[OpenLayers-Commits] r11086 - in sandbox/elemoine/draw-feature: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 10 05:46:31 EST 2011
Author: erilem
Date: 2011-02-10 02:46:31 -0800 (Thu, 10 Feb 2011)
New Revision: 11086
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
   sandbox/elemoine/draw-feature/tests/Handler/Point.html
point handler - do not call modifyFeature on mousedown
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-02-10 10:46:23 UTC (rev 11085)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-02-10 10:46:31 UTC (rev 11086)
@@ -333,7 +333,6 @@
     mousedown: function(evt) {
         this.lastDown = evt.xy;
-        this.modifyFeature(evt.xy);
         return !this.stopDown;
Modified: sandbox/elemoine/draw-feature/tests/Handler/Point.html
--- sandbox/elemoine/draw-feature/tests/Handler/Point.html	2011-02-10 10:46:23 UTC (rev 11085)
+++ sandbox/elemoine/draw-feature/tests/Handler/Point.html	2011-02-10 10:46:31 UTC (rev 11086)
@@ -142,7 +142,7 @@
     function test_callbacks(t) {
-        t.plan(25);
+        t.plan(23);
         var map = new OpenLayers.Map("map", {
             resolutions: [1]
@@ -181,14 +181,7 @@
         // mouse down
         handler.mousedown(
             {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
-        t.eq(logs.length, 1, "[mousedown] called back");
-        log = logs.shift();
-        t.eq(log.type, "modify", "[mousedown] modified called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75),
-                  "[mousedown] correct point");
-        t.geom_eq(log.args[1].geometry,
-                  new OpenLayers.Geometry.Point(-150, 75),
-                  "[mousedown] correct feature");
+        t.eq(logs.length, 0, "[mousedown] not called back");
         // mouse move
         handler.mousemove(
             {type: "mousemove", xy: new OpenLayers.Pixel(1, 0)});
@@ -203,17 +196,21 @@
         // mouse up (no finalize - we moved)
         handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(1, 0)});
         t.eq(logs.length, 0, "[mouseup] not called back");
-        // mouse down
-        handler.mousedown(
-            {type: "mousedown", xy: new OpenLayers.Pixel(2, 0)});
+        // mouse move
+        handler.mousemove(
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 0)});
+        t.eq(logs.length, 1, "[mousemove] called back");
         log = logs.shift();
+        t.eq(log.type, "modify", "[mousemove] modify called");
         t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-148, 75),
+                  "[mousemove] correct point");
+                  "[mousemove] correct feature");
+        // mouse down
+        handler.mousedown(
+            {type: "mousedown", xy: new OpenLayers.Pixel(2, 0)});
         // mouse up
         handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(2, 0)});
         t.eq(logs.length, 2, "[mouseup] called back twice");
More information about the Commits mailing list
