==false){options.defaultStyle={'externalGraphic':OpenLayers.Util.getImagesLocation()+"marker.png",'graphicWidth':21,'graphicHeight':25,'graphicXOffset':-10.5,'graphicYOffset':-12.5};}
+OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style=this.defaultStyle?OpenLayers.Util.applyDefaults({},this.defaultStyle):null;var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
+attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon'&&style){style['externalGraphic']=vals[valIndex];}else if(columns[valIndex]=='iconSize'&&style){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'&&style){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}else{attributes[columns[valIndex]]=vals[valIndex];}}}
+if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
+return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.location,success:this.parseData,failure:onFail,scope:this});this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options
 ,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
+var parser=new OpenLayers.Format.Text(options);var features=parser.read(text);for(var i=0,len=features.length;i<len;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
+if(feature.style.graphicXOffset!==undefined&&feature.style.graphicYOffset!==undefined){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
+if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
+if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
+data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
+this.addMarker(marker);}
+this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
+if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,citeCompliant:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.Drag.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
+if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
+this.layer=null;this.feature=null;deactivated=true;}
+return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.layer.getLonLatFromViewPortPx(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
+if(this.persist){this.clear();}
+this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.layer.getLonLatFromViewPortPx(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
+this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
+this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
+this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();if(this.start==this.last){this.callback("done",[evt.xy]);}},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
+this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
+for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures();}},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
+if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLength:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new O
 penLayers.StyleMap({"default":this.sketchStyle})});}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},destroy:function(){for(var key in this.layerCache){delete this.layerCache[key];}
+for(var key in this.wfsCache){delete this.wfsCache[key];}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},coupleLayerVisiblity:function(evt){this.setVisibility(evt.object.getVisibility());},createSelectionLayer:function(source){var selectionLayer;if(!this.layerCache[source.id]){selectionLayer=new OpenLayers.Layer.WMS(source.name,source.url,source.params,OpenLayers.Util.applyDefaults(this.layerOptions,source.getOptions()));this.layerCache[source.id]=selectionLayer;if(this.layerOptions.displayInLayerSwitcher===false){source.events.on({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});}
+this.map.addLayer(selectionLayer);}else{selectionLayer=this.layerCache[source.id];}
+return selectionLayer;},createSLD:function(layer,filters,geometryAttributes){var sld={version:"1.0.0",namedLayers:{}};var layerNames=[layer.params.LAYERS].join(",").split(",");for(var i=0,len=layerNames.length;i<len;i++){var name=layerNames[i];sld.namedLayers[name]={name:name,userStyles:[]};var symbolizer=this.selectionSymbolizer;var geometryAttribute=geometryAttributes[i];if(geometryAttribute.type.indexOf('Polygon')>=0){symbolizer={Polygon:this.selectionSymbolizer['Polygon']};}else if(geometryAttribute.type.indexOf('LineString')>=0){symbolizer={Line:this.selectionSymbolizer['Line']};}else if(geometryAttribute.type.indexOf('Point')>=0){symbolizer={Point:this.selectionSymbolizer['Point']};}
+var filter=filters[i];sld.namedLayers[name].userStyles.push({name:'default',rules:[new OpenLayers.Rule({symbolizer:symbolizer,filter:filter,maxScaleDenominator:layer.options.minScale})]});}
+return new OpenLayers.Format.SLD({srsName:this.map.getProjection()}).write(sld);},parseDescribeLayer:function(request){var format=new OpenLayers.Format.WMSDescribeLayer();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var describeLayer=format.read(doc);var typeNames=[];var url=null;for(var i=0,len=describeLayer.length;i<len;i++){if(describeLayer[i].owsType=="WFS"){typeNames.push(describeLayer[i].typeName);url=describeLayer[i].owsURL;}}
+var options={url:url,params:{SERVICE:"WFS",TYPENAME:typeNames.toString(),REQUEST:"DescribeFeatureType",VERSION:"1.0.0"},callback:function(request){var format=new OpenLayers.Format.WFSDescribeFeatureType();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var describeFeatureType=format.read(doc);this.control.wfsCache[this.layer.id]=describeFeatureType;this.control._queue&&this.control.applySelection();},scope:this};OpenLayers.Request.GET(options);},getGeometryAttributes:function(layer){var result=[];var cache=this.wfsCache[layer.id];for(var i=0,len=cache.featureTypes.length;i<len;i++){var typeName=cache.featureTypes[i];var properties=typeName.properties;for(var j=0,lenj=properties.length;j<lenj;j++){var property=properties[j];var type=property.type;if((type.indexOf('LineString')>=0)||(type.indexOf('GeometryAssociationType')>=0)||(type.indexOf('GeometryPropertyType')>=0)||(type.indexOf('Point')>=0)||(type.indexOf('Polygon')>=0)){result.push(property);}}}
+return result;},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&!this.wfsCache[layer.id]){var options={url:layer.url,params:{SERVICE:"WMS",VERSION:layer.params.VERSION,LAYERS:layer.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:layer,control:this}};OpenLayers.Request.GET(options);}}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&this.clearOnDeactivate===true){var layerCache=this.layerCache;var selectionLayer=layerCache[layer.id];if(selectionLayer){layer.events.un({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});selectionLayer.destroy();delete layerCache[layer.id];}}}}
+return deactivated;},setLayers:function(layers){if(this.active){this.deactivate();this.layers=layers;this.activate();}else{this.layers=layers;}},createFilter:function(geometryAttribute,geometry){var filter=null;if(this.handler instanceof OpenLayers.Handler.RegularPolygon){if(this.handler.irregular===true){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:geometryAttribute.name,value:geometry.getBounds()});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Polygon){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else if(this.handler instanceof OpenLayers.Handler.Path){if(geometryAttribute.type.indexOf('Point')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distanc
 e:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Click){if(geometryAttribute.type.indexOf('Polygon')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distance:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}}
+return filter;},select:function(geometry){this._queue=function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];var geometryAttributes=this.getGeometryAttributes(layer);var filters=[];for(var j=0,lenj=geometryAttributes.length;j<lenj;j++){var geometryAttribute=geometryAttributes[j];if(geometryAttribute!==null){if(!(geometry instanceof OpenLayers.Geometry)){var point=this.map.getLonLatFromPixel(geometry.xy);geometry=new OpenLayers.Geometry.Point(point.lon,point.lat);}
+var filter=this.createFilter(geometryAttribute,geometry);if(filter!==null){filters.push(filter);}}}
