[OpenLayers-Commits] r11071 - in trunk/openlayers: lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 8 15:47:23 EST 2011
Author: erilem
Date: 2011-02-08 12:47:23 -0800 (Tue, 08 Feb 2011)
New Revision: 11071
   trunk/openlayers/lib/OpenLayers/Control/DragFeature.js
   trunk/openlayers/tests/Control/DragFeature.html
add onEnter and onLeave callback functions to the DragFeature control, p=adube, r=me (closes #3034)
Modified: trunk/openlayers/lib/OpenLayers/Control/DragFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/DragFeature.js	2011-02-02 15:00:57 UTC (rev 11070)
+++ trunk/openlayers/lib/OpenLayers/Control/DragFeature.js	2011-02-08 20:47:23 UTC (rev 11071)
@@ -66,6 +66,28 @@
     onComplete: function(feature, pixel) {},
+     * APIProperty: onEnter
+     * {Function} Define this function if you want to know when the mouse
+     *     goes over a feature and thereby makes this feature a candidate
+     *     for dragging.
+     * Parameters:
+     * feature - {<OpenLayers.Feature.Vector>} The feature that is ready
+     *     to be dragged.
+    onEnter: function(feature) {},
+     * APIProperty: onLeave
+     *     goes out of the feature that was dragged.
+     * Parameters:
+     * feature - {<OpenLayers.Feature.Vector>} The feature that was dragged.
+    onLeave: function(feature) {},
      * APIProperty: documentDrag
      * {Boolean} If set to true, mouse dragging will continue even if the
      *     mouse cursor leaves the map viewport. Default is false.
@@ -192,6 +214,7 @@
             this.handlers.drag.activate();
             this.over = true;
             OpenLayers.Element.addClass(this.map.viewPortDiv, this.displayClass + "Over");
+            this.onEnter(feature);
         } else {
             if(this.feature.id == feature.id) {
                 this.over = true;
@@ -269,6 +292,7 @@
             OpenLayers.Element.removeClass(
+            this.onLeave(feature);
             this.feature = null;
         } else {
Modified: trunk/openlayers/tests/Control/DragFeature.html
--- trunk/openlayers/tests/Control/DragFeature.html	2011-02-02 15:00:57 UTC (rev 11070)
+++ trunk/openlayers/tests/Control/DragFeature.html	2011-02-08 20:47:23 UTC (rev 11071)
@@ -71,11 +71,14 @@
     function test_Control_DragFeature_over(t) {
-        t.plan(3);
+        t.plan(5);
+        var log = [];
         var map = new OpenLayers.Map("map");
         var layer = new OpenLayers.Layer.Vector();
         map.addLayer(layer);
-        var control = new OpenLayers.Control.DragFeature(layer);
+        var control = new OpenLayers.Control.DragFeature(layer, {
+            onEnter: function(f) { log.push({feature: f}); }
         map.addControl(control);
         control.activate();
@@ -94,6 +97,10 @@
              "control gets the proper feature from the feature handler");
         t.ok(control.handlers.drag.active,
              "drag handler activated when over a feature");
+        t.eq(log.length, 1,
+             "onEnter called exactly once");
+        t.eq(log[0].feature.id, feature.id,
+             "onEnter called with expected feature");
     function test_Control_DragFeature_down(t) {
@@ -241,11 +248,14 @@
     function test_Control_DragFeature_out(t) {
-        t.plan(2);
+        t.plan(4);
+        var log = [];
+            onLeave: function(f) { log.push({feature: f}); }
         control.activate();
@@ -268,7 +278,10 @@
         map.events.triggerEvent("mousemove", {type: "mousemove"});
         t.ok(control.feature == null,
              "feature is set to null on mouse out");
+             "onLeave called exactly once");
+             "onLeave called with expected feature");
     </script>
More information about the Commits mailing list
