[OpenLayers-Commits] r11078 - sandbox/elemoine/draw-feature/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 10 05:45:25 EST 2011
Author: erilem
Date: 2011-02-10 02:45:25 -0800 (Thu, 10 Feb 2011)
New Revision: 11078
   sandbox/elemoine/draw-feature/tests/Handler/Path.html
path handler - fix and add tests
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-10 10:45:19 UTC (rev 11077)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-10 10:45:25 UTC (rev 11078)
@@ -25,12 +25,27 @@
     function test_Handler_Path_activation(t) {
-        t.plan(3);
-        var map = new OpenLayers.Map('map');
+        t.plan(12);
+        var log = [];
+        var map = new OpenLayers.Map("map", {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
         var control = new OpenLayers.Control();
+        var handler = new OpenLayers.Handler.Path(control, {
+            "create": function(g, f) {
+                log.push({geometry: g, feature: f});
+        control.handler = handler;
         map.addControl(control);
-        var handler = new OpenLayers.Handler.Path(control);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
         handler.active = true;
         var activated = handler.activate();
         t.ok(!activated,
              "activate returns false if the handler was already active");
@@ -38,20 +53,44 @@
         t.ok(activated,
              "activate returns true if the handler was not already active");
+        t.ok(handler.layer instanceof OpenLayers.Layer.Vector,
+             "activate creates a vector layer");
+        t.ok(handler.layer.map == map,
+             "activate adds the vector layer to the map");
+        t.ok(handler.point instanceof OpenLayers.Feature.Vector,
+             "activate creates a point feature");
+        t.ok(handler.point.layer == handler.layer,
+             "activate adds the point feature to the layer");
+        t.ok(handler.line instanceof OpenLayers.Feature.Vector,
+             "acttivates creates a line feature");
+        t.ok(handler.line.layer == handler.layer,
+             "activate adds the line feature to the layer");
+        t.eq(log.length, 1,
+             "activate calls \"create\" once");
+        t.geom_eq(log[0].geometry, handler.point.geometry,
+                  "\"create\" called with expected geometry");
+        t.ok(log[0].feature == handler.line,
+             "\"create\" called with expected feature");
         activated = handler.deactivate();
         t.ok(activated,
              "deactivate returns true if the handler was active already");
-        map.destroy();
+        map.destroy();
     function test_Handler_Path_bounds(t) {
         t.plan(2);
+        var geometry;
         map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
         map.zoomToMaxExtent();
-        var handler = new OpenLayers.Handler.Path(control, {});
+            modify: function(g, f) {
+                geometry = f.geometry;
         var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
         handler.mousedown(evt);
@@ -60,17 +99,23 @@
         handler.mousemove(evt);
         handler.mouseup(evt);
-        t.ok(handler.line.geometry.getBounds().equals(new OpenLayers.Bounds(0,-35.15625,35.15625,0)), "Correct bounds");
+        t.ok(geometry.getBounds().equals(
+                    new OpenLayers.Bounds(0,-35.15625,35.15625,0)),
+             "Correct bounds");
         var evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
         var evt = {xy: new OpenLayers.Pixel(125, 100), which: 1};
-        t.ok(!handler.line.geometry.getBounds().equals(new OpenLayers.Bounds(0,-35.15625,35.15625,0)), "Correct bounds after dragging without letting go. (Came out as "+handler.line.geometry.getBounds().toBBOX() + ".)");
+        t.ok(!handler.line.geometry.getBounds().equals(
+             "Correct bounds after dragging without letting go. " +
+             "(Came out as " + handler.line.geometry.getBounds().toBBOX() +
         map.destroy();
     function test_callbacks(t) {
-        t.plan(15);
+        t.plan(36);
             resolutions: [1]
@@ -79,71 +124,124 @@
             isBaseLayer: true
-        var control = new OpenLayers.Control({
-        var log = {};
+        var control = new OpenLayers.Control({});
+        var log = [];
             create: function() {
-                log.type = "create",
-                log.args = arguments
+                log.push({type: "create", args: arguments});
+            point: function() {
+                log.push({type: "point", args: arguments});
             modify: function() {
-                log.type = "modify",
+                log.push({type: "modify", args: arguments});
             done: function() {
-                log.type = "done",
+                log.push({type: "done", args: arguments});
             cancel: function() {
-                log.type = "cancel",
+                log.push({type: "cancel", args: arguments});
-        // mock up feature drawing
+        // create line
         handler.activate();
-        handler.mousedown({type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