+var selectionLayer=this.createSelectionLayer(layer);var sld=this.createSLD(layer,filters,geometryAttributes);this.events.triggerEvent("selected",{layer:layer,filters:filters});selectionLayer.mergeNewParams({SLD_BODY:sld});delete this._queue;}};this.applySelection();},applySelection:function(){var canApply=true;for(var i=0,len=this.layers.length;i<len;i++){if(!this.wfsCache[this.layers[i].id]){canApply=false;break;}}
+canApply&&this._queue.call(this);},CLASS_NAME:"OpenLayers.Control.SLDSelect"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:false,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
+this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale;if(this.geodesic===true){var units=this.map.getUnits();if(!units){return;}
+var inches=OpenLayers.INCHES_PER_UNIT;scale=(this.map.getGeodesicPixelSize().w||0.000001)*inches["km"]*OpenLayers.DOTS_PER_INCH;}else{scale=this.map.getScale();}
+if(!scale){return;}
+if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
+this.element.innerHTML=OpenLayers.i18n("Scale = 1 : ${scaleDenom}",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),tileOriginCorner:"tl",initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
+if(options&&options.useOverlay!=null){this.useOverlay=options.useOverlay;}
+if(this.singleTile){if(this.useOverlay){OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS);if(!this.useAsyncOverlay){this.params.version="1.0.0";}}else{OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}}else{if(this.useHttpTile){OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);}
+this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getSize();if(this.singleTile){var params={setdisplaydpi:OpenLayers.DOTS_PER_INCH,setdisplayheight:mapSize.h*this.ratio,setdisplaywidth:mapSize.w*this.ratio,setviewcenterx:center.lon,setviewcentery:center.lat,setviewscale:this.map.getScale()};if(this.useOverlay&&!this.useAsyncOverlay){var getVisParams={};getVisParams=OpenLayers.Util.extend(getVisParams,params);getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';url=this.getFullRequestString(getVisParams);OpenLayers.Request.GET({url:url,async:false});}
+url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);if(this.useHttpTile){url=this.getImageFilePath({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}else{url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}}
+return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
+var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},getImageFilePath:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
+var requestString=url;var tileRowGroup="";var tileColGroup="";if(newParams.tilerow<0){tileRowGroup='-';}
+if(newParams.tilerow==0){tileRowGroup+='0';}else{tileRowGroup+=Math.floor(Math.abs(newParams.tilerow/this.params.tileRowsPerFolder))*this.params.tileRowsPerFolder;}
+if(newParams.tilecol<0){tileColGroup='-';}
+if(newParams.tilecol==0){tileColGroup+='0';}else{tileColGroup+=Math.floor(Math.abs(newParams.tilecol/this.params.tileColumnsPerFolder))*this.params.tileColumnsPerFolder;}
+var tilePath='/S'+Math.floor(newParams.scaleindex)
++'/'+this.params.basemaplayergroupname
++'/R'+tileRowGroup
++'/C'+tileColGroup
++'/'+(newParams.tilerow%this.params.tileRowsPerFolder)
++'_'+(newParams.tilecol%this.params.tileColumnsPerFolder)
++'.'+this.params.format;if(this.params.querystring){tilePath+="?"+this.params.querystring;}
+requestString+=tilePath;return requestString;},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=origin.lat-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{handlerOptions:null,callbacks:null,displaySystem:'metric',geodesic:false,displaySystemUnits:{geogr
 aphic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new handler(this,this.callbacks,this.handlerOptions);},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},cancel:function(){this.cancelDelay();this.handler.cancel();},setImmediate:function(immediate){this.immediate=immediate;if(this.immediate){this.callbacks.modify=this.measureImmediate;}else{delete this.callbacks.modify;}},updateHandler:function(handler,options){var active=this.active;if(active){this.deactivate();}
+this.handler=new handler(this,this.callbacks,options);if(active){this.activate();}},measureComplete:function(geometry){this.cancelDelay();this.measure(geometry,"measure");},measurePartial:function(point,geometry){this.cancelDelay();geometry=geometry.clone();if(this.handler.freehandMode(this.handler.evt)){this.measure(geometry,"measurepartial");}else{this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(geometry,"measurepartial");},this),this.partialDelay);}},measureImmediate:function(point,feature,drawing){if(drawing&&this.delayedTrigger===null&&!this.handler.freehandMode(this.handler.evt)){this.measure(feature.geometry,"measurepartial");}},cancelDelay:function(){if(this.delayedTrigger!==null){window.clearTimeout(this.delayedTrigger);this.delayedTrigger=null;}},measure:function(geometry,eventType){var stat,order;if(geometry.CLASS_NAME.indexOf('LineString')>-1){stat=this.getBestLength(geometry);order=1;}else{stat=this.
 getBestArea(geometry);order=2;}
+this.events.triggerEvent(eventType,{measure:stat[0],units:stat[1],order:order,geometry:geometry});},getBestArea:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,area;for(var i=0,len=units.length;i<len;++i){unit=units[i];area=this.getArea(geometry,unit);if(area>1){break;}}
+return[area,unit];},getArea:function(geometry,units){var area,geomUnits;if(this.geodesic){area=geometry.getGeodesicArea(this.map.getProjectionObject());geomUnits="m";}else{area=geometry.getArea();geomUnits=this.map.getUnits();}
+var inPerDisplayUnit=OpenLayers.INCHES_PER_UNIT[units];if(inPerDisplayUnit){var inPerMapUnit=OpenLayers.INCHES_PER_UNIT[geomUnits];area*=Math.pow((inPerMapUnit/inPerDisplayUnit),2);}
+return area;},getBestLength:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,length;for(var i=0,len=units.length;i<len;++i){unit=units[i];length=this.getLength(geometry,unit);if(length>1){break;}}
+return[length,unit];},getLength:function(geometry,units){var length,geomUnits;if(this.geodesic){length=geometry.getGeodesicLength(this.map.getProjectionObject());geomUnits="m";}else{length=geometry.getLength();geomUnits=this.map.getUnits();}
+var inPerDisplayUnit=OpenLayers.INCHES_PER_UNIT[units];if(inPerDisplayUnit){var inPerMapUnit=OpenLayers.INCHES_PER_UNIT[geomUnits];length*=(inPerMapUnit/inPerDisplayUnit);}
+return length;},CLASS_NAME:"OpenLayers.Control.Measure"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_wmc_SRS:function(layerContext,node){var srs=this.getChildValue(node);if(typeof layerContext.projections!="object"){layerContext.projections={};}
+var values=srs.split(/ +/);for(var i=0,len=values.length;i<len;i++){layerContext.projections[values[i]]=true;}},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[context]);if(context.srs){var projections=[];for(var name in context.srs){projections.push(name);}
+node.appendChild(this.createElementDefaultNS("SRS",projections.join(" ")));}
+node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));if(context.dimensions){node.appendChild(this.write_wmc_DimensionList(context));}
+node.appendChild(this.write_wmc_LayerExtension(context));},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(yx,this.yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],dimensions:[],tileMatrixSetLinks:[]};layer.layers=[];layer.boundingBox=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]
 };this.readChildNodes(node,tileMatrixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
+if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");},"LegendURL":function(node,obj){obj.legend={};obj.legend.href=node.getAttribute("xlink:href");obj.le
 gend.format=node.getAttribute("format");},"Dimension":function(node,obj){var dimension={values:[]};this.readChildNodes(node,dimension);obj.dimensions.push(dimension);},"Default":function(node,obj){obj["default"]=this.getChildValue(node);},"Value":function(node,obj){obj.values.push(this.getChildValue(node));}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities.v1_0_0"});OpenLayers.Raster={};OpenLayers.Raster.Grid=OpenLayers.Class({EVENT_TYPES:["update"],initialize:function(config){OpenLayers.Util.extend(this,config);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},getValue:function(col,row){throw new Error("getValue must be defined")},numCols:function(){throw new Error("numCols must be defined")},numRows:function(){throw new Error("numRows must be defined")},forEach:function(fn){var cols=this.numCols();var rows=this.numRows();for(var j=0;j<rows;++j){for(var i=0;i<cols;++i){fn(this.getValue(i,j),i+j*
 cols);}}},CLASS_NAME:"OpenLayers.Raster.Grid"});OpenLayers.Raster.Grid.fromArray=function(array){var rows=array.length;var cols=array[0]&&array[0].length||0;return new OpenLayers.Raster.Grid({numCols:function(){return cols;},numRows:function(){return rows;},getValue:function(col,row){return array[row][col];}});};OpenLayers.Raster.Composite=OpenLayers.Class(OpenLayers.Raster.Grid,(function(){var grids;return{initialize:function(config){if(config.grids){grids=config.grids;delete config.grids;}
+OpenLayers.Raster.Grid.prototype.initialize.apply(this,[config]);if(grids){for(var i=0,ii=grids.length;i<ii;++i){grids[i].events.register("update",this,function(){this.events.triggerEvent("update");});}}},numCols:function(){return grids&&grids[0]&&grids[0].numCols();},numRows:function(){return grids&&grids[0]&&grids[0].numRows();},getCount:function(){return grids&&grids.length;},getValue:function(col,row){var count=grids.length;var values=new Array(count);for(var c=0;c<count;++c){values[c]=grids[c].getValue(col,row);}
+return values;},getGrid:function(index){if(typeof index!=="number"||isNaN(index)||index<0||index>=this.getCount()){throw new Error("Bad grid index.")}
+var composite=this;return new OpenLayers.Raster.Grid({numCols:function(){return composite.numCols();},numRows:function(){return composite.numRows();},getValue:function(col,row){return composite.getValue(col,row)[index];}});},CLASS_NAME:"OpenLayers.Raster.Composite"};})());OpenLayers.Raster.Composite.fromLayer=function(layer){if(!(layer instanceof OpenLayers.Layer.Grid)){throw new Error("Only OpenLayers.Layer.Grid type layers can be used to create a raster");}
+var canvas=document.createElement("canvas");var context=canvas.getContext("2d");var composite=new OpenLayers.Raster.Composite({numCols:function(){return canvas.width;},numRows:function(){return canvas.height;},getCount:function(){return 4;},getValue:function(col,row){var pixelArray=getPixelArray();var cols=canvas.width;var offset=4*(col+(row*cols));return Array.prototype.slice.apply(pixelArray,[offset,offset+4]);}});var cache={};function getPixelArray(){if(!cache.pixelArray){var imageData=context.getImageData(0,0,canvas.width,canvas.height);cache.pixelArray=imageData.data;}
+return cache.pixelArray;}
+function update(){cache={};var map=layer.map;var tileSize=layer.tileSize;var mapSize=map.getSize();canvas.width=mapSize.w;canvas.height=mapSize.h;var mapBounds=map.getExtent();var tiles=layer.grid;var array,tile,tileBounds,img,cornerLocation,cornerPixel;for(var i=0,ii=tiles.length;i<ii;++i){array=tiles[i];for(var j=0,jj=array.length;j<jj;++j){tile=array[j];tileBounds=tile.bounds;img=tile.imgDiv
+if(img&&img.style.display!=="none"&&mapBounds.intersectsBounds(tileBounds)){cornerLocation=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);cornerPixel=map.getPixelFromLonLat(cornerLocation);context.drawImage(img,cornerPixel.x,cornerPixel.y,tileSize.w,tileSize.h);}}}
+composite.events.triggerEvent("update");}
+if(layer.map){layer.map.events.register("moveend",null,update);}else{layer.events.register("added",null,function(){layer.map.events.register("moveend",null,update);});}
+layer.events.register("tileloaded",null,update);return composite;};OpenLayers.Raster.Operation=(function(){var Grid=OpenLayers.Raster.Grid;var Composite=OpenLayers.Raster.Composite;var operations={};return{create:function(fn){var op=function(){var args=Array.prototype.slice.call(arguments);var len=args.length;function getFirstGrid(){var grid;for(var i=0;i<len;++i){if(args[i]instanceof Grid){grid=args[i];break;}}
+if(!grid){throw new Error("Operation must be called with at least one grid.");}
+return grid;}
+var count=1;for(var i=0;i<len;++i){if(args[i]instanceof Composite){count=Math.max(count,args[i].getCount());}}
+var Constructor=(count>1)?Composite:Grid;var grid=new Constructor({numCols:function(){return getFirstGrid().numCols();},numRows:function(){return getFirstGrid().numRows();},getValue:function(col,row){var values=new Array(len);var arg;for(var i=0;i<len;++i){arg=args[i];if(arg instanceof Grid){values[i]=arg.getValue(col,row);}else{values[i]=arg;}}
+return fn.apply(null,values);},getCount:function(){return count;}});for(var i=0;i<len;++i){if(args[i]instanceof Grid){args[i].events.register("update",null,function(){grid.events.triggerEvent("update");});}}
+return grid;};return op;},get:function(name){return operations[name];}};})();OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),positi
 on:new OpenLayers.Pixel(0,-688)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new Op
 enLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1
 238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,asynJobCompleteCallback:null,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;var addAndShowResults=this._bindFunction(function(evt){this.cleanu
 pResults();this.addResults(evt.results);this.showResults();},this);var _asynTaskCallbacks=[];_asynTaskCallbacks=_asynTaskCallbacks.concat(this.taskCallbacks);_asynTaskCallbacks=_asynTaskCallbacks.concat([addAndShowResults]);this.asynJobCompleteCallback=this._createCallbacks(this,_asynTaskCallbacks,{});this.events.on({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this);},destroy:function(){this.events.un({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[]);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});this._resultsPars
 er={'parser':this.geoprocessingResultsParser,'context':this};var agsFeatureSet=this.adapter.encodeAgsFeatureSet(olFeatures,this.layer.map['projection'],{});var agsGeoprocessor=new esri.tasks.Geoprocessor(this.url);var geoprocessingParams=this.geoprocessingParamsEnocoder(agsFeatureSet,_taskParameters);if(this.asynchronous==false){var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});agsGeoprocessor.execute(geoprocessingParams,_onExecuteComplete);}else{var _onExecuteAsynComplete=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:agsGeoprocessor});agsGeoprocessor.submitJob(geoprocessingParams,_onExecuteAsynComplete,null);}},geoprocessingParamsEnocoder:function(agsFeatureSet,tasksParameters){var geoprocessingParams=tasksParameters;return geoprocessingParams;},geoprocessingResultsParser:function(agsResults,options){var olResults={};return olResults;},CLASS_NAME:"OpenLayers.Control.AgsGeoprocessor"});OpenLa
 yers.Control.ModifyFeatureWithLock=OpenLayers.Class(OpenLayers.Control.ModifyFeature,{deleteFeatureCodes:null,initialize:function(layer,options){OpenLayers.Control.ModifyFeature.prototype.initialize.apply(this,[layer,options]);if(options){if(!options.deleteFeatureCodes){this.deleteFeatureCodes=[81];}else{this.deleteFeatureCodes=options.deleteFeatureCodes;}}
+this.layer.events.on({'transactionsucceeded':function(){this.deactivate();this.activate();},'transactionfailed':function(){this.deactivate();this.activate();},scope:this});},selectFeature:function(feature){this.feature=feature;if(feature.lockId&&feature.lockId!=""){if(this.mode==OpenLayers.Control.ModifyFeature.DELETE){OpenLayers.Console.log("...feature is locked...control in DELETE mode...it can only be deleted...");}else{this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);OpenLayers.Console.log("...feature is locked...so it can be modified...");}}else{OpenLayers.Console.log("...feature is not locked...so it can not be modified/deleted...");}},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){if(feature.lockId&&feature.lockId!=""){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);OpenLayers.Console.log("...feature is locked...drag start...");this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}else{OpenLayers.Console.log("...feature is not locked...drag not start...");}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.mode==OpenLayers.Control.ModifyFeatureWithLock.DELETE){if(this.feature&&OpenLayers.Util.indexOf(this.deleteFeatureCodes,code)!=-1){if(this.feature.lockId&&this.feature.lockId!=""){this.feature.state=OpenLayers.State.DELETE;this.layer.eraseFeatures([this.feature]);if(OpenLayers.Util.indexOf(this.layer.selectedFeatures,this.feature