-        t.eq(log.type, "create", "[mousedown] create called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[mousedown] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mousedown] correct sketch feature");
+        t.eq(log.length, 1, "[activate] called back");
+        t.eq(log[0].type, "create", "[activate] create called");
+        t.geom_eq(log[0].args[0], new OpenLayers.Geometry.Point(-200, 125),
+                  "[activate] correct point");
+        t.ok(log[0].args[1] == handler.line,
+             "[activate] correct feature");
+        // mouse down
+        handler.mousedown(
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(log.length, 2, "[mousedown] called back");
+        t.eq(log[1].type, "modify", "[mousedown] modify called");
+        t.geom_eq(log[1].args[0], new OpenLayers.Geometry.Point(-150, 75),
+                  "[mousedown] correct point");
+        t.ok(log[1].args[1] == handler.line,
+             "[mousedown] correct feature");
+        // mouse up
         handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
-        t.eq(log.type, "modify", "[mouseup] modify called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[mouseup] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mouseup] correct sketch feature");
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
-        t.eq(log.type, "modify", "[mousemove] modify called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-149, 74), "[mousemove] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mousemove] correct sketch feature");
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(10, 10)});
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-140, 65), "[mousemove] correct vertex");
-        handler.mousedown({type: "mousedown", xy: new OpenLayers.Pixel(10, 10)});
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(10, 10)});
-        handler.dblclick({type: "dblclick", xy: new OpenLayers.Pixel(10, 10)});
-        t.eq(log.type, "done", "[dblclick] done called");
-        t.geom_eq(
-            log.args[0],
+        t.eq(log.length, 4, "[mouseup] called back twice");
+        t.eq(log[2].type, "point", "[mouseup] point called");
+        t.geom_eq(log[2].args[0], new OpenLayers.Geometry.Point(-150, 75),
+                  "[mouseup] correct point");
+        t.geom_eq(log[2].args[1],
+                  new OpenLayers.Geometry.LineString([
+                      new OpenLayers.Geometry.Point(-150, 75),
+                  ]), "[mouseup] correct line");
+        t.eq(log[3].type, "modify", "[mouseup] modify called");
+        t.geom_eq(log[3].args[0], new OpenLayers.Geometry.Point(-150, 75),
+        t.ok(log[3].args[1] == handler.line,
+             "[mouseup] correct feature");
+        // mouse move
+        handler.mousemove({type: "mousemove",
+                           xy: new OpenLayers.Pixel(1, 1)});
+        t.eq(log.length, 5, "[mousemove] called back");
+        t.eq(log[4].type, "modify", "[mousemove] modify called");
+        t.geom_eq(log[4].args[0], new OpenLayers.Geometry.Point(-149, 74),
+                  "[mousemove] correct point");
+        t.ok(log[4].args[1] === handler.line,
+             "[mousemove] correct feature");
+        // mouse move
+                           xy: new OpenLayers.Pixel(10, 10)});
+        t.eq(log.length, 6, "[mousemove] called back");
+        t.eq(log[5].type, "modify", "[mousemove] modify called");
+        t.geom_eq(log[5].args[0], new OpenLayers.Geometry.Point(-140, 65),
+        t.ok(log[5].args[1] === handler.line,
+        // mouse down ("modify")
+        handler.mousedown({type: "mousedown",
+        t.eq(log.length, 7, "[mousedown] called back");
+        // mouse up ("point", "modify")
+        handler.mouseup({type: "mouseup",
+        t.eq(log.length, 9, "[mouseup] called back twice");
+        t.eq(log.length, 10, "[mousedown] called back");
+        t.eq(log.length, 10, "[mouseup] not called back");
+        // double click
+        handler.dblclick({type: "dblclick",
+        t.eq(log.length, 12, "[dblclick] called back");
+        t.eq(log[10].type, "done", "[dblclick] done called");
+        t.geom_eq(log[10].args[0],
             "[dblclick] correct linestring"
+        t.eq(log[11].type, "create", "[dblclick] create called");
+        t.geom_eq(log[11].args[0], new OpenLayers.Geometry.Point(-200, 125),
+                  "[dblclick] correct point");
+        t.ok(log[11].args[1] == handler.line,
+             "[dblclick] correct feature");
+        // cancel
+        handler.cancel();
+        t.eq(log.length, 13, "[cancel] called back");
+        t.eq(log[12].type, "cancel", "[cancel] canced called");
+        t.geom_eq(log[12].args[0],
+                new OpenLayers.Geometry.Point(-200, 125)
+            "[cancel] correct linestring"
-        // mock up sketch cancel
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
-        handler.deactivate();
-        t.eq(log.type, "cancel", "[deactivate while drawing] cancel called");
         map.destroy();
More information about the Commits mailing list