 )!=-1){OpenLayers.Util.removeItem(this.layer.selectedFeatures,this.feature);}
+console.log("...delete feature at client side...");this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}else{console.log("...can not delete feature...feature must be locked first...");}}}else{if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}}},CLASS_NAME:"OpenLayers.Control.ModifyFeatureWithLock"});OpenLayers.Control.ModifyFeatureWithLock.RESHAPE=1;OpenLayers.Control.ModifyFeatureWithLock.RESIZE=2;OpenLayers.Control.ModifyFeatureWithLock.ROTATE=4;OpenLayers.Control.ModifyFeat
 ureWithLock.DRAG=8;OpenLayers.Control.ModifyFeatureWithLock.DELETE=16;OpenLayers.Tile.Image.IFrame={useIFrame:null,draw:function(){var draw=OpenLayers.Tile.Image.prototype.shouldDraw.call(this);if(draw){var url=this.layer.getURL(this.bounds);var usedIFrame=this.useIFrame;this.useIFrame=this.maxGetUrlLength!==null&&!this.layer.async&&url.length>this.maxGetUrlLength;var fromIFrame=usedIFrame&&!this.useIFrame;var toIFrame=!usedIFrame&&this.useIFrame;if(fromIFrame||toIFrame){if(this.imgDiv&&this.imgDiv.parentNode===this.frame){this.frame.removeChild(this.imgDiv);}
+this.imgDiv=null;if(fromIFrame){this.frame.removeChild(this.frame.firstChild);}}}
+return OpenLayers.Tile.Image.prototype.draw.apply(this,arguments);},createImage:function(){if(this.useIFrame===true){if(!this.frame.childNodes.length){var eventPane=document.createElement("div"),style=eventPane.style;style.position="absolute";style.width="100%";style.height="100%";style.zIndex=1;style.backgroundImage="url("+this.blankImageUrl+")";this.frame.appendChild(eventPane);}
+var id=this.id+'_iFrame',iframe;if(parseFloat(navigator.appVersion.split("MSIE")[1])<9){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
+else{iframe=document.createElement('iframe');iframe.style.backgroundColor='transparent';iframe.name=id;}
+iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';iframe.style.position="absolute";iframe.style.width="100%";iframe.style.height="100%";if(this.layer.opacity<1){OpenLayers.Util.modifyDOMElement(iframe,null,null,null,null,null,null,this.layer.opacity);}
+this.frame.appendChild(iframe);this.imgDiv=iframe;return iframe;}else{return OpenLayers.Tile.Image.prototype.createImage.apply(this,arguments);}},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize(),params=OpenLayers.Util.getParameters(this.url),field;for(var par in params){field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.appendChild(field);}
+return form;},setImgSrc:function(url){if(this.useIFrame===true){if(url){var form=this.createRequestForm();this.frame.appendChild(this.imgDiv);this.frame.appendChild(form);form.submit();this.frame.removeChild(form);}else if(this.imgDiv.parentNode===this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv=null;}}else{OpenLayers.Tile.Image.prototype.setImgSrc.apply(this,arguments);}},createBackBuffer:function(){var backBuffer;if(!this.useIFrame){backBuffer=OpenLayers.Tile.Image.prototype.createBackBuffer.call(this);}
+return backBuffer;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
+this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
+return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options
 ]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
 seFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(node,offeringList[id]);},"time":function(node,offering){offering.time={};this.readChildNodes(node,offering.time);},"procedure":function(node,offering){offering.procedures.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"observedProperty":function(node,offering){offering.observedProperties.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"featureOfInterest":function(node,offering){offering.featureOfInterestIds.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"responseFormat":function(node,offering){offering.responseFormats.push(this.getChildValue(node));},"resultModel":function(node,offering){offering.resultModels.push(this.getChildValue(node));},"responseMode":function(node,offering){offering.responseModes.push(this.getChildValue(node));;}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});OpenL
 ayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:false,pinching:false,last:null,start:null,touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+OpenLayers.Event.stop(evt);return propagate;},touchmove:function(evt){if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;OpenLayers.Event.stop(evt);}
+return true;},touchend:function(evt){if(this.started){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;}
+return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
+return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.clientX-t1.clientX,2)+
+Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(this.defaultControl===null){this.defaultControl=this.controls[0];}
+return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,serverResolutions:null,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
+if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
+if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
+if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);}
+if(!this.tileFullExtent){this.tileFullExtent=this.maxExtent;}}},moveTo:function(bounds,zoomChanged,dragging){if(zoomChanged||!this.matrix){this.updateMatrixProperties();}
+return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMTS(this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getIdentifier:function(){return this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,this.getServerResolution()):this.getServerZoom()+this.zoomOffset;},getMatrix:function(){var matrix;if(!this.matrixIds||this.matrixIds.length===0){matrix={identifier:this.getIdentifier()};}else{if("scaleDenominator"in this.matrixIds[0]){var denom=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.getServerResolution()/0.28E-3;var diff=Number.POSITIVE_INFINITY;var delta;for(var i=0,ii=this.matrixIds.length;i<ii;++i){delta=Math.abs(1-(this.matrixIds[i].scaleDenominator/denom));if(delta<diff){diff=delta;matrix=this.matrixIds[i];}}}else{matrix=this.matrixIds[this.getIdentifier()];}}
+return matrix;},getTileInfo:function(loc){var res=this.getServerResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;if(this.requestEncoding.toUpperCase()==="REST"){var path=this.version+"/"+this.layer+"/"+this.style+"/";if(this.dimensions){for(var i=0;i<this.dimensions.length;i++){if(this.params[this.dimensions[i]]){path=path+this.params[this.dimensions[i]]+"/";}}}
+path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(OpenLayers.Util.isArray(this.url)){url=this.selectUrl(path,this.url);}else{url=this.url;}
+if(!url.match(/\/$/)){url=url+"/";}
+url=url+path;}else if(this.requestEncoding.toUpperCase()==="KVP"){var params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
+return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,autoActivate:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerOrigin,scope:this});this.updateContainerOrigin();}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.apply(this,arguments);if(this.map&&this.map.events){this.map.events.un({moveend:this.updateContainerOrigin,scope:this});}
+return deactivated;},updateContainerOrigin:function(){var container=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(container.style.left,10),y:parseInt(container.style.top,10)};},pinchStart:function(evt,pinchData){this.pinchOrigin=evt.xy;this.currentCenter=evt.xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerOrigin=this.containerOrigin;var pinchOrigin=this.pinchOrigin;var current=evt.xy;var dx=Math.round((current.x-pinchOrigin.x)+(scale-1)*(containerOrigin.x-pinchOrigin.x));var dy=Math.round((current.y-pinchOrigin.y)+(scale-1)*(containerOrigin.y-pinchOrigin.y));this.applyTransform("translate("+dx+"px, "+dy+"px) scale("+scale+")");this.currentCenter=current;},applyTransform:function(transform){var style=this.map.layerContainerDiv.style;style['-webkit-transform']=transform;style['-moz-transform']=transform;},pinchDone:function(evt,start,last){this.applyTransform("");var zoom=this.map.getZoomForResolution(this.map.getResolution()/last.sc
 ale,true);if(zoom!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.setCenter(location,zoom);}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.AgsWFSTLockControl=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,layer:null,lockStrategy:null,lock:null,lockOptions:null,unlock:null,unlockOptions:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(layer instanceof OpenLayers.Layer.Vector){for(var i=0;i<layer.strategies.length;i++){if(laye
 r.strategies[i]instanceof OpenLayers.Strategy.Lock){this.layer=layer;this.lockStrategy=layer.strategies[i];}}}else{OpenLayers.Console.error("...lock control error...");}
+if(this.layer&&this.lockStrategy){var lockOptions={trigger:OpenLayers.Function.bind(this.lockTrigger,this)};OpenLayers.Util.extend(lockOptions,this.lockOptions);this.lock=new OpenLayers.Control.Button(lockOptions);var unlockOptions={trigger:OpenLayers.Function.bind(this.unlockTrigger,this)};OpenLayers.Util.extend(unlockOptions,this.unlockOptions);this.unlock=new OpenLayers.Control.Button(unlockOptions);var toggleButtonFunc=OpenLayers.Util.AgsUtil.bindFunction(function(evt){var feature=evt.feature;if(this.lockStrategy.isFeatureLocked(feature)){this.lock.deactivate();this.unlock.activate();}else{this.lock.activate();this.unlock.deactivate();}},this);var disableButtonFunc=OpenLayers.Util.AgsUtil.bindFunction(function(evt){this.lock.deactivate();this.unlock.deactivate();},this);this.layer.events.on({"featureselected":toggleButtonFunc,"featureunselected":disableButtonFunc,"afterfeatureslocked":disableButtonFunc,"afterfeaturesunlocked":disableButtonFunc});}else{OpenLayers.Console.
 error("...lock control error...");}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.lock.destroy();this.unlock.destroy();this.deactivate();},setMap:function(map){this.map=map;},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.lock.draw();this.unlock.draw();},activate:function(){return OpenLayers.Control.prototype.activate.apply(this);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this);},lockTrigger:function(){if(this.layer.selectedFeatures.length>0){this.lockStrategy.lockFeatures(this.layer.selectedFeatures);}},unlockTrigger:function(){this.lockStrategy.unlockAllFeatures();},CLASS_NAME:"OpenLayers.Control.AgsWFSTLockControl"});OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.p
 rototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
+this.request=OpenLayers.Request.GET({url:this.url,success:success,failure:failure,scope:this});},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var xml=new OpenLayers.Format.XML();if(typeof doc=="string"){doc=xml.read(doc);}
+var resultFeatures=xml.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","featureMember");this.addResults(resultFeatures);}}
+if(this.events){this.events.triggerEvent("loadend");}
+this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{geolocation:navigator.geolocation,bind:true,watch:false,geolocationOptions:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
+if(OpenLayers.Control.prototype.activate.apply(this,arguments)){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);}else{this.getCurrentLocation();}
+return true;}
+return false;},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},geolocate:function(position){var center=new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());if(this.bind){this.map.setCenter(center);}
+this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},getCurrentLocation:function(){if(!this.active||this.watch){return false;}
+this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return true;},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:true,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+if(this.params.FORMAT=="jpg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var projWords=this.projection.getCode().split(":");var srid=projWords[projWords.length-1];var imageSize=this.getImageSize();var newParams={'BBOX':bounds.toBBOX(),'SIZE':imageSize.w+","+imageSize.h,'F':"image",'BBOXSR':srid,'IMAGESR':srid};if(this.layerDefs){var layerDefStrList=[];var layerID;for(layerID in this.layerDefs){if(this.layerDefs.hasOwnProperty(layerID)){if(this.layerDefs[layerID]){layerDefStrList.push(layerID);layerDefStrList.push(":");layerDefStrList.push(this.layerDefs[layerID]);layerDefStrList.push(";");}}}
+if(layerDefStrList.length>0){newParams['LAYERDEFS']=layerDefStrList.join("");}}
+var requestString=this.getFullRequestString(newParams);return requestString;},setLayerFilter:function(id,queryDef){if(!this.layerDefs){this.layerDefs={};}
+if(queryDef){this.layerDefs[id]=queryDef;}else{delete this.layerDefs[id];}},clearLayerFilter:function(id){if(id){delete this.layerDefs[id];}else{delete this.layerDefs;}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
+return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.clearTimer();this.callback('move',[evt]);}
+return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
+Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:false,click:true,single:true,clickout:true,toggle:false,clickTolerance:5,hover:false,box:false,maxFeatures:10,features:null,hoverFeature:null,handlerOptions:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,initialize:function(options){options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);this.features={};this.handlers={};if(this.click){this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.selectClick},this.handlerOptions.click||{});}
+if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},OpenLayers.Util.extend(this.handlerOptions.box,{boxDivClassName:"olHandlerBoxSelectFeature"}));}
+if(this.hover){this.handlers.hover=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.selectHover},OpenLayers.Util.extend(this.handlerOptions.hover,{'delay':250}));}},activate:function(){if(!this.active){for(var i in this.handlers){this.handlers[i].activate();}}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){for(var i in this.handlers){this.handlers[i].deactivate();}}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},selectClick:function(evt){var bounds=this.pixelToBounds(evt.xy);this.setModifiers(evt);this.request(bounds,{single:this.single});},selectBox:function(position){var bounds;if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{if(this.click){return;}
+bounds=this.pixelToBounds(position);}
+this.setModifiers(this.handlers.box.dragHandler.evt);this.request(bounds);},selectHover:function(evt){var bounds=this.pixelToBounds(evt.xy);this.request(bounds,{single:true,hover:true});},cancelHover:function(){if(this.hoverResponse){this.protocol.abort(this.hoverResponse);this.hoverResponse=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");}},request:function(bounds,options){options=options||{};var filter=new OpenLayers.Filter.Spatial({type:this.filterType,value:bounds});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");var response=this.protocol.read({maxFeatures:options.single==true?this.maxFeatures:undefined,filter:filter,callback:function(result){if(result.success()){if(result.features.length){if(options.single==true){this.selectBestFeature(result.features,bounds.getCenterLonLat(),options);}else{this.select(result.features);}}else if(options.hover){this.hoverSelect();}else{this.events.triggerEvent("clickout");if(this.clickout){this.
 unselectAll();}}}
+OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");},scope:this});if(options.hover==true){this.hoverResponse=response;}},selectBestFeature:function(features,clickPosition,options){options=options||{};if(features.length){var point=new OpenLayers.Geometry.Point(clickPosition.lon,clickPosition.lat);var feature,resultFeature,dist;var minDist=Number.MAX_VALUE;for(var i=0;i<features.length;++i){feature=features[i];if(feature.geometry){dist=point.distanceTo(feature.geometry,{edge:false});if(dist<minDist){minDist=dist;resultFeature=feature;if(minDist==0){break;}}}}
+if(options.hover==true){this.hoverSelect(resultFeature);}else{this.select(resultFeature||features);}}},setModifiers:function(evt){this.modifiers={multiple:this.multiple||(this.multipleKey&&evt[this.multipleKey]),toggle:this.toggle||(this.toggleKey&&evt[this.toggleKey])};},select:function(features){if(!this.modifiers.multiple&&!this.modifiers.toggle){this.unselectAll();}
+if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var cont=this.events.triggerEvent("beforefeaturesselected",{features:features});if(cont!==false){var selectedFeatures=[];var feature;for(var i=0,len=features.length;i<len;++i){feature=features[i];if(this.features[feature.fid||feature.id]){if(this.modifiers.toggle){this.unselect(this.features[feature.fid||feature.id]);}}else{cont=this.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){this.features[feature.fid||feature.id]=feature;selectedFeatures.push(feature);this.events.triggerEvent("featureselected",{feature:feature});}}}
+this.events.triggerEvent("featuresselected",{features:selectedFeatures});}},hoverSelect:function(feature){var fid=feature?feature.fid||feature.id:null;var hfid=this.hoverFeature?this.hoverFeature.fid||this.hoverFeature.id:null;if(hfid&&hfid!=fid){this.events.triggerEvent("outfeature",{feature:this.hoverFeature});this.hoverFeature=null;}
+if(fid&&fid!=hfid){this.events.triggerEvent("hoverfeature",{feature:feature});this.hoverFeature=feature;}},unselect:function(feature){delete this.features[feature.fid||feature.id];this.events.triggerEvent("featureunselected",{feature:feature});},unselectAll:function(){for(var fid in this.features){this.unselect(this.features[fid]);}},setMap:function(map){for(var i in this.handlers){this.handlers[i].setMap(map);}
+OpenLayers.Control.prototype.setMap.apply(this,arguments);},pixelToBounds:function(pixel){var llPx=pixel.add(-this.clickTolerance/2,this.clickTolerance/2);var urPx=pixel.add(this.clickTolerance/2,-this.clickTolerance/2);var ll=this.map.getLonLatFromPixel(llPx);var ur=this.map.getLonLatFromPixel(urPx);return new OpenLayers.Bounds(ll.lon,ll.lat,ur.lon,ur.lat);},CLASS_NAME:"OpenLayers.Control.GetFeature"});OpenLayers.Format.QueryStringFilter=(function(){var cmpToStr={};cmpToStr[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";cmpToStr[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN]="lt";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";cmpToStr[OpenLayers.Filter.Comparison.LIKE]="ilike";function regex2value(value){value=value.replace(/%/g,"\\%");value=value.replace(/\\\\\.(\*)?/g,function($0,$
 1){return $1?$0:"\\\\_";});value=value.replace(/\\\\\.\*/g,"\\\\%");value=value.replace(/(\\)?\.(\*)?/g,function($0,$1,$2){return $1||$2?$0:"_";});value=value.replace(/(\\)?\.\*/g,function($0,$1){return $1?$0:"%";});value=value.replace(/\\\./g,".");value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"*";});return value;}
+return OpenLayers.Class(OpenLayers.Format,{wildcarded:false,srsInBBOX:false,write:function(filter,params){params=params||{};var className=filter.CLASS_NAME;var filterType=className.substring(className.lastIndexOf(".")+1);switch(filterType){case"Spatial":switch(filter.type){case OpenLayers.Filter.Spatial.BBOX:params.bbox=filter.value.toArray();if(this.srsInBBOX&&filter.projection){params.bbox.push(filter.projection.getCode());}
+break;case OpenLayers.Filter.Spatial.DWITHIN:params.tolerance=filter.distance;case OpenLayers.Filter.Spatial.WITHIN:params.lon=filter.value.x;params.lat=filter.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+filter.type);}
+break;case"Comparison":var op=cmpToStr[filter.type];if(op!==undefined){var value=filter.value;if(filter.type==OpenLayers.Filter.Comparison.LIKE){value=regex2value(value);if(this.wildcarded){value="%"+value+"%";}}
+params[filter.property+"__"+op]=value;params.queryable=params.queryable||[];params.queryable.push(filter.property);}else{OpenLayers.Console.warn("Unknown comparison filter type "+filter.type);}
+break;case"Logical":if(filter.type===OpenLayers.Filter.Logical.AND){for(var i=0,len=filter.filters.length;i<len;i++){params=this.write(filter.filters[i],params);}}else{OpenLayers.Console.warn("Unsupported logical filter type "+filter.type);}
+break;default:OpenLayers.Console.warn("Unknown filter type "+filterType);}
+return params;},CLASS_NAME:"OpenLayers.Format.QueryStringFilter"});})();OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.events.register('mousemove',this,this.redraw);this.map.events.register('mouseout',this,this.reset);this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('mousemove',this,this.redraw);this.map.events.unregister('mouseout',this,this.reset);this.element.innerHTML="";return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left=
 "";this.div.top="";this.element=this.div;}
+return this.div;},redraw:function(evt){var lonLat;if(evt==null){this.reset();return;}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
+{this.lastXy=evt.xy;return;}
+lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
+if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
+this.lastXy=evt.xy;}
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},reset:function(evt){if(this.emptyString!=null){this.element.innerHTML=this.emptyString;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
+lonLat.lon.toFixed(digits)+
+this.separator+
+lonLat.lat.toFixed(digits)+
+this.suffix;return newHtml;},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Layer.Process=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,displayInLayerSwitcher:false,visibility:false,describeProcessUrl:"",executeUrl:"",processIdentifier:null,process:null,autoLoad:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Process"});OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:false,wildcarded:false,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var format=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=function(filter,params){return format.write(filter,params);}
 }},destroy:function(){this.params=null;this.headers=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=options||{};options.params=OpenLayers.Util.applyDefaults(options.params,this.options.params);options=OpenLayers.Util.applyDefaults(options,this.options);if(options.filter&&this.filterToParams){options.params=this.filterToParams(options.filter,options.params);}
+var readWithPOST=(options.readWithPOST!==undefined)?options.readWithPOST:this.readWithPOST;var resp=new OpenLayers.Protocol.Response({requestType:"read"});if(readWithPOST){resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,resp,options),data:OpenLayers.Util.getParameterString(options.params),headers:{"Content-Type":"application/x-www-form-urlencoded"}});}else{resp.priv=OpenLayers.Request.GET({url:options.url,callback:this.createCallback(this.handleRead,resp,options),params:options.params,headers:options.headers});}
+return resp;},handleRead:function(resp,options){this.handleResponse(resp,options);},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:features,requestType:"create"});resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleCreate,resp,options),headers:options.headers,data:this.format.write(features)});return resp;},handleCreate:function(resp,options){this.handleResponse(resp,options);},update:function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"update"});resp.priv=OpenLayers.Request.PUT({url:url,callback:this.createCallback(this.handleUpdate,resp,options),headers:options.headers,data:this.format.write(feature)});return resp;},handleUpdate:function(resp
 ,options){this.handleResponse(resp,options);},"delete":function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"delete"});resp.priv=OpenLayers.Request.DELETE({url:url,callback:this.createCallback(this.handleDelete,resp,options),headers:options.headers});return resp;},handleDelete:function(resp,options){this.handleResponse(resp,options);},handleResponse:function(resp,options){var request=resp.priv;if(options.callback){if(request.status>=200&&request.status<300){if(resp.requestType!="delete"){resp.features=this.parseFeatures(request);}
+resp.code=OpenLayers.Protocol.Response.SUCCESS;}else{resp.code=OpenLayers.Protocol.Response.FAILURE;}
+options.callback.call(options.scope,resp);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(!doc||doc.length<=0){return null;}
+return this.format.read(doc);},commit:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=[],nResponses=0;var types={};types[OpenLayers.State.INSERT]=[];types[OpenLayers.State.UPDATE]=[];types[OpenLayers.State.DELETE]=[];var feature,list,requestFeatures=[];for(var i=0,len=features.length;i<len;++i){feature=features[i];list=types[feature.state];if(list){list.push(feature);requestFeatures.push(feature);}}
+var nRequests=(types[OpenLayers.State.INSERT].length>0?1:0)+
+types[OpenLayers.State.UPDATE].length+
+types[OpenLayers.State.DELETE].length;var success=true;var finalResponse=new OpenLayers.Protocol.Response({reqFeatures:requestFeatures});function insertCallback(response){var len=response.features?response.features.length:0;var fids=new Array(len);for(var i=0;i<len;++i){fids[i]=response.features[i].fid;}
+finalResponse.insertIds=fids;callback.apply(this,[response]);}
+function callback(response){this.callUserCallback(response,options);success=success&&response.success();nResponses++;if(nResponses>=nRequests){if(options.callback){finalResponse.code=success?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.apply(options.scope,[finalResponse]);}}}
+var queue=types[OpenLayers.State.INSERT];if(queue.length>0){resp.push(this.create(queue,OpenLayers.Util.applyDefaults({callback:insertCallback,scope:this},options.create)));}
+queue=types[OpenLayers.State.UPDATE];for(var i=queue.length-1;i>=0;--i){resp.push(this.update(queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options.update)));}
+queue=types[OpenLayers.State.DELETE];for(var i=queue.length-1;i>=0;--i){resp.push(this["delete"](queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options["delete"])));}
+return resp;},abort:function(response){if(response){response.priv.abort();}},callUserCallback:function(resp,options){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}},CLASS_NAME:"OpenLayers.Protocol.HTTP"});OpenLayers.Strategy.Cluster=OpenLayers.Class(OpenLayers.Strategy,{distance:20,threshold:null,features:null,clusters:null,clustering:false,resolution:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"beforefeaturesadded":this.cacheFeatures,"moveend":this.cluster,scope:this});}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.clearCache();this.layer.events.un({"beforefeaturesadded":this.cacheFeatures,"moveend":this.cluster,scope:this});}
+return deactivated;},cacheFeatures:function(event){var propagate=true;if(!this.clustering){this.clearCache();this.features=event.features;this.cluster();propagate=false;}
+return propagate;},clearCache:function(){this.features=null;},cluster:function(event){if((!event||event.zoomChanged)&&this.features){var resolution=this.layer.map.getResolution();if(resolution!=this.resolution||!this.clustersExist()){this.resolution=resolution;var clusters=[];var feature,clustered,cluster;for(var i=0;i<this.features.length;++i){feature=this.features[i];if(feature.geometry){clustered=false;for(var j=clusters.length-1;j>=0;--j){cluster=clusters[j];if(this.shouldCluster(cluster,feature)){this.addToCluster(cluster,feature);clustered=true;break;}}
+if(!clustered){clusters.push(this.createCluster(this.features[i]));}}}
+this.layer.removeAllFeatures();if(clusters.length>0){if(this.threshold>1){var clone=clusters.slice();clusters=[];var candidate;for(var i=0,len=clone.length;i<len;++i){candidate=clone[i];if(candidate.attributes.count<this.threshold){Array.prototype.push.apply(clusters,candidate.cluster);}else{clusters.push(candidate);}}}
+this.clustering=true;this.layer.addFeatures(clusters);this.clustering=false;}
+this.clusters=clusters;}}},clustersExist:function(){var exist=false;if(this.clusters&&this.clusters.length>0&&this.clusters.length==this.layer.features.length){exist=true;for(var i=0;i<this.clusters.length;++i){if(this.clusters[i]!=this.layer.features[i]){exist=false;break;}}}
+return exist;},shouldCluster:function(cluster,feature){var cc=cluster.geometry.getBounds().getCenterLonLat();var fc=feature.geometry.getBounds().getCenterLonLat();var distance=(Math.sqrt(Math.pow((cc.lon-fc.lon),2)+Math.pow((cc.lat-fc.lat),2))/this.resolution);return(distance<=this.distance);},addToCluster:function(cluster,feature){cluster.cluster.push(feature);cluster.attributes.count+=1;},createCluster:function(feature){var center=feature.geometry.getBounds().getCenterLonLat();var cluster=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(center.lon,center.lat),{count:1});cluster.cluster=[feature];return cluster;},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Protocol.SOS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.SOS.DEFAULTS);var cls=OpenLayers.Protocol.SOS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported SOS version: "+options.version;}
+return new cls(options);};OpenLayers.Protocol.SOS.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");var box=this.getElementsByTagNameNS(item,this.georssns,"box");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenL
 ayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
+var geometry=new OpenLayers.Geometry.Point(location[1],location[0]);}else if(line.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(line[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(coords[i+1],coords[i]);components.push(point);}
+geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(polygon[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(coords[i+1],coords[i]);components.push(point);}
+geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
+var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}else if(box.length>0){var coords=OpenLayers.String.trim(box[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;if(coords.length>3){point=new OpenLayers.Geometry.Point(coords[1],coords[0]);components.push(point);point=new OpenLayers.Geometry.Point(coords[1],coords[2]);components.push(point);point=new OpenLayers.Geometry.Point(coords[3],coords[2]);components.push(point);point=new OpenLayers.Geometry.Point(coords[3],coords[0]);components.push(point);point=new OpenLayers.Geometry.Point(coords[1],coords[0]);components.push(point);}
+if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.getChildValue(item,"*","summary",this.featureDescription)));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
+var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;var eles=this.getElementsByTagNameNS(node,nsuri,name);if(eles&&eles[0]&&eles[0].firstChild&&eles[0].firstChild.nodeValue){value=OpenLayers.Format.XML.prototype.getChildValue(eles[0]);}else{value=(def==undefined)?"":def;}
+return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
+var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
+return features;},write:function(features){var georss;if(OpenLayers.Util.isArray(features)){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
+return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
+for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
+var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
+var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
+featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
+return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
+var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
+path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
+return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.WPSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.WPSCapabilities"});OpenLayers.Format.WPSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wps:"http://www.opengis.net/wps/1.0.0",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"wps":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"ProcessOfferings":function(node,obj){obj.processOfferings={};this.readChildNodes(node,obj.processOfferings);},"Process":function(node,processOfferings){var processVersion=this.getAttributeNS(node,this.namespaces.wps,"processVersion");var process={processVersion:processVersion};this.readChildNodes(node,process);processOfferings[process.identifier]=process;},"Languages":function(node,obj){obj.languages=[];this.readChildNodes(node,obj.languages);},"Default":function(node,languages){var language={isDefault:true};this.readChildNodes(node,language);languages.push(language);},"Supported":function(node,languages){var language={};this.readChildNodes(node,language);languages.push(language);}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.WPSCapabilities.v1_0_0"});OpenLayers.Contr
 ol.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.pinchZoom){this.pinchZoom.destroy();delete this.pinchZoom;}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();this.pinchZoom.activate();return true;}
+return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();this.pinchZoom.deactivate();return true;}
+return false;},draw:function(){var clickCallbacks={click:this.defaultClick,dblclick:this.defaultDblClick};var clickOptions=OpenLayers.Util.extend({"double":true,stopDouble:true,pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Style2=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,initialize:func
 tion(config){OpenLayers.Util.extend(this,config);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();}
+delete this.rules;},clone:function(){var config=OpenLayers.Util.extend({},this);if(this.rules){config.rules=[];for(var i=0,len=this.rules.length;i<len;++i){config.rules.push(this.rules[i].clone());}}
+return new OpenLayers.Style2(config);},CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Protocol.WFSTWithLock.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFSTWithLock.v1,{version:"1.1.0",CLASS_NAME:"OpenLayers.Protocol.WFSTWithLock.v1_1_0"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if
 ((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},read_cap_Service:function(capabilities,node){var service={};this.runChildNodes(service,node);capabilities.service=service;},read_cap_Fees:function(service,node){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){service.fees=fees;}},read_cap_AccessConstraints:function(service,node){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){service.accessConstraints=constraints;}},read_cap_OnlineResource:function(service,node){var onlineResource=this.getChildValue(node);if(onlineResource&&onlineResource.toLowerCase()!="none"){service.onlineResource=onlineResource;}},read_cap_Keywords:function(
 service,node){var keywords=this.getChildValue(node);if(keywords&&keywords.toLowerCase()!="none"){service.keywords=keywords.split(', ');}},read_cap_Capability:function(capabilities,node){var capability={};this.runChildNodes(capability,node);capabilities.capability=capability;},read_cap_Request:function(obj,node){var request={};this.runChildNodes(request,node);obj.request=request;},read_cap_GetFeature:function(request,node){var getfeature={href:{},formats:[]};this.runChildNodes(getfeature,node);request.getfeature=getfeature;},read_cap_ResultFormat:function(obj,node){var children=node.childNodes;var childNode;for(var i=0;i<children.length;i++){childNode=children[i];if(childNode.nodeType==1){obj.formats.push(childNode.nodeName);}}},read_cap_DCPType:function(obj,node){this.runChildNodes(obj,node);},read_cap_HTTP:function(obj,node){this.runChildNodes(obj.href,node);},read_cap_Get:function(obj,node){obj.get=node.getAttribute("onlineResource");},read_cap_Post:function(obj,node){obj.
 post=node.getAttribute("onlineResource");},read_cap_SRS:function(obj,node){var srs=this.getChildValue(node);if(srs){obj.srs=srs;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031],type:null,wrapDateLine:true,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},lo
 adMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
+this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
+return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lon
 lat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
+return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.
 75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(config){config=config||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[config.name,config]);},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);map.events.register("moveend",this,this.onMoveEnd);},removeMap:function(map){map.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},setRatio:function(ratio){this.ratio=ratio;this.updateGrid(true);},setMaxFeatures:function(maxFeatures)
 {this.maxFeatures=maxFeatures;this.updateGrid(true);},setSpacing:function(dx,dy){this.dx=dx;this.dy=dy||dx;this.updateGrid(true);},setOrigin:function(origin){this.origin=origin;this.updateGrid(true);},getOrigin:function(){if(!this.origin){this.origin=this.map.getExtent().getCenterLonLat();}
+return this.origin;},setRotation:function(rotation){this.rotation=rotation;this.updateGrid(true);},onMoveEnd:function(){this.updateGrid();},getViewBounds:function(){var bounds=this.map.getExtent();if(this.rotation){var origin=this.getOrigin();var rotationOrigin=new OpenLayers.Geometry.Point(origin.lon,origin.lat);var rect=bounds.toGeometry();rect.rotate(-this.rotation,rotationOrigin);bounds=rect.getBounds();}
+return bounds;},updateGrid:function(force){if(force||this.invalidBounds()){var viewBounds=this.getViewBounds();var origin=this.getOrigin();var rotationOrigin=new OpenLayers.Geometry.Point(origin.lon,origin.lat);var viewBoundsWidth=viewBounds.getWidth();var viewBoundsHeight=viewBounds.getHeight();var aspectRatio=viewBoundsWidth/viewBoundsHeight;var maxHeight=Math.sqrt(this.dx*this.dy*this.maxFeatures/aspectRatio);var maxWidth=maxHeight*aspectRatio;var gridWidth=Math.min(viewBoundsWidth*this.ratio,maxWidth);var gridHeight=Math.min(viewBoundsHeight*this.ratio,maxHeight);var center=viewBounds.getCenterLonLat();this.gridBounds=new OpenLayers.Bounds(center.lon-(gridWidth/2),center.lat-(gridHeight/2),center.lon+(gridWidth/2),center.lat+(gridHeight/2));var rows=Math.floor(gridHeight/this.dy);var cols=Math.floor(gridWidth/this.dx);var gridLeft=origin.lon+(this.dx*Math.ceil((this.gridBounds.left-origin.lon)/this.dx));var gridBottom=origin.lat+(this.dy*Math.ceil((this.gridBounds.bottom
 -origin.lat)/this.dy));var features=new Array(rows*cols);var x,y,point;for(var i=0;i<cols;++i){x=gridLeft+(i*this.dx);for(var j=0;j<rows;++j){y=gridBottom+(j*this.dy);point=new OpenLayers.Geometry.Point(x,y);if(this.rotation){point.rotate(this.rotation,rotationOrigin);}
+features[(i*rows)+j]=new OpenLayers.Feature.Vector(point);}}
+this.destroyFeatures(this.features,{silent:true});this.addFeatures(features,{silent:true});}},invalidBounds:function(){return!this.gridBounds||!this.gridBounds.containsBounds(this.getViewBounds());},CLASS_NAME:"OpenLayers.Layer.PointGrid"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,tileOriginCorner:"tl",numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);while(imageSize.w>this.standardTileSize||imageSiz
 e.h>this.standardTileSize){imageSize=new OpenLayers.Size(Math.floor(imageSize.w/2),Math.floor(imageSize.h/2));tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);}
+this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;this.tileCountUpToTier[0]=0;for(var i=1;i<this.numberOfTiers;i++){this.tileCountUpToTier.push(this.tierSizeInTiles[i-1].w*this.tierSizeInTiles[i-1].h+
+this.tileCountUpToTier[i-1]);}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var tileIndex=x+y*this.tierSizeInTiles[z].w+this.tileCountUpToTier[z];var path="TileGroup"+Math.floor((tileIndex)/256)+"/"+z+"-"+x+"-"+y+".jpg";var url=this.url;if(OpenLayers.Util.isA
